03-Layer 2-LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6800 & S6860 Switch Series Command References-Release 671x-6W10003-Layer 2-LAN Switching Command Reference
05-M-LAG commands
05-M-LAG commands 290.66 KB
M-LAG commands
The M-LAG feature was named DRNI in earlier software versions. For compatibility with earlier software versions, the device supports both M-LAG and DRNI commands. For more information about the keyword differences between the M-LAG and DRNI commands, see M-LAG configuration in Layer 2—LAN Switching Configuration Guide.
display m-lag consistency
Use display m-lag consistency to display information about the configuration consistency check done by M-LAG.
display m-lag consistency { type1 | type2 } { global | interface interface-type interface-number }
type1: Specifies type 1 configuration consistency check.
type2: Specifies type 2 configuration consistency check.
global: Specifies global information.
interface interface-type interface-number: Specifies an M-LAG interface by its type and number.
This command displays configuration details for the M-LAG member devices when type 1 or type 2 setting inconsistencies are detected. For more information about type 1 or type 2 configuration, see M-LAG configuration in Layer 2—LAN Switching Configuration Guide.
The device does not check the invalid VLANs for inconsistency during global or interface-specific type 2 configuration consistency check.
This command displays the following fields only when VLAN or VLAN interface inconsistencies are detected during global type 2 configuration consistency check:
·     Vlan-int(shutdown).
·     Vlan-int(IPv4).
·     Vlan-int(IPv6).
·     Vlan-int(VRRPv4).
# Display global information about type 1 configuration consistency check.
<Sysname> display m-lag consistency type1 global
Configuration       Local                         Peer
Link type           Access                        Trunk
PVID                10                            20
Global STP          Enabled                       Disabled
STP mode            MSTP                          RSTP
MST region          abc                           def
Revision level      100                           200
MSTI(VLANs)         1(1,64,127,190,316,379,442,   1(2,4,61,121,261,291,362)
                    505,568,631)
STP-enabled VLANs   10,12,14,16,18                20,22,24,26,28
# Display global information about type 2 configuration consistency check.
<Sysname> display m-lag consistency type2 global
VLANs               1,3,5,7,9                     2,4,6,8,10
Vlan-int            10,12,14,17,22,33             11,19,23,27,47
Vlan-int(shutdown)  100,103,107,200,301           200,261,290,333,465
Vlan-int(IPv4)      1019(192.168.1.1/29)          -
Vlan-int(IPv6)      40(fc00:0:0:102:0:0:0:1/64)   -
Vlan-int(VRRPv4)    100(192.168.100.1/24)         -
Global BPDU guard   Enabled                       Disabled
MAC aging time      100s                          No-aging
Port security       Enabled                       Disabled
Psec load sharing   Local                         Odd-MAC
Psec MAC move state Enabled                       Disabled
Psec MAC move mode  Port                          All
Dot1x               Enabled                       Disabled
802.1X auth method  Chap                          Pap
802.1X UniTrigQuiet 60s                           300s
802.1X EAD timeout  60                            30
802.1X hand-sh tmr  30                            15
802.1X off-det tmr  600                           300
802.1X quiet-period 120                           60
802.1X reau-period  4800                          3600
802.1X server tmr   200                           100
802.1X supp-timer   60                            30
802.1X tx-period    60                            30
802.1X failvlan tmr 2000                          1000
802.1X failvsi tmr  3000                          1000
802.1X crt-vlan tmr 5000                          1000
802.1X crt-vsi tmr  6000                          1000
802.1X gst-vlan tmr 7000                          1000
802.1X gst-vsi tmr  8000                          1000
MAC-authentication  Enabled                       Disabled
MAC auth method     Chap                          Pap
MAC off-det tmr     600                           300
MAC quiet-period    120                           60
MAC reauth-period   4800                          3600
MAC server-timeout  200                           100
MAC tmp-user-aging  120                           60
MAC crt-vlan tmr    3000                          1000
MAC crt-vsi tmr     4000                          1000
MAC guest-vlan tmr  5000                          1000
MAC guest-vsi tmr   6000                          1000
Web tmp-entry-aging 1200                          60
VSI name            vpna
VNI                 10
Gateway interface   VSI-interface1
VSI name            vpnb                          vpnb
VNI                 20                            30
VSI interface       1                             1
MAC address         1-1-1                         2-2-2
IPv4 address        192.168.0.1/24                192.168.0.2/24
IPv6 address        1::1/64                       1::2/64
Physical state      UP                            DOWN
Protocol state      UP                            DOWN
VSI interface       2                             2
MAC address         1-1-1                         2-2-3
IPv4 address        192.168.1.1/24                192.168.1.2/24
IPv6 address        2::2/64                       2::2/128
R2 mode             Single                        Disabled
R2 statistics       Global                        ACL
R2 ACL name         a                             b
R2 drop             Enabled                       Disabled
R2 report interval  10                            20
R2 inactive timeout 30                            50
IPCC mode           high-throughput               low-latency
IPCC queue          3                             6
# Display information about type 1 configuration consistency check on M-LAG interface Bridge-Aggregation 1.
<Sysname> display m-lag consistency type1 interface bridge-aggregation 1
LAGG mode           Static                        Dynamic
PVID                10                            20
# Display information about type 2 configuration consistency check on M-LAG interface Bridge-Aggregation 1.
<Sysname> display m-lag consistency type2 interface bridge-aggregation 1
LACP select speed   Enabled                       Disabled
LAGG ignore speed   Enabled                       Disabled
Root guard          Enabled                       Disabled
Psec port mode      Autolearn                     Mac-else-userlogin-secure-ext
Psec mac aging-type inactivity                    periodical
Dot1x critical VSI  vpna                          vpnb
Dot1x handshake     Enabled                       Disabled
Dot1x multi-trigger Enabled                       Disabled
Dot1x uni-trigger   Enabled                       Disabled
Dot1x off-detect    Enabled                       Disabled
Dot1x reauth-period 60                            0
Dot1x crt-vlan      100                           65535
MAC crt microseg    1                             2
MAC critical VSI    vpna                          vpnb
MAC with dot1x      Enabled                       Disabled
MAC offline-detect  Enabled                       Disabled
MAC multi-vlan      Multiple                      Single
MAC auth-delay tmr  20                            10
MAC reauth-period   1200                          1000
MAC crt-vlan        100                           65535
Web-auth            Enabled                       Disabled
Web auth-fail VLAN  1                             2
Web-auth P server   serverA                       serverB
Web-auth S server   serverB                       serverA
Web off-det intvl   3600
Local
Local configuration. This field displays a hyphen (-) if no configuration inconsistency exists. If the parameter does not have a local configuration, this field is empty.
Peer
Peer configuration. This field displays a hyphen (-) if no configuration inconsistency exists. If the parameter does not have a peer configuration, this field is empty.
Link type
Link type of the peer-link interface:
·     Access.
·     Hybrid.
·     Trunk.
PVID
PVID of the peer-link interface.
MSTI(VLANs)
VLAN-to-MSTI mappings. This field displays Inconsistent if inconsistent VLAN-to-MSTI mappings are detected and M-LAG cannot obtain VLAN-to-MSTI mappings.
VLANs
VLANs permitted by an interface. The system checks tagged VLANs before untagged VLANs.
Vlan-int(shutdown)
VLAN interfaces that were administratively shut down.
Vlan-int(VRRPv4)
Virtual IPv4 address of the VRRP group on a VLAN interface on the VRRP master.
MAC aging time
MAC aging timer in seconds. This field displays No-aging if MAC address entries do not age out.
Port security
Global state of port security:
·     Enabled.
·     Disabled.
Psec load sharing
Authentication load sharing mode for users on port security-enabled M-LAG interfaces:
·     Centralized—The primary M-LAG member device authenticates users.
·     Local—Each M-LAG member device authenticates their local users.
·     Odd-MAC—The local M-LAG member device authenticates odd-MAC users on all M-LAG interfaces of the M-LAG system.
·     Even-MAC—The local M-LAG member device authenticates even-MAC users on all M-LAG interfaces of the M-LAG system.
Psec MAC move state
State of the MAC move feature:
·     Enabled.
·     Disabled.
Psec MAC move mode
Port security MAC move mode:
·     Port—Allows an authenticated online user to move between ports on the device.
·     VLAN—Allows an authenticated online user to move between VLANs on a trunk or hybrid port.
·     All—Allows an authenticated online user to move between ports on the device or VLANs on a trunk or hybrid port.
Dot1x
Global state of 802.1X authentication:
·     Enabled.
·     Disabled.
802.1X auth method
802.1X authentication method:
·     Chap—Performs EAP termination and uses CHAP to communicate with the RADIUS server.
·     Eap—Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server.
·     Pap—Performs EAP termination and uses PAP to communicate with the RADIUS server.
802.1X UniTrigQuiet
Quiet timer for the 802.1X unicast trigger feature, in seconds.
802.1X EAD timeout
EAD rule timer of 802.1X authentication.
802.1X hand-sh tmr
Handshake timer of 802.1X authentication.
802.1X off-det tmr
Offline detection timer of 802.1X authentication.
802.1X quiet-period
Quiet timer of 802.1X authentication.
802.1X reau-period
Periodic reauthentication timer of 802.1X authentication.
802.1X server tmr
Server timeout timer of 802.1X authentication.
802.1X supp-timer
Client timeout timer of 802.1X authentication.
802.1X tx-period
Username request timeout timer of 802.1X authentication.
802.1X failvlan tmr
Aging timer for users in Auth-Fail VLANs of 802.1X authentication.
802.1X failvsi tmr
Aging timer for users in Auth-Fail VSIs of 802.1X authentication.
802.1X crt-vlan tmr
Aging timer for users in critical VLANs of 802.1X authentication.
802.1X crt-vsi tmr
Aging timer for users in critical VSIs of 802.1X authentication.
802.1X gst-vlan tmr
Aging timer for users in guest VLANs of 802.1X authentication.
802.1X gst-vsi tmr
Aging timer for users in guest VSIs of 802.1X authentication.
MAC-authentication
Global state of MAC authentication:
·     Enabled.
·     Disabled.
MAC auth method
MAC authentication method:
·     Chap—CHAP authentication.
·     Pap—PAP authentication.
MAC off-det tmr
Offline detection timer of MAC authentication.
MAC quiet-period
Quiet timer of MAC authentication.
MAC reauth-period
Periodic reauthentication timer of MAC authentication.
MAC server-timeout
Server timeout timer of MAC authentication.
MAC tmp-user-aging
Aging timer for temporary MAC authentication users.
MAC crt-vlan tmr
Aging timer for users in critical VLANs of MAC authentication.
MAC crt-vsi tmr
Aging timer for users in critical VSIs of MAC authentication.
MAC guest-vlan tmr
Aging timer for users in guest VLANs of MAC authentication.
MAC guest-vsi tmr
Aging timer for users in guest VSIs of MAC authentication.
Web tmp-entry-aging
Aging timer for MAC address entries created for temporary MAC authentication users.
VSI name
Name of the VSI that has ACs on an M-LAG interface.
VNI
VXLAN ID of the VSI.
Gateway interface
VSI interface associated with the VSI.
VSI interface
VSI interface number.
MAC address
MAC address of the VSI interface.
IPv4 address
IPv4 address of the VSI interface.
IPv6 address
IPv6 address of the VSI interface.
Physical state
Physical link state of the VSI interface:
·     ADM—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down.
·     UP—The interface is both administratively and physically up.
Protocol state
Data link layer state of the VSI interface:
LACP select speed
Whether an M-LAG interface uses port speed as the prioritized criterion for reference port selection:
·     Enabled.
·     Disabled.
LAGG ignore speed
Whether an M-LAG interface ignores port speed in setting the aggregation states of member ports:
·     Enabled.
·     Disabled.
Psec mac aging-type
Secure MAC address aging type:
·     Inactivity—Inactivity aging feature together with the aging timer.
·     Periodical—Timer aging only.
Dot1x
State of 802.1X authentication on the interface:
·     Enabled.
·     Disabled.
Dot1x critical VSI
Name of the 802.1X critical VSI.
Dot1x handshake
Whether the 802.1X online user handshake feature is enabled:
·     Enabled.
·     Disabled.
Dot1x multi-trigger
Whether the 802.1X multicast trigger feature is enabled:
·     Enabled.
·     Disabled.
Dot1x uni-trigger
Whether the 802.1X unicast trigger feature is enabled:
·     Enabled.
·     Disabled.
Dot1x off-detect
State of 802.1X authentication offline detection on the interface:
·     Enabled.
·     Disabled.
Dot1x reauth-period
Dot1x crt-vlan
802.1X critical VLAN which the interface is assigned to.
Dot1x packet-detect
State of 802.1X packet detection:
·     Enabled.
·     Disabled.
Dot1x pkt-det retry
Number of 802.1X packet detection retries.
MAC-authentication
State of MAC authentication on the interface:
·     Enabled.
·     Disabled.
MAC critical VSI
Name of the MAC authentication critical VSI.
MAC with dot1x
State of parallel processing of MAC authentication and 802.1X authentication:
·     Enabled.
·     Disabled.
MAC offline-detect
State of MAC authentication offline detection on the interface:
·     Enabled.
·     Disabled.
MAC multi-vlan
MAC authentication VLAN mode for users moving from one VLAN to another on the interface:
·     Single VLAN—Single-VLAN mode.
·     Multiple VLAN—Multi-VLAN mode.
MAC auth-delay tmr
MAC authentication delay timer.
MAC reauth-period
MAC crt-vlan
Critical VLAN of MAC authentication.
MAC packet-detect
State of MAC authentication packet detection:
·     Enabled.
·     Disabled.
MAC pkt-det retry
Number of MAC authentication packet detection retries.
Web-auth
State of Web authentication on the interface:
·     Enabled.
·     Disabled.
Web auth-fail VLAN
The Auth-Fail VLAN for Web authentication.
Web-auth P server
Name of the primary Web server for Web authentication.
Web-auth S server
Name of the secondary Web server for Web authentication.
Web off-det intvl
Online detection interval of Web authentication.
display m-lag consistency-check status
Use display m-lag consistency-check status to display the configuration consistency check status.
# Display the configuration consistency check status.
<Sysname> display m-lag consistency-check status
                 Global Consistency Check Configuration
Local status     : Enabled           Peer status     : Enabled
Local check mode : Strict            Peer check mode : Strict
                 Consistency Check on Modules
Module           Type1           Type2
LAGG             Check           Check
VLAN             Check           Check
STP              Check           Check
MAC              Not Check       Check
L2VPN            Not Check       Check
PORTSEC          Not Check       Check
DOT1X            Not Check       Check
MACA             Not Check       Check
WEBAUTH          Not Check       Check
                 Type1 Consistency Check Result
Global consistency check result: SUCCESS
Inconsistent global modules: -
M-LAG IF         M-LAG group ID  Check Result      Inconsistency modules
BAGG4            4               SUCCESS           -
Local status
Status of configuration consistency check at the local end:
·     Enabled.
·     Disabled.
Peer status
Status of configuration consistency check at the peer end:
·     Enabled.
·     Disabled.
Local check mode
Configuration consistency check mode at the local end:
·     Loose.
·     Strict.
Peer check mode
Configuration consistency check mode at the peer end:
·     Loose.
·     Strict.
Module
Feature module name.
Type1
Whether M-LAG checks the module for a type 1 configuration inconsistency:
·     Check.
·     Not Check.
Type2
Whether M-LAG checks the module for a type 2 configuration inconsistency:
·     Check.
·     Not Check.
Result of global configuration consistency check:
·     FAILURE.
·     SUCCESS.
Modules that failed global configuration consistency check. If the check succeeded, this field displays a hyphen (-).
M-LAG IF
Abbreviated name of the M-LAG interface.
Modules that failed interface configuration consistency check. If the check succeeded, this field displays a hyphen (-).
display m-lag drcp statistics
Use display m-lag drcp statistics to display DRCPDU statistics.
display m-lag drcp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a Layer 2 aggregate interface or VXLAN tunnel interface by its type and number. If you do not specify this option, the command displays the DRCPDU statistics about the peer-link interface and all M-LAG interfaces.
# Display DRCPDU statistics.
<Sysname> display m-lag drcp statistics
 * indicates the port is the peer-link interface.
Interface type:
BAGG -- Bridge-Aggregation, Tun -- Tunnel
Interface     State     Sent     Received(Normal/Error/Unknown)
*BAGG3        UP        30       26/0/0
 BAGG4        UP        29       26/0/0
# Display DRCPDU statistics about Bridge-Aggregation 4.
<Sysname> display m-lag drcp statistics interface bridge-aggregation 4
Interface type:
Interface  : BAGG4
State      : UP
Sent       : 31
Received (Normal/Error/Unknown): 28/0/0
Last received packet information:
  Source MAC address: 3cd4-437d-0300
  Time: 2019/09/11 09:19:58
  Action: Accept
Abbreviated interface name. The name of the peer-link interface is prefixed with an asterisk (*).
Physical state of the interface:
·     UP.
·     DOWN.
Sent
Number of sent DRCPDUs.
Numbers of received normal, error, and unrecognized DRCPDUs.
Information about the most recently received DRCPDU.
Time
Date and time when the DRCPDU was received, in the YYYY/MM/DD hh:mm:ss format.
Action
Action taken on the DRCPDU:
·     Accept.
·     Drop.
If the DRCPDU was dropped, this field also displays the reason for dropping the DRCPDU.
reset m-lag drcp statistics
display m-lag keepalive
Use display m-lag keepalive to display M-LAG keepalive packet statistics.
# Display M-LAG keepalive packet statistics.
<Sysname> display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 135642 s 501 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 10.0.0.2
  Time: 2019/09/11 09:21:51
  Action: Accept
M-LAG keepalive parameters:
Destination IP address: 10.0.0.2
Source IP address: 10.0.0.1
Keepalive UDP port : 6400
Keepalive VPN name : vpn1
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
State of the M-LAG peer:
·     Unknown—No M-LAG peer is detected because the destination IP address of keepalive packets is not specified.
·     Up—The M-LAG peer is up.
·     Down—The M-LAG peer is down.
Cause of the keepalive link down event:
·     M-LAG system init—M-LAG system initialization.
·     Local IP not configured—The local end does not have source and destination IP address settings for the keepalive link.
·     Local Tx failed—Packet transmission failed on the local end.
·     Local Rx timeout—Packet reception timed out on the local end.
·     Peer Rx timeout—Packet reception timed out on the peer end.
Time period for which the M-LAG peer has been up.
Information about the most recently received keepalive packet.
Time
Date and time when the keepalive packet was received, in the YYYY/MM/DD hh:mm:ss format. If the device has not received any keepalive packets, this field displays N/A.
Action
Action taken on the keepalive packet:
·     Accept.
·     Drop.
If the keepalive packet was dropped, this field also displays the reason for dropping the packet.
Destination IP address of keepalive packets sent by the device.
Source IP address
Source IP address of keepalive packets sent by the device.
Keepalive UDP port
Destination UDP port of keepalive packets.
Keepalive VPN name
VPN instance for keepalive packets. If no VPN instance is configured for keepalive packets, this field displays N/A.
Keepalive interval
Interval at which the device sends keepalive packets.
Keepalive timeout
Keepalive timeout timer.
Keepalive hold time
Keepalive hold timer setting. The keepalive hold timer specifies the amount of time that the device uses to identify the cause of a peer link down event.
m-lag keepalive { ip | ipv6 }
m-lag keepalive hold-time
m-lag keepalive interval
display m-lag mad verbose
Use display m-lag mad verbose to display detailed M-LAG MAD information.
# Display detailed M-LAG MAD information.
<Sysname> display m-lag mad verbose
M-LAG MAD DOWN state    : No
Restore delay          : 30 s
Remaining restore delay: -
M-LAG MAD default action: DOWN
M-LAG MAD DOWN persistence: Disabled
Excluding logical interfaces: Disabled
Port configuration for M-LAG MAD DOWN action:
 Included ports(user-configured):
   Bridge-Aggregation1
   Ten-GigabitEthernet1/0/5(ineffective)
 Included ports(system-configured):
   Member interfaces of M-LAG Bridge-Aggregation3:
     Ten-GigabitEthernet 1/0/3
 Excluded ports(user-configured):
   Bridge-Aggregation2
   Ten-GigabitEthernet1/0/4
 Excluded ports(system-configured):
   Management interfaces:
     M-GigabitEthernet0/0/0
   M-LAG interfaces:
     Bridge-Aggregation4
   Peer-link interface:
     Bridge-Aggregation3
   Member interfaces of peer-link interface Bridge-Aggregation3:
     Ten-GigabitEthernet1/0/1
     Ten-GigabitEthernet1/0/2
Table 5 Command output
Whether the network interfaces on the device are in M-LAG MAD DOWN state:
·     Yes—The device has network interfaces placed in M-LAG MAD DOWN state.
·     No—No network interfaces are in M-LAG MAD DOWN state.
If this field displays Yes, check the peer link for the link down issue to remove multi-active collision.
Restore delay
Data restoration interval, in seconds.
The remaining time (in seconds) before the data restoration interval expires. If the data restoration interval has not started, this field displays a hyphen (-).
Default action to take on network interfaces when the M-LAG system splits:
·     DOWN—Shut down interfaces and place them in M-LAG MAD DOWN state.
·     NONE—M-LAG MAD does not take action on interfaces.
M-LAG MAD DOWN state persistence:
·     Enabled—The M-LAG member device does not bring up the network interfaces in M-LAG MAD DOWN state when its role changes from secondary to primary.
·     Disabled—The M-LAG member device brings up the network interfaces in M-LAG MAD DOWN state when its role changes from secondary to primary.
Whether all logical interfaces are excluded from the shutdown action by M-LAG MAD:
·     Enabled.
·     Disabled.
Network interfaces manually configured to be shut down by M-LAG MAD when the M-LAG system splits.
An interface entry will be marked as ineffective if the system does not allow the specified interface to be shut down by M-LAG MAD. M-LAG MAD will not shut down interfaces in ineffective entries when the M-LAG system splits.
The following are interfaces not allowed to be shut down by M-LAG MAD:
·     Interfaces automatically excluded from being shut down by M-LAG MAD.
·     Interfaces used for special purposes.
Network interfaces automatically set by the system to shut down by M-LAG MAD when the M-LAG system splits.
Aggregation member ports of M-LAG interfaces are in this category of interfaces.
Network interfaces manually configured to not be shut down by M-LAG MAD.
An interface entry will be marked as ineffective if the specified interface is in the list of ports excluded by the system from the M-LAG MAD shutdown action. In this situation, the manual configuration does not take effect.
Network interfaces set by the system to not shut down by M-LAG MAD, including:
·     Management interfaces.
·     M-LAG interfaces.
·     Peer-link interface.
·     Aggregation member interfaces if a Layer 2 aggregate interface is used as the peer-link interface.
m-lag mad default-action
m-lag mad exclude logical-interfaces
m-lag mad exclude interface
m-lag mad include interface
m-lag mad persistent
display m-lag role
Use display m-lag role to display M-LAG role information.
display m-lag role
# Display M-LAG role information.
<Sysname> display m-lag role
                    Effective role information
Factors                  Local                    Peer
Effective role           Primary                  Secondary
Initial role             None                     None
MAD DOWN state           Yes                      Yes
Health level             0                        0
Role priority            32768                    32768
Bridge MAC               3cd4-3ce1-0200           3cd4-437d-0300
Effective role trigger: Peer link calculation
Effective role reason: Bridge MAC
                    Configured role information
Factors                  Local                    Peer
Configured role          Primary                  Secondary
Table 6 Command output
Factors
Factors used in role calculation.
Local
Peer
Peer configuration.
Effective role
Effective device role:
·     None.
·     Primary.
·     Secondary.
Status of M-LAG interfaces
The status of all M-LAG interfaces:
·     DownAll M-LAG interfaces are down.
·     UPOne or more M-LAG interfaces are up.
Initial role
Device role before role calculation:
·     None.
·     Primary.
·     Secondary.
MAD DOWN state
Whether there were interfaces in M-LAG MAD DOWN state during role calculation:
·     Yes.
·     No.
This field displays N/A if no peer exists.
Health level
Health level of the device during role calculation. The member device with a lower value is healthier.
Why effective role calculation was triggered:
·     Peer link calculation—The local device role was calculated over the peer link.
·     Peer link down and role calculation over keepalive link—The peer link went down, and the local device role was calculated over the keepalive link.
·     Peer link and keepalive link down—Both the peer link and the keepalive link went down.
·     Peer link and keepalive link down. All local M-LAG interfaces down—Both the peer link and the keepalive link went down, and all local M-LAG interfaces went down.
Factor that determined the effective device role:
·     No peer existed. In this situation, a hyphen (-) is displayed.
·     Initialization of an M-LAG member device.
·     Status of M-LAG interfaces.
·     Single None role. One M-LAG member device had the None role, and the other M-LAG member device had the Primary role.
·     MAD status.
·     Health level.
·     Role priority.
·     Bridge MAC.
Configured role
Manually assigned device role:
·     None.
·     Primary.
·     Secondary.
m-lag role priority
display m-lag summary
Use display m-lag summary to display summary information about the peer-link interface and M-LAG interfaces.
# Display summary information about the peer-link interface and M-LAG interfaces. In this example, global configuration consistency check was successful.
<Sysname> display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
       C -- Configuration consistency check failed
Peer-link interface: BAGG3
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
                     M-LAG interface information
M-LAG IF    M-LAG group  Local state (cause)  Peer state  Remaining down time(s)
BAGG4       4            UP                   UP          -
Table 7 Command output
Peer-link interface
Abbreviated name of the peer-link interface.
State of the peer-link interface:
·     UP.
·     DOWN.
·     If the peer-link interface is down, this field also displays the cause of the down state.
State of the keepalive link:
·     UP.
·     DOWN.
·     Local track negative—A local track entry became negative.
M-LAG IF
Name of the M-LAG interface.
Local state (cause)
State of the M-LAG interface:
·     UP.
·     DOWN.
If the M-LAG interface is down, this field also displays the cause of the down state:
·     A—The aggregate interface went down.
·     B—The peer M-LAG interface did not exist.
·     C—Configuration consistency check failed.
Peer state
State of the peer M-LAG interface:
·     UP.
·     DOWN—No peer M-LAG interface exists or the peer M-LAG interface is down.
·     UNKNOWN—The state of the peer M-LAG interface is unknown when the peer link is down.
Remaining down time (s)
Remaining time (in seconds) during which the M-LAG interface will stay in M-LAG MAD DOWN state. If the M-LAG interface is not in M-LAG MAD DOWN state, this field displays a hyphen (-).
display m-lag system
Use display m-lag system to display the M-LAG system settings.
# Display the M-LAG system settings.
<Sysname> display m-lag system
                     System information
Local system number: 1                      Peer system number: 2
Local system MAC: 0001-0001-0001            Peer system MAC: 0001-0001-0001
Local system priority: 123                  Peer system priority: 123
Local bridge MAC: 3cd4-3ce1-0200            Peer bridge MAC: 3cd4-437d-0300
Local effective role: Primary               Peer effective role: Secondary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: Yes
                     System timer information
Timer                      State       Value (s)    Remaining time (s)
Auto recovery              Disabled    -            -
Restore delay              Disabled    30           -
Consistency-check delay    Disabled    15           -
Standalone delay           Disabled    -            -
Role to None delay         Disabled    60           -
Table 8 Command output
Local system number
Local M-LAG system number. If the parameter is not configured, this field displays N/A.
Peer system number
Peer M-LAG system number. If the parameter is not configured or the peer does not exist, this field displays N/A.
Local system MAC
Local M-LAG system MAC address. If the parameter is not configured, this field displays N/A.
Peer system MAC
Peer M-LAG system MAC address. If the parameter is not configured or the peer does not exist, this field displays N/A.
Local M-LAG system priority. If the parameter is not configured, this field displays N/A.
Peer M-LAG system priority. If the parameter is not configured or the peer does not exist, this field displays N/A.
Local bridge MAC
Local bridge MAC address.
Peer bridge MAC
Peer bridge MAC address. If the peer does not exist, this field displays N/A.
Effective role of the local device:
·     None.
·     Primary.
·     Secondary.
Peer effective role
Effective role of the peer device:
·     None.
·     Primary.
·     Secondary.
Health level
Health level of the device. The member device with a lower value is healthier.
Whether M-LAG standalone mode is enabled:
·     Enabled.
·     Disabled.
In standalone state
Whether the device is in M-LAG standalone mode:
·     Yes.
·     No.
Timer
Timer type:
·     Auto recovery—Reload delay timer.
·     Restore delay—Data restoration interval.
·     Consistency check delay—Configuration consistency check delay timer.
·     Standalone delay—Delay that the device must wait before changing to M-LAG standalone mode.
·     Role to None delay—Delay that the device must wait before setting its role to None.
State of the timer:
·     Enabled.
·     Disabled.
Value (s)
Value of the timer, in seconds.
Remaining time (s)
Remaining time of the timer, in seconds.
If the timer has not started, this field displays a hyphen (-).
display m-lag troubleshooting
Use display m-lag troubleshooting to display M-LAG troubleshooting information.
display m-lag troubleshooting [ m-lag-interface | peer-link | keepalive ] [ history ] [ count ]
m-lag-interface: Displays M-LAG interface troubleshooting information.
peer-link: Displays peer-link interface troubleshooting information.
keepalive: Displays keepalive link troubleshooting information.
history: Displays troubleshooting records. If you do not specify this keyword, the command displays current troubleshooting information.
count: Specifies the number of events to display, in the range of 1 to 200. If you do not specify this argument, the command displays the most recent 20 events.
If you do not specify the m-lag-interfac, peer-link, or keepalive keywords, this command displays troubleshooting information about M-LAG interfaces, the peer-link interface, and the keepalive link.
# Display M-LAG troubleshooting records.
<Sysname> display m-lag troubleshooting history
Total: 3
Time                     Event description
2019-09-10 14:13:53.103  Peer-link interface BAGG10 went down because the
                         peer-link interface role of the interface was removed.
                         Please reconfigure an interface as the peer-link interface.
2019-09-10 14:23:53.102  Keepalive link went down because the peer keepalive
                         timeout timer expired. Please check the keepalive
                         packet transmission and reception status at the two
                         ends.
2019-09-10 14:53:53.103  Local M-LAG interface state of BAGG1024 in M-LAG group 1024
                         changed to down because the aggregate interface went
                         down. Please check the aggregate link status.
reset m-lag troubleshooting history
display m-lag verbose
Use display m-lag verbose to display detailed information about the peer-link interface and M-LAG interfaces.
display m-lag verbose [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an M-LAG interface or the peer-link interface by its number. The interface number must already exist. If you do not specify an interface, the command displays detailed information about the peer-link interface and all M-LAG interfaces.
If the specified interface is not the peer-link interface or an M-LAG interface, no information is displayed.
# Display detailed information about M-LAG interface Bridge-Aggregation 1.
<Sysname> display m-lag verbose interface bridge-aggregation 1
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
       D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
       G -- Port_Sync, H -- Expired
M-LAG interface/M-LAG group ID: BAGG1/1
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG interface down cause: -
Remaining M-LAG DOWN time: -
Local M-LAG interface LACP MAC: Config=0001-0001-0001, Effective=0001-0001-0001
Peer M-LAG interface LACP MAC: Config=0001-0001-0001, Effective=0001-0001-0001
Local M-LAG interface LACP priority: Config=200, Effective=200
Peer M-LAG interface LACP priority: Config=200, Effective=200
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): XGE1/0/1 (260), XGE1/0/2 (261)
Peer Selected ports indexes: 260, 261
# Display detailed information about peer-link interface Bridge-Aggregation 2.
<Sysname> display m-lag verbose interface bridge-aggregation 2
Peer-link interface/Peer-link interface ID: BAGG2/1
State: UP
Cause: -
Local Selected ports (index): XGE1/0/1 (258), XGE1/0/2 (259)
Peer Selected ports indexes: 258, 259
Table 9 Command output
Flags
DRCP state flags. The flag field is one byte long, represented by ABCDEFGH from the lowest bit to the highest bit. A letter is displayed when its bit is 1 and is not displayed when its bit is 0.
·     A—Indicates whether DRCP is enabled on the local device. 1 indicates enabled. 0 indicates disabled.
·     B—Indicates whether DRCP is enabled on the M-LAG peer. 1 indicates enabled. 0 indicates disabled.
·     C—Indicates whether DRCP is enabled on a third M-LAG member device. 1 indicates enabled. 0 indicates disabled.
·     D—Indicates whether the local peer-link interface has determined that DRCP is enabled on the M-LAG peer. 1 indicates yes. 0 indicates no.
·     E—Indicates the DRCP timeout timer. 1 indicates the short timeout timer. 0 indicates the long timeout timer.
·     F—Indicates whether the local peer-link interface permits the packets that contain the negotiated gateway conversation IDs. 1 indicates yes. 0 indicates no.
·     G—Indicates whether the local peer-link interface permits the packets that contain the negotiated port conversation IDs. 1 indicates yes. 0 indicates no.
·     H—Indicates whether the local DRCPDU receive machine is in default or expired state. 1 indicates yes. 0 indicates no.
Peer-link interface
M-LAG interface
State of the local M-LAG interface:
·     UP—The M-LAG interface is up if it has Selected ports in its aggregation group.
·     DOWN—The M-LAG interface is down if it does not have Selected ports in its aggregation group.
M-LAG group state
State of the M-LAG group:
·     UP—The M-LAG group is up if it contains a minimum of one member M-LAG interface in UP state.
·     DOWN—The M-LAG group is down if it all its member M-LAG interfaces are in DOWN state.
Cause of the down state of the local M-LAG interface. If the local M-LAG interface is up, this field displays a hyphen (-).
·     UP.
·     DOWN.
Cause
Cause of the down state of the peer-link interface. If the peer-link interface is up, this field displays a hyphen (-).
Config
Configured value.
Effective
Effective value.
Local DRCP flags
Local DRCP state flags. If all bits are set to 0, this field displays Unknown.
Peer DRCP flags
Peer DRCP state flags. If all bits are set to 0 or no peer exists, this field displays Unknown.
Abbreviated name of the Selected ports in the local aggregation group and their port indexes.
Port indexes of the Selected ports in the peer aggregation group.
display m-lag virtual-ip
Use display m-lag virtual-ip to display M-LAG virtual IP addresses (VIPs).
display m-lag virtual-ip [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a VLAN interface or loopback interface by its number. The interface number must already exist. If you do not specify an interface, the command displays detailed information about all M-LAG VIPs.
# Display all M-LAG VIPs.
<Sysname> display m-lag virtual-ip
Interface   IP address                MAC address       Effective State
Vlan2       10.10.10.10/24            0001-0001-0001    ACTIVE
            10.10.20.10/24            0001-0001-0002    STANDBY
Loop1       1::20/124                 0001-0001-0003    STANDBY
            1::10/124                 0001-0001-0004    ACTIVE
Table 10 Command output
Abbreviated name of the interface.
IP address
Virtual IP address.
MAC address
Virtual MAC address.
Effective State
State of the virtual IP address:
·     Active—The virtual IPv4 address is active on the local device.
·     Standby—The virtual IPv4 address is standby on the local device.
m-lag authentication key
Use m-lag authentication key to enable M-LAG packet authentication and configure an authentication key.
Use undo m-lag authentication key to disable M-LAG packet authentication.
m-lag authentication key { simple | cipher } string
M-LAG packet authentication is disabled.
cipher: Specifies an authentication key in encrypted form.
simple: Specifies an authentication key in plaintext form. For security purposes, the authentication key specified in plaintext form will be stored in encrypted form.
string: Specifies the authentication key. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
To prevent DRCPDU and keepalive packet tampering from causing link flapping, enable M-LAG packet authentication on M-LAG member devices. With this feature enabled, M-LAG member devices compute a message digest by using an authentication key for each outgoing DRCPDU or keepalive packet and insert the message digest into the packet. When receiving a DRCPDU or keepalive packet, an M-LAG member device computes a message digest and compares it with the message digest in the packet. If the message digests match, the packet passes authentication. If the message digests do not match, the device drops the packet.
For successful authentication, configure the same authentication key for the M-LAG member devices.
# Enable M-LAG packet authentication and configure the authentication key as abcdefg.
[Sysname] m-lag authentication key simple abcdefg
m-lag auto-recovery reload-delay
Use m-lag auto-recovery reload-delay to enable M-LAG system auto-recovery and set the reload delay timer.
Use undo m-lag auto-recovery reload-delay to restore the default.
m-lag auto-recovery reload-delay delay-value
M-LAG system auto-recovery is disabled and the reload delay timer is not set.
delay-value: Specifies a reload delay in the range of 240 to 3600 seconds.
If only one M-LAG member device recovers after the entire M-LAG system reboots, auto-recovery enables that member device to remove its M-LAG interfaces from the M-LAG DOWN interface list.
·     If that member device has up M-LAG interfaces, it takes over the primary role when the reload delay timer expires and forwards traffic.
·     If that member device does not have up M-LAG interfaces, it is stuck in the None role and does not forward traffic.
If auto-recovery is disabled, that M-LAG member device will be stuck in the None role with all its M-LAG interfaces being M-LAG DOWN after it recovers.
If both M-LAG member devices recover and have up M-LAG interfaces after the entire M-LAG system reboots, active-active situation might occur if both peer link and keepalive links were down when the reload delay timer expires. If this rare situation occurs, examine the peer link and keepalive links and restore them.
To avoid incorrect role preemption, make sure the reload delay timer is longer than the amount of time required for the device to restart.
# Enable M-LAG system auto-recovery and set the reload delay timer to 245 seconds.
[Sysname] m-lag auto-recovery reload-delay 245
display m-lag role
m-lag consistency-check disable
Use m-lag consistency-check disable to disable M-LAG from performing configuration consistency check.
Use undo m-lag consistency-check disable to enable M-LAG to perform configuration consistency check.
M-LAG performs configuration consistency check.
To ensure that the M-LAG system can operate correctly, M-LAG by default performs configuration consistency check when the M-LAG system is set up.
Configuration consistency check might fail when you upgrade the M-LAG member devices in an M-LAG system. To prevent the M-LAG system from falsely shutting down M-LAG interfaces, you can temporarily disable configuration consistency check.
You must make sure the M-LAG member devices use the same setting for configuration consistency check.
# Disable M-LAG from performing configuration consistency check.
[Sysname] m-lag consistency-check disable
m-lag consistency-check mode
Use m-lag consistency-check mode to set the mode of configuration consistency check.
Use undo m-lag consistency-check mode to restore the default.
m-lag consistency-check mode { loose | strict }
Configuration consistency check uses strict mode.
loose: Specifies loose mode.
strict: Specifies strict mode.
The device handles configuration inconsistency depending on the mode of configuration consistency check.
·     For type 1 configuration inconsistency:
¡     The device generates log messages if loose mode is enabled.
¡     The device shuts down M-LAG interfaces and generates log messages if strict mode is enabled.
·     For type 2 configuration inconsistency, the device only generates log messages, whether strict or loose mode is enabled.
# Enable the loose mode of configuration consistency check.
[Sysname] m-lag consistency-check mode loose
m-lag drcp period short
Use m-lag drcp period short to enable the short DRCP timeout timer (3 seconds) on the peer-link interface or an M-LAG interface.
Use undo m-lag drcp period to restore the default.
An aggregate interface uses the long DRCP timeout timer (90 seconds).
VXLAN tunnel interface view
This command takes effect only on the peer-link interface or an M-LAG interface.
DRCP uses a timeout mechanism to specify the amount of time that a peer-link interface or M-LAG interface must wait to receive DRCPDUs before it determines that the peer interface is down. This timeout mechanism provides the following timer options:
·     Short DRCP timeout timer, which is fixed at 3 seconds. If this timer is used, the peer interface sends one DRCPDU every second.
·     Long DRCP timeout timer, which is fixed at 90 seconds. If this timer is used, the peer interface sends one DRCPDU every 30 seconds.
Short DRCP timeout timer enables the M-LAG member devices to detect a peer interface down event more quickly than the long DRCP timeout timer. However, this benefit is at the expense of bandwidth and system resources.
To avoid traffic interruption during an ISSU or M-LAG process restart, disable the short DRCP timeout timer before you perform an ISSU or M-LAG process restart. For more information about ISSU, see Fundamentals Configuration Guide.
# Enable the short DRCP timeout timer on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] m-lag drcp period short
m-lag extra-vlan
Use m-lag extra-vlan to configure M-LAG extra VLANs.
Use undo m-lag extra-vlan to remove M-LAG extra VLANs.
m-lag extra-vlan vlan-id-list
undo m-lag extra-vlan vlan-id-list
No M-LAG extra VLANs are configured.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The end VLAN ID cannot be smaller than the start VLAN ID. The value range for VLAN IDs is 1 to 4094.
Make sure that the specified extra VLANs already exist on the device.
For VLANs permitted only on non-M-LAG interfaces, the device processes traffic locally and do not synchronize forwarding entries such as MAC and ARP entries with the M-LAG peer device. For the device to synchronize forwarding entries for such VLANs, configure them as extra VLANs. The device will synchronize forwarding entries for the extra VLANs even though they are not permitted on M-LAG interfaces. When the uplink of one M-LAG member device fails, traffic of the extra VLANs can fail over to the other M-LAG member device through the peer link.
# Configure VLAN 1 as an extra VLAN.
<Sysname> system
[Sysname] m-lag extra-vlan 1
m-lag peer-link mac-address hold
Use m-lag peer-link mac-address hold to enable the peer-link interface to retain MAC address entries for single-homed devices.
Use undo m-lag peer-link mac-address hold to disable the peer-link interface from retaining MAC address entries for single-homed devices.
The peer-link interface does not retain MAC address entries for single-homed devices when the devices go down.
When an M-LAG member device detects that the link to a single-homed device goes down, the peer-link interface takes the following actions:
·     Deletes the MAC address entries for the single-homed device.
·     Sends a message to the peer peer-link interface for it to delete the affected MAC address entries.
If the link to a single-homed device flaps constantly, the peer-link interface repeatedly deletes and adds MAC address entries for the device. This situation increases floods of unicast traffic destined for the single-homed device.
To reduce flood traffic, enable the peer-link interface to retain MAC address entries for single-homed devices. After the links to single-homed devices go down, the affected MAC address entries age out on expiration of the MAC aging timer instead of being deleted immediately. The timer is set by using the mac-address timer command. For more information about this command, see MAC address table commands in Layer 2—LAN Switching Command Reference.
# Enable the peer-link interface to retain MAC address entries for single-homed devices.
[Sysname] m-lag peer-link mac-address hold
mac-address timer
Use m-lag keepalive { ip | ipv6 } to configure M-LAG keepalive packet parameters.
Use undo m-lag keepalive { ip | ipv6 } to restore the default.
m-lag keepalive { ip | ipv6 } destination { ipv4-address | ipv6-address } [ source { ipv4-address | ipv6-address } | udp-port udp-number | vpn-instance vpn-instance-name ] *
No keepalive packet parameters are configured.
ip: Specifies IPv4 addresses.
ipv6: Specifies IPv6 addresses.
destination: Specifies an IP address of the M-LAG peer as the destination IP address of keepalive packets.
source: Specifies a local IP address as the source IP address of keepalive packets. If you do not specify a source IP address, the IP address of the outgoing interface is used.
ipv4-address: Specifies an IPv4 address.
ipv6-address: Specifies an IPv6 address.
udp-port udp-number: Specifies the destination UDP port of keepalive packets. The value range for the udp-number argument is 1 to 65535. If you do not specify a UDP port number, 6400 is used.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the keepalive packets belong to the public network, do not specify a VPN instance.
The device accepts only keepalive packets that are sourced from the specified destination IP address. The keepalive link goes down if the device receives keepalive packets sourced from any other IP addresses.
Make sure the M-LAG member devices in an M-LAG system use the same keepalive destination UDP port.
# Specify the destination and source IP addresses of keepalive packets as 192.168.68.125 and 192.168.68.100, respectively.
[Sysname] m-lag keepalive ip destination 192.168.68.125 source 192.168.68.100
Use m-lag keepalive hold-time to set the keepalive hold timer.
Use undo m-lag keepalive hold-time to restore the default.
m-lag keepalive hold-time value
The keepalive hold timer is 3 seconds.
value: Specifies a timer value in the range of 3 to 10 seconds.
IMPORTANT
IMPORTANT:
For the M-LAG member device to correctly determine the cause of a peer link down event, make sure the keepalive hold timer is longer than the keepalive interval and is shorter than the keepalive timeout timer.
The keepalive hold timer starts when the peer link goes down. The keepalive hold timer specifies the amount of time that the device uses to identify the cause of a peer link down event.
·     If the device receives keepalive packets from the M-LAG peer before the timer expires, the peer link is down because the peer link fails.
·     If the device does not receive keepalive packets from the M-LAG peer before the timer expires, the peer link is down because the peer M-LAG member device fails.
If you use M-LAG and VRRP together, make sure the keepalive hold timer is shorter than the interval at which the VRRP master sends VRRP advertisements. Violation of this restriction might cause a VRRP master/backup switchover to occur before peer link failure is confirmed. To set the interval at which the VRRP master sends VRRP advertisements, use the vrrp vrid timer advertise command. For more information about this command, see High Availability Command Reference.
# Set the keepalive hold timer to 5 seconds.
[Sysname] m-lag keepalive hold-time 5
vrrp vrid timer advertise (High Availability Command Reference)
Use m-lag keepalive interval to set the M-LAG keepalive interval and timeout timer.
Use undo m-lag keepalive interval to restore the default.
m-lag keepalive interval interval [ timeout timeout ]
The M-LAG keepalive interval is 1000 milliseconds, and the M-LAG keepalive timeout timer is 5 seconds.
interval interval: Specifies the keepalive interval, in the range of 100 to 10000 milliseconds.
timeout timeout: Specifies the keepalive timeout timer, in the range of 3 to 20 seconds. The local keepalive timeout timer must be two times the keepalive interval of the peer at minimum.
The device sends keepalive packets at the specified interval to its M-LAG peer. If the device has not received a keepalive packet from the M-LAG peer before the keepalive timeout timer expires, the device determines that the keepalive link is down.
You must configure the same M-LAG keepalive interval on the M-LAG member devices in an M-LAG system.
# Set the M-LAG keepalive interval and timeout timer to 2000 milliseconds and 6 seconds, respectively.
[Sysname] m-lag keepalive interval 2000 timeout 6
Changing the keepalive interval might cause system setup failure. Continue? [Y/N]:y
m-lag keepalive track
Use m-lag keepalive track to associate the keepalive link with a track entry.
Use undo m-lag keepalive track to restore the default.
m-lag keepalive track track-entry-number
undo m-lag keepalive track track-entry-number
No track entry is associated with the keepalive link.
track-entry-number: Specifies a track entry number in the range of 1 to 1024.
Associate a track entry with the keepalive link to fast detect state changes of the keepalive link. For more information about track entries, see Track configuration in High Availability Configuration Guide.
# Associate the keepalive link with track entry 1.
<Sysname> system
[Sysname] m-lag keepalive track 1
Use m-lag mad default-action to configure the default M-LAG MAD action to take on network interfaces on the secondary M-LAG member device when the M-LAG system splits.
Use undo m-lag mad default-action to restore the default.
m-lag mad default-action { down | none }
M-LAG MAD shuts down network interfaces on the secondary M-LAG member device.
down: Sets the action to M-LAG MAD DOWN. M-LAG MAD will shut down all network interfaces on the secondary M-LAG member device when the M-LAG system splits, except the interfaces excluded manually or by the system.
none: Sets the M-LAG MAD action to NONE. M-LAG MAD will not shut down any network interfaces when the M-LAG system splits, except the interfaces configured manually or by the system to be shut down by M-LAG MAD.
In most network environments, use the M-LAG MAD DOWN action in conjunction with the m-lag mad exclude interface command.
·     The M-LAG MAD DOWN action helps avoid network issues caused by multi-active collision, which occurs if the peer link goes down while the keepalive link is up.
·     The m-lag mad exclude interface command enables you to exclude special-purpose interfaces, for example, interfaces used in M-LAG for M-LAG keepalive detection.
This configuration method is inefficient if a large number of interfaces on the secondary M-LAG member must be retained in up state after the M-LAG system splits. For example, if you use a VXLAN tunnel as the peer link in an EVPN environment, you must retain a large number of logical interfaces (for example, VLAN, aggregate, loopback, tunnel, and VSI interfaces, and aggregation member ports) in up state.
In these situations, use the following method to configure M-LAG MAD:
·     Set the default M-LAG MAD action to NONE.
·     Execute the m-lag mad include interface command to specify interfaces that must be shut down by M-LAG MAD in addition to those already automatically specified by the system.
The M-LAG MAD DOWN action will not take effect on the following interfaces:
·     Interfaces automatically or manually excluded from being shut down by M-LAG MAD. To identify these interfaces, execute the display m-lag mad verbose command.
·     Interfaces used for special purposes, including:
¡     Interfaces placed in a loopback test by using the loopback command.
¡     Interfaces in a service loopback group.
¡     Interfaces in a mirroring group.
¡     Interfaces forced to stay up by using the port-up mode command.
# Configure M-LAG MAD to shut down all network interfaces except excluded interfaces when the M-LAG system splits.
[Sysname] m-lag mad default-action down
loopback (Interface Command Reference)
mirroring-group reflector-port (Network Management and Monitoring Command Reference)
port service-loopback group
port up-mode (Interface Command Reference)
Use m-lag mad exclude interface to add an interface to the user-configured list of excluded ports, which will not be shut down by M-LAG MAD when the M-LAG system splits.
Use undo m-lag mad exclude interface to remove an interface from the user-configured list of excluded ports.
m-lag mad exclude interface interface-type interface-number
undo m-lag mad exclude interface interface-type interface-number
M-LAG MAD shuts down all network interfaces when detecting a multi-active collision, except for the network interfaces set by the system to not shut down.
This command is typically used when the default M-LAG MAD action is set to M-LAG MAD DOWN. In this situation, when M-LAG MAD detects a multi-active collision, M-LAG sets all network interfaces on the secondary M-LAG member device to M-LAG MAD DOWN state, except for the following interfaces:
·     Network interfaces manually configured to not shut down by M-LAG MAD.
·     Network interfaces set by the system to not shut down by M-LAG MAD, including:
¡     Peer-link interface.
¡     Aggregation member interfaces if a Layer 2 aggregate interface is used as the peer-link interface.
¡     M-LAG interfaces.
¡     Management interfaces.
You must exclude the following interfaces from the shutdown action by M-LAG MAD:
·     For correct keepalive detection, you must exclude the interfaces used for keepalive detection from the shutdown action.
·     For M-LAG member devices to synchronize ARP entries, you must exclude the VLAN interfaces of the VLANs to which the M-LAG interfaces and peer-link interfaces belong from the shutdown action.
·     If the peer-link interface is a tunnel interface, you must exclude the traffic outgoing interface for the tunnel from the shutdown action. To view the traffic outgoing interface for a tunnel, use the display fib ip-address or display ip routing-table ip-address command. To view the destination address of a tunnel, use the display interface tunnel command.
# Exclude Ten-GigabitEthernet 1/0/1 from the shutdown action by M-LAG MAD.
[Sysname] m-lag mad exclude interface ten-gigabitethernet 1/0/1
display fib (Layer 3—IP Services Command Reference)
display interface tunnel (Layer 3—IP Services Command Reference)
display ip routing-table (Layer 3—IP Routing Command Reference)
Use m-lag mad exclude logical-interfaces to exclude all logical interfaces from the shutdown action by M-LAG MAD.
Use undo m-lag mad exclude logical-interfaces to restore the default.
By default, M-LAG MAD shuts down all network interfaces when it detects a multi-active collision, except for the network interfaces set by the system to not shut down.
When a VXLAN tunnel is used as the peer link on an EVPN M-LAG system, you must retain a large number of logical interfaces (for example, VLAN, aggregate, loopback, tunnel, and VSI interfaces, and aggregation member ports) in up state. To simplify configuration, you can exclude all logical interfaces from the shutdown action by M-LAG MAD.
The m-lag mad exclude interface and m-lag mad include interface commands take precedence over the m-lag mad exclude logical-interfaces command.
# Exclude all logical interfaces from the shutdown action by M-LAG MAD.
[Sysname] m-lag mad exclude logical-interfaces
Use m-lag mad include interface to add an interface to the user-configured list of included ports, which will be shut down by M-LAG MAD when the M-LAG system splits.
Use undo m-lag mad include interface to remove a network interface from the user-configured list of included ports.
m-lag mad include interface interface-type interface-number
undo m-lag mad include interface interface-type interface-number
The user-configured included port list does not contain any ports.
This command is typically used when the default M-LAG MAD action is set to NONE. In this situation, M-LAG MAD does not shut down the network interfaces on the secondary M-LAG member device when the M-LAG system splits. To avoid network issues caused by multi-active collision, add network interfaces to the user-configured include port list if they are not in the system-configured included port list. M-LAG MAD on the secondary M-LAG member device will shut down the interfaces in the system-configured and user-configured included port lists when the M-LAG system splits.
For example, if you use a VXLAN tunnel as the peer link in an EVPN environment, you must retain a large number of logical interfaces (for example, VLAN, aggregate, loopback, tunnel, and VSI interfaces, and aggregation member ports) in up state. To improve configuration efficiency, you can set the default M-LAG MAD action to NONE and add interfaces to the user-configured include port list.
·     Network interfaces automatically or manually excluded from being shut down by M-LAG MAD. To identify these interfaces, execute the display m-lag mad verbose command.
·     Network interfaces used for special purposes, including:
# Configure M-LAG MAD to shut down Bridge-Aggregation 1 on the secondary M-LAG member device when the M-LAG system splits.
[Sysname] m-lag mad include interface bridge-aggregation 1
Use m-lag mad persistent to enable M-LAG MAD DOWN state persistence.
Use undo m-lag mad persistent to disable M-LAG MAD DOWN state persistence.
The secondary M-LAG member device brings up interfaces in M-LAG MAD DOWN state when its role changes to primary.
M-LAG MAD DOWN state persistence prevents the secondary M-LAG member device from bringing up the network interfaces in M-LAG MAD DOWN state when its role change to primary. This feature helps avoid the forwarding issues that might occur in the multi-active situation that occurs because the keepalive link goes down while the peer link is down.
# Enable M-LAG MAD DOWN state persistence.
[Sysname] m-lag mad persistent
m-lag mad restore
m-lag mad restore
Use m-lag mad restore to bring up the interfaces in M-LAG MAD DOWN state.
m-lag mad restore
Execute this command only when both the peer link and the keepalive link are down.
You can bring up the interfaces in M-LAG MAD DOWN state on the secondary M-LAG member device for it to forward traffic if the following conditions exist:
·     The primary M-LAG member device fails while the peer link is down.
·     M-LAG MAD DOWN state persists on the secondary M-LAG member device.
# Bring up the interfaces in M-LAG MAD DOWN state.
[Sysname] m-lag mad restore
To avoid network issues, make sure the primary device has failed and cannot forward traffic. Continue? [Y/N]:y
m-lag restore-delay
Use m-lag restore-delay to set the data restoration interval.
Use undo m-lag restore-delay to restore the default.
m-lag restore-delay value
The data restoration interval is 30 seconds.
value: Specifies the data restoration interval, in the range of 1 to 3600 seconds.
The data restoration interval specifies the maximum amount of time for the secondary M-LAG member device to synchronize data with the primary M-LAG member device during M-LAG system setup. Within the data restoration interval, the secondary M-LAG member device sets all network interfaces to M-LAG MAD DOWN state, except for the following interfaces:
·     Interfaces excluded from the shutdown action by M-LAG MAD.
When the data restoration interval expires, the secondary M-LAG member device brings up all network interfaces.
To avoid packet loss and forwarding failure, increase the data restoration interval if the amount of data is large or if an ISSU is to be performed between the M-LAG member devices.
# Set the data restoration interval to 50 seconds.
[Sysname] m-lag restore-delay 50
m-lag role priority
Use m-lag role priority to set the M-LAG role priority of the device.
Use undo m-lag role priority to restore the default.
m-lag role priority priority-value
The M-LAG role priority of the device is 32768.
priority-value: Specifies the M-LAG role priority, in the range of 0 to 65535. The lower the value, the higher the priority.
For features that require centralized traffic processing, an M-LAG member device is assigned the primary or secondary role based on its M-LAG role priority. The secondary M-LAG member device forwards the traffic of those features to the primary M-LAG member device for processing. If the M-LAG member devices use the same M-LAG role priority, the member device with a lower bridge MAC address is assigned the primary role.
As a best practice to avoid network flapping, do not modify the M-LAG role priority of M-LAG member devices after the M-LAG system is established.
# Set the M-LAG role priority of the device to 66.
[Sysname] m-lag role priority 66
display m-lag role
m-lag sequence enable
Use m-lag sequence enable to enable M-LAG sequence number check.
Use undo m-lag sequence enable to disable M-LAG sequence number check.
M-LAG sequence number check is disabled.
To protect M-LAG member devices from replay attacks, enable M-LAG sequence number check for them to identify attack packets.
With this feature enabled, the M-LAG member devices insert a sequence number into each outgoing DRCPDU or keepalive packet and the sequence number increases by 1 for each sent packet. When receiving a DRCPDU or keepalive packet, the M-LAG member devices check its sequence number and drop the packet if the check result is either of the following:
·     The sequence number of the packet is the same as that of a previously received packet.
·     The sequence number of the packet is smaller than that of the most recently received packet.
As a best practice to improve security, use M-LAG sequence number check together with M-LAG packet authentication.
After one M-LAG member device reboots, the other M-LAG member device might receive and accept the packets that were intercepted by an attacker before the reboot. As a best practice, change the  authentication key after an M-LAG member device reboots.
# Enable M-LAG sequence number check.
[Sysname] m-lag sequence enable
m-lag standalone enable
Use m-lag standalone enable to enable M-LAG standalone mode.
Use undo m-lag standalone enable to disable M-LAG standalone mode.
m-lag standalone enable [ delay delay-time ]
undo m-lag standalone enable [ delay ]
M-LAG standalone mode is disabled.
delay delay-time: Sets the delay that the device must wait before changing to M-LAG standalone mode. The value range for this delay is 0 to 3600 seconds. If you do not set this parameter, the device changes to M-LAG standalone mode without delay when both the peer link and the keepalive link go down.
Enable M-LAG standalone mode to avoid forwarding issues in the multi-active situation that might occur after both the peer link and the keepalive link are down.
M-LAG standalone mode helps avoid traffic forwarding issues in this multi-active situation by allowing only the member ports in the M-LAG interfaces on one member device to forward traffic.
An M-LAG member device does not enter M-LAG standalone mode if the M-LAG peer reboots.
As a best practice, enable M-LAG standalone mode on both primary and secondary M-LAG member devices.
To prevent member ports of M-LAG interfaces from flapping, set the M-LAG standalone mode delay to be longer than the time required for a device reboot.
Before you enable M-LAG standalone mode on an M-LAG member device, make sure its LACP system priority is higher than that of the remote aggregation system. This restriction ensures that the reference port is on the remote aggregation system and prevents the interfaces attached to the M-LAG system from flapping.
An M-LAG member device changes to M-LAG standalone mode only when it detects that both the peer link and the keepalive link are down. It does not change to M-LAG standalone mode when the peer M-LAG member device reboots.
# Enable M-LAG standalone mode.
[Sysname] m-lag standalone enable
m-lag system-mac
Use m-lag system-mac to configure the M-LAG system MAC address.
Use undo m-lag system-mac to restore the default.
m-lag system-mac { bridge-address | mac-address }
The M-LAG system MAC address is not configured.
bridge-address: Specifies the bridge MAC address in the H-H-H format.
mac-address: Specifies a MAC address in the H-H-H format. The MAC address cannot be a multicast MAC address, all-zero MAC address, or all-F MAC address.
CAUTION
CAUTION:
Changing the M-LAG system MAC address causes M-LAG system split. When you perform this task on a live network, make sure you are fully aware of its impact.
The M-LAG system MAC address uniquely identifies the M-LAG system on the network. For the M-LAG member devices to be identified as one M-LAG system, you must configure the same M-LAG system MAC address on them. As a best practice to avoid MAC address collision, use the bridge MAC address of one M-LAG member device as the M-LAG system MAC address.
# Configure the M-LAG system MAC address as 0001-0001-0001.
[Sysname] m-lag system-mac 1-1-1
Changing the system MAC address might flap the intra-portal link and cause M-LAG system setup failure. Continue? [Y/N]:y
[Sysname]
m-lag system-number
Use m-lag system-number to set the M-LAG system number.
Use undo m-lag system-number to restore the default.
m-lag system-number system-number
The M-LAG system number is not set.
system-number: Specifies the M-LAG system number. Available values are 1 and 2.
CAUTION
CAUTION:
Changing the M-LAG system number causes M-LAG system split. When you perform this task on a live network, make sure you are fully aware of its impact.
You must assign different M-LAG system numbers to the M-LAG member devices in an M-LAG system.
# Set the M-LAG system number to 1.
[Sysname] m-lag system-number 1
Changing the system number might flap the intra-portal link and cause M-LAG system setup failure. Continue? [Y/N]:y
[Sysname]
m-lag system-priority
Use m-lag system-priority to set the M-LAG system priority.
Use undo m-lag system-priority to restore the default.
m-lag system-priority priority
The M-LAG system priority is 32768.
priority: Specifies a priority value in the range of 0 to 65535. The lower the value, the higher the priority.
CAUTION
CAUTION:
Changing the M-LAG system priority causes M-LAG system split. When you perform this task on a live network, make sure you are fully aware of its impact.
An M-LAG system uses its M-LAG system priority as the system LACP priority to communicate with the remote aggregation system.
You must configure the same M-LAG system priority for the M-LAG member devices in an M-LAG system.
# Set the M-LAG system priority to 64.
[Sysname] m-lag system-priority 64
Changing the system priority might flap the intra-portal link and cause M-LAG system setup failure. Continue? [Y/N]:y
[Sysname]
port m-lag group
Use port m-lag group to assign an aggregate interface to an M-LAG group.
Use undo port m-lag group to restore the default.
port m-lag group group-id [ allow-single-member ]
An aggregate interface does not belong to an M-LAG group.
group-id: Specifies an M-LAG group number in the range of 1 to 1024.
allow-single-member: Allows the Layer 2 aggregate interface to be the only member of the specified M-LAG group. M-LAG MAD will not place the interface in M-LAG MAD DOWN state. If you do not specify this keyword, M-LAG MAD will shut down the interface if it is the only member of the specified M-LAG group. As a best practice, specify this keyword for a dynamic aggregate interface.
Specify the allow-single-member keyword only when the network is managed by a controller. For example, Device A and Device B form an M-LAG system, and they separately set up OpenFlow channels with the controller. If the OpenFlow channel of Device A is disconnected, the controller will notify Device B of this event. Then, Device B will permit access of single-homed peer devices on the M-LAG interfaces with the allow-single-member keyword configured. Those M-LAG interfaces will not be shut down by M-LAG MAD.
To use a Layer 2 aggregate interface as an M-LAG interface, you must assign it to an M-LAG group.
The device can have multiple M-LAG interfaces. However, you can assign a Layer 2 aggregate interface to only one M-LAG group.
A Layer 2 aggregate interface cannot operate as both peer-link interface and M-LAG interface.
If you specify the allow-single-member keyword for an M-LAG interface, the access device attached to the aggregate interface is identified as a single-homed device. The M-LAG interface is a single-homed M-LAG interface.
To prevent loops when you assign a single-homed aggregate interface to an M-LAG group, use the following procedure:
1.     Assign the aggregate interface to the M-LAG group.
2.     Assign ports to the aggregation group of the aggregate interface.
When you remove a single-homed M-LAG interface from its M-LAG group, use the following procedure:
1.     Remove the member ports from the aggregation group of the M-LAG interface.
2.     Remove the M-LAG interface from the M-LAG group.
# Assign Bridge-Aggregation 1 to M-LAG group 100.
[Sysname-Bridge-Aggregation1] port m-lag group 100
port m-lag peer-link
Use port m-lag peer-link to specify an aggregate interface or VXLAN tunnel interface as the peer-link interface.
Use undo port m-lag peer-link to restore the default.
port m-lag peer-link port-id
No interface is the peer-link interface.
port-id: Specifies the peer-link interface ID, which is fixed at 1.
An M-LAG member device can have only one peer-link interface.
Make sure the bandwidth of the peer-link interface is higher than that of an M-LAG interface.
If you specify an aggregate interface as a peer-link interface, the device assigns the aggregate interface as a trunk port to all VLANs when the interface uses the default VLAN settings. If not, the device does not change the VLAN settings of the interface.
The device does not change the VLAN settings of an aggregate interface when you remove its peer-link interface role.
As a best practice to reduce the impact of interface flapping on upper-layer services, execute the link-delay command on the peer-link interface.
By default, MAC address learning is enabled on the peer-link interface. This feature is not configurable on the peer-link interface.
You must use the shutdown command to shut down an interface before you remove it from the peer-link interface's aggregation group.
# Specify Bridge-Aggregation 2 as the peer-link interface.
[Sysname] interface bridge-aggregation 2
[Sysname-Bridge-Aggregation2] port m-lag peer-link 1
link-delay
mac-address mac-learning enable
port m-lag ipv6 virtual-ip
Use port m-lag ipv6 virtual-ip to assign an M-LAG virtual IPv6 address to an interface.
Use undo port m-lag ipv6 virtual-ip to restore the default.
VLAN interface view:
port m-lag ipv6 virtual-ip ipv6-address { prefix-length [ active | standby ] [ virtual-mac mac-address ] | link-local }
undo port m-lag ipv6 virtual-ip [ ipv6-address ]
Loopback interface view:
port m-lag ipv6 virtual-ip ipv6-address { prefix-length [ active | standby ] | link-local }
VSI interface view:
No M-LAG virtual IPv6 addresses are assigned to interfaces.
VLAN interface view
VSI interface view
ipv6-address: Specifies a virtual IPv6 address.
prefix-length: Specifies a prefix length for the IPv6 address, in the range of 0 to 128.
active: Sets the virtual IPv6 address to be active on the local device.
standby: Sets the virtual IPv6 address to be standby on the local device.
virtual-mac mac-address: Specifies a MAC address in the H-H-H format. The MAC address cannot be a multicast MAC address, all-zero MAC address, or all-F MAC address.
link-local: Uses the specified link-local address as the virtual IPv6 address. Specify this keyword only for OSPFv3 neighbor establishment when dual-active gateways exist on the M-LAG system.
To ensure correct traffic forwarding, assign M-LAG virtual IPv6 addresses to the following interfaces on the M-LAG system:
·     VLAN interfaces that act as dual-active gateways for the same VLAN.
·     Loopback interfaces that offer AAA and 802.1X authentication services.
·     VSI interfaces that act as distributed EVPN gateways.
If you do not specify the active or standby keyword for a virtual IPv6 address, the address is active only on the primary M-LAG member device.
If you execute the undo port m-lag ipv6 virtual-ip command without specifying the ipv6-address argument, the command deletes all M-LAG virtual IPv6 addresses on the interface.
When the peer-link interface fails, the standby virtual IPv6 address becomes active on the primary M-LAG member device. If no virtual MAC address is associated with the standby virtual IPv6 address, the MAC address of the interface that owns the standby virtual IPv6 address is used as the virtual MAC address. In this scenario, the devices attached to the primary M-LAG member device will refresh their ND entries.
When you assign multiple M-LAG virtual IPv6 addresses to an interface, follow these restrictions and guidelines:
·     You can assign a maximum of two virtual IPv6 addresses to an interface.
·     If you configure different virtual MAC addresses for a virtual IPv6 address, the most recent configuration takes effect.
·     You cannot configure the same virtual MAC address for multiple virtual IPv6 addresses.
·     When you assign a virtual IPv6 address to VLAN interfaces, you must configure the same virtual MAC address for the virtual IPv6 address on both M-LAG member devices.
If you assign both virtual IPv4 and IPv6 addresses to VLAN interfaces, make sure the virtual IPv4 and IPv6 addresses that use the same virtual MAC address are in the same state on the M-LAG member devices.
When both M-LAG member devices act as gateways for dualhomed user-side devices, the gateway interfaces (VLAN or VSI interfaces) on the M-LAG member devices use the same IP address and MAC address. In this scenario, the M-LAG member devices cannot set up neighbor relationships with the user-side devices. To resolve this issue, assign virtual IPv6 addresses to the gateway interfaces and configure routing protocols such as BGP and OSPFv3 to use the virtual IPv6 addresses for neighbor relationship setup.
For the M-LAG member devices to set up BGP peer relationships with other devices, perform the following tasks:
·     Execute the port m-lag ipv6 virtual-ip ipv6-address prefix-length [ active | standby ] [ virtual-mac mac-address ] command.
·     Execute the peer source-address command to specify the virtual IPv6 address as the source IPv6 address for establishing TCP connections to peers.
For the M-LAG member devices to set up OSPFv3 neighbor relationships with other devices, execute the port m-lag ipv6 virtual-ip ipv6-address link-local command.
When dual-active gateways exist on the M-LAG system, you must assign unique virtual IPv6 addresses to the gateway interfaces on the M-LAG member devices and configure both virtual IPv6 addresses to be active. When you assign a virtual MAC address to a VLAN interface, make sure the virtual MAC address is identical to the MAC address assigned to the VLAN interface by using the mac-address command.
# Assign M-LAG virtual IPv6 address 1::10/64 to VLAN-interface 2 and set the state of the address to active.
[Sysname-Vlan-interface2] port m-lag ipv6 virtual-ip 1::10 64 active virtual-mac 1-1-1
nas-ip (Security Command Reference)
peer source-address (Layer 3IP Routing Command Reference)
port-security m-lag load-sharing-mode (Security Command Reference)
port m-lag system-mac
Use port m-lag system-mac to configure the M-LAG system MAC address on an aggregate interface.
Use undo port m-lag system-mac to restore the default.
port m-lag system-mac mac-address
Aggregate interface view
CAUTION
CAUTION:
The M-LAG system MAC address uniquely identifies the M-LAG system on the network. For the M-LAG member devices to be identified as one M-LAG system, you must configure the same M-LAG system MAC address on the M-LAG interfaces in the same M-LAG group. As a best practice to avoid MAC address collision, use the bridge MAC address of one M-LAG member device as the M-LAG system MAC address.
You can configure the M-LAG system MAC address on an aggregate interface only after it is configured as an M-LAG interface.
You can configure the M-LAG system MAC address globally and in aggregate interface view. The global M-LAG system MAC address takes effect on all aggregation groups. On an aggregate interface, the interface-specific M-LAG system MAC address takes precedence over the global M-LAG system MAC address.
# Configure the M-LAG system MAC address as 0001-0001-0001 on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port m-lag system-mac 1-1-1
m-lag system-mac
port m-lag system-priority
Use port m-lag system-priority to set the M-LAG system priority on an aggregate interface.
Use undo port m-lag system-priority to restore the default.
port m-lag system-priority priority
An M-LAG system uses its M-LAG system priority as the LACP system priority to communicate with the remote aggregation system.
You must configure the same M-LAG system priority for the M-LAG interfaces in the same M-LAG group.
You can configure the M-LAG system priority on an aggregate interface only after it is configured as an M-LAG interface.
You can configure the M-LAG system priority globally and in aggregate interface view. The global M-LAG system priority takes effect on all aggregation groups. On an aggregate interface, the interface-specific M-LAG system priority takes precedence over the global M-LAG system priority.
# Set the M-LAG system priority to 64 on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port m-lag system-priority 64
port m-lag virtual-ip
Use port m-lag virtual-ip to assign an M-LAG virtual IPv4 address to an interface.
Use undo port m-lag virtual-ip to restore the default.
port m-lag virtual-ip ipv4-address { mask-length | mask } [ active | standby ] [ virtual-mac mac-address ]
undo port m-lag virtual-ip [ ipv4-address ]
VSI interface view:
No M-LAG virtual IPv4 addresses are assigned to interfaces.
VLAN interface view
VSI interface view
ipv4-address: Specifies a virtual IPv4 address.
mask-length: Specifies the subnet mask length in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
active: Sets the virtual IPv4 address to be active on the local device.
standby: Sets the virtual IPv4 address to be standby on the local device.
To ensure correct traffic forwarding, assign M-LAG virtual IPv4 addresses to the following interfaces on the M-LAG system:
If you do not specify the active or standby keyword for a virtual IPv4 address, the address is active only on the primary M-LAG member device.
If you execute the undo port m-lag ipv4 virtual-ip command without specifying the ipv4-address argument, the command deletes all M-LAG virtual IPv4 addresses on the interface.
When the peer-link interface fails, the standby virtual IPv4 address becomes active on the primary M-LAG member device. If no virtual MAC address is associated with the standby virtual IPv4 address, the MAC address of the interface that owns the standby virtual IPv4 address is used as the virtual MAC address. In this scenario, the devices attached to the primary M-LAG member device will refresh their ARP entries.
When you assign multiple M-LAG virtual IPv4 addresses to an interface, follow these restrictions and guidelines:
·     You can assign a maximum of two virtual IPv4 addresses to an interface.
·     If you configure different virtual MAC addresses for a virtual IPv4 address, the most recent configuration takes effect.
·     You cannot configure the same virtual MAC address for multiple virtual IPv4 addresses.
·     When you assign a virtual IPv4 address to VLAN interfaces, you must configure the same virtual MAC address for the virtual IPv4 address on both M-LAG member devices.
When both M-LAG member devices act as gateways for dualhomed user-side devices, the gateway interfaces (VLAN or VSI interfaces) on the M-LAG member devices use the same IP address and MAC address. In this scenario, the M-LAG member devices cannot set up neighbor relationships with the user-side devices. To resolve this issue, assign virtual IPv4 addresses to the gateway interfaces and configure routing protocols such as BGP and OSPF to use the virtual IPv4 addresses for neighbor relationship setup.
·     Execute the port m-lag virtual-ip ipv4-address { mask-length | mask } [ active | standby ] [ virtual-mac mac-address ] command.
·     Execute the peer source-address command to specify the virtual IPv4 address as the source IPv4 address for establishing TCP connections to peers.
For the M-LAG member devices to set up OSPF neighbor relationships with other devices, perform the following tasks:
·     Execute the ospf peer sub-address enable command to specify the virtual IPv4 address as the secondary IPv4 address for establishing OSPF neighbor relationships.
When dual-active gateways exist on the M-LAG system, you must assign unique virtual IPv4 addresses to the gateway interfaces on the M-LAG member devices and configure both virtual IPv4 addresses to be active. When you assign a virtual MAC address to a VLAN interface, make sure the virtual MAC address is identical to the MAC address assigned to the VLAN interface by using the mac-address command.
# Assign M-LAG virtual IPv4 address 10.10.10.10/24 to VLAN-interface 2 and set the state of the address to active.
[Sysname-Vlan-interface2] port m-lag virtual-ip 10.10.10.10 24 active virtual-mac 1-1-1
ospf peer sub-address enable (Layer 3—IP Routing Command Reference)
peer source-address (Layer 3—IP Routing Command Reference)
reset m-lag drcp statistics
Use reset m-lag drcp statistics to clear DRCPDU statistics.
reset m-lag drcp statistics [ interface interface-list ]
interface interface-list: Specifies a space-separated list of interface items. Each item specifies an aggregate interface or a range of aggregate interfaces in the form of interface-type interface-number1 [ to interface-type interface-number2 ]. The value for interface-number2 must be greater than or equal to the value for interface-number1. The aggregate interfaces must be M-LAG interfaces or the peer-link interface. If you do not specify this option, the command clears the DRCPDU statistics about all M-LAG interfaces and the peer-link interface.
# Clear DRCPDU statistics.
<Sysname> reset m-lag drcp statistics
display m-lag drcp statistics
Use reset m-lag troubleshooting history to clear M-LAG troubleshooting records.
# Clear M-LAG troubleshooting records.
<Sysname> reset m-lag troubleshooting history
