07-IP Multicast Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10307-IP Multicast Command Reference
09-Multicast VPN Commands
09-Multicast VPN Commands 150.04 KB
display bgp mdt group
display bgp mdt group [ group-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-name: Displays the information of the specified BGP MDT peer group. A group name is a case-sensitive string of 1 to 47 characters and must not contain any space.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display bgp mdt group command to display the information of a BGP MDT peer group.
# Display the information of the BGP MDT peer group test.
<Sysname> display bgp mdt group test
 BGP peer-group is test
 Remote AS 2004
 Type : external
 Threshold: 75%
 Configured hold timer value: 180
 Keepalive timer value: 60
 Minimum time between advertisement runs is 30 seconds
 Connect-interface has been configured
 Multi-hop ebgp been enabled
 Peer Preferred Value: 0
  Members:
  Peer                    AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  2.2.2.1               2004        0        0     0       0 00:01:21 Active
Table 1 Output description
BGP peer-group
BGP peer group name
Remote AS
AS number of the peer group
Type of the peer group:
·       external: EBGP peer group
·       internal: IBGP peer group
Maximum number of allowed prefixes
Threshold
Percentage of received prefixes from the peer group to maximum prefixes allowed to receive from the peer group
Holdtime interval
Keepalive interval
Minimum route advertisement interval
The source interface for TCP connection is configured.
The hop count of the peer’s TCP connection can exceed 1 but cannot exceed the configured limit.
Preferred value specified for the routes from the peer
Members
Detailed information of the members in the peer group
Peer
IP address of the peer
AS
MsgRcvd
Number of received messages
MsgSent
Number of sent messages
OutQ
Number of messages to be sent
PrefRcv
Number of received prefixes
Up/Down
Length of time since the session was established/time elapsed in the current state (before the session is established)
State of the peer:
·       Active: Waiting for reestablishing a TCP connection after a establishment failure
·       Connect: A TCP connection is required but not established yet
·       Established: A TCP connection is established
·       Idle: No TCP connections are required after the peer relationship is configured
·       Idle(Admin): The peer is configured at the CLI not to require any TCP connection
·       Openconfirm: Waiting for the keepalive message after receiving an open message
·       Opensent: An open message is successfully sent to the peer
display bgp mdt peer
display bgp mdt peer [ [ ip-address ] verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Displays the information of the specified BGP MDT peer.
verbose: Displays detailed information.
Use the display bgp mdt peer command to display BGP MDT peer information.
# Display the detailed information of the BGP MDT peer 2.2.2.1.
<Sysname> display bgp mdt peer 2.2.2.1 verbose
         Peer: 2.2.2.1   Local: 2.2.2.2
         Type: IBGP link
         BGP version 4, remote router ID 1.1.1.1
         BGP current state: Established, Up for 00h01m51s
         BGP current event: RecvKeepalive
         BGP last state: OpenConfirm
         Port:  Local - 1029     Remote - 179
         Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time:60 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Address family IPv4 Unicast: advertised and received
         Address family IPv4 MDT: advertised and received
 Received: Total 5 messages, Update messages 1
 Sent: Total 4 messages, Update messages 0
 Threshold: 75%
 Optional capabilities:
 Routing policy configured:
Table 2 Output description
Peer
Local
Local router ID
Peer types
·       IBGP link, indicating IBGP peers
·       EBGP link, indicating EBGP peers
remote router ID
Router ID of the peer
BGP current state
Current state of the BGP peer:
·       Active: Waiting for reestablishing a TCP connection after a establishment failure.
·       Connect: A TCP connection is required but not established yet.
·       Established: A TCP connection is established between peers.
·       Idle: No TCP connections are required after the peer relationship is configured.
·       Idle(Admin): The peer is configured at the CLI not to require any TCP connection.
·       Openconfirm: Waiting for the keepalive message after receiving an open message.
·       Opensent: An open message is successfully sent to the peer.
BGP current event
Current event of the peer:
·       AdvTimerExpired: The route advertisement timer expires.
·       ConnCloesed: The TCP connection is closed.
·       ConnOpen: A TCP connection is required.
·       ConnOpenFailed: Fail to establish a TCP connection.
·       CRTTimerExpired: The connect timer expires.
·       HOLDTimerExpired: The holdtime timer expires.
·       KATTimerExpired: The keepalive timer expires.
·       RecvKeepalive: A keepalive message is received from the peer.
·       RecvNotification: A notification message is received from the peer.
·       RecvOpen: An open message is received from the peer.
·       RecvRouteRefresh: A route-refresh message is received from the peer.
·       RecvUpdate: An update message is received from the peer.
·       Start: No TCP connections are required after the peer relationship is configured.
·       Stop: The peer is configured not to require any TCP connection at the CLI.
·       TransFatalError: A fatal mistake occurs during the establishment of the TCP connection.
BGP last state
Previous state of the peer:
·       Active: Waiting for reestablishing a TCP connection after an establishment failure.
Port
Local and remote TCP port numbers for establishing a TCP connection
Configured
Locally configured timer value:
·       Active Hold Time: The holdtime interval for the connection to the peer
·       Keepalive Time: The keepalive interval for the connection to the peer
Received
Received timer settings on the peer:
Negotiated
Negotiated timer settings:
Optional capabilities supported by the peer
The peer supports multiprotocol BGP extensions.
The peer supports the BGP route refresh function.
Routes are advertised and received in IPv4 unicasts.
Routes are advertised and received in IPv4 multicasts.
Received
Total numbers of received packets and updates
Sent
Total numbers of sent packets and updates
Threshold
Optional capabilities enabled by the peer
Local route policy
display bgp mdt routing-table
display bgp mdt { all | route-distinguisher route-distinguisher } routing-table [ ip-address [ mask | mask-length ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays the information of all the BGP MDT routes.
route-distinguisher route-distinguisher: Displays the BGP MDT routing information of the specified route distinguisher. route-distinguisher identifies the route distinguisher name, a string of 3 to 21 characters in the form of nn:nn or IP-address:nn.
ip-address: Destination IP address.
mask: Network mask, 225.225.225.225 by default.
mask-length: Mask length, in the range 0 to 32. The default is 32.
Use the display bgp mdt all routing-table command to display the BGP MDT routing information.
# Display all the BGP MDT routing information.
<Sysname> display bgp mdt all routing-table
 BGP Local router ID is 2.2.2.2
 Status codes: * - valid, ^ - VPNv4 best, > - best, d - damped,
                  h - history,  i - internal, s - suppressed, S - Stale
                  Origin : i - IGP, e - EGP, ? - incomplete
 Total number of MDT routes: 1
 Route Distinguisher: 100:1
     Network            NextHop         MED        LocPrf     PrefVal Path/Ogn
 *>  1.1.1.1/32         3.3.3.3         0          100        10      ?
Table 3 Output description
Status codes
Status codes:
·       * – valid
·       ^ - VPNv4 best
·       > – best
·       d – damped
·       h – history
·       i – internal
·       s – suppressed
·       S – Stale
Origin
·       i – IGP (originated in the AS)
·       e – EGP (learned through EGP)
·       ? – incomplete (learned by some other means)
Network
MD source address displayed in the BGP routing table
NextHop
Next hop
MED
Metric associated with the destination network
LocPrf
Local preference value
PrefVal
Preferred value of the route
Path
AS_PATH attribute, recording the ASs the packet has passed to avoid routing loops
Ogn
Origin attribute of the route, which can be one of the following values:
·       i: Indicates that the route is interior to the AS. Aggregate routes and the routes injected with the network command are considered IGP routes.
·       e: Indicates that the route is learned from the Exterior Gateway Protocol (EGP).
·       ?: Indicates that the origin of the route is unknown, such as the MDT routes redistributed from other routing protocols.
display multicast-domain vpn-instance share-group
display multicast-domain vpn-instance vpn-instance-name share-group { local | remote } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance-name: Name of an MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters.
local: Displays the local share-group information.
remote: Displays the remote share-group information.
Use the display multicast-domain vpn-instance share-group command to display the share-group information of the specified VPN instance in the MD.
# Display the local share-group information of VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn share-group local
MD local share-group information for VPN-Instance: mvpn
  Share-group: 225.2.2.2
  MTunnel address: 1.1.1.1
# Display the remote share-group information of VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn share-group remote
MD remote share-group information for VPN-Instance: mvpn
  Route-Distinguisher    Router-ID        Share-Group      Next-Hop
  1:1                        2.2.2.2          225.2.2.2        10.1.1.1
Table 4 Output description
Local share-group information of VPN instance mvpn
Remote share-group information of VPN instance mvpn
Share-group
Share-group address
MTunnel address
MTI address associated with the share-group address
Router-ID
Router ID of the peer that sends the route information
Next-Hop
IP address of the next hop
display multicast-domain vpn-instance switch-group receive
display multicast-domain vpn-instance vpn-instance-name switch-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
brief: Displays the brief switch-group information received by the specified VPN instance.
active: Displays the received switch-group information about active multicast domains.
group-address: Public network multicast group address, in the range of 224.0.1.0 to 239.255.255.255.
source-address: Public network multicast source address.
vpn-source-address: VPN multicast source address.
mask: Subnet mask of the specified VPN multicast source/group address, 255.255.255.255 by default.
mask-length: Mask length of the specified multicast source/group address, in the range of 0 to 32. The system default is 32.
vpn-group-address: VPN multicast group address, in the range of 224.0.0.0 to 239.255.255.255.
Use the display multicast-domain vpn-instance switch-group receive command to display the switch-group information received by the specified VPN instance in the MD.
Related commands: display multicast-domain vpn-instance switch-group send.
# Display the switch-group information received by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn switch-group receive
MD switch-group information received by VPN-Instance: mvpn
Total 2 switch-groups for 8 entries
Total 2 switch-groups for 8 entries matched
switch group:  226.1.1.0 ref count: 4, active count: 2
  sender:  172.100.1.1 active count: 1
    (192.6.1.5, 239.1.1.1)       expire time: 00:03:10  active
    (192.6.1.5, 239.1.1.158)     expire time: 00:03:10
  sender:  181.100.1.1 active count: 1
    (195.6.1.2, 239.1.2.12)      expire time: 00:03:10 active
    (195.6.1.2, 239.1.2.197)     expire time: 00:03:10
switch group:  229.1.1.0 ref count: 4, active count: 2
  sender:  185.100.1.1 active count: 1
    (198.6.1.5, 239.1.3.62)      expire time: 00:03:10 active
    (198.6.1.5, 225.1.1.109)     expire time: 00:03:10
  sender:  190.100.1.1 active count: 1
    (200.6.1.2, 225.1.4.80)      expire time: 00:03:10 active
    (200.6.1.2, 225.1.4.173)     expire time: 00:03:10
# Display the brief switch-group information received by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn switch-group receive brief
Table 5 Output description
MD switch group information received by VPN-Instance: mvpn
Switch-group information received by VPN instance mvpn
Totally two switch-groups, corresponding to eight (S, G) entries
Totally two switch-groups are matched, corresponding to eight (S, G) entries
switch group
Switch-group address received
sender
BGP peer address of the PE device that sent the switch-group information
ref count
Number of VPN multicast groups referenced by the switch-group
active count
Number of active VPN multicast groups (multicast groups with active receivers) referenced by the switch-group
expire time
Remaining time of the VPN (S, G) entry referenced by the switch-group
display multicast-domain vpn-instance vpn-instance-name switch-group send [ group group-address | reuse interval | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Multicast group address, in the range of 224.0.1.0 to 239.255.255.255.
reuse interval: Displays the information about switch-group reuses that took place during the specified length of time in seconds. The value range of interval is 1 to 2147483647.
Use the display multicast-domain vpn-instance switch-group send command to display the switch-group information sent by the specified VPN instance in the MD.
Related commands: display multicast-domain vpn-instance switch-group receive.
# Display the switch-group information sent by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn switch-group send
MD switch-group information sent by VPN-Instance: mvpn
Total 2 switch-groups for 6 entries
Total 2 switch-groups for 6 entries matched
  226.1.1.0 reference_count: 3
    (192.6.1.5, 239.1.1.1)                  switch time: 00:00:21
    (192.6.1.5, 239.1.1.158)                switch time: 00:00:21
    (192.6.1.5, 239.1.2.50)                 switch time: 00:00:05
  226.1.1.1 reference_count: 3
    (192.6.1.2, 225.1.1.1)                  switch time: 00:00:21
    (192.6.1.2, 225.1.2.50)                 switch time: 00:00:05
    (192.6.1.5, 239.1.1.159)                switch time: 00:00:21
# Display the switch-group reuse information sent by VPN instance mvpn during 30 seconds in the MD.
<Sysname> display multicast-domain vpn-instance mvpn switch-group send reuse 30
Total 2 switch-groups for 3 entries
Total 2 switch-groups for 3 entries matched
  226.1.1.0 reuse_count: 1
  226.1.1.1 reuse_count: 1
  226.1.1.2 reuse_count: 1
Table 6 Output description
Switch-group information sent by the VPN instance mvpn
Totally two switch-groups, corresponding to six (S, G) entries
Totally two switch-groups are matched, corresponding to six (S, G) entries
reference_count
Number of VPN multicast groups referenced by the sent switch-group
switch time
Switching time of the VPN (S, G) entry referenced by the switch-group
reuse_count
Number of switch-group reuses during the specified length of time
ipv4-family mdt
ipv4-family mdt
undo ipv4-family mdt
View
BGP view
Default level
2: System level
None
Use the ipv4-family mdt command to enter BGP-MDT sub-address family view.
Use the undo ipv4-family mdt command to remove all the settings made in BGP-MDT sub-address family view.
# Enter BGP-MDT sub-address family view.
[Sysname] bgp 100
[Sysname-bgp] ipv4-family mdt
[Sysname-bgp-af-mdt]
multicast-domain log switch-group-reuse
undo multicast-domain log
View
VPN instance view
Default level
2: System level
None
Use the multicast-domain log switch-group-reuse command to enable switch-group reuse logging.
Use the undo multicast-domain log switch-group-reuse command to disable switch-group reuse logging.
By default, switch-group reuse logging is disabled.
This command cannot be configured without the previous share-MDT configuration in the VPN instance.
# Enable switch-group reuse logging in VPN instance mvpn.
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] multicast-domain log switch-group-reuse
multicast-domain share-group
multicast-domain share-group group-address binding mtunnel mtunnel-number
undo multicast-domain share-group
View
VPN instance view
Default level
2: System level
mtunnel-number: Number of the MTI interface to be created, in the range of 0 to 1022.
Use the multicast-domain share-group command to configure a share-group address and associate an MTI with the current VPN instance.
Use the undo multicast-domain share-group command to restore the default.
By default, no share-group address is configured and no MTI is associated with a VPN instance.
To specify a multicast group address on the public network SSM group range as a share-group address, you must first configure BGP MDT peers or peer groups.
On the same PE device, different VPN instances must not have the same group addresses, and group-address must not coincide with the switch-group address of any VPN instance; in addition, mtunnel-number must not coincide with the number of any MTI already created.
This command must not be used repeatedly in the same VPN instance view. To configure a new group address and MTI for a VPN instance, you must remove the existing configuration.
The undo multicast-domain share-group command removes the configured MTI and the configurations the multicast-domain switch-group-pool, multicast-domain log switch-group-reuse and multicast-domain switch-delay commands.
IP multicast routing must be enabled in the VPN instance before this command can take effect.
Related commands: multicast routing-enable, multicast-domain log switch-group-reuse, multicast-domain switch-delay, and multicast-domain switch-group-pool .
# Specify 224.1.1.1 as the share-group address in VPN instance mvpn and associate MTI 0 with the VPN instance.
[Sysname-vpn-instance-mvpn] multicast-domain share-group 224.1.1.1 binding mtunnel 0
multicast-domain switch-delay switch-delay
undo multicast-domain switch-delay
View
VPN instance view
Default level
2: System level
switch-delay: Switch-delay period in seconds, namely the delay time for multicast traffic to be switched from the share-MDT to the switch-MDT, in the range of 3 to 60.
Use the multicast-domain switch-delay command to configure the switch-delay period.
Use the undo multicast-domain switch-delay command to restore the default.
By default, the switch-delay period is 5 seconds.
# Set the switch-delay period to 20 seconds in VPN instance mvpn.
[Sysname-vpn-instance-mvpn] multicast-domain switch-delay 20
multicast-domain switch-group-pool switch-group-pool { mask | mask-length } [ acl acl-number ]
undo multicast-domain switch-group-pool
View
VPN instance view
Default level
2: System level
switch-group-pool: The start address of the switch-group-pool, in the range of 224.0.1.0 to 239.255.255.255.
mask: Mask for addresses in the switch-group-pool, in the range of 255.255.255.0 to 255.255.255.255, meaning the switch-group-pool contains 1 to 256 group addresses.
mask-length: Mask length for addresses in the switch-group-pool, in the range of 22 to 32, meaning the switch-group-pool contains 1 to 256 group addresses.
acl-number: Advanced ACL number, in the range of 3000 to 3999. An advanced ACL is used to define the (S, G) entry or entries to which the configured MDT switching condition will apply. If you do not specify an ACL, the configured MDT switching condition will apply to all (S, G) entries. When creating an advanced ACL, specify the protocol type as IP and use the source and destination parameters to specify a multicast source address range and a multicast group address range respectively.
Use the multicast-domain switch-group-pool command to configure the address range of the switch-group-pool and the switching condition.
Use the undo multicast-domain switch-group-pool command to restore the default.
By default, no switch-group-pool is configured and multicast traffic is never switched to a switch-MDT.
On a given PE device, the switch-group address range for a VPN must not contain the share-group of any VPN.
On a given PE device, the switch-group address range for a VPN instance must not overlap with that for any other VPN instance. A new configuration with this command in the same VPN instance supersedes the existing configuration.
 If you use the multicast-domain switch-group-pool command on a device, share-MDT to switch-MDT switching will take place after the switch receives multicast traffic for this VPN instance and has maintained it for the switch-delay period.
Related commands: multicast-domain switch-delay.
# Configure the address range of the switch-group-pool in VPN instance mvpn as 225.2.2.0 to 225.2.2.15.
[Sysname-vpn-instance-mvpn] multicast-domain switch-group-pool 225.2.2.0 28
peer enable (BGP-MDT sub-address family view)
peer { group-name | ip-address } enable
undo peer { group-name | ip-address } enable
View
Default level
2: System level
group-name: Name of a BGP MDT peer group, a case-sensitive string of 1 to 47 characters. A peer group name must not contain any space.
ip-address: IP address of a BGP MDT peer.
Use the peer enable command to enable the specified peer or peer group.
Use the undo peer enable command to disable the specified peer or peer group.
By default, no BGP MDT peer or peer group is enabled.
The BGP peer or peer group must be configured before this command can take effect.
Related commands: group, peer as-number, and peer group (Layer 3 – IP Routing Command Reference).
# Configure and enable the BGP MDT peer 18.10.0.9.
[Sysname] bgp 100
[Sysname-bgp] peer 18.10.0.9 as-number 100
[Sysname-bgp-af-mdt] peer 18.10.0.9 enable
peer group (BGP-MDT sub-address family view)
peer ip-address group group-name
undo peer ip-address group group-name
View
Default level
2: System level
Use the peer group command to add a peer to the BGP MDT peer group.
Use the undo peer group command to delete a specified peer from the peer group.
By default, a peer belongs to no peer groups.
The BGP MDT peer and peer group must be configured and enabled before this command can take effect.
Related commands: peer enable.
# Configure and enable the BGP MDT peer 10.1.1.1 and the peer group test, and then add the peer to the peer group.
[Sysname] bgp 100
[Sysname-bgp] group test
[Sysname-bgp] peer test as-number 2004
[Sysname-bgp] peer 10.1.1.1 group test
[Sysname-bgp-af-mdt] peer test enable
[Sysname-bgp-af-mdt] peer 10.1.1.1 enable
[Sysname-bgp-af-mdt] peer 10.1.1.1 group test
peer reflect-client (BGP-MDT sub-address family view)
peer { group-name | ip-address } reflect-client
undo peer { group-name | ip-address } reflect-client
View
Default level
2: System level
group-name: Name of a BGP MDT peer group, a case-sensitive string of 1 to 47 characters. A peer name must not contain any space.
Use the peer reflect-client command to configure the router as a route reflector and specify a peer or peer group as its client.
Use the undo peer reflect-client command to remove the configuration.
By default, neither route reflectors nor clients are configured.
Before you configure this command, BGP MDT peers or peer groups should be configured.
Your configuration will overwrite the old configuration (if any).
Related commands: peer enable, reflect between-clients, and reflect cluster-id.
# Configure and activate BGP MDT peer group test, and then configure the local device as a route reflector and specify the BGP MDT peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp-af-mdt] peer test reflect-client
reflect between-clients (BGP-MDT sub-address family view)
undo reflect between-clients
View
Default level
2: System level
None
Use the reflect between-clients command to enable route reflection between clients.
Use the undo reflect between-clients command to disable this function.
By default, route reflection between clients is enabled.
Related commands: peer reflect-client and reflector cluster-id.
# Disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-af-mdt] undo reflect between-clients
reflector cluster-id (BGP-MDT sub-address family view)
undo reflector cluster-id
View
Default level
2: System level
cluster-id: Cluster ID of the route reflector, in the range 1 to 4294967295.
ip-address: Cluster ID of the route reflector, which is the IP address of the specified BGP MDT peer.
Use the reflector cluster-id command to configure the cluster ID of the route reflector.
Use the undo reflector cluster-id command to remove the configured cluster ID.
By default, a route reflector uses its router ID as the cluster ID.
In general, a cluster has only one route reflector whose router ID identifies the cluster. However, you can configure several route reflectors in a cluster to improve network reliability, and they must have the same cluster ID configured to avoid routing loops.
Related commands: peer reflect-client and reflect between-clients.
# Specify 80 as the cluster ID for the route reflector.
[Sysname] bgp 100
[Sysname-bgp-af-mdt] reflector cluster-id 80
reset bgp mdt
reset bgp mdt { as-number | ip-address | all | external | group group-name | internal }
View
Default level
1: Monitor level
as-number: Resets BGP MDT connections to peers in the specified AS, in the range of 1 to 4294967295.
ip-address: Resets the connection with the specified BGP MDT peer.
all: Resets all the BGP MDT connections.
external: Resets all the EBGP MDT connections.
group group-name: Resets connections with the specified BGP peer group. A peer group name is a case-sensitive string of 1 to 47 characters and must not contain any space.
internal: Resets all the IBGP MDT connections.
Use the reset bgp mdt command to reset BGP MDT connections.
# Reset all the BGP MDT connections.
<Sysname> reset bgp mdt all
