16-BRAS业务命令参考
12-Portal命令
本章节下载 12-Portal命令  (645.92 KB)
12-Portal命令
1 Portal
1.1 Portal配置命令
1.1.1 aging-time
1.1.2 authentication-timeout
1.1.3 binding-retry
1.1.4 captive-bypass enable
1.1.5 default-logon-page
1.1.6 display portal
1.1.7 display portal http-defense attacked-ip
1.1.8 display portal http-defense blocked-ip
1.1.9 display portal http-defense ip-count
1.1.10 display portal http-defense monitored-ip
1.1.11 display portal ip-subscriber message statistics
1.1.12 display portal mac-trigger entry
1.1.13 display portal mac-trigger-server
1.1.14 display portal mac-trigger-server packet statistics
1.1.15 display portal packet statistics
1.1.16 display portal rule
1.1.17 display portal server
1.1.18 display portal user
1.1.19 display portal user count
1.1.20 display portal web-server
1.1.21 display web-redirect rule
1.1.22 exclude-attribute
1.1.23 free-traffic threshold
1.1.24 if-match
1.1.25 ip (MAC binding server view)
1.1.26 ip (portal authentication server view)
1.1.27 ipv6
1.1.28 logon-page bind
1.1.29 logout-notify
1.1.30 nas-port-type
1.1.31 port (MAC binding server view)
1.1.32 port (portal authentication server view)
1.1.33 portal { bas-ip | bas-ipv6 } (interface view)
1.1.34 portal { ipv4-max-user | ipv6-max-user } (interface view)
1.1.35 portal access-info trust
1.1.36 portal apply mac-trigger-server
1.1.37 portal apply pre-auth-policy
1.1.38 portal apply web-server (interface view)
1.1.39 portal authorization strict-checking
1.1.40 portal delete-user
1.1.41 portal device-id
1.1.42 portal domain (interface view)
1.1.43 portal enable (interface view)
1.1.44 portal fail-permit server
1.1.45 portal free-rule
1.1.46 portal free-rule destination
1.1.47 portal free-rule source
1.1.48 portal http-defense
1.1.49 portal http-defense enable
1.1.50 portal http-defense max-ip-number
1.1.51 portal ipv6 layer3 source
1.1.52 portal ipv6 user-detect
1.1.53 portal layer3 source
1.1.54 portal local-web-server
1.1.55 portal mac-trigger-proxy ip
1.1.56 portal mac-trigger-server
1.1.57 portal max-user
1.1.58 portal nas-id-profile
1.1.59 portal nas-port-id format
1.1.60 portal pre-auth ip-pool
1.1.61 portal pre-auth policy
1.1.62 portal roaming enable
1.1.63 portal server
1.1.64 portal traffic-backup threshold
1.1.65 portal user log enable
1.1.66 portal user-block failed-times
1.1.67 portal user-block reactive
1.1.68 portal user-detect
1.1.69 portal user-dhcp-only
1.1.70 portal user-rule assign-check enable
1.1.71 portal web-proxy port
1.1.72 portal web-server
1.1.73 refresh portal
1.1.74 reset portal http-defense attacked-ip
1.1.75 reset portal http-defense blocked-ip
1.1.76 reset portal ip-subscriber message statistics
1.1.77 reset portal mac-trigger-server packet statistics
1.1.78 reset portal packet statistics
1.1.79 server-detect (portal authentication server view)
1.1.80 server-detect (portal web server view)
1.1.81 server-register
1.1.82 server-type
1.1.83 server-type (MAC binding server view)
1.1.84 tcp-port
1.1.85 url
1.1.86 url-parameter
1.1.87 user-attribute
1.1.88 user-sync
1.1.89 version
1.1.90 vpn-instance
1.1.91 web-redirect url
1 Portal
·     本特性仅在standard工作模式下支持。有关系统工作模式的介绍,请参见“基础配置指导”中的“设备管理”。
·     本功能仅CSPEX类单板(CSPEX-1104-E除外)支持。
1.1  Portal配置命令
1.1.1  aging-time
aging-time命令用来配置MAC-Trigger表项的老化时间。
undo aging-time命令用来恢复缺省情况。
aging-time seconds
undo aging-time
MAC-Trigger表项老化时间为300秒。
MAC绑定服务器视图
seconds:MAC-Trigger表项的老化时间,取值范围为60~7200,单位为秒。
开启了基于MAC地址的快速认证功能的设备,在检测到用户首次上线的流量后,会生成MAC-Trigger表项,用于记录用户的MAC地址、接口索引、VLAN ID、流量、定时器等信息。
当某条MAC-Trigger表项达到设定的老化时间时,该表项将被删除,设备再次检测到同一用户的流量时,会为其重新建立MAC-Trigger表项。
# 指定MAC-Trigger表项老化时间为300秒。
[Sysname] portal mac-trigger-server mts
[Sysname-portal-mac-trigger-server-mts] aging-time 300
·     display mac-trigger-server
authentication-timeout命令用来配置设备在收到MAC绑定服务器的查询响应消息后,等待Portal认证完成的超时时间。
undo authentication-timeout命令用来恢复缺省情况。
authentication-timeout minutes
设备在收到MAC绑定服务器的查询响应消息后,等待Portal认证完成的超时时间为3分钟。
MAC绑定服务器视图
minutes:设备等待Portal认证完成的超时时间,取值范围为1~15,单位为分钟。
设备在收到MAC绑定服务器的查询响应消息后,无论查询结果如何,都会启动定时器来记录用户进行Portal认证的时间。定时器超时后,设备将立即删除该用户的MAC-Trigger表项。
# 配置设备在收到MAC绑定服务器的查询响应消息后,等待Portal认证完成的超时时间为10分钟。
[Sysname-portal-mac-trigger-server-mts] authentication-timeout 10
1.1.3  binding-retry
binding-retry命令用来配置设备向MAC绑定服务器发起MAC查询的最大尝试次数和时间间隔。
undo binding-retry命令用来恢复缺省情况。
binding-retry { retries | interval interval } *
undo binding-retry
设备向MAC绑定服务器发起MAC地址查询的最大尝试次数为3次,查询时间间隔为1秒。
MAC绑定服务器视图
retries:最大尝试次数,取值范围为1~10。
interval interval:查询时间间隔,取值范围为1~60,单位为秒。
如果设备向MAC绑定服务器发起查询的次数达到最大尝试次数后,仍未收到服务器的响应,则设备认为服务器不可达。设备将对用户进行普通Portal认证,即需要用户在认证页面中输入用户名、密码来进行认证。
在同一MAC绑定服务器视图下多次执行本命令,最后一次执行的命令生效。
# 配置设备向MAC绑定服务器mts发起查询的最大尝试次数为3次,查询时间间隔为60秒。
[Sysname-portal-mac-trigger-server-mts] binding-retry 3 interval 60
captive-bypass enable命令用来开启Portal被动Web认证功能。
undo captive-bypass enable命令用来关闭Portal被动Web认证功能。
captive-bypass [ optimize ] enable
undo captive-bypass [ optimize ] enable
Portal被动Web认证功能处于关闭状态。
Portal Web服务器视图
optimize:开启Portal被动Web认证的优化功能。
# 开启Portal被动Web认证功能。
[Sysname] portal web-server wbs
[Sysname-portal-websvr-wbs] captive-bypass enable
# 开启Portal被动Web认证优化功能。
[Sysname-portal-websvr-wbs] captive-bypass optimize enable
·     display portal web-server
default-logon-page命令用来配置本地Portal Web服务提供的缺省认证页面文件。
undo default-logon-page命令用来恢复缺省情况。
default-logon-page file-name
本地Portal Web服务未提供缺省认证页面文件。
本地Portal Web服务视图
file-name:表示缺省认证页面文件名(不包括文件的保存路径),为1~91个字符的字符串,包括字母、数字、点和下划线。
指定的缺省认证页面文件由用户编辑,并将其打包成zip格式文件后上传到设备存储介质的根目录下。配置default-logon-page命令后设备会将指定的压缩文件进行解压缩,并设置为本地Portal Web服务为用户进行Portal认证提供的缺省认证页面文件。如果没有配置default-logon-page命令,则设备中就不存在为用户进行Portal认证的缺省认证页面文件,进而,用户无法进行正常的本地Portal认证。
# 配置本地Portal Web 服务器提供的缺省认证页面文件为pagefile1.zip。
[Sysname] portal local-web-server http
[Sysname-portal-local-websvr-http] default-logon-page pagefile1.zip
·     portal local-web-server
display portal命令用来显示Portal配置信息和Portal运行状态信息。
display portal interface interface-type interface-number
interface interface-type interface-number:表示接口类型和接口编号。
# 显示接口GigabitEthernet3/1/1的Portal配置信息和Portal运行状态信息。
<Sysname> display portal interface gigabitethernet 3/1/1
 Portal information of GigabitEthernet3/1/1
     NAS-ID profile: aaa
     Authorization : Strict checking
     ACL           : Enabled
     User profile  : Disabled
 IPv4:
     Portal status: Enabled
     Portal authentication method: Layer3
     Portal web server: wbs
     Portal mac-trigger-server: mts
     Authentication domain: my-domain
     Pre-auth policy: abc
     User-dhcp-only: Enabled
     Pre-auth IP pool: ab
     Max Portal users: Not configured
     Bas-ip: Not configured
     User detection: Type: ICMP  Interval: 300s  Attempts: 5  Idle time: 180s
     Action for sever detection:
         Server type    Server name                        Action
         Web server     wbs                                fail-permit
         Portal server  pts                                fail-permit
     Layer3 source network:
         IP address               Mask
         1.1.1.1                  255.255.0.0
IPv6:
     Portal status: Disabled
     Portal authentication method: Disabled
     Portal web server: Not configured
     Authentication domain: Not configured
     Pre-auth policy: Not configured
     User-dhcp-only: Disabled
     Pre-auth IP pool: Not configured
     Bas-ipv6: Not configured
     User detection: Not configured
         IP address                                        Prefix length
表1-1 display portal interface命令显示信息描述表
Portal information of interface
接口上的Portal信息
NAS-ID profile
接口上引用的NAS-ID profile
Authorization
服务器下发给Portal用户的授权信息类型,包括ACL和User profile
Strict checking
Portal授权信息的严格检查模式是否开启
IPv4
IPv4 Portal的相关信息
IPv6
IPv6 Portal的相关信息
Portal status
接口上Portal认证的运行状态,包括以下取值:
·     Disabled:Portal认证未开启
·     Enabled:Portal认证已开启
·     Authorized:Portal认证服务器或者Portal Web服务器不可达,端口自动开放
接口上配置的认证方式,包括以下取值:
·     Direct:直接认证方式
·     Redhcp:二次地址分配认证方式
·     Layer3:可跨三层认证方式
Portal Web server
接口上配置的Portal Web服务器的名称
接口上配置MAC绑定服务器的名称
接口上的Portal强制认证域
Pre-auth policy
接口上的Portal认证前策略,即Portal认证前用户使用的认证策略
User-dhcp-only
仅允许通过DHCP方式获取IP地址的客户端上线功能
·     Enabled:仅允许通过DHCP方式获取IP地址的客户端上线功能处于开启状态,表示仅允许通过DHCP方式获取IP地址的客户端上线
·     Disabled:仅允许通过DHCP方式获取IP地址的客户端上线功能处于关闭状态,表示通过DHCP方式获取IP地址的客户端和静态配置IP地址的客户端都可以上线
Pre-auth ip-pool
为认证前的Portal用户指定的IP地址池名称
Max Portal users
接口上配置的最大用户数
Bas-ip
发送给Portal认证服务器的Portal报文的BAS-IP属性
Bas-ipv6
发送给Portal认证服务器的Portal报文的BAS-IPv6属性
User detection
接口上配置的用户在线状态探测配置,包括探测的方法(ARP、ICMP、ND、ICMPv6),探测周期和探测尝试次数,用户闲置的时间
Action for server detection
服务器可达性探测功能对应的端口控制配置:
·     Server type:服务器类型,包括Portal server和Web server,分别表示Portal认证服务器和Portal Web服务器
·     Server name:服务器名称
·     Action:是否开启服务器不可达时的Portal用户逃生功能。fail-permit表示开启了服务器不可达时的Portal用户逃生功能
Portal源认证网段信息
IP address
Portal认证网段的IP地址
Mask
Portal认证网段的子网掩码
Prefix length
Portal IPv6认证网段的地址前缀长度
·     portal domain
·     portal enable
·     portal ipv6 layer3 source
·     portal layer3 source
·     portal web-server
display portal http-defense attacked-ip命令用来显示HTTP/HTTPS防攻击中被攻击过的目的IP统计信息。
(独立运行模式)
display portal http-defense attacked-ip [ slot slot-number ]
display portal http-defense attacked-ip [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上HTTP/HTTPS防攻击中被攻击过的目的IP统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上最近发生的HTTP/HTTPS防攻击中被攻击过的目的IP统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上HTTP/HTTPS防攻击中被攻击过的目的IP统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上HTTP/HTTPS防攻击中被攻击过的目的IP统计信息。(IRF模式)
本命令用来显示发生过HTTP/HTTPS攻击的目的IP统计信息,最多可显示512条攻击记录信息。当记录信息超过512条时,将会删除最早的记录,同时添加最新的攻击信息。
# 显示HTTP/HTTPS防攻击中被攻击过的目的IP统计信息。
<Sysname> display portal http-defense attacked-ip
slot 3:
  Dest IP       Attacks          First attack             Last attack
  1.1.1.2         1              17:12:34 11/23/2016      17:12:34 11/23/2016
  2.2.2.2         2              17:12:34 11/23/2016      17:13:25 11/23/2016
表1-2 display portal http-defense attacked-ip命令显示信息描述表
Dest IP
发生过HTTP/HTTPS攻击的目的IP地址
Attacks
该目的IP发生过HTTP/HTTPS攻击的次数
First attack
该目的IP首次发生攻击的时间
Last attack
该目的IP最后一次发生攻击的时间
·     reset portal http-defense attacked-ip
display portal http-defense blocked-ip命令用来显示HTTP/HTTPS防攻击中处于阻塞状态的目的IP统计信息。
(独立运行模式)
display portal http-defense blocked-ip [ slot slot-number ]
display portal http-defense blocked-ip [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上HTTP/HTTPS防攻击中处于阻塞状态的目的IP统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上HTTP/HTTPS防攻击中处于阻塞状态的目的IP地址统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上HTTP/HTTPS防攻击中处于阻塞状态的目的IP统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上HTTP/HTTPS防攻击中处于阻塞状态的目的IP统计信息。(IRF模式)
# 显示HTTP/HTTPS防攻击中处于阻塞状态的目的IP统计信息。
<Sysname> display portal http-defense blocked-ip
slot 3:
  Destination IP address       Defense status on driver
  1.1.1.2                      Succeed
  2.2.2.2                      Failed
表1-3 display portal http-defense blocked-ip命令显示信息描述表
HTTP/HTTPS防攻击中处于阻塞状态的目的IP地址列表
HTTP/HTTPS防攻击中处于阻塞状态的目的IP地址下发到驱动的标志,有如下取值:
·     Succeed:下发到驱动成功
·     Failed:下发到驱动失败
·     reset portal http-defense blocked-ip
display portal http-defense ip-count命令用来显示HTTP/HTTPS防攻击中处于不同状态的目的IP数目。
(独立运行模式)
display portal http-defense ip-count [ slot slot-number ]
display portal http-defense ip-count [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上HTTP/HTTPS防攻击中处于不同状态的目的IP数目。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上HTTP/HTTPS防攻击中处于不同状态的目的IP数目。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上HTTP/HTTPS防攻击中处于不同状态的目的IP数目。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上HTTP/HTTPS防攻击中处于不同状态的目的IP数目。(IRF模式)
# 显示HTTP/HTTPS防攻击中处于不同状态的目的IP数目。
<Sysname> display portal http-defense ip-count
slot 3:
   Blocked IP: 10
  Attacked IP: 20
 Monitored IP: 10
表1-4 display portal http-defense ip-count命令显示信息描述表
Blocked IP
HTTP/HTTPS防攻击中处于阻塞状态的目的IP数目
Attacked IP
HTTP/HTTPS防攻击中被阻塞过的目的IP数目
Monitored IP
HTTP/HTTPS防攻击中处于监控状态的目的IP数目
display portal http-defense monitored-ip命令用来显示HTTP/HTTPS防攻击中处于监控状态下的目的IP统计信息。
(独立运行模式)
display portal http-defense monitored-ip [ slot slot-number ]
display portal http-defense monitored-ip [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上的HTTP/HTTPS防攻击中处于监控状态的目的IP统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则显示所有单板上的HTTP/HTTPS防攻击中处于监控状态的目的IP统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的HTTP/HTTPS防攻击中处于监控状态的目的IP统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上的HTTP/HTTPS防攻击中处于监控状态的目的IP统计信息。(IRF模式)
显示HTTP/HTTPS防攻击过程中尚未满足攻击条件仍处于监控状态下的目的IP统计信息,且显示的最大目的IP地址数为portal http-defense max-ip-number max-ip-number配置的数量。如果某个目的IP地址已经满足攻击条件,则该目的IP地址会被阻塞。被阻塞的目的IP地址信息可以通过命令display portal http-defense blocked-ip查看。
# 显示HTTP/HTTPS防攻击中处于监控状态的目的IP的统计信息。
<Sysname> display portal http-defense monitored-ip
slot 3:
      IP Address            Packet Statistics
      1.1.1.2               30
      1.1.1.3               100
      1.1.1.4               50
表1-5 display portal http-defense monitored-ip命令显示信息描述表
IP Address
处于监控状态的目的IP地址信息
Packet Statistics
访问目的IP地址的报文个数
·     display portal http-defense blocked-ip
display portal ip-subscriber message statistics命令用来显示Portal与IPoE的交互报文统计信息。
本命令用来统计IPoE Web认证时,Portal和IPoE之间交互的消息。
# 显示Portal与IPoE的交互报文统计信息。
<Sysname> display portal ip-subscriber message statistics
  Message                                 Total    Error    Duplicate
  Sent logon request                      0        0        0
  Received logon success                  0        0        0
  Received logon failure                  0        0        0
  Received EAP authentication continue    0        0        0
  Sent logoff request                     0        0        0
  Received logoff response                0        0        0
  Received forced logoff request          0        0        0
  Sent smooth user start                  0        0        0
  Sent smooth user end                    0        0        0
  Sent smooth user message                0        0        0
  Sent mac-trigger enable                 0        0        0
  Sent mac-trigger disable                0        0        0
  Received binding request                0        0        0
  Sent binding response                   0        0        0
  Sent nobinding response                 0        0        0
  Sent processing bind response           0        0        0
  Sent delete mac-trigger entry           0        0        0
  Received mac-trigger user online        0        0        0
  Received mac-trigger user offline       0        0        0
表1-6 display portal ip-subscriber message statistics命令显示信息描述表
Message
消息的名称
Total
消息的总数
Error
错误的消息数目
Duplicate
重复的消息数目
Sent logon request
发送的上线请求消息数目
收到的上线成功消息数目
收到的上线失败消息数目
收到的EAP认证持续消息数目
Sent logoff request
发送的下线请求消息数目
收到的下线回应消息数目
收到的强制下线请求消息数目
发送的用户信息平滑开始消息数目
发送的用户信息平滑结束消息数目
发送的用户信息平滑消息数目
发送接口上应用MAC绑定服务器的事件消息
发送接口上取消应用MAC绑定服务器的事件消息
收到的绑定查询消息数目
发送的已绑定回应消息数目
发送的未绑定回应消息数目
发送的正在处理绑定回应消息数目
发送的删除MAC-Trigger表项消息数目
收到的MAC Trigger认证用户上线消息数目
收到的MAC Trigger认证用户下线消息数目
·     reset portal ip-subscriber message statistics
display portal mac-trigger entry命令用来显示用户的MAC Trigger表项信息。
display portal mac-trigger entry [ ip ipv4-address ]
ip ipv4-address:显示指定IPv4用户的MAC Trigger表项信息。ipv4-address表示指定用户的IPv4地址。若未指定该参数,则显示当前所有用户的MAC Trigger表项信息。
# 显示当前所有用户的MAC Trigger表项信息。
<Sysname> display portal mac-trigger entry
IP       MAC ADDR         L3IF    L2IF                   SVLAN CVLAN Status   Source
2.2.2.2  0001-0001-0001   vlan2   GE3/1/2                2     --    Bound    Portal
表1-7 display portal mac-trigger entry命令显示信息描述表
IP
接入用户的IP地址
MAC ADDR
接入用户的MAC地址
L3IF
用户接入的三层接口
L2IF
用户接入的二层端口
用户接入的接口为三层接口时,该处显示为“--”
SVLAN
Portal用户报文的外层VLAN ID
CVLAN
Portal用户报文的内层VLAN ID
Status
用户的MAC地址和认证信息的绑定状态,包括以下取值:
·     Auth-free:MAC地址免认证通行状态
·     Querying:MAC地址查询等待状态
·     Not bound:MAC地址未绑定状态
·     Bound:MAC地址已绑定状态
·     Deleting:MAC地址无效状态,对应的MAC Trigger表项正在被删除
Source
用户接入的认证方式,包括以下取值:
·     Portal
·     IPoE
display portal mac-trigger-server命令用来显示MAC绑定服务器信息。
display portal mac-trigger-server { all | name server-name }
all:显示所有MAC绑定服务器信息。
name server-name:MAC绑定服务器的名称,server-name为1~32个字符的字符串,区分大小写。
# 显示全部MAC绑定服务器的信息。
<Sysname> display portal mac-trigger-server all
Portal mac trigger server name: ms1
  Version                    : 2.0
  Server type                : CMCC
  IP                         : 10.1.1.1
  Port                       : 100
  VPN instance               : Not configured
  Aging time                 : 120 seconds
  Free-traffic threshold     : 1000 bytes
  NAS-Port-Type              : 255
  Binding retry times        : 5
  Binding retry interval     : 2 seconds
  Authentication timeout     : 5 minutes
Portal mac trigger server name: mts
  Version                    : 1.0
  Server type                : IMC
  IP                         : 4.4.4.2
  Port                       : 50100
  Aging time                 : 300 seconds
  Free-traffic threshold     : 0 bytes
  NAS-Port-Type              : Not configured
  Binding retry times        : 3
  Binding retry interval     : 1 seconds
  Authentication timeout     : 3 minutes
# 显示名字为ms1的MAC绑定服务器的信息。
<Sysname> display portal mac-trigger-server name ms1
  Version                    : 2.0
  Server type                : CMCC
  IP                         : 10.1.1.1
  Port                       : 100
  NAS-Port-Type              : 255
表1-8 display portal mac-trigger-server命令显示信息描述表
MAC绑定服务器的名称
Version
Portal协议报文的版本,取值包括:
·     1.0:版本1
·     2.0:版本2
·     3.0:版本3
Server type
MAC绑定服务器的服务类型,取值包括:
·     CMCC:CMCC Portal服务器
·     iMC:H3C iMC Portal服务器或H3C CAMS Portal服务器
IP
MAC绑定服务器的IP地址
Port
设备向MAC绑定服务器发送MAC查询报文时使用的UDP端口号
VPN instance
MAC绑定服务器所属的VPN实例
Aging time
MAC-Trigger表项老化时间,单位为秒
用户免认证流量阈值,单位为字节
NAS-Port-Type
发往RADIUS服务器的RADIUS请求报文中的NAS-Port-Type属性值
Binding retry times
设备向MAC绑定服务器发起MAC查询的时间间隔
设备在收到MAC绑定服务器的查询响应消息后,等待用户完成Portal认证的超时时间
display portal mac-trigger-server packet statistics命令用来显示设备与MAC绑定服务器的交互报文统计信息。
# 显示设备与MAC绑定服务器的交互报文统计信息。
<Sysname> display portal mac-trigger-server packet statistics
Packets sent:
  User online notifications:                       0
  User offline notifications:                      0
  MAC binding queries:                             0
    Retries:                                       0
    MaxRetryCount reached:                         0
    Sending failures:                              0
Packets received:
  MAC binding responses:                           0
    Binding:                                       0
    Nobinding:                                     0
    Checksum failures:                             0
表1-9 display portal mac-trigger-server packet statistics命令显示信息描述表
Packets sent
发送给MAC绑定服务器的报文数目
发送用户上线通知报文次数
发送用户下线通知报文次数
MAC binding queries
发送的绑定查询报文总数
Retries
重传报文次数
达到最大重传次数的次数
Sending failures
发送失败的报文数
Packets received
收到MAC绑定服务器回应的报文数目
收到的绑定回应报文总数:
·     Binding:回应为已绑定的报文数
·     Nobinding:回应为未绑定的报文数
·     Checksum failures:校验失败报文数
Binding
回应为已绑定的报文数
Nobinding
回应为未绑定的报文数
Checksum failures
校验失败报文数
·     display portal packet statistics
·     reset portal mac-trigger-server packet statistics
display portal packet statistics命令用来显示Portal认证服务器的报文统计信息。
display portal packet statistics [ server server-name ]
server server-name:Portal认证服务器的名称,为1~32个字符的字符串,区分大小写。
执行此命令后,显示的报文统计信息包括设备接收到Portal认证服务器发送的报文以及设备发送给该Portal认证服务器的报文的信息。
若不指定参数server,则依次显示所有Portal认证服务器的报文统计信息。
# 显示名称为pts的Portal认证服务器的报文统计信息。
<Sysname> display portal packet statistics server pts
 Portal server :  pts
 Invalid packets: 0
 Pkt-Type                            Total    Drops    Errors
 REQ_CHALLENGE                       3        0        0
 ACK_CHALLENGE                       3        0        0
 REQ_AUTH                            3        0        0
 ACK_AUTH                            3        0        0
 REQ_LOGOUT                          1        0        0
 ACK_LOGOUT                          1        0        0
 AFF_ACK_AUTH                        3        0        0
 NTF_LOGOUT                          1        0        0
 REQ_INFO                            6        0        0
 ACK_INFO                            6        0        0
 NTF_USERDISCOVER                    0        0        0
 NTF_USERIPCHANGE                    0        0        0
 AFF_NTF_USERIPCHAN                  0        0        0
 ACK_NTF_LOGOUT                      1        0        0
 NTF_HEARTBEAT                       0        0        0
 NTF_USER_HEARTBEAT                  2        0        0
 ACK_NTF_USER_HEARTBEAT              0        0        0
 NTF_CHALLENGE                       0        0        0
 NTF_USER_NOTIFY                     0        0        0
 AFF_NTF_USER_NOTIFY                 0        0        0
表1-10 display portal server statistics命令显示信息描述表
Portal server
Portal认证服务器名称
Invalid packets
无效报文的数目
Pkt-Type
报文的名称
Total
报文的总数
Drops
丢弃报文数
Errors
携带错误信息的报文数
REQ_CHALLENGE
Portal认证服务器向接入设备发送的challenge请求报文
ACK_CHALLENGE
接入设备对Portal认证服务器challenge请求的响应报文
REQ_AUTH
Portal认证服务器向接入设备发送的请求认证报文
ACK_AUTH
接入设备对Portal认证服务器认证请求的响应报文
REQ_LOGOUT
Portal认证服务器向接入设备发送的下线请求报文
ACK_LOGOUT
接入设备对Portal认证服务器下线请求的响应报文
AFF_ACK_AUTH
Portal认证服务器收到认证成功响应报文后向接入设备发送的确认报文
NTF_LOGOUT
接入设备发送给Portal认证服务器,用户被强制下线的通知报文
REQ_INFO
信息询问报文
ACK_INFO
信息询问的响应报文
NTF_USERDISCOVER
Portal认证服务器向接入设备发送的发现新用户要求上线的通知报文
NTF_USERIPCHANGE
接入设备向Portal认证服务器发送的通知更改某个用户IP地址的通知报文
AFF_NTF_USERIPCHAN
Portal认证服务器通知接入设备对用户表项的IP切换已成功报文
ACK_NTF_LOGOUT
Portal认证服务器对强制下线通知的响应报文
NTF_HEARTBEAT
Portal认证服务器周期性向接入设备发送的服务器心跳报文
NTF_USER_HEARTBEAT
接入设备收到的从Portal认证服务器发送的用户同步报文
接入设备向Portal认证服务器回应的用户同步响应报文
NTF_CHALLENGE
接入设备向Portal认证服务器发送的challenge请求报文
NTF_USER_NOTIFY
接入设备向Portal认证服务器发送的用户消息通知报文
AFF_NTF_USER_NOTIFY
Portal认证服务器向接入设备发送的对NTF_USER_NOTIFY的确认报文
·     reset portal packet statistics
display portal rule命令用来显示用于报文匹配的Portal过滤规则信息。
(独立运行模式)
display portal rule { all | dynamic | static } interface interface-type interface-number [ slot slot-number ]
display portal rule { all | dynamic | static } interface interface-type interface-number [ chassis chassis-number slot slot-number ]
all:显示所有Portal过滤规则信息,包括动态Portal过滤规则和静态Portal过滤规则。
dynamic:显示动态Portal过滤规则信息,即用户通过Portal认证后设备上产生的Portal过滤规则,这类规则定义了允许指定源IP地址的报文通过接口。
static:显示静态Portal规则信息,即开启Portal后产生的Portal过滤规则,这类规则定义了在Portal功能开启后对接口上收到的报文的过滤动作。
interface interface-type interface-number:显示指定接口的Portal过滤规则信息。interface-type interface-number为接口类型和接口编号。
slot slot-number:显示指定单板上的Portal过滤规则信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上的Portal过滤规则信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的Portal过滤规则信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上的Portal过滤规则信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上指定slot上的所有Portal过滤规则的信息。
<Sysname> display portal rule all interface gigabitethernet 3/1/1 slot 3
slot 3:
IPv4 portal rules on GigabitEthernet3/1/1:
Rule 1:
 Type                : Static
 Action              : Permit
 Protocol            : Any
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : Any
    MAC            : 0000-0000-0000
    Interface      : GigabitEthernet3/1/1
    VLAN           : Any
 Destination:
    IP             : 192.168.0.111
    Mask           : 255.255.255.255
    Port           : Any
Rule 2:
 Type                : Dynamic
 Action              : Permit
 Status              : Active
 Source:
    IP             : 2.2.2.2
    MAC            : 000d-88f8-0eab
    VLAN           : Any
 Author ACL:
    Number         : 3001
Rule 3:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    VLAN           : Any
    Protocol       : TCP
 Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : 80
Rule 4:
 Type                : Static
 Action              : Deny
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    VLAN           : Any
 Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
IPv6 portal rules on GigabitEthernet3/1/1:
Rule 1:
 Type                : Static
 Action              : Permit
 Protocol            : Any
 Status              : Active
 Source:
    IP             : ::
    Prefix length  : 0
    Port           : Any
    VLAN           : Any
 Destination:
    IP             : 3000::1
    Prefix length  : 64
    Port           : Any
Rule 2:
 Type                 : Dynamic
 Action               : Permit
 Status               : Active
 Source:
    IP              : 3000::1
    MAC             : 0015-e9a6-7cfe
    VLAN            : Any
 Author ACL:
    Number          : 3001
Rule 3:
 Type                 : Static
 Action               : Redirect
 Status               : Active
 Source:
    IP              : ::
    Prefix length   : 0
    VLAN            : Any
    Protocol        : TCP
 Destination:
    IP              : ::
    Prefix length   : 0
    Port            : 80
Rule 4:
 Type                : Static
 Action              : Deny
 Status              : Active
 Source:
    IP             : ::
    Prefix length  : 0
    VLAN           : Any
 Destination:
    IP             : ::
    Prefix length  : 0
Rule 5:
 Type                : Static
 Action              : Match pre-auth ACL
 Status              : Active
 Source:
Pre-auth ACL:
    Number         : 3002
表1-11 display portal rule命令显示信息描述表
Rule
Portal过滤规则编号。IPv4过滤规则和IPv6过滤规则分别编号
Portal过滤规则的类型,包括以下取值:
·     Static:静态类型
·     Dynamic:动态类型
Action
Portal过滤规则的匹配动作,包括以下取值:
·     Permit:允许报文通过
·     Redirect:重定向报文
·     Deny:拒绝报文通过
·     Match pre-auth ACL:匹配认证前策略中的授权ACL规则
Protocol
Portal免认证过滤规则中使用的传输层协议,包括以下取值:
·     Any:不限制传输层协议类型
·     TCP:TCP传输类型
·     UDP:UDP传输类型
Status
Portal过滤规则下发的状态,若未下发Portal过滤规则,则显示为N/A。下发的状态包括以下取值:
·     Active:表示规则已生效
·     Unactuated:表示规则未生效
Source
Portal过滤规则的源信息
IP
源IP地址
Mask
源IPv4地址子网掩码
Prefix length
源IPv6地址前缀
Port
源传输层端口号
MAC
源MAC地址
Portal过滤规则应用的二层或三层接口
VLAN
源VLAN
Protocol
Portal重定向过滤规则中使用的传输层协议类型,取值只能为TCP
Destination
Portal规则的目的信息
IP
目的IP地址
Port
目的传输层端口号
Mask
目的IPv4地址子网掩码
Prefix length
目的IPv6地址前缀
Author ACL
Portal用户认证后的授权ACL,即AAA授权给用户的ACL,该字段仅在Type为Dynamic时才显示
Pre-auth ACL
Portal用户认证前的授权ACL,该字段仅在Action为Match pre-auth ACL时显示
Number
授权ACL编号,N/A表示AAA未授权ACL
display portal server命令用来显示Portal认证服务器信息。
display portal server [ server-name ]
若不指定参数server-name,则显示所有Portal认证服务器信息。
# 显示Portal认证服务器pts的信息。
<Sysname> display portal server pts
Portal server: pts
  Type                  : IMC
  IP                    : 192.168.0.111
  Port                  : 50100
  Server detection      : Timeout 60s  Action: log
  User synchronization  : Timeout 200s
  Status                : Up
  Exclude-attribute     : Not configured
  Logout notification   : Retry 3 interval 5s
表1-12 display portal server命令显示信息描述表
Portal认证服务器类型,其取值如下:
·     CMCC:符合中国移动标准规范的服务器
·     iMC:符合iMC标准规范的服务器
Portal server
Portal认证服务器名称
IP
Portal认证服务器的IP地址
VPN instance
Portal认证服务器所属的MPLS L3VPN实例
Port
Portal认证服务器的监听端口
Server detection
Portal认证服务器可达性探测功能的参数,包括超时时间(单位:秒),以及探测到服务器状态变化后触发的动作(log)
Portal用户信息同步功能的参数,包括超时时间(单位:秒)
Status
Portal认证服务器当前状态,其取值如下:
·     Up:服务器可达性探测功能未开启,或服务器可达性探测功能开启且探测结果为该服务器当前可达
·     Down:服务器可达性探测功能已开启,探测结果为该服务器当前不可达
Exclude-attribute
Portal协议报文中不携带的属性字段
Logout notification
设备强制用户下线通知报文的最大重传次数和重传时间间隔(单位:秒)
·     portal enable
·     portal server
·     server-detect (portal server view)
·     user-sync
display portal user命令用来显示Portal用户的信息。
display portal user { all | interface interface-type interface-number | ip ipv4-address | ipv6 ipv6-address | pre-auth [ interface interface-type interface-number | ip ipv4-address | ipv6 ipv6-address ] } [ verbose ]
all:显示所有Portal用户的信息。
interface interface-type interface-number:显示指定接口上的Portal用户信息。interface-type interface-number为接口类型和接口编号。
ip ipv4-address:显示指定IPv4地址的Portal用户信息。
ipv6 ipv6-address:显示指定IPv6地址的Portal用户信息。
pre-auth:显示Portal认证前用户信息。认证前用户是指被加入认证前策略的未进行Portal认证的用户。若不指定该参数,则显示Portal用户的信息。
verbose:显示指定Portal用户的详细信息。
# 显示所有Portal用户的信息。
<Sysname> display portal user all
Total portal users: 2
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
  MAC                IP                 VLAN   Interface
  000d-88f8-0eab     2.2.2.2            --     GigabitEthernet3/1/1
  Authorization information:
    DHCP IP pool: N/A
    User profile: abc (active)
    Session group profile: cd (inactive)
    ACL number: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
    Inbound priority: N/A
    Outbound priority: N/A
Username: def
  Portal server: pts
  State: Online
  VPN instance: N/A
  000d-88f8-0eac     3.3.3.3            --     GigabitEthernet3/1/2
    DHCP IP pool: N/A
    User profile: N/A
    Session group profile: N/A
    ACL number: 3000 (inactive)
    Inbound CAR: CIR 3 kbps PIR 3 kbps
                 CBS N/A (inactive)
    Outbound CAR: CIR 3 kbps PIR 3 kbps
                  CBS N/A (inactive)
    Inbound priority: 7 (active)
    Outbound priority: 0 (active)
表1-13 display portal user命令显示信息描述表
Total portal users
总计的Portal用户数目
Username
用户名
Portal server
用户认证所使用的Portal认证服务器的名称
Portal用户的当前状态,包括以下取值:
·     Initialized:初始化完成后的待认证状态
·     Authenticating:正在认证状态
·     Authorizing:正在授权状态
·     Online:在线状态
VPN instance
Portal用户所属的MPLS L3VPN实例。若用户属于公网,则显示为N/A
MAC
Portal用户的MAC地址
IP
Portal用户的IP地址
VLAN
Portal用户所在的VLAN
Portal用户接入的接口
Portal用户的授权信息
DHCP IP pool
(暂不支持)Portal用户的授权地址池名称,显示为N/A
User profile
Portal用户的授权User Profile名称。若未授权User Profile,则显示为N/A。授权状态包括如下:
·     active:AAA授权User profile成功
·     inactive:AAA授权User profile失败或者设备上不存在该User profile
(暂不支持)Portal用户的授权Session Group Profile名称。若未授权Session Group Profile,则显示为N/A。授权状态包括如下:
·     active:AAA授权Session group profile成功
·     inactive:AAA授权Session group profile失败或者设备上不存在该User profile
ACL number
Portal用户的授权ACL编号。若未授权ACL,则显示为N/A。授权状态包括如下:
·     active:AAA授权ACL成功
·     inactive:AAA授权ACL失败或者设备上不存在该ACL
Inbound CAR
授权的入方向CAR(CIR:平均速率,单位为kbps;PIR:峰值速率,单位为kbps;CBS:承诺突发尺寸,单位为byte)。若未授权入方向CAR,则显示为N/A。如果下发成功,显示为active,否则为inactive
Outbound CAR
授权的出方向CAR(CIR:平均速率,单位为kbps;PIR:峰值速率,单位为kbps;CBS:承诺突发尺寸,单位为byte)。若未授权出方向CAR,则显示为N/A。如果下发成功,显示为active,否则为inactive
Inbound priority
授权的入方向优先级,若未授权入方向优先级,则显示为N/A。如果下发成功,显示为active,否则为inactive
Outbound priority
授权的出方向优先级,若未授权出方向优先级,则显示为N/A。如果下发成功,显示为active,否则为inactive
# 显示IP地址为50.50.50.3的Portal用户的详细信息。
<Sysname> display portal user ip 50.50.50.3 verbose
Basic:
  Current IP address: 50.50.50.3
  Original IP address: 30.30.30.2
  Username: user1@hrss
  User ID: 0x18000002
  Acct-Session-ID: 678900123456790123456788901234534578901266789001234567890
  Access interface: GigabitEthernet3/1/1
  Service-VLAN/Customer-VLAN: -/-
  MAC address: 0000-0000-0001
  Domain name: hrss
  VPN instance: N/A
  Status: Online
  Portal server: test
  Portal authentication method: Direct
AAA:
  Realtime accounting interval: 60s, retry times: 3
  Idle cut: 180 sec, 10240 bytes, direction: Inbound
  Session duration: 500 sec, remaining: 300 sec
  Remaining traffic: 10240000 bytes
  Login time: 2018-04-16 14:00:05 UTC
  Online time: 01:28:16
  Accounting-start fail action: Online
  Accounting-update fail action: Online
  Accounting quota-out action: Offline
  ITA policy name: test
  DHCP IP pool: N/A
ACL&QoS&Multicast:
  Inbound CAR: CIR 64kbps PIR 640kbps
               CBS N/A (active)
  Outbound CAR: CIR 64kbps PIR 640kbps
                CBS N/A (active)
  ACL number:3000 (inactive)
  User profile: portal (active)
  Max multicast addresses: 4
  Multicast address list: 1.2.3.1, 1.34.33.1, 3.123.123.3, 4.5.6.7
2.2.2.2, 3.3.3.3, 4.4.4.4
  User group: 1 (Id=1)
Flow statistic:
  Uplink   packets/bytes: 7/546
  Downlink packets/bytes: 0/0
ITA:
  Accounting merge: Disabled
  Traffic separate: Disabled
  Quota-out offline: Enabled
level-1 Session duration: N/A, remaining: N/A
        Remaining traffic: N/A
        Traffic action: Permit
        Inbound CAR: CIR: 1000 kbps, PIR: 1000 kbps
        Outbound CAR: CIR: 1000 kbps, PIR: 1000 kbps
        Uplink packets/bytes: 0/0
level-2 Session duration: N/A, remaining: N/A
        Inbound CAR: CIR: 2000 kbps, PIR: 2000 kbps
        Outbound CAR: CIR: 2000 kbps, PIR: 2000 kbps
表1-14 display portal user verbose命令显示信息描述表
Current IP address
Portal用户当前的IP地址
Original IP address
Portal用户认证时的IP地址
Username
Portal用户上线时使用的用户名
User ID
Portal用户ID
Acct-Session-ID
Portal用户计费时的会话ID
Access interface
Portal用户接入的接口
Portal用户所在的公网VLAN/私网VLAN(“-”表示没有VLAN信息)
MAC address
用户的MAC地址
Domain name
用户认证时使用的ISP域名
VPN instance
用户所属的MPLS L3VPN实例,N/A表示用户属于公网
Status
·     Waiting_SetRule:正在下发Portal规则状态
·     Online:在线状态
·     Waiting_Traffic:正在等待用户流量状态
·     Stop Accounting:正在停止计费状态
·     Done:用户下线完成状态
Portal server
Portal服务器名称
接入接口上的Portal认证方式,包括如下取值:
·     Direct:直接认证方式
·     Redhcp:二次地址分配认证方式
·     Layer3:可跨三层认证方式
AAA
Portal用户的AAA授权信息
授权的实时计费间隔和重传次数。若未授权,则显示为N/A
Idle cut
授权的闲置切断时长和流量。若未授权,则显示为N/A
direction
用户数据流量的统计方向,包括以下取值:
·     Both:表示用户双向数据流量
·     Inbound:表示用户上行数据流量
·     Outbound:表示用户下行数据流量
Session duration
授权的会话时长以及剩余的会话时长。若未授权,则显示为N/A
Remaining traffic
授权的剩余流量。若未授权,则显示为N/A
Login time
用户登录时间,即用户授权成功的时间,格式为设备时间,如:2023-1-19  2:42:30 UTC
Online time
用户在线时长,格式为xx:xx:xx,表示时:分:秒
用户计费开始失败的动作,包括以下取值:
·     Online:如果用户计费开始失败,则保持用户在线
·     Offline:如果用户计费开始失败,则强制用户下线
用户计费更新失败的动作,包括以下取值:
·     Online:如果用户计费更新失败,则保持用户在线
·     Offline:如果用户计费更新失败,则强制用户下线
用户计费流量配额耗尽策略,包括以下取值:
·     Online:如果用户计费流量配额耗尽,则保持用户在线
·     Offline:如果用户计费流量配额耗尽,则强制用户下线
ITA policy name
授权的ITA(Intelligent Target Accounting,智能靶向计费)策略名称
DHCP IP pool
(暂不支持)授权的DHCP地址池名称,显示为N/A
Inbound CAR
Outbound CAR
Inbound priority
Outbound priority
ACL number
授权的ACL编号。若未授权ACL,则显示为N/A。授权状态包括如下:
·     active:AAA授权ACL成功
User profile
授权的User profile名称。若未授权User profile,则显示为N/A。授权状态包括如下:
(暂不支持)授权的Session group profile名称。若未授权Session group profile,则显示为N/A。授权状态包括如下:
授权Portal用户可加入的组播组的最大数目
授权Portal用户可加入的组播组列表。若未授权组播组列表,则显示为N/A
User group
Portal用户所属的用户组
Flow statistic
Portal用户流量统计信息
上行流量报文数/字节数
下行流量报文数/字节数
ITA
Portal用户的ITA业务流量统计信息
Accounting merge
统一计费功能的开启状态,包括以下取值:
·     Enabled:开启了统一计费功能,即系统将ITA业务策略下所有级别的流量进行合并,并以该ITA业务策略中配置的最低的流量计费级别上报给计费服务器
·     Disabled:未开启统一计费功能,即系统将各个级别的流量分别上报给计费服务器
Traffic separate
ITA业务流量与用户总计费流量分离功能的开启状态,包括以下取值:
·     Enabled:设备上报给计费服务器的用户总计费流量中不包含ITA流量
·     Disabled:设备上报给计费服务器的用户主计费流量中包含ITA流量
Quota-out offline
ITA业务流量配额耗尽策略,包括以下取值:
·     Enabled:当用户的指定级别的流量配额耗尽后,用户不能访问授权的目的IP地址段
·     Disabled:当用户的指定级别的流量配额耗尽后,用户仍能访问授权的目的IP地址段
level-n Session duration
AAA授权计费级别为n的ITA业务流量的会话超时时间以及剩余的在线时长。若未授权,则显示为N/A,n的取值范围为1~8
Remaining traffic
AAA授权ITA业务流量的剩余流量
Traffic action
ITA业务流量配额耗尽策略规则的匹配动作,包括以下取值:
·     Permit:当用户的指定级别的流量配额耗尽后,允许用户访问授权的目的IP地址段
·     Deny:当用户的指定级别的流量配额耗尽后,禁止用户访问授权的目的IP地址段
Inbound CAR
AAA为ITA业务流量授权的入方向CAR(CIR:平均速率,单位为bps;PIR:峰值速率,单位为bps)。若未授权入方向CAR,则显示为N/A。如果下发成功,显示为active,否则为inactive
Outbound CAR
AAA为ITA业务流量授权的出方向CAR(CIR:平均速率,单位为bps;PIR:峰值速率,单位为bps)。若未授权出方向CAR,则显示为N/A。如果下发成功,显示为active,否则为inactive
ITA业务流量上行流量报文数/字节数
ITA业务流量下行流量报文数/字节数
·     portal enable
display portal user count命令用来显示Portal用户数量。
# 显示Portal用户数量。
<Sysname> display portal user count
Total number of users: 1
·     portal delete-user
·     portal enable
display portal web-server命令用来显示Portal Web服务器信息。
display portal web-server [ server-name ]
server-name:Portal Web服务器的名称,为1~32个字符的字符串,区分大小写。
若不指定参数server-name,则显示所有Portal Web服务器信息。
# 显示Portal Web服务器wbs的信息。
<Sysname> display portal web-server wbs
Portal Web server: wbs
    Type             : IMC
    URL              : http://www.test.com/portal
    URL parameters   : userurl=http://www.test.com/welcome
                       userip=source-address
    Server detection : Interval: 120s  Attempts: 5  Action: log
    IPv4 status      : Up
    IPv6 status      : Up
    Captive-bypass   : Enabled
If-match         : original-url: http://2.2.2.2, redirect-url http://192.168.56.2
表1-15 display portal web-server命令显示信息描述表
Portal Web服务器类型,其取值如下:
·     iMC:符合iMC标准规范的服务器
Portal Web server
Portal Web服务器名称
URL
Portal Web服务器的URL地址以及携带的参数
URL parameters
Portal Web服务器的URL携带的参数信息
VPN instance
Portal Web服务器所属的MPLS L3VPN实例名称
Server detection
Portal Web服务器可达性探测功能的参数,包括探测间隔时间(单位:秒),探测尝试次数以及探测到服务器状态变化后的动作(log)
IPv4 status
IPv4 Portal Web服务器当前状态,其取值如下:
·     Down:服务器可达性探测功能已开启,且探测结果为该服务器当前不可达
IPv6 status
IPv6 Portal Web服务器当前状态,其取值如下:
Captive-bypass
Portal被动Web认证功能状态,其取值如下:
·     Disabled:未开启
·     Enabled:已开启
·     Optimize Enabled:优化功能已开启
If-match
配置的URL重定向匹配规则,未配置时,显示Not configured
·     portal enable
·     portal web-server
·     server-detect (portal web-server view)
display web-redirect rule命令用来显示指定接口上的Web重定向过滤规则信息。
(独立运行模式)
display web-redirect rule interface interface-type interface-number [ slot slot-number ]
display web-redirect rule interface interface-type interface-number [ chassis chassis-number slot slot-number ]
interface interface-type interface-number:显示指定接口的Web重定向过滤规则信息。interface-type interface-number为接口类型和接口编号。
slot slot-number:显示指定单板上指定接口的Web重定向过滤规则信息。slot-number表示单板所在槽位号。若不指定该参数,则显示主用主控板上的Web重定向过滤规则信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上指定接口的Web重定向过滤规则。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在槽位号。若不指定该参数,则显示全局主用主控板上的Web重定向过滤规则信息。(IRF模式)
# 显示接口GigabitEthernet3/1/1上的所有Web重定向过滤规则。
<Sysname> display web-redirect rule interface gigabitethernet 3/1/1
IPv4 web-redirect rules on GigabitEthernet3/1/1:
Rule 1:
 Type                : Dynamic
 Action              : Permit
 Status              : Active
 Source:
    IP             : 192.168.2.114
    VLAN           : Any
Rule 2:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    VLAN           : Any
    Protocol       : TCP
 Destination:
    Port           : 80
IPv6 web-redirect rules on GigabitEthernet3/1/1:
Rule 1:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    VLAN           : Any
    Protocol       : TCP
 Destination:
    Port           : 80
表1-16 display web-redirect rule命令显示信息描述表
Rule
Web重定向规则编号
Web重定向规则的类型,包括以下取值:
·     Static:静态类型。该类型的规则在Web重定向功能生效时生成
·     Dynamic:动态类型。该类型的规则在用户访问重定向页面时生成
Action
Web重定向规则的匹配动作,包括以下取值:
·     Permit:允许报文通过
·     Redirect:重定向报文
Status
Web重定向规则下发的状态,包括以下取值:
·     Active:表示规则已生效
·     Inactive:表示规则未生效
Source
Web重定向规则的源信息
IP
源IP地址
Mask
源IPv4地址子网掩码
Prefix length
源IPv6地址前缀
VLAN
源VLAN,如果未指定,显示为Any
Protocol
Web重定向规则中使用的传输层协议类型,取值只能为TCP
Destination
Web重定向规则的目的信息
Port
目的传输层端口号,默认为80
exclude-attribute命令用来配置Portal协议报文中不携带的属性字段。
undo exclude-attribute命令用来删除所配置的Portal协议报文中不携带的属性字段。
exclude-attribute number [ ack-auth | ack-challenge | ack-info | ack-logout | ack-ntf-user-heartbeat | ntf-challenge | ntf-logout | ntf-user-notify | ntf-useripchange ]
undo exclude-attribute number [ ack-auth | ack-challenge | ack-info | ack-logout | ack-ntf-user-heartbeat | ntf-challenge | ntf-logout | ntf-user-notify ntf-useripchange |]
未配置Portal协议报文中不携带的属性字段。
Portal认证服务器视图
number:Portal协议报文属性字段中属性类型编号,取值范围1~255。
ack-auth:Portal协议报文类型为ACK_AUTH。
ack-challengePortal协议报文类型为ACK_CHALLENGE。
ack-infoPortal协议报文类型为ACK_INFO。
ack-logout:Portal协议报文类型为ACK_LOGOUT。
ack-ntf-user-heartbeatPortal协议报文类型为ACK_NTF_USER_HEARTBEAT。
ntf-challengePortal协议报文类型为NTF_CHALLENGE。
ntf-logout:Portal协议报文类型为NTF_LOGOUT。
ntf-user-notifyPortal协议报文类型为NTF_USER_NOTIFY。
ntf-useripchangePortal协议报文类型为NTF_USERIPCHANGE。
由于不同的Portal认证服务器对Portal协议报文中的属性字段支持情况不同,如果设备发送给Portal认证服务器的Portal协议报文中携带了服务器不支持的属性字段,会导致设备和Portal认证服务器不能通信。
可以通过本命令,指定设备发送的Portal协议报文中不携带Portal认证服务器不支持的属性字段,从而避免因设备与Portal认证服务器不通导致Portal认证失败。
Portal协议所有属性的详细描述如表1-17所示。
表1-17 Portal协议所有属性详细描述
属性名称
属性编号
属性含义
UserName
1
用户名
PassWord
2
用户提交的明文密码
Challenge
3
用于CHAP方式加密的随机数
ChapPassWord
4
通过MD5算法加密后的密码
TextInfo
5
该属性用于设备将RADIUS服务器的提示信息或报文错误时的提示信息透传到Portal服务器。属性的内容可以为任意字符串,但是不包括字符串结束符‘\0’。该属性可以存在于从设备到Portal服务器的任何报文中。同一个报文中允许有多个该属性,建议只携带1个
UpLinkFlux
6
表示该用户的上行(输出)的流量,为一个8字节无符号整数,单位为KB
DownLinkFlux
7
表示该用户的下行(输入)的流量,为一个8字节无符号整数,单位为KB
Port
8
端口信息,内容为一个字符串(无 '\0' 结束符)
IP-Config
9
在不同报文类型中含义不同:
·     在ACK _AUTH(Type=0x04)报文中,表示设备端通知Portal服务器此用户需要二次地址分配
·     在ACK_LOGOUT(Type=0x06)和NTF_LOGOUT(Type=0x08)报文中,表示用户此时使用的IP地址必须回收,Portal服务器必须通知用户端触发DHCP过程释放公网IP,设备将重新为用户分配一个私网的IP地址
BAS-IP
10
用于标识用户接入设备的IP地址。对于二次地址方式,其值为接入设备的公网IP地址
Session-ID
11
用户标识,通常使用用户的MAC地址作为标识
Delay-Time
12
报文发送延时,携带在NTF_LOGOUT(Type=0x08)报文中
User-List
13
用户IP地址列表
EAP-Message
14
需要透传的EAP属性,适用于EAP_TLS认证,允许出现多个
User-Notify
15
需要透传的RADIUS计费回应报文中的hw_User_Notify内容
BAS-IPv6
16
标识用户接入设备的IPv6地址,所有接入设备发送的报文都应该携带该属性
UserIPv6-List
101
用户IPv6地址列表
如果配置属性类型编号后不指定任何参数,则表示设备发送给Portal认证服务器的所有类型的Portal协议报文均不携带该属性字段。
# 在Portal认证时,若Portal服务器不支持UpLinkFlux属性,则配置类型为ACK_AUTH的Portal协议报文中不携带属性字段UpLinkFlux。
[Sysname] portal server pts
[Sysname-portal-server-pts] exclude-attribute 6 ack-auth
·     display portal server
free-traffic threshold命令用来配置用户免认证流量的阈值。
undo free-traffic threshold命令用来恢复缺省情况。
free-traffic threshold value
用户免认证流量的阈值为0字节。
MAC绑定服务器视图
value:用户免认证流量的阈值,取值范围为0~10240000,单位为字节。如果配置用户免认证流量的阈值为0,表示只要用户有访问网络的流量产生,设备就会立即触发基于MAC地址的快速认证。
设备开启了基于MAC地址的快速认证功能时,用户在上线前都拥有一定的免认证流量。设备会在MAC-Trigger表项老化之前实时检测Portal用户收发的流量。当用户收发的流量还未达到设定的阈值时,允许用户访问外部网络资源;当用户收发的流量达到设定的阈值时,则触发基于MAC地址的快速认证。
用户通过Portal认证后,设备将该用户的流量统计清零;若用户未通过Portal认证,则设备在MAC-Trigger表项老化之前不会再次对该用户触发基于MAC地址的快速认证,当MAC-Trigger表项老化后,将该用户的流量统计清零。如果在MAC-Trigger表项老化后,设备再次检测到来自同一用户的流量,则设备将重新建立MAC-Trigger表项,重复以上过程。
# 配置用户免认证流量的阈值为10240字节。
[Sysname-portal-mac-trigger-server-mts] free-traffic threshold 10240
1.1.24  if-match
if-match命令用来配置重定向URL的匹配规则。
undo if-match命令用来删除配置的重定向URL匹配规则。
if-match { original-url url-string redirect-url url-string [ url-param-encryption { aes | des } key { cipher | simple } string ] | user-agent string redirect-url url-string }
undo if-match { original-url url-string | user-agent user-agent }
不存在重定向URL的匹配规则。
Portal Web服务器视图
original-url url-string:根据用户Web访问请求的URL地址进行匹配,其中url-string是用户Web访问请求的URL地址,为1~256个字符的字符串,区分大小写。该URL地址必须是以http://或者https://开头的完整URL路径。
redirect-url url-string:Web访问请求被重定向后的地址,为1~256个字符的字符串,区分大小写。该URL地址必须是以http://或者https://开头的完整URL路径。
url-param-encryption:对设备重定向给用户的Portal Web服务器URL中携带的所有参数信息进行加密。如果未指定本参数,则表示不对携带的所有参数信息进行加密。
aes:加密算法为AES算法。
des:加密算法为DES算法。
key:设置密钥。
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。密钥的长度范围和选择的加密方式有关。具体关系如下:
·     对于des加密方式,明文密钥为8个字符的字符串,密文密钥为41个字符的字符串。
·     对于aes加密方式,明文密钥为1~31个字符的字符串,密文密钥为1~73个字符的字符串。
user-agent user-agent:根据用户HTTP/HTTPS请求报文中的User Agent信息进行匹配,其中user-agent是HTTP/HTTPS User Agent信息内容,为1~255个字符的字符串,区分大小写。HTTP/HTTPS User Agent信息包括硬件厂商信息、软件操作系统信息、浏览器信息、搜索引擎信息等内容。
重定向URL匹配规则用于控制重定向用户的HTTP或HTTPS请求,该匹配规则可匹配用户的Web请求地址或者用户的终端信息。为了让用户能够成功访问重定向后的地址,需要通过portal free-rule命令配置免认证规则,放行去往该地址的HTTP或HTTPS请求报文。与url命令不同的是,重定向匹配规则可以灵活的进行地址的重定向,而url命令一般只用于将用户的HTTP或HTTPS请求重定向到Portal Web服务器进行Portal认证。在二者同时存在时,if-match命令优先进行地址的重定向。
# 配置URL地址为http://www.abc.com.cn的匹配规则,访问此地址的报文被重定向到http://192.168.0.1,对重定向URL中携带的参数进行加密。
[Sysname-portal-websvr-wbs] if-match original-url http://www.abc.com.cn redirect-url http://192.168.0.1 url-param-encryption des key simple 12345678
# 配置用户代理信息为5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36的匹配规则,访问此地址的报文被重定向到http://192.168.0.1。
[Sysname-portal-websvr-wbs] if-match user-agent 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 redirect-url http://192.168.0.1
·     portal free-rule
·     url
·     url-parameter
ip命令用来配置MAC绑定服务器的IP地址。
undo ip命令用来恢复缺省情况。
ip ipv4-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
undo ip
未配置MAC绑定服务器的IP地址。
MAC绑定服务器视图
ipv4-address:MAC绑定服务器的IPv4地址。
vpn-instance vpn-instance-name:MAC绑定服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示MAC绑定服务器位于公网中。
key:设备与MAC绑定服务器通信时使用的共享密钥。设备与MAC绑定服务器交互的Portal报文中会携带验证字,该验证字在共享密钥参与下生成,用于接收方校验收到的Portal报文的正确性。如果未指定本参数,则表示设备与MAC绑定服务器通信时不使用共享密钥进行报文校验。
cipher:以密文方式设置共享密钥。
simple:以明文方式设置共享密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~64个字符的字符串;密文密钥为1~117个字符的字符串。
# 配置MAC绑定服务器mts的IP地址为192.168.0.111,共享密钥为明文portal。
[Sysname-portal-mac-trigger-server-mts] ip 192.168.0.111 key simple portal
ip命令用来指定Portal认证服务器的IPv4地址。
undo ip命令用来恢复缺省情况。
undo ip
未指定Portal认证服务器的IPv4地址。
Portal认证服务器视图
ipv4-address:Portal认证服务器的IPv4地址。
vpn-instance vpn-instance-name:Portal认证服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示Portal认证服务器位于公网中。
key:与Portal认证服务器通信时使用的共享密钥。设备与Portal认证服务器交互的Portal报文中会携带一个在该共享密钥参与下生成的验证字,该验证字用于接受方校验收到的Portal报文的正确性。
cipher:以密文方式设置密钥。
string:密码字符串,区分大小写。明文密钥为1~64个字符的字符串,密文密钥为1~117个字符的字符串。
一个Portal认证服务器对应一个IPv4地址,因此一个Portal认证服务器视图下只允许存在一个IPv4地址。多次执行本命令,最后一次执行的命令生效。
不同的Portal认证服务器不允许IPv4地址和VPN的配置都相同。
# 指定Portal认证服务器pts的IPv4地址为192.168.0.111、共享密钥为明文portal。
[Sysname-portal-server-pts] ip 192.168.0.111 key simple portal
·     portal server
1.1.27  ipv6
ipv6命令用来指定Portal认证服务器的IPv6地址。
undo ipv6命令用来恢复缺省情况。
ipv6 ipv6-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
undo ipv6
未指定Portal认证服务器的IPv6地址。
Portal认证服务器视图
ipv6-address:Portal认证服务器的IPv6地址。
key:与Portal认证服务器通信需要的共享密钥。设备与Portal认证服务器交互的Portal报文中会携带一个在该共享密钥参与下生成的验证字,该验证字用于接受方校验收到的Portal报文的正确性。
cipher:以密文方式设置密钥。
一个Portal认证服务器对应一个IPv6地址,因此一个Portal认证服务器视图下只允许存在一个IPv6地址。多次执行本命令,最后一次执行的命令生效。
不同的Portal认证服务器不允许IPv6地址和VPN实例的配置都相同。
# 指定Portal认证服务器pts的IPv6地址为2000::1、共享密钥为明文portal。
[Sysname-portal-server-pts] ipv6 2000::1 key simple portal
·     portal server
logon-page bind命令用来配置终端设备类型与认证页面文件的绑定关系,实现Portal用户认证页面的定制功能。
undo logon-page bind命令用来取消指定终端设备类型与认证页面的绑定关系。
logon-page bind device-type type-name file file-name
undo logon-page bind { all | device-type type-name }
未配置终端设备类型与任何认证页面文件的绑定关系。
本地Portal Web服务视图
all:表示所有绑定的终端设备类型。
device-type type-name:表示绑定的终端设备类型。type-name为终端设备类型的名称,为1~127个字符的字符串,区分大小写。指定的终端设备类型必须为设备指纹库中已定义的设备类型,否则绑定的认证页面不生效。
file file-name:表示绑定的认证页面文件。file-name为认证页面文件的文件名(不包括文件的保存路径),为1~91个字符的字符串,包括字母、数字、点和下划线。该文件由用户编辑,将其打包成zip格式文件后上传到设备存储介质的根目录下。
未认证用户通过Web浏览器访问外网,并触发了本地Portal认证时,如果设备上配置了logon-page bind命令,则会根据终端设备类型查找与认证页面文件的绑定关系,如果查找成功,则推出相应的认证页面;否则,则向Portal用户推出缺省的认证页面,但是如果设备上没有配置default-logon-page命令,则将无法进行本地Portal认证。
当绑定文件的名称或内容有更新或需要修改绑定关系时,可通过重复执行本命令进行修改。
对于相同的终端设备类型,多次执行本命令,最后一次执行的命令生效。
设备上允许同时存在多条绑定条目。
# 创建本地Portal Web 服务器,进入本地Portal Web 服务器视图,并指定使用HTTP协议和客户端交互认证信息。
# 配置终端设备类型为iphone的设备与定制认证页面文件file2.zip进行绑定。
[Sysname-portal-local-websvr-http] logon-page bind device-type iphone file file2.zip
·     default-logon-page
logout-notify命令用来配置强制用户下线通知报文的最大重传次数和重传时间间隔。
undo logout-notify命令用来恢复缺省情况。
logout-notify retry retries interval interval
undo logout-notify
未配置强制用户下线通知报文的最大重传次数和重传时间间隔。
Portal认证服务器视图
retry retries:最大重传次数,取值范围为1~5。
interval interval:重传时间间隔,取值范围为1~10,单位为秒。
由于Portal协议采用UDP报文来承载数据,因此其通信过程是不可靠的。为防止Portal认证服务器收不到强制用户下线通知报文,可以配置重传次数和重传间隔。
当设备发送强制用户下线通知报文后,无论设备在指定的时间内(重传次数乘以重传时间间隔)是否收到Portal认证服务器的响应,都会强制用户下线并删除用户信息。
# 配置强制用户下线报文的最大重传次数为3次,时间间隔为5秒。
[Sysname-portal-server-pt] logout-notify retry 3 interval 5
nas-port-type命令用来配置设备发送的RADIUS请求报文中的NAS-Port-Type属性值。
undo nas-port-type命令用来恢复缺省情况。
nas-port-type value
undo nas-port-type
未配置设备发送的RADIUS请求报文中的NAS-Port-Type属性值。
MAC绑定服务器视图
value:NAS-Port-Type属性值,取值范围为1~255。
设备在与特定厂商的MAC绑定服务器通信时,需要使用RADIUS报文中的NAS-Port-Type属性来标识该认证过程是基于MAC地址的快速认证还是普通Portal认证。
请根据MAC绑定服务器的配置来设置本设备的NAS-Port-Type属性值。
# 配置设备向MAC绑定服务器mts发送的RADIUS请求报文中的NAS-Port-Type属性值为30。
[Sysname-portal-mac-trigger-server-mts] nas-port-type 30
port命令用来配置MAC绑定服务器监听查询报文的UDP端口号。
undo port命令用来恢复缺省情况。
port port-number
undo port
MAC绑定服务器监听查询报文的UDP端口号是50100。
MAC绑定服务器视图
port-number:UDP端口号,取值范围为1~65534。
本命令配置的端口号需要与MAC绑定服务器上配置的监听查询报文的端口号保持一致。
# 配置MAC绑定服务器mts监听查询报文的UDP端口号为1000。
<sysname> system-view
[sysname] portal mac-trigger-server mts
[sysname-portal-mac-trigger-server-mts] port 1000
port命令用来配置设备主动向Portal认证服务器发送Portal报文时使用的UDP端口号。
port port-number
undo port
设备主动发送Portal报文时使用的UDP端口号为50100。
Portal认证服务器视图
port-number:设备向Portal认证服务器主动发送Portal报文时使用的目的UDP端口号,取值范围为1~65534。
本命令配置的端口号要和Portal认证服务器上配置的监听Portal报文的端口号保持一致。
# 配置设备向Portal认证服务器pts主动发送Portal报文时使用的目的UDP端口号为50000。
[Sysname-portal-server-pts] port 50000
·     portal server
portal { bas-ip | bas-ipv6 }命令用来设置发送给Portal认证服务器的Portal报文中的BAS-IP或BAS-IPv6属性。
undo portal { bas-ip | bas-ipv6 }命令用来恢复缺省情况。
portal { bas-ip ipv4-address | bas-ipv6 ipv6-address }
对于响应类报文IPv4 Portal报文中的BAS-IP属性为报文的源IPv4地址,IPv6 Portal报文中的BAS-IPv6属性为报文源IPv6地址。
对于通知类报文IPv4 Portal报文中的BAS-IP属性为出接口的IPv4地址,IPv6 Portal报文中的BAS-IPv6属性为出接口的IPv6地址。
ipv4-address:接口发送Portal报文的BAS-IP属性值,应该为本机的地址,不能为全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6-address:接口发送Portal报文的BAS-IPv6属性值,应该为本机的地址,不能为多播地址、全0地址、本地链路地址。
设备上运行Portal协议2.0版本时,主动发送给Portal认证服务器的报文(例如强制用户下线报文)中必须携带BAS-IP属性。设备上运行Portal协议3.0版本时,主动发送给Portal认证服务器必须携带BAS-IP或者BAS-IPv6属性。
配置此命令后,设备主动发送的通知类Portal报文,其源IP地址为配置的BAS-IP,否则为Portal报文出接口IP地址。
接口上开启了二次地址分配认证方式的Portal认证时,如果Portal认证服务器上指定的设备IP不是Portal报文出接口IP地址,则必须通过本命令配置相应的BAS-IP或BAS-IPv6属性,使其值与Portal认证服务器上指定的设备IP一致,否则Portal用户无法认证成功。
使用H3C iMC的Portal认证服务器的情况下,如果Portal服务器上指定的设备IP不是设备上Portal报文出接口的IP地址,则开启了Portal认证的接口上必须配置BAS-IP或者BAS-IPv6属性。
# 配置接口GigabitEthernet3/1/1发送Portal报文的BAS-IP属性值为2.2.2.2。
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] portal bas-ip 2.2.2.2
·     display portal
portal { ipv4-max-user | ipv6-max-user }命令用来配置接口上的Portal最大用户数。
undo portal { ipv4-max-user | ipv6-max-user }命令用来恢复缺省情况。
portal { ipv4-max-user | ipv6-max-user } max-number
接口上的Portal最大用户数不受限制。
max-number:接口上允许的最大IPv4或IPv6 Portal用户数,取值范围为1~4294967295。
如果接口上配置的Portal最大用户数小于当前接口上已经在线的Portal用户数,则该配置可以执行成功,且在线Portal用户不受影响,但系统将不允许新的Portal用户从该接口接入。
# 在接口GigabitEthernet3/1/1上配置IPv4 Portal最大用户数为100。
[Sysname-GigabitEthernet3/1/1] portal ipv4-max-user 100
·     display portal
·     portal max-user
portal access-info trust命令用来指定通过查询ARP/ND表项来获取用户信息。
portal access-info trust命令用来恢复缺省情况。
portal access-info trust { arp | nd }
undo portal access-info trust { arp | nd }
设备通过查询FIB表项来获取用户信息。
arp:表示通过查询ARP表项来获取用户接入的接口和所属VPN等信息。
nd:表示通过查询ND表项来获取用户接入的接口和所属VPN等信息。
在IPoE Web认证组网中,如果DHCP接入用户和Portal认证服务器属于不同的VPN,且用户接入接口未绑定VPN实例,设备收到Portal认证服务器发送的Portal协议报文时,无法通过查询Portal认证服务器所属VPN实例的FIB表项获取到用户的接入信息,从而导致用户无法在Web认证阶段上线。为了解决这个问题,可以通过配置本特性,使得设备在用户的Web认证阶段通过查询ARP/ND表项获取到用户的接入信息。
需要注意的是,请确保组网中不同的VPN内不存在相同的IP地址,否则配置本功能也无法保证用户正常上线。
# 指定通过查询ARP表项来获取用户信息。
[Sysname] portal access-info trust arp
portal apply mac-trigger-server命令用来应用MAC绑定服务器。
undo portal apply mac-trigger-server命令用来恢复缺省情况。
portal apply mac-trigger-server server-name
未应用MAC绑定服务器。
server-name:MAC绑定服务器名称,为1~32个字符的字符串,区分大小写。
仅IPv4的直接认证方式支持基于MAC地址的快速认证。
为使基于MAC地址的快速认证生效,必须完成以下配置:
·     完成普通三层Portal认证的相关配置;
·     配置MAC绑定服务器的IP地址和端口号;
·     在接口上应用MAC绑定服务器。
# 在接口GigabitEthernet3/1/1上应用MAC绑定服务器mts。
[Sysname-GigabitEthernet3/1/1] portal apply mac-trigger-server mts
·     portal mac-trigger-server
portal apply pre-auth-policy命令用来配置在接口上应用Portal认证前策略。
undo portal apply pre-auth-policy命令用来恢复缺省情况。
portal [ ipv6 ] apply pre-auth-policy policy-name
undo portal [ ipv6 ] apply pre-auth-policy
接口上未应用Portal认证前策略。
ipv6:配置IPv6 Portal认证前策略。若不指定该参数,则表示指定IPv4 Portal认证前策略。
policy-name:表示Portal认证前策略的名称,为1~64个字符的字符串,不区分大小写。
开启Portal的接口上配置了未认证Portal用户使用的Portal认证前策略时,在此接口上获取到IP地址的用户将被Portal授予指定Portal认证前策略内配置的相关属性(目前包括ACL、User Profile和CAR),并根据此策略信息获得相应的网络访问权限。若此用户后续触发了Portal认证,则认证成功之后会被AAA下发新的授权信息。用户下线之后,将被重新授予该认证前策略中的属性。
Portal认证前策略的配置只对采用DHCP或DHCPv6分配IP地址的用户生效。
Portal认证前策略的配置在可跨三层认证方式的接口上不生效。
当Portal认证前策略中的配置或配置参数的内容发生变化后,策略的修改对应用此策略接口上的所有未认证Portal用户立即生效。
# 在接口GigabitEthernet3/1/1上应用Portal认证前策略abc。
[Sysname-GigabitEthernet3/1/1] portal apply pre-auth-policy abc
·     portal pre-auth policy
portal [ ipv6 ] apply web-server命令用来引用Portal Web服务器,设备会将Portal用户的HTTP/HTTPS请求报文重定向到该Web服务器。
undo portal [ ipv6 ] apply web-server命令用来恢复缺省情况。
portal [ ipv6 ] apply web-server server-name [ fail-permit ]
未引用Portal Web服务器。
ipv6:表示IPv6 Portal Web服务器。若不指定该参数,则表示IPv4 Portal Web服务器。
server-name:被引用的Portal Web服务器的名称,为1~32个字符的字符串,区分大小写,且必须已经存在。
fail-permit:开启Portal Web服务器不可达时的Portal用户逃生功能,即设备探测到Portal Web服务器不可达时取消接口上的Portal认证功能,允许用户不经过Portal认证即可自由访问网络。
一个接口上可以同时开启IPv4 Portal认证和IPv6 Portal认证,因此也可以同时引用一个IPv4 Portal Web服务器和一个IPv6 Portal Web认证服务器。
如果接口上同时开启了Portal认证服务器逃生功能和Portal Web服务器逃生功能,则当任意一个服务器不可达时,即取消接口Portal认证功能,当两个服务器均恢复正常通信后,再重新启动Portal认证功能。
# 在接口GigabitEthernet3/1/1上引用名称为wbs的Portal Web服务器作为用户认证时使用的Web服务器。
[Sysname-GigabitEthernet3/1/1] portal apply web-server wbs
·     display portal
·     portal fail-permit server
·     portal web-server
portal authorization strict-checking命令用来开启Portal授权信息的严格检查模式。
undo portal authorization strict-checking命令用来关闭Portal授权信息的严格检查模式。
portal authorization { acl | user-profile } strict-checking
undo portal authorization { acl | user-profile } strict-checking
缺省为非严格检查授权信息模式,当服务器下发的授权ACL、User Profile在设备上不存在或者设备下发ACL、User Profile失败时,用户保持在线。
acl:表示开启对授权ACL的严格检查。
user-profile:表示开启对授权User Profile的严格检查。
接口上开启Portal授权信息的严格检查模式后当服务器给用户下发的授权ACL、User Profile在设备上不存在或者设备下发ACL、User Profile失败时,设备将强制该用户下线。
可同时开启对授权ACL和授权User Profile的严格检查模式。若同时开启了对授权ACL和对授权User Profile的严格检查模式,则只要其中任意一个授权属性未通过严格授权检查,则用户就会下线。
# 在接口GigabitEthernet3/1/1上开启对授权ACL的严格检查模式。
[Sysname–GigabitEthernet3/1/1] portal authorization acl strict-checking
·     display portal
portal delete-user命令用来强制在线Portal用户下线。
portal delete-user { ipv4-address | all | interface interface-type interface-number | ipv6 ipv6-address | session-id session-id | username username }
ipv4-address:在线Portal用户的IPv4地址。
all:所有接口下的在线IPv4 Portal用户和IPv6 Portal用户。
interface interface-type interface-number:指定接口下的所有在线Portal用户,包括IPv4 Portal用户和IPv6 Portal用户。interface-type interface-number为接口类型和接口编号。
ipv6 ipv6-address:指定在线IPv6 Portal用户的地址。
session-id session-id:指定会话的在线Portal用户。其中session-id表示会话ID,为1~64个字符的字符串,不包含字母。会话ID用于唯一标识当前的在线用户。
username username:指定用户名的在线Portal用户。其中username表示用户名,为1~253个字符的字符串,区分大小写。
# 强制IP地址为1.1.1.1的在线Portal用户下线。
[Sysname] portal delete-user 1.1.1.1
·     display portal user
portal device-id命令用来配置设备ID。
undo portal device-id命令用来恢复缺省情况。
portal device-id device-id
未配置任何设备ID。
device-id:设备ID,为1~63个字符的字符串,区分大小写。
通过配置设备ID,使得设备向Portal服务器发送的协议报文中携带一个属性,此属性用于向Portal服务器标识发送协议报文的接入设备。
不同设备的设备ID不能相同。
# 配置设备的ID名为0002.0010.100.00。
[Sysname] portal device-id 0002.0010.100.00
portal [ ipv6 ] domain命令用于指定Portal用户使用的认证域,使得所有从该接口接入的Portal用户强制使用该认证域。
undo portal [ ipv6 ] domain命令用来删除Portal用户使用的认证域。
portal [ ipv6 ] domain domain-name
未指定Portal用户使用的认证域。
ipv6:指定IPv6 Portal用户使用的认证域。若不指定本参数,则表示指定IPv4 Portal用户使用的认证域。
domain-name:ISP认证域名,为1~255个字符的字符串,不区分大小写。
接口上可以同时指定IPv4 Portal用户和IPv6 Portal用户的认证域。
如果不指定ipv6参数,则表示配置或者删除IPv4 Portal用户使用的认证域。
# 指定从接口GigabitEthernet3/1/1上接入的IPv4 Portal用户使用认证域为my-domain。
[Sysname–GigabitEthernet3/1/1] portal domain my-domain
·     display portal
portal [ ipv6 ] enable命令用来开启Portal认证功能,并指定认证方式。
undo portal [ ipv6 ] enable命令用来关闭Portal认证功能。
portal enable method { direct | layer3 | redhcp }
portal ipv6 enable method { direct | layer3 }
Portal认证功能处于关闭状态。
ipv6:表示IPv6 Portal认证。若不指定该参数,则表示IPv4 Portal认证。
method:认证方式。
·     direct:直接认证方式。
·     layer3:可跨三层认证方式。
·     redhcp:二次地址分配认证方式。
请优先在三层以太网接口和三层以太网子接口上开启Portal认证功能,不推荐在VLAN接口上开启Portal认证功能。
不能通过重复执行本命令来修改Portal认证方式。如需修改Portal的认证方式,请先通过undo portal [ ipv6 ] enable命令取消Portal认证功能,再执行portal [ ipv6 ] enable命令。
开启IPv6 Portal认证功能之前,需要保证设备支持IPv6 ACL和IPv6转发功能。
IPv6 Portal认证不支持二次地址分配方式。
允许在接口上同时开启IPv4 Portal认证和IPv6 Portal认证功能。
为保证以太网接口上的Portal功能生效,请不要将开启Portal认证功能的以太网接口加入聚合组。
# 在接口GigabitEthernet3/1/1上开启IPv4 Portal认证功能,且指定为直接认证方式。
[Sysname-GigabitEthernet3/1/1] portal enable method direct
·     display portal
portal [ ipv6 ] fail-permit server命令用来开启Portal认证服务器不可达时的Portal用户逃生功能。
undo portal [ ipv6 ] fail-permit server命令用来关闭Portal认证服务器不可达时的Portal用户逃生功能。
portal [ ipv6 ] fail-permit server server-name
Portal认证服务器不可达时的Portal用户逃生功能处于关闭状态。
ipv6:表示IPv6 Portal认证服务器。若不指定该参数,则表示IPv4 Portal认证服务器。
server-name:Portal认证服务器名称,为1~32个字符的字符串,区分大小写。
如果接口上同时开启了Portal认证服务器不可达时的Portal用户逃生功能和Portal Web服务器不可达时的Portal用户逃生功能,则当任意一个服务器不可达时,立即放开接口控制,允许用户不经过Portal认证即可自由访问网络;当两个服务器均恢复可达后,再重新启动接口的Portal认证功能。重新启动接口的Portal认证功能之后,未通过认证的用户需要通过认证之后才能访问网络资源,已通过认证的用户可继续访问网络资源。
一个接口上,最多同时可以开启一个Portal认证服务器不可达时的Portal用户逃生功能和一个Portal Web服务器不可达时的Portal用户逃生功能。
# 在接口GigabitEthernet3/1/1上启用Portal认证服务器pts1不可达时的Portal用户逃生功能。
[Sysname-GigabitEthernet3/1/1] portal fail-permit server pts1
·     display portal
portal free-rule命令用来配置基于IP地址的Portal免认证规则。
undo portal free-rule命令用来删除指定的或所有Portal免认证规则。
portal free-rule rule-number { destination ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] | source ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ]
portal free-rule rule-number { destination ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] | source ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ]
undo portal free-rule { rule-number | all }
不存在基于IP地址的Portal免认证规则。
rule-number:免认证规则编号。取值范围为0~4294967295。
destination:指定目的信息。
source:指定源信息。
ip ipv4-address:免认证规则的IPv4地址。
{ mask-length | mask }:免认证规则的IP地址掩码。其中,mask-length为子网掩码长度,取值范围为0~32;mask为子网掩码,点分十进制格式。
ipv6 ipv6-address:免认证规则的IPv6地址。
prefix-length:免认证规则的IPv6地址前缀长度,取值范围为0~128。
ip any:任意IPv4地址。
ipv6 any:任意IPv6地址。
tcp tcp-port-number:免认证规则的TCP端口号,取值范围为0~65535。
udp udp-port-number:免认证规则的UDP端口号,取值范围为0~65535。
all:所有免认证规则。
interface interface-type interface-number:免认证规则生效的三层接口。
可以同时指定源和目的参数,或者仅指定其中一个参数,后者表示另外一个地址不受限制。
如果免认证规则中同时配置了源端口号和目的端口号,则要求源和目的端口号所属的传输层协议类型保持一致。
未指定三层接口的情况下,免认证规则对所有开启Portal的接口生效;指定三层接口的情况下,免认证规则只对指定的三层接口生效。
相同内容的免认证规则不能重复配置,否则提示免认证规则已存在或重复。
# 配置一条基于IPv4地址的Portal免认证规则:编号为1、源地址为10.10.10.1/24、目的地址为20.20.20.1、目的TCP端口号为23、生效接口为GigabitEthernet3/1/1。该规则表示在GigabitEthernet3/1/1接口上,10.10.10.1/24网段地址的用户不需要经过Portal认证即可以访问地址为20.20.20.1的主机在TCP端口23上提供的服务。
[Sysname] portal free-rule 1 destination ip 20.20.20.1 32 tcp 23 source ip 10.10.10.1 24 interface gigabitethernet 3/1/1
# 配置一条基于IPv6地址的Portal免认证规则:编号为2、源地址为2000::1/64、目的地址为2001::1、目的TCP端口号为23、生效接口为GigabitEthernet3/1/1。该规则表示在GigabitEthernet3/1/1接口上,2000::1/64网段地址的用户不需要经过Portal认证即可以访问目的地址为2001::1的主机在TCP端口23上提供的服务。
[Sysname] portal free-rule 2 destination ipv6 2001::1 128 tcp 23 source ipv6 2000::1 64 interface gigabitethernet 3/1/1
·     display portal rule
portal free-rule destination命令用来配置基于目的的Portal免认证规则,这里的目的指的是主机名。
portal free-rule rule-number destination host-name
不存在基于目的的Portal免认证规则。
destination:指定目的信息。
host-name:主机名,为1~253个字符的字符串,不区分大小写,字符串中可以包含字母、数字、“-”、“_”、“.”和通配符“*”,且不能为“i”、“ip”、“ipv”和“ipv6”。
all:所有免认证规则。
基于目的Portal免认证规则支持如下两种配置方式:
·     精确匹配:即完整匹配主机名。例如配置的主机名为abc.com.cn,其含义为只匹配abc.com.cn的主机名,如果报文中携带的主机名为dfabc.com.cn,则匹配失败。
·     模糊匹配:即使用通配符配置主机名,通配符只能位于主机名字符串之首或末尾,例如配置的主机名为*abc.com.cn、abc*和*abc*,其含义分别为匹配所有以abc.com.cn结尾的主机名、匹配所有以abc开头的主机名和匹配所有含有abc字符串的主机名。
配置基于目的Portal免认证规则时,需要注意的是:
·     配置本功能前,请确保组网中已部署DNS服务器。
·     通配符“*”表示任意个数字符,设备会将已配置的多个连续的通配符识别为一个通配符。
·     配置的主机名不能只有通配符。
·     相同内容的免认证规则不能重复配置,否则提示免认证规则已存在或重复。
·     目前,只有用户浏览器发起的HTTP/HTTPS请求报文支持模糊匹配的免认证规则。
# 配置一条基于目的的Portal免认证规则:编号为4、主机名为www.h3c.com。该规则表示用户的HTTP/HTTPS请求报文中的主机名必须是www.h3c.com时,该用户才可以不需要经过Portal认证即可以访问网络资源。
[Sysname] portal free-rule 4 destination www.h3c.com
portal free-rule source命令用来配置基于源的Portal免认证规则,这里的源可以是源接口或者源VLAN。
portal free-rule rule-number source{ interface interface-type interface-number | vlan vlan-id } *
未配置基于源的Portal免认证规则。
interface interface-type interface-number:免认证规则的源接口。interface-type interface-number为接口类型和接口编号。
vlan vlan-id:免认证规则的源VLAN编号。配置本关键字仅对通过VLAN接口接入的Portal用户生效。
all:所有免认证规则。
如果免认证规则中同时指定了源VLAN和二层源接口,则要求该接口属于对应的VLAN,否则该规则无效。
# 配置一条Portal免认证规则:编号为3、源VLAN为VLAN 10。该规则表示属于VLAN 10的用户不需要经过Portal认证即可以访问网络资源。
[Sysname] portal free-rule 3 source vlan 10
portal http-defense命令用来配置Portal HTTP/HTTPS防攻击参数。
undo portal http-defense命令用来恢复缺省情况。
portal http-defense { block-timeout minutes | statistics-interval value | threshold number } *
undo portal http-defense { block-timeout minutes | statistics-interval value | threshold number } *
攻击报文的阻断时长为10分钟,匹配重定向规则的报文的统计时间为5分钟,统计时间内报文的统计阈值为6000。
block-timeout minutes:攻击报文的阻断的时长,取值范围为1~60,单位分钟。
statistics-interval value:匹配重定向规则的报文的统计时间,取值范围为1~60,单位分钟。
threshold number:触发HTTP/HTTPS防攻击的报文阈值,取值范围为100~4294967295。
开启Portal HTTP/HTTPS防攻击功能后,设备会基于目的IP地址统计匹配重定向规则的HTTP/HTTPS请求报文数。如果在统计时间内,访问某一目的IP地址的报文统计数值达到了HTTP/HTTPS防攻击的触发阈值,访问该目的IP地址的报文将被视为攻击报文而丢弃,使用户不能在阻断时长内访问该目的IP地址。
修改后的配置,仅对后续发生攻击的报文有效。
# 配置Portal HTTP/HTTPS防攻击报文的阻断时长为5分钟,统计时间为2分钟,触发HTTP/HTTPS防攻击的报文阈值为200。
[Sysname] portal http-defense block-timeout 5 statistics-interval 2 threshold 200
·     portal http-defense enable
·     portal http-defense max-ip-number
portal http-defense enable命令用来开启Portal HTTP/HTTPS防攻击功能。
undo portal http-defense enable命令用来关闭Portal HTTP/HTTPS防攻击功能。
Portal HTTP/HTTPS防攻击功能处于关闭状态。
由于某些用户使用的客户端安装了各种工具软件(如百度云等),使得用户在通过Portal认证前产生大量的HTTP/HTTPS请求,导致设备的资源占用率过高,影响正常用户的认证效率,甚至导致用户认证失败。开启HTTP/HTTPS防攻击功能,可针对某些频繁发起的HTTP/HTTPS请求报文进行控制,减轻大量HTTP/HTTPS报文对认证服务器资源的占用。
# 开启Portal HTTP/HTTPS防攻击功能。
[Sysname] portal http-defense enable
portal http-defense max-ip-number命令用来配置Portal HTTP/HTTPS防攻击中处于监控状态的最大目的IP地址数。
undo portal http-defense max-ip-number命令用来恢复缺省情况。
Portal HTTP/HTTPS防攻击中处于监控状态的最大目的IP地址数为4096。
max-ip-number:Portal HTTP/HTTPS防攻击中处于监控状态的最大目的IP地址数,取值范围为1~8000。
可通过配置最大目的IP地址数,对该范围内的处于监控状态的目的IP地址进行HTTP/HTTPS报文数量的统计。
# 配置Portal HTTP/HTTPS防攻击中处于监控状态的最大目的IP地址数为2000。
[Sysname] portal http-defense max-ip-number 2000
portal ipv6 layer3 source命令用来配置IPv6 Portal源认证网段。
undo portal ipv6 layer3 source命令用来删除IPv6 Portal源认证网段。
portal ipv6 layer3 source ipv6-network-address prefix-length
undo portal ipv6 layer3 source [ ipv6-network-address ]
未配置IPv6 Portal源认证网段,表示对来自任意网段的IPv6用户都进行Portal认证。
ipv6-network-address:IPv6 Portal源认证网段地址。
prefix-length:IPv6地址前缀长度,取值范围为0~128。
配置此功能后,接口上只允许在源认证网段范围内的IPv6用户报文才能触发Portal认证,否则丢弃。
如果undo命令中不携带IP地址参数,则表示删除所有的IPv6 Portal源认证网段。
源认证网段仅对Portal的可跨三层认证方式(layer3)生效。
# 在接口GigabitEthernet3/1/1上配置一条IPv6 Portal源认证网段为1::1/16,仅允许来自1::1/16网段的用户触发Portal认证。
[Sysname–GigabitEthernet3/1/1] portal ipv6 layer3 source 1::1 16
·     display portal
portal ipv6 user-detect命令用来开启IPv6 Portal用户在线探测功能。
undo portal ipv6 user-detect命令用来关闭IPv6 Portal用户在线探测功能。
portal ipv6 user-detect type { icmpv6 | nd } [ retry retries ] [ interval interval ] [ idle time ]
IPv6 Portal用户在线探测功能处于关闭状态。
type:指定探测类型。
·     icmpv6:表示探测类型为ICMPv6。
·     nd:表示探测类型为ND。
retry retries:探测次数,取值范围为1~10,缺省值为3。
interval interval:探测间隔,取值范围为1~1200,单位为秒,缺省值为3。
idle time:用户在线探测闲置时长,即闲置多长时间后发起探测,取值范围为60~3600,单位为秒,缺省值为180。
根据探测类型的不同,设备有以下两种探测机制:
·     当探测类型为ICMPv6时,若设备发现一定时间(idle time)内接口上未收到某Portal用户的报文,则会向该用户定期(interval interval)发送探测报文。如果在指定探测次数(retry retries)之内,设备收到了该用户的响应报文,则认为用户在线,且停止发送探测报文,重复这个过程,否则,强制其下线。
·     当探测类型为ND时,若设备发现一定时间(idle time)内接口上未收到某Portal用户的报文,则会向该用户发送ND请求报文。设备定期(interval interval)检测用户ND表项是否被刷新过,如果在指定探测次数(retry retries)内用户ND表项被刷新过,则认为用户在线,且停止检测用户ND表项,重复这个过程,否则,强制其下线。
请根据配置的认证方式选择合适的探测方法,如果配置了直接方式或者二次地址分配方式,则可以使用ND或ICMPv6探测方式,如果配置了可跨三层认证方式,则可以使用ICMPv6探测方式,若配置了ND探测方式,则探测功能不生效。
如果用户接入设备上配置了阻止ICMPv6报文的防火墙策略,则接口上的ICMPv6探测方式可能会失败,从而导致接口上的Portal用户非正常下线。因此,若接口上需要使用ICMPv6探测方式,请保证用户接入设备不会过滤掉ICMPv6报文。
# 在接口GigabitEthernet3/1/1上开启IPv6 Portal用户在线探测功能:探测类型为ICMPv6,发送探测报文的次数为5次,发送间隔为10秒,闲置时间为300秒。
[Sysname–GigabitEthernet3/1/1] portal ipv6 user-detect type icmpv6 retry 5 interval 10 idle 300
·     display portal
portal layer3 source命令用来配置IPv4 Portal源认证网段。
undo portal layer3 source命令用来删除IPv4 Portal源认证网段。
portal layer3 source ipv4-network-address { mask-length | mask }
undo portal layer3 source [ ipv4-network-address ]
未配置IPv4 Portal源认证网段,表示对来自任意网段的IPv4用户都进行Portal认证。
ipv4-network-address:IPv4 Portal认证网段地址。
mask-length:子网掩码长度,取值范围为0~32。
mask:子网掩码,点分十进制格式。
配置此功能后,接口上只允许在源认证网段范围内的IPv4用户报文才能触发Portal认证,否则丢弃。
如果undo命令中不携带IP地址参数,则表示删除所有的IPv4 Portal源认证网段。
# 在接口GigabitEthernet3/1/1上配置一条IPv4 Portal源认证网段为10.10.10.0/24,仅允许来自10.10.10.0/24网段的用户触发Portal认证。
[Sysname–GigabitEthernet3/1/1] portal layer3 source 10.10.10.0 24
·     display portal
portal local-web-server命令用来开启本地Portal服务,并进入基于HTTP/HTTPS协议的本地Portal Web服务视图。
undo portal local-web-server命令用来关闭本地Portal服务功能。
portal local-web-server { http | https ssl-server-policy policy-name [ tcp-port port-number ] }
undo portal local-web-server { http | https }
本地Protal服务功能处于关闭状态。
http:指定本地Portal Web服务使用HTTP协议和客户端交互认证信息。
https:指定本地Portal Web服务使用HTTPS协议和客户端交互认证信息。
ssl-server-policy policy-name:指定HTTPS服务关联的SSL服务器端策略。policy-name为SSL服务器端策略的名称,为1~31个字符的字符串,不区分大小写,且必须已经存在。
tcp-port port-number:指定本地Portal Web服务的HTTPS服务侦听的TCP端口号,取值范围为1~65535,缺省值为443。
本地Portal服务功能是指,Portal认证系统中不采用外部独立的Portal Web服务器和Portal认证服务器,而由接入设备实现Portal Web服务器和Portal认证服务器功能。
只有接口上引用的Portal Web服务器中的URL同时满足以下两个条件时,接口上才会使用本地Portal Web服务功能。条件如下:
·     该URL中的IP地址是设备上与客户端路由可达的三层接口IP地址(除127.0.0.1以外)。
·     该URL以/portal/结尾,例如:http://1.1.1.1/portal/。
配置本地Portal Web服务参数时,需要注意的是:
·     已经被HTTPS服务关联的SSL服务器端策略不能被删除。
·     不能通过重复执行本命令来修改HTTPS服务关联的SSL服务器端策略,如需修改,请先通过undo portal local-web-server https命令删除已创建的本地Portal Web服务,再执行portal local-web-server https ssl-server-policy命令。
·     如果本地Portal Web服务引用的SSL服务器端策略与HTTPS服务引用的SSL服务器端策略相同,则本地Portal Web服务使用的TCP端口号可以与HTTPS服务器使用的TCP端口号相同,否则不能使用相同的TCP端口号。
·     除了HTTPS协议默认的端口号,本地Portal Web服务的TCP端口号不能与知名协议使用的端口号或者设备上其它服务已使用的TCP端口号配置一致,如HTTP的端口号80;Telnet的端口号23,否则会造成本地Portal Web服务无法向Portal用户推送认证页面。
·     使用HTTP协议和HTTPS协议的本地Portal Web服务侦听的TCP端口号不能配置一致,比如不能都配置为8080,否则会导致本地Web服务无法正常使用。
# 开启本地Portal服务,并进入基于HTTP协议的本地Portal Web服务视图。
# 开启本地Portal服务,并进入基于HTTPS协议的本地Portal Web服务视图,引用的SSL服务器端策略为policy1。
[Sysname] portal local-web-server https ssl-server-policy policy1
# 更改引用的SSL服务器端策略为policy2。
[Sysname] undo portal local-web-server https
[Sysname] portal local-web-server https ssl-server-policy policy2
# 使用HTTPS协议和客户端交互认证信息的方式创建本地Portal Web服务,引用的SSL服务器端策略为policy1,指定侦听的端口号为442。
[Sysname] portal local-web-server https ssl-server-policy policy1 tcp-port 442
[Sysname-portal-local-websvr-https] quit
·     ssl server-policy(安全命令参考/SSL)
1.1.55  portal mac-trigger-proxy ip
portal mac-trigger-proxy ip命令用来配置与MAC绑定服务器互连的Portal代理。
undo portal mac-trigger-proxy ip命令用来恢复缺省情况。
portal mac-trigger-proxy ip ip-address [ port port-number ]
未配置与MAC绑定服务器互连的Portal代理。
ip-address:指定与MAC绑定服务器互连的Portal代理的IP地址。
port port-number:指定Portal代理侦听接入设备报文的UDP端口号,取值范围为1~65535,缺省值为50100。
# 配置与MAC绑定服务器互连的Portal代理IP地址为192.168.0.111,Portal代理侦听接入设备报文的UDP端口号为4000。
[Sysname] portal mac-trigger-proxy ip 192.168.0.111 port 4000
1.1.56  portal mac-trigger-server
portal mac-trigger-server命令用来创建MAC绑定服务器,并进入MAC绑定服务器视图。如果指定的MAC绑定服务器已经存在,则直接进入MAC绑定服务器视图。
undo portal mac-trigger-server命令用来删除MAC绑定服务器。
portal mac-trigger-server server-name
undo portal mac-trigger-server server-name
不存在MAC绑定服务器。
在MAC绑定服务器视图下可以配置MAC绑定服务器的相关参数,包括服务器的IP地址、服务器的端口号、服务器所在的VPN实例以及设备和服务器间通信的预共享密钥等。
# 创建MAC绑定服务器mts,并进入MAC绑定服务器视图。
[Sysname] portal mac-trigger-server mts
·     portal apply mac-trigger-server
·     display mac-trigger-server
1.1.57  portal max-user
portal max-user命令用来配置全局Portal最大用户数。
undo portal max-user命令用来恢复缺省情况。
portal max-user max-number
全局Portal最大用户数不受限制。
max-number:系统中允许同时在线的最大Portal用户数。取值范围为1~4294967295。
如果配置的全局Portal最大用户数小于当前已经在线的Portal用户数,则该命令可以执行成功,且在线Portal用户不受影响,但系统将不允许新的Portal用户接入。
该命令指定的最大用户数是指IPv4 Portal和IPv6 Portal用户的总数。
建议所有开启Portal的接口上的最大IPv4 Portal用户数和最大IPv6 Portal用户数之和不超过配置的全局最大Portal用户数,否则会有部分Portal用户因为全局最大用户数已达到上限而无法上线。
# 配置全局Portal最大用户数为100。
[Sysname] portal max-user 100
·     portal { ipv4-max-user | ipv6-max-user }
1.1.58  portal nas-id-profile
portal nas-id-profile命令用来指定接口引用的NAS-ID Profile。
undo portal nas-id-profile命令用来恢复缺省情况。
portal nas-id-profile profile-name
未指定引用的NAS-ID Profile。
profile-name:标识指定VLAN和NAS-ID绑定关系的Profile名称,为1~31个字符的字符串,不区分大小写。
本命令引用的NAS-ID Profile由命令aaa nas-id profile配置,且在引用的NAS-ID Profile下,必须存在通过nas-id bind命令指定的NAS-ID与VLAN的绑定关系,否则NAS-ID Profile不生效。关于aaa nas-id profilenas-id bind命令的详细介绍请参见“BRAS业务命令参考”中的“AAA”。
若在接口上同时通过aaa nas-id-profile命令和portal nas-id-profile命令指定了NAS-ID Profile,则portal nas-id-profile命令指定的NAS-ID Profile优先级较高。关于aaa nas-id-profile命令的详细介绍,请参见“BRAS业务命令参考”中的“AAA”。
如果接口上指定了NAS-ID Profile,则此Profile中定义的绑定关系优先使用;如果接口上未指定NAS-ID Profile或指定的Profile中没有找到匹配的绑定关系,则使用设备名作为NAS-ID。
# 在接口GigabitEthernet3/1/1上指定名为aaa的NAS-ID Profile。
[Sysname–GigabitEthernet3/1/1] portal nas-id-profile aaa
·     aaa nas-id profile(BRAS业务命令参考/AAA)
1.1.59  portal nas-port-id format
portal nas-port-id format命令用来配置NAS-Port-ID属性的格式。
undo portal nas-port-id format命令用来恢复缺省情况。
portal nas-port-id format { 1 | 2 | 3 | 4 | custom { c-vid [ delimiter ] | interface-type [ delimiter ] | port [ delimiter ] | slot [ delimiter ] | subslot [ delimiter ] | s-vid [ delimiter ] | string string [ delimiter ] | vxlan-id [ delimiter ] } * }
NAS-Port-ID的消息格式为格式2。
1:表示格式1,具体为{eth|trunk} NAS_slot/NAS_subslot/NAS_port:[VXLAN.]XPI.XCI AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port[:ANI_XPI.ANI_XCI]。
2:表示格式2,具体为SlotID00IfNOVlanID。
3:表示格式3,具体为在格式2的内容后面添加Option82或者Option18。
4:表示格式4,具体为slot=**;subslot=**;port=**;vlanid=**;vlanid2=**。
custom:用户自定义NAS-Port-ID属性的格式。
c-vid:报文内层VLAN ID。
interface-type:用户接入的接口类型。
port:用户接入的端口号。
s-vid:报文外层VLAN ID。
slot:用户接入的槽位号。
subslot:用户接入的子槽位号。
string string:用户输入的自定义信息,string为1~63个字符的字符串,字符串中不能出现问号,区分大小写。
vxlan-id:VXLAN ID。
delimiter:属性字段之间的分隔符,可以为除了问号之外的其它任意可输入字符。若不指定该参数,则表示不使用分隔符。
可通过本命令修改设备为Portal用户发送的RADIUS报文中填充的NAS-Port-ID属性的格式。NAS-Port-ID属性的格式有预定义和自定义两种。预定义有格式1、格式2、格式3、格式4四种固定格式,不可更改。自定义可通过选择参数灵活配置NAS-Port-ID属性中可携带的属性字段、各字段之间使用的分隔符以及各字段的顺序。自定义属性格式中各字段填充的先后顺序为该命令中参数配置的先后顺序。
不同厂商的RADIUS服务器要求不同的格式,通常中国电信的RADIUS服务器要求采用格式1。
1. 格式1
各项含义如下:
·     {eth|trunk}:BRAS端口类型,包括以太接口或trunk类型的以太网接口。
·     NAS_slot:BRAS槽号,取值为0~31。
·     NAS_subslot:BRAS子槽号,取值为0~31。
·     NAS_Port:BRAS端口号,取值为0~63。
·     VXLAN:可选项,VXLAN ID。
·     XPI:接口类型为eth或trunk,XPI对应PVLAN,XPI取值为0~4095,未配置PVLAN时,XPI取值为4096。
·     XCI:接口类型为eth或trunk,XCI对应于CVLAN,XCI取值为0~4095,未配置CVLAN时,XCI取值为4096。
·     AccessNodeIdentifier:接入节点标识(例如DSLAM设备),为不超过50个字符的字符串,字符串中不能包括空格。
·     ANI_rack:接入节点机架号(如支持紧耦合的DSLAM设备),取值为0~15。
·     ANI_frame:接入节点机框号,取值为0~31。
·     ANI_slot:接入节点槽号,取值为0~127。
·     ANI_subslot:接入节点子槽号,取值为0~31。
·     ANI_port:接入节点端口号,取值为0~255。
·     ANI_XPI.ANI_XCI:可选项,主要用于携带CPE侧的业务信息,可用于标识未来的业务类型需求。接口类型为eth或trunk,ANI_XPI对应PVLAN,取值为0~4095,ANI_XCI对应CVLAN,取值为0~4095。
字符串之间用一个空格隔开,要求字符串中间不能有空格。花括号中的内容是必选的,|表示并列的关系,多选一。[]表示可选项。对于某些设备没有机架、框、子槽的概念,相应位置应统一填0,对于无效的VLAN ID值都填4096。
如运营商未使用SVLAN技术,则XPI=4096,XCI=VLAN,取值为0~4095。
如运营商未使用VLAN技术区分用户(用户PC直连BAS端口),则XPI=4096,XCI=4096。
对于接入节点设备(如DSLAM),按如上格式上报本接入节点的接入线路信息,对于与BRAS设备相关的接入线路信息可统一填0,如:“0 0/0/0:4096.1234 guangzhou003/1/31/63/31/127”
其含义是DSLAM节点标识为guangzhou003、DSLAM的机架号为0(没有机架)、DSLAM的框号为31、DSLAM的槽号为63、DSLAM的子槽号为31、DSLAM的端口号为127、VLAN ID号为1234,BRAS接入线路信息为未知。
对于BRAS设备,在获取接入节点设备(如DSLAM)的接入线路信息后,根据BRAS的配置可透传接入线路信息,也可修改添加接入线路信息中与BRAS设备相关的线路信息,形成完整的接入线路信息,如:“eth  31/31/7:4096.1234 guangzhou003/1/31/63/31/127”。
格式1的解释示例如下:
·     例1:NAS_PORT_ID =“eth 31/31/7:1234.2345 0/0/0/0/0/0”
含义:BRAS设备的用户接口类型为以太接口,BRAS槽号为31,BRAS子槽号为31,BRAS端口号为7,PVLAN ID为1234,CVLAN ID为2345。
·     例2:NAS_PORT_ID =“eth 31/31/7:4096.2345 0/0/0/0/0/0”
含义:BRAS设备的用户接口类型为以太接口,BRAS槽号为31,BRAS子槽号为31,BRAS端口号为7,VLAN ID为2345。
·     例3:NAS_PORT_ID =“eth  31/31/7:4096.2345 guangzhou001/1/31/63/31/127”
含义:BRAS设备的用户接口类型为以太接口,BRAS槽号为31,BRAS子槽号为31, BRAS端口号为7,VLAN ID为2345,接入节点DSLAM的标识为guangzhou001,DSLAM的机架号为1,DSLAM的框号为31,DSLAM的槽号为63,DSLAM的子槽号为31,DSLAM的端口号为127。
2. 格式2
SlotID00IfNOVlanID
各项含义如下:
·     SlotID:用户接入的槽位号,为两个字符的字符串。
·     IfNO:用户接入的接口编号,为3个字符的字符串。
·     VlanID:用户接入的VLAN ID,为9个字符的字符串。
3. 格式3
其格式为在格式2的NAS-Port-ID内容后面添加用户DHCP报文中指定Option的内容:对于IPv4用户,此处添加的是DHCP Option82的内容。对于IPv6用户,此处添加的是DHCP Option18的内容。
4. 格式4
其格式为slot=**;subslot=**;port=**;vlanid=**;vlanid2=**,具体情况如下:
·     对于非VLAN接口,其格式为slot=**;subslot=**;port=**;vlanid=0。
·     对于只终结了一层VLAN Tag的接口,其格式为slot=**;subslot=**;port=**;vlanid=**。
5. 格式custom
可通过选取不同的参数灵活配置NAS-Port-ID属性中可携带的属性字段、各字段之间使用的分隔符以及各字段的顺序。例如,可以通过配置命令“portal nas-port-id format custom slot @ subslot @ port”,使NAS-Port-ID属性中只携带槽号、子槽号以及端口号。
# 配置NAS-Port-ID属性的格式为format 1。
[Sysname] portal nas-port-id format 1
1.1.60  portal pre-auth ip-pool
portal [ ipv6 ] pre-auth ip-pool命令用来配置Portal认证前用户使用的地址池。
undo portal [ ipv6 ] pre-auth ip-pool命令用来恢复缺省情况。
portal [ ipv6 ] pre-auth ip-pool pool-name
未配置Portal认证前用户使用的地址池。
ipv6:表示IPv6 Portal用户。若不指定该参数,则表示IPv4 Portal用户。
pool-name:表示IP地址池的名称,为1~63个字符的字符串,不区分大小写。
在Portal用户通过设备的子接口接入网络的组网环境中,当子接口上未配置IP地址,且用户需要通过DHCP获取地址时,就必须通过本命令指定一个地址池,并在用户进行Portal认证之前为其分配一个IP地址使其可以进行Portal认证。
仅当接口使用直接认证方式的情况下,接口上为认证前的Portal用户指定的IP地址池才能生效。
当使用接口上指定的IP地址池为认证前的Portal用户分配IP地址时,该指定的IP地址池必须存在且配置完整,否则无法为Portal用户分配IP地址,并导致用户无法进行Portal认证。
# 在接口GigabitEthernet3/1/1上为认证前的Portal用户指定IPv4地址池为abc。
[Sysname-GigabitEthernet3/1/1] portal pre-auth ip-pool abc
·     dhcp server ip-pool(BRAS业务命令参考/DHCP)
·     display portal
·     ipv6 dhcp pool(BRAS业务命令参考/DHCP)
1.1.61  portal pre-auth policy
portal pre-auth policy命令用来创建Portal认证前策略,并进入Portal认证前策略视图。如果指定的Portal认证前策略已经存在,则直接进入Portal认证前策略视图。
undo portal pre-auth policy命令用来删除指定的Portal认证前策略。
portal pre-auth policy policy-name
undo portal pre-auth policy policy-name
不存在Portal认证前策略。
Portal认证前策略用来定义未认证Portal用户访问的策略,具体包括ACL、User Profile和CAR。当Portal认证前策略中的配置或配置参数的内容发生变化后,策略的修改对引用此策略接口上的所有未认证Portal用户立即生效。
可通过多次执行本命令,配置多条Portal认证前策略。
# 创建名称为abc的Portal认证前策略,并进入Portal认证前策略视图。
[Sysname] portal pre-auth policy abc
[Sysname-pre-auth-abc]
·     user-attribute
1.1.62  portal roaming enable
portal roaming enable命令用来开启Portal用户漫游功能。
undo portal roaming enable命令用来关闭Portal用户漫游功能。
Portal用户漫游功能处于关闭状态,即Portal用户上线后不能在所在的VLAN内漫游。
Portal用户漫游功能只对通过VLAN接口上线的Portal用户有效。
设备上有用户在线或认证前域用户的情况下,不能更改Portal用户漫游功能的配置。
如果开启了Portal用户漫游功能,则Portal用户上线后可以在开启Portal的VLAN内漫游,即用户通过VLAN内的任何二层端口都可以访问网络资源;否则用户只能通过认证成功的二层端口访问网络资源。
# 开启Portal用户漫游功能。
[Sysname] portal roaming enable
1.1.63  portal server
portal server命令用来创建Portal认证服务器,并进入Portal认证服务器视图。如果指定的Portal认证服务器已经存在,则直接进入Portal认证服务器视图。
undo portal server命令用来删除指定的Portal认证服务器。
portal server server-name
undo portal server server-name
不存在Portal认证服务器。
Portal认证服务器视图用于配置Portal认证服务器的相关参数,包括服务器的IP地址、端口号,服务器所在的VPN实例,设备和服务器间通信的预共享密钥,服务器探测功能等。
可以配置多个Portal认证服务器。
# 创建名称为pts的Portal认证服务器,并进入Portal认证服务器视图。
1.1.64  portal traffic-backup threshold
portal traffic-backup threshold命令用来配置对Portal用户流量进行备份的阈值。
undo portal traffic-backup threshold命令用来恢复缺省情况。
portal traffic-backup threshold value
Portal用户流量备份阈值为10兆字节。
value:对Portal用户流量进行备份的阈值,取值范围为0~100000,单位为兆字节。取值为0时,表示对Portal用户流量进行实时备份。
缺省情况下,流量备份的阈值为10M字节,即用户流量达到10M字节时设备会对该Portal用户的会话数据以及流量等信息进行备份。流量备份的阈值越小备份越频繁,流量备份越精确。当设备上有大量Portal用户在线时,对Portal用户信息进行频繁备份会影响到用户的上下线以及计费等流程的处理性能。因此,需综合考虑对各业务的处理性能和流量备份的精确度合理配置流量备份阈值。
# 配置对Portal用户流量进行备份的阈值为10240兆字节。
[Sysname] portal traffic-backup threshold 10240
1.1.65  portal user log enable
portal user log enable命令用来开启Portal用户上/下线日志功能。
undo portal user log enable命令用来关闭Portal用户上/下线日志功能。
portal user log enable [ abnormal-logout | failed-login | normal-logout | successful-login ] *
undo portal user log enable [ abnormal-logout | failed-login | normal-logout | successful-login ] *
Portal用户上/下线日志功能处于关闭状态。
abnormal-logout:用户异常下线的日志信息。
failed-login:用户上线失败的日志信息。
normal-logout:用户正常下线的日志信息。
successful-login:用户上线成功的日志信息。
开启本功能后,设备会对用户上线和下线时的信息进行记录,包括用户名、IP地址、接口名称、VLAN、用户MAC地址、上线失败原因等。生成的日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启Portal用户上线成功的日志信息功能。
[Sysname] portal user log enable successful-login
·     portal packet log enable
·     portal redirect log enable
1.1.66  portal user-block failed-times
portal user-block failed-times命令用来开启Portal认证失败后的用户阻塞功能。
undo portal user-block failed-times命令用来关闭Portal认证失败后的用户阻塞功能。
portal user-block failed-times failed-times period period
Portal认证失败后的用户阻塞功能处于关闭状态。
failed-times:表示允许用户进行Portal认证失败的最大次数,取值范围为0~10。取值为0时表示Portal认证的次数不受限制。
period period:表示用户连续认证失败的检测时长。period的取值范围为1~120,单位为分钟。
如果在指定时间内用户进行Portal认证失败达到限定次数,该用户将被阻塞,即来自该用户的认证请求报文将被丢弃。阻塞时长由命令portal user-block reactive配置。通过配置该功能,可防止非法用户使用穷举法试探合法用户的密码。
需要注意的是,Portal认证前域中的用户在指定时间内认证失败达到限定次数后不会被阻塞。
# 配置在100分钟内用户进行Portal认证失败次数达到2次时被阻塞。
[Sysname] portal user-block failed-times 2 period 100
·     portal user-block reactive
1.1.67  portal user-block reactive
portal user-block reactive命令用来配置Portal用户被阻塞的时长。
undo portal user-block reactive命令用来恢复缺省情况。
portal user-block reactive period
被阻塞的用户重新进行Portal认证的时间间隔为30分钟。
period:表示被阻塞的用户重新进行Portal认证的时间间隔,取值范围为0~1000,单位为分钟。取值为0时表示被阻塞的用户不能重新进行Portal认证。
配置用户进行Portal认证的最大失败次数后(通过命令portal user-block failed-times),如果在指定时间内用户连续认证失败,用户会被阻塞。用户可以通过配置该命令改变被阻塞用户重新进行Portal认证的时间间隔。
# 配置被阻塞用户重新进行Portal认证的时间间隔为20分钟。
[Sysname] portal user-block reactive 20
·     portal user-block failed-times
1.1.68  portal user-detect
portal user-detect命令用来开启IPv4 Portal用户在线探测功能。
undo portal user-detect命令用来关闭IPv4 Portal用户在线探测功能。
portal user-detect type { arp | icmp } [ retry retries ] [ interval interval ] [ idle time ]
IPv4 Portal用户在线探测功能处于关闭状态。
type:指定探测类型。
·     arp:表示探测类型为ARP。
·     icmp:表示探测类型为ICMP。
·     当探测类型为ICMP时,若设备发现一定时间(idle time)内接口上未收到某Portal用户的报文,则会向该用户定期(interval interval)发送探测报文。如果在指定探测次数(retry retries)之内,设备收到了该用户的响应报文,则认为用户在线,且停止发送探测报文,重复这个过程,否则,强制其下线。
·     当探测类型为ARP时,若设备发现一定时间(idle time)内接口上未收到某Portal用户的报文,则会向该用户发送ARP请求报文。设备定期(interval interval)检测用户ARP表项是否被刷新过,如果在指定探测次数(retry retries)内用户ARP表项被刷新过,则认为用户在线,且停止检测用户ARP表项,重复这个过程,否则,强制其下线。
请根据配置的认证方式选择合适的探测方法,如果配置了直接方式或者二次地址分配方式,则可以使用ARP或ICMP探测方式,如果配置了可跨三层认证方式,则仅可以使用ICMP探测方式,若配置了ARP探测方式,则探测功能不生效。
如果用户接入设备上配置了阻止ICMP报文的防火墙策略,则接口上的ICMP探测方式可能会失败,从而导致接口上的Portal用户非正常下线。因此,若接口上需要使用ICMP探测方式,请保证用户接入设备不会过滤掉ICMP报文。
# 在接口GigabitEthernet3/1/1上开启Portal用户在线探测功能:探测类型为ICMP,发送探测报文的次数为5次,发送间隔为10秒,闲置时间为300秒。
[Sysname–GigabitEthernet3/1/1] portal user-detect type icmp retry 5 interval 10 idle 300
·     display portal
1.1.69  portal user-dhcp-only
portal user-dhcp-only命令用来开启仅允许通过DHCP方式获取IP地址的客户端上线的功能。
undo portal user-dhcp-only命令用来关闭仅允许通过DHCP方式获取IP地址的客户端上线的功能。
portal [ ipv6 ] user-dhcp-only
undo portal [ ipv6 ] user-dhcp-only
仅允许通过DHCP方式获取IP地址的客户端上线的功能处于关闭状态,通过DHCP方式获取IP地址的客户端和配置静态IP地址的客户端都可以上线。
ipv6:表示允许上线的客户端的IP地址为IPv6地址,如果不指定本参数,则表示允许上线的客户端的IP地址为IPv4地址。
配置本命令后,配置静态IP地址的Portal认证用户不能上线。
本命令仅在DHCP客户端和DHCP服务器处于同一物理网段的组网中生效。
在IPv6网络中,配置本命令后,终端仍会使用临时IPv6地址进行Portal认证,从而导致认证失败,所以必须关闭临时IPv6地址。
# 在接口GigabitEthernet3/1/1上配置仅允许通过DHCP获取IP地址的客户端上线功能。
[Sysname-GigabitEthernet3/1/1] portal user-dhcp-only
·     display portal
1.1.70  portal user-rule assign-check enable
portal user-rule assign-check enable命令用来开启第二类Portal过滤规则下发的完整性检查功能。
undo portal user-rule assign-check enable命令用来关闭第二类Portal过滤规则下发的完整性检查功能。
第二类Portal过滤规则下发的完整性检查功能处于关闭状态。
缺省情况下,用户通过认证后,只要有一块单板成功下发第二类Portal过滤规则,用户就可以上线,对于通过全局接口接入的用户,上线后可能会无法正常访问网络。开启本功能后,只有设备上所有单板都成功下发第二类Portal过滤规则,才会允许用户上线。在全局接口上使能Portal认证时,建议开启下发第二类Portal过滤规则的完整性检查功能,可确保用户上线后可以正常访问网络。
下发的第二类Portal过滤规则,可通过display portal rule dynamic命令查看。
# 开启第二类Portal过滤规则下发的完整性检查功能。
[Sysname] portal user-rule assign-check enable
1.1.71  portal web-proxy port
portal web-proxy port命令用来配置允许触发Portal认证的Web代理服务器端口。
undo portal web-proxy port命令用来删除指定或所有的Web代理服务器端口。
portal web-proxy { http | https } port port-number
undo portal web-proxy { { http | https } port port-number | all-port }
未配置允许触发Portal认证的Web代理服务器端口。
http:表示HTTP请求触发Portal认证。
https:表示HTTPS请求触发Portal认证。
port-number:Portal认证的Web代理服务器的TCP端口号,取值范围为1~65535。80和443端口是Portal预留端口号,Portal认证的Web代理服务器的TCP端口号不能配置为80和443。
all-port:指定所有Portal认证的Web代理服务器的TCP端口号。
设备默认只允许未配置Web代理服务器的用户浏览器发起的HTTP/HTTPS请求才能触发Portal认证。若用户使用配置了Web代理服务器的浏览器上网,则用户的这类HTTP/HTTPS请求报文将被丢弃,而不能触发Portal认证。这种情况下,网络管理员可以通过在设备上添加Web代理服务器的TCP端口号,来允许使用Web代理服务器的用户浏览器发起的HTTP/HTTPS请求也可以触发Portal认证。
配置允许触发Portal认证的Web代理服务器端口,需要注意的是:
·     通过多次执行本命令,最多可以添加64个允许触发Portal认证的Web代理服务器端口。
·     HTTP和HTTPS请求允许触发Portal认证的Web代理服务器端口不能相同。
如果用户浏览器采用WPAD(Web Proxy Auto-Discovery,Web代理服务器自动发现)方式自动配置Web代理,还需要注意以下几点:
·     配置允许触发Portal认证的Web代理服务器端口的同时,还需要配置免认证规则,允许目的IP为WPAD主机IP地址的用户报文免认证。
·     需要用户在浏览器上将Portal认证服务器的IP地址配置为Web代理服务器的例外地址,避免Portal用户发送给Portal认证服务器的HTTP/HTTPS报文被发送到Web代理服务器上,从而影响正常的Portal认证。
# 配置HTTP请求允许触发Portal认证的Web代理服务器端口号为8080。
[Sysname] portal web-proxy http port 8080
·     portal enable method
1.1.72  portal web-server
portal web-server命令用来创建Portal Web服务器,并进入Portal Web服务器视图。如果指定的Portal Web服务器已经存在,则直接进入Portal Web服务器视图。
undo portal web-server命令用来删除Portal Web服务器。
portal web-server server-name
undo portal web-server server-name
不存在Portal Web服务器。
Portal Web服务器是指Portal认证过程中向用户推送认证页面的Web服务器,也是设备强制重定向用户HTTP/HTTPS请求报文时所指的Web服务器。Portal Web服务器视图用于配置该Web服务器的URL地址及配置设备重定向该URL地址给用户时URL地址所携带的参数,同时该视图还用于配置Portal Web服务器探测等功能。
# 创建名称为wbs的Portal Web服务器,并进入Portal Web服务器视图。
[Sysname] portal web-server wbs
·     display portal web-server
·     portal apply web-server
1.1.73  refresh portal
refresh portal命令用来根据当前在线Portal用户信息更新Rule ARP/ND表项。
refresh portal { rule-arp | rule-nd }
rule-arp:表示根据当前在线Portal用户信息更新Rule ARP表项。
rule-nd:表示根据当前在线Portal用户信息更新Rule ND表项。
设备上生成的Rule ARP/ND表项,在Portal客户端下线后会被立即删除。特殊情况下,Portal客户端下线后,设备上的Portal用户信息被删除,但对应的Rule表项未被删除。此时,Portal用户信息(通过display portal user all命令查看)和Rule ARP/ND表项信息不一致(通过display arp alldisplay ipv6 neighbors命令查看),可能会导致Portal客户端无法重新上线。为了解决这个问题,执行根据当前在线Portal用户信息更新Rule ARP/ND表项操作,可以删除残留的Rule ARP/ND表项,从而保证了Rule ARP/ND表项信息和Portal用户信息一致性。
大量Portal用户同时上下线时,建议不要执行本操作,否则会影响设备处理Portal用户上下线的整体性能。
# 根据当前在线Portal用户信息更新Rule ARP表项。
<Sysname> refresh portal rule-arp
·     display arp
·     display ipv6 neighbors
1.1.74  reset portal http-defense attacked-ip
reset portal http-defense attacked-ip命令用来清除HTTP/HTTPS防攻击中被阻塞过的目的IP统计信息。
(独立运行模式)
reset portal http-defense attacked-ip [ slot slot-number ]
reset portal http-defense attacked-ip [ chassis chassis-number slot slot-number ]
slot slot-number:清除指定单板上HTTP/HTTPS防攻击中被阻塞过的目的IP统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示清除所有单板上HTTP/HTTPS防攻击中被阻塞过的目的IP统计信息。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备的指定单板上HTTP/HTTPS防攻击中被阻塞过的目的IP统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示清除所有单板上HTTP/HTTPS防攻击中被阻塞过的目的IP统计信息。(IRF模式)
# 清除slot 3上HTTP/HTTPS防攻击中被阻塞过的目的IP统计信息。
<Sysname> reset portal http-defense attacked-ip slot 3
·     display portal http-defense attacked-ip
1.1.75  reset portal http-defense blocked-ip
reset portal http-defense blocked-ip命令用来清除被阻塞的目的IP地址记录。
(独立运行模式)
reset portal http-defense blocked-ip [ ip ipv4-address | ipv6 ipv6-address ] [ slot slot-number ]
reset portal http-defense blocked-ip [ ip ipv4-address | ipv6 ipv6-address ] [ chassis chassis-number slot slot-number ]
ip ipv4-address:清除指定的被阻塞的目的IP地址记录。
ipv6 ipv6-address:清除指定的被阻塞目的IPv6地址记录。
slot slot-number:清除指定单板上被阻塞的目的IP地址记录。slot-number表示单板所在的槽位号。若不指定该参数,则表示清除所有单板上被阻塞的目的IP地址记录。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备的指定单板上被阻塞的目的IP地址记录。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示清除所有单板上被阻塞的目的IP地址记录。(IRF模式)
清除被阻塞IP地址记录之后,允许用户对该IP地址进行正常访问。
若不指定参数IP/IPv6,则清除所有被阻塞的目的IP地址记录。
# 清除slot 3上被阻塞的目的IP地址为1.1.1.1的记录。
<Sysname> reset portal http-defense blocked-ip 1.1.1.1 slot 3
·     display portal http-defense blocked-ip
1.1.76  reset portal ip-subscriber message statistics
reset portal ip-subscriber message statistics命令用来清除Portal与IPoE的交互消息统计信息。
# 清除Portal与IPoE的交互消息统计信息。
<Sysname> reset portal ip-subscriber message statistics
·     display portal ip-subscriber message statistics
1.1.77  reset portal mac-trigger-server packet statistics
reset portal mac-trigger-server packet statistics命令用来清除设备与MAC绑定服务器的交互报文统计信息。
# 清除设备与MAC绑定服务器的交互报文统计信息。
<Sysname> reset portal mac-trigger-server packet statistics
·     display portal mac-trigger-server packet statistics
1.1.78  reset portal packet statistics
reset portal packet statistics命令用来清除Portal报文的统计信息。
reset portal packet statistics [ server server-name ]
server-name:Portal认证服务器的名称,为1~32个字符的字符串,区分大小写。
若不指定参数server,则清除所有Portal认证服务器的报文统计信息。
# 清除名称为pts上的Portal认证服务器的统计信息。
<Sysname> reset portal packet statistics server pts
·     display portal packet statistics
1.1.79  server-detect (portal authentication server view)
server-detect命令用来开启Portal认证服务器的可达性探测功能。开启Portal认证服务器的可达性探测功能后,设备会定期检测Portal认证服务器发送的Portal报文来判断服务器的可达状态。
undo server-detect命令用来关闭Portal认证服务器的可达性探测功能。
server-detect [ timeout timeout ] log
undo server-detect
Portal认证服务器的可达性探测功能处于关闭状态。
Portal认证服务器视图
timeout timeout:探测超时时间,取值范围为10~3600,单位为秒,缺省值为60。
log:Portal认证服务器可达或者不可达的状态改变时,发送日志信息。日志信息中记录了Portal认证服务器名以及该服务器状态改变前后的状态。
只有当设备上存在开启Portal认证的接口时,Portal认证服务器的可达性探测功能才生效。
只有在支持Portal服务器心跳功能(目前仅iMC的Portal认证服务器支持)的Portal认证服务器的配合下,本功能才有效。
若设备在指定的探测超时时间(timeout timeout)内收到Portal报文,且验证其正确,则认为此次探测成功且服务器可达,否则认为此次服务器不可达。
设备配置的探测超时时间(timeout timeout)必须大于服务器上配置的逃生心跳间隔时间。
# 开启对Portal认证服务器pts的探测功能,探测超时时间为600秒,若服务器状态改变,则发送日志信息。
[Sysname-portal-server-pts] server-detect timeout 600 log
·     portal server
1.1.80  server-detect (portal web server view)
server-detect命令用来开启Portal Web服务器的可达性探测功能。
undo server-detect命令用来关闭Portal Web服务器的可达性探测功能。
server-detect [ interval interval ] [ retry retries ] log
undo server-detect
Portal Web服务器的可达性探测功能处于关闭状态。
Portal Web服务器视图
interval interval:进行探测尝试的时间间隔,取值范围为10~1200,单位为秒,缺省值为20。
retry retries:连续探测失败的最大次数,取值范围为1~10,缺省值为3。若连续探测失败数目达到此值,则认为服务器不可达。
log:Portal Web服务器可达或者不可达的状态改变时,发送日志信息。日志信息中记录了Portal Web服务器名以及该服务器状态改变前后的状态。
该探测方法可由设备独立完成,不需要Portal Web服务器端的任何配置来配合。
只有当配置了Portal Web服务器的URL地址,且设备上存在开启Portal认证接口时,该Portal Web服务器的可达性探测功能才生效。
# 配置对Portal Web服务器wbs的探测功能,每次探测间隔时间为600秒,若连续二次探测均失败,则发送服务器不可达的日志信息。
[Sysname-portal-websvr-wbs] server-detect interval 600 retry 2 log
·     portal web-server
1.1.81  server-register
server-register命令用来配置设备定期向Portal认证服务器发送注册报文。
undo server-register命令用来恢复缺省情况。
server-register [ interval interval-value ]
设备不会定期向Portal认证服务器发送注册报文。
Portal认证服务器视图
interval interval-value:设备定期向Portal认证服务器发送注册报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为600。
Portal服务器与接入设备认证交互时,如果二者之间有NAT设备,为了使Portal服务器能够访问该接入设备,在NAT设备上需配置静态NAT表项,该静态NAT表项中记录了接入设备的IP地址以及与Portal服务器交互时使用的转换后的IP地址。当有大量的接入设备需要与Portal服务器进行认证交互时,则需要在NAT设备上配置大量的静态NAT表项。开启本功能后,接入设备会主动向Portal服务器发送注册报文,该报文中携带了接入设备的名称。Portal服务器收到该注册报文,记录下接入设备的名称、地址转换后的IP地址以及端口号等信息后,后续这些信息用于与接入设备进行认证交互。接入设备通过定期发送注册报文更新Portal服务器上维护的注册信息。
需要注意的是,本功能仅用于和CMCC类型的Portal服务器配合使用。
# 配置设备每隔120秒向Portal认证服务器发送注册报文。
[Sysname-portal-server-pts] server-register interval 120
·     server-type
1.1.82  server-type
server-type命令用来配置Portal认证服务器或Portal Web服务器的类型。
undo server-type命令用来恢复缺省情况。
server-type { cmcc | imc }
undo server-type
Portal认证服务器或Portal Web服务器的类型为iMC服务器。
Portal认证服务器视图
Portal Web服务器视图
cmcc:表示Portal服务器类型为符合中国移动标准规范的服务器。
imc:表示Portal服务器类型为符合iMC标准规范的服务器。
设备配置的Portal服务器类型必须保证与设备所使用的服务器类型保持一致。
# 配置Portal认证服务器类型为CMCC。
[Sysname-portal-server-pts] server-type cmcc
# 配置Portal Web服务器类型为CMCC。
[Sysname] portal web-server pts
[Sysname-portal-websvr-pts] server-type cmcc
1.1.83  server-type (MAC binding server view)
server-type命令用来配置MAC绑定服务器的服务类型。
undo server-type用来恢复缺省情况。
undo server-type
MAC绑定服务器的服务类型为imc。
MAC绑定服务器视图
cmcc:表示MAC绑定服务器类型为符合中国移动标准规范的服务器。
imc:表示MAC绑定服务器类型为符合iMC标准规范的服务器。
# 指定MAC绑定服务器的服务类型为cmcc。
[Sysname-portal-mac-trigger-server-mts] server-type cmcc
1.1.84  tcp-port
tcp-port命令用来配置本地Portal Web服务的HTTP/HTTPS服务侦听的TCP端口号。
undo tcp-port命令用来恢复缺省情况。
undo tcp-port
HTTP服务侦听的TCP端口号为80,HTTPS服务侦听的TCP端口号为portal local-web-server命令指定的TCP端口号。
本地Portal Web服务视图
port-number:表示侦听的TCP端口号,取值范围为1~65535。
接口上指定的Portal Web服务器的URL中配置的端口号,应该与本地Portal Web服务视图下指定的侦听端口号保持一致。
配置本地Portal Web服务的HTTP/HTTPS服务侦听的TCP端口号时,需要注意的是:
·     除了HTTP和HTTPS协议默认的端口号,本地Portal Web服务的TCP端口号不能与知名协议使用的端口号配置一致,如FTP的端口号21;Telnet的端口号23,否则会造成本地Web Server无法收到用户的认证或下线请求数据。
·     不能把使用HTTP协议的本地Portal Web服务下的TCP端口号配置成HTTPS的默认端口号443,反之亦然。
·     使用HTTP和HTTPS的本地Portal Web服务下TCP端口号不能配置一致,比如不能都配置为8080,否则会导致本地Web服务无法正常使用。
·     如果本地Portal Web服务引用的SSL服务器端策略与HTTPS服务引用的SSL服务器端策略相同,则本地Portal Web服务使用的TCP端口号可以与HTTPS服务器使用的TCP端口号相同;否则使用TCP端口号不能相同。
# 配置本地Portal Web服务的HTTP服务侦听的TCP端口号为2331。
[Sysname-portal-local-websvr-http] tcp-port 2331
·     portal local-web-server
1.1.85  url
url命令用来指定Portal Web服务器的URL。
undo url命令用来恢复缺省情况。
url url-string
undo url
未指定Portal Web服务器的URL。
Portal Web服务器视图
url-string:Portal Web服务器的URL,为1~256个字符的字符串,区分大小写。
本命令指定的URL是可用标准HTTP或者HTTPS协议访问的URL,它以http://或者https://开头。如果该URL未以http://或者https://开头,则缺省认为是以http://开头。
# 配置Portal Web服务器wbs的URL为http://www.test.com/portal。
[Sysname-portal-websvr-wbs] url http://www.test.com/portal
1.1.86  url-parameter
url-parameter命令用来配置设备重定向给用户的Portal Web服务器的URL中携带的参数信息。
undo url-parameter命令用来删除配置的Portal Web服务器URL携带的参数信息。
url-parameter param-name { nas-id | nas-port-id | original-url | source-address | source-mac [ encryption { aes | des } key { cipher | simple } string ] | value expression }
undo url-parameter param-name
未配置设备重定向给用户的Portal Web服务器的URL中携带的参数信息。
Portal Web服务器视图
param-name:URL参数名,为1~32个字符的字符串,区分大小写。URL参数名对应的参数内容由param-name后的参数指定。
nas-id:网络接入服务器标识。
nas-port-id:网络接入服务器端口标识。
original-url:用户初始访问的Web页面的URL。
source-address:用户的IP地址。
source-mac:用户的MAC地址。
encryption:表示以密文的方式携带用户的MAC地址。
aes指定加密算法为AES算法。
des指定加密算法为DES算法。
cipher:以密文方式设置密钥。
key:指定加密密钥。
·     对于des cipher,密钥为41个字符的字符串。
·     对于des simple,密钥为8个字符的字符串。
·     对于aes cipher,密钥为1~73个字符的字符串。
·     对于aes simple,密钥为1~31个字符的字符串。
value expression:自定义字符串,为1~256个字符的字符串,区分大小写。
可以通过多次执行本命令配置多条参数信息。
对于同一个参数名param-name后的参数设置,最后配置的生效。
该命令用于配置用户访问Portal Web服务器时,要求携带的一些参数,比较常用的是要求携带用户的IP地址、MAC地址、用户原始访问的URL信息。用户也可以手工指定,携带一些特定的字符信息。配置完成后,在设备给用户强制重定向URL时会携带这些参数,例如配置Portal Web服务器的URL为:http://www.test.com/portal,若同时配置如下两个参数信息:url-parameter userip source-addressurl-parameter userurl value http://www.abc.com/welcome,则设备给源IP为1.1.1.1的用户重定向时回应的URL格式即为:http://www.test.com/portal?userip=1.1.1.1&userurl=http://www.abc.com/welcome。
param-name这个URL参数名必须与具体应用环境中的Portal服务器所支持的URL参数名保持一致,不同的Portal服务器支持URL参数名是不一样的,请根据具体情况配置URL参数名。例如iMC服务器支持的URL参数名如下:
·     userurl:表示original-url
·     userip:表示source-address
·     usermac:表示source-mac
在Portal服务器为H3C公司的iMC服务器的组网环境中,如果设备重定向给用户的Portal Web服务器的URL中需要携带用户的IP地址参数信息时,必须把param-name参数配置成userip,否则,iMC服务器不能识别用户的IP地址。
如果给某个参数配置了加密方式,则重定向URL中携带的将是其加密后的值。例如在上述配置的基础上,再配置url-parameter usermac source-mac encryption des key simple 12345678则设备给源MAC地址为1111-1111-1111的用户重定向时回应的URL格式即为:http://www.test.com/portal?usermac=xxxxxxxxx&userip=1.1.1.1&userurl= http://www.test.com/welcome,其中xxxxxxxxx为加密后的用户mac地址。
# 为设备重定向给用户的Portal Web服务器wbs的URL中配置两个参数userip和userurl,其值分别为用户IP地址和自定义字符串http://www.abc.com/welcome。
[Sysname-portal-websvr-wbs] url-parameter userip source-address
[Sysname-portal-websvr-wbs] url-parameter userurl value http://www.abc.com/welcome
# 为设备重定向给用户的Portal Web服务器wbs的URL中配置参数usermac,其值为用户mac地址,并使用des算法进行加密。
[Sysname-portal-websvr-wbs] url-parameter usermac source-mac encryption des key simple 12345678
·     url
1.1.87  user-attribute
user-attribute命令用来配置Portal认证前策略中的用户属性。
undo user-attribute命令用来删除指定的用户属性。
user-attribute { acl acl-number | car { inbound | outbound } cir committed-information-rate [ pir peak-information-rate ] | user-profile profile-name }
undo user-attribute { acl | car { inbound | outbound } | user-profile }
Portal认证前策略中无用户属性。
Portal认证前策略视图
acl acl-number:指定用于匹配Portal认证前用户流量的ACL。其中acl-number表示ACL的编号,取值范围及其代表的ACL类型如下:
·     2000~2999:表示基本ACL。
·     3000~3999:表示高级ACL。
car:指定Portal认证前用户的流量监管动作。
inbound:表示用户的上传速率。
outbound:表示用户的下载速率。
cir committed-information-rate:承诺信息速率,取值范围为8~160000000,单位为kbps。
pir peak-information-rate:峰值速率,取值范围为8~160000000,单位为kbps。若不指定该参数,则表示不对峰值信息速率进行限制。
user-profile profile-name:指定Portal认证前用户的User Profile。profile-name表示User Profile的名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线、减号和英文句号,支持以字母或数字开头,但不能为纯数字,区分大小写。User Profile的名称必须全局唯一。
可通过多次执行本命令配置多个用户属性,对于相同用户属性,最后一次执行的命令生效。
# 配置Portal认证前策略abc引用的ACL为3000。
[Sysname-portal-preauth-policy-abc] user-attribute acl 3000
1.1.88  user-sync
user-sync命令用来配置开启Portal用户信息同步功能。
undo user-sync命令用来关闭Portal用户信息同步功能。
user-sync timeout timeout
undo user-sync
Portal认证服务器的Portal用户信息同步功能处于关闭状态。
Portal认证服务器视图
timeout timeout:检测用户同步报文的时间间隔,取值范围为60~18000,单位为秒。
配置此功能后,设备会响应并周期性地检测指定的Portal认证服务器发来的用户同步报文,以保持设备与该服务器上在线用户信息的一致性。
只有在支持Portal用户心跳功能(目前仅iMC的Portal认证服务器支持)的Portal认证服务器的配合下,本功能才有效。为了实现该功能,还需要在Portal认证服务器上选择支持用户心跳功能,且服务器上配置的用户心跳间隔要小于等于设备上配置的检测超时时间。
在设备上删除Portal认证服务器时将会同时删除该服务器的用户信息同步功能配置。
对同一服务器多次执行本命令,最后一次执行的命令生效。
对于设备上多余的用户信息,即在检测用户同步报文的时间间隔timeout到达后被判定为Portal认证服务器上已不存在的用户信息,设备会在timeout后的某时刻将其删除掉。
如果服务器同步过来的用户信息在设备上不存在,则设备会将这些用户的IP地址封装在用户心跳回应报文中发送给服务器,由服务器删除多余的用户。
# 配置对Portal认证服务器pts的Portal用户信息同步功能,检测用户同步报文的时间间隔为600秒,如果设备中的某用户信息在600秒内未在该Portal认证服务器发送的同步报文中出现,设备将强制该用户下线。
[Sysname-portal-server-pts] user-sync timeout 600
·     portal server
1.1.89  version
version命令用来配置Portal协议报文的版本号。
undo version命令用来恢复缺省情况。
version version-number
undo version
Portal协议报文的版本号为1。
MAC绑定服务器视图
version-number:Portal协议报文的版本号,取值范围为1~3。
配置Portal协议报文的版本必须与MAC绑定服务器要求的Portal协议版本保持一致。
# 配置设备向MAC绑定服务器mts发送Portal协议报文时,使用的版本为版本2。
[Sysname-portal-mac-trigger-server-mts] version 2
1.1.90  vpn-instance
vpn-instance命令用来配置Portal Web服务器所属的VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
Portal Web服务器位于公网中。
Portal Web服务器视图
vpn-instance-name:Portal Web服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
一个Portal Web服务器只能属于一个VPN实例。
# 配置Portal Web服务器wbs所属的VPN实例为abc。
[Sysname-portal-websvr-wbs] vpn-instance abc
1.1.91  web-redirect url
web-redirect url命令用来配置Web重定向功能。
undo web-redirect命令用来关闭Web重定向功能。
web-redirect [ ipv6 ] url url-string [ interval interval ]
undo web-redirect [ ipv6 ]
Web重定功能处于关闭状态。
ipv6:表示IPv6 Web重定向功能。若不指定该参数,则表示IPv4 Web重定向功能。
url url-string:Web重定向的地址,即用户的Web访问请求被重定向的URL地址,为1~256个字符的字符串,必须是以http://或者https://开头的完整URL路径。
interval interval:对用户访问的Web页面进行重定向的周期,取值范围为60~86400,单位为秒,缺省值为86400。
请不要同时开启Web重定向功能和Portal功能,否则Web重定向功能不能生效。
接口上配置了Web重定向功能后,当该接口上接入的用户初次通过Web页面访问外网时,设备会将用户的初始访问页面重定向到指定的URL页面,之后用户才可以正常访问外网,经过一定时长(interval)后,设备又可以对用户要访问的网页或者正在访问的网页重定向到指定的URL页面。
Web重定向功能仅对使用默认端口号80的HTTP协议报文生效。
# 在接口GigabitEthernet3/1/1上配置IPv4 Web重定向功能:Web重定向地址为http://192.0.0.1,Web重定向周期为3600秒。
[Sysname-GigabitEthernet3/1/1] web-redirect url http://192.0.0.1 interval 3600
·     display web-redirect rule
