18-无线探针命令
本章节下载: 18-无线探针命令 (249.12 KB)
1.1.2 client-proximity-sensor ap-timer
1.1.3 client-proximity-sensor ap-udp-server
1.1.4 client-proximity-sensor audit-mac-address
1.1.5 client-proximity-sensor client-timer
1.1.6 client-proximity-sensor coordinates
1.1.7 client-proximity-sensor filter-list
1.1.8 client-proximity-sensor random-mac-report enable
1.1.9 client-proximity-sensor report-ac enable
1.1.10 client-proximity-sensor report-ac-interval
1.1.11 client-proximity-sensor report-ap enable
1.1.12 client-proximity-sensor report-oasis cache
1.1.13 client-proximity-sensor report-oasis client
1.1.14 client-proximity-sensor report-oasis disable
1.1.15 client-proximity-sensor report-oasis rssi-change-threshold
1.1.16 client-proximity-sensor rssi-change-threshold
1.1.17 client-proximity-sensor rssi-threshold
1.1.18 client-proximity-sensor rt-report enable
1.1.19 client-proximity-sensor server
1.1.20 client-proximity-sensor timezone-offset
1.1.21 client-proximity-sensor udp-server
1.1.22 display client-proximity-sensor device
1.1.23 display client-proximity-sensor sensor
1.1.24 display client-proximity-sensor statistics receive
1.1.25 reset client-proximity-sensor device
1.1.26 reset client-proximity-sensor statistics
client-proximity-sensor enable命令用来开启探针功能。
client-proximity-sensor disable命令用来关闭探针功能。
undo client-proximity-sensor命令用来恢复缺省情况。
client-proximity-sensor { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,探针功能处于关闭状态。
Radio视图
AP组Radio视图
# 开启探针功能。(Radio视图)
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] client-proximity-sensor enable
# 开启探针功能。(AP组Radio视图)
[Sysname] wlan ap-group aaa
[Sysname-wlan-ap-group-aaa] ap-model WA6320
[Sysname -wlan-ap-group-aaa-ap-model-WA6320] radio 1
[Sysname -wlan-ap-group-aaa-ap-model-WA6320-radio-1] client-proximity-sensor enable
client-proximity-sensor ap-timer命令用来配置AP表项的时间参数。
undo client-proximity-sensor ap-timer命令用来恢复缺省情况。
client-proximity-sensor ap-timer inactive inactive-value aging aging-value
AP表项的非活跃时间为300秒,老化时间为600秒。
inactive inactive-value:AP表项的非活跃时间,取值范围为60~1200,单位为秒。
aging aging-value:AP表项的老化时间,取值范围为120~86400,单位为秒。
配置的老化时间必须大于或等于两倍非活跃时间,建议使用缺省值。
AP表项的时间参数变化会存在误差,误差大小取决于探针AP将无线设备表项上报AC的周期。
# 配置AP表项的时间参数,非活跃时间为120秒,老化时间为360秒。
[Sysname] client-proximity-sensor ap-timer inactive 120 aging 360
· client-proximity-sensor report-ac-interval
client-proximity-sensor ap-udp-server命令用来配置探针AP上报无线设备信息的UDP服务器。
undo client-proximity-sensor ap-udp-server命令用来恢复缺省情况。
client-proximity-sensor ap-udp-server ip-address port port-number [ interval interval | preshared-key { cipher | simple } key-string ] *
未配置探针AP上报无线设备信息的UDP服务器。
AP视图
AP组视图
ip-address:指定上报无线设备信息的UDP服务器的IPv4地址。
port port-number:指定UDP服务器的端口号,取值范围为1~65534。
interval interval:指定上报同一个无线设备信息到UDP服务器的周期,取值范围为1~600,单位为秒,缺省值为30。
preshared-key:指定预共享密钥。
cipher:表示以密文方式设置共享密钥。
simple:表示以明文方式设置共享密钥。
key-string:设置的明文密钥或密文密钥,区分大小写。明文密钥字符串为8~63个字符的字符串,密文密钥为41~117个字符的字符串。
# 配置探针AP上报无线设备信息的UDP服务器,IP地址为10.152.3.209,UDP服务器的端口号为443。(AP视图)
[Sysname-ap-ap1] client-proximity-sensor ap-udp-server 10.152.3.209 port 443
# 配置探针AP上报无线设备信息的UDP服务器,IP地址为10.152.3.209,UDP服务器的端口号为443。(AP组视图)
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] client-proximity-sensor ap-udp-server 10.152.3.209 port 443
client-proximity-sensor audit-mac-address命令用来配置探针AP上报服务器时携带审计设备的MAC地址。
undo client-proximity-sensor audit-mac-address命令用来恢复缺省情况。
client-proximity-sensor audit-mac-address mac-address
探针AP上报服务器时未携带审计设备的MAC地址。
AP视图
mac-address:审计设备的MAC地址,格式为H-H-H。
用户可以手动配置探针AP的审计设备的MAC地址,探针AP会将收集到的无线设备信息和审计设备的MAC地址信息一同上传至指定的服务器。
在网络审计应用场景中,如果服务器要求获取上报的无线设备信息所属的审计设备,则必须配置本命令,否则会因服务器无法区分上报的无线设备信息所属的审计设备,导致服务器处理上报的无线设备信息失败。
# 配置探针AP上报服务器时携带的审计设备的MAC地址为001b-2233-5d2b。
[Sysname-wlan-ap-ap1] client-proximity-sensor audit-mac-address 001b-2233-5d2b
client-proximity-sensor client-timer命令用来配置客户端表项的时间参数。
undo client-proximity-sensor client-timer命令用来恢复缺省情况。
client-proximity-sensor client-timer inactive inactive-value aging aging-value
客户端表项的非活跃时间为300秒,老化时间为600秒。
inactive inactive-value:客户端表项的非活跃时间,取值范围为60~1200,单位为秒。
aging aging-value:客户端表项的老化时间,取值范围为120~86400,单位为秒。
客户端表项的时间参数变化会存在误差,误差大小取决于探针AP将无线设备表项上报AC的周期。
# 配置客户端表项的时间参数,非活跃时间为120秒,老化时间为360秒。
[Sysname] client-proximity-sensor client-timer inactive 120 aging 360
client-proximity-sensor coordinates命令用来配置探针AP的经纬度。
undo client-proximity-sensor coordinates命令用来删除探针AP的经纬度。
client-proximity-sensor coordinates longitude longitude-value latitude latitude-value
未配置探针AP的经纬度。
AP视图
longitude longitude-value:配置探针AP坐标的经度,格式为XXX-XX-XX.X,XXX的取值范围为0~180,XX的取值范围为0~60,.X的取值为e或者w,不区分大小写。
latitude latitude-value:配置探针AP坐标的纬度,格式为XXX-XX-XX.X,XXX的取值范围为0~90,XX的取值范围为0~60,.X的取值为s或者n,不区分大小写。
用户可以根据探针AP的安装位置,手动配置探针AP的经纬度,探针AP会将收集到的无线设备信息与经纬度信息一同上传至指定的服务器。
# 配置探针AP的坐标为东经123°40’40’’,北纬80°30‘30’’。
[Sysname-ap-ap1] client-proximity-sensor coordinates longitude 123-40-40.e latitude 80-30-30.n
client-proximity-sensor filter-list命令用来配置上报服务器的MAC地址过滤列表。
undo client-proximity-sensor filter-list命令用来删除上报服务器的MAC地址过滤列表。
client-proximity-sensor filter-list list
undo client-proximity-sensor filter-list { list | all }
未配置上报服务器的MAC地址过滤列表。
list:上报服务器的MAC地址过滤列表,格式为H-H-H。可以指定MAC地址加入过滤列表,也可以根据MAC地址的特征进行过滤,比如过滤首个字节的3个比特为1的MAC地址,就配置过滤MAC地址为0400-0000-0000。
all:所有MAC地址过滤列表。
# 配置上报服务器的MAC地址过滤列表,过滤首字节的第3比特为1的MAC地址。
[Sysname] client-proximity-sensor filter-list 0400-0000-0000
client-proximity-sensor random-mac-report enable 命令用来开启上报苹果终端随机伪MAC地址功能。
undo client-proximity-sensor random-mac-report enable命令用来关闭上报苹果终端随机伪MAC地址功能。
上报苹果终端随机伪MAC地址功能处于关闭状态。
苹果终端的随机MAC地址特征为首字节的第2比特为1。当苹果终端作为无线客户端时,会使用随机MAC地址发送无线探测请求帧,从而造成探针AP检测到实际上并不存在的设备。关闭该功能后,苹果终端的随机MAC地址不会被上报到服务器。
# 开启上报苹果终端随机伪MAC地址功能。
[Sysname] client-proximity-sensor random-mac-report enable
client-proximity-sensor report-ac enable命令用来开启探针AP将无线设备表项上报AC功能。
undo client-proximity-sensor report-ac enable命令用来关闭探针AP将无线设备表项上报AC功能。
探针AP将无线设备表项上报AC功能处于关闭状态。
# 配置探针AP将无线设备表项上报AC。
[Sysname] client-proximity-sensor report-ac enable
client-proximity-sensor report-ac-interval命令用来配置探针AP将无线设备表项上报AC的周期。
undo client-proximity-sensor report-ac-interval命令用来恢复缺省情况。
client-proximity-sensor report-ac-interval interval
探针AP将无线设备表项上报AC的周期为10000毫秒。
interval:上报时间间隔,取值范围为100~600000,单位为毫秒。
# 配置探针AP将无线设备表项上报AC的周期为2000毫秒。
[Sysname] client-proximity-sensor report-ac-interval 2000
client-proximity-sensor report-ap enable命令用来开启AP设备信息上报UDP服务器功能。
undo client-proximity-sensor report-ap enable命令用来关闭AP设备信息上报UDP服务器功能。
AP设备信息上报UDP服务器功能处于关闭状态。
# 开启AP设备信息上报UDP服务器功能。
[Sysname] client-proximity-sensor report-ap enable
client-proximity-sensor report-oasis cache enable命令用来开启探针AP上报云平台缓存功能。
undo client-proximity-sensor report-oasis cache enable命令用来关闭探针AP上报云平台缓存功能。
探针上报云平台缓存功能处于关闭状态。
开启探针AP上报云平台缓存功能后,当设备与云平台连接断开时,设备会将探针表项缓存在本地,等到连接恢复后再上报到云平台。
# 配置开启探针AP上报云平台缓存功能。
[Sysname] client-proximity-sensor report-oasis cache enable
client-proximity-sensor report-oasis client命令用来配置客户端表项上报云平台的时间间隔和上报个数。
undo client-proximity-sensor report-oasis命令用来恢复缺省情况。
client-proximity-sensor report-oasis client interval interval number number
undo client-proximity-sensor report-oasis client
客户端表项上报云平台的时间间隔为1000毫秒,上报个数为10。
interval interval:客户端表项上报云平台的时间间隔,取值范围100~60000,单位为毫秒。
number number:客户端表项上报云平台时每次的上报个数,取值范围1~100。
# 配置客户端表项上报云平台的时间间隔为500毫秒,上报个数为50。
[Sysname] client-proximity-sensor report-oasis client interval 500 number 50
client-proximity-sensor report-oasis disable命令用来关闭上报云平台功能。
undo client-proximity-sensor report-oasis disable命令用来恢复缺省情况。
上报云平台功能处于开启状态。
# 关闭上报云平台功能。
[Sysname] client-proximity-sensor report-oasis disable
client-proximity-sensor report-oasis rssi-change-threshold命令用来配置上报云平台的客户端信号强度变化阈值。
undo client-proximity-sensor report-oasis rssi-change-threshold命令用来恢复缺省情况。
client-proximity-sensor report-oasis rssi-change-threshold threshold-value
上报云平台的客户端信号强度变化阈值为50。
rssi-change-threshold threshold-value:指定上报云平台的客户端信号强度变化阈值,取值范围为1~100。
如果同一客户端被探针AP检测到两次,并且检测到的信号强度不同,如果变化值小于阈值则不上报云平台。
# 配置上报云平台的客户端信号强度变化阈值为50。
[Sysname] client-proximity-sensor report-oasis rssi-change-threshold 50
client-proximity-sensor rssi-change-threshold命令用来配置探针AP检测的设备信号强度变化阈值。
undo client-proximity-sensor rssi-change-threshold命令用来恢复缺省情况。
client-proximity-sensor rssi-change-threshold threshold-value
探针AP检测的设备信号强度变化阈值为100。
threshold-value:探针AP检测的设备信号强度变化阈值,取值范围为1~100。
当同一设备再次被探针AP检测到后,信号强度的变化小于阈值则不会更新表项。
# 配置探针AP检测的设备信号强度变化阈值为50。
[Sysname] client-proximity-sensor rssi-change-threshold 50
client-proximity-sensor rssi-threshold命令用来配置探针AP根据信号强度对无线设备进行检测。
undo client-proximity-sensor rssi-threshold命令用来恢复缺省情况。
client-proximity-sensor rssi-threshold { ap ap-rssi-value | client client-rssi-value }
undo client-proximity-sensor rssi-threshold { ap | client }
未配置探针AP根据信号强度对无线设备进行检测。
ap ap-rssi-value:探针AP检测AP设备信号强度阈值,取值范围为1~100。
client client-rssi-value:探针AP检测客户端信号强度阈值,取值范围为1~100。
缺省情况下,探针AP会检测任意信号强度的无线设备,配置该功能后,探针AP仅检测信号强度大于或等于阈值的无线设备。
# 配置探针AP检测信号强度大于30的AP设备。
[Sysname] client-proximity-sensor rssi-threshold ap 30
client-proximity-sensor rt-report enable命令用来开启快速上报UDP服务器功能。
undo client-proximity-sensor rt-report enable命令用来关闭快速上报UDP服务器功能。
快速上报UDP服务器功能处于关闭状态。
缺省情况下,探针AP和AC会在指定的上报周期上报UDP服务器,开启该功能后,探针AP和AC在获取到无线设备信息后会立即进行上报。
# 开启快速上报UDP服务器功能。
[Sysname] client-proximity-sensor rt-report enable
client-proximity-sensor server命令用来配置上报无线设备信息的HTTPS服务器。
undo client-proximity-sensor server命令用来恢复缺省情况。
client-proximity-sensor server string [ window-time window-time-value | partner partner-value ] *
未配置上报无线设备信息的HTTPS服务器。
string:指定上报无线设备信息的HTTPS服务器地址,为8~127个字符的字符串,区分大小写。必须以“https://”作为前缀。
window-time window-time-value:统计周期,取值范围为10~60,单位为秒。在配置了HTTPS服务器地址后,缺省统计周期为30秒。
partner partner-value:上传给服务器的报文中partner flag字段的取值,在配置了HTTPS服务器地址后,缺省值为11。
# 配置上报无线设备信息的HTTPS服务器地址为https://10.152.3.209:443/xxx/yy。
[Sysname] client-proximity-sensor server https://10.152.3.209:443/xxx/yy
client-proximity-sensor timezone-offset命令用来配置探针AP与AC的时区差。
undo client-proximity-sensor timezone-offset命令用来恢复缺省情况。
client-proximity-sensor timezone-offset { add | minus } timevalue
未配置探针AP与AC的时区差。
AP视图
add:配置探针AP与AC的时区差为正。
minus:配置探针AP与AC的时区差为负。
timevalue:配置探针AP与AC的时区差,格式为hh:mm:ss。
# 配置探针AP与AC的时区差为11小时。
[Sysname-ap-ap1] client-proximity-sensor timezone-offset add 11:00:00
client-proximity-sensor udp-server命令用来配置上报无线设备信息的UDP服务器。
undo client-proximity-sensor udp-server命令用来恢复缺省情况。
client-proximity-sensor udp-server ip-address port port-number [ interval interval | preshared-key { cipher | simple } key-string ] *
未配置上报无线设备信息的UDP服务器。
# 配置上报无线设备信息的UDP服务器,IP地址为10.152.3.209,UDP服务器的端口号为443。
[Sysname] client-proximity-sensor udp-server 10.152.3.209 port 443
display client-proximity-sensor device命令用来显示探针AP检测到的无线设备信息。
display client-proximity-sensor device [ ap | client | mac-address mac-address ] [ verbose ]
ap:显示探针AP检测到的AP设备。
client:显示探针AP检测到的客户端设备。
mac-address mac-address:显示指定MAC地址的无线设备,格式为H-H-H。
verbose:显示详细信息,若不指定该参数,则显示探针AP检测到的所有无线设备的简要信息。
# 显示探针AP检测到的所有无线设备的信息。
<Sysname> display client-proximity-sensor device
Total 3 detected devices
MAC address Type Duration Sensors Channel Status
0AFB-423B-893C AP 00h 10m 46s 1 11 Active
0AFB-423B-893D AP 00h 10m 46s 1 6 Active
0AFB-423B-893E AP 00h 10m 46s 1 1 Active
表1-1 display client-proximity-sensor device命令显示信息描述表
| 字段 | 描述 |
| MAC address | 检测到的无线设备的MAC地址 |
| Type | 无线设备的类型: · AP:AP设备 · Client:无线客户端 |
| Duration | 无线设备当前状态的持续时间 |
| Sensors | 检测到该无线设备的Sensor的数量 |
| Channel | 最后一次检测到该无线设备的信道 |
| Status | 无线设备的工作状态: · Active:无线设备处于活跃状态 · Inactive:无线设备处于非活跃状态 |
# 显示探针AP检测到的所有无线设备的详细信息。
<Sysname> display client-proximity-sensor device verbose
Total 2 detected devices
AP: 0AFB-423B-893C
Status: Active
Status duration: 00h 27m 57s
Vendor: Not found
SSID: service
Radio type: 802.11ac
Security: None
Encryption method: None
Authentication method: None
Broadcast SSID: Yes
QoS supported: No
Beacon interval: 100 TU
Up duration: 00h 27m 57s
Channel bandwidth supported: 20/40/80MHz
Total number of reported APs: 1
AP 1:
AP ID: 3
AP name: 1
Radio ID: 1
RSSI: 15
Channel: 419
First detected time: 2016-04-03/09:05:51
Last detected time: 2016-04-03/09:05:51
Total number of associated clients: 1
01: 80EA-9656-AAAB
Client: 80EA-9656-AAAB
Last detected associated AP: 0AFB-423B-893C
Status: Active
Status duration: 00h 00m 02s
Vendor: Not found
Radio type: 802.11a
AP 1:
AP ID: 2
AP name: 1
Radio ID: 1
RSSI: 50
Channel: 116
First detected time: 2016-04-03/14:52:56
Last detected time: 2016-04-03/14:52:56
Detected associated AP: 0AFB-423B-893C
表1-2 display client-proximity-sensor device verbose命令显示信息描述表
| 字段 | 描述 |
| Total number detected devices | 检测到无线设备的总数 |
| AP | 检测到AP的MAC地址 |
| Client | 检测到Client的MAC地址 |
| Last detected associated AP | 客户端最近一次上报关联AP的MAC地址,此MAC地址为实际检测到的AP的BSSID |
| Status | AP或客户端表项的状态: · Active:AP或客户端表项处于活跃状态 · Inactive:AP或客户端表项处于非活跃状态 |
| Status duration | 无线设备当前状态的持续时间 |
| Vendor | 无线设备厂商信息。如果该无线设备的OUI能够匹配import oui命令导入配置文件中的OUI,则显示设备厂商,没有配置或者没有匹配到显示为Not found |
| SSID | AP提供的SSID |
| Radio Type | 无线设备使用的射频模式 |
| Security | 无线服务使用的安全模式: · WEP:WEP模式 · WPA:WPA模式 · WPA2:WPA2模式 · None:明文方式 |
| Encryption method | 无线数据的加密方式: · TKIP:使用TKIP加密套件 · CCMP:使用AES-CCMP加密套件 · WEP:使用WEP加密套件 · None:明文方式,不加密 |
| Authentication method | AP提供的接入无线网络的认证方式: · PSK:使用PSK认证方式 · 802.1X:使用802.1X认证方式 · Others:使用除PSK和802.1X之外的认证方式 · None:不认证 |
| Broadcast SSID | AP是否是广播SSID,如果AP不广播SSID,则SSID字段取值为空 |
| QoS supported | 是否支持QoS |
| Beacon interval | 信标间隔,单位为TU,1TU等于1024微秒 |
| Up duration | AP设备从启动到当前的持续时间 |
| Channel bandwidth supported | AP支持的信道带宽: · 20/40MHZ:AP支持20MHz和40MHz的信道带宽 · 20MHZ:AP支持20MHz的信道带宽 |
| Total number of reported APs | 上报该无线客户端的AP总数 |
| AP n | 发现该设备的Sensor,n为系统自动的编号 |
| AP ID | Sensor的ID,即Sensor的AP ID |
| AP name | 检测到该无线设备的Sensor的名字 |
| Radio ID | 发现该设备的Sensor上的Radio ID |
| RSSI | Sensor的信号强度 |
| Channel | 该Sensor最近一次探测到该AP或无线客户端设备的信道 |
| First detected time | 该Sensor第一次检测到该AP或无线客户端的时间 |
| Last detected time | 该Sensor最近一次检测到该AP或无线客户端的时间 |
| Total number of associated clients | 关联该设备的无线客户端的数量 |
| n:H-H-H | AP上关联的无线客户端的MAC地址,n为系统自动的编号 |
| Detected associated AP | 该Sensor上报关联AP的MAC地址 |
display client-proximity-sensor sensor命令用来显示所有探针AP的信息。
# 显示所有探针AP的信息。
<Sysname> display client-proximity-sensor sensor
Total number of sensors: 1
Sensor ID Sensor name Radio ID Status
3 ap1 1 Active
表1-3 display client-proximity-sensor sensor命令显示信息描述表
| 字段 | 描述 |
| Total number of sensors | 探针AP的总数 |
| Sensor ID | 探针AP的ID |
| Sensor name | 探针AP的设备名称 |
| Radio ID | 开启探针功能的射频 |
| Status | 探针AP的状态: · Active:探针AP处于活跃状态 · Inactive:探针AP处于非活跃状态 |
display client-proximity-sensor statistics receive命令用来显示探针AP上报的检测统计信息。
# 显示探针AP上报的检测统计信息。
<Sysname> display client-proximity-sensor statistics receive
Information from sensor 1
Statistics information for received messages:
Detected AP updated messages: 7
Detected client updated messages: 5
Detected AP deleted messages: 3
Detected client deleted messages: 0
Detected all device deleted messages: 0
Information from sensor 2
Detected AP updated messages: 6
Detected client deleted messages: 2
表1-4 display client-proximity-sensor statistics receive命令显示信息描述表
| 字段 | 描述 |
| Information from sensor n | Sensor n发送的消息,n表示Sensor ID |
| Statistics information for received messages | 检测信息的统计信息 |
| Detected AP updated messages | AP设备更新事件的计数 |
| Detected client updated messages | 客户端更新事件的计数 |
| Detected AP deleted messages | AP设备删除事件的计数 |
| Detected client deleted messages | 客户端删除事件的计数 |
| Detected all device deleted messages | 所有设备删除事件的计数 |
· reset client-proximity-sensor statistics
reset client-proximity-sensor device命令用来清除无线设备表项。
reset client-proximity-sensor device { ap | client | mac-address mac-address | all }
ap:清除所有检测到的AP信息。
client:清除所有检测到的客户端信息。
mac-address mac-address:清除指定MAC地址的信息,格式为H-H-H。
all:清除所有检测到的设备信息。
# 清除所有检测到的客户端信息。
<Sysname> reset client-proximity-sensor device client
# 清除指定MAC地址的设备信息。
<Sysname> reset client-proximity-sensor device mac-address 0023-1212-2323
· display client-proximity-sensor device
reset client-proximity-sensor statistics命令用来清除所有探针AP上报的信息。
# 清除所有探针AP上报的信息。
<Sysname> reset client-proximity-sensor statistics
· display client-proximity-sensor statistics receive
