- 05-Layer 3-IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-RIPng commands
- 10-OSPFv3 commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
- 13-DCN commands
| 11-IPv6 policy-based routing commands | 111.74 KB |
apply fail-action-drop next-hop
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
reset ipv6 policy-based-route statistics
apply default-next-hop
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] }&<1-2>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-2> ]
No default next hop is set.
IPv6 policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ipv6-address: Specifies the IPv6 address of the default next hop. If you do not specify the vpn-instance vpn-instance-name option, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
service-chain path-id service-path-id: Specifies a service chain by its path ID. A path ID uniquely identifies a service chain, and its value range is 1 to 16777215.
path-index service-path-index: Specifies a node in the service chain as a default next hop by its index in the range of 1 to 255.
&<1-2>: Indicates that the argument before it can be entered up to two times.
You can specify multiple default next hops for backup in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
To set multiple default next hops and specify their service chain parameters (service chain path ID and node index), follow these guidelines:
· If the next hops are used in different service chains, use the apply default-next-hop command to specify the service chain parameters.
· If the next hops are used in the same service chain, use the apply service-chain command to specify the service chain parameters as a best practice.
· On an IPv6 policy node, you cannot configure both the apply default-next-hop command with the service chain parameters and the apply service-chain command.
# Set a directly-connected default next hop of 1:1::1:1.
[Sysname] ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply default-next-hop 1:1::1:1 direct
apply service-chain
Use apply fail-action-drop next-hop to set the action that drops matching packets when all next hops on an IPv6 policy node are invalid.
Use undo apply fail-action-drop next-hop to restore the default.
The drop action is not configured. The matching packets are forwarded based on the typical packet forwarding process if all next hops on the IPv6 policy node are invalid.
By default, the device uses the typical packet forwarding process to route matching packets when all next hops on the IPv6 policy node are unavailable. To drop all matching packets when all next hops on the IPv6 policy node are unavailable, use this command. This command is typically used in scenarios that require strict routing paths.
If no next hops are specified on the IPv6 policy node, this command drops all packets that match the node.
This command does not apply to software-forwarded packets.
# Set next hop 1::1 on IPv6 policy node 10 and configure the IPv6 policy node to drop matching packets when the next hop is invalid.
[Sysname] ipv6 policy-based-route policy1 permit node 10
[Sysname-pbr6-policy1-1] apply next-hop 1::1
[Sysname-pbr6-policy1-1] apply fail-action-drop next-hop
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] } &<1-2>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-2> ]
No next hops are set.
ipv6-address: Specifies the IPv6 address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
path-index service-path-index: Specifies a node in the service chain as a next hop by its index in the range of 1 to 255.
You can specify multiple next hops for backup in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
To set multiple next hops and specify their service chain parameters (service chain path ID and node index), follow these guidelines:
· If the next hops are used in different service chains, use the apply next-hop command to specify the service chain parameters.
· On an IPv6 policy node, you cannot configure both the apply next-hop command with the service chain parameters and the apply service-chain command.
# Set a directly-connected next hop of 1::1.
[Sysname-pbr6-aa-11] apply next-hop 1::1
apply service-chain
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface null 0
undo apply output-interface [ null 0 ]
No output interface is set.
null 0: Specifies Null 0 as the output interface.
# Specify Null 0 as the output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply output-interface null 0
apply loadshare
apply precedence
Use apply precedence to set a precedence for IPv6 packets.
Use undo apply precedence to restore the default.
No precedence is set for IPv6 packets.
type: Specifies the precedence type for IPv6 packets.
value: Specifies the precedence for IPv6 packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IPv6 packets.
Table 1 IP precedences and the corresponding types
Precedence value |
Precedence type |
0 |
routine |
1 |
priority |
2 |
immediate |
3 |
flash |
4 |
flash-override |
5 |
critical |
6 |
internet |
7 |
network |
# Set the precedence to 5 (critical) for IPv6 packets.
[Sysname]ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply precedence critical
apply service-chain
Use apply service-chain to set service chain information.
Use undo apply service-chain to restore the default.
apply service-chain path-id service-path-id [ path-index service-path-index ]
No service chain information is set.
path-id service-path-id: Specifies a service chain by its path ID in the range of 1 to 16777215. The path ID uniquely identifies a service chain.
path-index service-path-index: Specifies the path index of the node to which you are sending the matching packets. The value range for path indexes is 1 to 255. Specify this option if the destination node might receive packets from different nodes in the service chain. If the destination node receives packets only from the device, you do not need to specify this option.
# Set service chain path ID 1 and node index 10.
[Sysname] ipv6 policy-based-route aa permit node 5
[Sysname-pbr6-aa-5] apply service-chain path-id 1 path-index 10
if-match service-chain
description
Use description to configure a description for an IPv6 policy node.
No description is configured for an IPv6 policy node.
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for IPv6 policy node 1.
[Sysname] ipv6 policy-based-route 1 permit node 1
[Sysname-pbr6-1-1] description Officeuse
Use display ipv6 policy-based-route to display IPv6 PBR policy information.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all IPv6 PBR policies.
# Display all IPv6 policy information.
<Sysname> display ipv6 policy-based-route
Policy name: aaa
node 1 permit:
if-match acl 2000
apply next-hop 1000::1
node 1 permit |
The match mode of Node 1 is permit. |
if-match acl |
Compares IPv6 packets with IPv6 ACL. |
apply next-hop |
Specifies a next hop for permitted IPv6 packets. |
Use display ipv6 policy-based-route interface to display IPv6 interface PBR configuration and statistics.
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 interface PBR configuration and statistics for the master device.
# Display IPv6 PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ipv6 policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-inerface2(failed):
Policy name: aaa
node 0 deny:
Matches: 0, bytes: 0
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
node 5 permit:
if-match acl 3101
Total matches: 0, total bytes: 0
Policy based routing information for interface XXXX |
IPv6 PBR configuration and statistics on the interface. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. To successfully issue the policy, you must remove the policy from the interface and then apply it on the interface again. NOTE: The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
node 0 deny node 2 permit |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. NOTE: The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
if-match acl |
Compares IPv6 packets with the IPv6 ACL. |
apply next-hop |
Matches |
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. NOTE: The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
bytes |
Number of matching bytes on the node. |
Total matches |
Total number of successful matches on all nodes. |
total bytes |
Total number of matching bytes on all nodes. |
Use display ipv6 policy-based-route local to display IPv6 local PBR configuration and statistics.
display ipv6 policy-based-route local [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 local PBR configuration and statistics for the master device.
# Display IPv6 local PBR configuration and statistics.
<Sysname> display ipv6 policy-based-route local
Policy based routing information for local:
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
apply next-hop 1::1
node 5 permit:
if-match acl 3101
apply next-hop 2::2
Policy based routing information for local |
IPv6 local PBR configuration and statistics. |
node 0 deny/node 2 permit |
Match mode of the node, permit or deny. |
if-match acl |
Compares packets with the ACL. |
apply next-hop |
Specifies a next hop for permitted packets. |
Matches |
Number of successful matches on the node. |
bytes |
Total matches |
total bytes |
ipv6 local policy-based-route
Use display ipv6 policy-based-route setup to display IPv6 PBR configuration.
# Display IPv6 PBR configuration.
<Sysname> display ipv6 policy-based-route setup
Policy name Type Interface
pr01 Forward Vlan-interface 2
pr02 Local N/A
Table 5 Command output
Policy name |
Policy name. |
Type |
Type of the PBR: · Forward—Interface PBR. · Local—Local PBR. |
Interface where the policy is applied. This field displays N/A for IPv6 local PBR. |
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999. The value range of a basic ACL is 2000 to 2999 and that of an advanced ACL is 3000 to 3999.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all. For the command to take effect, make sure the specified IPv6 ACL is a basic or advanced ACL.
If the specified ACL does not exist or has no rules configured, no packets will match the ACL.
If the vpn-instance keyword is specified for an ACL rule, the ACL does not take effect. If the vpn-instance keyword is not specified, the rule applies to both public and private network packets.
# Configure Node 10 of policy aa to permit the packets matching ACL 2000.
[Sysname] ipv6 policy-based-route aa permit node 10
[Sysname-pbr6-aa-10] if-match acl 2000
# Configure Node 10 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr6-aa-10] if-match acl name aaa
if-match qos-local-id
Use if-match qos-local-id to set a local QoS ID match criterion.
Use undo if-match qos-local-id to restore the default.
if-match qos-local-id local-id-value [ qppb-manipulation ]
No local QoS ID match criterion is set.
local-id-value: Specifies a local QoS ID in the range of 1 to 4095.
qppb-manipulation: Applies the match criterion only to QPPB when the device acts as a BGP receiver. A received packet matches the policy node if the local QoS ID obtained from its matching route entry is identical to the specified local QoS ID criterion. For more information about QPPB, see ACL and QoS Configuration Guide.
If the device is configured with MAC authentication, make sure the local QoS ID specified in the if-match qos-local-id command is smaller than 3000. For more information about MAC authentication, see MAC authentication configuration in Security Configuration Guide.
# Match packets with local QoS ID 200.
[Sysname-pbr6-aa-11] if-match qos-local-id 200
Use if-match service-chain to set a service chain match criterion.
Use undo if-match service-chain to restore the default.
if-match service-chain path-id service-path-id [ path-index service-path-index ]
undo if-match service-chain [ path-id service-path-id ]
No service chain match criteria are set.
path-index service-path-index: Specifies a node in the service chain by its index to match packets sent from that node. The value range for path indexes is 1 to 255. Specify this option if the device might receive packets from different nodes in the service chain. If only one node in the service chain sends packets to the device, you do not need to specify this option.
# Set a service chain match criterion to match packets with service chain path ID 1 and node index 10.
[Sysname-pbr6-aa-5] if-match service-chain path-id 1 path-index 10
apply service-chain
Use ipv6 local policy-based-route to configure IPv6 local PBR based on a specified policy.
Use undo ipv6 local policy-based-route to restore the default.
No policy is specified for IPv6 local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified IPv6 policy must already exist.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR is used to route locally generated packets except the packets destined for the sender. This feature might affect local services. Do not configure IPv6 local PBR unless doing so is required.
# Configure IPv6 local PBR based on policy aaa.
[Sysname] ipv6 local policy-based-route aaa
Use ipv6 policy-based-route to configure IPv6 interface PBR by applying an IPv6 policy to an interface.
Use undo ipv6 policy-based-route to restore the default.
ipv6 policy-based-route policy-name
No IPv6 policy is applied to an interface.
Interface view
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ipv6 policy-based-route aaa
Use ipv6 policy-based-route to create an IPv6 policy node and enter its view, or enter the view of an existing IPv6 policy node.
Use undo ipv6 policy-based-route to delete an IPv6 policy or IPv6 policy node.
undo ipv6 policy-based-route policy-name [ deny | node node-number | permit ]
No IPv6 policy nodes exist.
policy-name: Specifies a policy name, a case-sensitive string of 1 to 19 characters.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies the number of the IPv6 policy node. A smaller number has a higher priority. The value range for the node-number argument is 0 to 65535.
To delete an IPv6 policy that has already applied to an interface, you must delete the policy from the interface first.
If a policy node is specified, the undo ipv6 policy-based-route command deletes the specified policy node. If a match mode is specified, the command deletes all nodes configured with the match mode. If no node is specified, the command deletes the whole policy.
# Create permit-mode Node 10 for IPv6 policy aaa and enter its view.
[Sysname] ipv6 policy-based-route aaa permit node 10
[Sysname-pbr6-aaa-10]
Use reset ipv6 policy-based-route statistics to clear IPv6 PBR statistics.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears IPv6 PBR statistics for all policies.
# Clear all IPv6 PBR statistics.
<Sysname> reset ipv6 policy-based-route statistics
