01-OpenFlow commands | 242.30 KB |
controller echo-request interval
forbidden packet-in arp controller
openflow ttp-controller global-ssl
reset openflow instance statistics
snmp-agent trap enable openflow
OpenFlow commands
active instance
Use active instance to activate an OpenFlow instance.
Use undo active instance to deactivate an OpenFlow instance.
active instance
An OpenFlow instance is not activated.
OpenFlow instance view
After an OpenFlow instance is created or modified, use this command to activate or reactivate the instance to make the instance take effect. After an OpenFlow instance is reactivated, it disconnects from all controllers, clears the deployed flow tables, updates the capability set, and then reconnects to controllers.
# Activate OpenFlow instance 1.
[Sysname] openflow instance 1
[Sysname-of-inst-1] active instance
classification
Use classification to configure the OpenFlow instance mode.
Use undo classification to restore the default.
classification { global | vlan vlan-id [ mask vlan-mask ] [ loosen ] }
undo classification
The OpenFlow instance mode is not configured.
global: Specifies the global mode.
vlan: Specifies the VLAN mode.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
vlan-mask: Specifies a VLAN mask in the range of 0 to 4095. The default value is 4095.
loosen: Specifies the loosen mode. If the loosen mode is used, a port belongs to the OpenFlow instance when VLANs associated with the OpenFlow instance overlap with the port's allowed VLANs. If you do not specify the loosen mode, a port belongs to an OpenFlow instance only when VLANs associated with the OpenFlow instance are within the port's allowed VLAN list.
The VLANs to be associated are calculated by a bitwise AND operation on the specified VLAN ID and mask. The VLAN mask supports non-contiguous 1s and ignores all 0 bits. To view the associated VLANs, use the display openflow instance command.
# Enable the VLAN mode for OpenFlow instance 1 and associate OpenFlow instance 1 with VLANs determined by VLAN ID 255 and VLAN mask 7.
[Sysname-of-inst-1] classification vlan 255 mask 7
controller address
Use controller address to specify a controller for an OpenFlow switch and configure the main connection to the controller.
Use undo controller address to delete the main connection to the specified controller.
controller controller-id address { ip ipv4-address | ipv6 ipv6-address } [ port port-number ] [ local address { ip local-ipv4-address | ipv6 local-ipv6-address } [ port local-port-number ] ] [ global-ssl | ssl ssl-policy-name [ access-control-policy acp-policy-name ] ] [ vrf vrf-name ]
undo controller controller-id address
An OpenFlow instance does not have a main connection to a controller.
controller-id: Specifies a controller by its ID in the range of 0 to 63.
ip ipv4-address: Specifies the IPv4 address of the controller.
ipv6 ipv6-address: Specifies the IPv6 address of the controller.
port port-number: Sets the port number used by the controller to establish TCP connections to the OpenFlow switch. The value range for the port number is 1 to 65535. The default value is 6633.
local address: Specifies the source IP address used to establish TCP connections to the controller. When multiple routes are available between a controller and a switch, you can use this keyword to configure a source IP address for the switch. When the switch restarts or an active/standby switchover occurs, the switch can use the original route to reconnect to the controller without selecting a new route.
ip local-ipv4-address: Specifies the source IPv4 address.
ipv6 local-ipv6-address: Specifies the source IPv6 address.
port local-port-number: Specifies the source port number in the range of 1 to 65535. If you do not specify this option, the system automatically assigns a source port number for establishing the main connection to the controller.
global-ssl: Configures the controller to use the global SSL client policy to authenticate the OpenFlow switch during connection establishment.
ssl ssl-policy-name: Specifies the SSL client policy used to establish a secure connection to the controller. To create an SSL client policy, use the ssl client-policy command. You can configure a separate SSL client policy for the main connection to each controller. The ssl-policy-name argument is a case-insensitive string of 1 to 31 characters. If you do not specify this option, the switch does not establish an SSL connection to the controller.
access-control-policy acp-policy-name: Specifies the certificate-based access control policy used to establish a secure connection and check the controller (SSL server) certificates. To create a certificate-based access control policy, use the pki certificate access-control-policy command. The acp-policy-name argument is a case-insensitive string of 1 to 31 characters. For more information about certificate-based access control policies, see PKI configuration in Security Configuration Guide.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VRF name, the controller is in the public network.
You can specify multiple controllers for an OpenFlow switch. The OpenFlow channel between the OpenFlow switch and each controller can have only one main connection.
The OpenFlow switch uses the main connection to a controller to exchange control messages with the controller to perform the following operations:
· Receive flow table entries or data from the controller.
· Report information to the controller.
As a best practice, configure a unicast IP address for a controller. An OpenFlow switch might fail to establish a connection with the controller that does not use a unicast IP address.
The main connection must be a reliable TCP or SSL connection. The OpenFlow switch uses the main connection to a controller to exchange control messages with the controller to perform the following operations:
For an OpenFlow instance in TTP mode, you can configure the controller to use an SSL client policy used to authenticate the instance during main connection establishment.
· To use a specific SSL client policy for main connection establishment, specify the ssl ssl-policy-name option.
· To use the global SSL client policy for main connection establishment, specify the global-ssl keyword.
# Specify controller 1 for OpenFlow instance 1. The controller's IP address is 1.1.1.1 and the port number is 6666.
[Sysname-of-inst-1] controller 1 address ip 1.1.1.1 port 6666
# Specify controller 1 at IP address 1.1.1.1 for OpenFlow instance 1. Specify the controller to use SSL policy p1 and certificate-based access control policy myacp to authenticate OpenFlow instance 1.
[Sysname] pki certificate attribute-group mygroup
[Sysname-pki-cert-attribute-group-mygroup] attribute 1 subject-name dn ctn abc
[Sysname-pki-cert-attribute-group-mygroup] quit
[Sysname] pki certificate access-control-policy myacp
[Sysname-pki-cert-acp-myacp] rule 1 deny mygroup
[Sysname-pki-cert-acp-myacp] quit
[Sysname-of-inst-1] controller 1 address ip 1.1.1.1 ssl p1 access-control-policy myacp
The PKI-related commands configure the following settings:
· Create certificate attribute group mygroup. In the certificate attribute group, configure rule 1 to match certificates that contain the abc string in the subject DN.
· Create certificate-based access control policy myacp. In the certificate-based access control policy, create rule 1 to deny all certificates that match certificate attribute group mygroup.
pki certificate access-control-policy (Security Command Reference)
ssl client-policy (Security Command Reference)
controller auxiliary
Use controller auxiliary to specify a controller for an OpenFlow switch and configure an auxiliary connection to the controller.
Use undo controller auxiliary to delete the specified auxiliary connection to the specified controller.
controller controller-id auxiliary auxiliary-id transport { tcp | udp | ssl ssl-policy-name } [ address { ip ipv4-address | ipv6 ipv6-address } ] [ port port-number ]
undo controller id auxiliary auxiliary-id
An OpenFlow instance does not have auxiliary connections to a controller.
auxiliary auxiliary-id: Specifies an auxiliary connection ID in the range of 1 to 255.
transport: Specifies the transport layer protocol.
tcp: Specifies TCP connections.
udp: Specifies UDP connections.
ssl ssl-policy-name: Specifies the SSL client policy that the controller uses to authenticate the OpenFlow switch. The ssl-policy-name argument is a case-insensitive string of 1 to 31 characters.
port port-number: Sets the port number used to establish TCP connections to the controller. The value range for the port number is 1 to 65535. The default value is 6633.
Auxiliary connections are used to improve the communication performance between the controller and OpenFlow switches.
For an auxiliary connection to be successfully established, make sure the configuration of the auxiliary connection does not conflict with the configuration of the main connection.
An auxiliary connection can have a different destination IP address and port number than the main connection. If no destination IP address and port number are specified, the auxiliary connection uses the destination IP address and port number configured for the main connection.
# Specify controller 1 for OpenFlow instance 1 and configure auxiliary connection 1 to the controller.
[Sysname-of-inst-1] controller 10 auxiliary 1 transport tcp
controller connect interval
Use controller connect interval to set the reconnection interval.
Use undo controller connect interval to restore the default.
controller connect interval interval
The reconnection interval is 60 seconds.
interval: Specifies the reconnection interval in the range of 10 to 120 seconds.
# Set the reconnection interval to 10 seconds for OpenFlow instance 1.
[Sysname-of-inst-1] controller connect interval 10
Use controller echo-request interval to set the connection detection interval for an OpenFlow switch.
Use undo controller echo-request interval to restore the default.
controller echo-request interval interval
The connection detection interval is 5 seconds for an OpenFlow switch.
interval: Specifies the connection detection interval in the range of 1 to 10 seconds.
# Set the connection detection interval to 10 seconds for OpenFlow instance 1.
[Sysname-of-inst-1] controller echo-request interval 10
controller mode
Use controller mode to set the controller connection mode for an OpenFlow instance.
Use undo controller mode to restore the default.
The controller connection mode is multiple.
multiple: Specifies the multiple mode. In multiple mode, the OpenFlow switch simultaneously connects to all controllers. If one or more controllers become invalid or disconnected, the OpenFlow switch continues to exchange messages with the rest of the controllers.
single: Specifies the single mode. In single mode, the OpenFlow switch connects to only one controller at a time. When communication with the current controller fails, the OpenFlow instance connects to the controller with the lowest ID among the rest controllers.
# Set all controllers of OpenFlow instance 1 to operate in single mode.
[Sysname-of-inst-1] controller mode single
datapath-id
Use datapath-id to set the datapath ID for an OpenFlow instance.
Use undo datapath-id to restore the default.
datapath-id id
undo datapath-id
The datapath ID of an OpenFlow instance contains the instance ID and the bridge MAC address of the device. The lower 16 bits are the instance ID and the upper 48 bits are the bridge MAC address of the device.
id: Specifies the datapath ID for the OpenFlow instance, in the range of 1 to ffffffffffffffff in hexadecimal format.
The datapath ID uniquely identifies an OpenFlow instance.
# Set the datapath ID to 123456 for OpenFlow instance 1.
[Sysname-of-inst-1] datapath-id 123456
default table-miss permit
Use default table-miss permit to configure the default action of table-miss flow entries to forward packets to the normal pipeline.
Use undo default table-miss permit to restore the default.
The default action of a table-miss flow entry is to drop packets.
# Configure the default action of table-miss flow entries to forward packets to the normal pipeline.
[Sysname-of-inst-1] default table-miss permit
description
Use description to configure a description for an OpenFlow instance.
An OpenFlow instance does not have a description.
# Configure the description as test-desc for OpenFlow instance 1.
[Sysname-of-inst-1] description test-desc
display openflow
Use display openflow to display controller information for an OpenFlow instance.
display openflow instance instance-id { controller [ controller-id ] | listened }
instance-id: Specifies an OpenFlow instance by its ID in the range of 1 to 4094.
controller-id: Specifies a controller by its ID in the range of 0 to 63. If you do not specify a controller ID, this command displays information about all controllers for an OpenFlow instance.
listened: Specifies the controllers acting as SSL clients to which the OpenFlow instance connects as an SSL server.
# Display controller information for OpenFlow instance 100.
<Sysname> display openflow instance 100 controller
Instance 1 controller information:
Reconnect interval : 60 (s)
Echo interval : 5 (s)
Controller ID : 1
Controller IP address : 192.168.49.49
Controller port : 6633
Local IP address : 192.0.0.1
Local port : 5566
Controller role : Equal
Connect type : TCP
Connect state : Established
Packets sent : 9
Packets received : 9
SSL policy : --
VRF name : --
Reconnect interval |
Reconnection interval (in seconds) for an OpenFlow instance to reconnect to all controllers. |
Echo interval |
Connection detection interval (in seconds) at which an OpenFlow instance sends an echo request message to all controllers. |
Controller IP address |
IP address of the controller. |
Controller port |
TCP port number of the controller. |
Local IP address |
Source IP address of the controller that is connected to the OpenFlow instance. |
Local port |
Source TCP port number of the current controller. |
Controller role |
Role of the controller: · Equal—The controller has the same mode as other controllers that are specified for the OpenFlow instance. · Master—The controller is the master controller for the OpenFlow instance. · Slave—The controller is a subordinate controller for the OpenFlow instance. If the controller is not configured with any role, this field displays two hyphens (--). |
Connect type |
Type of the connection between the OpenFlow instance and the controller: TCP or SSL. |
Connect state |
State of the connection between the OpenFlow instance and the controller: Idle or Established. |
Packets sent |
Number of packets that have been sent to the controller. |
Packets received |
Number of packets that have been received from the controller. |
SSL policy |
Name of the SSL client policy used for SSL connections. If no SSL client policy is configured, this field displays two hyphens (--). |
VRF name |
Name of the MPLS L3VPN to which the controller belongs. If no MPLS L3VPN instance is configured, this field displays two hyphens (--). |
display openflow auxiliary
Use display openflow auxiliary to display auxiliary connection information for an OpenFlow instance.
display openflow instance instance-id auxiliary [ controller-id [ auxiliary auxiliary-id ] ]
auxiliary auxiliary-id: Specifies an auxiliary connection by its ID in the range of 1 to 255.
# Display auxiliary connection information for OpenFlow instance 100.
<Sysname> display openflow instance 100 auxiliary
Controller ID: 1 Auxiliary connection number: 2
Auxiliary connection ID : 1
Controller IP address : 192.168.49.48
Connect type : TCP
Packets sent : 9
SSL policy : --
Auxiliary connection ID : 2
Connect type : TCP
Packets sent : 9
SSL policy : --
Auxiliary connection number |
Total number of auxiliary connections. |
Auxiliary connection ID |
ID of an auxiliary connection. |
Controller port |
Connect type |
Type of the connection between the OpenFlow instance and the controller: TCP UDP, or SSL. |
Connect state |
Packets sent |
Packets received |
SSL policy |
display openflow flow-table
Use display openflow flow-table to display flow table information for an OpenFlow instance.
display openflow instance instance-id flow-table [ table-id ]
table-id: Specifies a flow table by its ID in the range of 0 to 254. If you do not specify a flow table ID, the command displays information about all flow tables for the specified OpenFlow instance.
# Display information about all flow tables for OpenFlow instance 100.
<Sysname> display openflow instance 100 flow-table
Instance 100 flow table information:
Table 0 information:
Table type: MAC-IP, flow entry count: 1, total flow entry count: 2
MissRule (default) flow entry information:
cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: reset_counts
|no_pkt_counts|no_byte_counts, byte count: --, packet count: --
Create time: 09:39:42 10/24/2017, Last modified time: 09:39:42 10/24/2017
Match information: any
Instruction information:
Write actions:
Drop
Flow entry 1 information:
cookie: 0x0, priority: 1, hard time: 0, idle time: 0, flags: none,
Match information:
Ethernet destination MAC address: 0000-0000-0001
Ethernet destination MAC address mask: ffff-ffff-ffff
VLAN ID: 100, mask: 0xfff
Write actions:
Output interface: XGE1/0/4
Write metadata/mask: 0x0000000000000001/0xffffffffffffffff
Goto table: 1
Table 1 information:
Table type: Extensibility, flow entry count: 2, total flow entry count: 2
cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: none,
byte count: 300, packet count: 60
Write actions:
Drop
Flow entry 1 information: (Not effective)
cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: flow_send_rem
|check_overlap, byte count: 8, packet count: 1
Match information:
Input interface: XGE1/0/3
Ethernet source MAC address: 0000-0000-0001
Ethernet source MAC address mask: ffff-ffff-ffff
Set meter: 100
Apply actions:
Write actions:
Output interface: Controller, send length: 128 bytes
Table information |
Information about the flow table. |
Table type |
Type of the flow table. |
flow entry count |
Number of flow entries deployed by the controller. |
total flow entry count |
Total number of flow entries in the table. |
Flow entry information |
Information about the flow entry. If the flow entry does not take effect, this field displays Not effective. MissRule (default) indicates that the flow entry is a table-miss flow entry. |
cookie |
Cookie ID of the flow entry. |
priority |
Priority of the flow entry. The larger the value, the higher the priority. |
hard time |
Hard timeout of the flow entry, in seconds. The flow entry is removed when the timer times out, whether or not the flow entry matches any data stream. If the flow entry has no hard timeout, the field displays 0. |
idle time |
Idle timeout of the flow entry, in seconds. The flow entry is removed if the flow entry does not match any data stream during the idle time. If the flow entry has no idle timeout, the field displays 0. |
flags |
Flags that the flow entry includes: · flow_send_rem—Sends a flow removed message when the flow entry is removed or expires. · check_overlap—Checks for overlapping flow entries. · reset_counts—Resets flow table counters. · no_pkt_counts—Does not count packets. · no_byte_counts—Does not count bytes. If the flow entry does not include any flags, this field displays none. |
byte count |
Number of bytes that have matched the flow entry. |
packet count |
Number of packets that have matched the flow entry. |
Create time |
Time when the flow entry was created. |
Last modified time |
Time when the flow entry was modified for the last time. |
Match information |
Contents of the match field of the flow entry (see Table 4). |
Instruction information |
Contents of the instruction set of the flow entry: · Set meter—Sends the matched packet to a specific meter. · Goto table—Sends the matched packet to the next flow table for processing. · Clear actions—Immediately clears all actions in the action set. · Apply actions—Immediately applies specified actions in the action set. · Write actions—Writes specified actions into the current action set. For more information about actions, see Table 5. |
Mask field |
Input interface |
N/A |
Ingress port (see Table 6). |
Physical input interface |
N/A |
Ingress physical port. |
Metadata |
Metadata mask |
Metadata and mask. |
Ethernet destination MAC address |
Ethernet destination MAC address mask |
Ethernet destination MAC address and mask. |
Ethernet source MAC address |
Ethernet source MAC address mask |
Ethernet source MAC address and mask. |
Ethernet type |
N/A |
Ethernet type of the OpenFlow packet payload. |
VLAN ID |
Mask |
VLAN ID and mask. |
VLAN PCP |
N/A |
VLAN priority. |
IP DSCP |
N/A |
Differentiated Services Code Point (DSCP) value. |
IP ECN |
N/A |
Explicit Congestion Notification (ECN) value in the IP header. |
IP protocol |
N/A |
IPv4 or IPv6 protocol number. |
IPv4 source address |
Mask |
IPv4 source address and mask. |
IPv4 destination address |
Mask |
IPv4 destination address and mask. |
TCP source port |
Mask |
TCP source port and mask. |
TCP destination port |
Mask |
TCP destination port and mask. |
UDP source port |
Mask |
UDP source port and mask. |
UDP destination port |
Mask |
UDP destination port and mask. |
SCTP source port |
Mask |
Stream Control Transmission Protocol (SCTP) source port and mask. |
SCTP destination port |
Mask |
SCTP destination port and mask. |
ICMPv4 type |
N/A |
ICMPv4 type. |
ICMPv4 code |
N/A |
ICMPv4 code. |
ARP opcode |
N/A |
ARP opcode. |
ARP source IPv4 address |
Mask |
Sender IPv4 address and mask in the ARP payload. |
ARP target IPv4 address |
Mask |
Target IPv4 address and mask in the ARP payload. |
ARP source MAC address |
ARP source MAC address mask |
Sender MAC address and mask in the ARP payload. |
ARP target MAC address |
ARP target MAC address mask |
Target MAC address and mask in the ARP payload. |
IPv6 source address |
IPv6 source address mask |
Source IPv6 address and mask. |
IPv6 destination address |
IPv6 destination address mask |
Destination IPv6 address and mask. |
IPv6 flow label |
Mask |
IPv6 flow label and mask. |
ICMPv6 type |
N/A |
ICMPv6 type. |
ICMPv6 code |
N/A |
ICMPv6 code. |
IPv6 ND target address |
N/A |
Target IP address in an IPv6 Neighbor Discovery message. |
IPv6 ND source MAC address |
N/A |
Source link-layer address in an IPv6 Neighbor Discovery message. |
IPv6 ND target MAC address |
N/A |
Target link-layer address in an IPv6 Neighbor Discovery message. |
MPLS label |
N/A |
Label in the first MPLS header. |
MPLS tc |
N/A |
Traffic Class (TC) in the first MPLS header. |
MPLS bos |
N/A |
Bottom of stack flag in the MPLS label. |
Tunnel ID |
Mask |
Metadata and mask that are associated with a logical port. |
IPv6 extension header |
Mask |
IPv6 extension header and mask. |
Output interface |
N/A |
Output port. |
VRF index |
N/A |
VPN index. |
Fragment |
N/A |
Fragment. |
Physical output interface |
N/A |
Output physical port. |
CVLAN ID |
Mask |
CVLAN ID and mask. |
Experimenter |
N/A |
Extension matching fields. Address ID represents the unique identifier of an address. |
Drop |
Drops the matched packet. This action is not defined in the OpenFlow specifications. |
Output interface |
Sends the packet through a specific port. For more information about ports, see Table 6. |
Group |
Specifies a group table to process the packet. |
Set queue |
Maps the flow entry to a queue specified by its ID. |
Set field |
Modifies a field of the packet. |
Port name |
Ingress port |
Output port |
In port |
Not supported. |
Supported. |
Forwarding the packet out of the ingress port. |
Normal |
Not supported. |
Supported. |
Processing the packet by using the normal forwarding process. |
Flood |
Not supported. |
Supported. |
Flooding the packet. |
All |
Not supported. |
Supported. |
Forwarding the packet out of all ports. |
Controller |
Supported. |
Supported. |
Sending the packet to the controller. |
Local |
Supported. |
Supported. |
Sending the packet to the local CPU. |
port name |
Supported. |
Supported. |
Valid physical or logical port on the switch. |
display openflow group
Use display openflow group to display group information for an OpenFlow instance.
display openflow instance instance-id group [ group-id ]
group-id: Specifies a group by its ID in the range of 0 to 4294967040. If you do not specify a group ID, this command displays information about all group entries for an OpenFlow instance.
# Display group information for OpenFlow instance 100.
<Sysname> display openflow instance 100 group
Instance 100 group table information:
Group count: 2
Group entry 103:
Type: All, byte count: 55116, packet count: 401
Bucket 1 information:
Action count 1, watch port: any, watch group: any
Byte count 55116, packet count 401
Output interface: BAGG100
Bucket 2 information:
Byte count 0, packet count 0
Referenced information:
Count: 3
Flow table 0
Flow entry: 1, 2, 3
Group entry 104:
Some buckets are invalid.
Type: All, byte count: 0, packet count: 0
Action count 2, watch port: any, watch group: any
Set field:
Ethernet destination MAC address: 0000-0000-0013
Ethernet source MAC address: 0000-0000-0012
IPv4 destination address: 100.0.0.21
UDP destination port: 1001
Count: 0
Group entry 16777233:
Bound program group entry: 17
Count: 0
Group count |
Total number of group entries included in the OpenFlow instance. |
Some buckets are invalid. |
Some buckets of the group entry are invalid because the hardware resources are insufficient or the device fails. |
Type |
Type of the group entry. The value of All indicates that the device executes all buckets in the group. This group is used for multicast or broadcast forwarding. |
Bound program group entry |
ID of the program group entry bound to the target group entry. This field displays two hyphens (--) if no program group entries are bound to the target group entry. This field is displayed only when support of smart group entries is enabled for the OpenFlow instance. |
Bucket |
Buckets included in the group table. |
Action count |
Number of actions included in the bucket. |
Byte count |
Number of bytes processed by a group or by a bucket. If the statistics cannot be collected, this field displays two hyphens (--). |
packet count |
Number of packets processed by a group or by a bucket. If the statistics cannot be collected, this field displays two hyphens (--). |
watch port |
Port whose state affects whether this bucket is live. |
watch group |
Group whose state affects whether this bucket is live. |
Set field |
Fields to be modified for packets, for example, the destination/source MAC address, destination IPv4 address, and destination UDP port number. |
Output interface |
OpenFlow port to which packets are forwarded. |
Referenced information |
Information about the group entry used by flow entries. |
Count |
Total number of flow entries that use the group entry. |
Flow table |
Flow table to which the flow entries that use the group entry belong. |
Flow entry |
Flow entries that use the group entry. |
Use display openflow instance to display detailed information about an OpenFlow instance.
display openflow instance [ instance-id ]
instance-id: Specifies an OpenFlow instance by its ID in the range of 1 to 4094. If you do not specify an instance ID, this command displays detailed information about all OpenFlow instances.
# Display detailed information about all OpenFlow instances.
Instance 100 information:
Configuration information:
Description : test-desc
Active status : Active
Inactive configuration:
None
Active configuration:
Classification: VLAN, loosen mode, total VLANs(1)
2
In-band management VLAN, total VLANs(0)
Empty VLAN
Connect mode: Multiple
MAC address learning: Disabled
TCP DSCP value: 10
Flow table:
Table ID(type): 0(MAC-IP), count: 0
Flow-entry max-limit: 65535
Datapath ID: 0x0000001234567891
Default table-miss: Drop
Forbidden port: None
Qinq Network: Disabled
TCP connection backup: Enabled
Data-plane: Disabled
Smart-group: Disabled
Port information:
Ten-GigabitEthernet1/0/3
Active channel information:
Controller 1 IP address: 192.168.49.49 port: 6633
Controller 2 IP address: 192.168.43.49 port: 6633
Configuration information |
Information about the configuration. |
Description of the OpenFlow instance. |
Active status |
OpenFlow instance status: Active or Inactive. |
Inactive configuration |
Inactive configuration for the OpenFlow instance. |
Active configuration |
Active configuration for the OpenFlow instance. |
Classification: VLAN, total VLANs |
VLANs that are associated with the OpenFlow instance and the total number of these VLANs. |
loose mode |
The loose mode is used. |
In-band management VLAN, total VLANs |
Inband management VLANs and the total number of them. |
Connect mode |
Connection mode of the controller: · Single—The OpenFlow instance connects to only one controller at a time. · Multiple—The OpenFlow instance can simultaneously connect to multiple controllers. |
MAC address learning |
Whether MAC address learning is disabled: Enabled or Disabled. |
TCP DSCP value |
DSCP value for OpenFlow packets. |
Flow table |
Flow table information for the OpenFlow instance. |
Table ID(type) |
count |
Total number of flow entries included in the current flow table. |
Flow-entry max-limit |
Maximum number of flow entries allowed in the extensibility flow table. |
Datapath ID |
Datapath ID of the OpenFlow instance. |
Default table-miss |
Default action of the table-miss flow entry: Permit or Drop. |
Forbidden port |
Type of interfaces that are forbidden to be reported to the controller: · L3 Physical Interface—Layer 3 Ethernet interfaces and Layer 3 aggregate interfaces. · VLAN interface. · Virtual Switch Interface. |
Qinq Network |
Whether the OpenFlow instance is enabled to perform QinQ tagging for double-tagged packets passing an extensibility flow table: · Disabled. · Enabled. |
TCP connection backup |
Whether OpenFlow connection backup is enabled: · Disabled. · Enabled. |
Data-plane |
This field is not supported in the current software version. Whether the OpenFlow data plane forwarding feature is enabled: · Disabled. · Enabled. |
Smart-group |
This field is not supported in the current software version. Whether the OpenFlow is enabled to support smart group entries: · Disabled. · Enabled. |
Port information |
Ports that have been added to the OpenFlow instance. |
Active channel information |
Information about active channels. |
IP address |
IP address of the controller configured for the OpenFlow instance. |
Port |
TCP port number that is used to connect to the controller. |
Failopen mode |
Connection interruption mode for the OpenFlow instance: · Standalone. · Smart. · Secure. |
display openflow meter
Use display openflow meter to display meter information for an OpenFlow instance.
display openflow instance instance-id meter [ meter-id ]
meter-id: Specifies a meter by its ID in the range of 1 to 4294901760. If you do not specify a meter ID, this command displays information about all meter entries for an OpenFlow instance.
# Display meter information for OpenFlow instance 100.
<Sysname> display openflow instance 100 meter
Meter flags: KBPS -- Rate value in kb/s, PKTPS -- Rate value in packet/sec
BURST -- Do burst size, STATS -- Collect statistics
Instance 100 meter table information:
meter entry count: 2
Meter entry 100 information:
Meter flags: KBPS
Band 1 information
Type: drop, rate: 1024, burst size: 65536
Byte count: 0, packet count: 0
Count: 3
Flow table: 0
Flow entry: 1, 2, 3
Meter entry 200 information:
Meter flags: KBPS
Band 1 information
Type: drop, rate: 10240, burst size: 655360
Count: 0
Table 9 Command output
Group entry count |
Total number of meter entries that the OpenFlow instance has. |
Meter flags |
Flags configured for the meter: · KBPS—The rate value is in kbps. · PKTPS—The rate value is in pps. · BURST—The burst size field in the band is used and the length of the packet or byte burst is determined by the burst size. · STATS—Meter statistics are collected. |
Band |
Bands contained in the meter. |
Type |
Type of the band: · drop—Discard the packet. · dscp_remark—Modify the drop precedence of the DSCP field in the IP header of the packet. |
Rate |
Rate value above which the corresponding band applies to packets. |
Burst size |
Length of the packet or byte burst to consider for applying the meter. |
Byte count |
Number of bytes processed by a band. If the statistics cannot be collected, this field displays two hyphens (--). |
packet count |
Number of packets processed by a band. If the statistics cannot be collected, this field displays two hyphens (--). |
Information about the meter entry used by flow entries. |
Count |
Total number of flow entries that use the meter entry. |
Flow table |
Flow table to which the flow entries that use the meter entry belong. |
Flow entry |
Flow entries that use the meter entry. |
display openflow summary
Use display openflow summary to display brief OpenFlow instance information.
display openflow instance summary
# Display brief OpenFlow instance information.
<Sysname> display openflow summary
Fail-open mode: Se - Secure mode, Sa - Standalone mode, Sm - Smart mode
ID Status Datapath-ID Channel Table-num Port-num Reactivate
1 Active 0x0000000100001221 Connected 2 8 N
10 Inactive - - - - -
4094 Active 0x00000ffe00001221 Failed(Sa) 2 0 N
Table 10 Command output
ID |
OpenFlow instance ID. |
Status |
Activation status of the OpenFlow instance: · Active—The OpenFlow instance has been activated. · Inactive—The OpenFlow instance has not been activated. |
Datapath-ID |
Datapath ID of the OpenFlow instance. If the OpenFlow instance is not activated, this field displays a hyphen (-). |
Channel |
Status of the OpenFlow channel to the controller: · Connected—An OpenFlow channel has been established. · Failed(Se)—The OpenFlow channel is disconnected from the controller, and the OpenFlow instance uses the secure connection interruption mode. · Failed(Sm)—The OpenFlow channel is disconnected from the controller, and the OpenFlow instance uses the smart connection interruption mode. · Failed(Sa)—The OpenFlow channel is disconnected from the controller, and the OpenFlow instance uses the standalone connection interruption mode. If the OpenFlow instance is not activated, this field displays a hyphen (-). |
Table num |
Number of flow tables that the OpenFlow instance has. If the OpenFlow instance is not activated, this field displays a hyphen (-). |
Port num |
Number of ports that belong to the OpenFlow instance. If the OpenFlow instance is not activated, this field displays a hyphen (-). |
Reactivate |
Whether the OpenFlow instance is required to be reactivated. N indicates the configuration is unchanged and the OpenFlow instance is not required to be reactivated. If the OpenFlow instance is not activated, this field displays a hyphen (-). |
fail-open mode
Use fail-open mode to set the connection interruption mode for an OpenFlow switch.
Use undo fail-open mode to restore the default.
fail-open mode { secure | smart | standalone }
undo fail-open mode
The connection interruption mode is secure.
secure: Configures the OpenFlow switch to use flow tables for traffic forwarding after it is disconnected from all controllers. The OpenFlow switch does not remove unexpired flow entries.
smart: Configures the OpenFlow switch to use flow tables for traffic forwarding after it is disconnected from all controllers. If the output action in a matching flow entry is to forward traffic to a controller, the traffic is forwarded in normal process.
standalone: Configures the OpenFlow switch to use the normal forwarding process after it is disconnected from all controllers.
# Set the connection interruption mode to standalone for OpenFlow instance 1.
[Sysname-of-inst-1] fail-open mode standalone
flow-entry max-limit
Use flow-entry max-limit to set the maximum number of entries for an extensibility flow table on an OpenFlow switch.
Use undo flow-entry max-limit to restore the default.
flow-entry max-limit limit-value
An extensibility flow table can have a maximum of 65535 flow entries.
limit-value: Specifies the maximum number of flow entries for an extensibility flow table. The value range for this argument is 1 to 65535.
If the number of extensibility flow table entries deployed from a controller to an OpenFlow switch exceeds the maximum, the switch returns a failure message to the controller.
When multiple extensibility flow tables exist, this command sets a limit on every extensibility flow table.
# Configure OpenFlow instance 1 to have a maximum of 256 entries in each extensibility flow table.
[Sysname-of-inst-1] flow-entry max-limit 256
flow-log disable
Use flow-log disable to disable logging for successful flow table modifications.
Use undo flow-log disable to restore the default.
flow-log disable
Logging for successful flow table modifications is enabled.
# Disable logging for successful flow table modifications for OpenFlow instance 1.
[Sysname-of-inst-1] flow-log disable
flow-table
Use flow-table to configure the flow table type and the flow table ID for an OpenFlow instance.
Use undo flow-table to restore the default.
flow-table { ingress-vlan ingress-table-id | mac-ip mac-ip-table-id | mpls mpls-table-id | extensibility extensibility-table-id&<1-n> | egress-vlan egress-table-id }*
undo flow-table
An OpenFlow instance has an extensibility flow table with ID 0.
ingress-vlan ingress-table-id: Specifies a VLAN tagging flow table by its ID in the range of 0 to 254.
mac-ip mac-ip-table-id: Specifies a MAC-IP flow table by its ID in the range of 0 to 254.
mpls mpls-table-id: Specifies an MPLS flow table by its ID in the range of 0 to 254.
extensibility extensibility-table-id: Specifies an extensibility flow table by its ID in the range of 0 to 254.
&<1-n>: Specifies the maximum number of flow tables that can be configured. The value for n is 2.
egress-vlan egress-table-id: Specifies a VLAN untagging flow table by its ID in the range of 0 to 254. If you specify this option, the device untags all outgoing packets matching the table.
The ID you enter for an extensibility flow table must be greater than the ID for an MAC-IP or MPLS flow table.
If you specify the ingress-vlan ingress-table-id option, make sure the VLAN tagging flow table has the smallest ID among all flow tables. If you specify the egress-vlan egress-table-id option, make sure the VLAN untagging flow table has the largest ID among all flow tables. The VLAN tagging flow table and untagging flow table take effect only when the following conditions are met:
· The OpenFlow instance is configured to perform QinQ tagging for double-tagged packets passing an extensibility flow table.
· The OpenFlow instance uses the standalone connection interruption mode.
# Create a MAC-IP flow table with ID 0 and an extensibility flow table with ID 1 for OpenFlow instance 1.
[Sysname-of-inst-1] flow-table mac-ip 0 extensibility 1
qinq-network enable
Use forbidden packet-in arp controller to configure controllers to which ARP packets are forbidden to be reported.
Use undo forbidden packet-in arp controller to restore the default.
forbidden packet-in arp controller controller-id-list
undo forbidden packet-in arp controller [ controller-id-list ]
No controllers to which ARP packets are forbidden to be reported are configured.
controller-id-list: Specifies a space-separated list of a maximum of 10 controller items. Each item specifies a controller ID or a range of controller IDs in the form of controller-id1 to controller-id2. The value range for controller IDs is 0 to 63. The value for the controller-id2 argument must be equal to or greater than the value for the controller-id1 argument. If you do not specify the controller-id-list argument, the undo form of this command restores all configuration of this feature to the default.
# Forbid the device not to report ARP packets to controller 0.
[Sysname-of-inst-1] forbidden packet-in arp controller 0
forbidden port
Use forbidden port to forbid an OpenFlow instance from reporting ports of the specified types to controllers.
Use undo forbidden port to restore the default.
forbidden port { l3-physical-interface | vlan-interface | vsi-interface } *
undo forbidden port
No port types are prevented from being reported to the controllers. All ports that belong to an OpenFlow instance are reported to the controllers.
l3-physical-interface: Specifies Layer 3 Ethernet interfaces and Layer 3 aggregate interfaces that belong to an OpenFlow instance.
vlan-interface: Specifies VLAN interfaces that belong to an OpenFlow instance.
vsi-interface: Specifies virtual switch instance (VSI) interfaces that belong to an OpenFlow instance.
# Forbid OpenFlow instance 1 from reporting VLAN interfaces that belong to the OpenFlow instance to controllers.
[Sysname-of-inst-1] forbidden port vlan-interface
in-band management vlan
Use in-band management vlan to configure inband management VLANs for an OpenFlow instance.
Use undo in-band management vlan to restore the default.
in-band management vlan vlan-id-list
No inband management VLANs are configured for an OpenFlow instance.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094.
Traffic in inband management VLANs is forwarded in the normal forwarding process for an OpenFlow instance to establish secure connections to controllers.
# Configure VLAN 10 as the inband management VLAN for OpenFlow instance 1.
[Sysname-of-inst-1] in-band management vlan 10
listening port
Use listening port to configure an OpenFlow instance to act as an SSL server to listen to controllers.
Use undo listening port to restore the default.
listening port port-number ssl ssl-policy-name
undo listening port
An OpenFlow instance is not configured to acts as an SSL server to listen to controllers.
port-number: Specifies the SSL server port number in the range of 1 to 65535.
ssl ssl-policy-name: Specifies the SSL server policy name, a case-insensitive string of 1 to 31 characters.
Typically, an OpenFlow instance actively connects to the controller and acts as a TCP/SSL client. After the SSL server is enabled for an OpenFlow instance, the controller acts as the SSL client and actively connects to the OpenFlow instance. For more information about SSL, see Security Configuration Guide.
To re-configure the SSL server, first execute the undo form of the command to delete the existing SSL server configuration.
# Configure OpenFlow instance 1 to act as an SSL server with port number 20000 and SSL server policy name ssl_name.
[Sysname-of-inst-1] listening port 20000 ssl ssl_name
loop-protection enable
Use loop-protection enable to enable loop guard for an OpenFlow instance.
Use undo loop-protection enable to restore the default.
Loop guard is disabled for an OpenFlow instance.
After an OpenFlow instance is deactivated, loops might occur in VLANs associated with the OpenFlow instance. To avoid loops, you can enable loop guard for the OpenFlow instance. This feature enables the deactivated OpenFlow instance to create a flow entry for dropping all traffic in theses VLANs.
# Enable loop guard for OpenFlow instance 1.
[Sysname-of-inst-1] loop-protection enable
mac-ip dynamic-mac aware
Use mac-ip dynamic-mac aware to configure an OpenFlow instance to support matching the dynamic MAC addresses in the query and deletion flow entry instructions sent from controllers.
Use undo mac-ip dynamic-mac aware to restore the default.
An OpenFlow instance ignores the dynamic MAC addresses in the query and deletion flow entry instructions sent from controllers.
This command takes effect only on MAC-IP flow tables.
# Configure OpenFlow instance 1 to support matching the dynamic MAC addresses in the query and deletion flow entry instructions sent from controllers.
[Sysname-of-inst-1] mac-ip dynamic-mac aware
mac-learning forbidden
Use mac-learning forbidden to configure OpenFlow to forbid MAC address learning in VLANs associated with an OpenFlow instance.
Use undo mac-learning forbidden to restore the default.
MAC address learning is allowed for VLANs associated with an OpenFlow instance.
# Forbid MAC address learning in VLANs associated with OpenFlow instance 1.
[Sysname-of-inst-1] mac-learning forbidden
openflow instance
Use openflow instance to create an OpenFlow instance and enter its view, or enter the view of an existing OpenFlow instance.
Use undo openflow instance to remove an OpenFlow instance.
undo openflow instance instance-id
No OpenFlow instances exist.
# Create OpenFlow instance 1 and enter OpenFlow instance view.
[Sysname-of-inst-1]
openflow lossless enable
Use openflow lossless enable to enable packet loss prevention for OpenFlow forwarding.
Use undo openflow lossless enable to disable packet loss prevention for OpenFlow forwarding.
Packet loss prevention for OpenFlow forwarding is disabled.
This command is not supported on the S6860 switch series.
Packet loss prevention ensures successful OpenFlow forwarding without packet loss. In an OpenFlow network, packet loss might occur on the switch during the flow entry deployment process. Packet loss then causes OpenFlow forwarding errors. For example, traffic is mistakenly sent to controllers and the controllers deploy faulty flow entries.
When this feature is enabled, the OpenFlow matching ability is decreased. For example, packets cannot be matched by IPv6 address.
To avoid the forwarding efficiency and matching ability decrease, do not enable this feature in non-OpenFlow networks.
After you enable or disable packet loss prevention on a switch, save the configuration and restart the switch to make the configuration take effect.
# Enable packet loss prevention for OpenFlow forwarding.
[Sysname] openflow lossless enable
Enable lossless traffic function? [Y/N]:y
For the setting to take effect, save the configuration, and then reboot the device.
openflow normal-forward vlan
Use openflow normal-forward vlan to exclude the specified VLANs from the VLANs in which traffic is forwarded in the OpenFlow forwarding process.
Use undo openflow normal-forward vlan to restore the default.
openflow normal-forward vlan { vlan-id [ to vlan-id ] } &<1-10>
No VLANs are excluded from the VLANs in which traffic is forwarded in the OpenFlow forwarding process.
The VLANs to be associated with an OpenFlow instance are calculated by a bitwise AND operation on the VLAN ID and mask. Use this command to exclude VLANs in which traffic is required to be forwarded in the normal forwarding process from the calculated VLANs. Traffic in the excluded VLANs is forwarded in the normal forwarding process instead of the OpenFlow forwarding process.
# Exclude VLAN 10 from the VLANs in which traffic is forwarded in the OpenFlow forwarding process.
[Sysname] openflow normal-forward vlan 10
openflow permit-flag ignore
Use openflow permit-flag ignore to ignore the permit flag added by OpenFlow.
Use undo openflow permit-flag ignore to restore the default.
The permit flag added by OpenFlow is not ignored.
Packets matching an OpenFlow flow entry with the output action as Normal are permitted to pass through and marked with a permit flag. Packets with a permit flag are not dropped by a discard action in a QoS policy (for example, a CAR discard action).
This command allows the device to drop packets with a permit flag by using a discard action in a QoS policy.
# Ignore the permit flag added by OpenFlow.
[Sysname] openflow permit-flag ignore
openflow shutdown
Use openflow shutdown to shut down an interface by OpenFlow.
Use undo openflow shutdown to restore the default.
openflow shutdown
An interface is not shut down by OpenFlow.
Interface view
After an interface is shut down by OpenFlow, the Current state field displays OFP DOWN in the display interface command output.
To bring up an interface shut down by OpenFlow, use either of the following methods:
· Use the undo openflow shutdown command on the interface.
· Use the controller to send port modification messages to the interface.
# Shut down Ten-GigabitEthernet 1/0/1 by OpenFlow.
[Sysname-Ten-GigabitEthernet1/0/1] openflow shutdown
Use openflow ttp-controller global-ssl to specify the global SSL client policy for TTP controllers.
Use undo openflow ttp-controller global-ssl to delete the global SSL client policy for TTP controllers.
openflow ttp-controller [ ttp-controller-id ] global-ssl ssl-policy-name
undo openflow ttp-controller [ ttp-controller-id ] global-ssl
No global SSL client policy is specified for TTP controllers.
ttp-controller-id: Specifies a TTP controller by its ID in the range of 0 to 63. If you do not specify a TTP controller, this command specifies the global SSL client policy for all TTP controllers.
ssl-policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters.
A TTP controller refers to an OpenFlow controller that uses the TTP flow table model. For an OpenFlow instance in TTP mode, you can use the controller address command to specify a TTP controller for the instance and specify the global SSL client policy for the instance and controller to establish a main connection.
You can execute this command multiple times to specify different global SSL client policies for different TTP controllers. If you execute this command multiple times for the same TTP controller, the most recent configuration takes effect.
To delete an SSL client policy that has been specified as the global SSL client policy for TTP controllers, first delete the main connection between the controller and OpenFlow instance. To delete the main connection, use the undo controller controller-id address command.
# Specify SSL client policy ssl-1 as the global SSL client policy for TTP controller 1. Then, configure OpenFlow instance 1 in global mode and configure TTL controller at 1.1.1.1 to use the global SSL client policy to establish a main connection with the instance.
[Sysname] openflow ttp-controller 1 global-ssl ssl-1
[Sysname-of-inst-1] classification global
[Sysname-of-inst-1] ttp enable
[Sysname-of-inst-1] controller address 1 address ip 1.1.1.1 global-ssl
controller address
ttp enable
permit-port-type member-port
Use permit-port-type member-port to allow link aggregation member ports to be in the deployed flow tables.
Use undo permit-port-type to restore the default.
Link aggregation member ports cannot be in the deployed flow tables.
# Configure OpenFlow instance 1 to allow link aggregation member ports to be in the deployed flow tables.
[Sysname-of-inst-1] permit-port-type member-port
precedence dynamic arp
Use precedence dynamic arp to allow dynamic ARP entries to overwrite OpenFlow ARP entries.
Use undo precedence dynamic to restore the default.
undo precedence dynamic arp
An OpenFlow instance does not allow dynamic ARP entries to overwrite OpenFlow ARP entries.
This command takes effect only on the MAC-IP flow table of an OpenFlow instance.
# Configure OpenFlow instance 1 to allow dynamic ARP entries to overwrite OpenFlow ARP entries.
[Sysname-of-inst-1] precedence dynamic arp
protocol-packet filter slow
Use protocol-packet filter slow to configure an OpenFlow instance to drop slow protocol packets.
Use undo protocol-packet filter to restore the default.
An OpenFlow instance is not configured to drop slow protocol packets.
The slow protocols include LACP and OAM.
# Configure OpenFlow instance 1 to drop slow protocol packets.
[Sysname-of-inst-1] protocol-packet filter slow
qinq-network enable
Use qinq-network enable to enable an OpenFlow instance to perform QinQ tagging for double-tagged packets passing an extensibility flow table. Then, double-tagged packets keep double-tagged after passing an extensibility flow table.
Use undo qinq-network enable to restore the default.
qinq-network enable
A double-tagged packet becomes single-tagged after it passes an extensibility flow table.
# Enable OpenFlow instance 1 to perform QinQ tagging for double-tagged packets passing an extensibility flow table.
[Sysname-of-inst-1] qinq-network enable
flow-table
refresh ip-flow
Use refresh ip-flow to refresh all Layer 3 flow entries in the MAC-IP flow tables for an OpenFlow instance.
refresh ip-flow
Layer 3 flow entries in the MAC-IP flow tables might be overwritten. In such cases, you can use this command to obtain all Layer 3 flow entries in the MAC-IP flow tables from the controller again.
# Refresh all Layer 3 flow entries in the MAC-IP flow tables for OpenFlow instance 1.
[Sysname-of-inst-1] refresh ip-flow
Use reset openflow instance statistics to clear statistics on packets that a controller sends and receives for an OpenFlow instance.
reset openflow instance instance-id { controller [ controller-id ] | listened } statistics
controller-id: Specifies a controller by its ID in the range of 0 to 63. If you do not specify a controller ID, this command clears statistics on packets that all controllers send and receive for an OpenFlow instance.
listened: Specifies the client that connects to the server enabled for the OpenFlow instance.
# Clear statistics on packets that all controllers send and receive for OpenFlow instance 1.
<Sysname> reset openflow instance 1 controller statistics
tcp dscp
Use tcp dscp to set a DSCP value for OpenFlow packets.
Use undo tcp dscp to restore the default.
tcp dscp dscp-value
undo tcp dscp
The DSCP value for OpenFlow packets is not set.
dscp-value: Specifies a DSCP value for OpenFlow packets, in the range of 0 to 63.
# Set the DSCP value to 63 for OpenFlow packets.
[Sysname-of-inst-1] tcp dscp 63
Use snmp-agent trap enable openflow to enable SNMP notifications for OpenFlow.
Use undo snmp-agent trap enable openflow to disable SNMP notifications for OpenFlow.
snmp-agent trap enable openflow [ connect-state ]
undo snmp-agent trap enable openflow [ connect-state ]
SNMP notifications are enabled for OpenFlow.
connect-state: Specifies notifications about status changes of the connections between OpenFlow switches and controllers. If you do not specify this keyword, the command enables all notifications for OpenFlow.
This command enables OpenFlow to generate SNMP notifications for important OpenFlow events. For the notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see SNMP configuration in Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for OpenFlow.
[Sysname] snmp-agent trap enable openflow
tcp-connection backup
Use tcp-connection backup to enable OpenFlow connection backup.
Use undo tcp-connection backup to disable OpenFlow connection backup.
OpenFlow connection backup is enabled.
This command enables an OpenFlow instance to back up OpenFlow connections established over TCP. This prevents connection interruption when an active/standby switchover occurs.
This feature is available only on an IRF fabric with two member devices.
# Disable OpenFlow connection backup for OpenFlow instance 1.
[Sysname-of-inst-1] undo tcp-connection backup
ttp enable
Use ttp enable to enable the TTP mode for an OpenFlow instance.
Use undo ttp enable to disable the TTP mode for an OpenFlow instance.
ttp enable
undo ttp enable
The TTP mode is disabled for an OpenFlow instance.
An OpenFlow instance enabled with the TTP mode supports only TTP flow entries. This command is exclusive with commands related to other types of flow entries.
You can enable the TTP mode only for an OpenFlow instance in global mode. To configure an OpenFlow instance to operate in global mode by using the classification global command.
You can enable the TTP mode for the OpenFlow instance only when all OpenFlow instances are not activated.
The device supports enabling the TTP mode for only one OpenFlow instance.
# Configure OpenFlow instance 1 in global mode, and then enable the TTP mode for the instance.
classification
