13-可靠性命令参考
07-VRRP命令
本章节下载 07-VRRP命令  (721.89 KB)
07-VRRP命令
1 VRRP
1.1 IPv4 VRRP配置命令
1.1.1 display vrrp
1.1.2 display vrrp binding
1.1.3 display vrrp statistics
1.1.4 reset vrrp statistics
1.1.5 snmp-agent trap enable vrrp
1.1.6 vrrp check-ttl enable
1.1.7 vrrp dot1q
1.1.8 vrrp dscp
1.1.9 vrrp isolate enable
1.1.10 vrrp mode
1.1.11 vrrp send-gratuitous-arp
1.1.12 vrrp send-gratuitous-arp enhance enable
1.1.13 vrrp state-transition-delay
1.1.14 vrrp version
1.1.15 vrrp vrid
1.1.16 vrrp vrid authentication-mode
1.1.17 vrrp vrid backup-arp
1.1.18 vrrp vrid follow
1.1.19 vrrp vrid gratuitous-arp copy-to-member
1.1.20 vrrp vrid ignore-interface-down
1.1.21 vrrp vrid initialize state-hold-time
1.1.22 vrrp vrid name
1.1.23 vrrp vrid preempt-mode
1.1.24 vrrp vrid priority
1.1.25 vrrp vrid shutdown
1.1.26 vrrp vrid source-interface
1.1.27 vrrp vrid timer advertise
1.1.28 vrrp vrid track
1.1.29 vrrp vrid vrrpv3-send-packet
1.2 IPv6 VRRP配置命令
1.2.1 display vrrp ipv6
1.2.2 display vrrp ipv6 binding
1.2.3 display vrrp ipv6 statistics
1.2.4 reset vrrp ipv6 statistics
1.2.5 vrrp ipv6 dot1q
1.2.6 vrrp ipv6 dscp
1.2.7 vrrp ipv6 isolate enable
1.2.8 vrrp ipv6 mode
1.2.9 vrrp ipv6 send-nd
1.2.10 vrrp ipv6 send-nd enhance enable
1.2.11 vrrp ipv6 state-transition-delay
1.2.12 vrrp ipv6 vrid
1.2.13 vrrp ipv6 vrid follow
1.2.14 vrrp ipv6 vrid ignore-interface-down
1.2.15 vrrp ipv6 vrid initialize state-hold-time
1.2.16 vrrp ipv6 vrid name
1.2.17 vrrp ipv6 vrid nd copy-to-member
1.2.18 vrrp ipv6 vrid preempt-mode
1.2.19 vrrp ipv6 vrid priority
1.2.20 vrrp ipv6 vrid shutdown
1.2.21 vrrp ipv6 vrid source-interface
1.2.22 vrrp ipv6 vrid timer advertise
1.2.23 vrrp ipv6 vrid track
1 VRRP
提示
在聚合组的成员端口上配置VRRP不生效。
1.1  IPv4 VRRP配置命令
1.1.1  display vrrp
display vrrp命令用来显示IPv4 VRRP备份组的状态信息。
display vrrp [ interface interface-type interface-number [ vrid virtual-router-id ] ] [ verbose ]
interface interface-type interface-number:显示指定接口的IPv4 VRRP备份组状态信息。其中,interface-type interface-number为接口类型和接口编号。
vrid virtual-router-id:显示指定IPv4 VRRP备份组的状态信息。其中,virtual-router-id为IPv4 VRRP备份组号,取值范围为1~255。
verbose:显示IPv4 VRRP备份组状态的详细信息。如果未指定本参数,则显示IPv4 VRRP备份组状态的简要信息。
如果未指定接口名和备份组号,则显示该路由器上所有IPv4 VRRP备份组的状态信息;如果只指定接口名,未指定备份组号,则显示该接口上的所有IPv4 VRRP备份组的状态信息;如果同时指定接口名和备份组号,则显示该接口上指定IPv4 VRRP备份组的状态信息。
# VRRP工作在标准协议模式时,显示全部IPv4 VRRP备份组的简要信息。
<Sysname> display vrrp
IPv4 virtual router information:
 Running mode : Standard
 Gratuitous ARP sending interval : 120 seconds
 Enhanced sending of gratuitous ARP packets : Disabled
 Interface          VRID  State       Running Adver     Auth    Virtual
                                      pri     timer(cs) type    IP
 RAGG10             10    Initialize  100     100       None    10.10.10.1
 XGE3/0/1           1     Initialize  100     100       None    1.1.1.1
表1-1 display vrrp命令显示信息描述表(标准协议模式)
IPv4 VRRP备份组的信息
Running mode
VRRP的工作模式,取值为Standard(标准协议模式)
免费ARP报文发送时间间隔,只有配置了vrrp send-gratuitous-arp命令才显示此字段
Enhanced sending of gratuirous ARP packets
VRRP备份组增强发送免费ARP报文功能的开启状态,取值为:
·     Enabled:表示功能开启
·     Disabled:表示功能关闭
备份组的数目
备份组所在接口名
VRID
虚拟路由器号(即备份组号)
当前路由器在备份组中的状态,取值为:
·     Master表示设备为VRRP备份组中的Master路由器
·     Backup表示设备为VRRP备份组中的Backup路由器
·     Initialize表示设备上VRRP备份组处于关闭状态
·     Inactive表示VRRP备份组处于无效状态,原因可能为:未配置虚拟IP地址,或者关联了管理备份组,但是关联的管理备份组不存在
Running pri
路由器的运行优先级,即路由器当前的优先级。配置监视指定Track项后,路由器的优先级会根据Track项的状态改变
Adver timer(cs)
VRRP通告报文发送时间间隔,单位为厘秒
Auth type
认证类型,取值包括:
·     None:无认证
·     Simple:简单字符认证
·     MD5:MD5认证
Virtual IP
备份组的虚拟IP地址
·     如果用户给VRRP备份组配置了多个虚拟IP地址,此处仅显示取值最小的IP地址
·     如需显示给VRRP备份组配置的所有虚拟IP地址,请指定verbose参数
# VRRP工作在标准协议模式时,显示全部IPv4 VRRP备份组的详细信息。
<Sysname> display vrrp verbose
 Total number of virtual routers : 5
   Interface Route-Aggregation10
     VRID             : 10                  Adver timer  : 100 centiseconds
     Admin status     : Up                  State        : Initialize
     Config pri       : 100                 Running pri  : 100
     Preempt mode     : Yes                 Delay time   : 0 centiseconds
     Auth type        : None
     Version          : 3
     Virtual IP       : 10.10.10.1
     Master IP        : 0.0.0.0
     Backup ARP       : Disabled
     Copy-to-member   : Disabled
   Interface Ten-GigabitEthernet3/0/1
     VRID             : 1                    Adver timer  : 100 centiseconds
     Admin status     : Up                   State        : Master
     Config pri       : 150                  Running pri  : 150
     Preempt mode     : Yes                  Delay time   : 5 centiseconds
     Auth type        : Simple               Key          : ******
     Pkt sending mode : v2-only
     Version          : 2
     Virtual IP       : 1.1.1.1
     Virtual MAC      : 0000-5e00-0101
     Master IP        : 1.1.1.2
     Config role      : Master
     Backup ARP       : Enabled
   VRRP track information:
     Track object   : 1                    State : Positive   Pri reduced : 50
     VRID             : 2                    Adver timer  : 100 centiseconds
     Admin status     : Up                   State        : Backup
     Config pri       : 80                   Running pri  : 80
     Become master    : 2370 milliseconds left
     Auth type        : None
     Version          : 2
     Virtual IP       : 1.1.1.11
     Master IP        : 1.1.1.12
     VRID             : 3                    Adver timer : 100 centiseconds
     Auth type        : None
     Version          : 2
     Virtual IP       : 1.1.1.10
     Virtual MAC      : 0000-5e00-0103
     Master IP        : 1.1.1.2
     Config role      : Subordinate
     Follow name      : abc
   Interface Ten-GigabitEthernet3/0/2
     VRID             : 4                    Adver timer : 100 centiseconds
     State transition : 3700 milliseconds left
     Auth type        : None
     Version          : 2
     Virtual IP       : 1.1.1.110
     Master IP        : 0.0.0.0
表1-2 display vrrp verbose命令显示信息描述表(标准协议模式)
Running mode
·     Enabled:表示功能开启
·     Disabled:表示功能关闭
备份组的数目
备份组所在接口名
VRID
虚拟路由器号(即备份组号)
Adver timer
Admin status
管理状态,包括Up和Down两种状态
当前路由器在备份组中的状态,取值为:
Config pri
路由器的配置优先级,即通过vrrp vrid priority命令指定的路由器优先级
Running pri
路由器的运行优先级,即路由器当前的优先级,配置监视指定Track项后,路由器的优先级会根据Track项的状态改变
Preempt mode
抢占模式,取值包括:
·     Yes:路由器工作在抢占模式
·     No:路由器工作在非抢占模式
Delay time
抢占延迟时间,单位为厘秒
State transition
VRRP从Initialize状态切换到Master(或Backup)状态的需要等待的时间,单位为毫秒。只有配置了vrrp state-transition-delay命令后VRRP备份组处于Initialize状态,接口显示状态和VRRP备份组管理状态都为up时,才会显示此信息
Become master
切换到Master状态需要等待的时间,单位为毫秒,只有处于Backup状态时才会显示此信息
Auth type
认证类型,取值包括:
·     None:无认证
·     Simple:简单字符认证
·     MD5:MD5认证
Key
认证字,无认证时不显示此信息
Pkt sending mode
报文发送模式,只有配置vrrp vrid vrrpv3-send-packet命令才显示该字段,取值包括:
·     v2-only:路由器只发送版本号为2的报文
·     v2v3-both:路由器发送版本号为2和版本号为3的报文
Version
VRRP使用的版本号
Virtual IP
备份组的虚拟IP地址
Virtual MAC
备份组虚拟IP地址对应的虚拟MAC地址。只在路由器为Master状态时,才会显示此信息
Master IP
处于Master状态的路由器所对应接口的主IP地址
Config role
路由器角色,取值包括:
·     Master:管理备份组路由器
·     Subordinate:成员备份组路由器
Name
管理备份组名称,只有配置了vrrp vrid name命令才会显示此信息
Follow name
VRRP备份组所关联的管理组名称,只有配置了vrrp vrid follow命令才会显示此信息
Backup ARP
VRRP备份组的ARP表项备份功能状态,取值包括:
·     Disabled:关闭状态
·     Enabled:开启状态
Copy-to-member
VRRP复制免费ARP报文功能开启状态,取值包括:
·     Enabled:功能处于开启状态
·     Disabled:功能处于关闭状态
仅以太网聚合接口和以太网聚合子接口支持显示该信息
VRRP备份组监视的Track项信息。执行vrrp vrid track命令后,才会显示此信息
Track object
监视的Track项
Track项的状态,Track项的状态可包括Negative、Positive和NotReady
Pri reduced
监视的Track项状态为Negative时,优先级降低的数额
Switchover
快速切换。显示此信息时表示当监视的Track项变为Negative状态时,Backup路由器会马上抢占成为Master路由器
# VRRP工作在负载均衡模式时,显示全部IPv4 VRRP备份组的简要信息。
 Running mode      : Load balance
 Interface          VRID  State        Running Address             Active
                                       pri
 XGE3/0/1           1     Master       150     1.1.1.1             Local
 -----              VF1   Active       255     000f-e2ff-0011      Local
表1-3 display vrrp命令显示信息描述表(负载均衡模式)
Running mode
VRRP的工作模式,取值为Load balance(负载均衡模式)
备份组的数目
备份组所在接口名
VRID
虚拟路由器号(即备份组号)number或虚拟转发器编号VF number
对于虚拟备份组,该字段表示当前路由器在备份组中的状态,取值为:
对于虚拟转发器,该字段表示虚拟转发器的状态,取值为:
·     Active表示虚拟转发器处于转发状态
·     Listening表示虚拟转发器处于侦听状态(即备份状态)
·     Initialize表示虚拟转发器处于初始状态
Running pri
对于虚拟备份组,该字段表示路由器的运行优先级,即路由器当前的优先级,配置监视指定Track项后,路由器的优先级会根据Track项的状态改变
对于虚拟转发器,该字段表示虚拟转发器的运行优先级,配置监视指定Track项后,虚拟转发器的优先级会根据Track项的状态改变
Address
·     对于虚拟备份组,该字段表示备份组的虚拟IP地址:
¡     如果用户给VRRP备份组配置了多个虚拟IP地址,此处仅显示取值最小的IP地址
¡     如需显示给VRRP备份组配置的所有虚拟IP地址,请指定verbose参数
·     对于虚拟转发器,该字段表示虚拟转发器的虚拟MAC地址
Active
对于虚拟备份组,该字段表示Master的接口IP地址,当前路由器为Master时,显示为local
对于虚拟转发器,该字段表示AVF的接口IP地址,当前虚拟转发器为AVF时,显示为local
# VRRP工作在负载均衡模式时,显示全部IPv4 VRRP备份组的详细信息。
 Total number of virtual routers : 3
     Auth type        : None
     Version          : 2
     Virtual IP       : 10.1.1.1
                        10.1.1.2
                        10.1.1.3
     Member IP list   : 10.1.1.10 (Local, Master)
                        10.1.1.20 (Backup)
   Forwarder information: 2 Forwarders 1 Active
     Config weight  : 255
     Running weight : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-0011 (Owner)
     Owner ID       : 0000-5e01-1101
     Priority       : 255
     Active         : local
    Forwarder 02
     State          : Listening
     Virtual MAC    : 000f-e2ff-0012 (Learnt)
     Owner ID       : 0000-5e01-1103
     Priority       : 127
     Active         : 10.1.1.20
   Forwarder weight track information:
     Track object   : 1          State : Positive   Weight reduced : 250
     VRID             : 11                   Adver timer  : 100 centiseconds
     Auth type        : None
     Version          : 2
     Virtual IP       : 10.1.1.11
                      : 10.1.1.12
                      : 10.1.1.13
     Member IP list   : 10.1.1.10 (Local, Backup)
                        10.1.1.15 (Master)
     Config weight  : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-40b1 (Learnt)
     Priority       : 127
     Active         : 10.1.1.15
    Forwarder 02
     State          : Listening
     Virtual MAC    : 000f-e2ff-40b2 (Owner)
     Priority       : 255
     Active         : local
     State transition : 2370 milliseconds left
     Auth type        : None
     Version          : 2
     Virtual IP       : 10.1.1.8
     Member IP list   : 10.1.1.3 (Local, Initialize)
   Forwarder information: 2 Forwarders 0 Active
     Config weight  : 255
表1-4 display vrrp verbose命令显示信息描述表(负载均衡模式)
Running mode
备份组的数目
备份组所在接口名
VRID
虚拟路由器号(即备份组号)
Adver timer
Admin status
管理状态,包括Up和Down两种状态
当前路由器在备份组中的状态,取值为:
Config pri
Running pri
Preempt mode
抢占模式,取值包括:
·     Yes:路由器工作在抢占模式
·     No:路由器工作在非抢占模式
Delay time
抢占延迟时间,单位为厘秒
State transition
Become master
Auth type
认证类型,取值包括:
·     None:无认证
·     Simple:简单字符认证
·     MD5:MD5认证
Key
认证字,无认证时不显示此信息
Pkt sending mode
Version
VRRP使用的版本号
Virtual IP
备份组的虚拟IP地址列表
Member IP list
备份组中成员设备的IP地址列表:
·     Local:表示本地设备的IP地址
·     Master:表示处于Master状态的成员设备的IP地址
·     Backup:表示处于Backup状态的成员设备的IP地址
VRRP备份组监视的Track项信息,执行vrrp vrid track命令后,才会显示此信息
Track object
监视的Track项
Track项的状态,Track项的状态包括Negative、Positive和NotReady
Pri reduced
监视的Track项状态为Negative时,优先级降低的数额,执行vrrp vrid track命令后,才会显示此信息
Switchover
快速切换,显示此信息时表示当监视的Track项变为Negative状态时,Backup路由器会马上抢占成为Master路由器
虚拟转发器信息:路由器的虚拟转发器数目为2,处于Active状态的虚拟转发器数目为1
Config weight
虚拟转发器的配置权重,取值为255
Running weight
虚拟转发器的运行权重,即虚拟转发器当前的权重,配置监视指定Track项后,虚拟转发器的权重会根据Track项的状态改变
Forwarder 01
虚拟转发器01的信息
虚拟转发器的状态,取值包括:
·     Active:表示虚拟转发器处于转发状态,可转发报文
·     Listening:表示虚拟转发器处于备份侦听状态,不转发报文
·     Initialize:表示虚拟转发器处于初始状态,不具备VRRP备份功能
Virtual MAC
虚拟转发器的虚拟MAC地址
当VRRP处于负载分担模式时,本字段的取值中还会包含虚拟MAC地址的属性,形如000f-e2ff-40b2 (Owner),虚拟MAC地址的属性取值包括:
·     Owner:表示本设备为此虚拟MAC地址对应的VF Owner(虚拟转发器拥有者)
·     Learnt:表示本设备不是VF Owner,是VF Owner的备份
·     Take Over:表示本设备已经接替VF Owner成为AVF,负责转发流量(如果直到VF超时定时器超时,大约1800秒,VF Owner的故障仍未恢复,系统将自动删除该虚拟转发器)
Owner ID
虚拟转发器拥有者的接口实际MAC地址
Priority
虚拟转发器的优先级,取值范围为1~255
Active
AVF的接口IP地址,当前转发器为AVF时,显示为local
Forwarder weight track configuration
虚拟转发器权重监视配置信息。执行vrrp vrid track命令后,才会显示此信息
Track object
权重监视的Track项。执行vrrp vrid track命令后,才会显示此信息
Weight reduced
监视的Track项状态为Negative时,权重降低的数额。执行vrrp vrid track命令后,才会显示此信息
Forwarder switchover track information:
虚拟转发器快速切换模式监视配置信息。执行vrrp vrid track命令后,才会显示此信息
Member IP
备份组中成员设备的IP地址。执行vrrp vrid track命令后,才会显示此信息
·     vrrp mode
·     vrrp vrid
·     vrrp vrid authentication-mode
·     vrrp vrid backup-arp
·     vrrp vrid preempt-mode
·     vrrp vrid priority
·     vrrp vrid timer advertise
·     vrrp vrid track
·     vrrp vrid vrrpv3-send-packet
display vrrp binding命令用来显示IPv4 VRRP备份组的管理备份组和成员备份组关联信息。
display vrrp binding [ interface interface-type interface-number [ vrid virtual-router-id ] | name name ]
interface interface-type interface-number:显示指定接口的IPv4 VRRP备份组的管理备份组和成员备份组的关联信息。interface-type interface-number为接口类型和接口编号。
vrid virtual-router-id:显示指定IPv4 VRRP备份组的管理备份组和成员备份组的关联信息。virtual-router-id为IPv4 VRRP备份组号,取值范围为1~255。
name name:显示指定管理组和成员备份组的关联信息。name 为IPv4 VRRP管理备份组名称,为1~20个字符的字符串,区分大小写。
如果未指定接口名、备份组号和管理组名称,则显示所有IPv4 VRRP备份组的管理备份组和成员备份组的关联信息。如果只指定接口名,未指定备份组号,则显示该接口上的所有IPv4 VRRP管理备份组的关联信息。如果同时指定接口名和备份组号,则显示该接口上指定IPv4 VRRP备份组的管理备份组和成员备份组的关联信息。如果只指定管理组名称,则显示与管理组名称对应的IPv4 VRRP备份组的管理备份组和成员备份组的关联信息。
# 显示IPv4 VRRP备份组的管理备份组及成员备份组关联信息。
<Sysname> display vrrp binding
IPv4 virtual router binding information:
  Total number of master virtual routers        : 1
  Total number of subordinate virtual routers   : 2
  Interface : XGE3/0/1             Master VRID  : 1
  Name      : a                    Status       : Backup
  Subordinate virtual routers: 1
    Interface : XGE3/0/2           VRID         : 4
  Interface : --                   Master VRID  : --
  Name      : c                    Status       : --
    Interface : XGE3/0/1           VRID         : 4
表1-5 display vrrp binding命令显示信息描述表
IPv4虚拟路由器绑定信息
设备上管理备份组的数目
设备上成员备份组的数目
VRRP管理备份组所在的接口,成员备份组关联不存在的备份组管理名称,则显示为“--”
Master VRID
VRRP管理备份组号,成员备份组关联不存在的备份组管理名称,则显示为“--”
Name
VRRP管理备份组名称
Status
当前路由器在备份组中的状态,取值为:
·     当成员备份组关联不存在的备份组管理名称时,则显示为--
与VRRP管理备份组绑定的成员备份组数目
与VRRP管理备份组绑定的VRRP成员备份组所在的接口
VRID
与VRRP管理备份组绑定的VRRP成员备份组号
·     vrrp vrid follow
·     vrrp vrid name
display vrrp statistics命令用来显示IPv4 VRRP备份组的统计信息。
interface interface-type interface-number:显示指定接口的IPv4 VRRP备份组统计信息。其中,interface-type interface-number为接口类型和接口编号。
vrid virtual-router-id:显示指定备份组的IPv4 VRRP统计信息。其中,virtual-router-id为IPv4 VRRP备份组号,取值范围为1~255。
如果未指定接口名和备份组号,则显示该路由器上所有IPv4 VRRP备份组的统计信息;如果指定接口名,未指定备份组号,则显示该接口上的所有IPv4 VRRP备份组的统计信息;如果同时输入接口名和备份组号,则显示该接口上指定IPv4 VRRP备份组的统计信息。
# VRRP工作在标准协议模式时,显示所有IPv4 VRRP备份组的统计信息。
<Sysname> display vrrp statistics
 Interface               : Ten-GigabitEthernet3/0/1
 VRID                    : 1
 CheckSum Errors         : 0          Version Errors                : 0
 Invalid Pkts Rcvd  :      0          Unexpected Pkts Rcvd          : 0
 IP TTL Errors           : 0          Advertisement Interval Errors : 0
 Invalid Auth Type       : 0          Auth Failures                 : 0
 Packet Length Errors    : 0          Auth Type Mismatch            : 0
 Become Master           : 1          Address List Errors           : 0
 Adver Rcvd              : 0          Priority Zero Pkts Rcvd       : 0
 Adver Sent              : 807        Priority Zero Pkts Sent       : 0
 ARP Entry Writes        :0           ARP Entry Write Errors        : 0
 ARP Entry Reads         :0           ARP Entry Read Errors         : 0
 IP Owner Conflicts      : 0
 Global statistics
 CheckSum Errors         : 0
 Version Errors          : 0
 VRID Errors             : 0
# VRRP工作在负载均衡模式时,显示全部IPv4 VRRP备份组的统计信息。
 VRID                    : 1
 Become Master           : 39         Address List Errors           : 0
 Become AVF              : 13         Packet Option Errors          : 0
 Adver Rcvd              : 2562       Priority Zero Pkts Rcvd       : 1
 Adver Sent              : 16373      Priority Zero Pkts Sent       : 49
 Request Rcvd            : 2          Reply Rcvd                    : 10
 Request Sent            : 12         Reply Sent                    : 2
 Release Rcvd            : 0          VF Priority Zero Pkts Rcvd    : 1
 Release Sent            : 0          VF Priority Zero Pkts Sent    : 11
 Redirect Timer Expires  : 1          Time-out Timer Expires        : 0
 Global statistics
 CheckSum Errors         : 0
 Version Errors          : 0
 VRID Errors             : 0
表1-6 display vrrp statistics显示信息描述表(标准协议模式)
备份组所在接口
VRID
备份组号
CheckSum Errors
校验和错误的报文数
Version Errors
版本号错误的报文数
Invalid Pkts Rcvd
接收到报文类型错误的报文数
接收到未期望的报文数
VRRP通告报文发送时间间隔错误的报文数
IP TTL Errors
TTL错误的报文数
Auth Failures
认证失败的报文数
Invalid Auth Type
认证类型无效的报文数
Auth Type Mismatch
认证类型不匹配的报文数
VRRP报文长度错误的报文数
Address List Errors
备份组虚拟IP地址列表错误的报文数
Become Master
成为Master路由器的次数
收到的优先级为0的VRRP通告报文的数目
Adver Rcvd
收到的VRRP通告报文的数目
发送的优先级为0的VRRP通告报文的数目
Adver Sent
发送的VRRP通告报文的数目
ARP Entry Writes
在VRRP通告报文中写入ARP表项信息的次数
在VRRP通告报文中写入ARP表项信息失败的次数
ARP Entry Reads
从VRRP通告报文中读取ARP表项信息的次数
从VRRP通告报文中读取ARP表项信息失败的次数
IP Owner Conflicts
IP地址拥有者发生冲突的报文数
Global statistics
所有备份组的全局统计信息
CheckSum Errors
校验和错误的报文总数
Version Errors
版本号错误的报文总数
VRID Errors
备份组号错误的报文总数
表1-7 display vrrp statistics显示信息描述表(负载均衡模式)
备份组所在接口
VRID
备份组号
CheckSum Errors
校验和错误的报文数
Version Errors
版本号错误的报文数
Invalid Pkts Rcvd
接收到报文类型错误的报文数
接收到未期望的报文数
IP TTL Errors
TTL错误的报文数
Auth Failures
认证错误的报文数
Invalid Auth Type
认证类型无效的报文数
Auth Type Mismatch
认证类型不匹配的报文数
VRRP报文长度错误的报文数
Address List Errors
虚拟IP地址列表错误的报文数
Become Master
成为Master路由器的次数
Redirect Timer超时的次数
Become AVF
成为AVF的次数
Time-out Timer超时的次数
Adver Rcvd
收到的Advertisement报文的数目
Request Rcvd
收到的Request报文的数目
Adver Sent
发送的Advertisement报文的数目
Request Sent
发送的Request报文的数目
Reply Rcvd
收到的Reply报文的数目
Release Rcvd
收到的Release报文的数目
Reply Sent
发送的Reply报文的数目
Release Sent
发送的Release报文的数目
收到的路由器优先级为0的Advertisement报文的数目
收到的虚拟转发器优先级为0的Advertisement报文的数目
发送的路由器优先级为0的Advertisement报文的数目
发送的虚拟转发器优先级为0的Advertisement报文的数目
报文状态选项错误的次数
Global statistics
所有备份组的全局统计信息
CheckSum Errors
校验和错误的报文总数
Version Errors
版本号错误的报文总数
VRID Errors
备份组号错误的报文总数
·     reset vrrp statistics
reset vrrp statistics命令用来清除IPv4 VRRP备份组的统计信息。
interface interface-type interface-number:清除指定接口的IPv4 VRRP备份组统计信息。其中,interface-type interface-number为接口类型和接口编号。
vrid virtual-router-id:清除指定备份组的IPv4 VRRP统计信息。其中,virtual-router-id为IPv4 VRRP备份组号,取值范围为1~255。
在清除IPv4 VRRP备份组统计信息时,如果未指定接口名和备份组号,则清除该路由器上所有IPv4 VRRP备份组的统计信息;如果指定接口名,未指定备份组号,则清除该接口上所有IPv4 VRRP备份组的统计信息;如果同时输入接口名和备份组号,则清除该接口上指定IPv4 VRRP备份组的统计信息。
# 清除所有接口上所有IPv4 VRRP备份组的VRRP统计信息。
<Sysname> reset vrrp statistics
·     display vrrp statistics
snmp-agent trap enable vrrp命令用来开启VRRP告警功能。
undo snmp-agent trap enable vrrp命令用来关闭VRRP告警功能。
snmp-agent trap enable vrrp [ auth-failure | new-master ]
undo snmp-agent trap enable vrrp [ auth-failure | new-master ]
VRRP告警功能处于开启状态。
auth-failure:配置该参数后,当VRRP备份组中的设备收到的VRRP通告报文中的认证类型或认证字与本地不匹配时,会产生RFC2787规定的告警信息。
new-master:配置该参数后,当备份组中设备从Initialize或Backup状态升级为Master状态时,会产生RFC2787规定的告警信息。
开启VRRP模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 当VRRP备份组中的设备收到的VRRP通告报文中的认证类型或认证字与本地不匹配时,发送RFC2787规定的告警信息。
[Sysname] snmp-agent trap enable vrrp auth-failure
vrrp check-ttl enable命令用来启动对IPv4 VRRP报文TTL域的检查。
undo vrrp check-ttl enable命令用来禁止对IPv4 VRRP报文的TTL域的检查。
检查IPv4 VRRP报文的TTL域。
Master路由器定时发送VRRP通告报文,来通告它的存在。该报文以组播的形式在本网段内传播,不能被路由器转发,因此报文中的TTL值不会改变。Master路由器在发送VRRP通告报文时,将报文中的TTL值设置为255。如果启动备份组里的路由器检查VRRP报文的TTL域,则Backup路由器接收到TTL值小于255的VRRP通告报文时,将丢弃该报文,从而有效防止来自其他网段的攻击。
不同厂商的设备实现可能不同,在与其他厂商设备互通时,检查VRRP报文的TTL域可能导致错误地丢弃报文,这时可以通过undo vrrp check-ttl enable命令禁止检查VRRP报文的TTL域。
# 禁止检查IPv4 VRRP报文的TTL域。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] undo vrrp check-ttl enable
1.1.7  vrrp dot1q
vrrp dot1q命令用来配置IPv4 VRRP的控制VLAN。
undo vrrp dot1q命令用来恢复缺省情况。
vrrp dot1q vid vlan-id [ secondary-dot1q secondary-vlan-id ]
undo vrrp dot1q
未指定IPv4 VRRP的控制VLAN,即VLAN终结支持广播/组播功能后,Master在所有模糊终结的VLAN内发送VRRP通告报文。
三层以太网子接口视图
三层聚合子接口视图
vid vlan-id:指定IPv4 VRRP的外层控制VLAN的编号,vlan-id的取值范围为1~4094。
secondary-dot1q secondary-vlan-id:指定内层控制VLAN的编号,secondary-vlan-id的取值范围为1~4094。如果未指定本参数,则表示在配置了模糊Dot1q终结的子接口上指定控制VLAN。
多次执行本命令,最后一次执行的命令生效。
只有在三层以太网子接口或三层聚合子接口下执行本命令才会生效;在其他接口视图下也可以执行本命令,但不会生效。
当某子接口下有大量PPPoE用户在线的情况下,不建议再在该子接口上配置VRRP的控制VLAN功能。有关PPPoE的介绍,请参见“BRAS业务配置指导”中的“PPPoE”。
# 配置IPv4 VRRP的外层控制VLAN ID为2,内层控制VLAN ID为100。
[Sysname] interface ten-gigabitethernet 3/0/1.2
[Sysname-Ten-GigabitEthernet3/0/1.2] vrrp dot1q vid 2 secondary-dot1q 100
1.1.8  vrrp dscp
vrrp dscp命令用来配置VRRP报文的DSCP优先级。
undo vrrp dscp命令用来恢复缺省情况。
vrrp dscp dscp-value
undo vrrp dscp
VRRP报文的DSCP优先级为48。
dscp-value:VRRP报文的DSCP优先级,取值范围为0~63。
DSCP用来体现报文自身的优先等级,决定报文传输的优先程度。配置的DSCP优先级的取值越大,报文的优先级越高。
# 配置VRRP报文的DSCP优先级为30。
[Sysname] vrrp dscp 30
vrrp isolate enable命令用来开启IPv4 VRRP的隔离模式。
undo vrrp isolate enable命令用来关闭IPv4 VRRP的隔离模式。
vrrp isolate enable
IPv4 VRRP的隔离模式处于关闭状态。
在VRRP组网场景下,需要维护当前的主设备时,可以配置本功能,实现主备切换,让备设备接替主设备的业务。在隔离模式下,等主备切换完成后,再对主设备进行维护,不影响业务的运行。
开启IPv4 VRRP的隔离模式后,本设备在IPv4 VRRP备份组中的优先级将被设置为0。
当设备处于隔离模式时,通过vrrp vrid priority命令配置的新优先级不会立即生效,会在关闭IPv4 VRRP的隔离模式后生效。
# 开启IPv4 VRRP的隔离模式。
[Sysname] vrrp isolate enable
1.1.10  vrrp mode
vrrp mode命令用来配置IPv4 VRRP的工作模式。
undo vrrp mode命令用来恢复缺省情况。
vrrp mode load-balance [ version-8 ]
undo vrrp mode
IPv4 VRRP工作在标准协议模式。
load-balance:指定IPv4 VRRP工作在负载均衡模式。
version-8:发送的协议报文携带的版本号为8。
创建IPv4 VRRP备份组后,仍然可以修改IPv4 VRRP的工作模式。修改IPv4 VRRP的工作模式后,路由器上所有的IPv4 VRRP备份组都会工作在该模式。
只有接口配置的IPv4 VRRP使用的版本为VRRPv2时,指定version-8参数才会生效。若备份组满足以下所有条件时,需要配置version-8参数:
·     备份组中存在使用ComwareV5版本软件的路由器,可使用display version命令查看路由器软件版本;
·     备份组中所有路由器的IPv4 VRRP均需要工作在负载均衡模式;
·     备份组中所有路由器的IPv4 VRRP使用的版本均要配置为VRRPv2。
# 配置IPv4 VRRP工作在负载均衡模式。
[Sysname] vrrp mode load-balance
·     display vrrp
vrrp send-gratuitous-arp命令用来配置IPv4 VRRP Master路由器定时发送免费ARP报文。
undo vrrp send-gratuitous-arp命令用来恢复缺省情况。
vrrp send-gratuitous-arp [ interval interval ]
IPv4 VRRP Master路由器不会定时发送免费ARP报文。
interval:指定发送免费ARP报文的时间间隔,取值范围为30~1200,单位为秒。缺省值为120。
配置本功能后,Master路由器定时发送免费ARP报文用来保证下游设备的MAC地址表项能够定时刷新。
该命令只在VRRP标准模式下生效。
重复执行本命令修改免费ARP报文的发送时间间隔,修改后的时间间隔在下一个发送时间间隔生效。
为了防止设备在同一时间发送大量免费ARP报文,当设备同时作为多个VRRP备份组的Master路由器时,在这些VRRP备份组中Master路由器会在执行本命令后的interval/2到interval时间内随机发送第一个免费ARP报文。
如果设备上配置了大量的VRRP备份组,同时又配置了很小的免费ARP报文发送时间间隔,那么免费ARP报文的实际发送时间间隔可能会远远高于用户配置的时间间隔。
# 配置IPv4 VRRP Master路由器定时发送免费ARP报文,并配置发送免费ARP报文发送时间间隔为200秒。
[Sysname] vrrp send-gratuitous-arp interval 200
vrrp send-gratuitous-arp enhance enable命令用来开启IPv4 VRRP备份组增强发送免费ARP报文功能。
undo vrrp send-gratuitous-arp enhance enable命令用来关闭IPv4 VRRP备份组增强发送免费ARP报文功能。
IPv4 VRRP备份组增强发送免费ARP报文功能处于关闭状态。
本命令只在VRRP标准模式下生效。
当IPv4 VRRP备份组发生备升主时,缺省情况下,新Master路由器只发送一次免费ARP报文。为了避免免费ARP报文丢失导致下游交换机不能及时刷新目的MAC地址和出接口,可配置本命令。
配置本命令后,当IPv4 VRRP备份组发生备升主时,新Master路由器会连续发送六次免费ARP报文;如果新Master路由器同时作为多个VRRP备份组的Master路由器时,新Master路由器会针对每个虚IP地址发送六次免费ARP报文。
# 开启IPv4 VRRP备份组增强发送免费ARP报文功能。
[Sysname] vrrp send-gratuitous-arp enhance enable
·     display vrrp
vrrp state-transition-delay命令用来指定IPv4 VRRP备份组从Initialize状态切换到Master(或Backup)状态的延迟时间。
undo vrrp state-transition-delay命令用来恢复缺省情况。
vrrp state-transition-delay delay-value
IPv4 VRRP备份组从Initialize状态切换到Master(或Backup)状态的延迟时间为0秒。
delay-value:IPv4 VRRP备份组从Initialize状态切换到Master(或Backup)状态的延迟时间,取值范围为0~60,单位为秒。
缺省情况下,当设备的接口UP后,该接口上配置的IPv4 VRRP备份组的状态会立即从Initialize状态切换到Master(或Backup)状态。当设备重启或接口状态频繁改变时,会导致IPv4 VRRP备份组状态不稳定,影响IPv4 VRRP备份组正常工作。配置本功能后可以解决该问题,当设备的接口UP后,状态切换延迟时间开始计时,如果超时前接口Shutdown,则计时停止,VRRP备份组仍处于Initialize状态。等接口UP后重新开始计时,当延迟时间超时后,VRRP备份组才会从Initialize状态切换到Master(或Backup)状态。
# 在接口Ten-GigabitEthernet3/0/1上指定IPv4 VRRP备份组从Initialize状态切换Master(或Backup)状态的延迟时间为5秒。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp state-transition-delay 5
1.1.14  vrrp version
vrrp version命令用来配置接口下IPv4 VRRP使用的版本。
undo vrrp version命令用来恢复缺省情况。
vrrp version version-number
undo vrrp version
IPv4 VRRP使用的版本为VRRPv3。
version-number:VRRP协议的版本号,取值为2或3,其中2表示使用VRRPv2版本(RFC 3768),3表示使用VRRPv3版本(RFC 5798)。
IPv4 VRRP备份组中的所有路由器上配置的IPv4 VRRP版本必须一致。
# 配置接口Ten-GigabitEthernet3/0/1上IPv4 VRRP使用的版本为VRRPv2。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp version 2
1.1.15  vrrp vrid
vrrp vrid命令用来创建IPv4 VRRP备份组,并配置IPv4 VRRP备份组的虚拟IP地址,或为一个已经存在的IPv4 VRRP备份组添加一个虚拟IP地址。
undo vrrp vrid命令用来删除一个已经存在的IPv4 VRRP备份组的所有配置,或删除已经存在的IPv4 VRRP备份组中的虚拟IP地址。
vrrp vrid virtual-router-id virtual-ip virtual-address
undo vrrp vrid virtual-router-id [ virtual-ip [ virtual-address ] ]
不存在IPv4 VRRP备份组。
virtual-router-id:IPv4 VRRP备份组号,取值范围为1~255。
virtual-ip virtual-address:备份组的虚拟IP地址。不能为全零地址(0.0.0.0)、广播地址(255.255.255.255)、环回地址、非A/B/C类地址和其它非法IP地址(如0.0.0.1)。删除IPv4 VRRP备份组中的虚拟IP地址时,如果未指定virtual-address参数,则表示删除该备份组中的所有虚拟IP地址。
重复执行本命令,可以为IPv4 VRRP备份组配置多个虚拟IP地址,但每个备份组最多只能配置16个虚拟IP地址。
如果没有为备份组配置虚拟IP地址,但是为备份组进行了其他配置(如优先级、抢占方式等),则该备份组会存在于设备上,并处于Inactive状态,此时备份组不起作用。
建议将备份组的虚拟IP地址和备份组中设备下行接口的IP地址配置为同一网段,否则可能导致局域网内的主机无法访问外部网络。
IPv4 VRRP工作在负载均衡模式时,要求备份组的虚拟IP地址和接口的IP地址不能相同。否则,IPv4 VRRP负载均衡功能将无法正常工作。
# 创建IPv4 VRRP备份组1,配置IPv4 VRRP备份组1的虚拟IP地址为10.10.10.10。为IPv4 VRRP备份组1添加一个虚拟IP地址10.10.10.11。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 10.10.10.10
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 10.10.10.11
·     display vrrp
vrrp vrid authentication-mode命令用来配置备份组发送和接收IPv4 VRRP报文的认证方式和认证字。
undo vrrp vrid authentication-mode命令用来恢复缺省情况。
vrrp vrid virtual-router-id authentication-mode { md5 | simple } { cipher | plain } string
undo vrrp vrid virtual-router-id authentication-mode
备份组发送和接收IPv4 VRRP报文时不进行认证。
md5:表示使用MD5算法进行认证。
simple:表示使用简单字符进行认证。
cipher:表示以密文方式设置密钥。
plain:表示以明文方式设置密钥,该密钥以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~8个字符的字符串,密文密钥为1~41个字符的字符串。
为了防止非法用户构造报文攻击备份组,VRRP通过在VRRP报文中增加认证字的方式,验证接收到的VRRP报文。VRRP提供了两种认证方式:
·     simple:简单字符认证。发送VRRP报文的路由器将认证字填入到VRRP报文中,而收到VRRP报文的路由器会将收到的VRRP报文中的认证字和本地配置的认证字进行比较。如果认证字相同,则认为接收到的报文是真实、合法的VRRP报文;否则认为接收到的报文是一个非法报文。
·     md5:MD5认证。发送VRRP报文的路由器利用认证字和MD5算法对VRRP报文进行摘要运算,运算结果保存在Authentication Header(认证头)中。收到VRRP报文的路由器会利用认证字和MD5算法进行同样的运算,并将运算结果与认证头的内容进行比较。如果相同,则认为接收到的报文是真实、合法的VRRP报文;否则认为接收到的报文是一个非法报文。
MD5认证比简单字符认证更安全,但是MD5认证需要进行额外的运算,占用的系统资源较多。
一个接口上的不同备份组可以设置不同的认证方式和认证字;加入同一备份组的成员需要设置相同的认证方式和认证字。
使用VRRPv3版本的IPv4 VRRP不支持认证。使用VRRPv3版本时,此配置不会生效。
# 设置接口Ten-GigabitEthernet3/0/1上备份组1发送和接收IPv4 VRRP报文的认证方式为simple,认证字为Sysname。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 authentication-mode simple plain Sysname
·     display vrrp
·     vrrp version
vrrp vrid backup-arp命令用来开启IPv4 VRRP备份组的ARP表项备份功能。
undo vrrp vrid backup-arp命令用来关闭IPv4 VRRP备份组的ARP表项备份功能。
vrrp vrid virtual-router-id backup-arp
undo vrrp vrid virtual-router-id backup-arp
IPv4 VRRP备份组的ARP表项备份功能处于关闭状态。
只有标准协议模式的VRRP备份组才支持配置本功能。
在Master设备上开启本功能后,Master设备将在发送下一个VRRP通告报文添加ARP表项信息。在Backup设备上开启本功能后,Backup设备将会学习VRRP通告报文中的ARP信息。因此,VRRP备份组内的所有成员设备上都需要开启本功能,IPv4 VRRP备份组的ARP表项备份功能才能正常进行。
本功能会增加VRRP的Master设备发送通告报文的时长,对VRRP性能造成影响。如果同一个接口上创建了多个VRRP备份组,只需要在其中一个VRRP备份组中配置本功能即可。
当Master设备上的ARP表项较多时,Master设备需要发送多个VRRP通告报文才能将这些ARP表项备份给Backup设备,Backup设备需要较长的时间才能学到Master设备备份的所有ARP表项。当该Backup设备需要切换为Master设备时,如果ARP表项还未学习完,可能导致流量转发中断。管理员需要根据Master设备ARP表项的数目,配置合理的VRRP备份组抢占延迟时间,保证Backup设备有足够的时间学习备份的ARP表项。
# 在接口Ten-GigabitEthernet3/0/1上开启IPv4 VRRP备份组的ARP表项备份功能。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 backup-arp
·     display vrrp
vrrp vrid follow命令用来配置IPv4 VRRP成员备份组关联的管理备份组。
undo vrrp vrid follow命令取消IPv4 VRRP成员备份组关联的管理备份组。
vrrp vrid virtual-router-id follow name
undo vrrp vrid virtual-router-id follow
未配置IPv4 VRRP成员备份组关联的管理备份组。
name:IPv4 VRRP管理备份组名称,为1~20个字符的字符串,区分大小写。
为IPv4 VRRP备份组关联了管理备份组后,该VRRP备份组作为该管理备份组的成员备份组,其状态与管理备份组状态保持一致。成员备份组不处理VRRP通告报文,只转发业务流量。
一个VRRP备份组不能同时作为管理备份组和成员备份组。
如果VRRP备份组所关联的管理备份组不存在,则该VRRP备份组始终处于Inactive状态。
如果VRRP备份组在关联管理备份组前处于Inactive或Initialize状态,关联的管理备份组处于除Inactive状态的其他状态,则关联之后该VRRP备份组状态保持不变。
# 配置IPv4 VRRP成员备份组关联的管理备份组为abc。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 follow abc
·     vrrp vrid name
·     display vrrp binding
vrrp vrid gratuitous-arp copy-to-member命令用来开启VRRP复制免费ARP报文功能。
undo vrrp vrid gratuitous-arp copy-to-member命令用来关闭VRRP复制免费ARP报文功能。
vrrp vrid virtual-router-id gratuitous-arp copy-to-member
undo vrrp vrid virtual-router-id gratuitous-arp copy-to-member
VRRP复制免费ARP报文功能处于关闭状态。
以太网聚合接口视图
以太网聚合子接口视图
本命令只在VRRP标准模式下生效。
当IPv4 VRRP备份组发生备升主(Master路由器故障,Backup路由器变成Master路由器),且IPv4 VRRP备份组配置在聚合接口或者聚合子接口时,缺省情况下,VRRP只会往一个聚合成员接口发送免费ARP报文。为了确保下游设备能及时收到免费ARP报文,加快网络收敛速度,可以执行本命令,开启VRRP复制免费ARP报文功能。
配置本命令后,当IPv4 VRRP备份组发生备升主时,VRRP会往所有聚合成员接口复制一份免费ARP报文,使得下游设备可以及时收到免费ARP报文并刷新表项,网络可以快速收敛。
如果备份组配置在聚合接口下,请根据需要在对应的聚合接口下配置本命令;如果备份组配置在聚合子接口下,请根据需要在对应的聚合子接口下配置本命令。
# 在聚合接口1下开启IPv4 VRRP备份组1的复制免费ARP报文功能。
[Sysname-Route-Aggregation1] vrrp vrid 1 gratuitous-arp copy-to-member
·     display vrrp
vrrp vrid ignore-interface-down命令用来开启IPv4 VRRP忽略接口物理状态down功能。
undo vrrp vrid ignore-interface-down命令用来关闭IPv4 VRRP忽略接口物理状态down功能。
vrrp vrid virtual-router-id ignore-interface-down
undo vrrp vrid virtual-router-id ignore-interface-down
IPv4 VRRP忽略接口物理状态down功能处于关闭状态。
某些可靠性业务(如多机备份、备份组和VRRP成员备份组)需要根据VRRP备份组中的设备状态选举出本业务的主用设备和备用设备。主用设备对应VRRP备份组中的Master设备,用来处理业务数据;备用设备对应VRRP备份组中的Backup设备,用来监控主用设备状态。当在两台设备直连链路两端的接口上配置VRRP备份组时,如果链路的一端接口故障或链路故障,VRRP备份组内的Master设备和Backup设备都会变成Initialize状态,可靠性业务中的主用设备和备用设备也会变成初始状态,主用设备无法继续处理业务数据。在VRRP备份组中的两台设备上同时开启IPv4 VRRP忽略接口物理状态down功能后,当VRRP备份组的端口物理状态down时,VRRP备份组内的Master设备和Backup设备保持状态不变,从而保证可靠性业务不会中断。
# 在接口Ten-GigabitEthernet3/0/1上开启IPv4 VRRP忽略接口物理状态down功能。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 ignore-interface-down
vrrp vrid initialize state-hold-time命令用来配置IPv4 VRRP备份组初始化状态保持时间。
undo vrrp vrid initialize state-hold-time命令用来恢复缺省情况。
vrrp vrid virtual-router-id initialize state-hold-time timer
undo vrrp vrid virtual-router-id initialize state-hold-time
IPv4 VRRP备份组初始化状态保持时间为0秒。表示初始化状态不保持,根据IPv4 VRRP组实际状态立即切换。
timer:IPv4 VRRP备份组初始化状态保持时间,取值范围为0~3600,单位为秒。
在使用管理备份组,且配置了忽略接口Down事件功能,当IPv4 VRRP备份组的端口物理状态为down时,IPv4 VRRP备份组内的Master设备和Backup设备的状态会保持不变。如果设备重启或者备份接口第一次连通,Master设备和Backup设备会在接口第一次up前一直保持Initialize状态。导致引用该备份组的其它功能不能处理业务。为了应对这种场景,可配置本命令,IPv4 VRRP会启动相应时间的定时器,定时器超时后IPv4 VRRP就会进入Backup状态,从而保证引用该备份组的其它功能可以处理业务。
# 在接口Ten-GigabitEthernet3/0/1上配置IPv4 VRRP备份组初始化状态保持时间为60秒。
[Sysname] interfac ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 initialize state-hold-time 60
vrrp vrid name命令用来配置IPv4 VRRP管理备份组。
undo vrrp vrid name命令用来取消配置的IPv4 VRRP管理备份组。
vrrp vrid virtual-router-id name name
undo vrrp vrid virtual-router-id name
未配置IPv4 VRRP管理备份组。
创建IPv4 VRRP备份组后,通过该命令为VRRP备份组指定一个管理备份组名称,则该备份组成为管理备份组。其他VRRP备份组关联该管理备份组后,即成为该管理备份组的成员备份组。管理备份组既处理VRRP通告报文,也转发业务流量。成员备份组不处理VRRP通告报文,只转发业务流量。
同一台设备上不同的VRRP备份组不能配置相同的管理备份组名称。
# 配置IPv4 VRRP管理备份组abc。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 name abc
·     vrrp vrid follow
vrrp vrid preempt-mode命令用来设置IPv4 VRRP备份组中的路由器工作在抢占方式,并配置抢占延迟时间。
undo vrrp vrid preempt-mode命令用来取消抢占方式,即设置IPv4 VRRP备份组中的路由器工作在非抢占方式。
undo vrrp vrid preempt-mode delay命令用来恢复抢占延迟时间为缺省值。
vrrp vrid virtual-router-id preempt-mode [ delay delay-value ]
undo vrrp vrid virtual-router-id preempt-mode [ delay ]
IPv4 VRRP备份组中的路由器工作在抢占方式下,抢占延迟时间为0厘秒。
delay delay-value:抢占延迟时间。delay-value取值范围为0~180000,单位为厘秒。
应用场景
抢占方式可以确保承担转发任务的Master路由器始终是备份组中优先级最高的设备。
工作机制
在VRRP组网中,如果Master路由器故障、链路故障或者Master路由器的VRRP优先级变成了0,导致Backup路由器在超时时间到达仍未收到Master路由器的VRRP通告报文,或者收到的VRRP通告报文优先级为0,则不管是否配置抢占方式,Backup路由器会立即切成成Master路由器,接替原Master路由器工作。
当因为Track项状态变化等原因导致当前Master路由器的VRRP优先级大于0小于Backup路由器优先级时,抢占机制才会启动。抢占规则为:
·     如果设备配置为立即抢占,并且收到VRRP优先级低于本机的VRRP通告报文,则它将立刻变成新的Master路由器。
·     如果设备配置了抢占和抢占延迟,并且收到VRRP优先级低于本机的VRRP通告报文,它会启动一个定时器。只有当延迟时间结束且期间收到的VRRP通告报文的优先级均低于本机的VRRP优先级时,它才会成为新的Master路由器。
·     如果设备设置为非抢占模式,即便收到VRRP优先级低于本机的VRRP通告报文,它也不会切换成新的Master路由器。
抢占延迟时间的主要应用场景如下,请根据当前组网需要设置抢占延迟时间的值:
·     抢占延迟时间可以避免网络不稳定导致的备份组内成员频繁进行主备状态转换。
·     抢占延迟时间能给设备预留数据备份的时间。
推荐配置
通常情况下,推荐按如下原则配置抢占参数:
·     Backup路由器设置为抢占模式,且不设置抢占延迟。以确保在Master路由器的VRRP优先级降低时,能立即触发正切,Backup路由器能迅速接管业务,成为新的Master,继续提供服务。
·     Master路由器设置为抢占模式,且配置n分钟的抢占延迟。以便当原Master路由器故障恢复,VRRP进行回切时,n分钟的抢占延迟使得原Master路由器有足够时间从新Master路由器同步数据,从而维持VRRP备份组的稳定和数据一致。n的取值与当前网络中的业务数据量有关:
¡     n取值太小会导致流量已经回切到原Master路由器,但数据还没有完成备份,从而影响业务。
¡     适当放大n的取值,因为有新Master路由器处理业务,也不会对业务造成影响。
# 配置VRRP备份组1中的设备工作在抢占方式,抢占延迟时间为5000厘秒。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 preempt-mode delay 5000
·     display vrrp
vrrp vrid priority命令用来设置路由器在IPv4 VRRP备份组中的优先级。
undo vrrp vrid priority命令用来恢复缺省情况。
undo vrrp vrid virtual-router-id priority
路由器在IPv4 VRRP备份组中的优先级为100。
priority-value:优先级的值,取值范围为1~254,该值越大表明优先级越高。
优先级决定了路由器在备份组中的地位。优先级越高,越有可能成为Master路由器。优先级0是系统保留为特殊用途来使用的,255则是系统保留给IP地址拥有者的。
路由器为IP地址拥有者时,其运行优先级始终为255,表明只要其工作正常,则为Master路由器。
# 设置路由器在IPv4 VRRP备份组1中的优先级为150。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 priority 150
·     display vrrp
·     vrrp vrid track
vrrp vrid shutdown命令用来关闭指定的IPv4 VRRP备份组。
undo vrrp vrid shutdown命令用来开启指定的IPv4 VRRP备份组。
vrrp vrid virtual-router-id shutdown
undo vrrp vrid virtual-router-id shutdown
IPv4 VRRP备份组处于开启状态。
关闭IPv4 VRRP备份组功能通常用于暂时禁用备份组,用户发送给IPv4 VRRP备份组的报文可能会被丢弃。
关闭备份组后,该备份组的状态为Initialize,并且该备份组所有已存在的配置保持不变。在关闭状态下还可以对备份组进行配置。备份组再次被开启后,基于最新的配置,从Initialize状态重新开始运行。
# 关闭IPv4 VRRP备份组1。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 shutdown
vrrp vrid source-interface命令用来为IPv4 VRRP备份组指定源接口,该源接口用来代替IPv4 VRRP备份组所在接口进行该备份组VRRP报文的收发。
undo vrrp vrid source-interface命令用来取消当前指定的源接口,VRRP报文通过IPv4 VRRP备份组所在接口进行收发。
vrrp vrid virtual-router-id source-interface interface-type interface-number
undo vrrp vrid virtual-router-id source-interface
未指定备份组的源接口,VRRP报文通过IPv4 VRRP备份组所在接口进行收发。
interface-type interface-number:源接口的接口类型和接口编号。
因组网要求或网络故障,导致同一个IPv4 VRRP备份组中的设备不能通过备份组所在接口进行VRRP协议报文交互时,可以使用本命令将其他能进行报文交互的接口设置为备份组源接口,用来代替备份组所在接口进行该备份组VRRP报文的收发。
# 设置接口Ten-GigabitEthernet3/0/1上备份组的源接口为接口Ten-GigabitEthernet3/0/2。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 10 source-interface ten-gigabitethernet 3/0/2
vrrp vrid timer advertise命令用来设置IPv4 VRRP备份组中的Master路由器发送VRRP通告报文的时间间隔。
undo vrrp vrid timer advertise命令用来恢复缺省情况。
vrrp vrid virtual-router-id timer advertise { adver-interval | msec milliseconds-adver-interval }
undo vrrp vrid virtual-router-id timer advertise
IPv4 VRRP备份组中Master路由器发送VRRP通告报文的时间间隔为100厘秒。
adver-interval:备份组中的Master路由器发送VRRP通告报文的间隔时间,取值范围为10~4095,单位为厘秒。使用VRRPv2版本时,该参数的实际生效值只能是100的整倍数,例如,配置该参数取值在10~100、101~200、4001~4095范围内时,实际生效值分别为100、200、4100;使用VRRPv3版本时,该参数的实际生效值与所配置数值相同。
milliseconds-adver-interval:IPv4 VRRP备份组中的Master路由器发送VRRP通告报文的间隔时间,取值范围为100~999,单位为毫秒,该参数的实际生效值只能是10的整数倍,例如,配置该参数取值在100~109、200~209、990~999范围内时,实际生效值分别为100、200、990。只有在VRRPv2配置此参数才生效,当VRRPv3配置此参数时,实际生效通告时间为默认值1秒。
IPv4 VRRP备份组中的Master路由器会定时发送VRRP通告报文,通知备份组内的路由器自己工作正常。VRRP通告报文的发送时间间隔为本命令配置的值。
网络流量过大可能会导致Backup路由器在指定时间内未收到Master路由器的VRRP通告报文,从而发生状态转换。可以通过将VRRP通告报文的发送时间间隔延长的办法来解决该问题。
VRRPv2备份组中的所有路由器上配置的VRRP通告报文时间间隔要么都大于1秒,要么都小于等于1秒。具体情况如下:
·     如果VRRP备份组中的所有路由器上配置的VRRP通告报文时间间隔都大于1秒,必须保证所有路由器的VRRP通告报文时间间隔相同。Backup路由器发起Master重选举的延迟时间为3×Master路由器的VRRP通告报文时间间隔+Skew_Time。
·     如果VRRP备份组中的所有路由器上配置的VRRP通告报文时间间隔都小于等于1秒,备份组中所有路由器的间隔可以不同,但是Master路由器的VRRP通告报文时间间隔必须小于各Backup路由器中的最小的“3×自身配置的时间间隔+Skew_Time”。Backup路由器发起Master重选举的延迟时间为3×自身配置的时间间隔+Skew_Time。为了保证工作正常,建议备份组各路由器上配置的VRRP通告报文时间间隔相同。
VRRPv3备份组中的所有路由器上配置的VRRP通告报文时间间隔可以不同,Backup路由器发起Master重选举的延迟时间为3×Master路由器的VRRP通告报文时间间隔+Skew_Time。
# 设置IPv4 VRRP备份组1的Master路由器发送VRRP通告报文的间隔时间为500厘秒。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 timer advertise 500
·     display vrrp
vrrp vrid track命令用来配置监视指定的Track项。
undo vrrp vrid track命令用来取消监视指定的Track项。
vrrp vrid virtual-router-id track track-entry-number { forwarder-switchover member-ip ip-address | priority reduced [ priority-reduced ] | switchover | weight reduced [ weight-reduced ] }
undo vrrp vrid virtual-router-id track [ track-entry-number ] [ forwarder-switchover | priority reduced | switchover | weight reduced ]
未指定被监视的Track项。
track-entry-number:被监视的Track项序号,track-entry-number取值范围为1~1024。
forwarder-switchover member-ip ip-address:虚拟转发器快速切换模式。当监视的Track项状态变为Negative时,如果本地设备上有处于Listening状态的虚拟转发器,且其对应的AVF地址为member-ip,则马上将该虚拟转发器切换到Active状态。ip-address为备份组中成员设备的IP地址。可以通过display vrrp verbose命令查看备份组中包含的成员设备。
priority reduced [ priority-reduced ]:当监视的Track项状态变为Negative时,降低本地路由器在备份组中的优先级。优先级降低的数值为priority-reducedpriority-reduced的取值范围为1~255,缺省值为10。
switchover:切换模式,当监视的Track项的状态变为Negative时,如果本路由器在备份组中处于Backup状态,则马上切换成为Master路由器。
weight reduced [ weight-reduced ]:当监视的Track项状态变为Negative时,当前路由器上属于指定IPv4 VRRP组的所有虚拟转发器的权重都降低指定的数值。权重降低的数值为weight-reducedweight-reduced的取值范围为1~255,缺省值为30。
当关联的Track项的状态为Negative时,设备立即将虚拟转发器切换为Active状态、降低路由器的优先级、立即切换成为Master路由器或降低本地虚拟转发器权重值。
在执行本配置之前,需要先在接口上创建备份组并配置虚拟IP地址。
关于track-entry-number参数,需要注意的是:
·     指定的Track项可以是未创建的Track项,即可以先通过本命令指定监视的Track项后,再通过track命令创建该Track项。Track项的详细介绍请参见“可靠性配置指导”中的“Track”。
·     执行undo vrrp vrid track命令时如果未指定track-entry-number参数,则删除该备份组与所有Track项的关联。
路由器在某个备份组中作为IP地址拥有者时,如果在该路由器上执行vrrp vrid track priority reducedvrrp vrid track switchover命令,则该配置不会生效。该路由器不再作为IP地址拥有者后,之前的配置才会生效。
关于forwarder-switchover member-ip ip-addressweight reduced [ weight-reduced ]参数,需要注意的是:
·     只有VRRP工作在负载均衡模式时,执行forwarder-switchover member-ip ip-addressweight reduced [ weight-reduced ]才会生效。
·     虚拟转发器的权重值为255,虚拟转发器的失效下限为10。由于VF Owner的权重高于或等于失效下限时,它的优先级始终为255,不会根据虚拟转发器的权重改变。当监视的上行接口出现故障时,配置的权重降低数额需保证VF Owner的权重低于失效下限,即权重降低的数额大于245,其他的虚拟转发器才能接替VF Owner成为AVF。
被监视的Track项的状态由Negative变为Positive或NotReady后,对应的路由器优先级会自动恢复、对应虚拟转发器的权重会自动恢复、故障恢复后的原Master路由器会重新抢占为Master状态、故障恢复后的原AVF会重新抢占为Active状态。
# 在接口Ten-GigabitEthernet3/0/1上配置监视Track项1,当Track项1状态为Negative时,接口Ten-GigabitEthernet3/0/1上备份组1的优先级降低50。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 track 1 priority reduced 50
# 在接口Ten-GigabitEthernet3/0/1上配置虚拟转发器监视Track项1,当Track项1状态为Negative时,如果本地设备上AVF地址为10.1.1.3的虚拟转发器处于Listening状态,则马上将该虚拟转发器切换到Active状态。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 track 1 forwarder-switchover member-ip 10.1.1.3
# 在接口Ten-GigabitEthernet3/0/1上配置虚拟转发器权重监视Track项1,当Track项1状态为Negative时,接口Ten-GigabitEthernet3/0/1上IPv4 VRRP备份组1所有虚拟转发器的权重都降低50。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 track 1 weight reduced 50
·     display vrrp
vrrp vrid vrrpv3-send-packet命令用来配置VRRPv3发送报文的模式。
undo vrrp vrid vrrpv3-send-packet命令用来恢复缺省情况。
vrrp vrid virtual-router-id vrrpv3-send-packet { v2-only | v2v3-both }
undo vrrp vrid virtual-router-id vrrpv3-send-packet
VRRPv3发送报文的模式为只发送版本号为3的报文。
v2-only:VRRPv3只发送版本号是2的报文。
v2v3-both:VRRPv3既发送版本号是2的报文,也发送版本号是3的报文。
该命令只对VRRPv3生效。
该命令只配置报文的发送模式。对于接收模式,VRRPv3既接收版本号是2的报文,也接收版本号是3的报文,无法通过命令行控制。
配置了VRRP认证之后,如果发送的是VRRPv2报文,则会携带配置的认证信息。如果发送的是VRRPv3报文,则不会携带配置的认证信息。(VRRPv3不支持认证)
VRRPv3发送版本号是2的VRRP报文时,报文中携带的VRRP通告报文发送时间间隔必须是100厘秒的整数倍,可能与vrrp vrid timer advertise命令设置的时间间隔不同。具体介绍请参见vrrp vrid timer advertise命令。
# 配置VRRP备份组1既发送版本号是2的报文,也发送版本号是3的报文。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp vrid 1 vrrpv3-send-packet v2v3-both
·     display vrrp
1.2  IPv6 VRRP配置命令
display vrrp ipv6命令用来显示IPv6 VRRP备份组的状态信息。
display vrrp ipv6 [ interface interface-type interface-number [ vrid virtual-router-id ] ] [ verbose ]
interface interface-type interface-number:显示指定接口的IPv6 VRRP备份组状态信息。其中,interface-type interface-number为接口类型和接口编号。
vrid virtual-router-id:显示指定IPv6 VRRP备份组的状态信息。其中,virtual-router-id为IPv6 VRRP备份组号,取值范围为1~255。
verbose:显示IPv6 VRRP备份组状态的详细信息。如果未指定本参数,则显示IPv6 VRRP备份组状态的简要信息。
如果未指定接口名和备份组号,则显示该路由器上所有IPv6 VRRP备份组的状态信息;如果只指定接口名,未指定备份组号,则显示该接口上的所有IPv6 VRRP备份组的状态信息;如果同时指定接口名和备份组号,则显示该接口上指定IPv6 VRRP备份组的状态信息。
# VRRP工作在标准协议模式时,显示全部IPv6 VRRP备份组的简要信息。
<Sysname> display vrrp ipv6
IPv6 virtual router information:
 ND sending interval : 120 seconds
 Enhanced sending of gratuitous ND packets: Enabled
 XGE3/0/1           1     Master      150     100       None     FE80::1
表1-8 display vrrp ipv6命令显示信息描述表(标准协议模式)
IPv6虚拟路由器信息
Running mode
ND sending interval
ND报文发送时间间隔,只有配置了vrrp ipv6 send-nd命令才显示此字段
VRRP备份组增强发送ND报文功能的开启状态,取值为:
·     Enabled:表示功能开启
·     Disabled:表示功能关闭
备份组的数目
备份组所在接口名
VRID
虚拟路由器号(即备份组号)
当前路由器在备份组中的状态,取值为:
Running pri
Adver timer(cs)
Auth type
认证类型,取值只能是None,表示无认证
Virtual IP
备份组的虚拟IP地址
# VRRP工作在标准协议模式时,显示全部IPv6 VRRP备份组的详细信息。
<Sysname> display vrrp ipv6 verbose
   Interface Route-Aggregation20
     VRID             : 21                  Adver timer  : 100 centiseconds
     Auth type        : None
     Virtual IP       : FE80::21
     Master IP        : ::
     Preempt mode     : Yes                  Delay time   : 10 centiseconds
     Auth type        : None
     Virtual IP       : FE80::1
     Virtual MAC      : 0000-5e00-0201
     Master IP        : FE80::2
     Become master    : 2450 milliseconds left
     Auth type        : None
     Virtual IP       : FE80::11
     Master IP        : FE80::12
   Interface Ten-GigabitEthernet3/0/3
     Auth type        : None
     Virtual IP       : FE80::10
     Virtual MAC      : 0000-5e00-0203
     Master IP        : FE80::2
     Follow name      : abc
   Interface Ten-GigabitEthernet3/0/4
     Auth type        : None
     Master IP        : ::
表1-9 display vrrp ipv6 verbose命令显示信息描述表(标准协议模式)
IPv6虚拟路由器信息
Running mode
ND sending interval
·     Enabled:表示功能开启
·     Disabled:表示功能关闭
备份组的数目
备份组所在接口名
VRID
虚拟路由器号(即备份组号)
Adver timer
Admin status
管理状态,包括Up和Down两种状态
当前路由器在备份组中的状态,取值为:
Config pri
路由器的配置优先级,即通过vrrp ipv6 vrid priority命令指定的路由器优先级
Running pri
Preempt mode
抢占模式,取值包括:
·     Yes:路由器工作在抢占模式
·     No:路由器工作在非抢占模式
State transition
VRRP从Initialize状态切换到Master(或Backup)状态的需要等待的时间,单位为毫秒。只有配置了vrrp ipv6 state-transition-delay命令后VRRP备份组处于Initialize状态,接口显示状态和VRRP备份组管理状态都为up时,才会显示此信息
Become master
Delay time
抢占延迟时间,单位为厘秒
Auth type
Virtual IP
备份组的虚拟IP地址
Virtual MAC
Master IP
处于Master状态的路由器所对应接口的链路本地地址
Config role
IPv6路由器角色,取值包括:
·     Master:IPv6管理备份组路由器
·     Subordinate:IPv6成员备份组路由器
Name
IPv6管理备份组名称,只有配置了vrrp ipv6 vrid name命令才会显示此信息
Follow name
IPv6 VRRP备份组所关联的IPv6管理备份组名称,只有配置了vrrp ipv6 vrid follow命令才会显示此信息
VRRP备份组监视的Track项信息。执行vrrp ipv6 vrid track命令后,才会显示此信息
Track object
监视的Track项
Pri reduced
Switchover
# VRRP工作在负载均衡模式时,显示全部IPv6 VRRP备份组的简要信息。
                                       pri
 XGE3/0/1           1     Master       150     FE80::1             Local
 -----              VF1   Active       255     000f-e2ff-4011      Local
表1-10 display vrrp ipv6命令显示信息描述表(负载均衡模式)
Running mode
备份组的数目
备份组所在接口名
VRID
Running pri
对于虚拟转发器,该字段表示虚拟转发器的运行优先级,即虚拟转发器当前的优先级,配置监视指定Track项后,虚拟转发器的优先级会根据Track项的状态改变
Address
¡     如果用户给IPv6 VRRP备份组配置了多个虚拟IP地址,此处仅显示链路本地地址
¡     如需显示给IPv6 VRRP备份组配置的所有虚拟IP地址,请指定verbose参数
Active
对于虚拟备份组,该字段表示Master的接口的链路本地地址,当前路由器为Master时,显示为local
对于虚拟转发器,该字段表示AVF的接口的链路本地地址,当前虚拟转发器为AVF时,显示为local
# VRRP工作在负载均衡模式时,显示全部IPv6 VRRP备份组的详细信息。
     Auth type        : None
     Member IP list   : FE80::3 (Local, Master)
                        FE80::2 (Backup)
     Master IP        : FE80::3
     Config weight  : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-4011 (Owner)
     Priority       : 255
     Active         : local
    Forwarder 02
     State          : Listening
     Virtual MAC    : 000f-e2ff-4012 (Learnt)
     Priority       : 127
     Active         : FE80::2
     Auth type        : None
     Member IP list   : FE80::3 (Local, Backup)
                        FE80::2 (Master)
     Master IP        : FE80::2
     Config weight  : 255
    Forwarder 01
     State          : Active
     Priority       : 127
     Active         : FE80::2
    Forwarder 02
     State          : Listening
     Priority       : 255
     Active         : local
   Interface Vlan-interface3
     Auth type        : None
     Master IP        : :: (Local, Initialize)
     Config weight  : 255
表1-11 display vrrp ipv6 verbose命令显示信息描述表(负载均衡模式)
Running mode
备份组的数目
备份组所在接口名
VRID
虚拟路由器号(即备份组号)
Adver timer
Admin status
管理状态,包括Up和Down两种状态
当前路由器在备份组中的状态,取值为:
Config pri
Running pri
Preempt mode
抢占模式,取值包括:
·     Yes:路由器工作在抢占模式
·     No:路由器工作在非抢占模式
Delay time
抢占延迟时间,单位为厘秒
State transition
Become master
Auth type
Virtual IP
备份组的虚拟IP地址列表
Member IP list
备份组中成员设备的IP地址列表:
·     Local:表示本地设备的IP地址
VRRP备份组监视的Track项信息,执行vrrp ipv6 vrid track命令后,才会显示此信息
Track object
监视的Track项,执行vrrp ipv6 vrid track命令后,才会显示此信息
Pri reduced
监视的Track项状态为Negative时,优先级降低的数额,执行vrrp ipv6 vrid track命令后,才会显示此信息
Switchover
Config weight
虚拟转发器的配置权重,取值为255
Running weight
Forwarder 01
虚拟转发器01的信息
虚拟转发器的状态,取值包括:
Virtual MAC
虚拟转发器的虚拟MAC地址
Owner ID
虚拟转发器拥有者的接口实际MAC地址
Priority
Active
AVF的接口的链路本地地址,当前转发器为AVF时,显示为local
虚拟转发器权重监视配置信息。执行vrrp ipv6 vrid track命令后,才会显示此信息
Track object
权重监视的Track项。执行vrrp ipv6 vrid track命令后,才会显示此信息
Weight reduced
监视的Track项状态为Negative时,权重降低的数额。执行vrrp ipv6 vrid track命令后,才会显示此信息
虚拟转发器快速切换模式监视配置信息。执行vrrp ipv6 vrid track命令后,才会显示此信息
Member IP
备份组中成员设备的IPv6地址。执行vrrp ipv6 vrid track命令后,才会显示此信息
·     vrrp ipv6 mode
·     vrrp ipv6 vrid
·     vrrp ipv6 vrid preempt-mode
·     vrrp ipv6 vrid priority
·     vrrp ipv6 vrid timer advertise
·     vrrp ipv6 vrid track
display vrrp ipv6 binding命令用来显示IPv6 VRRP备份组的管理备份组和成员备份组关联信息。
display vrrp ipv6 binding [ interface interface-type interface-number [ vrid virtual-router-id ] | name name ]
interface interface-type interface-number:显示指定接口的IPv6 VRRP备份组的管理备份组和成员备份组的关联信息。interface-type interface-number为接口类型和接口编号。
vrid virtual-router-id:显示指定IPv6 VRRP备份组的管理备份组和成员备份组的关联信息。virtual-router-id为IPv6 VRRP备份组号,取值范围为1~255。
name name:显示指定管理组和成员备份组的关联信息。name 为IPv6 VRRP管理备份组名称,为1~20个字符的字符串,区分大小写。
如果未指定接口名、备份组号和管理组名称,则显示所有IPv6 VRRP备份组的管理备份组和成员备份组的关联信息。如果只指定接口名,未指定备份组号,则显示该接口上的所有IPv6 VRRP管理备份组的关联信息。如果同时指定接口名和备份组号,则显示该接口上指定IPv6 VRRP备份组的管理备份组和成员备份组的关联信息。如果只指定管理组名称,则显示与管理组名称对应的IPv6 VRRP备份组的管理备份组和成员备份组的关联信息。
# 显示IPv6 VRRP备份组的管理备份组及成员备份组关联信息。
<Sysname> display vrrp ipv6 binding
IPv6 virtual router binding information:
表1-12 display vrrp ipv6 binding命令显示信息描述表
IPv6虚拟路由器绑定信息
设备上管理备份组的数目
设备上成员备份组的数目
Master VRID
Name
VRRP管理备份组名称
Status
当前路由器在备份组中的状态,取值为:
VRID
·     vrrp ipv6 vrid follow
·     vrrp ipv6 vrid name
display vrrp ipv6 statistics命令用来显示IPv6 VRRP备份组的统计信息。
display vrrp ipv6 statistics [ interface interface-type interface-number [ vrid virtual-router-id ] ]
interface interface-type interface-number:显示指定接口的IPv6 VRRP备份组的统计信息。其中,interface-type interface-number为接口类型和接口编号。
vrid virtual-router-id:显示指定备份组号的IPv6 VRRP备份组统计信息,其中,virtual-router-id为IPv6 VRRP备份组号,取值范围为1~255。
如果未指定接口名和备份组号,则显示该路由器上所有IPv6 VRRP备份组的统计信息;如果指定接口名,未指定备份组号,则显示该接口上的所有IPv6 VRRP备份组的统计信息;如果同时输入接口名和备份组号,则显示该接口上指定IPv6 VRRP备份组的统计信息。
# VRRP工作在标准协议模式时,显示所有IPv6 VRRP备份组的统计信息。
<Sysname> display vrrp ipv6 statistics
 VRID                    : 1
 Hop Limit Errors        : 0          Advertisement Interval Errors : 0
 Adver Sent              : 425        Priority Zero Pkts Sent       : 0
 Global statistics
 CheckSum Errors         : 0
 Version Errors          : 0
 VRID Errors             : 0
# VRRP工作在负载均衡模式时,显示全部IPv6 VRRP备份组的统计信息。
 VRID                    : 1
 Global statistics
 CheckSum Errors         : 0
 Version Errors          : 0
 VRID Errors             : 0
表1-13 display vrrp ipv6 statistics显示信息描述表(标准协议模式)
备份组所在接口
VRID
备份组号
CheckSum Errors
校验和错误的报文数
Version Errors
版本号错误的报文数
Invalid Pkts Rcvd
接收到报文类型错误的报文数
接收到未期望的报文数
Hop Limit Errors
跳数限制错误的报文数
Auth Failures
认证失败的报文数
Invalid Auth Type
认证类型无效的报文数
Auth Type Mismatch
认证类型不匹配的报文数
VRRP报文长度错误的报文数
Address List Errors
备份组虚拟IP地址列表错误的报文数
Become Master
成为Master路由器的次数
Adver Rcvd
收到的VRRP通告报文的数目
Adver Sent
发送的VRRP通告报文的数目
IP Owner Conflicts
IP地址拥有者发生冲突的报文数
Global statistics
所有备份组的全局统计信息
CheckSum Errors
校验和错误的报文总数
Version Errors
版本号错误的报文总数
VRID Errors
备份组号错误的报文总数
表1-14 display vrrp ipv6 statistics显示信息描述表(负载均衡模式)
备份组所在接口
VRID
备份组号
CheckSum Errors
校验和错误的报文数
Version Errors
版本号错误的报文数
Invalid Pkts Rcvd
接收到报文类型错误的报文数
接收到未期望的报文数
Hop Limit Errors
跳数限制错误的报文数
Auth Failures
认证错误的报文数
Invalid Auth Type
认证类型无效的报文数
Auth Type Mismatch
认证类型不匹配的报文数
VRRP报文长度错误的报文数
Address List Errors
虚拟IP地址列表错误的报文数
Become Master
成为Master路由器的次数
Redirect Timer超时的次数
Become AVF
成为AVF的次数
Time-out Timer超时的次数
Adver Rcvd
Request Rcvd
收到的Request报文的数目
Adver Sent
Request Sent
发送的Request报文的数目
Reply Rcvd
收到的Reply报文的数目
Release Rcvd
收到的Release报文的数目
Reply Sent
发送的Reply报文的数目
Release Sent
发送的Release报文的数目
报文状态选项错误的次数
Global statistics
所有备份组的全局统计信息
CheckSum Errors
校验和错误的报文总数
Version Errors
版本号错误的报文总数
VRID Errors
备份组号错误的报文总数
·     reset vrrp ipv6 statistics
reset vrrp ipv6 statistics命令用来清除IPv6 VRRP备份组的统计信息。
reset vrrp ipv6 statistics [ interface interface-type interface-number [ vrid virtual-router-id ] ]
interface interface-type interface-number:清除指定接口的IPv6 VRRP备份组统计信息。其中,interface-type interface-number为接口类型和接口编号。
vrid virtual-router-id:清除指定备份组的IPv6 VRRP统计信息。其中,virtual-router-id为IPv6 VRRP备份组号,取值范围为1~255。
在清除IPv6 VRRP备份组统计信息时,如果未指定接口名和备份组号,则清除该路由器上所有IPv6 VRRP备份组的统计信息;如果指定接口名,未指定备份组号,则清除该接口上所有IPv6 VRRP备份组的统计信息;如果同时输入接口名和备份组号,则清除该接口上指定IPv6 VRRP备份组的统计信息。
# 清除所有接口上所有备份组的IPv6 VRRP统计信息。
<Sysname> reset vrrp ipv6 statistics
·     display vrrp ipv6 statistics
vrrp ipv6 dot1q命令用来配置IPv6 VRRP的控制VLAN。
undo vrrp ipv6 dot1q命令用来恢复缺省情况。
vrrp ipv6 dot1q vid vlan-id [ secondary-dot1q secondary-vlan-id ]
未指定IPv6 VRRP的控制VLAN,即VLAN终结支持广播/组播功能后,Master在所有模糊终结的VLAN内发送IPv6 VRRP通告报文。
三层以太网子接口视图
三层聚合子接口视图
vid vlan-id:指定IPv6 VRRP的外层控制VLAN的编号,vlan-id的取值范围为1~4094。
secondary-dot1q secondary-vlan-id:指定内层控制VLAN的编号,secondary-vlan-id的取值范围为1~4094。如果未指定该参数,则表示在配置了模糊Dot1q终结的子接口上指定控制VLAN。
# 配置IPv6 VRRP的外层控制VLAN ID为2,内层控制VLAN ID为100。
[Sysname-Ten-GigabitEthernet3/0/1.2] vrrp ipv6 dot1q vid 2 secondary-dot1q 100
vrrp ipv6 dscp命令用来配置IPv6 VRRP发送报文的DSCP优先级。
undo vrrp ipv6 dscp命令用来恢复缺省情况。
vrrp ipv6 dscp dscp-value
undo vrrp ipv6 dscp
IPv6 VRRP发送报文的DSCP优先级为56。
dscp-value:IPv6 VRRP报文的DSCP优先级,取值范围为0~63。
# 配置IPv6 VRRP报文的DSCP优先级为30。
[Sysname] vrrp ipv6 dscp 30
vrrp ipv6 isolate enable命令用来开启IPv6 VRRP的隔离模式。
undo vrrp ipv6 isolate enable命令用来关闭IPv6 VRRP的隔离模式。
IPv6 VRRP的隔离模式处于关闭状态。
开启IPv6 VRRP的隔离模式后,本设备在IPv6 VRRP备份组中的优先级将被设置为0。
当设备处于隔离模式时,通过vrrp ipv6 vrid priority命令配置的新优先级不会立即生效,会在关闭IPv6 VRRP的隔离模式后生效。
# 开启IPv6 VRRP的隔离模式。
[Sysname] vrrp ipv6 isolate enable
vrrp ipv6 mode命令用来配置IPv6 VRRP的工作模式。
undo vrrp ipv6 mode命令用来恢复缺省情况。
vrrp ipv6 mode load-balance
undo vrrp ipv6 mode
IPv6 VRRP工作在标准协议模式。
load-balance:指定IPv6 VRRP工作在负载均衡模式。
IPv6 VRRP工作在负载均衡模式时,要求备份组虚拟IPv6地址和接口的IPv6地址不能相同。否则,负载均衡功能将无法正常工作。
创建IPv6 VRRP备份组后,仍然可以修改工作模式。修改工作模式后,路由器上所有的IPv6 VRRP备份组都会工作在该模式。
# 配置IPv6 VRRP工作在负载均衡模式。
[Sysname] vrrp ipv6 mode load-balance
·     display vrrp ipv6
vrrp ipv6 send-nd命令用来配置IPv6 VRRP Master路由器定时发送ND报文。
undo vrrp ipv6 send-nd命令用来恢复缺省情况。
vrrp ipv6 send-nd [ interval interval ]
IPv6 VRRP Master路由器不会定时发送ND报文。
interval:指定发送ND报文的时间间隔,取值范围为30~1200,单位为秒。缺省值为120。
配置本功能后,Master路由器定时发送ND报文用来保证下游设备的MAC地址表项能够定时刷新。该命令只在VRRP标准模式下生效。
重复执行本命令修改ND报文的发送时间间隔,修改后的时间间隔在下一个发送时间间隔生效。
为了防止设备在同一时间发送大量ND报文,当设备同时作为多个IPv6 VRRP备份组的Master路由器时,在这些IPv6 VRRP备份组中Master路由器会在执行本命令后的interval/2到interval时间内随机发送第一个ND报文。
如果设备上配置了大量的IPv6 VRRP备份组,同时又配置了很小的ND报文发送时间间隔,那么ND报文的实际发送时间间隔可能会远远高于用户配置的时间间隔。
# 配置IPv6 VRRP Master路由器定时发送ND报文,并配置ND报文发送时间为200秒。
[Sysname] vrrp ipv6 send-nd interval 200
vrrp ipv6 send-nd enhance enable命令用来开启IPv6 VRRP备份组增强发送ND报文功能。
undo vrrp ipv6 send-nd enhance enable命令用来关闭IPv6 VRRP备份组增强发送ND报文功能。
IPv6 VRRP备份组增强发送ND报文功能处于关闭状态。
本命令只在VRRP标准模式下生效。
当IPv6 VRRP备份组发生备升主时,缺省情况下,新Master路由器只发送一次ND报文。为了避免ND报文丢失导致下游交换机不能及时刷新目的MAC地址和出接口,可配置本命令。
配置本命令后,当IPv6 VRRP备份组发生备升主时,新Master路由器会连续发送六次ND报文;如果新Master路由器同时作为多个IPv6 VRRP备份组的Master路由器时,新Master路由器会针对每个虚IPv6地址发送六次ND报文。
# 开启IPv6 VRRP备份组增强发送ND报文功能。
[Sysname] vrrp ipv6 send-nd enhance enable
·     display vrrp ipv6
vrrp ipv6 state-transition-delay命令用来指定IPv6 VRRP备份组从Initialize状态切换到Master(或Backup)状态的延迟时间。
undo vrrp ipv6 state-transition-delay命令用来恢复缺省情况。
vrrp ipv6 state-transition-delay delay-value
IPv6 VRRP备份组从Initialize状态切换到Master(或Backup)状态的延迟时间为0秒。
delay-value:IPv6 VRRP备份组从Initialize状态切换到Master(或Backup)状态的延迟时间,取值范围为0~60,单位为秒。
缺省情况下,当设备的接口UP后,该接口上配置的IPv6 VRRP备份组的状态会立即从Initialize状态切换到Master(或Backup)状态。当设备重启或接口状态频繁改变时,会导致IPv6 VRRP备份组状态不稳定,影响IPv6 VRRP备份组正常工作。配置本功能后可以解决该问题,当设备的接口UP后,状态切换延迟时间开始计时,如果超时前接口Shutdown,则计时停止,IPv6 VRRP备份组仍处于Initialize状态。等接口UP后重新开始计时,当延迟时间超时后,IPv6 VRRP备份组才会从Initialize状态切换到Master(或Backup)状态。
# 指定IPv6 VRRP备份组从Initialize状态切换Master(或Backup)状态的延迟时间为5秒。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 state-transition-delay 5
vrrp ipv6 vrid命令用来创建IPv6 VRRP备份组,配置IPv6 VRRP备份组的虚拟IPv6地址,或为一个已经存在的IPv6 VRRP备份组添加一个虚拟IPv6地址。
undo vrrp ipv6 vrid命令用来删除一个已经存在的IPv6 VRRP备份组的所有配置,或删除已经存在的IPv6 VRRP备份组中的虚拟IPv6地址。
vrrp ipv6 vrid virtual-router-id virtual-ip virtual-address [ link-local ]
undo vrrp ipv6 vrid virtual-router-id [ virtual-ip [ virtual-address [ link-local ] ] ]
不存在IPv6 VRRP备份组。
virtual-router-id:IPv6 VRRP备份组号,取值范围为1~255。
virtual-ip virtual-address:备份组的虚拟IPv6地址。删除IPv6 VRRP备份组中的虚拟IPv6地址时,如果未指定virtual-address参数,则表示删除该备份组中的所有虚拟IPv6地址。
link-local:虚拟IPv6地址为链路本地地址。如果未指定本参数,则虚拟IPv6地址不是链路本地地址。IPv6链路本地地址,地址前面10位必须为1111111010(二进制标识),即地址最前面的一组十六进制数为FE80~FEBF。
重复执行本命令,可以为备份组配置多个虚拟IPv6地址,但每个备份组最多只能配置16个虚拟IPv6地址。
备份组的第一个虚拟IPv6地址必须是链路本地地址,链路本地地址必须最后删除。
一个VRRP备份组中只允许有一个链路本地地址。
如果没有为备份组配置虚拟IPv6地址,但是为备份组进行了其他配置(如优先级、抢占方式等),则该备份组会存在于设备上,并处于Inactive状态,此时备份组不起作用。
建议将备份组的虚拟IPv6地址和接口的IPv6地址配置为同一网段,否则可能导致局域网内的主机无法访问外部网络。
# 创建IPv6 VRRP备份组1,配置IPv6 VRRP备份组1的虚拟IPv6地址为fe80::10。为IPv6 VRRP备份组1添加一个虚拟IPv6地址1::10。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 virtual-ip fe80::10 link-local
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 virtual-ip 1::10
·     display vrrp ipv6
vrrp ipv6 vrid follow命令用来配置IPv6 VRRP成员备份组关联的IPv6管理备份组。
undo vrrp ipv6 vrid follow命令取消IPv6 VRRP成员备份组关联的IPv6管理备份组。
vrrp ipv6 vrid virtual-router-id follow name
undo vrrp ipv6 vrid virtual-router-id follow
未配置IPv6 VRRP成员备份组关联IPv6管理备份组。
name:IPv6 VRRP管理备份组名称,为1~20个字符的字符串,区分大小写。
为IPv6 VRRP备份组关联了IPv6管理备份组后,该IPv6 VRRP备份组作为该IPv6管理备份组的IPv6成员备份组,其状态与IPv6管理备份组状态保持一致。IPv6成员备份组不处理IPv6 VRRP通告报文,只转发业务流量。
一个IPv6 VRRP备份组不能同时作为IPv6管理备份组和IPv6成员备份组。
如果IPv6 VRRP备份组所关联的IPv6管理备份组不存在,则该IPv6 VRRP备份组始终处于Inactive状态。
如果IPv6 VRRP备份组在关联IPv6管理备份组前处于Inactive或Initialize状态,关联的IPv6管理备份组处于除Inactive状态的其他状态,则关联之后该IPv6 VRRP备份组状态保持不变。
# 配置IPv6 VRRP成员备份组关联的IPv6管理备份组为abc。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 follow abc
·     display vrrp ipv6 binding
vrrp ipv6 vrid ignore-interface-down命令用来开启IPv6 VRRP忽略接口物理状态down功能。
undo vrrp ipv6 vrid ignore-interface-down命令用来关闭IPv6 VRRP忽略接口物理状态down功能。
vrrp ipv6 vrid virtual-router-id ignore-interface-down
undo vrrp ipv6 vrid virtual-router-id ignore-interface-down
IPv6 VRRP忽略接口物理状态down功能处于关闭状态。
某些可靠性业务(如多机备份、备份组和IPv6 VRRP成员备份组)需要根据IPv6 VRRP备份组中的设备状态选举出本业务的主用设备和备用设备。主用设备对应IPv6 VRRP备份组中的Master设备,用来处理业务数据;备用设备对应IPv6 VRRP备份组中的Backup设备,用来监控主用设备状态。当在两台设备直连链路两端的接口上配置IPv6 VRRP备份组时,如果链路的一端接口故障或链路故障,IPv6 VRRP备份组内的Master设备和Backup设备都会变成Initialize状态,可靠性业务中的主用设备和备用设备也会变成初始状态,主用设备无法继续处理业务数据。在IPv6 VRRP备份组中的两台设备上同时开启IPv6 VRRP忽略接口物理状态down功能后,当IPv6 VRRP备份组的端口物理状态down时,IPv6 VRRP备份组内的Master设备和Backup设备保持状态不变,从而保证可靠性业务不会中断。
# 在接口Ten-GigabitEthernet3/0/1上开启IPv6 VRRP忽略接口物理状态down功能。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 ignore-interface-down
vrrp ipv6 vrid initialize state-hold-time命令用来配置IPv6 VRRP备份组初始化状态保持时间。
undo vrrp ipv6 vrid initialize state-hold-time命令用来恢复缺省情况。
vrrp ipv6 vrid virtual-router-id initialize state-hold-time timer
undo vrrp ipv6 vrid virtual-router-id initialize state-hold-time
IPv6 VRRP备份组初始化状态保持时间为0秒。表示初始化状态不保持,根据IPv6 VRRP组实际状态立即切换。
timer:IPv6 VRRP备份组初始化状态保持时间,取值范围为0~3600,单位为秒。
在使用管理备份组,且配置了忽略接口Down事件功能,当IPv6 VRRP备份组的端口物理状态为down时,IPv6 VRRP备份组内的Master设备和Backup设备的状态会保持不变。如果设备重启或者备份接口第一次连通,Master设备和Backup设备会在接口第一次up前一直保持Initialize状态。导致引用该备份组的其它功能不能处理业务。为了应对这种场景,可配置本命令,IPv6 VRRP会启动相应时间的定时器,定时器超时后IPv6 VRRP就会进入Backup状态,从而保证引用该备份组的其它功能可以处理业务。
# 在接口Ten-GigabitEthernet3/0/1上配置IPv6 VRRP备份组初始化状态保持时间为60秒。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 initialize state-hold-time 60
vrrp ipv6 vrid name命令用来配置IPv6 VRRP管理备份组。
undo vrrp ipv6 vrid name命令用来取消配置的IPv6 VRRP管理备份组。
vrrp ipv6 vrid virtual-router-id name name
undo vrrp ipv6 vrid virtual-router-id name
未配置IPv6 VRRP管理备份组。
创建IPv6 VRRP备份组后,通过该命令为IPv6 VRRP备份组指定一个管理备份组名称,则该备份组成为管理备份组。其他IPv6 VRRP备份组关联该管理备份组后,即成为该管理备份组的成员备份组。管理备份组既处理IPv6 VRRP通告报文,也转发业务流量。成员备份组不处理IPv6 VRRP通告报文,只转发业务流量。
同一台设备上不同的IPv6 VRRP备份组不能配置相同的管理备份组名称。
# 配置IPv6 VRRP管理备份组abc。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 name abc
vrrp ipv6 vrid nd copy-to-member命令用来开启VRRP复制ND报文功能。
undo vrrp ipv6 vrid nd copy-to-member命令用来关闭VRRP复制ND报文功能。
vrrp ipv6 vrid virtual-router-id nd copy-to-member
undo vrrp ipv6 vrid virtual-router-id nd copy-to-member
VRRP复制ND报文功能处于关闭状态。
以太网聚合接口视图
以太网聚合子接口视图
本命令只在VRRP标准模式下生效。
当IPv6 VRRP备份组发生备升主时,且IPv6 VRRP备份组配置在聚合接口或者聚合子接口时,缺省情况下,VRRP只会往一个聚合成员接口发送ND报文。为了确保下游设备能及时收到ND报文,加快网络收敛速度,可执行本命令,开启IPv6 VRRP复制ND报文功能。
配置本命令后,当IPv6 VRRP备份组发生备升主时,VRRP会往所有聚合成员接口复制一份ND报文,使得下游设备可以及时收到ND报文并刷新表项,网络可以快速收敛。
# 在聚合接口1下开启IPv6 VRRP备份组1的复制ND报文功能。
[Sysname-Route-Aggregation1] vrrp ipv6 vrid 1 nd copy-to-member
·     display vrrp ipv6
vrrp ipv6 vrid preempt-mode命令用来配置IPv6 VRRP备份组中的路由器工作在抢占方式,并配置抢占延迟时间。
undo vrrp ipv6 vrid preempt-mode命令用来取消抢占方式,即配置IPv6 VRRP备份组中的路由器工作在非抢占方式。
undo vrrp ipv6 vrid preempt-mode delay命令用来恢复抢占延迟时间为缺省值。
vrrp ipv6 vrid virtual-router-id preempt-mode [ delay delay-value ]
undo vrrp ipv6 vrid virtual-router-id preempt-mode [ delay ]
IPv6 VRRP备份组中的路由器工作在抢占方式,抢占延迟时间为0厘秒。
应用场景
工作机制
推荐配置
# 配置路由器工作于抢占方式,抢占延迟时间为5000厘秒。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 10 preempt-mode delay 5000
·     display vrrp ipv6
vrrp ipv6 vrid priority命令用来设置路由器在IPv6 VRRP备份组中的优先级。
undo vrrp ipv6 vrid priority命令用来恢复缺省情况。
vrrp ipv6 vrid virtual-router-id priority priority-value
undo vrrp ipv6 vrid virtual-router-id priority
路由器在IPv6 VRRP备份组中的优先级为100。
优先级决定路由器在备份组中的地位。优先级越高,越有可能成为Master路由器。优先级0是系统保留为特殊用途来使用的,255则是系统保留给IP地址拥有者的。
# 设置路由器在IPv6 VRRP备份组1中的优先级为150。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 priority 150
·     display vrrp ipv6
vrrp ipv6 vrid shutdown命令用来关闭指定的IPv6 VRRP备份组。
undo vrrp ipv6 vrid shutdown命令用来开启指定的IPv6 VRRP备份组。
vrrp ipv6 vrid virtual-router-id shutdown
undo vrrp ipv6 vrid virtual-router-id shutdown
IPv6 VRRP备份组处于开启状态。
virtual-router-id:VRRP备份组号,取值范围为1~255。
关闭IPv6 VRRP备份组功能通常用于暂时禁用备份组,用户发送给IPv6 VRRP备份组的报文可能会被丢弃。
# 关闭IPv6 VRRP备份组1。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 shutdown
vrrp ipv6 vrid source-interface命令用来为IPv6 VRRP备份组指定源接口。
undo vrrp ipv6 vrid source-interface命令用来取消为IPv6 VRRP备份组指定的源接口。
vrrp ipv6 vrid virtual-router-id source-interface interface-type interface-number
undo vrrp ipv6 vrid virtual-router-id source-interface
未指定IPv6 VRRP备份组的源接口,VRRP报文通过IPv6 VRRP备份组所在接口进行收发。
因组网要求或网络故障,导致同一个IPv6 VRRP备份组中的设备不能通过备份组所在接口进行VRRP协议报文交互时,可以使用本命令将其他能进行报文交互的接口设置为备份组的源接口,用来代替备份组所在接口进行该备份组VRRP报文的收发。
本功能不能与IPv6 VRRP忽略接口物理状态down功能一起使用,否则会导致生成的VRRP协议报文不合法,IPv6 VRRP备份组中的其他设备收到报文后,校验失败,丢弃该报文。
# 设置接口Ten-GigabitEthernet3/0/1上IPv6 VRRP备份组的源接口为接口Ten-GigabitEthernet3/0/2。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 10 source-interface ten-gigabitethernet 3/0/2
vrrp ipv6 vrid timer advertise命令用来配置IPv6 VRRP备份组中Master路由器发送VRRP通告报文的时间间隔。
undo vrrp ipv6 vrid timer advertise命令用来恢复缺省情况。
vrrp ipv6 vrid virtual-router-id timer advertise adver-interval
undo vrrp ipv6 vrid virtual-router-id timer advertise
IPv6 VRRP备份组中Master路由器发送VRRP通告报文的时间间隔为100厘秒。
adver-interval:IPv6 VRRP备份组中的Master路由器发送VRRP通告报文的间隔时间,取值范围为10~4095,单位为厘秒。
IPv6 VRRP备份组中的Master路由器会定时发送VRRP通告报文,通知备份组内的路由器自己工作正常。VRRP通告报文的发送时间间隔为本命令配置的值。
建议配置VRRP通告报文的发送间隔大于100厘秒,否则会对系统的稳定性产生影响。
IPv6 VRRP备份组中的路由器上配置的VRRP通告报文时间间隔可以不同。Master路由器根据自身配置的报文时间间隔定时发送通告报文,并在通告报文中携带Master路由器上配置的时间间隔;Backup路由器接收到Master路由器发送的通告报文后,记录报文中携带的Master路由器通告报文时间间隔,如果在3×记录的时间间隔+Skew_Time内未收到Master路由器发送的VRRP通告报文,则认为Master路由器出现故障,重新选举Master路由器。
# 设置IPv6 VRRP备份组1的Master路由器发送VRRP通告报文的间隔时间为500厘秒。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 timer advertise 500
·     display vrrp ipv6
vrrp ipv6 vrid track命令用来配置监视指定的Track项。
undo vrrp ipv6 vrid track命令用来取消监视指定的Track项。
vrrp ipv6 vrid virtual-router-id track track-entry-number { forwarder-switchover member-ip ipv6-address | priority reduced [ priority-reduced ] | switchover | weight reduced [ weight-reduced ] }
undo vrrp ipv6 vrid virtual-router-id track [ track-entry-number ] [ forwarder-switchover | priority reduced | switchover | weight reduced ]
未指定被监视的Track项。
forwarder-switchover member-ip ipv6-address:虚拟转发器快速切换模式。当监视的Track项状态变为Negative时,如果本地设备上有处于Listening状态的虚拟转发器,且其对应的AVF地址为member-ip,则马上将该虚拟转发器切换到Active状态。ipv6-address为备份组中成员设备的IPv6地址。可以通过display vrrp verbose命令查看备份组中包含的成员设备。
在执行本配置之前,需要先在接口上创建备份组并配置虚拟IPv6地址。
·     执行undo vrrp ipv6 vrid track命令时如果未指定track-entry-number参数,则删除该备份组与所有Track项的关联。
路由器在某个备份组中作为IP地址拥有者时,如果在该路由器上执行vrrp ipv6 vrid track priority reducedvrrp ipv6 vrid track switchover命令,则该配置不会生效。该路由器不再作为IP地址拥有者后,之前的配置才会生效。
关于forwarder-switchover member-ip ipv6-addressweight reduced [ weight-reduced ]参数,需要注意的是:
·     只有VRRP工作在负载均衡模式时,指定forwarder-switchover member-ip ipv6-addressweight reduced [ weight-reduced ]才会生效。
# 在接口Ten-GigabitEthernet3/0/1上配置监视Track项1,当Track项1状态为Negative时,接口Ten-GigabitEthernet3/0/1上IPv6 VRRP备份组1的优先级降低50。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 track 1 priority reduced 50
# 在接口Ten-GigabitEthernet3/0/1上配置虚拟转发器监视Track项1,当Track项1状态为Negative时,如果本地设备上AVF地址为1::3的虚拟转发器处于Listening状态,则马上将该虚拟转发器切换到Active状态。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 track 1 forwarder-switchover member-ip 1::3
# 在接口Ten-GigabitEthernet3/0/1上配置虚拟转发器权重监视Track项1,当Track项1状态为Negative时,接口Ten-GigabitEthernet3/0/1上IPv6 VRRP备份组1所有虚拟转发器的权重都降低50。
[Sysname-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 track 1 weight reduced 50
·     display vrrp ipv6
