09-安全命令参考
13-SSH命令
本章节下载 13-SSH命令  (731.77 KB)
13-SSH命令
1 SSH
1.1 SSH服务器端配置命令
1.1.1 display ssh exception-record
1.1.2 display ssh server
1.1.3 display ssh user-information
1.1.4 free ssh
1.1.5 scp server enable
1.1.6 sftp server enable
1.1.7 sftp server idle-timeout
1.1.8 ssh exception-record max-number
1.1.9 ssh server acl
1.1.10 ssh server acl-deny-log enable
1.1.11 ssh server authentication-retries
1.1.12 ssh server authentication-timeout
1.1.13 ssh server authentication-type keyboard-interactive enable
1.1.14 ssh server compatible-ssh1x enable
1.1.15 ssh server dscp
1.1.16 ssh server enable
1.1.17 ssh server ipv6 acl
1.1.18 ssh server ipv6 dscp
1.1.19 ssh server key-re-exchange enable
1.1.20 ssh server login-failed threshold-alarm
1.1.21 ssh server pki-domain
1.1.22 ssh server port
1.1.23 ssh server rekey-interval
1.1.24 ssh user
1.2 SSH客户端配置命令
1.2.1 bye
1.2.2 cd
1.2.3 cdup
1.2.4 delete
1.2.5 delete ssh client server-public-key
1.2.6 dir
1.2.7 display scp client source
1.2.8 display sftp client source
1.2.9 display ssh client server-public-key
1.2.10 display ssh client source
1.2.11 exit
1.2.12 get
1.2.13 help
1.2.14 ls
1.2.15 mkdir
1.2.16 put
1.2.17 pwd
1.2.18 quit
1.2.19 remove
1.2.20 rename
1.2.21 rmdir
1.2.22 scp
1.2.23 scp client ipv6 source
1.2.24 scp client source
1.2.25 scp ipv6
1.2.26 scp ipv6 suite-b
1.2.27 scp suite-b
1.2.28 sftp
1.2.29 sftp client ipv6 source
1.2.30 sftp client source
1.2.31 sftp ipv6
1.2.32 sftp ipv6 suite-b
1.2.33 sftp suite-b
1.2.34 ssh client ipv6 source
1.2.35 ssh client source
1.2.36 ssh2
1.2.37 ssh2 ipv6
1.2.38 ssh2 ipv6 suite-b
1.2.39 ssh2 suite-b
1.3 SSH2协议配置命令
1.3.1 display ssh2 algorithm
1.3.2 ssh2 algorithm cipher
1.3.3 ssh2 algorithm key-exchange
1.3.4 ssh2 algorithm mac
1.3.5 ssh2 algorithm public-key
1 SSH
1.1  SSH服务器端配置命令
display ssh exception-record命令用来显示SSH用户登录异常记录的详细信息。
缺省情况下,设备会将最近10条SSH用户登录异常记录到系统内存中,如果需要将设备记录的条数调大,可通过ssh exception-record max-number命令进行配置。
# 显示SSH用户登录异常记录的详细信息。
<Sysname> display ssh exception-record
User name: aaa
IP address: 19.19.0.1
Version: 1.5
State: Ver-exchange
Service type: N/A
VTY number: N/A
Exception time: 2022-03-25 20:13:34 UTC
Exception reason: Change of username or service not allowed
User name: bbb@test
IP address: 19.19.0.2
Version: 2.0
State: Auth-request
Service type: N/A
VTY number: N/A
Exception time: 2022-03-24 19:19:54 UTC
Exception reason: Authentication failed
Reply message: Invalid username or wrong password
表1-1 display ssh exception-record命令显示信息描述表
User name
用户名
IP address
用户的IP地址
Version
SSH客户端协议版本信息
异常时会话状态:
·     Init:初始化状态
·     Ver-exchange:版本协商
·     Keys-exchange:密钥交换
·     Auth-request:用户认证
·     Serv-request:服务请求
·     Established:会话已经建立
·     Disconnected:会话已经断开
Service type
服务类型,取值包括SCP、SFTP、Stelnet和NETCONF
VTY number
占用的VTY用户线的编号,若用户未占用,则显示为N/A
Exception time
异常发生的时间
Exception reason
异常发生的原因,详细介绍请参见表1-2
Reply message
AAA回应的失败原因、客户端回应的消息,或用户进程携带给主进程的具体原因
表1-2 SSH用户登录异常原因描述表
Maximum number of logins already reached
超出最大登录会话数
Public key or private key file error
公钥或私钥文件错误
Authentication timeout
认证超时
Bad service request
SSH服务器的服务类型与SSH登录用户的不一致
用户修改了用户名或配置了设备上不允许的接入服务类型
认证失败
Authorization failed
授权失败
Accounting failed
计费失败
Login not permitted because RBAC check failed
SSH用户RBAC用户角色权限检查失败,不允许登录
Cannot open the working directory
SSH用户无法打开授权工作目录(比如文件损坏导致)
Request was denied according to ACL rules
SSH客户端的IP地址不在ACL的permit规则中,请求被拒绝
The connection was disconnected due to client reasons
由于客户端原因连接断开
Server is unavailable
SSH服务器上配置的服务类型与SSH用户的服务类型不匹配,服务类型包括SCP、SFTP、Stelnet和NETCONF
VTY allocation failed because of VTY session limit or no enough resource
VTY用户线不足或者系统资源不足导致VTY用户线占用失败
Authentication attempts exceeded the upper limit
认证尝试次数超过上限
Version mismatch
服务器的SSH版本与客户端版本不兼容
Key negotiation processing failed
密钥协商过程失败
·     netconf ssh server enable(网络管理和监控命令参考/NETCONF)
·     scp server enable
·     sftp server enable
·     ssh exception-record max-number
·     ssh server enable
display ssh server命令用来在SSH服务器端显示该服务器的状态信息或会话信息。
session:显示SSH服务器的会话信息。
status:显示SSH服务器的状态信息。
# 在SSH服务器端显示该服务器的状态信息。
<Sysname> display ssh server status
 Stelnet server: Disable
 SSH version : 2.0
 SSH authentication-timeout : 60 second(s)
 SSH server key generating interval : 0 hour(s)
 SSH authentication retries : 3 time(s)
 SFTP server: Disable
 SFTP server Idle-Timeout: 10 minute(s)
 NETCONF server: Disable
 SCP server: Disable
 SSH Server PKI domain name: aaa
表1-3 display ssh server status命令显示信息描述表
Stelnet server
Stelnet服务器功能的状态
SSH version
SSH协议版本
SSH服务器兼容SSH1时,协议版本为1.99;SSH服务器不兼容SSH1时,协议版本为2.0
认证超时时间
RSA服务器密钥对的最小更新间隔时间
SSH用户认证尝试的最大次数
SFTP server
SFTP服务器功能的状态
SFTP用户连接的空闲超时时间
NETCONF server
NETCONF over SSH服务器功能的状态
SCP server
SCP服务器功能的状态
SSH服务器PKI域配置
# 在SSH服务器端显示该服务器的会话信息。
<Sysname> display ssh server session
UserPid   SessID Ver   Encrypt    State          Retries  Serv     Username
 184       0     2.0   aes128-cbc Established    1        Stelnet  abc@123
表1-4 display ssh server session显示信息描述表
UserPid
用户进程PID
SessID
会话ID
Ver
SSH客户端的协议版本
Encrypt
SSH服务器本端使用的加密算法
会话状态,包括:
·     Init:初始化状态
·     Ver-exchange:版本协商
·     Auth-request:用户认证
·     Serv-request:服务请求
·     Disconnected:断开会话
Retries
认证失败的次数
Serv
服务类型,包括SCP、SFTP、Stelnet和NETCONF
Username
客户端登录服务器时采用的用户名
display ssh user-information命令用来在SSH服务器端显示SSH用户的信息。
username:SSH用户名,为1~80个字符的字符串,区分大小写。如果没有指定本参数,则显示所有SSH用户的信息。
本命令仅用来显示SSH服务器端通过ssh user命令配置的SSH用户信息。
# 显示所有SSH用户的信息。
<Sysname> display ssh user-information
 Total ssh users:2
 Username            Authentication-type  User-public-key-name  Service-type
 yemx                password                                   Stelnet
 test                publickey            pubkey                SFTP
表1-5 display ssh user-information显示信息描述表
Total ssh users
SSH用户的总数
Username
用户名
Authentication-type
认证类型,取值包括password、publickey、password-publickey和any
用户公钥名称
如果认证类型为password,则该字段显示为空
Service-type
服务类型,取值包括all、SCP、SFTP、Stelnet和NETCONF
·     ssh user
1.1.4  free ssh
free ssh命令用来强制释放已建立的SSH连接。
free ssh { user-ip { ip-address | ipv6 ipv6-address } [ port port-number ] | user-pid pid-number | username username }
user-ip:根据IP地址强制释放已建立的SSH连接。
ip-address:待释放的SSH连接的源IPv4地址。
ipv6 ipv6-address:待释放的SSH连接的源IPv6地址。
port port-number:待释放的SSH连接的源端口。port-number为源端口号,取值范围为1~65535。未指定本参数时,表示强制释放对应IP地址建立的所有SSH连接。
user-pid pid-number:根据进程号强制释放已建立的SSH连接。pid-number为待释放的SSH连接进程号,取值范围为1~2147483647。可以通过display ssh server session查看当前SSH连接的进程号。
username username:根据用户名强制释放已建立的SSH连接,可以通过display ssh server session查看当前SSH连接的用户名。
# 强制释放通过IPv4地址192.168.15.45建立的SSH连接。
<Sysname> free ssh user-ip 192.168.15.45
Releasing SSH connection. Continue? [Y/N]:y
# 强制释放通过IPv6地址2000::11建立的SSH连接。
<Sysname> free ssh user-ip ipv6 2000::11
# 强制释放进程号为417的SSH连接。
<Sysname> free ssh user-pid 417
# 强制释放通过用户名sshuser建立的SSH连接。
<Sysname> free ssh username sshuser
·     display ssh server session
scp server enable命令用来开启SCP服务器功能。
undo scp server enable命令用来关闭SCP服务器功能。
scp server enable
SCP服务器功能处于关闭状态。
# 开启SCP服务器功能。
[Sysname] scp server enable
sftp server enable命令用来开启SFTP服务器功能。
undo sftp server enable命令用来关闭SFTP服务器功能。
sftp server enable
SFTP服务器功能处于关闭状态。
# 开启SFTP服务器功能。
[Sysname] sftp server enable
sftp server idle-timeout命令用来在SFTP服务器端设置SFTP用户连接的空闲超时时间。
undo sftp server idle-timeout命令用来恢复缺省情况。
SFTP用户连接的空闲超时时间为10分钟。
time-out-value:超时时间,取值范围为1~35791,单位为分钟。
当SFTP用户连接的空闲时间超过设定的阈值后,系统会自动断开此用户的连接,从而有效避免用户长期占用连接而不进行任何操作。若同一时间内并发的SFTP连接数较多,可适当减小该值,及时释放系统资源给新用户接入。
# 设置SFTP用户连接的空闲超时时间为500分钟。
[Sysname] sftp server idle-timeout 500
ssh exception-record max-number命令用来配置设备可存储的SSH用户登录异常原因最大条数。
undo ssh exception-record max-number命令用来恢复缺省情况。
ssh exception-record max-number max-number
设备可存储的SSH用户登录异常原因最大条数为10。
max-number:设备可存储的SSH用户登录异常原因最大条数,取值范围为10~1000。
缺省情况下,开启SSH服务功能后,设备会将最近10条SSH用户登录异常记录到系统内存中,SSH用户登录异常原因详细内容可通过display ssh exception-record命令查看。当管理员需要获取更多的SSH用户登录异常记录时,可通过配置本命令将设备可存储的SSH用户登录异常原因条数调大。
当设备上产生的SSH用户登录异常记录条数超过配置的最大值时,设备每新增一条新的记录都将会覆盖最旧的一条记录。
# 配置设备可存储的SSH用户登录异常原因最大条数为100。
[Sysname] ssh exception-record max-number 100
·     display ssh exception-record
·     netconf ssh server enable (网络管理和监控命令参考/NETCONF)
·     scp server enable
·     ssh server enable
ssh server acl命令用来设置对IPv4 SSH客户端的访问控制。
undo ssh server acl命令用来恢复缺省情况。
undo ssh server acl
允许所有IPv4 SSH客户端向设备发起SSH访问。
advanced-acl-number:指定IPv4高级ACL,取值范围为3000~3999。
basic-acl-number:指定IPv4基本ACL,取值范围为2000~2999。
mac acl-number:指定二层ACL。acl-number是二层ACL的编号,取值范围为4000~4999。
对IPv4 SSH客户端的访问控制通过引用ACL来实现,具体情况如下:
·     当引用的ACL不存在或者引用的ACL为空时,不允许IPv4 SSH客户端访问设备。
·     当引用的ACL非空时,则只有匹配ACL中permit规则的IPv4 SSH客户端可以访问设备,其他客户端不可以访问设备。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则表示该规则仅对VPN报文有效;若规则未指定vpn-instance参数,则表示该规则仅对公网报文有效。
该配置生效后,只会过滤新建立的SSH连接,不会影响已建立的SSH连接。
多次执行本命令,最后一次执行的命令生效。
# 只允许IPv4地址为1.1.1.1的SSH客户端向设备发起SSH访问。
[Sysname] acl basic 2001
[Sysname] ssh server acl 2001
ssh server acl-deny-log enable命令用来开启匹配ACL deny规则后打印日志信息功能。
undo ssh server acl-deny-log enable命令用来关闭匹配ACL deny规则后打印日志信息功能。
匹配ACL deny规则后打印日志信息功能处于关闭状态。
通过配置ssh server aclssh server ipv6 acl命令,可限制SSH客户端对设备的访问。此时,通过配置ssh server acl-deny-log enable命令,设备可以记录匹配deny规则的IP用户的登录日志,用户可以查看非法登录的地址信息。
执行本配置后,SSH客户端匹配ACL deny规则时,将产生日志信息。生成的日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。
# 开启匹配ACL deny规则后打印日志信息功能。
[Sysname] ssh server acl-deny-log enable
·     ssh server acl
·     ssh server ipv6 acl
ssh server authentication-retries命令用来设置允许SSH用户认证尝试的最大次数。
undo ssh server authentication-retries命令用来恢复缺省情况。
ssh server authentication-retries retries
允许SSH用户认证尝试的最大次数为3次。
retries:指定每个SSH用户认证尝试的最大次数,取值范围为1~5。
通过本命令可以限制用户尝试登录的次数,防止非法用户对用户名和密码进行恶意地猜测和破解。
如果用户的认证次数超过了最大认证次数,还未认证成功,则不再允许认证。不同认证方式的认证次数统计方式有所不同,具体统计方式请参考如下:
·     在any认证方式下,认证次数是指SSH客户端通过publickey和password两种方式进行认证尝试的次数总和。
·     对于password-publickey认证方式,设备首先对SSH用户进行publickey认证,然后进行password认证,这个过程为一次认证尝试,而不是两次认证尝试。
该配置不会影响已经登录的SSH用户,仅对新登录的SSH用户生效。
# 指定允许SSH用户认证尝试的最大次数为4。
[Sysname] ssh server authentication-retries 4
ssh server authentication-timeout命令用来在SSH服务器端设置SSH用户的认证超时时间。
undo ssh server authentication-timeout命令用来恢复缺省情况。
SSH用户的认证超时时间为60秒。
time-out-value:认证超时时间,取值范围为1~120,单位为秒。
如果SSH用户在设置的认证超时时间内没有完成认证,SSH服务器就拒绝该用户的连接。
为了防止不法用户建立起TCP连接后,不进行接下来的认证,而占用系统资源,妨碍其它合法用户的正常登录,可以适当调小SSH用户认证超时时间。
# 设置SSH用户认证超时时间为10秒。
[Sysname] ssh server authentication-timeout 10
ssh server authentication-type keyboard-interactive enable命令用来配置SSH认证方式为keyboard-interactive认证。
undo ssh server authentication-type keyboard-interactive enable命令用来关闭SSH服务器的Keyboard交互认证功能。
仅R6717及以上版本支持本命令。
SSH服务器采用的认证方式以SSH用户各自配置的认证方式为准。
应用场景
本命令旨在提高keyboard-interactive认证方式的易用性,使得认证方式可以全局指定。这样,管理员不需要为每个用户分别配置ssh user命令指定认证方式为keyboard-interactive,减少了配置的复杂性。
工作机制
在配置了全局SSH认证方式为keyboard-interactive后,用户可以通过ssh user命令为特定用户配置不同的认证方式。这种情况下,该特定用户的认证将优先采用ssh user命令配置的认证方式。对于未单独配置认证方式的用户,系统将默认使用全局的keyboard-interactive认证方式进行身份验证。
# 服务器开启键盘交互式认证开关。
[Sysname] ssh server authentication-type keyboard-interactive enable
·     ssh user
ssh server compatible-ssh1x enable命令用来设置SSH服务器兼容SSH1版本的客户端。
undo ssh server compatible-ssh1x [ enable ]命令用来恢复缺省情况。
SSH服务器不兼容SSH1版本的客户端。
FIPS模式下,不支持本命令。
执行undo命令时,指定enable和不指定enable均表示恢复缺省情况。
# 配置服务器兼容SSH1版本的客户端。
[Sysname] ssh server compatible-ssh1x enable
ssh server dscp命令用来设置IPv4 SSH服务器向SSH客户端发送的报文的DSCP优先级。
undo ssh server dscp命令用来恢复缺省情况。
ssh server dscp dscp-value
IPv4 SSH报文的DSCP优先级为48。
dscp-value:IPv4 SSH报文的DSCP优先级,取值范围为0~63。取值越大,优先级越高。
DSCP携带在IP报文中的ToS字段,用来体现报文自身的优先等级,决定报文传输的优先程度。
# 配置IPv4 SSH服务器向SSH客户端发送的报文的DSCP优先级为30。
[Sysname] ssh server dscp 30
ssh server enable命令用来开启Stelnet服务器功能。
undo ssh server enable命令用来关闭Stelnet服务器功能。
ssh server enable
Stelnet服务器功能处于关闭状态。
# 开启Stelnet服务器功能。
[Sysname] ssh server enable
ssh server ipv6 acl命令用来设置对IPv6 SSH客户端的访问控制。
undo ssh server ipv6 acl命令用来恢复缺省情况。
允许所有IPv6 SSH客户端向设备发起SSH访问。
ipv6:指定IPv6 ACL。
advanced-acl-number:指定IPv6高级ACL,取值范围为3000~3999。
basic-acl-number:指定IPv6基本ACL,取值范围为2000~2999。
对IPv6 SSH客户端的访问控制通过引用ACL来实现,具体情况如下:
·     当引用的ACL不存在、或者引用的ACL为空时,不允许IPv6 SSH客户端访问设备。
·     当引用的ACL非空时,则只有匹配ACL中permit规则的IPv6 SSH客户端可以访问设备,其他客户端不可以访问设备。
# 只允许1::1/64网段内的SSH客户端向设备发起SSH访问。
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source 1::1 64
[Sysname] ssh server ipv6 acl ipv6 2001
ssh server ipv6 dscp命令用来设置IPv6 SSH服务器向SSH客户端发送的报文的DSCP优先级。
undo ssh server ipv6 dscp命令用来恢复缺省情况。
IPv6 SSH报文的DSCP优先级为48。
dscp-value:IPv6 SSH报文的DSCP优先级,取值范围为0~63。取值越大,优先级越高。
DSCP携带在IPv6报文中的Traffic class字段,用来体现报文自身的优先等级,决定报文传输的优先程度。
# 配置IPv6 SSH服务器向SSH客户端发送的报文的DSCP优先级为30。
[Sysname] ssh server ipv6 dscp 30
ssh server key-re-exchange enable命令用来开启SSH算法重协商和密钥重交换功能。
undo ssh server key-re-exchange enable命令用来关闭SSH算法重协商和密钥重交换功能。
(非FIPS模式)
ssh server key-re-exchange enable [ interval interval ]
(FIPS模式)
ssh server key-re-exchange enable [ interval-minutes interval ]
SSH算法重协商和密钥重交换功能处于关闭状态。
interval interval:SSH算法重协商和密钥重交换间隔时间。interval取值范围为1~24,单位为小时,缺省值为1。
interval-minutes interval:SSH算法重协商和密钥重交换间隔时间。interval取值范围为30~60,单位为分钟,缺省值为60。
配置该命令后,服务器将在客户端和服务器第一次算法协商开始后根据用户设置的时间间隔定时向客户端发起算法协商请求,进行算法协商和密钥交换操作。
本功能的开启和间隔时间变化不影响已存在的SSH连接。
# 开启SSH算法重协商和密钥重交换功能。
<Sysname> sysname
[Sysname] ssh server key-re-exchange enable
ssh server login-failed threshold-alarm命令用来配置在指定统计时间内,SSH用户登录失败的告警阈值。
undo ssh server login-failed threshold-alarm命令用来恢复缺省情况。
ssh server login-failed threshold-alarm upper-limit report-time lower-limit resume-time period period-time
统计时间为5分钟,SSH用户失败的告警上报和取消阈值分别为30和20。
upper-limit report-time:指定SSH用户登录失败的告警上报阈值,当在指定统计时间(通过period period-time参数配置)内SSH用户登录失败的次数达到或者超过告警上报阈值时,设备将生成对应的告警信息。report-time表示SSH用户登录失败的次数,取值范围为0~100。取值为0,表示SSH用户登录失败不生成告警信息。
lower-limit resume-time:指定SSH用户登录失败的告警取消阈值,当在指定统计时间(通过period period-time参数配置)内SSH用户登录失败的次数低于告警取消阈值时,设备将生成对应的告警信息。resume-time表示SSH用户登录失败的次数,当report-time配置的值小于等于45时,取值范围为0~report-time;当report-time配置的值大于45时,取值范围为0~45。取值为0和1,均表示在统计周期内,未出现SSH用户登录失败,才生成对应的告警信息。
period period-time:指定统计SSH用户登录用户失败次数的周期,取值范围为1~120,单位为分钟,缺省值为5。如果report-time取值为0,则本参数的配置不生效。
配置本命令后,在指定的统计时间内,当SSH用户登录失败的次数大于等于告警上限阈值,或者从超过上限回落到小于下限阈值时,将产生对应的告警信息,以便管理及时了解SSH用户登录的实时情况。
本命令中配置的report-time必须大于等于resume-time
# 配置SSH用户登录失败统计周期为3分钟,告警上报阈值和取消阈值分别为20和10。
[Sysname] ssh server login-failed threshold-alarm upper-limit 20 lower-limit 10 period 3
ssh server pki-domain命令用来配置服务器所属的PKI域。
undo ssh server pki-domain命令用来恢复缺省情况。
ssh server pki-domain domain-name
未配置服务器所属的PKI域。
domain-name:验证服务端的PKI域名称,为1~31个字符的字符串,不区分大小写,不能包括“~”、“*”、“\”、“|”、“:”、“.”、“<”、“>”、“"”和“'”。
# 配置SSH服务器所属的PKI域为serverpkidomain。
[Sysname] ssh server pki-domain serverpkidomain
ssh server port命令用来配置SSH服务的端口号。
undo ssh server port命令用来恢复缺省情况。
ssh server port port-number
SSH服务的端口号为22。
port-number:SSH服务的端口号,取值范围为1~65535。
·     如果修改端口号前SSH服务是开启的,则修改端口号后系统会自动重启SSH服务,正在访问的用户将被断开,用户需要重新建立SSH连接后才可以继续访问。
·     如果使用1~1024之间的知名端口号,有可能会导致其他服务启动失败。
# 配置SSH服务的端口号为1025。
[Sysname] ssh server port 1025
ssh server rekey-interval命令用来设置RSA服务器密钥对的最小更新间隔时间。
undo ssh server rekey-interval命令用来恢复缺省情况。
ssh server rekey-interval interval
RSA服务器密钥对的最小更新间隔时间为0,表示系统不更新RSA服务器密钥对。
interval:服务器密钥对的最小更新间隔时间,取值范围为1~24,单位为小时。
FIPS模式下,不支持本命令。
通过定时更新服务器密钥对,可以防止对密钥对的恶意猜测和破解,从而提高了SSH连接的安全性。
配置该命令后,从首个SSH1用户登录开始,SSH服务器需要等待后续有新的SSH1用户登录,才会更新当前的RSA服务器密钥对,然后使用新的RSA服务器密钥对与新登录的这个SSH1用户进行密钥对的协商,其中等待的最小时长就为此处配置的最小更新间隔时间。之后,重复此过程,直到下一个新的SSH1用户登录才会再次触发RSA服务器密钥的更新。
本配置仅对SSH客户端版本为SSH1的用户有效。
# 设置RSA服务器密钥对的最小更新间隔时间为3小时。
[Sysname] ssh server rekey-interval 3
1.1.24  ssh user
ssh user命令用来创建SSH用户,并指定SSH用户的服务类型和认证方式。
undo ssh user命令用来删除SSH用户。
(非FIPS模式)
ssh user username service-type { all | netconf | scp | sftp | stelnet } authentication-type { keyboard-interactive | password | { any | password-publickey | publickey } [ assign { pki-domain domain-name | publickey keyname&<1-6> } ] }
undo ssh user username
(FIPS模式)
ssh user username service-type { all | netconf | scp | sftp | stelnet } authentication-type { keyboard-interactive | password | password-publickey [ assign { pki-domain domain-name | publickey keyname&<1-6> } ] }
不存在SSH用户。
username:SSH用户名,为1~80个字符的字符串,区分大小写。用户名不能包括符号“\”、“|”、“/”、“:”、“*”、“?”、“<”、“>”和“@”,且不能为“a”、“al”、“all”。其中,“@”、“\”和“/”仅用于作为用户名的ISP域名分隔符,具体使用形式为:pureusername@domainpureusername/domaindomain\pureusername。当创建SCP服务类型的用户时,用户名中请不要包含短横杠-,否则使用此用户名进行SCP登录会失败。
service-type:SSH用户的服务类型。包括:
·     all:包括scpsftpstelnetnetconf四种服务类型。
·     scp:服务类型为SCP(Secure Copy的简称)。
·     sftp:服务类型为SFTP(Secure FTP的简称)。
·     stelnet:服务类型为Stelnet(Secure Telnet的简称)。
·     netconf:服务类型为NETCONF。
authentication-type:SSH用户的认证方式。包括:
·     keyboard-interactive:强制用户使用交互式认证。该认证方式与password认证方式类似,相较于password认证,该认证方式提供了可变的交互信息。在远程认证服务器要求用户进行交互认证时,客户端终端上可以显示出远程认证服务器所提供的认证交互信息。在远程认证服务器不要求用户进行交互认证时,该认证处理流程和password认证相同。
·     password:强制指定该用户的认证方式为password。该认证方式的加密机制简单,加密速度快,可结合AAA(Authentication, Authorization, Accounting,认证、授权、计费)实现对用户认证、授权和计费,但容易受到攻击。
·     any:不指定用户的认证方式,用户可以采用keyboard-interactive认证、password认证或publickey认证中任意一种。
·     password-publickey:指定客户端版本为SSH2的用户认证方式为必须同时进行password和publickey两种认证,安全性更高;客户端版本为SSH1的用户认证方式为只要进行其中一种认证即可。
·     publickey:强制指定该用户的认证方式为publickey。该认证方式的加密速度相对较慢,但认证强度高,不易受到暴力猜测密码等攻击方式的影响,而且具有较高的易用性。一次配置成功后,后续认证过程自动完成,不需要用户记忆和输入密码。
assign:指定用于验证客户端的参数。
·     pki-domain domain-name:指定验证客户端证书的PKI域。domain-name表示PKI域的名称,为1~31个字符的字符串,不区分大小写,不能包括“~”、“*”、“\”、“|”、“:”、“.”、“<”、“>”、“"”和“'”。服务器端使用保存在该PKI域中的CA证书对客户端证书进行合法性检查,无需提前保存客户端的公钥,能够灵活满足大数量客户端的认证需求。
·     publickey keyname&<1-6>:指定SSH客户端的公钥,可以指定多个SSH客户端的公钥。keyname表示已经配置的客户端公钥名称,为1~64个字符的字符串,区分大小写。&<1-6>表示前面的参数最多可以输入6次。服务器端使用提前保存在本地的用户公钥对用户进行合法性检查,如果客户端密钥文件改变,服务器端需要及时更新本地配置。如果指定了多个用户公钥,则在验证SSH用户身份时,按照配置顺序使用指定的公钥依次对其进行验证,只要用户通过任意一个公钥验证即可。
SSH用户的配置与服务器端采用的认证方式有关,具体如下:
·     如果服务器采用了publickey认证,则必须在设备上创建相应的SSH用户,以及同名的本地用户(用于下发授权属性:工作目录、用户角色)。
·     如果服务器采用了password认证,则必须在设备上创建相应的本地用户(适用于本地认证),或在远程服务器(如RADIUS服务器,适用于远程认证)上创建相应的SSH用户。这种情况下,并不需要通过本配置创建相应的SSH用户,如果创建了SSH用户,则必须保证指定了正确的服务类型以及认证方式。
·     如果服务器采用了keyboard-interactive、password-publickey或any认证,则必须在设备上创建相应的SSH用户,以及在设备上创建同名的本地用户(适用于本地认证)或者在远程认证服务器上创建同名的SSH用户(如RADIUS服务器,适用于远程认证)。
SCP或SFTP用户登录时使用的工作目录与用户使用的认证方式有关:
·     采用publickey或password-publickey认证方式的用户,使用的工作目录为对应的本地用户视图下通过authorization-attribute命令设置的工作目录。
·     采用keyboard-interactive或password认证方式的用户,使用的工作目录为通过AAA授权的工作目录。
SSH用户登录时拥有的用户角色与用户使用的认证方式有关:
·     采用publickey或password-publickey认证方式的用户,用户角色为对应的本地用户视图下通过authorization-attribute命令设置的用户角色。
·     采用keyboard-interactive或password认证方式的用户,用户角色为通过AAA授权的用户角色。
使用该命令为用户指定公钥或PKI域时,以最后一次指定的公钥或PKI域为准。若不指定pki-domainpublickey,则表示该用户采用证书认证方式登录,服务器使用其所属的PKI域来验证客户端的证书。
对SSH用户配置的修改,不会影响已经登录的SSH用户,仅对新登录的用户生效。
# 创建SSH用户user1,配置user1的服务类型为SFTP,认证方式为password-publickey,并指定客户端公钥为key1。
[Sysname] ssh user user1 service-type sftp authentication-type password-publickey assign publickey key1
# 创建设备管理类本地用户user1,配置用户密码为明文123456TESTplat&!,服务类型为SSH,授权工作目录为flash:,授权用户角色为network-admin。
[Sysname-luser-manage-user1] service-type ssh
[Sysname-luser-manage-user1] authorization-attribute work-directory flash: user-role network-admin
·     authorization-attribute(安全命令参考/AAA)
·     display ssh user-information
·     local-user(安全命令参考/AAA)
·     pki domain(安全命令参考/PKI)
1.2  SSH客户端配置命令
1.2.1  bye
bye命令用来终止与远程SFTP服务器的连接,并退回到用户视图。
bye
SFTP客户端视图
该命令功能与exitquit相同。
# 终止与远程SFTP服务器的连接。
sftp> bye
<Sysname>
1.2.2  cd
cd命令用来改变远程SFTP服务器上的工作路径。
cd [ remote-path ]
SFTP客户端视图
remote-path:目的工作路径的名称。
命令“cd ..”用来返回到上一级目录。
命令“cd /”用来返回到系统的根目录。
# 改变工作路径到new1。
sftp> cd new1
Current Directory is:/new1
sftp> pwd
Remote working directory: /new1
sftp>
1.2.3  cdup
cdup命令用来返回到上一级目录。
cdup
SFTP客户端视图
# 从当前工作目录/test1返回到上一级目录。
sftp> cd test1
Current Directory is:/test1
sftp> pwd
Remote working directory: /test1
sftp> cdup
sftp> pwd
sftp>
1.2.4  delete
delete命令用来删除SFTP服务器上指定的文件。
delete remote-file
SFTP客户端视图
remote-file:要删除的文件的名称。
该命令和remove功能相同。
# 删除服务器上的文件temp.c。
sftp> delete temp.c
Removing /temp.c
delete ssh client server-public-key命令用来删除SSH客户端公钥文件中的服务器公钥信息。
delete ssh client server-public-key [ server-ip ip-address ]
server-ip ip-address:删除指定IP地址的服务器的公钥信息。不指定本参数时,删除公钥文件中所有服务器公钥信息。
# 删除所有SSH客户端保存在公钥文件的服务器公钥。
[Sysname] delete ssh client server-public-key
Public keys of all SSH servers will be deleted. Continue? [Y/N]:y
# 删除SSH客户端保存的服务器2.2.2.1的公钥。
[Sysname] delete ssh client server-public-key server-ip 2.2.2.1
1.2.6  dir
dir命令用来显示指定目录下文件及文件夹的信息。
SFTP客户端视图
-a:以列表的形式显示指定目录下文件及文件夹的详细信息,其中包括以“.”开头的文件及文件夹的详细信息。
-l:以列表的形式显示指定目录下文件及文件夹的详细信息,但不包括以“.”开头的文件及文件夹的详细信息。
remote-path:查询的目录名。如果没有指定remote-path,则显示当前工作目录下文件及文件夹的信息。
如果没有指定-a-l参数,则显示指定目录下文件及文件夹的名称。
该命令功能与ls相同。
# 以列表的形式显示当前工作目录下文件及文件夹的详细信息,其中包括以“.”开头的文件及文件夹的详细信息。
sftp> dir -a
drwxrwxrwx    2 1        1               512 Dec 18 14:12 .
drwxrwxrwx    2 1        1               512 Dec 18 14:12 ..
-rwxrwxrwx    1 1        1               301 Dec 18 14:11 010.pub
-rwxrwxrwx    1 1        1               301 Dec 18 14:12 011.pub
-rwxrwxrwx    1 1        1               301 Dec 18 14:12 012.pub
# 以列表的形式显示当前工作目录下文件及文件夹的详细信息,但不包括以“.”开头的文件及文件夹的详细信息。
sftp> dir -l
display scp client source命令用来显示SCP客户端的源IP地址配置。
# 显示SCP客户端的源IP地址配置。
<Sysname> display scp client source
The source IP address of the SCP client is 192.168.0.1.
The source IPv6 address of the SCP client is 2:2::2:2.
·     scp client ipv6 source
·     scp client source
display sftp client source命令用来显示SFTP客户端的源IP地址配置。
# 显示SFTP客户端的源IP地址配置。
<Sysname> display sftp client source
The source IP address of the SFTP client is 192.168.0.1.
The source IPv6 address of the SFTP client is 2:2::2:2.
·     sftp client ipv6 source
·     sftp client source
display ssh client server-public-key命令用来显示SSH客户端公钥文件中的服务器公钥信息。
display ssh client server-public-key [ server-ip ip-address ]
server-ip ip-address:显示指定IP地址的服务器的公钥信息。不指定本参数时,显示公钥文件中所有服务器公钥信息。
设备作为SSH客户端时使用本命令可以显示保存在公钥文件中的服务器公钥。该部分公钥信息在配置文件中不可见,用户登录未认证过的服务器并选择保存公钥时,对应公钥信息被写入公钥文件。
# 显示SSH客户端保存在公钥文件中所有服务器公钥。
<Sysname> display ssh client server-public-key
 Server address: 10.153.124.209
 Key type: ecdsa-sha2-nistp256
 Key length: 256
 Key code:
   AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBAOGpJfwJExK
   eYb53KKqmrZ0V/XnYZKZEchyN9ax1IBt+toIXHeW5NfBE5ymeklPSNgQNhcndkU/
   422fT15UmgM=
 Server address: 2.2.2.1
 Key type: rsa
 Key length: 1024
 Key code:
   AAAAB3NzaC1yc2EAAAADAQABAAAAgQDIUrHbeLx/W7xElB1Ny3zeA8/uV9K6sj1p
   dSlhx5XcOatdNMoD/sioYgSsy9IxKZPqBs+vadqx/wCCB5+T2GLLu2qgaT0P9J+v
   RR/9Y8fI2b4tS7PoNf/QKDVD7XnoiZ+dqd0tnnRf6GV+74cp8ZEUQdAoTeDzzaAh
   7t6FbxrNrQ==
# 显示SSH客户端保存在公钥文件中的服务器2.2.2.1的公钥。
<Sysname> display ssh client server-public-key server-ip 2.2.2.1
 Key type: rsa
 Key length: 1024
 Key code:
   7t6FbxrNrQ==
表1-6 display ssh client server-public-key命令显示信息描述表
Server address
服务器IP地址
Key type
公钥类型:
·     dsa:公钥算法为DSA
·     ecdsa-sha2-nistp256:名称为secp256r1的椭圆曲线生成的ECDSA密钥,密钥长度为256比特
·     ecdsa-sha2-nistp384:名称为secp384r1的椭圆曲线生成的ECDSA密钥,密钥长度为384比特
·     rsa:公钥算法为RSA
Key length
公钥长度,单位为比特
Key code
公钥内容
display ssh client source命令用来显示STelnet客户端的源IP地址配置。
# 显示STelnet客户端的源IP地址配置。
<Sysname> display ssh client source
The source IP address of the SSH client is 192.168.0.1.
The source IPv6 address of the SSH client is 2:2::2:2.
·     ssh client ipv6 source
·     ssh client source
1.2.11  exit
exit命令用来终止与远程SFTP服务器的连接,并退回到用户视图。
exit
SFTP客户端视图
该命令功能与byequit相同。
# 终止与远程SFTP服务器的连接。
sftp> exit
<Sysname>
1.2.12  get
get命令用来从远程SFTP服务器上下载文件并存储在本地。
SFTP客户端视图
remote-file:远程SFTP服务器上的文件名。
local-file:本地文件名。如果没有指定本地文件名,则认为本地保存文件的文件名与服务器上的文件名相同。
# 下载远程服务器上的temp1.c文件,并以文件名temp.c在本地保存。
sftp> get temp1.c temp.c
Fetching /temp1.c to temp.c
/temp.c                                                 100% 1424     1.4KB/s   00:00
1.2.13  help
help命令用来显示SFTP客户端命令的帮助信息。
help
SFTP客户端视图
键入和执行help命令的功能相同。
# 查看帮助信息。
sftp> help
Available commands:
  bye                          Quit sftp
  cd [path]                    Change remote directory to 'path'
  cdup                         Change remote directory to the parent directory
  delete path                  Delete remote file
  dir [-a|-l][path]            Display remote directory listing
       -a                        List all filenames
       -l                        List filename including the specific
                                 information of the file
  exit                         Quit sftp
  get remote-path [local-path] Download file
  help                         Display this help text
  ls [-a|-l][path]             Display remote directory
  mkdir path                   Create remote directory
  put local-path [remote-path] Upload file
  pwd                          Display remote working directory
  quit                         Quit sftp
  rename oldpath newpath       Rename remote file
  remove path                  Delete remote file
  rmdir path                   Delete remote empty directory
  ?                            Synonym for help
1.2.14  ls
ls命令用来显示指定目录下文件及文件夹的信息。
SFTP客户端视图
该命令功能与dir相同。
sftp> ls -a
sftp> ls -l
1.2.15  mkdir
mkdir命令用来在远程SFTP服务器上创建新的目录。
mkdir remote-path
SFTP客户端视图
remote-path:远程SFTP服务器上的目录名。
# 在远程SFTP服务器上建立目录test。
sftp> mkdir test
1.2.16  put
put命令用来将本地的文件上传到远程SFTP服务器。
SFTP客户端视图
local-file:本地的文件名。
remote-file:远程SFTP服务器上的文件名。如果没有指定远程服务器上的文件名,则认为服务器上保存文件的文件名与本地的文件名相同。
# 将本地startup.bak文件上传到远程SFTP服务器,并以startup01.bak文件名保存。
sftp> put startup.bak startup01.bak
Uploading startup.bak to /startup01.bak
startup01.bak                                   100% 1424     1.4KB/s   00:00
1.2.17  pwd
pwd命令用来显示远程SFTP服务器上的当前工作目录。
pwd
SFTP客户端视图
# 显示远程SFTP服务器上的当前工作目录。
sftp> pwd
以上显示信息表示当前的工作目录为根目录。
1.2.18  quit
quit命令用来终止与远程SFTP服务器的连接,并退回到用户视图。
SFTP客户端视图
该命令功能与byeexit相同。
# 终止与远程SFTP服务器的连接。
sftp> quit
<Sysname>
1.2.19  remove
remove命令用来删除远程SFTP服务器上指定的文件。
remove remote-file
SFTP客户端视图
该命令和delete命令相同。
# 删除远程SFTP服务器上的文件temp.c。
sftp> remove temp.c
Removing /temp.c
1.2.20  rename
rename命令用来改变远程SFTP服务器上指定的文件或者文件夹的名字。
rename old-name new-name
SFTP客户端视图
old-name:原文件名或者文件夹名。
new-name:新文件名或者文件夹名。
# 将远程SFTP服务器上的文件temp1.c改名为temp2.c。
sftp> dir
aa.pub  temp1.c
sftp> rename temp1.c temp2.c
sftp> dir
aa.pub  temp2.c
1.2.21  rmdir
rmdir命令用来删除远程SFTP服务器上指定的目录。
rmdir remote-path
SFTP客户端视图
# 删除SFTP服务器上当前工作目录下的temp1目录。
sftp> rmdir temp1
1.2.22  scp
scp命令用来与远程的SCP服务器建立连接,并进行文件传输。
(非FIPS模式)
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] * [ user username [ password password [ no-more-input ] ] ]
(FIPS模式)
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { put | get } source-file-name [ destination-file-name ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-ctos-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-stoc-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] * [ user username [ password password [ no-more-input ] ] ]
server:服务器的IPv4地址或主机名称,为1~253个字符的字符串,不区分大小写。
port-number:服务器端口号,取值范围为1~65535,缺省值为22。
vpn-instance vpn-instance-name:服务器所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
get:指定下载文件操作。
put:指定上传文件操作。
source-file-name:源文件名称,为1~255个字符的字符串,区分大小写。
destination-file-name:目的文件名称,为1~255个字符的字符串,区分大小写。若未指定该参数,则表示使用源文件的名称作为目的文件名称。
identity-key:客户端publickey认证时采用的公钥算法,非FIPS模式下,缺省算法为dsa;FIPS模式下,缺省算法为rsa。如果服务器采用publickey认证,必须指定该参数。客户端使用指定算法的本地私钥生成数字签名或证书。
·     dsa:公钥算法为DSA。
·     ecdsa-sha2-nistp256:指定公钥长度为256的ECDSA算法。
·     ecdsa-sha2-nistp384:指定公钥长度为384的ECDSA算法。
·     rsa:公钥算法为RSA。
·     x509v3-ecdsa-sha2-nistp256:x509v3-ecdsa-sha2-nistp256公钥算法
·     x509v3-ecdsa-sha2-nistp384:x509v3-ecdsa-sha2-nistp384公钥算法。
·     pki-domain domain-name:指定客户端证书的PKI域,为1~31个字符的字符串,不区分大小写,公钥算法为x509v3时,指定客户端证书所在PKI域名称,才能得到正确的本地证书。
prefer-compress:服务器与客户端之间的首选压缩算法,缺省不支持压缩。
zlib:压缩算法ZLIB。
prefer-ctos-cipher:客户端到服务器端的首选加密算法,缺省算法为aes128-ctrdes-cbc3des-cbcaes128-cbcaes128-ctraes128-gcmaes192-ctraes256-cbcaes256-ctraes256-gcm算法的安全强度和运算花费时间依次递增。
·     3des-cbc:3DES-CBC加密算法。
·     aes128-cbc:128位的AES-CBC加密算法。
·     aes128-ctr:128位AES-CTR加密算法。
·     aes128-gcm:128位AES-GCM加密算法。
·     aes192-ctr:192位AES-CTR加密算法。
·     aes256-cbc:256位的AES-CBC加密算法。
·     aes256-ctr:256位AES-CTR加密算法。
·     aes256-gcm:256位AES-GCM加密算法。
·     des-cbc:DES-CBC加密算法。
prefer-ctos-hmac:客户端到服务器端的首选HMAC算法,缺省算法为sha2-256md5md5-96sha1sha1-96sha2-256sha2-512算法的安全强度和运算花费时间依次递增。
·     md5:HMAC算法HMAC-MD5。
·     md5-96:HMAC算法HMAC-MD5-96。
·     sha1:HMAC算法HMAC-SHA1。
·     sha1-96:HMAC算法HMAC-SHA1-96。
·     sha2-256:HMAC算法HMAC-SHA2-256。
·     sha2-512:HMAC算法HMAC-SHA2-512。
prefer-kex:密钥交换首选算法,缺省算法为ecdh-sha2-nistp256dh-group-exchange-sha1dh-group1-sha1dh-group14-sha1ecdh-sha2-nistp256ecdh-sha2-nistp384算法的安全强度和运算花费时间依次递增。
·     dh-group-exchange-sha1:密钥交换算法diffie-hellman-group-exchange-sha1。
·     dh-group1-sha1:密钥交换算法diffie-hellman-group1-sha1。
·     dh-group14-sha1:密钥交换算法diffie-hellman-group14-sha1。
·     ecdh-sha2-nistp256:密钥交换算法ecdh-sha2-nistp256。
·     ecdh-sha2-nistp384:密钥交换算法ecdh-sha2-nistp384。
prefer-stoc-cipher:服务器端到客户端的首选加密算法,缺省算法为aes128-ctr。支持的加密算法与客户端到服务器端的加密算法相同。
prefer-stoc-hmac:服务器端到客户端的首选HMAC算法,缺省算法为sha2-256。支持的加密算法与客户端到服务器端的HMAC算法相同。
public-key keyname:指定服务器端的主机公钥,用于验证服务器端的身份。其中,keyname表示已经配置的主机公钥名称,为1~64个字符的字符串,不区分大小写。
server-pki-domain domain-name:指定验证服务端证书的PKI域。其中,domain-name表示验证服务端证书的PKI域名称,为1~31个字符的字符串,不区分大小写,不能包括“~”、“*”、“\”、“|”、“:”、“.”、“<”、“>”、“"”和“'”。
source:指定与服务器通信的源IPv4地址或者源接口。缺省情况下,报文源IPv4地址为根据路由表项查找的发送此报文的出接口的主IPv4地址。为保证客户端与服务器之间的通信不会因为所指定的接口发生故障而中断,通常建议指定Loopback接口作为源接口,或者Loopback接口的IPv4地址作为源IPv4地址。
interface interface-type interface-number:指定源接口。interface-type interface-number为接口类型和接口编号。系统将使用该接口的IPv4地址作为发送报文的源IP地址。
ip ip-address:指定源IPv4地址。
user username:指定SCP用户名,为1~80个字符的字符串,区分大小写。若用户登录时用户名中携带ISP域名,则其形式为pureusername@domainpureusername/domaindomain\pureusername
password password:指定明文密码,为1~63个字符的字符串,区分大小写。
no-more-input:表示不再进行交互式输入。若未指定该参数,则表示执行该命令后,设备会打印提示信息,用户需要根据提示信息进行输入。
当客户端主机公钥算法协商成功为证书时,需要校验服务端证书是否正确,这样需要通过server-pki-domain指定服务端证书所在的PKI域名称,这样才能获取正确验证服务器证书。客户端使用保存在该PKI域中的CA证书对服务器证书进行合法性检查,无需提前保存服务器的公钥。如果客户端没有指定验证服务端证书所在的PKI域,则缺省使用客户端证书所在的PKI域进行验证。
如果不指定用户名和密码,则表示以交互方式输入用户名和密码。
如果SCP服务器对客户端的认证方式为publickey认证,则本命令指定的密码将被忽略。
如果指定no-more-input参数,则执行本命令后,设备不会在以下情况时输出交互提示信息:
·     如果输入的用户名或密码错误,设备不会提示再次输入用户名和密码,而是直接认证失败;
·     客户端首次访问服务器时,设备不提示是否保存服务器公钥,客户端直接保存服务器公钥到本地;
·     首次登录或密码过期时不提示修改密码。
当设备作为SCP服务器,SCP客户端在指定destination-file-name参数时,支持以下两种方式指定目标文件名称:
·     指定destination-file-name为目标文件名称且不携带文件路径,此时源文件将从服务器下载至客户端的当前工作目录或从客户端上传至服务器的当前工作目录。比如,需要将服务器上的remote.bin文件下载到客户端的当前工作目录并改名为local.bin,可以将destination-file-name直接指定为local.bin。
·     指定destination-file-name为目标文件名称并携带文件路径,此时源文件将从服务器下载至客户端的指定文件路径或从客户端上传至服务器的指定文件路径,同时将文件名称改为目标文件名称。比如,需要将服务器上的remote.bin文件下载到客户端的指定路径flash:/logfile下,并将文件名称修改为local.bin。可以将destination-file-name指定为flash:/logfile/local.bin或者logfile/local.bin。
# SCP客户端采用publickey认证方式,登录地址为200.1.1.1的远程SCP服务器,下载名为abc.txt的文件,采用如下连接策略,并指定服务器端的公钥名称为svkey:
·     首选密钥交换算法为dh-group14-sha1
·     服务器到客户端的首选加密算法为aes128-cbc
·     客户端到服务器的首选HMAC算法为sha1
·     服务器到客户端的HMAC算法为sha1-96
·     服务器与客户端之间的首选压缩算法为zlib
<Sysname> scp 200.1.1.1 get abc.txt prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey
scp client ipv6 source命令用来配置SCP客户端发送SCP报文使用的源IPv6地址。
undo scp client ipv6 source命令用来恢复缺省情况。
scp client ipv6 source { interface interface-type interface-number | ipv6 ipv6-address }
未配置SCP客户端使用的源IPv6地址,设备自动选择IPv6 SCP报文的源IPv6地址,具体选择原则请参见RFC 3484。
interface interface-type interface-number:指定接口下与报文目的地址最匹配的IPv6地址作为源地址。interface-type interface-number表示源接口类型与源接口编号。
ipv6 ipv6-address:指定源IPv6地址。
scp client ipv6 source命令指定的源地址对所有的IPv6 SCP连接有效,scp ipv6命令指定的源地址只对当前的SCP连接有效,后者优先级高。
# 指定SCP客户端发送SCP报文使用的源IPv6地址为2:2::2:2。
[Sysname] scp client ipv6 source ipv6 2:2::2:2
·     display scp client source
scp client source命令用来配置SCP客户端发送SCP报文使用的源IPv4地址。
undo scp client source命令用来恢复缺省情况。
scp client source { interface interface-type interface-number | ip ip-address }
未配置SCP客户端使用的源IPv4地址,SCP客户端发送SCP报文使用的源IPv4地址为设备路由指定的SCP报文出接口的主IP地址。
interface interface-type interface-number:指定接口的主IP地址作为源地址。interface-type interface-number表示源接口类型与源接口编号。
ip ip-address:指定源IP地址。
scp client source命令指定的源地址对所有的SCP连接有效,scp命令指定的源地址只对当前的SCP连接有效,后者优先级高。
# 指定SCP客户端发送SCP报文使用的源IP地址为192.168.0.1。
[Sysname] scp client source ip 192.168.0.1
1.2.25  scp ipv6
scp ipv6命令用来与远程的IPv6 SCP服务器建立连接,并进行文件传输。
(非FIPS模式)
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] * [ user username [ password password [ no-more-input ] ] ]
(FIPS模式)
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number  ] { put | get } source-file-name [ destination-file-name ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-ctos-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group14-sha1  | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-stoc-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] * [ user username [ password password [ no-more-input ] ] ]
server:服务器的IPv6地址或主机名称,为1~253个字符的字符串,不区分大小写。
-i interface-type interface-number:当前SCP客户端连接所使用的出接口的接口类型和接口编号。此参数用于SCP服务器的地址是链路本地地址的情况,而且指定的出接口必须具有链路本地地址。
get:指定下载文件操作。
put:指定上传文件操作。
destination-file-name:目的文件名称,为1~255个字符的字符串,区分大小写。不指定该参数时,表示使用源文件的名称作为目的文件名称。
·     dsa:公钥算法为DSA。
·     rsa:公钥算法为RSA。
zlib:压缩算法ZLIB。
source:指定与服务器通信的源IPv6地址或者源接口。缺省情况下,设备根据RFC 3484的规则自动选择一个源IPv6地址。为保证客户端与服务器之间的通信不会因为所指定的接口发生故障而中断,通常建议指定Loopback接口作为源接口,或者Loopback接口的IPv6地址作为源地址。
interface interface-type interface-number:指定源接口。interface-type interface-number为接口类型和接口编号。系统将使用该接口的IPv6地址作为发送报文的源IP地址。
当设备作为IPv6 SCP服务器,SCP客户端在指定destination-file-name参数时,支持以下两种方式指定目标文件名称:
# SCP客户端采用publickey认证方式,登录地址为2000::1的远程SCP服务器,下载名为abc.txt的文件,采用如下连接策略,并指定服务器端的公钥名称为svkey:
<Sysname> scp ipv6 2000::1 get abc.txt prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey
scp ipv6 suite-b命令用来与远程的ipv6 SCP服务器建立基于Suite B算法集的连接,并进行文件传输。
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { put | get } source-file-name [ destination-file-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ source { interface interface-type interface-number | ipv6 ipv6-address } ] * [ user username [ password password [ no-more-input ] ] ]
vpn-instance vpn-instance-name:服务器所属的VPN。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
-i interface-type interface-number:当前SCP客户端连接所使用的出接口的接口类型和接口编号。本参数用于SCP服务器的地址是链路本地地址的情况,而且指定的出接口必须具有链路本地地址。
get:指定下载文件操作。
put:指定上传文件操作。
destination-file-name:目的文件名称,为1~255个字符的字符串,区分大小写。若未指定本参数,则表示使用源文件名称作为目的文件名称。
suite-b:指定采用Suite B算法集。若未指定128-bit和192-bit参数,则表示同时采用128-bit和192-bit的算法集。
128-bit:指定客户端采用安全级别为128-bit的Suite B算法集。
192-bit:指定客户端采用安全级别为192-bit的Suite B算法集。
pki-domain domain-name:配置客户端证书的PKI域。domain-name为客户端证书的PKI域名称,为1~31个字符的字符串,不区分大小写,不能包括“~”、“*”、“\”、“|”、“:”、“.”、“<”、“>”、“"”和“'”。
server-pki-domain domain-name:配置验证服务端证书的PKI域。domain-name为验证服务端证书的PKI域名称,为1~31个字符的字符串,不区分大小写,不能包括“~”、“*”、“\”、“|”、“:”、“.”、“<”、“>”、“"”和“'”。如果客户端没有指定验证服务端证书所在的PKI域,则缺省使用客户端证书所在的PKI域进行验证。
prefer-compress:服务器与客户端之间的首选压缩算法,缺省情况下,不支持压缩。
zlib:压缩算法ZLIB。
interface interface-type interface-number:指定源接口。interface-type interface-number为接口类型和接口编号。系统将使用该接口的IPv6地址作为发送报文的源IPv6地址。
当客户端采用安全级别为128-bit的Suite B算法集与远程的SCP服务器建立连接时,客户端算法要求:
·     密钥交换算法为ecdh-sha2-nistp256
·     服务器到客户端的加密算法为aes128-gcm
·     客户端到服务器的加密算法为aes128-gcm
·     服务器到客户端的HMAC算法为aes128-gcm
·     客户端到服务器的HMAC算法为aes128-gcm
·     主机公钥算法为x509v3-ecdsa-sha2-nistp256
当客户端采用安全级别为192-bit的Suite B算法集与远程的SCP服务器建立连接时,客户端算法要求:
·     密钥交换算法为ecdh-sha2-nistp384
·     服务器到客户端的加密算法为aes256-gcm
·     客户端到服务器的加密算法为aes256-gcm
·     服务器到客户端的HMAC算法为aes256-gcm
·     客户端到服务器的HMAC算法为aes256-gcm
·     主机公钥算法为x509v3-ecdsa-sha2-nistp384
当客户端未采用安全级别为128-bit和192-bit的Suite B算法集与远程的SCP服务器建立连接时,客户端算法要求:
·     密钥交换算法为ecdh-sha2-nistp256ecdh-sha2-nistp384
·     服务器到客户端的加密算法为aes128-gcmaes256-gcm
·     客户端到服务器的加密算法为aes128-gcmaes256-gcm
·     服务器到客户端的HMAC算法为aes128-gcmaes256-gcm
·     客户端到服务器的HMAC算法为aes128-gcmaes256-gcm
·     主机公钥算法为x509v3-ecdsa-sha2-nistp256x509v3-ecdsa-sha2-nistp384
# SCP客户端采用安全级别为192-bit的Suite B算法集,与登录地址为2000::1的远程SCP服务器建立连接,下载名为abc.txt的文件,采用如下连接策略:指定客户端证书的PKI域名称为clientpkidomain,指定验证服务端证书的PKI域名称为serverpkidomain。
<Sysname> scp ipv6 2000::1 get abc.txt suite-b 192-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username:
1.2.27  scp suite-b
scp suite-b命令用来与远程的SCP服务器建立基于Suite B算法集的连接,并进行文件传输。
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { put | get } source-file-name [ destination-file-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ source { interface interface-type interface-number | ip ip-address } ] * [ user username [ password password [ no-more-input ] ] ]
get:指定下载文件操作。
put:指定上传文件操作。
zlib:压缩算法ZLIB。
source:指定与服务器通信的源IP地址或者源接口。缺省情况下,设备根据路由表项自动选择一个源IPv4地址。为保证客户端与服务器之间的通信不会因为所指定的接口发生故障而中断,通常建议指定Loopback接口作为源接口,或者Loopback接口的IP地址作为源地址。
# SCP客户端采用安全级别为128-bit的Suite B算法集,与登录地址为200.1.1.1的远程SCP服务器建立连接,下载名为abc.txt的文件,采用如下连接策略:指定客户端证书的PKI域名称为clientpkidomain,指定验证服务端证书的PKI域名称为serverpkidomain。
<Sysname> scp 200.1.1.1 get abc.txt suite-b 128-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username:
1.2.28  sftp
sftp命令用来与远程IPv4 SFTP服务器建立连接,并进入SFTP客户端视图。
(非FIPS模式)
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
(FIPS模式)
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-ctos-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-stoc-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
server:服务器IPv4地址或主机名称,为1~253个字符的字符串,不区分大小写。
·     dsa:公钥算法为DSA。
·     rsa:公钥算法为RSA。
·     x509v3-ecdsa-sha2-nistp256:x509v3-ecdsa-sha2-nistp256钥算法。
zlib:压缩算法ZLIB。
dscp dscp-value:指定客户端发送的SFTP报文中携带的DSCP优先级,取值范围为0~63,缺省值为48。DSCP携带在IP报文中的ToS字段,用来体现报文自身的优先等级,决定报文传输的优先程度。
interface interface-type interface-number:指定源接口。interface-type interface-number为接口类型和接口编号。系统将采用该接口的主IPv4地址作为发送报文的源IP地址。
# SFTP客户端采用publickey认证方式,连接IP地址为10.1.1.2的SFTP服务器,采用如下连接策略,并指定服务器端的公钥名称为svkey:
<Sysname> sftp 10.1.1.2 prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey
sftp client ipv6 source命令用来配置SFTP客户端发送SFTP报文使用的源IPv6地址。
undo sftp client ipv6 source命令用来恢复缺省情况。
sftp client ipv6 source { interface interface-type interface-number | ipv6 ipv6-address }
未配置SFTP客户端使用的源IPv6地址,设备自动选择IPv6 SFTP报文的源IPv6地址,具体选择原则请参见RFC 3484。
sftp client ipv6 source命令指定的源地址对所有的SFTP连接有效,sftp ipv6命令指定的源地址只对当前的SFTP连接有效。
使用该命令指定了源地址后,若SFTP用户使用sftp ipv6命令登录时又指定了源地址,则采用sftp ipv6命令中指定的源地址。
# 指定SFTP客户端发送SFTP报文使用的源IPv6地址为2:2::2:2。
[Sysname] sftp client ipv6 source ipv6 2:2::2:2
·     display sftp client source
sftp client source命令用来配置SFTP客户端发送SFTP报文使用的源IPv4地址。
undo sftp client source命令用来恢复缺省情况。
sftp client source { interface interface-type interface-number | ip ip-address }
未配置SFTP客户端使用的源IPv4地址,SFTP客户端发送SFTP报文使用的源IPv4地址为根据路由表项查找的发送此报文的出接口的主IP地址。
sftp client source命令指定的源地址对所有的SFTP连接有效,sftp命令指定的源地址只对当前的SFTP连接有效。
使用该命令指定了源地址后,若SFTP用户使用sftp命令登录时又指定了源地址,则采用sftp命令中指定的源地址。
# 指定SFTP客户端发送SFTP报文使用的源IP地址为192.168.0.1。
[Sysname] sftp client source ip 192.168.0.1
1.2.31  sftp ipv6
sftp ipv6命令用来建立SFTP客户端和与远程IPv6 SFTP服务器建立连接,并进入SFTP客户端视图。
(非FIPS模式)
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
(FIPS模式)
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-ctos-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-stoc-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
-i interface-type interface-number:客户端连接服务器时使用的出接口。其中,interface-type interface-number表示接口类型和接口编号。本参数仅在客户端所连接的服务器的地址是链路本地地址时使用。指定的出接口必须具有链路本地地址。
·     dsa:公钥算法为DSA。
·     rsa:公钥算法为RSA。
·     x509v3-ecdsa-sha2-nistp256:x509v3-ecdsa-sha2-nistp256公钥算法。
zlib:压缩算法ZLIB。
dscp dscp-value:指定客户端发送的IPv6 SFTP报文中携带的DSCP优先级,取值范围为0~63,缺省值为48。DSCP携带在IPv6报文中的Traffic class字段,用来体现报文自身的优先等级,决定报文传输的优先程度。
# SFTP客户端采用publickey认证方式,连接IPv6地址为2000::1的SFTP服务器,采用如下连接策略,并指定服务器端的公钥名称为svkey:
<Sysname> sftp ipv6 2000::1 prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey
Username:
sftp ipv6 suite-b命令用来与远程的ipv6 SFTP服务器建立基于Suite B算法集的连接,并进入SFTP客户端视图。
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
zlib:压缩算法ZLIB。
当客户端采用安全级别为128-bit的Suite B算法集与远程的SFTP服务器建立连接时,客户端算法要求:
当客户端采用安全级别为192-bit的Suite B算法集与远程的SFTP服务器建立连接时,客户端算法要求:
当客户端未采用安全级别为128-bit和192-bit的Suite B算法集与远程的SFTP服务器建立连接时,客户端算法要求:
# SFTP客户端采用安全级别为192-bit的Suite B算法集,与登录地址为2000::1的远程SFTP服务器建立连接,采用如下连接策略:指定客户端证书的PKI域名称为clientpkidomain,指定验证服务端证书的PKI域名称为serverpkidomain。
<Sysname> sftp ipv6 2000::1 suite-b 192-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username:
1.2.33  sftp suite-b
sftp suite-b命令用来与远程的IPv4 SFTP服务器建立基于Suite B算法集的连接,并进入SFTP客户端视图。
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | source { interface interface-type interface-number | ip ip-address } ] *
zlib:压缩算法ZLIB。
# SFTP客户端采用安全级别为128-bit的Suite B算法集,与登录地址为10.1.1.2的远程SFTP服务器建立连接,采用如下连接策略:指定客户端证书的PKI域名称为clientpkidomain,指定验证服务端证书的PKI域名称为serverpkidomain。
<Sysname> sftp 10.1.1.2 suite-b 128-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username:
ssh client ipv6 source命令用来为配置Stelnet客户端发送SSH报文使用的源IPv6地址。
undo ssh client ipv6 source命令用来恢复缺省情况。
未配置Stelnet客户端使用的源IPv6地址,设备自动选择IPv6 SSH报文的源IPv6地址,具体选择原则请参见RFC 3484。
ssh client ipv6 source命令指定的源地址对所有的IPv6 Stelnet连接有效,ssh2 ipv6命令指定的源地址只对当前的Stelnet连接有效。
使用该命令指定了源地址后,若SSH用户使用ssh2 ipv6命令登录时又指定了源地址,则采用ssh2 ipv6命令中指定的源地址。
# 指定Stelnet客户端发送SSH报文使用的源IPv6地址为2:2::2:2。
[Sysname] ssh client ipv6 source ipv6 2:2::2:2
·     display ssh client source
ssh client source命令用来配置Stelnet客户端发送SSH报文使用的源IPv4地址。
undo ssh client source命令用来恢复缺省情况。
未配置Stelnet客户端使用的源IPv4地址,Stelnet客户端发送SSH报文使用的源IPv4地址为设备路由指定的SSH报文出接口的主IP地址。
ssh client source命令指定的源地址对所有的Stelnet连接有效,ssh2命令指定的源地址只对当前的Stelnet连接有效。
使用该命令指定了源地址后,若SSH用户使用ssh2命令登录时又指定了源地址,则采用ssh2命令中指定的源地址。
# 指定Stelnet客户端发送SSH报文使用的源IPv4地址为192.168.0.1。
[Sysname] ssh client source ip 192.168.0.1
1.2.36  ssh2
ssh2命令用来建立Stelnet客户端和IPv4 Stelnet服务器端的连接。
(非FIPS模式)
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
(FIPS模式)
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-gcm | aes256-gcm } | prefer-ctos-hmac { sha2-256 | sha2-512 } | prefer-kex { ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-gcm | aes256-gcm } | prefer-stoc-hmac { sha2-256 | sha2-512 }] * [ escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
·     dsa:公钥算法为DSA。
·     rsa:公钥算法为RSA。
zlib:压缩算法ZLIB。
prefer-kex:密钥交换首选算法,缺省算法为ecdh-sha2-nistp256dh-group-exchange-sha1dh-group14-sha1ecdh-sha2-nistp256ecdh-sha2-nistp384算法的安全强度和运算花费时间依次递增。
escape character:指定退出字符。character为一个字符,区分大小写,缺省为~,即输入~.可以强制断开与服务端的连接。
source:指定与服务器通信的源IPv4地址或者源接口。缺省情况下,报文源IPv4地址为根据路由表项查找的发送此报文的出接口的主IPv4地址。为保证客户端与服务器之间的通信不会因为所指定的接口发生故障而中断,通常建议指定Loopback接口作为源接口,或者Loopback接口的IPv4地址作为源地址。
关于退出字符的使用,需要注意的是:
·     退出字符与字符.配合使用可以强制断开客户端与服务器连接(该方式通常用于服务器端重启或发生异常的情况下,客户端快速中断当前连接)。
·     必须在一行中首先输入退出字符和.,该操作才能生效,若该行中曾经输入过其它字符或执行了其它操作(比如退格),则需要重新换行输入才能生效。
·     一般情况下,建议使用缺省退出字符,避免退出字符和.的组合与登录用户名相同。
# Stelnet客户端采用publickey认证方式,登录地址为3.3.3.3的远程Stelnet服务器,采用如下连接策略,并指定服务器端的公钥名称为svkey:
·     输入$.时强制断开客户端和服务端的连接。
<Sysname> ssh2 3.3.3.3 prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey escape $
1.2.37  ssh2 ipv6
ssh2 ipv6命令用来建立Stelnet客户端和IPv6 Stelnet服务器端的连接。
(非FIPS模式)
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
(FIPS模式)
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-gcm | aes256-gcm } | prefer-ctos-hmac { sha2-256 | sha2-512 } | prefer-kex { ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-gcm | aes256-gcm } | prefer-stoc-hmac { sha2-256 | sha2-512 } ] * [ escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
·     dsa:公钥算法为DSA。
·     rsa:公钥算法为RSA。
zlib:压缩算法ZLIB。
dscp dscp-value:指定客户端发送的IPv6 SSH报文中携带的DSCP优先级,取值范围为0~63,缺省值为48。DSCP携带在IPv6报文中的Traffic class字段,用来体现报文自身的优先等级,决定报文传输的优先程度。
关于退出字符的使用,需要注意的是:
# SSH客户端采用publickey认证方式,登录地址为2000::1的远程Stelnet服务器,采用如下连接策略,并指定服务器端的公钥名称为svkey:
<Sysname> ssh2 ipv6 2000::1 prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey escape $
ssh2 ipv6 suite-b命令用来与远程的ipv6 Stelnet服务器建立基于Suite B算法集的连接。
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | escape character | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
zlib:压缩算法ZLIB。
escape character:指定退出字符,该退出字符与字符.配合使用可以强制断开客户端与服务器连接(该方式通常用于服务器端重启或发生异常的情况下,客户端快速中断当前连接)。character为一个字符,区分大小写,缺省为~,即输入~.可以强制断开与服务端的连接。
关于退出字符的使用,需要注意的是:
当客户端采用安全级别为128-bit的Suite B算法集与远程的Stelnet服务器建立连接时,客户端算法要求:
当客户端采用安全级别为192-bit的Suite B算法集与远程的Stelnet服务器建立连接时,客户端算法要求:
当客户端未采用安全级别为128-bit和192-bit的Suite B算法集与远程的Stelnet服务器建立连接时,客户端算法要求:
# SSH客户端采用安全级别为192-bit的Suite B算法集,与登录地址为2000::1的远程Stelnet服务器建立连接,采用如下连接策略:指定客户端证书的PKI域名称为clientpkidomain,指定验证服务端证书的PKI域名称为serverpkidomain。
<Sysname> ssh2 ipv6 2000::1 suite-b 192-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username:
1.2.39  ssh2 suite-b
ssh2 suite-b命令用来与远程的IPv4 Stelnet服务器建立基于Suite B算法集的连接。
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | escape character | source { interface interface-type interface-number | ip ip-address } ] *
zlib:压缩算法ZLIB。
关于退出字符的使用,需要注意的是:
# Stelnet客户端采用128-bit的Suite B算法集,与登录地址为3.3.3.3的远程Stelnet服务器建立连接,采用如下连接策略:指定客户端证书的PKI域名称为clientpkidomain,指定验证服务端证书的PKI域名称为serverpkidomain。
<Sysname> ssh2 3.3.3.3 suite-b 128-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username:
1.3  SSH2协议配置命令
display ssh2 algorithm命令用来显示设备上配置的SSH2协议使用的算法优先列表。
# 显示设备上配置的SSH2协议使用的算法优先列表。
<Sysname> display ssh2 algorithm
 Key exchange algorithms: ecdh-sha2-nistp256 ecdh-sha2-nistp384 dh-group-exchange-sha1 dh-group14-sha1 dh-group1-sha1
 Public key algorithms: x509v3-ecdsa-sha2-nistp256 x509v3-ecdsa-sha2-nistp384 ecdsa-sha2-nistp256 ecdsa-sha2-nistp384 rsa dsa
 Encryption algorithms: aes128-ctr aes192-ctr aes256-ctr aes128-gcm aes256-gcm aes128-cbc 3des-cbc aes256-cbc des-cbc
 MAC algorithms: sha2-256 sha2-512 sha1 md5 sha1-96 md5-96
表1-7 display ssh2 algorithm命令显示信息描述表
按优先级前后顺序显示当前使用的密钥交换算法列表
按优先级前后顺序显示当前使用的主机算法列表
按优先级前后顺序显示当前使用的加密算法列表
MAC algorithms
按优先级前后顺序显示当前使用的HMAC算法列表
·     ssh2 algorithm key-exchange
·     ssh2 algorithm public-key
·     ssh2 algorithm cipher
·     ssh2 algorithm mac
ssh2 algorithm cipher命令用来配置SSH2协议使用的加密算法列表。
undo ssh2 algorithm cipher命令用来恢复缺省情况。
(非FIPS模式)
ssh2 algorithm cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes128-gcm@openssh | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | aes256-gcm@openssh | des-cbc } *
(FIPS模式)
ssh2 algorithm cipher { aes128-gcm | aes128-gcm@openssh | aes256-gcm | aes256-gcm@openssh } *
(非FIPS模式)
SSH2协议采用的缺省加密算法从高到低的优先级列表为aes128-ctraes192-ctraes256-ctraes128-gcm@opensshaes256-gcm@opensshaes128-gcmaes256-gcmaes128-cbc3des-cbcaes256-cbcdes-cbc
(FIPS模式)
SSH2协议采用的缺省加密算法从高到低的优先级列表为aes128-gcm@opensshaes256-gcm@opensshaes128-gcmaes256-gcm
aes128-cbc:128位AES-CBC加密算法。
aes128-gcm@openssh:OpenSSH版128位AES-GCM加密算法。
aes256-cbc:256位AES-CBC加密算法。
aes256-gcm@openssh:OpenSSH版256位AES-GCM加密算法。
当设备运行环境要求SSH2只能采用特定加密算法的情况下,可采用本命令将设备上的SSH2客户端、SSH2服务器所能使用的加密算法限定在配置的范围内。算法的配置顺序即为算法的优先级顺序。当SSH2客户端或者服务器需要与第三方OpenSSH软件对接时,可以配置OpenSSH版的加密算法(aes128-gcm@openssh、aes256-gcm@openssh)。
# 配置SSH2协议所使用的加密算法为aes256-cbc
[Sysname] ssh2 algorithm cipher aes256-cbc
·     display ssh2 algorithm
ssh2 algorithm key-exchange命令用来配置SSH2协议使用的密钥交换算法列表。
undo ssh2 algorithm key-exchange命令用来恢复缺省情况。
(非FIPS模式)
ssh2 algorithm key-exchange { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } *
(FIPS模式)
ssh2 algorithm key-exchange { ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } *
(非FIPS模式)
SSH2协议采用的缺省密钥交换算法从高到低的优先级列表为ecdh-sha2-nistp256ecdh-sha2-nistp384dh-group-exchange-sha1dh-group14-sha1dh-group1-sha1
(FIPS模式)
SSH2协议采用的缺省密钥交换算法从高到低的优先级列表为ecdh-sha2-nistp256 ecdh-sha2-nistp384
当设备运行环境要求SSH2只能采用特定密钥交换算法的情况下,可采用本命令将设备上的SSH2客户端、SSH2服务器所能使用的密钥交换算法限定在配置的范围内。算法的配置顺序即为算法的优先级顺序。
# 配置SSH2协议所使用的密钥交换算法为dh-group1-sha1。
[Sysname] ssh2 algorithm key-exchange dh-group1-sha1
ssh2 algorithm mac命令用来配置SSH2协议使用的HMAC算法列表。
undo ssh2 algorithm mac命令用来恢复缺省情况。
(非FIPS模式)
ssh2 algorithm mac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } *
(FIPS模式)
ssh2 algorithm mac { sha2-256 | sha2-512 } *
(非FIPS模式)
SSH2协议使用的缺省HMAC算法从高到底的优先级列表为sha2-256sha2-512sha1md5sha1-96md5-96
(FIPS模式)
SSH2协议使用的缺省HMAC算法从高到低的优先级列表为sha2-256sha2-512
md5:HMAC算法HMAC-MD5。
当设备运行环境要求SSH2只能采用特定HMAC算法的情况下,可采用本命令将设备上的SSH2客户端、SSH2服务器所能使用的HMAC算法限定在配置的范围内。算法的配置顺序即为算法的优先级顺序。
# 配置SSH2协议所使用的HMAC算法为md5。
[Sysname] ssh2 algorithm mac md5
ssh2 algorithm public-key命令用来配置SSH2协议使用的主机签名算法列表。
undo ssh2 algorithm public-key命令用来恢复缺省情况。
(非FIPS模式)
ssh2 algorithm public-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } *
(FIPS模式)
ssh2 algorithm public-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } *
SSH2协议使用的缺省主机签名算法从高到低的优先级列表为x509v3-ecdsa-sha2-nistp256x509v3-ecdsa-sha2-nistp384ecdsa-sha2-nistp256ecdsa-sha2-nistp384rsadsa
dsa:公钥算法为DSA。
rsa:公钥算法为RSA。
当设备运行环境要求SSH2只能采用特定主机签名算法的情况下,可采用本命令将设备上的SSH2客户端、SSH2服务器所能使用的主机签名算法限定在配置的范围内。算法的配置顺序即为算法的优先级顺序。
# 配置SSH2协议所使用的主机签名算法为dsa
[Sysname] ssh2 algorithm public-key dsa
