07-IP Multicast Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10307-IP Multicast Command Reference
11-IPv6 PIM Snooping Commands
11-IPv6 PIM Snooping Commands 81.96 KB
IPv6 PIM snooping configuration commands
display pim-snooping ipv6 neighbor
display pim-snooping ipv6 neighbor [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays the IPv6 PIM snooping neighbor information of the specified VLAN. The vlan-id argument is in the range of 1 to 4094. If you do not specify a VLAN, this command displays the IPv6 PIM snooping neighbor information in all VLANs.
slot slot-number: Displays the IPv6 PIM snooping neighbor information of the card specified by its slot number. If no slot is specified, the command displays the IPv6 PIM snooping neighbor information of all cards.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display pim-snooping ipv6 neighbor command to display IPv6 PIM snooping neighbor information.
# Display IPv6 PIM snooping neighbor information about VLAN 2.
<Sysname> display pim-snooping ipv6 neighbor vlan 2
  Total number of neighbors: 2
  VLAN ID: 2
    Neighbor        Port                     Expires   Option Flags
    FE80::6401:101  GE3/1/1                   02:02:23  LAN Prune Delay(T)
    FE80::C801:101  GE3/1/2                   03:00:05  LAN Prune Delay
Table 1 Output description
Total number of IPv6 PIM snooping neighbors.
Neighbor
IP address of the IPv6 PIM snooping neighbor.
Port
Name of the port that connects to the IPv6 PIM snooping neighbor.
Expires
Remaining time before the IPv6 PIM snooping neighbor expires. Never means the IPv6 PIM snooping neighbor never expires.
Option Flags
Possible values includes the following items:
·       LAN Prune Delay—Indicates that the IPv6 PIM hello messages received from the neighbor carry the LAN_Prune_Delay option.
·       LAN Prune Delay(T)—Indicates that the IPv6 PIM hello messages received from the neighbor carry the LAN_Prune_Delay option, and the join suppression function has been enabled.
display pim-snooping ipv6 routing-table
display pim-snooping ipv6 routing-table [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays the IPv6 PIM snooping routing entries  of the specified VLAN. The vlan-id argument is in the range of 1 to 4094. If you do not specify a VLAN, this command displays the IPv6 PIM snooping routing entries  in all VLANs.
slot slot-number: Displays  the IPv6 PIM snooping routing entries  of the card specified by its slot number. If no slot is specified, the command displays information about the IPv6 PIM snooping routing entries on the main board.
Use the display pim-snooping ipv6 routing-table command to display the IPv6 PIM snooping routing table.
# Display the IPv6 PIM snooping routing entries of VLAN 2.
<Sysname> display pim-snooping ipv6 routing-table vlan 2
  Total 1 entry(ies)
  FSM Flag: NI-no info, J-join, PP-prune pending
  VLAN ID: 2
    Total 1 entry(ies)
    (2000::1, FF1E::1)
      Upstream neighbor: FE80::101
        Total number of downstream ports: 2
          1: GE3/1/3
          2: GE3/1/4
      Upstream neighbor: FE80::102
        Total number of downstream ports: 1
          1: GE3/1/5
·       To determine the Upstream port field of an upstream interface that is not on the main board, you must specify the slot number of the card that the interface belongs to.
·       To determine the Expires and FSM fields of a non-aggregate interface that is not on the main board, you must specify the slot number of the card that the interface belongs to. For aggregate interfaces, the Expires and FSM fields are displayed, whether the slot number is specified or not.
Table 2 Output description
Total 1 entry(ies)
Total number of (S, G) entries and (*, G) entries in the IPv6 PIM snooping routing table.
State machine flag of the downstream port. Possible values include:
·       NI—Initial state.
·       J—Join.
·       PP—Prune pending.
(2000::1, FF1E::1)
An (S, G) entry.
Upstream neighbor
Upstream neighbor of the (S, G) or (*, G) entry.
Upstream port
Upstream port of the (S, G) entry or (*, G) entry.
FSM
State machine of the downstream port.
display pim-snooping ipv6 statistics
display pim-snooping ipv6 statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display pim-snooping ipv6 statistics command to display the statistics for received IPv6 PIM messages.
# Display the statistics for received IPv6 PIM messages.
<Sysname> display pim-snooping ipv6 statistics
 Received IPv6 PIM IPv6 hello: 100
 Received IPv6 PIM IPv6 join/prune: 100
 Received IPv6 PIM IPv6 error: 0
 Received IPv6 PIM IPv6 messages in total: 200
Table 3 Output description
Number of received IPv6 PIM hello messages
Number of received IPv6 PIM join/prune messages
Number of received IPv6 PIM messages with errors
Total number of received IPv6 PIM messages
pim-snooping ipv6 enable
undo pim-snooping ipv6 enable
View
VLAN view
Default level
2: System level
None
Use the pim-snooping ipv6 enable command to enable IPv6 PIM snooping in a VLAN.
Use the undo pim-snooping ipv6 enable command to disable IPv6 PIM snooping in a VLAN.
By default, IPv6 PIM snooping is disabled.
Before you enable IPv6 PIM snooping in a VLAN, be sure to enable MLD snooping globally and specially in the VLAN.
IPv6 PIM snooping does not work in a sub-VLAN of a multicast VLAN.
Related commands: mld-snooping enable.
# Enable MLD snooping globally, and enable MLD snooping and IPv6 PIM snooping in VLAN 2.
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] pim-snooping ipv6 enable
reset pim-snooping ipv6 statistics
View
Default level
2: System level
None
Use the reset pim-snooping ipv6 statistics command to clear the statistics for received IPv6 PIM messages.
# Clear the statistics for received IPv6 PIM messages.
<Sysname> reset pim-snooping ipv6 statistics
