02-QoS命令
本章节下载: 02-QoS命令 (783.25 KB)
1.1.2 display traffic classifier
1.2.3 display traffic behavior
1.2.5 mac-address mac-learning enable
1.2.13 remark local-precedence
1.3.4 display qos policy control-plane
1.3.5 display qos policy control-plane pre-defined
1.3.6 display qos policy diagnosis control-plane
1.3.7 display qos policy diagnosis global
1.3.8 display qos policy diagnosis interface
1.3.9 display qos policy diagnosis l2vpn-ac
1.3.10 display qos policy diagnosis user-profile
1.3.11 display qos policy global
1.3.12 display qos policy interface
1.3.13 display qos policy l2vpn-ac
1.3.14 display qos policy user-profile
1.3.15 display qos vlan-policy
1.3.16 display qos vlan-policy diagnosis
1.3.17 qos apply policy (Ethernet service instance view, interface view, control plane view)
1.3.18 qos apply policy (user profile view)
1.3.19 qos apply policy global
1.3.22 reset qos policy control-plane
1.3.23 reset qos policy global
1.3.24 reset qos policy l2vpn-ac
2.2.1 display qos trust interface
3.1.1 display qos gts interface
3.2.1 display qos lr interface
4.1.1 display qos queue interface
4.2.1 display qos queue sp interface
4.3.1 display qos queue wrr interface
4.3.3 qos wrr { byte-count | weight }
4.4.1 display qos queue wfq interface
4.4.4 qos wfq { byte-count | weight }
4.5.2 display qos qmprofile configuration
4.5.3 display qos qmprofile interface
4.6.1 display qos queue-statistics interface outbound
4.6.2 reset qos queue-statistics interface outbound
5.1.1 display qos wred interface
5.1.9 qos wred queue weighting-constant
5.1.10 qos wred smart-ecn enable
5.1.11 queue weighting-constant
8.1.1 display qos packet-statistics interface
8.1.3 reset qos packet-statistics interface
description命令用来配置类的描述信息。
undo description命令用来恢复缺省情况。
未配置类的描述信息。
类视图
text:表示类的描述信息,为1~127个字符的字符串,区分大小写。
多次执行本命令,最后一次执行的命令生效。
# 为类class1配置描述信息。
[Sysname-classifier-class1] description classifier
display traffic classifier命令用来显示类的配置信息。
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定成员设备的流分类的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示主用设备的类的配置信息。
# 显示用户定义类的配置信息。
User-defined classifier information:
Classifier: 1 (ID 100)
Operator: AND
Rule(s) :
If-match acl 2000
Classifier: 2 (ID 101)
Operator: AND
Rule(s) :
If-match protocol ipv6
Classifier: 3 (ID 102)
Operator: AND
Rule(s) :
-none-
表1-1 display traffic classifier命令显示信息描述表
User-defined classifier information |
用户自定义类的信息 |
Classifier |
类的名称及其内容,内容可以有多种类型 |
Operator |
分类规则之间的逻辑关系 |
Rule(s) |
分类规则 |
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match match-criteria
undo if-match match-criteria
未定义匹配数据包的规则。
类视图
取值 |
acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } [ inner ] |
定义匹配ACL的规则 acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999,用户自定义ACL序号的取值范围是5000~5999 acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all inner用来指定ACL规则匹配VXLAN报文的内层内容,在VXLAN组网环境中,可以通过配置inner指定ACL规则匹配VXLAN报文内层字段。例如,IPv4高级ACL 3000中存在rule permit ip source 10.0.0.0 0.255.255.255这样的匹配规则: · 如果指定了inner,则ACL规则中的10.0.0.0/24表示的是VXLAN报文内层源IP · 如果未指定inner,则ACL规则中的10.0.0.0/24表示的是未封装报文的源IP或封装后报文外层源IP 如果if-match引用ACL时携带了inner,如需删除该配置,则执行undo if-match acl命令时必须携带inner |
any |
定义匹配所有数据包的规则 如需使用QoS策略对以太网服务实例出方向所有IPv6流量进行流量监管,流分类中的规则不可以配置为if-match any,而要配置为if-match protocol ipv6 |
control-plane protocol protocol-name&<1-8> |
定义匹配控制平面协议的规则,protocol-name&<1-8>为系统预定义匹配协议报文类型名称的列表,具体如表1-3所示,&<1-8>表示前面的参数最多可以输入8次 |
control-plane protocol-group protocol-group-name |
定义匹配控制平面协议组的规则,protocol-group-name取值为critical、important、management、monitor、normal、redirect |
customer-dot1p dot1p-value&<1-8> |
定义匹配内层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次 |
customer-vlan-id vlan-id-list |
定义匹配内层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次 Nest场景下,若报文只携带单层VLAN Tag,请用内层VLAN Tag VLAN ID规则来匹配 |
destination-mac mac-address |
定义匹配目的MAC地址的规则,仅对以太网接口生效 |
dscp dscp-value&<1-8> |
定义匹配DSCP的规则,dscp-value&<1-8>为DSCP取值的列表,DSCP的取值范围为0~63,&<1-8>表示前面的参数最多可以输入8次;也可以输入关键字,具体如表1-5所示 |
inbound-interface interface-type interface-number |
仅Release 6635及以上版本支持本参数 定义匹配入接口的规则,interface-type interface-number为接口类型和接口编号。入接口不支持配置为VLAN接口和VSI接口 在“and”模式的流分类中如果配置了本规则,然后将入接口所在接口卡拔出,会导致流分类失效,此时如果将接口卡恢复,则流分类会重新生效。但如果不恢复接口卡,请删除该流分类并按需重新配置。否则,即使再向该流分类中新增其他匹配规则,该流分类也不会生效 |
ip-precedence ip-precedence-value&<1-8> |
定义匹配IP优先级的规则,ip-precedence-value&<1-8>为IP优先级的列表,IP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次 |
outbound-interface interface-type interface-number |
定义匹配出接口的规则,interface-type interface-number为接口类型和接口编号 |
protocol protocol-name |
定义匹配协议的规则,protocol-name取值为ip、ipv6 如需使用QoS策略对以太网服务实例出方向所有IPv6流量进行流量监管,流分类中的规则不可以配置为if-match any,而要配置为if-match protocol ipv6 |
qos-local-id local-id-value |
定义匹配QoS本地ID值的规则,local-id-value为QoS本地ID,取值范围为1~4095 如果QoS策略流分类中配置了匹配QoS本地ID值: · 入方向应用QoS策略时,设备实际可以用的QoS本地ID值的取值为1~3999 · 出方向应用QoS策略时,设备实际可用的QoS本地ID值为1~511 在IRF组网中,如果通过QoS策略重标记成员设备收到报文的QoS本地ID值,则在另一成员设备的接口出方向上无法通过QoS本地ID值匹配该报文 在VXLAN组网中,如果通过QoS策略重标记VTEP设备或VXLAN IP网关收到报文的QoS本地ID值,则在对端VXLAN IP网关或VTEP设备的接口出方向上无法通过QoS本地ID值匹配该报文 |
rocev2 { opcode opcode-value | dst-qpair dst-qpair-value | src-qpair src-qpair-value | nack nack-value } * |
仅Release 6635及以上版本支持本参数 定义匹配RoCEv2报文的规则: · opcode opcode-value:匹配BTH头中的OpCode字段,其中opcode-value表示OpCode的值,取值范围为0~255 · dst-qpair dst-qpair-value:匹配BTH头中的Destination QP字段,其中dst-qpair-value表示Destination QP的值,取值范围为0~16777215 · src-qpair src-qpair-value:匹配DETH头中的Source QP字段,其中src-qpair-value表示Source QP的值,取值范围为0~16777215 · nack nack-value:匹配NACK报文中Syndrome字段的低5 bit,其中nack-value表示Syndrome字段的低5位的值,取值范围为0~31 |
service-dot1p dot1p-value&<1-8> |
定义匹配外层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次 |
service-vlan-id vlan-id-list |
定义匹配外层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次 通常情况下(Nest场景除外),若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID规则来匹配 |
source-mac mac-address |
定义匹配源MAC地址的规则,仅对以太网接口生效 |
traffic-type { unicast | unknown-unicast | broadcast | multicast } |
定义匹配不同类型流量的规则: · unicast:已知二层单播流量 · unknown-unicast:未知二层单播流量 · broadcast:广播流量 · multicast:已知二层组播流量 如果希望同一个类可以匹配多种不同类型的流量,例如,即匹配已知二层单播流量又匹配广播流量,则创建类时必须指定该类下的规则之间是逻辑或的关系 |
tunnel-id tunnel-id |
定义匹配指定隧道内的所有VXLAN报文,指定的隧道必须是VXLAN隧道,如果是其它隧道协议的隧道,则该流分类不生效 |
vxlan { any | vxlan-id } |
定义匹配VXLAN编号的规则 当设备作为VXLAN网络中VTEP之间的中间节点时,仅支持在入方向匹配报文的VXLAN编号 |
报文类型 |
arp |
ARP协议 |
arp-snooping |
ARP Snooping协议 |
bfd |
BFD协议 |
bgp |
BGP协议 |
bgp4+ |
IPv6 BGP |
dhcp |
DHCP协议 |
dhcp-snooping |
DHCP Snooping协议 |
dhcpv6 |
IPv6 DHCP协议 |
dldp |
DLDP协议 |
dot1x |
802.1p 协议 |
http |
HTTP协议 |
https |
HTTPS协议 |
hoplimit-expires |
ICMPv6超时报文 |
icmp |
ICMP协议 |
icmpv6 |
IPv6 ICMP协议 |
igmp |
IGMP协议 |
ip-option |
带选项字段的IPv4报文 |
ipv6-option |
带选项字段的IPv6报文 |
isis |
IS-IS协议 |
lacp |
LACP协议 |
lldp |
LLDP协议 |
mvrp |
MVRP协议(包含GVRP协议) |
nd |
ND协议 仅Release 6616及以上版本支持本参数 |
ospf-multicast |
OSPF组播 |
ospf-unicast |
OSPF单播 |
ospf3-multicast |
OSPFv3组播 |
ospf3-unicast |
OSPFv3单播 |
pim-multicast |
PIM组播 |
pim-unicast |
PIM单播 |
pim6-multicast |
IPv6 PIM组播 |
pim6-unicast |
IPv6 PIM单播 |
radius |
RADIUS协议 |
snmp |
SNMP协议 |
ssh |
SSH协议 |
stp |
STP协议 |
tacacs |
TACACS协议 |
telnet |
TELNET协议 |
ttl-expires |
TTL超时 |
vrrp |
VRRP协议 |
vrrp6 |
IPv6 VRRP协议 |
一个类下可配置多条匹配命令,各个配置之间互相不覆盖。
在接口出方向应用QoS策略时,如果流分类引用的二层ACL中包含匹配MAC地址的规则,则该规则无法匹配IPv6报文。
在定义匹配规则(控制平面、DSCP、VLAN ID、802.1p优先级、IP优先级)时,请注意:
· 一条命令可以配置多个规则,如果指定了多个相同的规则,系统默认为一个;一条命令中多个不同的规则是或的关系,即只要有一个值匹配,就算匹配这条规则。
· 删除某条匹配的规则时,必须与该规则中定义的完全相同才会删除,顺序可以不同。
在定义匹配ACL的规则时,类中引用的ACL必须已经存在。
在定义匹配VXLAN隧道报文内层内容的规则时,ACL中只能包含匹配报文源IP地址、目的IP地址、源端口号,目的端口号以及传输层协议类型的规则,不能包含匹配其它字段的规则。
在定义匹配RoCEv2报文字段的规则时,由于opcode字段的取值标识了不同的RoCEv2报服务类型,且仅部分类型的RoCEv2报文中包含src-qpair字段和nack字段,因此需要确保它们的配置对应关系合法:
· 如果同时指定opcode字段和src-qpair字段时,opcode字段取值必须指定为100或101(UD服务类型),否则无法匹配报文。
· 如果同时指定opcode字段和nack字段时,opcode字段取值必须指定为17(RC服务类型)或177(XRC服务类型),否则无法匹配报文。
当if-match中引用的ACL规则的动作为deny时,则直接忽略ACL规则的动作,以流行为中定义的动作为准,报文匹配只使用ACL中的分类域。
在定义匹配类的规则时,如果匹配类的规则之间既有逻辑与,又有逻辑或的关系,请使用以下方式配置。例如,需要定义classA,满足以下关系:规则1 & 规则2 | 规则3,可以这样定义:
· traffic classifier classB operator and
¡ if-match规则1
¡ if-match规则2
· traffic classifier classA operator or
¡ if-match规则3
如果流分类的匹配规则中包括customer-vlan-id,则使用该流分类的QoS策略只能应用在接口上。
一个流分类中匹配control-plane protocol或control-plane protocol-group的规则不能和其它匹配规则同时存在,否则使用该类的QoS策略将不能正常应用。
当流分类匹配control-plane protocol或control-plane protocol-group时,使用该流分类的QoS策略只能应用在控制平面上。
除service-vlan-id和customer-vlan-id外,对于其他匹配条件,只有通过重复执行多次匹配单一取值的if-match命令才能对同一匹配条件的多个值进行匹配。
对于在接口出方向应用的QoS策略,在定义匹配类的规则时,如果匹配类的规则中没有指定IPv6特征,则规则无法匹配IPv6报文。例如,通过if-match source-mac或引用二层ACL定义的流分类,无法匹配满足类中规则的IPv6报文。
# 定义类class1的匹配规则为:匹配内层报文特征符合ACL 3000的所有VXLAN报文。
[Sysname-classifier-class1] if-match acl 3000 inner
# 定义类class1的匹配规则为:匹配内层VLAN Tag的802.1p优先级为3。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1或6或9的报文。
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# 定义类class1的匹配规则为:匹配IP优先级值为1或6的报文。
[Sysname-classifier-class1] if-match ip-precedence 1 6
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的VLAN ID值为1或6或9的报文。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的VLAN ID值为2或7或10的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# 定义类class1匹配QoS本地ID值为3的报文。
[Sysname-classifier-class1] if-match qos-local-id 3
# 在流分类class1中配置匹配上送控制平面的ARP协议报文。
[Sysname-classifier-class1] if-match control-plane protocol arp
# 在流分类class1中配置匹配上送控制平面的normal协议组报文。
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# 在流分类class1中配置匹配组播类型的报文。
[Sysname-classifier-class1] if-match traffic-type multicast
# 在流分类class1中定义匹配隧道编号为2的VXLAN隧道中的所有VXLAN报文。
[Sysname-classifier-class1] if-match tunnel-id 2
# 定义类class1的匹配规则为:匹配VXLAN编号为10的报文。
[Sysname-classifier-class1] if-match vxlan 10
traffic classifier命令用来创建一个类,并进入类视图。如果指定的类已经存在,则直接进入类视图。
undo traffic classifier命令用来删除一个类。
未配置类。
operator:指定各规则之间的逻辑运算符。缺省情况为and。
# 定义一个名为class1的类。
· display traffic classifier
accounting命令用来配置流量统计动作。
undo accounting命令用来恢复缺省情况。
accounting [ byte | packet ] *
undo accounting
未配置流量统计动作。
流行为视图
byte:表示报文基于字节进行统计。
packet:表示报文基于包进行统计。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
如果未指定byte和packet,设备将以包为单位进行报文统计;如果同时指定了byte和packet,设备将以包和字节为单位进行报文统计。
# 为流行为配置流量统计动作,基于字节进行统计。
[Sysname-behavior-database] accounting byte
car命令用来配置流量监管动作。
undo car命令用来恢复缺省情况。
car cir [ pps ] committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir [ pps ] committed-information-rate [ cbs committed-burst-size ] pir [ pps ] peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
未配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。流量的平均速率,不指定pps关键字时单位为kbps,取值范围为8~4294967288且必须为8的整数倍,指定pps关键字时单位为pps,取值范围为1~160000000。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
· 如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于512的整数倍,但是最大值不能超过256000000。
· 如果指定cbs参数,取值范围512~256000000且必须为512的整数倍。
ebs excess-burst-size:超出突发尺寸,单位为byte。
· 配置pir参数后:
¡ 如果不指定ebs,则ebs缺省取值为与62.5 × peak-information-rate的乘积最接近且不小于512的整数倍,但是最大值不能超过256000000。
¡ 如果指定ebs,取值范围0~256000000且必须为512的整数倍。
· 未配置pir参数时,ebs的取值范围为0~256000000且必须为512的整数倍。
pir peak-information-rate:峰值速率,不指定pps关键字时单位为kbps,取值范围为8~4294967288且必须为8的整数倍,指定pps关键字时单位为pps,取值范围为1~160000000。配置时pir和cir速率单位必须保持一致。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass。
action:对数据包采取的动作,有以下几种:
· discard:丢弃数据包。
· pass:允许数据包通过。
· remark-dot1p-pass new-cos:设置新的802.1P报文的优先级值,并允许数据包通过,取值范围为0~7。
· remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63。
· remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
如果未配置峰值速率,则表示所配置的是单速率流量监管,否则表示双速率流量监管。
基于控制平面应用QoS策略配置流量监管时,cir的单位必须指定为pps。
# 为流行为配置流量监管。报文正常流速为200kbps,承诺突发尺寸为51200bytes,速率大于200kbps时,报文DSCP值改为0并发送。
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior命令用来显示流行为的配置信息。
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定成员设备的流行为的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的流行为的配置信息。
# 显示用户定义行为的配置信息。
User-defined behavior information:
Behavior: 1 (ID 100)
Marking:
Remark dscp 3
Committed Access Rate:
CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Behavior: 2 (ID 101)
Accounting enable: Packet
Filter enable: Permit
Redirecting:
Redirect to the CPU
Behavior: 3 (ID 102)
-none-
表1-4 display traffic behavior命令显示信息描述表
User-defined behavior information |
用户自定义流行为的信息 |
Behavior |
行为的名称及其内容,内容可以有多种类型 |
Marking |
标记相关信息 |
Remark dscp |
重新标记报文的DSCP优先级值 |
Committed Access Rate |
流量限速的相关信息 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,单位为byte |
EBS |
超出突发尺寸,单位为byte |
Green action |
对绿色报文的动作 |
Red action |
对红色报文的动作 |
Yellow action |
对黄色报文的动作 |
Accounting enable |
流量统计动作 |
Filter enable |
流量过滤动作 |
Redirecting |
流量重定向相关信息 |
Mirroring |
流量镜像相关信息 |
none |
表示未配置其他流行为 |
filter命令用来配置流量过滤动作。
undo filter命令用来恢复缺省情况。
filter { deny | none | permit }
undo filter
未配置流量过滤动作。
流行为视图
deny:丢弃命中规则的数据包。
none:允许命中规则的数据包通过,且此类数据包不会再被本QoS策略中的其他流分类处理。
permit:允许命中规则的数据包通过,如果本QoS策略中还有其他流分类,则这类数据包可以被继续处理。
# 为流行为database配置丢弃数据包的过滤动作。
mac-address mac-learning enable命令用来开启流行为的MAC地址学习功能。
undo mac-address mac-learning enable命令用来关闭流行为的MAC地址学习功能。
流行为的MAC地址学习功能处于开启状态。
流行为视图
有时为了保证设备的安全,需要关闭MAC地址学习功能。常见的危及设备安全的情况是:非法用户使用大量源MAC地址不同的报文攻击设备,导致设备MAC地址表资源耗尽,造成设备无法根据网络的变化更新MAC地址表。关闭MAC地址学习功能可以有效防止这种攻击。
仅基于接口入方向和全局入方向应用QoS策略时,QoS策略中配置的关闭MAC地址学习功能才会生效。关闭MAC地址学习功能后,需要注意:
· 对于匹配QoS策略的流,设备不能学习新的MAC地址,从而影响设备及时刷新MAC地址表。
· 如果MAC地址表中无对应表项,则会导致广播泛洪。因此,在关闭该功能的同时,应用QoS策略的接口一般还要配置接口广播风暴抑制功能。有关广播风暴抑制功能的介绍,请参见“二层技术-以太网交换配置指导”中的“以太网接口”。
· 对于接口上已存在的MAC地址表项,必须手动删除该表项或等MAC地址老化时间后设备自动删除,否则,设备不会立即删除已学习到的MAC地址表项。
# 关闭流行为的MAC地址学习功能。
[Sysname-behavior-data] undo mac-address mac-learning enable
nest top-most命令用来配置添加报文的外层VLAN Tag动作。
undo nest top-most命令用来恢复缺省情况。
nest top-most vlan vlan-id
undo nest top-most
未配置添加报文外层VLAN Tag动作。
流行为视图
vlan vlan-id:添加的VLAN ID,取值范围为1~4094。
引用了添加VLAN Tag动作的QoS策略只能应用到接口的入方向上。
仅基于接口入方向、VLAN入方向和全局入方向应用QoS策略时,QoS策略中配置的Nest才会生效。
本命令对Overlay网络转发的报文不生效。
# 在流行为b1上配置如下动作:添加VLAN ID为123的外层VLAN Tag。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来恢复缺省情况。
redirect { cpu | interface interface-type interface-number | tunnel-group group-id }
undo redirect { cpu | interface interface-type interface-number | tunnel-group }
未配置流量重定向动作。
流行为视图
cpu:重定向到CPU。
interface:重定向到指定的接口。
tunnel-group group-id:重定向到隧道组,group-id表示隧道组的编号,取值范围为1~32。有关隧道组的详细介绍,请参见“三层技术-IP业务命令参考”中的“隧道”。仅Release 6635及以上版本支持本参数。
仅基于以太网服务实例入方向、接口入方向、VLAN入方向、全局入方向和上线用户入方向应用QoS策略时,QoS策略中配置的流量重定向才会生效。
配置流量重定向到接口仅对二层转发报文生效。
配置重定向到指定接口时,必须保证:
· 报文入接口的VLAN ID与指定接口的缺省VLAN ID相同;
· 报文入接口的VLAN ID在指定接口允许通过的VLAN ID列表中;
否则报文到达重定向到指定接口后会被丢弃。
# 为流行为配置流量重定向动作,重定向到接口HundredGigE1/0/1。
[Sysname-behavior-database] redirect interface hundredgige 1/0/1
# 为流行为aa配置流量重定向到隧道组1。
[Sysname] traffic behavior aa
[Sysname-behavior-aa] redirect tunnel-group 1
· classifier behavior
· group(三层技术-IP业务/隧道)
· qos policy
· traffic behavior
remark customer-vlan-id命令用来重新标记报文的CVLAN。
undo remark customer-vlan-id命令用来恢复缺省情况。
未配置重新标记报文CVLAN的动作。
流行为视图
vlan-id:表示重新标记报文内层VLAN(CVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重新标记报文的CVLAN为VLAN 111。
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p命令用来配置重新标记报文的802.1p优先级或内外层标签802.1p优先级复制动作。
undo remark dot1p命令用来恢复缺省情况。
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
未配置重新标记报文802.1p优先级以及内外层标签802.1p优先级复制动作。
流行为视图
green:对绿色报文进行重新标记。
red:对红色报文进行重新标记。
yellow:对黄色报文进行重新标记。
dot1p-value:802.1p优先级,取值范围为0~7。
customer-dot1p-trust:将内层VLAN tag的802.1p优先级复制为外层VLAN tag的802.1p优先级。
命令remark dot1p dot1p-value和remark dot1p customer-dot1p-trust是覆盖关系。
对于只携带一层VLAN tag的报文,配置的remark dot1p customer-dot1p-trust不会生效。
在同一个流行为中,如果多次对同一种颜色的报文重新标记802.1p优先级,则最后一次执行的命令生效。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
# 配置内外层标签优先级复制功能。
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark drop-precedence命令用来重新标记报文的丢弃优先级。
undo remark drop-precedence命令用来恢复缺省情况。
remark drop-precedence drop-precedence-value
未配置重新标记报文丢弃优先级的动作。
流行为视图
drop-precedence-value:丢弃优先级,取值范围为0~2。
仅基于入方向应用QoS策略时,QoS策略中配置的重新标记报文的丢弃优先级才会生效。
# 重新标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来恢复缺省情况。
undo remark [ green | red | yellow ] dscp
未配置重新标记报文DSCP值的动作。
流行为视图
green:对绿色报文进行重新标记。
red:对红色报文进行重新标记。
yellow:对黄色报文进行重新标记。
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
表1-5 DSCP关键字与值的对应表
关键字 |
DSCP值(二进制) |
DSCP值(十进制) |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
# 重新标记报文的DSCP值为6。
remark ip-precedence命令用来重新标记报文的IP优先级。
undo remark ip-precedence命令用来恢复缺省情况。
remark ip-precedence ip-precedence-value
未配置重新标记报文IP优先级的动作。
流行为视图
ip-precedence-value:IP优先级,取值范围为0~7。
# 重新标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来恢复缺省情况。
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
未配置重新标记报文本地优先级的动作。
流行为视图
green:对绿色报文进行重新标记。
red:对红色报文进行重新标记。
yellow:对黄色报文进行重新标记。
local-precedence-value:本地优先级,取值范围为0~7。
仅基于入方向应用QoS策略时,QoS策略中配置的重新标记报文的本地优先级才会生效。
# 重新标记报文的本地优先级值为2。
remark qos-local-id命令用来重新标记报文的QoS本地ID值。
undo remark qos-local-id命令用来恢复缺省情况。
remark qos-local-id [ egress-active ] local-id-value
未配置重新标记报文的QoS本地ID值的动作。
流行为视图
egress-active:QoS本地ID值仅在出方向生效。如果未指定本参数,则QoS本地ID值仅在入方向生效。
local-id-value:QoS本地ID值,取值范围为1~4095。如果指定egress-active参数,则取值范围为1~128。
在入方向应用QoS策略对报文的QoS本地ID值进行标记,此QoS本地ID值仅在入方向生效,如果希望其仅在出方向生效,则在标记时必须指定egress-active关键字。
仅基于接口入方向、VLAN入方向和全局入方向应用QoS策略时,QoS策略中配置的重新标记报文的QoS本地ID值才会生效。
在VXLAN组网中,如果通过QoS策略重标记VTEP设备或VXLAN IP网关收到报文的QoS本地ID值,则在对端VXLAN IP网关或VTEP设备的接口出方向上无法通过QoS本地ID值匹配该报文。
# 重新标记报文的QoS本地ID值为2。
[Sysname-behavior-database] remark qos-local-id 2
remark service-vlan-id命令用来重新标记报文的SVLAN。
undo remark service-vlan-id命令用来恢复缺省情况。
未配置重新标记报文的SVLAN的动作。
流行为视图
vlan-id:表示重新标记报文外层VLAN(SVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重新标记报文的SVLAN为VLAN 222。
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior命令用来创建一个流行为,并进入流行为视图。如果指定的流行为已经存在,则直接进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
不存在流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
# 定义一个名为behavior1的流行为。
[Sysname-behavior-behavior1]
· display traffic behavior
classifier behavior命令用来为类指定流行为。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [ mode { dcbx | loose | qppb-manipulation } | insert-before before-classifier-name ] *
没有为类指定流行为。
QoS策略视图
mode dcbx:表示该流分类与流行为的关联模式为DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议)模式。有关DCBX的介绍,请参见“二层技术-以太网交换配置指导”中的“LLDP”。
mode loose:表示该流分类与流行为的关联模式为宽松模式。仅基于控制平面应用QoS策略时,本模式才会生效。仅Release 6635及以上版本支持本参数。
mode qppb-manipulation:设置流分类和流行为对应关系用于匹配BGP路由策略中apply qos-local-id的信息。即类中if-match qos-local-id匹配的内容对应路由策略命令中apply qos-local-id命令设置的信息,具体内容请参见“三层技术-IP路由配置指导”中的“路由策略”。
insert-before before-classifier-name:表示将配置的类插入到QoS策略中已存在的指定类之前。before-classifier-name表示QoS策略中已存在的类名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示新配置的类与流行为配对将添加到QoS策略最后。
QoS策略下每个类只能与一个流行为关联。
如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
使用宽松模式(mode loose)可以对特定接口进入并上送控制平面的特定协议报文进行限速,具体配置方法为:
(1) 创建ACL,并定义匹配特定协议报文的rule规则。
(2) 创建and模式的流分类,配置if-match acl和if-match inbound-interface。
(3) 创建流行为并配置动作。
(4) 创建QoS策略,并在为类关联流行为时指定mode loose。
(5) 将QoS策略应用在控制平面上。
其他接口进入的该类型协议报文,上送控制平面时依然受到原有控制平面协议报文限速功能的限制。
# 在QoS策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
# 在QoS策略user1中为类database指定流行为test,并将该类插入到策略中已存在的类class-a前。
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
· qos policy
control-plane命令用来进入控制平面视图。
slot slot-number:指定成员设备。slot-number表示设备在IRF中的成员编号。
# 进入指定slot上的控制平面视图。
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
display qos policy命令用来显示QoS策略的配置信息。
display qos policy user-defined [ ipv6-matching | { accounting | mirroring | remarking } ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
user-defined:用户定义QoS策略。
ipv6-matching:显示IPv6 Matching类型的QoS策略。
accounting:显示统计类型的QoS策略。
mirroring:显示镜像类型的QoS策略。
remarking:显示重标记类型的QoS策略。
policy-name:QoS策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:QoS策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定成员设备的QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的QoS策略的配置信息。
如果未指定ipv6-matching、accounting、mirroring和remarking,则显示用户定义的通用类型QoS策略的配置信息。
# 显示用户定义的通用类型QoS策略的配置信息。
User-defined QoS policy information:
Policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
Green action : pass
Behavior: 2
Marking:
Remark dot1p 4
Behavior: 3
-none-
# 显示用户定义的统计类型QoS策略的配置信息。
<Sysname> display qos policy user-defined accounting
Accounting policy: 1 (ID 100)
Behavior: 1
# 显示用户定义的镜像类型QoS策略的配置信息。
<Sysname> display qos policy user-defined mirroring
Mirroring policy: 1 (ID 100)
Behavior: 1
Mirroring:
Mirror to the CPU
# 显示用户定义的重标记类型QoS策略的配置信息。
<Sysname> display qos policy user-defined remarking
Marking policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
表1-6 display qos policy命令显示信息描述表
User-defined QoS policy information |
用户自定义QoS策略的信息 |
IPv6 Matching policy |
用户定义的IPv6类型的QoS策略名 |
Accounting policy |
用户定义的统计类型的QoS策略名 |
Mirroring policy |
用户定义的镜像类型的QoS策略名 |
Marking policy |
用户定义的重标记类型的QoS策略名 |
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
slot slot-number:显示指定成员设备的控制平面应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。
# 显示应用到slot 1控制平面的QoS策略信息。
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Yellow packets: 0 (Packets) 0 (Bytes)
Red packets : 0 (Packets) 0 (Bytes)
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
表1-7 display qos policy control-plane命令显示信息描述表
Direction |
QoS策略应用的方向 |
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
slot slot-number:显示指定成员设备的系统预定义的控制平面策略信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示所有成员设备的系统预定义的控制平面应用QoS策略的信息。
# 显示指定slot上的系统预定义的控制平面应用QoS策略的信息。
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
Protocol Priority Bandwidth Group
Default N/A 1000 (pps) N/A
IS-IS 18 1000 (pps) critical
VRRP 19 1000 (pps) important
OSPF Multicast 18 1000 (pps) critical
OSPF Unicast 18 1000 (pps) critical
PIM Multicast 12 500 (pps) critical
PIM Unicast 12 500 (pps) critical
IGMP 11 500 (pps) important
PIMv6 Multicast 12 300 (pps) critical
PIMv6 Unicast 12 300 (pps) critical
OSPFv3 Unicast 18 1000 (pps) critical
OSPFv3 Multicast 18 1000 (pps) critical
VRRPv6 19 1000 (pps) important
ARP 2 1000 (pps) normal
DHCP Snooping 10 300 (pps) redirect
DHCP 10 300 (pps) normal
802.1x 3 500 (pps) important
STP 17 300 (pps) critical
LACP 22 300 (pps) critical
MVRP 15 300 (pps) critical
BGP 16 1000 (pps) critical
ICMP 3 500 (pps) monitor
TTL Expires 5 300 (pps) monitor
IPOPTION 5 300 (pps) normal
BGPv6 16 1000 (pps) critical
ND 2 3000 (pps) critical
Hop Limit Expires 5 300 (pps) monitor
IPOPTIONv6 5 300 (pps) normal
LLDP 14 300 (pps) important
DLDP 16 300 (pps) critical
TELNET 1 800 (pps) management
SSH 1 800 (pps) management
TACACS 1 800 (pps) management
RADIUS 1 800 (pps) management
HTTP 3 500 (pps) management
HTTPS 3 500 (pps) management
SNMP 4 800 (pps) management
ARP Snooping 2 1000 (pps) redirect
ICMPv6 3 300 (pps) monitor
DHCPv6 10 300 (pps) normal
BFD 21 1000 (pps) critical
表1-8 display qos policy control-plane pre-defined命令显示信息描述表
Pre-defined control plane policy |
预定义控制平面策略内容 |
Protocol |
系统预定义协议报文类型 |
Default |
其他协议 |
Priority |
优先级 |
Bandwidth |
带宽 |
Group |
协议所属的协议组 |
其它显示信息解释请参见表1-3。
display qos policy diagnosis control-plane命令用来显示控制平面应用QoS策略的诊断信息。
display qos policy diagnosis control-plane slot slot-number
slot slot-number:显示指定成员设备的控制平面应用QoS策略的诊断信息,slot-number表示设备在IRF中的成员编号。
# 显示应用到指定slot上的控制平面的QoS策略的诊断信息。
<Sysname> display qos policy diagnosis control-plane slot 2
Control plane slot 2
Direction: Inbound
Policy: 1
Classifier: 1 (Incomplete)
Operator: AND
Rule(s) :
If-match acl 2000 (Incomplete)
Failed Rule ID: 0, 3, 5, 50
Behavior: 1
Marking:
Remark dscp 3
CIR 112 (kbps), CBS 7000 (Bytes), EBS 512 (Bytes)
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
If-match not protocol ipv6
Behavior: 2
Accounting enable:
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
表1-9 display qos policy diagnosis control-plane命令显示信息描述表
Direction |
QoS策略应用的方向 |
Classifier: 1 (Incomplete) |
流分类的下发状态: · Incomplete:表示部分内容下发成功 · Failed:表示所有内容下发失败 |
If-match acl 2000 (Incomplete) |
匹配规则的下发状态: · Incomplete:表示部分内容下发成功 · Failed:表示所有内容下发失败 |
Failed rule ID |
下发失败的ACL规则索引列表 |
display qos policy diagnosis global命令用来显示基于全局应用QoS策略的诊断信息。
display qos [ ipv6-matching | { accounting | mirroring | remarking } ] policy diagnosis global [ slot slot-number ] [ inbound | outbound ]
ipv6-matching:显示IPv6 Matching类型QoS策略的诊断信息。
accounting:显示统计类型QoS策略的诊断信息。
mirroring:显示镜像类型QoS策略的诊断信息。
remarking:显示重标记类型QoS策略的诊断信息。
inbound:显示入方向QoS策略的诊断信息。
outbound:显示出方向QoS策略的诊断信息。
slot slot-number:显示指定成员设备的基于全局应用QoS策略的诊断信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于全局应用QoS策略的诊断信息,不显示各成员设备的信息。
如果未指定ipv6-matching、accounting、mirroring或remarking,则显示通用类型QoS策略的诊断信息。
如果未指定显示方向,则同时显示出入两个方向QoS策略的诊断信息。
# 显示基于全局应用通用类型QoS策略的诊断信息。
<Sysname> display qos policy diagnosis global
Direction: Inbound
Policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# 显示基于全局应用统计类型QoS策略的诊断信息。
<Sysname> display qos accounting policy diagnosis global
Direction: Inbound
Classifier: 1
Operator: AND
Rule(s) :
If-match protocol ipv4
Behavior: 1
# 显示基于全局应用镜像类型QoS策略的诊断信息。
<Sysname> display qos mirroring policy diagnosis global
Direction: Inbound
Mirroring policy: 1
Classifier: 1
Operator: AND
Rule(s) :
Behavior: 1
Mirroring:
Mirror to the CPU
# 显示基于全局应用重标记类型QoS策略的诊断信息。
<Sysname> display qos remarking policy diagnosis global
Direction: Inbound
Marking policy: 1
Classifier: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
表1-10 display qos policy diagnosis global命令显示信息描述表
Direction |
QoS策略应用的方向 |
Policy |
用户定义的通用类型的QoS策略名或系统预定义的QoS策略名 |
用户定义的IPv6 Matching类型的QoS策略名 |
Accounting policy |
用户定义的统计类型的QoS策略名 |
Mirroring policy |
用户定义的镜像类型的QoS策略名 |
Marking policy |
用户定义的重标记类型的QoS策略名 |
Failed rule ID |
下发失败的ACL规则索引列表 |
display qos policy diagnosis interface命令用来显示接口上QoS策略的诊断信息。
display qos [ ipv6-matching | { accounting | mirroring | remarking } ] policy diagnosis interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的诊断信息。
slot slot-number:显示指定成员设备指定逻辑接口的QoS策略的诊断信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于逻辑接口应用QoS策略的诊断信息。
如果未指定ipv6-matching、accounting、mirroring或remarking,则显示通用类型QoS策略的配置信息。
# 显示接口HundredGigE1/0/1上通用类型QoS策略的诊断信息。
<Sysname> display qos policy diagnosis interface hundredgige 1/0/1 inbound
Interface: HundredGigE1/0/1
Direction: Inbound
Policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# 显示接口HundredGigE1/0/1上统计类型QoS统计策略的诊断信息。
<Sysname> display qos accounting policy diagnosis interface hundredgige 1/0/1 inbound
Direction: Inbound
Operator: AND
Rule(s) :
Behavior: 1
# 显示接口HundredGigE1/0/1上镜像类型QoS统计策略的诊断信息。
<Sysname> display qos mirroring policy diagnosis interface hundredgige 1/0/1 inbound
Direction: Inbound
Mirroring policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Mirroring:
Mirror to the CPU
# 显示接口HundredGigE1/0/1上重标记类型QoS重标记策略的诊断信息。
<Sysname> display qos remarking policy diagnosis interface hundredgige 1/0/1 inbound
Direction: Inbound
Marking policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
表1-11 display qos policy diagnosis interface命令显示信息描述表
Direction |
QoS策略应用的方向 |
Accounting policy |
用户定义的统计类型的QoS策略名 |
Mirroring policy |
用户定义的镜像类型的QoS策略名 |
Marking policy |
用户定义的重标记类型的QoS策略名 |
Failed rule ID |
下发失败的ACL规则索引列表 |
display qos policy diagnosis l2vpn-ac命令用来显示L2VPN AC上QoS策略的诊断信息。
display qos policy diagnosis l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound | outbound ]
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口下以太网服务实例上QoS策略的诊断信息。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将显示接口下所有以太网服务实例上QoS策略的诊断信息。
slot slot-number:显示指定成员设备指定二层聚合接口下以太网服务实例的QoS策略的诊断信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上二层聚合接口下以太网服务实例的QoS策略的诊断信息。
仅Release 6616及以上版本支持outbound参数。
# 显示对接口HundredGigE1/0/1下以太网服务实例1接收到的报文应用QoS策略的诊断信息。
<Sysname> display qos policy diagnosis interface hundredgige 1/0/1 service-instance 1 inbound
Interface: HundredGigE1/0/1 Service instance ID: 1
Direction: Inbound
Policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
表1-12 display qos policy diagnosis l2vpn-ac命令显示信息描述表
Direction |
QoS策略应用的方向 |
Failed rule ID |
下发失败的ACL规则索引列表 |
display qos policy diagnosis user-profile命令用来显示用户上线后User Profile下应用的QoS策略的诊断信息。
display qos policy diagnosis user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
name profile-name:指定User Profile的名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线,且必须以英文字母开始,区分大小写。User Profile的名称必须全局唯一。如果未指定本参数,将显示所有User Profile下应用的QoS策略的诊断信息。
user-id user-id:表示在线用户的ID,为系统所分配,取值范围为十六进制数0~fffffffe。若未指定本参数,则显示所有用户在User Profile下应用的QoS策略的诊断信息。
slot slot-number:显示指定成员设备上指定用户在User Profile下应用的QoS策略的诊断信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的在线用户上指定用户在User Profile下应用的QoS策略的诊断信息。
# 显示指定全局用户(从聚合口等全局口上线的用户)在User Profile下应用QoS策略的诊断信息。
<Sysname> display qos policy user-profile name abc user-id 30000000 inbound
User-Profile: abc
User ID: 0x30000000(global)
Direction: Inbound
Policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
表1-13 display qos policy diagnosis user-profile命令显示信息描述表
Direction |
QoS策略应用的方向 |
Failed rule ID |
下发失败的ACL规则索引列表 |
display qos policy global命令用来显示基于全局应用QoS策略的配置信息和运行情况。
display qos [ ipv6-matching | { accounting | mirroring | remarking } ] policy global [ slot slot-number ] [ inbound | outbound ]
ipv6-matching:显示IPv6 Matching类型QoS策略的配置信息和运行情况。
accounting:显示统计类型QoS策略的配置信息和运行情况。
mirroring:显示镜像类型QoS策略的配置信息和运行情况。
remarking:显示重标记类型QoS策略的配置信息和运行情况。
inbound:显示入方向QoS策略的配置信息和运行情况。
outbound:显示出方向QoS策略的配置信息和运行情况。
slot slot-number:显示指定成员设备的基于全局应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于全局应用QoS策略的信息。
如果未指定ipv6-matching、accounting、mirroring或remarking,则显示通用类型QoS策略的配置信息和运行情况。
如果未指定显示方向,则同时显示出入两个方向QoS策略的配置信息和运行情况。
# 显示基于全局应用通用类型QoS策略的信息。
<Sysname> display qos policy global
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# 显示基于全局应用统计类型QoS策略的信息。
<Sysname> display qos accounting policy global
Direction: Inbound
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
# 显示基于全局应用镜像类型QoS策略的信息。
<Sysname> display qos mirroring policy global
Direction: Inbound
Mirroring policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Mirroring:
Mirror to the CPU
# 显示基于全局应用重标记类型QoS策略的信息。
<Sysname> display qos remarking policy global
Direction: Inbound
Marking policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
# 显示基于全局应用IPv6 Matching类型QoS策略的信息。
<Sysname> display qos ipv6-matching policy global
Direction: Inbound
IPv6 Matching policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl ipv6 3000
Behavior: 1
Marking:
Remark dscp 3
表1-14 display qos policy global命令显示信息描述表
Direction |
QoS策略应用的方向 |
Policy |
Accounting policy |
用户定义的统计类型的QoS策略名 |
Mirroring policy |
用户定义的镜像类型的QoS策略名 |
Marking policy |
用户定义的重标记类型的QoS策略名 |
Green packets |
绿色报文的流量统计 |
Yellow packets |
黄色报文的流量统计 |
Red packets |
红色报文的流量统计 |
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
display qos [ ipv6-matching | { accounting | mirroring | remarking } ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的配置信息和运行情况。
slot slot-number:显示指定成员设备指定逻辑接口的QoS策略的配置信息和运行情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备逻辑接口QoS策略的配置信息和运行情况。
# 显示对接口HundredGigE1/0/1接收到的报文应用通用类型QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface hundredgige 1/0/1 inbound
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# 显示对接口HundredGigE1/0/1接收到的报文应用统计类型QoS策略的配置信息和运行情况。
<Sysname> display qos accounting policy interface hundredgige 1/0/1 inbound
Direction: Inbound
Accounting Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Accounting enable:
0 (Packets)
# 显示对接口HundredGigE1/0/1接收到的报文应用重标记类型QoS策略的配置信息和运行情况。
<Sysname> display qos remarking policy interface hundredgige 1/0/1 inbound
Direction: Inbound
Marking policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
# 显示对接口HundredGigE1/0/1接收到的报文应用镜像类型QoS策略的配置信息和运行情况。
<Sysname> display qos mirroring policy interface hundredgige 1/0/1 inbound
Direction: Inbound
Mirroring policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Mirroring:
Mirror to the CPU
# 显示所有接口上通用类型QoS策略的配置信息和运行情况。
Direction: Inbound
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: HundredGigE1/0/2
CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Green action : pass
Interface: HundredGigE1/0/3
Direction: Inbound
Policy: b
Classifier: b
Operator: AND
Rule(s) :
If-match any
Behavior: b
Green action : pass
Green packets : 0(Packets)
Interface: HundredGigE1/0/4
Direction: Inbound
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: HundredGigE1/0/5
Green action : pass
表1-15 display qos policy interface命令显示信息描述表
Direction |
QoS策略应用的方向 |
IPv6类型的QoS策略名 |
Accounting policy |
统计类型的QoS策略名 |
Mirorring policy |
镜像类型的QoS策略名 |
Marking policy |
重标记类型的QoS策略名 |
Mode |
QoS和ACL资源的共享模式,当应用QoS策略时携带了share-mode关键字,显示信息中才会出现该字段 |
Matched |
符合分类规则的数据包数目 |
5-minute statistics |
最近5分钟的流速统计信息 |
Forwarded |
符合分类规则的成功转发报文在统计周期内的平均速率 |
Dropped |
符合分类规则的丢弃报文在统计周期内的平均速率 |
Green packets |
绿色报文的流量统计 |
Yellow packets |
黄色报文的流量统计 |
Red packets |
红色报文的流量统计 |
display qos policy l2vpn-ac命令用来显示L2VPN AC承载的以太网服务实例上QoS策略的配置信息和运行情况。
display qos [ ipv6-matching | { accounting | mirroring | remarking } ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound | outbound ]
ipv6-matching:指定IPv6 Matching类型的QoS策略。
accounting:指定统计类型的QoS策略。
mirroring:指定镜像类型的QoS策略。
remarking:指定重标记类型的QoS策略。
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口下以太网服务实例上QoS策略的配置信息和运行情况。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将显示接口下所有以太网服务实例上QoS策略的配置信息和运行情况。
slot slot-number:显示指定成员设备指定二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。
仅Release 6635及以上版本支持ipv6-matching、accounting、mirroring和remarking参数。
如果未指定ipv6-matching、accounting、mirroring和remarking,则显示通用类型QoS策略的配置信息和运行情况。
# 显示对接口HundredGigE1/0/1下以太网服务实例1接收到的报文应用通用类型QoS策略的配置信息和运行情况。
<Sysname> display qos policy l2vpn-ac interface hundredgige 1/0/1 service-instance 1 inbound
Direction: Inbound
Policy: p
Classifier: c
Operator: AND
Rule(s) :
If-match any
Behavior: b
CIR 88 (kbps), CBS 5632 (Bytes), EBS 0 (Bytes)
Green action : pass
表1-16 display qos policy l2vpn-ac命令显示信息描述表
Service instance ID |
以太网服务实例ID |
Direction |
QoS策略应用的方向 |
Policy |
通用类型QoS策略名 |
Accounting policy |
统计类型QoS策略名 |
Mirroring policy |
镜像类型QoS策略名 |
Marking policy |
重标记类型QoS策略名 |
Green action |
对绿色报文的动作 |
Yellow action |
对黄色报文的动作 |
Red action |
对红色报文的动作 |
Green packets |
绿色报文的流量统计 |
Yellow packets |
黄色报文的流量统计 |
Red packets |
红色报文的流量统计 |
display qos policy user-profile命令用来显示用户上线后User Profile下应用的QoS策略的信息和运行情况。
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
name profile-name:指定User Profile的名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线,且必须以英文字母开始,区分大小写。User Profile的名称必须全局唯一。如果未指定本参数,将显示所有User Profile下应用的QoS策略的信息和运行情况。
user-id user-id:表示在线用户的ID,为系统所分配,取值范围为十六进制数0~fffffffe。若未指定本参数,则显示所有用户在User Profile下应用的QoS策略的信息和运行情况。
slot slot-number:显示指定成员设备上指定用户在User Profile下应用的QoS策略的信息和运行情况,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的在线用户上指定用户在User Profile下应用的QoS策略的信息和运行情况。
# 显示指定全局用户(从聚合口等全局口上线的用户)在User Profile下应用QoS策略的配置信息和运行情况。
User-Profile: abc
Direction: Inbound
Policy: p1
Classifier: default-class
Matched : 0 (Packets) 0 (Bytes)
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
# 显示指定的非全局用户在User Profile下应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy user-profile name abc user-id 30000001 inbound
User-Profile: abc
slot 2:
User ID: 0x30000001(local)
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
表1-17 display qos policy user-profile命令显示信息描述表
User-Profile |
User Profile名称 |
User ID |
上线用户的ID |
global |
该用户从聚合口等全局口上线 |
local |
该用户从物理口上线 |
Mirror to the interface |
镜像到接口 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为byte |
EBS |
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位为byte |
PIR |
峰值信息速率 |
Direction |
QoS策略应用的方向 |
Matched |
符合分类规则的数据包数目 |
Green packets |
绿色报文的流量统计 |
Yellow packets |
黄色报文的流量统计 |
Red packets |
红色报文的流量统计 |
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的配置信息和运行情况。
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称,为1~31个字符的字符串,区分大小写。
vlan vlan-id:显示指定VLAN上应用QoS策略的信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
slot slot-number:显示指定成员设备上基于VLAN应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于VLAN应用QoS策略的信息。
如果未指定显示方向,则同时显示出入两个方QoS策略的配置信息和运行情况。
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
Direction: inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Green packets : 0(Packets) 0(Bytes)
Yellow packets: 0(Packets) 0(Bytes)
Red packets : 0(Packets) 0(Bytes)
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
表1-18 display qos vlan-policy命令显示信息描述表
Direction |
QoS策略应用的方向 |
Green packets |
绿色报文的流量统计 |
Yellow packets |
黄色报文的流量统计 |
Red packets |
红色报文的流量统计 |
display qos vlan-policy diagnosis命令用来显示基于VLAN应用QoS策略的诊断信息。
display qos vlan-policy diagnosis { name policy-name | vlan [ vlan-id ] } [ slot slot-number ] [ inbound | outbound ]
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的诊断信息。policy-name表示策略名称,为1~31个字符的字符串,区分大小写。
vlan vlan-id:显示指定VLAN上应用QoS策略的诊断信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
slot slot-number:显示指定成员设备上基于VLAN应用QoS策略的诊断信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于VLAN应用QoS策略的诊断信息。
如果未指定方向,则同时显示出入两个方向QoS策略的诊断信息。
# 显示基于VLAN 2应用QoS策略的诊断信息。
<Sysname> display qos vlan-policy diagnosis vlan 2
Vlan 2
Direction: Outbound
Type : Extension
Policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
表1-19 display qos vlan-policy diagnosis命令显示信息描述表
Direction |
QoS策略应用的方向 |
Failed rule ID |
下发失败的ACL规则索引列表 |
qos apply policy命令用来在以太网服务实例、接口或控制平面上应用QoS策略。
undo qos apply policy命令用来取消以太网服务实例、接口或控制平面上应用的QoS策略。
qos apply [ ipv6-matching | { accounting | mirroring | remarking } ] policy policy-name { inbound | outbound } [ share-mode ]
undo qos apply [ ipv6-matching | { accounting | mirroring | remarking } ] policy policy-name { inbound | outbound }
未应用QoS策略。
控制平面视图
以太网服务实例视图
ipv6-matching:指定IPv6 Matching类型的QoS策略。仅支持基于接口和以太网服务实例应用IPv6类型的QoS策略。
accounting:指定统计类型的QoS策略。仅支持基于接口和以太网服务实例应用统计类型的QoS策略。
mirroring:指定镜像类型的QoS策略。仅支持基于接口和以太网服务实例应用镜像类型的QoS策略。
remarking:指定重标记类型的QoS策略。仅支持基于接口和以太网服务实例应用重标记类型的QoS策略。
policy-name:策略名,为1~31个字符的字符串,区分大小写。
inbound:入方向应用QoS策略。
outbound:出方向应用QoS策略。设备不支持在控制平面出方向应用QoS策略。
仅Release 6616及以上版本支持在以太网服务实例出方向应用QoS策略。
share-mode:对二层以太网接口和三层以太网接口应用ACL配置共享QoS和ACL资源模式的报文过滤。该模式下,同一设备接口出方向所有应用了相同QoS策略的接口共享一份QoS和ACL资源。缺省情况下,同一设备接口入方向应用ACL配置报文过滤时会采用共享QoS和ACL资源模式,不用指定share-mode关键字。
二层以太网接口和三层以太网接口在出方向应用共享QoS和ACL资源模式的QoS策略时:
· 设备最多支持7份共享的QoS和ACL资源。
· QoS策略的流行为中不支持配置car和accounting。
QoS策略应用后不能动态修改QoS和ACL的资源共享模式,如需修改,请先取消该接口应用的QoS策略,然后在配置接口应用QoS策略时选择携带或不携带share-mode关键字。
基于接口应用QoS策略时,在相同方向最多可以应用五个不同类型的策略,即每个类型的QoS策略各一个。接口同时应用不同类型的QoS策略后,可以对接口收到的同一份流量分别执行不同的流行为动作。
在以太网服务实例上应用QoS策略时,如果对应物理口的状态为down,则应用策略时会提示应用失败。此时,一旦物理口状态变为up,策略会自动生效,无需再次应用。
关于以太网服务实例的相关配置命令,请参见“VXLAN命令参考”。
在控制平面应用QoS策略时,如果流分类的匹配条件是control-plane protocol-group或control-plane protocol,则流行为的动作只能为car,或者car和accounting动作的组合,且在car动作中只有cir参数的取值可以被正常应用。
在二层聚合接口和三层聚合接口上应用QoS策略时,仅支持对收到的报文应用QoS策略。
# 将通用类型QoS策略TEST1应用到接口HundredGigE1/0/1的出方向上。
[Sysname-HundredGigE1/0/1] qos apply policy TEST1 outbound
# 将统计类型QoS策略TEST2应用到接口HundredGigE1/0/1的出方向上。
[Sysname-HundredGigE1/0/1] qos apply accounting policy TEST2 outbound
# 将镜像类型QoS策略TEST3应用到接口HundredGigE1/0/1的出方向上。
[Sysname-HundredGigE1/0/1] qos apply mirroring policy TEST3 outbound
# 将重标记类型QoS策略TEST4应用到接口HundredGigE1/0/1的出方向上。
[Sysname-HundredGigE1/0/1] qos apply remarking policy TEST4 outbound
# 对进入3号槽控制平面的报文应用通用类型QoS策略TEST5。
[Sysname-cp-slot3] qos apply policy TEST5 inbound
# 对进入以太网服务实例的报文应用通用类型QoS策略TEST9。
[Sysname-HundredGigE1/0/1] service-instance 200
[Sysname-HundredGigE1/0/1-srv200] qos apply policy TEST9 inbound
# 以共享QoS和ACL资源的模式将通用类型QoS策略TEST10应用到接口HundredGigE1/0/1的出方向上。
[Sysname-HundredGigE1/0/1] qos apply policy TEST10 outbound share-mode
# 将IPv6 Matching类型QoS策略TEST13应用到接口HundredGigE1/0/1的出方向上。
[Sysname-HundredGigE1/0/1] qos apply ipv6-matching policy TEST13 outbound
qos apply policy命令用来在User Profile下应用策略。
undo qos apply policy命令用来取消User Profile下应用的策略。
undo qos apply policy policy-name { inbound | outbound }
未在User Profile下应用QoS策略。
User Profile视图
inbound:入方向应用QoS策略。
policy-name:策略名,为1~31个字符的字符串。
User Profile被删除将导致其下引用的QoS策略被删除。
User Profile视图下应用的QoS策略不能为空,因为应用空策略的User Profile不能被激活,且QoS策略中的流行为只支持car和accounting动作。
# 对设备发送的上线用户user的流量应用策略test(该策略已经建立)。
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
qos apply [ ipv6-matching | { accounting | mirroring | remarking } ] policy policy-name global { inbound | outbound }
undo qos apply [ ipv6-matching | { accounting | mirroring | remarking } ] policy policy-name global { inbound | outbound }
未在全局应用QoS策略。
inbound:入方向应用QoS策略。
全局应用的QoS策略对全部流量生效。
基于全局应用策略时,在相同方向最多可以应用五个不同类型的策略,即每个类型的QoS策略各一个。
如果未指定ipv6-matching、accounting、mirroring和remarking,则在全局应用通用类型QoS策略。
# 将通用类型QoS策略user1应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
# 将镜像类型QoS策略user2应用到全局的入方向上。
[Sysname] qos apply mirroring policy user2 global inbound
qos policy命令用来创建一个QoS策略,并进入QoS策略视图。如果指定的QoS策略已经存在,则直接进入QoS策略视图。
undo qos policy命令用来删除一个QoS策略。
qos [ ipv6-matching | { accounting | mirroring | remarking } ] policy policy-name
undo qos [ ipv6-matching | { accounting | mirroring | remarking } ] policy policy-name
不存在QoS策略。
创建QoS策略时:
· 如果未指定ipv6-matching、accounting、mirroring和remarking,则表示通用类型的QoS策略。
· 不同类型的QoS策略不能使用相同的名称。
· 请避免使用“ipv6-matching”、“accounting”、“mirroring”、“remarking”做策略名称,也不要使用这些词的前几个字母做策略名称,例如“ipv6”、“acc”、“mirror”、“remark”等。如果这样做,会导致执行display qos policy user-defined policy-name命令时无相关信息显示,因为系统会认为输入的策略名是命令行关键字而非policy-name。
如下各类型QoS策略的使用方法相同:
· 通用类型的QoS策略可以应用在所有支持的位置,包括接口、VLAN、全局等,能配置所有的流行为动作。
· IPv6 Matching类型的QoS策略仅支持应用在接口或全局,常用于配置引用IPv6 ACL的流分类。
· 统计类型QoS策略仅支持应用在接口或全局,常用于配置流量统计动作。
· 镜像类型QoS策略仅支持应用在接口或全局,常用于配置镜像动作。
· 重标记类型QoS策略仅支持应用在接口或全局,常用于配置重标记动作。
IPv6 Matching类型的QoS策略用于配置引用IPv6 ACL的流分类,其他类型的QoS策略并不区分IPv4和IPv6。
在某些场景下,需要将一个用于匹配IPv4报文的QoS策略和一个用于匹配IPv6报文的QoS策略同时应用在相同位置的相同方向,此时可以配置一个通用类型QoS策略和一个IPv6 Matching类型的QoS策略。
如果QoS策略已经被应用,则不允许删除,需要先在应用的位置上取消对QoS策略的应用,然后再使用undo qos policy命令删除。
# 定义一个名为user1的通用类型的QoS策略。
# 定义一个名为user2的统计类型的QoS策略。
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# 定义一个名为user3的重标记类型的QoS策略。
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
# 定义一个名为user4的镜像类型的QoS策略。
[Sysname] qos mirroring policy user4
[Sysname-qospolicy-user4]
# 定义一个名为user6的IPv6 Matching类型的QoS策略。
[Sysname] qos ipv6-matching policy user6
[Sysname-qospolicy-user6]
· qos apply policy
· qos apply policy global
· qos vlan-policy
qos vlan-policy命令用来在VLAN上应用QoS策略。
undo qos vlan-policy命令用来取消VLAN上应用的QoS策略。
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
未在VLAN上应用QoS策略。
policy-name:策略名称,为1~31个字符的字符串,区分大小写。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:入方向应用QoS策略。
# 在VLAN 200、300、400、500的入方向上应用策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
slot slot-number:清除指定成员设备的基于控制平面应用QoS策略的统计信息,slot-number表示设备在IRF中的成员编号。
# 清除应用到指定slot上的控制平面的QoS策略统计信息。
<Sysname> reset qos policy control-plane slot 1
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
reset qos [ ipv6-matching | { accounting | mirroring | remarking } ] policy global [ inbound | outbound ]
inbound:清除入方向QoS策略的统计信息。
outbound:清除出方向QoS策略的统计信息。
如果未指定ipv6-matching、accounting、mirroring和remarking,则清除通用类型QoS策略的统计信息。
如果未指定清除方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除全局入方向应用的通用类型QoS策略的统计信息。
<Sysname> reset qos policy global inbound
# 清除全局入方向应用的镜像类型QoS策略的统计信息。
<Sysname> reset qos mirroring policy global inbound
reset qos policy l2vpn-ac命令用来清除L2VPN AC承载的以太网服务实例上QoS策略的统计信息。
仅Release 6635及以上版本支持本命令。
reset qos [ ipv6-matching | { accounting | mirroring | remarking } ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ] [ inbound | outbound ]
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将清除所有接口下以太网服务实例上QoS策略的统计信息。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将清除接口下所有以太网服务实例上QoS策略的统计信息。
# 清除接口HundredGigE1/0/1下以太网服务实例1入方向QoS策略的统计信息。
<Sysname> reset qos policy l2vpn-ac interface hundredgige 1/0/1 service-instance 1 inbound
# 清除接口HundredGigE1/0/1下以太网服务实例1收到的IPv6 Matching类型QoS策略的统计信息。
<Sysname> reset qos ipv6-matching policy l2vpn-ac interface hundredgige 1/0/1 service-instance 1 inbound
· display qos policy l2vpn-ac
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
vlan vlan-id:指定VLAN。vlan-id为指定VLAN的ID号,取值范围为1~4094。
如果未指定方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
display qos map-table命令用来显示优先级映射表的配置情况。
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p ]
优先级映射 |
dot1p-dp |
802.1p优先级到丢弃优先级映射表 |
dot1p-exp |
802.1p优先级到EXP映射表 |
dot1p-lp |
802.1p优先级到本地优先级映射表 |
dscp-dot1p |
DSCP到802.1p优先级映射表 |
dscp-dp |
DSCP到丢弃优先级映射表 |
dscp-dscp |
DSCP到DSCP映射表 |
exp-dot1p |
EXP到802.1p优先级映射表 |
如果未指定表的类型,将显示所有映射表的配置情况。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
表2-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME |
映射表的名称 |
TYPE |
映射表的类型 |
IMPORT |
映射表的输入值 |
EXPORT |
映射表的输出值 |
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 B。
优先级映射表视图
import-value-list:输入值列表。
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
# 配置802.1p优先级到本地优先级映射表的映射关系,与802.1p优先级4、5相对应的本地优先级为1。
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
· display qos map-table
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p }
其它参数请参见表2-1。
# 进入802.1p优先级到本地优先级映射表视图。
· import
display qos trust interface命令用来显示端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示端口优先级信任模式信息。
<Sysname> display qos trust interface hundredgige 1/0/1
Port priority trust information
Port priority:4
Port dscp priority: -
Port priority trust type: dscp
表2-3 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成 |
Port priority trust information |
端口优先级信任信息 |
Port priority |
端口优先级 |
Port dscp priority |
改写报文的DSCP优先级的值,-表示未配置修改报文的DSCP优先级的值 |
Port priority trust type |
端口优先级信任类型,取值为: · dot1p:802.1p优先级 · dscp:DSCP优先级 · none:不信任任何优先级 |
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { dot1p | dscp }
undo qos trust
设备不信任报文携带的优先级,会使用端口优先级作为报文的802.1p优先级进行优先级映射。
二层以太网接口视图/三层以太网接口视图
如果希望VXLAN隧道接口信任VXLAN报文内层IP头的DSCP优先级,VXLAN隧道所在的以太网接口下需要配置qos trust dscp。
# 在接口HundredGigE1/0/1上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname-HundredGigE1/0/1] qos trust dot1p
qos trust命令用来配置全局优先级信任模式。
qos trust { tunnel-dot1p | tunnel-dscp }
undo qos trust { tunnel-dot1p | tunnel-dscp }
未配置全局优先级信任模式。
tunnel-dot1p:信任VXLAN报文外层帧头的802.1p优先级,以此优先级进行优先级映射。
tunnel-dscp:信任VXLAN报文外层IP头的DSCP优先级,以此优先级进行优先级映射。
如果希望VXLAN隧道接口信任VXLAN报文外层IP头的DSCP优先级,除了VXLAN隧道所在的以太网接口下配置qos trust dscp,系统视图下还需要配置qos trust tunnel-dscp。
如果希望VXLAN隧道接口信任VXLAN报文外层帧头的802.1p优先级,除了VXLAN隧道所在的以太网接口下配置qos trust dot1p,系统视图下还需要配置qos trust tunnel-dot1p。
为实现Overlay网络的PFC功能,所有VTEP设备均需要配置信任VXLAN报文外层IP头的802.1P优先级,关于Overlay网络的相关介绍,请参见“VXLAN配置指导”,关于PFC功能的相关介绍,请参见“二层技术-以太网交换配置指导”中的“以太网接口”。
# 配置设备信任VXLAN报文外层IP头的DSCP优先级。
[Sysname] qos trust tunnel-dscp
# 配置设备信任VXLAN报文外层帧头的802.1p优先级。
[Sysname] qos trust tunnel-dot1p
qos priority命令用来配置端口的端口优先级。
undo qos priority命令用来恢复端口优先级为缺省值。
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
端口优先级的缺省值为0,未配置修改报文的DSCP优先级的值。
二层以太网接口视图/三层以太网接口视图
priority-value:端口优先级值。未配置DSCP关键字时,表示配置端口优先级,端口优先级的取值范围为0~7;配置DSCP关键字后,表示修改报文的DSCP优先级,取值范围为0~63。
未配置端口优先级信任模式时,表示设备以端口优先级作为报文的802.1P优先级进行映射,如果携带dscp关键字,同时对于三层报文将改写报文的DSCP优先级。
配置端口优先级信任模式后,本命令将不再生效。
# 配置接口HundredGigE1/0/1的端口优先级为2,修改收到的三层报文的DSCP优先级为20。
[Sysname-HundredGigE1/0/1] qos priority 2
[Sysname-HundredGigE1/0/1] qos priority dscp 20
· display qos trust interface
display qos gts interface命令用来显示接口的流量整形配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量整形配置情况。
# 显示所有接口的流量整形配置情况。
Rule: If-match queue 1
CIR 512 (kbps), CBS 51200 (Bytes)
表3-1 display qos gts命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成 |
Rule |
匹配规则 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,单位为byte |
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
undo qos gts queue queue-id
未配置流量整形。
二层以太网接口视图/三层以太网接口视图
queue queue-id:对队列上的数据包进行流量整形。queue-id为匹配的队列号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。10GE端口的取值范围为8~10000000,25GE端口的取值范围为8~25000000,100GE端口的取值范围为8~100000000,用户配置的数值必须是8的倍数。
cbs committed-burst-size:承诺突发尺寸,单位为byte。
· 如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过16000000。
· 如果指定cbs参数,取值范围512~16000000且必须为512的整数倍。
# 在接口HundredGigE1/0/1上对队列1中的报文进行流量整形。正常流速为6400kbps,突发流量为51200bytes。
[Sysname-HundredGigE1/0/1] qos gts queue 1 cir 6400 cbs 51200
display qos lr interface命令用来显示接口上的限速配置情况。
display qos lrinterface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的限速配置情况。
# 显示所有接口的接口限速配置情况。
Direction: outbound
CIR 2000 (kbps), CBS 20480 (Bytes)
表3-2 display qos lr命令显示信息描述表
Direction |
接口限速应用的方向 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,单位为byte |
qos lr命令用来配置接口限速。
undo qos lr命令用来取消接口配置的限速。
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
未配置限速。
二层以太网接口视图/三层以太网接口视图
outbound:出方向限速。
cbs committed-burst-size:承诺突发尺寸,单位为bytes。
· 如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过128000000。
· 如果指定cbs参数,取值范围512~128000000且必须为512的整数倍。
# 对接口HundredGigE1/0/1上出方向的报文进行限速。正常流速为256kbps,突发流量为51200bytes,以后速率小于等于256kbps时正常发送,速率大于256kbps时,将进行限速。
[Sysname-HundredGigE1/0/1] qos lr outbound cir 256 cbs 51200
display qos queue interface命令用来显示接口上队列配置情况和统计信息。
display qos queue interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的接口队列配置情况和运行统计信息。
# 显示所有接口下的队列信息。
<Sysname> display qos queue interface
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Byte count
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 5
5 ef 1 9
6 cs6 1 13
7 cs7 1 15
Interface: HundredGigE1/0/2
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 5
5 ef 1 9
6 cs6 1 13
7 cs7 1 15
.....(省略部分显示信息)
表4-1 display qos queue interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列的相关信息 |
Queue ID |
队列号 |
Queue name |
队列名称 |
Group |
分组号,说明队列属于哪一个分组 |
Weight |
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算,N/A表示该队列采用SP调度算法 |
Byte count |
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算 |
display qos queue sp interface命令用来显示接口的SP(Strict Priority,严格优先级)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的SP队列配置情况。
# 显示HundredGigE1/0/1的严格优先级队列配置情况。
<Sysname> display qos queue sp interface hundredgige 1/0/1
Output queue: Strict Priority queuing
表4-2 display qos queue sp interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列类型 |
qos sp命令用来在接口上配置严格优先队列。
undo qos sp命令用来恢复缺省情况。
qos sp
undo qos sp
接口采用WRR调度算法,各队列按照每次轮询可发送的字节数进行计算。
二层以太网接口视图/三层以太网接口视图
# 在接口HundredGigE1/0/1上应用SP模式的队列调度。
[Sysname-HundredGigE1/0/1] qos sp
· display qos queue sp interface
display qos queue wrr interface命令用来显示接口的WRR(Weighted Round Robin,加权轮询)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WRR队列配置情况。
# 显示接口HundredGigE1/0/1的WRR队列配置情况。
<Sysname> display qos queue wrr interface hundredgige 1/0/1
Queue ID Queue name Group Weight
0 be 1 1
1 af1 1 1
2 af2 1 1
3 af3 1 1
4 af4 1 1
5 ef 1 1
6 cs6 1 1
7 cs7 sp N/A
表4-3 display qos queue wrr interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列类型 |
Queue ID |
队列号 |
Queue name |
队列名称 |
Group |
分组号,说明队列属于哪一个分组 |
Weight |
Byte count |
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算,N/A表示该队列采用SP调度算法 |
qos wrr命令用来在接口上开启WRR队列。
undo qos wrr命令用来恢复缺省情况。
qos wrr { byte-count | weight }
undo qos wrr { byte-count | weight }
二层以太网接口视图/三层以太网接口视图
byte-count:表示按照每次轮询可发送的字节数进行计算。
weight:表示按照每次轮询可发送的报文个数进行计算。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行WRR配置。
# 在接口HundredGigE1/0/1上开启WRR队列,并按照每次轮询可发送的报文个数进行计算。
[Sysname-HundredGigE1/0/1] qos wrr weight
# 在接口HundredGigE1/0/1上开启WRR队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-HundredGigE1/0/1] qos wrr byte-count
· display qos queue wrr interface
qos wrr { byte-count | weight }命令用来配置WRR队列或修改WRR队列的参数。
undo qos wrr命令用来恢复指定队列的缺省情况。
qos wrr queue-id group 1 { byte-count | weight } schedule-value
undo qos wrr queue-id
所有队列都处于WRR调度组1中,调度权重从队列0到7分别为1、2、3、4、5、9、13、15,各队列按照每次轮询可发送的字节数进行计算。
二层以太网接口视图/三层以太网接口视图
queue-id:队列序号。取值范围为0~7或表4-4中的关键字。
表4-4 queue-id数字和关键字对应表
queue-id数字 |
queue-id关键字 |
0 |
be |
1 |
af1 |
2 |
af2 |
3 |
af3 |
4 |
af4 |
5 |
ef |
6 |
cs6 |
7 |
cs7 |
group 1:表示该队列属于WRR优先组,目前仅支持1个WRR调度组。
schedule-value:配置队列的调度权重,取值范围为1~127。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行本配置。
# 在接口HundredGigE1/0/1上应用WRR队列,并按照每次轮询可发送的报文个数数进行计算,配置队列0的调度权重为10。
[Sysname-HundredGigE1/0/1] qos wrr 0 group 1 weight 10
· qos wrr
qos wrr group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wrr group sp命令用来取消将队列加入SP组。
qos wrr queue-id group sp
当接口使用WRR队列时,所有队列均处于WRR调度组1中。
二层以太网接口视图/三层以太网接口视图
本命令需要在端口队列为WRR调度模式下使用。
SP组与普通WRR优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WRR优先组。
# 在接口HundredGigE1/0/1上应用WRR队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-HundredGigE1/0/1] qos wrr 0 group sp
· qos wrr
display qos queue wfq interface命令用来显示接口的WFQ配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WFQ配置情况。
# 显示接口HundredGigE1/0/1的加权公平队列配置情况。
<Sysname> display qos queue wfq interface hundredgige 1/0/1
Output queue: Hardware Weighted Fair Queuing
Queue ID Queue name Group Byte count Min Bandwidth
0 be 1 1 64
1 af1 1 1 64
2 af2 1 1 64
3 af3 1 1 64
4 af4 1 1 64
5 ef 1 1 64
6 cs6 1 1 64
7 cs7 1 1 64
表4-5 display qos queue wfq interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列类型 |
Queue ID |
队列号 |
Queue name |
队列名称 |
Group |
分组号,说明队列属于哪一个分组 |
Byte-count |
Weight |
Min-Bandwidth |
队列的最小保证带宽值 |
qos bandwidth queue命令用来配置端口队列的最小带宽保证。
undo qos bandwidth queue命令用来恢复缺省情况。
undo qos bandwidth queue queue-id
在使用WFQ队列时,每个队列的最小带宽保证为64kbps。
二层以太网接口视图/三层以太网接口视图
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。10GE端口的取值范围为8~10000000, 100GE端口的取值范围为8~100000000,表示端口流量拥塞时能够保证的最小队列带宽。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行本配置。
# 在接口HundredGigE1/0/1上配置队列0的最小保证带宽值为100kbps。
[Sysname-HundredGigE1/0/1] qos wfq weight
[Sysname-HundredGigE1/0/1] qos bandwidth queue 0 min 100
· qos wfq
qos wfq命令用来在接口上开启WFQ队列。
undo qos wfq命令用来恢复缺省情况。
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
二层以太网接口视图/三层以太网接口视图
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行WFQ配置。
# 在接口HundredGigE1/0/1上开启WFQ队列,并按照每次轮询可发送的报文个数进行计算。
# 在接口HundredGigE1/0/1上开启WFQ队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-HundredGigE1/0/1] qos wfq byte-count
· display qos queue wfq interface
qos wfq { byte-count | weight }命令用来配置WFQ队列或修改WFQ队列的参数。
undo qos wfq命令用来恢复指定队列的缺省情况。
qos wfq queue-id group 1 { byte-count | weight } schedule-value
undo qos wfq queue-id
当接口使用WFQ队列时,所有队列都处于WFQ调度组1中,各队列的调度权重均为1。
二层以太网接口视图/三层以太网接口视图
group 1:表示该队列属于WFQ优先组,目前仅支持1个WFQ调度组。
# 在接口HundredGigE1/0/1上应用WFQ队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10。
[Sysname-HundredGigE1/0/1] qos wfq 0 group 1 byte-count 10
· qos bandwidth queue
· qos wfq
qos wfq group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wfq group sp命令用来取消将队列加入SP组。
qos wfq queue-id group sp
当接口使用WFQ队列时,所有队列均处于WFQ调度组1中。
二层以太网接口视图/三层以太网接口视图
本命令需要在端口队列为WFQ调度模式下使用。
SP组与普通WFQ优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WFQ优先组。
# 在接口HundredGigE1/0/1上应用WFQ队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-HundredGigE1/0/1] qos wfq 0 group sp
· qos wfq
bandwidth queue命令用来配置队列调度策略下队列的最小带宽保证。
undo bandwidth queue命令用来恢复缺省情况。
undo bandwidth queue queue-id
在队列调度策略中配置某个队列为WFQ队列后,该队列的最小带宽保证为0kbps。
队列调度策略视图
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。取值范围为8~100000000,单位为kbps,表示端口流量拥塞时能够为该队列保证的最小带宽。
必须先在队列调度策略中将某个队列配置为WFQ队列,才能为该队列配置最小带宽保证。
# 在队列调度策略myprofile中,配置队列0使用WFQ队列算法,使用报文个数作为调度权重,权重值为1,分组为1,并为该队列配置最小保证带宽值为100kbps。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有队列调度策略的配置情况。
slot slot-number:显示指定成员设备的队列调度策略的配置情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的队列调度策略的配置情况。
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID Type Group Schedule Schedule Min Max
unit value bandwidth bandwidth
be WRR 1 weight 1 N/A N/A
af1 WRR 1 weight 2 N/A N/A
af2 WRR 1 weight 3 N/A N/A
af3 WRR 1 weight 4 N/A N/A
af4 WRR 1 weight 5 N/A N/A
ef WRR 1 weight 9 N/A N/A
cs6 WRR 1 weight 13 N/A N/A
cs7 WRR 1 weight 15 N/A N/A
表4-6 display qos qmprofile configuration命令显示信息描述表
Queue management profile |
队列调度策略名称 |
Queue ID |
队列号 |
Type |
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)、WFQ(加权公平队列) |
Group |
优先组,N/A表示无效,取值只能为1 |
Schedule unit |
队列调度单位,包括weight和byte-count,N/A表示无效 |
Schedule vlaue |
· 队列调度单位为weight时,表示报文个数 · 队列调度单位为byte-count时,表示字节个数 · N/A表示无效 |
Min Bandwidth |
最小保证带宽,N/A表示无效 |
Max bandwidth |
(设备暂不支持)最大带宽值,N/A表示无效 |
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface hundredgige 1/0/1
Direction: Outbound
表4-7 display qos qmprofile interface命令显示信息描述表
接口名称 |
Direction |
队列调度策略应用的方向 |
队列调度策略名称 |
qos apply qmprofile命令用来在接口出方向上应用队列调度策略。
undo qos apply qmprofile命令用来恢复缺省情况。
接口上未应用队列调度策略。
二层以太网接口视图/三层以太网接口视图
每个接口只能应用一个队列调度策略。
# 在接口HundredGigE1/0/1出方向上应用队列调度策略myprofile。
[Sysname-HundredGigE1/0/1] qos apply qmprofile myprofile
· display qos qmprofile interface
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入相应的队列调度策略视图。如果指定的队列调度策略已经存在,则直接进入该队列调度策略视图。
undo qos qmprofile命令用来删除用户自定义的队列调度策略。
qos qmprofile profile-name
undo qos qmprofile profile-name
不存在用户自定义的队列调度策略。
如果需要删除已经应用到接口的队列调度策略,必须先在应用的位置上取消对该队列调度策略的应用,然后再删除该队列调度策略。
# 创建队列调度策略myprofile,并进入队列调度策略视图。
· queue
queue命令用来配置队列调度参数。
undo queue命令用来取消队列调度参数的配置。
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
队列调度策略的内容是所有队列均采用WRR方式调度,各队列的权重分别为1、2、3、4、5、9、13、15,按照每次轮询可发送的报文个数进行计算。
队列调度策略视图
sp:配置队列为严格优先级调度。
wfq:配置队列为加权公平调度。
wrr:配置队列为加权轮询调度。
group group-id:优先组号。取值只能为1。
schedule-value:配置队列的调度权重。对于采用WRR调度算法的队列,取值范围为1~15。对于采用WFQ调度算法的队列,如果指定的是byte-count,则取值范围为1~15;如果指定的是weight,则取值范围为1~127。
# 创建自定义的队列调度策略myprofile,并配置队列0为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 0 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,分组为1,权重为10。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
· qos qmprofile
display qos queue-statistics interface outbound命令用来显示端口队列出方向的统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列出方向统计信息。
# 显示接口HundredGigE1/0/1的队列出方向统计信息。
<Sysname> display qos queue-statistics interface hundredgige 1/0/1 outbound
Direction: outbound
Forwarded: 0 packets, 0 bytes
Dropped: 0 packets, 0 bytes
Queue 0
Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
Current queue length: 0 packets
Queue 1
Queue 2
Queue 3
Queue 4
Queue 5
Queue 6
Queue 7
表4-8 display qos queue-statistics interface outbound命令显示信息描述表
端口队列统计的端口 |
Direction |
端口队列统计的方向 |
Forwarded |
转发的数据包数目和字节数 |
Dropped |
丢弃的数据包数目和字节数 |
Queue 0、Queue 1、Queue 2、Queue 3、Queue 4、Queue 5、Queue 6、Queue 7 |
某端口队列统计信息 |
Current queue length |
当前队列长度 |
· reset counters interface(接口管理命令参考/以太网接口)
reset qos queue-statistics interface outbound命令用来清除端口队列出方向的统计信息。
reset qos queue-statistics interface [ interface-type interface-number ] outbound
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将清除所有接口的队列出方向统计信息。
# 清除所有接口的队列统计计数
<Sysname> reset qos queue-statistics interface outbound
# 清除接口HundredGigE1/0/1的队列统计计数
<Sysname> reset qos queue-statistics interface hundredgige 1/0/1 outbound
display qos wred interface命令用来显示接口上WRED配置情况和统计信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的WRED配置情况和统计信息。
# 显示所有接口下应用的WRED表配置情况和统计信息。
<Sysname> display qos wred interface
Current WRED configuration:
Applied WRED table name: q1
Table type: Queue based WRED
QID gmin gmax gpro ymin ymax ypro rmin rmax rpro exp ECN
0 100 1000 10 100 1000 10 100 1000 10 9 N
1 100 1000 10 100 1000 10 100 1000 10 9 N
2 100 1000 10 100 1000 10 100 1000 10 9 N
3 100 1000 10 100 1000 10 100 1000 10 9 N
4 100 1000 10 100 1000 10 100 1000 10 9 N
5 100 1000 10 100 1000 10 100 1000 10 9 N
6 100 1000 10 100 1000 10 100 1000 10 9 N
7 100 1000 10 100 1000 10 100 1000 10 9 N
# 显示所有接口下配置的WRED配置情况和统计信息。
表5-1 display qos wred interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Current WRED configuration |
当前WRED的配置情况 |
Applied WRED table name |
当前应用的WRED表的名称 |
Table type |
WRED表类型,当前仅支持Queue based WRED |
QID |
队列ID |
gmin |
绿色报文的队列下限 |
gmax |
绿色报文的队列上限 |
gpro |
绿色报文的丢弃概率 |
ymin |
黄色报文的队列下限 |
ymax |
黄色报文的队列上限 |
ypro |
黄色报文的丢弃概率 |
rmin |
红色报文的队列下限 |
rmax |
红色报文的队列上限 |
rpro |
红色报文的丢弃概率 |
exp |
计算平均队列长度指数 |
ECN |
是否对该队列开启了拥塞通知功能,Y表示开启,N表示未开启 |
display qos wred table命令用来显示WRED表的配置情况。
name table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则显示所有WRED表配置情况。
slot slot-number:显示指定成员设备的WRED表配置情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的WRED表配置情况。
# 显示WRED表1的配置情况,表1是一个已经配置好的WRED参数表。
<Sysname> display qos wred table name 1
Table name: 1
QID gmin gmax gprob ymin ymax yprob rmin rmax rprob exponent ECN
表5-2 display qos wred table命令显示信息描述表
Table name |
WRED表名 |
Table type |
WRED表类型 |
QID |
队列ID |
gmin |
绿色报文的队列下限 |
gmax |
绿色报文的队列上限 |
gprob |
绿色报文的丢弃概率 |
ymin |
黄色报文的队列下限 |
ymax |
黄色报文的队列上限 |
yprob |
黄色报文的丢弃概率 |
rmin |
红色报文的队列下限 |
rmax |
红色报文的队列上限 |
rprob |
红色报文的丢弃概率 |
exponent |
计算平均队列长度指数 |
ECN |
qos wred apply命令用来在接口上应用WRED表。
undo qos wred apply命令用来恢复缺省情况。
qos wred apply [ table-name ]
undo qos wred apply
接口没有应用WRED表,即接口采用尾丢弃。
二层以太网接口视图/三层以太网接口视图
table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则在接口上应用缺省WRED表。
# 在接口HundredGigE1/0/1上应用WRED表。
[Sysname-HundredGigE1/0/1] qos wred apply table1
· display qos wred interface
· display qos wred table
· qos wred queue table
· qos wred smart-ecn enable
qos wred queue命令用来配置队列的WRED参数。
undo qos wred queue命令用来恢复缺省情况。
qos wred queue queue-id low-limit low-limit high-limit high-limit [ discard-probability discard-prob ] [ ecn ] [ weighting-constant exponent ]
qos wred queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo qos wred queue { queue-id [ drop-level drop-level ] | all }
未配置队列的WRED参数。
queue-id:队列编号。取值范围为0~7。
low-limit low-limit:队列平均长度的下限。取值范围为0~52224,当下发值大于52224时,设备实际生效值为52224,而非下发值。单位为cell资源的个数,每个cell资源的大小为208 Byte。
high-limit high-limit:队列平均长度的上限。取值范围为0~52224,当下发值大于52224时,设备实际生效值为52224,而非下发值。单位为cell资源的个数,每个cell资源的大小为208 Byte。
discard-probability discard-prob:丢弃概率,取值越大,计算出的丢弃概率越大。取值范围为0~100。
ecn:表示开启指定队列的拥塞通知功能。
weighting-constant exponent:计算平均队列长度的指数。缺省值为9,取值范围为0~15。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,表示后续配置的参数对该队列所有丢弃级别的报文都生效。
all:表示所有队列。
当队列平均长度小于下限时,不丢弃报文。当队列平均长度在上限和下限之间时,设备随机丢弃报文,队列越长,丢弃概率越高。当队列平均长度超过上限时,丢弃所有到来的报文。
配置本命令时指定ecn参数,与配置qos wred queue ecn命令等效。
配置本命令时指定weighting-constant exponent参数,与配置qos wred queue weighting-constant命令等效。
通过本命令直接在接口下配置队列的WRED参数,与使用qos wred apply命令在接口下应用WRED表等效,且两种配置方式互斥。
# 配置接口HundredGigE1/0/1下队列1中的WRED参数:丢弃级别为1,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30%。
[Sysname-HundredGigE1/0/1] qos wred queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
· qos wred queue ecn
qos wred queue ecn命令用来开启指定队列的拥塞通知功能。
undo qos wred queue ecn命令用来恢复缺省情况。
qos wred queue queue-id ecn
undo qos wred queue queue-id ecn
未开启指定队列的拥塞通知功能。
在报文的发送端和接收端都支持ECN功能时,设备可以通过对ECN域的识别和标记将拥塞状况告知终端,避免拥塞加剧。
配置本命令与配置qos wred queue命令时指定ecn参数等效。
# 开启接口HundredGigE1/0/1下队列1的拥塞通知功能。
[Sysname-HundredGigE1/0/1] qos wred queue 1 ecn
· qos wred queue
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。如果指定的WRED表已经存在,则直接进入WRED表视图。
undo qos wred queue table命令用来删除WRED表。
undo qos wred queue table table-name
设备上不存在WRED表。
table table-name:指定WRED表的名称,为1~32个字符的字符串,区分大小写。
设备不允许删除正在使用的WRED表。如果需要删除正在使用的表,请先在接口上取消应用的WRED表。
缺省WRED表可以通过display qos wred table命令显示,不允许修改和删除。
# 创建基于queue的WRED表queue-table1。
[Sysname-wred-table-queue-table1]
queue命令用来配置基于队列的WRED表的内容。
undo queue命令用来恢复缺省情况。
undo queue { queue-id [ drop-level drop-level ] | all }
WRED表在创建之后,有缺省的一套参数,low-limit的取值为100,high-limit的取值为1000,discard-prob的取值为10。
WRED表视图
all:表示所有队列。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:队列平均长度的下限。对于R6607版本,取值范围为0~38000;对于Release 6616版本、Release 6616P01版本、F6619及以上版本,取值范围为0~52224,当下发值大于52224时,设备实际生效值为52224,而非下发值;对于F6617L01版本和F6618版本,取值范围为0~52224,如果配置值大于52224,设备返回不支持。单位为cell资源的个数,每个cell资源的大小为208 Byte。
high-limit high-limit:队列平均长度的上限。对于R6607版本,取值范围为0~38000;对于Release 6616版本、Release 6616P01版本、F6619及以上版本,取值范围为0~52224,当下发值大于52224时,设备实际生效值为52224,而非下发值;对于F6617L01版本和F6618版本,取值范围为0~52224,如果配置值大于52224,设备返回不支持。单位为cell资源的个数,每个cell资源的大小为208 Byte。队列平均长度上限必须大于队列平均长度下限。
# 配置基于队列的WRED表queue-table1中队列1的丢弃参数:丢弃级别为1,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30%。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
queue ecn命令用来对指定队列开启拥塞通知功能。
undo queue ecn命令用来恢复缺省情况。
queue queue-id ecn
undo queue queue-id ecn
对任何队列都未开启拥塞通知功能。
WRED表视图
# 在WRED表queue-table1中,对队列1开启拥塞通知功能。
[Sysname-wred-table-queue-table1] queue 1 ecn
qos wred queue weighting-constant命令用来配置计算平均队列长度的指数。
undo qos wred queue weighting-constant命令用来恢复缺省情况。
qos wred queue queue-id weighting-constant exponent
undo qos wred queue queue-id weighting-constant
计算平均队列长度的指数为9。
weighting-constant exponent:计算平均队列长度的指数。取值范围为0~15。
平均队列长度的指数越大,计算平均队列长度时对队列的实时变化越不敏感。计算队列平均长度的公式为:平均队列长度=(以前的平均队列长度×(1-1/2n))+(当前队列长度×(1/2n))。其中n表示指数。
配置本命令与配置qos wred queue命令时指定weighting-constant exponent参数等效。
# 配置接口HundredGigE1/0/1下队列1计算平均队列长度的指数为12。
[Sysname-HundredGigE1/0/1] qos wred queue 1 weighting-constant 12
· qos wred queue
qos wred smart-ecn enable命令用来开启全局WRED Smart ECN功能。
undo qos wred smart-ecn enable命令用来关闭全局WRED Smart ECN功能。
qos wred smart-ecn queue queue-id enable
undo qos wred smart-ecn queue queue-id enable
全局WRED Smart ECN功能处于关闭状态。
开启全局WRED Smart ECN功能与接口下应用WRED表冲突。
对于同一个队列,开启全局WRED Smart ECN功能与开启接口队列的拥塞通知功能冲突。
# 开启队列1的全局WRED Smart ECN功能。
[Sysname] qos wred smart-ecn queue 1 enable
· qos wred apply
undo queue weighting-constant命令用来恢复缺省情况。
undo queue queue-id weighting-constant
计算平均队列长度的指数为9。
WRED表视图
# 在WRED表queue-table1中,配置计算平均队列长度的指数为12。
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
car name命令用来配置聚合CAR动作。
undo car用来恢复缺省情况。
car name car-name
undo car
未配置聚合CAR动作。
流行为视图
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
# 配置流行为be1的聚合CAR动作为aggcar-1。
· display qos car name
· display traffic behavior user-defined
display qos car name命令用来显示聚合CAR的配置和统计信息。
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。显示指定聚合CAR的配置和统计信息。如果未指定本参数,将显示所有聚合CAR的配置和统计信息。
# 显示聚合CAR的配置和统计信息。
<Sysname> display qos car name
Mode: aggregative
CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Slot 0:
Green packets : 0 (Packets), 0 (Bytes)
Yellow packets: 0 (Packets), 0 (Bytes)
Red packets : 0 (Packets), 0 (Bytes)
Slot 1:
Slot 2:
Apply failed
表6-1 display qos car name命令显示信息描述表
Name |
聚合CAR的名称 |
Mode |
聚合CAR的类型,取值为aggregative(聚合CAR) |
CIR CBS PIR EBS |
流量监管流量的参数配置 |
Green action |
对绿色报文的动作 · discard:丢弃报文 · pass:允许报文通过 |
Yellow action |
对黄色报文的动作 · discard:丢弃报文 · pass:允许报文通过 |
Red action |
对红色报文的动作 · discard:丢弃报文 · pass:允许报文通过 |
Green packets |
绿色报文的流量统计 |
Yellow packets |
黄色报文的流量统计 |
Red packets |
红色报文的流量统计 |
qos car命令用来配置聚合CAR。
undo qos car命令用来取消聚合CAR的配置。
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
未配置聚合CAR。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~160000000且必须为8的整数倍。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,单位为byte。
· 如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过256000000。
· 如果指定cbs参数,取值范围512~256000000且必须为512的整数倍。
ebs excess-burst-size:过度突发尺寸,单位为byte。
· 配置pir参数后:
¡ 如果不指定ebs,则ebs缺省取值为与62.5 × peak-information-rate的乘积最接近且不小于512的整数倍,但是最大值不能超过256000000。
¡ 如果指定ebs,取值范围0~256000000且必须为512的整数倍。
· 未配置pir参数时,ebs的取值范围为0~256000000且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为8~160000000且必须为8的整数倍。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass。
action:对数据包采取的动作,有以下几种:
· discard:丢弃数据包。
· pass:允许数据包通过。
· remark-dot1p-pass new-cos:设置新的802.1P报文的优先级值,并允许数据包通过,取值范围为0~7。
· remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63;用文字表示时,可以选取af11、af12、af13、af21、af22、af23、af31、af32、af33、af41、af42、af43、cs1、cs2、cs3、cs4、cs5、cs6、cs7、default、ef。
聚合CAR配置需要在策略中引用后才能生效。
不配置峰值速率表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 配置聚合CAR采取的CAR参数取值,cir取值为25600,cbs取值为512000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name命令用来清除聚合CAR的统计信息。
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。清除指定聚合CAR的统计信息。如果未指定本参数,将清除所有聚合CAR的统计信息。
# 清除聚合CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
仅Release 6616及以上版本支持大小流区分调度功能。
elephant-flow action命令用来配置大流的处理动作。
undo elephant-flow action命令用来恢复缺省情况。
elephant-flow action { drop-precedence drop-precedence-value | dot1p dot1p-value | local-precedence local-precedence-value | none }
未配置大流的处理动作。
大小流视图
drop-precedence drop-precedence-value:指定丢弃优先级,drop-precedence-value的取值范围为0~2。
dot1p dot1p-value:指定802.1p优先级,dot1p-value的取值范围为0~7。仅Release 6635及以上版本支持本参数。
local-precedence local-precedence-value:指定本地优先级,local-precedence-value的取值范围为0~7。仅Release 6635及以上版本支持本参数。
none:无后续处理动作,此时大小流功能仅将大流识别出来,不做优先级降级等任何处理。
# 配置大流的丢弃优先级为2。
<Sysname> system-View
[Sysname] qos mice-elephant-flow
[Sysname-mice-elephant-flow] elephant-flow action drop-precedence 2
elephant-flow rate命令用来配置大流识别参数。
undo elephant-flow rate命令用来取消已配置的大流识别参数。
elephant-flow rate rate [ gbps | kbps | mbps ] [ size size [ bytes | kbytes | mbytes ] ]
未配置大流识别参数。
大小流视图
rate:大流速率,缺省单位为kbps,取值范围为1~1000。
· gbps:指定大流速率的单位为gbps。
· kbps:指定大流速率的单位为kbps。
· mbps:指定大流速率的单位为mbps。
size size:大流尺寸,缺省单位为bytes,取值范围为1~1000。
· bytes:指定大流尺寸的单位为bytes。
· kbytes:指定大流尺寸的单位为kbytes。
· mbytes:指定大流尺寸的单位为mbytes。
配置本命令后,设备将依据本命令中指定的流量识别参数区分大流和小流,对小流不进行处理,保持其在原始优先级队列进行转发,对大流自动进行优先级降级处理,即将这部分流量送至缺省优先级队列进行转发。
# 配置大流识别参数,速率为20kbps,尺寸为100kbytes。
[Sysname-mice-elephant-flow] elephant-flow rate 20 kbps size 100 kbytes
qos mice-elephant-flow命令用来进入大小流视图。
# 进入大小流视图。
仅Release 6616及以上版本支持接口报文统计功能。
display qos packet-statistics interface命令用来显示接口的DSCP或ECN报文统计信息。
display qos packet-statistics interface interface-type interface-number inbound
inbound:显示接口入方向报文统计信息。
# 显示接口HundredGigE1/0/1入方向的报文统计信息。
<Sysname> display qos packet-statistics interface hundredgige 1/0/1 inbound
DSCP ECN Statistics
0 0 1 packets, 100 bytes
0 1 1 packets, 100 bytes
0 2 1 packets, 100 bytes
0 3 1 packets, 100 bytes
…略…
63 3 1 packets, 100 bytes
表8-1 display qos packet-statistics interface命令显示信息描述表
接口名称 |
DSCP |
DSCP优先级 |
ECN |
ECN标志 |
Statistics |
统计的数据包数目和字节数 |
qos packet-statistics命令用来开启接口上的DSCP或ECN报文统计功能。
undo qos packet-statistics命令用来关闭接口上的DSCP或ECN报文统计功能。
qos packet-statistics inbound { dscp | ecn } *
undo qos packet-statistics inbound
接口上的报文统计功能处于关闭状态。
inbound:表示开启接口入方向的报文统计功能。
dscp:表示统计携带DSCP优先级的报文。
ecn:表示统计ECN报文。
若同时指定dscp和ecn,表示统计携带DSCP优先级的ECN报文。
同时开启DSCP和ECN报文统计功能时,设备会将所有非IP协议的报文统计到DSCP=0、ECN=0中。
# 开启接口HundredGigE1/0/1入方向的DSCP和ECN报文统计功能。
[Sysname-HundredGigE1/0/1] qos packet-statistics inbound dscp ecn
reset qos packet-statistics interface命令用来清除接口的DSCP或ECN报文统计信息。
reset qos packet-statistics interface [ interface-type interface-number ] [ inbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将清除所有接口的报文统计信息。
inbound:表示清除接口入方向的报文统计信息。
不指定inbound参数时,也表示清除入方向的报文统计信息。
# 清除接口HundredGigE1/0/1入方向的报文统计信息。
<Sysname> reset qos packet-statistics hundredgige 1/0/1 inbound
bgp-policy命令用来配置QPPB功能,即通过BGP传播路由策略中设置的apply qos-local-id信息。
undo bgp-policy命令用来恢复缺省情况。
bgp-policy destination ip-qos-map
undo bgp-policy destination ip-qos-map
未配置QPPB功能。
三层以太网接口视图/VLAN接口视图
destination:使用目的IP查找路由。
ip-qos-map:设置QoS本地ID。
本配置只对接口接收的报文生效。
在MPLS L3VPN网络中,PE公网接口入方向QoS业务在本配置之前进行;其他网络环境中QoS业务在本配置之后进行。
# 在接口HundredGigE1/0/1上根据目的IP查找路由获得QoS本地ID。
[Sysname-HundredGigE1/0/1] bgp-policy destination ip-qos-map
· apply qos-local-id (三层技术-IP路由命令参考/路由策略)
· route-policy (三层技术-IP路由命令参考/路由策略)
qos control-plane logging interval命令用来配置控制平面协议丢包告警日志信息的生成与发送周期。
undo qos control-plane logging interval命令用来恢复缺省情况。
qos control-plane logging interval interval
控制平面协议丢包告警日志信息的生成与发送周期为5秒。
interval:表示控制平面协议丢包告警日志信息的生成与发送周期,取值范围为5~60,单位为秒。
本命令的配置会对所有已开启告警日志信息记录功能的控制平面协议生效。
上报信息中仅包含周期内的丢包数量,若周期内未产生丢包则不进行信息上报。
# 配置控制平面协议丢包告警日志信息的生成与发送周期为10秒。
[Sysname] qos control-plane logging interval 10
· qos control-plane protocol logging enable
qos control-plane logging protocol enable命令用来开启控制平面协议丢包告警日志记录功能。
undo qos control-plane logging protocol enable命令用来恢复缺省情况。
qos control-plane logging protocol { protocol-list&<1-8> | all } enable
undo qos control-plane logging protocol { protocol-list&<1-8> | all } enable
控制平面协议丢包告警日志信息记录功能处于关闭状态。
protocol-list&<1-8>:控制平面协议名称。表示方式为protocol-list = { protocol-name1 protocol-name2 ] },&<1-8>表示前面的参数最多可以重复输入8次。
all:所有控制平面协议。
设备上存在用户平面和控制平面:
· 用户平面(User Plane):是指对报文进行收发、交换的处理单元,它的主要工作是转发报文。在设备上,与之相对应的核心物理实体就是各种专用转发芯片,它们有极高的处理速度和很强的数据吞吐能力。
· 控制平面(Control Plane):是指运行大部分路由交换协议进程的处理单元,它的主要工作是进行协议报文的解析和协议的计算。在设备上,与之相对应的核心物理实体就是CPU,它具备灵活的报文处理能力,但数据吞吐能力有限。
如果上送控制平面的报文产生丢包,可能会影响协议的正常运行。用户可以开启控制平面协议丢包告警日志信息记录功能,设备将在周期结束后生成日志并发送到信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。
有关信息中心的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启所有控制平面协议的丢包告警日志信息上报功能。
[Sysname] qos control-plane logging protocol all enable
· qos control-plane logging interval
