WLAN Configuration Guide
HomeSupportWirelessWA2200 Series WLAN Access PointsConfigure & DeployConfiguration GuidesH3C WA Series WLAN Access Points Configuration Guide-6W100WLAN Configuration Guide
02-WLAN Interface Configuration
02-WLAN Interface Configuration 63.93 KB
l          The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l          Support of the H3C WA series WLAN access points (APs) for features may vary by AP model. For more information, see Feature Matrix.
l          The interface types and the number of interfaces vary by AP model.
l          The term AP in this document refers to common APs, wireless bridges, or mesh APs.
This chapter includes these sections:
l          Overview
l          WLAN-Radio Interface
l          WLAN-BSS Interface
l          WLAN Mesh Interface
l          WLAN Mesh Link Interface
l          Displaying and Maintaining a WLAN Interface
Overview
FAT APs support WLAN-Radio physical interfaces and WLAN-BSS virtual interfaces. WLAN-Radio interfaces can be bound to WLAN-BSS interfaces to provide wireless network access.
Introduction
WLAN-Radio interfaces are physical interfaces and are used for providing wireless access service. They can be configured but cannot be removed.
Configuring a WLAN-Radio Interface
Follow these steps to configure a WLAN-Radio interface:
To do…
Use the Command…
Remarks
Enter system view
Enter WLAN-Radio interface view
interface wlan-radio interface-number
Required
Set the description string for the interface
Optional
By default, the description string of an interface is interface-name + interface.
Shut down the WLAN-Radio interface
shutdown
Optional
By default, a WLAN-Radio interface is up.
WLAN-BSS Interface
Introduction
WLAN-BSS interfaces are virtual Layer 2 interfaces. They operate like Layer 2 access Ethernet ports and have Layer 2 attributes. A WLAN-BSS interface supports multiple Layer 2 protocols. On a FAT AP, a WLAN-Radio interface bound to a WLAN-BSS interface operates as a Layer 2 interface.
Configuring a WLAN-BSS Interface
Follow these steps to configure a WLAN-BSS interface:
To do…
Use the command…
Remarks
Enter system view
Enter WLAN-BSS interface view
interface wlan-bss interface-number
Required
If the WLAN-BSS interface does not exist, this command creates the WLAN-BSS interface first.
Optional
Add the WLAN-BSS interface to a VLAN
port access vlan vlan-id
Optional
By default, an interface belongs to VLAN 1 (the default VLAN).
Shut down the WLAN-BSS interface
shutdown
Optional
By default, a WLAN-BSS interface is up.
Before executing the port access vlan command, make sure the VLAN identified by the vlan-id argument already exists. You can use the vlan command to create a VLAN. For more information about the port access vlan command, see VLAN in the Layer 2 – LAN Switching Command Reference.
WLAN Mesh Interface
Introduction
WLAN mesh interfaces are Layer 2 virtual interfaces. You can use them as configuration templates to make and save settings for WLAN mesh link interfaces. Once a WLAN mesh link interface is created, you will not be allowed to change the settings on its associated WLAN mesh interface.
Entering WLAN Mesh Interface View
Follow these steps to enter WLAN mesh interface view:
To do…
Use the command…
Remarks
Enter system view
Enter WLAN mesh interface view
interface wlan-mesh interface-number
Required
If the specified WLAN mesh interface does not exist, this command creates the WLAN mesh interface first.
Configuring a WLAN Mesh Interface
Follow these steps to configure a WLAN mesh interface.
To do…
Use the command…
Remarks
Configure the description of the WLAN mesh interface
description
Configure VLAN settings
l      port link-type
l      port access
l      port trunk
l      port hybrid
WLAN mesh link interfaces are similar to Layer 2 virtual Ethernet interfaces and have the features of Layer 2 interfaces. They are dynamically created or deleted by the WLAN module and are responsible for local data forwarding on the mesh network.
WLAN mesh link interfaces use the settings you made on their corresponding WLAN mesh interfaces and are not configurable.
To do…
Use the command …
Remarks
Display WLAN-Radio interface information
display interface wlan-radio [ interface-number ]
Available in any view
Display WLAN-BSS interface information
display interface wlan-bss [ interface-number ]
Display WLAN mesh interface information
display interface wlan-mesh [ interface-number ]
