02-QoS命令
本章节下载: 02-QoS命令 (914.71 KB)
1.1.2 display traffic classifier
1.2.4 display traffic behavior
1.2.9 primap pre-defined color
1.2.16 remark local-precedence
1.3.4 display qos policy control-plane
1.3.5 display qos policy control-plane pre-defined
1.3.6 display qos policy global
1.3.7 display qos policy interface
1.3.8 display qos policy user-profile
1.3.10 qos apply policy (interface view, control plane view)
1.3.11 qos apply policy (user-profile view)
1.3.12 qos apply policy global
1.3.15 reset qos policy control-plane
1.3.16 reset qos policy global
2.1.1 display qos exclusive-bandwidth interface outbound
3.1.1 display mode channel-bandwidth interface
4.1.2 display qos map-table color
4.1.3 display qos map-table interface
4.1.4 display qos map-table name
4.1.5 import (flexible priority map view)
4.1.6 import (priority map view)
4.1.7 qos apply map-table name
4.2.1 display qos trust interface
5.1.1 display qos car control-plane whitelist
5.1.2 display qos car interface
5.1.3 display qos car l2vpn-pw
5.1.4 display qos user-profile-car member-link-scheduler distribute
5.1.5 qos car (control plane view)
5.1.6 qos car (interface view)
5.1.7 qos car any (Cross-connect PW view, VSI LDP PW view, VSI static PW view)
5.1.8 qos car any(user-profile view)
5.1.9 qos car percent (interface view)
5.1.10 qos car whitelist enable
5.1.11 qos member-link-scheduler distribute
5.1.12 reset qos car control-plane whitelist
5.2.1 display qos gts interface
5.2.2 qos gts (interface view)
5.2.3 qos gts(user-group-profile view)
5.2.4 qos gts(session-group-profile view)
6.1.1 display qos queue interface
6.1.2 display qos-queue resource
6.2.1 display qos queue sp interface
6.3.1 display qos queue wrr interface
6.4.1 display qos queue wfq interface
6.5.2 display qos qmprofile configuration
6.5.3 display qos qmprofile interface
6.5.5 qos apply qmprofile fabric
6.5.6 qos apply qmprofile(interface view)
6.5.7 qos apply qmprofile(user-group-profile view,session-group-profile view)
7.1.1 display qos wred interface
7.1.7 queue weighting-constant
7.2.1 display qos wred-profile
7.2.4 queue (WRED profile view)
7.2.5 queue ecn (WRED profile view)
7.2.7 queue weighting-constant (WRED profile view)
9.1.1 display qos queue-statistics interface outbound
9.2.1 display qos queue-statistics user-id
9.2.2 reset qos queue-statistics user-id
11.1.1 display qos control-plane logging
11.1.2 logging packet-drop { count-threshold | rate-threshold } *
本文中的“SPC类单板”仅代表单板丝印以“SPC”开头的单板。
description命令用来配置类的描述信息。
undo description命令用来删除类的描述信息。
未配置类的描述信息。
类视图
text:表示类的描述信息,为1~127个字符的字符串,区分大小写。
多次执行本命令,最后一次执行的命令生效。
# 为类class1配置描述信息。
[Sysname-classifier-class1] description classifier
display traffic classifier命令用来显示类的配置信息。
(独立运行模式)
display traffic classifier user-defined [ classifier-name ] [ slot slot-number [ cpu cpu-number ] ]
display traffic classifier user-defined [ classifier-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定单板的流分类的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主用主控板的类的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的流分类的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示全局主用主控板的类的配置信息。(IRF模式)
cpu cpu-number:指定CPU。cpu-number表示单板上CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
# 显示用户定义类的配置信息。
User-defined classifier information:
Classifier: 1 (ID 100)
Operator: AND
Rule(s) :
If-match acl 2000
Classifier: 2 (ID 101)
Operator: AND
Rule(s) :
If-match protocol ipv6
Classifier: 3 (ID 102)
Operator: AND
Rule(s) :
-none-
表1-1 display traffic classifier命令显示信息描述表
User-defined classifier information |
用户自定义类的信息 |
Classifier |
类的名称及其内容,内容可以有多种类型 |
类的配置描述信息 |
Operator |
分类规则之间的逻辑关系 |
Rule(s) |
分类规则 |
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match match-criteria
undo if-match match-criteria
未定义匹配数据包的规则。
类视图
取值 |
acl [ ipv6 | mac ] { acl-number | name acl-name } [ mpls-inner ] |
定义匹配ACL的规则 acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999 acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all ACL规则中未指定VPN实例时,表示该规则对非VPN报文和VPN报文均有效 mpls-inner用来指定ACL规则用于匹配MPLS报文的内层报文信息,未配置mpls-inner则表示ACL规则匹配的是未经封装报文的信息或封装后的MPLS报文的外层报文头信息。此配置仅满足以下条件时生效: · 匹配IPv4高级ACL规则 · QoS策略应用在MPLS网络Transit或者Egress节点接口的入方向上 · 配置在CSPEX类单板、SPE类单板和CEPC类单板上 |
any |
定义匹配所有数据包的规则 仅SPC类单板和MPE-1104单板支持定义匹配所有数据包的规则 |
authenticated-user |
定义匹配已认证用户的数据包,且认证方式必须为IPoE、Portal或PPPoE standard工作模式下,仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板支持本功能。 sdn-wan工作模式下,仅CSPEX-1802X、CSPEX-1812X-E、CEPC-CQ8L单板支持本功能。 |
control-plane protocol protocol-name&<1-8> |
定义匹配控制平面协议的规则,protocol-name&<1-8>为系统预定义匹配协议报文类型名称的列表,具体如表1-3所示,&<1-8>表示前面的参数最多可以输入8次 通过if-match control-plane protocol protocol-name&<1-8>命令定义匹配规则时,仅对使用知名端口号的协议报文生效 |
control-plane protocol-group protocol-group-name |
定义匹配控制平面协议组的规则,protocol-group-name取值为critical、important、management、monitor、normal、redirect |
customer-dot1p dot1p-value&<1-8> |
定义匹配内层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次 仅SPC类单板和MPE-1104单板支持定义匹配入方向报文内层VLAN Tag的802.1优先级规则 |
customer-vlan-id vlan-id-list |
定义匹配内层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次 |
destination-mac mac-address |
定义匹配目的MAC地址的规则,仅对以太网接口生效 CSPEX-1802X、CSPEX-1812X-E、CEPC-CQ8L单板仅出方向支持 CSPEX类单板(CSPEX-1104-E、CSPEX-1802X、CSPEX-1812X-E除外)、SPE类单板和CEPC类单板(CEPC-CQ8L除外)仅在sdn-wan工作模式下出方向支持 |
dscp dscp-value&<1-8> |
定义匹配DSCP的规则,dscp-value&<1-8>为DSCP取值的列表,DSCP的取值范围为0~63,&<1-8>表示前面的参数最多可以输入8次;也可以输入关键字,具体如表1-5所示 |
inbound-interface interface-type interface-number |
定义匹配入接口的规则,interface-type interface-number为接口类型和接口编号 |
ip-precedence ip-precedence-value&<1-8> |
定义匹配IP优先级的规则,ip-precedence-value&<1-8>为IP优先级的列表,IP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次 |
mpls-exp exp-value&<1-8> |
定义匹配第一层MPLS EXP优先级的规则,exp-value&<1-8>为EXP的列表,EXP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次 仅对MPLS报文生效 仅CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板支持 |
protocol protocol-name |
定义匹配协议的规则,protocol-name取值为arp、ip、ipv6 |
qos-local-id local-id-value |
定义匹配QoS本地ID值的规则,local-id-value为QoS本地ID,取值范围为1~4095 |
service-dot1p dot1p-value&<1-8> |
定义匹配外层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次 |
service-vlan-id vlan-id-list |
定义匹配外层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次 若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID规则来匹配 |
source-mac mac-address |
定义匹配源MAC地址的规则,仅对以太网接口生效 CSPEX-1802X、CSPEX-1812X-E、CEPC-CQ8L单板仅在入方向支持 CSPEX类单板(CSPEX-1104-E、CSPEX-1802X、CSPEX-1812X-E除外)、SPE类单板和CEPC类单板(CEPC-CQ8L除外)sdn-wan工作模式下,仅在入方向支持;standard工作模式下,出和入方向都支持 |
vxlan { any | vxlan-id } |
定义匹配VXLAN编号的规则,取值范围为0~16777215 仅在VXLAN网络中核心设备和VXLAN隧道两端的入方向上生效 standard工作模式下,仅CSPEX-1802X、CSPEX-1812X-E、CEPC-CQ8L单板入方向支持。 sdn-wan工作模式下,仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板入方向支持。 CSPEX-1802X、CSPEX-1812X-E、CEPC-CQ8L单板的接口上使用本匹配规则后,如果通过vxlan udp-port命令修改了VXLAN报文的目的UDP端口号,则需要依次执行undo if-match vxlan { any | vxlan-id }和if-match vxlan { any | vxlan-id }命令重新定义匹配VXLAN编号的规则。有关vxlan udp-port命令的详细介绍,请参见“VXLAN命令参考”中的“VXLAN” |
报文类型 |
arp |
ARP协议 |
arp-snooping |
ARP Snooping协议 |
bgp4+ |
IPv6 BGP |
default |
其他协议 |
dhcp-snooping |
DHCP Snooping协议 |
dldp |
DLDP协议 |
dot1x |
802.1p 协议 |
hoplimit-expires |
Hop Limit超时 |
igmp |
IGMP协议 |
ip-option |
带选项字段的IPv4报文 |
ipv6-option |
带选项字段的IPv6报文 |
isis |
IS-IS协议 |
lacp |
LACP协议 |
lldp |
LLDP协议 |
mvrp |
MVRP协议(包含GVRP协议) |
nqa-icmp |
用于NQA探测的ICMP协议 |
nqa-tcp |
用于NQA测试的TCP协议 |
nqa-udp |
用于NQA探测的UDP协议 |
ospf-multicast |
OSPF组播 |
ospf3-multicast |
OSPFv3组播 |
ospf3-unicast |
OSPFv3单播 |
radius |
RADIUS协议 |
stp |
STP协议 |
tacacs |
TACACS协议 |
ttl-expires |
TTL超时 |
vrrp |
VRRP协议 |
vrrp6 |
IPv6 VRRP协议 |
一个类下可配置多条匹配命令,各个配置之间互相不覆盖。
在定义匹配规则(DSCP、VLAN ID、802.1p优先级、IP优先级、MPLS EXP优先级)时,请注意:
· 一条命令可以配置多个规则,如果指定了多个相同的规则,系统默认为一个;一条命令中多个不同的规则是或的关系,即只要有一个值匹配,就算匹配这条规则。
· 删除某条匹配的规则时,必须与该规则中定义的完全相同才会删除,顺序可以不同。
在定义匹配ACL的规则时,请注意:
· 类中引用的ACL必须已经存在,如果类中引用的ACL不存在,则不能在硬件中下发。
· 当if-match中引用的ACL规则的动作为deny时,将不执行任何动作。报文匹配只使用ACL中的分类域。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的802.1p优先级为3。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1或6或9的报文。
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# 定义类class1的匹配规则为:匹配IP优先级值为1或6的报文。
[Sysname-classifier-class1] if-match ip-precedence 1 6
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的VLAN ID值为1或6或9的报文。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的VLAN ID值为2或7或10的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# 定义类class1匹配QoS本地ID值为3的报文。
[Sysname-classifier-class1] if-match qos-local-id 3
# 定义类class1的匹配规则为:匹配VXLAN编号为10的报文。
[Sysname-classifier-class1] if-match vxlan 10
traffic classifier命令用来创建一个类,并进入类视图。如果指定的类已经存在,则直接进入类视图。
undo traffic classifier命令用来删除一个类。
未配置类。
operator:指定各规则之间的逻辑运算符。缺省情况为and。
# 定义一个名为class1的类。
· display traffic classifier
accounting命令用来配置流量统计动作。
undo accounting命令用来恢复缺省情况。
accounting { byte | packet }
undo accounting
未配置流量统计动作。
流行为视图
byte:表示报文基于字节进行统计。
packet:表示报文基于包进行统计。
# 为流行为配置流量统计动作,基于字节进行统计。
[Sysname-behavior-database] accounting byte
bind nat-instance命令用来为流行为配置流量绑定NAT实例动作。
undo bind nat-instance命令用来恢复缺省情况。
bind nat-instance instance-name
undo bind nat-instance instance-name
未配置流量绑定NAT实例动作。
流行为视图
instance-name:表示NAT实例的名称,为1~31个字符的字符串,区分大小写。
NAT可以分为接口NAT和全局NAT;通过配置流量绑定NAT实例动作,即将需要进行NAT的流量重定向到指定NAT实例,由NAT实例对流量进行NAT处理,可以实现全局NAT功能。有关NAT的详细介绍,请参见“NAT配置指导”中的“NAT”。
本命令与redirect failover-group命令互斥。
# 为流行为database配置流量绑定NAT实例test的动作。
[Sysname-behavior-database] bind nat-instance test
· nat instance(NAT命令参考/NAT)
car命令用来配置流量监管动作。
undo car命令用来恢复缺省情况。
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
未配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。取值范围为1~300000000。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
· 如果不指定cbs参数,缺省取值为62.5 × committed-information-rate的乘积。
· 如果指定cbs参数,取值范围512~256000000。
ebs excess-burst-size:超出突发尺寸,单位为byte。
· 如果指定本参数,取值范围0~256000000。
· 如果不指定本参数,缺省值为62.5 × peak-information-rate的乘积。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为1~300000000。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass。
action:对数据包采取的动作,有以下几种:
· discard:丢弃数据包。
· pass:允许数据包通过。
· remark-dot1p-pass new-cos:设置新的802.1P报文的优先级值,并允许数据包通过,取值范围为0~7。
· remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63。
· remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
对于CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板上的绿色和黄色报文,只支持缺省动作,对于CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板上的红色报文,只支持discard和pass动作。
接口上应用的策略中使用car时,可以应用到接口报文的接收或者发送方向。
控制平面上应用的策略中使用car时,支持配置cir的取值范围为1~10000kbps。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
如果未配置峰值速率,则表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 为流行为配置流量监管。报文正常流速为200kbps,承诺突发尺寸为51200bytes,速率大于200kbps时,报文DSCP值改为0并发送。
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior命令用来显示流行为的配置信息。
display traffic behavior user-defined [ behavior-name ] [ slot slot-number [ cpu cpu-number ] ]
display traffic behavior user-defined [ behavior-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定单板的流行为的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的流行为的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的流行为的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的流行为的配置信息。(IRF模式)
# 显示用户定义行为的配置信息。
User-defined behavior information:
Behavior: 1 (ID 100)
Marking:
Remark dscp 3
Committed Access Rate:
CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Primap pre-defined table: dscp-dp
Behavior: 2 (ID 101)
Accounting enable: Packet
Filter enable: Permit
Marking:
Remark mpls-exp 4
Redirect to SR-TE policy:
Endpoint: 10.0.0.2
Color : 123464
Redirect to SRv6-TE policy:
Endpoint: 56::44
Color : 123464
SID : 5a::13
Behavior: 3 (ID 102)
-none-
Behavior: 4 (ID 103)
Mirroring:
Mirror to the interface: Ten-GigabitEthernet3/1/1 pop-label
表1-4 display traffic behavior命令显示信息描述表
User-defined behavior information |
用户自定义流行为的信息 |
Behavior |
行为的名称及其内容,内容可以有多种类型 |
Marking |
标记相关信息 |
Remark dscp |
重新标记报文的DSCP优先级值 |
Committed Access Rate |
流量限速的相关信息 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,单位为byte |
EBS |
超出突发尺寸,单位为byte |
Green action |
对绿色报文的动作 |
Red action |
对红色报文的动作 |
Yellow action |
对黄色报文的动作 |
Primap pre-defined color table |
预定义带颜色映射表相关信息。对于带颜色映射表的描述可以参见4.1 优先级映射表配置命令 |
Accounting enable |
流量统计动作 |
Filter enable |
流量过滤动作 |
Remark mpls-exp |
重新标记报文的EXP优先级值 |
none |
表示未配置其他流行为 |
Redirect to SR-TE policy |
重定向到SR-MPLS TE Policy · Endpoint:目的节点地址 · Color:Color属性值 |
Redirect to SRv6-TE policy |
重定向到SRv6 TE Policy · Endpoint:目的节点地址 · Color:Color属性值 · SID:尾节点的SRv6 SID |
filter命令用来配置流量过滤动作。
undo filter命令用来恢复缺省情况。
filter { deny | permit }
undo filter
未配置流量过滤动作。
流行为视图
deny:丢弃数据包。
permit:允许数据包通过。
# 为流行为配置丢弃数据包的过滤动作。
free account命令用来配置流量放行,对于匹配的流量不进行限速和计费。
undo free account命令用来取消流量放行。
free account
undo free account
未配置流量放行的动作。
流行为视图
# 配置流量放行动作,对于匹配的流量不进行限速和计费。
[Sysname-behavior-database] free account
nest top-most命令用来配置添加报文的外层VLAN Tag动作。
undo nest top-most命令用来恢复缺省情况。
nest top-most vlan vlan-id
undo nest top-most
未配置添加报文外层VLAN Tag动作。
流行为视图
vlan vlan-id:添加的VLAN ID,取值范围为1~4094。
引用了添加VLAN Tag动作的QoS策略只能应用到接口的入方向上。
# 在流行为b1上配置如下动作:添加VLAN ID为123的外层VLAN Tag。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
primap color-map-dp命令用来配置根据报文颜色标记报文丢弃优先级的动作。
undo primap color-map-dp命令用来恢复缺省情况。
primap color-map-dp
未配置标记报文丢弃优先级的动作。
流行为视图
本命令需要和car命令共同使用。
报文颜色与丢弃优先级的映射关系为:红色对应丢弃优先级2,黄色对应丢弃优先级1,绿色对应丢弃优先级0。此映射关系固定,不能修改。
# 根据报文的颜色标记报文的丢弃优先级。
[Sysname-behavior-behavior1] car cir 1600
[Sysname-behavior-behavior1] primap color-map-dp
· primap pre-defined color
primap pre-defined color命令用来配置流行为中的动作为使用相应的带颜色优先级映射表为报文获取其他的优先级参数。
undo primap pre-defined color命令用来取消流行为中的使用相应的带颜色优先级映射表为报文映射优先级的动作。
primap pre-defined color { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
undo primap pre-defined color { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
未配置优先级映射动作。
流行为视图
pre-defined:预先定义的优先级映射表。
color:使用带颜色优先级映射表做映射。
dot1p-dot1p:802.1p优先级到802.1p优先级映射表。
dot1p-dp:802.1p优先级到丢弃优先级映射表。
dot1p-dscp:802.1p优先级到DSCP映射表。
dot1p-exp:802.1p优先级到EXP映射表。
dot1p-lp:802.1p优先级到本地优先级映射表。
dscp-dot1p:DSCP到802.1p优先级映射表。
dscp-dp:DSCP到丢弃优先级映射表。
dscp-dscp:DSCP到DSCP映射表。
dscp-exp:DSCP到EXP映射表。
dscp-lp:DSCP到本地优先级映射表。
exp-dot1p:EXP到802.1p优先级映射表。
exp-dp:EXP到丢弃优先级映射表。
exp-dscp:EXP到DSCP映射表。
exp-exp:EXP到EXP映射表。
exp-lp:EXP到本地优先级映射表。
本命令需要和car命令共同使用。
# 使用带颜色的DSCP到丢弃优先级映射表为报文获取丢弃优先级参数。
[Sysname-behavior-behavior1] primap pre-defined color dscp-dp
· display qos map-table color
· primap color-map-dp
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来恢复缺省情况。
(独立运行模式)
redirect { { access-vpn | access-cgn-vpn } vpn-instance vpn-instance-name | cpu | failover-group group-name | http-to-cpu | https-to-cpu | interface interface-type interface-number | next-hop [ vpn-instance vpn-instance-name ] { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] } | slot slot-number }
undo redirect { { access-vpn | access-cgn-vpn } | cpu | failover-group group-name | http-to-cpu | https-to-cpu | interface interface-type interface-number | next-hop | slot slot-number }
redirect { sr-policy endpoint color | srv6-policy endpoint color [ { sid | vpnsid } sid ] }
undo redirect { sr-policy | srv6-policy }
redirect { { access-vpn | access-cgn-vpn } vpn-instance vpn-instance-name | cpu | failover-group group-name | http-to-cpu | https-to-cpu | interface interface-type interface-number | next-hop [ vpn-instance vpn-instance-name ] { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] } | chassis chassis-number slot slot-number }
undo redirect { { access-vpn | access-cgn-vpn } | cpu | failover-group group-name | http-to-cpu | https-to-cpu | interface interface-type interface-number | next-hop | chassis chassis-number slot slot-number }
未配置流量重定向动作。
流行为视图
access-vpn vpn-instance vpn-instance-name:重定向到VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
access-cgn-vpn vpn-instance vpn-instance-name:将CGN业务板的流量重定向到VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
cpu:重定向到CPU。
failover-group group-name:重定向到备份组。group-name表示备份组的名称,为1~63个字符的字符串,区分大小写。
http-to-cpu:将HTTP请求报文重定向到CPU。
https-to-cpu:将HTTPS请求报文重定向到CPU。
interface:重定向到指定的接口。
interface-type interface-number:指定接口类型和接口编号(对于重定向到隧道来说,接口类型是tunnel;对于重定向到二层聚合接口来说,接口类型是bridge-aggregation;对于重定向到三层聚合接口来说,接口类型是route-aggregation)。
next-hop:重定向到指定的下一跳。在配置重定向到下一跳的动作时,指定的下一跳地址必须路由可达,如果同时配置了优选和备选地址,则至少需要有一个地址路由可达,否则将导致重定向失败。在配置生效后,重定向功能会定期查询路由表,检查下一跳地址是否有效;如果配置了Track项,则通过Track检测结果来判断下一跳地址是否有效。如果检测到优选和备选地址均失效,则重定向到下一跳的动作将不再生效。
vpn-instance vpn-instance-name:下一跳所在的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示公网的下一跳地址。
ipv4-add1:优选的下一跳IPv4地址。如果重定向到优选的IPv4地址失败,则会重定向到备选IPv4地址。
ipv4-add2:备选的下一跳IPv4地址。
ipv6-add1:优选的下一跳IPv6地址。如果重定向到优选的IPv6地址失败,则会重定向到备选IPv6地址。
ipv6-add2:备选的下一跳IPv6地址。
track track-entry-number:指定下一跳关联的Track项,优选和备选的地址可以分别指定不同的Track项。track-entry-number取值范围为1~1024。通过指定Track项,可实现与监测特性(如NQA、BFD)的联动,详情请参见“可靠性配置指导”中的“Track”。
slot slot-number:重定向到指定的单板,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:重定向到指定成员设备上的指定单板,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
sr-policy endpoint color:流量重定向到SR-MPLS TE Policy。endpoint表示SR-MPLS TE Policy的目的节点地址,格式为IPv4地址。color表示SR-MPLS TE Policy的Color属性值,取值范围为0~4294967295。
srv6-policy endpoint color [ { sid | vpnsid } sid ]:流量重定向到SRv6 TE Policy。endpoint表示SRv6 TE Policy的目的节点地址,格式为IPv6地址。color表示SRv6 TE Policy的Color属性值,取值范围为0~4294967295。sid表示指定尾节点的公网SRv6 SID。报文经SRv6 TE Policy转发后,再依据该SRv6 SID继续进行公网转发。vpnsid表示指定尾节点的私网SRv6 SID。报文经SRv6 TE Policy转发后,再依据该SRv6 SID继续进行私网转发。sid表示指定IPv6地址形式的SRv6 SID。在为报文封装的SRH中添加该SID,该SID位于SRv6 TE Policy的SID列表之后。报文经SRv6 TE Policy转发到尾节点后,尾节点再依据该SRv6 SID执行对应的转发动作。
在同一个流行为中多次配置不同的重定向动作,这些动作均会生效,但需要注意的是redirect cpu、redirect http-to-cpu和redirect https-to-cpu命令仅能配置一条。
在IPoE Web认证方式下必须配置将HTTP请求报文或HTTPS请求报文重定向到CPU。配置完成后,当用户使用浏览器进行Web认证时,如果访问的不是Portal Web服务器,接入设备会将此请求重定向到CPU,由CPU推送Portal Web服务器的Web认证页面。
为避免IPoE Web认证过程中CPU收到的大量的HTTP请求报文,可以配置ip subscriber http-fast-reply enable命令开启HTTP请求报文的快速应答功能,设备通过硬件识别HTTP请求报文并自动回复HTTP应答报文,从而减轻CPU的负担。关于ip subscriber http-fast-reply enable命令的详细介绍,请参见“BRAS业务命令参考”中的“IPoE”
仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板支持重定向到三层以太网接口和环回接口,且不支持重定向到三层聚合接口。
在配置重定向到下一跳的动作时,如果下一跳位于MPLS网络,则内层标签的TTL复制功能始终处于使能状态。关于TTL复制功能的详细介绍,请参见“MPLS基础配置指导”中的“MPLS基础”。
在CGN业务场景中,需要将内网用户某些业务流量重定向到VPN进行监控等特殊处理,redirect access-cgn-vpn vpn-instance可以将CGN业务单板中经过地址转换后的流量根据VPN实例的路由表转发到对应的VPN实例绑定的出接口。redirect access-cgn-vpn vpn-instance对于非CGN业务单板的流量不生效。CGN单板业务流量重定向到VPN功能仅支持在全局应用QoS策略时生效。
将流量重定向到SR-MPLS TE Policy时,仅支持重定向到公网;将流量重定向到SRv6 TE Policy时,支持重定向到公网与私网,且不指定{ sid | vpnsid } sid时表示公网。
配置本命令中的sid时请注意,该值在报文中携带时并不区分公网与私网,目的节点接收报文后直接根据目的节点本地的Local SID转发表项进行转发。因此,可能出现需要流量重定向到公网(或私网),而实际上尾节点根据配置的SID对流量进行了私网(或公网)转发的情况。所以在配置sid时请确保该值的正确性。
# 为流行为配置流量重定向动作,重定向到接口GigabitEthernet3/1/1。
[Sysname-behavior-database] redirect interface gigabitethernet 3/1/1
# 为流行为配置流量重定向到下一跳的动作,优选IPv4地址为10.55.66.1,备选IPv4地址为10.55.88.1,并且为优选和备选地址分别关联Track项1和2。
[Sysname-behavior-database] redirect next-hop 10.55.66.1 track 1 10.55.88.1 track 2
# 为流行为配置流量重定向动作,重定向到VPN实例vpn1中。
[Sysname-behavior-database] redirect access-vpn vpn-instance vpn1
# 为流行为配置流量重定向动作,重定向到SR-MPLS TE Policy,目的节点地址为192.168.32.32,Color属性为5。
[Sysname] traffic behavior 1
[Sysname-behavior-1] redirect sr-policy 192.168.32.32 5
# 为流行为配置流量重定向动作,重定向到公网SRv6 TE Policy,目的节点地址为2::2,Color属性为2,公网SID为2::1。
[Sysname-behavior-1] redirect srv6-policy 2::2 2 sid 2::1
· classifier behavior
· qos policy
· traffic behavior
remark account-level命令用来重新标记流量计费的级别。
undo remark account-level命令用来恢复缺省情况。
remark account-level account-level
未配置重新标记流量计费的级别。
流行为视图
account-level:流量计费的级别,取值范围为1~8。
在全局、认证接口、User-Profile视图下应用重新标记流量计费级别的QoS策略后,被QoS策略匹配的上线用户流量都应配置对应的ITA业务策略,以此实现基于目的地址的差别化计费。有关ITA业务策略的具体配置和命令,请参见“BRAS业务配置指导”和“BRAS业务命令参考”中的“AAA”。
当QoS策略中的流行为包含重新标记流量计费级别的动作时,该QoS策略仅对ITA业务策略中配置了对应的流量计费级别的上线用户生效。
请不要将ITA业务流量计费级别指定为1,因为该级别的流量还包括非ITA业务流量,会导致无法对ITA业务流量准确计费。
当QoS策略中匹配的流行为包含重新标记流量计费级别的动作时,该QoS策略仅对配置了对应流量计费级别业务的上线用户生效。
本命令仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板支持。
# 重新标记流量计费级别的值为3。
[Sysname-behavior-database] remark account-level 3
remark dot1p命令用来配置重新标记报文的802.1p优先级。
undo remark dot1p命令用来恢复缺省情况。
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
未配置重新标记报文的动作。
流行为视图
green:对绿色报文进行重新标记。CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板不支持对绿色报文进行重标记。
red:对红色报文进行重新标记。CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板不支持对红色报文进行重标记。
yellow:对黄色报文进行重新标记。CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板不支持对黄色报文进行重标记。
dot1p-value:802.1p优先级,取值范围为0~7。
在同一个流行为中,如果多次对同一种颜色的报文重新标记802.1p优先级,则最后一次执行的命令生效。
不指定green、red和yellow时,表示重标记所有颜色报文的802.1p优先级。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence命令用来重新标记报文的丢弃优先级。
undo remark drop-precedence命令用来恢复缺省情况。
remark drop-precedence drop-precedence-value
未配置重新标记报文丢弃优先级的动作。
流行为视图
drop-precedence-value:丢弃优先级,取值范围为0~2。
SPC类单板和MPE-1104单板仅支持在入方向应用QoS策略配置重新标记报文的丢弃优先级。
# 重新标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来恢复缺省情况。
undo remark [ green | red | yellow ] dscp
未配置重新标记报文的动作。
流行为视图
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
表1-5 DSCP关键字与值的对应表
关键字 |
DSCP值(二进制) |
DSCP值(十进制) |
default |
000000 |
0 |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
ef |
101110 |
46 |
在同一个流行为中,如果已配置remark tunnel-dscp命令,则不允许再配置remark dscp命令,反之亦然。
CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板不支持对有颜色的报文进行重标记。
# 重新标记报文的DSCP值为6。
remark ip-precedence命令用来重新标记报文的IP优先级。
undo remark ip-precedence命令用来恢复缺省情况。
remark ip-precedence ip-precedence-value
未配置重新标记报文的动作。
流行为视图
ip-precedence-value:IP优先级,取值范围为0~7。
在同一个流行为中,如果已配置remark tunnel-dscp命令,则不允许再配置remark ip-precedence命令,反之亦然。
# 重新标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来恢复缺省情况。
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
未配置重新标记报文的动作。
流行为视图
local-precedence-value:本地优先级,取值范围为0~7。
重新标记报文的本地优先级功能通过QoS策略实现。重新标记报文的本地优先级,即是将命中规则的报文送入指定的优先级队列中,实现报文在本设备中的差分服务。通过display qos queue-statistics interface outbound命令可查看端口队列出方向的统计信息,需保证已在出方向开启端口队列统计功能。
SPC类单板和MPE-1104单板仅支持在入方向应用QoS策略配置重新标记报文的本地优先级。
# 重新标记报文的本地优先级值为2。
· display qos queue-statistics interface outbound
· qos queue-statistics
remark qos-local-id命令用来重新标记报文的QoS本地ID值。
undo remark qos-local-id命令用来恢复缺省情况。
remark qos-local-id local-id-value
未配置重新标记报文的动作。
流行为视图
local-id-value:QoS本地ID值,取值范围为1~4095。
一般情况下,在QoS策略的入方向对报文的QoS本地ID值进行标记,在QoS策略的出方向根据标记的QoS本地ID值对报文进行分类以及指定相应的流行为,两者要结合使用。
本命令仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板支持在出方向应用QoS策略配置重新标记报文的QoS本地ID值。
# 重新标记报文的QoS本地ID值为2。
[Sysname-behavior-database] remark qos-local-id 2
remark service-class命令用来重新标记报文的MPLS TE隧道转发类的值。
undo remark service-class命令用来恢复缺省情况。
remark service-class service-class-value
未配置重新标记报文的动作。
流行为视图
service-class-value:报文的MPLS TE隧道转发类的值,取值范围为1~15。
如果流行为视图下配置了remark service-class命令:
· 则指定该动作的QoS策略仅支持应用在接口上,且当QoS策略应用在接口入方向时,该动作才能生效。可以通过display qos policy interface命令查看QoS策略中未生效的流行为。
· 当对匹配mpls-exp的流量执行重新标记报文的MPLS TE隧道转发类值的动作时,对于同一个EXP值,同一接口上仅支持配置一个重新标记报文的MPLS TE隧道转发类值的动作;且仅支持通过删除并重新配置的方式进行修改。
通过mpls te service-class命令可以配置MPLS TE隧道转发类的值,关于该命令的详细介绍,请参见“MPLS命令参考”中的“MPLS TE命令”。
仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板支持重新标记报文服务类隧道的动作。
# 重新标记报文MPLS TE隧道转发类的值为2。
[Sysname-behavior-data] remark service-class 2
remark service-id命令用来重新标记报文的EDSG业务ID。
undo remark service-id命令用来恢复缺省情况。
remark service-id service-id
未配置重新标记报文的动作。
流行为视图
service-id:表示EDSG业务ID值,取值范围为1~8,目前产品实际支持的取值范围为1~4。
基于接口和全局应用QoS策略时,该动作才会生效。
当QoS策略中匹配的流行为包含重新标记报文的EDSG业务ID动作时,该QoS策略仅对配置了对应EDSG业务ID的用户生效。
# 重新标记报文的EDSG业务ID值为2。
[Sysname-behavior-database] remark service-id 2
· service policy(BRAS业务命令参考/AAA命令)
· service-id(BRAS业务命令参考/AAA命令)
remark tunnel-dscp命令用来重新标记隧道封装后报文外层IP头的DSCP值。
undo remark tunnel-dscp命令用来恢复缺省情况。
remark tunnel-dscp dscp-value
未配置重新标记报文的动作。
流行为视图
dscp-value:隧道封装后报文外层IP头的DSCP值,取值范围为0~63,也可以是表1-6中对应的关键字。
表1-6 DSCP关键字与值的对应表
关键字 |
DSCP值(二进制) |
DSCP值(十进制) |
default |
000000 |
0 |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
ef |
101110 |
46 |
本命令对GRE、VXLAN隧道封装后的报文生效。
基于接口或全局应用QoS策略时,本命令才会生效。
在同一个流行为中,如果已配置remark dscp命令或remark ip-precedence命令,则不允许再配置remark tunnel-dscp命令,反之亦然。
如果VXLAN隧道上配置了tunnel tos命令,那么对于从本地站点接收到的广播/组播报文,在隧道封装后,该报文外层IP头的ToS值以隧道上配置的tunnel tos命令为准,不能通过remark tunnel-dscp命令修改。关于tunnel tos命令请参见“三层技术-IP业务命令参考”中的“隧道”。
仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板支持重新标记隧道封装后报文外层IP头的DSCP值。
# 重新标记隧道封装后报文外层IP头的DSCP值为2。
[Sysname-behavior-data] remark tunnel-dscp 2
traffic behavior命令用来创建一个流行为,并进入流行为视图。如果指定的流行为已经存在,则直接进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
不存在流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
# 定义一个名为behavior1的流行为。
· display traffic behavior
classifier behavior命令用来为类指定流行为。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [ mode qppb-manipulation | insert-before before-classifier-name ] *
没有为类指定流行为。
QoS策略视图
mode qppb-manipulation:设置流分类和流行为对应关系用于匹配BGP路由策略中apply qos-local-id的信息。即类中if-match qos-local-id匹配的内容对应路由策略命令中apply qos-local-id命令设置的信息,具体内容请参见“三层技术-IP路由配置指导”中的“路由策略”。
insert-before before-classifier-name:表示将配置的类插入到QoS策略中已存在的指定类之前。before-classifier-name表示QoS策略中已存在的类名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示新配置的类与流行为配对将添加到QoS策略最后。
QoS策略下每个类只能与一个流行为关联。
如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
CSPEX-1802X、CEPC-CQ8L、CSPEX-1812X-E单板配置mode qppb-manipulation时不支持匹配BGP路由策略中的IP优先级。支持匹配BGP路由策略中的QoS本地ID值和定义其他规则匹配数据包。
# 在QoS策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
# 在QoS策略user1中为类database指定采用流行为test,对应关系用于匹配BGP路由策略中apply qos-local-id的信息。
[Sysname-qospolicy-user1] classifier database behavior test mode qppb-manipulation
# 在QoS策略user1中为类database指定流行为test,并将该类插入到策略中已存在的类class-a前。
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
· qos policy
control-plane命令用来进入控制平面视图。
(独立运行模式)
control-plane slot slot-number [ cpu cpu-number ]
control-plane chassis chassis-number slot slot-number[ cpu cpu-number ]
slot slot-number:指定单板。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 进入指定slot上的控制平面视图。
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
display qos policy命令用来显示QoS策略的配置信息。
(独立运行模式)
display qos policy user-defined [ policy-name [ classifier classifier-name ] ] [ slot slot-number [ cpu cpu-number ] ]
display qos policy user-defined [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
user-defined:用户定义QoS策略。
policy-name:QoS策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:QoS策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定单板的QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的QoS策略的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的QoS策略的配置信息。(IRF模式)
# 显示用户定义QoS策略的配置信息。
User-defined QoS policy information:
Policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Behavior: 2
Marking:
Remark mpls-exp 4
Behavior: 3
-none-
Classifier: 4 (ID 103)
Behavior: 4
Redirecting:
Endpoint: 10.0.0.3
Color : 123464
Endpoint: 56::44
Color : 123464
SID : 5a::13
表1-7 display qos policy命令显示信息描述表
User-defined QoS policy information |
用户自定义QoS策略的信息 |
Policy |
QoS策略名 |
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
(独立运行模式)
display qos policy control-plane slot slot-number [ cpu cpu-number ]
display qos policy control-plane chassis chassis-number slot slot-number [ cpu cpu-number ]
slot slot-number:显示指定单板的控制平面应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的控制平面应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 显示应用到指定slot上的控制平面的QoS策略信息。
<Sysname> display qos policy control-plane slot 2
Control plane slot 2
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Green packets : 0 (Bytes)
0 (bps)
Yellow packets: 0 (Bytes)
0 (bps)
Red packets : 0 (Bytes)
0 (bps)
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
3268134 (Packets)
1000 (pps)
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
表1-8 display qos policy control-plane命令显示信息描述表
Direction |
对进入控制平面(Inbound)的报文应用QoS策略 |
Green packets |
绿色报文的流量统计和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔。有关flow-interval命令的详细介绍,请参见“接口管理命令参考”中的“以太网接口” |
Yellow packets |
黄色报文的流量统计和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔。有关flow-interval命令的详细介绍,请参见“接口管理命令参考”中的“以太网接口” |
Red packets |
红色报文的流量统计和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔。有关flow-interval命令的详细介绍,请参见“接口管理命令参考”中的“以太网接口” |
其它显示信息解释请参见表1-7。
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
(独立运行模式)
display qos policy control-plane pre-defined [ slot slot-number [ cpu cpu-number ] ]
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定单板的系统预定义的控制平面策略信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有在位单板的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的系统预定义的控制平面策略信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有成员设备上在位单板的系统预定义的控制平面应用QoS策略的信息。(IRF模式)
# 显示指定slot上的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
<Sysname> display qos policy control-plane pre-defined slot 3
Pre-defined policy information slot 3
Protocol Priority Bandwidth Group
Default N/A 7168 (kbps) N/A
IS-IS 29 8192 (kbps) critical
VRRP 36 512 (kbps) important
OSPF Multicast 30 5120 (kbps) critical
IGMP 18 512 (kbps) important
OSPFv3 Unicast 30 5120 (kbps) critical
OSPFv3 Multicast 30 5120 (kbps) critical
VRRPv6 36 512 (kbps) important
ARP 12 1024 (kbps) normal
DHCP Snooping 18 3072 (kbps) redirect
802.1x 12 128 (kbps) important
STP 36 256 (kbps) critical
LACP 36 64 (kbps) critical
MVRP 18 256 (kbps) critical
TTL Expires 18 64 (kbps) monitor
IPOPTION 18 64 (kbps) normal
BGPv6 24 1024 (kbps) critical
Hop Limit Expires 18 64 (kbps) monitor
IPOPTIONv6 18 64 (kbps) normal
LLDP 24 64 (kbps) important
DLDP 24 64 (kbps) critical
ARP Snooping 18 1024 (kbps) redirect
DHCPv6 18 3072 (kbps) normal
表1-9 display qos policy control-plane pre-defined命令显示信息描述表
Pre-defined control plane policy |
预定义控制平面策略内容 |
Protocol |
系统预定义协议报文类型 |
Priority |
优先级 |
Bandwidth |
带宽 |
Group |
协议组类型,取值包括 · normal · critical · management · monitor · important · critical · NA |
display qos policy global命令用来显示基于全局应用QoS策略的信息。
(独立运行模式)
display qos policy global [ slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ]
display qos policy global [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ]
inbound:显示入方向QoS策略的配置信息和运行情况。
outbound:显示出方向QoS策略的配置信息和运行情况。
slot slot-number:显示指定单板的基于全局应用QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于全局应用QoS策略的信息,不显示各单板的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于全局应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于全局应用QoS策略的信息,不显示各单板的信息。(IRF模式)
如果未指定显示方向,则同时显示出入两个方向QoS策略的配置信息和运行情况。
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
0 (bps)
0 (bps)
0 (bps)
表1-10 display qos policy global命令显示信息描述表
Direction |
对接收到(Inbound)/发送(Outbound)的报文应用QoS策略 |
Green packets |
Yellow packets |
Red packets |
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
(独立运行模式)
display qos policy interface [ interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] | all ] [ inbound | outbound ]
display qos policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] | all ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的配置信息和运行情况。
slot slot-number:显示指定单板上指定接口的QoS策略的配置信息和运行情况。slot-number表示单板所在的槽位号。只有当接口为聚合接口等类型时才支持此参数。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定接口的QoS策略的配置信息和运行情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。只有当接口为聚合口等类型时才支持此参数。(IRF模式)
all:显示所有单板上逻辑接口的QoS策略的配置信息和运行情况。如果未指定本参数,则显示全局主用主控板逻辑接口应用QoS策略的配置信息和运行情况。
# 显示对接口GigabitEthernet3/1/1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface gigabitethernet 3/1/1 inbound
Interface: GigabitEthernet3/1/1
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
0 (bps)
0 (bps)
0 (bps)
Classifier: 2
Operator: AND
Rule(s) :
If-match acl 3000
Behavior: 2
Assured Forwarding:
Bandwidth 30000 (kbps) CBS 750000 (Bytes)
Matched : 0 (Packets) 0 (Bytes)
Enqueued : 0 (Packets) 0 (Bytes)
Discarded: 0 (Packets) 0 (Bytes)
Discarded Method: WRED
Discard Method: Tail drop
Classifier: 3
Matched : 10 (Packets) 8000 (Bytes)
5-minute statistics:
Forwarded: 0/0 (pps/bps)
Dropped : 0/0 (pps/bps)
Operator: AND
Rule(s) :
If-match acl 3001
Behavior: 4
Redirecting:
NID : 123464
Forwarding ID: 123464
SID : 25::5a
# 显示接口Route-Aggregation1在所有单板上接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface Route-Aggregation 1 all inbound
slot 1:
Interface: Route-Aggregation1
Direction: Inbound
Policy: p
Classifier: c
Operator: AND
Rule(s) :
If-match any
Behavior: b
Marking:
Remark dscp af11
slot 2:
Direction: Inbound
Policy: p
Classifier: c
Operator: AND
Rule(s) :
If-match any
Behavior: b
Marking:
Remark dscp af11
# 显示所有接口上QoS策略的接口的配置信息和运行情况。
Direction: Inbound
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
CIR 112 (kbps), CBS 5120 (Bytes), EBS 0 (Bytes)
Green action : pass
0 (bps)
0 (bps)
0 (bps)
表1-11 display qos policy interface命令显示信息描述表
Direction |
Policy应用在接口的方向 |
Green packets |
Yellow packets |
Red packets |
Matched |
符合分类规则的数据包数目 |
Enqueued |
在基于类的队列中,报文入队列统计计数 |
Discarded |
在基于类的队列中,被丢弃报文统计计数 |
Discard Method |
在基于类的队列中,报文的丢弃方式 · Tail drop:尾丢弃 · WRED:WRED丢弃 |
重定向到SR-MPLS TE Policy。NID表示重定向到SR-MPLS TE Policy的NHLFE(Next Hop Label Forwarding Entry,下一跳标签转发项)表项索引 |
重定向到SRv6 TE Policy · Forwarding ID:重定向到SRv6 TE Policy的转发表项索引 · SID:尾节点的SRv6 SID |
display qos policy user-profile命令用来显示用户上线后User Profile下应用的QoS策略的信息和运行情况。
(独立运行模式)
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ]
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ]
name profile-name:指定User Profile的名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线、减号和英文句号,支持以字母或数字开头,但不能为纯数字,区分大小写。User Profile的名称必须全局唯一。如果未指定本参数,将显示所有User Profile下应用的QoS策略的信息和运行情况。
user-id user-id:表示在线用户的ID,取值范围为十六进制数1~7fffff。若未指定本参数,则显示所有用户在User Profile下应用的QoS策略的信息和运行情况。有关用户ID的详细介绍,请参见“BRAS业务命令参考”中的“UCM”。
slot slot-number:显示指定单板上指定用户在User Profile下应用的QoS策略的信息和运行情况,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上的在线用户的QoS策略的信息和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上指定用户在User Profile下应用的QoS策略的信息和运行情况,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备所有单板上指定用户在User Profile下应用的QoS策略的信息和运行情况。(IRF模式)
如果未指定显示方向,则同时显示出入两个方向上QoS策略的配置信息和运行情况。
# 显示指定用户在User Profile下应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy user-profile name abc user-id 300000 inbound
User-Profile: abc
User ID: 0x300000
Direction: Inbound
Policy: p1
Classifier: c1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: b1
CIR 3000 (kbps), CBS 187500 (Bytes), EBS 0 (Bytes)
Green action : pass
0 (bps)
0 (bps)
0 (bps)
表1-12 display qos policy user-profile命令显示信息描述表
User-Profile |
User Profile名称 |
User ID |
上线用户的ID |
Direction |
Policy应用在User Profile的方向 |
Matched |
符合分类规则的数据包数目 |
Green packets |
Yellow packets |
Red packets |
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的配置信息和运行情况。
(独立运行模式)
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ]
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ]
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称,为1~31个字符的字符串,区分大小写。
vlan vlan-id:显示指定VLAN上应用QoS策略的信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
slot slot-number:显示指定单板上基于VLAN应用QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于VLAN应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于VLAN应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于VLAN应用QoS策略的信息。(IRF模式)
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
Direction: Outbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Green packets : 0(Bytes)
0 (bps)
Yellow packets: 0(Bytes)
0 (bps)
Red packets : 0(Bytes)
0 (bps)
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
3268134 (Packets)
1000 (pps)
Marking:
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
表1-13 display qos vlan-policy命令显示信息描述表
Direction |
对VLAN接收到(Inbound)/发送(Outbound)的报文应用QoS策略 |
Green packets |
Yellow packets |
Red packets |
qos apply policy命令用来在接口、控制平面上应用QoS策略。
undo qos apply policy命令用来取消接口、控制平面上应用的QoS策略。
qos apply policy policy-name { inbound | outbound } [ preorder preorder-value ] [ share-mode ]
undo qos apply policy [ policy-name ] { inbound | outbound }
未应用QoS策略。
控制平面视图
policy-name:策略名,为1~31个字符的字符串,区分大小写。
执行undo命令时如果未指定本参数,表示删除该类型所有策略。仅接口上应用的QoS策略,才支持通过本方式执行取消策略应用的操作。
inbound:入方向应用QoS策略。
outbound:出方向应用QoS策略。
preorder preorder-value:指定接口入方向不同QoS策略的流行为执行顺序,取值越大,该QoS策略的流行为越优先被执行。目前preorder-value的取值仅能为1。该关键字仅在接口视图下应用QoS策略时支持。在控制平面上应用策略时,不支持配置流行为执行顺序。
share-mode:对二层以太网接口和三层以太网接口应用共享QoS和ACL资源模式的QoS策略。该模式下,同一单板相同方向应用相同QoS策略的接口共享一份QoS和ACL资源。该关键字仅在接口视图下应用QoS策略时支持。在控制平面上应用策略时,不支持配置共享模式。
在转控分离组网中,在VSI虚接口上应用的QoS策略实际功能不会生效,需要在AC对应的端口上应用QoS策略。
策略在接口上应用的规则,入方向的策略与类关联的行为不允许有queue af、queue ef与queue wfq配置。
仅CSPEX-1802X、CSPEX-1812X-E单板支持在Tunnel接口的入方向上应用QoS策略。
以下单板在聚合接口及其成员接口分别应用策略时,聚合接口上应用的策略优先生效。成员接口上应用的策略在退出聚合口后才会生效:
· CEPC类单板
· SPEX类单板
· CSPEX类单板
· CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板
· SPE类单板
在控制平面上应用策略时,不支持配置了CBQ的策略。
基于控制平面应用QoS策略时,流分类中支持使用如下方法匹配上送控制平面的协议报文:
· 使用if-match control-plane protocol命令。
· 使用if-match acl命令,该方法可以更灵活的匹配上送控制平面的协议报文,需要注意的是if-match引用的ACL必须为高级ACL,且该ACL规则必须满足如下条件:
¡ 规则中的protocol协议类型必须为TCP或UDP;
¡ 规则中必须通过操作符eq指定一个源端口或指定一个目的端口。
例如,在流行为中,通过if-match引用配置rule permit tcp source-port eq 80规则的IPv4高级ACL,则该流行为可以匹配上送控制平面的TCP协议报文。
应用QoS策略时,如果携带了share-mode关键字,则需要注意的是:
· 同一单板的相同方向上所有应用了该QoS策略的接口共享一份QoS和ACL资源,而未携带share-mode关键字时,应用该QoS策略的各接口独享一份QoS和ACL资源。
· 当QoS策略的流行为视图下配置了流量监管动作,则共享一份QoS和ACL资源的所有接口的带宽总和为car命令中的承诺信息速率,而未携带share-mode关键字时所有接口的承诺信息速率均为car命令中配置的承诺信息速率。
· 在同一个接口的同一个方向上,不能再携带share-mode关键字配置应用ACL进行报文过滤。关于接口应用ACL进行报文过滤命令的详细介绍,请参见“ACL和QoS命令参考”中的“ACL命令”。
应用QoS策略时,如果携带了preorder关键字,则需要注意的是:
· 目前仅在SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板上接口的入方向支持应用配置了流行为执行顺序的QoS策略。
· 报文优先匹配配置了preorder的QoS策略中的流分类。
display qos policy interface命令中共享QoS和ACL资源的接口的统计信息不仅包含接口自身的统计信息,还包含了所有共享该QoS和ACL资源的接口的统计信息。
QoS策略应用后不能动态修改QoS和ACL的资源共享模式,如需修改,请先取消该接口应用的QoS策略,然后在配置接口应用QoS策略时选择携带或不携带share-mode关键字。
# 将策略USER1应用到接口GigabitEthernet3/1/1的出方向上。
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] qos apply policy USER1 outbound
# 对进入3号槽控制平面的报文应用策略aaa。
[Sysname-cp-slot3] qos apply policy aaa inbound
# 以共享QoS和ACL资源的模式将策略aaa应用到接口GigabitEthernet3/1/1的出方向上。
[Sysname-GigabitEthernet3/1/1] qos apply policy aaa outbound share-mode
qos apply policy命令用来在User Profile下应用策略。
undo qos apply policy命令用来取消User Profile下应用的策略。
undo qos apply policy policy-name { inbound | outbound }
未在User Profile下应用QoS策略。
User Profile视图
inbound:入方向应用QoS策略。
policy-name:策略名,为1~31个字符的字符串。
User Profile被删除将导致其下引用的QoS策略被删除。
# 对设备发送的上线用户user的流量应用策略test(该策略已经建立)。
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
qos apply policy policy-name global { inbound | outbound } [ preorder preorder-value ]
undo qos apply policy policy-name global { inbound | outbound }
未在全局应用QoS策略。
inbound:对设备所有端口接收到的流量应用QoS策略。
outbound:对设备所有端口发送的流量应用QoS策略。
preorder preorder-value:指定全局入方向不同QoS策略的流行为执行顺序,取值越大,该QoS策略的流行为越优先被执行。目前preorder-value的取值仅能为1。
全局应用的QoS策略对全部流量生效。
· 目前配置了流行为执行顺序的QoS策略仅在SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板的入方向生效。
# 将名为user1的策略应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
qos policy命令用来创建一个策略,并进入策略视图。如果指定的策略已经存在,则直接进入策略视图。
undo qos policy命令用来删除一个策略。
qos policy policy-name
undo qos policy policy-name
不存在策略。
如果该策略已经被应用,则不允许删除该策略,需要先在应用的位置上取消对该策略的应用,然后再使用undo qos policy命令删除该策略。
# 定义一个名为user1的策略。
· qos apply policy
· qos apply policy global
· qos vlan-policy
qos vlan-policy命令用来在VLAN上应用QoS策略。
undo qos vlan-policy命令用来取消VLAN上应用的QoS策略。
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
未在VLAN上应用QoS策略。
policy-name:策略名称,为1~31个字符的字符串,区分大小写。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:入方向应用QoS策略。
# 在VLAN 200、300、400、500的入方向上应用VLAN策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
(独立运行模式)
reset qos policy control-plane slot slot-number [ cpu cpu-number ]
reset qos policy control-plane chassis chassis-number slot slot-number [ cpu cpu-number ]
slot slot-number:清除指定单板的基于控制平面应用QoS策略的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的基于控制平面应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 清除应用到指定slot上的控制平面的QoS策略统计信息。
<Sysname> reset qos policy control-plane slot 3
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
inbound:清除全局接收到的报文应用QoS策略的统计信息。
outbound:清除全局发送的报文应用QoS策略的统计信息。
如果未指定方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
vlan vlan-id:指定VLAN。vlan-id为指定VLAN的ID号,取值范围为1~4094。
inbound:清除入方向QoS策略的统计信息。
outbound:清除出方向QoS策略的统计信息。
如果未指定方向,则同时清除出入两个方向VLAN应用的QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
display qos exclusive-bandwidth interface outbound命令用来显示接口出方向独占带宽的配置信息和运行情况。
(独立运行模式)
display qos exclusive-bandwidth interface [ interface-type interface-number ] outbound [ slot slot-number [ cpu cpu-number ] ]
display qos exclusive-bandwidth interface [ interface-type interface-number ] outbound [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口独占带宽的配置信息和运行情况。
slot slot-number:显示指定单板上指定接口独占带宽的配置信息和运行情况。slot-number表示单板所在的槽位号。只有当指定接口为聚合接口时才支持此参数。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板指定接口独占带宽的配置信息和运行情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。只有当指定接口为聚合接口时才支持此参数。(IRF模式)
# 显示接口Ten-GigabitEthernet3/1/1出方向独占带宽的配置信息和运行情况。
<Sysname> display qos exclusive-bandwidth interface ten-gigabitEthernet3/1/1 outbound
Ten-GigabitEthernet3/1/1 exclusive-bandwidth: 500 kbps
Outbound traffic statistics:
Total passed: 1 packets, 2 bytes
Total discarded: 3 packets, 4 bytes
Last 30 seconds pass rate: 0 pps, 0 bps
Last 30 seconds discard rate: 0 pps, 0 bps
表2-1 display qos hard-pipe statistics interface outbound命令显示信息描述表
Ten-GigabitEthernet3/1/1 exclusive-bandwidth |
接口独占带宽值 |
Outbound traffic statistics |
出方向流量统计 |
Total passed |
通过总包数和总字节数 |
Total discarded |
丢弃总包数和总字节数 |
Last 30 seconds pass rate |
最近30s通过包速率和字节速率 |
Last 30 seconds discard rate |
最近30s丢弃包速率和字节速率 |
· qos exclusive-bandwidth
qos exclusive-bandwidth命令用来在接口上配置独占带宽。
undo qos exclusive-bandwidth命令用来取消接口独占带宽配置。
qos exclusive-bandwidth bandwidth-value
接口上未配置独占带宽。
三层以太网接口视图/三层聚合接口视图
bandwidth-value:表示独占带宽值,单位为kbps。千兆端口的取值范围为300~950000,万兆端口的取值范围为300~9500000,40GE端口的取值范围为300~38000000,100GE端口的取值范围为300~95000000,三层聚合接口的取值范围为300~95000000。
仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板上的接口支持接口带宽独占功能。
在接口上配置独占带宽后,该部分带宽会被预留,此时接口总带宽将减少配置的独占带宽值。需要注意的是,独占带宽仅允许特定流量使用,不允许与其他业务流量共享。例如,开启静态CRLSP独占带宽功能后,一旦配置了接口独占带宽,则接口独占带宽只能被静态CRLSP使用,其他业务流量不能共享这部分带宽资源。有关静态CRLSP独占带宽功能的详细介绍,请参见“MPLS配置指导”中的“静态CRLSP”。
本命令与HQoS命令互斥,即接口上配置独占带宽时,若接口已配置HQoS命令,则该配置将会执行失败,反之亦然。
# 在接口Ten-GigabitEthernet3/1/1上配置独占带宽为500kbps。
[Sysname] interface ten-gigabitEthernet3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] qos exclusive-bandwidth 500
· display qos exclusive-bandwidth interface outbound
display mode channel-bandwidth interface命令用来显示子接口切片配置信息。
(独立运行模式)
display mode channel-bandwidth interface [ interface-type { interface-number | interface-number.subnumber } ] [ slot slot-number [ cpu cpu-number ] ]
display mode channel-bandwidth interface [ interface-type { interface-number | interface-number.subnumber } ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
interface-type:指定接口类型。如果未指定本参数,将显示所有子接口切片的配置信息。
interface-number:指定接口编号。
interface-number.subnumber:指定子接口编号。其中interface-number为主接口编号,.subnumber为子接口编号,取值范围为1~99999999。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定所有单板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定所有单板。(IRF模式)
# 显示子接口GigabitEthernet3/1/1.1的子接口切片配置信息。
<Sysname> display mode channel-bandwidth interface gigabitethernet 3/1/1.1
Subinterface : GE3/1/1.1 Channelized bandwidth : 300 kbps
# 显示三层聚合接口的子接口切片配置信息。
<Sysname> display mode channel-bandwidth interface route-aggregation 1
Slot 2
Interface : RAGG 1 Total bandwidth : 1000000 kbps
Total channelized bandwidth : 700 kbps
Subinterface : RAGG 1.1 Channelized bandwidth : 300 kbps
Subinterface : RAGG 1.2 Channelized bandwidth : 400 kbps
Subinterface : RAGG 1.3 Channelized bandwidth : 300 kbps(Failed)
Slot 5
# 显示所有主接口的子接口切片配置信息。
Interface : GE3/1/1 Total bandwidth : 1000000 kbps
Total channelized bandwidth : 1000 kbps
Subinterface : GE3/1/1.2 Channelized bandwidth : 400 kbps
Subinterface : GE3/1/1.3 Channelized bandwidth : 300 kbps
Interface : GE3/1/2 Total bandwidth : 1000000 kbps
Subinterface : GE3/1/2.1 Channelized bandwidth : 300 kbps
Subinterface : GE3/1/2.2 Channelized bandwidth : 400 kbps
Subinterface : GE3/1/2.3 Channelized bandwidth : 300 kbps
表3-1 display mode channel-bandwidth interface命令显示信息描述表
Subinterface |
配置了子接口切片带宽的子接口 |
Channelized bandwidth |
子接口切片的带宽值,显示三层聚合接口的子接口切片配置时,如果配置失败则带宽值会显示为Failed |
Slot |
聚合口所属的槽位号 |
子接口切片对应的主接口 |
Total bandwidth |
主接口的总带宽值 |
Total channelized bandwidth |
所有成功生效的子接口切片带宽值之和 |
· mode channel-bandwidth
mode channel-bandwidth命令用来配置子接口切片带宽。
undo mode channel-bandwidth命令用来恢复缺省情况。
mode channel-bandwidth bandwidth-value
子接口上未配置子接口切片带宽。
子接口视图
bandwidth-value:表示子接口切片带宽值,单位为kbps,千兆端口的取值范围为300~950000,万兆端口的取值范围为300~9500000,40GE端口的取值范围为300~38000000,100GE端口的取值范围为300~95000000,三层聚合接口的取值范围为300~95000000。
缺省情况下,所有子接口共享主接口的带宽,不同子接口的业务流量之间存在竞争关系,因此无法保证个别子接口的关键业务流量。配置子接口切片功能后,该子接口将独占指定的带宽。
在网络分片场景中,可以在物理以太网接口或聚合接口的不同子接口上配置子接口切片带宽,保障该子接口的业务流量独享一定的带宽并独立进行QoS调度。
子接口切片的带宽总和不能超过主接口实际物理带宽。子接口切片带宽仅在出接口方向生效。
· 子接口切片功能与接口独占带宽功能互斥,即主接口和主接口对应的子接口下不能同时配置子接口切片带宽和接口独占带宽;
· 子接口切片功能与MPLS TE链路最大可预留带宽功能互斥,主接口和主接口对应的子接口下不能同时配置子接口切片带宽和MPLS TE链路最大可预留带宽,有关MPLS TE链路最大可预留带宽的详细介绍,请参见“MPLS配置指导”中的“MPLS TE”。
· 子接口切片功能与HQoS功能互斥,即主接口和主接口对应的子接口下不能同时配置子接口切片带宽和HQoS调度策略,有关HQoS功能的详细介绍,请参见“ACL和QoS配置指导”中的“HQoS”。
# 在子接口GigabitEthernet3/1/1.1上配置子接口切片带宽为300kbps。
[Sysname] interface gigabitethernet 3/1/1.1
[Sysname-GigabitEthernet3/1/1.1] mode channel-bandwidth 300
· display mode channel-bandwidth interface
· mpls te max-reservable-bandwidth(MPLS命令参考/MPLS TE)
· qos apply scheduler-policy(ACL和QoS命令参考/HQos)
display qos map-table命令用来显示优先级映射表的配置情况。
display qos map-table [ inbound [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp ] ]
inbound:显示入方向优先级映射表的配置情况。
优先级映射 |
dot1p-dot1p |
802.1p优先级到802.1p优先级映射表 |
dot1p-dp |
802.1p优先级到丢弃优先级映射表 |
dot1p-dscp |
802.1p优先级到DSCP映射表 |
dot1p-exp |
802.1p优先级到EXP映射表 |
dot1p-lp |
802.1p优先级到本地优先级映射表 |
dscp-dot1p |
DSCP到802.1p优先级映射表 |
dscp-dp |
DSCP到丢弃优先级映射表 |
dscp-dscp |
DSCP到DSCP映射表 |
dscp-exp |
DSCP到EXP映射表 |
dscp-lp |
DSCP到本地优先级映射表 |
exp-dot1p |
EXP到802.1p优先级映射表 |
exp-dp |
EXP到丢弃优先级映射表 |
exp-dscp |
EXP到DSCP映射表 |
exp-exp |
EXP到EXP映射表 |
exp-lp |
EXP到本地优先级映射表 |
如果未指定优先级映射表的类型,则显示所有映射表(除带颜色映射表)的配置情况。
如果未指定任何参数,即display qos map-table命令将显示所有映射表(以及带颜色映射表)的配置情况。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp TYPE: pre-define DIRECTION: inbound
IMPORT : EXPORT
0 : 0
1 : 1
2 : 2
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
表4-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME |
映射表的名称 |
TYPE |
映射表的类型 |
DIRECTION |
映射表的方向 |
IMPORT |
映射表的输入值 |
EXPORT |
映射表的输出值 |
display qos map-table color命令用来显示带颜色优先级映射表配置情况。
display qos map-table color [ green | yellow | red ] { inbound [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp ] | outbound [ dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp ] }
outbound:显示出方向带颜色的优先级映射表的配置情况。
其它参数请参见表4-1。
经过流量监管处理的报文被分成了三种颜色(绿色、黄色、红色),为了对不同颜色报文进行优先级映射,设备提供了多张带颜色优先级映射表,分别对应相应颜色的优先级映射关系。流量监管对报文处理的相关内容请参见流量监管章节内容。
如果未指定颜色,则同时显示三种颜色的优先级映射表的配置情况。
如果未指定优先级映射表的类型,则同时显示所有优先级映射表的配置情况。
# 显示绿色报文的接收报文方向的EXP到本地优先级映射表的配置信息。
<Sysname> display qos map-table color green inbound exp-lp
MAP-TABLE NAME: exp-lp TYPE: pre-define COLOR: green DIRECTION: inbound
表4-3 display qos map-table color命令显示信息描述表
display qos map-table interface命令用来显示接口上应用的灵活优先级映射表。
display qos map-table interface [ interface-type interface-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定该参数,则显示所有接口上应用的灵活优先级映射表。
inbound:入方向应用的灵活优先级映射表。
outbound:出方向应用的灵活优先级映射表。
如果未指定方向,将显示接口所有方向应用的灵活优先级映射表。
# 显示接口GigabitEthernet3/1/1应用的灵活优先级映射表。
<Sysname> display qos map-table interface gigabitethernet 3/1/1
Direction: Inbound
Map table name: user1
表4-4 display qos map-table interface命令显示信息描述表
接口名,由接口类型和接口编号构成 |
Direction |
对进入接口(inbound)的报文应用灵活优先级映射表 |
Map table name |
灵活优先级映射表的名称 |
· display qos map-table name
· qos map-table name
display qos map-table name命令用来显示灵活优先级映射表的配置情况。
display qos map-table name [ map-table-name ]
map-table-name:灵活优先级映射表的名称,为1~31个字符的字符串,区分大小写。如果未指定该参数,则显示所有灵活优先级映射表的配置情况。
# 显示名为user1的灵活优先级映射表的配置情况。
<Sysname> display qos map-table name user1
Map table name: user1 Item: 3
Type Import Import Color Export Export Color
dot1p-lp 0 None 2 None
dot1p-lp 1 None 3 Yellow
dscp-dp 3 None 2 Green
表4-5 display qos map-table name命令显示信息描述表
Map table name |
灵活优先级映射表的名称 |
Item |
优先级映射关系的项数 |
Type |
优先级映射关系的类型 |
Import |
优先级映射关系的输入值 |
Export |
优先级映射关系的输出值 |
Import Color |
优先级映射关系的输入颜色,None表示不区分报文颜色 |
Export Color |
优先级映射关系的输出颜色,None表示不对报文染色 |
· display qos map-table interface
import命令用来配置灵活优先级映射关系。
undo import命令用来删除指定的灵活优先级映射关系。
{ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp } import import-value-list export export-value color { green | red | yellow }
{ lp-dot1p | lp-dp | lp-dscp | lp-exp | lp-phb } import import-value-list color { green | red | yellow } export export-value
undo { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp } import import-value-list
undo { lp-dot1p | lp-dp | lp-dscp | lp-exp | lp-phb } import import-value-list color { green | red | yellow }
灵活优先级映射表视图
灵活优先级映射表中不存在优先级映射关系。
import-value-list:输入值列表。
export-value:输出值。
green:绿色报文。
red:红色报文。
yellow:黄色报文。
表4-6 优先级映射表
优先级映射 |
dot1p-dot1p |
dot1p-dp |
dot1p-dscp |
802.1p优先级到DSCP映射表 |
dot1p-exp |
802.1p优先级到EXP映射表 |
dot1p-lp |
dscp-dot1p |
DSCP到802.1p优先级映射表 |
dscp-dp |
DSCP到丢弃优先级映射表 |
dscp-dscp |
DSCP到DSCP映射表 |
dscp-exp |
DSCP到EXP映射表 |
dscp-lp |
DSCP到本地优先级映射表 |
exp-dot1p |
EXP到802.1p优先级映射表 |
exp-dp |
EXP到丢弃优先级映射表 |
exp-dscp |
EXP到DSCP映射表 |
exp-exp |
EXP到EXP映射表 |
exp-lp |
EXP到本地优先级映射表 |
lp-dot1p |
本地优先级到802.1p优先级映射表 |
lp-dp |
本地优先级到丢弃优先级映射表 |
lp-dscp |
本地优先级到DSCP映射表 |
lp-exp |
本地优先级到EXP映射表 |
lp-phb |
本地优先级到PHB优先级映射表 |
对于同一个映射关系:
· 多次执行本命令时,如果输入值和输入颜色相同,则最后一次执行的命令生效。
· 同一输入值,可以再根据其不同输入颜色指定不同输出值。
# 定义名为user1的灵活优先级映射表,在该灵活优先级映射表视图下配置dscp优先级到本地优先级的映射关系,与dscp优先级2相对的本地优先级为4。
[Sysname] qos map-table name user1
[Sysname-flexmaptbl-user1] dscp-lp import 2 export 4
# 定义名为user2的灵活优先级映射表,在该灵活优先级映射表视图下配置dscp优先级到本地优先级的映射关系,与dscp优先级2相对的本地优先级为4且颜色为绿色。
[Sysname] qos map-table name user2
[Sysname-flexmaptbl-user2] dscp-lp import 2 export 4 color green
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 B。
优先级映射表视图
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
# 配置802.1p优先级到丢弃优先级映射表的映射关系,与802.1p优先级4、5相对应的丢弃优先级为1。
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
qos apply map-table name命令用来在接口上应用一个灵活优先级映射表。
undo qos apply map-table name命令用来取消接口上应用的灵活优先级映射表。
qos apply map-table name map-table-name { inbound | outbound }
undo qos apply map-table name map-table-name { inbound | outbound }
接口上未应用灵活优先级映射表。
map-table-name:灵活优先级映射表的名称,为1~31个字符的字符串,区分大小写,且指定的灵活优先级映射表必须已经存在。
inbound:入方向应用灵活优先级映射表。
outbound:出方向应用灵活优先级映射表。
配置该命令时,指定的灵活优先级映射表必须已经存在。
如果未指定方向,表示入方向。接口的一个方向只允许应用一个灵活优先级映射表。
如果在优先级映射表视图下配置了指定优先级映射表的映射关系,但在某个接口上应用了灵活优先级映射表,此时通过该接口的报文将根据灵活优先级映射表的映射关系分配或修改报文的优先级。
接口入方向上仅支持应用dot1p-dot1p、dot1p-dp、dot1p-dscp、dot1p-exp、dot1p-lp、dscp-dot1p、dscp-dp、dscp-dscp、dscp-exp、dscp-lp、exp-dot1p、exp-dp、exp-dscp、exp-exp和exp-lp映射表;接口出方向上仅支持应用lp-dot1p、lp-dp、lp-dscp、lp-exp和lp-phb映射表。
# 在接口GigabitEthernet3/1/1出方向上应用名为user1的灵活优先级映射表。
[Sysname-GigabitEthernet3/1/1] qos apply map-table name user1 outbound
qos map-table inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
inbound:入方向优先级映射表。
outbound:出方向优先级映射表。
其它参数请参见表4-1。
SPC类单板和MPE-1104单板不支持dot1p-dot1p、dot1p-dscp、dot1p-exp、dscp-exp、dscp-lp、exp-dscp、exp-dp、exp-exp和exp-lp映射。
# 进入接收报文方向的802.1p优先级到丢弃优先级映射表视图。
[Sysname] qos map-table inbound dot1p-dp
[Sysname-maptbl-in-dot1p-dp]
· import
qos map-table color命令用来进入指定的带颜色优先级映射表视图。
qos map-table color { green | yellow | red } { inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp } | outbound { dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp } }
green:绿色报文。
yellow:黄色报文。
red:红色报文。
inbound:入方向优先级映射表。
outbound:出方向优先级映射表。
其它参数请参见表4-1。
每个优先级映射(颜色也相同)存在接收报文方向、发送报文方向两张不同的映射表。SPC类单板和MPE-1104单板不支持带颜色的优先级映射 。
# 进入绿色报文的接收报文方向的EXP到本地优先级映射表视图。
[Sysname] qos map-table color green inbound exp-lp
[Sysname-maptbl-green-in-exp-lp]
# 进入红色报文的接收报文方向的DSCP到本地优先级映射表视图。
[Sysname] qos map-table color red inbound dscp-lp
[Sysname-maptbl-red-in-dscp-lp]
· import
qos map-table name命令用来创建灵活优先级映射表,并进入灵活优先级映射表视图。如果指定的灵活优先级映射表已经存在,则直接进入灵活优先级映射表视图。
undo qos map-table name命令用来删除一个灵活优先级映射表。
qos map-table name map-table-name
undo qos map-table name map-table-name
不存在灵活优先级映射表。
已经应用到接口上的灵活优先级映射表不允许直接删除。如果需要删除,请先在接口视图下通过执行undo qos apply map-table name命令取消应用,回到系统视图后,再执行undo qos map-table name命令删除该灵活优先级映射表。
# 创建一个名为user1的灵活优先级映射表,并进入该灵活优先级映射表视图。
[Sysname-map-tbl-user1]
· qos apply map-table name
display qos trust interface命令用来显示端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示端口优先级信任模式信息。
<Sysname> display qos trust interface gigabitethernet 3/1/1
Port priority information
Port priority: 0
Port dot1p priority: -
Port dscp priority: -
Port exp priority: -
Port priority trust type: none, Override: disable
表4-7 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成 |
Port priority trust information |
端口优先级信任信息 |
Port priority |
端口优先级 |
Port dot1p priority |
端口802.1p优先级 |
Port dscp priority |
端口DSCP优先级 |
Port exp priority |
端口EXP优先级 |
Port priority trust type |
端口优先级信任类型,取值为: · auto:根据报文的类型,自动提取报文中的优先级字段 · dot1p:802.1p优先级 · dscp:DSCP优先级 · exp:EXP优先级 · inner-dot1p:内层802.1p优先级 · none:不信任任何优先级 |
Override |
是否覆盖报文本身的优先级 |
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { auto | dot1p | dscp | exp | inner-dot1p } [ override ]
undo qos trust
端口信任端口优先级。
auto:表示根据报文的类型,自动提取报文中的优先级字段进行优先级映射。
· 对于SPC类单板和MPE-1104单板,对于非IP报文,采用802.1p优先级;对于IP报文,采用IP优先级;对于MPLS报文,采用EXP。
· 对于CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板,对于二层转发的报文,采用802.1p优先级;对于三层转发的报文,采用IP优先级;对于MPLS报文,采用EXP。
exp:信任MPLS报文自带的EXP,以此优先级进行优先级映射。
inner-dot1p:信任QinQ报文自带的内层802.1p优先级,以此优先级进行优先级映射。
override:表示通过优先级映射表取得的优先级将覆盖报文本身的优先级,缺省为不覆盖。
· 以下单板配置qos trust auto命令时,必须加上override参数。
¡ SPC类单板
¡ CSPC类单板
¡ MPE-1104单板
¡ CSPEX-1104-E和SPEX-1204单板
· dot1p、dscp和inner-dot1p参数仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板支持。
· 当IP报文进入MPLS网络且不配置override参数时,报文标签的EXP字段也会使用优先级映射表获得的EXP值。
· 对于三层转发的报文,根据端口优先级信任模式,提取报文中的优先级字段进行优先级映射覆盖外层dot1p值与是否配置override参数无关。
· 从公网进入的MPLS报文不信任端口配置的qos trust dot1p或者qos trust dscp,而是提取MPLS报文中的EXP进行优先级映射。
· exp参数仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板L2VE或L3VE接口上支持配置。有关L2VE或L3VE接口的介绍,请参见“MPLS”中“L2VPN接入L3VPN或IP骨干网配置”。
# 在接口GigabitEthernet3/1/1上配置优先级信任模式为auto模式。
[Sysname-GigabitEthernet3/1/1] qos trust auto
qos priority命令用来配置端口的端口优先级。
undo qos priority命令用来恢复端口优先级为缺省值。
qos priority [ dot1p | dscp | exp ] priority-value
undo qos priority [ dot1p | dscp | exp ]
端口优先级的缺省值为0。
priority-value:端口优先级值。当不指定端口优先级类型时,取值范围为0~7;当指定端口优先级类型时,设备支持的端口优先级取值范围如表4-8所示。
端口优先级类型 |
priority-value取值范围 |
dot1p(802.1p优先级) |
0~7 |
仅CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板支持该参数 |
dscp(DSCP优先级) |
0~63 |
exp(EXP优先级) |
0~7 |
# 配置接口GigabitEthernet3/1/1的端口优先级为2。
[Sysname-GigabitEthernet3/1/1] qos priority 2
# 配置接口GigabitEthernet3/1/1的DSCP优先级为20。
[Sysname-GigabitEthernet3/1/1] qos priority dscp 20
· display qos trust interface
display qos car control-plane whitelist命令用来显示控制平面动态白名单的流量监管情况和统计信息。
(独立运行模式)
display qos car control-plane whitelist [ ipv6 ] slot slot-number [ cpu cpu-number ]
display qos car control-plane whitelist [ ipv6 ] chassis chassis-number slot slot-number [ cpu cpu-number ]
ipv6:显示IPv6动态白名单的流量监管情况和统计信息。如果未指定本参数,将显示IPv4动态白名单的流量监管情况和统计信息。
slot slot-number:显示指定单板的控制平面流量监管情况和统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的控制平面流量监管情况和统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
cpu cpu-number:指定CPU。cpu-number表示单板上CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
为实现对控制平面动态白名单中的流量进行保护的目的,需要保证控制平面动态白名单流量监管功能处于开启状态。通过本命令,可以按照不同的队列,显示动态白名单流量监管情况和统计信息。
系统根据当前建立的TCP连接及其他协议会话自动生成动态白名单,动态白名单中包含流量的匹配规则。用户可以通过display acl whitelist命令查看动态生成的白名单包含的匹配规则。
关于display acl whitelist命令的详细介绍,请参见“ACL和QoS命令参考”中的“ACL命令”。
# 显示指定slot上的控制平面的动态白名单流量监管情况和统计信息。
<Sysname> display qos car control-plane whitelist slot 2
Slot 2
Whitelist-based traffic policing: Enabled
Queue name: default
CIR 30720 (kbps), CBS 8192 (Bytes)
Green packets : 0 (Packets), 0 (Bytes)
Yellow packets: 0 (Packets), 0 (Bytes)
Red packets : 0 (Packets), 0 (Bytes)
Queue name: ftp
CIR 1024 (kbps), CBS 8192 (Bytes)
Queue name: telnet
Queue name: ssh
Queue name: http
Queue name: https
Queue name: ldp
CIR 15360 (kbps), CBS 8192 (Bytes)
Queue name: bgp
Queue name: snmp
Queue name: bfd
表5-1 display qos car control-plane命令显示信息描述表
Whitelist-based traffic policing |
控制平面动态白名单流量监管功能的开启状态,取值为: · Enabled,表示控制平面动态白名单流量监管功能已开启 · Disabled,表示控制平面动态白名单流量监管功能处于关闭状态 |
Failed rule ID |
下发失败的ACL规则编号 |
Queue name |
协议队列名称 |
CIR |
承诺信息速率 |
CBS |
承诺突发尺寸 |
Green packets |
绿色报文的统计信息 |
Yellow packets |
黄色报文的统计信息 |
Red packets |
红色报文的统计信息 |
· display acl whitelist(ACL和QoS命令参考/ACL)
· qos car whitelist enable
display qos car interface命令用来显示接口的流量监管配置情况和统计信息。
(独立运行模式)
display qos car interface [ interface-type interface-number [ slot slot-number ] ]
display qos car interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量监管配置情况和统计信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定Master设备主用主控板。(IRF模式)
# 显示接口GigabitEthernet3/1/1的流量监管配置情况和统计信息。
<Sysname> display qos car interface gigabitethernet 3/1/1
Direction: inbound
Rule: If-match any
CIR 128 (kbps), CBS 5120 (Bytes), PIR 128 (kbps), EBS 512 (Bytes)
# 显示接口GigabitEthernet3/1/2的流量监管配置情况和统计信息。
<Sysname> display qos car interface gigabitethernet 3/1/2
Interface: GigabitEthernet3/1/2
Direction: inbound
Rule: If-match any
CIR 50 (%), CBS 600 (ms), EBS 500 (ms),PIR 50 (%)
表5-2 display qos car interface命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成 |
Direction |
指定流量监管的方向 |
Rule |
数据包的匹配规则 |
CIR |
承诺信息速率,当采用绝对值形式输入时,单位为kbps;当采用百分比形式时,单位为% |
CBS |
承诺突发尺寸,当采用绝对值形式输入时,单位为byte;当采用百分比形式时,单位为ms,实际的CBS值是cbs-time 乘以实际的承诺信息速率(cir值乘以接口带宽) |
EBS |
超出突发尺寸,当采用绝对值形式输入时,单位为byte;当采用百分比形式时,单位为ms,实际的EBS值是ebs-time 乘以实际的承诺信息速率(cir值乘以接口带宽) |
PIR |
峰值信息速率,当采用绝对值形式输入时,单位为kbps;当采用百分比形式时,单位为% |
Green packets |
绿色报文的流量统计 |
Yellow packets |
黄色报文的流量统计 |
Red packets |
红色报文的流量统计 |
display qos car l2vpn-pw命令用来显示PW上CAR的配置和统计信息。
display qos car l2vpn-pw [ peer ip-address pw-id pw-id ]
peer ip-address:指定PW远端PE的LSR ID。
pw-id pw-id:指定PW的PW ID,取值范围为1~4294967295。
# 显示所有PW上CAR的配置和统计信息。
<Sysname> display qos car l2vpn-pw
L2VPN-PW: peer 1.2.3.4, pw-id 1
Direction: outbound
Rule: If-match any
表5-3 display qos car l2vpn-pw命令显示信息描述表
L2VPN-PW |
显示PW的信息,PW通过远端PE地址和PW ID唯一标识 |
Direction |
方向。当前仅支持outbound,表示出方向 |
Rule |
匹配报文的规则。当前仅支持If-match any,表示匹配所有报文 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,单位为字节 |
PIR |
峰值速率,单位为kbps |
EBS |
超出突发尺寸,单位为字节 |
Green packets |
绿色报文计数,单位为包数和字节数 |
Yellow packets |
黄色报文计数,单位为包数和字节数 |
Red packets |
红色报文计数,单位为包数和字节数 |
display qos user-profile-car member-link-scheduler distribute命令用来显示应用了User Profile的三层聚合接口的各成员口的流量限速值。
display qos user-profile-car member-link-scheduler distribute interface [ route-aggregation interface-number ]
route-aggregation interface-number:显示指定三层聚合接口的各成员口的流量限速值。其中interface-number表示三层聚合接口的编号。不指定本参数时,则显示所有三层聚合接口的成员口流量限速值。
# 显示应用了User Profile的三层聚合接口Route-Aggregation 1的各成员口的流量限速值。
<Sysname> display qos user-profile-car member-link-scheduler distribute interface route-aggregation 1
Interface: Route-Aggregation 1
User-profile CAR:
Inbound:
CIR 4001(Kbps), PIR 4001(Kbps), CBS 750048(byte), PBS 2048(byte)
Shared access rate: CIR 2001(Kbps), PIR 2001(Kbps), CBS 750048(byte), EBS 2048(byte)
Interface GigabitEthernet3/1/1
Interface GigabitEthernet3/1/2
Shared access rate: CIR 1000(Kbps), PIR 1000(Kbps), CBS 750048(byte), EBS 2048(byte)
Interface GigabitEthernet3/1/3
Shared access rate: CIR 1000(Kbps), PIR 1000(Kbps), CBS 750048(byte), PBS 2048(byte)
Interface GigabitEthernet3/1/4
Outbound:
表5-4 display qos user-profile-car distribute命令显示信息描述表
三层聚合接口名称 |
User-profile CAR |
三层聚合口下应用的User Profile中的流量监管配置信息及各成员口的流量限速信息 |
Inbound |
入方向各成员口实际流量限速值 |
Outbound |
出方向各成员口实际流量限速值 |
Shared Access Rate |
同一芯片下所有成员口共享的流量限速值 |
· qos member-link-scheduler distribute
qos car命令用来在控制平面上配置流量监管。
undo qos car命令用来取消控制平面上流量监管的配置。
qos car { any | user } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { any | user } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car { any | user }
未配置流量监管。
控制平面视图
any:对控制平面所有流量进行流量监管。
user:对上线用户流量进行流量监管。
ipv6:对符合IPv6动态白名单的流量进行流量监管。如果未指定本参数,将对符合IPv4动态白名单的流量进行流量监管。
cir committed-information-rate:承诺信息速率,单位为kbps。
· 如果是对控制平面上所有流量进行流量监管,取值范围为8~300000000。当前仅支持配置承诺信息速率取值范围为8~1000000。
· 如果是对上线用户流量进行流量监管,取值范围为8~300000000。
· 如果是对符合动态白名单的流量进行流量监管,取值范围为8~300000000。当前仅支持配置承诺信息速率取值范围为8~100000。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,单位为byte。
· 如果不指定cbs参数,缺省取值为62.5 × committed-information-rate的乘积。
· 如果指定cbs参数,取值范围512~256000000。
ebs excess-burst-size:过度突发尺寸,单位为byte。
· 如果指定本参数,取值范围0~256000000。
· 如果不指定本参数,缺省值为62.5 × peak-information-rate的乘积。
pir peak-information-rate:峰值速率,单位为kbps。
对上线用户流量进行监管时,配置的承诺信息速率为每个上线用户流量的总速率。
不配置峰值速率表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 对进入slot 3控制平面的所有流量配置流量监管。
[Sysname-cp-slot3] qos car any cir 2000 cbs 150000 ebs 0
# 对进入slot 3控制平面的上线用户流量配置流量监管。
[Sysname-cp-slot3] qos car user cir 200 cbs 15000 ebs 0
qos car命令用来在接口上配置流量监管。
undo qos car命令用来取消接口上流量监管的配置。
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car { inbound | outbound } any
未配置流量监管。
inbound:入方向流量监管。
outbound:出方向流量监管。
any:对所有的IP数据包进行流量监管。
cir committed-information-rate:承诺信息速率,单位为kbps。千兆端口的取值范围为8~1000000,万兆端口的取值范围为8~10000000,40GE端口的取值范围为8~40000000,100GE端口的取值范围为8~100000000,三层聚合接口的取值范围为8~300000000,FlexE接口的取值范围为8~100000000。
ebs excess-burst-size:过度突发尺寸,单位为byte。取值范围0~256000000。
pir peak-information-rate:峰值速率,单位为kbps。千兆端口的取值范围为8~1000000,万兆端口的取值范围为8~10000000,40GE端口的取值范围为8~40000000,100GE端口的取值范围为8~100000000,三层聚合接口的取值范围为8~300000000,FlexE接口的取值范围为8~100000000。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板上的三层以太网接口或者三层以太网聚合接口支持配置本命令。
# 在接口GigabitEthernet3/1/1的出方向上对满足ANY规则的报文进行流量监管。报文正常流速为200kbps,允许5120byte的突发流量通过,速率小于等于200kbps时正常发送,大于200kbps时,报文被丢弃。
[Sysname-GigabitEthernet3/1/1] qos car outbound any cir 200 cbs 5120
· display qos car interface
qos car any命令用来在PW上配置CAR。
undo qos car any命令用来恢复缺省情况。
qos car outbound any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
qos car outbound any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
undo qos car outbound any
PW上未配置CAR。
交叉连接PW视图
VSI LDP PW视图
VSI静态PW视图
outbound:表示配置出方向CAR。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~300000000。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
· 如果指定本参数,取值范围为512~256000000。
· 如果不指定本参数,缺省值为62.5 × committed-information-rate的乘积。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为8~300000000。
ebs excess-burst-size:超出突发尺寸,单位为byte。
# 在交叉连接pw2pw的PW上配置CAR,报文正常流速为200kbps,承诺突发尺寸为51200bytes。
[Sysname] xconnect-group vpn1
[Sysname-xcg-vpn1] connection pw2pw
[Sysname-xcg-vpn1-pw2pw] peer 5.5.5.5 pw-id 200 in-label 100 out-label 200
[Sysname-xcg-vpn1-pw2pw-5.5.5.5-200] qos car outbound any cir 200 cbs 51200 pir 500 ebs 0
# 在静态PW上配置CAR,报文正常流速为200kbps,承诺突发尺寸为51200bytes。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling static
[Sysname-vsi-vpn1-static] peer 5.5.5.5 pw-id 200 in-label 100 out-label 200
[Sysname-xcg-vpn1-static-5.5.5.5-200] qos car outbound any cir 200 cbs 51200 pir 500 ebs 0
# 在LDP PW上配置CAR,报文正常流速为200kbps,承诺突发尺寸为51200bytes。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling ldp
[Sysname-vsi-vpn1-ldp] peer 4.4.4.4 pw-id 100
[Sysname-vsi-vpn1-ldp-4.4.4.4-100] qos car outbound any cir 200 cbs 51200 pir 500 ebs 0
· display qos car l2vpn-pw
qos car any命令用来在User Profile下配置流量监管。
undo qos car命令用来取消User Profile下流量监管的配置。
未配置流量监管。
User Profile视图
inbound:对上线用户发送的报文进行流量监管。
outbound:对上线用户接收到的报文进行流量监管。
cir committed-information-rate:承诺信息速率,单位为kbps,取值范围为8~300000000。
ebs excess-burst-size:过度突发尺寸,单位为byte,缺省值为0byte。取值范围为0~256000000。
pir peak-information-rate:峰值速率,单位为kbps,取值范围为8~300000000。
数据流量符合承诺速率时,允许数据包通过;数据流量不符合承诺速率时,丢弃数据包。
多次执行本命令,最后一次执行的命令生效。
# 对上线用户user接收的报文进行流量监管。报文正常流速为200kbps,允许51200byte的突发流量通过,速率小于等于200kbps时正常发送,大于200kbps时,报文被丢弃。
[Sysname-user-profile-user] qos car outbound any cir 200 cbs 51200
qos car percent命令用来采用百分比的方式在接口上配置流量监管。
qos car { inbound | outbound } any percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ]
qos car { inbound | outbound } any percent cir cir-percent [ cbs cbs-time ] pir pir-percent [ ebs ebs-time ]
未配置百分比形式的流量监管。
inbound:入方向流量监管。
outbound:出方向流量监管。
percent cir cir-percent:以百分比的形式来指定承诺信息速率,取值范围为1~100。
cbs cbs-time:用指定的时间(单位为ms)来设置CBS,实际的CBS值是cbs-time 乘以实际的承诺信息速率(cir值乘以接口带宽)。cbs-time的取值范围为50~2000。
ebs ebs-time:用指定的时间(单位为ms)来设置EBS,实际的EBS值是ebs-time 乘以实际的承诺信息速率(cir值乘以接口带宽)。ebs-time的取值范围为0~2000。
pir pir-percent:以百分比的形式来指定峰值速率,取值范围为1~100。峰值速率不能比承诺信息速率小。
配置本命令之前,请先通过bandwidth命令配置接口的期望带宽。有关bandwidth命令的详细介绍,请参见“接口管理命令参考”中的“以太网接口”。
在同一个接口上重复执行本命令可以配置多个CAR策略,策略的执行顺序与配置的先后顺序一致。
# 在接口GigabitEthernet3/1/1的出方向上对满足ANY规则的报文进行流量监管。指定CIR 50%,CBS 1000 ms。
[Sysname-GigabitEthernet3/1/1] qos car outbound any percent cir 50 cbs 1000
qos car whitelist enable命令用来开启控制平面动态白名单流量监管功能。
undo qos car whitelist enable命令用来关闭控制平面动态白名单流量监管功能。
qos car whitelist [ ipv6 ] enable
undo qos car whitelist [ ipv6 ] enable
控制平面动态白名单流量监管功能处于开启状态,设备使用缺省的限速值对动态白名单的流量进行流量监管。
控制平面视图
为实现控制平面动态白名单的流量监管,需要保证控制平面动态白名单流量监管功能处于开启状态。
# 开启slot 3上的控制平面动态白名单流量监管功能。
[Sysname-cp-slot3] qos car whitelist enable
qos member-link-scheduler distribute命令用来配置按照三层聚合接口成员口的物理带宽为成员口分配流量的限速值。
undo qos member-link-scheduler distribute命令用来恢复缺省情况。
undo qos user-profile-car member-link-scheduler distribute
设备不会按照三层聚合接口成员口的物理带宽为成员口分配流量的限速值。
三层聚合接口视图
user-profile-car:指定在三层聚合接口下应用配置了流量监管的User Profile时,按照三层聚合接口成员口的物理带宽为成员口分配流量的限速值。
缺省情况下,在三层聚合接口下应用配置了流量监管的User Profile时,如果所有成员口均属于同一芯片,则所有成员口的流量速率之和不应超过聚合接口上配置的限速带宽;否则,每个芯片上的成员口的流量速率之和不应超过聚合接口上配置的限速带宽,此时多个芯片上的所有成员口的流量速率之和可以超出配置的限速值,未达到限速效果。
在三层聚合接口下执行本命令后,设备将按照成员口物理带宽占所有成员口总物理带宽的百分比,来为每个芯片上的成员口分配流量限速值,以解决成员口位于不同芯片时聚合接口实际带宽超过限速值的问题。例如,三层聚合口下应用的User Profile限速为100Mbps,该聚合口存在4个物理带宽为1Gbps的成员口A、B、C、D,成员口A、B属于芯片1,成员口C属于芯片2,成员口D属于芯片3,则成员口A、B共享限速带宽50Mbps,成员口C和D各自独享限速带宽25Mbps。可以通过display qos user-profile-car member-link-scheduler distribute命令查看每个成员口的流量限速值。
若三层聚合接口上应用了CAR策略,执行本命令也会触发按照三层聚合接口成员口的物理带宽为成员口分配流量的限速值。
本命令对三层聚合接口的成员口出入方向的流量限速均生效。
# 配置按照三层聚合接口成员口1的物理带宽为成员口分配流量的限速值。
[Sysname] interface Route-Aggregation 1
[Sysname-Route-Aggregation1] qos user-profile-car member-link-scheduler distribute
· display qos user-profile-car member-link-scheduler distribute
reset qos car control-plane whitelist命令用来清除控制平面动态白名单流量监管的统计信息。
(独立运行模式)
reset qos car control-plane whitelist [ ipv6 ] slot slot-number [ cpu cpu-number ]
reset qos car control-plane whitelist [ ipv6 ] chassis chassis-number slot slot-number [ cpu cpu-number ]
ipv6:清除IPv6动态白名单流量监管的统计信息。如果未指定本参数,将清除IPv4动态白名单流量监管的统计信息。
slot slot-number:清除指定单板的控制平面流量监管的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的控制平面流量监管的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 清除slot 2控制平面的动态白名单流量监管的统计信息。
<Sysname> reset qos car control-plane whitelist slot 2
display qos gts interface命令用来显示接口的流量整形配置情况和统计信息。
(独立运行模式)
display qos gts interface [ interface-type interface-number [ slot slot-number ] ]
display qos gts interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量整形配置情况和统计信息。
slot slot-number:显示指定单板上接口流量整形的配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上接口流量整形的配置情况。只有当接口为聚合接口时才支持此参数。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上接口流量整形的配置情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上接口流量整形的配置情况。只有当接口为聚合接口时才支持此参数。(IRF模式)
# 显示所有接口的流量整形配置情况和统计信息。
Rule: If-match queue 1
CIR 10000 (kbps), CBS 625000 (Bytes)
表5-5 display qos gts命令显示信息描述表
Rule |
匹配规则 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,单位为byte |
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
undo qos gts queue queue-id
未配置流量整形。
queue queue-id:对队列上的数据包进行流量整形。queue-id为匹配的队列号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。千兆端口的取值范围为300~1000000,万兆端口的取值范围为300~10000000,100GE口取值范围为2500~100000000。需要注意的是,对于100GE口,实际取值不能大于10000000。
cbs committed-burst-size:承诺突发尺寸,单位为byte。
· 如果不指定cbs参数,committed-burst-size缺省取值为62.5*committed-information-rate。
· 如果指定cbs参数,取值范围为4096~133169152。
需要注意的是,CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E、CSPEX-1104-E或SPEX-1204单板上,同一接口不能同时应用配置了加权轮询调度的队列调度策略和流量整形。
# 在接口GigabitEthernet3/1/1上对队列1中的报文进行流量整形。正常流速为6400kbps,突发流量为51200bytes。
[Sysname-GigabitEthernet3/1/1] qos gts queue 1 cir 6400 cbs 51200
qos gts命令用来在User Group Profile下配置流量整形。
undo qos gts命令用来取消User Group Profile下流量整形的配置。
qos gts any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
undo qos gts any
未配置流量整形。
User Group Profile视图
any:对所有的报文进行流量整形。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为300~300000000。
ebs excess-burst-size:超出突发尺寸,在双令牌桶算法中超出承诺突发流量的部分,单位为byte,缺省值为0byte。取值范围为0~256000000。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为300~300000000。
queue-length queue-length:缓存队列的最大长度。单位1000byte,取值范围为1~29296875。缺省情况下,缓存队列的最大长度为4096。需要注意的是:实际使用中,queue-length的取值不应超过最接近且大于等于committed-information-rate*0.078125的整数。
# 对家庭用户接收的报文进行流量整形。正常流速为400kbps,突发流量为51200bytes,以后速率小于等于400kbps时正常发送,速率大于400kbps时,将进入缓存队列。
[Sysname] user-group-profile aaa
[Sysname-session-group-profile-aaa] qos gts any cir 400 cbs 51200
qos gts命令用来在Session Group Profile下配置流量整形。
undo qos gts命令用来取消Session Group Profile下流量整形的配置。
qos gts { any | queue queue-id } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts { any | queue queue-id } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
undo qos gts { any | queue queue-id }
未配置流量整形。
Session Group Profile视图
any:对所有的报文进行流量整形。
Session Group Profile下配置的流量整形动作仅对出方向的报文生效。
# 对家庭用户队列1接收的报文进行流量整形。正常流速为400kbps,突发流量为51200bytes,以后速率小于等于400kbps时正常发送,速率大于400kbps时,将进入缓存队列。
[Sysname] user-profile aaa type session-group
[Sysname-session-group-profile-aaa] qos gts queue 1 cir 400 cbs 51200
display qos lr命令用来显示接口上的限速配置情况和统计信息。
(独立运行模式)
display qos lr interface [ interface-type interface-number [ slot slot-number ] ]
display qos lr interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的限速配置情况和运行统计信息。
slot slot-number:显示指定单板上指定接口的限速配置情况和统计信息,slot-number表示单板所在的槽位号。只有当接口为聚合接口或Tunnel接口时才支持此参数。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定接口的限速配置情况和统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。只有当接口为聚合接口或Tunnel接口时才支持此参数。(IRF模式)
# 显示所有接口的接口限速配置情况和统计信息。
Direction: Outbound
Direction: Outbound
CIR 60 (%), CBS 1000 (ms)
表5-6 display qos lr命令显示信息描述表
Direction |
方向,可以是Inbound、Outbound |
CIR |
CBS |
承诺突发尺寸,当采用绝对值形式输入时,单位为byte;当采用百分比形式时,单位为ms,实际的CBS值是cbs-time乘以实际的承诺信息速率(cir值乘以接口带宽) |
qos lr命令用来对接口发送的数据进行限速。
undo qos lr命令用来取消接口配置的限速。
undo qos lr { inbound | outbound }
未配置限速。
inbound:入方向限速。
outbound:出方向限速。
cir committed-information-rate:承诺信息速率,单位为kbps。千兆端口的取值范围为300~1000000,万兆端口的取值范围为300~10000000,100GE口的取值范围为2500~100000000,三层聚合接口和Tunnel接口的取值范围为160~300000000。
cbs committed-burst-size:承诺突发尺寸,单位为bytes。
· 如果不指定cbs参数,committed-burst-size缺省取值为62.5ms*committed-information-rate。
· 如果指定cbs参数,三层聚合接口和Tunnel接口的取值范围为1024~133169152,其他接口的取值范围为4096~133169152。
仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板支持配置入方向限速。
# 对接口GigabitEthernet3/1/1上出方向的报文进行限速。正常流速为400kbps,突发流量为51200bytes,以后速率小于等于400kbps时正常发送,速率大于400kbps时,将进行限速。
[Sysname-GigabitEthernet3/1/1] qos lr outbound cir 400 cbs 51200
# 对三层聚合接口1上入方向的报文进行限速。正常流速为3000kbps,突发流量为102400bytes,以后速率小于等于3000kbps时正常发送,速率大于3000kbps时,将进行限速。
[Sysname-Route-Aggregation1] qos lr inbound cir 3000 cbs 102400
qos lr percent命令用来采用百分比的方式在接口上配置接口限速。
undo qos lr命令用来取消接口上配置接口限速的配置。
qos lr { inbound | outbound } percent cir cir-percent [ cbs cbs-time ]
未配置百分比形式的限速。
inbound:入方向限速。
outbound:出方向限速。
cbs cbs-time:用指定的时间(单位为ms)来设置CBS,实际的CBS值是cbs-time乘以实际的承诺信息速率(cir值乘以接口带宽)。cbs-time的取值范围为50~2000。
# 在接口GigabitEthernet3/1/1上配置限制接口出方向的报文速率,指定CIR 50%,CBS 1000 ms。
[Sysname-GigabitEthernet3/1/1] qos lr outbound percent cir 50 cbs 1000
display qos queue interface命令用来显示接口上队列配置情况。
display qos queue interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的接口队列配置情况。
# 显示所有接口下的队列信息。
<Sysname> display qos queue interface
Output queue: Strict Priority queuing
Interface: GigabitEthernet3/1/3
Interface: GigabitEthernet3/1/4
Interface: GigabitEthernet3/1/5
Interface: GigabitEthernet3/1/6
表6-1 display qos queue interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列的相关信息 |
display qos-queue resource命令用来显示指定单板上QoS队列资源的使用信息。
(独立运行模式)
display qos-queue resource slot slot-number { inbound | outbound }
display qos-queue resource chassis chassis-number slot slot-number { inbound | outbound }
slot slot-number:显示指定单板上QoS队列资源的使用信息,slot-number表示单板所在的槽位号。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上QoS队列资源的使用信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
inbound:表示显示入方向的QoS队列资源使用信息。
outbound:表示显示出方向的QoS队列资使用源信息。
如果指定的单板不支持统计QoS队列资源,则不会显示对应的统计信息。
# 显示3号槽位单板出方向上的QoS队列资源使用信息。
[Sysname] display qos-queue resource slot 3 outbound
Chip 0
Res-Pool Type Total Used Free
TM0 UserGroup 22126 0 22126 (share with each other)
Hqos 22126 0 22126 (share with each other)
PortQos 22126 0 22126 (share with each other)
AdvancedUser22126 0 22126 (share with each other)
BasicUser 33174 0 33174 (share with each other)
Res-Pool |
资源对应的TM芯片 |
Type |
资源类型 |
Total |
资源总数 |
Userd |
已经配置的资源数 |
Free |
剩余可用的资源数 |
display qos queue sp interface命令用来显示接口的SP(Strict Priority,严格优先级)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的SP队列配置情况。
# 显示GigabitEthernet3/1/1的严格优先级队列配置情况。
<Sysname> display qos queue sp interface gigabitethernet 3/1/1
表6-2 display qos queue sp interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列类型 |
qos sp命令用来在接口上配置严格优先队列。
undo qos sp命令用来恢复缺省情况。
qos sp
undo qos sp
端口采用SP调度算法。
仅以下单板支持本命令。
· SPC类单板
· MPE-1104单板
# 在接口GigabitEthernet3/1/1上应用SP模式的队列调度。
[Sysname-GigabitEthernet3/1/1] qos sp
· display qos queue sp interface
CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板不支持配置加权轮询队列命令。
display qos queue wrr interface命令用来显示接口的WRR(Weighted Round Robin,加权轮询)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WRR队列配置情况。
# 显示接口GigabitEthernet3/1/1的WRR队列配置情况。
<Sysname> display qos queue wrr interface gigabitethernet 3/1/1
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Weight
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 5
5 ef 1 6
6 cs6 1 7
7 cs7 1 8
表6-3 display qos queue wrr interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列类型 |
Queue ID |
队列号 |
Queue name |
队列名称 |
Group |
分组号,说明队列属于哪一个分组,缺省情况下,队列所属的分组号为1 |
Weight |
各个队列的调度权重,当前WRR队列调度权重的计算方式为Weight, N/A表示该队列采用SP调度算法 |
qos wrr命令用来在接口上开启WRR队列。
undo qos wrr命令用来恢复缺省情况。
qos wrr weight
undo qos wrr weight
接口上采用SP队列算法。
weight:表示按照权重进行计算。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行WRR配置。
# 在接口GigabitEthernet3/1/1上开启WRR队列,并按照权重进行计算。
[Sysname-GigabitEthernet3/1/1] qos wrr weight
· display qos queue wrr interface
qos wrr weight命令用来配置WRR队列或修改WRR队列的参数。
undo qos wrr命令用来恢复指定队列的缺省情况。
qos wrr queue-id group { 1 | 2 | 3 | 4 } weight schedule-value
undo qos wrr queue-id
接口开启WRR队列后,所有队列均属于group 1,0~7队列的调度权重分别为1~8。
queue-id:队列序号,取值范围为0~7。
group { 1 | 2 | 3 | 4 }:表示该队列属于哪个WFQ优先组,当前仅支持配置为group 1,表示该队列属于WFQ优先组1,其余优先组暂不支持。
schedule-value:配置队列的调度权重,取值范围为0~310。当前只支持配置调度权重取值范围为1~63。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行本配置。
仅SPC类单板和MPE-1104单板上的接口支持配置队列的调度权重。
queue-id除了支持数字外,还支持直接输入关键字,具体情况请参见表6-4。
表6-4 queue-id数字和关键字对应表
queue-id数字 |
queue-id关键字 |
0 |
be |
1 |
af1 |
2 |
af2 |
3 |
af3 |
4 |
af4 |
5 |
ef |
6 |
cs6 |
7 |
cs7 |
# 在接口GigabitEthernet3/1/1上应用WRR队列,配置队列0的调度权重为10。
[Sysname-GigabitEthernet3/1/1] qos wrr 0 group 1 weight 10
· qos wrr
qos wrr group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wrr group sp命令用来取消将队列加入SP组。
qos wrr queue-id group sp
当使用WRR队列时,所有队列都处于WRR调度组中。
queue-id:队列序号,取值范围为0~7或表6-4中的关键字。
本命令需要在端口队列为WRR调度模式下使用。
SP组与普通WRR优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WRR优先组。
# 在接口GigabitEthernet3/1/1上应用WRR队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-GigabitEthernet3/1/1] qos wrr 0 group sp
· qos wrr
CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板不支持配置加权公平队列命令。
SPC类单板和MPE-1104单板的三层以太网子接口不支持配置加权公平队列命令。
display qos queue wfq interface命令用来显示接口的WFQ配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WFQ配置情况。
# 显示接口GigabitEthernet3/1/1的加权公平队列配置情况。
<Sysname> display qos queue wfq interface gigabitethernet 3/1/1
Output queue: Hardware Weighted Fair Queuing
Queue ID Queue name Weight Min bandwidth
0 be 1 0
1 af1 1 0
2 af2 1 0
3 af3 1 0
4 af4 1 0
5 ef 1 0
6 cs6 1 0
7 cs7 1 0
表6-5 display qos queue wfq interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列类型 |
Queue ID |
队列号 |
Queue name |
队列名称 |
Min-Bandwidth |
队列的最小保证带宽值 |
qos bandwidth queue命令用来配置端口队列的最小带宽保证。
undo qos bandwidth queue命令用来恢复缺省情况。
undo qos bandwidth queue queue-id
在使用WFQ队列时,不提供最小带宽保证。
min bandwidth-value:最小保证带宽值,单位为kbps。千兆端口的取值范围为300~1000000,万兆端口的取值范围为300~10000000,40GE端口的取值范围为300~40000000,100GE端口的取值范围为300~100000000。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行本配置。
# 在接口GigabitEthernet3/1/1上配置队列0的最小保证带宽值为100kbps。
[Sysname-GigabitEthernet3/1/1] qos wfq weight
[Sysname-GigabitEthernet3/1/1] qos bandwidth queue 0 min 100
· qos wfq
qos wfq命令用来在接口上开启WFQ队列。
undo qos wfq命令用来恢复缺省情况。
qos wfq weight
undo qos wfq weight
接口使用SP队列调度算法。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行WFQ配置。
# 在接口GigabitEthernet3/1/1上开启WFQ队列。
· display qos queue wfq interface
qos wfq weight命令用来配置WFQ队列或修改WFQ队列的参数。
undo qos wfq命令用来恢复指定队列的缺省情况。
qos wfq queue-id weight schedule-value
undo qos wfq queue-id
在使用WFQ队列时,所有队列的调度权重均为1。
schedule-value:配置队列的调度权重,取值范围为1~310。当前只支持配置调度权重取值范围为1~63。
# 在接口GigabitEthernet3/1/1上应用WFQ队列,配置队列0的调度权重为10。
[Sysname-GigabitEthernet3/1/1] qos wfq 0 weight 10
· qos bandwidth queue
· qos wfq
bandwidth queue命令用来配置队列调度策略下队列的最小带宽保证。
undo bandwidth queue命令用来恢复缺省情况。
bandwidth queue queue-id min { bandwidth-value | percent percent }
undo bandwidth queue queue-id
未配置队列调度策略下队列的最小带宽保证。
队列调度策略视图
queue-id:队列序号,取值范围0~7。
min bandwidth-value:最小保证带宽值,单位为kbps,取值范围300~300000000。
percent percent:以百分比的形式指定最小保证带宽。取值范围为1~100。最小保证带宽的实际值是百分比值乘以接口带宽值。
对于CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板,队列调度策略下队列的最小保证带宽仅当队列使用严格优先调度算法时生效。
仅在高级调度策略中支持配置最小保证带宽。在基础调度策略中不支持。有关队列调度策略的详细介绍,请参见6.5.8 qos qmprofile。
配置了以百分比形式指定最小保证带宽的队列调度策略不支持在子接口、User Profile、User Group Profile和Session Group Profile上应用。
# 配置队列1的最小保证带宽为128kbps。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] bandwidth queue 1 min 128
# 配置队列1的最小保证带宽为10%。
[Sysname-qmprofile-myprofile] bandwidth queue 1 min percent 10
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
(独立运行模式)
display qos qmprofile configuration [ profile-name ] [ slot slot-number [ cpu cpu-number ] ]
display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有队列调度策略的配置情况。
slot slot-number:显示指定单板的队列调度策略的配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的队列调度策略的配置情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的队列调度策略的配置情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的队列调度策略的配置情况。(IRF模式)
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID Applied WRED profile
be aaa
af1 bbb
Queue ID Type Group Schedule Schedule Min Max
unit value bandwidth bandwidth
be SP N/A N/A N/A 0 N/A
af1 SP N/A N/A N/A 0 N/A
af2 SP N/A N/A N/A 1000 N/A
af3 SP N/A N/A N/A 0 N/A
af4 SP N/A N/A N/A 0 N/A
ef SP N/A N/A N/A 0 N/A
cs6 SP N/A N/A N/A 0 N/A
cs7 SP N/A N/A N/A 0 N/A
表6-6 display qos qmprofile configuration命令显示信息描述表
Queue management profile |
队列调度策略名称 |
Basic |
表示此策略为基础队列调度策略,如未显示此字段则表示该策略为高级队列调度策略 |
Queue ID |
队列号 |
Applied WRED profile |
引用的WRED模板名称 |
Type |
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度) |
Group |
优先组,N/A表示无效 |
Schedule unit |
队列调度单位,N/A表示无效 |
Schedule vlaue |
· 队列调度单位为weight时,表示权重值 · N/A表示无效 |
Min Bandwidth |
最小保证带宽 |
Max bandwidth |
最大带宽值 |
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
(独立运行模式)
display qos qmprofile interface [ interface-type interface-number [ slot slot-number ] ] [ inbound ]
display qos qmprofile interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ] [ inbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列调度策略的配置情况。
slot slot-number:显示指定单板上接口队列调度策略的配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上接口队列调度策略的配置情况。只有当接口为聚合接口时才支持此参数。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上接口队列调度策略的配置情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上接口队列调度策略的配置情况。只有当接口为聚合接口时才支持此参数。(IRF模式)
inbound:显示在接口入方向上的队列调度策略的配置情况。如果未指定该参数,将显示接口出方向上的队列调度策略的配置情况。目前暂不支持配置该参数。
本命令仅CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板支持。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface gigabitethernet 3/1/1
Direction: Inbound
Queue scheduling profile: myprofile
Direction: Outbound
be w1(Active)
af1 w2(Inactive)
Queue Type Group Schedule Schedule Min Max
ID unit value bandwidth bandwidth
be SP N/A N/A N/A 64 10000
af1 WRR 1 weight 100 100 10000
af2 WRR 1 weight 100 100 10000
af3 WRR 1 weight 100 100 10000
af4 WRR 1 weight 50 100 10000
ef WRR 1 weight 50 100 10000
cs6 WRR 1 weight 100 100 10000
cs7 WRR 1 weight 50 100 10000
表6-7 display qos qmprofile interface命令显示信息描述表
接口名称 |
Direction |
应用方向 |
队列调度策略名称 |
Queue ID |
队列号 |
引用的WRED模板名称。Active表示引用的队列WRED模板已生效,Inactive表示引用的队列WRED模板未生效 |
Type |
Group |
优先组,N/A表示无效 |
Schedule unit |
队列调度单位,N/A表示无效 |
Schedule value |
Min bandwidth |
最小保证带宽,取值有两种形式: · 配置的实际值 · 配置的百分比 |
Max bandwidth |
最大带宽值,取值有两种形式: · 配置的实际值 · 配置的百分比 |
group命令用来配置调度优先组的最大带宽。
undo group命令用来恢复缺省情况。
group group-id max-bandwidth { bandwidth-value | percent percent }
undo group group-id max-bandwidth
未配置调度优先组的最大带宽。
队列调度策略视图
group group-id:优先组号,取值范围1~4。
max-bandwidth bandwidth-value:最大带宽值,单位为kbps,取值范围300~300000000。
percent percent:以百分比的形式指定最大带宽。取值范围为1~100。最大带宽的实际值是百分比值乘以接口带宽值。
本命令仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板支持。
仅在高级队列调度策略中队列优先级与优先组号一致时支持配置该命令。
配置了以百分比形式指定调度优先组最大带宽的队列调度策略对用户上线流量不生效。
# 创建高级队列调度策略myprofile,并配置优先组1的最大带宽为200Mbps。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 100
[Sysname-qmprofile-myprofile] group 1 max-bandwidth 200000
# 创建高级队列调度策略myprofile,并配置优先组1的最大带宽为20%。
[Sysname-qmprofile-myprofile] group 1 max-bandwidth percent 20
· display qos qmprofile interface
· qos qmprofile
qos apply qmprofile fabric命令用来在交换网板上应用队列调度策略。
undo qos apply qmprofile fabric命令用来恢复缺省情况。
(独立运行模式)
qos apply qmprofile profile-name fabric [ slot slot-number ]
undo qos apply qmprofile profile-name fabric [ slot slot-number ]
qos apply qmprofile profile-name fabric [ chassis chassis-number slot slot-number ]
undo qos apply qmprofile profile-name fabric [ chassis chassis-number slot slot-number ]
所有交换网板上未应用队列调度策略。
slot slot-number:在指定交换网板上应用队列调度策略。slot-number表示交换网板所在的槽位号。如果未指定本参数,将在所有交换网板上应用队列调度策略。(独立运行模式)
chassis chassis-number slot slot-number:在指定成员设备的指定交换网板上应用队列调度策略。chassis-number表示设备在IRF中的成员编号,chassis-number表示交换网板所在的槽位号。如果未指定本参数,将在所有成员设备的所有交换网板上应用队列调度策略。(IRF模式)
在指定交换网板上应用队列调度策略的优先级要高于在全局应用队列调度策略。
slot和chassis参数仅CSPEX-1804X、CSPEX-1512X、CSPEX-1612X、CSPEX-1812X、SPE类单板和CEPC类单板(CEPC-XP4LX除外)支持。
# 在所有交换网板上应用队列调度策略myprofile。
[Sysname] qos apply qmprofile myprofile fabric
qos apply qmprofile命令用来在接口上应用队列调度策略。
undo qos apply qmprofile命令用来恢复缺省情况。
qos apply qmprofile profile-name [ inbound ]
undo qos apply qmprofile [ inbound ]
接口使用SP队列调度算法。
inbound:表示在接口的入方向上应用队列调度策略。如果未指定该参数,则表示在接口的出方向应用队列调度策略。
每个接口在同一方向上只能应用一个队列调度策略。
本命令与qos apply wred-profile命令在接口应用WRED模板同时配置时,qos apply wred-profile命令在接口应用的WRED模板优先生效。
本命令与qos wred apply命令在接口上应用WRED表同时配置时,qos wred apply命令在接口上应用的WRED表优先生效。
本命令仅CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板支持。需要注意的是,CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E、CSPEX-1104-E或SPEX-1204单板同一接口不能同时应用配置了加权轮询调度的队列调度策略和流量整形。
仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板支持在接口的入方向上应用队列调度策略。
# 在接口GigabitEthernet3/1/1的出方向上应用队列调度策略myprofile。
[Sysname-GigabitEthernet3/1/1] qos apply qmprofile myprofile
# 在三层聚合接口1的入方向上应用队列调度策略myprofile。
[Sysname-Route-Aggregation1] qos apply qmprofile myprofile inbound
· qos apply wred-profile
· qos wred apply
qos apply qmprofile命令用来在User Group Profile或Session Group Profile上应用队列调度策略。
未配置User Group Profile或Session Group Profile的队列调度策略。
inbound:表示在User Group Profile或Session Group Profile入方向应用队列调度策略。如果未指定该参数,则表示在User Group Profile或Session Group Profile出方向应用队列调度策略。目前暂不支持配置该参数。
每个User Group Profile或Session Group Profile在同一方向只能应用一个队列调度策略。
如果需要删除应用到User Group Profile或Session Group Profile的队列调度策略,必须先取消对该队列调度策略的应用,然后再删除该队列调度策略。
配置User Group Profile或Session Group Profile下应用队列调度策略时,指定的队列调度策略必须已经存在。
# 在Session Group Profile出方向应用调度策略myprofile。
[Sysname] user-profile a123 type session-group
[Sysname-session-group-profile-a123] qos apply qmprofile myprofile
# 在User Group Profile出方向应用调度策略myprofile。
[Sysname] user-group-profile a123
[Sysname-user-group-profile-a123] qos apply qmprofile myprofile
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入相应的队列调度策略视图。如果指定的队列调度策略已经存在,则直接进入该队列调度策略视图。
undo qos qmprofile命令用来删除用户自定义的队列调度策略。
qos qmprofile profile-name [ basic ]
undo qos qmprofile profile-name
不存在用户自定义的队列调度策略。
basic:指定创建的队列调度策略类型为基础调度策略。如果未指定本参数,则表示创建的队列调度策略为高级调度策略。
如果需要删除已经应用到接口、User Profile、User Group Profile或Session Group Profile的队列调度策略,必须先在应用的位置上取消对该队列调度策略的应用,然后再删除该队列调度策略。
# 创建队列调度策略myprofile,并进入队列调度策略视图。
· queue
queue命令用来配置队列调度参数。
undo queue命令用来取消队列调度参数的配置。
queue queue-id { sp | wrr group group-id weight schedule-value } [ max-bandwidth { bandwidth-value | percent percent } | wred-profile profile-name ] *
undo queue queue-id
各队列采用严格优先级调度。
队列调度策略视图
sp:配置队列为严格优先级调度。
wrr:配置队列为加权轮询调度。
weightschedule-value:配置队列的调度权重,取值范围0~310,对于SPEX-1204单板,当前只支持取值范围为0~63。
max-bandwidth:最大限制带宽。
bandwidth-value:带宽值,单位为kbps,取值范围300~300000000。
percent percent:以百分比的形式指定带宽。取值范围为1~100。带宽的实际值是百分比值乘以接口带宽值。
本参数仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板上的接口支持。
wred-profile profile-name:指定WRED模板的名称,为1~32个字符的字符串,区分大小写。
queue-id除了支持数字外,还支持直接输入关键字,具体情况请参见表6-8。
表6-8 queue-id数字和关键字对应表
queue-id数字 |
queue-id关键字 |
0 |
be |
1 |
af1 |
2 |
af2 |
3 |
af3 |
4 |
af4 |
5 |
ef |
6 |
cs6 |
7 |
cs7 |
调度权重为0的队列不支持配置队列的最小带宽保证且调度优先级最低,权重为0的队列之间调度时,按相同权重进行轮询调度。
在满足以下条件的场景中,建议配置本命令时为所有队列最多指定同一个优先组号,否则会引起队列调度异常。
· 配置了本命令的基础队列调度策略并应用到User Profile、User Group Profile或Session Group Profile。
· 该User Profile、User Group Profile或Session Group Profile下执行了qos user-queue命令或qos gts命令来配置cir和pir双速令牌桶。
· PPP和IPoE用户授权属性时指定了该User Profile、User Group Profile或Session Group Profile
此时,指定了加权轮询优先组号的队列的调度优先级等效于队列序号为2的严格优先级调度。
# 创建自定义的队列调度策略myprofile,并配置队列0为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 0 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,权重为100,分组为1。
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,分组为1,权重为100,最大带宽为30%。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 100 max-bandwidth percent 30
· qos qmprofile
qos reserved-bandwidth命令用来设置最大预留带宽占可用带宽的百分比。
undo qos reserved-bandwidth命令用来恢复缺省情况。
qos reserved-bandwidth pct percent
最大预留带宽占可用带宽的百分比为80。
percent:预留带宽占可用带宽的百分比,取值范围为1~100。
为队列分配带宽时,考虑到部分带宽用于控制协议报文、二层帧头等,通常配置的最大预留带宽不大于可用带宽的80%。
建议慎重使用该命令修改最大预留带宽。如果配置的最大预留带宽过大,发送的报文加上链路层的帧头有可能大于接口最大可用带宽,导致接口无法满足需求,建议使用缺省最大预留带宽。
接口最大可用带宽通过命令bandwidth进行配置,具体情况请参见“接口管理命令参考”中的“以太网接口”。
# 配置GigabitEthernet3/1/1接口的最大预留带宽占可用带宽的百分比为70。
[Sysname-GigabitEthernet3/1/1] qos reserved-bandwidth pct 70
queue af命令用来配置类进行确保转发(Assured-forwarding),并配置类可确保的保证带宽。
undo queue af命令用来恢复缺省情况。
queue af bandwidth { bandwidth [ pir peak-information-rate ] | pct percentage }
undo queue af
未配置类进行确保转发。
流行为视图
bandwidth:可确保的保证带宽,单位kbps,取值范围为64~300000000。
pir peak-information-rate:峰值速率,单位为kbps,取值范围为64~300000000。MPE-1104单板上pir配置后不生效。
pct percentage:可用带宽的百分比,取值范围为1~100。
采用参数pct percentage配置类可确保的最小带宽时,带宽的计算方式为接口的最大预留带宽×可用带宽的百分比。接口的最大预留带宽由qos reserved-bandwidth命令配置。
将类与queue af所属行为关联时,必须满足:
· 同一个策略下为确保转发(queue af)和加速转发(queue ef)的类指定的带宽之和必须不大于该策略所应用接口的可用带宽。
· 同一个策略下为AF队列和EF队列指定的带宽百分比之和必须不大于100;
· 同一个策略下AF队列和EF队列的带宽的配置必须都采用相同的值的类型,比如都采用绝对值形式,或者都采用百分比形式。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
该命令在流行为视图下不能与queue ef和queue wfq同时使用。
SPC类单板不支持该命令。
# 为行为database配置确保转发,并且确保保证带宽为200kbps。
[Sysname-behavior-database] queue af bandwidth 200
queue ef命令用来配置类进行加速转发(Expedited-forwarding),报文进入绝对优先级队列,并配置保证带宽。
undo queue ef命令用来恢复缺省情况。
queue ef bandwidth { bandwidth [ cbs burst ] [ pir peak-information-rate ] | pct percentage [ cbs-ratio ratio ] }
undo queue ef
未配置类进行加速转发。
流行为视图
bandwidth:用户定义的需要加速转发的流量保证带宽,取值范围为64~300000000,单位是kbps。
cbs burst:指定承诺突发尺寸,即实际平均速率在用户定义带宽以内时的突发流量,取值范围为1600~1000000000,单位为byte,缺省值为bandwidth的25倍。用户配置的承诺突发尺寸不允许小于50ms bandwidth的流量,以避免令牌桶突发速率太小,影响网络流量的突发特征。
pir peak-information-rate:峰值速率,单位为kbps,取值范围为64~300000000。MPE-1104单板不支持配置pir。
cbs-ratio ratio:允许的突发因子,取值范围为25~500,缺省值是25。
采用参数pct percentage配置最大带宽时,带宽的计算方式为接口的最大预留带宽×可用带宽的百分比。接口的最大预留带宽由qos reserved-bandwidth命令配置。
该命令在同一个流行为视图下不能与queue af同时使用。
当将类与queue ef所属行为关联时,必须满足以下条件:
· 同一个策略下为AF队列和EF队列指定的带宽之和必须不大于该策略所应用接口的可用带宽。
· 对于设置百分比形式queue ef bandwidth pct percentage [ cbs-ratio ratio ],CBS = 接口可用带宽×percentage×ratio÷100。
· 对于设置绝对值形式queue ef bandwidth bandwidth [ cbs burst ],CBS = burst,若不指定burst,则CBS = bandwidth×25。
SPC类单板不支持该命令。
# 配置报文进入优先级队列,保证带宽为200kbps,承诺突发尺寸为5000bytes。
[Sysname-behavior-database] queue ef bandwidth 200 cbs 5000
queue wfq命令用来为缺省类配置采用公平队列。
undo queue wfq命令用来恢复缺省情况。
queue wfq
undo queue wfq
没有为缺省类配置采用公平队列。
流行为视图
SPC类单板不支持该命令。
该命令在流行为视图下不能与queue ef、queue af命令同时使用。
# 为流行为test配置WFQ。
[Sysname] traffic behavior test
[Sysname-behaviro-test] queue wfq
queue-length命令用来配置最大队列长度,丢弃方式为尾部丢弃。
undo queue-length命令用来恢复缺省情况。
undo queue-length
丢弃方式为尾部丢弃方式,队列长度为4096。
流行为视图
queue-length:队列长度,即队列中所能容纳的数据包个数,取值范围为0~29296875,单位为报文个数。
本命令必须在配置了queue af或queue wfq或queue ef后使用。
配置queue-length后,若执行undo queue af、undo queue wfq和undo queue ef命令,则queue-length也同时被取消。
# 配置尾部丢弃,队列长度最大为16。
[Sysname-behavior-database] queue-length 16
· queue af
· queue wfq
· queue ef
weight命令用来配置WFQ的权重。
undo weight命令用来恢复缺省情况。
weight weight-value
undo weight
对于MPE-1104单板,AF超出保证带宽的流量和BE队列的流量,WFQ的权重为1;EF超出保证带宽的流量,WFQ的权重为0。
对于CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E、CSPEX类单板、SPE类单板和CEPC类单板,AF超出保证带宽的流量和EF超出保证带宽的流量,WFQ的权重为1;BE的流量,WFQ的权重为0。
对于SPEX-1204单板上的POS主接口和以太网主接口,AF超出保证带宽的流量和EF超出保证带宽的流量,WFQ的权重为1;BE的流量,WFQ的权重为0;对于SPEX-1204单板上的其他接口及子接口,各队列的流量按照严格优先级进行调度。
流行为视图
weight-value:权重的值,取值范围为1~63。
在AF最小可保证带宽和峰值速率之间的流量采用WFQ调度;在EF最大带宽和峰值速率之间的流量采用WFQ调度。
该命令在流行为视图下不能单独使用,必须与queue af、queue wfq两者中的一条配合使用。
对于MPE-1104单板,AF超出保证带宽的流量和BE队列的流量,按照WFQ的权重进行调度,若有剩余带宽,再发送EF超出保证带宽的流量。
对于CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E、CSPEX类单板、SPE类单板和CEPC类单板,AF超出保证带宽的流量、EF超出保证带宽的流量和BE队列的流量,按照WFQ的权重进行调度。BE队列的缺省WFQ权重为0,即有剩余带宽时,才发送BE队列的流量。
对于SPEX-1204单板上的POS主接口和以太网主接口,AF超出保证带宽的流量、EF超出保证带宽的流量和BE队列的流量,按照WFQ的权重进行调度。BE队列的缺省WFQ权重为0,即有剩余带宽时,才发送BE队列的流量;对于SPEX-1204单板上的其他接口及子接口,各队列流量的优先级关系为EF队列保证带宽的流量 > AF队列保证带宽的流量 > AF队列超带宽的流量 > BE队列的流量 > EF队列超带宽的流量。
SPC类单板不支持该命令。
# 配置流行为database1采用AF,最小可保证带宽为200kbps,超出200kbps的流量采用WFQ调度,其权重为10。
[Sysname] traffic behavior database1
[Sysname-behavior-database1] queue af bandwidth 200
[Sysname-behavior-database1] weight 10
display qos weight命令用来显示子接口的调度权重。
display qos weight interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ outbound ]
interface-number:指定接口编号。如果未指定接口,将显示所有接口的调度权重。
interface-number.subnumber:指定子接口编号。其中interface-number为主接口编号,.subnumber为子接口编号,取值范围为1~4096。
outbound:出方向调度权重。
如果指定的是子接口编号,将显示子接口的调度权重。
如果指定的是主接口编号,将显示该主接口下所有子接口的调度权重。
如果未指定接口类型,将显示所有主接口下所有子接口的调度权重。
# 显示指定子接口的调度权重。
<Sysname> display qos weight interface GigabitEthernet 3/1/1.1
Interface: GigabitEthernet3/1/1.1
Direction: Outbound
Weight: 2
Status: Successful
# 显示所有子接口的调度权重。
Direction: outbound
Interface GigabitEthernet3/1/1.1 weight 2
Interface GigabitEthernet3/1/1.2 weight 2
表6-9 display qos weight命令显示信息描述表
Direction |
调度权重应用在子接口的方向 |
Weight |
子接口上应用的调度权重 |
Status |
调度权重在指定设备子接口上的下发状态 · Successful:表示下发成功 · Failed:表示下发失败 |
qos weight命令用来配置子接口的调度权重。
undo qos weight命令用来恢复缺省情况。
qos weight weight-value outbound
undo qos weight outbound
未配置子接口的调度权重。
子接口视图
weight-value:权重的值,取值范围为1~15。
outbound:出方向应用调度权重。
此命令需与HQoS配合使用,用于实现用户流量的多级调度。
# 为子接口GigabitEthernet3/1/1.1配置调度权重。
[Sysname-GigabitEthernet3/1/1.1] qos weight 3 outbound
display qos wred interface命令用来显示接口WRED配置情况和统计信息。
(独立运行模式)
display qos wred interface [ interface-type interface-number [ slot slot-number ] ]
display qos wred interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ]
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的WRED配置情况和统计信息。
slot slot-number:显示指定单板上接口WRED的配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上接口WRED配置情况。只有当接口为聚合接口时才支持此参数。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上接口WRED的配置情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上接口WRED的配置情况。只有当接口为聚合接口时才支持此参数。(IRF模式)
# 显示所有接口的WRED配置情况和统计信息。
<Sysname> display qos wred interface
Current WRED configuration:
Applied WRED table name: queue-table1
Table type: Queue based WRED
QID gmin gmax gpro ymin ymax ypro rmin rmax rpro exp ECN
0 100 1000 10 100 1000 10 100 1000 10 - N
1 100 1000 10 100 1000 10 100 1000 10 - N
2 100 1000 10 100 1000 10 100 1000 10 - N
3 100 1000 10 100 1000 10 100 1000 10 - N
4 100 1000 10 100 1000 10 100 1000 10 - N
5 100 1000 10 100 1000 10 100 1000 10 - N
6 100 1000 10 100 1000 10 100 1000 10 - N
7 100 1000 10 100 1000 10 100 1000 10 - N
# 显示所有接口上应用WRED模板的配置情况和统计信息。
exp ECN Length Applied WRED profile
- Y 100 aaa(Active)
- N 100 bbbvcbnfdhtt(Active)
- Y 100 ccc(Active)
- N 100 ddd(Active)
- Y 100 eee(Active)
- Y 100 gggffff(Inactive)
- N 100 asdfgg(Active)
- N 100 hknngkd(Active)
表7-1 display qos wred interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Current WRED configuration |
当前WRED的配置情况 |
Applied WRED table name |
当前应用的WRED表的名称 |
Table name |
WRED表名 |
Table type |
WRED表类型 |
QID |
队列ID |
gmin |
绿色报文的队列下限 |
gmax |
绿色报文的队列上限 |
gpro |
绿色报文的丢弃概率 |
ymin |
黄色报文的队列下限 |
ymax |
黄色报文的队列上限 |
ypro |
黄色报文的丢弃概率 |
rmin |
红色报文的队列下限 |
rmax |
红色报文的队列上限 |
rpro |
红色报文的丢弃概率 |
exp |
计算平均队列长度指数 |
ECN |
是否对该队列开启了拥塞通知功能,Y表示开启,N表示未开启 |
Length |
队列长度 |
应用的WRED模板的名称。Active表示该队列WRED模板已生效,Inactive表示该队列WRED模板未生效 |
display qos wred table命令用来显示WRED表的配置情况。
(独立运行模式)
display qos wred table [ name table-name ] [ chassis chassis-number slot slot-number ]
name table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则显示所有WRED表配置情况。
slot slot-number:显示指定单板的WRED表配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的WRED表配置情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的WRED表配置情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的WRED表配置情况。(IRF模式)
# 显示WRED表1的配置情况,表1是一个已经配置好的WRED参数表。
<Sysname> display qos wred table name 1
Table name: 1
0 100 1000 10 100 1000 10 100 1000 10 9 N
1 100 1000 10 100 1000 10 100 1000 10 9 N
2 100 1000 10 100 1000 10 100 1000 10 9 N
3 100 1000 10 100 1000 10 100 1000 10 9 N
4 100 1000 10 100 1000 10 100 1000 10 9 N
5 100 1000 10 100 1000 10 100 1000 10 9 N
6 100 1000 10 100 1000 10 100 1000 10 9 N
7 100 1000 10 100 1000 10 100 1000 10 9 N
表7-2 display qos wred table命令显示信息描述表
Table name |
WRED表名 |
Table type |
WRED表类型 |
QID |
队列ID |
gmin |
绿色报文的队列下限 |
gmax |
绿色报文的队列上限 |
gpro |
绿色报文的丢弃概率 |
ymin |
黄色报文的队列下限 |
ymax |
黄色报文的队列上限 |
ypro |
黄色报文的丢弃概率 |
rmin |
红色报文的队列下限 |
rmax |
红色报文的队列上限 |
rpro |
红色报文的丢弃概率 |
exp |
计算平均队列长度指数 |
ECN |
qos wred apply命令用来在接口上应用WRED表。
undo qos wred apply命令用来恢复缺省情况。
qos wred apply [ table-name ]
undo qos wred apply
接口没有应用WRED表,即接口采用尾丢弃。
table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则在接口上应用缺省WRED表。
本命令与qos apply wred-profile命令互斥。
本命令与通过队列调度策略下发队列WRED模板同时配置时,本命令优先生效。
# 在接口GigabitEthernet3/1/1上应用WRED表。
[Sysname-GigabitEthernet3/1/1] qos wred apply table1
· display qos wred interface
· display qos wred table
· qos apply qmprofile(interface view)
· qos wred table
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。如果指定的WRED表已经存在,则直接进入WRED表视图。
undo qos wred queue table命令用来删除WRED表。
undo qos wred queue table table-name
设备上不存在WRED表。
queue:基于队列的表,拥塞时根据报文所在队列进行随机丢弃。
table table-name:指定WRED表的名称,为1~32个字符的字符串,区分大小写。
设备不允许删除正在使用的WRED表。如果需要删除正在使用的表,请先在接口上取消应用的WRED表。
# 创建基于queue的WRED表queue-table1。
[Sysname-wred-table-queue-table1]
queue命令用来配置基于队列的WRED表的内容。
undo queue命令用来恢复缺省情况。
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id [ drop-level drop-level ] | all }
WRED表在创建之后,有缺省的一套参数,low-limit的取值为100,high-limit的取值为1000,discard-prob的取值为10。
WRED表视图
all:表示所有队列。指定该参数后将取消WRED表中所有基于队列的配置。
queue-id:队列编号,取值范围为0~7。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:队列平均长度的下限,取值范围为0~29296875,单位为报文个数。
high-limit high-limit:队列平均长度的上限,取值范围为0~29296875,单位为报文个数。需要注意的是:实际使用中,high-limit的取值必须大于等于丢弃下限且不应超过12582912。
discard-probability discard-prob:以百分数形式表示的丢弃概率,取值范围为0~100。当报文队列平均长度在上限和下限之间时,设备采用这个概率来丢弃报文。SPEX-1204单板暂不支持配置此参数。
当队列平均长度小于下限时,不丢弃报文。当队列平均长度在上限和下限之间时,设备随机丢弃报文,队列越长,丢弃概率越高。当队列平均长度超过上限时,丢弃所有到来的报文。
当配置的队列平均长度的下限与上限相等时,表示本队列的报文丢弃策略为尾丢弃。
# 配置全局WRED表queue-table1中队列1丢弃参数:丢弃下限为10,丢弃上限为20,丢弃概率为30%。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
· qos wred table
queue ecn命令用来对指定队列开启拥塞通知功能。
undo queue ecn命令用来恢复缺省情况。
queue queue-id ecn
undo queue queue-id ecn
对任何队列都未开启拥塞通知功能。
WRED表视图
在报文的发送端和接收端都支持ECN功能时,设备可以通过对ECN域的识别和标记将拥塞状况告知终端,避免拥塞加剧。
需要注意的是,CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板不支持开启拥塞通知功能。
# 在WRED表queue-table1中,对队列1开启拥塞通知功能。
[Sysname-wred-table-queue-table1] queue 1 ecn
· qos wred table
queue weighting-constant命令用来配置计算平均队列长度的指数。
undo queue weighting-constant命令用来恢复缺省情况。
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
计算平均队列长度的指数为9。
WRED表视图
weighting-constant exponent:计算平均队列长度的指数,exponent的取值范围为0~15。
平均队列长度的指数越大,计算平均队列长度时对队列的实时变化越不敏感。计算队列平均长度的公式为:平均队列长度=(以前的平均队列长度×(1-1/2n))+(当前队列长度×(1/2n))。其中n表示指数。
需要注意的是,CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板上配置计算平均队列长度的指数后不生效。
# 在WRED表queue-table1中,配置计算平均队列长度的指数为12。
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
· qos wred table
display qos wred-profile命令用来显示WRED模板。
display qos wred-profile [ profile-name ]
profile-name:指定WRED模板的名称。
不指定profile-name时,显示所有已存在的WRED模板。
WRED模板中无配置时,仅显示模板名称。
# 显示所有WRED模板。
<Sysname> display qos wred-profile
WRED profile: myprofile
exp ECN Length
- Y 1024
表7-3 display qos wred-profile命令显示信息描述表
gmin |
绿色报文的队列下限 |
gmax |
绿色报文的队列上限 |
gpro |
绿色报文的丢弃概率 |
ymin |
黄色报文的队列下限 |
ymax |
黄色报文的队列上限 |
ypro |
黄色报文的丢弃概率 |
rmin |
红色报文的队列下限 |
rmax |
红色报文的队列上限 |
rpro |
红色报文的丢弃概率 |
exp |
计算平均队列长度指数 |
ECN |
Length |
队列长度 |
qos apply wred-profile命令用来在指定的队列上应用WRED模板。
undo qos apply wred-profile命令用来取消指定队列上已应用的WRED模板。
qos apply wred-profile profile-name queue queue-id
undo qos apply wred-profile { queue-id | all }
未在队列上应用WRED模板。
queue-id:队列编号。取值范围为0~7。
应用的WRED模板必须已存在。
本命令与qos wred apply命令互斥。
# 在接口上为队列应用WRED模板。
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] qos apply wred-profile profile1 queue 1
· display qos wred-profile
· qos apply qmprofile (interface view)
· qos wred apply
· qos wred-profile
qos wred-profile命令用来创建WRED模板,同时进入WRED模板视图。如果指定的WRED模板已经存在,则直接进入WRED模板视图。
undo qos wred-profile命令用来删除WRED模板。
qos wred-profile profile-name
undo qos wred-profile profile-name
设备上不存在WRED模板。
已经应用的WRED模板不允许删除,如需删除,请先取消应用。
# 创建WRED模板queue-profile1。
[Sysname] qos wred-profile queue-profile1
[Sysname-wred-profile-queue-profile1]
queue命令用来配置队列的WRED参数。
queue [ drop-level drop-level ] [ limit-percent ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
queue low-limit low-limit high-limit high-limit [ discard-probability discard-prob ] [ ecn | weighting-constant exponent ] *
queue limit-percent low-limit low-limit high-limit high-limit [ discard-probability discard-prob ] [ ecn | weighting-constant exponent | queue-length length ] *
undo queue [ drop-level drop-level ]
未配置队列的WRED参数。
WRED模板视图
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,表示后续配置的参数对队列所有丢弃级别的报文都生效。
limit-percent:表示队列平均长度的上下限为百分比模式。如果不指定本参数,则表示队列平均长度的上下限为绝对值模式。
low-limit low-limit:队列平均长度的下限。
· 指定limit-percent时,取值范围为1~100,单位为%。队列平均长度的下限值=low-limit×队列长度。
· 不指定limit-percent时,取值范围为0~29296875,单位为报文个数。
high-limit high-limit:队列平均长度的上限。
· 指定limit-percent时,取值范围为1~100,单位为%。队列平均长度的上限值=high-limit×队列长度。
discard-probability discard-prob:丢弃概率,取值越大,计算出的丢弃概率越大。取值范围为0~100,单位为%。SPEX-1204单板暂不支持配置此参数。
ecn:表示开启队列的拥塞通知功能。仅以下单板支持本功能:
· SPC类单板
· MPE-1104单板
weighting-constant exponent:计算平均队列长度的指数。exponent的取值范围为0~15。仅以下单板支持本功能:
· SPC类单板
· MPE-1104单板
queue-length length:队列长度。取值范围为1~29296875,单位为报文个数。
所有drop-level的队列平均长度上下限单位必须保持一致,即必须同为百分比模式或同为非百分比模式。
如果不指定drop-level,设备实际上会对每个drop-level都下发一次命令,即设备内部会生成三条配置。
指定ecn参数,与配置queue ecn (WRED profile view)命令等效。
指定weighting-constant exponent参数,与配置queue weighting-constant (WRED profile view)命令等效。
指定queue-length length参数,与配置queue length命令等效。且仅在队列平均长度的上下限为百分比模式时,才需要配置队列长度;反之,命令会下发失败。
重复下发命令时:
· 如果不修改百分比模式,且命令中不包含ecn、weighting-constant或queue-length,则这三个属性依然保持命令下发前的原有配置生效;命令中如果包含ecn、weighting-constant或queue-length中的一个或多个,则新下发的配置生效。
· 如果修改百分比模式,且命令中不包含ecn、weighting-constant或queue-length,则这三个属性将被恢复至缺省情况;命令中如果包含ecn、weighting-constant或queue-length中的一个或多个,则新下发的配置生效。
# 在名为queue-profile1的WRED模板视图下,配置队列的WRED参数:对于丢弃级别未1的报文,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30。
[Sysname-wred-profile-queue-profile1] queue drop-level 1 low-limit 10 high-limit 20 discard-probability 30
· queue ecn (WRED profile view)
· queue length
· queue weighting-constant (WRED profile view)
queue ecn命令用来开启队列的拥塞通知功能。
undo queue ecn命令用来关闭队列的拥塞通知功能。
queue ecn
undo queue ecn
对任何队列都未开启拥塞通知功能。
WRED模板视图
配置本命令与配置queue (WRED profile view)命令时指定ecn参数等效。
当启用ECN功能时,请勿在iNQA中指定比特位6或7作为其染色位,反之亦然。有关iNQA的详细介绍,请参见“网络管理与监控配置指导”中的“iNQA”。
# 开启队列的拥塞通知功能。
[Sysname-wred-profile-queue-profile1] queue ecn
· queue (WRED profile view)
queue length命令用来配置队列长度。
undo queue length命令用来恢复缺省情况。
queue length length
undo queue length
未配置队列长度。
WRED模板视图
配置本命令与配置queue (WRED profile view)命令时指定queue-length length参数等效。
只有在queue (WRED profile view)命令中配置队列平均长度的上下限为百分比模式时,才需要配置本命令;反之,命令会下发失败。
# 配置队列长度为10。
[Sysname-wred-profile-queue-profile1] queue length 10
queue weighting-constant exponent
计算平均队列长度的指数为9。
WRED模板视图
exponent:计算平均队列长度的指数。取值范围为0~15。
配置本命令与配置queue (WRED profile view)命令时指定weighting-constant exponent参数等效。
# 配置计算平均队列长度的指数为12。
[Sysname-wred-profile-queue-profile1] queue weighting-constant 12
car name命令用来配置全局CAR动作。
undo car用来恢复缺省情况。
car name car-name
undo car
未配置全局CAR动作。
流行为视图
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
# 配置流行为be1的聚合CAR动作为aggcar-1。
· display qos car name
· display traffic behavior user-defined
display qos car name命令用来显示全局CAR的配置和统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。显示指定全局CAR的配置和统计信息。如果未指定本参数,将显示所有全局CAR的配置和统计信息。
# 显示全局CAR的配置和统计信息。
<Sysname> display qos car name
Mode: aggregative
CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
表8-1 display qos car name命令显示信息描述表
Name |
全局CAR的名称 |
Mode |
全局CAR的类型 |
CIR CBS PIR EBS |
流量监管流量的参数配置 |
qos car命令用来配置聚合CAR。
undo qos car命令用来取消聚合CAR的配置。
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car car-name
未配置聚合CAR。
aggregative:该全局CAR为聚合模式。
cir committed-information-rate:承诺信息速率,单位为kbps,取值范围为1~300000000。
ebs excess-burst-size:过度突发尺寸,缺省值为512,单位为byte。取值范围为0~256000000。
pir peak-information-rate:峰值速率,单位为kbps,取值范围为1~300000000。
聚合CAR配置需要在策略中引用后才能生效。
# 配置聚合CAR采取的CAR参数取值,cir取值为200,cbs取值为2048。
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2048
reset qos car name命令用来清除全局CAR的统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。清除指定全局CAR的统计信息。如果未指定本参数,将清除所有全局CAR的统计信息。
# 清除全局CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
display qos queue-statistics interface outbound命令用来显示端口队列出方向的统计信息。
(独立运行模式)
display qos queue-statistics interface [ interface-type interface-number [ slot slot-number ] ] outbound
display qos queue-statistics interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ] outbound
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列出方向统计信息。
slot slot-number:显示指定单板上接口队列出方向的统计信息。slot-number表示单板所在的槽位号。如果未指定本参数,将按单板显示接口出方向的队列统计信息。只有当指定接口为聚合接口时才支持此参数。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上接口队列出方向的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将按单板显示接口出方向的队列统计信息。只有当指定接口为聚合接口时才支持此参数。(IRF模式)
目前设备仅支持显示绿色报文转发的数据包数目、字节数和红色报文丢弃的数据包数目、字节数的统计情况。
对于SPEX-1204单板,仅支持显示转发的数据包数目、字节数的统计情况。
# 显示接口GigabitEthernet3/1/1的队列出方向统计信息。
<Sysname> display qos queue-statistics interface GigabitEthernet 3/1/1 outbound
Direction: Outbound
Forwarded: 10077 packets, 864466 bytes, 0 pps, 0 bps
Dropped: 0 packets, 0 bytes, 0 pps, 0 bps
Queue 0
Forwarded: 61 packets, 4758 bytes, 0 pps, 0 bps
Green forwarded: 61 packets, 4758 bytes, 0 pps, 0 bps
Green dropped: 0 packets, 0 bytes, 0 pps, 0 bps
Yellow forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
Yellow dropped: 0 packets, 0 bytes, 0 pps, 0 bps
Red forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
Red dropped: 0 packets, 0 bytes, 0 pps, 0 bps
Total queue length: 0 packets
Current queue length: 0 packets
Queue 1
Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
Green forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
Queue 2
Queue 3
Queue 4
Queue 5
Queue 6
Queue 7
表9-1 display qos queue-statistics interface outbound命令显示信息描述表
端口队列统计的端口 |
Direction |
端口队列统计的方向 |
Forwarded |
转发的数据包数目、字节数和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔 |
Dropped |
丢弃的数据包数目、字节数和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔 |
Queue 0、Queue 1、Queue 2、Queue 3、Queue 4、Queue 5、Queue 6、Queue 7 |
某端口队列统计信息 |
Green forwarded |
绿色报文转发的数据包数目、字节数和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔 |
Green dropped |
绿色报文丢弃的数据包数目、字节数和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔 |
Yellow forwarded |
黄色报文转发的数据包数目、字节数和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔 |
Yellow dropped |
黄色报文丢弃的数据包数目、字节数和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔 |
Red forwarded |
红色报文转发的数据包数目、字节数和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔 |
Red dropped |
红色报文丢弃的数据包数目、字节数和最近一个时间间隔内的平均速率,时间间隔为flow-interval命令配置的接口统计报文信息的时间间隔 |
Total queue length |
队列总长度 |
Current queue length |
当前队列长度 |
· reset counters interface(接口管理命令参考/以太网接口)
qos queue-statistics命令用来开启端口队列统计功能。
undo qos queue-statistics命令用来关闭端口队列统计功能。
qos queue-statistics { inbound | outbound }
undo qos queue-statistics { inbound | outbound }
端口队列统计功能处于开启状态。
inbound:开启入方向端口队列统计功能。本参数配置后不生效。
outbound:开启出方向端口队列统计功能。
本命令CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板支持。
# 开启出方向端口队列统计功能。
[Sysname] qos queue-statistics outbound
· display qos queue-statistics interface outbound
display qos queue-statistics user-id命令用来显示用户队列的统计信息。
(独立运行模式)
display qos queue-statistics user-id user-id [ slot slot-number [ cpu cpu-number ] ] outbound
display qos queue-statistics user-id user-id [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] outbound
user-id:表示在线用户的ID,取值范围为十六进制数1~7fffff。有关用户ID的详细介绍,请参见“BRAS业务命令参考”中的“UCM”。
slot slot-number:显示指定单板上指定用户队列的统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,将按单板显示指定用户队列的统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上指定用户队列的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将按单板显示指定用户队列的统计信息。(IRF模式)
outbound:显示在线用户出方向上的队列统计信息。
# 显示用户ID为400000的用户队列信息。
<Sysname> display qos queue-statistics user-id 400000 outbound
slot 2
User ID: 0x400000
Direction: Outbound
Forwarded: 6756832 packets, 891901824 bytes
Dropped: 49648521 packets, 6553604772 bytes
Queue 0
Forwarded: 1333037 packets, 175960884 bytes
Dropped: 5721125 packets, 755188500 bytes
Green forwarded: 1333037 packets, 175960884 bytes
Red dropped: 5721125 packets, 755188500 bytes
Current queue length: 999 packets
Queue 1
Forwarded: 162933 packets, 21507156 bytes
Dropped: 6888203 packets, 909242796 bytes
Green forwarded: 162933 packets, 21507156 bytes
Red dropped: 6888203 packets, 909242796 bytes
Current queue length: 4092 packets
Queue 2
Forwarded: 162945 packets, 21508740 bytes
Dropped: 6888260 packets, 909250320 bytes
Green forwarded: 162945 packets, 21508740 bytes
Red dropped: 6888260 packets, 909250320 bytes
Queue 3
Forwarded: 162956 packets, 21510192 bytes
Dropped: 6888315 packets, 909257580 bytes
Green forwarded: 162956 packets, 21510192 bytes
Red dropped: 6888315 packets, 909257580 bytes
Queue 4
Forwarded: 163895 packets, 21634140 bytes
Dropped: 6887445 packets, 909142740 bytes
Green forwarded: 163895 packets, 21634140 bytes
Red dropped: 6887445 packets, 909142740 bytes
Queue 5
Forwarded: 475882 packets, 62816424 bytes
Dropped: 6575525 packets, 867969300 bytes
Green forwarded: 475882 packets, 62816424 bytes
Red dropped: 6575525 packets, 867969300 bytes
Queue 6
Forwarded: 1986335 packets, 262196220 bytes
Dropped: 5065139 packets, 668598348 bytes
Green forwarded: 1986335 packets, 262196220 bytes
Red dropped: 5065139 packets, 668598348 bytes
Queue 7
Forwarded: 2308849 packets, 304768068 bytes
Dropped: 4734509 packets, 624955188 bytes
Green forwarded: 2308849 packets, 304768068 bytes
Red dropped: 4734509 packets, 624955188 bytes
Current queue length: 12276 packets
slot 4
User ID: 0x480000
Direction: Outbound
Queue 0
Queue 1
Queue 2
Queue 3
Queue 4
Queue 5
Queue 6
Queue 7
表9-2 display qos queue-statistics user-id命令显示信息描述表
User ID |
在线用户的ID |
Direction |
用户队列统计的方向 |
Forwarded |
转发的数据包数目和字节数 |
Dropped |
丢弃的数据包数目和字节数 |
Queue |
某用户队列统计信息 |
Green forwarded |
绿色报文转发的数据包数目和字节数 |
Green dropped |
绿色报文丢弃的数据包数目和字节数 |
Yellow forwarded |
黄色报文转发的数据包数目和字节数 |
Yellow dropped |
黄色报文丢弃的数据包数目和字节数 |
Red forwarded |
红色报文转发的数据包数目和字节数 |
Red dropped |
红色报文丢弃的数据包数目和字节数 |
当前队列长度 |
reset qos queue-statistics user-id命令用来清除用户队列的统计信息。
(独立运行模式)
reset qos queue-statistics user-id user-id [ slot slot-number [ cpu cpu-number ] ] outbound
reset qos queue-statistics user-id user-id [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] outbound
user-id:表示在线用户的ID。取值范围为十六进制数1~7fffff。有关用户ID的详细介绍,请参见“BRAS业务命令参考”中的“UCM”。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定所有单板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定所有单板。(IRF模式)
cpu cpu-number:指定CPU。cpu-number表示单板上CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
outbound:清除在线用户出方向上的队列统计信息。
如果清除家庭用户中其中一个用户的队列统计信息,则该家庭下其他用户的队列统计信息也会一并清除。
# 清除在线用户ID为400000的用户队列统计信息。
<Sysname> reset qos queue-statistics user-id 400000
· display qos queue-statistics user-id
bgp-policy命令用来配置QPPB功能,即通过BGP传播路由策略中设置的apply ip-precedence和apply qos-local-id信息。
undo bgp-policy命令用来恢复缺省情况。
bgp-policy { destination | source } ip-prec-map ip-qos-map
undo bgp-policy { destination | source } [ ip-prec-map ip-qos-map ]
未配置QPPB功能。
destination:使用目的IP查找路由。
source:使用源IP查找路由。如果指定本参数,则以源IP为目的进行反向查找。
ip-prec-map:设置IP优先级。
ip-qos-map:设置QoS本地ID。
对于CSPEX类单板(CSPEX-1104-E、CSPEX-1802X、CSPEX-1812X-E除外)、SPE类单板和CEPC类单板(CEPC-CQ8L除外)只对接口接收的报文生效。
在MPLS L3VPN网络中,PE公网接口入方向QoS业务在本配置之前进行;其他网络环境中QoS业务在本配置之后进行。
如果存在两条bgp-policy命令,分别指定source和destination,后者的设置操作会覆盖前者。
本命令仅CSPEX类单板(CSPEX-1104-E除外)、SPE类单板和CEPC类单板上的接口支持。
# 在接口Ten-GigabitEthernet3/1/1上根据源IP查找路由获得IP优先级和QoS本地ID。
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] bgp-policy source ip-prec-map ip-qos-map
· apply ip-precedence (三层技术-IP路由命令参考/路由策略)
· apply qos-local-id (三层技术-IP路由命令参考/路由策略)
· route-policy (三层技术-IP路由命令参考/路由策略)
display qos control-plane logging命令用来查看上送控制平面报文的丢报告警功能的配置和状态信息。
(独立运行模式)
display qos control-plane logging [ slot slot-number [ cpu cpu-number ] ]
display qos control-plane logging [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定Master设备主用主控板。(IRF模式)
# 显示slot 1的上送控制平面报文的告警功能的配置和状态信息。(独立运行模式)
<Sysname> display qos control-plane logging slot 1
Control plane slot 1
user-defined-flow:
Logging status : Enabled
Logging parameters:
Interval : 600 seconds
Count threshold: 30000 packets
Rate threshold : 50 packets/min
whitelist:
Logging parameters:
表11-1 display qos control-plane logging命令显示信息描述表
user-defined-flow |
用户自定义流量 |
whitelist |
IPv4和IPv6白名单流量 |
logging status |
· Disabled:上送控制平面报文的丢包告警功能处于关闭状态 · Enabled:上送控制平面报文的丢包告警功能处于开启状态 |
logging parameters |
· Interval:上送控制平面报文的丢包统计周期 · Count threshold:上送控制平面报文的丢包数量告警阈值 · Rate threshold:上送控制平面报文的丢包速率告警阈值 |
logging packet-drop { count-threshold | rate-threshold } *命令用来配置上送控制平面报文的丢包告警阈值。
undo logging packet-drop命令用来恢复缺省情况。
logging packet-drop { user-defined-flow | whitelist } { count-threshold count-threshold-value | rate-threshold rate-threshold-value } *
undo logging packet-drop { user-defined-flow | whitelist } [ count-threshold | rate-threshold ]
上送控制平面报文的丢包数量告警阈值为30000个,丢包速率告警阈值为50个/分钟。
控制平面视图
user-defined-flow:用户自定义流量,用户自定义流量指的是命中控制平面上应用的QoS策略的流量。
whitelist:上送控制平面的IPv4白名单流量。IPv4白名单流量指的是命中IPv4动态白名单的流量。
count-threshold count-threshold-value:丢包数量告警阈值,达到此阈值则生成告警,单位为报文个数。取值范围为1~1000000。
rate-threshold rate-threshold-value:丢包速率告警阈值,达到此阈值则生成告警,单位为报文个数/分钟。取值范围为0~1000000。
执行undo命令时,如果指定可选参数,表示仅将指定参数恢复至缺省情况,如果不指定可选参数,表示将丢包统计周期和丢包告警阈值都恢复至缺省情况。
# 配置slot 1的上送控制平面用户自定义流量的丢包数量告警阈值为100。(独立运行模式)
[Sysname] control-plane slot 1
[Sysname-cp-slot1] logging packet-drop user-defined-flow rate-threshold 100
· display qos control-plane logging
· logging packet-drop enable
· logging packet-drop interval
logging packet-drop enable命令用来开启上送控制平面报文的丢包告警功能。
undo logging packet-drop enable命令用来关闭上送控制平面报文的丢包告警功能。
logging packet-drop { user-defined-flow | whitelist } enable
undo logging packet-drop { user-defined-flow | whitelist } enable
上送控制平面报文的丢包告警功能处于开启状态。
控制平面视图
user-defined-flow:对上送控制平面的用户自定义流量开启丢包告警功能。用户自定义流量指的是命中控制平面上应用的QoS策略的流量。
whitelist:对上送控制平面的IPv4和IPv6白名单流量开启丢包告警功能。IPv4和IPv6白名单流量指的是命中IPv4和IPv6动态白名单的流量。
开启指定流量的丢包告警功能后,当该流量在丢包统计周期内的丢包数量达到设置阈值时,会生成日志并发送到信息中心。有关信息中心的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启slot 1的上送控制平面的用户自定义流量的丢包告警功能。(独立运行模式)
[Sysname-cp-slot1] logging packet-drop user-defined-flow enable
· display acl whitelist(ACL和QoS命令参考/ACL)
· display qos car control-plane whitelist
· display qos policy control-plane
logging packet-drop interval命令用来配置上送控制平面报文的丢包统计周期。
logging packet-drop { user-defined-flow | whitelist } interval interval-value
undo logging packet-drop { user-defined-flow | whitelist } [ interval ]
上送控制平面报文的丢包统计周期为600秒。
控制平面视图
interval-value:丢包统计周期,单位为秒。取值范围为60~3600。
执行undo命令时,如果指定interval,表示仅将丢包统计周期恢复至缺省情况,如果不指定interval,表示将丢包统计周期和丢包告警阈值都恢复至缺省情况。
# 配置slot 1的上送控制平面用户自定义流量的丢包统计周期为600秒。(独立运行模式)
[Sysname-cp-slot1] logging packet-drop user-defined-flow interval 600
· logging packet-drop { count-threshold | rate-threshold } *
