21-Command Index-book_CHM.rar(10.49 MB)
H3C S6800 & S6860 Switch Series Command References-Release 671x-6W100-book.pdf(28.55 MB)
- Released At: 29-08-2023
- Page Views:
- Downloads:
1 Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
aaa connection-recording policy
address-family evpn (public instance view)
address-family evpn (VPN instance view)
address-family ipv4 (public instance view)
address-family ipv4 (VPN instance view)
address-family ipv6 (public instance view)
address-family ipv6 (VPN instance view)
advertise lowest-priority on-peer-up duration
advertise lowest-priority on-startup duration
apply fail-action-drop next-hop
archive configuration interval
archive configuration location
archive configuration server password
archive configuration server user
arp detection port-match-ignore
arp distributed-gateway dynamic-entry synchronize
arp mac-interface-consistency check enable
arp resolving-route probe-count
arp resolving-route probe-interval
arp timer aging probe-interval
arp user-ip-conflict record enable
attack-defense local apply policy
attack-defense login reauthentication-delay
attack-defense signature log non-aggregate
attack-defense tcp fragment enable
attribute convert (RADIUS DAS view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAS view)
attribute reject (RADIUS scheme view)
authen-radius-unavailable online domain
authorization-attribute (ISP domain view)
authorization-attribute (local user view/user group view)
bandwidth (Ethernet service instance view)
bandwidth (FC aggregate interface view)
bandwidth (service instance view)
bandwidth (VFC interface view)
bestroute origin-as-validation
bfd detect-interface first-fail-timer
bfd detect-interface source-ip
bfd detect-interface special-processing
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-echo-receive-interval
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
bgp apply-policy on-startup duration
bgp update-delay on-startup ipv6-prefix-list
bgp update-delay on-startup prefix-list
bgp update-delay wait-other-protocol
bidir-pim enable (IPv6 PIM view)
bidir-rp-limit (IPv6 PIM view)
bmp server monitor all-vpn-instance
bmp server monitor current-instance
bsm-fragment enable (IPv6 PIM view)
bsm-fragment enable (PIM view)
bsm-reflection enable (IPv6 PIM view)
bsm-reflection enable (PIM view)
bsr-rp-mapping rfc2362 (IPv6 PIM view)
buffer packet-drop alarm enable
buffer packet-drop alarm interval
buffer threshold alarm interval
buffer usage threshold headroom
buffer usage threshold headroom queue
buffer usage threshold queue (interface view)
buffer usage threshold queue (system view)
c-bsr holdtime (IPv6 PIM view)
c-bsr interval (IPv6 PIM view)
certificate-chain-sending enable
cfd ais-track link-status global
cfd ais-track link-status level
cfd ais-track link-status period
cfd ais-track link-status vlan
configuration exclusive by-user-name
controller echo-request interval
cwmp cpe inform interval enable
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
default (FC aggregate interface view)
delete ssh client server-public-key
description (FC aggregate interface view)
description (FC interface view)
description (VFC interface view)
description (VPN instance view)
destination-group (subscription view)
destination-group (telemetry view)
dhcp flood-protection aging-time
dhcp flood-protection threshold
dhcp relay check mac-address aging-time
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay dhcp-server timeout
dhcp relay information circuit-id
dhcp relay information link-selection
dhcp relay information remote-id
dhcp relay information strategy
dhcp relay master-server switch-delay
dhcp relay request-from-tunnel discard
dhcp relay server-address algorithm
dhcp server bootp reply-rfc-1048
dhcp server database update interval
dhcp server database update now
dhcp server database update stop
dhcp server relay information enable
dhcp server request-ip-address check
dhcp snooping alarm enable (interface view)
dhcp snooping alarm enable (system view)
dhcp snooping alarm threshold (interface view)
dhcp snooping alarm threshold (system view)
dhcp snooping binding database filename
dhcp snooping binding database update interval
dhcp snooping binding database update now
dhcp snooping check mac-address
dhcp snooping check request-message
dhcp snooping exhaustion trap enable
dhcp snooping information circuit-id
dhcp snooping information enable
dhcp snooping information remote-id
dhcp snooping information strategy
dhcp snooping information vendor-specific
dhcp snooping learning-num-threshold
dhcp snooping max-learning-num
dhcp snooping untrusted-server-record enable
display [ | [ by-linenum ] { begin | exclude | include } ]
display aaa connection-recording policy
display arp detection statistics attack-source
display arp detection statistics packet-drop
display arp filter source service-instance
display arp route-direct advertise
display arp scan keepalive entry
display arp scan keepalive statistics
display arp source-suppression
display arp source-suppression cache
display arp user-ip-conflict record
display attack-defense flood statistics ip
display attack-defense flood statistics ipv6
display attack-defense policy ip
display attack-defense policy ipv6
display attack-defense scan attacker ip
display attack-defense scan attacker ipv6
display attack-defense scan victim ip
display attack-defense scan victim ipv6
display attack-defense statistics local
display bgp bmp server monitor-peer
display bgp dampening parameter
display bgp egress-engineering ipv4
display bgp l2vpn auto-discovery
display bgp non-stop-routing status
display bgp peer received prefix-list
display bgp routing-table dampened
display bgp routing-table dedicated
display bgp routing-table flap-info
display bgp routing-table ipv4 mdt
display bgp routing-table ipv4 multicast
display bgp routing-table ipv4 mvpn
display bgp routing-table ipv4 rtfilter
display bgp routing-table ipv4 unicast
display bgp routing-table ipv4 unicast inlabel
display bgp routing-table ipv4 unicast outlabel
display bgp routing-table ipv6 multicast
display bgp routing-table ipv6 unicast
display bgp routing-table ipv6 unicast inlabel
display bgp routing-table ipv6 unicast outlabel
display bgp routing-table vpnv4
display bgp routing-table vpnv4 inlabel
display bgp routing-table vpnv4 outlabel
display bgp routing-table vpnv6
display bgp routing-table vpnv6 inlabel
display bgp routing-table vpnv6 outlabel
display bgp segment-routing label-range
display buffer usage interface
display cfd ais-track link-status
display cfd dm one-way history
display cfd linktrace-reply auto-detection
display configuration exclusive by-user-name
display cpu-usage configuration
display crypto-engine statistics
display current-configuration diff
display dhcp relay check mac-address
display dhcp relay client-information
display dhcp relay information
display dhcp relay server-address
display dhcp server statistics
display dhcp snooping alarm packet statistics
display dhcp snooping binding database
display dhcp snooping information
display dhcp snooping m-lag-statistics
display dhcp snooping m-lag-status
display dhcp snooping packet statistics
display diagnostic-information
display diagnostic-logfile summary
display dot1x unicast-trigger quiet-mac
display evpn ipv6 auto-discovery
display evpn m-lag synchronized-mac
display evpn route { igmp-js | igmp-ls | smet }
display evpn route arp suppression
display evpn route arp-mobility
display evpn route mac-mobility
display evpn route nd suppression
display evpn route nd-mobility
display fc name-service database
display fc-port-security database
display fc-port-security statistics
display fc-port-security status
display fc-port-security violation
display fip-snooping flushing-rules
display hardware-resource routing-mode
display hardware-resource switch-mode
display hardware-resource vxlan (S6800 switch series)
display hardware-resource vxlan (S6860 switch series)
display igmp proxy routing-table
display igmp-snooping evpn-group
display igmp-snooping host-tracking
display igmp-snooping router-port
display igmp-snooping static-group
display igmp-snooping static-router-port
display igmp-snooping statistics
display interface { s-channel | schannel-aggregation }
display interface register-tunnel
display interface san-aggregation
display interface vlan-interface
display interface vsi-interface
display ip fast-forwarding aging-time
display ip fast-forwarding cache
display ip fast-forwarding fragcache
display ip policy-based-route egress interface
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table summary
display ip source binding statistics
display ip source binding-local
display ip source binding-remote
display ip-subnet-vlan interface
display ipv6 dhcp client statistics
display ipv6 dhcp guard policy
display ipv6 dhcp option-group
display ipv6 dhcp relay client-information address
display ipv6 dhcp relay client-information pd
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 dhcp server conflict
display ipv6 dhcp server database
display ipv6 dhcp server expired
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics
display ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
display ipv6 dhcp snooping m-lag-statistics
display ipv6 dhcp snooping m-lag-status
display ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping pd binding
display ipv6 dhcp snooping trust
display ipv6 fast-forwarding aging-time
display ipv6 fast-forwarding cache
display ipv6 l2-multicast fast-forwarding cache
display ipv6 l2-multicast ip forwarding
display ipv6 l2-multicast mac forwarding
display ipv6 multicast boundary
display ipv6 multicast fast-forwarding cache
display ipv6 multicast forwarding df-info
display ipv6 multicast forwarding event
display ipv6 multicast forwarding-table
display ipv6 multicast forwarding-table df-list
display ipv6 multicast routing-table
display ipv6 multicast routing-table static
display ipv6 multicast rpf-info
display ipv6 multicast-vlan forwarding-table
display ipv6 multicast-vlan group
display ipv6 nd detection statistics
display ipv6 nd proxy statistics
display ipv6 nd raguard policy
display ipv6 nd raguard statistics
display ipv6 nd route-direct advertise
display ipv6 nd scan keepalive entry
display ipv6 nd scan keepalive statistics
display ipv6 nd snooping count vlan
display ipv6 nd snooping count vsi
display ipv6 nd suppression vsi
display ipv6 nd user-ip-conflict record
display ipv6 nd user-move record
display ipv6 neighbors entry-limit
display ipv6 neighbors statistics
display ipv6 neighbors vpn-instance
display ipv6 pim claimed-route
display ipv6 pim routing-table
display ipv6 pim-snooping neighbor
display ipv6 pim-snooping router-port
display ipv6 pim-snooping routing-table
display ipv6 pim-snooping statistics
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 route-static routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table summary
display ipv6 sava packet-drop statistics
display ipv6 source binding pd
display ipv6 source binding statistics
display ipv6 source binding-local
display ipv6 source binding-remote
display irf-port load-sharing mode
display isis event-log graceful-restart
display isis event-log non-stop-routing
display isis graceful-restart status
display isis interface hello-sent
display isis mpls te advertisement
display isis mpls te configured-sub-tlvs
display isis non-stop-routing status
display isis peer hello-received
display isis segment-routing adjacency
display isis segment-routing global-block
display isis segment-routing prefix-sid-map
display kernel deadloop configuration
display kernel starvation configuration
display l2-multicast fast-forwarding cache
display l2-multicast ip forwarding
display l2-multicast mac forwarding
display l2vpn forwarding evpn split-horizon
display l2vpn mac-address mac-move
display l2vpn m-lag arp suppression
display l2vpn m-lag mac-address
display l2vpn pw state-machine
display l2vpn service-instance
display link-aggregation load-sharing mode
display link-aggregation load-sharing path
display link-aggregation member-port
display link-aggregation summary
display link-aggregation troubleshooting
display link-aggregation verbose
display link-state-change statistics interface
display lldp local-information
display lldp neighbor-information
display local-guest waiting-approval
display mac-address [ multicast ]
display mac-address aging-time
display mac-address mac-learning
display mac-address statistics
display mac-authentication connection
display mac-authentication mac-address
display mac-authentication user-recovery-profile
display mac-forced-forwarding interface
display mac-forced-forwarding vlan
display m-lag consistency-check status
display mld proxy routing-table
display mld-snooping evpn-group
display mld-snooping host-tracking
display mld-snooping router-port
display mld-snooping static-group
display mld-snooping static-router-port
display mld-snooping statistics
display mpls ldp troubleshooting
display mpls static-sr-mpls prefix
display mpls te link-management bandwidth-allocation
display mpls te pce statistics
display mpls te tunnel-interface
display msdp non-stop-routing status
display multicast fast-forwarding cache
display multicast forwarding df-info
display multicast forwarding event
display multicast forwarding-table
display multicast forwarding-table df-list
display multicast routing-table
display multicast routing-table static
display multicast-vlan forwarding-table
display multicast-vpn data-group receive
display multicast-vpn data-group send
display multicast-vpn default-group
display multicast-vpn ipv6 data-group receive
display multicast-vpn ipv6 data-group send
display multicast-vpn ipv6 default-group
display multicast-vpn vxlan data-group receive
display multicast-vpn vxlan data-group send
display multicast-vpn vxlan default-group
display multicast-vpn vxlan ipv6 data-group receive
display multicast-vpn vxlan ipv6 data-group send
display multicast-vpn vxlan ipv6 default-group
display ntp-service ipv6 sessions
display ospf fast-reroute lfa-candidate
display ospf mpls te advertisement
display ospf non-stop-routing status
display ospfv3 graceful-restart
display ospfv3 non-stop-routing
display packet-filter statistics
display packet-filter statistics sum
display password-control blacklist
display performance-management statistics
display performance-management task
display pim-snooping router-port
display pim-snooping routing-table
display pim-snooping statistics
display pki certificate access-control-policy
display pki certificate attribute-group
display pki certificate domain
display pki certificate request-status
display port-security access-user
display port-security mac-address block
display port-security mac-address security
display port-security static-user
display port-security static-user connection
display port-security statistics
display process memory fragment free
display process memory fragment used
display process memory heap address
display process memory heap size
display protocol-vlan interface
display provision failed-config
display ptp foreign-masters-record
display public-key local public
display qos policy control-plane
display qos policy control-plane pre-defined
display qos policy diagnosis control-plane
display qos policy diagnosis global
display qos policy diagnosis interface
display qos policy diagnosis l2vpn-ac
display qos policy diagnosis user-profile
display qos policy diagnosis vsi
display qos policy user-profile
display qos qmprofile configuration
display qos qmprofile interface
display qos queue sp interface
display qos queue wfq interface
display qos queue wrr interface
display qos queue-statistics interface outbound
display qos vlan-policy diagnosis
display radius server-load statistics
display rdp request-polling-interval
display reserve-vlan-interface global
display ripng graceful-restart
display ripng non-stop-routing
display route-static routing-table
display security-logfile buffer
display security-logfile summary
display segment-routing mapping-server prefix-sid-map
display snmp mib event object list
display snmp mib event summary
display snmp mib event trigger
display snmp-agent local-engineid
display snmp-agent trapbuffer drop
display snmp-agent trapbuffer send
display spbm agreement-protocol
display spbm bvlan-info statistics
display spbm common statistics
display spbm fast-channel statistics
display spbm graceful-restart event-log
display spbm graceful-restart status
display spbm multicast-fib statistics
display spbm non-stop-routing event-log
display spbm non-stop-routing status
display spbm unicast-fib statistics
display ssh client server-public-key
display stop-accounting-buffer (for HWTACACS)
display stop-accounting-buffer (for RADIUS)
display stp region-configuration
display trill graceful-restart status
display vcf-fabric underlay autoconfigure
display vcf-fabric underlay template-version
display version comp-matrix file
display voice-vlan mac-address
display vxlan tunnel-interface
dldp port unidirectional-shutdown
domain auto-reconfigure enable
domain-authentication send-only
dot1p-priority (IGMP-snooping view)
dot1p-priority (MLD-snooping view)
dot1x { ip-verify-source | ipv6-verify-source } enable
dot1x after-mac-auth max-attempt
dot1x auth-server-unavailable escape
dot1x duplicate-eapol-start discard
dot1x eap-tls-fragment to-server
dot1x re-authenticate server-unreachable keep-online
dot1x server-recovery online-user-sync
dot1x unauthenticated-user aging enable
enable out-of-band-resynchronization
entry-limit (IGMP-snooping view)
entry-limit (MLD-snooping view)
evb vdp timer keepalive exponent
evb vdp timer resource-wait-delay exponent
event (trigger-existence view)
evpn encapsulation vxlan binding instance
evpn mac-ip advertise distributed-gateway
evpn multihoming advertise disable
evpn multihoming timer df-delay
evpn multihoming vxlan-frr local
evpn route arp-mobility suppression
evpn route gateway-mac unmovable
evpn route mac-mobility suppression
evpn route nd-mobility suppression
ext-community-type (OSPF view)
ext-community-type (OSPFv3 view)
extcommunity-type microsegment-id
fast-leave (IGMP-snooping view)
fast-leave (MLD-snooping view)
fast-reroute microloop-avoidance enable
fast-reroute microloop-avoidance rib-update-delay
fast-reroute remote-lfa maximum-cost
fast-reroute remote-lfa prefix-list
fast-reroute remote-lfa tunnel ldp
fc mode (FC aggregate interface view)
fc name-service auto-discovery
fc-port-security database copy
forbidden packet-in arp controller
forwarding vxlan-packet inner-protocol
forwarding-conversational-learning
fspf graceful-restart interval
ftp server acl-deny-log enable
gir system-mode maintenance maintenance-delay
gir system-mode maintenance revert-delay
gir system-mode maintenance snapshot-delay
global-enable (IGMP-snooping view)
global-enable (MLD-snooping view)
graceful-restart helper enable
graceful-restart helper strict-lsa-checking
graceful-restart timer purge-time
graceful-restart timer restart
graceful-restart timer wait-for-rib
gratuitous-arp mac-change retransmit
gratuitous-arp-learning enable
group-policy (IGMP-snooping view)
group-policy (MLD-snooping view)
hello-option dr-priority (IPv6 PIM view)
hello-option dr-priority (PIM view)
hello-option holdtime (IPv6 PIM view)
hello-option holdtime (PIM view)
hello-option lan-delay (IPv6 PIM view)
hello-option lan-delay (PIM view)
hello-option neighbor-tracking (IPv6 PIM view)
hello-option neighbor-tracking (PIM view)
hello-option override-interval (IPv6 PIM view)
hello-option override-interval (PIM view)
holdtime join-prune (IPv6 PIM view)
holdtime join-prune (PIM view)
host-aging-time (IGMP-snooping view)
host-aging-time (MLD-snooping view)
host-tracking (IGMP-snooping view)
host-tracking (MLD-snooping view)
http-flood detect non-specific
http-redirect ssl-server-policy
icmp-flood detect non-specific
icmpv6-flood detect non-specific
if-match autoconfig managed-address-flag
if-match autoconfig other-flag
if-match ipv6 even-prefix-length
if-match ipv6 odd-prefix-length
igmp last-member-query-interval
igmp other-querier-present-interval
igmp-snooping { disable | enable }
igmp-snooping general-query source-ip
igmp-snooping last-member-query-interval
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping querier-election
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping router-port-discard
igmp-snooping special-query source-ip
igmp-snooping triggered-query enable
import-route isis level-1 into level-2
import-route isis level-2 into level-1
import-route isisv6 level-1 into level-2
import-route isisv6 level-2 into level-1
include-attribute 218 vendor-id 25506
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center logfile alarm-threshold
info-center logfile size-quota
info-center logging suppress duplicates
info-center logging suppress module
info-center loghost locate-info with-sn
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center syslog trap buffersize
info-center trace-logfile quota
ingress assign-rule load-balancing
interface-peer/peer additional-paths
interface-peer/peer advertise additional-paths best
interface-peer/peer advertise origin-as-validation
interface-peer/peer advertise-community
interface-peer/peer advertise-ext-community
interface-peer/peer advertise-policy exist-policy
interface-peer/peer advertise-policy non-exist-policy
interface-peer/peer allow-as-loop
interface-peer/peer as-number (for a BGP peer)
interface-peer/peer as-path-acl
interface-peer/peer bmp server
interface-peer/peer capability-advertise orf prefix-list
interface-peer/peer default-route-advertise
interface-peer/peer description
interface-peer/peer filter-policy
interface-peer/peer graceful-restart timer restart extra
interface-peer/peer ignore-first-as
interface-peer/peer ignore-originatorid
interface-peer/peer keep-all-routes
interface-peer/peer log-change
interface-peer/peer low-memory-exempt
interface-peer/peer next-hop-local
interface-peer/peer nexthop-recursive-policy disable
interface-peer/peer preferred-value
interface-peer/peer prefix-list
interface-peer/peer public-as-only
interface-peer/peer reflect-client
interface-peer/peer route-limit
interface-peer/peer route-policy
interface-peer/peer route-update-interval
interface-peer/peer substitute-as
interface-peer/peer timer connect-retry
ip (Web authentication local Web server view)
ip (Web authentication remote Web server view)
ip fast-forwarding load-sharing
ip forwarding-conversational-learning
ip icmp broadcast-echo-reply enable
ip load-sharing local-first enable
ip load-sharing symmetric enable
ip route fast-switchover enable
ip route-static default-preference
ip route-static fast-reroute auto
ip route-static primary-path-detect bfd echo
ip source binding (interface view)
ip source binding (system view)
ip vpn-instance (BGP instance view)
ip-prefix-route generate disable
ipv6 (Web authentication local Web server view)
ipv6 (Web authentication remote Web server view)
ipv6 address duplicate-detect enable
ipv6 address duplicate-detect interval
ipv6 dhcp advertise address-route
ipv6 dhcp client stateless enable
ipv6 dhcp relay client-information record
ipv6 dhcp relay client-link-address enable
ipv6 dhcp relay duid aging-time
ipv6 dhcp relay mac-forward enable
ipv6 dhcp relay remote-id duid
ipv6 dhcp relay remote-id enable
ipv6 dhcp relay request-from-tunnel discard
ipv6 dhcp relay source-address
ipv6 dhcp server database filename
ipv6 dhcp server database update interval
ipv6 dhcp server database update now
ipv6 dhcp server database update stop
ipv6 dhcp server entry-convert enable
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dhcp snooping alarm enable
ipv6 dhcp snooping alarm threshold
ipv6 dhcp snooping binding database filename
ipv6 dhcp snooping binding database update interval
ipv6 dhcp snooping binding database update now
ipv6 dhcp snooping binding record
ipv6 dhcp snooping check relay-forward
ipv6 dhcp snooping check request-message
ipv6 dhcp snooping client-detect
ipv6 dhcp snooping enable vlan
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping option interface-id
ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
ipv6 dhcp snooping pd binding record
ipv6 dhcp snooping relay-agent enable
ipv6 dhcp snooping trust interface
ipv6 dhcp snooping trust tunnel
ipv6 extension-header drop enable
ipv6 fast-forwarding load-sharing
ipv6 multicast cpu-forwarding max-copy-count
ipv6 multicast extranet select-rpf
ipv6 multicast forwarding supervlan community
ipv6 multicast forwarding-table cache-unknown per-entry
ipv6 multicast forwarding-table cache-unknown total
ipv6 multicast-vlan entry-limit
ipv6 nd detection port-match-ignore
ipv6 nd distributed-gateway dynamic-entry synchronize
ipv6 nd online-offline-log enable
ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server suppress
ipv6 nd ra hop-limit unspecified
ipv6 nd ra tunnel-broadcast enable
ipv6 nd ra tunnel-broadcast global enable
ipv6 nd rate-limit log interval
ipv6 nd route-direct prefix convert-length
ipv6 nd scan keepalive send-rate
ipv6 nd snooping dad retrans-timer
ipv6 nd snooping enable global
ipv6 nd snooping enable link-local
ipv6 nd snooping max-learning-num
ipv6 nd unsolicited-na-learning enable
ipv6 nd user-ip-conflict record enable
ipv6 nd user-move record enable
ipv6 neighbor aging probe-count
ipv6 neighbor aging probe-interval
ipv6 neighbor timer stale-aging
ipv6 neighbors max-learning-num
ipv6 neighbors max-learning-number
ipv6 pim hello-option dr-priority
ipv6 pim hello-option holdtime
ipv6 pim hello-option lan-delay
ipv6 pim hello-option neighbor-tracking
ipv6 pim hello-option override-interval
ipv6 pim state-refresh-capable
ipv6 pim triggered-hello enable
ipv6 pim triggered-hello-delay
ipv6 pim-snooping graceful-restart join-aging-time
ipv6 pim-snooping graceful-restart neighbor-aging-time
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
ipv6 route fast-switchover enable
ipv6 route-static default-preference
ipv6 sava import remote-route-tag
ipv6 sava log enable spoofing-packet
ipv6 source binding (interface view)
ipv6 source binding (system view)
ipv6 verify source max-entries
irf-port global load-sharing mode
isis fast-reroute lfa-backup exclude
isis fast-reroute remote-lfa disable
isis fast-reroute ti-lfa disable
isis ipv6 fast-reroute lfa-backup exclude
isis ipv6 primary-path-detect bfd
isis peer hold-max-cost duration
isis troubleshooting max-number
l2vpn mac-address software-learning enable
l2vpn m-lag peer-link ac-match-rule vxlan-mapping
labeled-route ignore-no-tunnel
lacp default-selected-port disable
last-listener-query-count (MLD view)
last-listener-query-interval (MLD view)
last-listener-query-interval (MLD-snooping view)
last-member-query-count (IGMP view)
last-member-query-interval (IGMP view)
last-member-query-interval (IGMP-snooping view)
license activation-file install
license activation-file uninstall
link-aggregation auto-aggregation enable
link-aggregation global load-sharing algorithm
link-aggregation global load-sharing minm
link-aggregation global load-sharing mode
link-aggregation global load-sharing offset
link-aggregation global load-sharing seed
link-aggregation global load-sharing tunnel
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing ignore
link-aggregation load-sharing mode local-first
link-aggregation management-port
link-aggregation management-subnet
link-aggregation management-vlan
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-management periodic-flooding timer
lldp compliance admin-status cdp
lldp global tlv-enable basic-tlv management-address-tlv
lldp ignore-pvid-inconsistency
lldp management-address-format string
lldp neighbor-identity chassis-id
lldp neighbor-identity port-id
lldp neighbor-protection aging
lldp neighbor-protection validation
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp timer notification-interval
lldp tlv-config basic-tlv port-id
load-splitting (IPv6 MRIB view)
local-server log change-password-prompt
longest-match (IPv6 MRIB view)
loopback-detection delay-timer
loopback-detection enable s-vid c-vid
loopback-detection global action
loopback-detection global enable
loopback-detection interval-time
mac-address forwarding-conversational-learning
mac-address information enable (interface view)
mac-address information enable (system view)
mac-address information interval
mac-address information queue-length
mac-address mac-learning enable
mac-address mac-learning priority
mac-address mac-move fast-update
mac-address mac-roaming enable
mac-address max-mac-count enable-forwarding
mac-address notification mac-move
mac-address notification mac-move suppression (interface view)
mac-address notification mac-move suppression (system view)
mac-address static source-check enable
mac-authentication access-user log enable
mac-authentication authentication-method
mac-authentication auth-server-unavailable escape
mac-authentication auto-recover-user
mac-authentication carry user-ip
mac-authentication critical vlan
mac-authentication critical vsi
mac-authentication critical-voice-vlan
mac-authentication guest-vlan auth-period
mac-authentication guest-vlan re-authenticate
mac-authentication guest-vsi auth-period
mac-authentication guest-vsi re-authenticate
mac-authentication host-mode multi-vlan
mac-authentication mac-range-account
mac-authentication offline-detect enable
mac-authentication offline-detect mac-address
mac-authentication parallel-with-dot1x
mac-authentication re-authenticate
mac-authentication re-authenticate server-unreachable keep-online
mac-authentication recover-user
mac-authentication redirect-url
mac-authentication server-recovery online-user-sync
mac-authentication timer (interface view)
mac-authentication timer (system view)
mac-authentication unauthenticated-user aging enable
mac-authentication user-name-format
mac-forced-forwarding gateway probe
mac-forced-forwarding network-port
macsec replay-protection enable
macsec replay-protection window-size
max-response-time (IGMP-snooping view)
max-response-time (MLD-snooping view)
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-egress
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirroring-group reflector-port
mirroring-group remote-probe vlan
m-lag auto-recovery reload-delay
m-lag consistency-check disable
m-lag mad exclude logical-interfaces
m-lag peer-link mac-address hold
mld last-listener-query-interval
mld other-querier-present-timeout
mld-snooping { disable | enable }
mld-snooping general-query source-ip
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping router-aging-time
mld-snooping router-port-discard
mld-snooping special-query source-ip
mld-snooping triggered-query enable
monitor cpu-usage logging interval
monitor kernel deadloop action
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
monitor memory-usage logging interval
monitor resend memory-threshold
mpls ldp sync (OSPF view/OSPF area view)
mpls periodic-tracert (for LSP)
mpls te auto-tunnel backup disable
mpls te bandwidth change thresholds
mpls te enable (interface view)
mpls te enable (OSPF area view)
mpls te fast-reroute bypass-tunnel
mpls te max-reservable-bandwidth
mpls te max-reservable-bandwidth mam
mpls te max-reservable-bandwidth rdm
mpls te reoptimization (tunnel interface view)
mpls te reoptimization (user view)
multicast rpf-proxy-vector compatible
multicast-vpn vxlan dci switch-delay
multicast-vpn vxlan edge remote
multicast-vpn vxlan m-lag local
multicast-vpn vxlan public-instance
multicast-vpn vxlan vpn-instance
netconf capability specific-namespace
netconf soap https ssl-server-policy
network (IPv4 address object group view)
network (IPv6 address object group view)
nexthop evpn-m-lag group-address
nexthop recursive-lookup default-route ignore
nexthop recursive-lookup longest-match
npv auto-load-balance-interval
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service ipv6 inbound enable
ntp-service ipv6 multicast-client
ntp-service ipv6 multicast-server
ntp-service ipv6 unicast-server
ntp-service max-dynamic-sessions
ntp-service reliable authentication-keyid
ntp-service time-offset-threshold
oam errored-frame-period threshold
oam errored-frame-period window
oam errored-frame-seconds threshold
oam errored-frame-seconds window
oam errored-symbol-period threshold
oam errored-symbol-period window
oam global errored-frame threshold
oam global errored-frame window
oam global errored-frame-period threshold
oam global errored-frame-period window
oam global errored-frame-seconds threshold
oam global errored-frame-seconds window
oam global errored-symbol-period threshold
oam global errored-symbol-period window
oam remote-loopback reject-request
object list (action-notification view)
object list (trigger-Boolean view)
object list (trigger-existence view)
object list (trigger-threshold view)
oid (action-notification view)
openflow ttp-controller global-ssl
operation (FTP operation view)
operation (HTTP/HTTPS operation view)
ospf peer hold-max-cost duration
ospf troubleshooting max-number
ospfv3 fast-reroute lfa-backup exclude
ospfv3 peer hold-max-cost duration
ospfv3 primary-path-detect bfd
other-querier-present-interval (IGMP view)
other-querier-present-timeout (MLD view)
overflow-replace (IGMP-snooping view)
overflow-replace (MLD-snooping view)
ovsdb server bootstrap ca-certificate
packet-capture local interface
packet-capture remote interface
packet-filter (Ethernet service instance view)
packet-filter (interface view)
packet-filter permit-flag ignore
parity-error consistency-check log enable
parity-error consistency-check threshold
parity-error monitor log enable
parity-error monitor threshold
parity-error unrecoverable log enable
parity-error unrecoverable period
parity-error unrecoverable reboot
parity-error unrecoverable threshold
password (device management user view)
password (network access user view)
password-control { aging | composition | history | length } enable
password-control alert-before-expire
password-control authentication-timeout
password-control blacklist all-line
password-control change-password first-login enable
password-control change-password weak-password enable
password-control expired-user-login
password-control login idle-time
password-control login-attempt
password-control per-user blacklist-limit
password-control super composition
password-control update-interval
peer advertise evpn-route suppress
peer advertise vpn-reoriginate ibgp
peer as-number (for a BGP peer group)
peer capability-advertise conventional
peer capability-advertise orf non-standard
peer capability-advertise route-refresh
peer capability-advertise suppress-4-byte-as
peer default-gateway no-advertise
pki certificate logging enable
pki-domain (SSL client policy view)
pki-domain (SSL server policy view)
port (IPv6 multicast VLAN view)
port private-vlan trunk promiscuous
port private-vlan trunk secondary
port-security access-user log enable
port-security authentication open
port-security authentication open global
port-security authorization ignore
port-security authorization-fail offline
port-security escape critical-vsi
port-security global escape critical-vsi
port-security mac-address aging-type inactivity
port-security mac-address dynamic
port-security mac-move bypass-vlan-check
port-security m-lag load-sharing-mode
port-security static-user match-mac acl
port-security static-user max-user
port-security static-user password
port-security static-user timer detect-period
port-security static-user timer offline-detect
port-security static-user update-ip enable
port-security static-user user-name-format
port-security static-user user-name-format mac-address
port-security timer autolearn aging
port-security timer disableport
port-security triple-auth-order mac-dot1x-web
port-security url-unavailable domain
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
priority-flow-control (Ethernet interface view)
priority-flow-control (system view)
priority-flow-control deadlock auto-recover action
priority-flow-control deadlock auto-recover cos
priority-flow-control deadlock cos
priority-flow-control deadlock enable
priority-flow-control deadlock precision
priority-flow-control deadlock recover
priority-flow-control deadlock recover-mode
priority-flow-control deadlock threshold
priority-flow-control deadlock threshold action
priority-flow-control dot1p headroom
priority-flow-control dot1p ingress-buffer dynamic
priority-flow-control dot1p ingress-buffer static
priority-flow-control dot1p ingress-threshold-offset
priority-flow-control dot1p reserved-buffer
priority-flow-control headroom
priority-flow-control no-drop dot1p (Ethernet interface view)
priority-flow-control no-drop dot1p (system view)
private-vlan (VLAN interface view)
protocol nexthop recursive-lookup
pw-class (auto-discovery cross-connect group view)
pw-class (auto-discovery VSI view)
qinq ethernet-type (interface view)
qinq ethernet-type (system view)
qos apply policy (Ethernet service instance view, interface view, control plane view, VSI view)
qos apply policy (user profile view)
qos mirroring local-precedence
qos wfq { byte-count | weight }
qos wrr { byte-count | weight }
radius authentication-request first
radius-server authen-state-check interval
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
reauthentication server-select
redirect move-temporarily enable
register-policy (IPv6 PIM view)
register-suppression-timeout (IPv6 PIM view)
register-suppression-timeout (PIM view)
register-whole-checksum (IPv6 PIM view)
register-whole-checksum (PIM view)
report-aggregation (IGMP-snooping view)
report-aggregation (MLD-snooping view)
reset arp detection statistics attack-source
reset arp detection statistics packet-drop
reset arp scan keepalive statistics
reset attack-defense policy flood
reset attack-defense statistics interface
reset attack-defense statistics local
reset bgp advertise lowest-priority
reset bgp bmp server statistics
reset counters interface { s-channel | schannel-aggregation }
reset counters interface loopback
reset counters interface san-aggregation
reset counters interface tunnel
reset counters interface vlan-interface
reset counters interface vsi-interface
reset crypto-engine statistics
reset dhcp relay client-information
reset dhcp snooping alarm packet statistics
reset dhcp snooping m-lag-statistics
reset dhcp snooping packet statistics
reset dot1x unicast-trigger quiet-mac
reset evpn route arp-mobility suppression
reset evpn route mac-mobility suppression
reset evpn route nd-mobility suppression
reset fc-port-security database
reset fc-port-security statistics
reset igmp-snooping router-port
reset igmp-snooping statistics
reset install log-history oldest
reset ip fast-forwarding cache
reset ip policy-based-route statistics
reset ip routing-table statistics protocol
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay client-information address
reset ipv6 dhcp relay client-information pd
reset ipv6 dhcp relay statistics
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics
reset ipv6 dhcp snooping binding
reset ipv6 dhcp snooping m-lag-statistics
reset ipv6 dhcp snooping packet statistics
reset ipv6 dhcp snooping pd binding
reset ipv6 fast-forwarding cache
reset ipv6 l2-multicast fast-forwarding cache
reset ipv6 multicast fast-forwarding cache
reset ipv6 multicast forwarding event
reset ipv6 multicast forwarding-table
reset ipv6 multicast routing-table
reset ipv6 multicast-vlan group
reset ipv6 nd detection statistics
reset ipv6 nd raguard statistics
reset ipv6 nd scan keepalive statistics
reset ipv6 pim-snooping statistics
reset ipv6 policy-based-route statistics
reset ipv6 routing-table statistics protocol
reset ipv6 sava packet-drop statistics
reset isis event-log graceful-restart
reset isis event-log non-stop-routing
reset l2-multicast fast-forwarding cache
reset l2vpn mac-address mac-move
reset link-state-change statistics interface
reset local-guest waiting-approval
reset mac-authentication access-user
reset mac-authentication critical vlan
reset mac-authentication critical vsi
reset mac-authentication critical-voice-vlan
reset mac-authentication guest-vlan
reset mac-authentication guest-vsi
reset mac-authentication statistics
reset m-lag troubleshooting history
reset mld-snooping router-port
reset multicast fast-forwarding cache
reset multicast forwarding event
reset multicast forwarding-table
reset netconf service statistics
reset netconf session statistics
reset openflow instance statistics
reset packet-filter statistics
reset password-control blacklist
reset password-control history-record
reset port-security static-user
reset port-security statistics
reset qos policy control-plane
reset qos queue-statistics interface outbound
reset radius server-load statistics
reset spbm bvlan-info statistics
reset spbm graceful-restart event-log
reset spbm multicast-fib statistics
reset spbm non-stop-routing event-log
reset spbm unicast-fib statistics
reset stop-accounting-buffer (for HWTACACS)
reset stop-accounting-buffer (for RADIUS)
resource-monitor minor resend enable
restful https ssl-server-policy
retry stop-accounting (HWTACACS scheme view)
retry stop-accounting (RADIUS scheme view)
rip primary-path-detect bfd echo
ripng primary-path-detect bfd echo
route-distinguisher (VPN instance view)
route-policy-change delay-time
router-aging-time (IGMP-snooping view)
router-aging-time (MLD-snooping view)
route-replicate (public instance IPv4 address family view)
route-replicate (public instance IPv6 address family view)
route-replicate (VPN instance IPv4 address family view)
route-replicate (VPN instance IPv6 address family view)
router-id (BGP-VPN instance view)
route-update-interval withdrawn enable
rr-filter (BGP VPNv4 address family view)
rr-filter (BGP VPNv6 address family view)
rsvp authentication window-size
rsvp reduction retransmit increment
rsvp reduction retransmit interval
san-aggregation load-sharing mode local-first
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
segment-routing adjacency enable
segment-routing mapping-server advertise-local
segment-routing mapping-server receive
segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
selective-flooding mac-address
select-seq load-balance-number
sensor-group (subscription view)
session-time include-idle-time
shutdown (cross-connect group view)
shutdown (FC aggregate interface view)
shutdown all-physical-interface
signature { large-icmp | large-icmpv6 } max-length
snmp mib event sample instance maximum
snmp-agent { inform | trap } source
snmp-agent configuration-examine interval
snmp-agent packet response dscp
snmp-agent trap enable dhcp server
snmp-agent trap enable dhcp snooping
snmp-agent trap enable event-mib
snmp-agent trap enable fc-fabric
snmp-agent trap enable fc-name-service
snmp-agent trap enable fc-port-security
snmp-agent trap enable fc-zone
snmp-agent trap enable ipv6 dhcp server
snmp-agent trap enable mac-address
snmp-agent trap enable openflow
snmp-agent trap enable port-security
snmp-agent trap if-mib link extended
snmp-agent trap periodical-interval
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3 user-role
sntp reliable authentication-keyid
source interface (ICMP echo/UDP tracert operation view)
source-deny (IGMP-snooping view)
source-deny (MLD-snooping view)
source-lifetime (IPv6 PIM view)
s-pmsi advertise source-active
spt-switch-threshold (IPv6 PIM view)
spt-switch-threshold (PIM view)
ssh exception-record max-number
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server key-re-exchange enable
ssh server login-failed threshold-alarm
startup (trigger-existence view)
startup (trigger-threshold view)
startup-query-count (IGMP view)
startup-query-count (MLD view)
startup-query-interval (IGMP view)
startup-query-interval (MLD view)
state-refresh-hoplimit (IPv6 PIM view)
state-refresh-interval (IPv6 PIM view)
state-refresh-interval (PIM view)
state-refresh-rate-limit (IPv6 PIM view)
state-refresh-rate-limit (PIM view)
statistics enable (Ethernet service instance view)
statistics enable (tunnel interface view)
stop-accounting-buffer enable (HWTACACS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
stop-accounting-packet send-force
stp global config-digest-snooping
subvlan (IPv6 multicast VLAN view)
syn-ack-flood detect non-specific
telnet server acl-deny-log enable
timer join-prune (IPv6 PIM view)
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
track list threshold percentage
trill bypass-pseudonode enable
trill timer holding-multiplier
tunnel discard ipv4-compatible-packet
tunnel-policy (auto-discovery cross-connect view)
tunnel-policy (auto-discovery VSI view)
user-name-format (HWTACACS scheme view)
user-name-format (RADIUS scheme view)
vcf-fabric underlay netconf-password
vcf-fabric underlay netconf-username
vpn-instance (HWTACACS scheme view)
vpn-instance (RADIUS scheme view)
vpn-instance-capability simple (OSPF view)
vpn-instance-capability simple (OSPFv3 view)
vpn-target export-extcommunity
vpn-target import-extcommunity
vrrp ipv6 state-transition-delay
vrrp ipv6 vrid timer advertise
vxlan invalid-udp-checksum discard
vxlan invalid-vlan-tag discard
vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable
web-auth apply portal mac-trigger-server
web-auth auth-server-unavailable escape
web-auth timer temp-entry-aging
wildcard context (action-set view)
wildcard context (trigger view)
