07-IP Multicast Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10307-IP Multicast Command Reference
04-Multicast Routing and Forwarding Commands
04-Multicast Routing and Forwarding Commands 150.14 KB
delete ip rpf-route-static
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN, where the vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If this option is not specified, the command deletes all multicast static routes on the public network.
Use the delete ip rpf-route-static command to delete all multicast static routes.
Related commands: ip rpf-route-static.
# Delete all multicast static routes on the public network.
[Sysname] delete ip rpf-route-static
This will erase all multicast static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]:
display multicast boundary
display multicast [ all-instance | vpn-instance vpn-instance-name ] boundary [ group-address [ mask | mask-length ] ] [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all-instance: Specifies all MPLS L3VPNs.
group-address: Multicast group address, in the range of 224.0.0.0 to 239.255.255.255.
mask: Mask of the multicast group address, 255.255.255.255 by default.
mask-length: Mask length of the multicast group address, in the range of 4 to 32. The system default is 32.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display multicast boundary command to display the multicast boundary information on the specified interface or all interfaces.
If neither all-instance nor vpn-instance is specified, this command displays the information on the public network.
Related commands: multicast boundary.
# Display the multicast boundary information on all interfaces in the public network instance.
<Sysname> display multicast boundary
Multicast boundary information of VPN-Instance: public net
 Boundary            Interface
 224.1.1.0/24        GE3/1/1
 239.2.2.0/24        Pos5/1/1
Table 1 Output description
Multicast boundary for the public network
Boundary
Multicast group corresponding to the multicast boundary
Interface:
Boundary interface corresponding to the multicast boundary
display multicast forwarding-table
display multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table [ source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { { exclude | include | match } { interface-type interface-number | register } } | statistics | slot slot-number ] * [ port-info ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
source-address: Displays the forwarding entries containing the specified multicast source address.
group-address: Displays the forwarding entries containing the specified multicast group address, in the range of 224.0.0.0 to 239.255.255.255.
mask: Mask of the multicast group/source address, 255.255.255.255 by default.
mask-length: Mask length of the multicast group/source address. For a multicast group address, this argument has an effective value range of 4 to 32; for a multicast source address, this argument has an effective value range of 0 to 32. The system default is 32 in both cases.
incoming-interface: Displays forwarding entries of which the incoming interface is the specified one.
register: Displays the forwarding entries of which the incoming interface is the PIM-SM register interface.
outgoing-interface: Displays forwarding entries of which the outgoing interface is the specified one.
exclude: Displays the forwarding entries of which the outgoing interface list excludes the specified interface.
include: Displays the forwarding entries of which the outgoing interface list includes the specified interface.
match: Specifies the forwarding entries of which the outgoing interface list includes and includes only the specified interface.
statistics: Specifies to display the statistics information of the multicast forwarding table.
slot slot-number: Specifies the slot number of an interface card. If you do not specify this option, this command will display the multicast forwarding table information of the switching and routing processing unit (SRPU).
port-info: Specifies to display Layer 2 port information.
Use the display multicast forwarding-table command to display the multicast forwarding table information.
Multicast forwarding tables are used to guide multicast forwarding. You can view the forwarding state of multicast traffic by checking the multicast forwarding table.
Related commands: display multicast routing-table, multicast forwarding-table downstream-limit, and multicast forwarding-table route-limit.
# Display the multicast forwarding table information in the public network instance.
<Sysname> display multicast forwarding-table
Multicast Forwarding Table of VPN-Instance: public net
Total 1 entry
Total 1 entry matched
00001. (172.168.0.2, 227.0.0.1)
     MID: 0, Flags: 0x100000:0
     Incoming interface: GigabitEthernet3/1/1
     List of 1 outgoing interfaces:
       1: GigabitEthernet3/1/2
     Matched 19648 packets(20512512 bytes), Wrong If 0 packets
Table 2 Output description
Multicast forwarding table for the public network.
Total 1 entry
Total number of (S, G) entries in the multicast forwarding table.
Total number of matched (S, G) entries in the multicast forwarding table.
00001
Sequence number of the (S, G) entry.
(172.168.0.2,227.0.0.1)
An (S, G) entry of the multicast forwarding table.
MID
(S, G) entry ID. Each (S, G) entry has a unique MID.
Flags
Current state of the (S, G) entry. Different bits are used to indicate different states of (S, G) entries. Major values of this field are described in Table 3.
Uptime
Length of time for which the (S, G) entry has been up, in hours:minutes:seconds.
Timeout in
Length of time in which the (S, G) entry will expire, in hours:minutes:seconds.
Incoming interface
Name of the incoming interface of the (S, G) entry.
List of 1 outgoing interface:
Outgoing interface list
Interface ID: outgoing interface name and number.
(S, G)-matched packets (bytes), packets with incoming interface errors.
(S, G)-forwarded packets (bytes).
Table 3 Major values of the flags field
Value
Meaning
0x00000001
Indicates that  a register-stop message must be sent
0x00000002
Indicates whether the multicast source corresponding to the (S, G) is active
0x00000004
Indicates a null forwarding entry
0x00000008
Indicates whether the RP is a PIM domain border router
0x00000010
Indicates that a register outgoing interface is available
0x00000400
Identifies an (S, G) entry to be deleted
0x00008000
Indicates that the (S, G) entry is in the smoothening process after active/standby switchover
0x00010000
Indicates that the (S, G) has been updated during the smoothing process
0x00080000
Indicates that the (S, G) entry has been repeatedly updated and needs to be deleted before a new entry is added
0x00100000
Indicates that an entry is successfully added
0x01000000
Indicates a multicast forwarding entry for BIDIR-PIM
0x02000000
Indicates the RP for BIDIR-PIM
display multicast forwarding-table df-info
display multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table df-info [ rp-address ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
rp-address: RP address of BIDIR-PIM.
slot slot-number: Displays the DF information of the multicast forwarding table for the card specified by its slot number. If no slot is specified, the command displays the DF information of the multicast forwarding table for the main processing board.
exclude: Displays the lines that do not match the specified regular expression.
Use the display multicast forwarding-table df-info command to display the DF information of the multicast forwarding table.
If neither all-instance nor vpn-instance is specified, this command displays the DF information for the public network.
# Display the DF information of the multicast forwarding table for the public network.
<Sysname> display multicast forwarding-table df-info
Multicast DF information of VPN-Instance: public net
Total 1 RP
Total 1 RP matched
00001. RP Address: 1.1.1.1
     MID: 0, Flags: 0x2100000:0
     Uptime: 00:08:32
     RPF interface: GigabitEthernet3/1/1
     List of 1 DF interfaces:
Table 4 Output description
Total 1 RP
Total number of RPs.
Total 1 RP matched
Total number of matched RPs.
00001
Sequence number of the RP.
MID
ID of the RP. Each RP has a unique MID.
Flags
Current state of the RP. Different bits are used to indicate different states of an RP. For major values of this field, see Table 3.
Uptime
Length of time for which the RP has been up, in hours:minutes:seconds.
RPF interface
RPF interface to the RP.
DF interface list.
display multicast [ all-instance | vpn-instance vpn-instance-name ] routing-table [ source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { { exclude | include | match } { interface-type interface-number | register } } ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
source-address: Displays multicast routing entries containing the specified multicast source address.
group-address: Displays multicast routing entries containing the specified multicast group address, in the range of 224.0.0.0 to 239.255.255.255.
incoming-interface: Displays multicast routing entries of which the incoming interface is the specified one.
register: Displays multicast routing entries of which the incoming interface is the PIM-SM register interface.
outgoing-interface: Displays multicast routing entries of which the outgoing interface is the specified one.
exclude: Displays routing entries of which the outgoing interface list excludes the specified interface.
include: Displays routing entries of which the outgoing interface list includes the specified interface.
match: Displays routing entries of which the outgoing interface list includes only the specified interface.
Use the display multicast routing-table command to display the multicast routing table information.
Multicast routing tables are the basis of multicast forwarding. You can view the establishment state of an (S, G) entry by checking the multicast routing table.
Related commands: display multicast forwarding-table.
# Display the routing information in the multicast routing table on the public network.
<Sysname> display multicast routing-table
Multicast routing table of VPN-Instance: public net
 Total 1 entry
       Uptime: 00:00:28
       Upstream Interface: GigabitEthernet3/1/1
       List of 2 downstream interfaces
           2:  GigabitEthernet3/1/3
Table 5 Output description
Multicast routing table for the public network
Total 1 entry
Total number of (S, G) entries in the multicast routing table
00001
Uptime
Upstream interface
Name of the upstream interface the (S, G) entry: Multicast packets should arrive at this interface
Downstream interface list: these interfaces need to forward multicast packets
display multicast routing-table static
display multicast routing-table [ all-instance | vpn-instance vpn-instance-name ] static [ source-address { mask-length | mask } ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
source-address: Multicast source address.
mask: Mask of the multicast source address.
mask-length: Mask length of the multicast source address, in the range of 0 to 32.
Use the display multicast routing-table static command to display the information of multicast static routes.
# Display all multicast static routes on the public network.
<Sysname> display multicast routing-table static
Multicast Routing Table of VPN-Instance: public net
Routes : 1
 Mroute 50.1.1.0/24
          Interface = GigabitEthernet4/1/7        RPF Neighbor = 162.2.2.10
          Matched routing protocol = <none>, Route-policy = <none>
          Preference = 1, Order = 1
 Running Configuration = ip rpf-route-static 50.1.1.0 24 162.2.2.10 order 1
Table 6 Output description
Multicast routing table for the public network.
Routes
Number of routes.
Mroute
Multicast route source address and its mask length.
Outgoing interface to the multicast source.
RPF Neighbor
IP address of the RPF neighbor through which the multicast source is reachable.
Route-policy
Routing policy. The multicast source address of the route should match the routing policy.
Preference
Route preference.
Order
Sequence number of the route.
CLI that configured the multicast static route.
display multicast rpf-info
display multicast [ all-instance | vpn-instance vpn-instance-name ] rpf-info source-address [ group-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Multicast group address, in the range of 224.0.1.0 to 239.255.255.255.
Use the display multicast rpf-info command to display the RPF information of a multicast source.
Related commands: display multicast forwarding-table and display multicast routing-table.
# Display all the RPF information of multicast source 192.168.1.55 in the public network.
<Sysname> display multicast rpf-info 192.168.1.55
 RPF information about source 192.168.1.55:
     VPN instance: public net
     RPF interface: GigabitEthernet3/1/1, RPF neighbor: 10.1.1.1
     Referenced route/mask: 192.168.1.0/24
     Referenced route type: igp
     Load splitting rule: disable
Table 7 Output description
Information of the RPF path to multicast source 192.168.1.55
RPF interface
Name of the RPF interface
RPF neighbor
Referenced route and its mask length
Type of the referenced route, which can be any of the following:
·       igp—Unicast route (IGP)
·       egp—Unicast route (EGP)
·       unicast (direct)—Unicast route (directly connected)
·       unicast—Other unicast route (such as unicast static route)
·       mbgp—MBGP route
·       multicast static—Multicast static route
Rule for RPF route selection, which can be based on the preference of the routing protocol or based on the longest match on the destination address
Load splitting rule
Status of the load splitting rule (enabled/disabled)
ip rpf-route-static
ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask | mask-length } [ protocol [ process-id ] ] [ route-policy policy-name ] { rpf-nbr-address | interface-type interface-number } [ preference preference ] [ order order-number ]
undo ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask | mask-length } [ protocol [ process-id ] ] [ route-policy policy-name ]
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN, where the vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If this option is not specified, this command configures a multicast static route on the public network.
protocol: Routing protocol, which can have any of the following values:
·           bgp: Specifies the BGP protocol.
·           isis: Specifies the IS-IS protocol.
·           ospf: Specifies the OSPF protocol.
·           rip: Specifies the RIP protocol.
·           static: Specifies the static route.
process-id: Process number of the unicast routing protocol, in the range of 1 to 65535. This argument must be provided if IS-IS, OSPF or RIP is the specified unicast routing protocol.
policy-name: Name of the routing policy used for matching multicast static routes, a case-sensitive string of 1 to 63 characters.
rpf-nbr-address: Specifies an RPF neighbor by the IP address.
interface-type interface-number: Specifies the interface that connects to an RPF neighbor by the interface type and interface number.
preference: Route preference, in the range of 1 to 255 and defaulting to 1.
order-number: Match order for routes on the same segment, in the range of 1 to 100.
Use the ip rpf-route-static command to configure a multicast static route.
Use the undo ip rpf-route-static command to delete a multicast static route from the multicast static routing table.
By default, no multicast static route is configured.
The arguments source-address { mask | mask-length }, protocol and policy-name are critical elements in multicast static route configuration. The variation of any of these arguments results in a different configuration.
When you configure a multicast static route, the system first checks whether any of these argument exists. If the system finds a match, you must modify the corresponding fields without changing the configuration sequence. Otherwise, the system adds a multicast static route.
When you configure a multicast static route, specify an RPF neighbor only by providing its IP address (rpf-nbr-address) rather than providing the type and number (interface-type interface-number) of the interface connecting the RPF if the interface of the RPF neighbor is a Layer 3 Ethernet interface, Layer 3 aggregate interface, Loopback interface, Layer 3 RPR logical interface, or VLAN interface.
Because outgoing interface iteration might fail or the specified interface might be in the down state, the multicast static route configured with this command might fail to take effect. Therefore, use the display multicast routing-table static command after you configure a multicast static route to check whether the route has been successfully configured or whether the route has taken effect.
Related commands: delete ip rpf-route-static and display multicast routing-table static.
# Configure a multicast static route to the multicast source 10.1.1.1/24, specifying a router with the IP address of 192.168.1.23 as its RPF neighbor.
[Sysname] ip rpf-route-static 10.1.1.1 24 192.168.1.23
mtracert
mtracert source-address [ [ last-hop-router-address ] group-address ]
View
Default level
1: Monitor level
source-address: Specifies a multicast source address.
group-address: Specifies a multicast group address, in the range of 224.0.1.0 to 239.255.255.255.
last-hop-router-address: Specifies a last-hop router address, which is the IP address of the local router by default.
Use the mtracert command to trace the path down which the multicast traffic from a given multicast source flows to the last-hop router.
If the last-hop-router-address argument is given in the command to trace the path for a specific (S, G) multicast stream, the interface corresponding to the last-hop router address must be the outgoing interface for the (S, G) multicast stream; otherwise the multicast traceroute will fail.
# Trace the path down which the (6.6.6.6, 225.2.1.1) multicast traffic flows to the last-hop router with an IP address of 5.5.5.8.
<Sysname> mtracert 6.6.6.6 5.5.5.8 225.2.1.1
Type Ctrl+C to quit mtrace facility
Tracing reverse path of (6.6.6.6, 225.2.1.1) from last-hop router (5.5.5.8) to source via multicast routing-table
 -1 5.5.5.8
   Incoming interface address: 4.4.4.8
   Previous-hop router address: 4.4.4.7
   Input packet count on incoming interface: 17837
   Output packet count on outgoing interface: 0
   Total number of packets for this source-group pair: 8000
   Protocol: PIM
   Forwarding TTL: 0
   Forwarding code: No error
 -2 4.4.4.7
   Incoming interface address: 6.6.6.7
   Previous-hop router address: 0.0.0.0
   Input packet count on incoming interface: 2
   Output packet count on outgoing interface: 259
   Total number of packets for this source-group pair: 8100
   Protocol: PIM
   Forwarding TTL: 1
Table 8 Output description
last-hop router
Last-hop router
The (S, G) multicast stream for which the forwarding path is being traced
-1 5.5.5.8
The (S, G) outgoing interface address of each hop, starting from the last-hop router
The address of the interface on which the (S, G) packets arrive
The IP address of the router from which this router receives packets from this source
The total number of multicast packets received on the incoming interface
The total number of multicast packets transmitted on the outgoing interface
The total number of packets from the specified source forwarded by this router to the specified group
Protocol
The multicast routing protocol in use between this router and the previous hop router
Forwarding TTL
The minimum TTL that a packet is required to have before it can be forwarded over the outgoing interface
Forwarding code
Forwarding code
multicast boundary
multicast boundary group-address { mask | mask-length }
undo multicast boundary { group-address { mask | mask-length } | all }
View
Interface view
Default level
2: System level
mask: Mask of the multicast group address.
all: Specifies to remove all forwarding boundaries configured on the interface.
Use the multicast boundary command to configure a multicast forwarding boundary.
Use the undo multicast boundary command to remove a multicast forwarding boundary.
By default, no multicast forwarding boundary is configured.
A multicast forwarding boundary sets the boundary condition for the multicast groups in the specified address range. If the destination address of a multicast packet matches the set boundary condition, the packet will not be forwarded.
An interface can act as a forwarding boundary for multiple multicast groups in different address ranges. To achieve this, execute this command on the interface for each multicast address range.
Assume that Set A and Set B are multicast forwarding boundary sets with different address ranges, and B is a subset of A. If B is configured after A, A still takes effect. If A is configured after B, B is removed.
Related commands: display multicast boundary.
# Configure GigabitEthernet 3/1/1 to be the forwarding boundary of multicast groups 239.2.0.0/16.
[Sysname] interface GigabitEthernet3/1/1
[Sysname-GigabitEthernet3/1/1] multicast boundary 239.2.0.0 16
multicast forwarding on-demand
undo multicast forwarding on-demand
View
VLAN view
Default level
2: System level
None
Use the multicast forwarding on-demand command to enable the multicast forwarding on-demand function in the VLAN.
Use the undo multicast forwarding on-demand command to restore the default.
By default, multicast forwarding on-demand is disabled.
After using this command in a multicast VLAN, you must clear all the IGMP snooping multicast group information in the VLAN. Otherwise, this configuration cannot take effect.
After using this command in a non-multicast VLAN with a Layer 3 multicast protocol (IGMP or PIM) enabled on the corresponding VLAN interface, you must clear the Layer 2 port information of all IGMP multicast groups in the VLAN and the IGMP multicast group information on the corresponding VLAN interface. Otherwise, this configuration cannot take effect.
This command cannot take effect in a multicast VLAN with IGMP snooping enabled in the VLAN.
Related commands: igmp-snooping enable, reset igmp group, reset igmp group port-info, and reset igmp-snooping group.
# Enable multicast forwarding on-demand in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] multicast forwarding on-demand
multicast forwarding-table downstream-limit limit
undo multicast forwarding-table downstream-limit
View
System view, VPN instance view
Default level
2: System level
limit: Maximum number of downstream nodes (namely, the maximum number of outgoing interfaces) for a single forwarding entry in the multicast forwarding table. The value ranges from 0 to 128.
Use the multicast forwarding-table downstream-limit command to configure the maximum number of downstream nodes for a single forwarding entry in the multicast forwarding table.
Use the undo multicast forwarding-table downstream-limit command to restore the default.
By default, the upper limit is 128.
# Set the maximum number of downstream nodes for a single forwarding entry in the multicast forwarding table on the public network to 120.
[Sysname] multicast forwarding-table downstream-limit 120
# Set the maximum number of downstream nodes for a single forwarding entry in the multicast forwarding table of VPN instance mvpn to 60.
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] multicast forwarding-table downstream-limit 60
multicast forwarding-table route-limit limit
undo multicast forwarding-table route-limit
View
Default level
2: System level
limit: Maximum number of entries in the multicast forwarding table. The value ranges 0 to 13824.
Use the multicast forwarding-table route-limit command to configure the maximum number of entries in the multicast forwarding table.
Use the undo multicast forwarding-table route-limit command to restore the maximum number of entries in the multicast forwarding table to the system default.
By default, the upper limit is 13824.
# Set the maximum number of entries in the multicast forwarding table on the public network to 200.
[Sysname] multicast forwarding-table route-limit 200
# Set the maximum number of entries in the multicast forwarding table of VPN instance mvpn to 200.
[Sysname-vpn-instance-mvpn] multicast forwarding-table route-limit 200
multicast load-splitting
multicast load-splitting { source | source-group }
undo multicast load-splitting
View
Default level
2: System level
source: Specifies to implement per-source load splitting.
source-group: Specifies to implement per-source and per-group load splitting simultaneously.
Use the multicast load-splitting command to enable load splitting of multicast traffic.
Use the undo multicast load-splitting command to disable load splitting of multicast traffic.
By default, load splitting of multicast traffic is disabled.
# Enable per-source load splitting of multicast traffic on the public network.
[Sysname] multicast load-splitting source
# Enable per-source load splitting of multicast traffic in VPN instance mvpn.
[Sysname-vpn-instance-mvpn] multicast load-splitting source
multicast longest-match
undo multicast longest-match
View
Default level
2: System level
None
Use the multicast longest-match command to configure RPF route selection based on the longest match, namely based on the mask length.
Use the undo multicast longest-match command to restore the default.
By default, the route with the highest priority is selected as an RPF route.
# Configure RPF route selection based on the longest match on the public network.
[Sysname] multicast longest-match
# Configure RPF route selection based on the longest match in VPN instance mvpn.
[Sysname-vpn-instance-mvpn] multicast longest-match
multicast routing-enable
undo multicast routing-enable
View
Default level
2: System level
None
Use the multicast routing-enable command to enable IP multicast routing.
Use the undo multicast routing-enable command to disable IP multicast routing.
IP multicast routing is disabled by default.
You must enable IP multicast routing on the public network or VPN instance before you can use other Layer 3 multicast commands in the corresponding instance.
The device does not forward any multicast packets before IP multicast routing is enabled.
# Enable IP multicast routing on the public network.
[Sysname] multicast routing-enable
# Enable IP multicast routing in VPN instance mvpn.
[Sysname-vpn-instance-mvpn] route-distinguisher 100:1
[Sysname-vpn-instance-mvpn] multicast routing-enable
multicast rpf-fail-pkt bridging
undo multicast rpf-fail-pkt bridging
View
Default level
2: System level
None
Use the multicast rpf-fail-pkt bridging command to enable forwarding of multicast packets upon RPF check failure on VLAN interfaces.
Use the undo multicast rpf-fail-pkt bridging command to restore the default.
By default, this function is disabled.
After using this command, you must clear all the entries in the multicast forwarding table; otherwise this configuration cannot take effect.
Related commands: multicast rpf-fail-pkt trap-to-cpu and reset multicast forwarding-table.
# Configure the device to forward multicast packets that have failed an RPF check in all VLANs.
[Sysname] multicast rpf-fail-pkt bridging
undo multicast rpf-fail-pkt trap-to-cpu
View
Default level
2: System level
None
Use the multicast rpf-fail-pkt trap-to-cpu command to enable sending multicast data packets that have failed an RPF check to the CPU.
Use the undo multicast rpf-fail-pkt trap-to-cpu command to restore the default.
Related commands: multicast rpf-fail-pkt bridging and reset multicast forwarding-table.
# Configure the device to send multicast data packets that have failed an RPF check to the CPU.
[Sysname] multicast rpf-fail-pkt trap-to-cpu
reset multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table { { source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } } * | all }
View
Default level
2: System level
source-address: Clears multicast forwarding entries containing the specified multicast source address.
group-address: Clears multicast forwarding entries containing the specified multicast group address, in the range of 224.0.0.0 to 239.255.255.255.
incoming-interface: Clears multicast forwarding entries of which the incoming interface is the specified one.
register: Clears multicast forwarding entries of which the incoming interface is the PIM-SM register interface.
all: Clears all the forwarding entries from the multicast forwarding table.
Use the reset multicast forwarding-table command to clear the multicast forwarding table information.
If neither all-instance nor vpn-instance is specified, this command clears the forwarding table information on the public network.
When a forwarding entry is deleted from the multicast forwarding table, the corresponding route entry is also deleted from the multicast routing table.
Related commands: display multicast forwarding-table, display multicast routing-table, and reset multicast routing-table.
# Clear the multicast forwarding entries related to multicast group 225.5.4.3 from the multicast forwarding table on the public network.
<Sysname> reset multicast forwarding-table 225.5.4.3
# Clear the multicast forwarding entries related to multicast group 226.1.2.3 from the multicast forwarding table of VPN instance mvpn.
<Sysname> reset multicast vpn-instance mvpn forwarding-table 226.1.2.3
reset multicast [ all-instance | vpn-instance vpn-instance-name ] routing-table { { source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } } * | all }
View
Default level
2: System level
source-address: Clears multicast routing entries containing the specified multicast source address.
group-address: Clears multicast routing entries containing the specified multicast group address, in the range of 224.0.1.0 to 239.255.255.255.
incoming-interface: Specifies the incoming interface of multicast routing entries.
register: Clears multicast routing entries of which the incoming interface is the PIM-SM register interface.
all: Specifies to clear all the routing entries from the multicast routing table.
Use the reset multicast routing-table command to clear multicast routing entries from the multicast routing table.
When a route entry is deleted from the multicast routing table, the corresponding forwarding entry is also deleted from the multicast forwarding table.
Related commands: display multicast forwarding-table, display multicast routing-table, and reset multicast forwarding-table.
# Clear the route entries related to multicast group 225.5.4.3 from the multicast routing table on the public network.
<Sysname> reset multicast routing-table 225.5.4.3
# Clear the route entries related to multicast group 226.1.2.3 from the multicast routing table of VPN instance mvpn.
<Sysname> reset multicast vpn-instance mvpn routing-table 226.1.2.3
