- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-SSH commands
- 13-SSL commands
- 14-Object group commands
- 15-Attack detection and prevention commands
- 16-TCP attack prevention commands
- 17-IP source guard commands
- 18-ARP attack protection commands
- 19-ND attack defense commands
- 20-uRPF commands
- 21-SAVI commands
- 22-SAVA commands
- 23-MFF commands
- 24-Crypto engine commands
- 25-FIPS commands
- 26-MACsec commands
- 27-Microsegmentation commands
03-MAC authentication commands | 311.48 KB |
display mac-authentication connection
display mac-authentication mac-address
display mac-authentication user-recovery-profile
mac-authentication access-user log enable
mac-authentication authentication-method
mac-authentication auth-server-unavailable escape
mac-authentication auto-recover-user
mac-authentication carry user-ip
mac-authentication critical vlan
mac-authentication critical vsi
mac-authentication critical-voice-vlan
mac-authentication guest-vlan auth-period
mac-authentication guest-vlan re-authenticate
mac-authentication guest-vsi auth-period
mac-authentication guest-vsi re-authenticate
mac-authentication host-mode multi-vlan
mac-authentication mac-range-account
mac-authentication offline-detect enable
mac-authentication offline-detect mac-address
mac-authentication parallel-with-dot1x
mac-authentication redirect-url
mac-authentication re-authenticate
mac-authentication re-authenticate server-unreachable keep-online
mac-authentication recover-user
mac-authentication server-recovery online-user-sync
mac-authentication timer (interface view)
mac-authentication timer (system view)
mac-authentication unauthenticated-user aging enable
mac-authentication user-name-format
reset mac-authentication access-user
reset mac-authentication critical vlan
reset mac-authentication critical vsi
reset mac-authentication critical-voice-vlan
reset mac-authentication guest-vlan
reset mac-authentication guest-vsi
reset mac-authentication statistics
Use display mac-authentication to display MAC authentication settings and statistics.
interface interface-type interface-number: Specifies a port by its type and number. If the specified port is not enabled with MAC authentication, this command displays only global MAC authentication information.
If you do not specify any parameters, this command displays all MAC authentication information including the global settings, port-specific settings, MAC authentication statistics, and online user statistics.
# Display all MAC authentication settings and statistics.
MAC authentication : Enabled
Authentication method : PAP
M-LAG member configuration conflict : Unknown
Username format : MAC address in lowercase(xxxxxxxxxxxx)
Username : mac
Password : Not configured
MAC range accounts : 2
MAC address Mask Username
2222-0000-0000 ffff-0000-0000 user1
4444-0000-0000 ffff-0000-0000 user1
Offline detect period : 300 s
Quiet period : 60 s
Server timeout : 100 s
Reauth period : 3600 s
User aging period for critical VLAN : 1000 s
User aging period for critical VSI : 1000 s
User aging period for guest VLAN : 1000 s
User aging period for guest VSI : 1000 s
Temporary user aging period : 60 s
Authentication domain : Not configured, use default domain
HTTP proxy port list : Total 10 ports
1-3, 5, 7, 9, 11-13, 15
HTTPS proxy port list : Not configured
Online MAC-auth wired users : 1
Silent MAC users:
MAC address VLAN ID From port Port index
0001-0000-0001 100 XGE1/0/2 21
Ten-GigabitEthernet1/0/1 is link-up
Carry User-IP : Disabled
Auth-delay timer : Enabled
Auth-delay period : 60 s
Periodic reauth : Enabled
Reauth period : 120 s
Guest VLAN : 100
Guest VLAN reauthentication : Enabled
Guest VLAN auth-period : 150 s
Critical VLAN : Not configured
Critical voice VLAN : Disabled
Host mode : Single VLAN
Offline detection : Enabled
Authentication order : Parallel
User aging : Enabled
Server-recovery online-user-sync : Enabled
Guest VSI : Not configured
Guest VSI reauthentication : Enabled
Guest VSI auth-period : 30 s
Critical VSI : Not configured
URL user logoff : No
Auto-tag feature : Disabled
VLAN tag configuration ignoring : Disabled
Max online users : 4294967295
Max online preauth-domain users : 4294967295
Max online Auth-Fail-domain users : 4294967295
Auth-server-unavailable escape : Enabled
Authentication attempts : successful 2, failed 3
Current online users : 1
MAC address Auth state
0001-0000-0000 Authenticated
0001-0000-0001 Unauthenticated
MAC authentication |
Whether MAC authentication is enabled globally. |
Authentication method |
Authentication method for MAC authentication: CHAP or PAP. |
M-LAG member configuration conflict |
M-LAG member configuration check result: · Conflicted—The configuration on one M-LAG member device conflicts with that on the other M-LAG member device. · Not conflicted—The configuration on one M-LAG member device does not conflict with that on the other M-LAG member device. · Unknown—The system cannot detect whether the configuration on one M-LAG member device conflicts with that on the other M-LAG member device. |
Username format |
Global user account policy: MAC-based or shared. · If MAC-based accounts are used, this field displays the format settings for the username. For example, MAC address in lowercase(xxxxxxxxxxxx) indicates that the MAC address is in hexadecimal notation without hyphens, and letters are in lower case. · If a shared account is used, this field displays Fixed account. |
Username |
Username for MAC authentication. · If MAC-based accounts are used, this field displays mac. · If a shared account is used, this field displays the username of the shared account for MAC authentication users. By default, the username is mac. |
Password |
Password for MAC authentication. · If the MAC address of each user is used as the password or if a shared account is used but no password is configured, this field displays Not configured. · If a password is configured, this field displays a string of asterisks (******). |
MAC range accounts |
MAC authentication user accounts specific to MAC address ranges. |
MAC address |
MAC address. |
Mask |
MAC address mask. A MAC address and a mask together specify a MAC address range. |
Username |
Username for the users in the MAC address range. |
Offline detect period |
Offline detection timer. |
Quiet period |
Quiet timer. |
Server timeout |
Server timeout timer. |
Reauth period |
Periodic MAC reauthentication timer in seconds. |
User aging period for critical VLAN |
Aging timer in seconds for users in critical VLANs. |
User aging period for critical VSI |
Aging timer in seconds for users in critical VSIs. |
User aging period for guest VLAN |
Aging timer in seconds for users in guest VLANs. |
User aging period for guest VSI |
Aging timer in seconds for users in guest VSIs. |
Temporary user aging period |
Aging timer in seconds for temporary MAC authentication users. |
Authentication domain |
MAC authentication domain specified in system view. If no authentication domain is specified in system view, this field displays Not configured, use default domain. |
HTTP proxy port list |
HTTP proxy ports. |
HTTPS proxy port list |
HTTPS proxy ports. |
Online MAC-auth wired users |
Number of wired online MAC authentication users, including users that have passed MAC authentication and users that are performing MAC authentication. |
Silent MAC users |
Information about silent MAC addresses, including MAC addresses that have failed MAC authentication and MAC addresses that have been assigned the blackhole MAC attribute from the RADIUS server. |
MAC address |
Silent MAC address. |
VLAN ID |
ID of the VLAN to which the silent MAC address belongs. |
From port |
Name of the port that marks the MAC address as a silent MAC address. |
Port index |
Index of the port that marks the MAC address as a silent MAC address. |
Ten-GigabitEthernet1/0/1 is link-up |
Status of the link on Ten-GigabitEthernet 1/0/1. In this example, the link is up. |
Status of MAC authentication on the port: · Enabled. · Enabled (but NOT effective). This value is displayed if MAC authentication is enabled, but the device does not have available ACL resources. · Disabled. |
Carry User-IP |
Whether user IP addresses are included in MAC authentication requests. |
MAC authentication domain specified for the port. |
Auth-delay timer |
Whether MAC authentication delay is enabled on the port. |
Auth-delay period |
MAC authentication delay timer. |
Periodic reauth |
Whether periodic MAC reauthentication is enabled on the port. |
Reauth period |
Periodic MAC reauthentication timer on the port. If no periodic MAC reauthentication timer is configured on the port, this field displays N/A. If periodic MAC reauthentication is not enabled on the port, this field is not available. |
Re-auth server-unreachable |
Action taken when no server is reachable for MAC reauthentication: · Logoff—Logs off online MAC authentication users. · Online—Keeps MAC authenticated users online. |
Guest VLAN |
MAC authentication guest VLAN configured on the port. If no MAC authentication guest VLAN is configured, this field displays Not configured. |
Guest VLAN reauthentication |
Status of guest VLAN reauthentication in MAC authentication, which is Enabled or Disabled. |
Guest VLAN auth-period |
Authentication interval for users in the MAC authentication guest VLAN on the port. |
Critical VLAN |
MAC authentication critical VLAN configured on the port. If no MAC authentication critical VLAN is configured, this field displays Not configured. |
Critical voice VLAN |
Whether the MAC authentication critical voice VLAN feature is enabled on the port. |
Host mode |
MAC authentication VLAN mode for users moving from one VLAN to another on the port: · Single VLAN—Single-VLAN mode. · Multiple VLAN—Multi-VLAN mode. |
Offline detection |
Status of MAC authentication offline detection: · Enabled. · Disabled. |
Authentication order |
If parallel processing of MAC authentication and 802.1X authentication is disabled, this field displays Default. If parallel processing of MAC authentication and 802.1X authentication is enabled, this field displays Parallel. |
User aging |
Status of the aging feature for unauthenticated MAC authentication users on a port: · Enabled. · Disabled. |
Server-recovery online-user-sync |
Status of online user synchronization for MAC authentication on the port: · Enabled. · Disabled. |
Guest VSI |
MAC authentication guest VSI configured on the port. If no MAC authentication guest VSI is configured, this field displays Not configured. |
Guest VSI reauthentication |
Status of guest VSI reauthentication in MAC authentication, which is Enabled or Disabled. |
Guest VSI auth-period |
Authentication interval for users in the MAC authentication guest VSI on the port. |
Critical VSI |
MAC authentication critical VSI configured on the port. If no MAC authentication critical VSI is configured, this field displays Not configured. |
URL user logoff |
Whether to log off MAC authentication users that are assigned authorization URLs and have not passed authentication on the port when the first user is assigned to the critical VSI. |
Auto-tag feature |
This field is not supported in the current software version. Status of the authorization VLAN auto-tag feature: · Enabled. · Disabled. |
VLAN tag configuration ignoring |
This field is not supported in the current software version. Status of the ignore-config mode: · Enabled. · Disabled. |
Max online users |
Maximum number of concurrent online users allowed on the port. |
Max online preauth-domain users |
Maximum number of MAC authentication users in the preauthentication domain on the port. |
Max online Auth-Fail-domain users |
Maximum number of MAC authentication users in the Auth-Fail domain on the port. |
Auth-server-unavailable escape |
Whether the online MAC authentication users can escape from offline detection to stay online when all RADIUS servers are unreachable. Available options: · Enabled—Online MAC authentication users can escape from offline detection to stay online when all RADIUS servers are unreachable. · Disabled—Online MAC authentication users cannot escape from offline detection when all RADIUS servers are unreachable. |
Authentication attempts: successful 1, failed 0 |
MAC authentication statistics, including the number of successful and unsuccessful authentication attempts. |
MAC address |
MAC address of the online user. |
Auth state |
User status: · Authenticated—The user has passed MAC authentication. · Unauthenticated—The user has not passed MAC authentication. |
Use display mac-authentication connection to display information about online MAC authentication users.
display mac-authentication connection [ open ] [ [ m-lag [ local | peer ] ] [ interface interface-type interface-number | online-type { auth-fail-domain | critical-domain | preauth-domain | success | url-unavailable-domain } | slot slot-number | user-name user-name ] | user-mac mac-address ]
open: Displays information only about MAC authentication users that use nonexistent usernames or incorrect passwords for network access in open authentication mode. If you do not specify this keyword, the command displays information about all online MAC authentication users.
m-lag [ local | peer ]: Specifies online MAC authentication users on M-LAG interfaces. If you do not specify these keywords, the command does not distinguish online MAC authentication users on M-LAG interfaces and non-M-LAG interfaces. If you specify the m-lag keyword without the local or peer keyword, the command displays information about online MAC authentication users on both the local and peer M-LAG member devices.
· local: Displays information about online MAC authentication users on the local M-LAG member device.
· peer: Displays information about online MAC authentication users on the peer M-LAG member device.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays information about online MAC authentication users for all ports.
online-type: Specifies a type of online MAC authentication users.
· auth-fail-domain: Specifies MAC authentication users in the Auth-Fail domain.
· critical-domain: Specifies MAC authentication users in the critical domain.
· preauth-domain: Specifies MAC authentication users in the preauthentication domain.
· success: Specifies users that have passed MAC authentication.
· url-unavailable-domain: Specifies MAC authentication users assigned to the URL-unavailable domain when the redirect URL is unavailable.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about online MAC authentication users for all member devices.
user-mac mac-address: Specifies an online MAC authentication user by its MAC address. The mac-address argument represents the MAC address of the user, in the form of H-H-H. If you do not specify an online MAC authentication user, this command displays all online MAC authentication user information.
user-name user-name: Specifies an online MAC authentication user by its username. The user name is a case-sensitive string of 1 to 55 characters, and it can include the domain name. If you do not specify an online MAC authentication user, this command displays all online MAC authentication user information.
# Display information about all online MAC authentication users.
Total connections: 1
Slot ID: 0
Username: ias
User access state: Successful
Authentication domain: macusers
IPv4 address: 192.168.1.1
IPv4 address source: User packet
IPv6 address source: User packet
Initial VLAN: 1
Authorization VSI: N/A
Authorization microsegment ID: N/A
Authorization dynamic ACL name: N/A
Authorization CAR: N/A
Authorization URL: N/A
Authorization IPv6 URL: N/A
Authorization temporary redirect: Disabled
Start accounting: Successful
Real-time accounting-update failures: 0
Termination action: RADIUS-request
Session timeout period: 2 sec
Offline detection: 100 sec (server-assigned)
Online from: 2013/03/02 13:14:15
Online duration: 0h 2m 15s
Port-down keep online: Enabled
User MAC address: 0015-e9a6-abcd
M-LAG NAS-IP type: Local
M-LAG user state: Active
Access interface: Bridge-Aggregation1
Username: luser
Initial VLAN: 1
Authorization CAR:
Average input rate: 102400 bps
Peak input rate: 204800 bps
Average output rate: 102400 bps
Peak output rate: 204800 bps
Online from: 2020/12/02 13:14:15
Online duration: 0h 7m 15s
Total connections |
Total number of online MAC authentication users. |
User MAC address |
MAC address of the user. |
M-LAG NAS-IP type |
NAS-IP address type for the user if the user is authenticated on an M-LAG interface of the M-LAG system. · Local—Local NAS-IP address. The source IP address of outgoing RADIUS packets is an IP address on the local M-LAG member device. · Peer—Peer NAS-IP address. The source IP address of outgoing RADIUS packets is an IP address on the peer M-LAG member device. |
M-LAG user state |
Local state of the user on the M-LAG interface: · Active—The local M-LAG member device exchanges user authentication information with the AAA server. · Inactive—The peer M-LAG member device exchanges user authentication information with the AAA server. |
Access interface |
Interface through which the user accesses the device. |
User access state |
Access state of the user: · Auth-Fail domain—The user is in the Auth-Fail domain. · Critical domain—The user is in the critical domain. · Preauth domain—The user is in the preauthentication domain. · Successful—The user has passed MAC authentication and is online. · URL-unavailable domain—The user is in the URL-unavailable domain. · Open—The user uses a nonexistent username or an incorrect password to come online in open authentication mode. · Temporary—The user has passed MAC authentication on a port operating in macAddressAndUserLoginSecureExt mode. |
MAC authentication domain to which the user belongs. |
IPv4 address |
IPv4 address of the user. If no user IPv4 address is available, this field is not displayed. |
IPv6 address |
IPv6 address of the user. If no user IPv6 address is available, this field is not displayed. |
IPv4 address source |
Source of the user IPv4 address: · User packet—The IPv4 address was obtained from a user packet. · IP Source Guard—The IPv4 address was received from the IP source guard module. |
IPv6 address source |
Source of the user IPv6 address: · User packet—The IPv6 address was obtained from a user packet. · IP Source Guard—The IPv6 address was received from the IP source guard module. |
Initial VLAN |
VLAN that holds the user before MAC authentication. |
Authorization untagged VLAN |
Untagged VLAN authorized to the user. |
Authorization tagged VLAN |
Tagged VLAN authorized to the user. |
Authorization VSI |
VSI authorized to the user. |
Authorization ACL number/name |
Number or name of the static ACL authorized to the user. If no ACL has been authorized to the user, this field displays N/A. If ACL authorization failed, this field displays (NOT effective) next to the ACL number or name. |
Authorization dynamic ACL name |
Name of the dynamic ACL authorized to the user. If no dynamic ACL has been authorized to the user, this field displays N/A. If ACL authorization failed, this field displays (NOT effective) next to the ACL name. |
Authorization user profile |
User profile authorized to the user. |
Authorization CAR |
This field is not supported in the current software version. Authorization CAR attributes assigned by the server. If no authorization CAR attributes are assigned, this field displays N/A. |
Authorization URL |
Redirect URL authorized to the user. |
Authorization IPv6 URL |
IPv6 redirect URL authorized to the user. |
Authorization temporary redirect |
State of temporary redirection authorization: · Enabled—Temporary redirection is authorized. The HTTP or HTTPS redirection packets sent to the user include state code 302. · Disabled—Temporary redirection is not authorized. The HTTP or HTTPS redirection packets sent to the user include state code 200. |
Start accounting |
Start-accounting request result: · Successful. · Failed. The device does not support accounting for users in the preauthentication domain. For such users, this field displays N/A. |
Real-time accounting-update failures |
Number of consecutive real-time accounting-update failures. |
Termination action |
Action attribute assigned by the server to terminate the user session: · Default—Logs off the online authenticated user when the server-assigned session timeout timer expires. This attribute does not take effect when periodic MAC reauthentication is enabled and the periodic reauthentication timer is shorter than the server-assigned session timeout timer. · RADIUS-request—Reauthenticates the online user when the server-assigned session timeout timer expires, regardless of whether the periodic MAC reauthentication feature is enabled or not. If the device performs local authentication, this field displays N/A. |
Session timeout period |
Session timeout timer assigned by the server. |
Offline detection |
Offline detection setting for the user: · Ignore (command-configured)—The device does not perform offline detection for the user. The setting is configured from the CLI. · timer (command-configured)—Represents the offline detection timer. The timer is configured from the CLI, · Ignore (server-assigned)—The device does not perform offline detection for the user. The setting is assigned by a RADIUS server. · timer (server-assigned)—Represents the offline detection timer. The timer is assigned by a RADIUS server. |
Online from |
Time from which the MAC authentication user came online. |
Online duration |
Online duration of the MAC authentication user. |
Port-down keep online |
Whether the device allows the user to stay online after the user's access interface goes down. Setting for this field depends on the state of the shutdown-keep-online proprietary attribute issued by the RADIUS server. · Enabled—The device allows the user to stay online after the access interface goes down. This state is displayed if the RADIUS server assigned the shutdown-keep-online proprietary attribute and set the attribute not to 0. · Disabled (offline)—The device logs off the user when the access interface goes down. This state is displayed if the RADIUS server assigned the shutdown-keep-online proprietary attribute and set the attribute to 0, or the RADIUS server did not assign the attribute. |
Use display mac-authentication mac-address to display the MAC addresses of MAC authentication users in a type of MAC authentication VLAN, or VSI.
display mac-authentication mac-address { critical-vlan | critical-vsi | guest-vlan | guest-vsi } [ interface interface-type interface-number ]
critical-vlan: Specifies MAC authentication critical VLANs.
critical-vsi: Specifies MAC authentication critical VSIs.
guest-vlan: Specifies MAC authentication guest VLANs.
guest-vsi: Specifies MAC authentication guest VSIs.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays the MAC addresses of MAC authentication users in the specified type of MAC authentication VLAN, or VSI on all ports.
The displayed MAC addresses and MAC address count might not include all MAC addresses if a large number of MAC authentication users are performing authentication frequently.
# Display the MAC addresses of MAC authentication users in the MAC authentication guest VLANs on all ports.
<Sysname> display mac-authentication mac-address guest-vlan
Total MAC addresses: 10
Interface: Ten-GigabitEthernet1/0/1 Guest VLAN: 3 Aging time: N/A
MAC addresses: 8
0800-2700-9427 0800-2700-2341 0800-2700-2324 0800-2700-2351
0800-2700-5627 0800-2700-2251 0800-2700-8624 0800-2700-3f51
Interface: Ten-GigabitEthernet1/0/2 Guest VLAN: 5 Aging time: 30 sec
MAC addresses: 2
0801-2700-9427 0801-2700-2341
# Display the MAC addresses of MAC authentication users in the MAC authentication guest VSIs on all ports.
<Sysname> display mac-authentication mac-address guest-vsi
Interface: Ten-GigabitEthernet1/0/3 Guest VSI: text-vsi Aging time: N/A
MAC addresses: 8
Interface: Ten-GigabitEthernet1/0/4 Guest VSI: text1-vsi Aging time: 30 sec
MAC addresses: 2
Total MAC addresses |
Total number of MAC addresses in the specified type of VLAN, or VSI on the specified port or all ports. |
Access port of MAC authentication users. |
Type VLAN/VSI |
Location of the MAC authentication users. Available types: · Critical VLAN. · Critical VSI. · Guest VLAN. · Guest VSI. |
Aging time |
MAC address aging time in seconds. This field displays N/A if the MAC addresses do not age out. |
MAC addresses |
Number of matching MAC addresses on a port. |
xxxx-xxxx-xxxx |
MAC address. |
Use display mac-authentication user-recovery-profile to display MAC authentication user recovery profiles.
display mac-authentication user-recovery-profile [ profile-name ]
profile-name: Specifies a MAC authentication user recovery profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a profile, this command displays all authentication user recovery profiles.
# Display all MAC authentication user recovery profiles.
<Sysname> display mac-authentication user-recovery-profile
User-recovery profile: profile1
Server IP : 3.3.3.3
Port : 8080
VPN : Not configured
Login name : user1
NAS IP address: 10.1.1.1
URI : dumbtermina/list
User-recovery profile: profile2
Server IP : 1.1.1.2
Port : 80
Login name : user1
NAS IP address: 1:2::3:4
User-recovery profile |
MAC authentication user recovery profile name. |
Server IP |
IP address of the RESTful server |
Port |
Port number of the RESTful server. |
VPN |
VPN instance to which the RESTful server belongs. |
Login name |
Username for accessing the RESTful server. |
NAS IP address |
NAS IP address used by the device to communicate with the RESTful server. |
URI |
URI used by the RESTful server to provide MAC authentication user information. |
server-address
login-user
nas-ip
uri
login-name
Use login-name to configure the username and password for accessing the RESTful server in a MAC authentication user recovery profile.
Use undo login-name to restore the default.
login-name username [ password { cipher | simple } string ]
undo login-name
No username or password is configured for accessing the RESTful server in a MAC authentication user recovery profile.
MAC authentication user recovery profile view
username: Specifies the username, a case-sensitive string of 1 to 55 characters.
password: Specifies the password. If no password is required for accessing the RESTful server, do not specify this keyword.
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters, and its encrypted form is a case-sensitive string of 1 to 117 characters.
Make sure the username and password settings are the same as the settings on the RESTful server.
# In MAC authentication user recovery profile profile1, configure the username and password for accessing the RESTful server as abc and plaintext string 123, respectively.
[Sysname] mac-authentication user-recovery-profile profile1
[Sysname-user-recovery-profile-profile1] login-name abc password simple 123
mac-authentication
Use mac-authentication to enable MAC authentication globally or on a port.
Use undo mac-authentication to disable MAC authentication globally or on a port.
mac-authentication
MAC authentication is disabled globally or on any port.
To use MAC authentication on a port, you must enable the feature both globally and on the port.
When you enable MAC authentication and use one or both of the if-match qos-local-id and remark qos-local-id commands, the following restrictions apply:
· The local QoS ID configured by using the if-match qos-local-id command must be lower than 3000.
· The local QoS ID to be marked for packets configured by using the remark qos-local-id command must be lower than 3000.
For more information about the if-match qos-local-id command, see policy-based routing commands and IPv6 policy-based routing commands in Layer 3—IP Routing Command Reference. For more information about the remark qos-local-id command, see QoS commands in ACL and QoS Command Reference.
# Enable MAC authentication globally.
# Enable MAC authentication on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication
Use mac-authentication access-user log enable to enable MAC authentication user logging.
Use undo mac-authentication access-user log enable to disable MAC authentication user logging.
MAC authentication user logging is disabled.
failed-login: Logs MAC authentication user login failures.
logoff: Logs MAC authentication user logoffs.
successful-login: Logs successful MAC authentication user logins.
To prevent excessive MAC authentication user log entries, use this feature only if you need to analyze abnormal MAC authentication user logins or logouts.
If you do not specify any parameters, this command enables all types of MAC authentication user logs.
# Enable logging MAC authentication user login failures.
info-center source maca logfile deny (Network Management and Monitoring Command Reference)
Use mac-authentication authentication-method to specify an authentication method for MAC authentication.
Use undo mac-authentication authentication-method to restore the default.
mac-authentication authentication-method { chap | pap }
The device uses PAP for MAC authentication.
chap: Configures the access device to use the Challenge Handshake Authentication Protocol (CHAP) to communicate with the RADIUS server.
pap: Configures the access device to use the Password Authentication Protocol (PAP) to communicate with the RADIUS server.
RADIUS-based MAC authentication supports the following authentication methods:
· PAP—Transports usernames and passwords in plain text. The authentication method applies to scenarios that do not require high security.
· CHAP—Transports usernames in plain text and passwords in encrypted form over the network. CHAP is more secure than PAP.
# Configure the device to use CHAP for MAC authentication.
[Sysname] mac-authentication authentication-method chap
Use mac-authentication auth-server-unavailable escape to enable online MAC authentication users to escape from offline detection and stay online when no reachable RADIUS authentication servers are available.
Use undo mac-authentication auth-server-unavailable escape to disable online MAC authentication users from escaping from offline detection when no reachable RADIUS authentication servers are available.
By default, online MAC authentication users cannot escape from offline detection (if enabled) when no reachable RADIUS authentication servers are available.
The offline detection feature for MAC authentication logs off an online MAC authentication user if it has not detected traffic from that user before the offline-detect timer expires. To prevent online MAC authentication users on a port from being forced offline by the offline detection feature and stay online when none of the RADIUS servers in their ISP domain is reachable, use this command.
Use this command only when RADIUS scheme authentication is configured for the MAC authentication users on a port. If local or no authentication is also configured, offline detection might be undesirably disabled for MAC authentication users that come online through local authentication or without authentication.
# Enable online MAC authentication users on port Ten-GigabitEthernet 1/0/1 to escape from offline detection and stay online when no reachable RADIUS authentication servers are available.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication auth-server-unavailable escape
Use mac-authentication auto-recover-user to enable automatic MAC authentication user recovery based on a MAC authentication user recovery profile.
Use undo mac-authentication auto-recover-user to disable automatic MAC authentication user recovery based on a profile.
mac-authentication auto-recover-user profile profile-name
undo mac-authentication auto-recover-user profile profile-name
Automatic MAC authentication user recovery is disabled.
profile profile-name: Specifies a MAC authentication user recovery profile by its name, a case-insensitive string of 1 to 31 characters.
This feature enables the device to automatically obtain MAC authentication user information from a RESTful server and perform a reauthentication after the device or an interface module reboots or after an interface recovers from a failure.
This feature recovers the online state of MAC authenticated users quickly without waiting for packets from the MAC authentication users to trigger a reauthentication. It is helpful when the network has a large number of dumb terminals or the operation of dumb terminals is important for services.
To define the profile used for obtaining MAC authentication user information from a RESTful server, use the mac-authentication user-recovery-profile command.
For this feature to take effect after the system reboots, use the save command to save the configuration to the next-startup configuration file after you configure this feature. For more information about the save command, see configuration file management commands in Fundamentals Command Reference.
The automatic MAC authentication user recovery feature is mutually exclusive with the RADIUS accounting-on feature. Do not use the two features together. For more information about the RADIUS accounting-on feature, see AAA configuration in Security Configuration Guide.
# Enable automatic MAC authentication user recovery based on profile profile1.
[Sysname] mac-authentication auto-recover-user profile profile1
accounting-on enable
Use mac-authentication carry user-ip to include user IP addresses in MAC authentication requests sent to an IMC server.
Use undo mac-authentication carry user-ip to restore the default.
mac-authentication carry user-ip [ exclude-ip acl acl-number ]
A MAC authentication request does not include the user IP address.
exclude-ip: Specifies an ACL-based filter to identify source IP addresses that can or cannot trigger MAC authentication.
acl acl-number: Specifies a basic ACL or user-defined ACL. The value range for the acl-number argument is 2000 to 2999 and 5000 to 5999.
IMPORTANT: This command can only operate in conjunction with an IMC server. |
To avoid IP conflicts that result from changes to static IP addresses, use this command on a port that has MAC authentication users with static IP addresses.
This command adds user IP addresses to the MAC authentication requests sent to the authentication server. When MAC authentication is triggered for a user, the device checks the user's IP address for invalidity.
· If the IP address is valid, the device sends a MAC authentication request with the IP address included.
· If the IP address is not a valid host IP address or the triggering packet does not contain an IP address, the device does not initiate MAC authentication.
· If the packet is a DHCP packet with a source IP address of all zeros, the device sends a MAC authentication request without including the IP address. In this case, the IMC server does not examine the user IP address when it performs authentication.
Upon receipt of the authentication request that includes a user's IP address, the IMC server compares the user's IP and MAC addresses with its IP-MAC mappings.
· If an exact match is found or if no match is found, the user passes MAC authentication. In the latter case, the server creates an IP-MAC mapping for the user.
· If a mapping is found for the MAC address but the IP addresses do not match, the user fails the MAC authentication.
If the user host is configured with IPv6, the device might receive packets that contain an IPv6 link-local address, which starts with fe80. MAC authentication failure or incorrect MAC-IP binding will occur if this address is used in MAC authentication. To avoid these issues, configure an ACL to exclude the IPv6 IP addresses that start with fe80.
When you configure the ACL, follow these guidelines:
· The specified ACL number represents an IPv4 ACL and an IPv6 ACL with the same number. For example, if the ACL number is 2000, you specify both IPv4 ACL 2000 and IPv6 ACL 2000. The IPv4 ACL and the IPv6 ACL will be used to process IPv4 packets and IPv6 packets, respectively.
· Use permit rules to identify source IP addresses that are valid for MAC authentication. Use deny rules to identify source IP addresses that cannot trigger MAC authentication.
· In the rules, only the action keyword (permit or deny) and the source IP match criteria can take effect. If the ACL is a user-defined ACL (numbered in the range of 5000 to 5999), only the ipv4, ipv6, and any source IP match criteria can take effect.
· As a best practice, configure a deny rule to exclude the IPv6 IP addresses that start with fe80 from triggering MAC authentication.
· If you configure permit rules, add a deny all rule at the bottom of the ACL.
· If the specified ACL does not exist or is empty, any user IP addresses can trigger MAC authentication.
· If the specified ACL does not contain source IP address rules, no user IP addresses can trigger MAC authentication.
· If an ACL rule contains a VPN instance matching criterion, that rule does not take effect.
Do not use this command in conjunction with the mac-authentication guest-vlan or the mac-authentication guest-vsi command on a port. The device cannot perform MAC authentication for a user once that user is added to the MAC authentication guest VLAN or guest VSI.
# Include user IP addresses in MAC authentication requests on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication carry user-ip
# Include user IP addresses in MAC authentication requests on Ten-GigabitEthernet 1/0/1 and deny users that use IPv6 link-local addresses from performing MAC authentication on the port.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule deny source fe80:0::0:0 16
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication carry user-ip exclude-ip acl 2000
mac-authentication
Use mac-authentication critical vlan to configure a MAC authentication critical VLAN on a port.
Use undo mac-authentication critical vlan to restore the default.
mac-authentication critical vlan critical-vlan-id [ url-user-logoff ]
No MAC authentication critical VLAN exists on a port.
critical-vlan-id: Specifies a VLAN as the MAC authentication critical VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created.
url-user-logoff: Forces the MAC authentication users that have been assigned a redirect URL to go offline when the Web authentication server at the URL is detected unreachable or when all the RADIUS authentication servers are detected unreachable. You specify this keyword to make sure the Web users can be logged off and added to the critical VLAN promptly to gain access to limited network resources when the Web authentication service or RADIUS authentication service becomes unavailable. If you do not specify this keyword, the MAC authentication users that have been assigned redirect URLs will stay online without network access until the offline detection feature forces them to go offline. The offline detection feature forces a user to go offline when no packets have been received from them before the offline detection timer expires.
The MAC authentication critical VLAN accommodates users that have failed MAC authentication because all the servers in their ISP domains are unreachable. Users in the critical VLAN can access network resources in the critical VLAN.
You cannot specify a VLAN as both a super VLAN and a MAC authentication critical VLAN on a port. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
On a port, the MAC authentication critical VLAN configuration is mutually exclusive with the MAC authentication guest and critical VSI settings.
The critical VLAN feature takes effect when MAC authentication is performed only through RADIUS servers. If a MAC authentication user fails local authentication after RADIUS authentication, the user is not assigned to the critical VLAN.
Before you delete a VLAN that has been set as a MAC authentication critical VLAN, use the undo mac-authentication critical vlan command to remove the critical VLAN configuration.
If the url-user-logoff keyword is specified, the device forces the MAC authentication users that have been assigned a redirect URL on the port to go offline when the Web authentication service or RADIUS authentication service is detected unavailable by using one of the following methods:
· The redirect URL is detected unreachable by the Track module. You associate a track entry with the redirect URL by using the mac-authentication redirect-url command.
· All the RADIUS servers are detected unreachable when MAC authentication users have been enabled to escape from online detection by using the mac-authentication auth-server-unavailable escape command.
· The first user is added to the critical VLAN. This means that none of the authentication servers is reachable.
The device does not add MAC authentication users that are assigned a redirect URL to the critical VLAN if the Web authentication server at the redirect URL is unreachable or no RADIUS servers are reachable the first time they attempt to come online. The device adds these users to the critical VLAN only if the Web authentication server at the redirect URL is unreachable or no RADIUS servers are reachable when they make a reauthentication attempt.
# Configure VLAN 100 as the MAC authentication critical VLAN on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication critical vlan 100
Use mac-authentication critical vsi to configure a MAC authentication critical VSI on a port.
Use undo mac-authentication critical vsi to restore the default.
mac-authentication critical vsi critical-vsi-name [ url-user-logoff ]
No MAC authentication critical VSI exists on a port.
critical-vsi-name: Specifies the name of the MAC authentication critical VSI on the port, a case-sensitive string of 1 to 31 characters.
url-user-logoff: Forces the MAC authentication users that have been assigned a redirect URL to go offline when the Web authentication server at the URL is detected unreachable or when all the RADIUS authentication servers are detected unreachable. You specify this keyword to make sure the Web users can be logged off and added to the critical VSI promptly to gain access to limited network resources when the Web authentication service or RADIUS authentication service becomes unavailable. If you do not specify this keyword, the MAC authentication users that have been assigned redirect URLs will stay online without network access until the offline detection feature forces them to go offline. The offline detection feature forces a user to go offline when no packets have been received from them before the offline detection timer expires.
The MAC authentication critical VSI accommodates users that have failed MAC authentication because all the servers in their ISP domains are unreachable. Users in the critical VSI can access only network resources in the VXLAN associated with this VSI.
You can configure only one MAC authentication critical VSI on a port. The MAC authentication critical VSIs on different ports can be different.
On a port, the MAC authentication critical VSI configuration is mutually exclusive with the MAC authentication guest and critical VLAN settings.
· The first user is added to the critical VSI. This means that none of the authentication servers is available.
The device does not add MAC authentication users that are assigned a redirect URL to the critical VSI if the Web authentication server at the redirect URL is unreachable or no RADIUS servers are reachable the first time they attempt to come online. The device adds these users to the critical VSI only if the Web authentication server at the redirect URL is unreachable or no RADIUS servers are reachable when they make a reauthentication attempt.
# Configure VSI vpna as the MAC authentication critical VSI on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication critical vsi vpna
Use mac-authentication critical-voice-vlan to enable the MAC authentication critical voice VLAN feature on a port.
Use undo mac-authentication critical-voice-vlan to restore the default.
The MAC authentication critical voice VLAN feature is disabled on a port.
The MAC authentication critical voice VLAN on a port accommodates MAC authentication voice users that have failed authentication because none of the RADIUS servers in their ISP domain are reachable.
Before you enable the MAC authentication critical voice VLAN feature on the port, make sure the following requirements are met:
· The port is configured with the voice VLAN.
To configure a voice VLAN on a port, use the voice-vlan enable command (see Layer 2—LAN Switching Command Reference).
· LLDP is enabled both globally and on the port.
The device uses LLDP to identify voice users. For information about LLDP commands, see Layer 2—LAN Switching Command Reference.
· A MAC authentication critical VLAN is configured on the port. This setting ensures that a voice user is assigned to the critical VLAN if it has failed authentication for unreachability of RADIUS servers before the device recognizes it as a voice user. If a MAC authentication critical VLAN is not available, the voice user might be logged off instead.
# Enable the MAC authentication critical voice VLAN feature on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication critical-voice-vlan
lldp enable (Layer 2—LAN Switching Command Reference)
lldp global enable (Layer 2—LAN Switching Command Reference)
voice-vlan enable (Layer 2—LAN Switching Command Reference)
mac-authentication domain
Use mac-authentication domain to specify a global or port-specific authentication domain.
Use undo mac-authentication domain to restore the default.
The system default authentication domain is used. For more information about the default authentication domain, see the domain default enable command in "AAA commands."
domain-name: Specifies the name of an ISP domain, a case-insensitive string of 1 to 255 characters.
The global authentication domain applies to all MAC authentication-enabled ports. An authentication domain specified in Layer 2 Ethernet interface view or Layer 2 aggregate interface view applies only to the port. You can specify different authentication domains on different ports.
A port chooses an authentication domain for MAC authentication users in the following order:
1. Authentication domain specified on the port.
2. Global authentication domain specified in system view.
3. Default authentication domain.
# Specify ISP domain domain1 as the global MAC authentication domain.
# Specify ISP domain aabbcc as the MAC authentication domain on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication domain aabbcc
Use mac-authentication guest-vlan to configure a MAC authentication guest VLAN on a port.
Use undo mac-authentication guest-vlan to restore the default.
No MAC authentication guest VLAN exists on a port.
guest-vlan-id: Specifies a VLAN as the MAC authentication guest VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created.
The MAC authentication guest VLAN accommodates users that have failed MAC authentication for any reason other than server unreachable. For example, the VLAN accommodates users with invalid passwords entered. You can deploy a limited set of network resources in the MAC authentication guest VLAN. For example, a software server for downloading software and system patches.
You cannot specify a VLAN as both a super VLAN and a MAC authentication guest VLAN on a port. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
On a port, the MAC authentication guest VLAN configuration is mutually exclusive with the MAC authentication guest VSI and critical VSI settings.
Before you delete a VLAN that has been set as a MAC authentication guest VLAN, use the undo mac-authentication guest-vlan command to remove the guest VLAN configuration.
# Configure VLAN 100 as the MAC authentication guest VLAN on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication guest-vlan 100
Use mac-authentication guest-vlan auth-period to set the interval at which the device authenticates users in the MAC authentication guest VLAN.
Use undo mac-authentication guest-vlan auth-period to restore the default.
The device authenticates users in the MAC authentication guest VLAN every 30 seconds.
period-value: Sets the authentication interval for users in the MAC authentication guest VLAN. The value range is 1 to 3600, in seconds.
For this command to take effect, you must use the mac-authentication guest-vlan re-authenticate command to enable guest VLAN reauthentication in MAC authentication.
As a best practice, set the reauthentication interval to a value greater than 30 seconds if the number of concurrent MAC authentication users on a port is likely to exceed 300.
# Set the authentication interval to 150 seconds for users in the MAC authentication guest VLAN on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication guest-vlan auth-period 150
Use mac-authentication guest-vlan re-authenticate to enable the guest VLAN reauthentication feature of MAC authentication on a port.
Use undo mac-authentication guest-vlan re-authenticate to disable the guest VLAN reauthentication feature of MAC authentication on a port.
The guest VLAN reauthentication feature of MAC authentication is enabled on a port.
The guest VLAN reauthentication feature of MAC authentication enables the device to reauthenticate users in the MAC authentication guest VLAN on a port at reauthentication intervals.
Typically, you disable this feature to suppress excessive authentication failure log messages, which might occur when a network issue results in a large number of reauthentication failures.
If guest VLAN reauthentication is disabled on a port, the device does not reauthenticate users in the MAC authentication guest VLAN on the port. The guest VLAN users will stay in the guest VLAN until they age out. To configure the aging timer, use the mac-authentication timer user-aging guest-vlan aging-time-value command.
# Enable the guest VLAN reauthentication feature of MAC authentication on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication guest-vlan re-authenticate
Use mac-authentication guest-vsi to configure a MAC authentication guest VSI on a port.
Use undo mac-authentication guest-vsi to restore the default.
mac-authentication guest-vsi guest-vsi-name
No MAC authentication guest VSI exists on a port.
guest-vsi-name: Specifies the name of the MAC authentication guest VSI on the port, a case-sensitive string of 1 to 31 characters.
The MAC authentication guest VSI accommodates users that have failed MAC authentication for any reason other than server unreachable. For example, the VSI accommodates users with invalid passwords entered. You can deploy a limited set of network resources in the VXLAN that is associated with the guest VSI. For example, a software server for downloading software and system patches.
You can configure only one MAC authentication guest VSI on a port. The MAC authentication guest VSIs on different ports can be different.
On a port, the MAC authentication guest VSI configuration is mutually exclusive with the MAC authentication guest VLAN and critical VLAN settings.
From the start letter, the name of the guest VSI cannot overlay with the auth-period or re-authenticate keyword. For example, the name cannot be a, auth, r, or re. If a VSI with such a name is specified as the guest VSI, the guest VSI configuration fails. Instead, the mac-authentication guest-vsi auth-period or mac-authentication guest-vsi re-authenticate command is triggered.
# Configure VSI vpna as the MAC authentication guest VSI on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication guest-vsi vpna
Use mac-authentication guest-vsi auth-period to set the interval at which the device authenticates users in the MAC authentication guest VSI.
Use undo mac-authentication guest-vsi auth-period to restore the default.
mac-authentication guest-vsi auth-period period-value
The device authenticates users in the MAC authentication guest VSI every 30 seconds.
period-value: Sets the authentication interval for users in the MAC authentication guest VSI. The value range is 1 to 3600, in seconds.
For this command to take effect, you must use the mac-authentication guest-vsi re-authenticate command to enable guest VSI reauthentication in MAC authentication.
# Set the authentication interval to 150 seconds for users in the MAC authentication guest VSI on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication guest-vsi auth-period 150
Use mac-authentication guest-vsi re-authenticate to enable the guest VSI reauthentication feature of MAC authentication on a port.
Use undo mac-authentication guest-vsi re-authenticate to disable the guest VSI reauthentication feature of MAC authentication on a port.
The guest VSI reauthentication feature of MAC authentication is enabled on a port.
The guest VSI reauthentication feature of MAC authentication enables the device to reauthenticate users in the MAC authentication guest VSI on a port at reauthentication intervals.
If guest VSI reauthentication is disabled on a port, the device does not reauthenticate users in the MAC authentication guest VSI on the port. The guest VSI users will stay in the guest VSI until they age out. To configure the aging timer, use the mac-authentication timer user-aging guest-vsi aging-time-value command.
# Enable the guest VSI reauthentication feature of MAC authentication on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication guest-vsi re-authenticate
Use mac-authentication host-mode multi-vlan to enable multi-VLAN mode for MAC authentication users on a port.
Use undo mac-authentication host-mode to restore the default.
MAC authentication operates in single-VLAN mode on a port.
In single-VLAN mode, the port reauthenticates an online user when traffic received from that user contains a VLAN tag different from the VLAN in which the user was authenticated. The reauthentication might cause service interruption.
In multi-VLAN mode, the port forwards traffic from a user in different VLANs without reauthentication if the user has been authenticated and come online in any VLAN on the port. Free of reauthentication, traffic from an online user can be sent in different VLANs without delay or service interruption.
To accommodate IP phone services or any other applications that are sensitive to delay or service interruption in a multi-VLAN environment, enable MAC authentication multi-VLAN mode.
# Enable MAC authentication multi-VLAN mode on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication host-mode multi-vlan
port-security mac-move permit
Use mac-authentication mac-range-account to configure a username and password for MAC authentication users in a MAC address range.
Use undo mac-authentication mac-range-account to restore the default.
mac-authentication mac-range-account mac-address mac-address mask { mask | mask-length } account name password { cipher | simple } string
undo mac-authentication mac-range-account { all | mac-address mac-address }
No username or password is specifically configured for MAC authentication users in a MAC address range. The global user account policy applies to the users.
mac-address mac-address: Specifies a MAC address in the format of H-H-H.
mask mask: Specifies a MAC address mask, in the format of H-H-H. Make sure the most significant bits of the MAC address mask in binary format are consecutive 1s.
mask mask-length: Specifies a MAC address mask length, in the range of 1 to 48.
account name: Specifies a username. The name is a case-sensitive string of 1 to 55 characters, and cannot include the at sign (@).
password: Specifies the user password.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
all: Specifies all MAC address ranges.
Use this command to configure user account settings for users in a MAC address range (for example, users with a specific OUI). For users in the specified range, this command has higher priority than the mac-authentication user-name-format command.
You can configure a maximum of 16 MAC address ranges. However, you must make sure the MAC address ranges do not overlap.
If you configure user account settings multiple times for the same MAC address range, the most recent configuration overwrites the previous configuration.
The mac-authentication mac-range-account command applies only to unicast MAC addresses.
· If you specify a MAC address range that contains only multicast MAC addresses, execution of this command will fail.
· If you specify a MAC address range that contains both unicast and multicast MAC addresses, the command takes effect only on unicast MAC addresses.
The all-zero MAC address is invalid for MAC authentication. Users with the all-zero MAC address cannot pass MAC authentication.
# Configure a user account for MAC addresses that start with aaaa. Set the MAC address mask to ffff-0000-0000, the username to user1, and the password to 1234 in plaintext form.
[Sysname] mac-authentication mac-range-account mac-address aaaa-0000-0000 mask ffff-0000-0000 account user1 password simple 1234
mac-authentication max-user
Use mac-authentication max-user to set the maximum number of concurrent MAC authentication users on a port.
Use undo mac-authentication max-user to restore the default.
mac-authentication max-user [ preauth-domain | auth-fail-domain ] max-number
undo mac-authentication max-user [ preauth-domain | auth-fail-domain ]
A port allows a maximum of 4294967295 concurrent MAC authentication users.
preauth-domain: Specifies the preauthentication domain.
auth-fail-domain: Specifies the Auth-Fail domain.
max-number: Sets the maximum number of concurrent MAC authentication users on the port. The value range for this argument is 1 to 4294967295.
If you do not specify the preauth-domain or auth-fail-domain keyword, this command sets the maximum number of concurrent MAC authentication users on a port for MAC authentication users using all access types. The MAC authentication users include MAC authentication users in the preauthentication domain, Auth-Fail domain, and critical domain, and MAC authentication users that have passed authentication.
Set the maximum number of concurrent MAC authentication users on a port to prevent the system resources from being overused. When the maximum number is reached, the port denies subsequent MAC authentication users.
# Configure Ten-GigabitEthernet 1/0/1 to support a maximum of 32 concurrent MAC authentication users.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication max-user 32
mac-authentication offline-detect enable
Use mac-authentication offline-detect enable to enable MAC authentication offline detection on a port.
Use undo mac-authentication offline-detect enable to disable MAC authentication offline detection.
MAC authentication offline detection is enabled on a port.
The MAC authentication offline detection feature monitors the online status of MAC authentication users. This feature uses an offline detection timer to set the interval that the device must wait for traffic from a user before the device determines that the user is idle. If the device has not received traffic from a user before the timer expires, the device logs off that user and requests the accounting server to stop accounting for the user.
To set the offline detection timer, use the mac-authentication timer command.
# Disable MAC authentication offline detection on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] undo mac-authentication offline-detect enable
mac-authentication offline-detect mac-address
Use mac-authentication offline-detect mac-address to configure MAC authentication offline detection for a MAC authentication user.
Use undo mac-authentication offline-detect mac-address to restore the default.
mac-authentication offline-detect mac-address mac-address { ignore | timer offline-detect-value [ check-arp-or-nd-snooping ] }
undo mac-authentication offline-detect mac-address mac-address
The offline detection settings configured on access ports take effect and the offline detection timer set in system view is used.
mac-address: Specifies a MAC address in the format of H-H-H, excluding multicast, all-zero, and all-F MAC addresses.
ignore: Skips offline detection for the specified user.
timer offline-detect-value: Specifies the offline detection timer for the specified user. The value range is 60 to 2147483647 seconds.
check-arp-or-nd-snooping: Uses the ARP snooping or ND snooping table in offline detection to determine the offline state of the user.
Use this command to set offline detection parameters specific to a MAC authentication user. To have this command take effect, you must make sure MAC authentication offline detection is enabled on the user's access port. The user-specific offline detection settings take effect on the online users immediately after they are configured.
Use this command as follows:
· Set an offline detection timer specific to a user and control whether to use the ARP snooping or ND snooping table to determine the offline state of the user.
¡ If the ARP snooping or ND snooping table is used, the device searches the ARP snooping or ND snooping table before it checks for traffic from the user within the detection interval. If a matching ARP snooping or ND snooping entry is found, the device resets the offline detection timer and the user stays online. If the offline detection timer expires because the device has not found a matching snooping entry for the user or received traffic from the user, the device disconnects the user.
¡ If the ARP or ND snooping table is not used, the device disconnects the user if it has not received traffic from that user before the offline detection timer expires.
When disconnecting the user, the device also notifies the RADIUS server (if any) to stop user accounting.
· Skip offline detection for the user. You can choose this option if the user is a dumb terminal. A dumb terminal might fail to come online again after it is logged off by the offline detection feature.
The device uses the offline detection settings for a user in the following sequence:
1. User-specific offline detection settings.
2. Offline detection settings assigned to the user by the RADIUS server. The settings include the offline detection timer, use of the ARP or ND snooping table in offline detection, and whether to ignore offline detection.
3. Port-based offline detection settings.
# Disable MAC authentication offline detection for the MAC authentication user with MAC address 000a-eb29-7511.
[Sysname] mac-authentication offline-detect mac-address 000a-eb29-7511 ignore
# Enable MAC authentication offline detection for the MAC authentication user with MAC address 000a-eb29-7511, and set the offline detection timer to 24 hours.
[Sysname] mac-authentication offline-detect mac-address 000a-eb29-7511 timer 86400
mac-authentication timer (system view)
mac-authentication parallel-with-dot1x
Use mac-authentication parallel-with-dot1x to enable parallel processing of MAC authentication and 802.1X authentication on a port.
Use undo mac-authentication parallel-with-dot1x to restore the default.
Parallel processing of MAC authentication and 802.1X authentication is disabled on a port.
When you configure this command on a port, follow these restrictions and guidelines:
· Make sure the port meets the following requirements:
¡ The port is configured with both 802.1X authentication and MAC authentication and performs MAC-based access control for 802.1X authentication.
¡ The port is enabled with the 802.1X unicast trigger.
· For the port to perform MAC authentication before it is assigned to the 802.1X guest VLAN or guest VSI, use the dot1x guest-vlan-delay new-mac or dot1x guest-vsi-delay new-mac command to delay assigning the port to the 802.1X guest VLAN or guest VSI.
For information about the dot1x guest-vlan-delay new-mac or dot1x guest-vsi-delay new-mac command, see "802.1X commands."
· Do not enable MAC authentication delay on the port. This operation will delay MAC authentication after 802.1X authentication is triggered.
· To configure both 802.1X authentication and MAC authentication on the port, use one of the following methods:
¡ Enable the 802.1X and MAC authentication features separately on the port.
¡ Enable port security on the port. The port security mode must be userlogin-secure-or-mac or userlogin-secure-or-mac-ext.
For information about port security mode configuration, see port security in Security Configuration Guide.
# Enable parallel processing of MAC authentication and 802.1X authentication on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication parallel-with-dot1x
Use mac-authentication redirect-url to associate a redirect URL with a track entry to monitor the reachability of the Web authentication server at that URL.
Use undo mac-authentication redirect-url to remove the association of a redirect URL with its track entry.
mac-authentication redirect-url url-string track track-entry-number
undo mac-authentication redirect-url url-string
No redirect URLs are tracked.
url-string: Specifies the RADIUS server assigned redirect URL, a case-sensitive string of 1 to 255 characters. The URL must start with http:// or https://. Because a URL string can contain question marks (?), you cannot obtain help information by entering a question mark at the position of this argument.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
By default, the device does not track the availability of the Web server at the redirect URL assigned to MAC authentication users. On the device, the state of the Web server will always be active, regardless of its availability. To have the MAC authentication module log off MAC authentication users that have been assigned a redirect URL promptly when the Web server at that URL becomes unavailable, associate that redirect URL with a track entry to monitor its reachability.
As a best practice, configure the track entry associated with the redirect URL to collaborate with an HTTP NQA operation for detection. For more information about Track, see High Availability Configuration Guide. For more information about NQA, see Network Management and Monitoring Configuration Guide.
You can associate a URL with only one track entry. If you execute this command multiple times for a URL, the most recent configuration takes effect.
# Associate Web authentication service URL http://192.168.1.1:80/portal/ with a track entry.
[Sysname] mac-authentication redirect-url http://192.168.1.1:80/portal/ track 1
nqa schedule (Network Management and Monitoring Command Reference)
track nqa (High Availability Command Reference)
mac-authentication re-authenticate
Use mac-authentication re-authenticate to enable the periodic MAC reauthentication feature on a port.
Use undo mac-authentication re-authenticate to disable the periodic MAC reauthentication feature on a port.
The periodic MAC reauthentication feature is disabled on a port.
Periodic MAC reauthentication enables the access device to periodically authenticate online MAC authentication users on a port. This feature tracks the connection status of online users and updates the authorization attributes assigned by the server, such as the ACL and VLAN.
To set the periodic reauthentication timer, use the mac-authentication timer reauth-period command in system view or in Ethernet interface view.
If periodic reauthentication is triggered for a user while that user is waiting for online synchronization, the system performs online synchronization and does not perform reauthentication for the user.
# Enable the periodic MAC reauthentication feature on Ten-GigabitEthernet 1/0/1 and set the global periodic reauthentication timer to 1800 seconds.
[Sysname] mac-authentication timer reauth-period 1800
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication re-authenticate
mac-authentication server-recovery online-user-sync
mac-authentication re-authenticate server-unreachable keep-online
Use mac-authentication re-authenticate server-unreachable keep-online to enable the keep-online feature on a port.
Use undo mac-authentication re-authenticate server-unreachable to restore the default.
The keep-online feature is disabled on a port. The device logs off online MAC authentication users if no server is reachable for MAC reauthentication.
The keep-online feature keeps authenticated MAC authentication users online when no server is reachable for MAC reauthentication.
# Enable the keep-online feature for authenticated MAC authentication users on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication re-authenticate server-unreachable keep-online
mac-authentication recover-user
Use mac-authentication recover-user to manually trigger MAC authentication user recovery based on a MAC authentication user recovery profile.
mac-authentication recover-user profile profile-name [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command recovers MAC authentication users on all interfaces.
Use this command to manually trigger MAC authentication user recovery. Then, the device obtains MAC authentication user information from the RESTful server in the specified profile and performs reauthentication.
This command is helpful when automatic recovery fails to recover the online state of all MAC authenticated users because of link flapping.
# Use MAC authentication user recovery profile profile1 to manually recover MAC authentication users.
<Sysname> mac-authentication recover-user profile profile1
Use mac-authentication server-recovery online-user-sync to enable online user synchronization for MAC authentication.
Use undo mac-authentication server-recovery online-user-sync to disable online user synchronization for MAC authentication.
Online user synchronization for MAC authentication is disabled. The device does not synchronize online MAC authentication user information on a port with a RADIUS server after the RADIUS server recovers from the unreachable state.
IMPORTANT: This command takes effect only when the device uses an IMC RADIUS server to authenticate MAC authentication users. |
To ensure that the RADIUS server maintains the same online MAC authentication user information as the device after the server state changes from unreachable to reachable, use this feature.
This feature synchronizes online MAC authentication user information between the device and the RADIUS server when the RADIUS server state is detected having changed from unreachable to reachable.
When synchronizing online MAC authentication user information on a port with the RADIUS server, the device initiates MAC authentication in turn for each authenticated online MAC authentication user to the RADIUS server.
If synchronization fails for an online user, the device logs off that user unless the failure occurs because the server has become unreachable again.
The amount of time required to complete online user synchronization increases as the number of online users grows. This might result in an increased delay for new MAC authentication users and users in the critical VLAN or VSI to authenticate or reauthenticate to the RADIUS server and come online.
To have this feature take effect, you must use it in conjunction with the RADIUS server status detection feature, which is configurable with the radius-server test-profile command. For more information about the RADIUS server status detection feature, see AAA configuration in Security Configuration Guide.
# Enable online user synchronization for MAC authentication on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication server-recovery online-user-sync
timer quiet (RADIUS scheme view)
mac-authentication timer (interface view)
Use mac-authentication timer to configure a MAC authentication timer on a port.
Use undo mac-authentication timer to restore the default of a MAC authentication timer.
mac-authentication timer { auth-delay auth-delay-time | reauth-period reauth-period-value }
undo mac-authentication timer { auth-delay | reauth-period }
No MAC authentication delay timer is set on a port. MAC authentication delay is disabled. MAC authentication starts immediately after it is triggered by a user packet.
No periodic MAC reauthentication timer is set on a port. The port uses the global periodic MAC reauthentication timer.
auth-delay auth-delay-time: Sets the delay time for MAC authentication in seconds. The value range is 1 to 180.
reauth-period reauth-period-value: Sets the port-specific periodic MAC reauthentication timer in seconds. The value range is 60 to 86400.
When both 802.1X authentication and MAC authentication are enabled on a port, you can delay MAC authentication so that 802.1X authentication is preferentially triggered. If no 802.1X authentication is triggered or if 802.1X authentication fails within the delay period, the port continues to process MAC authentication.
Do not set the port security mode to mac-else-userlogin-secure or mac-else-userlogin-secure-ext when you want to use MAC authentication delay. The delay does not take effect on a port in either of the two modes. For more information about port security modes, see "Port security commands."
The device reauthenticates online MAC authentication users on a port at the specified periodic reauthentication interval if the port is enabled with periodic MAC reauthentication. To enable periodic MAC reauthentication on a port, use the mac-authentication re-authenticate command.
A change to the port-specific periodic reauthentication timer applies to online users only after the old timer expires.
The device selects a periodic reauthentication timer for MAC reauthentication in the following order:
1. Server-assigned reauthentication timer.
2. Port-specific reauthentication timer.
3. Global reauthentication timer.
4. Default reauthentication timer.
# Enable MAC authentication delay on Ten-GigabitEthernet 1/0/1 and set the delay time to 10 seconds.
[Sysname-Ten-GigabitEthernet1/0/1] mac-authentication timer auth-delay 10
port-security port-mode
Use mac-authentication timer to configure a MAC authentication timer.
mac-authentication timer { offline-detect offline-detect-value | quiet quiet-value | reauth-period reauth-period-value | server-timeout server-timeout-value | temporary-user-aging aging-time-value | user-aging { critical-vlan | critical-vsi | guest-vlan | guest-vsi } aging-time-value }
undo mac-authentication timer { offline-detect | quiet | reauth-period | server-timeout | temporary-user-aging | user-aging { critical-vlan | critical-vsi | guest-vlan | guest-vsi } }
The following MAC authentication timers apply:
· The offline detection timer is 300 seconds.
· The quiet timer is 60 seconds.
· The global periodic MAC reauthentication timer is 3600 seconds.
· The server timeout timer is 100 seconds.
· The aging timer for temporary MAC authentication users is 60 seconds.
· User aging timer for a type of MAC authentication VLAN, or VSI: 1000 seconds.
offline-detect offline-detect-value: Sets the offline detection timer. The value range is 60 to 2147483647 seconds.
quiet quiet-value: Sets the quiet timer. The value range is 1 to 3600 seconds.
reauth-period reauth-period-value: Sets the global periodic MAC reauthentication timer. The value range is 60 to 86400 seconds.
server-timeout server-timeout-value: Sets the server timeout timer. The value range is 100 to 300 seconds.
temporary-user-aging aging-time-value: Sets the aging timer for temporary MAC authentication users. The value range for the aging-time-value argument is 60 to 2147483647 seconds.
user-aging: Sets the user aging timer for a type of MAC authentication VLAN or VSI.
aging-time-value: Sets the user aging timer. The value range is 60 to 2147483647 seconds.
MAC authentication uses the following timers:
· Offline detection timer—Sets the interval that the device must wait for traffic from a user before the device determines that the user is idle. If the device has not received traffic from a user before the timer expires, the device logs off that user and requests the accounting server to stop accounting for the user. This timer takes effect only when the MAC authentication offline detection feature is enabled.
As a best practice, set the MAC address aging timer to the same value as the offline detection timer. This operation prevents a MAC authenticated user from being logged off within the offline detection interval because of MAC address entry expiration.
Inter-slot or inter-device user information synchronization takes some time. The effective offline detection interval for users on an aggregate interface is more 3 minutes than the configured offline detection interval. The effective offline detection interval for users on an M-LAG interface is more 25 minutes than the configured offline detection interval.
· Quiet timer—Sets the interval that the device must wait before the device can perform MAC authentication for a user that has failed MAC authentication. All packets from the MAC address are dropped during the quiet time. This quiet mechanism prevents repeated authentication from affecting system performance.
· Periodic MAC reauthentication timer—Sets the interval at which the device reauthenticates online MAC authentication users on a port if the port is enabled with periodic MAC reauthentication. A change to the global periodic reauthentication timer applies to online users only after the old timer expires.
· Server timeout timer—Sets the interval that the device waits for a response from a RADIUS server before the device determines that the RADIUS server is unavailable. If the timer expires during MAC authentication, the user fails MAC authentication.
To avoid forced logoff before the server timeout timer expires, set the server timeout timer to a value that is lower than or equal to the product of the following values:
¡ The maximum number of RADIUS packet transmission attempts set by using the retry command in RADIUS scheme view.
¡ The RADIUS server response timeout timer set by using the timer response-timeout command in RADIUS scheme view.
For information about setting the maximum number of RADIUS packet transmission attempts and the RADIUS server response timeout timer, see AAA configuration in Security Configuration Guide.
· Aging timer for temporary MAC authentication users (temporary-user-aging)—Sets the aging timer for temporary MAC authentication users. This timer starts when a user passes MAC authentication on a port operating in macAddressAndUserLoginSecureExt mode. If the device has not received 802.1X protocol packets from the MAC authenticated user on that port before the timer expires, the device determines that the user has failed authentication. Then, the device logs off the user. For more information about the port security mode, see port security configuration is Security Configuration Guide.
· User aging timer (user-aging)—Sets the user aging timer for a type of MAC authentication VLAN or VSI.
If you enable user aging for unthenticated MAC authentication user, you can set a user aging timer for MAC authentication critical or guest VLANs or VSIs. The user aging timer for a type of MAC authentication VLAN or VSI determines how long a user can stay in that type of VLAN or VSI.
For more information about how user aging operates, see the usage guidelines for the mac-authentication unauthenticated-user aging enable command.
Do not set the user aging timer for users in MAC authentication guest VLANs or VSIs to a multiple of the authentication interval configured by using the mac-authentication guest-vlan auth-period command or the mac-authentication guest-vsi auth-period command, respectively. If you do so, the aging timer will not take effect.
# Set the server timeout timer to 150 seconds.
retry
timer response-timeout (RADIUS scheme view)
Use mac-authentication unauthenticated-user aging enable to enable unauthenticated MAC authentication user aging.
Use undo mac-authentication unauthenticated-user aging enable to disable unauthenticated MAC authentication user aging.
Unauthenticated MAC authentication user aging is enabled.
Unauthenticated MAC authentication user aging applies to users added to the following locations because they have not been authenticated or have failed authentication:
· MAC authentication guest or critical VLANs.
· MAC authentication guest or critical VSIs.
When a user in one of those locations ages out, the device removes the user from the location and deletes the MAC address entry for the user from the access port.
For users in one of those locations on one port to be authenticated successfully and come online on another port, enable this feature. In any other scenarios, disable this feature as a best practice.
# Disable unauthenticated MAC authentication user aging on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] undo mac-authentication unauthenticated-user aging enable
Use mac-authentication user-name-format to configure the global user account policy for all MAC authentication users.
Use undo mac-authentication user-name-format to restore the default.
mac-authentication user-name-format { fixed [ account name ] | mac-address [ { with-hyphen [ separator colon ] | without-hyphen } [ lowercase | uppercase ] ] } [ password { cipher | simple } string ]
The MAC address of each user is used as both the username and password for MAC authentication. The MAC addresses are in hexadecimal notation without hyphens, and letters are in lower case.
fixed: Uses a shared account for all MAC authentication users.
account name: Specifies the username for the shared account. The name is a case-sensitive string of 1 to 55 characters, excluding the at sign (@). If you do not specify a username, the default name mac applies.
mac-address: Uses MAC-based user accounts for MAC authentication users.
with-hyphen: Includes hyphens in MAC addresses. The MAC addresses use the xx-xx-xx-xx-xx-xx format or the XX-XX-XX-XX-XX-XX format.
separator colon: Uses the colon (:) in place of the hyhen (-) as the separator in MAC addresses. The MAC addresses use the xx:xx:xx:xx:xx:xx format or the XX:XX:XX:XX:XX:XX format. If you do not specify the colon as the separator, the hypen is used.
without-hyphen: Excludes hyphens from a MAC address, for example, xxxxxxxxxxxx or XXXXXXXXXXXX.
lowercase: Specifies letters in lower case.
uppercase: Specifies letters in upper case.
password: Specifies the user password. If you do not specify a password for MAC-based user accounts, the device uses the MAC address of each user in the specified format as the password. If you do not specify a password for the shared account, the shared account does not have a password.
If you specify the MAC-based user account format, the device uses the MAC address of a user as the username for MAC authentication of the user. This user account type ensures high authentication security. However, you must create on the authentication server a user account for each user, using the MAC address of the user as the username.
If you specify a shared user account, the device uses the specified username and password for MAC authentication of all users. Because all MAC authentication users use a single account for authentication, you only need to create one account on the authentication server. This user account type is suitable for trusted networks.
# Configure a shared account for all MAC authentication users, and set the username to abc and password to xyz in plaintext form.
# Use the MAC address of each user as both the username and password for MAC authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in upper case.
[Sysname] mac-authentication user-name-format mac-address with-hyphen uppercase
display mac-authentication
Use mac-authentication user-recovery-profile to create a profile for MAC authentication user recovery and enter its view, or enter the view of an existing profile.
Use undo mac-authentication user-recovery-profile to delete a MAC authentication user recovery profile.
mac-authentication user-recovery-profile profile-name
undo mac-authentication user-recovery-profile profile-name
No MAC authentication user recovery profiles exist.
profile-name: Specifies a profile name, a case-insensitive string of 1 to 31 characters.
To obtain MAC authentication user information from a RESTful server, create a profile for obtaining information from that server. A profile contains a set of parameters for accessing a RESTful server and the URI from which you obtain MAC authentication user information.
You can configure a maximum of 16 profiles for MAC authentication user recovery.
# Create a MAC authentication user recovery profile named profile1 and enter its view.
[Sysname] mac-authentication user-recovery-profile profile1
New user-recovery profile created
[Sysname-user-recovery-profile-profile1]
display mac-authentication user-recovery-profile
mac-authentication web-proxy
Use mac-authentication web-proxy to enable the device to trigger URL redirection for HTTP or HTTPS requests sent by a MAC authenticated user to a specified Web proxy port.
Use undo mac-authentication web-proxy to remove the specified or all Web proxy ports.
mac-authentication web-proxy { http | https } port port-number
undo mac-authentication web-proxy { { http | https } port port-number | all-port }
No Web proxy ports are specified. The device redirects the HTTP or HTTPS requests from a MAC authenticated user to the authorized URL only if the requests are sent from a browser with Web proxy disabled.
http: Specifies HTTP requests.
https: Specifies HTTPS requests.
port port-number: Specifies the TCP port number of a Web proxy for HTTP or HTTPS requests, in the range of 1 to 65535. The device always allows Web requests that use ports 80 and 443 to trigger MAC authentication URL redirection, and the two port numbers are not user configurable.
all-port: Specifies all Web proxy ports for MAC authentication URL redirection.
By default, the device discards the HTTP and HTTPS requests sent by a MAC authenticated user if they are sent from a browser configured with a Web proxy. To redirect the HTTP or HTTPS requests sent by a MAC authenticated user to a Web proxy port, add that Web proxy port to the device.
When you use this command, follow these restrictions and guidelines:
· You can specify a maximum of 64 Web proxy ports.
· Specify different Web proxy port numbers for HTTP and HTTPS requests.
· Adding or removing a Web proxy port will cause the device to log off all online MAC authenticated users that have been assigned an authorization redirect URL.
# Configure the device to trigger URL redirection for the HTTP requests sent by MAC authenticated users to Web proxy port 8080.
[Sysname] mac-authentication web-proxy http port 8080
nas-ip
Use nas-ip to specify the NAS IP address for the device to communicate with the RESTful server in a MAC authentication user recovery profile.
Use undo nas-ip to remove the NAS IP addresses used by the device to communicate with the RESTful server in a MAC authentication user recovery profile.
nas-ip { ipv4-address | ipv6 ipv6-address }
undo nas-ip
No NAS IP address is specified for the device to communicate with the RESTful server in a MAC authentication user recovery profile.
MAC authentication user recovery profile view
ipv4-address: Specifies an IPv4 NAS IP address. The IPv4 address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 NAS IP address. The IPv6 address must be a unicast address and cannot be a loopback address or a link-local address.
The NAS IP address must be the same as that configured in the authentication RADIUS scheme for the MAC authentication users. In addition, it must be in the same IP address family as the IP address of the RESTful server in the profile.
You can specify only one NAS IP address in a profile. If you execute this command multiple times, the most recent configuration takes effect.
# In MAC authentication user recovery profile profile1, configure the device to use NAS IP address 10.1.1.1 to communicate with the RESTful server.
[Sysname-user-recovery-profile-profile1] nas-ip 10.1.1.1
nas-ip (RADIUS scheme view)
reset mac-authentication access-user
Use reset mac-authentication access-user to log off MAC authentication users.
reset mac-authentication access-user [ interface interface-type interface-number | mac mac-address | online-type { auth-fail-domain | critical-domain | preauth-domain | success | url-unavailable-domain } | username username | vlan vlan-id | vsi vsi-name ]
interface interface-type interface-number: Specifies a port by its type and number.
mac mac-address: Specifies a MAC authentication user by its MAC address. The mac-address argument is in the format of H-H-H.
online-type: Specifies a type of online MAC authentication users.
· auth-fail-domain: Specifies MAC authentication users in the Auth-Fail domain.
· critical-domain: Specifies MAC authentication users in the critical domain.
· preauth-domain: Specifies MAC authentication users in the preauthentication domain.
· success: Specifies users that have passed MAC authentication.
· url-unavailable-domain: Specifies MAC authentication users assigned to the URL-unavailable domain when the redirect URL is unavailable.
username username: Specifies a MAC authentication user by its name. The username argument is a case-sensitive string of 1 to 253 characters.
vlan vlan-id: Specifies a VLAN by its VLAN ID. The value range for the vlan-id argument is 1 to 4094.
vsi vsi-name: Specifies a VSI by its name. The vsi-name argument is a case-sensitive string of 1 to 31 characters.
Use this command to log off the specified MAC authentication users and clear information about these users from the device. These users must perform MAC authentication to come online again.
With a VSI specified, this command logs off a MAC authentication user if that user has passed authentication and its authorization VSI is the specified VSI.
With a VLAN specified, this command logs off the following MAC authentication users:
· Users that have passed MAC authentication and have been assigned the specified VLAN as their authorization VLAN by the server.
· Users that stay in the specified VLAN after they have passed MAC authentication, because they have not been assigned an authorization VLAN yet.
· Users that are performing MAC authentication in the specified VLAN.
To identify the VLAN in which a user is staying, use the display mac-address command.
If you do not specify any parameters, the reset mac-authentication access-user command logs off all MAC authentication users on the device.
# Log off all MAC authentication users on Ten-GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication access-user interface ten-gigabitethernet 1/0/1
display mac-authentication connection
reset mac-authentication critical vlan
Use reset mac-authentication critical vlan to remove users from the MAC authentication critical VLAN on a port.
reset mac-authentication critical vlan interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies a user by its MAC address. If you do not specify this option, the command removes all users from the MAC authentication critical VLAN on the port.
# Remove the user with MAC address 1-1-1 from the MAC authentication critical VLAN on Ten-GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication critical vlan interface ten-gigabitethernet 1/0/1 mac-address 1-1-1
display mac-authentication mac-address
reset mac-authentication critical vsi
Use reset mac-authentication critical vsi to remove users from the MAC authentication critical VSI on a port.
reset mac-authentication critical vsi interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies a user by its MAC address. If you do not specify this option, the command removes all users from the MAC authentication critical VSI on the port.
# Remove the user with MAC address 1-1-1 from the MAC authentication critical VSI on Ten-GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication critical vsi interface ten-gigabitethernet 1/0/1 mac-address 1-1-1
reset mac-authentication critical-voice-vlan
Use reset mac-authentication critical-voice-vlan to remove MAC authentication users from the MAC authentication critical voice VLAN on a port.
reset mac-authentication critical-voice-vlan interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies a user by its MAC address. If you do not specify this option, the command removes all users from the MAC authentication critical voice VLAN on the port.
# Remove the user with MAC address 1-1-1 from the MAC authentication critical voice VLAN on Ten-GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication critical-voice-vlan interface ten-gigabitethernet 1/0/1 mac-address 1-1-1
reset mac-authentication guest-vlan
Use reset mac-authentication guest-vlan to remove users from the MAC authentication guest VLAN on a port.
mac-address mac-address: Specifies a user by its MAC address. If you do not specify this option, the command removes all users from the MAC authentication guest VLAN on the port.
# Remove the user with MAC address 1-1-1 from the MAC authentication guest VLAN on Ten-GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication guest-vlan interface ten-gigabitethernet 1/0/1 mac-address 1-1-1
reset mac-authentication guest-vsi
Use reset mac-authentication guest-vsi to remove users from the MAC authentication guest VSI on a port.
reset mac-authentication guest-vsi interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies a user by its MAC address. If you do not specify this option, the command removes all users from the MAC authentication guest VSI on the port.
# Remove the user with MAC address 1-1-1 from the MAC authentication guest VSI on Ten-GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication guest-vsi interface ten-gigabitethernet 1/0/1 mac-address 1-1-1
reset mac-authentication statistics
Use reset mac-authentication statistics to clear MAC authentication statistics.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command clears both global and port-specific MAC authentication statistics.
# Clear MAC authentication statistics on Ten-GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication statistics interface ten-gigabitethernet 1/0/1
server-address
Use server-address to configure the IP address and service port number of a RESTful server.
Use undo server-address to restore the default.
server-address { ip ipv4-address | ipv6 ipv6-address } [ port port-number ] [ vpn-instance vpn-instance-name ]
undo server-address
A MAC authentication user recovery profile does not contain a RESTful server.
ip ipv4-address: Specifies the IPv4 address of the RESTful server.
ipv6 ipv6-address: Specifies the IPv6 address of the RESTful server.
port port-number: Specifies the port number on which the RESTful server listens for request messages. The value range is 1 to 65535 and the default setting is 80.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the RESTful server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Use this command to specify the RESTful server from which you obtain MAC authentication user information for reauthentication.
This server can only be the IMC server that acts as the authentication server for the MAC authentication users.
The IP address of the RESTful server must be in the same IP address family as the NAS IP address of the device in the same profile.
You can specify only one RESTful server in a profile. If you execute this command multiple times, the most recent configuration takes effect.
# In MAC authentication user recovery profile profile1, specify the RESTful server at 3.3.3.3 and set its service port number to 800.
[Sysname-user-recovery-profile-profile1] server-address ip 3.3.3.3 port 8080
nas-ip
uri
Use uri to specify the URI for the device to obtain MAC authentication user information from the RESTful server in a MAC authentication user recovery profile.
Use undo uri to remove the URI in a MAC authentication user recovery profile.
uri uri-string
undo uri
A MAC authentication user recovery profile does not contain a URI.
uri-string: Specifies a URI, a case-sensitive string of 1 to 255 characters.
Use this command to specify the URI that the RESTful server uses to provide MAC authentication user information.
The URI can only be imcrs/uam/online/notAgingMuteTerminal. Other URIs cannot take effect.
# In MAC authentication user recovery profile profile1, specify imcrs/uam/online/notAgingMuteTerminal as the URI for obtaining MAC authentication user information from the RESTful server.
[Sysname-user-recovery-profile-profile1] uri imcrs/uam/online/notAgingMuteTerminal
server-address
