09-MPLS命令参考
02-MPLS TE命令
本章节下载: 02-MPLS TE命令  (617.05 KB)
02-MPLS TE命令
1 MPLS TE
1.1 MPLS TE配置命令
1.1.1 add hop
1.1.2 delete hop
1.1.3 display explicit-path
1.1.4 display isis traffic-eng advertisements
1.1.5 display isis traffic-eng link
1.1.6 display isis traffic-eng network
1.1.7 display isis traffic-eng statistics
1.1.8 display isis traffic-eng sub-tlvs
1.1.9 display mpls lsp bfd te
1.1.10 display mpls rsvp-te
1.1.11 display mpls rsvp-te established
1.1.12 display mpls rsvp-te peer
1.1.13 display mpls rsvp-te psb-content
1.1.14 display mpls rsvp-te request
1.1.15 display mpls rsvp-te reservation
1.1.16 display mpls rsvp-te rsb-content
1.1.17 display mpls rsvp-te sender
1.1.18 display mpls rsvp-te statistics
1.1.19 display mpls static-cr-lsp
1.1.20 display mpls te cspf tedb
1.1.21 display mpls te ds-te
1.1.22 display mpls te link-administration admission-control
1.1.23 display mpls te link-administration bandwidth-allocation
1.1.24 display mpls te protection tunnel
1.1.25 display mpls te tunnel
1.1.26 display mpls te tunnel path
1.1.27 display mpls te tunnel statistics
1.1.28 display mpls te tunnel-interface
1.1.29 display ospf mpls-te
1.1.30 display ospf traffic-adjustment
1.1.31 display tunnel-info
1.1.32 enable traffic-adjustment
1.1.33 enable traffic-adjustment advertise
1.1.34 explicit-path
1.1.35 list hop
1.1.36 moam dm
1.1.37 moam lm
1.1.38 modify hop
1.1.39 mpls rsvp-te
1.1.40 mpls rsvp-te authentication
1.1.41 mpls rsvp-te bfd enable
1.1.42 mpls rsvp-te blockade-multiplier
1.1.43 mpls rsvp-te dscp
1.1.44 mpls rsvp-te graceful-restart
1.1.45 mpls rsvp-te hello
1.1.46 mpls rsvp-te hello-lost
1.1.47 mpls rsvp-te keep-multiplier
1.1.48 mpls rsvp-te reliability
1.1.49 mpls rsvp-te resvconfirm
1.1.50 mpls rsvp-te srefresh
1.1.51 mpls rsvp-te timer graceful-restart recovery
1.1.52 mpls rsvp-te timer graceful-restart restart
1.1.53 mpls rsvp-te timer hello
1.1.54 mpls rsvp-te timer refresh
1.1.55 mpls rsvp-te timer retransmission
1.1.56 mpls te
1.1.57 mpls te affinity property
1.1.58 mpls te backup
1.1.59 mpls te backup bandwidth
1.1.60 mpls te bandwidth
1.1.61 mpls te bandwidth change thresholds
1.1.62 mpls te bfd enable
1.1.63 mpls te bidirectional
1.1.64 mpls te commit
1.1.65 mpls te cspf
1.1.66 mpls te cspf timer failed-link
1.1.67 mpls te ds-te ietf bc-mode
1.1.68 mpls te ds-te ietf te-class
1.1.69 mpls te ds-te mode
1.1.70 mpls te failure-action teardown
1.1.71 mpls te fast-reroute
1.1.72 mpls te fast-reroute bypass-tunnel
1.1.73 mpls te igp advertise
1.1.74 mpls te igp metric
1.1.75 mpls te igp shortcut
1.1.76 mpls te link administrative group
1.1.77 mpls te load-share
1.1.78 mpls te loop-detection
1.1.79 mpls te max-link-bandwidth
1.1.80 mpls te max-reservable-bandwidth
1.1.81 mpls te max-reservable-bandwidth mam
1.1.82 mpls te max-reservable-bandwidth rdm
1.1.83 mpls te metric
1.1.84 mpls te path
1.1.85 mpls te path metric-type
1.1.86 mpls te periodic-tracert
1.1.87 mpls te priority
1.1.88 mpls te protection switch-mode
1.1.89 mpls te protection tunnel
1.1.90 mpls te protect-switch
1.1.91 mpls te record-route
1.1.92 mpls te reoptimization (User view)
1.1.93 mpls te reoptimization (Tunnel Interface view)
1.1.94 mpls te resv-style
1.1.95 mpls te retry
1.1.96 mpls te route-pinning
1.1.97 mpls te signal-protocol
1.1.98 mpls te tie-breaking
1.1.99 mpls te timer auto-bandwidth
1.1.100 mpls te timer fast-reroute
1.1.101 mpls te timer link-management periodic-flooding
1.1.102 mpls te timer retry
1.1.103 mpls te tunnel-id
1.1.104 mpls te vpn-binding
1.1.105 mpls-te
1.1.106 next hop
1.1.107 opaque-capability
1.1.108 ping lsp te
1.1.109 reset mpls rsvp-te statistics
1.1.110 static-cr-lsp egress
1.1.111 static-cr-lsp ingress
1.1.112 static-cr-lsp transit
1.1.113 statistics te
1.1.114 te-set-subtlv
1.1.115 tracert lsp te
1.1.116 traffic-eng
1 MPLS TE
当系统工作模式为IPv4增强模式时,设备不支持MPLS TE。关于系统工作模式的介绍请参见“基础配置指导”中的“设备管理”。
1.1  MPLS TE配置命令
1.1.1  add hop
add hop ip-address1 [ include [ loose | strict ] | exclude ] { after | before } ip-address2
显式路径视图
【缺省级别】
2:系统级
ip-address1:要插入的节点的IP地址或Router ID,点分十进制形式。
include:指定在显式路径中需要包含插入的节点。
loose:指定插入的节点为松散下一跳,即插入节点的上一跳与插入的节点可以不是直接相连。
strict:指定插入的节点为严格下一跳,即插入节点的上一跳与插入的节点必须直接相连。
exclude:指定在显式路径中不能包括插入的节点。
after:在指定节点ip-address2之后插入新的节点ip-address1。
before:在指定节点ip-address2之前插入新的节点ip-address1。
ip-address2:插入节点前或后的节点的IP地址,点分十进制形式。
【描述】
add hop命令用来向显式路径中插入一个节点,并指定插入节点的属性(显式路径中是否包括插入的节点;插入的节点是松散下一跳,还是严格下一跳)。
·     如果没有指定include和exclude关键字,则缺省为include,即在显式路径中需要包含插入的节点ip-address1。
·     如果没有指定loose和strict关键字,则缺省为strict,即插入节点的上一跳与插入的节点必须直接相连。
# 指定在显示路径path1的节点3.3.10.5后,不能包括下一跳3.3.29.3。
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] add hop 3.3.29.3 exclude after 3.3.10.5
1.1.2  delete hop
delete hop ip-address
显式路径视图
【缺省级别】
2:系统级
ip-address:显式路径的指定节点的IP地址。
【描述】
delete hop命令用来在显式路径中删除指定的一个节点。
# 在MPLS TE显式路径中删除下一跳IP地址10.0.0.1。
[Sysname-explicit-path-path1] delete hop 10.0.0.1
display explicit-path [ pathname ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
pathname:指定路径名,为1~31个字符的字符串。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display explicit-path命令用来显示显式路径信息。
如果不指定路径名,将显示所有显式路径信息。
# 显示所有显式路径信息。
<Sysname> display explicit-path
Path Name : ErHop-Path1  Path Status : Enabled
 1             1.1.1.10         Strict                    Include
 2             2.1.1.10         Strict                    Include
 3             1.1.1.20         Strict                    Include
 4             2.1.1.20         Strict                    Include
 5             2.1.1.30         Strict                    Include
 6             1.1.1.30         Strict                    Include
 7             9.4.4.4          Strict                    Include
Path Name : ErHop-Path2  Path Status : Enabled
 3             1.1.1.40         Strict                    Include
 4             2.1.1.40         Strict                    Include
 5             1.1.1.50         Strict                    Include
 6             2.1.1.40         Strict                    Include
 7             2.1.1.30         Strict                    Include
 8             1.1.1.30         Strict                    Include
 9             9.4.4.4          Strict                    Include
表1-1 display explicit-path命令显示信息描述表
Path Name
显式路径名称
Path Status
显式路径状态
display isis traffic-eng advertisements [ [ level-1 | level-1-2 | level-2 ] | [ lsp-id lsp-id | local ] ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
level-1:Level-1路由器的TE信息。
level-1-2:Level-1-2路由器的TE信息。
level-2:Level-2路由器的TE信息。
lsp-id lsp-id:显示指定LSP(Link State PDU,链路状态协议数据单元) ID发布的TE信息。有关IS-IS的LSP的详细介绍请参见“三层技术-IP路由配置指导”中的“IS-IS”。
local:显示本地发布的TE信息。
process-id:指定IS-IS进程号,取值范围为1~65535。
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的信息。
【描述】
display isis traffic-eng advertisements命令用来显示IS-IS TE最近一次发布的TE信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE信息。
# 显示IS-IS TE最近一次发布的TE信息。
<Sysname> display isis traffic-eng advertisements
                           TE information for ISIS(1)
Level-1 Link State Database
LSPID                 LSP Seq Num  LSP Checksum  LSP Holdtime  ATT/P/OL
0000.0000.0001.00-00* 0x00000001   0x3f57        534           0/0/0
 NLPID      : IPV4
 AREA ADDR  : 00.0005
 INTF ADDR  : 10.1.1.1
 INTF ADDR  : 1.1.1.9
 INTF ADDR  : 30.1.1.1
Level-2 Link State Database
0000.0000.0001.00-00* 0x0000001c   0xf1ec        687           0/0/0
 NLPID      : IPV4
 AREA ADDR  : 00.0005
 INTF ADDR  : 1.1.1.9
 Router ID  : 1.1.1.9
+NBR        : 0000.0000.0002.02  COST: 10
    Admin Group: 0x00000000
    Interface IP Address:  10.1.1.1
    Physical BW  :      12500 Bytes/sec
    Reservable BW:       6250 Bytes/sec
    Unreserved BW for Class Type 0:
    BW Unresrv[0]:       6250 Bytes/sec BW Unresrv[1]:       6250 Bytes/sec
    BW Unresrv[2]:       6250 Bytes/sec BW Unresrv[3]:       6250 Bytes/sec
    BW Unresrv[4]:       6250 Bytes/sec BW Unresrv[5]:       6250 Bytes/sec
    BW Unresrv[6]:       6250 Bytes/sec BW Unresrv[7]:       6250 Bytes/sec
    Unreserved BW for Class Type 1:
    BW Unresrv[0]:          0 Bytes/sec BW Unresrv[1]:          0 Bytes/sec
    BW Unresrv[2]:          0 Bytes/sec BW Unresrv[3]:          0 Bytes/sec
    BW Unresrv[4]:          0 Bytes/sec BW Unresrv[5]:          0 Bytes/sec
    BW Unresrv[6]:          0 Bytes/sec BW Unresrv[7]:          0 Bytes/sec
    TE Cost      :         10
    Bandwidth Constraint Model: Russian Doll
    Bandwidth Constraints:
    BC[0]        :       6250 Bytes/sec BC[1]        :          0 Bytes/sec
+NBR        : 0000.0000.0004.00  COST: 10
    Interface IP Address:  30.1.1.1
    Peer IP Address     :  30.1.1.2
    TE Cost      :         10
表1-2 display isis traffic-eng advertisements命令显示信息描述表
LSPID
LSP ID
LSP Seq Num
LSP序列号
LSP Checksum
LSP校验和
LSP Holdtime
LSP保持时长
ATT/P/OL
LSP中ATT、P、OL的置位情况,1表示置位,0表示没有置位
·     ATT:连接位
·     P:分区位
·     OL:过载位
NLPID
网络协议类型
AREA ADDR
IS-IS域地址
INTF ADDR
接口地址
Router ID
路由ID
+NBR
邻居
COST
开销
Admin Group
链路管理组属性
接口IP地址
Physical BW
物理带宽
Reservable BW
预留带宽
BW Unresrv[0]-[7]
子池中8个级别的可用带宽
TE Cost
TE开销
带宽约束模型
BC[0]
全局池
BC[1]
子池
Peer IP Address
对端邻居的IP地址
display isis traffic-eng link [ [ level-1 | level-1-2 | level-2 ] | verbose ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
verbose:显示详细信息。
【描述】
display isis traffic-eng link命令用来显示IS-IS TE的链路信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE的链路信息。
# 显示IS-IS TE的链路信息。
<Sysname> display isis traffic-eng link
Level-2 Link Information
 0000.0000.0001.00-->0000.0000.0001.01    Type: MULACC  LinkID: 10.1.1.1
 0000.0000.0002.00-->0000.0000.0003.00    Type: P2P     LinkID: 3.3.3.9
 0000.0000.0002.00-->0000.0000.0001.01    Type: MULACC  LinkID: 10.1.1.1
 0000.0000.0003.00-->0000.0000.0002.00    Type: P2P     LinkID: 2.2.2.9
 0000.0000.0003.00-->0000.0000.0004.01    Type: MULACC  LinkID: 30.1.1.2
 0000.0000.0004.00-->0000.0000.0004.01    Type: MULACC  LinkID: 30.1.1.2
 Total Number of TE Links in Level-2 Area: 6, Num Active: 6
表1-3 display isis traffic-eng link命令显示信息描述表
链路类型
LinkID
链路ID
Level-2区域中的TE链路数
Num Active
处于激活状态的数目
display isis traffic-eng network [ level-1 | level-1-2 | level-2 ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display isis traffic-eng network命令用来显示IS-IS TE的网络信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE的网络信息。
# 显示IS-IS TE的网络信息。
<Sysname> display isis traffic-eng network
Level-1 Network Information
    DIS Router ID  : 89.1.1.1        DIS's Ip Address         : 86.1.1.1
    Status In CSPF : ACTIVE          Attached Router Count    : 2
    List of Attached Routers
 RouterId : 89.1.1.1   Nbr : 1111.1111.1111.00
 Link State : 1
 RouterId : 89.2.2.2   Nbr : 1111.1111.1113.00
 Link State : 1
 Total Number of TE Networks in Level-1 Area: 1, Num Active: 1
Level-2 Network Information
 Link State : 1
 Link State : 1
 Total Number of TE Networks in Level-2 Area: 1, Num Active: 1
表1-4 display isis traffic-eng network命令显示信息描述表
Level-1网络信息
DIS Router ID
DR路由器ID
DIS's Ip Address
DR路由器IP地址
Status In CSPF
CSPF状态
相连路由器的数目
相连路由器列表
RouterId
路由器ID
Nbr
邻居
Link State
链路状态
处于Level-1的TE网络数目
Num Active
处于激活状态的数目
Level-2网络信息
处于Level-2的TE网络数目
display isis traffic-eng statistics [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display isis traffic-eng statistics命令用来显示IS-IS TE的统计信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE的统计信息。
# 显示IS-IS TE的统计信息。
<Sysname> display isis traffic-eng statistics
TE Statistics Information
 IS-IS System Type                          : Level-1-2
 IS-IS Cost Style Status                    : Wide
 IS-IS Level-1 Traffic Engineering Status   : Disabled
 IS-IS Level-2 Traffic Engineering Status   : Enabled
 IS-IS Router ID                            : 1.1.1.9
表1-5 display isis traffic-eng statistics命令显示信息描述表
IS-IS System Type
系统类型
路由器的开销类型
Level-1路由器的TE状态
Level-2路由器的TE状态
IS-IS Router ID
IS-IS路由器的Router ID
display isis traffic-eng sub-tlvs [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display isis traffic-eng sub-tlvs命令用来显示IS-IS TE扩展的子TLV信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE扩展的子TLV信息。
相关配置可参考命令te-set-subtlv。
# 显示IS-IS TE的子TLV信息。
<Sysname> display isis traffic-eng sub-tlvs
IS-IS(1) SubTlv Information
 Unreserved sub-pool bandwidth sub-tlv value : 251
 Bandwidth constraint sub-tlv value          : 252
 LO multiplier sub-tlv value                 : 253
表1-6 display isis traffic-eng sub-tlvs命令显示信息描述表
可用的子池带宽的子TLV值
带宽约束的子TLV值
本地过预订的倍数的子TLV值
display mpls lsp bfd [ te tunnel tunnel-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
tunnel tunnel-number:显示指定MPLS TE隧道的BFD检测信息。tunnel-number为隧道接口的编号。
【描述】
display mpls lsp bfd te命令用来显示BFD对MPLS TE隧道的检测信息。
# 显示BFD对接口Tunnel0对应的MPLS TE隧道的检测信息。
<Sysname> display mpls lsp bfd te Tunnel 0
               MPLS BFD Session(s) Information
 FEC            : Tunnel0           Type           : TE Tunnel
 Local Discr    : 3                 Remote Discr   : 3
 Tunnel ID      : 0xd2009           NextHop        : ----
 Session State  : Up                Source IP      : 1.1.1.1
 Session Role   : Active
 Total Session Num: 1
表1-7 display mpls lsp bfd te命令显示信息描述表
FEC
FEC信息
BFD检测的隧道类型,取值包括LSP和TE Tunnel
Local Discr
本地BFD会话的鉴别值
Remote Discr
远端BFD会话的鉴别值
Tunnel ID
隧道ID
NextHop
下一跳地址
Session State
BFD会话状态,取值包括:
·     Init:BFD会话处于初始化状态
·     Up:BFD会话处于up状态
·     Down:BFD会话处于down状态
Source IP
主动端(Ingress LSR)BFD会话的源IP地址
Session Role
BFD会话角色,取值包括
·     Active:BFD会话的主动端
·     Passive:BFD会话的被动端
display mpls rsvp-te [ interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ] ]
【缺省级别】
1:监控级
interface:显示接口的RSVP-TE配置信息。
interface-type interface-number:显示指定接口的RSVP-TE配置信息。interface-type interface-number为接口类型及接口编号。
【描述】
display mpls rsvp-te命令用来显示RSVP-TE的配置信息。
·     如果不使用关键字interface,将显示全局的RSVP-TE配置信息。
·     如果不指定接口名,将显示所有使能了RSVP-TE的接口的RSVP-TE配置信息。
# 显示全局的RSVP-TE配置信息。
<Sysname> display mpls rsvp-te
LSR ID: 4.4.4.4
 Resv Confirmation Request: DISABLE
 RSVP Hello Extension: ENABLE
 Hello interval: 3 sec         Max Hello misses: 3
 Path and Resv message refresh interval: 30 sec
 Path and Resv message refresh retries count: 3
 Blockade Multiplier: 4
 Graceful Restart: ENABLE
 Restart Time: 200 sec       Recovery Time: 150 sec
表1-8 display mpls rsvp-te命令显示信息描述表
LSR ID
标签交换路由器ID,格式为X.X.X.X
预留确认特性
是否使能Hello特性
Hello Interval
Hello定时器时长,单位为秒
Max Hello misses
最多可遗漏的Hello报文
路径和预留刷新消息的刷新定时器时间,单位为秒
路由和预留消息重发的次数
Blockade Multiplier
PSB和RSB的超时倍数
Graceful Restart
是否使能Graceful Restart功能
Restart Time
GR的重启定时器间隔,单位为秒
Recovery Time
GR的恢复定时器间隔,单位为秒
# 显示指定接口的RSVP-TE配置信息。
<Sysname> display mpls rsvp-te interface GigabitEthernet 3/1/1
Interface GigabitEthernet3/1/1
 Interface state: UP       BFD feature: ENABLE
 Total-BW: 80              Used-BW: 20
 Hello configured: NO      Num of Neighbors: 1
 SRefresh feature: ENABLE  SRefresh Interval: 30sec
 Authentication: DISABLE   Reliability configured: NO
 Retransmit Interval: 500msec  Increment Value: 1
表1-9 display mpls rsvp-te interface命令显示信息描述表
已使能RSVP-TE的接口名称
Interface state
物理接口状态
BFD feature
是否使能BFD
Total-BW
总带宽(单位:kbit/s)
Used-BW
所用带宽(单位:kbit/s)
Hello configured
是否配置了Hello特性
Num of Neighbors
经该接口连接的邻居个数
Srefresh feature
摘要刷新配置
Srefresh interval
摘要刷新定时器时长(单位:秒)
Authentication
是否使能验证
Reliability
是否存在可靠性特性
Retransmit interval
初始重传时间间隔(单位:毫秒)
Increment value
重传增量。如果在重传时间间隔内(假设为Rf秒),没有收到应答消息ACK,则经过(1+重传增量)×Rf秒后,将重传此消息
display mpls rsvp-te established [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface interface-type interface-number:指定接口类型及接口号。如果不指定本参数,则显示所有接口的RSVP-TE隧道信息。
regular-expression:表示正则表达式,为1~80个字符的字符串,区分大小写。
【描述】
display mpls rsvp-te established命令用来显示RSVP-TE隧道信息。
# 显示指定接口的RSVP-TE隧道信息。
<Sysname> display mpls rsvp-te established interface GigabitEthernet 3/1/1
 Token Bucket Rate: 0.00            Peak Data Rate: 0.00
 Tunnel Dest: 2.2.2.2               Ingress LSR ID: 3.3.3.3
 Local LSP ID: 4                    Session Tunnel ID: 4
 Next Hop Addr: 80.4.1.1
 Upstream Label: 1024               Downstream Label: 3
表1-10 display mpls rsvp-te established命令的显示信息描述表
使能RSVP-TE的接口
Token Bucket rate
流量参数,令牌桶速率
Peak Data Rate
流量参数,峰值速率
Tunnel Dest
隧道地址,格式为X.X.X.X
Ingress LSR ID
入口标签交换路由ID,格式为X.X.X.X
Local LSP ID
本地LSP ID
Session Tunnel ID
隧道ID
Next Hop Addr
下一跳地址,格式为X.X.X.X
Upstream label
上游标签
Downstream Label
下游标签
display mpls rsvp-te peer [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls rsvp-te peer命令用来显示RSVP-TE邻居信息。
如果不指定接口,将显示所有接口的RSVP-TE邻居信息。
# 显示所有接口的RSVP-TE邻居信息。
<Sysname> display mpls rsvp-te peer
 Neighbor Addr: 80.4.1.1
 SrcInstance: 841             NbrSrcInstance: 928
 PSB Count: 0                 RSB Count: 1
 Hello Type Sent: ACK         Neighbor Hello Extension: ENABLE
 SRefresh Enable: NO          Reliability Enable: YES
 Graceful Restart State: Ready
Interface GigabitEthernet4/1/1
 Neighbor Addr: 80.2.1.1
 SrcInstance: 832             NbrSrcInstance: 920
 PSB Count: 1                 RSB Count: 0
 Hello Type Sent: REQ         Neighbor Hello Extension: ENABLE
 Graceful Restart State: Not Ready
 Restart Time: ---            Recovery Time: ---
表1-11 display mpls rsvp-te peer 命令的显示信息描述表
使能RSVP-TE的接口
Neighbor Addr
邻居地址,格式为 X.X.X.X.
SrcInstance
源Message ID的Instance
NbrSrcInstance
对端Message ID的Instance
PSB Count
路径状态块数量
RSB Count
预留状态块数量
Hello Type Sent
向对端发送Hello类型,取值为REQ/ACK/NONE
邻居是否使能Hello特性,只有接口使能了hello扩展时才会显示此项
SRefresh Enable
是否使能摘要刷新,取值为YES/NO
Reliability Enable
对等体是否使能可靠性,取值为YES/NO
邻居的GR状态,取值为Not Ready、Ready、Restart或Recovery,设备不支持时显示为---
Restart Time
GR的重启定时器间隔,单位为秒
Recovery Time
GR的恢复定时器间隔,单位为秒
display mpls rsvp-te psb-content ingress-lsr-id lspid tunnel-id egress-lsr-id [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ingress-lsr-id:入口LSR ID。
lspid:本地LSP ID,取值范围为1~65535。
tunnel-id:隧道ID,取值范围为0~65535。
egress-lsr-id:出口LSR ID。
【描述】
display mpls rsvp-te psb-content命令用来显示RSVP-TE PSB(Path State Block,路径状态块)信息。
# 显示RSVP-TE PSB信息。
<Sysname> display mpls rsvp-te psb-content 19.19.19.19 1 0 29.29.29.29
The PSB Content:
 Tunnel Dest: 29.29.29.29     Session Tunnel ID: 0
 Tunnel ExtID: 19.19.19.19
 Ingress LSR ID: 19.19.19.19  Local LSP ID: 1
 Previous Hop : 101.101.101.1 Next Hop : -----
 Incoming / Outgoing Interface: GigabitEthernet3/1/1  /  -----
 InLabel : 3            OutLabel : NULL
 Reverse InLabel : null  Reverse OutLabel : 1024
Send Message ID : 1      Recv Message ID : 0
 Session Attribute-
   SetupPrio: 7         HoldPrio: 7
   SessionFlag: SE Style desired
  ERO Information-
     L-Type          ERO-IPAddr       ERO-PrefixLen
   ERHOP_STRICT    101.101.101.2         32
 RRO Information-
   RRO-CType: IPV4   RRO-IPAddress: 101.101.101.1   RRO-IPPrefixLen: 32
 SenderTspec Information-
   Token bucket rate: 0.00
   Token bucket size: 0.00
   Peak data rate: 0.00
   Minimum policed unit: 0
   Maximum packet size: 4294967295
 Path Message arrive on GigabitEthernet3/1/1 from PHOP 101.101.101.1
 Resource Reservation OK
 Graceful Restart State: Stale
 Bandwidth Constraint Mode: IETF DS-TE RDM
表1-12 display mpls rsvp-te psb-content命令显示信息描述表
Tunnel Dest
隧道目的地址,格式为 X.X.X.X
Session Tunnel ID
会话隧道ID
Tunnel ExtID
隧道的扩展ID,格式为X.X.X.X
Ingress LSR ID
入口标签交换路由器ID,格式为X.X.X.X
Local LSP ID
本地LSP ID
Next Hop
下一跳地址,格式为 X.X.X.X
Previous Hop
前一跳地址,格式为X.X.X.X
In Label
入标签
Out Label
出标签
Reverse InLabel
反向LSP的入标签
Reverse OutLabel
反向LSP的出标签
Send message ID
发送的MessageID的instance
Resv Message ID
接收的MessageID的instance
Setup Prio
会话建立优先级
HoldPrio
会话保持优先级
Session Flag
会话类型(需要的本地保护、标签、SE风格)
RRO Information
记录路由信息
RRO-C Type
记录路由的类型
RRO-IP Address
记录路由的IP地址 (X.X.X.X)
RRO-IPPrefixLen
记录路由前缀的长度
ERO Information
显式路由信息
L-Type
显式路由类型(Strict / Loose)
ERO-IPAddress
显式路由地址
ERO-Prefix Len
显式路由前缀值
Sender Tspec Information
包括发送方业务规格信息
Token Bucket rate
流量参数,令牌桶速率(单位:kbit/s)
Token Bucket size
流量参数,令牌桶大小
Peak Data Rate
流量参数:峰值数据速率(单位:kbit/s)
Maximum packet size
流量参数,最大报文长度
流量参数,最小监管单元
Path message
从接口发送到下一跳X.X.X.X的路径消息
Resource
只有配置了资源预留标记时才会有此项显示
GR状态,取值为Stale或Normal,设备不支持时显示为---
path报文中携带的带宽约束模型,取值包括:
·     IETF DS-TE RDM
·     IETF DS-TE MAM
·     Prestandard DS-TE RDM
display mpls rsvp-te request [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls rsvp-te request命令用来显示RSVP-TE请求消息信息。
如果不指定接口名,将显示所有接口的请求消息信息。
# 显示所有接口的请求消息信息。
<Sysname> display mpls rsvp-te request
Interface GigabitEthernet3/1/1:
 NextHopAddr: 80.4.1.1
 SessionFlag: SE Style desired.
 Token bucket rate: 0.00             Token bucket size: 1000.00
 Out Interface: GigabitEthernet4/1/1
表1-13 display mpls rsvp-te request 命令的显示信息描述表
使能了RSVP-TE的以太网接口
Tunnel Dest
隧道目的地址,格式为X.X.X.X
Ingress LSR ID
Local LSP ID
本地LSP ID
Session Tunnel ID
会话隧道ID
Next Hop Address
下一跳地址,格式为 X.X.X.X
SessionFlag
风格
Token Bucket rate
流量参数,令牌桶速率
Token Bucket Size
流量参数,令牌桶大小
Out Interface
消息出接口
display mpls rsvp-te reservation [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls rsvp-te reservation命令用来显示RSVP-TE资源预留信息。
如果不指定接口名,将显示所有接口的资源预留信息。
# 显示指定接口的RSVP-TE预留信息。
<Sysname> display mpls rsvp-te reservation interface GigabitEthernet 3/1/1
 Tunnel Dest: 29.29.29.29     Ingress LSR ID: 19.19.19.19
 LSP ID: 1                    Tunnel ID: 1
 Upstream Label: -----
 Token bucket rate: 0.00       Token bucket size: 0.00
# 显示所有接口的RSVP-TE预留信息。
 Interface: Outgoing-Interface at the Egress
 Tunnel Dest: 19.19.19.19     Ingress LSR ID: 29.29.29.29
 Upstream Label: 3
表1-14 display mpls rsvp-te reservation命令的显示信息描述表
使能了RSVP-TE的以太网接口
Tunnel Dest
隧道目的地址,格式为 X.X.X.X
Ingress LSR ID
LSP ID
LSP ID
Tunnel ID
隧道ID
Upstream Label
上游标签
Token Bucket rate
流量参数,令牌桶速率
Token Bucket Size
流量参数,令牌桶大小
display mpls rsvp-te rsb-content ingress-lsr-id Ispid tunnel-id egress-lsr-id nexthop-address [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
nexthop-address:下一跳地址。
【描述】
display mpls rsvp-te rsb-content命令用来显示RSVP-TE RSB(Reservation State Block,预留状态块)信息。
# 显示RSVP-TE RSB信息。
<Sysname> display mpls rsvp-te rsb-content 19.19.19.19 1 0 29.29.29.29 101.101.101.2
The RSB Content:
 Next Hop: 101.101.101.2    Resevation Style: SE Style
 Reservation Incoming Interface: GigabitEthernet3/1/1
 Reservation Interface: GigabitEthernet3/1/1
 Message ID : 2
 Filter Spec Information-
   The filter number: 1
   Ingress LSR ID: 19.19.19.19    Local LSP ID: 1      OutLabel: 3
 RRO Information-
 RRO-Flag is
   RRO-CType: IPV4   RRO-IPAddress: 101.101.101.2      RRO-IPPrefixLen: 32
 FlowSpec Information-
   Token bucket rate: 2500.00
   Maximum packet size: 0
   Bandwidth guarantees: 0.00
   Delay guarantees: 0
   Qos Service is Controlled
 Resv Message arrive on GigabitEthernet3/1/1 from NHOP 101.101.101.2
表1-15 display mpls rsvp-te rsb content命令显示信息描述表
Tunnel Dest
隧道地址,格式为 X.X.X.X
Session Tunnel ID
会话隧道ID
Tunnel Ext ID
隧道扩展(入口LSR ID),格式为 X.X.X.X
Next Hop
下一跳地址,格式为 X.X.X.X
Reservation Style
预留风格,取值为SE/FF
预留资源的接口名称
Reserve Incoming Interface
预留消息入接口
Message ID
减少刷新的消息的ID
过滤规格信息
Filter Num
过滤器总数
Ingress LSR ID
LSP ID
LSP ID
Out Label
出标签
RRO Information
记录路由信息
RRO-C Type
记录路由的类型
RRO-IP Address
记录路由的IP地址 (X.X.X.X)
RRO-IPPrefixLen
记录路由前缀的长度
Flow Spec information
包括流规格业务信息
Token Bucket rate
流量参数,令牌桶速率 (单位:kbit/s)
Token Bucket size
流量参数,令牌桶大小
Peak Data Rate
流量参数,峰值数据速率(单位:kbit/s)
Maximum packet size
流量参数,最大报文长度
流量参数,最少监管单位
预留规格参数,带宽保证
Delay guarantees
预留规格参数,延迟保证
QOS service
QoS保证/控制
Resv Message
从下一跳地址(X.X.X.X)到GigabitEthernet3/1/1的预留消息
display mpls rsvp-te sender [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls rsvp-te sender命令用来显示RSVP-TE发送方消息信息。
# 显示指定接口的RSVP-TE发送方消息信息。
<Sysname> display mpls rsvp-te sender interface GigabitEthernet 3/1/1
 LSP ID: 1                   Session Tunnel ID: 1
 Session Name: Tunnel3
 Previous Hop Address: 101.101.101.1
 Token bucket rate: 0.0      Token bucket size: 0.00
# 显示所有接口的RSVP-TE发送方消息信息。
 LSP ID: 1                   Session Tunnel ID: 0
 Previous Hop Address: 101.101.101.2
Interface: Incoming-Interface at the Ingress
 Session Name: Tunnel2
 Previous Hop Address: 19.19.19.19
表1-16 display mpls rsvp-te sender命令的显示信息描述表
使能RSVP-TE的以太网接口
Tunnel Dest
隧道地址,格式为X.X.X.X
Ingress LSR ID
LSP ID
LSP ID
Tunnel ID
会话隧道ID
Session Name
会话的名称
前一跳地址,格式为X.X.X.X
Token Bucket rate
流量参数,令牌桶速率
Token Bucket Size
流量参数,令牌桶大小
display mpls rsvp-te statistics { global | interface [ interface-type interface-number ] } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
global:全局RSVP-TE。
interface:所有接口。
【描述】
display mpls rsvp-te statistics命令用来显示RSVP-TE的统计信息。
·     如果选择参数global,则查看全局RSVP-TE的统计信息;
·     如果选择参数interface,则查看所有接口RSVP-TE的统计信息;
·     如果选择参数interface interface-type interface-number,则查看指定接口RSVP-TE的统计信息。
# 显示全局RSVP-TE的统计信息。
<Sysname> display mpls rsvp-te statistics global
LSR ID: 1.1.1.1
 PSB Count: 1                          RSB Count: 1
 RFSB Count: 0                         TCSB Count: 1
 LSP Count: 1
Total Statistics Information:
 PSB CleanupTimeOutCounter: 0          RSB CleanupTimeOutCounter: 0
 SendPacketCounter: 55                 RecPacketCounter: 54
 SendPathCounter: 5                    RecPathCounter: 0
 SendResvCounter: 0                    RecResvCounter: 4
 SendResvConfCounter: 0                RecResvConfCounter: 0
 SendHelloCounter: 2                   RecHelloCounter: 48
 SendAckCounter: 48                    RecAckCounter: 2
 SendPathErrCounter: 0                 RecPathErrCounter: 0
 SendResvErrCounter: 0                 RecResvErrCounter: 0
 SendPathTearCounter: 0                RecPathTearCounter: 0
 SendResvTearCounter: 0                RecResvTearCounter: 0
 SendSrefreshCounter: 0                RecSrefreshCounter: 0
 SendAckMsgCounter: 0                  RecAckMsgCounter: 0
 SendErrMsgCounter: 0                  RecErrMsgCounter: 0
 RecReqFaultCounter: 0                 BindFrrFaultCounter: 0
# 显示指定接口GigabitEthernet3/1/1的RSVP-TE的统计信息。
<Sysname> display mpls rsvp-te statistics interface GigabitEthernet 3/1/1
GigabitEthernet 3/1/1:
 SendPacketCounter: 69                 RecPacketCounter: 68
 SendPathCounter: 6                    RecPathCounter: 0
 SendResvCounter: 0                    RecResvCounter: 5
 SendHelloCounter: 2                   RecHelloCounter: 61
 SendAckCounter: 61                    RecAckCounter: 2
表1-17 display mpls rsvp-te statistics命令显示信息描述表
LSR ID
LSR的ID
PSB Count
PSB的数量
RSB Count
RSB的数量
RFSB Count
RFSB的数量
TCSB Count
TCSB的数量
LSP Count
LSP的数量
PSB超时次数
RSB超时次数
SendPacketCounter
发送的报文数量
RecPacketCounter
接收的报文数量
SendPathCounter
发送的Path消息数量
RecPathCounter
接收的Path消息数量
SendResvCounter
发送的Resv消息数量
RecResvCounter
接收的Resv消息数量
SendResvConfCounter
发送的ResvConf消息数量
RecResvConfCounter
接收的ResvConf消息数量
SendHelloCounter
发送的Hello消息数量
RecHelloCounter
接收的Hello消息数量
SendAckCounter
发送的Ack消息数量
RecAckCounter
接收的Ack消息数量
SendPathErrCounter
发送的PathErr消息数量
RecPathErrCounter
接收的PathErr消息数量
SendResvErrCounter
发送的ResvErr消息数量
RecResvErrCounter
接收的ResvErr消息数量
SendPathTearCounter
发送的PathTear消息数量
RecPathTearCounter
接收的PathTear消息数量
SendResvTearCounter
发送的ResvTear消息数量
RecResvTearCounter
接收的ResvTear消息数量
SendSrefreshCounter
发送的Srefresh消息数量
RecSrefreshCounter
接收的Srefresh消息数量
SendAckMsgCounter
发送的AckMsg消息数量
RecAckMsgCounter
接收的AckMsg消息数量
SendErrMsgCounter
发送错误的消息数量
RecErrMsgCounter
接收错误的消息数量
RecReqFaultCounter
请求失败的次数
BindFrrFaultCounter
在FRR过程中,为主隧道绑定Bypass隧道失败的次数
display mpls static-cr-lsp [ lsp-name lsp-name ] [ egress | ingress | transit ] [ { include | exclude } ip-address prefix-length ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
lsp-name lsp-name:标签转发路径的名称,为1~15个字符的字符串。
egress:显示本节点作为出节点的静态CR-LSP信息。
ingress:显示本节点作为入节点的静态CR-LSP信息。
transit:显示本节点作为中间节点的静态CR-LSP信息。
include:只显示指定FEC的CR-LSP信息。
exclude:显示除指定FEC外的所有CR-LSP信息。
ip-address:FEC的IP地址。
prefix-length:地址前缀的长度,取值范围为0~32。
verbose:显示详细信息。
| { begin | exclude | include } regular-expression:使用正则表达式对显示信息进行过滤。有关正则表达式的详细介绍,请参见“基础配置指导”中的“CLI”。其中:
·     begin:从包含指定正则表达式的行开始显示。
·     exclude:只显示不包含指定正则表达式的行。
·     include:只显示包含指定正则表达式的行。
·     regular-expression:表示正则表达式,为1~256个字符的字符串,区分大小写。
【描述】
display mpls static-cr-lsp命令用来显示静态CR-LSP信息。
# 显示静态CR-LSP的简要信息。
<Sysname> display mpls static-cr-lsp
total statics-cr-lsp : 1
Name            FEC                I/O Label  I/O If                      State
abc             -/-                60/NULL    GE3/1/1/-                    Down
表1-18 display mpls static-cr-lsp命令显示信息描述表
Name
静态CR-LSP的名称
FEC
FEC目的地址及目的地址掩码
I/O Label
入/出标签值
I/O If
入/出接口
静态CR-LSP当前的状态
# 显示静态CR-LSP的详细信息。
<Sysname> display mpls static-cr-lsp verbose
No             :        1
LSP-Name       :        abc
LSR-Type       :        Egress
FEC            :        -/-
In-Label       :        60
Out-Label      :        NULL
In-Interface   :        GigabitEthernet3/1/1
Out-Interface  :        -
NextHop        :        -
Lsp Status     :        Down
Class Type     :        0
Bandwith       :        0 kbps
表1-19 display mpls static-cr-lsp verbose命令显示信息描述表
No
静态CR-LSP的编号
LSP-Name
静态CR-LSP名称
LSR-Type
静态CR-LSP类型
FEC
FEC目的地址及目的地址掩码
In-Label
入标签值
Out-Label
出标签值
In-Interface
入接口名称
Out-Interface
出接口名称
NextHop
下一跳地址
Lsp Status
LSP状态
Class Type
静态CR-LSP流量所属的服务类型
Bandwidth
静态CR-LSP流量所需的带宽
display mpls te cspf tedb { all | area area-id | interface ip-address | network-lsa | node [ mpls-lsr-id ] } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
area area-id:区域ID。对于OSPF,取值范围为0~4294967295;对于IS-IS,取值为1或2。
interface ip-address:接口IP地址。
network-lsa:所有的Network-LSA信息。
node:节点信息。
mpls-lsr-id:MPLS LSR ID。
【描述】
display mpls te cspf tedb命令用来显示满足指定条件的基于CSPF的TEDB信息。
# 显示Network-LSA的TEDB信息。
<Sysname> display mpls te cspf tedb network-lsa
Maximum Network LSA Supported:  500
Current Total Network LSA Number:       7
Id   DR MPLS LSR-Id DR-Address       IGP   Process-Id  Area  Neighbor
1    8.1.1.2        3.0.0.2          OSPF  100         0     1.1.1.1
                                                             2.1.1.1
                                                             8.1.1.2
2    2.1.1.1        3.0.0.3          OSPF  100         0     2.1.1.1
                                                             3.1.1.1
                                                             2.1.1.2
3    3.1.1.2        3.0.0.4          OSPF  100         0     3.1.1.1
                                                             4.1.1.1
                                                             3.1.1.2
4    4.1.1.2        3.0.0.5          OSPF  100         0     4.1.1.1
                                                             5.1.1.1
                                                             4.1.1.2
5    5.1.1.2        3.0.0.6          OSPF  100         0     5.1.1.1
                                                             6.1.1.1
                                                             5.1.1.2
6    6.1.1.2        3.0.0.9          OSPF  100         0     6.1.1.1
                                                             7.1.1.1
                                                             6.1.1.2
7    7.1.1.1        12.0.0.7         OSPF  100         0     3.1.1.1
                                                             7.1.1.1
                                                             7.1.1.2
表1-20 display mpls te cspf tedb命令显示信息描述表
ID
序号
DR MPLS LSR-Id
指定路由器(Designated Router)的MPLS LSR ID,点分十进制形式
DR-Address
指定路由器(Designated Router)的接口地址
IGP
内部网关协议(OSPF/IS-IS)
Process-Id
IGP进程ID
Area
路由器属于的区域
Neighbor
邻居路由器ID
# 显示所有TEDB信息。
<Sysname> display mpls te cspf tedb all
Maximum Node Supported: 1000            Maximum Link Supported: 4000
Current Total Node Number: 3            Current Total Link Number: 44
Id    MPLS LSR-Id     IGP     Process-Id    Area            Link-Count
1     1.1.1.1         OSPF    100           1001,1002,1003  20
                                            1004,1005,1006
                                            1007,1008,1009
                                            1010,1,2
                                            13,14,15
                                            16,17,18
                                            19,20
2     2.1.1.1         ISIS    100           Level-0,1       20
3     3.1.1.1         OSPF    100           0               4
表1-21 display mpls te cspf tedb all命令显示信息描述表
ID
序号
MPLS LSR-Id
MPLS LSR ID,点分十进制形式
IGP
内部网关协议(OSPF/IS-IS)
Process-Id
IGP进程ID
Area
路由器属于的区域
Link-count
路由器上连接的指定IGP类型和进程号的链路总数
# 显示指定区域的TEDB信息。
<Sysname> display mpls te cspf tedb area 1
Router Node Information for Area 1:
1      2.2.2.2        OSPF    100            1               1
2      3.3.3.3        OSPF    100            1               1
3      2.2.2.2        ISIS    100            Level-1         1
4      3.3.3.3        ISIS    100            Level-1         1
Network LSA Information for Area 1:
1    3.3.3.3         20.1.1.2      OSPF 100        1       2.2.2.2
                                                           3.3.3.3
2    3.3.3.3         20.1.1.2      ISIS 100        Level-1 3.3.3.3
                                                           2.2.2.2
表1-22 display mpls te cspf tedb area命令显示信息描述表
Id
序号
MPLS LSR-Id
MPLS LSR ID,点分十进制形式
IGP
内部网关协议(OSPF或IS-IS)
Process-Id
IGP的进程号
Area
路由器所属的区域
Link-Count
DR MPLS LSR-Id
指定路由器DR的MPLS LSR ID
DR-Address
指定路由器DR的接口地址
Neighbor
邻居的MPLS LSR ID
# Prestandard模式下显示本地路由的TEDB信息。
<Sysname> display mpls te cspf tedb node
MPLS LSR-Id: 1.1.1.1
  IGP Type: OSPF   Process Id: 100
  MPLS-TE Link Count: 1
  Link[1] :
    Interface IP Address: 2.0.0.33, 2.0.0.35, 2.0.0.36,
    Neighbor  IP Address: 2.0.0.2, 2.0.0.42, 2.0.0.43,
                          2.0.0.44, 2.0.0.45, 2.0.0.46,
                          2.0.0.47, 2.0.0.32,
    Neighbor  MPLS LSR-Id : 1.1.1.2
    IGP Area: 1
    Link  Type: point-to-point  Link Status: Inactive
    IGP Metric: 100             TE Metric: 100         Color: 0xff
    Maximum Bandwidth: 100 (kbps)
    Maximum Reservable Bandwidth: 20 (kbps)
    Bandwidth Constraint Mode: Prestandard DS-TE RDM
         BC[0] :  100        (kbps)
         BC[1] :  20         (kbps)
    Unreserved Bandwidth for each TE Class:
         [0] :    10         (kbps),  [1] :     10         (kbps)
         [2] :    10         (kbps),  [3] :     10         (kbps)
         [4] :    10         (kbps),  [5] :     10         (kbps)
         [6] :    10         (kbps),  [7] :     10         (kbps)
         [8] :    10         (kbps),  [9] :     10         (kbps)
         [10]:    10         (kbps),  [11]:     10         (kbps)
         [12]:    10         (kbps),  [13]:     10         (kbps)
         [14]:    10         (kbps),  [15]:     10         (kbps)
  IGP Type: ISIS   Process Id: 100
  MPLS-TE Link Count: 2
  Link[1] :
                          2.0.0.47, 2.0.0.32, 2.0.0.33
    Neighbor  MPLS LSR-Id: 1.1.1.2
    IGP Area: Level-0
    Link  Type: point-to-point  Link Status: Active
    IGP Metric: 10              TE Metric: 10          Color: 0x11
    Maximum Reservable Bandwidth: 100 (kbps)
         BC[0] :  100        (kbps)
         BC[1] :  20         (kbps)
表1-23 display mpls te cspf tedb node命令显示信息描述表
MPLS LSR-Id
MPLS LSR ID,点分十进制形式
IGP Type
IGP类型
Process Id
IGP进程号
MPLS-TE Link Count
MPLS TE链路数目
Link[1]
第一条链路的信息
接口地址
DR Address
指定路由器DR地址
IGP Area
IGP区域
Link Type
链路类型
Link Status
链路状态
IGP Metric
IGP度量
TE Metric
TE度量
Color
链路管理属性
Maximum Bandwidth
链路最大带宽
链路最大可约束带宽
带宽预留模型
带宽约束
每个TE class的可预留带宽
# IETF DS-TE模式RDM带宽约束模型下显示指定接口地址的TEDB信息。
<Sysname> display mpls te cspf tedb interface 20.1.1.1
MPLS LSR-Id: 2.2.2.2
  Link[1] :
    Interface IP Address: 20.1.1.1
    DR Address: 20.1.1.2
    IGP Area: Level-1
    Link  Type: multi-access  Link Status: Active
    IGP Metric: 10              TE Metric: 0           Color: 0x0
    Maximum Bandwidth: 0 (kbps)
    Maximum Reservable Bandwidth: 0 (kbps)
         BC[0] :  0          (kbps)
         BC[1] :  0          (kbps)
         BC[2] :  0          (kbps)
         BC[3] :  0          (kbps)
         [0] :    0          (kbps),  [1] :     0          (kbps)
         [2] :    0          (kbps),  [3] :     0          (kbps)
         [4] :    0          (kbps),  [5] :     0          (kbps)
         [6] :    0          (kbps),  [7] :     0          (kbps)
表1-24 display mpls te cspf tedb interface命令显示信息描述表
MPLS LSR-Id
MPLS LSR ID,点分十进制形式
IGP Type
IGP类型
Process Id
IGP进程号
Link[1]
第一条链路的信息
接口地址
DR Address
指定路由器DR地址
IGP Area
IGP区域
Link Type
链路类型
Link Status
链路状态
IGP Metric
IGP度量
TE Metric
TE度量
Color
链路管理属性
Maximum Bandwidth
链路最大带宽
链路最大可预留带宽
带宽约束模型
带宽约束
每个TE class的可预留带宽
display mpls te ds-te [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls te ds-te命令用来显示DS-TE相关信息,包括DS-TE的模式、带宽约束模型及TE class与服务类型、优先级的对应关系等。
# 显示DS-TE相关信息。
<Sysname> display mpls te ds-te
  MPLS LSR ID          :  1.1.1.1
  MPLS DS-TE mode      :  Prestandard
  MPLS DS-TE BC mode   :  RDM
  TE CLASS    ClassType     Priority
  0           0             0
  1           0             1
  2           0             2
  3           0             3
  4           0             4
  5           0             5
  6           0             6
  7           0             7
  8           1             0
  9           1             1
  10          1             2
  11          1             3
  12          1             4
  13          1             5
  14          1             6
  15          1             7
表1-25 display mpls te ds-te命令显示信息描述表
MPLS LSR ID
设备的MPLS LSR ID
MPLS DS-TE mode
DS-TE模式,取值包括Prestandard和IETF
MPLS DS-TE BC mode
DS-TE的带宽约束模型,取值包括RDM和MAM
TE CLASS
TE类型
ClassType
服务类型
Priority
抢占优先级
display mpls te link-administration admission-control [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface interface-type interface-number:指定接口类型和接口编号。
【描述】
display mpls te link-administration admission-control命令用来显示所有链路接纳的CR-LSP信息。
如果不指定接口,将显示所有接口的所有链路接纳的CR-LSP信息。
# 显示所有链路接纳的CR-LSP信息。
<Sysname> display mpls te link-administration admission-control
LspID           In/Out IF         S/H Prio    CT       BW(kbps)
1.1.1.9:1024    ---/GE3/1/1          7/7         0        0
1.1.1.9:2048    ---/GE4/1/1          7/7         0        0
表1-26 display mpls te link-administration admission-control命令显示信息描述表
LspID
链路接纳的LSP的ID
In/Out IF
入/出接口名称
S/H Prio
建立/保持优先级
CT
服务类型
BW(kbps)
带宽
display mpls te link-administration bandwidth-allocation [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls te link-administration bandwidth-allocation命令用来显示使能了MPLS TE的接口分配的带宽。
如果不指定接口,将显示所有使能了MPLS TE的接口分配的带宽。
# 显示Prestandard模式下使能了MPLS TE的接口分配的带宽。
<Sysname> display mpls te link-administration bandwidth-allocation
Link ID:  GigabitEthernet3/1/1
  Max Link Bandwidth                          :  3200000 kbits/sec
  Max Reservable Bandwidth of Prestandard RDM :  2000000 kbits/sec
  Max Reservable Bandwidth of IETF RDM        :  200000 kbits/sec
  Max Reservable Bandwidth of IETF MAM        :  300000 kbits/sec
  Downstream LSP Count       :  0
  UpStream LSP Count         :  0
  Downstream Bandwidth       :  0 kbits/sec
  Upstream Bandwidth         :  0 kbits/sec
  IPUpdown Link Status       :  UP
  PhysicalUpdown Link Status :  UP
  BC  Prestandard RDM(kbps)  IETF Mode RDM(kbps)  IETF Mode MAM(kbps)
  0   2000000                200000               2000
  1   1000000                150000               2000
  2   0                      100000               2000
  3   0                      50000                2000
  TE CLASS    CLASS TYPE    PRIORITY   BW RESERVED(kbps)  BW AVAILABLE(kbps)
      0           0             0            0            2000000
      1           0             1            0            2000000
      2           0             2            0            2000000
      3           0             3            0            2000000
      4           0             4            0            2000000
      5           0             5            0            2000000
      6           0             6            0            2000000
      7           0             7            1000         1999000
      8           1             0            0            1000000
      9           1             1            0            1000000
     10           1             2            0            1000000
     11           1             3            0            1000000
     12           1             4            0            1000000
     13           1             5            0            1000000
     14           1             6            0            1000000
     15           1             7            0            1000000
表1-27 display mpls te link-administration bandwidth-allocation命令显示信息描述表
Link ID
链路ID
Max Link Bandwidth
最大链路带宽
Prestandard RDM模型的最大可预留带宽
IETF RDM模型的最大可预留带宽
IETF MAM模型的最大可预留带宽
下游LSP条数
UpStream LSP Count
上游LSP条数
下游带宽
Upstream Bandwidth
上游带宽
协议层链路状态
物理层链路状态
BC
带宽约束
Prestandard RDM
Prestandard模式RDM模型的带宽约束,单位为kbit/s
IETF Mode RDM
IETF模式RDM模型的带宽约束,单位为kbit/s
IETF Mode MAM
IETF模式MAM模型的带宽约束,单位为kbit/s
TE CLASS
TE类型
CLASS TYPE
服务类型
PRIORITY
优先级
BW RESERVED
已经为该TE class预留的带宽,单位为kbit/s
BW AVAILABLE
目前该TE class可用的带宽,单位为kbit/s
display mpls te protection tunnel { tunnel-id | all } [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
tunnel-id:主Tunnel ID,用来标识一个Tunnel。
all:显示所有保护组信息。
verbose:显示详细信息。
【描述】
display mpls te protection tunnel命令用来显示指定Tunnel和其对应保护Tunnel信息。
# 显示Tunnel ID为100的隧道及其保护隧道信息。
<Sysname> display mpls te protection tunnel 100
Work-tunnel id     Protect-tunnel id     Switch-Result
100                101                   work-tunnel
# 显示Tunnel ID为100的隧道及其保护隧道的全部信息。
<Sysname> display mpls te protection tunnel 100 verbose
Work-tunnel id                 : 100
Protect-tunnel id              : 101
Protection mode                : 1+1
Switching mode                 : bidirectional
Switch result                  : work-tunnel
Work-tunnel defect state       : No-defect
Protect-tunnel defect state    : No-defect
Holdoff                        : 0ms
WTR                            : 30s
Mode                           : revertive
Holdoff timer                  : not start
WTR timer                      : not start
The current external command   : --
表1-28 display mpls te protection tunnel命令显示信息描述表
Work-tunnel id
主Tunnel ID
Protect-tunnel id
保护Tunnel ID
Protection mode
保护倒换方式,取值包括:
·     1+1:表示1+1保护倒换
·     1:1:表示1:1保护倒换
Switching mode
保护倒换的路径切换方式,取值包括:
·     bidirectional:表示双向路径切换
·     unidirectional:表示单向路径切换
Switch result
倒换结果,即当前传输数据的Tunnel,取值包括:
·     work-tunnel:数据通过主Tunnel传输
·     protect-tunnel:数据通过保护Tunnel传输
主Tunnel缺陷状态,取值包括:
·     No-defect:主Tunnel无缺陷
·     In-defect:主Tunnel存在缺陷
保护Tunnel缺陷状态,取值包括:
·     No-defect:保护Tunnel无缺陷
·     In-defect:保护Tunnel存在缺陷
Holdoff
倒换延迟时间
WTR
回切等待时间
Mode
回切模式,取值包括:
·     revertive:可回切模式
·     non- revertive:不可回切模式
WTR timer
回切定时器是否启动
Holdoff timer
延迟定时器是否启动
已执行的外部倒换命令
display mpls te tunnel [ destination dest-addr ] [ lsp-id lsr-id lsp-id ] [ lsr-role { all | egress | ingress | remote | transit } ] [ name name ] [ { incoming-interface | outgoing-interface | interface } interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
destination dest-addr:只显示目的地址为指定IP地址的隧道。
lsp-id lsr-id lsp-id:lsr-id为Ingress节点的LSR-ID,点分十进制格式,lsp-id为LSP标识号,取值范围为1~65535。
lsr-role:显示具有指定角色的隧道(所有、入口、中间、出口或远端)。
all:显示所有隧道。
egress:显示出口位于该路由器的隧道。
ingress:显示入口位于该路由器的隧道。
remote:显示出口或中间节点位于该路由器的隧道。
transit:显示中间节点位于该路由器的隧道。
name name:显示具有指定名称的隧道,name,隧道名称,为1~63个字符的字符串。如果指定,该隧道名称从接口描述中获得。否则它就是接口名称。隧道名称应当包含在信令消息中,这样所有的跳都可以获得。
incoming-interface:显示使用指定入接口的所有隧道。
outgoing-interface:显示使用指定出接口的所有隧道。
interface:显示使用指定接口作为出接口或入接口的所有隧道。
verbose:显示详细信息。
【描述】
display mpls te tunnel命令用来显示MPLS TE隧道信息。
# 显示MPLS TE隧道信息。(根据隧道使用的信令协议不同,显示信息不同。)
<Sysname> display mpls te tunnel
LSP-Id            Destination     In/Out-If            Name
1.1.1.9:1024      3.3.3.9         -/GE3/1/1            Tunnel3
1.1.1.9:2048      3.3.3.9         -/GE4/1/1            Tunnel2
表1-29 display mpls te tunnel命令显示信息描述表
LSP-ID
隧道的LSP ID
Destination
目的路由器的ID
In/Out-IF
入接口/出接口
Name
隧道入口配置的隧道名称
# 显示MPLS TE隧道的详细信息。
<Sysname> display mpls te tunnel verbose
No             : 1
LSP-Id         : *1.1.1.9:23
Tunnel-Name    : Tunnel2
Destination    : 1.1.1.9
In-Interface   : Vlan1
Out-Interface  : -
Tunnel BW      : 0 kbps
Class Type     : CT0
Ingress LSR-Id : *1.1.1.9
Egress LSR-Id  : 1.1.1.9
Setup-Priority : 7
Hold-Priority  : 7
Sign-Protocol  : RSVP TE
Resv Style     : FF
IncludeAnyAff  : 0x0
ExcludeAllAff  : 0x0
IncludeAllAff  : 0x0
Created Time   : 2011/01/28 09:59:49
No             : 2
LSP-Id         : 1.1.1.9:23
Destination    : 2.2.2.9
In-Interface   : -
Out-Interface  : Vlan1
Tunnel BW      : 0 kbps
Class Type     : CT0
Ingress LSR-Id : 1.1.1.9
Egress LSR-Id  : 2.2.2.9
Setup-Priority : 7
Hold-Priority  : 7
Resv Style     : FF
IncludeAnyAff  : 0x0
ExcludeAllAff  : 0x0
IncludeAllAff  : 0x0
表1-30 display mpls te tunnel verbose命令显示信息描述表
No
序号
LSP-Id
隧道的LSP ID
显示信息中如果带有“*”,则表示该CR-LSP为双向隧道中的反向CR-LSP
Tunnel-Name
隧道入口配置的隧道名称
Destination
目的路由器的ID
In-Interface
入接口
Out-Interface
出接口
Tunnel BW
隧道带宽
Class Type
服务类别
Ingress LSR-Id
入口标签交换路由器的ID
Egress LSR-Id
出口标签交换路由器的ID
Setup-Priority
建立优先级
Hold-Priority
保持优先级
Sign-Protocol
信令协议
Resv Style
预留风格
IncludeAnyAff
需要包含的任一链路属性
ExcludeAllAff
排除的链路属性
IncludeAllAff
需要包含的全部链路属性
Created Time
建立时间
display mpls te tunnel path [ lsp-id lsr-id lsp-id | tunnel-name tunnel-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
tunnel-name tunnel-name:隧道名称,为1~63个字符的字符串。
【描述】
display mpls te tunnel path命令用来显示本地节点的MPLS TE隧道的路径属性信息。
如果不指定隧道名称,将显示所有隧道的路径属性信息。
# 显示所有隧道路径属性信息。
<Sysname> display mpls te tunnel path
Tunnel Interface Name : Tunnel3
Lsp ID :  1.1.1.9:10
Hop information:
Hop 0: 192.1.1.1;
Hop 1: 12.1.1.2;
Hop 2: 10.202.2.2.
表1-31 display mpls te tunnel path命令显示信息描述表
隧道接口名称
Lsp ID
LSP ID
Hop 0
第0跳
Hop 1
第1跳
Hop 2
第2跳
display mpls te tunnel statistics [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls te tunnel statistics命令用来显示MPLS TE隧道统计信息。
# 显示MPLS TE隧道统计信息。
<Sysname> display mpls te tunnel statistics
Ingress:   0 Tunnels,    0 Tunnels Up,    0 CRLSPs Up
           0 Modified,   0 In-Progress,   0 Failed
Transit:   0 Up
Egress :   0 Up
表1-32 display mpls te tunnel statistics命令显示信息描述表
Ingress
以本设备为隧道入口
Transit:
以本设备为隧道中间结点
Egress
以本设备为隧道出口
Modified
以本设备为入口,处于Modified状态的CRLSP数目
In-Progress
以本设备为入口,处于In-Progress状态的CRLSP数目
Failed
以本设备为入口,处于Failed状态的CRLSP数目
display mpls te tunnel-interface [ tunnel number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
tunnel number:显示指定Tunnel接口的信息。
【描述】
display mpls te tunnel-interface命令用来显示本地节点的MPLS TE隧道接口信息。
# 显示本地节点的MPLS TE隧道接口信息。
<Sysname> display mpls te tunnel-interface
  Tunnel Name         :  Tunnel3
  Tunnel Desc         :  Tunnel3 Interface
  Tunnel State Desc   :  CR-LSP is Up
  Tunnel Attributes   :
    LSP ID              :  1.1.1.9:1
    Session ID          :  10
    Admin State         :  UP                    Oper State   :  UP
    Ingress LSR ID      :  1.1.1.9               Egress LSR ID:  2.2.2.9
    Signaling Prot      :  RSVP                  Resv Style   :  FF
    Tunnel mode         :  Co-routed, active
    Class Type          :  CT0                   Tunnel BW    :  2000 kbps
    Reserved BW         :  2000 kbps
    Setup Priority      :  7                     Hold Priority:  7
    Affinity Prop/Mask  :  0/0
    Explicit Path Name  :  -
    Tie-Breaking Policy :  None
    Metric Type         :  None
    Record Route        :  Disabled          Record Label :  Disabled
    FRR Flag            :  Disabled          BackUpBW Flag:  Not Supported
    BackUpBW Type       :  -                 BackUpBW     :  -
    Route Pinning       :  Disabled
    Retry Limit         :  10                Retry Interval:  10
    Reopt               :  Disabled          Reopt Freq   :  -
    Back Up Type        :  None
    Back Up LSPID       :  -
    Auto BW             :  Disabled          Auto BW Freq :  -
    Min BW              :  -                 Max BW       :  -
    Current Collected BW:  -
    Interfaces Protected:  -
    VPN Bind Type       :  NONE
    VPN Bind Value      :  -
    Car Policy          :  Disabled
    Tunnel  Group       :  Secondary
    Primary Tunnel      :  120
    Backup  Tunnel      :  -
    Group   Status      :  -
表1-33 display mpls te tunnel-interface命令显示信息描述表
Tunnel Name
隧道的名称
Tunnel Desc
隧道的描述信息
Tunnel State Desc
隧道的状态信息
LSP ID
LSP ID
Session ID
会话ID
Admin State
管理状态
Oper State
运行状态
Ingress LSR ID
入口标签交换路由器ID
Egress LSR ID
目的标签交换路由器ID
Signaling Prot
隧道信令协议
Resv Style
预留方式
Tunnel mode
双向隧道模式,取值为:
·     Co-routed, active:表示Co-routed方式双向隧道的active端
·     Co-routed, passive:表示Co-routed方式双向隧道的passive端
·     Associated:表示Associated方式的双向隧道
Class Type
服务类型
Tunnel BW
隧道的带宽
Reserved BW
预留的带宽
Setup Priority
建立优先级
Hold Priority
保持优先级
Affinity Prop/Mask
亲和属性/掩码
Explicit Path Name
显式路径名称
Tie-Breaking Policy
路由选择策略
Metric Type
度量类型
Record Route
记录路由
Record Label
记录标签
FRR Flag
快速重路由标记
BackUpBW Flag
备份带宽标志
BackUpBW Type
备份带宽类型
BackUpBW
备份带宽
Route Pinning
路由固定
Retry Limit
最少重建次数
Retry Interval
重建间隔
Reopt
重优化
Reopt Freq
重优化频率
Back Up Type
备份路径类型
Back Up LSPID
备份LSP ID
Auto BW
自动带宽调整
Auto BW Freq
自动带宽调整频率
Min BW
自动带宽调整的最小带宽
Max BW
自动带宽调整的最大带宽
当前收集带宽
快速重路由保护接口
VPN Bind Type
绑定类型,指明是VPN或ACL
VPN Bind Value
具体绑定的值,VPN实例名称或ACL号
Car Policy
CAR(Committed Access Rate,承诺访问速率)策略
Tunnel Group
该隧道在保护组中是主隧道还是备份隧道
Primary Tunnel
主隧道的Tunnel ID,如果是主隧道,则不填写
Backup Tunnel
备份隧道Tunnel ID,如果是备隧道,则不填写
Group Status
保护组状态,如果未配保护组,则不填写
display ospf [ process-id ] mpls-te [ area area-id ] [ self-originated ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
process-id:OSPF进程号,取值范围为1~65535。
area area-id:OSPF区域号,可以是整数形式,也可以是IPv4地址形式。当是整数形式时,取值范围为0~4294967295。
self-originated:显示自产生(Self Originated)的TE LSA信息。
【描述】
display ospf mpls-te命令用来显示LSDB(链路状态数据库)中包含的所有TE LSA信息。
# 显示LSDB中包含的所有TE LSA信息。
<Sysname> display ospf mpls-te
OSPF Process 100 with Router ID 10.0.0.1
Area ID:
 Traffic Engineering LSA’s of the database
 LSA []
   LSA  Type                 : Opq-Area
   Opaque Type              : 1
   Opaque ID                :
   Advertising Router ID  : xxx.xxx.xxx.xxx
   LSA  Age                 :
   Length                   :
   LSA  Options             :
   LS Seq Number            :
   CheckSum                 :
   Link Type               :Point to Point / Point to Multi Point /MultiAccess
   Link ID                  :
   Local Interface Address  : xxx.xxx.xxx.xxx
   Remote Interface Address : xxx.xxx.xxx.xxx
   TE Metric                :
   Maximum Bandwidth        :  bytes/sec
   Maximum Reservable BW    :  bytes/sec
   Admin Group              :
       Unreserved BW [ 0] =   0  bytes/sec
       Unreserved BW [ 1] =   0  bytes/sec
       Unreserved BW [ 2] =   0  bytes/sec
       Unreserved BW [ 3] =   0  bytes/sec
       Unreserved BW [ 4] =   0  bytes/sec
       Unreserved BW [ 5] =   0  bytes/sec
       Unreserved BW [ 6] =   0  bytes/sec
       Unreserved BW [ 7] =   0  bytes/sec
       Unreserved BW [ 8] =   0  bytes/sec
       Unreserved BW [ 9] =   0  bytes/sec
       Unreserved BW [10] =   0  bytes/sec
       Unreserved BW [11] =   0  bytes/sec
       Unreserved BW [12] =   0  bytes/sec
       Unreserved BW [13] =   0  bytes/sec
       Unreserved BW [14] =   0  bytes/sec
       Unreserved BW [15] =   0  bytes/sec
       BC [ 0] =   bytes/sec
       BC [ 1] =   bytes/sec
表1-34 display ospf mpls-te命令显示信息描述表
Area ID
使能了TE的OSPF区域的区域号
LSA Type
LSA类型,为“Opq-Area”(在Opaque LSA头中携带)
Opaque Type
对于TE,这项值为1(在Opaque LSA头中携带)
Opaque ID
Opaque ID(在Opaque LSA头中携带)
生成这条LSA的路由器ID
LSA age
LSA的年龄(在Opaque LSA头中携带)
Length
Opaque LSA的长度(在Opaque LSA头中携带)
LSA Options
LSA选项(在Opaque LSA头中携带)
LS Seq Number
LSA的顺序号(在Opaque LSA头中携带)
Checksum
LSA的校验和(在Opaque LSA头中携带)
Link Type
链路类型,可能是点到点(Point to Point)、点到多点(Point to Multi Point)、广播(MultiAccess)
Link ID
链路ID
本地的主IP地址
远端接口地址
TE Metric
TE度量
Maximum bandwidth
最大带宽
Maximum reservable bandwidth
最大可预留带宽
Admin Group
管理组
每个TE class的可预留带宽
Unreserved BW [0] to [15]
16个TE class各自的可用带宽
带宽约束(对于DS-TE LSA有意义)
BC 0–1
2种带宽约束(对于DS-TE LSA有意义)
display ospf [ process-id ] traffic-adjustment [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
process-id:OSPF的进程号,取值范围为1~65535。
【描述】
display ospf traffic-adjustment命令用来显示与流量调节(IGP shortcut及转发邻接)相关的、OSPF进程的隧道信息。
# 显示所有OSPF进程与流量调节相关的隧道信息。
<Sysname> display ospf traffic-adjustment
          OSPF Process 1 with Router ID 3.3.3.137
                  Traffic Adjustment
 Interface: 3.3.3.137 (Tunnel1)
     Type: Not enabled  State: Down
     Neighbor ID: 0.0.0.0   Cost: 0
     Configuration:
     Neighbor IP Address: 1.1.1.201
     Cost     :0
     Cost Type: Relative
     Hold Time: 0 ms
表1-35 display ospf traffic-adjustment命令显示信息描述表
隧道类型接口的接口地址和接口名
该隧道是否用于IGP Shortcut或Forwarding Adjacency
Neighbor ID
隧道对端邻居的Router ID
Cost
开销
状态,取值为up/down
Neighbor Ip Address
邻居的IP地址
Cost Type
开销类型
Hold time
保持时间
display tunnel-info { tunnel-id | all | statistics } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
tunnel-id:指定隧道ID号,取值范围为1~FFFFFFFE。
all:所有隧道。
statistics:隧道的统计信息。
【描述】
display tunnel-info命令用来显示隧道信息。
# 显示所有隧道信息。
<Sysname> display tunnel-info all
Tunnel ID           Type              Destination
0x1100002           lsp               2.2.2.2
表1-36 display tunnel-info all命令显示信息描述表
Tunnel ID
隧道ID
隧道类型
Destination
隧道目的地址
# 显示隧道的统计信息。
<Sysname> display tunnel-info statistics
Tunnel Allocation Method :    GLOBAL
Avail Tunnel ID Value :       34816
Total Tunnel ID Allocated :   1
LSP :                         1
GRE :                         0
CRLSP :                       0
LOCAL IFNET :                 0
MPLS LOCAL IFNET :            0
表1-37 display tunnel-info statistics命令显示信息描述表
隧道分配方式
有效隧道ID值
所有已经分配隧道ID的数量
LSP
隧道类型为LSP隧道的数量
GRE
隧道类型为GRE隧道的数量
CRLSP
隧道类型为CRLSP隧道的数量
LOCAL IFNET
MPLS L2VPN中CE侧接口的数量
MPLS LOCAL IFNET
MPLS L2VPN中CCC远程方式出接口的数量
undo enable traffic-adjustment
OSPF视图
【缺省级别】
2:系统级
无
【描述】
enable traffic-adjustment命令用来使能IGP Shortcut特性。undo enable traffic-adjustment命令用来禁止IGP Shortcut特性。
缺省情况下,未使能IGP Shortcut特性。
配置后,在进行SPF计算和泛洪(flooding)时,所有静态LSP隧道也被包括在内。
# IGP协议为OSPF时使能IGP Shortcut特性。
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment
undo enable traffic-adjustment advertise
OSPF视图
【缺省级别】
2:系统级
无
【描述】
enable traffic-adjustment advertise命令用来使能转发邻接特性。undo enable traffic-adjustment advertise命令用来禁止转发邻接特性。
缺省情况下,未使能转发邻接特性。
使能转发邻接特性后,设备会对所有静态LSP隧道进行SPF计算和泛洪(flooding)。
# IGP协议为OSPF时使能转发邻接特性。
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment advertise
explicit-path pathname [ disable | enable ]
undo explicit-path pathname
【缺省级别】
2:系统级
pathname:隧道的显式路径名称,为1~31个字符的字符串。
disable:禁止显式路径。
enable:使能显式路径。
【描述】
explicit-path命令用来创建隧道的显式路径,并进入显式路径视图。undo explicit-path命令用来删除配置的路径。
# 创建一条名为path1的显式路径,并进入显式路径视图。
1.1.35  list hop
list hop [ ip-address ]
显式路径视图
【缺省级别】
2:系统级
【描述】
list hop命令用来显示显式路径的节点信息。
# 显示MPLS TE显式路径的节点信息。
[Sysname-explicit-path-path1] list hop
Path Name :   path1        Path Status :  Enabled
1             1.1.1.9      Strict         Include
2             2.2.2.9      Strict         Exclude
1.1.36  moam dm
moam dm [ -c count | -m interval | -exp value ] * te interface-type interface-number
【缺省级别】
1:监控级
-c count:指定检测的次数。count为检测的次数,取值范围为1~4294967295,缺省值为5。
-m interval:指定发送报文的时间间隔。interval为发送报文的时间间隔,取值范围为200~10000,单位为毫秒,缺省值为200毫秒。
-exp value:指定请求报文中携带的标签的EXP值。value为EXP值,取值范围为0~7,缺省值为0。
te interface-type interface-number:指定检测的TE隧道接口。interface-type interface-number为接口类型和接口编号。
【描述】
moam dm命令用来检测MPLS TE双向隧道的延时,包括正向、反向和往返延时。
需要注意的是,如果使用DM检测单向延时(正向延时或反向延时),则需要通过手工修改时钟、配置NTP(Network Time Protocol,网络时间协议)等方式确保头节点和尾节点的时钟同步,否则检测结果不准确。如果使用DM检测往返延时,则头节点和尾节点的时钟不需要同步。
# 检测双向隧道Tunnel 1的延时。
<Sysname> moam dm te tunnel 1
    Delay measurement for Tunnel 1, press CTRL_C to break
        1. Forward/Reverse/Round-trip delay = 1828/-1782/46 ms
        2. Forward/Reverse/Round-trip delay = 1828/-1797/31 ms
        3. Forward/Reverse/Round-trip delay = 1844/-1798/46 ms
        4. Forward/Reverse/Round-trip delay = 1828/-1797/31 ms
        5. Forward/Reverse/Round-trip delay = 1828/-1797/31 ms
    --- Delay measurement statistics for Tunnel 1 ---
        5 DM packet(s) transmitted
        5 DM packet(s) received
        0.00% DM packet loss
        Forward delay    min/avg/max = 1828/1831.20/1844 ms
        Reverse delay    min/avg/max = -1798/3689348814741909000.00/-1782 ms
        Round-trip delay min/avg/max = 31/37.00/46 ms
表1-38 moam dm命令显示信息描述表
对双向隧道Tunnel 1进行DM检测
在DM检测过程中,按组合键<Ctrl+C>可终止DM检测
本次DM检测计算出的正向、反向和往返延时
对Tunnel 1进行的DM检测的统计数据
发送了5个DM报文
接收到5个DM报文
DM packet loss
DM报文丢失率
正向延时的最小值、平均值和最大值
反向延时的最小值、平均值和最大值
往返延时的最小值、平均值和最大值
1.1.37  moam lm
moam lm [ -c count | -m interval | -exp value ] * te interface-type interface-number
【缺省级别】
1:监控级
【描述】
moam lm命令用来检测MPLS TE双向隧道的丢包率,包括发送丢包率和接收丢包率。
# 检测双向隧道Tunnel 2的丢包率。
<Sysname> moam lm te tunnel 2
    Loss measurement for Tunnel 2, press CTRL_C to break
        1. TxLoss = 1 (100.00% loss), Rxloss = 0 (100.00% loss)
        2. TxLoss = 1 (100.00% loss), Rxloss = 0 (100.00% loss)
        3. TxLoss = 1 (100.00% loss), Rxloss = 0 (100.00% loss)
        4. TxLoss = 1 (100.00% loss), Rxloss = 0 (100.00% loss)
        5. TxLoss = 1 (100.00% loss), Rxloss = 0 (100.00% loss)
    --- Loss measurement statistics for Tunnel 2 ---
        TxLoss/TxTotal = 5/5 (100.00% loss)
        RxLoss/RxTotal = 0/0 (100.00% loss)
表1-39 moam lm命令显示信息描述表
对双向隧道Tunnel 2进行LM检测
在LM检测过程中,按组合键<Ctrl+C>可终止LM检测
TxLoss
本次LM检测过程中,发送方向的丢包数及丢包率
Rxloss
本次LM检测过程中,接收方向的丢包数及丢包率
对Tunnel 2进行的LM检测的统计数据
TxLoss/TxTotal
发送方向的丢包数与本端发送给对端的报文总数的比率,即发送丢包率
RxLoss/RxTotal
接收方向的丢包数与对端发送给本端的报文总数的比率,即接收丢包率
1.1.38  modify hop
modify hop ip-address1 ip-address2 [ include [ loose | strict ] | exclude ]
显式路径视图
【缺省级别】
2:系统级
ip-address1 ip-address2:将显式路径中的IP地址ip-address1修改为ip-address2。可以指定链路的IP地址或节点的Router ID。
include:指定在显式路径中需要包含IP地址ip-address2。
loose:指定ip-address2为松散下一跳,即ip-address2的上一跳与ip-address2可以不是直接相连。
strict:指定ip-address2为严格下一跳,即ip-address2的上一跳与ip-address2必须直接相连。
exclude:指定在显式路径中不能包括地址ip-address2。
【描述】
modify hop命令用来修改显式路径中节点的IP地址及其属性(显式路径中是否包括插入的节点;插入的节点是松散下一跳,还是严格下一跳)。
·     如果没有指定include和exclude关键字,则缺省为include,即在显式路径中需要包含IP地址ip-address2。
·     如果没有指定loose和strict关键字,则缺省为strict,即ip-address2的上一跳与ip-address2必须直接相连。
# 将MPLS TE显式路径中的IP地址10.0.0.125修改为10.0.0.200,并指定显式路径中不能包括此地址。
[Sysname-explicit-path-path1] modify hop 10.0.0.125 10.0.0.200 exclude
1.1.39  mpls rsvp-te
mpls rsvp-te
undo mpls rsvp-te
MPLS视图/接口视图
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te命令用来使能RSVP-TE能力。undo mpls rsvp-te命令用来取消RSVP-TE能力。
缺省情况下,未使能RSVP-TE能力。
·     在配置其他RSVP-TE功能之前,应先使能RSVP-TE。
·     在MPLS视图下使能本节点的RSVP-TE能力之前,需要先在系统视图下使能本节点的MPLS能力,并在MPLS视图下使能本节点的MPLS TE能力。
·     在接口视图下使能接口的RSVP-TE能力之前,需要先在接口视图下使能接口的MPLS能力和MPLS TE能力。
·     当在MPLS视图下取消RSVP-TE能力时,将会同时取消所有接口上配置的RSVP-TE能力。
# 使能RSVP-TE能力。
[Sysname] mpls
[Sysname-mpls] mpls te
[Sysname-mpls] mpls rsvp-te
# 在接口GigabitEthernet3/1/1上使能RSVP-TE能力。
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] mpls
[Sysname-GigabitEthernet3/1/1] mpls te
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te
mpls rsvp-te authentication { cipher | plain } auth-key
undo mpls rsvp-te authentication
【缺省级别】
2:系统级
cipher:表示以密文形式设置密钥。
plain:表示以明文形式设置密钥。
auth-key:验证密钥,区分大小写。如果指定cipher参数,则auth-key为8~53个字符的密文字符串;如果指定plain参数,则auth-key为8~16个字符的明文字符串。
【描述】
mpls rsvp-te authentication命令用来使能RSVP验证功能。undo mpls rsvp-te authentication命令用来禁止RSVP验证功能。
缺省情况下,禁止RSVP验证功能。
RSVP-TE传送由验证密钥和加密哈希算法生成的消息验证摘要。所有从此接口发送的报文将使用此密钥来计算消息摘要,从此接口接收的报文也将使用此密钥来验证。
以明文或密文形式设置的密钥,均以密文的方式保存在配置文件中。
# 在接口GigabitEthernet3/1/1上启动RSVP验证功能,以明文形式设置密钥,密钥值为userkey1。
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te authentication plain userkey1
undo mpls rsvp-te bfd enable
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te bfd enable命令用来在已使能RSVP-TE的接口下使能BFD提供的链路检测功能。undo mpls rsvp-te bfd enable命令用来关闭已使能RSVP的接口下BFD提供的链路检测功能恢复缺省情况。
缺省情况下,已使能RSVP-TE的接口下未使能BFD提供的链路检测功能。
需要注意的是,在接口视图下使能BFD提供的链路检测功能,要先在接口视图下使能RSVP-TE。
#在接口GigabitEthernet3/1/1上使能MPLS RSVP-TE的BFD链路检测功能。
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te bfd enable
mpls rsvp-te blockade-multiplier number
undo mpls rsvp-te blockade-multiplier
MPLS视图
【缺省级别】
2:系统级
number:阻塞状态超时倍数,取值范围为3~255。
【描述】
mpls rsvp-te blockade-multiplier命令用来配置阻塞状态超时倍数。undo mpls rsvp-te blockade-multiplier用来恢复缺省配置。
缺省情况下,阻塞状态超时倍数为4。
如果有一个资源预留请求在某些节点上没有通过准入控制,但设备不希望立即删除这个请求的状态,也不希望这个请求阻止其他请求使用它预留的资源。这种情况下,设备将这个请求的状态置为阻塞状态(Blockade State),在下游节点生成BSB(Blockade State Block,阻塞状态块)。当连续未收到刷新消息的次数超过阻塞状态超时倍数时,BSB中相应的状态被删除。也就是说,阻塞状态超时时间为(阻塞状态超时倍数×路径/预留消息的刷新时间)。
需要注意的是,执行该命令前应先使能RSVP-TE特性。
相关配置可参考命令mpls rsvp-te timer refresh。
# 设定阻塞状态超时倍数为5。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te blockade-multiplier 5
mpls rsvp-te dscp dscp-value
undo mpls rsvp-te dscp
MPLS视图
【缺省级别】
2:系统级
dscp-value:发送的RSVP报文的DSCP优先级,取值范围为0~63。
【描述】
mpls rsvp-te dscp命令用来配置发送的RSVP报文的DSCP优先级。undo mpls rsvp-te dscp命令用来恢复缺省情况。
缺省情况下,发送的RSVP报文的DSCP优先级为48。
# 配置发送的RSVP报文的DSCP优先级为56。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te dscp 56
undo mpls rsvp-te graceful-restart
MPLS视图
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te graceful-restart命令用来使能MPLS RSVP-TE协议的GR能力。undo mpls rsvp-te graceful-restart命令用来关闭MPLS RSVP-TE协议的GR能力。
缺省情况下,MPLS RSVP-TE协议的GR能力处于关闭状态。
需要注意的是,在使能RSVP-TE协议的GR能力前,需要先使能RSVP-TE协议Hello扩展能力。
# 使能MPLS RSVP-TE协议的GR能力。
[Sysname] mpls lsr-id 1.1.1.1
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello
[Sysname-mpls] mpls rsvp-te graceful-restart
mpls rsvp-te hello
undo mpls rsvp-te hello
MPLS视图/接口视图
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te hello命令用来使能RSVP的Hello扩展。undo mpls rsvp-te hello命令用来禁止RSVP的Hello扩展。
缺省情况下,未使能RSVP的Hello扩展。
RSVP利用Hello扩展机制检测RSVP邻居节点的可达性。
在接口视图下使能RSVP的Hello扩展,要先在接口视图下使能RSVP-TE,并在MPLS视图下使能RSVP的Hello扩展。
# 使能RSVP的Hello扩展。
[Sysname] mpls
# 在接口GigabitEthernet3/1/1上使能RSVP的Hello扩展。
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te hello
mpls rsvp-te hello-lost times
undo mpls rsvp-te hello-lost
MPLS视图
【缺省级别】
2:系统级
times:最多可以接受的Hello报文丢失次数,取值范围为3~10。
【描述】
mpls rsvp-te hello-lost命令用来配置允许连续未收到Hello报文的次数。undo mpls rsvp-te hello-lost命令用来恢复缺省情况。
缺省情况下,最多允许连续3次收不到Hello报文。
采用Hello机制时,如果节点连续多次未接收到对端发来的Hello应答消息,则判定链路出现故障。执行该命令之前,应先使能RSVP-TE特性,并在MPLS视图下使能RSVP的Hello扩展功能。
相关配置可参考命令mpls rsvp-te timer hello。
# 设定节点允许连续未收到Hello应答的次数为5。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello-lost 5
mpls rsvp-te keep-multiplier number
undo mpls rsvp-te keep-multiplier
MPLS视图
【缺省级别】
2:系统级
number:超时倍数,取值范围为3~255。
【描述】
mpls rsvp-te keep-multiplier命令用来配置PSB和RSB的超时倍数。undo mpls rsvp-te keep-multiplier命令用来恢复缺省情况。
缺省情况下,PSB和RSB的超时倍数为3。
PSB和RSB的超时时间Expired_Time=(keep-multiplier+0.5)×1.5×refresh-time。
需要注意的是,执行该命令前,应先使能RSVP-TE特性。
# 配置PSB和RSB的超时倍数为5。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te keep-multiplier 5
undo mpls rsvp-te reliability
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te reliability命令用来使能RSVP可靠性功能。undo mpls rsvp-te reliability命令用来禁止RSVP可靠性功能。
缺省情况下,禁止RSVP可靠性功能。
使能RSVP可靠性功能后,设备将在发送的RSVP消息中携带用于RSVP消息确认的Message_ID和Message_ID_ACK对象,从而提高RSVP消息发送的可靠性。
# 在接口GigabitEthernet3/1/1上使能RSVP可靠性功能。
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te reliability
undo mpls rsvp-te resvconfirm
MPLS视图
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te resvconfirm命令用来使能节点的预留确认机制。undo mpls rsvp-te resvconfirm命令用来禁止预留确认机制。
缺省情况下,节点上不使能预留确认机制。
使能节点的预留确认机制后,节点在发送Resv消息时,携带一个要求对预留进行确认的对象。接收到Resv消息的节点需要发送ResvConf消息对预留消息进行确认。
# 在本节点使能预留确认机制。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te resvconfirm
undo mpls rsvp-te srefresh
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te srefresh 命令用来使能Srefresh(Summary Refresh,摘要刷新)功能。undo mpls rsvp-te srefresh命令用来禁止摘要刷新功能。
缺省情况下,未使能摘要刷新功能。
使能Srefresh功能将在当前接口禁用传统的时间驱动刷新。Srefresh消息用于刷新路径Path和预留Resv的状态。
# 在接口GigabitEthernet3/1/1上启动Srefresh特性。
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te srefresh
mpls rsvp-te timer graceful-restart recovery recovery-time
undo mpls rsvp-te timer graceful-restart recovery
MPLS视图
【缺省级别】
2:系统级
recovery-time:RSVP-TE GR恢复定时器的值,取值范围为60~300,单位为秒。
【描述】
mpls rsvp-te timer graceful-restart recovery命令用来配置RSVP-TE GR的恢复定时器。undo mpls rsvp-te timer graceful-restart recovery命令用来恢复缺省情况。
缺省情况下,RSVP-TE GR恢复定时器的值为300秒。
执行该命令之前,必须先使能RSVP-TE协议的GR能力。
# 配置RSVP-TE GR恢复定时器的值为100秒。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer graceful-restart recovery 100
mpls rsvp-te timer graceful-restart restart restart-time
undo mpls rsvp-te timer graceful-restart restart
MPLS视图
【缺省级别】
2:系统级
restart-time:RSVP-TE GR重启定时器的值,取值范围为60~300,单位为秒。
【描述】
mpls rsvp-te timer graceful-restart restart命令用来配置RSVP-TE GR的重启定时器。undo mpls rsvp-te timer graceful-restart restart命令用来恢复缺省情况。
缺省情况下,RSVP-TE GR重启定时器的值为120秒。
# 配置RSVP-TE GR重启定时器的值为200秒。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer graceful-restart restart 200
mpls rsvp-te timer hello timevalue
undo mpls rsvp-te timer hello
MPLS视图
【缺省级别】
2:系统级
timevalue:Hello定时器时长,取值范围为1~60,单位为秒。
【描述】
mpls rsvp-te timer hello命令用来配置Hello消息的发送时间间隔。undo mpls rsvp-te timer hello 命令用来恢复缺省配置。
缺省情况下,Hello消息发送时间间隔为3秒。
执行此命令前,必须先在MPLS视图下启动Hello机制。
相关配置可参考命令mpls rsvp-te hello和mpls rsvp-te hello-lost。
# 配置Hello消息的发送时间间隔为5秒。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer hello 5
mpls rsvp-te timer refresh timevalue
undo mpls rsvp-te timer refresh
MPLS视图
【缺省级别】
2:系统级
timevalue:刷新定时器时长,取值范围10~65535,单位为秒。
【描述】
mpls rsvp-te timer refresh命令用来配置节点的路径/预留消息的刷新时间。undo mpls rsvp-te timer refresh命令用来恢复缺省配置。
缺省情况下,节点的路径/预留消息的刷新时间为30秒。
相关配置可参考命令mpls rsvp-te keep-multiplier。
# 配置每60秒发送一次路径/预留刷新消息。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer refresh 60
mpls rsvp-te timer retransmission { increment-value [ increment-value ] | retransmit-value [ retrans-timer-value ] } *
undo mpls rsvp-te timer retransmission
【缺省级别】
2:系统级
increment-value increment-value:重传增量,取值范围为1~10,缺省值为1。
retransmit-value retrans-timer-value:初始重传时间间隔,取值范围为500~3000,单位为毫秒,缺省值为500毫秒。
【描述】
mpls rsvp-te timer retransmission命令用来使能重传功能。undo mpls rsvp-te timer retransmission命令用来关闭重传功能。
缺省情况下,未使能重传功能。
重传功能是指:节点发送了携带Message_ID对象的消息,且Message_ID对象的ACK_Desired标识(是否需要应答标识)置位后,如果在重传时间Rf内没有收到携带对应Message_ID_ACK对象的消息,则重传时间Rf超时后重传此消息,并将重传时间置为(1+Delta)×Rf。节点持续按照上述方法重传此消息,直到节点在重传时间超时前接收到对应的应答消息,或消息传送次数达到允许的最大值。
重传时间的初始值为本命令中配置的retrans-timer-value,Delta的值为本命令中配置的increment-value。
# 在接口GigabitEthernet3/1/1上启动重传功能,重传增量为2,初始重传时间间隔为1000毫秒。
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te timer retransmission increment-value 2 retransmit-value 1000
1.1.56  mpls te
mpls te
undo mpls te
MPLS视图/接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te用来使能MPLS TE能力。undo mpls te用来禁止MPLS TE能力。
·     在MPLS视图下执行mpls te命令,将使能本节点的MPLS TE能力;undo mpls te删除所有CR-LSP,禁止MPLS TE能力。
·     在接口视图下执行mpls te命令,将使能接口的MPLS TE能力;undo mpls te删除接口上所有CR-LSP,禁止接口的MPLS TE能力。
缺省情况下,未使能MPLS TE能力。
必须先全局使能本节点的MPLS TE能力,才能在接口下使能MPLS TE的能力。
在接口下使能MPLS TE时,如果用户修改了该接口的MTU,则需要先shutdown再undo shutdown该接口,从而刷新TE隧道。
# 使能本节点的MPLS TE能力。
[Sysname] mpls lsr-id 1.1.1.9
[Sysname] mpls
# 使能接口GigabitEthernet3/1/1的MPLS TE能力。
mpls te affinity property properties [ mask mask-value ]
undo mpls te affinity property
Tunnel接口视图
【缺省级别】
2:系统级
properties:承载隧道的链路的属性值,32位整数,取值范围为0x0~0xFFFFFFFF,每一位代表一种属性,属性值是1或0,缺省值为0x0。
mask-value:需要检查的链路属性位,32位整数,取值范围为0x0~0xFFFFFFFF,每一位代表一种属性,属性值是1或0,缺省值为0x00000000。
【描述】
mpls te affinity property命令用来配置隧道的亲和(Affinity)属性,也就是隧道使用的链路属性。undo mpls te affinity property命令用来恢复缺省情况。
缺省情况下,隧道的亲和属性为0x00000000,掩码为0x00000000。
亲和属性的掩码决定了设备需要检查哪些链路属性。
相关配置可参考命令mpls te link administrative group。
# 配置隧道的亲和属性。
[Sysname] interface tunnel 3
[Sysname-Tunnel3] mpls te affinity property 101 mask 303
mpls te backup { hot-standby | ordinary }
undo mpls te backup
Tunnel接口视图
【缺省级别】
2:系统级
hot-standby:热备份,即创建主CR-LSP后随即创建备份CR-LSP。主CR-LSP失效时,通过MPLS TE直接将业务切换至备份CR-LSP。
ordinary:普通备份,即主CR-LSP失效后再创建备份CR-LSP。
【描述】
mpls te backup命令用来使能当前隧道的备份功能,并配置使用的备份模式。undo mpls te backup命令用来恢复缺省情况。
缺省情况下,隧道不进行备份。
·     对隧道使能了备份功能后,记录路由标志将被自动配置为“record reroute”,而不论用户是否配置了命令mpls te record-route。
·     本命令与以下命令互斥:mpls te reoptimization, mpls te auto-bandwidth adjustment和mpls te resv-style ff。
# 使能隧道Tunnel0的备份功能,并配置使用的备份模式为热备份。
[Sysname-Tunnel3] mpls te backup hot-standby
mpls te backup bandwidth { bandwidth | { ct0 | ct1 | ct2 | ct3 } { bandwidth | un-limited } }
undo mpls te backup bandwidth
Tunnel接口视图
【缺省级别】
2:系统级
bandwidth:Bypass隧道所能保护的带宽总量,取值范围为1~32000000,单位为kbit/s。
ct0:只有CT 0的LSP可以使用Bypass隧道。
ct1:只有CT 1的LSP可以使用Bypass隧道。
ct2:只有CT 2的LSP可以使用Bypass隧道。
ct3:只有CT 3的LSP可以使用Bypass隧道。
un-limited:不对所能保护的带宽总量进行限制。
【描述】
mpls te backup bandwidth命令用来配置Bypass Tunnel可保护的带宽和LSP类型。undo mpls te backup bandwidth命令用来取消配置。
缺省情况下,Bypass Tunnel不对带宽进行保护。
·     如果不指定CT 0、CT 1、CT 2和CT 3,则所有LSP都可以使用Bypass隧道。
·     通过本命令配置的保护带宽数目,仅用于计算并确立带宽保护关系,在Bypass隧道上不会预留相应的带宽。
·     配置的保护带宽数目要小于Bypass隧道实际的带宽。否则,FRR切换后,会导致被保护隧道所承载的流量丢失,并造成被保护隧道down。
当MPLS TE隧道的动态协议类型为CR-LDP时,不支持本命令。
# 隧道Tunnel3只用来保护属于CT 0的LSP,并且不对所保护带宽总量进行限制。隧道Tunnel2只用来保护属于CT 1的LSP,保护的带宽总量是1000kbit/s。
[Sysname-Tunnel3] mpls te backup bandwidth ct0 un-limited
[Sysname-Tunnel3] quit
[Sysname] interface tunnel 2
[Sysname-Tunnel2] mpls te backup bandwidth ct1 1000
1.1.60  mpls te bandwidth
mpls te bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth
undo mpls te bandwidth
Tunnel接口视图
【缺省级别】
2:系统级
ct0:配置隧道流量属于CT 0。
ct1:配置隧道流量属于CT 1。
ct2:配置隧道流量属于CT 2。
ct3:配置隧道流量属于CT 3。
bandwidth:MPLS TE隧道所需的带宽,取值范围为1~32000000,单位为kbit/s。
【描述】
mpls te bandwidth命令用来配置MPLS TE隧道所需的带宽,并指定隧道流量所属的服务类型。undo mpls te bandwidth命令用来恢复缺省配置。
缺省情况下,未配置MPLS TE隧道所需的带宽,即带宽为0,隧道流量属于CT0。
配置带宽时,如果不指定ct0、ct1、ct2或ct3,则隧道流量属于CT0。
·     在CR16000系列核心路由器上,如果MPLS TE隧道中存在多条数据流,则每条数据流只会对应一个隧道的出端口。
·     当MPLS TE隧道存在多个出端口(如隧道的出口为加入了多个端口的聚合组)时,命令mpls te bandwidth的配置会在每一个端口上生效,这时当MPLS TE隧道存在多条数据流时,实际的带宽=用户配置的MPLS TE隧道所需的带宽(bandwidth)×有数据流的出端口数目。
·     当配置MPLS TE隧道所需带宽大于1024kbit/s时,建议取值配置为1024kbit/s的整数倍。
# 配置MPLS TE隧道所需带宽为1000kbit/s,隧道流量所属的服务类型为CT 1。
[Sysname-Tunnel3] mpls te bandwidth ct1 1000
1.1.61  mpls te bandwidth change thresholds
mpls te bandwidth change thresholds { down | up } percent
undo mpls te bandwidth change thresholds { down | up }
【缺省级别】
2:系统级
down:配置带宽减少时IGP进行泛洪的百分比阈值。当链路可用带宽的减少值与链路原有可用带宽的比值大于此百分比阈值时,IGP将进行泛洪,并更新流量工程数据库。
up:配置带宽增加时的IGP进行泛洪的百分比阈值。当链路可用带宽的增加值与链路原有可用带宽的比值大于此百分比阈值时,IGP将进行泛洪,并更新流量工程数据库。
percent:配置带宽阈值水平,取值范围为0~100。
【描述】
mpls te bandwidth change thresholds命令用来配置带宽变化IGP泛洪阈值。undo mpls te bandwidth change thresholds命令用来恢复缺省配置。
缺省情况下,带宽变化IGP泛洪阈值为10。
# 在接口GigabitEthernet3/1/1上配置链路带宽变化阈值,配置带宽变化IGP泛洪阈值为100%。
[Sysname-GigabitEthernet3/1/1] mpls te bandwidth change thresholds down 100
1.1.62  mpls te bfd enable
mpls te bfd enable [ discriminator local local-id remote remote-id ]
undo mpls te bfd enable
Tunnel接口视图
【缺省级别】
2:系统级
discriminator:指定BFD会话鉴别值。
local local-id:指定BFD会话的本地鉴别值,取值范围为1~512。
remote remote-id:指定BFD会话的远端鉴别值,取值范围为1~4294967295。
【描述】
mpls te bfd enable命令用来使能TE隧道接口的MPLS TE隧道BFD检测功能。undo mpls te bfd enable命令用来关闭TE隧道接口的MPLS TE隧道BFD检测功能。
缺省情况下,未使能TE隧道接口所在MPLS TE隧道的BFD检测功能。
·     执行本命令前,必须先通过mpls lspv命令使能LSP检测功能。mpls lspv命令的详细介绍,请参见“MPLS命令参考”中的“MPLS基础”。
·     BFD会话参数为TE隧道接口下配置的BFD参数,BFD会话的源地址为MPLS LSR-ID。因此,配置BFD检测MPLS TE隧道功能前,需要确保对端设备上存在MPLS LSR-ID对应的路由,还可以根据需要在隧道接口下配置BFD会话参数。BFD参数配置的详细介绍,请参见“可靠性配置指导”中的“BFD”。
# 使用BFD检测隧道接口Tunnel1下的MPLS TE隧道。
[Sysname] interface tunnel 1
[Sysname-Tunnel1] mpls te bfd enable
1.1.63  mpls te bidirectional
mpls te bidirectional { co-routed { active | passive reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id } | associated reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id }
undo mpls te bidirectional
Tunnel接口视图
【缺省级别】
2:系统级
co-routed:配置Co-routed方式的MPLS TE双向隧道。
active:指定本端作为Co-routed方式MPLS TE双向隧道的主动方。
passive reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id:指定本端作为Co-routed方式MPLS TE双向隧道的被动方,并指定关联的反向CR-LSP。ingress-lsr-id为反向CR-LSP的入节点LSR ID;tunnel-id为反向CR-LSP的Tunnel ID。被动方上需要指定反向CR-LSP,以便将正、反两个方向的单向CR-LSP关联为MPLS TE双向隧道。
associated reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id:配置Associated方式的MPLS TE双向隧道,并指定关联的反向CR-LSP。ingress-lsr-id为反向CR-LSP的入节点LSR ID;tunnel-id为反向CR-LSP的Tunnel ID。
【描述】
mpls te bidirectional命令用来在MPLS TE隧道接口上启用双向隧道功能。undo mpls te bidirectional命令用来关闭MPLS TE隧道接口的双向隧道功能。
缺省情况下,未启用MPLS TE隧道接口的双向隧道功能,MPLS TE隧道接口上建立的隧道为MPLS TE单向隧道。
MPLS TE双向隧道的建立有如下几种方式:
·     Co-routed方式:通过RSVP-TE信令协议建立MPLS TE双向隧道。配置Co-routed方式MPLS TE双向隧道时,隧道的两端节点需要分别配置为主动方(Active)和被动方(Passive)。
·     Associated方式:通过配置手工将两条单向的CR-LSP绑定,从而形成MPLS TE双向隧道。绑定在一起的两条单向CR-LSP可以通过不同的方式建立,例如一个方向上的CR-LSP使用静态方式建立,而另一个方向上的CR-LSP使用RSVP-TE信令建立。绑定在一起的两条单向CR-LSP使用的路径可以不同。
·     建立Co-routed方式MPLS TE双向隧道时,必须配置建立隧道使用的信令协议为RSVP-TE,且必须配置资源预留方式为FF方式。
·     Associated方式MPLS TE双向隧道的单向CR-LSP采用RSVP-TE信令建立时,必须配置资源预留方式为FF方式。
·     配置MPLS TE双向隧道时,在隧道两端都需要关闭PHP功能,为倒数第二跳分配非空标签。
# 在接口Tunnel0上启用MPLS TE双向隧道功能,并配置本端为Co-routed方式双向隧道的主动方。
[Sysname] interface tunnel 0
[Sysname-Tunnel0] destination 10.0.0.2
[Sysname-Tunnel0] mpls te tunnel-id 1
[Sysname-Tunnel0] mpls te bidirectional co-routed active
# 在接口Tunnel0上启用MPLS TE双向隧道功能,并配置本端为Co-routed方式双向隧道的被动方,关联的反向CR-LSP的入节点LSR ID为10.0.0.1,反向CR-LSP的Tunnel ID为1。
[Sysname-Tunnel0] destination 10.0.0.1
[Sysname-Tunnel0] mpls te bidirectional co-routed passive reverse-lsp lsr-id 10.0.0.1 tunnel-id 1
1.1.64  mpls te commit
mpls te commit
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te commit命令用来提交隧道当前配置。
在执行mpls te commit命令之前,对MPLS TE隧道的配置不会生效。
# 配置一条MPLS TE隧道,并提交隧道当前配置。
[Sysname-Tunnel3] tunnel-protocol mpls te
[Sysname-Tunnel3] destination 2.2.2.9
[Sysname-Tunnel3] mpls te commit
1.1.65  mpls te cspf
mpls te cspf
undo mpls te cspf
MPLS视图
【缺省级别】
2:系统级
无
【描述】
mpls te cspf命令用来使能本节点的CSPF功能。undo mpls te cspf命令用来禁止本节点的CSPF功能。
缺省情况下,未使能本节点的CSPF功能。
使能CSPF前,应先在MPLS视图下使能MPLS TE。
CSPF提供了一种在MPLS域中选择路径的方法。使用动态信令协议建立MPLS TE隧道时,需要使能节点的CSPF功能。
必须先使能CSPF,才能配置其他CSPF相关功能。
# 使能本节点的CSPF功能。
[Sysname] mpls
[Sysname-mpls] mpls te cspf
1.1.66  mpls te cspf timer failed-link
mpls te cspf timer failed-link timer-interval
undo mpls te cspf timer failed-link
MPLS视图
【缺省级别】
2:系统级
timer-interval:失效链路定时器的值,取值范围为0~300,单位为秒。
【描述】
mpls te cspf timer failed-link命令用来配置失效链路定时器的值。undo mpls te cspf timer failed-link命令用来恢复缺省情况。
缺省情况下,失效链路定时器的值为10秒。
一旦一条链路状态变为down,失效链路定时器就会启动。如果IGP在定时器超时之前删除或修改此链路,IGP将会把删除或修改情况通知CSPF。CSPF在TEDB中更新链路,并停止定时器。如果定时器超时时,IGP还没有删除链路,链路状态将被更新为up。
相关配置可参考命令mpls te cspf。
# 配置失效链路定时器的值为50秒。
[Sysname] mpls
[Sysname-mpls] mpls te cspf timer failed-link 50
1.1.67  mpls te ds-te ietf bc-mode
mpls te ds-te ietf bc-mode mam
undo mpls te ds-te ietf bc-mode
MPLS视图
【缺省级别】
2:系统级
mam:指定带宽约束模型为MAM模型。
【描述】
mpls te ds-te ietf bc-mode命令用来配置IETF DS-TE模式下使用的带宽约束模型。undo mpls te ds-te ietf bc-mode命令用来恢复缺省情况。
缺省情况下,IETF DS-TE模式的带宽约束模型为RDM模型。
·     本命令仅对IETF DS-TE模式有效。Prestandard DS-TE模式下,只能使用RDM带宽约束模型。
·     在IETF DS-TE模式下修改带宽约束模型后,设备上所有预留带宽非零的CR-LSP都将被拆除。
相关配置可参考命令mpls te ds-te mode。
# 配置IETF模式下带宽约束模型为MAM。
[Sysname] mpls
[Sysname-mpls] mpls te ds-te ietf bc-mode mam
1.1.68  mpls te ds-te ietf te-class
mpls te ds-te ietf te-class te-class-index class-type class-type-number priority pri-number
undo mpls te ds-te ietf te-class te-class-index
MPLS视图
【缺省级别】
2:系统级
te-class-index:TE class编号,取值范围为0~7。
class-type class-type-number:指定TE class对应的CT。class-type-number为CT编号,取值范围为0~3,即系统支持四个CT(CT 0、CT 1、CT 2和CT 3)。
priority pri-number:指定TE class对应的抢占优先级。pri-number为抢占优先级,取值范围为0~7。
【描述】
mpls te ds-te ietf te-class命令用来配置IETF DS-TE模式下TE class与服务类型、抢占优先级的对应关系,即TE class map。undo mpls te ds-te ietf te-class命令用来恢复缺省的TE class map。
缺省情况下,IETF模式的TE class map如表1-40所示。
表1-40 IETF模式的缺省TE class map
TE Class
CT
Priority
0
0
7
1
1
7
2
2
7
3
3
7
4
0
0
5
1
0
6
2
0
7
3
0
·     通过mpls te ds-te ietf te-class命令配置TE class map时,输入的CT和抢占优先级不要与已有TE class map的CT和抢占优先级相同。
·     通过undo mpls te ds-te ietf te-class命令恢复缺省TE class map时,恢复的TE class map的CT和抢占优先级不要与已有TE class map的CT和抢占优先级相同。
·     修改任意的TE class map后,设备都会通知IGP更新发布所有TE接口的带宽信息,并拆除所有TE接口上此TE class对应的CR-LSP,并重新建立。
# 配置IETF模式下TE class 7对应CT 2,抢占优先级为3。
[Sysname] mpls
[Sysname-mpls] mpls te ds-te ietf te-class 7 class-type 2 priority 3
1.1.69  mpls te ds-te mode
mpls te ds-te mode ietf
undo mpls te ds-te mode
MPLS视图
【缺省级别】
2:系统级
ietf:指定DS-TE模式为IETF模式。
【描述】
mpls te ds-te mode命令用来配置DS-TE模式。undo mpls te ds-te mode命令用来恢复缺省情况。
缺省情况下,DS-TE模式为Prestandard模式。
需要注意的是,修改DS-TE模式后,设备上所有的CR-LSP都将被拆除。
# 配置DS-TE模式为IETF模式。
[Sysname] mpls
[Sysname-mpls] mpls te ds-te mode ietf
1.1.70  mpls te failure-action teardown
undo mpls te failure-action teardown
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te failure-action teardown命令用来使能RSVP-TE隧道故障后的拆除重建功能。undo mpls te failure-action teardown命令用来关闭RSVP-TE隧道故障后的拆除重建功能。
缺省情况下,未使能RSVP-TE隧道故障后的拆除重建功能。
使能RSVP-TE隧道故障后的拆除重建功能后,如果在BFD检测MPLS TE隧道或周期性LSP Tracert检测到RSVP-TE隧道故障后的一段时间内,RSVP没有重新创建该RSVP-TE隧道,则拆除该隧道并进行重建。
# 在隧道接口Tunnel1上使能RSVP-TE隧道故障后的拆除重建功能。
[Sysname-Tunnel1] mpls te failure-action teardown
1.1.71  mpls te fast-reroute
undo mpls te fast-reroute
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te fast-reroute命令用来使能快速重路由功能。undo mpls te fast-reroute命令用来禁止快速重路由功能。
缺省情况下,未使能快速重路由功能。
对Tunnel接口使能快速重路由功能后,记录路由标志将自动配置“record reroute with label”,而不论用户是否配置了命令mpls te record-route label。如果用户需要配置mpls te record-route或undo mpls te record-route,必须先禁用快速重路由功能。
·     当MPLS TE隧道的动态协议类型为CR-LDP时,不支持本命令。
·     快速重路由功能与以下命令互斥:mpls te resv-style ff。
# 当一条链路失效时,使能MPLS TE隧道使用一条已经存在的备份隧道。
[Sysname-Tunnel3] mpls te fast-reroute
1.1.72  mpls te fast-reroute bypass-tunnel
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
undo mpls te fast-reroute bypass-tunnel tunnel tunnel-number
【缺省级别】
2:系统级
tunnel tunnel-number:指定旁路隧道的编号。
【描述】
mpls te fast-reroute bypass-tunnel命令用来为被保护的接口指定一条或多条旁路隧道。undo mpls te fast-reroute bypass-tunnel命令用来删除配置的旁路隧道。
如果需要为被保护的接口指定多条旁路隧道,可以多次使用mpls te fast-reroute bypass-tunnel命令。最多可以为被保护的接口指定3条旁路隧道。
为接口指定旁路隧道,需要满足以下条件:
·     旁路隧道必须是up状态的;
·     被保护的接口不是路由的下一跳的出接口。
·     被指定为Bypass隧道后,该隧道不能作为VPN等业务的隧道使用。
# 使用隧道接口Tunnel3作为旁路隧道。
[Sysname-GigabitEthernet3/1/1] mpls te fast-reroute bypass-tunnel tunnel 3
1.1.73  mpls te igp advertise
mpls te igp advertise [ hold-time value ]
undo mpls te igp advertise
Tunnel接口视图
【缺省级别】
2:系统级
hold-time value:TE隧道状态转为down后到通知网络之前等待的时间,取值范围为0~4294967295,单位为毫秒,缺省值为0毫秒。
【描述】
mpls te igp advertise命令用来将MPLS TE隧道作为链路发布到IGP网络。undo mpls te igp advertise命令用来取消配置。
缺省情况下,MPLS TE隧道不被作为链路发布到IGP网络。
mpls te igp advertise命令与mpls te igp shortcut命令互斥。
# 配置保持时间为10000毫秒。
[Sysname-Tunnel3] mpls te igp advertise hold-time 10000
1.1.74  mpls te igp metric
mpls te igp metric { absolute value | relative value }
undo mpls te igp metric
Tunnel接口视图
【缺省级别】
2:系统级
absolute value:绝对度量模式。value,正整数,取值范围为1~65535。
relative value:相对度量模式。value,表示相对于隧道IGP度量的差异,可以是正整数、负整数或0,取值范围为-10~10,缺省值为0。
【描述】
mpls te igp metric命令用来配置MPLS TE隧道的度量值。undo mpls te igp metric命令用来恢复缺省配置。
缺省情况下,TE隧道的度量等于其IGP度量。
在IGP Shortcut和转发邻接特性中计算路径时,可以指定TE隧道使用的度量值。如果使用绝对度量(absolute),则TE隧道的度量值就是配置的值;如果使用相对度量(relative),则TE隧道的度量值是相应IGP路径度量值加上相对度量值。
# 配置在IGP Shortcut和转发邻接特性中计算路径时,TE隧道使用的度量值为相对值-1。
[Sysname-Tunnel3] mpls te igp metric relative -1
1.1.75  mpls te igp shortcut
mpls te igp shortcut [ isis | ospf ]
undo mpls te igp shortcut
Tunnel接口视图
【缺省级别】
2:系统级
isis:IS-IS协议。
ospf:OSPF协议。
【描述】
mpls te igp shortcut命令用来配置IGP在进行增强的SPF计算时,使用处于up状态的MPLS TE隧道。undo mpls te igp shortcut命令用来取消这一功能。
如果不指定IGP类型,则ospf和isis都支持
缺省情况下,IGP在进行增强的SPF计算时不使用MPLS TE隧道。
mpls te igp shortcut命令与mpls te igp advertise命令互斥。
# 配置如果Tunnel3处于up状态,则OSPF和IS-IS在进行增强的SPF计算时都要使用此隧道。
[Sysname-Tunnel3] mpls te igp shortcut
1.1.76  mpls te link administrative group
mpls te link administrative group value
undo mpls te link administrative group
【缺省级别】
2:系统级
value:链路属性,在选路时将与隧道的affinity位进行比较。可用范围为0x00000000到0xFFFFFFFF,表示32个属性,每个属性占一位,属性值为0或1。
【描述】
mpls te link administrative group命令用来配置链路管理组属性值。undo mpls te link administrative group命令用来恢复缺省配置。
缺省情况下,链路管理组属性的值为0x00000000。
接口属性被全局范围内扩散,从而可以用作隧道源端的路径选择标准。
相关配置可参考命令mpls te affinity property。
# 在接口GigabitEthernet3/1/1上配置用户相关属性标志为0x00000101。
[Sysname-GigabitEthernet3/1/1] mpls te link administrative group 101
1.1.77  mpls te load-share
mpls te load-share value
undo mpls te load-share
Tunnel接口视图
【缺省级别】
2:系统级
value:TE隧道的非平衡负载分担权重,取值范围为1~65535。
【描述】
mpls te load-share命令用来配置TE隧道的非平衡负载分担权重。undo mpls te load-share命令用来恢复缺省情况。
缺省情况下,TE隧道的非平衡负载分担权重为1。
当设备上存在到达同一目的地的多条等价TE隧道时,设备在转发去往该目的地的报文时,依次通过各条TE隧道发送报文,从而实现流量的负载分担。
每条TE隧道上转发的流量比重并不一定完全相同。通过本命令指定TE隧道的非平衡负载分担权重后,设备将根据权重确定TE隧道转发流量的比例。例如,到达某一目的地址存在三条等价TE隧道:Tunnel1、Tunnel2和Tunnel3,这三条TE隧道的非平衡负载分担权重分别为1、1和2,则三条隧道承担的到达此目的地址的流量比重分别为1/4、1/4和1/2。
需要注意的是,如果存在和TE隧道等价的其他类型的转发路径,则其他类型转发路径的权重值为1。
# 配置TE隧道的非平衡负载分担权重为2。
[Sysname-Tunnel0] mpls te load-share 2
[Sysname-Tunnel0] mpls te commit
1.1.78  mpls te loop-detection
undo mpls te loop-detection
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te loop-detection命令用来配置隧道建立时进行环路检测。undo mpls te loop-detection命令用来取消环路检测功能。
缺省情况下,隧道建立时不进行环路检测。
# 配置建立TE隧道时进行环路检测。
[Sysname-Tunnel3] mpls te loop-detection
1.1.79  mpls te max-link-bandwidth
mpls te max-link-bandwidth bandwidth-value
undo mpls te max-link-bandwidth
【缺省级别】
2:系统级
bandwidth-value:链路的最大带宽,取值范围为1~32000000,单位为kbit/s。
【描述】
mpls te max-link-bandwidth命令用来配置用于转发MPLS TE流量的链路最大带宽。undo mpls te max-link-bandwidth命令用来恢复缺省情况。
缺省情况下,链路的最大带宽为0。
本命令配置的链路最大带宽只可用于MPLS TE流量。
缺省情况下,用于转发MPLS TE流量的链路最大带宽为0。
# 配置用于转发MPLS TE流量的链路最大带宽为1158kbit/s。
[Sysname-GigabitEthernet3/1/1] mpls te max-link-bandwidth 1158
1.1.80  mpls te max-reservable-bandwidth
mpls te max-reservable-bandwidth bandwidth-value [ bc1 bc1-bandwidth ]
undo mpls te max-reservable-bandwidth
【缺省级别】
2:系统级
bandwidth-value:链路的最大可预留带宽,即BC0的最大可预留带宽,取值范围为1~32000000,单位为kbit/s。
bc1 bc1-bandwidth:BC1的最大可预留带宽,取值范围为1~32000000,单位为kbit/s。未指定此参数时,BC 1的最大可预留带宽为0。
【描述】
mpls te max-reservable-bandwidth命令用来配置Prestandard DS-TE模式下RDM带宽约束模型BC 0和BC 1的最大可预留带宽。undo mpls te max-reservable-bandwidth命令用来恢复缺省情况。
缺省情况下,最大可预留带宽为0。
·     链路的最大可预留带宽bandwidth-value不能大于链路最大带宽,且BC 1的最大可预留带宽bc1-bandwidth不能大于链路的最大可预留带宽bandwidth-value。
·     本命令配置的链路最大可预留带宽只能用于MPLS TE流量。
# Prestandard模式下配置链路上最多允许MPLS-TE预留1158kbit/s的带宽。BC 1的最大可预留带宽为200kbit/s。
[Sysname-GigabitEthernet3/1/1] mpls te max-reservable-bandwidth 1158 bc1 200
1.1.81  mpls te max-reservable-bandwidth mam
mpls te max-reservable-bandwidth mam bandwidth-value { bc0 bc0-bandwidth | bc1 bc1-bandwidth | bc2 bc2-bandwidth | bc3 bc3-bandwidth } *
undo mpls te max-reservable-bandwidth mam
【缺省级别】
2:系统级
bandwidth-value:链路的最大可预留带宽,取值范围为1~32000000,单位为kbit/s。
bc0 bc0-bandwidth:BC 0的最大可预留带宽,取值范围为1~32000000,单位为kbit/s。如果未指定此参数,则BC 0的最大可预留带宽为0。
bc1 bc1-bandwidth:BC 1的最大可预留带宽,取值范围为1~32000000,单位为kbit/s。如果未指定此参数,则BC 1的最大可预留带宽为0。
bc2 bc2-bandwidth:BC 2的最大可预留带宽,取值范围为1~32000000,单位为kbit/s。如果未指定此参数,则BC 2的最大可预留带宽为0。
bc3 bc3-bandwidth:BC 3的最大可预留带宽,取值范围为1~32000000,单位为kbit/s。如果未指定此参数,则BC 3的最大可预留带宽为0。
【描述】
mpls te max-reservable-bandwidth mam命令用来配置IETF DS-TE模式下MAM带宽约束模型的MPLS TE链路最大可预留带宽及各BC的最大可预留带宽。undo mpls te max-reservable-bandwidth mam命令用来恢复缺省情况。
缺省情况下,最大可预留带宽均为0。
·     链路的最大可预留带宽bandwidth-value不能大于链路最大带宽;所有BC的最大可预留带宽均不能大于链路的最大可预留带宽,即bc0-bandwidth、bc1-bandwidth、bc2-bandwidth和bc3-bandwidth不能大于bandwidth-value。
# IETF模式MAM带宽约束模型下链路上最多允许MPLS-TE预留1158kbit/s的带宽,BC 0的最大可预留带宽为500kbit/s,BC 1的最大可预留带宽为300kbit/s,BC 2的最大可预留带宽为400kbit/s,BC 3的最大可预留带宽为100kbit/s。
[Sysname-GigabitEthernet3/1/1] mpls te max-reservable-bandwidth mam 1158 bc0 500 bc1 300 bc2 400 bc3 100
1.1.82  mpls te max-reservable-bandwidth rdm
mpls te max-reservable-bandwidth rdm bandwidth-value [ bc1 bc1-bandwidth ] [ bc2 bc2-bandwidth ] [ bc3 bc3-bandwidth ]
undo mpls te max-reservable-bandwidth rdm
【缺省级别】
2:系统级
bandwidth-value:链路的最大可预留带宽,即BC 0的最大可预留带宽,取值范围为1~32000000,单位为kbit/s。
【描述】
mpls te max-reservable-bandwidth rdm命令用来配置IETF DS-TE模式RDM带宽约束模型各BC的最大可预留带宽。undo mpls te max-reservable-bandwidth rdm命令用来恢复缺省情况。
缺省情况下,BC 0、BC 1、BC 2和BC 3的最大可预留带宽均为0。
·     BC 0的最大预留带宽bandwidth-value必须大于等于BC 1的最大预留带宽bc1-bandwidth;BC 1的最大预留带宽bc1-bandwidth必须大于等于BC 2的最大预留带宽bc2-bandwidth;BC 2的最大预留带宽bc2-bandwidth必须大于等于BC 3的最大预留带宽bc3-bandwidth。
# 配置IETF模式RDM带宽约束模型下BC 0的最大可预留带宽为500kbit/s,BC 1的最大可预留带宽为400kbit/s,BC 2的最大可预留带宽为300kbit/s,BC 3的最大可预留带宽为100kbit/s。
[Sysname-GigabitEthernet3/1/1] mpls te max-reservable-bandwidth rdm 500 bc1 400 bc2 300 bc3 100
1.1.83  mpls te metric
mpls te metric value
undo mpls te metric
【缺省级别】
2:系统级
value:链路的TE度量值,取值范围是0~4294967295。
【描述】
mpls te metric命令用来配置链路的TE度量。undo mpls te metric命令用来取消配置。
缺省情况下,链路使用其IGP度量作为TE的度量。
相关配置可参考命令mpls te path metric-type。
# 在接口GigabitEthernet3/1/1上配置链路的TE度量为20。
[Sysname-GigabitEthernet3/1/1] mpls te metric 20
1.1.84  mpls te path
mpls te path { dynamic | explicit-path pathname } preference value
undo mpls te path { dynamic | explicit-path pathname }
Tunnel接口视图
【缺省级别】
2:系统级
dynamic:使用动态自动计算的路径。
explicit-path pathname:使用已经存在的显示路径。其中,pathname为MPLS-TE显式路径名称,为1~31个字符的字符串,不区分大小写。
preference value:指定路径的优先级。其中,value取值范围为1~10,数值越小,优先级越高。
【描述】
mpls te path命令用来配置隧道应用的路径及路径的优先级。undo mpls te path命令用来删除配置。
缺省情况下,隧道应用动态自动计算的路径。
·     一条MPLS TE隧道下最多可以配置10条路径。
·     不同路径的优先级不能相同。
·     优先级高的路径,将优先用于CSPF计算。
# 配置Tunnel3可以使用显式路径path1和动态自动计算的路径,优先级分别为1和2。
[Sysname-Tunnel3] mpls te path explicit-path path1 preference 1
[Sysname-Tunnel3] mpls te path dynamic preference 2
1.1.85  mpls te path metric-type
mpls te path metric-type { igp | te }
undo mpls te path metric-type
MPLS视图/Tunnel接口视图
【缺省级别】
2:系统级
igp:使用IGP度量。
te:使用TE度量。
【描述】
在MPLS视图下,mpls te path metric-type命令用来配置未配置度量类型的隧道选路时使用的链路度量类型。
在Tunnel接口视图下,mpls te path metric-type命令用来配置为当前隧道选路时使用的链路度量类型。
undo mpls te path metric-type命令只用在Tunnel接口视图下,用于恢复缺省情况。
对于MPLS视图,缺省情况下,选路时使用链路的TE度量。
对于Tunnel接口视图,缺省情况下,没有指定选路时使用的链路度量类型。
隧道优先使用本隧道接口视图下配置的链路度量类型,如果隧道接口视图下没有配置,则使用MPLS视图下的配置。
相关配置可参考命令mpls te metric。
# 对所有未指定度量类型的TE隧道,配置其在进行路径计算时使用IGP度量。
[Sysname] mpls
[Sysname-mpls] mpls te path metric-type igp
# 配置为Tunnel3隧道选路时使用IGP度量。
[Sysname-Tunnel3] mpls te path metric-type igp
1.1.86  mpls te periodic-tracert
mpls te periodic-tracert [ -a source-ip | -exp exp-value | -h ttl-value  | -m wait-time | -t time-out | -u retry-attempt ] *
undo mpls te periodic-tracert
Tunnel接口视图
【缺省级别】
2:系统级
-a source-ip:指定MPLS Echo Request报文的源地址,缺省使用MPLS LSR-ID作为MPLS Echo Request报文的源地址。
-exp exp-value:指定标签的Exp值。exp-value取值范围为0~7,缺省值为0。
-h ttl-value:指定MPLS Echo Request报文中TTL的最大值(即检测的最大跳数)。ttl-value取值范围为1~255,缺省值为30。
-m wait-time:指定LSP Tracert功能的检测周期。wait-time取值范围为15~120,单位为分钟,缺省值为60分钟。
-t time-out:指定发送出MPLS Echo Request报文后等待响应的超时时间。time-out取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。
-u retry-attempt:指定MPLS Echo Request报文超时重试的次数。retry-attempt取值范围为1~9,单位为次数,缺省值为3次。
【描述】
mpls te periodic-tracert命令用来使能MPLS TE隧道的周期性LSP Tracert功能。undo mpls te periodic-tracert命令用来关闭MPLS TE隧道的周期性LSP Tracert功能。
缺省情况下,未使能MPLS TE隧道的周期性LSP Tracert功能。
MPLS TE隧道的周期性LSP Tracert功能,即周期性地对MPLS TE隧道进行Tracert检测,该功能用来对MPLS TE隧道的错误进行定位,对转发平面和控制平面一致性进行检测,并通过日志记录检测结果。管理员可以通过查看日志信息,了解MPLS TE隧道是否出现故障。
如果同时配置了BFD检测MPLS TE隧道功能和MPLS TE隧道的周期性LSP Tracert功能,则MPLS TE隧道的周期性LSP Tracert检测到转发平面故障或转发平面与控制平面不一致时,会触发删除原有BFD会话,并基于控制平面重新建立BFD会话。
需要注意的是,执行本命令前,必须先通过mpls lspv命令使能LSP检测功能。
# 在隧道接口Tunnel3上使能MPLS TE隧道的周期性LSP Tracert功能。
[Sysname-Tunnel3] mpls te periodic-tracert
1.1.87  mpls te priority
mpls te priority setup-priority [ hold-priority ]
undo mpls te priority
Tunnel接口视图
【缺省级别】
2:系统级
setup-priority:建立优先级,取值范围为0~7。
hold-priority:保持优先级,取值范围为0~7,缺省情况下与建立优先级相同。
【描述】
mpls te priority命令用来配置MPLS TE隧道的建立优先级和保持优先级。undo mpls te priority命令用来恢复缺省配置。
缺省情况下,建立优先级和保持优先级的值都为7。
建立优先级不能高于相应的保持优先级,即,其在数值上应大于或等于保持优先级的值。
# 配置建立优先级和保持优先级都为1。
[Sysname-Tunnel3] mpls te priority 1
1.1.88  mpls te protection switch-mode
mpls te protection switch-mode bidirectional
undo mpls te protection switch-mode
Tunnel接口视图
【缺省级别】
2:系统级
bidirectional:指定双向路径切换方式。
【描述】
mpls te protection switch-mode命令用来配置MPLS TE隧道保护组采用双向路径切换方式。undo mpls te protection switch-mode命令用来恢复缺省情况。
缺省情况下,MPLS TE隧道保护组采用单向路径切换方式。
·     配置此命令前,需要先通过mpls te protection tunnel命令配置MPLS TE隧道保护组功能。
·     双向路径切换方式要求主备隧道都是双向隧道,且两端保护组都采用双向路径切换方式,否则双向切换功能无法正常运行。
# 为MPLS TE双向隧道Tunnel1指定保护隧道为Tunnel102,并配置MPLS TE隧道保护组采用双向路径切换方式。
[Sysname-Tunnel1] mpls te protection tunnel 102 holdoff 20 mode revertive wtr 30
[Sysname-Tunnel1] mpls te protection switch-mode bidirectional
1.1.89  mpls te protection tunnel
mpls te protection tunnel tunnel-id [ holdoff holdoff-time | mode { non-revertive | revertive [ wtr wtr-time ] } | one-plus-one ] *
undo mpls te protection tunnel
Tunnel接口视图
【缺省级别】
2:系统级
tunnel-id:保护通道的隧道ID,用来标识一个Tunnel。
holdoff holdoff-time:指定倒换延迟时间。检测到主Tunnel发生缺陷后,等待Holdoff时间,如果保护Tunnel一直处于无缺陷状态,则数据流将被倒换到保护Tunnel上传输。holdoff-time取值范围是0~20,步长为500毫秒,即最大10秒,缺省值为0。
mode:模式选择,缺省值为可回切模式。
non-revertive:不可回切模式,即主Tunnel恢复无缺陷后,不会将数据流从保护Tunnel切换到主Tunnel。
revertive:可回切模式,即主Tunnel恢复无缺陷后,将数据流从保护Tunnel切换到主Tunnel。
wtr wtr-time:回切时间因子,wtr-time取值范围为0~60,缺省值为24。回切时间=回切时间因子×30秒,回切时间缺省为12分钟。建议您不要将回切时间因子设置为0,否则回切时报文可能会转发不通。
one-plus-one:设置保护组的保护倒换方式为1+1保护倒换。如果未指定本参数,则为1:1保护倒换。
【描述】
mpls te protection tunnel命令用来为主Tunnel创建保护Tunnel,主Tunnel和保护Tunnel构成一个保护组。undo mpls te protection tunnel命令用来删除主Tunnel的保护Tunnel。
缺省情况下,不存在主Tunnel的保护Tunnel。
配置1+1保护倒换方式时,具有如下要求:
·     主备隧道必须都是MPLS TE双向隧道。
·     在隧道的两端必须都配置保护组,且都采用1+1保护倒换方式。
·     隧道两端的保护组必须都采用双向路径切换方式。
·     隧道两端配置的回切模式和回切等待时间必须相同。
上述条件中任何一个不满足,都会导致1+1保护倒换功能无法正常运行。
·     配置此命令前,应该先在Tunnel接口视图下执行tunnel-protocol mpls te命令。
·     在Tunnel接口视图下执行mpls te commit后,创建的保护Tunnel才会生效。
·     由于TE FRR的Bypass隧道不能被VPN等应用选中,因此不推荐为TE FRR的Bypass隧道指定保护Tunnel。
# 指定Tunnel1的保护隧道。
[Sysname-Tunnel1] mpls te commit
1.1.90  mpls te protect-switch
mpls te protect-switch { clear | force | lock | manual }
Tunnel接口视图
【缺省级别】
2:系统级
clear:清除所有已执行的外部倒换命令。
force:强制数据流在备LSP上传输。
lock:将数据流锁定在主LSP上传输。
manual:手动将数据流从主LSP倒换到备LSP上传输。
【描述】
mpls te protect-switch命令用来在指定Tunnel上执行外部倒换命令。
缺省情况下,没有配置外部倒换动作。
外部倒换命令及信令倒换优先级从高到低依次为:
·     清除倒换
·     锁定倒换
·     备份LSP的信令倒换
·     强制倒换
·     主LSP的信令倒换
·     信令清除倒换
·     手工倒换
# 将数据流锁定在主LSP上传输。
[Sysname-Tunnel1] mpls te protect-switch lock
1.1.91  mpls te record-route
mpls te record-route [ label ]
Tunnel接口视图
【缺省级别】
2:系统级
label:使能路由记录特性时包含对标签的记录。当MPLS TE隧道的动态协议类型为CR-LDP时,不支持本参数。
【描述】
mpls te record-route命令用来配置隧道支持路由记录或标签记录。undo mpls te record-route命令用来恢复缺省情况。
缺省情况下,隧道不支持路由记录和标签记录。
# 配置MPLS TE隧道支持路由记录。
[Sysname-Tunnel3] mpls te record-route
1.1.92  mpls te reoptimization (User view)
【缺省级别】
2:系统级
无
【描述】
mpls te reoptimization命令用来立即对所有使能了重优化功能的TE隧道进行重优化。
# 立即对所有使能了重优化功能的TE隧道进行重优化。
<Sysname> mpls te reoptimization
1.1.93  mpls te reoptimization (Tunnel Interface view)
mpls te reoptimization [ frequency seconds ]
undo mpls te reoptimization
Tunnel接口视图
【缺省级别】
2:系统级
frequency seconds:指定重优化频率,取值范围为1~604800,单位为秒,缺省值为3600秒,即1小时。
【描述】
mpls te reoptimization命令用来使能隧道重优化功能。undo mpls te reoptimization命令用来禁止此功能。
缺省情况下,未使能重优化功能。
隧道重优化功能与以下命令互斥:mpls te auto-bandwidth adjustment,mpls te route-pining,mpls te backup和mpls te resv-style ff。
# 使能重优化功能,并配置每隔43200秒(12小时)重新计算路由。
[Sysname-Tunnel3] mpls te reoptimization frequency 43200
1.1.94  mpls te resv-style
mpls te resv-style { ff | se }
undo mpls te resv-style
Tunnel接口视图
【缺省级别】
2:系统级
ff:使用FF(Fixed-Filter,固定过滤器)样式的资源预留。
se:使用SE(Shared-Explicit,共享显式)样式的资源预留。
【描述】
mpls te resv-style命令用来配置隧道的资源预留风格。undo mpls te resv-style命令用来恢复缺省情况。
缺省情况下,资源预留样式为se。
只有RSVP-TE协议才存在FF和SE两种资源预留样式。
# 使用FF资源预留样式建立CR-LSP隧道。
[Sysname-Tunnel3] mpls te resv-style ff
1.1.95  mpls te retry
mpls te retry times
undo mpls te retry
Tunnel接口视图
【缺省级别】
2:系统级
times:重建次数,取值范围为10~4294967295。
【描述】
mpls te retry命令用来配置隧道重建的次数。undo mpls te retry命令用来恢复缺省配置。
缺省情况下,隧道重建的次数为10。
相关配置可参考命令mpls te timer retry。
# 配置隧道重建次数为20次。
[Sysname-Tunnel3] mpls te retry 20
1.1.96  mpls te route-pinning
undo mpls te route-pinning
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te route-pinning命令用来使能路由固定(route pinning)功能。undo mpls te route-pinning命令用来禁止路由固定功能。
缺省情况下,未使能路由固定功能。
mpls te route-pining命令与以下命令互斥:mpls te reoptimization命令和mpls te auto-bandwidth adjustment命令。
# 使能路由固定功能。
[Sysname-Tunnel3] mpls te route-pinning
1.1.97  mpls te signal-protocol
mpls te signal-protocol { crldp | rsvp-te | static }
Tunnel接口视图
【缺省级别】
2:系统级
crldp:使用CR-LDP作为信令协议。
rsvp-te:使用RSVP-TE作为信令协议。
static:使用静态信令协议。
【描述】
mpls te signal-protocol命令用来配置MPLS TE建立隧道使用的信令协议。
缺省情况下,配置MPLS TE建立隧道使用RSVP-TE信令协议。
如果使用RSVP-TE作为MPLS TE隧道的信令协议,那么必须在隧道经过的路径上,使能接口的MPLS TE能力的同时使能接口的RSVP-TE能力。
# 配置MPLS TE建立隧道使用RSVP-TE信令协议。
[Sysname-Tunnel3] mpls te signal-protocol rsvp-te
1.1.98  mpls te tie-breaking
mpls te tie-breaking { least-fill | most-fill | random }
undo mpls te tie-breaking
MPLS视图/Tunnel接口视图
【缺省级别】
2:系统级
least-fill:优先选择带宽使用率(已用带宽/链路最大可预留带宽)最小的路径。
most-fill:优先选择带宽使用率(已用带宽/链路最大可预留带宽)最大的路径。
random:随机选择路径。
【描述】
mpls te tie-breaking命令用来配置CR-LSP仲裁方法。undo mpls te tie-breaking命令用来恢复缺省情况。
对于MPLS视图,缺省情况下,采用随机选择路径方式(random)。
对于Tunnel接口视图,缺省情况下,没有指定CR-LSP仲裁方法。
·     隧道优先使用本隧道接口视图下配置的仲裁方式,如果隧道接口视图下没有配置,将使用MPLS视图下的配置。
·     IETF DS-TE模式只支持随机选择路径方式。
# 配置优选可用带宽最多的路径。
[Sysname] mpls
[Sysname-mpls] mpls te tie-breaking least-fill
# 配置当前隧道接口优选可用带宽最多的路径。
[Sysname-Tunnel3] mpls te tie-breaking least-fill
1.1.99  mpls te timer auto-bandwidth
mpls te timer auto-bandwidth [ seconds ]
undo mpls te timer auto-bandwidth
MPLS视图
【缺省级别】
2:系统级
seconds:为配置自动带宽的隧道进行出口速率采样的时间间隔,取值范围为1~604800,单位为秒,缺省值300秒。建议使用缺省值。
【描述】
mpls te timer auto-bandwidth命令用来使能自动带宽调整,并对为自动带宽调整配置的隧道进行出口速率采样。undo mpls te timer auto-bandwidth命令用来禁止自动带宽调整特性。
缺省情况下,未使能自动带宽调整。
如果需要改变出口速率采样的时间间隔配置,则必须先使用undo mpls te timer auto-bandwidth命令来禁止这一特性,再重新配置。
相关配置可参考命令mpls te auto-bandwidth。
# 配置对MPLS TE隧道的出口速率每隔10分钟(600秒)进行一次采样。
[Sysname] mpls
[Sysname-mpls] mpls te timer auto-bandwidth 600
1.1.100  mpls te timer fast-reroute
mpls te timer fast-reroute [ seconds]
undo mpls te timer fast-reroute
MPLS视图
【缺省级别】
2:系统级
seconds:为决定一条LSP是否应使用新的、更好的备份隧道而进行的扫描的间隔,取值范围为0~604800,单位为秒,缺省值为300秒(5分钟)。配置为0表示禁止使用更好的LSP。
【描述】
mpls te timer fast-reroute命令用来配置当备份带宽可用时,路由器每隔多长时间决定一次是否需要将LSP转移到一条更好的备份隧道。undo mpls te timer fast-reroute命令用来恢复缺省情况。
缺省情况下,扫描间隔为300秒。
# 配置每隔2分钟(120秒),对LSP进行一次扫描,决定是否需要将它们切换到更好的备份隧道。
[Sysname] mpls
[Sysname-mpls] mpls te timer fast-reroute 120
1.1.101  mpls te timer link-management periodic-flooding
mpls te timer link-management periodic-flooding interval
undo mpls te timer link-management periodic-flooding
MPLS视图
【缺省级别】
2:系统级
interval:定时发布带宽更新间隔,取值范围0~3600秒。
【描述】
mpls te timer link-management periodic-flooding命令用来设置带宽定时发布时间。undo mpls te timer link-management periodic-flooding命令用来恢复缺省情况。
缺省情况下,带宽定时发布时间为180秒。
该命令设置接口带宽变化没有超过门限值时定时发布接口带宽的定时器间隔。如果配置0则意味着关闭定期发布功能,其最小生效间隔为30秒。如果在等待超时过程中改变该配置值则以发布时的当前配置值为准,即开始设置为30秒后在等待30秒超时过程中改为3600秒,则以3600秒为准。
# 设置带宽更新定时发布间隔为100秒。
[Sysname] mpls
[Sysname- mpls] mpls te timer link-management periodic-flooding 100
1.1.102  mpls te timer retry
mpls te timer retry second
undo mpls te timer retry
Tunnel接口视图
【缺省级别】
2:系统级
second:隧道重建的时间间隔,取值范围为1~4294967295,单位为秒。
【描述】
mpls te timer retry命令用来配置隧道重建的时间间隔。undo mpls te timer retry命令用来恢复缺省配置。
缺省情况下,隧道重建的时间间隔为2秒。
相关配置可参考命令mpls te retry。
# 配置每隔20秒重建隧道。
[Sysname-Tunnel3] mpls te timer retry 20
1.1.103  mpls te tunnel-id
mpls te tunnel-id tunnel-id
Tunnel接口视图
【缺省级别】
2:系统级
tunnel-id:隧道ID。
【描述】
mpls te tunnel-id命令用来配置隧道ID。
在第一次提交隧道配置mpls te commit前必须完成,否则隧道将无法创建成功。
隧道ID在配置后不能修改,如果需要修隧道ID的值,需要删除Tunnel重新进行配置。
# 配置隧道的ID为100。
[Sysname-Tunnel3] mpls te tunnel-id 100
1.1.104  mpls te vpn-binding
mpls te vpn-binding { acl acl-number | vpn-instance vpn-instance-name }
undo mpls te vpn-binding
Tunnel接口视图
【缺省级别】
2:系统级
acl acl-number:指定TE隧道只转发满足此ACL过滤条件的VPN的流量。acl-number表示ACL编号,取值范围为3000~3999。
vpn-instance vpn-instance-name:TE隧道只转发此VPN的流量。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
只有使用参数vpn-instance-name定义规则的ACL,才能在命令mpls te vpn-binding中生效。
【描述】
mpls te vpn-binding命令用来配置TE隧道转发的流量类型,即只转发匹配指定ACL规则的VPN流量,或只转发属于指定VPN的流量。undo mpls te vpn-binding命令用来恢复缺省情况。
缺省情况下,TE隧道不限制可以转发的流量类型。
选择转发VPN流量的TE隧道时,选择顺序为:指定ACL匹配规则的TE隧道—>指定匹配的VPN实例的TE隧道—>未限制转发流量类型的TE隧道。并且,这三种匹配类型的TE隧道之间不能形成负载分担,例如,不能同时选择指定ACL匹配规则的TE隧道和指定匹配的VPN实例的TE隧道。
# 配置隧道接口只转发实例名为vpn1的VPN的流量。
[Sysname-Tunnel3] mpls te vpn-binding vpn-instance vpn1
# 配置隧道接口只转发满足ACL过滤条件的VPN的流量。
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule 0 permit ip vpn-instance vpn1
[Sysname-acl-adv-3001] quit
[Sysname-Tunnel3] mpls te vpn-binding acl 3001
1.1.105  mpls-te
mpls-te enable
undo mpls-te
OSPF区域视图
【缺省级别】
2:系统级
enable:使能MPLS TE特性。
【描述】
mpls-te命令用来在当前OSPF区域下使能MPLS TE能力。undo mpls-te命令用来取消当前OSPF区域的MPLS TE能力。
缺省情况下,OSPF区域不支持MPLS TE能力。
为了在区域上使能MPLS TE能力,相应的OSPF进程应具备Opaque LSA能力。
相关配置可参考命令opaque-capability。
# 在OSPF区域1使能TE。
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] mpls-te enable
1.1.106  next hop
next hop ip-address [ include [ loose | strict ] | exclude ]
显式路径视图
【缺省级别】
2:系统级
ip-address:显式路径中的下一跳IP地址,点分十进制格式。可以是链路的IP地址,也可以是节点的Router ID。对于严格(strict)方式,只能配置链路IP.对于松散(loose)方式,链路地址则认为指明链路对应的Router。
include:指定在显式路径中需要包含此下一跳IP地址。
loose:指定的下一跳为松散下一跳,即上一跳与本节点可以不是直接相连。
strict:指定的下一跳为严格下一跳,即上一跳与本节点必须直接相连。
exclude:在显式路径中不能包括此IP地址。
【描述】
next hop命令用来在显式路径中指定下一跳IP地址及其属性(显式路径中是否包括插入的节点;插入的节点是松散下一跳,还是严格下一跳)。
·     如果没有指定include和exclude关键字,则缺省为include,即在显式路径中需要包含此下一跳IP地址。
·     如果没有指定loose和strict关键字,则缺省为strict,即上一跳与本节点必须直接相连。
相关配置可参考命令delete hop。
# 配置在MPLS TE显式路径中不包括IP地址10.0.0.125。
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] next hop 10.0.0.125 exclude
1.1.107  opaque-capability
opaque-capability enable
undo opaque-capability
OSPF视图
【缺省级别】
2:系统级
enable:使能Opaque LSA能力。
【描述】
opaque-capability命令用来使能OSPF的Opaque LSA能力。undo opaque-capability命令用来禁止OSPF的Opaque LSA能力。
缺省情况下,未使能OSPF的Opaque LSA能力。
使能OSPF的Opaque LSA能力后,OSPF进程可以生成Opaque LSA,并能从邻居路由器接收Opaque LSA。
# 使能OSPF的Opaque LSA能力。
[Sysname] ospf 100
[Sysname-ospf-100] opaque-capability enable
1.1.108  ping lsp te
ping lsp [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -s packet-size | -t time-out | -v ] * te interface-type interface-number
【缺省级别】
0:访问级
-a source-ip:指定发送的Echo Request报文的源地址。source-ip为源IP地址。
-c count:指定发送Echo Request报文的次数。count为Echo Request报文发送次数,取值范围为1~4294967295,缺省值为5。
-exp exp-value:指定Echo Request报文中的EXP值。exp-value为EXP值,取值范围为0~7,缺省值为0。
-h ttl-value:指定Echo Request报文中的TTL值。ttl-value为TTL值,取值范围为1~255,缺省值为255。
-m wait-time:指定连续发送Echo Request报文的时间间隔。wait-time为发送报文的时间间隔,取值范围为1~10000,单位为毫秒,缺省值为200毫秒。
-r reply-mode:指定接收者对Echo Request报文的应答模式。reply-mode为应答模式,取值范围为1、2和5。1表示不回应,2表示使用UDP报文回应,5表示使用MPLS TE双向隧道的方向CR-LSP回应,缺省值为2。
-s packet-size:指定Echo Request报文的净荷报文长度。packet-size为净荷报文长度,取值范围为65~8100,单位为字节,缺省值为100字节。
-t time-out:指定发送Echo Request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。
-v:指定显示详细的应答信息。
te interface-type interface-number:指定隧道接口类型和接口编号。
【描述】
ping lsp te命令用来检测MPLS TE隧道的可达性。
# 检测隧道接口Tunnel1对应的MPLS TE隧道的可达性。
<Sysname> ping lsp te tunnel 1
LSP Ping FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 : 100  data bytes, press CTRL_C to break
    Reply from 100.1.2.1: bytes=100 Sequence=0 time = 31 ms
    Reply from 100.1.2.1: bytes=100 Sequence=1 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=2 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=3 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=4 time = 62 ms
  --- FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 31/55/62 ms
1.1.109  reset mpls rsvp-te statistics
reset mpls rsvp-te statistics { global | interface [ interface-type interface-number ]
【缺省级别】
1:监控级
global:全局RSVP-TE。
interface interface-type interface-number:指定接口类型及接口号。
【描述】
reset mpls rsvp-te statistics命令用来清除RSVP-TE的统计信息。
·     如果选择参数global,则清除全局RSVP-TE的统计信息;
·     如果选择参数interface,则清除所有接口RSVP-TE的统计信息;
·     如果选择参数interface interface-type interface-number,则清除指定接口RSVP-TE的统计信息。
# 清除全局RSVP-TE的统计信息。
<Sysname> reset mpls rsvp-te statistics global
1.1.110  static-cr-lsp egress
static-cr-lsp egress tunnel-name incoming-interface interface-type interface-number in-label in-label-value [ lsrid ingress-lsr-id tunnel-id tunnel-id ] [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp egress tunnel-name
【缺省级别】
2:系统级
tunnel-name:隧道的名字,为1~15个字符的字符串,区分大小写。
incoming-interface interface-type interface-number:指定入接口的接口类型和接口编号。
in-label in-label-value:指定入标签值,取值范围为0,3,16~1023。
lsrid ingress-lsr-id:入节点的LSR ID,IP地址形式。
tunnel-id tunnel-id:隧道ID,取值范围为1~65534。
bandwidth:指定静态CR-LSP流量所属的服务类型。缺省情况下,静态CR-LSP流量属于CT 0。
ct0:静态CR-LSP流量属于CT 0。
ct1:静态CR-LSP流量属于CT 1。
ct2:静态CR-LSP流量属于CT 2。
ct3:静态CR-LSP流量属于CT 3。
bandwidth-value:静态CR-LSP流量所需的带宽,取值范围为1~32000000,单位为kbit/s。
【描述】
static-cr-lsp egress命令用来为Egress节点配置静态CR-LSP。undo static-cr-lsp egress命令用来删除配置的静态CR-LSP。
·     在Prestandard DS-TE模式下,配置为CT2和CT3是无效的,隧道不会建立。只有在IETF模式下,配置为CT2和CT3才有效。
·     如果需要使用MPLS OAM功能检测隧道,则需要在Egress上配置入节点的LSR ID和隧道ID。
·     采用静态CR-LSP作为组成MPLS TE双向隧道的一条单向CR-LSP时,必须在Egress节点上配置入节点的LSR ID和隧道ID。
相关配置可参考命令mpls te tunnel-id。
# 在出口节点配置静态CR-LSP,名字为tunnel3,入接口是GigabitEthernet3/1/1,入口标签是233。
[Sysname] static-cr-lsp egress tunnel3 incoming-interface GigabitEthernet 3/1/1 in-label 233
1.1.111  static-cr-lsp ingress
static-cr-lsp ingress tunnel-name destination dest-addr { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp ingress tunnel-name
【缺省级别】
2:系统级
tunnel-name:隧道的名字,为1~15个字符的字符串,区分大小写。tunnel-name与interface tunnel命令创建的接口名称,包括大小写,必须保持一致,否则隧道将不能建立。例如建立的隧道接口为“Tunnel2”,此处的隧道名也必须为“Tunnel2”。
destination dest-addr:指定隧道的目的IP地址。
nexthop next-hop-addr:指定下一跳IP地址。
outgoing-interface interface-type interface-number:指定出接口的接口类型和接口编号。out-label out-label-value:指定出标签值,取值范围为0,3,16~1023。
【描述】
static-cr-lsp ingress命令用来为Ingress节点配置静态CR-LSP。undo static-cr-lsp ingress命令用来删除配置的静态CR-LSP。
需要注意的是,在Prestandard DS-TE模式下,配置为CT2和CT3是无效的,隧道不会建立。只有在IETF模式下,配置为CT2和CT3才有效。
本地公网IP地址不能被指定为下一跳。
# 在入口节点配置静态CR-LSP。名字为Tunnel3,目的IP地址为202.25.38.1,目的地址掩码长度为24,下一跳IP地址为202.55.25.33,出口标签为237,流量所属的服务类型为CT0,所需要的带宽为20kbit/s。
[Sysname] static-cr-lsp ingress Tunnel3 destination 202.25.38.1 nexthop 202.55.25.33 out-label 237 bandwidth ct0 20
1.1.112  static-cr-lsp transit
static-cr-lsp transit tunnel-name incoming-interface interface-type interface-number in-label in-label-value { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp transit tunnel-name
【缺省级别】
2:系统级
in-label in-label-value:指定入标签值,取值范围为16~1023。
ct0:静态CR-LSP流量属于CT0。
ct1:静态CR-LSP流量属于CT1。
ct2:静态CR-LSP流量属于CT2。
ct3:静态CR-LSP流量属于CT3。
【描述】
static-cr-lsp transit命令用来为Transit节点配置静态CR-LSP。undo static-cr-lsp transit命令用来删除配置的静态CR-LSP。
本地公网IP地址不能被指定为下一跳。
# 在转发节点配置静态CR-LSP,名字为tunnel3,入接口为GigabitEthernet3/1/1,入口标签为123,出接口为GigabitEthernet4/1/1,出口标签为253,流量所属的服务类型为CT0,所需带宽为20kbit/s。
[Sysname] static-cr-lsp transit tunnel3 incoming-interface GigabitEthernet3/1/1 in-label 123 outgoing-interface GigabitEthernet 4/1/1 out-label 253 bandwidth ct0 20
1.1.113  statistics te
statistics te ingress-lsr-id tunnel-id
undo statistics te ingress-lsr-id tunnel-id
MPLS视图
【缺省级别】
2:系统级
ingress-lsr-id tunnel-id:指定需要统计的RSVP-TE隧道。ingress-lsr-id为入节点的LSR ID,tunnel-id为隧道ID,取值范围为0~65535。
【描述】
statistics te命令用来使能指定RSVP-TE隧道的统计功能。undo statistics te命令用来关闭指定RSVP-TE隧道的统计功能。
缺省情况下,所有RSVP-TE隧道的统计功能均处于关闭状态。
相关配置可参考“MPLS命令参考/MPLS基础”中的命令display mpls statistics lsp。
# 使能入节点LSR ID为2.2.2.2、隧道ID为100的RSVP-TE隧道的统计功能。
[Sysname] mpls
[Sysname-mpls] statistics te 2.2.2.2 100
1.1.114  te-set-subtlv
te-set-subtlv { bw-constraint value | lo-multiplier value | unreserved-bw-sub-pool value } *
undo te-set-subtlv { bw-constraint | lo-multiplier | unreserved-bw-sub-pool } *
IS-IS视图
【缺省级别】
2:系统级
bw-constraint value:指定带宽约束的子TLV值,取值范围为19~254。
lo-multiplier value:指定LOM(Local Overbooking Multipliers,本地过预订倍数)的子TLV值,取值范围为19~254。
unreserved-bw-sub-pool value:指定子池未预订带宽的子TLV值,取值范围为19~254。
【描述】
te-set-subtlv命令用来配置携带DS-TE参数的各种子TLV的TLV类型。由于这些子TLV的类型尚未形成标准,当使用不同厂商提供的设备互联时,用户需要手工配置这些子TLV值。undo te-set-subtlv命令用来恢复缺省配置。
缺省情况下,bw-constraint(带宽约束)的子TLV为252;lo-multiplier(本地过预订倍数)的子TLV为253;unreserved-bw-sub-pool(子池未预订带宽)的子TLV为251。
相关配置可参考命令display isis traffic-eng sub-tlvs。
# 配置IS-IS进程1的子TLV类型值。
[Sysname] isis 1
[Sysname-isis-1] te-set-subtlv bw-constraint 200 lo-multiplier 201 unreserved-bw-sub-pool 202
1.1.115  tracert lsp te
tracert lsp [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode |-t time-out ] * te interface-type interface-number
【缺省级别】
0:访问级
-a source-ip:指定Echo Request报文的源地址。source-ip为源IP地址。
-h ttl-value:指定Echo Request报文中TTL的最大值(即检测的最大跳数)。ttl-value为TTL的最大值,取值范围为1~255,缺省值为30。
-r reply-mode:指定接收者对Echo Request报文的应答模式。reply-mode为应答模式,取值范围为1和2,1表示不回应,2表示使用UDP报文回应,缺省值为2。
-t time-out:指定发送出Echo Request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。
【描述】
tracert lsp te命令用来对MPLS TE隧道的错误进行定位。
# 对隧道接口Tunnel1对应的MPLS TE隧道的错误进行定位。
<Sysname> tracert lsp te tunnel 1
LSP Trace Route FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 , press CTRL_C to break.
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   10.4.5.1/[1025]
  1     10.4.5.1           1       Transit   100.3.4.1/[1024]
  2     100.3.4.1          63      Transit   100.1.2.1/[3]
  3     100.1.2.1          129     Egress
表1-41 tracert lsp te命令显示信息描述表
TTL
跳数
Replier
应答的LSR地址
Time
接收到应答的时间,单位为毫秒
LSR的类型,取值包括:
·     Ingress:入节点
·     Transit:中间节点
·     Egress:出节点
Downstream
下游LSR地址及出标签值
1.1.116  traffic-eng
traffic-eng [ level-1 | level-1-2 | level-2 ]
undo traffic-eng [ level-1 | level-1-2 | level-2 ]
IS-IS视图
【缺省级别】
2:系统级
level-1:配置Level-1的IS-IS TE。
level-1-2:配置Level-1和Level-2的IS-IS TE。
level-2:配置Level-2的IS-IS TE。
如果命令中不指定Level,则对Level-1-2有效。
【描述】
traffic-eng命令用来使能IS-IS TE功能。undo traffic-eng命令用来恢复缺省配置。
如果不指定中间系统IS的级别,将对Level-1-2有效。
缺省情况下,未使能IS-IS TE功能。
为了在IS-IS进程使用TE特性,必须将IS-IS报文的cost类型配置为wide、compatible或wide-compatible,使用的命令是IS-IS视图下的cost-style,这条命令的详细介绍请参见“三层技术-IP路由命令参考”中的“IS-IS”。
# 在IS-IS进程1的Level-2上使能TE功能。
[Sysname] isis 1
[Sysname-isis-1] cost-style compatible
[Sysname-isis-1] traffic-eng level-2
