05-QCN commands | 77.68 KB |
QCN commands
display qcn cp interface
Use display qcn cp interface to display congestion point (CP) statistics.
display qcn cp interface [ interface-type interface-number ] [ priority priority ]
interface-type interface-number: Specifies a Layer 2 Ethernet interface by its type and number. If you do not specify an interface, this command displays CP statistics for all Layer 2 Ethernet interfaces.
priority priority: Specifies a congestion notification domain (CND) by a congestion notification priority value (CNPV) in the range of 0 to 7. If you do not specify a CND, this command displays CP statistics for all CNDs.
CP statistics for a Layer 2 Ethernet interface include the following information:
· Profiles bound to CNDs specified by CNPVs.
· Number of packets allowed to pass through.
· Number of packets discarded.
· Number of congestion notification messages (CNMs) sent.
# Display CP statistics for all Layer 2 Ethernet interfaces.
<Sysname> display qcn cp interface
Interface: XGE1/0/1
CNPV 1: CP profile 1
Passed : 100000 (Packets)
Discarded: 10 (Packets)
CNM count: 3000 (Packets)
CNPV 2: CP profile default
Passed : 200000 (Packets)
Discarded: 20 (Packets)
Interface: XGE1/0/2
CNPV |
Congestion detection profile bound to the CND specified by the CNPV. |
Passed |
Number of packets allowed to pass through. |
Discarded |
Number of packets discarded. |
CNM count |
Number of CNMs sent. |
reset qcn cp interface
display qcn global
Use display qcn global to display the global CND settings.
display qcn global [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the global CND settings for the master device.
# Display the global CND settings.
<Sysname> display qcn global
Slot 1:
QCN global status: Enabled
CNPV Mode Defense-mode Alternate CP-profile
1 admin interior-ready 4 default
2 auto - 0 1
3 auto - 0 1
Mode |
Indicates the way how the interface selects the defense mode: · auto—The interface negotiates the defense mode by using LLDP. · admin—The interface uses a user-configured defense mode. |
Defense-mode |
Defense mode of the interface: · disabled—Disables congestion notification and performs priority mapping according to the priority mapping table. · edge—Maps the priority of incoming frames with a specific CNPV to an alternate value and removes congestion notification (CN) tags before sending out the frames. · interior—Does not alter the priority of incoming frames with a specific CNPV and removes CN tags before sending out the frames. · interior-ready—Does not alter the priority of incoming frames with a specific CNPV and retains CN tags when sending out the frames. When auto is configured, this field display a hyphen (-). Each interface on the device negotiates the defense mode by using LLDP. |
Alternate |
Alternate value. |
CP-profile |
Congestion detection profile. |
display qcn interface
Use display qcn interface to display the CND settings of interfaces.
display qcn interface [ interface-type interface-number ]
interface-type interface-number: Specifies a Layer 2 Ethernet interface by its type and number. If you do not specify an interface, this command displays the CND settings of all Layer 2 Ethernet interfaces.
# Display the CND settings of all Layer 2 Ethernet interfaces.
<Sysname> display qcn interface
Interface: XGE1/0/1
1 comp interior-ready 4
2 admin edge 0
3 auto edge 0
Interface: XGE1/0/2
2 admin edge 0
3 auto edge 0
Mode |
Indicates the way how the interface selects the defense mode: · auto—The interface negotiates the defense mode by using LLDP. · admin—The interface uses a user-configured defense mode. · comp—The interface uses the global defense mode. |
Alternate |
Alternate value. |
display qcn profile
Use display qcn profile to display the settings of congestion detection profiles.
display qcn profile [ profile-id | default ] [ slot slot-number ]
profile-id: Specifies a congestion detection profile by its ID. The value range for this argument is 1 to 128.
default: Specifies the default congestion detection profile (profile 0).
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the settings of congestion detection profiles for the master device.
If you do not specify profile-id or default, this command displays the settings of all congestion detection profiles.
# Display the settings of congestion detection profiles.
<Sysname> display qcn profile
Slot 1:
Profile Set-point Weight
default 26000 1
1 30000 2
Set-point |
Desired queue length in bytes. |
qcn enable
Use qcn enable to enable Quantized Congestion Notification (QCN).
Use undo qcn enable to disable QCN.
qcn enable
undo qcn enable
QCN is disabled.
To make QCN settings take effect, you must enable QCN.
# Enable QCN.
[Sysname] qcn enable
qcn port priority
Use qcn port priority to configure CND settings for an interface.
Use undo qcn port priority to delete the CND settings of an interface.
qcn port priority priority { admin [ defense-mode { disabled | edge | interior | interior-ready } alternate alternate-value ] | auto }
undo qcn port priority priority
The global CND settings apply.
priority: Assigns the interface to a CND specified by a priority value (CNPV) in the range of 0 to 7.
admin: Configures the interface to use a user-configured defense mode.
defense-mode: Configures a defense mode. By default, the disabled defense mode is used.
disabled: Specifies the disabled defense mode. This mode disables congestion notification and performs priority mapping according to the priority mapping table.
edge: Specifies the edge defense mode. This mode maps the priority of frames with the specified CNPV to an alternate value.
interior: Specifies the interior defense mode. This mode does not alter the priority of incoming frames with a specific CNPV and removes CN tags before sending out the frames.
interior-ready: Specifies the interior-ready defense mode. This mode does not alter the priority of incoming frames with a specific CNPV and retains CN tags when sending out the frames.
alternate alternate-value: Specifies an alternate value in the range of 0 to 7. The default value for the alternate-value argument is 0. The alternate value cannot be equal to a CNPV.
auto: Configures the interface to negotiate the defense mode by using LLDP.
If a device is not assigned to a CND, you cannot configure this command on its interfaces.
The CND settings for an interface take precedence over the global CND settings.
# Configure defense mode disabled and alternate value 0 for Ten-GigabitEthernet 1/0/1 in the CND with CNPV 1.
[Sysname] qcn priority 1 auto
[Sysname-Ten-GigabitEthernet1/0/1] qcn port priority 1 admin defense-mode disabled alternate 0
# Configure Ten-GigabitEthernet 1/0/2 to negotiate the defense mode by using LLDP.
[Sysname] qcn priority 2 admin
[Sysname-Ten-GigabitEthernet1/0/2] qcn port priority 2 auto
qcn priority
qcn priority
Use qcn priority to configure global CND settings.
Use undo qcn priority to remove a device from a CND and delete all settings in that CND.
qcn priority priority { admin [ defense-mode { disabled | edge | interior | interior-ready } alternate alternate-value ] | auto }
undo qcn priority priority
A device does not belong to any CND.
priority: Specifies a priority value as the CNPV, in the range of 0 to 7. The CNPV cannot be equal to the alternate value configured globally or for interfaces.
admin: Configures the device to use a user-configured defense mode.
defense-mode: Configures a defense mode. By default, the interior defense mode is used.
edge: Specifies the edge defense mode. This mode maps the specified CNPV of frames to an alternate value.
auto: Configures the device to negotiate the defense mode by using LLDP.
When you configure the auto keyword, the alternate value is the priority value that is closest to but smaller than the CNPV. For example, if you set the CNPV to 5, the alternative value is 4. If all priority values smaller than the CNPV are used as CNPVs, the alternate value is the priority value that is closest to but greater than the CNPV.
# Assign a device to the CND with CNPV 2.
[Sysname] qcn priority 2 auto
# Assign a device to the CND with CNPV 1.
[Sysname] qcn priority 1 admin defense-mode disabled alternate 0
qcn port priority
qcn priority profile
Use qcn priority profile to bind a congestion detection profile to a CND.
Use undo qcn priority profile to unbind a congestion detection profile from a CND.
qcn priority priority profile profile-id
undo qcn priority priority profile
The default congestion detection profile (profile 0) is bound to a CND.
priority: Specifies a priority value (CNPV) in the range of 0 to 7.
If the device has not been assigned to the CND or the specified congestion detection profile does not exist, the binding fails.
# Bind congestion detection profile 2 to the CND with CNPV 2.
[Sysname] qcn priority 2 profile 2
qcn profile
Use qcn profile to create a congestion detection profile.
Use undo qcn profile to delete a congestion detection profile.
qcn profile profile-id set-point length-value weight weight-value
undo qcn profile profile-id
The default congestion detection profile (profile 0) is automatically created after QCN is enabled. The desired queue length is 26000 bytes and the weight value is 1.
profile-id: Specifies the ID of the congestion detection profile to be created. The value range for this argument is 1 to 128. The system automatically creates the default congestion detection profile (profile 0), which cannot be modified.
set-point length-value: Specifies the desired queue length in bytes. The value range for length-value is 16644 to 8320000.
weight weight-value: Specifies a weigh value. The value range for weight-value is 2 to 5.
# Create congestion detection profile 1, with a desired queue length of 28000 bytes and a weight value of 1.
[Sysname] qcn profile 1 set-point 28000 weight 1
Use reset qcn cp interface to clear CP statistics.
reset qcn cp interface [ interface-type interface-number ] [ priority priority ]
interface-type interface-number: Specifies a Layer 2 Ethernet interface by its type and number. If you do not specify an interface, this command clears CP statistics for all Layer 2 Ethernet interfaces.
priority priority: Specifies a CND by a priority value (CNPV). If you do not specify a CND, this command clears CP statistics for all CNDs.
# Clear CP statistics for Layer 2 Ethernet interfaces in all CNDs.
<Sysname> reset qcn cp interface
