07-IP Multicast Configuration Guide
HomeSupportRoutersSR8800 SeriesConfigure & DeployConfiguration GuidesH3C SR8800 Configuration Guide-Release3347-6W10307-IP Multicast Configuration Guide
10-Multicast VPN Configuration
10-Multicast VPN Configuration 621.3 KB
Multicast VPN overview
·       For more information about MPLS L3VPN, see MPLS Configuration Guide.
·       For more information about BGP, see Layer 3—IP Routing Configuration Guide.
Multicast VPN is a technique that implements multicast delivery in virtual private networks (VPNs).
Figure 1 Typical VPN networking diagram
A VPN is comprised of multiple sites and the public network provided by the network provider. The sites communicate through the public network. As shown in Figure 1, VPN A comprises Site 1, Site 3 and Site 5, and VPN B comprises Site 2, Site 4 and Site 6. A VPN involves the following types of devices:
·           Provider (P) deviceCore device on the public network. A P device does not directly connect to CE devices.
·           Provider edge (PE) device—Edge device on the public network. A PE device directly connects to one or more customer edge (CE) devices, and processes VPN routing.
·           CE device—Edge device on a customer network. A CE device can be a router, a switch, or a host, that implements route distribution on the customer network.
As shown in Figure 2, the network that runs multicast VPN carries independent multicast services for the public network, VPN A, and VPN B. A PE multicast device at the edge of the public network supports multiple VPN instances, and operates as multiple independent multicast devices. Each VPN forms a plane, and all these planes are isolated from one another. For example, in Figure 1, PE1 supports the public network, VPN A, and VPN B. You can regard these instances as independent virtual devices, which are PE 1’, PE 1”, and PE 1’”. Each virtual device works on a plane as shown in Figure 2.
Figure 2 Multicast in multiple VPN instances
With multicast VPN, when a multicast source in VPN A sends a multicast stream to a multicast group, of all possible receivers on the network for that group, only those that belong to VPN A, namely, in Site 1, Site 3 or Site 5, can receive the multicast stream. The stream is multicast in these sites and on the public network.
The prerequisites for implementing multicast VPN are as follows:
1.      Within each site, multicast for a single VPN is supported.
2.      In the public network, multicast for the public network is supported.
3.      The PE devices support multiple VPN instances as follows:
¡  The PE devices connect with different sites through VPNs and support multicast for each single VPN.
¡  The PE devices connect with the public network and support multicast for the public network.
¡  The PE devices support information exchange and data conversion between the public network and VPNs.
The device implements multicast VPN by means of the multicast domain (MD) method. This multicast VPN implementation is referred to as MD-VPN.
The most significant advantage of MD-VPN is that it requires only the PE devices to support multiple VPN instances. Multicast VPN can be implemented without the need of upgrading any CE devices or P devices, and without the need of changing the original PIM configuration of the CE devices or the P devices. In other words, the MD-VPN solution is transparent to the CE devices and the P devices.
MD-VPN overview
For more information about the concepts of Protocol Independent Multicast (PIM), bootstrap router (BSR), candidate-BSR (C-BSR), rendezvous point (RP), designated forwarder (DF), candidate-RP (C-RP), shortest path tree (SPT) and rendezvous point tree (RPT), see the chapter “Configuring PIM.”
Basic concepts in MD-VPN
The basic concepts involved in MD-VPN are described in Table 1.
Table 1 Basic concepts in MD-VPN
Concept
Multicast domain (MD)
An MD is a set of VPN instances running on PE devices that can send multicast traffic to each other. Each MD uniquely corresponds to the same set of VPN instances.
Multicast distribution tree (MDT)
An MDT is a multicast distribution tree between all PE devices in the same VPN. There are two kinds of MDTs: share-MDT and switch-MDT.
Multicast tunnel (MT)
An MT is a tunnel that interconnects all PEs in an MD for delivering VPN traffic within the MD.
Multicast tunnel interface (MTI)
An MTI is the entrance to or exit of an MT, equivalent to an entrance to or exit of an MD. PE devices use the MTI to access the MD. An MTI handles only multicast packets but not unicast packets. An MTI is automatically created with the configuration of a share-group and MTI binding for a VPN instance.
Share-group
In the public network, each MD is assigned an independent multicast address, called share-group. A share-group is the unique identifier of an MD on the public network. It is used to build a share-MDT corresponding to the MD on the public network.
Share-multicast distribution tree (Share-MDT)
A share-MDT is an MDT that uses a share-group as its group address. In a VPN, the share-MDT is uniquely identified by the share-group. A share-MDT is automatically created after configuration and will always exist on the public network, regardless of the presence of any actual multicast services on the public network or the VPN.
Switch-multicast distribution tree (Switch-MDT)
A switch-MDT is an MDT that uses a switch-group as it group address. At MDT switchover, PE devices with receivers downstream join a switch-group, forming a switch-MDT, along which the ingress PE forwards the encapsulated VPN multicast traffic over the public network.
Switch-group
When the multicast traffic of a VPN reaches or exceeds a threshold, the ingress PE device assigns it an independent multicast address called switch-group, and notifies the other PE devices that they should use that address to forward the multicast traffic for that VPN. This initiates a switchover to the switch-MDT.
Switch-group-pool
The switch-group-pool is a range of multicast addresses. At MDT switchover, an address (namely, switch-group address) is chosen from the switch-group-pool. The multicast packets for the VPN that enter the public network at the PE device are to be encapsulated using that address. The switch-group-pool of a VPN must not overlap that of another VPN, and must not contain the share-group of another VPN.
Introduction to MD-VPN
Main points in the implementation of MD-VPN are as follows:
1.      The public network of the service provider supports multicast. The PE devices need to support the public instance and multiple VPN instances, each instance running PIM independently. Private network multicast traffic between the PE devices and the CE devices is transmitted on a per-VPN-instance basis, while the public network multicast traffic between the PE devices and the P devices is transmitted through the public instance.
2.      Logically, an MD defines the transmission range of the multicast traffic of a specific VPN over the public network; physically, an MD identifies all the PE devices that support that VPN on the public network. Different VPN instances correspond to different MDs. As shown in Figure 3, the ellipse area in the center of each VPN instance plane represents an MD, which serves that particular VPN. All the private network multicast traffic in that VPN is transmitted within that MD.
3.      Inside an MD, all the private traffic is transmitted through the MT. The process of multicast traffic transmission through an MT is as follows: the local PE device encapsulates the private network data into a public network packet, which is then forwarded on the public network, and the remote PE device decapsulates the packet to turn it back into a private packet.
4.      The local PE device sends out private network data through the MTI, and the remote PE devices receive the private data through the MTI. As shown in Figure 3, an MD can be thought of as a private data transmission pool, and an MTI can be thought of an entrance/exit of the pool. The local PE device puts the private data into the transmission pool (the MD) through the entrance (MTI), and the transmission pool automatically duplicates the private data and transmits the data to each exit (MTI) of the transmission pool, so that any remote PE device that needs the data can get it from the respective exit (MTI).
Figure 3 Relationship between PIM on the public network and a MD in a VPN instance
5.      Each VPN instance is assigned a unique share-group address. The private network data is transparent to the public network. A PE device encapsulates any private network multicast packet within a normal public network multicast packet, no matter what multicast group the private network packet is destined for and whether it is a protocol packet or a data packet, and uses the share-group as the public network multicast group for the packet. Then, the PE sends the public network multicast packet onto the public network.
6.      A share-group corresponds to a unique MD; for each share-group, a unique share-MDT is constructed by leveraging the public network resources for multicast data forwarding. All the private network multicast packets transmitted in this VPN are forwarded along this share-MDT, no matter at which PE device they entered the public network.
7.      A share-group is assigned a unique switch-group-pool for MDT switching. When the rate of a private network multicast stream that entered the public network at a PE device exceeds the switching threshold, the PE chooses an idle address (namely, switch-group) from the switch-group-pool, and encapsulates the multicast packets for that VPN sing that address.
8.      All the ingress PE devices in the network monitor the forwarding rate on the share-MDT. When the multicast traffic meets the switchover conditions, the PE device initiates a switchover message to the downstream along the share-MDT, so that a switch-MDT is built using the switch-group between that PE device and the remote PE devices with receivers downstream. Then, after a switch-delay period has passed, an MDT switching takes place: all private network multicast packets that have entered the public network at that PE device are encapsulated into public network multicast packets using the switch-group, instead of using the share-group, so that they are switched from the share-MDT to the switch-MDT.
·       A VPN uniquely corresponds to an MD and an MD serves only one VPN, which is called a one-to-one relationship. Such a relationship exists between VPN, MD, MTI, share-group, and switch-group-pool.
·       For more information about switch-MDT, see “MDT switchover.”
PIM neighboring relationships MD-VPN
Figure 4 PIM neighboring relationships MD-VPN
PIM neighboring relationships are established between two or more directly interconnected devices on the same subnet. As shown in Figure 4, there are three types of PIM neighboring relationships in MD-VPN, as follows:
·           PE-P neighboring relationship—PIM neighboring relationship established between the public instance interface on a PE device and an interface on the P device across the link.
·           PE-PE neighboring relationship—PIM neighboring relationship established after a VPN instance on a PE device receives a PIM hello from a VPN instance on a remote PE device through an MTI.
·           PE-CE neighboring relationship—PIM neighboring relationship established between a VPN-instance-associated interface on a PE device and an interface on a peer CE device.
Protocols and standards
·           RFC 4684: Constrained Route Distribution for Border Gateway Protocol/MultiProtocol Label Switching (BGP/MPLS) Internet Protocol (IP) Virtual Private Networks (VPNs)
·           draft-rosen-vpn-mcast-08: Multicast in MPLS/BGP IP VPNs
How MD-VPN works
This section describes the implementation principle of the MD-VPN technology, including establishment of a share-MDT, packet delivery over it, and implementation of multi-AS MD-VPN.
For a VPN instance, multicast data transmission on the public network is transparent. The MTIs at the local PE device and the remote PE device form a channel for the seamless transmission of VPN data over the public network. All that is known to the VPN instance is that the VPN data is sent out the MTI and then the remote site can receive the data through the MTI. Actually, the multicast data transmission process (the MDT transmission process) over the public network is very complicated.
Share-MDT establishment
The multicast routing protocol running on the public network can be PIM-DM, PIM-SM, BIDIR-PIM, or PIM-SSM. The process of creating a share-MDT is different in these three PIM modes.
Share-MDT establishment in a PIM-DM network
Figure 5 Share-MDT establishment in a PIM-DM network
As shown in Figure 5, PIM-DM is enabled in the network and all the PE devices support VPN instance A. The process of establishing a share-MDT is as follows:
The public instance on PE 1 initiates a flood-prune process in the entire public network, with the BGP interface address (namely the interface address used to establish the BGP peer) as the multicast source address and the share-group address as the multicast group address. All the other PE devices that are running VPN instance A are group members, so that a (11.1.1.1, 239.1.1.1) state entry is created on each device along the path on the public network. This forms an SPT with PE 1 as the root, and PE 2 and PE 3 as leaves.
At the same time, PE 2 and PE 3 respectively initiate a similar flood-prune process. Finally, three independent SPTs are established in the MD. In the PIM-DM network, these independent SPTs constitute a share-MDT.
Share-MDT establishment in a PIM-SM network
Figure 6 Share-MDT establishment in a PIM-SM network
As shown in Figure 6, PIM-SM is enabled in the network and all the PE devices support VPN instance A. The process of establishing a share-MDT is as follows:
1.      The public instance on PE 1 initiates a join to the public network RP, with the share-group address as the multicast group address in the join message, and a (*, 239.1.1.1) state entry is created on each device along the path on the public network. At the same time, PE 2 and PE 3 respectively initiate a similar join process. Finally, an RPT is established in the MD, with the public network RP as the root and PE 1, PE 2 and PE 3 as leaves.
2.      The public instance on PE 1 registers the multicast source with the public network RP and the public network RP initiates a join to PE 1. With the BGP interface address as the multicast source address and the share-group address as the multicast group address, a (11.1.1.1, 239.1.1.1) state entry is created on each device along the path on the public network. At the same time, PE 2 and PE 3 respectively initiate a similar register process. Finally, three SPTs between the PE devices and the RP are established in the MD.
In the PIM-SM network, the RPT, namely the (*, 239.1.1.1) tree, and the three independent SPTs constitute a share-MDT.
Share-MDT establishment in a BIDIR-PIM network
Figure 7 Share-MDT establishment in a BIDIR-PIM network
As shown in Figure 7, BIDIR-PIM is enabled in the network and all the PE devices support VPN instance A. The process of establishing a share-MDT is as follows:
1.      The public network on PE 1 initiates a join to the public network RP, with the share-group address as the multicast group address in the join message, and a (*, 239.1.1.1) entry is created on each device along the path on the public network. At the same time, PE 2 and PE 3 respectively initiate a similar join process. Finally, the receiver-side RPT is established in the MD, with the public network RP as the root and PE 1, PE 2 and PE 3 as leaves.
2.      The public network on PE 1 sends multicast data, with the share-group address as the destination multicast group address. The DF on each subnet that the multicast data travels through on the public network unconditionally forwards the data to the RP, and a (*, 239.1.1.1) entry is created on each device along the path. At the same time, PE 2 and PE 3 respectively initiate a similar process. Finally, the source-side RPT is established in the MD, with PE 1, PE 2, and PE 3 as the roots and the public network RP as the leave.
In the BIDIR-PIM network, the receiver-side RPT and the source-side RPT constitute a bi-directional RPT, namely, the (*, 239.1.1.1) tree, which is a share-MDT.
Share-MDT establishment in a PIM-SSM network
Figure 8 Share-MDT establishment in a PIM-SSM network
As shown in Figure 8, PIM-SSM is enabled in the network and all the PE devices support VPN instance A. The process of establishing a share-MDT is as follows:
The public instance on PE 1 sends the local BGP MDT routing information, including its BGP interface address and the share-group address, to PE 2 and PE 3. PE 2 and PE 3 perform the same operation to exchange their BGP MDT routing information with one another. Upon receiving the BGP MDT information from PE1, PE 2 and PE 3 respectively send a subscribe message for channel subscription hop by hop toward the BGP interface of PE1. A (11.1.1.1, 232.1.1.1) entry is created on devices on the path toward PE 1 on the public network. Thus an SPT is created in the network, with PE 1 as its root, PE 2 and PE 3 as its leaves.
At the same time, PE 2 and PE 3 respectively initiate a similar SPT establishment process. Finally, three independent SPTs are established in the MD. In the PIM-SS M network, the three independent SPTs constitute a share-MDT.
In PIM-SSM, subscribe messages are used equivalent to join messages.
Characteristics of a share-MDT
As discussed above, a share-MDT is characterized as follows, no matter what PIM mode is running on the public network:
·           All PE devices that support this VPN instance join the share-MDT.
·           All VPN multicast packets that belong to this VPN, including protocol packets and data packets, are forwarded along the share-MDT to every PE device on the public network, even if they have no active receivers downstream.
Share-MDT-based delivery
A share-MDT can be used for delivering multicast packets, including both multicast protocol packets and multicast data packets. However, the transmission processes for these two types of multicast packets are different.
Delivery of multicast protocol packets
To forward the multicast protocol packets of a VPN over the public network, the local PE device encapsulates them into public-network multicast data packets. These packets are transmitted along the share-MDT, and then decapsulated on the remote PE device to go into the normal protocol procedure. Finally a distribution tree is established across the public network. The following describes how multicast protocol packets are forwarded in two circumstances:
1.      If the VPN network runs PIM-DM or PIM-SSM:
¡  Hello packets are forwarded among MTI interfaces to establish PIM neighboring relationships.
¡  A flood-prune process (in PIM-DM) or a join process (in PIM-SSM) is initiated across the public network to establish an SPT across the public network.
2.      If the VPN network runs PIM-SM:
¡  If the receivers and the VPN RP are in different sites, a join process is initiated across the public network to establish an RPT.
¡  If the multicast source and the VPN RP are in different sites, a registration process is initiated across the public network to establish an SPT.
3.      If the VPN network runs BIDIR-PIM:
¡  If the receivers and the VPN RP are in different sites, a join process is initiated across the public network to establish the receiver-side RPT.
¡  If the multicast source and the VPN RP are in different sites, multicast data is transmitted across the public network to establish the source-side RPT.
·       All interfaces that belong to the same VPN, including those interfaces with VPN instance bindings and the MTI on PE devices, must run the same PIM mode.
·       The following example explains how multicast protocol packets are delivered based on the share-MDT while PIM-SM is running in both the public network and the VPNs network and the receivers and the VPN RP are in different sites.
As shown in Figure 9, PIM-SM is running in both the public network and the VPNs network, Receiver for the VPN multicast group G (225.1.1.1) in Site 2 is attached to CE 2, while CE 1 of Site 1 acts as the RP for group G; the share-group address used to forward public network data is 239.1.1.1.
Figure 9 Transmission of multicast protocol packets
The work process of multicast protocol packets is as follows:
1.      Receiver sends an IGMP membership report for multicast group G to CE 2. CE 2 creates a local (*, 225.1.1.1) state entry and sends a join message to the VPN RP (CE 1).
2.      Upon receiving the join message from CE 2, the VPN instance on PE 2 creates a (*, 225.1.1.1) state entry with the upstream interface being the MTI, and then PE 2 processes the join message. Now, the VPN instance on PE 2 considers that the join message has been sent out the MTI.
3.      PE 2 encapsulates the join message by means of Generic Routing Encapsulation (GRE), with its BGP interface address as the multicast source address and the share-group address as the multicast group address, to convert it into a normal, public network multicast data packet (11.1.2.1, 239.1.1.1), and then passes the packet to the public instance on PE 2 to have it forwarded to the public network.
4.      The multicast data packet (11.1.2.1, 239.1.1.1) is forwarded to the public instance on all the PE devices along the share-MDT. Upon receiving this packet, every PE device decapsulates it to turn it back into a join message to be sent to the VPN RP. Then, each PE device checks the join message. If any PE device finds that the VPN RP is in the site it interfaces with, it passes the join message to the VPN instance on it; otherwise, it discards the join message.
5.      When receiving the join message, the VPN instance on PE 1 considers that it received the message from the MTI. PE 1 creates a local (*, 225.1.1.1) state entry, with the downstream interface being the MTI and the upstream interface being the one that leads to CE 1. At the same time, it sends a join message to CE 1, which is the VPN RP.
6.      Upon receiving the join message from the VPN instance on PE 1, CE 1 creates a local (*, 225.1.1.1) state entry or updates the entry if it already exists. By now, the construction of an RPT across the public network is completed.
For more information about GRE, see Layer 3—IP Services Configuration Guide.
Delivery of multicast data packets
After the share-MDT is established, the multicast source forwards the VPN multicast data to the receivers in each site along the distribution tree. The VPN multicast packets are encapsulated into public network multicast packets on the local PE device, transmitted along the share-MDT, and then decapsulated on the remote PE device and transmitted in that VPN site. VPN multicast data flows are forwarded across the public network differently in the following two circumstances:
1.      On a VPN that is running PIM-DM or PIM-SSM, the multicast source forwards multicast data to the receivers along the VPN SPT across the public network.
2.      On a VPN that is running PIM-SM:
¡  Before SPT switchover, if the multicast source and the VPN RP are in different sites, the multicast source forwards VPN multicast data to the VPN RP along the VPN SPT across the public network. If the VPN RP and the receiver are in different sites, the VPN RP forwards VPN multicast traffic to the receiver along the VPN RPT over the public network.
¡  After SPT switchover, if the multicast source and the receiver are in different sites, the multicast source forwards VPN multicast data to the receiver along the VPN SPT across the public network.
3.      On a VPN that is running BIDIR-PIM, if the multicast source and the VPN RP are in different sites, the multicast source sends multicast data to the VPN RP across the public network along the source-side RPT. If the VPN RP and the receivers are in different sites, the VPN RP forwards the multicast data to the receivers across the public network along the receiver-side RPT.
·       For more information of RPT-to-SPT switchover, see the chapter “Configuring PIM.”
·       The following example explains how multicast data packets are delivered based on the share-MDT while PIM-DM is running in both the public network and the VPNs network.
As shown in Figure 10, PIM-DM is running in both the public network and the VPN sites, Receiver of the VPN multicast group G (225.1.1.1) in Site 2 is attached to CE 2, and Source in Site 1 sends multicast data to multicast group G); the share-group address used to forward public network multicast data is 239.1.1.1.
Figure 10 Delivery of multicast data packets
The VPN multicast traffic is delivered across the public network as follows.
1.      Source sends customer multicast data (192.1.1.1, 225.1.1.1) to CE 1.
2.      CE 1 forwards the VPN multicast data along an SPT to CE 1, and the VPN instance on PE 1 checks the MVRF. If the outgoing interface list of the forwarding entry contains an MTI, PE 1 processes the VPN multicast data.. Now, the VPN instance on PE 1 considers that the VPN multicast data has been sent out the MTI.
3.      PE 1 encapsulates the multicast data by means of GRE, with its BGP interface address as the multicast source address and the share-group address as the multicast group address, to convert it into a normal, public network multicast data packet (11.1.1.1, 239.1.1.1), and then passes the packet to the public instance on PE 1 to have it forwarded to the public network.
4.      The multicast data packet (11.1.1.1, 239.1.1.1) is forwarded to the public instance on all the PE devices along the share-MDT. Upon receiving this packet, every PE device decapsulates it to turn it back into a VPN multicast data packet, and passes it to the corresponding VPN instance. If any PE has a downstream interface for an SPT, it forwards the VPN multicast packet down the SPT; otherwise, it discards the packet.
5.      The VPN instance on PE 2 searches the MVRF and finally delivers the VPN multicast data to Receiver. By now, the process of transmitting a VPN multicast packet across the public network is completed.
MDT switchover
Switching from Share-MDT to Switch-MDT
When a multicast data packet of a VPN is transmitted through the share-MDT on the public network, the packet is forwarded to all PE devices that support that VPN instance, no matter whether any active receivers exist in the attached sites. When the rate of the customer multicast traffic of that VPN is high, multicast data may get flooded on the public network, causing bandwidth waste and extra burden on the PE devices.
To optimize multicast transmission, the MD solution establishes a dedicated switch-MDT between the PE devices with private network multicast receivers and multicast sources for any large-traffic private network multicast stream before it enters the public network. Then, the multicast stream is switched from the share-MDT to the switch-MDT, to deliver the multicast data to only those receivers that need it.
The process of share-MDT to switch-MDT switching is as follows:
1.      The source-side PE (PE 1 in this example) device periodically checks the forwarding rate of the VPN multicast traffic. Share-MDT to switch-MDT switching takes place only when both of the following conditions are met:
¡  The private network multicast data has passed ACL filtering for MDT switching, if an ACL rule was configured.
¡  The source-side PE device has received private multicast traffic and kept forwarding the multicast traffic for a certain length of time.
2.      PE 1 chooses an idle switch-group address from the switch-group-pool and sends a switchover message to all the other PE devices down the share-MDT. This message contains the private network multicast source address, the private network multicast group address and the switch-group address.
3.      Each PE device that receives this message checks whether it interfaces with a private network that has receivers of that VPN multicast stream. If so, it joins the switch-MDT rooted at PE 1; otherwise, it caches the message and will join the switch-MDT when it has attached receivers.
4.      After sending the switchover message, PE 1 waits a certain length of time and then starts using the switch-group address to encapsulate the private network multicast data, so that the multicast data is forwarded down the switch-MDT.
5.      After the multicast traffic is switched from the share-MDT to the switch-MDT, PE 1 continues sending switchover messages periodically, so that subsequent PE devices with attached receivers can join the switch-MDT. When a downstream PE device has no longer active receivers attached to it, it leaves the switch-MDT.
For a given VPN instance, the share-MDT and the switch-MDT are both forwarding tunnels in the same MD. A share-MDT is uniquely identified by a share-group address, while a switch-MDT is uniquely identified by a switch-group address. Each share-group is uniquely associated with a set of switch-group addresses, namely a switch-group-pool.
Backward Switching from Switch-MDT to Share-MDT
After the private network multicast traffic is switched to the switch-MDT, the multicast traffic conditions may change and no longer meet the aforesaid switching criterion. In this case, PE 1, as in the example above, initiates a backward MDT switching process. When any of the following conditions is met, the multicast traffic is switched from the switch-MDT back to the share-MDT:
·           The associated switch-group-pool is changed and the switch-group address for encapsulating the private network multicast data is out of the new address pool.
·           The ACL rule for controlling the switching of private network multicast traffic from the share-MDT to the switch-MDT is changed and the private network multicast data fails to pass the new ACL rule.
Multi-AS MD-VPN
If nodes of a VPNs network are allocated in multiple autonomous systems (ASs), these VPN nodes must be interconnected. Two approaches are available to implement multi-AS VPN:
VRF-to-VRF PE interconnectivity
As shown in Figure 11, a VPNs network involves two ASs, AS 1 and AS 2. PE 3 and PE 4 are the autonomous system boundary router (ASBR) for AS 1 and AS 2 respectively. PE 3 and PE 4 are interconnected through their respective VPN instance and treat each other as a CE device.
Figure 11 VPN instance-VPN instance interconnectivity
In the VPN instance-VPN instance interconnectivity approach, a separate MD needs to be established within each AS, and VPN multicast traffic between different ASs is transmitted between these MDs.
Because only VPN multicast traffic is forwarded between ASBRs, different PIM modes can run within different ASs. However, the same PIM mode (PIM-DM, PIM-SM, BIDIR-PIM, or PIM-SSM) must run on all interfaces that belong to the same VPN (including interfaces with VPN bindings on ASBRs).
Multi-hop EBGP interconnectivity
As shown in Figure 12, a VPNs network involves two ASs, AS 1 and AS 2. PE 3 and PE 4 are the autonomous system boundary router (ASBR) for AS 1 and AS 2 respectively. PE 3 and PE 4 are interconnected through their respective public network instance and treat each other as a P device.
Figure 12 Multi-hop EBGP interconnectivity
In the multi-hop EBGP interconnectivity approach, only one MD needs to be established for all the ASs, and public network multicast traffic between different ASs is transmitted within this MD.
MD-VPN configuration task list
Complete these tasks to configure MD-VPN:
Remarks
Configuring MD-VPN
Enabling IP multicast routing in a VPN instance
Required
Configuring a share-group and an MTI binding
Required
Configuring MDT switching parameters
Optional
Enabling switch-group reuse logging
Optional
Configuring BGP MDT
Configuring BGP MDT peers or peer groups
Required
Configuring a BGP MDT route reflector
Optional
Configuring MD-VPN
Configuration prerequisites
Before configuring MD-VPN, complete the following tasks:
·           Configure any unicast routing protocol to provide intra-domain interoperability at the network layer.
·           Configure MPLS L3VPN.
·           Configure PIM (PIM-DM, PIM-SM, BIDIR-PIM, or PIM-SSM).
·           Determine the VPN instance names and route distinguishers (RDs).
·           Determine the share-group addresses and an MTI numbers.
·           Determine the address ranges of switch-group-pools and ACL rules for MDT switching.
·           Determine the switch-delay period.
CAUTION
CAUTION:
The MTU of the public network forwarding path must not be set below 1500; otherwise GRE multicast packets will be fragmented on the public network, resulting in fragmented packets unrecognizable to the destination PE device.
Before configuring any MD-VPN functionality for a VPN, you must enable IP multicast routing in the VPN instance.
To enable IP multicast routing in a VPN instance:
Step
Remarks
1.     Enter system view.
N/A
2.     Create a VPN instance and enter VPN instance view.
N/A
3.     Configure an RD for the VPN instance.
No RD is configured for a VPN instance by default.
4.     Enable IP multicast routing.
multicast routing-enable
Disabled by default.
·       For more information about the ip vpn-instance and route-distinguisher commands, see MPLS Command Reference.
·       For more information about the multicast routing-enable command, see IP Multicast Command Reference.
By running multiple instances on each PE device, you enable the PE device to work for multiple VPNs. You need to configure the same share-group address for the same VPN instance on different PE devices. With a share-group and an MTI number configured, the system automatically creates an MTI, binds the share-group address to the MTI and binds the MTI to the current VPN instance.
To configure a share-group and an MTI binding:
Step
Remarks
5.     Enter system view.
N/A
6.     Enter VPN instance view.
N/A
7.     Configure a share-group address and an MTI binding.
multicast-domain share-group group-address binding mtunnel mtunnel-number
No share-group address or MTI binding is configured.
·       After a BGP peer is configured with the peer connect-interface command, the MTI interface automatically obtains the connect-interface address and uses it as its own IP address. This IP address cannot be used in the VPN any more; otherwise the MTI interface will fail to obtain an IP address. When you configure multiple BGP peers on the same device, you must specify the same connect-interface address for these BGP peers; otherwise the MTI interface will also fail to obtain an IP address, either. For more information about the peer connect-interface command, see Layer 3—IP Routing Command Reference.
·       The MTI interface becomes up only after it obtains an IP address.
·       PIM on the MTI interface takes effect only after PIM is enabled on at least one interface of the VPN instance; when PIM is disabled on all the interfaces of the VPN instance, PIM on the MTI interface is disabled simultaneously.
To avoid frequent switching of multicast traffic between the share-MDT and the switch-MDT:
An MDT switchover does not take place immediately after the multicast traffic forwarding becomes stable, but it takes place after a switch-delay period has passed, during which the multicast traffic keeps being forwarded.
To configure MDT switching parameters:
Step
Remarks
1.     Enter VPN instance view.
N/A
2.     Configure the address range of the switch-group-pool.
multicast-domain switch-group-pool switch-group-pool { mask | mask-length } [ acl acl-number ]
By default, no switch-group-pool is configured and multicast traffic is never switched to a switch-MDT.
3.     Configure the switch-delay period.
multicast-domain switch-delay switch-delay
Optional.
5 seconds by default.
For a given VPN, if the number of private network multicast streams to be switched to switch-MDTs exceeds the number of addresses in the switch-group-pool, the VPN instance on the source-side PE device can reuse the addresses in the address pool. By enabling the switch-group reuse logging function, you can have the address reuse information logged.
To enable the switch-group reuse logging function:
Step
Remarks
N/A
2.     Enter VPN instance view.
N/A
3.     Enable the switch-group reuse logging function.
multicast-domain log switch-group-reuse
Disabled by default
·       Attributed to the MD module, the group address reuse logging information has a severity level of informational. For more information about the logging information, see Network Management and Monitoring Configuration Guide.
·       With switch-group reuse logging enabled, the generated group address reuse logging information will be sent to the information center, where you can configure the rules for outputting the logging information. For more information about the configuration of the information center, see Network Management and Monitoring Configuration Guide.
Configuring BGP MDT
If PIM-SSM is running on the public network, you must configure BGP MDT.
Before configuring BGP MDT, complete the following tasks:
·           Configure basic BGP functions.
·           Determine the route reflector cluster ID.
With BGP MDT peers or peer groups configured, a PE exchanges the BGP MDT routing information with other PEs to obtain their addresses and thus establish a share-MDT.
To configure BGP MDT peers or peer groups:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enter BGP MDT sub-address family view.
ipv4-family mdt
N/A
4.     Enable a BGP MDT peer or peer group.
peer { group-name | ip-address } enable
5.     Add a peer to the BGP MDT peer group.
peer ip-address group group-name
Optional.
By default, a BGP MDT peer belongs to no peer groups.
A BGP MDT peer or peer group is a peer or peer group created in BGP-MDT subaddress family view.
BGP MDT peers in the same AS must be fully meshed to maintain connectivity. However, when many BGP MDT peers exist in an AS, connection establishment among them may cause great expenses. To reduce connections between them, you can configure one of them as a route reflector and specify other routers as clients. The clients establish BGP MDT connections with the route reflector, and the route reflector forwards (reflects) BGP MDT routing information between clients. In this way, the clients need not to be fully meshed. Furthermore, you can disable client-to-client reflection to reduce overloads if the clients have been fully meshed.
The route reflector and its clients form a cluster. In general, a cluster has only one route reflector whose router ID identifies the cluster. However, you can configure several route reflectors in a cluster to improve network reliability, and they must have the same cluster ID configured to avoid routing loops.
To configure a BGP MDT route reflector:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
ipv4-family mdt
N/A
4.     Configure the local device as a route reflector and specify its clients.
peer { group-name | ip-address } reflect-client
By default, neither route reflectors nor clients exist.
5.     Disable route reflection between clients.
undo reflect between-clients
Optional.
Enabled by default.
6.     Configure the cluster ID of the route reflector.
Optional.
By default, a route reflector uses its router ID as the cluster ID.
Displaying and maintaining multicast VPN
Remarks
1.     Display the share-group information of the specified VPN instance in the MD.
display multicast-domain vpn-instance vpn-instance-name share-group { local | remote } [ | { begin | exclude | include } regular-expression ]
Available in any view
2.     Display the switch-group information received by the specified VPN instance in the MD.
display multicast-domain vpn-instance vpn-instance-name switch-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ] [ | { begin | exclude | include } regular-expression ]
3.     Display the switch-group information sent by the specified VPN instance in the MD.
display multicast-domain vpn-instance vpn-instance-name switch-group send [ group group-address | reuse interval | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * [ | { begin | exclude | include } regular-expression ]
4.     Display information about the BGP MDT peer groups.
display bgp mdt group [ group-name ] [ | { begin | exclude | include } regular-expression ]
5.     Display information about the BGP MDT peers.
display bgp mdt peer [ [ ip-address ] verbose ] [ | { begin | exclude | include } regular-expression ]
6.     Display BGP MDT routing information.
display bgp mdt { all | route-distinguisher route-distinguisher } routing-table [ ip-address [ mask | mask-length ] ] [ | { begin | exclude | include } regular-expression ]
7.     Reset the BGP MDT connections.
reset bgp mdt { as-number | ip-address | all | external | group group-name | internal }
Multicast VPN configuration example
Single-AS MD-VPN configuration
Network requirements
The network requirements for single-AS MD-VPN configuration are listed in the table below:
Item
Multicast sources and receivers
·       In VPN a, S 1 is the multicast source, and R 1, R 2 and R 3 are receivers
·       In VPN a, S 2 is the multicast source, and R 4 is a receiver
·       Of VPN a, the share-group address is 239.1.1.1, and the address range of its switch-group-pool is 225.2.2.0 to 225.2.2.15
·       Of VPN b, the share-group address is 239.2.2.2, and the address range of its switch-group-pool is 225.4.4.0 to 225.4.4.15
PE interfaces and VPN instances they belong to
·       PE 1: GigabitEthernet 2/1/2 and GigabitEthernet 2/1/3 belong to VPN instance a; GigabitEthernet 2/1/1 and Loopback 1 belong to the public instance
·       PE 2: GigabitEthernet 2/1/2 belongs to VPN instance b; GigabitEthernet 2/1/3 belongs to VPN instance a; GigabitEthernet 2/1/1 and Loopback 1 belong to the public instance
·       PE 3: GigabitEthernet 2/1/2 belongs to VPN instance a; GigabitEthernet 2/1/3 and Loopback 2 belongs to VPN instance b; GigabitEthernet 2/1/1 and Loopback 1 belong to the public instance
Unicast routing protocols and MPLS
·       Configure OSPF on the public network, and configure RIP between the PE devices and the CE devices.
·       Establish BGP peer connections between PE 1, PE 2 and PE 3 via their respective Loopback 1 interface and exchange routing information between all private networks
·       Configure MPLS on the public network
·       Enable IP multicast routing on the P router
·       Enable IP multicast routing on the public network on PE 1, PE 2, and PE 3
·       Enable IP multicast routing in VPN instance a on PE 1, PE 2, and PE 3
·       Enable IP multicast routing in VPN instance b on PE 2 and PE 3
·       Enable IP multicast routing on CE a1, CE a2, CE a3, CE b1, and CE b2
IGMP
·       Run IGMPv2 on GigabitEthernet 2/1/2 of PE 1
·       Run IGMPv2 on GigabitEthernet 2/1/1 of CE a2, CE a3, and CE b2
PIM
·       Enable PIM-SM on all interfaces of the P router
·       Enable PIM-SM on all public network interfaces and private network interface of PE 1, PE 2, and PE 3
·       Enable PIM-SM on all interfaces of CE a1, CE a2, CE a3, CE b1, and CE b2
·       Configure Loopback 1 of P as a public network C-BSR and C-RP (to work for all multicast groups)
·       Configure Loopback 1 of CE a2 as a C-BSR and C-RP for VPN a (to work for all multicast groups)
·       Configure Loopback 2 of PE 3 as a C-BSR and C-RP for VPN b (to work for all multicast groups)
Figure 13 Network diagram
Device
IP address
Device
IP address
S 1
10.110.7.2/24
PE 3
GE2/1/1
192.168.8.1/24
S 2
10.110.8.2/24
GE2/1/2
10.110.5.1/24
R 1
10.110.1.2/24
GE2/1/3
10.110.6.1/24
R 2
10.110.9.2/24
Loop1
1.1.1.3/32
R 3
10.110.10.2/24
Loop2
33.33.33.33/32
R 4
10.110.11.2/24
CE a1
GE2/1/1
10.110.7.1/24
P
GE2/1/1
192.168.6.2/24
GE2/1/2
10.110.2.2/24
GE2/1/2
192.168.7.2/24
CE a2
GE2/1/1
10.110.9.1/24
GE2/1/3
192.168.8.2/24
GE2/1/2
10.110.4.2/24
Loop1
2.2.2.2/32
GE2/1/3
10.110.12.1/24
PE 1
GE2/1/1
192.168.6.1/24
Loop1
22.22.22.22/32
GE2/1/2
10.110.1.1/24
CE a3
GE2/1/1
10.110.10.1/24
GE2/1/3
10.110.2.1/24
GE2/1/2
10.110.5.2/24
Loop1
1.1.1.1/32
GE2/1/3
10.110.12.2/24
PE 2
GE2/1/1
192.168.7.1/24
CE b1
GE2/1/1
10.110.8.1/24
GE2/1/2
10.110.3.1/24
GE2/1/2
10.110.3.2/24
GE2/1/3
10.110.4.1/24
CE b2
GE2/1/1
10.110.11.1/24
Loop1
1.1.1.2/32
GE2/1/2
10.110.6.2/24
Configuration procedure
1.      Configure PE 1:
# Configure a Router ID, enable IP multicast routing on the public network, configure an MPLS label switching router (LSR) ID, and enable the Label Distribution Protocol (LDP) capability.
<PE1> system-view
[PE1] router id 1.1.1.1
[PE1] multicast routing-enable
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
# Create VPN instance a, configure an RD for it, and create an ingress route and an egress route for it.
[PE1] ip vpn-instance a
[PE1-vpn-instance-a] route-distinguisher 100:1
[PE1-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE1-vpn-instance-a] vpn-target 100:1 import-extcommunity
# Enable IP multicast routing in VPN instance a, configure a share-group address, associate an MTI with the VPN instance, and define the address range of the switch-group-pool.
[PE1-vpn-instance-a] multicast routing-enable
[PE1-vpn-instance-a] multicast-domain share-group 239.1.1.1 binding mtunnel 0
[PE1-vpn-instance-a] multicast-domain switch-group-pool 225.2.2.0 28
[PE1-vpn-instance-a] quit
# Assign an IP address, enable PIM-SM and LDP capability on the public network interface GigabitEthernet 2/1/1.
[PE1] interface GigabitEthernet 2/1/1
[PE1-GigabitEthernet2/1/1] ip address 192.168.6.1 24
[PE1-GigabitEthernet2/1/1] pim sm
[PE1-GigabitEthernet2/1/1] mpls
[PE1-GigabitEthernet2/1/1] mpls ldp
[PE1-GigabitEthernet2/1/1] quit
# Bind GigabitEthernet 2/1/2 to VPN instance a, configure an IP address and enable IGMP and PIM-SM on the interface.
[PE1] interface GigabitEthernet 2/1/2
[PE1-GigabitEthernet2/1/2] ip binding vpn-instance a
[PE1-GigabitEthernet2/1/2] ip address 10.110.1.1 24
[PE1-GigabitEthernet2/1/2] igmp enable
[PE1-GigabitEthernet2/1/2] pim sm
[PE1-GigabitEthernet2/1/2] quit
# Bind GigabitEthernet 2/1/3 to VPN instance a, configure an IP address and enable PIM-SM on the interface.
[PE1] interface GigabitEthernet 2/1/3
[PE1-GigabitEthernet2/1/3] ip binding vpn-instance a
[PE1-GigabitEthernet2/1/3] ip address 10.110.2.1 24
[PE1-GigabitEthernet2/1/3] pim sm
[PE1-GigabitEthernet2/1/3] quit
# Assign an IP address for Loopback 1, and enable PIM-SM.
[PE1] interface loopback 1
[PE1-LoopBack1] ip address 1.1.1.1 32
[PE1-LoopBack1] pim sm
[PE1-LoopBack1] quit
# Configure BGP.
[PE1] bgp 100
[PE1-bgp] group vpn-g internal
[PE1-bgp] peer vpn-g connect-interface loopback 1
[PE1-bgp] peer 1.1.1.2 group vpn-g
[PE1-bgp] peer 1.1.1.3 group vpn-g
[PE1–bgp] ipv4-family vpn-instance a
[PE1-bgp-a] import-route rip 2
[PE1-bgp-a] import-route direct
[PE1-bgp-a] quit
[PE1–bgp] ipv4-family vpnv4
[PE1–bgp-af-vpnv4] peer vpn-g enable
[PE1-bgp-af-vpnv4] peer 1.1.1.2 group vpn-g
[PE1–bgp-af-vpnv4] peer 1.1.1.3 group vpn-g
[PE1–bgp-af-vpnv4] quit
[PE1–bgp] quit
The interface MTI 0 will automatically obtain an IP address after BGP peer configuration on PE 1. This address is the loopback interface address specified in the BGP peer configuration. The PIM mode running on MTI 0 is the same as the PIM mode running in VPN instance a.
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] area 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.255.255
[PE1-ospf-1] quit
# Configure RIP.
[PE1] rip 2 vpn-instance a
[PE1-rip-2] network 10.0.0.0
[PE1-rip-2] import-route bgp
[PE1-rip-2] return
2.      Configure PE 2:
# Configure a Router ID, enable IP multicast routing on the public network, configure an MPLS LSR ID, and enable the LDP capability.
<PE2> system-view
[PE2] router id 1.1.1.2
[PE2] multicast routing-enable
[PE2] mpls lsr-id 1.1.1.2
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
# Create VPN instance b, configure an RD for it, and create an ingress route and an egress route for it.
[PE2] ip vpn-instance b
[PE2-vpn-instance-b] route-distinguisher 200:1
[PE2-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE2-vpn-instance-b] vpn-target 200:1 import-extcommunity
# Enable IP multicast routing in VPN instance b, configure a share-group address, associate an MTI with the VPN instance, and define the address range of the switch-group-pool.
[PE2-vpn-instance-b] multicast routing-enable
[PE2-vpn-instance-b] multicast-domain share-group 239.2.2.2 binding mtunnel 1
[PE2-vpn-instance-b] multicast-domain switch-group-pool 225.4.4.0 28
[PE2-vpn-instance-b] quit
[PE2] ip vpn-instance a
[PE2-vpn-instance-a] route-distinguisher 100:1
[PE2-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE2-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE2-vpn-instance-a] multicast routing-enable
[PE2-vpn-instance-a] multicast-domain share-group 239.1.1.1 binding mtunnel 0
[PE2-vpn-instance-a] multicast-domain switch-group-pool 225.2.2.0 28
[PE2-vpn-instance-a] quit
[PE2] interface GigabitEthernet 2/1/1
[PE2-GigabitEthernet2/1/1] ip address 192.168.7.1 24
[PE2-GigabitEthernet2/1/1] pim sm
[PE2-GigabitEthernet2/1/1] mpls
[PE2-GigabitEthernet2/1/1] mpls ldp
[PE2-GigabitEthernet2/1/1] quit
# Bind GigabitEthernet 2/1/2 to VPN instance b, configure an IP address and enable PIM-SM on the interface.
[PE2] interface GigabitEthernet 2/1/2
[PE2-GigabitEthernet2/1/2] ip binding vpn-instance b
[PE2-GigabitEthernet2/1/2] ip address 10.110.3.1 24
[PE2-GigabitEthernet2/1/2] pim sm
[PE2-GigabitEthernet2/1/2] quit
[PE2] interface GigabitEthernet 2/1/3
[PE2-GigabitEthernet2/1/3] ip binding vpn-instance a
[PE2-GigabitEthernet2/1/3] ip address 10.110.4.1 24
[PE2-GigabitEthernet2/1/3] pim sm
[PE2-GigabitEthernet2/1/3] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ip address 1.1.1.2 32
[PE2-LoopBack1] pim sm
[PE2-LoopBack1] quit
# Configure BGP.
[PE2] bgp 100
[PE2-bgp] group vpn-g internal
[PE2-bgp] peer vpn-g connect-interface loopback 1
[PE2-bgp] peer 1.1.1.1 group vpn-g
[PE2-bgp] peer 1.1.1.3 group vpn-g
[PE2–bgp] ipv4-family vpn-instance a
[PE2-bgp-a] import-route rip 2
[PE2-bgp-a] import-route direct
[PE2-bgp-a] quit
[PE2–bgp] ipv4-family vpn-instance b
[PE2-bgp-b] import-route rip 3
[PE2-bgp-b] import-route direct
[PE2-bgp-b] quit
[PE2–bgp] ipv4-family vpnv4
[PE2–bgp-af-vpnv4] peer vpn-g enable
[PE2-bgp-af-vpnv4] peer 1.1.1.1 group vpn-g
[PE2–bgp-af-vpnv4] peer 1.1.1.3 group vpn-g
[PE2–bgp-af-vpnv4] quit
[PE2–bgp] quit
The interface MTI 0 will automatically obtain an IP address after BGP peer configuration on PE 2. This address is the loopback interface address specified in the BGP peer configuration. The PIM mode running on MTI 0 is the same as the PIM mode running in VPN instance a.
The interface MTI 1 will automatically obtain an IP address after BGP peer configuration on PE 2. This address is the loopback interface address specified in the BGP peer configuration. The PIM mode running on MTI 1 is the same as the PIM mode running in VPN instance b.
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] area 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 1.1.1.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.255.255
[PE2-ospf-1] quit
# Configure RIP.
[PE2] rip 2 vpn-instance a
[PE2-rip-2] network 10.0.0.0
[PE2-rip-2] import-route bgp
[PE2-rip-2] quit
[PE2] rip 3 vpn-instance b
[PE2-rip-3] network 10.0.0.0
[PE2-rip-3] import-route bgp
[PE2-rip-3] return
3.      Configure PE 3:
<PE3> system-view
[PE3] router id 1.1.1.3
[PE3] multicast routing-enable
[PE3] mpls lsr-id 1.1.1.3
[PE3] mpls
[PE3-mpls] quit
[PE3] mpls ldp
[PE3-mpls-ldp] quit
[PE3] ip vpn-instance a
[PE3-vpn-instance-a] route-distinguisher 100:1
[PE3-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE3-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE3-vpn-instance-a] multicast routing-enable
[PE3-vpn-instance-a] multicast-domain share-group 239.1.1.1 binding mtunnel 0
[PE3-vpn-instance-a] multicast-domain switch-group-pool 225.2.2.0 28
[PE3-vpn-instance-a] quit
[PE3] ip vpn-instance b
[PE3-vpn-instance-b] route-distinguisher 200:1
[PE3-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE3-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE3-vpn-instance-b] multicast routing-enable
[PE3-vpn-instance-b] multicast-domain share-group 239.2.2.2 binding mtunnel 1
[PE3-vpn-instance-b] multicast-domain switch-group-pool 225.4.4.0 28
[PE3-vpn-instance-b] quit
[PE3] interface GigabitEthernet 2/1/1
[PE3-GigabitEthernet2/1/1] ip address 192.168.8.1 24
[PE3-GigabitEthernet2/1/1] pim sm
[PE3-GigabitEthernet2/1/1] mpls
[PE3-GigabitEthernet2/1/1] mpls ldp
[PE3-GigabitEthernet2/1/1] quit
# Bind GigabitEthernet 2/1/2 to VPN instance a, configure an IP address and enable PIM-SM on the interface.
[PE3] interface GigabitEthernet 2/1/2
[PE3-GigabitEthernet2/1/2] ip binding vpn-instance a
[PE3-GigabitEthernet2/1/2] ip address 10.110.5.1 24
[PE3-GigabitEthernet2/1/2] pim sm
[PE3-GigabitEthernet2/1/2] quit
# Bind GigabitEthernet 2/1/3 to VPN instance b, configure an IP address and enable PIM-SM on the interface.
[PE3] interface GigabitEthernet 2/1/3
[PE3-GigabitEthernet2/1/3] ip binding vpn-instance b
[PE3-GigabitEthernet2/1/3] ip address 10.110.6.1 24
[PE3-GigabitEthernet2/1/3] pim sm
[PE3-GigabitEthernet2/1/3] quit
[PE3] interface loopback 1
[PE3-LoopBack1] ip address 1.1.1.3 32
[PE3-LoopBack1] quit
# Bind Loopback 2 to VPN instance b, configure an IP address and enable PIM-SM on the interface.
[PE3] interface loopback 2
[PE3-LoopBack2] ip binding vpn-instance b
[PE3-LoopBack2] ip address 33.33.33.33 32
[PE3-LoopBack2] pim sm
[PE3-LoopBack2] quit
# Configure Loopback 2 as a C-BSR and C-RP for VPN b.
[PE3] pim vpn-instance b
[PE3-pim-b] c-bsr loopback 2
[PE3-pim-b] c-rp loopback 2
[PE3-pim-b] quit
# Configure BGP.
[PE3] bgp 100
[PE3-bgp] group vpn-g internal
[PE3-bgp] peer vpn-g connect-interface loopback 1
[PE3-bgp] peer 1.1.1.1 group vpn-g
[PE3-bgp] peer 1.1.1.2 group vpn-g
[PE3–bgp] ipv4-family vpn-instance a
[PE3-bgp-a] import-route rip 2
[PE3-bgp-a] import-route direct
[PE3-bgp-a] quit
[PE3–bgp] ipv4-family vpn-instance b
[PE3-bgp-b] import-route rip 3
[PE3-bgp-b] import-route direct
[PE3-bgp-b] quit
[PE3–bgp] ipv4-family vpnv4
[PE3–bgp-af-vpnv4] peer vpn-g enable
[PE3-bgp-af-vpnv4] peer 1.1.1.1 group vpn-g
[PE3–bgp-af-vpnv4] peer 1.1.1.2 group vpn-g
[PE3–bgp-af-vpnv4] quit
[PE3–bgp] quit
The interface MTI 0 will automatically obtain an IP address after BGP peer configuration on PE 3. This address is the loopback interface address specified in the BGP peer configuration. The PIM mode running on MTI 0 is the same as the PIM mode running in VPN instance a.
The interface MTI 1 will automatically obtain an IP address after BGP peer configuration on PE 3. This address is the loopback interface address specified in the BGP peer configuration. The PIM mode running on MTI 1 is the same as the PIM mode running in VPN instance b.
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] area 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 1.1.1.3 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.255.255
[PE3-ospf-1] quit
# Configure RIP.
[PE3] rip 2 vpn-instance a
[PE3-rip-2] network 10.0.0.0
[PE3-rip-2] import-route bgp
[PE3-rip-2] quit
[PE3] rip 3 vpn-instance b
[PE3-rip-3] network 10.0.0.0
[PE3-rip-3] network 33.0.0.0
[PE3-rip-3] import-route bgp
[PE3-rip-3] return
4.      Configuring the R router:
# Enable IP multicast routing, configure an MPLS LSR ID, and enable the LDP capability on the public network.
<P> system-view
[P] multicast routing-enable
[P] mpls lsr-id 2.2.2.2
[P] mpls
[P-mpls] quit
[P] mpls ldp
[P-mpls-ldp] quit
[P] interface GigabitEthernet 2/1/1
[P-GigabitEthernet2/1/1] ip address 192.168.6.2 24
[P-GigabitEthernet2/1/1] pim sm
[P-GigabitEthernet2/1/1] mpls
[P-GigabitEthernet2/1/1] mpls ldp
[P-GigabitEthernet2/1/1] quit
# Assign an IP address, enable PIM-SM and LDP capability on the public network interface GigabitEthernet 2/1/2.
[P] interface GigabitEthernet 2/1/2
[P-GigabitEthernet2/1/2] ip address 192.168.7.2 24
[P-GigabitEthernet2/1/2] pim sm
[P-GigabitEthernet2/1/2] mpls
[P-GigabitEthernet2/1/2] mpls ldp
[P-GigabitEthernet2/1/2] quit
# Assign an IP address, enable PIM-SM and LDP capability on the public network interface GigabitEthernet 2/1/3.
[P] interface GigabitEthernet 2/1/3
[P-GigabitEthernet2/1/3] ip address 192.168.8.2 24
[P-GigabitEthernet2/1/3] pim sm
[P-GigabitEthernet2/1/3] mpls
[P-GigabitEthernet2/1/3] mpls ldp
[P-GigabitEthernet2/1/3] quit
# Assign an IP address for Loopback 1 and enable PIM-SM on the interface.
[P] interface loopback 1
[P-LoopBack1] ip address 2.2.2.2 32
[P-LoopBack1] pim sm
[P-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and C-RP for the public instance.
[P] pim
[P-pim] c-bsr loopback 1
[P-pim] c-rp loopback 1
[P-pim] quit
# Configure OSPF.
[P] ospf 1
[P-ospf-1] area 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.255.255
5.      Configure CE a1:
# Enable IP multicast routing.
<CEa1> system-view
[CEa1] multicast routing-enable
# Assign an IP address and enable PIM-SM on GigabitEthernet 2/1/1.
[CEa1] interface GigabitEthernet 2/1/1
[CEa1-GigabitEthernet2/1/1] ip address 10.110.7.1 24
[CEa1-GigabitEthernet2/1/1] pim sm
[CEa1-GigabitEthernet2/1/1] quit
# Assign an IP address and enable PIM-SM on GigabitEthernet 2/1/2.
[CEa1] interface GigabitEthernet 2/1/2
[CEa1-GigabitEthernet2/1/2] ip address 10.110.2.2 24
[CEa1-GigabitEthernet2/1/2] pim sm
[CEa1-GigabitEthernet2/1/2] quit
# Configure RIP.
[CEa1] rip 2
[CEa1-rip-2] network 10.0.0.0
6.      Configure CE b1:
<CEb1> system-view
[CEb1] multicast routing-enable
[CEb1] interface GigabitEthernet 2/1/1
[CEb1-GigabitEthernet2/1/1] ip address 10.110.8.1 24
[CEb1-GigabitEthernet2/1/1] pim sm
[CEb1-GigabitEthernet2/1/1] quit
[CEb1] interface GigabitEthernet 2/1/2
[CEb1-GigabitEthernet2/1/2] ip address 10.110.3.2 24
[CEb1-GigabitEthernet2/1/2] pim sm
[CEb1-GigabitEthernet2/1/2] quit
# Configure RIP.
[CEb1] rip 3
[CEb1-rip-3] network 10.0.0.0
7.      Configure CE a2:
<CEa2> system-view
[CEa2] multicast routing-enable
# Assign an IP address, and enable IGMP and PIM-SM on GigabitEthernet 2/1/1.
[CEa2] interface GigabitEthernet 2/1/1
[CEa2-GigabitEthernet2/1/1] ip address 10.110.9.1 24
[CEa2-GigabitEthernet2/1/1] igmp enable
[CEa2-GigabitEthernet2/1/1] pim sm
[CEa2-GigabitEthernet2/1/1] quit
[CEa2] interface GigabitEthernet 2/1/2
[CEa2-GigabitEthernet2/1/2] ip address 10.110.4.2 24
[CEa2-GigabitEthernet2/1/2] pim sm
[CEa2-GigabitEthernet2/1/2] quit
# Assign an IP address and enable PIM-SM on GigabitEthernet 2/1/3.
[CEa2] interface GigabitEthernet 2/1/3
[CEa2-GigabitEthernet2/1/3] ip address 10.110.12.1 24
[CEa2-GigabitEthernet2/1/3] pim sm
[CEa2-GigabitEthernet2/1/3] quit
[CEa2] interface loopback 1
[CEa2-LoopBack1] ip address 22.22.22.22 32
[CEa2-LoopBack1] pim sm
[CEa2-LoopBack1] quit
# Configure Loopback 1 as a BSR and RP for VPN a.
[CEa2] pim
[CEa2-pim] c-bsr loopback 1
[CEa2-pim] c-rp loopback 1
[CEa2-pim] quit
# Configure RIP.
[CEa2] rip 2
[CEa2-rip-2] network 10.0.0.0
[CEa2-rip-2] network 22.0.0.0
8.      Configure CE a3:
<CEa3> system-view
[CEa3] multicast routing-enable
[CEa3] interface GigabitEthernet 2/1/1
[CEa3-GigabitEthernet2/1/1] ip address 10.110.10.1 24
[CEa3-GigabitEthernet2/1/1] igmp enable
[CEa3-GigabitEthernet2/1/1] pim sm
[CEa3-GigabitEthernet2/1/1] quit
[CEa3] interface GigabitEthernet 2/1/2
[CEa3-GigabitEthernet2/1/2] ip address 10.110.5.2 24
[CEa3-GigabitEthernet2/1/2] pim sm
[CEa3-GigabitEthernet2/1/2] quit
[CEa3] interface GigabitEthernet 2/1/3
[CEa3-GigabitEthernet2/1/3] ip address 10.110.12.2 24
[CEa3-GigabitEthernet2/1/3] pim sm
[CEa3-GigabitEthernet2/1/3] quit
# Configure RIP.
[CEa3] rip 2
[CEa3-rip-2] network 10.0.0.0
9.      Configure CE b2:
<CEb2> system-view
[CEb2] multicast routing-enable
[CEb2] interface GigabitEthernet 2/1/1
[CEb2-GigabitEthernet2/1/1] ip address 10.110.11.1 24
[CEb2-GigabitEthernet2/1/1] igmp enable
[CEb2-GigabitEthernet2/1/1] pim sm
[CEb2-GigabitEthernet2/1/1] quit
[CEb2] interface GigabitEthernet 2/1/2
[CEb2-GigabitEthernet2/1/2] ip address 10.110.6.2 24
[CEb2-GigabitEthernet2/1/2] pim sm
[CEb2-GigabitEthernet2/1/2] quit
# Configure RIP.
[CEb2] rip 3
[CEb2-rip-3] network 10.0.0.0
10.    Verify the configuration:
# Display the local share-group information of VPN instance a on PE 1.
<PE1> display multicast-domain vpn-instance a share-group local
MD local share-group information for VPN-Instance: a
  Share-group: 239.1.1.1
  MTunnel address: 1.1.1.1
# Display the local share-group information of VPN instance a on PE 2.
<PE2> display multicast-domain vpn-instance a share-group local
  MTunnel address: 1.1.1.2
# Display the local share-group information of VPN instance b on PE 2.
<PE2> display multicast-domain vpn-instance b share-group local
MD local share-group information for VPN-Instance: b
  Share-group: 239.2.2.2
# Display the local share-group information of VPN instance a on PE 3.
<PE3> display multicast-domain vpn-instance a share-group local
  MTunnel address: 1.1.1.3
# Display the local share-group information of VPN instance b on PE 3.
<PE3> display multicast-domain vpn-instance b share-group local
Multi-AS MD-VPN configuration
The network requirements for multi-AS MD-VPN configuration are listed in the table below:
Item
·       In VPN a, S 1 is a multicast source, and R 2 is a receiver.
·       In VPN b, S 2 is a multicast source, and R 1 is a receiver.
·       For VPN a, the share-group address is 239.1.1.1, and the range of its switch-group-pool addresses is 225.1.1.0 to 225.1.1.15.
·       For VPN b, the share-group address is 239.4.4.4, and the range of its switch-group-pool addresses is 225.4.4.0 to 225.4.4.15.
·       PE 1: GigabitEthernet 4/1/2 belongs to VPN a; GigabitEthernet 4/1/3 belongs to VPN b; GigabitEthernet 4/1/1 and Loopback 1 belong to the public network instance.
·       PE 2: GigabitEthernet 4/1/1, GigabitEthernet4/1/2, Loopback 1 and Loopback 2 belong to the public network instance.
·       PE 3: GigabitEthernet 4/1/1, GigabitEthernet4/1/2, Loopback 1 and Loopback 2 belong to the public network instance.
·       PE 4: GigabitEthernet4/1/2 belongs to VPN a; GigabitEthernet 4/1/3 belongs to VPN b; GigabitEthernet 4/1/1 and Loopback 1 belong to the public network instance.
·       Configure OSPF separately in AS 100 and AS 200, and configure OSPF between the PEs and CEs.
·       Establish BGP peer connections between PE 1, PE 2, PE 3 and PE 4 on their respective Loopback 1 interface and exchange all private network routes between them.
·       Configure MPLS separately in AS 100 and AS 200.
·       Enable IP multicast routing on the public network on PE 1, PE 2, PE 3 and PE 4.
·       Enable IP multicast routing in VPN a on PE 1 and PE 4.
·       Enable IP multicast routing in VPN b on PE 1 and PE 4.
·       Enable IP multicast routing on CE a1, CE a2, CE b1, and CE b2.
IGMP
·       Run IGMPv2 on GigabitEthernet 4/1/1 of CE a2.
·       Run IGMPv2 on GigabitEthernet 4/1/1 of CE b2.
PIM
·       Enable PIM-SM on all public network interfaces of PE 2 and PE 3.
·       Enable PIM-SM on all public and private network interfaces of PE 1 and PE 4.
·       Enable PIM-SM on all interfaces of CE a1, CE a2, CE b1, and CE b2.
·       Configure Loopback 2 of PE 2 and PE 3 as a C-BSR and a C-RP for their respective AS (to work for all multicast groups).
·       Configure Loopback 0 of CE a1 as a C-BSR and a C-RP for VPN a (to work for all multicast groups).
·       Configure Loopback 0 of CE b1 as a C-BSR and a C-RP for VPN b (to work for all multicast groups).
MSDP
·       Establish an MSDP peering relationship between PE 2 and PE 3 on their respective Loopback 1.
Figure 14 Network diagram
Device
IP address
Device
IP address
S 1
10.11.5.2/24
R 1
10.11.8.2/24
S 2
10.11.6.2/24
R 2
10.11.7.2/24
PE 1
GE4/1/1
10.10.1.1/24
PE 3
GE4/1/1
10.10.2.1/24
GE4/1/2
10.11.1.1/24
GE4/1/2
192.168.1.2/24
GE4/1/3
10.11.2.1/24
Loop1
1.1.1.3/32
Loop1
1.1.1.1/32
Loop2
22.22.22.22/32
PE 2
GE4/1/1
10.10.1.2/24
PE 4
GE4/1/1
10.10.2.2/24
GE4/1/2
192.168.1.1/24
GE4/1/2
10.11.3.1/24
Loop1
1.1.1.2/32
GE4/1/3
10.11.4.1/32
Loop2
11.11.11.11/32
Loop2
1.1.1.4/32
CE a1
GE4/1/1
10.11.5.1/24
CE b1
GE4/1/1
10.11.6.1/24
GE4/1/2
10.11.1.2/24
GE4/1/2
10.11.2.2/24
Loop0
2.2.2.2/32
CE b2
GE4/1/1
10.11.8.1/24
CE a2
GE4/1/1
10.11.7.1/24
GE4/1/2
10.11.4.2/24
GE4/1/2
10.11.3.2/24
Loop0
3.3.3.3/32
1.      Configure PE 1:
<PE1> system-view
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
# Create VPN instance a, configure an RD for it, and create an ingress route and an egress route for it; enable IP multicast routing in VPN instance a, configure a share-group address, associate an MTI with the VPN instance, and define the switch-group-pool address range.
[PE1-vpn-instance-a] multicast-domain switch-group-pool 225.1.1.0 28
# Create VPN instance b, configure an RD for it, and create an ingress route and an egress route for it; enable IP multicast routing in VPN instance b, configure a share-group address, associate an MTI with the VPN instance, and define the switch-group-pool address range.
[PE1] ip vpn-instance b
[PE1-vpn-instance-b] route-distinguisher 200:1
[PE1-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE1-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE1-vpn-instance-b] multicast routing-enable
[PE1-vpn-instance-b] multicast-domain share-group 239.4.4.4 binding mtunnel 1
[PE1-vpn-instance-b] multicast-domain switch-group-pool 225.4.4.0 28
[PE1-vpn-instance-b] quit
# Assign an IP address, and enable PIM-SM and LDP capability on the public network interface GigabitEthernet 4/1/1.
[PE1] interface GigabitEthernet 4/1/1
[PE1-GigabitEthernet4/1/1] ip address 10.10.1.1 24
[PE1-GigabitEthernet4/1/1] pim sm
[PE1-GigabitEthernet4/1/1] mpls
[PE1-GigabitEthernet4/1/1] mpls ldp
[PE1-GigabitEthernet4/1/1] quit
# Bind GigabitEthernet 4/1/2 to VPN instance a, configure an IP address and enable PIM-SM on the interface.
[PE1] interface GigabitEthernet 4/1/2
[PE1-GigabitEthernet4/1/2] ip binding vpn-instance a
[PE1-GigabitEthernet4/1/2] ip address 10.11.1.1 24
[PE1-GigabitEthernet4/1/2] pim sm
[PE1-GigabitEthernet4/1/2] quit
# Bind GigabitEthernet 4/1/3 to VPN instance b, configure an IP address and enable PIM-SM on the interface.
[PE1] interface GigabitEthernet 4/1/3
[PE1-GigabitEthernet4/1/3] ip binding vpn-instance b
[PE1-GigabitEthernet4/1/3] ip address 10.11.2.1 24
[PE1-GigabitEthernet4/1/3] pim sm
[PE1-GigabitEthernet4/1/3] quit
# Configure BGP.
[PE1] bgp 100
[PE1-bgp] group pe1-pe2 internal
[PE1-bgp] peer pe1-pe2 label-route-capability
[PE1-bgp] peer pe1-pe2 connect-interface loopback 1
[PE1-bgp] peer 1.1.1.2 group pe1-pe2
[PE1-bgp] group pe1-pe4 external
[PE1-bgp] peer pe1-pe4 as-number 200
[PE1-bgp] peer pe1-pe4 ebgp-max-hop 255
[PE1-bgp] peer 1.1.1.4 group pe1-pe4
[PE1-bgp] peer pe1-pe4 connect-interface loopback 1
[PE1-bgp-a] import-route ospf 2
[PE1-bgp-a] quit
[PE1–bgp] ipv4-family vpn-instance b
[PE1-bgp-b] import-route ospf 3
[PE1-bgp-b] import-route direct
[PE1-bgp-b] quit
[PE1–bgp-af-vpnv4] peer 1.1.1.4 enable
[PE1–bgp] quit
With BGP peers configured on PE 1, the interfaces MTI 0 and MTI 1 will automatically obtain IP addresses, which are the loopback interface addresses specified in the BGP peer configuration. The PIM mode running on MTI 0 is the same as on the interfaces in VPN instance a, and the PIM mode running on MTI 1 is the same as on the interfaces in VPN instance b.
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1-area-0.0.0.0] network 10.10.0.0 0.0.255.255
[PE1-ospf-1] quit
[PE1] ospf 2 vpn-instance a
[PE1-ospf-2] import-route bgp
[PE1-ospf-2] area 0.0.0.0
[PE1-ospf-2-area-0.0.0.0] network 10.11.0.0 0.0.255.255
[PE1-ospf-2-area-0.0.0.0] quit
[PE1-ospf-2] quit
[PE1] ospf 3 vpn-instance b
[PE1-ospf-3] import-route bgp
[PE1-ospf-3] area 0.0.0.0
[PE1-ospf-3-area-0.0.0.0] network 10.11.0.0 0.0.255.255
[PE1-ospf-3-area-0.0.0.0] quit
[PE1-ospf-3] quit
2.      Configure PE 2:
<PE2> system-view
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface GigabitEthernet 4/1/1
[PE2-GigabitEthernet4/1/1] ip address 10.10.1.2 24
[PE2-GigabitEthernet4/1/1] pim sm
[PE2-GigabitEthernet4/1/1] mpls
[PE2-GigabitEthernet4/1/1] mpls ldp
[PE2-GigabitEthernet4/1/1] quit
# Assign an IP address, and enable PIM-SM and MPLS on the public network interface GigabitEthernet 4/1/2.
[PE2] interface GigabitEthernet 4/1/2
[PE2-GigabitEthernet4/1/2] ip address 192.168.1.1 24
[PE2-GigabitEthernet4/1/2] pim sm
[PE2-GigabitEthernet4/1/2] mpls
[PE2-GigabitEthernet4/1/2] quit
# Assign an IP address for Loopback 2, and enable PIM-SM.
[PE2] interface loopback 2
[PE2-LoopBack2] ip address 11.11.11.11 32
[PE2-LoopBack2] pim sm
[PE2-LoopBack2] quit
# Configure Loopback 2 as a C-BSR and a C-RP for the public network instance.
[PE2] pim
[PE2-pim] c-bsr loopback 2
[PE2-pim] c-rp loopback 2
[PE2-pim] quit
#  Configure a BSR message boundary.
[PE2-GigabitEthernet4/1/2] pim bsr-boundary
# Establish an MSDP peering relationship.
[PE2] msdp
[PE2-msdp] encap-data-enable
[PE2-msdp] peer 1.1.1.3 connect-interface loopback 1
# Configure a static route.
[PE2] ip route-static 1.1.1.3 32 GigabitEthernet 4/1/2 192.168.1.2
# Configure BGP.
[PE2] bgp 100
[PE2-bgp] import-route ospf 1
[PE2-bgp] group pe2-pe1 internal
[PE2-bgp] peer pe2-pe1 route-policy map2 export
[PE2-bgp] peer pe2-pe1 label-route-capability
[PE2-bgp] peer pe2-pe1 connect-interface loopback 1
[PE2-bgp] peer 1.1.1.1 group pe2-pe1
[PE2-bgp] group pe2-pe3 external
[PE2-bgp] peer pe2-pe3 as-number 200
[PE2-bgp] peer pe2-pe3 route-policy map1 export
[PE2-bgp] peer pe2-pe3 label-route-capability
[PE2-bgp] peer pe2-pe3 connect-interface loopback 1
[PE2-bgp] peer 1.1.1.3 group pe2-pe3
[PE2–bgp] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1-area-0.0.0.0] network 11.11.11.11 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.10.0.0 0.0.255.255
[PE2-ospf-1] quit
# Configure a route policy.
[PE2] route-policy map1 permit node 10
[PE2-route-policy] apply mpls-label
[PE2-route-policy] quit
[PE2] route-policy map2 permit node 10
[PE2-route-policy] if-match mpls-label
3.      Configure PE 3:
<PE3> system-view
[PE3] mpls
[PE3-mpls] quit
[PE3] mpls ldp
[PE3-mpls-ldp] quit
[PE3] interface GigabitEthernet 4/1/1
[PE3-GigabitEthernet4/1/1] ip address 10.10.2.1 24
[PE3-GigabitEthernet4/1/1] pim sm
[PE3-GigabitEthernet4/1/1] mpls
[PE3-GigabitEthernet4/1/1] mpls ldp
[PE3-GigabitEthernet4/1/1] quit
[PE3] interface GigabitEthernet 4/1/2
[PE3-GigabitEthernet4/1/2] ip address 192.168.1.2 24
[PE3-GigabitEthernet4/1/2] pim sm
[PE3-GigabitEthernet4/1/2] mpls
[PE3-GigabitEthernet4/1/2] quit
[PE3-LoopBack1] pim sm
[PE3-LoopBack2] ip address 22.22.22.22 32
[PE3] pim
[PE3-pim] c-bsr loopback 2
[PE3-pim] c-rp loopback 2
[PE3-pim] quit
[PE3-GigabitEthernet4/1/2] pim bsr-boundary
[PE3] msdp
[PE3-msdp] encap-data-enable
[PE3-msdp] peer 1.1.1.2 connect-interface loopback 1
[PE3] ip route-static 1.1.1.2 32 GigabitEthernet 4/1/2 192.168.1.1
# Configure BGP.
[PE3] bgp 200
[PE3-bgp] import-route ospf 1
[PE3-bgp] group pe3-pe4 internal
[PE3-bgp] peer pe3-pe4 route-policy map2 export
[PE3-bgp] peer pe3-pe4 label-route-capability
[PE3-bgp] peer pe3-pe4 connect-interface loopback 1
[PE3-bgp] peer 1.1.1.4 group pe3-pe4
[PE3-bgp] group pe3-pe2 external
[PE3-bgp] peer pe3-pe2 as-number 100
[PE3-bgp] peer pe3-pe2 route-policy map1 export
[PE3-bgp] peer pe3-pe2 label-route-capability
[PE3-bgp] peer pe3-pe2 connect-interface loopback 1
[PE3-bgp] peer 1.1.1.2 group pe3-pe2
[PE3–bgp] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1-area-0.0.0.0] network 22.22.22.22 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 10.10.0.0 0.0.255.255
[PE3-ospf-1] quit
[PE3] route-policy map1 permit node 10
[PE3-route-policy] apply mpls-label
[PE3-route-policy] quit
[PE3] route-policy map2 permit node 10
[PE3-route-policy] if-match mpls-label
4.      Configure PE 4:
<PE4> system-view
[PE4] router id 1.1.1.4
[PE4] multicast routing-enable
[PE4] mpls lsr-id 1.1.1.4
[PE4] mpls
[PE4-mpls] quit
[PE4] mpls ldp
[PE4-mpls-ldp] quit
[PE4] ip vpn-instance a
[PE4-vpn-instance-a] route-distinguisher 100:1
[PE4-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE4-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE4-vpn-instance-a] multicast routing-enable
[PE4-vpn-instance-a] multicast-domain share-group 239.1.1.1 binding mtunnel 0
[PE4-vpn-instance-a] multicast-domain switch-group-pool 225.1.1.0 28
[PE4-vpn-instance-a] quit
[PE4] ip vpn-instance b
[PE4-vpn-instance-b] route-distinguisher 200:1
[PE4-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE4-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE4-vpn-instance-b] multicast routing-enable
[PE4-vpn-instance-b] multicast-domain share-group 239.4.4.4 binding mtunnel 1
[PE4-vpn-instance-b] multicast-domain switch-group-pool 225.4.4.0 28
[PE4-vpn-instance-b] quit
[PE4] interface GigabitEthernet 4/1/1
[PE4-GigabitEthernet4/1/1] ip address 10.10.2.2 24
[PE4-GigabitEthernet4/1/1] pim sm
[PE4-GigabitEthernet4/1/1] mpls
[PE4-GigabitEthernet4/1/1] mpls ldp
[PE4-GigabitEthernet4/1/1] quit
[PE4] interface GigabitEthernet 4/1/2
[PE4-GigabitEthernet4/1/2] ip binding vpn-instance a
[PE4-GigabitEthernet4/1/2] ip address 10.11.3.1 24
[PE4-GigabitEthernet4/1/2] pim sm
[PE4-GigabitEthernet4/1/2] quit
[PE4] interface GigabitEthernet4/1/3
[PE4-GigabitEthernet4/1/3] ip binding vpn-instance b
[PE4-GigabitEthernet4/1/3] ip address 10.11.4.1 24
[PE4-GigabitEthernet4/1/3] pim sm
[PE4-GigabitEthernet4/1/3] quit
[PE4] interface loopback 1
[PE4-LoopBack1] ip address 1.1.1.4 32
[PE4-LoopBack1] pim sm
[PE4-LoopBack1] quit
# Configure BGP.
[PE4] bgp 200
[PE4-bgp] group pe4-pe3 internal
[PE4-bgp] peer pe4-pe3 label-route-capability
[PE4-bgp] peer pe4-pe3 connect-interface loopback 1
[PE4-bgp] peer 1.1.1.3 group pe4-pe3
[PE4-bgp] group pe4-pe1 external
[PE4-bgp] peer pe4-pe1 as-number 100
[PE4-bgp] peer pe4-pe1 ebgp-max-hop 255
[PE4-bgp] peer 1.1.1.1 group pe4-pe1
[PE4-bgp] peer pe4-pe1 connect-interface loopback 1
[PE4–bgp] ipv4-family vpn-instance a
[PE4-bgp-a] import-route ospf 2
[PE4-bgp-a] import-route direct
[PE4-bgp-a] quit
[PE4–bgp] ipv4-family vpn-instance b
[PE4-bgp-b] import-route ospf 3
[PE4-bgp-b] import-route direct
[PE4-bgp-b] quit
[PE4–bgp] ipv4-family vpnv4
[PE4–bgp-af-vpnv4] peer 1.1.1.1 enable
[PE4–bgp-af-vpnv4] quit
[PE4–bgp] quit
With BGP peers configured on PE 4, the interfaces MTI 0 and MTI 1 will automatically obtain IP addresses, which are the loopback interface addresses specified in the BGP peer configuration. The PIM mode running on MTI 0 is the same as on the interfaces in VPN instance a, and the PIM mode running on MTI 1 is the same as on the interfaces in VPN instance b.
# Configure OSPF.
[PE4] ospf 1
[PE4-ospf-1] area 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 1.1.1.4 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 10.10.0.0 0.0.255.255
[PE4-ospf-1-area-0.0.0.0] quit
[PE4-ospf-1] quit
[PE4] ospf 2 vpn-instance a
[PE4-ospf-2] import-route bgp
[PE4-ospf-2] area 0.0.0.0
[PE4-ospf-2-area-0.0.0.0] network 10.11.0.0 0.0.255.255
[PE4-ospf-2-area-0.0.0.0] quit
[PE4-ospf-2] quit
[PE4] ospf 3 vpn-instance b
[PE4-ospf-3] import-route bgp
[PE4-ospf-3] area 0.0.0.0
[PE4-ospf-3-area-0.0.0.0] network 10.11.0.0 0.0.255.255
[PE4-ospf-3-area-0.0.0.0] quit
[PE4-ospf-3] quit
5.      Configure CE a1:
<CEa1> system-view
# Assign an IP address and enable PIM-SM on GigabitEthernet 4/1/1.
[CEa1] interface GigabitEthernet 4/1/1
[CEa1-GigabitEthernet4/1/1] ip address 10.11.5.1 24
[CEa1-GigabitEthernet4/1/1] pim sm
[CEa1-GigabitEthernet4/1/1] quit
# Assign an IP address and enable PIM-SM on GigabitEthernet 4/1/2.
[CEa1] interface GigabitEthernet 4/1/2
[CEa1-GigabitEthernet4/1/2] ip address 10.11.1.2 24
[CEa1-GigabitEthernet4/1/2] pim sm
[CEa1-GigabitEthernet4/1/2] quit
[CEa1] interface loopback 1
[CEa1-LoopBack1] ip address 2.2.2.2 32
[CEa1-LoopBack1] pim sm
[CEa1-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP for VPN a.
[CEa1] pim
[CEa1-pim] c-bsr loopback 1
[CEa1-pim] c-rp loopback 1
[CEa1-pim] quit
[CEa1-pim-a] quit
# Configure OSPF.
[CEa1] ospf 1
[CEa1-ospf-1] area 0.0.0.0
[CEa1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[CEa1-ospf-1-area-0.0.0.0] network 10.11.0.0 0.0.255.255
[CEa1-ospf-1-area-0.0.0.0] quit
[CEa1-ospf-1] quit
6.      Configure CE b1:
<CEb1> system-view
[CEb1] interface GigabitEthernet 4/1/1
[CEb1-GigabitEthernet4/1/1] ip address 10.11.6.1 24
[CEb1-GigabitEthernet4/1/1] pim sm
[CEb1-GigabitEthernet4/1/1] quit
[CEb1] interface GigabitEthernet 4/1/2
[CEb1-GigabitEthernet4/1/2] ip address 10.11.2.2 24
[CEb1-GigabitEthernet4/1/2] pim sm
[CEb1-GigabitEthernet4/1/2] quit
# Configure OSPF.
[CEb1] ospf 1
[CEb1-ospf-1] area 0.0.0.0
[CEb1-ospf-1-area-0.0.0.0] network 10.11.0.0 0.0.255.255
[CEb1-ospf-1-area-0.0.0.0] quit
[CEb1-ospf-1] quit
7.      Configure CE a2:
<CEa2> system-view
# Assign an IP address and enable IGMP and PIM-SM on GigabitEthernet 4/1/1.
[CEa2] interface GigabitEthernet 4/1/1
[CEa2-GigabitEthernet4/1/1] ip address 10.11.7.1 24
[CEa2-GigabitEthernet4/1/1] igmp enable
[CEa2-GigabitEthernet4/1/1] pim sm
[CEa2-GigabitEthernet4/1/1] quit
[CEa2] interface GigabitEthernet 4/1/2
[CEa2-GigabitEthernet4/1/2] ip address 10.11.3.2 24
[CEa2-GigabitEthernet4/1/2] pim sm
[CEa2-GigabitEthernet4/1/2] quit
# Configure OSPF.
[CEa2] ospf 1
[CEa2-ospf-1] area 0.0.0.0
[CEa2-ospf-1-area-0.0.0.0] network 10.11.0.0 0.0.255.255
[CEa2-ospf-1-area-0.0.0.0] quit
[CEa2-ospf-1] quit
8.      Configure CE b2:
<CEb2> system-view
[CEb2] interface GigabitEthernet 4/1/1
[CEb2-GigabitEthernet4/1/1] ip address 10.11.8.1 24
[CEb2-GigabitEthernet4/1/1] igmp enable
[CEb2-GigabitEthernet4/1/1] pim sm
[CEb2-GigabitEthernet4/1/1] quit
[CEb2] interface GigabitEthernet 4/1/2
[CEb2-GigabitEthernet4/1/2] ip address 10.11.4.2 24
[CEb2-GigabitEthernet4/1/2] pim sm
[CEb2-GigabitEthernet4/1/2] quit
[CEb2] interface loopback 1
[CEb2-LoopBack1] ip address 3.3.3.3 32
[CEb2-LoopBack1] pim sm
[CEb2-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP for VPN b.
[CEb2] pim
[CEb2-pim] c-bsr loopback 1
[CEb2-pim] c-rp loopback 1
[CEb2-pim] quit
# Configure OSPF.
[CEb2] ospf 1
[CEb2-ospf-1] area 0.0.0.0
[CEb2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[CEb2-ospf-1-area-0.0.0.0] network 10.11.0.0 0.0.255.255
[CEb2-ospf-1-area-0.0.0.0] quit
[CEb2-ospf-1] quit
9.      Verify the configuration:
# Display the local share-group information of VPN instance b on PE 1.
<PE1> display multicast-domain vpn-instance b share-group local
  Share-group: 239.4.4.4
# Display the local share-group information of VPN instance a on PE 4.
<PE4> display multicast-domain vpn-instance a share-group local
  MTunnel address: 1.1.1.4
# Display the local share-group information of VPN instance b on PE 4.
<PE4> display multicast-domain vpn-instance b share-group local
Troubleshooting MD-VPN
A share-MDT cannot be established
Symptom
A share-MDT cannot be established. PIM adjacencies cannot be established between the same VPN instance’s interfaces on different PE devices.
Analysis
·           On different PE devices, the same share-group must be configured for the same VPN instance. A share-group address uniquely identifies a share-MDT. If different share-group addresses have been configured for a VPN instance on different PE devices, a share-MDT cannot be established for that VPN instance on different PE devices.
·           The same PIM mode must run on all the interfaces of the same VPN instance on different PE devices and on all the interfaces of the P router. Otherwise, a share-MDT cannot be correctly built for the VPN instance and PIM adjacencies cannot be established between the VPN instance on the local PE device and the same VPN instance on the remote PE device.
·           BGP and unicast route configurations are prerequisites for the MTI interface to obtain an IP address automatically, and PIM is enabled on at least one interface of the VPN instance so that PIM can be enabled on the MTI interface. PIM adjacencies can be established between the same VPN instance on different PE devices only after the MTI interface obtains an IP address and gets PIM enabled.
Solution
1.      Use the display multicast-domain vpn-instance share-group command to verify that the same share-group address has been configured for the same VPN instance on different PE devices.
2.      Use the display pim interface command to verify that PIM is enabled on at least one interface of the same VPN on different PE devices and the same PIM mode is running on all the interfaces of the same VPN instance on different PE devices and on all the interfaces of the P router.
3.      Use the display ip routing-table command to verify that a unicast route exists from the VPN instance on the local PE device to the same VPN instance on each remote PE device.
4.      Use the display bgp peer command to verify that the BGP peer connections have been correctly configured.
An MVRF cannot be created
Symptom
A VPN instance cannot create an MVRF correctly.
Analysis
·           If PIM-SM is running in the VPN instance, the BSR information for the VPN instance is required. Otherwise, the VPN instance’s MVRF cannot be correctly established.
·           If PIM-SM is running in the VPN instance, the RP information for the VPN instance is required. If a unicast route to the RP is not available, this means that a PIM adjacency has not been correctly established between the public network and the VPN instance, and thus VPN instance cannot correctly establish its MVRF.
·           The customer DR must have a route to the VPN RP.
Solution
1.      Use the display pim bsr-info command to verify that the BSR information exists on the public network and VPN instance. If not, verify that a unicast route exists to the BSR.
2.      Use the display pim rp-info command to view the RP information. If no RP information is available, verify that a unicast route exists to the RP. Use the display pim neighbor command to verify that the PIM adjacencies have correctly established on the public network and the VPN.
3.      Use the ping command to check the connectivity between the VPN DR and the VPN RP.
