06-IP组播命令参考
01-IGMP Snooping命令
本章节下载: 01-IGMP Snooping命令  (252.48 KB)
01-IGMP Snooping命令
1 IGMP Snooping
1.1 IGMP Snooping配置命令
1.1.1 display igmp-snooping
1.1.2 display igmp-snooping group
1.1.3 display igmp-snooping router-port
1.1.4 display igmp-snooping static-group
1.1.5 display igmp-snooping static-router-port
1.1.6 display igmp-snooping statistics
1.1.7 display l2-multicast ip
1.1.8 display l2-multicast ip forwarding
1.1.9 display l2-multicast mac
1.1.10 display l2-multicast mac forwarding
1.1.11 drop-unknown (IGMP-Snooping view)
1.1.12 enable (IGMP-Snooping view)
1.1.13 entry-limit (IGMP-Snooping view)
1.1.14 fast-leave (IGMP-Snooping view)
1.1.15 group-policy (IGMP-Snooping view)
1.1.16 host-aging-time (IGMP-Snooping view)
1.1.17 igmp-snooping
1.1.18 igmp-snooping drop-unknown
1.1.19 igmp-snooping enable
1.1.20 igmp-snooping fast-leave
1.1.21 igmp-snooping general-query source-ip
1.1.22 igmp-snooping group-limit
1.1.23 igmp-snooping group-policy
1.1.24 igmp-snooping host-aging-time
1.1.25 igmp-snooping host-join
1.1.26 igmp-snooping last-member-query-interval
1.1.27 igmp-snooping leave source-ip
1.1.28 igmp-snooping max-response-time
1.1.29 igmp-snooping overflow-replace
1.1.30 igmp-snooping querier
1.1.31 igmp-snooping query-interval
1.1.32 igmp-snooping report source-ip
1.1.33 igmp-snooping router-aging-time
1.1.34 igmp-snooping source-deny
1.1.35 igmp-snooping special-query source-ip
1.1.36 igmp-snooping static-group
1.1.37 igmp-snooping static-router-port
1.1.38 igmp-snooping version
1.1.39 last-member-query-interval (IGMP-Snooping view)
1.1.40 max-response-time (IGMP-Snooping view)
1.1.41 overflow-replace (IGMP-Snooping view)
1.1.42 report-aggregation (IGMP-Snooping view)
1.1.43 reset igmp-snooping group
1.1.44 reset igmp-snooping router-port
1.1.45 reset igmp-snooping statistics
1.1.46 router-aging-time (IGMP-Snooping view)
1.1.47 source-deny (IGMP-Snooping view)
1.1.48 version (IGMP-Snooping view)
1 IGMP Snooping
display igmp-snooping命令用来显示IGMP Snooping的状态信息。
display igmp-snooping [ global | vlan vlan-id ]
global:显示IGMP Snooping的全局状态信息。
vlan vlan-id:显示IGMP Snooping在指定VLAN内的状态信息。vlan-id为VLAN的编号,取值范围为1~4094。
如果未指定任何可选参数,将显示IGMP Snooping在全局和所有VLAN内的状态信息。
# 显示IGMP Snooping在全局和所有VLAN内的状态信息。
<Sysname> display igmp-snooping
IGMP snooping information: Global
 IGMP snooping: Enabled
 Drop-unknown: Disabled
 Host-aging-time: 260s
 Router-aging-time: 260s
 Max-response-time: 10s
 Last-member-query-interval: 1s
 Report-aggregation: Enabled
IGMP snooping information: VLAN 1
 Version: 2
IGMP snooping information: VLAN 10
 Drop-unknown: Enabled
 Version: 3
表1-1 display igmp-snooping命令显示信息描述表
IGMP Snooping的状态信息
IGMP snooping
IGMP Snooping的使能状态:
·     Enabled:表示已使能
·     Disabled:表示未使能
Drop-unknown
丢弃未知组播数据报文功能的使能状态:
·     Enabled:表示已使能
·     Disabled:表示未使能
Version
IGMP Snooping的版本
Host-aging-time
动态成员端口的老化时间
Router-aging-time
动态路由器端口老化时间
Max-response-time
IGMP普遍组查询的最大响应时间
IGMP特定组查询报文的发送间隔
Report-aggregation
IGMP成员关系报告报文抑制功能的使能状态:
·     Enabled:表示已使能
·     Disabled:表示未使能
display igmp-snooping group命令用来显示动态组播组的IGMP Snooping转发表项信息。
独立运行模式:
display igmp-snooping group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
IRF模式:
display igmp-snooping group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
group-address:显示指定组播组的信息,取值范围为224.0.1.0~239.255.255.255。如果未指定本参数,将显示所有组播组的信息。
source-address:显示指定组播源的信息。如果未指定本参数,将显示所有组播源的信息。
vlan vlan-id:显示指定VLAN内的信息。vlan-id为VLAN的编号,取值范围为1~4094。如果未指定本参数,将显示所有VLAN内的信息。
verbose:显示详细信息,如果未指定本参数,将显示简要信息。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板或PEX设备上的信息,chassis-number表示设备在IRF中的成员编号或IRF3中PEX设备的虚拟框号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上的信息。(IRF模式)
# 显示VLAN 2内动态组播组的IGMP Snooping转发表项详细信息。
<Sysname> display igmp-snooping group vlan 2 verbose
Total 1 entries.
VLAN 2: Total 1 entries.
  (0.0.0.0, 224.1.1.1)
    Attribute: local port
    FSM information: normal
    Host slots (0 in total):
    Host ports (1 in total):
      XGE1/0/2         (00:03:23)
表1-2 display igmp-snooping group命令显示信息描述表
Total 1 entries
表项总数
VLAN 2内的表项总数
(S,G)表项,0.0.0.0表示所有组播源
Attribute
表项属性,包括:
·     global port:表示表项中存在全局口
·     local port:表示表项中存在本设备的端口
·     slot:表示表项中存在其它设备的端口
FSM information
表项状态机,包括:
·     delete:表示所有成员属性均已删除
·     dummy:表示新创建的临时表项
·     no info:表示没有表项存在
·     normal:表示主控板通知创建的正式表项
·     独立运行模式:除当前单板外,其它所有有成员端口的单板总数,以及各单板的槽位号
·     IRF模式:除当前单板外,其它所有有成员端口的单板总数,以及各单板所在成员设备的编号和单板的槽位号
成员端口及总数
(00:03:23)
成员端口的老化剩余时间。需要注意的是,本字段对于全局口将无条件显示,而对于非全局口:
·     独立运行模式上,若该口属于主控板,会显示;否则须指定其所在单板的槽位号才会显示
·     IRF模式上,若该口属于主控板,会显示;否则须指定其所在成员设备的编号和单板的槽位号才会显示
·     reset igmp-snooping group
display igmp-snooping router-port命令用来显示动态路由器端口的信息。
独立运行模式:
display igmp-snooping router-port [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display igmp-snooping router-port [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
# 显示VLAN 2内动态路由器端口的信息。
<Sysname> display igmp-snooping router-port vlan 2
VLAN 2:
  Router slots (0 in total):
  Router ports (2 in total):
    XGE1/0/1                 (00:01:30)
    XGE1/0/2                 (00:00:23)
表1-3 display igmp-snooping router-port命令显示信息描述表
VLAN 2
VLAN的编号
·     独立运行模式:除当前单板外,其它所有有动态路由器端口的单板总数,以及各单板的槽位号
·     IRF模式:除当前单板外,其它所有有动态路由器端口的单板总数,以及各单板所在成员设备的编号和单板的槽位号
动态路由器端口及总数
(00:01:30)
动态路由器端口的老化剩余时间。需要注意的是,本字段对于全局口将无条件显示,而对于非全局口:
·     reset igmp-snooping router-port
display igmp-snooping static-group命令用来显示静态组播组的IGMP Snooping转发表项信息。
独立运行模式:
display igmp-snooping static-group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
IRF模式:
display igmp-snooping static-group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
verbose:显示详细信息。如果未指定本参数,将显示简要信息。
# 显示VLAN 2内静态组播组的IGMP Snooping转发表项详细信息。
<Sysname> display igmp-snooping static-group vlan 2 verbose
Total 1 entries.
      XGE1/0/2
表1-4 display igmp-snooping static-group命令显示信息描述表
Total 1 entries
表项总数量
VLAN 2内的表项总数
Attribute
表项属性,包括:
FSM information
表项状态机,包括:
·     dummy:表示新创建的临时表项
·     no info:表示没有表项存在
成员端口及总数
display igmp-snooping static-router-port命令用来显示静态路由器端口的信息。
独立运行模式:
display igmp-snooping static-router-port [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display igmp-snooping static-router-port [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
# 显示VLAN 2内静态路由器端口的信息。
<Sysname> display igmp-snooping static-router-port vlan 2
VLAN 2:
    XGE1/0/1
    XGE1/0/2
表1-5 display igmp-snooping static-router-port命令显示信息描述表
VLAN 2
VLAN的编号
静态路由器端口及总数
display igmp-snooping statistics命令用来显示IGMP Snooping监听到的IGMP报文和PIMv2 hello报文统计信息。
# 显示IGMP Snooping监听到的IGMP报文和PIMv2 hello报文统计信息。
<Sysname> display igmp-snooping statistics
Received IGMP general queries:  0
Received IGMPv1 reports:  0
Received IGMPv2 reports:  19
Received IGMP leaves:  0
Received IGMPv2 specific queries:  0
Sent     IGMPv2 specific queries:  0
Received IGMPv3 reports:  1
Received IGMPv3 reports with right and wrong records:  0
Received IGMPv3 specific queries:  0
Received IGMPv3 specific sg queries:  0
Sent     IGMPv3 specific queries:  0
Sent     IGMPv3 specific sg queries:  0
Received PIMv2 hello:  0
Received error IGMP messages:  19
表1-6 display igmp-snooping statistics命令显示信息描述表
general queries
IGMP普遍组查询报文的数量
specific queries
IGMP特定组查询报文的数量
reports
IGMP成员关系报告报文的数量
leaves
IGMP离开组报文的数量
包含错误和正确纪录的IGMP成员关系报告报文数量
specific sg queries
IGMP特定源组查询报文的数量
PIMv2 hello
PIMv2 hello报文的数量
error IGMP messages
错误IGMP报文的数量
·     reset igmp-snooping statistics
display l2-multicast ip命令用来显示二层组播的IP组播组信息。
独立运行模式:
display l2-multicast ip [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display l2-multicast ip [ group group-address | source source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
group group-address:显示指定组播组的信息。如果未指定本参数,将显示所有组播组的信息。
source source-address:显示指定组播源的信息。如果未指定本参数,将显示所有组播源的信息。
# 显示VLAN 2内二层组播的IP组播组信息。
<Sysname> display l2-multicast ip vlan 2
Total 1 entries.
VLAN 2: Total 1 IP entries.
    Attribute: static, success
      XGE1/0/1                  (S, SUC)
表1-7 display l2-multicast ip命令显示信息描述表
Total 1 entries
表项总数
VLAN 2内的表项总数
Attribute
表项属性,包括:
·     dynamic:表示由动态协议创建的表项
·     static:表示由静态协议创建的表项
·     pim:表示由PIM协议创建的表项
·     kernel:表示从内核中获取的表项
·     success:表示处理成功
·     fail:表示处理失败
成员端口及总数
(S, SUC)
端口属性,包括:
·     D:表示动态端口
·     S:表示静态端口
·     P:表示PIM端口
·     K:表示从内核中获取的端口
·     R:表示从(*,*)表项扩展的端口
·     W:表示从(*,G)表项扩展的端口
·     SUC:表示处理成功
·     F:表示处理失败
·     BC:表示网络发生拓扑变化后TRILL路径上的端口
display l2-multicast ip forwarding命令用来显示二层组播的IP转发表信息。
独立运行模式:
display l2-multicast ip forwarding [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display l2-multicast ip forwarding [ group group-address | source source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
# 显示VLAN 2内二层组播的IP转发表信息。
<Sysname> display l2-multicast ip forwarding vlan 2
Total 1 entries.
    Host ports (3 in total):
      XGE1/0/1
      XGE1/0/2
      XGE1/0/3
表1-8 display l2-multicast ip forwarding命令显示信息描述表
Total 1 entries
表项总数
VLAN 2内的表项总数
成员端口及总数
display l2-multicast mac命令用来显示二层组播的MAC组播组信息。
独立运行模式:
display l2-multicast mac [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display l2-multicast mac [ mac-address ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
mac-address:显示指定MAC组播组的信息。如果未指定本参数,将显示所有MAC组播组的信息。
# 显示VLAN 2内二层组播的MAC组播组信息。
<Sysname> display l2-multicast mac vlan 2
Total 1 MAC entries.
VLAN 2: Total 1 MAC entries.
  MAC group address: 0100-5e01-0101
    Attribute: success
      XGE1/0/1
表1-9 display l2-multicast mac命令显示信息描述表
Total 1 MAC entries
表项总数
VLAN 2内的表项总数
MAC group address
MAC组播组的地址
Attribute
表项属性,包括:
·     success:表示处理成功
·     fail:表示处理失败
成员端口的总数和列表
display l2-multicast mac forwarding命令用来显示二层组播的MAC转发表信息。
独立运行模式:
display l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
# 显示VLAN 2内二层组播的MAC转发表信息。
<Sysname> display l2-multicast mac forwarding vlan 2
      XGE1/0/1
      XGE1/0/2
      XGE1/0/3
表1-10 display l2-multicast mac forwarding命令显示信息描述表
Total 1 MAC entries
表项总数
VLAN 2内的表项总数
MAC group address
MAC组播组的地址
成员端口的总数和列表
drop-unknown命令用来全局使能丢弃未知组播数据报文功能。
undo drop-unknown命令用来全局关闭丢弃未知组播数据报文功能。
drop-unknown
undo drop-unknown
丢弃未知组播数据报文功能处于关闭状态,即对未知组播数据报文进行广播。
IGMP-Snooping视图
本命令与igmp-snooping drop-unknown命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有VLAN都有效, VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
# 全局使能丢弃未知组播数据报文功能。
[Sysname] igmp-snooping
[Sysname-igmp-snooping] drop-unknown
·     igmp-snooping drop-unknown
enable命令用来使能指定VLAN内的IGMP Snooping。
undo enable命令用来关闭指定VLAN内的IGMP Snooping。
enable vlan vlan-list
undo enable vlan vlan-list
VLAN内的IGMP Snooping处于关闭状态。
IGMP-Snooping视图
vlan vlan-list:表示对指定VLAN进行配置。vlan-list为VLAN列表,表示一或多个VLAN,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
·     在使能VLAN内的IGMP Snooping之前,必须先全局使能IGMP Snooping。
·     对于基于VLAN的配置,本命令与igmp-snooping enable命令的功能相同,只是作用范围不同:IGMP-Snooping视图下可以对指定VLAN进行配置,VLAN视图下只能对当前VLAN进行配置,二者的配置优先级相同。
# 全局使能IGMP Snooping,并使能VLAN 2~10内的IGMP Snooping。
[Sysname-igmp-snooping] enable vlan 2 to 10
·     igmp-snooping
·     igmp-snooping enable
entry-limit命令用来配置IGMP Snooping转发表项(包括动态表项和静态表项)的全局最大数量。
undo entry-limit命令用来恢复缺省情况。
entry-limit limit
undo entry-limit
IGMP Snooping转发表项的全局最大数量为4294967295。
IGMP-Snooping视图
limit:表示IGMP Snooping转发表项的全局最大数量,取值范围为0~4294967295。
# 配置IGMP Snooping转发表项的全局最大数量为512个。
[Sysname-igmp-snooping] entry-limit 512
fast-leave命令用来全局使能端口快速离开功能。
undo fast-leave命令用来全局关闭端口快速离开功能。
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
端口快速离开功能处于关闭状态。
IGMP-Snooping视图
vlan vlan-list:表示对指定VLAN进行配置。vlan-list为VLAN列表,表示一或多个VLAN,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果未指定本参数,则表示对所有VLAN进行配置。
·     端口快速离开是指当端口收到主机发来的离开指定组播组的IGMP离开组报文时,直接将该端口从相应转发表项的出端口列表中删除。
·     本命令与igmp-snooping fast-leave命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
# 全局使能VLAN 2内的端口快速离开功能。
[Sysname-igmp-snooping] fast-leave vlan 2
·     igmp-snooping fast-leave
group-policy命令用来全局配置组播组过滤器,以限定主机所能加入的组播组。
undo group-policy命令用来删除全局组播组过滤器。
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
没有配置组播组过滤器,即主机可以加入任意合法的组播组。
IGMP-Snooping视图
acl-number:指定IPv4基本或高级ACL的编号,取值范围为2000~3999。主机只能加入该ACL规则所允许的组播组。当指定的ACL不存在或ACL中未配置有效规则,将过滤掉所有组播组。
·     对于IPv4基本ACL,该ACL规则中的source参数用来指定IGMP报文中的组播组地址范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。
·     对于IPv4高级ACL,该ACL规则中的source参数用来指定IGMP报文中的组播源地址(对于IGMPv1/v2报文和未携带组播源地址的IS_EX/TO_EX类型的IGMPv3报文,视其组播源地址为0.0.0.0)范围,destination参数用来指定组播组地址范围,若指定了vpn-instance参数则此规则不生效,而除fragment和time-range以外的其它可选参数都将被忽略。
·     可以为端口在不同的VLAN内配置不同的ACL规则,但在相同VLAN内所配置的新规则会取代旧规则。
·     本命令只对动态组播组有效,对静态组播组无效。
·     本命令与igmp-snooping group-policy命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
#全局配置组播组过滤器,以限定VLAN 2内的主机只能加入组播组225.1.1.1。
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname-igmp-snooping] group-policy 2000 vlan 2
·     igmp-snooping group-policy
host-aging-time命令用来全局配置动态成员端口的老化时间。
undo host-aging-time命令用来恢复缺省情况。
host-aging-time interval
动态成员端口的老化时间为260秒。
IGMP-Snooping视图
interval:表示动态成员端口的老化时间,取值范围为1~8097894,单位为秒。
本命令与igmp-snooping host-aging-time命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有VLAN都有效,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
为避免误删组播组成员,请确保配置动态成员端口的老化时间大于IGMP普遍组查询报文的发送间隔与IGMP普遍组查询的最大响应时间之和。建议配置动态成员端口的老化时间为IGMP普遍组查询报文的发送间隔的2倍与IGMP普遍组查询的最大响应时间之和。
# 全局配置动态成员端口的老化时间为300秒。
[Sysname-igmp-snooping] host-aging-time 300
·     igmp-snooping host-aging-time
igmp-snooping命令用来全局使能IGMP Snooping,并进入IGMP-Snooping视图。
undo igmp-snooping命令用来全局关闭IGMP Snooping。
igmp-snooping
undo igmp-snooping
IGMP Snooping处于全局关闭状态。
# 全局使能IGMP Snooping,并进入IGMP-Snooping视图。
·     enable (IGMP-Snooping view)
igmp-snooping drop-unknown命令用来在VLAN内使能丢弃未知组播数据报文功能。
undo igmp-snooping drop-unknown命令用来在VLAN内关闭丢弃未知组播数据报文功能。
VLAN视图
·     在配置本命令之前,必须先在VLAN内使能IGMP Snooping。
·     本命令与drop-unknown命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有VLAN都有效,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
# 在VLAN 2内使能IGMP Snooping,并使能丢弃未知组播数据报文功能。
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] igmp-snooping drop-unknown
·     drop-unknown (IGMP-Snooping view)
igmp-snooping enable命令用来在VLAN内使能IGMP Snooping。
undo igmp-snooping enable命令用来在VLAN内关闭IGMP Snooping。
VLAN视图
·     在VLAN内使能IGMP Snooping之前,必须先全局使能IGMP Snooping。
·     对于基于VLAN的配置,本命令与enable命令的功能相同,只是作用范围不同:IGMP-Snooping视图下可以对指定VLAN进行配置,VLAN视图下只能对当前VLAN进行配置,二者的配置优先级相同。
# 全局使能IGMP Snooping,并在VLAN 2内使能IGMP Snooping。
[Sysname] vlan 2
·     igmp-snooping
igmp-snooping fast-leave命令用来在端口上使能端口快速离开功能。
undo igmp-snooping fast-leave命令用来在端口上关闭端口快速离开功能。
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
端口快速离开功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
·     本命令与fast-leave命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
# 将VLAN 2内的端口Ten-GigabitEthernet1/0/1在VLAN 2内使能端口快速离开功能。
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping fast-leave vlan 2
·     fast-leave (IGMP-Snooping view)
igmp-snooping general-query source-ip命令用来配置IGMP普遍组查询报文的源IP地址。
undo igmp-snooping general-query source-ip命令用来恢复缺省情况。
igmp-snooping general-query source-ip ip-address
IGMP普遍组查询报文的源IP地址为当前VLAN接口的IP地址;若当前VLAN接口没有IP地址,则采用0.0.0.0。
VLAN视图
ip-address:表示IGMP普遍组查询报文的源IP地址。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP普遍组查询报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip 10.1.1.1
igmp-snooping group-limit命令用来配置端口加入的组播组最大数量。
undo igmp-snooping group-limit命令用来恢复缺省情况。
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
端口加入的组播组最大数量为4294967295。
二层以太网接口视图/二层聚合接口视图
limit:表示端口加入的组播组最大数量,取值范围为0~4294967295。
# 配置端口Ten-GigabitEthernet1/0/1在VLAN 2内加入的组播组最大数量为10个。
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping group-limit 10 vlan 2
igmp-snooping group-policy命令用来在端口上配置组播组过滤器,以限定主机所能加入的组播组。
undo igmp-snooping group-policy命令用来删除端口上的组播组过滤器。
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
二层以太网接口视图/二层聚合接口视图
·     本命令与group-policy命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
# 在端口Ten-GigabitEthernet1/0/1上配置组播组过滤器,以限定VLAN 2内的主机只能加入组播组225.1.1.1。
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping group-policy 2000 vlan 2
·     group-policy (IGMP-Snooping view)
igmp-snooping host-aging-time命令用来在VLAN内配置动态成员端口的老化时间。
undo igmp-snooping host-aging-time命令用来恢复缺省情况。
igmp-snooping host-aging-time interval
动态成员端口的老化时间为260秒。
VLAN视图
·     本命令与host-aging-time命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有VLAN都有效,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
·     为避免误删组播组成员,请确保配置动态成员端口的老化时间大于IGMP普遍组查询报文的发送间隔与IGMP普遍组查询的最大响应时间之和。建议配置动态成员端口的老化时间为IGMP普遍组查询报文的发送间隔的2倍与IGMP普遍组查询的最大响应时间之和。
# 在VLAN 2内使能IGMP Snooping,并配置动态成员端口的老化时间为300秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
·     host-aging-time (IGMP-Snooping view)
igmp-snooping host-join命令用来配置模拟主机加入组播组或组播源组。模拟主机加入就是将二层设备的端口配置为组播组的成员。
undo igmp-snooping host-join命令用来删除模拟主机加入的配置。
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join { group-address [ source-ip source-address ] vlan vlan-id | all }
没有配置模拟主机加入组播组或组播源组。
二层以太网接口视图/二层聚合接口视图
group-address:表示模拟主机要加入的组播组的地址,取值范围为224.0.1.0~239.255.255.255。
source-ip source-address:表示模拟主机要加入的组播源的地址。如果指定了本参数,表示加入组播源组;如果未指定本参数,则表示加入组播组。配置有本参数的模拟主机,只在IGMP Snooping版本3下生效。
vlan vlan-id:表示对指定VLAN进行配置。vlan-id为VLAN的编号,取值范围为1~4094。
all:表示对所有组播组和组播源组进行配置。
·     与静态成员端口不同,配置了模拟主机加入的端口将作为动态成员端口参与动态成员端口的老化过程。
·     模拟主机所采用的IGMP版本与IGMP Snooping的版本一致。
# 在端口Ten-GigabitEthernet1/0/1上配置模拟主机加入VLAN 2内的组播源组(1.1.1.1,232.1.1.1)。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping host-join 232.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping last-member-query-interval命令用来在VLAN内配置IGMP特定组查询报文的发送间隔。
undo igmp-snooping last-member-query-interval命令用来恢复缺省情况。
igmp-snooping last-member-query-interval interval
IGMP特定组查询报文的发送间隔为1秒。
VLAN视图
interval:表示IGMP特定组查询报文的发送间隔,取值范围为1~25,单位为秒。
·     本命令与last-member-query-interval命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有VLAN都有效,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP特定组查询报文的发送间隔为3秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
·     last-member-query-interval (IGMP-Snooping view)
igmp-snooping leave source-ip命令用来配置IGMP离开组报文的源IP地址。
undo igmp-snooping leave source-ip命令用来恢复缺省情况。
igmp-snooping leave source-ip ip-address
IGMP离开组报文的源IP地址为当前VLAN接口的IP地址;若当前VLAN接口没有IP地址,则采用0.0.0.0。
VLAN视图
ip-address:表示IGMP离开组报文的源IP地址。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP离开组报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping leave source-ip 10.1.1.1
igmp-snooping max-response-time命令用来在VLAN内配置IGMP普遍组查询的最大响应时间。
undo igmp-snooping max-response-time命令用来恢复缺省情况。
igmp-snooping max-response-time interval
IGMP普遍组查询的最大响应时间为10秒。
VLAN视图
interval:表示IGMP普遍组查询的最大响应时间,取值范围为1~3174,单位为秒。
·     VLAN上的配置只对当前VLAN有效,但配置优先级高于全局配置。
·     本命令与max-response-time命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有VLAN都有效,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP普遍组查询的最大响应时间为5秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
·     max-response-time (IGMP-Snooping view)
igmp-snooping overflow-replace命令用来在端口上使能组播组替换功能。
undo igmp-snooping overflow-replace命令用来在端口上关闭组播组替换功能。
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
组播组替换功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
·     本命令与overflow-replace命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
# 将端口Ten-GigabitEthernet1/0/1在VLAN 2内使能组播组替换功能。
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping overflow-replace vlan 2
·     overflow-replace (IGMP-Snooping view)
igmp-snooping querier命令用来使能IGMP Snooping查询器。
undo igmp-snooping querier命令用来关闭IGMP Snooping查询器。
IGMP Snooping查询器处于关闭状态。
VLAN视图
·     如果在组播VLAN的子VLAN内配置了本命令,只有当该子VLAN被从组播VLAN中删除后,IGMP Snooping查询器才会生效。
# 在VLAN 2内使能IGMP Snooping,并使能IGMP Snooping查询器。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
·     subvlan (multicast-VLAN view)(IP组播命令参考/组播VLAN)
igmp-snooping query-interval命令用来在VLAN内配置IGMP普遍组查询报文的发送间隔。
undo igmp-snooping query-interval命令用来恢复缺省情况。
igmp-snooping query-interval interval
IGMP普遍组查询报文的发送间隔为125秒。
VLAN视图
interval:表示IGMP普遍组查询报文的发送间隔,取值范围为2~31744,单位为秒。
·     为避免误删组播组成员,请确保IGMP普遍组查询报文的发送间隔大于IGMP普遍组查询的最大响应时间,否则配置虽能生效但系统会给出提示。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP普遍组查询报文的发送间隔为20秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
·     igmp-snooping max-response-time
·     igmp-snooping querier
·     max-response-time
igmp-snooping report source-ip命令用来配置IGMP成员关系报告报文的源IP地址。
undo igmp-snooping report source-ip命令用来恢复缺省情况。
igmp-snooping report source-ip ip-address
IGMP成员关系报告报文的源IP地址为当前VLAN接口的IP地址;若当前VLAN接口没有IP地址,则采用0.0.0.0。
VLAN视图
ip-address:表示IGMP成员关系报告报文的源IP地址。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP成员关系报告报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping report source-ip 10.1.1.1
igmp-snooping router-aging-time命令用来在VLAN内配置动态路由器端口的老化时间。
undo igmp-snooping router-aging-time命令用来恢复缺省情况。
igmp-snooping router-aging-time interval
动态路由器端口的老化时间为260秒。
VLAN视图
interval:表示动态路由器端口的老化时间,取值范围为1~8097894,单位为秒。
·     本命令与router-aging-time命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有VLAN都有效,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
# 在VLAN 2内使能IGMP Snooping,并配置动态路由器端口的老化时间为100秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
·     router-aging-time (IGMP-Snooping view)
igmp-snooping source-deny命令用来使能当前端口的组播数据报文源端口过滤功能。
undo igmp-snooping source-deny命令用来关闭当前端口的组播数据报文源端口过滤功能。
组播数据报文源端口过滤功能处于关闭状态。
二层以太网接口视图
本命令与source-deny命令的功能相同,只是作用范围不同:IGMP-Snooping视图下可以对指定端口进行配置,端口视图下只能对当前端口进行配置,二者的配置优先级相同。
# 在端口Ten-GigabitEthernet1/0/1上使能组播数据报文源端口过滤功能。
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping source-deny
·     source-deny (IGMP-Snooping view)
igmp-snooping special-query source-ip命令用来配置IGMP特定组查询报文的源IP地址。
undo igmp-snooping special-query source-ip命令用来恢复缺省情况。
igmp-snooping special-query source-ip ip-address
如果收到过IGMP普遍组查询报文,则以其源IP地址作为IGMP特定组查询报文的源IP地址;否则,采用当前VLAN接口的IP地址;若当前VLAN接口没有IP地址,则采用0.0.0.0。
VLAN视图
ip-address:表示IGMP特定组查询报文的源IP地址。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP特定组查询报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip 10.1.1.1
igmp-snooping static-group命令用来配置静态成员端口,即配置端口静态加入组播组或组播源组。
undo igmp-snooping static-group命令用来删除静态成员端口的配置。
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group { group-address [ source-ip source-address ] vlan vlan-id | all }
端口不是静态成员端口。
二层以太网接口视图/二层聚合接口视图
group-address:表示静态加入的组播组地址,取值范围为224.0.1.0~239.255.255.255。
source-ip source-address:表示静态加入的组播源地址。
all:表示对所有VLAN进行配置。如果指定了本参数,表示加入组播源组;如果未指定本参数,则表示加入组播组。配置有本参数的静态成员端口,只在IGMP Snooping版本3下生效。
# 将端口Ten-GigabitEthernet1/0/1配置为组播源组(1.1.1.1,225.0.0.1)在VLAN 2内的静态成员端口。
[Sysname] vlan 2
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping static-group 225.0.0.1 source-ip 1.1.1.1 vlan 2
igmp-snooping static-router-port命令用来配置静态路由器端口。
undo igmp-snooping static-router-port命令用来删除静态路由器端口的配置。
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port { all | vlan vlan-id }
端口不是静态路由器端口。
二层以太网接口视图/二层聚合接口视图
all:表示对所有VLAN进行配置。
# 将端口Ten-GigabitEthernet1/0/1配置为VLAN 2内的静态路由器端口。
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping static-router-port vlan 2
igmp-snooping version命令用来配置IGMP Snooping的版本。
undo igmp-snooping version命令用来恢复缺省情况。
igmp-snooping version version-number
IGMP Snooping的版本为2。
VLAN视图
version-number:表示IGMP Snooping的版本号,取值范围为2~3。
# 在VLAN 2内使能IGMP Snooping,并配置该VLAN内的IGMP Snooping版本为3。
[Sysname] vlan 2
·     version (IGMP-Snooping view)
last-member-query-interval命令用来全局配置IGMP特定组查询报文的发送间隔。
undo last-member-query-interval命令用来恢复缺省情况。
IGMP-Snooping视图
本命令与igmp-snooping last-member-query-interval命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有VLAN都有效,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
# 全局配置IGMP特定组查询报文的发送间隔为3秒。
[Sysname-igmp-snooping] last-member-query-interval 3
·     igmp-snooping last-member-query-interval
max-response-time命令用来全局配置IGMP普遍组查询的最大响应时间。
undo max-response-time命令用来恢复缺省情况。
IGMP-Snooping视图
本命令与igmp-snooping max-response-time命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有VLAN都有效,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
# 全局配置IGMP普遍组查询的最大响应时间为5秒。
[Sysname-igmp-snooping] max-response-time 5
overflow-replace命令用来全局使能组播组替换功能。
undo overflow-replace命令用来全局关闭组播组替换功能。
undo overflow-replace [ vlan vlan-list ]
组播组替换功能处于关闭状态。
IGMP-Snooping视图
·     本命令与igmp-snooping overflow-replace命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
# 全局使能VLAN 2内的组播组替换功能。
[Sysname-igmp-snooping] overflow-replace vlan 2
·     igmp-snooping overflow-replace
report-aggregation命令用来使能IGMP成员关系报告报文抑制功能。
undo report-aggregation命令用来关闭IGMP成员关系报告报文抑制功能。
report-aggregation
IGMP成员关系报告报文抑制功能处于使能状态。
IGMP-Snooping视图
# 关闭IGMP成员关系报告报文抑制功能。
[Sysname-igmp-snooping] undo report-aggregation
reset igmp-snooping group命令用来清除动态组播组的IGMP Snooping转发表项信息。
reset igmp-snooping group { group-address [ source-address ] | all } [ vlan vlan-id ]
group-address:清除指定组播组的信息,取值范围为224.0.1.0~239.255.255.255。
source-address:清除指定组播源的信息。如果未指定本参数,将清除所有组播源的信息。
all:清除所有组播组的信息。
vlan vlan-id:清除指定VLAN内的信息。vlan-id为VLAN的编号,取值范围为1~4094。如果未指定本参数,将清除所有VLAN内的信息。
# 清除所有动态组播组的IGMP Snooping转发表项信息。
<Sysname> reset igmp-snooping group all
·     display igmp-snooping group
reset igmp-snooping router-port命令用来清除动态路由器端口的信息。
reset igmp-snooping router-port { all | vlan vlan-id ]
all:清除所有动态路由器端口的信息。
# 清除所有动态路由器端口的信息。
<Sysname> reset igmp-snooping router-port all
·     display igmp-snooping router-port
reset igmp-snooping statistics命令用来清除IGMP Snooping监听到的IGMP报文和PIMv2 hello报文统计信息。
# 清除IGMP Snooping监听到的IGMP报文和PIMv2 hello报文统计信息。
<Sysname> reset igmp-snooping statistics
·     display igmp-snooping statistics
router-aging-time命令用来全局配置动态路由器端口的老化时间。
undo router-aging-time命令用来恢复缺省情况。
动态路由器端口的老化时间为260秒。
IGMP-Snooping视图
本命令与igmp-snooping router-aging-time命令的功能相同,只是作用范围不同:IGMP-Snooping视图下的全局配置对所有VLAN,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
# 全局配置动态路由器端口的老化时间为100秒。
[Sysname-igmp-snooping] router-aging-time 100
·     igmp-snooping router-aging-time
source-deny命令用来使能指定端口的组播数据报文源端口过滤功能。
undo source-deny命令用来关闭指定端口的组播数据报文源端口过滤功能。
undo source-deny port interface-list
IGMP-Snooping视图
port interface-list:表示对指定端口进行配置。interface-list为端口列表,表示一或多个端口,表示方式为interface-list = { interface-type interface-number [ to interface-type interface-number ] },其中,interface-type为接口类型,interface-number为接口编号。
本命令与igmp-snooping source-deny命令的功能相同,只是作用范围不同:IGMP-Snooping视图下可以对指定端口进行配置,端口视图下只能对当前端口进行配置,二者的配置优先级相同。
# 使能从端口Ten-GigabitEthernet1/0/1到Ten-GigabitEthernet1/0/4的组播数据报文源端口过滤功能。
[Sysname-igmp-snooping] source-deny port ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
·     igmp-snooping source-deny
version命令用来配置指定VLAN内的IGMP Snooping的版本。
undo version命令用来恢复缺省情况。
undo version vlan vlan-list
VLAN内IGMP Snooping的版本为2。
IGMP-Snooping视图
·     对于基于VLAN的配置,本命令与igmp-snooping version命令的功能相同,只是作用范围不同:IGMP-Snooping视图下可以对指定VLAN进行配置,VLAN视图下只能对当前VLAN进行配置,二者的配置优先级相同。
# 使能VLAN 2~10内的IGMP Snooping,并配置这些VLAN内的IGMP Snooping版本为3。
[Sysname-igmp-snooping] version 3 vlan 2 to 10
·     igmp-snooping version
