24-IP路由基础命令
本章节下载: 24-IP路由基础命令 (461.22 KB)
1.1.1 display ip load-sharing mode
1.1.2 display ip load-sharing path
1.1.3 display ip routing-table
1.1.4 display ip routing-table acl
1.1.5 display ip routing-table ip-address
1.1.6 display ip routing-table prefix-list
1.1.7 display ip routing-table protocol
1.1.8 display ip routing-table statistics
1.1.9 display ip routing-table summary
1.1.10 display ipv6 rib graceful-restart
1.1.12 display ipv6 route-direct nib
1.1.13 display ipv6 routing-table
1.1.14 display ipv6 routing-table acl
1.1.15 display ipv6 routing-table ipv6-address
1.1.16 display ipv6 routing-table prefix-list
1.1.17 display ipv6 routing-table protocol
1.1.18 display ipv6 routing-table statistics
1.1.19 display ipv6 routing-table summary
1.1.20 display rib graceful-restart
1.1.22 display route-direct nib
1.1.24 ip load-sharing symmetric enable
1.1.25 ipv6 route fast-switchover enable
1.1.26 reset ip routing-table statistics protocol
1.1.27 reset ipv6 routing-table statistics protocol
display ip load-sharing mode命令用来显示当前使用的负载分担方式。
# 显示当前使用的负载分担方式。
<Sysname> display ip load-sharing mode slot 1
Load-sharing mode: per-flow
Load-sharing options: dest-ip | src-ip | ip-pro | dest-port | src-port | ingress-port
Load-sharing algorithm: 0
IP tunnel load-sharing mode: outer
Load-sharing algorithm: 1
Load-sharing algorithm: 2
表1-1 display ip load-sharing mode命令显示信息描述表
    字段  |
    描述  |
   Load-sharing mode  |
   采用的负载分担方式:per-flow表示基于报文逐流进行负载分担  |
   Load-sharing options  |
   负载分担时的选项: · dest-ip:基于报文的目的IP地址进行负载分担 · src-ip:基于报文的源IP地址进行负载分担 · ip-pro:基于报文的IP协议号进行负载分担 · dest-port:基于报文的目的端口进行负载分担 · src-port:基于报文的源端口进行负载分担 · ingress-port:基于报文的入端口进行负载分担  |
   Load-sharing algorithm  |
   负载分担算法编号  |
· ip load-sharing mode
display ip load-sharing path命令用来指定计算等价路由哈希选路的参数并显示计算出的等价路由哈希选路信息。
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address ] } [ dest-port port-id | ip-pro protocol-id | src-port port-id ] *
ingress-port interface-type interface-number:指定设备计算等价路由选路信息时的报文入接口。interface-type interface-number为接口类型和接口编号。
packet-format { ipv4oe dest-ip ip-address [src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address ] }:指定设备计算等价路由选路信息时的报文封装格式。
· ipv4oe:指定报文的封装格式为IPv4封装以太网。
· dest-ip ip-address:指定目的IP地址,为点分十进制格式。如果未指定该参数,则设备计算等价路由选路信息时使用的目的IP地址为0。
· src-ip ip-address:指定源IP地址,为点分十进制格式。如果未指定该参数,则设备计算等价路由选路信息时使用的源IP地址为0。
· ipv6oe:指定报文的封装格式为IPv6封装以太网。
· dest-ipv6 ipv6-address:指定目的IPv6地址。如果未指定该参数,则设备计算等价路由选路信息时使用的目的IPv6地址为0。
· src-ipv6 ipv6-address:指定源IPv6地址。如果未指定该参数,则设备计算等价路由选路信息时使用的源IPv6地址为0。
dest-port port-id:指定设备计算等价路由选路信息时的目的端口号,port-id取值范围为1~65535。如果未指定该参数,则设备计算等价路由选路信息时使用的目的端口号为0。
ip-pro protocol-id:指定设备计算等价路由选路信息时使用的IP协议类型,protocol-id取值范围为1~65535。如果未指定该参数,则设备计算等价路由选路信息时使用的IP协议类型值为0。
src-port port-id:指定设备计算等价路由选路信息时的源端口号,port-id取值范围为1~65535。如果未指定该参数,则设备计算等价路由选路信息时使用的源端口号为0。
本命令行的参数输入需要和display ip load-sharing mode命令显示的配置参数以及负载分担报文所携带的字段相匹配。如不匹配,则显示的等价路由哈希选路信息可能跟实际不一致。
# 指定设备计算等价路由选路信息时的参数:接口GigabitEthernet1/0/3进入,目的IP地址为10.110.0.2、源IP地址10.100.0.2、IP协议类型编号为153、目的端口号为2000、源端口号为2000。并显示计算出的报文的等价路由选路信息。
<Sysname> display ip load-sharing path ingress-port gigabitethernet 1/0/3 packet-format ipv4oe dest-ip 10.110.0.2 src-ip 10.100.0.2 ip-pro 153 dest-port 2000 src-port 2000
Load-sharing parameters:
Missing configured are set to 0.
ingress-port: GigabitEthernet1/0/3
packet-format: IPv4oE
dest-ip: 10.110.0.2
src-ip: 10.100.0.2
ip-pro: 153
dest-port: 2000
src-port: 2000
Path selected: 20.0.0.2(interface GigabitEthernet1/0/3)
表1-2 display ip load-sharing path命令显示信息描述表
    字段  |
    描述  |
   用户配置的逐流负载分担算法编号  |
   用户配置的逐流负载分担方式选项  |
   Load-sharing parameters  |
   用户输入信息,用于显示等价路由哈希选路信息  |
   Missing configured are set to 0.  |
   用户未明确输入参数采用缺省值0  |
   ingress-port  |
   报文入接口  |
   packet-format  |
   报文封装格式  |
   dest-ip  |
   目的IP地址  |
   src-ip  |
   源IP地址  |
   ip-pro  |
   IP协议类型  |
   dest-port  |
   目的端口号  |
   src-port  |
   源端口号  |
   Path selected  |
   计算出的等价路由哈希选路信息,包含下一跳的IP/IPv6地址和出接口  |
display ip routing-table命令用来显示路由表的信息。
display ip routing-table [ verbose ]
display ip routing-table all-routes
all-routes:显示公网的路由表信息。
verbose:显示全部路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
# 显示路由表中当前激活路由的概要信息。
<Sysname> display ip routing-table
Destinations : 12 Routes : 12
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
1.1.1.0/24 Static 60 0 192.168.47.4 Vlan12
Static 60 0 192.168.47.4 Vlan13
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.0/24 Direct 0 0 192.168.1.40 Vlan11
192.168.1.0/32 Direct 0 0 192.168.1.40 Vlan11
192.168.1.40/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.40 Vlan11
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# 显示公网中当前激活路由的概要信息。
<Sysname> display ip routing-table all-routes
VPN instance: public instance
Destinations : 10 Routes : 10
1.1.1.0/24 Static 60 0 192.168.47.4 Vlan11
表1-3 display ip routing-table命令显示信息描述表
    字段  |
    描述  |
   Destinations  |
   目的地址个数  |
   Routes  |
   路由条数  |
   Destination/Mask  |
   目的地址/掩码长度  |
   Proto  |
   发现该路由的路由协议类型: · Direct:直连路由 · Static:静态路由 · RIP:RIP路由协议 · OSPF:OSPF路由协议 · O_INTRA:OSPF区域内路由 · O_INTER:OSPF区域间路由 · O_ASE1:OSPF第一类外部路由 · O_ASE2:OSPF第二类外部路由 · O_SUM:OSPF聚合路由  |
   Pre  |
   路由的优先级  |
   Cost  |
   路由的度量值  |
   NextHop  |
   此路由的下一跳地址  |
   Interface  |
   出接口,即到该目的网段的数据包将从此接口发出  |
   Summary count  |
   路由数目  |
# 显示路由表的全部详细信息。
<Sysname> display ip routing-table verbose
Destinations : 13 Routes : 13
Destination: 0.0.0.0/32
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 08h34m37s
Cost: 0 Preference: 0
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active NoAdv
TableID: 0x2 OrigAs: 0
NibID: 0x10000000 LastAs: 0
AttrID: 0xffffffff Neighbor: 0.0.0.0
Flags: 0x1000c OrigNextHop: 127.0.0.1
Label: NULL RealNextHop: 127.0.0.1
BkLabel: NULL BkNextHop: N/A
SRLabel: NULL Interface: InLoopBack0
BkSRLabel: NULL BkInterface: N/A
Tunnel ID: Invalid IPInterface: InLoopBack0
BkTunnel ID: Invalid BKIPInterface: N/A
InLabel: NULL ColorInterface: N/A
SIDIndex: NULL BKColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: N/A
TrafficIndex: N/A BKTunnelInterface: N/A
Connector: N/A PathID: 0x0
SRTunnelID: Invalid
SID Type: N/A NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid StatFlags: 0x0
Exp: N/A
VpnPeerId: N/A Dscp: N/A
SID: N/A OrigLinkID: 0x0
BkSID: N/A RealLinkID: 0x0
CommBlockLen: 0
Destination: 1.1.1.0/24
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 04h20m37s
Cost: 0 Preference: 60
Tag: 0 State: Active Adv
NibID: 0x10000003 LastAs: 0
Flags: 0x1008c OrigNextHop: 192.168.47.4
Label: NULL RealNextHop: 192.168.47.4
SRLabel: NULL Interface: Vlan-interface12
Tunnel ID: Invalid IPInterface: Vlan-interface12
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
表1-4 display ip routing-table verbose命令显示信息描述表
    字段  |
    描述  |
   Destinations  |
   目的地址个数  |
   Routes  |
   路由条数  |
   Destination  |
   目的地址/掩码  |
   Protocol  |
   Process ID  |
   进程号  |
   SubProtID  |
   路由子协议ID  |
   Age  |
   此路由在路由表中存在的时间  |
   Cost  |
   路由的度量值  |
   Preference  |
   路由的优先级  |
   IpPre  |
   IP优先级值  |
   QosLocalID  |
   QoS本地ID,N/A表示无效值  |
   Tag  |
   路由标记  |
   State  |
   路由状态描述: · Active:有效的单播路由 · Adv:允许对外发送的路由 · Inactive:非激活路由标志 · NoAdv:不允许发布的路由 · Nat:NAT产生的路由 · TunE:Tunnel隧道的标志 · Derive:派生路由,即路由迭代的出接口不唯一时,第一条迭代路由外的其他迭代路由。携带此标记的路由不计入路由条数  |
   OrigTblID  |
   原始路由表ID  |
   OrigVrf  |
   (暂不支持)路由所属的原始VPN,显示为default-vrf表示公网  |
   TableID  |
   路由所在路由表的ID  |
   OrigAs  |
   (暂不支持)初始AS号  |
   NibID  |
   下一跳ID  |
   LastAs  |
   (暂不支持)最后AS号  |
   AttrID  |
   路由属性ID号  |
   Neighbor  |
   路由协议的邻居地址  |
   Flags  |
   路由标志位  |
   OrigNextHop  |
   此路由的下一跳地址  |
   Label  |
   (暂不支持)标签  |
   RealNextHop  |
   路由真实下一跳  |
   BkLabel  |
   (暂不支持)备份标签  |
   BkNexthop  |
   备份下一跳地址  |
   SRLabel  |
   (暂不支持)SR(Segment Routing,分段路由)标签  |
   BkSRLabel  |
   (暂不支持)SR备份标签  |
   SIDIndex  |
   (暂不支持)SID的索引值  |
   InLabel  |
   (暂不支持)路由入标签  |
   Tunnel ID  |
   隧道ID  |
   Interface  |
   BkTunnel ID  |
   备份隧道ID  |
   BkInterface  |
   备份出接口  |
   IPInterface  |
   IP出接口  |
   BkIPInterface  |
   备份IP出接口  |
   ColorInterface  |
   (暂不支持)Color出接口,即通过SR-MPLS TE Policy迭代的出接口  |
   BkColorInterface  |
   (暂不支持)备份Color出接口  |
   FtnIndex  |
   FTN表项索引  |
   TunnelInterface  |
   Tunnel出接口  |
   TrafficIndex  |
   流量统计索引值,取值范围为1~64,N/A表示无效值  |
   BkTunnelInterface  |
   备份Tunnel出接口  |
   Connector  |
   (暂不支持)表示BGP为MD VPN特性所携带的Connector属性,具体取值为BGP对等体在交换VPN-IPv4路由时携带源PE的地址,N/A表示没有该属性  |
   Summary count  |
   路由数目  |
   PathID  |
   路径ID  |
   SRTunnelID  |
   (暂不支持)SR隧道ID  |
   SID Type  |
   (暂不支持)SID类型,N/A表示没有该属性  |
   NID  |
   路由协议下刷的NHLFE(Next Hop Label Forwarding Entry,下一跳标签转发项)表项索引  |
   FlushNID  |
   实际向FIB下刷的NHLFE表项索引  |
   BkNID  |
   路由协议下刷的备份NHLFE表项索引  |
   BkFlushNID  |
   实际向FIB下刷的备份NHLFE表项索引  |
   StatFlags  |
   (暂不支持)SRv6流量统计标记  |
   VpnPeerId  |
   (暂不支持)路由所属的VPN peer ID值,取值范围为1~134217727,N/A表示无效值  |
   Dscp  |
   路由的DSCP优先级,取值范围为0~63,N/A表示无效值  |
   Exp  |
   路由的EXP优先级(仅BGP支持),N/A表示无效值  |
   SID  |
   (暂不支持)主用SID(Segment Identifier,段标识),N/A表示没有该属性  |
   BkSID  |
   (暂不支持)备用SID,N/A表示没有该属性  |
   CommBlockLen  |
   (暂不支持)Locator中的公共前缀长度  |
   OrigLinkID  |
   SDWAN TTE连接的原始Link ID  |
   RealLinkID  |
   SDWAN TTE连接的真实Link ID  |
display ip routing-table acl命令用来显示通过指定ACL过滤的路由信息。
display ip routing-table acl ipv4-acl-number [ verbose ]
ipv4-acl-number:基本ACL的编号,取值范围为2000~2999。
verbose:显示通过指定ACL过滤的所有路由的详细信息。如果未指定本参数,将只显示通过指定ACL过滤的激活路由的概要信息。
如果用户指定的ACL不存在或者ACL中没有任何规则,将显示所有的路由信息。
# 配置ACL 2000,并设置路由过滤规则。
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# 显示通过ACL 2000过滤的激活路由的概要信息。
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24 Direct 0 0 192.168.1.111 Vlan11
192.168.1.0/32 Direct 0 0 192.168.1.111 Vlan11
192.168.1.111/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.111 Vlan11
以上显示信息解释请参见表1-3。
# 显示通过ACL 2000过滤的所有路由的详细信息。
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
Protocol: Direct
Process ID: 0
SubProtID: 0x1 Age: 04h20m37s
Flags: 0x10080 OrigNextHop: 192.168.1.111
Label: NULL RealNextHop: 192.168.1.111
SRLabel: NULL Interface: Vlan-interface11
Tunnel ID: Invalid IPInterface: Vlan-interface11
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.0/32
Protocol: Direct
Process ID: 0
Flags: 0x1008c OrigNextHop: 192.168.1.111
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.111/32
Protocol: Direct
Process ID: 0
Flags: 0x10004 OrigNextHop: 127.0.0.1
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.255/32
Protocol: Direct
Process ID: 0
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
以上显示信息解释请参见表1-4。
display ip routing-table ip-address命令用来显示指定目的地址的路由信息。
display ip routing-table ip-address1 to ip-address2命令用来显示指定目的地址范围内的路由信息。
display ip routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table ip-address1 to ip-address2 [ verbose ]
ip-address:目的IP地址,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
longer-match:显示与指定目的网络匹配的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ip-address1 to ip-address2:IP地址范围。ip-address1和ip-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
使用不同的可选参数,命令的输出也不相同,以下是对该命令不同形式的输出说明:
(1) display ip routing-table ip-address
显示满足如下条件的所有激活路由:
· 用户输入的目的IP地址同路由表中各条路由的子网掩码值进行与运算;
· 路由表中各条路由的目的IP地址同其自身子网掩码值进行与运算;
· 两次运算结果相同的路由条目将被显示出来。
(2) display ip routing-table ip-address mask
显示满足如下条件的所有激活路由:
· 用户输入的目的IP地址同用户输入的子网掩码值进行与运算;
· 路由表中各条路由的目的IP地址同用户输入的子网掩码值进行与运算;
· 两次运算结果相同,并且掩码小于等于用户输入的子网掩码的路由条目将被显示出来。
(3) display ip routing-table ip-address longer-match
显示满足如下条件的所有激活路由:
· 用户输入的目的IP地址同子网掩码值进行与运算,有以下三种情况:
¡ 用户输入的目的IP地址得出其所对应的自然网段,取该自然网段对应的子网掩码默认值(A、B、C类IP地址对应的子网掩码默认值分别为255.0.0.0、255.255.0.0和255.255.255.0),再将用户输入的目的IP地址与对应的子网掩码默认值进行与运算。
¡ 如果用户输入的目的IP地址是0.0.0.0,将使用掩码0.0.0.0与其进行与运算。
¡ 除上述两种情况外(如环回地址),将使用掩码255.255.255.255与用户输入的目的IP地址进行与运算。
· 路由表中各条路由的目的IP地址同上一步得到的子网掩码值进行与运算;
· 两次运算结果相同的所有路由条目将被显示出来。
(4) display ip routing-table ip-address mask longer-match
显示满足如下条件的所有激活路由:
(5) display ip routing-table ip-address1 to ip-address2
显示ip-address1/32到ip-address2/32之间的激活路由,目的地址与掩码(32位)同时在指定范围内才会显示。
# 显示目的地址为11.0.0.1的路由信息。
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8 Static 60 0 0.0.0.0 NULL0
11.0.0.0/16 Static 60 0 0.0.0.0 NULL0
11.0.0.0/24 Static 60 0 0.0.0.0 NULL0
# 显示目的地址/掩码为11.0.0.1/20的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# 显示目的地址为11.0.0.1并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 3
# 显示目的地址/掩码为11.0.0.1/20并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 3
# 显示目的地址从1.1.1.0到5.5.5.0范围内的路由信息。
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 4
1.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.0/24 Direct 0 0 2.2.2.1 Vlan2
3.3.3.1/32 Direct 0 0 127.0.0.1 InLoop0
4.4.4.1/32 Direct 0 0 127.0.0.1 InLoop0
# 显示目的地址为1.2.3.4的路由的详细信息。
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
Destination: 1.2.3.4/32
Protocol: Static
Process ID: 0
SubProtID: 0x1 Age: 00h00m37s
NibID: 0x15000000 LastAs: 0
AttrID: 0x0 Neighbor: 0.0.0.0
Flags: 0x10060 OrigNextHop: 192.168.47.2
Label: NULL RealNextHop: 192.168.47.2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-3。
display ip routing-table prefix-list命令用来显示通过指定前缀列表过滤的路由信息。
display ip routing-table prefix-list prefix-list-name [ verbose ]
prefix-list-name:前缀列表名称,为1~63个字符的字符串,区分大小写。
verbose:当使用该参数时,显示通过过滤规则的所有路由的详细信息。如果未指定本参数,将只显示通过过滤规则的激活路由的概要信息。
如果指定的前缀列表不存在,将显示所有的路由信息。
# 配置地址前缀列表test允许前缀为1.1.1.0,掩码长度为24的路由通过。
[Sysname] ip prefix-list test permit 1.1.1.0 24
# 显示通过前缀列表test过滤的激活路由的概要信息。
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24 Direct 0 0 1.1.1.2 Vlan11
以上显示信息的解释请参见表1-3。
# 显示通过前缀列表test过滤的所有路由的详细信息。
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
Protocol: Direct
Process ID: 0
Flags: 0x1008c OrigNextHop: 1.1.1.2
Label: NULL RealNextHop: 1.1.1.2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-4。
display ip routing-table protocol命令用来显示指定协议生成或发现的路由信息。
display ip routing-table protocol protocol [ inactive | verbose ]
protocol:显示指定路由协议的信息。
inactive:显示未激活路由的信息。如果未指定本参数,则显示激活路由和未激活路由的信息。
verbose:当使用该参数时,显示路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有直连路由的概要信息。
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
2.2.2.0/32 Direct 0 0 2.2.2.1 Vlan2
2.2.2.2/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.255/32 Direct 0 0 2.2.2.1 Vlan2
Direct Routing table status : <Inactive>
Summary count : 0
# 显示静态路由表。
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
1.2.3.0/24 Static 60 0 1.2.4.5 Vlan10
display ip routing-table statistics命令用来显示路由表中路由或前缀的统计信息。
display ip routing-table [ all-routes ] [ prefix ] statistics
all-routes:显示公网的信息。
prefix:显示前缀的统计信息。如果不指定本参数,则显示路由的统计信息。
如果不指定任何参数,将显示公网的信息。
# 显示路由表中的综合路由统计信息。
<Sysname> display ip routing-table statistics
Total prefixes: 15 Active prefixes: 15
Proto Routes Active Added Deleted
DIRECT 12 12 30 18
STATIC 3 3 5 2
UNR 0 0 0 0
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 15 15 35 20
# 显示公网的前缀统计信息。
<Sysname> display ip routing-table prefix statistics
Proto Prefixes Active Added Deleted
DIRECT 7 7 7 0
STATIC 0 0 0 0
UNR 0 0 0 0
RIP 1 0 1 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 8 7 8 0
表1-5 display ip routing-table statistics命令显示信息描述表
    字段  |
    描述  |
   Total prefixes  |
   总的前缀数目  |
   Active prefixes  |
   总的激活前缀数目  |
   Proto  |
   路由协议,仅支持直连路由和静态路由  |
   Route  |
   总的路由数目  |
   Prefixes  |
   前缀数目  |
   Active  |
   活跃的、正在使用的路由数目  |
   Added  |
   路由器启动后或在上一次清除路由表后,路由表中添加的路由数目  |
   Deleted  |
   标记为删除的路由数目(此类路由在等待一段时间后会被释放)  |
   Total  |
   各种类型路由数目的总和  |
display ip routing-table summary命令用来显示路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
# 显示公网的路由表概要信息。
<Sysname> display ip routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
表1-6 display ip routing-table summary命令显示信息描述表
    字段  |
    描述  |
   Max ECMP  |
   (暂不支持)最大等价路由数  |
   Max Active Route  |
   最多支持激活路由前缀数  |
   Remain Active Route  |
   剩余可激活路由前缀数  |
display ipv6 rib graceful-restart命令用来显示IPv6 RIB的GR状态信息。
# 显示IPv6 RIB的GR状态信息。
<Sysname> display ipv6 rib graceful-restart
RIB GR state : Phase2-calculation end
RCOM GR state : Flush end
Protocol GR state:
No. Protocol Lifetime FD State Start/End
1 DIRECT6 480 29 End No/No
2 STATIC6 480 32 End No/No
3 OpenR6 480 83 End No/No
以上显示信息的解释请参见表1-10。
display ipv6 rib nib命令用来显示IPv6 RIB的下一跳信息。
display ipv6 rib nib [ sub-nib nib-id ] [ verbose ]
self-originated:路由管理自己生成的下一跳。
sub-nib:根据子下一跳查找组合下一跳信息。
nib-id:路由下一跳ID值,取值范围为十六进制数1~ffffffff。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议的下一跳信息。
# 显示IPv6 RIB的下一跳信息。
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
NibID: 0x20000000 Sequence: 0
Type: 0x1 Flushed: Yes
UserKey0: 0x0 VrfNthp: 0
UserKey1: 0x0 Nexthop: ::
UserKey2: 0x0 IFIndex: 0x111
UserKey3: 0x0 LocalAddr: ::
TopoNthp: Invalid ExtType: 0x0
Color: 0 COFlag: 0x0
LinkID: 0x0
SIDIndex: 0x0 SRPName:
OriNexthop: ::
NibID: 0x20000001 Sequence: 1
UserKey1: 0x0 Nexthop: ::1
UserKey2: 0x0 IFIndex: 0x112
UserKey3: 0x0 LocalAddr: ::1
LinkID: 0x0
OriNexthop: ::
# 显示IPv6 RIB下一跳的详细信息。
<Sysname> display ipv6 rib nib verbose
LinkID: 0x0
OriNexthop: ::
RefCnt: 4 FlushRefCnt: 1
Flag: 0x84 Version: 1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::
RelyDepth: 0 RealNexthop: ::
Interface: NULL0 LocalAddr: ::
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology:
Weight: 0 Flags: 0x0
SRPolicyNID: 4294967295 SRInterface:
ColorWeight: 0 Locator: N/A
OrigLinkID: 0x0 RealLinkID: 0x0
LinkID: 0x0
OriNexthop: ::
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::1
RelyDepth: 0 RealNexthop: ::1
Interface: InLoop0 LocalAddr: ::1
NibID: 0x26000002 Sequence: 1
UserKey1: 0x0 Nexthop: 122::2
UserKey3: 0x0 LocalAddr: 122::2
LinkID: 0x0
OriNexthop: ::
Instance: abc
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 122::2
RelyDepth: 0 RealNexthop: 122::2
display ipv6 route-direct nib命令用来显示IPv6直连路由下一跳信息。
nib-id:路由邻居ID值,取值范围为十六进制数1~ffffffff。
# 显示IPv6直连路由下一跳信息。
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
LinkID: 0x0
OriNexthop: ::
LinkID: 0x0
OriNexthop: ::
# 显示IPv6直连路由下一跳详细信息。
<Sysname> display ipv6 route-direct nib verbose
LinkID: 0x0
OriNexthop: ::
RefCnt: 1 FlushRefCnt: 0
Flag: 0x2 Version: 1
1 nexthop(s):
LinkID: 0x0
OriNexthop: ::
1 nexthop(s):
display ipv6 routing-table命令用来显示IPv6路由表的信息。
display ipv6 routing-table [ verbose ]
display ipv6 routing-table all-routes
verbose:显示IPv6路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
# 显示当前路由表的概要信息。
<Sysname> display ipv6 routing-table
Destinations : 3 Routes : 3
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 6::/64 Protocol : Static
NextHop : 5::2 Preference: 60
Interface : GE1/0/1 Cost : 0
Interface : GE1/0/2 Cost : 0
Destination: FE80::/10 Protocol : Direct
NextHop : :: Preference: 0
Destination: FF00::/8 Protocol : Direct
Interface : NULL0 Cost : 0
表1-7 display ipv6 routing-table命令显示信息描述表
    字段  |
    描述  |
   Destinations  |
   目的地址个数  |
   Routes  |
   路由条数  |
   Destination  |
   目的网络/主机的IPv6地址和前缀  |
   NextHop  |
   下一跳地址  |
   Preference  |
   路由优先级  |
   Interface  |
   出接口,即到该目的地址的数据包将从此接口发出  |
   Protocol  |
   发现该路由的路由协议类型: · Direct:直连路由 · Static:静态路由 · RIPng:RIPng路由协议  |
   Cost  |
   路由的开销值  |
   Summary count  |
   路由数目  |
# 显示路由表的详细路由信息。
<Sysname> display ipv6 routing-table verbose
Destinations : 6 Routes : 6
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 19h23m02s
TableID: 0xa OrigAs: 0
NibID: 0x20000000 LastAs: 0
AttrID: 0xffffffff Neighbor: ::
Flags: 0x10004 OrigNextHop: ::1
Label: NULL RealNextHop: ::1
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 6::/64
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 00h01m47s
NibID: 0x21000000 LastAs: 0
Flags: 0x10080 OrigNextHop: 5::2
Label: NULL RealNextHop: 3::3
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 12::/96
Protocol: Direct
Process ID: 0
NibID: 0x20000003 LastAs: 0
Flags: 0x10080 OrigNextHop: ::
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 12::1/128
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h01m45s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
表1-8 display ipv6 routing-table verbose命令显示信息描述表
    字段  |
    描述  |
   Destination  |
   目的网络/主机的IPv6地址和前缀  |
   Protocol  |
   Process ID  |
   进程号  |
   SubProtID  |
   路由子协议ID  |
   Age  |
   此路由在路由表中存在的时间  |
   Cost  |
   路由的度量值  |
   Preference  |
   路由的优先级  |
   IpPre  |
   IP优先级值  |
   QosLocalID  |
   QoS本地ID,N/A表示无效值  |
   Tag  |
   路由标记  |
   State  |
   OrigTblID  |
   原始路由表ID  |
   OrigVrf  |
   TableID  |
   路由所在路由表的ID  |
   OrigAs  |
   (暂不支持)初始AS号  |
   NibID  |
   下一跳ID  |
   LastAs  |
   (暂不支持)最后AS号  |
   AttrID  |
   路由属性ID号  |
   Neighbor  |
   路由协议的邻居地址  |
   Flags  |
   路由标志位  |
   OrigNextHop  |
   此路由的下一跳地址  |
   Label  |
   (暂不支持)标签  |
   RealNextHop  |
   路由真实下一跳  |
   BkLabel  |
   (暂不支持)备份标签  |
   BkNexthop  |
   备份下一跳地址  |
   SRLabel  |
   BkSRLabel  |
   (暂不支持)SR备份标签  |
   SIDIndex  |
   (暂不支持)SID的索引值  |
   InLabel  |
   (暂不支持)路由入标签  |
   Tunnel ID  |
   隧道ID  |
   Interface  |
   BkTunnel ID  |
   备份隧道ID  |
   BkInterface  |
   备份出接口  |
   IPInterface  |
   IP出接口  |
   BkIPInterface  |
   备份IP出接口  |
   ColorInterface  |
   BkColorInterface  |
   (暂不支持)备份Color出接口  |
   TunnelInterface  |
   Tunnel出接口  |
   BkTunnelInterface  |
   备份Tunnel出接口  |
   FtnIndex  |
   FTN表项索引  |
   TrafficIndex  |
   Connector  |
   PathID  |
   路径ID  |
   SRTunnelID  |
   (暂不支持)SR隧道ID  |
   SID Type  |
   NID  |
   FlushNID  |
   BkNID  |
   BkFlushNID  |
   StatFlags  |
   (暂不支持)SRv6流量统计标记  |
   VpnPeerId  |
   Dscp  |
   Exp  |
   SID  |
   BkSID  |
   CommBlockLen  |
   OrigLinkID  |
   RealLinkID  |
display ipv6 routing-table acl命令用来显示通过指定IPv6 ACL过滤的IPv6路由信息。
display ipv6 routing-table acl ipv6-acl-number [ verbose ]
ipv6-acl-number:基本IPv6 ACL编号,取值范围为2000~2999。
verbose:显示通过指定IPv6 ACL过滤的所有路由的详细信息。如果未指定本参数,只显示通过IPv6 ACL过滤的激活路由的概要信息。
如果指定的IPv6 ACL不存在或者IPv6 ACL中没有任何规则,将显示所有的IPv6路由信息。
# 显示通过IPv6 ACL 2000过滤的激活路由的概要信息。
<Sysname> display ipv6 routing-table acl 2000
Summary count : 6
Destination : ::1/128 Protocol : Direct
Destination: 12::/96 Protocol : Direct
Interface : Vlan11 Cost : 0
Destination: 12::1/128 Protocol : Direct
以上显示信息的解释请参见表1-7。
# 显示通过IPv6 ACL 2000过滤的所有路由的详细信息。
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 19h29m12s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h07m57s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-8。
display ipv6 routing-table ipv6-address命令用来显示指定目的地址的IPv6路由信息。
display ipv6 routing-table ipv6-address1 to ipv6-address2命令用来显示指定目的地址范围内的IPv6路由信息。
display ipv6 routing-table ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address:IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
longer-match:显示满足匹配条件的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ipv6-address1 to ipv6-address2:IPv6地址范围。ipv6-address1和ipv6-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示激活路由的概要信息。
(1) display ipv6 routing-table ipv6-address
显示满足如下条件的所有激活路由:
· 用户输入的目的IPv6地址同路由表中各条路由的前缀长度值进行与运算;
· 路由表中各条路由的目的IPv6地址同其自身前缀长度值进行与运算;
(2) display ipv6 routing-table ipv6-address prefix-length
显示满足如下条件的所有激活路由:
· 用户输入的目的IPv6地址同用户输入的前缀长度值进行与运算;
· 路由表中各条路由的目的IPv6地址同用户输入的前缀长度值进行与运算;
· 两次运算结果相同,并且路由表中前缀长度小于等于用户输入的前缀长度的路由条目将被显示出来。
(3) display ipv6 routing-table ipv6-address longer-match
用户未指定前缀长度时,显示结果与display ipv6 routing-table命令的显示结果相同。
(4) display ipv6 routing-table ipv6-address prefix-length longer-match
显示满足如下条件的所有激活路由:
(5) display ipv6 routing-table ipv6-address1 to ipv6-address2
显示ipv6-address1/128到ipv6-address2/128之间的路由,目的IPv6地址与前缀长度(128位)同时在指定范围内才会显示。
# 显示目的IPv6地址/前缀为10::1/127的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64 Protocol : Static
NextHop : :: Preference: 60
Destination: 10::/68 Protocol : Static
Destination: 10::/120 Protocol : Static
# 显示目的IPv6地址/前缀为10::1/127并且满足匹配条件的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 3
# 显示目的IPv6地址从100::到300::范围内的IPv6路由信息。
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64 Protocol : Static
Destination: 200::/64 Protocol : Static
Destination: 300::/64 Protocol : Static
· display ipv6 routing-table
display ipv6 routing-table prefix-list命令用来显示通过指定前缀列表过滤的IPv6路由信息。
display ipv6 routing-table prefix-list prefix-list-name [ verbose ]
prefix-list-name:IPv6前缀列表的名称,为1~63个字符的字符串,区分大小写。
verbose:显示所有路由的详细信息。如果未指定本参数,只显示激活路由的概要信息。
# 配置地址前缀列表test允许前缀为::1,前缀长度为128的IPv6路由通过。
[Sysname] ipv6 prefix-list test permit ::1 128
# 显示通过前缀列表test过滤的IPv6激活路由的概要信息。
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
以上显示信息的解释请参见表1-7。
# 显示通过前缀列表test过滤的所有IPv6路由的详细信息。
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 08h57m19s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-8。
display ipv6 routing-table protocol命令用来显示指定协议生成或发现的IPv6路由信息。
display ipv6 routing-table protocol protocol [ inactive | verbose ]
inactive:如果配置了该参数,此命令只显示未激活路由信息。如果未指定本参数,将显示所有激活和未激活路由信息。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有IPv6直连路由的概要信息。
<Sysname> display ipv6 routing-table protocol direct
Summary count : 3
Summary count : 3
Summary count : 0
# 显示IPv6静态路由表。
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128 Protocol : Static
NextHop : fe80::2 Preference: 60
Interface : Vlan12 Cost : 0
NextHop : fe80::3 Preference: 60
Destination: 3::3/128 Protocol : Static
NextHop : 2::2 Preference: 60
Summary count : 0
display ipv6 routing-table statistics命令用来显示IPv6路由表中路由或前缀的统计信息。
display ipv6 routing-table [ all-routes ] [ prefix ] statistics
all-routes:显示公网的信息。
如果不指定任何参数时,则显示公网的信息。
# 显示综合路由统计信息。
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8 Active prefixes: 8
DIRECT 5 5 5 0
STATIC 3 3 3 0
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 8 8 8 0
# 显示公网的IPv6前缀统计信息。
<Sysname> display ipv6 routing-table prefix statistics
DIRECT 5 5 5 0
STATIC 1 1 1 0
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 6 6 6 0
表1-9 display ipv6 routing-table statistics命令显示信息描述表
    字段  |
    描述  |
   Total prefixes  |
   总的前缀数目  |
   Active prefixes  |
   总的激活前缀数目  |
   Proto  |
   路由协议,仅支持直连路由和静态路由  |
   Routes  |
   总的路由数目  |
   Prefixes  |
   前缀数目  |
   Active  |
   激活的、正在使用的路由数目  |
   Added  |
   Deleted  |
   Total  |
   各种类型路由数目的总和  |
display ipv6 routing-table summary命令用来显示IPv6路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
# 显示公网的路由表概要信息。
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
以上显示信息的解释请参见表1-6。
display rib graceful-restart命令用来显示RIB的GR状态信息。
# 显示RIB的GR状态信息。
<Sysname> display rib graceful-restart
Protocol GR state:
1 DIRECT 100 30 End No/No
2 STATIC 480 34 End No/No
表1-10 display rib graceful-restart命令显示信息描述表
    字段  |
    描述  |
   RIB GR state  |
   RIB GR状态: · Start:协议GR开始 · IGP end:所有IGP协议GR结束 · Routing protocol end:所有路由协议GR结束 · NSR-calculation unfinished:NSR优选未完成状态 · Triggering start:所有路由触发优选开始 · Triggering end:所有路由触发优选结束 · Phase1-calculation end:第一阶段优选结束 · All end:所有协议GR结束 · Phase2-calculation end:第二阶段优选结束  |
   RCOM GR state  |
   RCOM GR状态: · Start:协议GR开始 · Routing protocol end:所有路由协议GR结束 · NSR-calculation unfinished:NSR优选未完成状态 · Phase1-calculation end:第一阶段优选结束 · Notification end:所有路由上报结束 · Phase2-calculation end:第二阶段优选结束 · Flush start:开始下刷FIB · Flush end:下刷FIB结束  |
   Protocol GR state  |
   协议GR状态  |
   No.  |
   编号  |
   Protocol  |
   协议名称  |
   Lifetime  |
   倒换过程中协议的路由信息/标签信息在RIB中的存活时间,单位为秒  |
   FD  |
   协议进程与RIB连接的句柄  |
   State  |
   协议GR状态: · Init:协议GR初始化状态 · Listen:协议GR监听状态 · Idle:协议GR空闲状态 · Active:协议GR激活状态 · Start:协议GR开始状态 · End:协议GR结束状态  |
   Start/End  |
   · No:表示该消息未发送 · Yes:表示该消息已发送  |
display rib nib命令用来显示RIB的下一跳信息。
display rib nib [ sub-nib nib-id ] [ verbose ]
self-originated:路由管理自己生成的下一跳信息。
nib-id:路由下一跳信息的ID值,取值范围为十六进制数1~ffffffff。
protocol protocol:显示指定路由协议生成的下一跳信息。
# 显示RIB的下一跳信息。
<Sysname> display rib nib
Total number of nexthop(s): 176
NibID: 0x10000000 Sequence: 0
UserKey1: 0x0 Nexthop: 0.0.0.0
UserKey3: 0x0 LocalAddr: 0.0.0.0
TopoNthp: 0 ExtType: 0x0
LinkID: 0x0
OriNexthop: 0.0.0.0
NibID: 0x10000001 Sequence: 1
UserKey1: 0x0 Nexthop: 127.0.0.1
UserKey3: 0x0 LocalAddr: 127.0.0.1
LinkID: 0x0
OriNexthop: 0.0.0.0
NibID: 0x10000002 Sequence: 2
Type: 0x5 Flushed: Yes
LinkID: 0x0
OriNexthop: 0.0.0.0
表1-11 display rib nib命令显示信息描述表
    字段  |
    描述  |
   Total number of Nexthop(s)  |
   总的下一跳个数  |
   NibID  |
   下一跳ID  |
   Sequence  |
   下一跳序列号  |
   Type  |
   下一跳类型  |
   Flushed  |
   是否下刷  |
   UserKey0  |
   第一个协议保留数据  |
   UserKey1  |
   第二个协议保留数据  |
   UserKey2  |
   第三个协议保留数据  |
   UserKey3  |
   第四个协议保留数据  |
   VrfNthp  |
   (暂不支持)下一跳所在VPN索引,显示为0表示公网  |
   Nexthop  |
   下一跳地址  |
   IFIndex  |
   接口索引  |
   LocalAddr  |
   本地接口地址  |
   TopoNthp  |
   (暂不支持子拓扑)下一跳所在拓扑索引,对于IPv4路由,显示为0表示公网拓扑;对于IPv6路由,显示为Invalid  |
   ExtType  |
   NIB扩展类型  |
   Color  |
   (暂不支持)Color扩展团体属性  |
   COFlag  |
   (暂不支持)Color的下一跳标志位  |
   LinkID  |
   SDWAN TTE连接的Link ID  |
   SIDIndex  |
   (暂不支持)SID的索引值  |
   SubNibID  |
   子下一跳的ID  |
   SubSeq  |
   子下一跳的序列号  |
   NthpCnt  |
   子下一跳的下一跳计数  |
   Samed  |
   子下一跳中相同下一跳计数  |
   NthpType  |
   IP:表示子下一跳类型是IP转发类型  |
   SRPName  |
   (暂不支持)SR-MPLS TE Policy的名称  |
   OriNexthop  |
   路由的原始下一跳地址  |
# 显示RIB下一跳详细信息。
<Sysname> display rib nib verbose
UserKey2: 0x0 IFIndex: 0x10002
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 6 FlushRefCnt: 2
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 0.0.0.0
RelyDepth: 0 RealNexthop: 0.0.0.0
Interface: NULL0 LocalAddr: 0.0.0.0
TunnelID: N/A Topology: base
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 11 FlushRefCnt: 5
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 127.0.0.1
RelyDepth: 0 RealNexthop: 127.0.0.1
Interface: InLoop0 LocalAddr: 127.0.0.1
NibID: 0x15000003 Sequence: 3
Type: 0x43 Flushed: Yes
UserKey0: 0x100010000 VrfNthp: 0
UserKey1: 0x0 Nexthop: 22.22.22.22
LinkID: 0x0
OriNexthop: 0.0.0.0
Instance: default
RefCnt: 9 FlushRefCnt: 3
Policy: tnl-policy1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 22.22.22.22
RelyDepth: 1 RealNexthop: 13.1.1.2
Interface: Vlan11 LocalAddr: 13.1.1.1
TunnelCnt: 1 Vrf: default-vrf
TunnelID: 1025 Topology: base
表1-12 display rib nib verbose命令显示信息描述表
    字段  |
    描述  |
   总的下一跳个数  |
   NibID  |
   下一跳ID  |
   Sequence  |
   下一跳序列号  |
   Type  |
   下一跳类型  |
   Flushed  |
   是否下刷  |
   UserKey0  |
   第一个协议保留数据  |
   UserKey1  |
   第二个协议保留数据  |
   UserKey2  |
   第三个协议保留数据  |
   UserKey3  |
   第四个协议保留数据  |
   VrfNthp  |
   Nexthop  |
   下一跳地址  |
   ExtType  |
   NIB扩展类型  |
   SubNibID  |
   子下一跳的ID  |
   SubSeq  |
   子下一跳的序列号  |
   NthpCnt  |
   子下一跳的下一跳计数  |
   Samed  |
   子下一跳中相同下一跳计数  |
   NthpType  |
   子下一跳类型: · IP:下一跳是IP转发类型 · MPLS:下一跳是MPLS转发类型  |
   Policy  |
   隧道策略名  |
   x nexthop (s)  |
   下一跳具体值(前面数值表示下一跳个数)  |
   PrefixIndex  |
   等价时下一跳序号  |
   Vrf  |
   (暂不支持)VPN实例名,显示为default-vrf表示公网  |
   OrigNexthop  |
   原始下一跳  |
   RealNexthop  |
   真实下一跳  |
   Interface  |
   出接口  |
   LocalAddr  |
   本地接口地址  |
   IFIndex  |
   接口索引  |
   TopoNthp  |
   Color  |
   (暂不支持)Color扩展团体属性  |
   COFlag  |
   LinkID  |
   SIDIndex  |
   (暂不支持)SID的索引值  |
   SRPName  |
   OriNexthop  |
   路由的原始下一跳地址  |
   RelyDepth  |
   迭代深度  |
   TunnelCnt  |
   迭代到隧道的个数  |
   TunnelID  |
   迭代到隧道的ID  |
   Topology  |
   (暂不支持子拓扑)拓扑名称,对于IPv4路由,显示为base表示公网拓扑;对于IPv6路由,显示为空  |
   Weight  |
   等价路由各路由的权重,取值为0表示不是等价路由  |
   RefCnt  |
   下一跳信息的引用计数  |
   FlushRefCnt  |
   下一跳信息的下刷引用计数  |
   Flag  |
   下一跳信息的标志位  |
   Version  |
   下一跳信息的版本号  |
   Flags  |
   当前下一跳的标志位  |
   SRPolicyNID  |
   (暂不支持)SR-MPLS TE Policy迭代路由的下一跳ID  |
   SRInterface  |
   (暂不支持)SR-MPLS TE Policy迭代路由的出接口  |
   ColorWeight  |
   (暂不支持)SR-MPLS TE Policy中Color的权重值  |
   Locator  |
   (暂不支持)SID所属Locator段的IPv6前缀,N/A表示没有该属性  |
   OrigLinkID  |
   RealLinkID  |
display route-direct nib命令用来显示直连路由下一跳信息。
# 显示直连路由下一跳信息。
<Sysname> display route-direct nib
Total number of nexthop(s): 116
LinkID: 0x0
OriNexthop: 0.0.0.0
LinkID: 0x0
OriNexthop: 0.0.0.0
表1-13 display route-direct nib命令显示信息描述表
    字段  |
    描述  |
   Total number of nexthop(s)  |
   总的下一跳个数  |
   NibID  |
   NIB ID号  |
   Sequence  |
   NIB序列号  |
   Type  |
   NIB类型  |
   Flushed  |
   是否下刷FIB  |
   UserKey0  |
   NIB协议保留数据1  |
   UserKey1  |
   NIB协议保留数据2  |
   UserKey2  |
   第三个协议保留数据  |
   UserKey3  |
   第四个协议保留数据  |
   Color  |
   (暂不支持)Color扩展团体属性  |
   COFlag  |
   LinkID  |
   SIDIndex  |
   (暂不支持)SID的索引值  |
   VrfNthp  |
   Nexthop  |
   下一跳信息  |
   IFIndex  |
   接口索引  |
   LocalAddr  |
   本地接口地址  |
   TopoNthp  |
   ExtType  |
   NIB扩展类型  |
   SRPName  |
   OriNexthop  |
   路由的原始下一跳地址  |
# 显示直连路由下一跳详细信息。
<Sysname> display route-direct nib verbose
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 2 FlushRefCnt: 0
1 nexthop(s):
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 5 FlushRefCnt: 0
1 nexthop(s):
表1-14 display route-direct nib verbose命令显示信息描述表
    字段  |
    描述  |
   总的下一跳个数  |
   NibID  |
   NIB ID号  |
   Sequence  |
   NIB序列号  |
   Type  |
   NIB类型  |
   Flushed  |
   是否下刷FIB  |
   UserKey0  |
   NIB协议保留数据1  |
   UserKey1  |
   NIB协议保留数据2  |
   UserKey2  |
   第三个协议保留数据  |
   UserKey3  |
   第四个协议保留数据  |
   VrfNthp  |
   Nexthop  |
   下一跳信息  |
   x nexthop (s)  |
   PrefixIndex  |
   等价时下一跳序号  |
   Vrf  |
   OrigNexthop  |
   原始下一跳  |
   RealNexthop  |
   真实下一跳  |
   Interface  |
   出接口  |
   localAddr  |
   本地接口地址  |
   RelyDepth  |
   迭代深度  |
   TunnelCnt  |
   迭代到隧道的个数  |
   TunnelID  |
   迭代到隧道的ID  |
   Topology  |
   Weight  |
   RefCnt  |
   下一跳信息的引用计数  |
   FlushRefCnt  |
   下一跳信息的下刷引用计数  |
   Flag  |
   下一跳信息的标志位  |
   Version  |
   下一跳信息的版本号  |
   IFIndex  |
   接口索引  |
   TopoNthp  |
   ExtType  |
   NIB扩展类型  |
   Color  |
   (暂不支持)Color扩展团体属性  |
   COFlag  |
   LinkID  |
   SIDIndex  |
   (暂不支持)SID的索引值  |
   SRPName  |
   OriNexthop  |
   路由的原始下一跳地址  |
   Flags  |
   具体下一跳信息的标志位  |
   SRPolicyNID  |
   SRInterface  |
   ColorWeight  |
   Locator  |
   OrigLinkID  |
   RealLinkID  |
ip load-sharing mode命令用来配置负载分担方式。
undo ip load-sharing mode命令用来恢复缺省情况。
ip load-sharing mode per-flow [ algorithm algorithm-number [ seed seed-number ] | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { all | inner | outer } ] global
undo ip load-sharing mode [ per-flow [ algorithm algorithm-number [ seed seed-number ] | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { all | inner | outer } ] ] global
设备使用基于报文的目的IP地址逐流进行报文的负载分担。
per-flow:基于报文逐流进行负载分担。
algorithm algorithm-number:基于报文逐流进行负载分担的算法切换。algorithm-number指定要进行算法切换的算法编号。本参数的取值范围为0~15。
seed seed-number:负载分担算法的起始HASH值。本参数的取值范围为0~ffff。
ingress-port:基于报文的入端口逐流进行负载分担。
global:表示全局配置。
当负载分担不够均匀时,可以通过修改seed参数的值来进行调整。
[Sysname] ip load-sharing mode per-flow
ip load-sharing symmetric enable命令用来开启对称负载分担功能。
undo ip load-sharing symmetric enable命令用来关闭对称负载分担功能。
开启对称负载分担功能后,对于源IP为A、目的IP为B的流量,和源IP为B、目的IP为A的流量,将负载分担到同一条路径。
# 开启对称负载分担功能。
[Sysname] ip load-sharing symmetric enable
ipv6 route fast-switchover enable命令用来开启IPv6路由快速切换功能。
undo ipv6 route fast-switchover enable命令用来关闭IPv6路由快速切换功能。
IPv6路由快速切换功能处于关闭状态。
在未开启本功能的情况下,当某个物理接口为大量路由(包括等价路由和主备路由的主路由)连接下一跳的出接口时,如果该接口所在的链路故障时,设备需要先删除失效链路对应的所有ND表项,然后通知FIB删除失效的FIB表项,处理时间过长,流量无法快速切换到可用路径。通过开启本功能,当接口所在的链路故障时,设备直接通知FIB删除失效的FIB表项,以加快路由的切换、缩短流量中断的时间。
# 开启IPv6路由快速切换功能。
[Sysname] ipv6 route fast-switchover enable
reset ip routing-table statistics protocol命令用来清除路由表中的路由统计信息。
reset ip routing-table statistics protocol { protocol | all }
reset ip routing-table [ all-routes ] statistics protocol { protocol | all }
all-routes:清除公网的路由统计信息。
protocol:清除IPv4路由表中指定路由协议的统计信息。
all:清除IPv4路由表中所有路由协议的统计信息。
如果没有指定all-routes参数,则清除公网的路由统计信息。
# 清除路由表中的路由统计信息。
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics protocol命令用来清除IPv6路由表中的综合路由统计信息。
reset ipv6 routing-table statistics protocol { protocol | all }
reset ipv6 routing-table [ all-routes ] statistics protocol { protocol | all }
protocol:清除IPv6路由表中指定路由协议的统计信息。
all:清除IPv6路由表中所有路由协议的统计信息。
# 清除IPv6路由表中所有路由协议的综合路由统计信息。
<Sysname> reset ipv6 routing-table statistics protocol all
