01 Fundamentals Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10001 Fundamentals Command Reference
08-ISSU commands
08-ISSU commands 197.23 KB
ISSU commands
display install active
Use display install active to display active software images.
display install active [ slot slot-number ] [ verbose ]
slot slot-number: Specifies an IRF member by its member ID. If you do not specify this option, the command is applied to all IRF members.
verbose: Displays detailed information. If you do not specify this keyword, the command displays only the names of the active software images.
# Display active software images.
<Sysname> display install active
Active packages on slot 1:
  flash:/boot.bin
  flash:/system.bin
# Display detailed information about active software images.
<Sysname> display install active verbose
flash:/boot.bin
 [Package]
 Vendor: H3C
 Product: xxxx
 Service name: boot
 Platform version: 7.1.022
 Product version: Test 2201
 Supported board: mpu
 [Component]
 Component: boot
 Description: boot package
flash:/system.bin
 [Package]
 Vendor: H3C
 Product: xxxx
 Service name: system
[Component]
 Component: system
 Description: system package
Active packages on slot n
Active software images on the specified member. The argument n indicates the member ID of the member.
[Package]
Detailed information about the software image.
Service name
Image type:
·     boot—Boot image.
·     system—System image.
·     boot-patch—Patch image for the boot image.
·     system-patch—Patch image for the system image.
·     Any other value indicates a feature image.
Supported board
Cards supported by the software image. The mpu string indicates a member device.
[Component]
Information about components included in the image file.
install active
display install backup
Use display install backup to display backup startup software images.
display install backup [ slot slot-number ] [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays only the names of the software images.
Backup startup images are used only when the main boot or system image is missing or corrupt. For more information, see Fundamental Configuration Guide.
To modify the backup startup image list, you must use the boot-loader file command.
# Display the backup startup software images.
<Sysname> display install backup
Backup startup software images on slot 1:
  flash:/boot-a0201.bin
  flash:/system-a0201.bin
# Display detailed information about backup startup software images.
<Sysname> display install backup verbose
 [Package]
 Vendor: H3C
 Product: xxxx
 Service name: boot
 Product version: Beta 1330
 [Component]
 Component: boot
 [Package]
 Vendor: H3C
 Product: xxxx
 [Component]
 Component: system
For command output descriptions, see Table 1.
·     boot-loader file
·     display install committed
Use display install committed to display main startup software images.
display install committed [ slot slot-number ] [ verbose ]
After you execute the install commit command, use the display install committed command to verify that the main startup image list has been updated with the software image change.
Both the install commit and boot-loader file commands modify the main startup software image list.
For more information about main and backup startup images, see Fundamental Configuration Guide.
# Display the main startup software images.
<Sysname> display install committed
Committed packages on slot 1:
flash:/system-patch.bin
# Display detailed information about main startup software images.
<Sysname> display install committed verbose
 [Package]
 Vendor: H3C
 Product: xxxx
 Service name: boot
 [Component]
 Component: boot
 [Package]
 Vendor: H3C
 Product: xxxx
 [Component]
 Component: system
·     boot-loader file
·     display install backup
·     install commit
display install inactive
Use display install inactive to display inactive software images.
display install inactive [ slot slot-number ] [ verbose ]
This command displays inactive images in the root directories of the storage media.
# Display brief information about inactive software images in the root directory of each storage medium.
<Sysname> display install inactive
Inactive packages on slot 1:
 flash:/ssh-feature.bin
# Display detailed information about inactive software images in the root directory of each storage medium.
<Sysname> display install inactive verbose
 [Package]
 Vendor: H3C
 Product: XXXX
 Service name: ssh
 [Component]
 Component: ssh
 Description: ssh package
For information about the command output, see Table 1.
install deactivate
display install ipe-info
Use display install ipe-info to display the software images included in an .ipe file.
display install ipe-info ipe-filename
ipe ipe-filename: Specifies the name of an .ipe file, a case-insensitive string of up to 63 characters. Use one of the following formats:
·     storage-medium:/base-filename.ipe on the master.
·     slotn#storage-medium:/base-filename.ipe on a subordinate member. For example, slot1#flash:/a.ipe.
An .ipe file contains one or more software images. You can use the software images for a software upgrade.
The specified file must be saved in the root directory of the storage medium.
# Display information about the .ipe file flash:/test.ipe.
<Sysname> display install ipe-info flash:/test.ipe
Verifying image file...Done.
Verifying the IPE file and the images.....Done.
Images in IPE:
  boot.bin
  system.bin
display install package
display install job
Use display install job to display ongoing ISSU activate, deactivate, and rollback operations.
display install job
# Display ongoing ISSU activate, deactivate, and rollback operations.
<Sysname> display install job
 JobID:5
  Action:install activate flash:/ssh-feature.bin on slot 1
The output shows that the device is executing the install activate flash:/ssh-feature.bin slot 1 command.
display install log
Use display install log to display ISSU log information.
display install log [ verbose ]
verbose: Displays detailed ISSU log information. If you do not specify this keyword, the command displays brief ISSU log information.
The device creates one log entry for each ISSU operation to track the process and operation result.
The ISSU log can contain a maximum of 50 entries. The latest entry overwrites the oldest entry if the log is full.
# Display all ISSU log entries.
<Sysname> display install log
Install job 1 started by user admin at 01/01/2011 04:53:40.
 Job 1 completed successfully at 01/01/2011 04:53:46.
 Install job 2 started by user admin at 01/01/2011 04:55:23.
 Job 2 completed successfully at 01/01/2011 04:55:29.
# Displays detailed information about ISSU log entry 1.
<Sysname> display install log 1 verbose
 Detail of activating packages on slot 1.
    Got upgrade policy successfully.
    Updated active package list successfully.
    Set startup software images successfully.
reset install log-history oldest
Use display install package to display software image file information.
display install package { filename | all } [ verbose ]
filename: Specifies the name of a software image file, a case-insensitive string of up to 63 characters. Use one of the following formats:
·     storage-medium:/base-filename.bin on the master.
·     slotn#storage-medium:/base-filename.bin on a subordinate member. For example, slot1#flash:/a.bin.
all: Specifies all software image files in the root directories of the master's storage media.
verbose: Displays detailed information. If you do not specify this keyword, the command displays only basic software image information.
# Display information about software image file system.bin.
<Sysname> display install package flash:/system.bin
  flash:/system.bin
  [Package]
  Vendor: H3C
  Product: xxxx
# Display detailed information about software image file system.bin.
<Sysname> display install package flash:/system.bin verbose
  flash:/system.bin
  [Package]
  Vendor: H3C
  Product: xxxx
  [Component]
  Component: system
For more information about the command output, see Table 1.
display install rollback
Use display install rollback to display rollback point information.
Use this command to identify available rollback points during an ISSU that uses install commands. The system does not record rollback points during an ISSU that uses issu commands.
# Display all rollback points.
<Sysname> display install rollback
Install rollback information 1 on slot 1:
    Updating from flash:/boot-a2403.bin
             to flash:/boot-a2404.bin.
    Updating from flash:/system-a2403.bin
             to flash:/system-a2404.bin.
The output shows that the device has one rollback point. At this rollback point, flash:/boot-a2403.bin and system-a2403.bin were upgraded to flash:/boot-a2404.bin and system-a2404, respectively.
·     install rollback
·     reset install rollback oldest
display install which
Use display install which to display all software image files that include a specific component or file.
display install which { component name | file filename } [ slot slot-number ]
component name: Specifies a component name.
file filename: Specifies a file name, a case-insensitive string of up to 63 characters. It cannot contain path information.
A component is a collection of features. The features of a component are installed or uninstalled at the same time.
When the system displays a component or file error, use this command to identify the relevant image files before you make a software upgrade decision.
This command searches only the root directory of the storage medium.
# Display all software image files that include file sshc.cli.
<Sysname> display install which file sshc.cli
File sshc.cli is in following packages on slot 1:
  flash:/system-1330.bin
  [Package]
  Vendor: xxx
  Product: xxxx
  Service name: ssh
display issu rollback-timer
Use display issu rollback-timer to display automatic rollback timer information.
Change to the automatic rollback interval does not take effect on the ongoing ISSU process. The current remaining rollback time might be greater than the configured automatic rollback interval.
# Display automatic rollback timer information after the issu run switchover command is executed.
<Sysname> display issu rollback-timer
Rollback timer: Working
Rollback interval: 45 minutes
Rollback time remaining : 40 minutes
# Display automatic rollback timer information after the issu accept command is executed.
Rollback timer: Not working
Rollback interval: 30 minutes
# Display automatic rollback timer information when no ISSU process is taking place.
issu rollback-timer
display issu state
Use display issu state to display ISSU status information.
display issu state
During an ISSU that uses issu commands, you can use this command to verify the ISSU status and determine what to do next.
This command does not apply to an ISSU that uses install commands, because the ISSU state machine is not involved.
# Display ISSU status information when no upgrade is taking place.
<Sysname> display issu state
ISSU state: Init
Compatibility: Unknown
Work state: Normal
Upgrade method: Card by card
Upgraded slot: None
Current upgrading slot: None
Current version list:
  boot: 7.1.041, Demo 2402
  system: 7.1.041, Demo 2402
Current software images:
  flash:/boot.bin
  flash:/system.bin
# Display ISSU status information while the issu load command is being executed.
ISSU state: Loading
Compatibility: Incompatible
Work state: Normal
Upgraded slot: None
  slot 1
Previous version list:
Previous software images:
  flash:/boot.bin
  flash:/system.bin
Upgrade version list:
  boot: 7.1.041, Demo 2403
  system: 7.1.041, Demo 2403
Upgrade software images:
  flash:/boot02.bin
  flash:/system04.bin
ISSU state
ISSU status:
·     Init—The ISSU process has not started or has finished.
·     Loading—The system is executing the issu load command.
·     Loaded—The issu load command is completed.
·     Switching—The system is executing the issu run switchover command.
·     Switchover—The issu run switchover command is completed.
·     Accepted—The issu accept command is completed.
·     Committing—The system is executing the issu commit command.
·     Rollbacking—A rollback is in process.
Compatibility
Version compatibility:
·     Compatible.
·     Incompatible.
·     Unknown—No upgrade is in process.
Work state
Operating state of the device:
·     Normal—The device is operating correctly.
·     Independent active—When you perform an ISSU for an incompatible version, the member devices that have been upgraded enter this state. In this state, the member devices of the IRF fabric are running different software versions.
Upgrade method
Upgrade mode. If this field displays Card by card, the upgrade is performed on a member-by-member basis.
Upgraded slot
Upgraded member device.
Member devices that are being upgraded.
Software versions running on the device before the ISSU.
Software images running on the device before the ISSU.
Software versions to upgrade to.
Software images used for the upgrade.
·     issu accept
·     issu commit
·     issu load
·     issu rollback
·     issu run switchover
display version comp-matrix
Use display version comp-matrix to display version compatibility information.
display version comp-matrix file { boot filename | system filename | feature filename&<1-30> } *
display version comp-matrix file ipe ipe-filename
boot: Specifies a boot image file.
system: Specifies a system image file.
feature: Specifies feature image files. You can specify a space-separated list of up to 30 feature image files.
filename: Specifies the name of a software image file on the master, in the format storage-medium:/base-filename.bin. It can be a case-insensitive string of up to 63 characters and cannot contain slot information.
ipe ipe-filename: Specifies the name of an .ipe file on the master, in the format storage-medium:/base-filename.ipe. It can be a case-insensitive string of up to 63 characters and cannot contain slot information.
The specified image files must be saved in the root directory of the storage medium.
If you do not specify any image files, the command displays compatibility information for the running software images.
If you specify file names, the command displays compatibility information for the specified images and the recommended ISSU methods for upgrade the running images to the specified images.
# Display compatibility information for the running software images.
<Sysname> display version comp-matrix
Boot image: flash:/boot-r2208p01.bin
  Version:
  7.1.035P05
System image: flash:/system-r2208p01.bin
  Version:
  R2208P01
  Version compatibility list:
  E2206P02
  R2207
  R2208
  R2208P01
  Version dependency boot list:
  7.1.035P02
  7.1.035P03
  7.1.035P04
  7.1.035P05
# Display compatibility information for flash:/boot-a2403.bin and flash:/system-a2403.bin, and the recommended ISSU method. (In this example, the specified versions are incompatible with the running versions.)
<Sysname> display version comp-matrix file boot flash:/boot-a2403.bin system flash:/system-a2403.bin
Boot image: flash:/boot-a2403.bin
  Version:
  7.1.046
System image: flash:/system-a2403.bin
  Version:
  A2403
  A2403
  7.1.046
Incompatible upgrade.
# Display compatibility information for flash:/boot-f2209.bin and flash:/system-f2209.bin, and the recommended ISSU method. (In this example, the specified versions are compatible with the running versions.)
<Sysname> display version comp-matrix file boot flash:/boot-f2209.bin system flash:/system-f2209.bin
Boot image: flash:/boot-f2209.bin
  Version:
  7.1.035P08
System image: flash:/system-f2209.bin
  Version:
  F2209
  E2206P02
  R2207
  R2208
  R2208P01
  F2209
  7.1.035P02
  7.1.035P03
  7.1.035P04
  7.1.035P05
  7.1.035P07
  7.1.035P08
  Slot                        Upgrade Way
  1                           Reboot
  2                           Reboot
·     Under a system image, this field shows all system image versions that are compatible with the system image.
·     Under a feature image, this field shows all feature image versions that are compatible with the feature image.
Boot image versions that support the system image. To install the system image, you must install one of the boot image versions that is in the list.
Version dependency system list
System image versions that support the feature image. To install the feature image, you must install one of the system image versions that is in the list.
Influenced service according to following table
Services that will be affected by the upgrade.
This field is displayed only for compatible versions.
You are upgrading the software to an incompatible version.
Slot
Member ID of the device in the IRF fabric. This field is displayed only for compatible versions.
Upgrade Way
ISSU method to be used for a compatible version:
·     Service Upgrade—Service-level incremental upgrade.
·     File Upgrade—File-level incremental upgrade.
·     Reboot—Reboots the entire device to complete the upgrade.
For more information about ISSU methods, see Fundamentals Configuration Guide.
issu load
install abort
Use install abort to abort an ISSU operation.
install abort
The system creates a software image management job each time you use the install activate, install add, install commit, install deactivate, install remove, or install rollback to command. Each job represents one command and is assigned a unique job ID. You can abort only ongoing activate and deactivate operations.
To obtain the ID of a job, use the display install job command.
# Abort a software image operation.
<Sysname> install abort
display install job
install activate
Use install activate to activate software images, or identify the ISSU method and the possible impact on the device.
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number [ test ]
install activate patch filename { all | slot slot-number }
all: Specifies all IRF members.
boot: Specifies a boot image file. For more information about software images, see Fundamental Configuration Guide.
patch: Specifies a patch image file.
test: Only checks for the ISSU method to be used for the upgrade. If you do not specify this keyword, the command activates the specified software images.
The specified files must be saved in the root directory of the storage medium.
Before you use this command to activate a software image, read the release notes to identify the licensing requirement for the image. If the image requires a license, make sure the device has a valid license installed for the image.
An image runs in memory immediately after it is activated. For an activated image to run after a reboot, you must commit the software change by using the install commit command.
If you specify a subordinate member for the command, the command copies the images to the subordinate member automatically.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install activate command on the subordinate device. To check the synchronization progress, use the display device command. The synchronization is completed when all member devices are in normal state.
# Identify the ISSU method for feature upgrade with ssh2.bin on subordinate member 2 and the upgrade impact on the device.
<Sysname> install activate feature flash:/ssh2.bin slot 2 test
Copying file flash:/ssh2.bin to slot2#flash:/ssh2.bin......Done.
flash:/ssh2.bin
  Running Version             New Version
  Beta 1330                   Beta 1331
  Slot                        Upgrade Way
  2                           Service Upgrade
Influenced service according to following table:
flash:/ssh2.bin
     SSH       IFMGR     CFA       LAGG
The output shows that a service upgrade is recommended. The SSH, IFMGR, CFA, and LAGG modules will be rebooted during the upgrade.
# Activate the patch image system-patch.bin on member device 1.
<Sysname> install activate system-patch.bin slot 1
# Activate the system image in file system.bin and feature images in file feature.bin on member device 2.
<Sysname> install activate system flash:/system.bin feature flash:/feature.bin slot 2
Copying file flash:/system.bin to slot2#flash:/system.bin......Done.
Copying file flash:/feature.bin to slot2#flash:/feature.bin......Done.
flash:/system.bin
  Beta 1330                   Beta 1331
flash:/feature.bin
  None                        Beta 1330
  Slot                        Upgrade Way
  2                           Service Upgrade
This operation maybe take several minutes, please wait.......................................................................Done.
Upgrade summary.
Running Version
Version number of the running software.
New Version
Version number of the new software.
Slot
Upgrade Way
ISSU methods:
·     File Upgrade—File-level incremental upgrade. The upgrade involves only hidden program files and does not affect the operation of the system or services.
This field is displayed only for an upgrade to a compatible version.
Services influenced by the upgrade.
·     display install active
·     install commit
·     install deactivate
install add
Use install add to decompress an .ipe file.
install add ipe-filename medium-name:
medium-name: Specifies the name of the storage medium for saving the software images. If the storage medium is on a subordinate member, use the slotn#storage-medium format, for example, slot1#flash.
The .ipe file must be saved in the root directory of the storage medium.
To use install commands for upgrade, you must use .bin image files. If the upgrade file is an .ipe file, use this command to decompress the .ipe file before you start the upgrade.
The images decompressed from the .ipe file will be saved to the root directory of the specified medium.
To identify software images that are included in an .ipe file, use the display install ipe-info command.
# Decompress all.ipe to the flash memory.
<Sysname> install add flash:/all.ipe flash:
Verifying image file..........................Done.
Decompressing file boot.bin to flash:/boot.bin.......................Done.
Decompressing file system.bin to lash:/system.bin.................................Done.
install commit
Use install commit to commit software changes.
install commit
Before you use this command, read the release notes to determine whether the images require licenses. Make sure the device has valid licenses for all license-based images.
This command revises the main startup software image list to be the same as the committed image list. Software changes take effect at the next startup.
You must execute this command after using the following commands:
·     The install activate command in an incremental upgrade.
·     The install deactivate command.
·     The install rollback command.
In a reboot upgrade, the install activate command revises both the current and startup software image lists. You do not need to commit software changes.
Both the install commit and boot-loader file commands change main startup software images. To change backup startup images or add inactive images as main startup images, however, you must use the boot-loader file command.
For more information about main and backup startup software images, see Fundamental Configuration Guide.
# Commit software changes.
<Sysname> install commit
·     install activate
·     install rollback
install deactivate
Use install deactivate to deactivate feature or patch images.
install deactivate feature filename&<1-30> slot slot-number
install deactivate patch filename { all |slot slot-number }
You can deactivate only active feature and patch images.
To prevent deactivated images from running after a reboot, you must confirm the software changes by using the install commit command.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install deactivate command on the subordinate device. To check the synchronization progress, use the display device command. The synchronization is completed when all member device are in normal state.
# Deactivate the patch images in file route-patch.bin on IRF member 1.
<Sysname> install deactivate patch flash:/route-patch.bin slot 1
·     display install inactive
install remove
Use install remove to remove inactive software images.
install remove [ slot slot-number ] { filename | inactive }
inactive: Removes all inactive software image files in the root directories of the specified storage media.
This command deletes only inactive software image files saved in the root directories of the specified storage media.
Removing a software image deletes the image file from the device permanently. You cannot use the install rollback to command to revert the operation, or use the install abort command to abort the operation.
# Remove inactive software image file flash:/ssh-feature.bin.
<Sysname> install remove flash:/ssh-feature.bin
# Remove inactive patch package flash:/ssh-patch.bin.
<Sysname> install remove flash:/ssh-patch.bin
install rollback to
Use install rollback to to roll back the software to an earlier rollback point.
install rollback to { point-id | original }
point-id: Specifies a rollback point ID. This option is supported only when there are two or more rollback points. To view available rollback points, use the display install rollback command.
original: Rolls back to the software images that were running before the ISSU.
The system creates a rollback point for each service or file upgrade performed through activate or deactivate operation. The rollback points are retained until any of the following events occur:
·     A reboot upgrade is performed.
·     The install commit command is executed.
After a reboot upgrade is performed, you can roll back the running software images only to the status before any activate or deactivate operations were performed.
After a commit operation is performed, you cannot perform a rollback.
For a rollback to take effect after a reboot, you must perform a commit operation to update the main startup software image list.
A maximum of 50 rollback points are available for service and file upgrades. The earliest rollback point is removed if this limit has been reached when a rollback point is created.
Patch images do not support rollback.
# Roll back the software to rollback point 1.
<Sysname>install rollback to 1
# Roll back the software to the original software versions and observe the change made by the rollback.
   flash:/ssh-feature-a0201.bin
  Update from no package
         to flash:/ssh-feature-a0201.bin.
The output shows that currently three images are active but only two of them are confirmed. Image flash:/ssh-feature-a0201.bin is not confirmed yet.
<Sysname> install rollback to original
The output shows the SSH feature has been rolled back to the original version. Image flash:/ssh-feature-a0201.bin has been removed.
install verify
Use install verify to verify the software change confirmation status and software image integrity and consistency.
install verify
If some software images are not integral or some activated/deactivated software images are not confirmed, a switchover might not occur as expected, and the IRF members might run different versions of software images after a reboot or even cannot reboot correctly.
To solve the problem, perform one of the following tasks:
·     Download and install the software images again to ensure software integrity.
·     Use the install activate, install deactivate, and install commit commands as appropriate to guarantee software image consistency.
# Verify the software change confirmation status and software image integrity and consistency on member devices.
<Sysname> install verify
Active packages on slot 1 are the reference packages.
Packages will be compared with the reference packages.
This operation will take several minutes, please wait...
  Verifying packages on slot 1:
  Start to check active package completeness.
    flash:/boot-a0101.bin verification successful.
    flash:/system-a0101.bin verification successful.
  Start to check active package consistency.
    Active packages are consistent with committed packages on their own board.
    Active packages are consistent with the reference packages.
  Verifying packages on slot 2:
Verification is done.
issu accept
Use issu accept to accept the upgrade to a compatible version and delete the automatic rollback timer.
issu accept
The system cannot perform automatic rollback for the ISSU process after you execute this command. However, you can still use the issu rollback command to perform a manual rollback.
You can execute the issu commit command to finish the ISSU process without executing this command.
The issu accept command does not apply to the ISSU to an incompatible version. The system will display an error message if you execute this command during this type of ISSU.
# Accept the upgrade to a compatible version.
<Sysname> issu accept
·     issu load
issu commit
Use issu commit to upgrade subordinate members (including the original master) during an ISSU to a compatible version.
issu commit slot slot-number
slot slot-number: Specifies the member ID of the original master or a subordinate member that has not been upgraded.
For a multichassis IRF fabric, use this command to upgrade subordinate members one by one. You must wait for the upgraded subordinate member to start up again and join the IRF fabric before upgrading another subordinate member. After all members are upgraded, the ISSU status changes to Init, and the ISSU process ends and cannot be rolled back.
For an IRF fabric with a single member, this command ends the ISSU process. When this command is completed, the ISSU status changes to Init, and the ISSU process cannot be rolled back.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the issu commit command on the subordinate device. To check the synchronization progress, use the display device command. The synchronization is completed when all member device are in normal state.
# After member 2 is upgraded and becomes the new master, upgrade the original master (member 3) and the other subordinate members that have not been upgraded (member 4 and member 1).
<Sysname> issu commit slot 3
flash:/feature.bin
  Alpha 7122                  Alpha 7123
  Slot                        Upgrade Way
  3                           Service Upgrade
Upgrading software images to compatible versions. Continue? [Y/N]: y
<Sysname> issu commit slot 4
Copying file flash:/feature.bin to slot4#flash:/feature.bin...Done.
flash:/feature.bin
  Slot                        Upgrade Way
  4                           Service Upgrade
<Sysname> issu commit slot 1
Copying file flash:/feature.bin to slot1#flash:/feature.bin...Done.
flash:/feature.bin
  Slot                        Upgrade Way
  1                           Service Upgrade
For field descriptions, see Table 3.
·     issu accept
·     issu load
issu load
Use issu load to upgrade the software images of subordinate members and configure the upgrade images as the main startup software images for the subordinate members.
issu load file { boot filename | system filename | feature filename&<1-30> } * slot slot-number&<1-9>
issu load file ipe ipe-filename slot slot-number&<1-9>
filename: Specifies the name of a software image file in the root directory of the master's flash memory, in the format flash:/xxx.bin. It can be a case-insensitive string of up to 63 characters and cannot contain slot information.
slot slot-number: Specifies the member ID of a subordinate member. For a compatible upgrade, you can specify only one member ID. For an incompatible upgrade, you can specify a space-separated list of up to three member IDs. If the IRF fabric has only one member, enter the member ID of this member to upgrade the entire fabric.
On a single-chassis IRF fabric, specify the member ID of the member for this command.
On a multichassis IRF fabric, specify one or more subordinate members for this command. If the member devices of the IRF fabric are connected into a ring topology, H3C recommends that you specify half of the subordinate members for this command to reduce service interruption. Make sure the specified subordinate members are physically connected.
This command performs the following tasks:
·     Examines the compatibility of the specified images with the running images. The result might be compatible or incompatible.
·     Determines the ISSU methods.
The ISSU methods available for a compatible version include:
¡     Incremental upgrade. During the upgrade, the involved processes will be upgrade.
¡     Reboot. During the upgrade, the specified member devices will be rebooted.
The ISSU method for an incompatible version is always reboot.
·     Uses the ISSU methods to upgrade the specified member devices, and configures the upgrade software images as the main startup software images for the specified member devices.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the issu load command on the subordinate device. To check the synchronization progress, use the display device command. The synchronization is completed when all member device are in normal state.
# Upgrade member device 2 (subordinate member) with the feature image file flash:/feature.bin. (In this example, the image is compatible with the running images.)
<Sysname> issu load file feature flash:/feature.bin slot 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:Y
flash:/feature.bin
  Slot                        Upgrade Way
  2                           Service Upgrade
# Upgrade member device 3 and 4 (subordinate members) with the feature image file flash:/feature.bin. (In this example, the image is incompatible with the running images.)
<Sysname> issu load file feature flash:/feature.bin slot 3 4
Copying file flash:/feature.bin to slot3#flash:/feature.bin......Done.
Copying file flash:/feature.bin to slot4#flash:/feature.bin......Done.
flash:/feature.bin
  Slot                        Upgrade Way
  3                           Reboot
  4                           Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
Table 5 Command output
Slot
Upgrade Way
ISSU method:
issu rollback
Use issu rollback to cancel the ISSU and roll back to the original software versions.
issu rollback
The device supports automatic rollback and manual rollback. This command performs a manual rollback.
You can perform a manual rollback while an ISSU is in one of the following states:
·     Loaded.
·     Switching (during an upgrade to a compatible version).
·     Switchover (during an upgrade to a compatible version).
·     Accepted.
If you perform a manual rollback while an ISSU is in Loading state, the ISSU process ends without changing the original software versions.
When an ISSU to an incompatible version is in Switching state, you cannot perform a manual rollback.
When an ISSU is in Committing state, rollback is not supported.
If the IRF fabric has multiple members, a rollback performed after you execute the issu run switchover command cancels all operations performed during the ISSU process, including the master/subordinate switchover operation.
# Roll back to the original software versions.
<Sysname> issu rollback
This command will quit the ISSU process and roll back to the previous version. Continue? [Y/N]:y
·     issu accept
·     issu commit
·     issu load
issu rollback-timer
Use issu rollback-timer to set the automatic rollback timer.
Use undo issu rollback-timer to restore the default.
issu rollback-timer minutes
The automatic rollback interval is 45 minutes.
minutes: Specifies the automatic rollback interval in minutes, in the range of 0 to 120. Setting it to 0 disables the automatic rollback function.
The automatic software version rollback function is only available on a multichassis IRF fabric during an ISSU to a compatible version.
The system starts the automatic rollback timer when you execute the issu run switchover command in a scenario where automatic rollback is supported. If you do not execute the issu accept or issu commit command before the timer expires, the system automatically rolls back to the software versions before the ISSU.
# Set the automatic rollback timer to 50 minutes.
[Sysname] issu rollback-timer 50
issu rollback
issu run switchover
Use issu run switchover to perform a master/subordinate switchover. If the new and old versions are incompatible, this command also upgrades all members that have not been upgraded.
issu run switchover
Use this command on multichassis IRF fabrics.
·     For a compatible version, this command performs tasks depending on the ISSU method:
¡     Incremental upgrade—Performs a process-level master/subordinate switchover for the processes to be upgraded.
¡     Reboot upgrade or ISSU upgrade—Reboots the current master with the old software version, causing the upgraded subordinate member to be elected as the new master.
·     For an incompatible version, the issu load command splits the IRF fabric into two fabrics, with the upgraded members forming a new fabric. The issu run switchover command reboots the members in the old IRF fabric with the upgrade images. After startup, the members join the new IRF fabric as subordinate members.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the issu run switchover command on the subordinate device. To check the synchronization progress, use the display device command. The synchronization is completed when all member device are in normal state.
# On a multichassis IRF fabric, perform a master/subordinate switchover during an ISSU to a compatible version.
<Sysname> issu run switchover
flash:/feature.bin
  Slot                        Switchover Way
  1                           Active standby process switchover
# On a multichassis IRF fabric, perform a master/subordinate switchover and upgrade members that have not been upgraded (member 1 and member 2) during an ISSU to an incompatible version.
Copying file flash:/feature.bin to slot2#flash:/feature.bin...Done.
flash:/feature.bin
  Slot                        Upgrade Way
  1                           Reboot
  2                           Reboot
Table 6 Command output
Switchover Way
Switchover method:
·     Active standby process switchover—Switch from the active process to the standby process.
·     Master subordinate switchover—Switch from the master to a subordinate member.
For descriptions of other fields, see Table 3.
issu load
Use reset install log-history oldest to clear ISSU log entries.
reset install log-history oldest log-number
log-number: Specifies the number of ISSU log entries to be deleted.
This command clears the specified number of log entries, beginning with the oldest log entry.
# Clear the two oldest ISSU log entries.
<Sysname> reset install log-history oldest 2
display install log
Use reset install rollback oldest to clear ISSU rollback points.
reset install rollback oldest point-id
point-id: Specifies a rollback point by its ID.
This command clears the specified rollback point and all rollback points older than the specified rollback point.
# Clear rollback point 2 and all rollback points older than rollback point 2.
<Sysname> reset install rollback oldest 2
