07-IP Multicast Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10307-IP Multicast Command Reference
13-IPv6 Multicast Routing and Forwarding Commands
display multicast ipv6 boundary
display multicast ipv6 boundary { group [ ipv6-group-address [ prefix-length ] ] | scope [ scope-id ] } [ | interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group: Displays the IPv6 multicast boundary information for the specified group.
ipv6-group-address: IPv6 multicast group address, in the range of FFxy::/16, where x and y represent any hexadecimal number from 0 through F.
prefix-length: Prefix length of an IPv6 multicast group address, in the range of 8 to 128. The system default is 128.
scope: Displays the IPv6 multicast group boundary information in the admin-scope zone.
scope-id: Specifies the ID of an admin-scope zone in the range of 3 to 15.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display multicast ipv6 boundary command to display the IPv6 multicast boundary information on the specified interface or all interfaces.
Related commands: multicast ipv6 boundary.
# Display the IPv6 multicast boundary information configured on all interfaces.
<Sysname> display multicast ipv6 boundary group
 Boundary            Interface
 FF03::/16           GE2/1/1
 FF09::/16           Pos2/1/2
Table 1 Output description
Boundary
IPv6 multicast group corresponding to the IPv6 multicast boundary
Boundary interface corresponding to the IPv6 multicast boundary
display multicast ipv6 forwarding-table
display multicast ipv6 forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { { exclude | include | match } { interface-type interface-number | register } } | statistics | slot slot-number ] * [ port-info ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-source-address: Displays the forwarding entries containing the specified IPv6 multicast source address.
ipv6-group-address: Displays the forwarding entries containing the specified IPv6 multicast group address, in the range of FFxy::/16, where x and y represent any hexadecimal number from 0 through F.
prefix-length: Prefix length of an IPv6 multicast group address or an IPv6 multicast source address. For an IPv6 multicast group address, this argument has an effective value range of 8 to 128; for an IPv6 multicast source address, this argument has an effective value range of 0 to 128. The system default is 128 in both cases.
incoming-interface: Displays the forwarding entries whose incoming interface is the specified one.
register: Displays the forwarding entries of which the incoming interface is the IPv6 PIM-SM registered interface.
outgoing-interface: Displays the forwarding entries whose outgoing interface is the specified one.
exclude: Displays the forwarding entries whose outgoing interface list excludes the specified interface.
include: Displays the forwarding entries whose outgoing interface list includes the specified interface.
match: Displays the forwarding entries whose outgoing interface list includes and includes only the specified interface.
statistics: Specifies to display the statistics information of the IPv6 multicast forwarding table.
slot slot-number: Specifies the slot number of an interface card. If you do not provide this option, the multicast forwarding table information of the switching and routing processing unit (SRPU) will be displayed.
port-info: Displays Layer 2 port information.
Use the display multicast ipv6 forwarding-table command to display information of an IPv6 multicast forwarding table.
IPv6 multicast forwarding tables are used to guide IPv6 multicast forwarding. You can view the forwarding state of IPv6 multicast traffic by checking the IPv6 multicast forwarding table.
Related commands: multicast ipv6 forwarding-table downstream-limit, multicast ipv6 forwarding-table route-limit, and display multicast ipv6 routing-table.
# Display information about an IPv6 multicast forwarding table.
<Sysname> display multicast ipv6 forwarding-table
IPv6 Multicast Forwarding Table
Total 1 entry
Total 1 entry matched
00001. (2000:5::1:1000, FF1E::1234)
     MID: 0, Flags: 0x100000:0
     Uptime: 04:04:37, Timeout in: 00:03:26
     Incoming interface: GigabitEthernet2/1/1
     List of 1 outgoing interfaces:
       1: GigabitEthernet2/1/2
     Matched 146754 packets(10272780 bytes), Wrong If 0 packets
     Forwarded 139571 packets(9769970 bytes)
Table 2 Output description
Total 1 entry
Total number of (S, G) entries in the IPv6 multicast forwarding table.
Total number of matched (S, G) entries in the IPv6 multicast forwarding table.
00001
Sequence number of the (S, G) entry.
An (S, G) entry in the IPv6 multicast forwarding table.
MID
MID of the (S, G). Each (S, G) entry has a unique MID.
Flags
Current state of the (S, G) entry. Different bits are used to indicate different states of the (S, G) entry. For the values and meanings of this field, see Table 3.
Uptime
Length of time for which the (S, G) entry has been up.
Timeout in
Length of time in which the (S, G) entry will time out.
Incoming interface
Name of the incoming interface of the (S, G) entry.
One outgoing interface list:
Interface number: interface type and number.
(S, G)-matched packets (bytes), packets with incoming interface errors.
(S, G) forwarded IPv6 multicast packets (bytes).
Table 3 Values and meanings of the Flags field
Value
Meaning
0x00000001
Indicates that a register-stop message needs to be sent.
0x00000002
Indicates whether the IPv6 multicast source corresponding to the (S, G) entry is active.
0x00000004
Indicates a null forwarding entry.
0x00000008
Indicates whether the RP is a border router in an IPv6 PIM domain.
0x00000010
Indicates a register outgoing interface is available.
0x00000400
Indicates an (S, G) entry to be deleted.
0x00008000
Indicates that the (S, G) entry is in smoothening process after active/standby switchover.
0x00010000
Indicates that the (S, G) entry has been updated during the smoothening process.
0x00080000
Indicates that the (S, G) entry has been repeatedly updated and need to be deleted before a new entry is added.
0x00100000
Indicates that the (S, G) entry was added successfully
0x01000000
Indicates a multicast forwarding entry for IPv6 BIDIR-PIM
0x02000000
Indicates the RP for IPv6 BIDIR-PIM
display multicast ipv6 forwarding-table df-info
display multicast ipv6 forwarding-table df-info [ rp-address ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
rp-address: RP address of IPv6 BIDIR-PIM.
slot slot-number: Displays the DF information of the IPv6 multicast forwarding table for the card specified by its slot number. If no slot is specified, the command displays the DF information of the IPv6 multicast forwarding table for the main processing board.
exclude: Displays the lines that do not match the specified regular expression.
Use the display multicast ipv6 forwarding-table df-info command to display the DF information of the IPv6 multicast forwarding table.
# Display the DF information of the IPv6 multicast forwarding table.
<Sysname> display multicast ipv6 forwarding-table df-info
IPv6 Multicast DF information
Total 1 RP
Total 1 RP matched
00001. RP Address: 2010::1
     MID: 0, Flags: 0x2100000:0
     Uptime: 00:08:32
     RPF interface: GigabitEthernet3/1/1
     List of 1 DF interfaces:
       1: GigabitEthernet3/1/2
Table 4 Output description
Total 1 RP
Total number of RPs.
Total 1 RP matched
Total number of matched RPs.
00001
Sequence number of the RP.
MID
ID of the RP. Each RP has a unique MID.
Flags
Current state of the RP. Different bits are used to indicate different states of an RP. Major values of this field are described in Table 3.
Uptime
Length of time for which the RP has been up, in hours:minutes:seconds.
RPF interface
RPF interface to the RP.
DF interface list.
display multicast ipv6 routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { { exclude | include | match } { interface-type interface-number | register } } ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-source-address: Displays multicast routing entries containing the specified IPv6 multicast source address.
ipv6-group-address: Displays multicast routing entries containing the specified IPv6 multicast group address, in the range of FFxy::/16, where x and y represent any hexadecimal number from 0 through F.
prefix-length: Prefix length of a multicast group address or an IPv6 multicast source address. For an IPv6 multicast group address, this argument has an effective value range of 8 to 128; for an IPv6 multicast source address, this argument has an effective value range of 0 to 128. The system default is 128 in both cases.
incoming-interface: Displays routing entries whose incoming interface is the specified one.
interface-type interface-number: Specifies an interface by its name and number.
register: Displays multicast routing entries whose incoming interface is the IPv6 PIM-SM register interface.
outgoing-interface: Displays routing entries of which the outgoing interface is the specified one.
exclude: Displays routing entries whose outgoing interface list excludes the specified interface.
include: Displays routing entries whose outgoing interface list includes the specified interface.
match: Displays routing entries whose outgoing interface list includes only the specified interface.
Use the display multicast ipv6 routing-table command to display the information of an IPv6 multicast routing table.
IPv6 multicast routing tables are the basis of IPv6 multicast forwarding. You can view the establishment state of an (S, G) entry by checking the multicast routing table.
Related commands: display multicast ipv6 forwarding-table.
# Display the information of an IPv6 multicast routing table.
<Sysname> display multicast ipv6 routing-table
 Total 1 entry
 00001. (2001::2, FFE3::101)
       Uptime: 00:00:14
       Upstream Interface: GigabitEthernet2/1/1
       List of 1 downstream interface
Table 5 Output description
Total 1 entry
Total number of (S, G) entries in the IPv6 multicast routing table.
00001
Uptime
Upstream interface
Name of the upstream interface of the (S, G) entry. Multicast packets should arrive through this interface.
List of 2 downstream interfaces
Downstream interface list. These interfaces need to forward multicast packets.
display multicast ipv6 rpf-info
display multicast ipv6 rpf-info ipv6-source-address [ ipv6-group-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-source-address: IPv6 multicast source address.
ipv6-group-address: IPv6 multicast group address, in the range of FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where x and y represent any hexadecimal number from 0 to F.
Use the display multicast ipv6 rpf-info command to display RPF information of an IPv6 multicast source.
Related commands: display multicast ipv6 routing-table and display multicast ipv6 forwarding-table.
# Display all RPF information of the multicast source with an IPv6 address 2001::101.
<Sysname> display multicast ipv6 rpf-info 2001::101
 RPF information about source 2001::101:
VPN instance: public net
     RPF interface: GigabitEthernet3/1/1, RPF neighbor: 2002::201
     Referenced prefix/prefix length: 2001::/64
     Referenced route type: igp
     Load splitting rule: disable
Table 6 Output description
RPF information of the IPv6 multicast source 2001::101.
RPF interface
Name of the RPF interface.
RPF neighbor
Indicate the IPv6 address of the RPF neighbor.
Referenced route and prefix length.
Type of the referenced route, which can be any of the following:
·       igp—IPv6 unicast route (IGP).
·       egp—IPv6 unicast (EGP).
·       unicast (direct)—IPv6 unicast route (directly connected).
·       unicast—Other IPv6 unicast route (such as IPv6 unicast static route).
·       mbgp—IPv6 MBGP route.
RPF route selection rule: An RPF route can be selected by the priority of the routing protocol or by the longest match of the destination address in the routing table.
Load splitting rule
Load sharing rule.
multicast ipv6 boundary { ipv6-group-address prefix-length | scope { scope-id | admin-local | global | organization-local | site-local } }
undo multicast ipv6 boundary { ipv6-group-address prefix-length | scope { scope-id | admin-local | global | organization-local | site-local } | all }
View
Interface view
Default level
2: System level
scope-id: Specifies the ID of an admin-scope zone in the range 3 to 15, which is identified by the scope field in the IPv6 multicast group address,.
admin-local: Specifies the scope zone as admin-local, which has a scope ID of 4.
global: Specifies the scope zone as global, which has a scope ID of 14.
organization-local: Specifies the scope zone as organization-local, which has a scope ID of 8.
site-local: Specifies the scope zone as site-local, which has a scope ID of 5.
all: Deletes all IPv6 multicast boundaries configured on the interface.
Use the multicast ipv6 boundary command to configure an IPv6 multicast forwarding boundary.
Use the undo multicast ipv6 boundary command to delete the specified IPv6 multicast forwarding boundary or all IPv6 multicast forwarding boundaries.
By default, no multicast forwarding boundary is configured.
A multicast forwarding boundary sets the boundary condition for the IPv6 multicast groups in the specified address range. If the destination address of an IPv6 multicast packet matches the set boundary condition, the packet will not be forwarded.
An interface can act as a forwarding boundary for multiple IPv6 multicast groups in different address ranges. This is implemented by carrying out this command on the interface for each multicast address range. Note that these multicast groups must in the same scope. The latest configuration of a scope overwrites the previous one.
Assume that Set A and Set B are both multicast forwarding boundary sets with different address ranges, and that B is a subset of A. If B is configured after A, A still takes effect. If A is configured after B, B is removed.
Related commands: display multicast ipv6 boundary.
# Configure GigabitEthernet 3/1/1 to be the forwarding boundary of the IPv6 multicast group FF03::/16.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] multicast ipv6 boundary FF03:: 16
# Configure GigabitEthernet 3/1/1 to be the forwarding boundary of the IPv6 multicast groups in the admin-local scope 4.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] multicast ipv6 boundary scope 4
multicast ipv6 forwarding on-demand
undo multicast ipv6 forwarding on-demand
View
VLAN view
Default level
2: System level
None
Use the multicast ipv6 forwarding on-demand command to enable the IPv6 multicast forwarding on-demand function in the VLAN.
Use the undo multicast ipv6 forwarding on-demand command to restore the default.
By default, IPv6 multicast forwarding on-demand is disabled.
After using this command in an IPv6 multicast VLAN, you must clear all the MLD snooping multicast group information in the VLAN. Otherwise, this configuration cannot take effect.
After using this command in a non-multicast VLAN with a Layer 3 multicast protocol (MLD or IPv6 PIM) enabled on the corresponding VLAN interface, you must clear the Layer 2 port information of all MLD multicast groups in the VLAN and the MLD multicast group information on the corresponding VLAN interface. Otherwise, this configuration cannot take effect.
This command cannot take effect in an IPv6 multicast VLAN with MLD snooping enabled in the VLAN.
Related commands: mld-snooping enable, reset mld group, reset mld group port-info, and reset mld-snooping group.
# Enable IPv6 multicast forwarding on-demand in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] multicast ipv6 forwarding on-demand
multicast ipv6 forwarding-table downstream-limit limit
undo multicast ipv6 forwarding-table downstream-limit
View
Default level
2: System level
limit: Maximum number of downstream nodes for a single route in the IPv6 multicast forwarding table. The value ranges 0 to 128.
Use the multicast ipv6 forwarding-table downstream-limit command to configure the maximum number of downstream nodes for a single route in the IPv6 multicast forwarding table.
Use the undo multicast ipv6 forwarding-table downstream-limit command to restore the default.
By default, the upper limit is 128.
# Set the maximum number of downstream nodes for a single route in the IPv6 multicast forwarding table to 120.
[Sysname] multicast ipv6 forwarding-table downstream-limit 120
multicast ipv6 forwarding-table route-limit limit
undo multicast ipv6 forwarding-table route-limit
View
Default level
2: System level
limit: Maximum number of entries in the IPv6 multicast forwarding table. The value ranges from 0 to 1024.
Use the multicast ipv6 forwarding-table route-limit command to configure the maximum number of IPv6 multicast forwarding table entries.
Use the undo multicast ipv6 forwarding-table route-limit command to restore the default.
By default, the upper limit is 1024.
# Set the maximum number of entries in the IPv6 multicast forwarding table to 200.
[Sysname] multicast ipv6 forwarding-table route-limit 200
multicast ipv6 load-splitting
multicast ipv6 load-splitting {source | source-group }
undo multicast ipv6 load-splitting
View
Default level
2: System level
source: Specifies to implement IPv6 multicast load splitting on a per-source basis.
source-group: Specifies to implement IPv6 multicast load splitting on a per-source and per-group basis.
Use the multicast load-splitting command to enable load splitting of IPv6 multicast traffic.
Use the undo multicast load-splitting command to disable load splitting of IPv6 multicast traffic.
By default, load splitting of IPv6 multicast traffic is disabled.
# Enable load splitting of IPv6 multicast traffic on a per-source basis.
[Sysname] multicast ipv6 load-splitting source
multicast ipv6 longest-match
undo multicast ipv6 longest-match
View
Default level
2: System level
None
Use the multicast ipv6 longest-match command to configure RPF route selection based on the longest match, namely to select the route with the longest prefix.
Use the undo multicast ipv6 longest-match command to restore the default.
By default, the route with the highest priority is selected as the RPF route.
# Configure RPF route selection based on the longest match.
[Sysname] multicast ipv6 longest-match
multicast ipv6 routing-enable
undo multicast ipv6 routing-enable
View
Default level
2: System level
None
Use the multicast ipv6 routing-enable command to enable IPv6 multicast routing.
Use the undo multicast ipv6 routing-enable command to disable IPv6 multicast routing.
IPv6 multicast routing is disabled by default.
You must enable IPv6 multicast routing before you can execute other Layer 3 IPv6 multicast commands.
The device does not forward any IPv6 multicast packets before IPv6 multicast routing is enabled.
# Enable IPv6 multicast routing.
[Sysname] multicast ipv6 routing-enable
multicast ipv6 rpf-fail-pkt bridging
undo multicast ipv6 rpf-fail-pkt bridging
View
Default level
2: System level
None
Use the multicast ipv6 rpf-fail-pkt bridging command to enable forwarding IPv6 multicast data packets that have failed an RPF check in all VLANs or the current VLAN.
Use the undo multicast ipv6 rpf-fail-pkt bridging command to restore the default.
By default, this function is disabled.
After using this command, you must clear all the entries in the IPv6 multicast forwarding table; otherwise this configuration cannot take effect.
Related commands: reset multicast ipv6 forwarding-table.
# Configure the device to forward IPv6 multicast packets that have failed an RPF check in all VLANs.
[Sysname] multicast ipv6 rpf-fail-pkt bridging
multicast ipv6 rpf-fail-pkt trap-to-cpu
undo multicast ipv6 rpf-fail-pkt trap-to-cpu
View
Default level
2: System level
None
Use the multicast ipv6 rpf-fail-pkt trap-to-cpu command to enable sending IPv6 multicast data packets that have failed an RPF check to the CPU.
Use the undo multicast ipv6 rpf-fail-pkt trap-to-cpu command to restore the default.
# Configure the device to send IPv6 multicast data packets that have failed an RPF check to the CPU.
[Sysname] multicast ipv6 rpf-fail-pkt trap-to-cpu
reset multicast ipv6 forwarding-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number | register } } * | all }
View
Default level
2: System level
ipv6-source-address: Clears multicast forwarding entries containing the specified IPv6 multicast source address.
ipv6-group-address: Clears multicast forwarding entries containing the specified IPv6 multicast group address, in the range of FFxy::/16, where x and y represent any hexadecimal number from 0 to F.
prefix-length: Prefix length of an IPv6 multicast group or an IPv6 multicast source address. For an IPv6 multicast group address, this argument has an effective value range of 8 to 128; for an IPv6 multicast source address, this argument has an effective value range of 0 to 128. The system default is 128 in both cases.
incoming-interface: Clears IPv6 multicast forwarding entries of which the incoming interface is the specified one.
register: Clears IPv6 multicast forwarding entries of which the incoming interface is the IPv6 PIM-SM register interface.
all: Clears all forwarding entries from the IPv6 multicast forwarding table.
Use the reset multicast ipv6 forwarding-table command to clear forwarding entries from the IPv6 multicast forwarding table.
When a forwarding entry is deleted from the IPv6 multicast forwarding table, the corresponding routing entry is also deleted from the IPv6 multicast routing table.
Related commands: display multicast ipv6 forwarding-table, display multicast ipv6 routing-table, and reset multicast IPv6 routing-table.
# Clear the IPv6 multicast forwarding entries related to the IPv6 multicast group FF03::101 from the IPv6 multicast forwarding table.
<Sysname> reset multicast ipv6 forwarding-table ff03::101
reset multicast ipv6 routing-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number | register } } * | all }
View
Default level
2: System level
ipv6-source-address: Clears IPv6 multicast routing entries containing the specified IPv6 multicast source address.
ipv6-group-address: Clears IPv6 multicast routing entries containing the specified IPv6 multicast group address, in the range of FFxy::/16, where x and y represent any hexadecimal number from 0 to F.
incoming-interface: Clears IPv6 multicast routing entries of which the incoming interface is the specified one.
register: Clears IPv6 multicast routing entries of which the incoming interface is the IPv6 PIM-SM register interface.
all: Clears all routing entries from the IPv6 multicast routing table.
Use the reset multicast ipv6 routing-table command to clear IPv6 routing entries from the IPv6 multicast routing table.
When a routing entry is deleted from the IPv6 multicast routing table, the corresponding forwarding entry is also deleted from the IPv6 multicast forwarding table.
Related commands: display multicast ipv6 forwarding-table, display multicast ipv6 routing-table, and reset multicast ipv6 forwarding-table.
# Clear the routing entries related to the IPv6 multicast group FF03::101 from the IPv6 multicast routing table.
<Sysname> reset multicast ipv6 routing-table ff03::101
