WLAN Configuration Guide
HomeSupportWirelessWA2200 Series WLAN Access PointsConfigure & DeployConfiguration GuidesH3C WA Series WLAN Access Points Configuration Guide-6W100WLAN Configuration Guide
04-WLAN RRM Configuration
04-WLAN RRM Configuration 54.04 KB
l          The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l          Support of the H3C WA series WLAN access points (APs) for features may vary by AP model. For more information, see Feature Matrix.
l          The interface types and the number of interfaces vary by AP model.
l          The term AP in this document refers to common APs, wireless bridges, or mesh APs.
This chapter includes these sections:
l          Overview
l          Configuring Data Transmission Rates
l          Configuring Power Constraint
l          Configuring Only Non-802.11h Channels to Be Scanned
l          Enabling 802.11g Protection
l          Displaying and Maintaining WLAN RRM
Overview
Radio signals are susceptible to surrounding interference. Causes of radio signal attenuation in different directions are very complex. Therefore, we need to make careful plans before deploying a WLAN network. After WLAN deployment, the running parameters still need to be adjusted because the radio environment is always varying due to interference from mobile obstacles, micro-wave ovens and so on. To adapt to environment changes, radio resources such as working channels and transmit power should be dynamically adjusted. Such adjustments are complex and require experienced personnel to implement regularly, which brings high maintenance costs.
WLAN radio resource management (RRM) is a scalable radio resource management solution. Through information collection (APs collect radio environment information in real time), information analysis (The AC analyzes the collected information), decision-making (The AC makes radio resource adjustment configuration according to analysis results), and implementation (APs implement the configuration made by the AC for radio resource optimization), WLAN RRM delivers a real-time, intelligent, integrated radio resource management solution, which enables a WLAN network to quickly adapt to radio environment changes and keep staying in a healthy state.
Configuration Task list
Complete the following tasks to configure WLAN RRM:
Remarks
Optional
Optional
Optional
Optional
Configuring 802.11a/802.11b/802.11g Rates
Follow these steps to configure 802.11a/802.11b/802.11g rates:
To do…
Use the command…
Remarks
Enter system view
Enter WLAN RRM view
wlan rrm
Configure rates (in Mbps) for 802.11a
dot11a { disabled-rate | mandatory-rate | supported-rate } rate-value
Optional
By default, mandatory rates are 6, 12, and 24; supported rates are 9, 18, 36, 48, and 54; no rates are disabled.
Configure rates for 802.11b
dot11b { disabled-rate | mandatory-rate | supported-rate } rate-value
Optional
By default, mandatory rates are 1 and 2; supported rates are 5.5 and 11; no rates are disabled.
Configure rates for 802.11g
dot11g { disabled-rate | mandatory-rate | supported-rate } rate-value
Optional
By default, mandatory rates are 1, 2, 5.5 and 11; supported rates are 6, 9, 12, 18, 24, 36, 48 and 54; no rates are disabled.
Configuring 802.11n Rates
Configuration of mandatory and supported 802.11n rates is achieved by specifying the maximum Modulation and Coding Scheme (MCS) index. The MCS data rate table shows relations between data rates, MCS indexes, and parameters that affect data rates. A sample MCS data rate table is shown in Table 1-1. For the whole table, see IEEE P802.11n D2.00.
Table 1-1 MCS data rate table
MCS index
Modulation
Data rate (Mbps)
800ns GI
400ns GI
0
BPSK
6.5
7.2
1
QPSK
13.0
14.4
2
QPSK
19.5
21.7
3
16-QAM
26.0
28.9
For example, if you specify the maximum MCS index as 5 for mandatory rates, rates corresponding to MCS indexes 0 through 5 are configured as 802.11n mandatory rates.
Mandatory rates must be supported by the AP and the clients that want to associate with the AP.
Supported rates allow some clients that support both mandatory and supported rates to choose higher rates when communicating with the AP.
Follow these steps to configure 802.11n rates:
To do…
Use the command…
Remarks
Enter system view
Enter RRM view
wlan rrm
Specify the maximum MCS index for 802.11n mandatory rates
dot11n mandatory maximum-mcs index
Optional
No maximum MCS index is specified for 802.11n mandatory rates by default.
Specify the maximum MCS index for 802.11n supported rates
dot11n support maximum-mcs index
Optional
By default, the maximum MCS index for 802.11n supported rates is 76.
If you configure the client dot11n-only command for a radio, you must configure the maximum MCS index for 802.11n mandatory rates.
The radio is enabled and at least one service template is configured.
Follow these steps to configure power constraint:
To do…
Use the command…
Remarks
Enter system view
Enter WLAN RRM view
wlan rrm
Enable spectrum management for 802.11a radios
spectrum-management enable
Required
By default, spectrum management is disabled.
Configure power constraint for all 11a radios
power-constraint power-constraint
Optional
The default value for power constraint is 0 dBm.
Follow these steps to configure only non-802.11h channels to be scanned:
To do…
Use the command…
Remarks
Enter system view
Enter WLAN RRM view
wlan rrm
Configure only non-802.11h channels to be scanned
autochannel-set avoid-dot11h
Optional
By default, the auto-channel set involves all channels.
When both 802.11b and 802.11g clients access a WLAN network, interference easily occurs and thus access rate is greatly degraded because they adopt different modulation modes. To enable both 802.11b and 802.11g clients to operate normally, 802.11g protection needs to be enabled for an 802.11g device to send RTS/CTS or CTS-to-self packets to 802.11b devices, which will defer access to the medium.
Either of the following cases can start 802.11g protection on an 802.11g AP.
1)        An 802.11b client associates with the 802.11g AP. In this case, 802.11g protection is always enabled.
2)        The 802.11g AP detects an overlapping 802.11b BSS or some 802.11b packets that are not destined to it. For this case, you can use the following command to enable 802.11g protection or disable it using the undo form of the command.
Follow these steps to enable 802.11g protection:
To do…
Use the command…
Remarks
Enter system view
Enter WLAN RRM view
wlan rrm
Enable 802.11g protection
dot11g protection enable
Optional
Disabled by default.
Enabling 802.11g protection reduces network performance.
To do…
Use the command…
Remarks
Display WLAN RRM configuration information
display wlan rrm
Available in any view
