03-Layer 2-LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6800 & S6860 Switch Series Command References-Release 671x-6W10003-Layer 2-LAN Switching Command Reference
12-PBB commands
12-PBB commands 107.83 KB
PBB commands
bvlan
Use bvlan to specify a B-VLAN for a PBB VSI.
Use undo bvlan to remove the B-VLAN of a PBB VSI.
bvlan vlan-id
undo bvlan
No B-VLAN is specified for a PBB VSI.
PBB VSI view
vlan-id: Specifies a B-VLAN ID in the range of 1 to 4094.
You can assign only one B-VLAN to a PBB VSI, but different PBB VSIs can use the same B-VLAN.
For a PBB VSI, you must specify the same I-SID and B-VLAN across all BEBs.
# Create PBB VSI web with I-SID 100. Specify B-VLAN 100 for the PBB VSI.
[Sysname] l2vpn enable
[Sysname] vsi web
[Sysname-vsi-web] pbb i-sid 100
[Sysname-vsi-web-100] bvlan 100
vsi
display l2vpn minm connection
Use display l2vpn minm connection to display MAC-in-MAC connections.
display l2vpn minm connection [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC-in-MAC connections for all VSIs.
# Display MAC-in-MAC connections for all VSIs.
<Sysname> display l2vpn minm connection
Total number of MinM connections: 2
Types: MC - multicast, UC - unicast
VSI name: 1
Link ID  I-SID     BMAC            BVLAN  Owner   Type  Interface
68       1         00e0-3948-0100  4001   PBB     UC    XGE1/0/1
-        1         011e-8300-0001  4001   PBB     MC    XGE1/0/1
VSI name: 2
69       2         00e0-3948-0300  4002   PBB     UC    XGE1/0/2
-        2         011e-8300-0002  4002   PBB     MC    XGE1/0/2
Link ID
Link ID of the MAC-in-MAC connection.
I-SID
Backbone service instance identifier.
BMAC
Backbone MAC address.
BVLAN
Backbone VLAN.
Owner
Entry source: PBB or SPB.
Type of the MAC-in-MAC connection:
·     MC—The connection is for multicast.
·     UC—The connection is for unicast.
Outgoing interface.
display l2vpn minm forwarding
Use display l2vpn minm forwarding to display MAC-in-MAC forwarding entries.
display l2vpn minm forwarding [ vsi vsi-name ] [ slot slot-number ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC-in-MAC forwarding entries for all VSIs.
slot slot-number: Specifies an IRF member device by its ID. If you do not specify a member device, this command displays MAC-in-MAC forwarding entries for the master device.
# Display all MAC-in-MAC forwarding entries.
<Sysname> display l2vpn minm forwarding
Total number of MinM connections: 4
Types: MC - multicast, UC – unicast
Status Flag: * - inactive
VSI name: 1
VSI name: 2
                                                   XGE1/0/3
                                                   XGE1/0/4
Link ID
I-SID
BMAC
BVLAN
Backbone VLAN.
Owner
Outgoing interface.
An asterisk (*) indicates that the MAC-in-MAC forwarding entry is ineffective.
display l2vpn vsi
Use display l2vpn vsi to display VSI information.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information for all VSIs.
verbose: Displays detailed VSI information. If you do not specify this keyword, the command displays brief VSI information.
# Display detailed information for all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: 1
  VSI Index               : 1
  VSI State               : Up
  Bandwidth               : Unlimited
  Broadcast Restrain      : Unlimited
  Multicast Restrain      : Unlimited
  Unknown Unicast Restrain: Unlimited
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  PBB I-SID               : 100
  Statistics              : Disabled
  VXLAN ID                : -
  ACs:
    AC                                 Link ID    State       Type
    BAGG200 srv100                     0          Down        Manual
VSI Description
VSI description. This field appears only when you have configured a description for the VSI.
VSI State
VSI state:
·     Up.
·     Down.
·     Administratively down—The VSI has been manually shut down by using the shutdown command.
MTU
MTU for the VSI.
Bandwidth
Maximum bandwidth in kbps for the VSI.
Broadcast Restrain
Broadcast restraint bandwidth (in kbps).
Multicast Restrain
Multicast restraint bandwidth (in kbps).
Unknown unicast restraint bandwidth (in kbps).
MAC Learning
MAC learning state: Enabled or Disabled.
MAC Table Limit
Maximum number of MAC address entries on the VSI.
If the value is set to Unlimited, the number of MAC address entries is not limited.
MAC Learning rate
MAC address entry learning rate of the VSI.
Drop Unknown
Whether the VSI drops packets with unknown source MAC addresses after the maximum number of MAC entries is reached:
·     EnabledDrops these packets.
·     Disabled—Forwards these packets.
Flooding
State of the VSI's flooding feature:
·     Enabled—Flooding is enabled on the VSI.
·     Disabled—Flooding is disabled on the VSI.
Statistics
Packet statistics state:
·     Enabled—The packet statistics feature is enabled for the VSI.
·     Disabled—The packet statistics feature is disabled for the VSI.
BMAC
BVLAN
Backbone VLAN.
Entry type:
·     Multicast—The entry is used for multicast forwarding.
·     Unicast—The entry is used for unicast forwarding.
ACs
Attachment circuits (ACs) that are bound to the VSI.
AC
AC type:
·     Layer 3 interface such as XGE1/0/4.
·     Layer 2 interface and service instance, such as XGE1/0/3 srv1.
Link ID
Link ID in the VSI for the AC.
AC state: Up or Down.
Type and traffic match mode of the Ethernet service instance. Manual represents a static Ethernet service instance in VLAN-based traffic match mode.
display pbb connection
Use display pbb connection to display PBB VSI connections.
# Display connections for all PBB VSIs.
<Sysname> display pbb connection
BMAC            BVLAN  Port       Type  Aging
011e-8300-0001  4001   XGE1/0/1   MC    N
00e0-3948-0100  4001   XGE1/0/1   UC    Y
011e-8300-0002  4002   XGE1/0/2   MC    N
                       XGE1/0/3
                       XGE1/0/4
00e0-3948-0300  4002   XGE1/0/2    UC    Y
BMAC
BVLAN
Backbone VLAN ID.
Port
Outgoing interface.
Entry type:
Aging
Support for aging:
·     Y—The entry supports aging.
·     N—The entry does not age.
reset pbb connection
encapsulation
Use encapsulation to specify a data encapsulation type for a PBB VSI.
Use undo encapsulation to restore the default.
encapsulation { ethernet | vlan }
undo encapsulation
The data encapsulation type is VLAN for a PBB VSI.
PBB VSI view
ethernet: Specifies Ethernet encapsulation.
vlan: Specifies VLAN encapsulation.
# Configure the Ethernet encapsulation type.
[Sysname] vsi web
[Sysname-vsi-web-100] encapsulation ethernet
pbb i-sid
vsi
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
# Enable L2VPN.
pbb i-sid
Use pbb i-sid to configure a VSI as a PBB VSI and enter its view, or enter the view of an existing PBB VSI.
Use undo pbb i-sid to restore the default.
pbb i-sid i-sid
undo pbb i-sid
No PBB VSIs exist.
VSI view
i-sid: Specifies a PBB I-SID for the VSI, in the range of 1 to 16777215.
For a VSI, the PBB I-SID cannot be the same as the SPB I-SID. For more information about SPB, see SPB Configuration Guide.
The name of a PBB VSI can be different on different PBB nodes, but its I-SID must be the same across the PBBN.
As a best practice, specify the same name for a PBB VSI on different PBB nodes.
# Specify PBB I-SID 100 for VSI vpn1 and enter PBB VSI view.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pbb i-sid 100
[Sysname-vsi-vpn1-100]
pbb uplink
Use pbb uplink to configure an interface as an uplink port for PBB VSIs.
Use undo pbb uplink to remove an uplink port of PBB VSIs.
pbb uplink { all | vsi vsi-name-list }
undo pbb uplink { all | vsi vsi-name-list }
An interface is not configured as the uplink port of any PBB VSI.
all: Specifies all VSIs.
vsi vsi-name-list: Specifies a space-separated list of up to 10 VSI names. A VSI name is a case-sensitive string of 1 to 31 characters.
For a PBB VSI to operate correctly, you must specify a minimum of one uplink port for it.
You can create VSIs before or after you configure the pbb uplink command. The uplink port configuration takes effect after you create the VSIs.
The pbb uplink all command can override the pbb uplink vsi command on an interface. However, the pbb uplink vsi command cannot override the pbb uplink all command.
·     If an interface has been an uplink port for a list of PBB VSIs, you can use the pbb uplink all command to specify it for all PBB VSIs.
·     If an interface has been an uplink port for all PBB VSIs, the pbb uplink vsi command cannot take effect. To specify the interface as an uplink port only for a list of PBB VSIs, you must first execute the undo pbb uplink all command.
To configure the pbb uplink command successfully on an aggregate interface, you must make sure all its member ports support PBB.
After the command is configured on an aggregate interface, you can add PBB-incapable ports to the aggregate interface. The system will generate a log message that the member port does not support PBB. This situation does not affect the operations of the aggregate interface or PBB.
# Specify Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 as the uplink ports of the web and mail PBB VSIs.
[Sysname] vsi web
[Sysname-vsi-web-100] quit
[Sysname-vsi-web] quit
[Sysname] vsi mail
[Sysname-vsi-mail] pbb i-sid 200
[Sysname-vsi-mail-200] bvlan 200
[Sysname-vsi-mail-200] quit
[Sysname-vsi-mail] quit
[Sysname] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/2
[Sysname-if-range] pbb uplink vsi web mail
vsi
Use reset pbb connection to clear PBB VSI connections.
reset pbb connection [ bvlan vlan-id | interface interface-type interface-number ] *
bvlan vlan-id: Specifies a B-VLAN by its ID in the range of 1 to 4094. If you do not specify a B-VLAN, this command clears PBB VSI connections for all B-VLANs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears PBB VSI connections for all interfaces.
The command clears only unicast-type PBB VSI connections.
# Clear connections of PBB VSI web.
<Sysname> reset pbb connection vsi web
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
# Create a VSI and enter VSI view.
[Sysname] vsi test
[Sysname-vsi-test]
display l2vpn vsi
