07-IP Multicast Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10307-IP Multicast Command Reference
02-PIM Snooping Commands
02-PIM Snooping Commands 81.03 KB
PIM snooping configuration commands
display pim-snooping neighbor
display pim-snooping neighbor [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays the PIM snooping neighbor information of the specified VLAN. The vlan-id argument is in the range of 1 to 4094. If you do not specify a VLAN, this command displays the PIM snooping neighbor information of all VLANs.
slot slot-number: Displays the PIM snooping neighbor information of the card specified by its slot number. If no slot is specified, the command displays the PIM snooping neighbor information of all cards.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display pim-snooping neighbor command to display PIM snooping neighbor information.
# Display PIM snooping neighbor information about VLAN 2.
<Sysname> display pim-snooping neighbor vlan 2
  Total number of neighbors: 2
  VLAN ID: 2
    Neighbor        Port                     Expires   Option Flags
    10.1.1.2        GE3/1/1                   02:02:23  LAN Prune Delay(T)
    20.1.1.2        GE3/1/2                   03:00:05  LAN Prune Delay
Table 1 Output description
Total number of PIM snooping neighbors.
Neighbor
IP address of the PIM snooping neighbor.
Port
Name of the port that connects to the PIM snooping neighbor.
Expires
Remaining time before the PIM snooping neighbor expires. Never means the PIM snooping neighbor never expires.
Option Flags
Possible values includes the following items:
·       LAN Prune Delay—Indicates that the PIM hello messages received from the neighbor carry the LAN_Prune_Delay option.
·       LAN Prune Delay(T)—Indicates that the PIM hello messages received from the neighbor carry the LAN_Prune_Delay option, and the join suppression function has been enabled
display pim-snooping routing-table
display pim-snooping routing-table [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays the PIM snooping routing entries of the specified VLAN. The vlan-id argument is in the range of 1 to 4094. If you do not specify a VLAN, this command displays the PIM snooping routing entries in all VLANs.
slot slot-number: Displays  the PIM snooping routing entries on the card specified by its slot number. If no slot is specified, the command displays information about the PIM snooping routing entries on the main board.
Use the display pim-snooping routing-table command to display the PIM snooping routing entries.
# Display the PIM snooping routing entries of VLAN 2.
<Sysname> display pim-snooping routing-table vlan 2
  Total 1 entry(ies)
  FSM Flag: NI-no info, J-join, PP-prune pending
  VLAN ID: 2
    Total 1 entry(ies)
    (172.10.10.1, 225.1.1.1)
      Upstream neighbor: 20.1.1.1
        Total number of downstream ports: 2
          1: GE3/1/3
             Expires: 00:03:01, FSM: J
          2: GE3/1/4
      Upstream neighbor: 10.1.1.1
        Total number of downstream ports: 1
          1: GE3/1/5
·       To determine the Upstream port field of an upstream interface that is not on the main board, you must specify the slot number of the card that the interface belongs to.
·       To determine the Expires and FSM fields of a non-aggregate interface that is not on the main board, you must specify the slot number of the card that the interface belongs to. For aggregate interfaces, the Expires and FSM fields are displayed, whether the slot number is specified or not.
Table 2 Output description
Total 1 entry(ies)
Total number of (S, G) entries and (*, G) entries in the PIM snooping routing table.
State machine flag of the downstream port. Possible values include:
·       NI—Initial state.
·       J—Join.
·       PP—Prune pending.
An (S, G) entry.
Upstream neighbor
Upstream neighbor of the (S, G) or (*, G) entry.
Upstream port
Upstream port of the (S, G) entry or (*, G) entry).
FSM
display pim-snooping statistics
display pim-snooping statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display pim-snooping statistics command to display the statistics for received PIM messages.
# Display the statistics for received PIM messages.
<Sysname> display pim-snooping statistics
 Received PIMv2 hello: 100
 Received PIMv2 join/prune: 100
 Received PIMv2 error: 0
 Received PIMv2 messages in total: 200
 Received PIMv1 messages in total: 0
Table 3 Output description
Number of received PIMv2 hello messages
Number of received PIMv2 join/prune messages
Number of received PIMv2 messages with errors
Total number of received PIMv2 messages
Total number of received PIMv1 messages
pim-snooping enable
pim-snooping enable
undo pim-snooping enable
View
VLAN view
Default level
2: System level
None
Use the pim-snooping enable command to enable PIM snooping in a VLAN.
Use the undo pim-snooping enable command to disable PIM snooping in a VLAN.
By default, PIM snooping is disabled.
Before you enable PIM snooping in a VLAN, be sure to enable IGMP snooping globally and specifically in the VLAN.
PIM snooping does not work in a sub-VLAN of a multicast VLAN.
Related commands: igmp-snooping enable.
# Enable IGMP snooping globally, and enable IGMP snooping and PIM snooping in VLAN 2.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] pim-snooping enable
reset pim-snooping statistics
View
Default level
2: System level
None
Use the reset pim-snooping statistics command to clear the statistics for received PIM messages.
# Clear the statistics for received PIM messages.
<Sysname> reset pim-snooping statistics
