21-WLAN命令参考
01-AP管理命令
本章节下载 01-AP管理命令  (350.13 KB)
docurl=/cn/Service/Document_Software/Document_Center/Switches/Catalog/S10500/S10500/Command/Command_Manual/H3C_S10500_CR-R7536P02-6W100/21/201704/985508_30005_0.htm
01-AP管理命令
1 AP管理
1.1 AP管理配置命令
1.1.1 ac
1.1.2 ap
1.1.3 control-address
1.1.4 control-address enable
1.1.5 delete file
1.1.6 description (AP group view)
1.1.7 description (AP view)
1.1.8 display wlan ap
1.1.9 display wlan ap connection
1.1.10 display wlan ap files
1.1.11 display wlan ap online-time
1.1.12 display wlan ap running-configuration
1.1.13 display wlan ap reboot-log
1.1.14 display wlan ap-distribution
1.1.15 display wlan ap-distribution ap-name
1.1.16 display wlan ap-group
1.1.17 display wlan ap-model
1.1.18 display wlan tunnel latency ap name
1.1.19 dns domain
1.1.20 dns server
1.1.21 download file
1.1.22 echo-interval
1.1.23 firmware-upgrade
1.1.24 fragment-size
1.1.25 gateway
1.1.26 hybrid-remote-ap enable
1.1.27 if-match ip
1.1.28 if-match ipv6
1.1.29 ip address
1.1.30 ipv6 address
1.1.31 led-mode
1.1.32 mac-address(AP group view)
1.1.33 mac-address(AP view)
1.1.34 priority
1.1.35 provision
1.1.36 provision auto-recover
1.1.37 provision auto-update
1.1.38 reset wlan ap
1.1.39 reset wlan ap provision
1.1.40 reset wlan ap reboot-log
1.1.41 reset wlan tunnel latency ap
1.1.42 retransmit-count
1.1.43 retransmit-interval
1.1.44 save wlan ap provision
1.1.45 serial-id(AP group view)
1.1.46 serial-id(AP view)
1.1.47 snmp-agent trap enable wlan ap
1.1.48 snmp-agent trap enable wlan capwap
1.1.49 statistics-interval
1.1.50 tunnel latency-detect
1.1.51 wlan ap
1.1.52 wlan apdb
1.1.53 wlan apdb file
1.1.54 wlan ap-group
1.1.55 wlan auto-ap enable
1.1.56 wlan auto-ap persistent
1.1.57 wlan auto-persistent enable
1.1.58 wlan capwap discovery-policy
1.1.59 wlan global-configuration
1.1.60 wlan image-load filepath
1.1.61 wlan re-group
1.1.62 wlan rename-ap
1 AP管理
1.1  AP管理配置命令
1.1.1  ac
ac命令用来配置AP建立CAPWAP隧道的静态AC的IP地址或主机名。
undo ac命令用来删除AP静态发现使用的AC。
ac { host-name hostname | ip ipv4-address | ipv6 ipv6-address }
undo ac { host-name | ip [ ipv4-address ] | ipv6 [ ipv6-address ] }
AP provision视图:继承AP组配置。
AP组provision视图:未配置AP建立CAPWAP隧道的静态AC的IP地址或主机名。
AP provision视图/AP组provision视图
host-name host-name:AC的主机名,为1~253个字符的字符串,不区分大小写,字符串中可以包含字母、数字、“-”、“_”和“.”。
ip ipv4-address:指定的AC IPv4地址。
ipv6 ipv6-address:指定的AC IPv6地址。
·     最多可配置3个AC的IPv4地址、3个AC的IPv6地址;主机名最多可以配置1个,后配置的主机名会覆盖已配置的主机名。
·     在AP组provision视图下,本命令对所有AP组内的AP生效;AP provision视图下,本命令只对该AP生效。
·     AP provision视图下的配置优先级高于AP组provision视图下的配置。
·     当使用undo ac { ip [ ip-address ] | ipv6 [ ipv6-address ] }命令时,若未指定ip-addressipv6-address参数时,则表示删除所有配置的IPv4或IPv6地址。
# 在AP provision视图下配置AP静态发现AC的IPv4地址为192.168.100.11。(AP provision视图)
[Sysname] wlan ap ap1 model WA4320H
[Sysname-wlan-ap-ap1] provision
[Sysname-wlan-ap-ap1-prvs] ac ip 192.168.100.11
# 在AP组provision视图下配置AP静态发现AC的IPv4地址为192.168.100.11。(AP组provision视图)
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] provision
[Sysname-wlan-ap-group-group1-prvs] ac ip 192.168.100.11
1.1.2  ap
ap命令用来配置AP名字入组规则。
undo ap命令用来删除AP名字入组规则。
ap ap-name-list
undo ap ap-name-list
未配置AP名字入组规则。
AP组视图
ap-name-list:AP的名字列表,表示方式为ap-name-list={ ap-name }&<1-10>。其中ap-name为AP的名字,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写,&<1-10>表示前面的参数最多可以输入10个。
·     本命令不检查指定的AP是否存在。
·     AP将按照如下顺序匹配入组规则:AP名称入组规则-->AP序列号入组规则-->AP MAC地址入组规则-->IPv4网段入组规则或IPv6网段入组规则。若AP未匹配到入组规则,则将被加入默认组。
·     若其它组已经存在该AP名称入组规则,在新组配置该AP名称入组规则,则原AP组将删除该AP名称入组规则。
·     默认组视图下不能进行该配置。
# 在AP组视图下添加名字入组规则。
[Sysname-wlan-ap-group-group1] ap ap1 ap2 ap3
·     wlan ap-group
control-address命令用来配置CAPWAP Control IP Address消息元素中的IP地址。
undo control-address命令用来恢复缺省情况。
control-address { ip ipv4-address | ipv6 ipv6-address }
undo control-address { ip | ipv6 }
AP视图:AP组有配置的情况下,继承AP组配置;AP组无配置的情况下,继承全局配置。
AP组视图:继承全局配置。
全局配置视图:CAPWAP Control IP Address消息元素中的IP地址为AC自身的IP地址。
AP视图/AP组视图/全局配置视图
ip ipv4-address:指定CAPWAP Control IPv4 Address消息元素中的IPv4地址。
ipv6 ipv6-address:指定CAPWAP Control IPv6 Address消息元素中的IPv6地址。
本命令仅在二次发现AC功能处于开启的情况下才会生效。
最多可配置三个IPv4地址和三个IPv6地址,即AC回复的Discovery response报文中最多可携带三个CAPWAP Control IPv4 Address消息元素或三个CAPWAP Control IPv6 Address消息元素,并将配置的IP地址告知AP。
AP视图下的配置优先级高于AP组视图下的配置,AP组视图下的配置优先级高于全局配置视图下的配置。
# 配置CAPWAP Control IPv4 Address消息元素中的IP地址为IPv4地址192.168.1.1。(AP视图)
[Sysname-wlan-ap-ap1] control-address ip 192.168.1.1
# 配置CAPWAP Control IPv4 Address消息元素中的IP地址为IPv4地址192.168.1.1。(AP组视图)
[Sysname] wlan ap-group 10
[Sysname-ap-group-10] control-address ip 192.168.1.1
# 配置CAPWAP Control IPv4 Address消息元素中的IP地址为IPv4地址192.168.1.1。(全局配置视图)
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] control-address ip 192.168.1.1
·     control-address enable
control-address enable命令用来开启二次发现AC功能。
control-address disable命令用来关闭二次发现AC功能。
control-address { disable | enable }
AP组视图:继承全局配置。
全局配置视图:二次发现AC功能处于关闭状态。
AP视图/AP组视图/全局配置视图
二次发现AC功能用于向AP提供建立CAPWAP隧道的目的AC的IP地址。开启该功能后,AC发送的Discovery response报文中会携带CAPWAP Control IP Address消息元素,AP收到Discovery response报文后,将向消息元素中的IP地址发送Discovery request报文,达到二次发现AC的目的。
关闭二次发现AC功能后,AC发送的Discovery response报文中不会携带CAPWAP Control IP Address消息元素,AP收到此类Discovery response报文后,将与Discovery response报文的源IP地址建立CAPWAP隧道。
# 开启二次发现AC功能。(AP视图)
[Sysname-wlan-ap-ap1] control-address enable
# 开启二次发现AC功能。(AP组视图)
[Sysname-ap-group-10] control-address enable
# 开启二次发现AC功能。(全局配置视图)
[Sysname-wlan-global-configuration] control-address enable
·     control-address
1.1.5  delete file
delete file命令用来删除AP上的文件。
delete file filename
AP视图
filename:要删除的文件名,为1~255个字符的字符串。
只有在AP和AC建立了CAPWAP隧道并且当前AC为主AC时,用户才能通过文件删除操作将AP上的文件删除。
# 删除AP上的文件startup.cfg。
[Sysname-wlan-ap-ap1] delete file startup.cfg
·     download file
·     display wlan ap files
description命令用来配置AP组的描述信息。
undo description命令用来清除AP组的描述信息。
未配置AP组的描述信息。
AP组视图
text:AP组的描述信息,为1~64个字符的字符串,区分大小写。
当存在多个AP组时,可以配置每个AP组的描述信息,以便区别各个AP组。
使用display wlan ap-group命令可以看到配置的描述信息。
# 配置group1的描述信息。
[Sysname-ap-group-group1] description L3-office
·     display wlan ap-group
·     wlan ap-group
description命令用来配置AP的描述信息。
undo description命令用来清除AP的描述信息。
未配置AP的描述信息。
AP视图
text:网络中AP的描述信息,为1~64个字符的字符串,区分大小写。
当存在多个AP时,可以配置每个AP的描述信息,以便区别各个AP。
使用display wlan ap命令可以看到配置的描述信息。
# 配置ap1的描述信息。
[Sysname-ap-ap1] description L3-office
display wlan ap命令用来显示指定AP或所有AP的信息。
display wlan ap { all | name ap-name } [ address | radio [ frequency-band { 5 | 2.4 } ] | verbose ]
all:显示所有AP的信息。
name ap-name:指定AP的名称,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
address:显示AP的地址信息。
radio:显示AP上Radio的信息。
frequency-band:显示工作在指定频段的射频的信息。
5:显示工作在5GHz频段的射频的信息。
2.4:显示工作在2.4GHz频段的射频的信息。
verbose:显示AP的详细信息。
# 显示所有AP的信息。
<Sysname> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3071
Total AP licenses: 128
Remaining AP licenses: 127
                                 AP information
 State : I = Idle,       J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,     DC = DataCheck,  R  = Run   M = Master,  B = Backup
AP name                         AP ID   State Model           Serial ID
ap1                             1       I     WA4320H         219801A0YG8165E00001
表1-1 display wlan ap all命令显示信息描述表
Total number of APs
AP的总数量
处于连接状态的AP的总数量
处于连接状态的手工AP的总数量
处于连接状态的自动AP的总数量
处于连接状态的普通AP的总数量
处于连接状态的WTU总数量
处于连接状态的内部AP数量
AC上最大AP容量
Remaining APs
剩余AP容量,即最大AP容量减去处于连接状态的AP数量
Total AP licenses
AP license总数量
剩余AP license数量
APID
AP的ID号,用于在AC上唯一标识一个AP
AP name
AP名称
AP当前状态:
·     I:空闲状态
·     J:CAPWAP连接建立状态
·     JA:CAPWAP连接确认阶段
·     IL:版本下载状态
·     C:初始化配置下载状态
·     DC:数据校验状态
·     R:运行状态,表示AP与AC成功建立CAPWAP隧道
·     R/M:CAPWAP主隧道运行状态,表示AP与主AC成功建立主隧道
·     R/B:CAPWAP备隧道处于运行状态,表示AP与备AC成功建立备隧道
·     M:主用状态,表示当前AC为AP的主用AC
·     B:备用状态,表示当前AC为AP的备用AC
Model
AP型号信息
Serial ID
AP序列号,如果未指定,则显示为Not configured
# 显示ap1的详细信息。
<Sysname> display wlan ap name ap1 verbose
AP name                       : ap1
AP ID                         : 1
AP group name                 : default-group
State                         : Run
Backup type                   : Master
Online time                   : 0 days 1 hours 25 minutes 12 seconds
System up time                : 0 days 2 hours 22 minutes 12 seconds
Model                         : WA4320H
Region code                   : CN
Region code lock              : Disable
Serial ID                     : 219801A0YG8165E00001
MAC address                   : 0AFB-423B-893C
IP address                    : 192.168.1.50
UDP port number               : 18313
H/W version                   : Ver.C
S/W version                   : R2121P04
Boot version                  : 1.01
USB state                     : N/A
Power Level                   : N/A
PowerInfo                     : N/A
Description                   : wtp1
Priority                      : 4
Echo interval                 : 10 seconds
Statistics report interval    : 50 seconds
Fragment size (data)          : 1500
Fragment size (control)       : 1450
MAC type                      : Local MAC & Split MAC
Tunnel mode                   : Local Bridging & 802.3 Frame & Native Frame
Discovery type                : Static Configuration
Retransmission count          : 3
Retransmission interval       : 5 seconds
Firmware upgrade              : Enabled
Sent control packets          : 1
Received control packets      : 1
Echo requests                 : 147
Lost echo responses           : 0
Average echo delay            : 3
Last reboot reason            : User soft reboot
Latest IP address             : 10.1.0.2
Tunnel down reason            : Request wait timer expired
Connection count              : 1
Backup Ipv4                   : Not configured
Backup Ipv6                   : Not configured
Tunnel encryption             : Disabled
LED mode                      : Normal
Remote configuration          : Enabled
Radio 1:
    Basic BSSID               : 7848-59f6-3940
    Admin state               : Up
    Radio type                : 802.11ac
    Antenna type              : internal
    Client dot11ac-only       : Disabled
    Client dot11n-only        : Disabled
    Channel band-width        : 20/40/80MHz
    Active band-width         : 20/40/80MHz
    Secondary channel offset  : SCB
    Short GI for 20MHz        : Supported
    Short GI for 40MHz        : Supported
    Short GI for 80MHz        : Supported
    Short GI for 160MHz       : Not supported
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Not Supported
    STBC                      : Supported
    Operational VHT-MCS Set:
        Mandatory             : Not configured
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
        Multicast             : Not configured
    Operational HT MCS Set:
        Supported             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15
    Channel                   : 44(auto)
    Max power                 : 20 dBm
    Operational rate:
        Mandatory             : 6, 12, 24 Mbps
        Multicast             : Auto
        Supported             : 9, 18, 36, 48, 54 Mbps
        Disabled              : Not configured
    Distance                  : 1 km
    ANI                       : Enabled
    Fragmentation threshold   : 2346 bytes
    Beacon interval           : 100 TU
    Protection threshold      : 2346 bytes
    Long retry threshold      : 4
    Short retry threshold     : 7
    Maximum rx duration       : 2000 ms
    Noise Floor               : -102 dBm
    Smart antenna             : Enabled
    Smart antenna policy      : Auto
    Protection mode           : rts-cts
    Continuous mode           : N/A
    HT protection mode        : No protection
Radio 2:
    Basic BSSID               : 7848-59f6-3950
    Admin state               : Down
    Radio type                : 802.11b
    Channel band-width        : 20MHz
    Active band-width         : 20MHz
    Secondary channel offset  : SCN
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    STBC                      : Supported
    Channel                   : 5(auto)
    Max power                 : 20 dBm
    Preamble type             : Short
    Operational rate:
        Mandatory             : 1, 2, 5.5, 11 Mbps
        Multicast             : Auto
        Supported             : 6, 9, 12, 18, 24, 36, 48, 54 Mbps
    Distance                  : 1 km
    ANI                       : Enabled
    Noise Floor               : 0 dBm
表1-2 display wlan ap name verbose命令显示信息描述表
AP name
AP名称
AP ID
AP的ID号,用于唯一标识一个AP
AP group name
AP组名称
AP当前状态:
·     Idle:空闲状态
·     Join:CAPWAP连接建立状态
·     JoinAck:CAPWAP连接确认状态
·     Image Download:版本下载状态
·     Config:初始化配置下载状态
·     Data Check:数据校验状态
·     Run:运行状态,表示AP与AC成功建立CAPWAP隧道
Backup type
AP与AC间隧道类型:
·     Idle:未建立隧道
·     Master:主用隧道
·     Backup:备用隧道
Online time
AP在线时长
System up time
AP系统启动时长
Model
AP型号信息
Region code
区域码
Region code lock
区域码锁定功能:
·     Enabled:开启状态
·     Disabled:关闭状态
Serial ID
AP序列号。如果未指定序列号,显示为Not configured
MAC address
AP的MAC地址。如果未指定MAC地址,显示为Not configured
IP address
AP当前连接的IP地址
UDP port number
AP建立CAPWAP控制隧道的端口号
H/W version
AP当前硬件信息
S/W version
AP当前软件信息
Boot version
AP当前引导程序版本
USB state
USB的状态信息:
·     N/A:无
·     Enabled:开启状态
·     Disabled:关闭状态
Power Level
供电等级:
·     N/A:未知供电等级
·     Low:低供电等级
·     Middle:中供电等级
·     High:高供电等级
PowerInfo
供电信息
PoE status
PoE接口的供电状态:
·     Port number:PoE接口编号
·     Enabled:开启状态
·     Disabled:关闭状态
(本字段的支持情况与AP设备的型号有关)
AP描述信息。如果未指定描述信息,显示为Not configured
Priority
AC配置的AP连接的优先级
Echo interval
AP的两次回声请求的时间间隔
AP上报统计信息的时间间隔
CAPWAP数据报文分片的最大长度
CAPWAP控制报文分片的最大长度
MAC type
AP与AC连接的MAC模式类型:
·     Local MAC:AP侧数据帧支持802.3格式封装
·     Split MAC:AP侧数据帧支持802.11格式封装
·     Local & Split MAC:AP侧数据帧支持802.3与802.11格式封装
Tunnel mode
AP支持的隧道模式:
·     Local Bridging:AP侧支持用户数据本地桥接,不上送给AC
·     802.3 Frame:AP侧支持用户数据以802.3帧格式封装上传给AC
·     Native Frame:AP侧支持用户数据以802.11帧格式封装上传给AC
·     Local Bridging & 802.3 Frame:AP侧支持用户数据本地桥接、以802.3帧格式封装上传
·     802.3 Frame & Native Frame:AP侧支持用户数据以802.3或802.11帧格式封装上传
·     Local Bridging & Native Frame:AP侧支持用户数据本地桥接、以802.11帧格式封装上传
·     Local Bridging & 802.3 Frame & Native Frame:AP侧支持用户数据本地桥接、以802.3或802.11帧格式封装上传
Discovery type
AP的发现方式:
·     Static Configuration:AP使用静态配置的IPv4或IPv6地址发现AC
·     DHCP:AP使用DHCP选项发现AC
·     DNS:AP使用DHCP+DNS发现AC
·     Unknown:未知的发现方式
AC重传请求报文的重传次数
AC重传请求报文的重传间隔
Firmware upgrade
AP的版本下载:
·     Enabled:开启AP的版本下载
·     Disabled:关闭AP的版本下载
AC在Run状态之后发送的控制报文的个数(包含Change State Event Response报文)
AC在Run状态之后接收的控制报文的个数(包含Change State Event Request报文)
Echo requests
AP在RUN状态下发送的echo请求报文数量
Lost echo responses
AP在Run状态下没有接收到的echo响应报文数量
Average echo delay
AP控制隧道保活报文的平均延时,单位为毫秒
Last reboot reason
AP上一次重启的原因:
·     Power on:AP设备上电重启
·     Hard reboot:硬重启,即使用reset按钮重启AP设备
·     Watchdog reboot:看门狗重启
·     Unknown reboot:未知原因重启
·     User soft reboot:通过命令行、SNMP、Web等管理手段重启设备
·     Kernel exception soft reboot:内核异常重启
·     Kernel deadloop soft reboot:内核死循环重启
·     Auto update soft reboot:版本自动升级
·     Unknown soft reboot:未知软件原因
·     Memory exhausted:内存耗尽
·     Other unknown soft reboot:其他原因
Latest IP address
AP最近一次使用的IP地址
Tunnel down reason
CAPWAP隧道关闭的原因:
·     N/A:无
·     Failed to create timer:创建定时器失败
·     Neighbor dead timer expired:邻居报告定时器超时
·     Request wait timer expired:等待请求消息定时器超时
·     Data check timer expired:数据检测定时器超时
·     Failed to process data channel keep-alive message:处理数据隧道保活报文失败
·     Failed to process request:请求报文处理失败
·     AP was reset:AP重启
·     AP was deleted:AP被删除
·     Failed to come online:AP上线失败
·     Serial number changed:AP的Serial ID改变
·     MAC address changed:AP的MAC地址改变
·     Number of APs exceeded the limit:AP数量超出AC能力集
·     Processed join request in Run state:在Run状态处理join request
·     Failed to create AP context:创建AP上下文信息失败
·     Received failure result code:CAPWAP状态机状态变迁时收到错误结果码
·     Failed to retransmit message:报文重传失败
·     Failed to download image file:下载AP镜像失败
·     Image file downloaded successfully:AP下载镜像成功重启系统
·     File operation timer expired:文件操作定时器超时
·     Failed to add tunnel:添加隧道失败
·     Received WTP tunnel down event from AP:AC收到AP的隧道down事件
·     Backup AC closed the backup tunnel:备份AC关闭备份隧道
·     Master and backup tunnel switchover:主备隧道切换
·     Failed to inherit configuration:继承配置失败
·     AP authentication failed:AP认证失败
Connection count
AP和AC的连接次数,只有在以下情况下连接次数会清零:
·     AC重启
·     重新配置AP序列号
需要注意的是,使用reset wlan ap命令不会造成AP连接次数清零
Backup Ipv4
备AC的IPv4地址。如果未指定,显示为Not configured
Backup Ipv6
备AC的IPv6地址。如果未指定,显示为Not configured
Tunnel encryption
CAPWAP隧道加密功能:
·     Enabled:开启状态
·     Disabled:关闭状态
LED mode
LED闪烁模式:
·     quiet:表示所有LED常灭
·     awake:表示所有LED每分钟闪烁一次
·     always-on:表示所有LED常亮
·     normal:Normal模式的LED闪烁情况与AP型号有关,请以设备的实际情况为准
远程配置同步功能:
·     Enabled:开启状态
·     Disabled:关闭状态
Radio
射频
Basic BSSID
Radio的MAC地址。N/A表示AP还未与AC建立CAPWAP隧道
Admin state
Radio状态:
·     UpRadio处于开启状态
·     DownRadio处于关闭状态
Radio type
Radio类型:
·     2.4GHz:802.11b、802.11g、802.11n(2.4GHz)
·     5GHz:802.11a、802.11n(5GHz)、802.11ac
Antenna type
天线类型
Client dot11ac-only
只允许802.11ac客户端接入功能:
·     Enabled:只有802.11ac的无线客户端才能接入射频
·     Disabled:兼容802.11a/b/g/n的无线客户端,同时还要接入802.11ac的无线客户端
Client dot11n-only
仅允许802.11n及802.11ac客户端接入功能:
·     Disabled:兼容802.11a/b/g的无线客户端,同时还要接入802.11n或802.11ac的无线客户端
·     Enabled:只有802.11n或802.11ac的无线客户端才能接入射频
Channel band-width
配置的带宽模式:
·     20MHz:工作带宽为20MHz
·     20/40MHz:工作带宽为20/40MHz
·     20/40/80MHz:工作带宽为20/40/80MHz
Active band-width
射频运行带宽
802.11n及802.11ac射频模式中的辅信道信息:
·     SCA:Second Channel Above,表示射频当前工作在40MHz带宽模式,并且辅信道高于主信道
·     SCB:Second Channel Below,表示射频当前工作在40MHz带宽模式,并且辅信道低于主信道
·     SCN:表示射频未工作在40MHz带宽模式
Short GI for 20MHz
射频工作带宽为20MHz时,对于Short GI的支持情况:
·     Not supported:射频不支持20MHz Short GI
·     Supported:射频支持20MHz Short GI
Short GI for 40MHz
射频工作带宽为40MHz时,对于Short GI的支持情况:
·     Not supported:射频不支持40MHz Short GI
·     Supported:射频支持40MHz Short GI
Short GI for 80MHz
射频工作带宽为80MHz时,对于Short GI的支持情况:
·     Not supported:射频不支持80MHz Short GI
·     Supported:射频支持80MHz Short GI
Short GI for 160MHz
射频工作带宽为160MHz时,对于Short GI的支持情况:
·     Not supported:射频不支持160MHz Short GI
·     Supported:射频支持160MHz Short GI
A-MSDU
A-MSDU功能:
·     Disabled:A-MSDU功能处于关闭状态
·     Enabled:A-MSDU功能处于开启状态
A-MPDU
A-MPDU功能:
·     Disabled:A-MPDU功能处于关闭状态
·     Enabled:A-MPDU功能处于开启状态
LDPC
低密度奇偶校验码:
·     Supported:射频支持LDPC功能
·     Not Supported:射频不支持LDPC功能
STBC
空时块编码:
·     Supported:射频支持STBC功能
·     Not Supported:射频不支持STBC功能
Operational VHT MCS Set
VHT-MCS集:
·     Mandatory:基本VHT-MCS索引
·     Supported:支持VHT-MCS索引
·     Multicast:组播VHT-MCS索引
HT-MCS集:
·     Supported:支持MCS索引
·     Mandatory:强制MCS索引
·     Multicast:组播MCS索引
Channel
Radio信道:
·     Number <auto>:表示自动信道模式根据实际环境自动选择最优信道
·     Number:手动配置的工作信道
·     Number <avoid radar>在手工信道上发现雷达信号时自动调整的规避信道
Max power
Radio的最大传输功率
Preamble type
前导码类型:
·     Long:长和短前导码
·     Short:短前导码
Operational rate
操作速率:
·     Mandatory:强制速率
·     Supported:支持速率
·     Multicast:组播速率
·     Disabled:禁止速率
·     Not configured:未指定速率
Distance
Radio可覆盖的最远距离
ANI
ANI功能的状态:
·     Enabled:ANI功能处于开启状态
·     Disabled:ANI功能处于关闭状态
帧的分片门限值
Beacon interval
发送Beacon帧的时间间隔
启用protection机制所要求的帧的长度门限值
帧长超过RTS门限值的帧的最大重传次数
帧长不大于RTS门限值的帧的最大重传次数
Maximum rx duration
帧可以在缓存中保存的最长时间
Noise Floor
噪声基底
Smart antenna
智能天线功能:
·     Enabled:智能天线处于开启状态
·     Disabled:智能天线处于关闭状态
智能天线策略:
·     Auto:自适应策略
·     High availability:高可靠性策略
·     High throughput:高吞吐量策略
Protection mode
冲突避免方式:
·     cts-to-self:CTS-to-self方式
·     rts-cts:RTS/CTS方式
Continuous mode
常发模式所使用的速率、MCS索引值、NSS索引值和VHT-MCS索引值,N/A表示未配置常发模式
HT protection mode
802.11n保护模式:
·     No protection:此模式下,AP上关联的客户端以及周围环境中的无线设备都为802.11n模式,并且在AP上关联的客户端都是40MHz带宽的802.11n客户端;或者在AP上关联的客户端都是20MHz带宽的802.11n客户端
·     Non-member protection:此模式下,AP上关联的客户端都是802.11n客户端,但是周围环境中存在着非802.11n无线设备
·     20 MHz protection:此模式下,AP的射频带宽模式为40MHz,AP上关联的客户端以及周围环境中的无线设备都为802.11n模式,并且在该AP的射频上至少关联了一个20MHz带宽的802.11n客户端
·     Non-HT mixed:除以上三种模式之外的其它所有情况都属于此模式
MU-TxBF
多用户TxBF功能:
·     Enabled:多用户TxBF功能处于开启状态
·     Disabled:多用户TxBF功能处于关闭状态
SU-TxBF
单用户TxBF功能:
·     Enabled:单用户TxBF功能处于开启状态
·     Disabled:单用户TxBF功能处于关闭状态
# 显示所有AP的地址信息。
<Sysname> display wlan ap all address
Total number of connected manual Aps: 1
AP name                          IP address                     MAC address
ap1                              1.1.1.5                        000b-6b8f-fc6a
表1-3 display wlan ap all address命令显示信息描述表
AP name
AP名称
IP address
AP的IP地址,AP未上线时,该字段显示为N/A
MAC address
AP的MAC地址,AP未上线时,该字段显示为N/A
# 显示所有AP上的Radio信息。
<Sysname> display wlan ap all radio
Maximum supported APs: 256
Remaining APs: 255
AP name                    RadioID Channel          Usage TxPower AntGain EIRP
                                                    (%)   (dBm)   (dBi)   (dBm)
ap1                        1       36(auto)         0     20      10      30
ap1                        2       6(auto)          0     20      10      30
# 显示ap1上工作在2.4GHz频段的Radio信息。
<Sysname> display wlan ap name ap1 radio frequency-band 2.4
表1-4 display wlan ap all radio命令显示信息描述表
AP name
AP名称
RadioID
射频的ID号
Channel
射频使用的工作信道
Usage
信道利用率
Tx power (dBm)
射频的发送功率(缺省为最大功率)
Ant gain (dBi)
天线增益值
EIRP (dBm)
有效全向辐射功率(Effective Isotropic Radiated Power)
display wlan ap connection命令用来显示AC上的AP连接记录。
display wlan ap connection record { all | name ap-name }
all:显示所有AP的连接记录。
name ap-name:显示指定AP的连接记录,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
# 显示AC上所有AP的连接记录。
<Sysname> display wlan ap connection record all
AP name                         IP address      State     Time
ap2                             192.168.100.27  Run       01-06 09:06:40
表1-5 display wlan ap connection命令显示信息描述表
AP name
AP名称
IP address
AP的IP地址
AP当前状态:
·     Idle:空闲状态
·     Run:CAPWAP隧道处于运行状态,表示AP与AC成功建立CAPWAP隧道
Time
AP与AC最后一次建立CAPWAP隧道的时间
display wlan ap files命令用来显示AP上的文件及文件夹信息。
display wlan ap files name ap-name
# 显示ap1的文件及文件夹信息。
<Sysname> display wlan ap files name ap1
Directory of flash:
   0   13638656  wa4300-system.bin
   1   2573312   wa4300-boot.bin
131072 KB total (114208 KB free)
表1-6 display wlan ap files命令显示信息描述表
Directory of
当前显示的AP目录
0   13638656  xx.xx
AP文件夹的信息:
·     0表示编号,由系统自动分配
·     13638656表示文件大小,单位为B。如果显示为“-”,则表示它是文件夹
·     xx.xx表示名称
·     download file
·     delete file
display wlan ap online-time命令用来显示AP的关联时长。
display wlan ap online-time { all | name ap-name }
all:显示所有AP的关联时长。
name ap-name:显示指定AP的关联时长。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
# 显示所有AP的关联时长。
<Sysname> display wlan ap online-time all
AP name            IP address               Time
ap1                1.1.1.2                  0 days 0 hours 2 minutes 6 seconds
ap2                1.1.1.1                  0 days 0 hours 5 minutes 6 seconds
ap3                1.1.1.6                  0 days 0 hours 2 minutes 1 seconds
表1-7 display wlan ap online-time命令显示信息描述表
AP name
AP名称
IP address
AP的IP地址
Time
AP从上线到当前查询时刻的关联时长
display wlan ap running-configuration命令用来显示指定AP或所有AP的运行配置。
display wlan ap running-configuration { all | ap-name ap-name } [ verbose ]
all:显示所有AP的运行配置。
ap-name ap-name:指定AP的名称,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
verbose:显示AP的详细运行配置。
# 显示所有AP的详细运行配置。
<Sysname> display wlan ap running-configuration all verbose
(i) -- Inherited from AP group
(g) -- Inherited from AP gloabl-configuration
wlan ap ap1 model WA4320H id 5
  ap group name 1
  serialid
  region code 156
  echo interval 10 (i)
  retransmission count 3 (i)
  retransmission interval 5 (i)
  statistics interval 50 (i)
  jumbo frame 1500 (i)
  firmware update 1
  priority 4 (i)
…略…
  radio 1
    radio type 802.11ac (i)
    radio disable (i)
    channel auto<64> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    distance 1 kilometer (i)
    ANI Enabled (i)
…略…
  radio 2
    radio type 802.11n(2.4GHz) (i)
    radio disable (i)
    channel auto<11> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
…略…
wlan ap ap2 model WA4320H id 6
  ap group name 2
  serialid
  region code 156
  firmware update 1
  priority 4 (i)
…略…
  radio 1
    radio disable (i)
    channel auto<60> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
…略…
  radio 2
    radio disable (i)
    channel auto<13> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
…略…
表1-8 display wlan ap running-configuration all verbose命令显示信息描述表
表示继承AP组配置
表示继承AP全局配置
display wlan ap reboot-log命令用来显示指定AP的重启日志信息。
display wlan ap reboot-log name ap-name
name ap-name:指定重启的AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
如果AP曾发生过系统崩溃,那么可以使用该命令查看相关信息,注意指定的AP必须处于Run状态。
# 显示名为ap1的AP的重启日志信息。
<Sysname> display wlan ap reboot-log name ap1
Debugging information is not available on the AC.
Downloading debugging data from AP. Continue? [Y/N]:y
Downloading debugging data. Please wait...
Please enter the same command again to view the log messages.
·     reset wlan ap reboot-log
display wlan ap-distribution命令用来显示AC上的AP负载信息。
独立运行模式:
display wlan ap-distribution { all | slot slot-number }
IRF模式:
display wlan ap-distribution { all | chassis chassis-number slot slot-number }
all:显示所有AC上的AP负载信息。
slot slot-number:显示指定成员设备上的AP负载信息。
# 显示AC上的AP负载信息。
<Sysname> display wlan ap-distribution all
Slot               : 0
AP name            : 722a-d561-0301
Slot               : 1
Total number of APs: 3
AP name            : 722a-d561-0300, 4c0b-494a-0400, 0002-0038-0000
表1-9 display wlan ap-distribution all命令显示信息描述表
Slot
指定成员设备上的负载信息
Total number of APs
AC上负载AP的总数量
AP name
AP的名称
# 显示slot 0上的AP负载信息。
<Sysname> display wlan ap-distribution slot 0
                                 AP information
         C = Config,    DC = DataCheck,  R  = Run,   M = Master,  B = Backup
AP name                        APID  State Model           Serial ID
722a-d561-0300                 4     R/M   WA4320H         219801A0YG8165E00001
表1-10 display wlan ap-distribution命令显示信息描述表
AP name
AP的名称
APID
AP当前状态:
·     I:空闲状态
·     J:CAPWAP连接建立状态
·     JA:CAPWAP连接确认阶段
·     IL:版本下载状态
·     C:初始化配置下载状态
·     DC:数据校验状态
·     R:CAPWAP隧道处于运行状态,表示AP与AC成功建立CAPWAP隧道
·     R/M:CAPWAP主隧道处于运行状态,表示AP与主AC成功建立主隧道
Model
AP型号信息
Serial ID
display wlan ap-distribution ap-name命令用来显示指定AP的负载位置。
display wlan ap-distribution ap-name ap-name
ap-name:指定AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
# 显示名称为ap1的AP的负载位置。
<Sysname> display wlan ap-distribution ap-name ap1
The AP is attached to slot 0.
display wlan ap-group命令用来显示AP Group信息。
display wlan ap-group [ brief | name group-name ]
brief:所有AP组的概要信息。
name group-name:显示指定AP组的详细信息。其中,group-name表示AP组的名称,为1~31个字符的字符串,不区分大小写。
# 显示全部AP组的详细信息。
<Sysname> display wlan ap-group
Total number of AP groups: 2
Description         : Not configured
AP model            : Not configured
APs                 : Not configured
AP group name       : group1
Description         : abcd
AP model            : WA4320H
AP grouping rules:
  AP name           : ap1, ap2
  IPv4 address      : Not configured
  IPv6 address      : Not configured
APs                 : ap1 (AP name)
# 显示指定AP组的详细信息。
<Sysname> display wlan ap-group group1
AP model            : WA4320H
AP grouping rules:
  AP name           : ap1, ap2
APs                 : ap1 (AP name)
# 显示所有AP组的概要信息。
<Sysname> display wlan ap-group brief
Total number of AP groups: 4
AP group name                  Group ID  Member APs   Online APs
default-group                  1         1            0
group1                         2         2006         1986
group2                         3         10           10
group3                         4         4            4
表1-11 display wlan ap-group命令显示信息描述表
AP组的总数量
AP group name
AP组名
AP组描述信息
AP model
AP型号名
AP grouping rules
AP组入组规则
AP name
AP名称入组规则
Serial ID
AP序列号入组规则
MAC address
AP MAC地址入组规则
IPv4 address
IPv4网段入组规则
IPv6 address
IPv6网段入组规则
APs
AP组中的AP
Group ID
AP组的ID号,用于在AC上唯一标识一个AP组
Member APs
加入该AP组的AP的数量
Online APs
该AP组中在线AP的数量
·     wlan ap-group
display wlan ap-model命令用来显示AP型号的信息。
display wlan ap-model { all | name model-name }
all:显示所有AP型号的信息。
name model-name:显示指定AP型号的信息。
# 显示AP型号WA4320H的信息。
<Sysname> display wlan ap-model name WA4320H
AP model        : WA4320H
Alias           : WA4320H
Vendor name     : H3C
Vendor ID       : 25506
License weight  : 100
Radio count     : 2
 Radio 1:
  Mode          : 802.11a, 802.11an, 802.11ac
  Default mode  : 802.11ac
  BSS count     : 16
 Radio 2:
  Mode          : 802.11b, 802.11g, 802.11gn
  Default mode  : 802.11gn
  BSS count     : 16
Version Support List :
 Hardware Version Ver.A:
  Software Version         : Alpha 2102
  Default Software Version : Alpha 2102
  Image Name               : wa4300.ipe
 Hardware Version Ver.B:
 Hardware Version Ver.C:
 Hardware Version Ver.D:
 Hardware Version Ver.E:
表1-12 display wlan ap-model命令显示信息描述表
AP model
AP型号名
Alias
AP型号别名
Vendor name
厂商名
Vendor ID
厂商ID
License weight
占用单个AP license的权重,单位为%
Radio count
射频个数
Mode
支持的射频模式
Default mode
默认的射频模式
BSS count
一个Radio可以创建的最大基本服务集个数
版本支持列表
Hardware Version
AP的硬件版本
Software Version
AP的软件版本,用于和AP上报的软件版本号进行比较,缺省值为APDB中保存的AP软件版本
APDB中保存的AP软件版本
Image Name
AP镜像文件
display wlan tunnel latency ap name命令用来显示指定AP的隧道延迟信息。
display wlan tunnel latency ap name ap-name
只有CAPWAP隧道延迟检测功能处于开启状态,才能够显示指定AP的控制隧道和数据隧道延迟的信息。
 # 显示ap1的隧道延迟信息。
<Sysname> display wlan tunnel latency ap name ap1
AP name                              : ap1
Tunnel latency                       : Enabled
Control link delay:
  Current delay                      : 1ms
  Maximum delay                      : 1ms
  Minimum delay                      : 1ms
Data link delay:
  Current delay                      : 1ms
  Maximum delay                      : 1ms
  Minimum delay                      : 1ms
表1-13 display wlan tunnel latency ap命令显示信息描述表
Tunnel latency
隧道延迟检测功能的开启状态
Control link delay
控制隧道延时检测结果
Data link delay
数据隧道延时检测结果
Current delay
最近一次的延时时间,单位为毫秒
Maximum delay
最大的延时时间,单位为毫秒
Minimum delay
最小的延时时间,单位为毫秒
·     reset wlan tunnel latency ap
·     tunnel latency-detect
1.1.19  dns domain
dns domain命令用来配置AP发现AC时使用的域名服务器的域名后缀。
undo dns domain命令用来恢复缺省情况。
dns domain domain-name
undo dns domain
AP组provision视图:未配置AP使用的域名服务器的域名后缀。
domain-name:AP使用的域名服务器的域名后缀,由“.”分隔的字符串组成,包括“.”在内,为1~253个字符的字符串,且每两个“.”之间的字符为1~63个字符的字符串。不区分大小写,字符串中可以包含字母、数字、“-”及下划线“_”。
# 配置AP使用的域名服务器的域名后缀为com。(AP视图)
[Sysname-wlan-ap-ap1-prvs] dns domain com
# 配置AP使用的域名服务器的域名后缀为com。(AP组视图)
[Sysname-wlan-ap-group-goupp1-prvs] dns domain com
·     dns server
1.1.20  dns server
dns server命令用来配置AP使用的域名服务器的IP地址。
undo dns server命令用来恢复缺省情况。
dns server { ip ipv4-address | ipv6 ipv6-address }
undo dns server { ip | ipv6 }
AP组provision视图:未配置AP使用的域名服务器的IP地址。
ip ipv4-address:指定AP使用的域名服务器的IPv4地址。对于输入的IP地址要保证合法性和有效性。非法地址有:环回地址、全网广播、0.X.X.X、D类E类IP地址。
ipv6 ipv6-address:指定AP使用的域名服务器的IPv6地址。
·     每个视图下最多可分别配置1个IPv4地址和一个IPv6地址。
# 配置ap1使用的域名服务器的IPv4 地址为192.168.100.123。(AP provision视图)
[Sysname-wlan-ap-ap1-prvs] dns server ip 192.168.100.123
# 配置AP组group1内的AP使用的域名服务器的IPv4 地址为192.168.100.123。(AP组provision视图)
[Sysname-wlan-ap-group-goupp1-prvs] dns server ip 192.168.100.123
·     dns domain
download file filename命令用来下发指定的文件到AP。
AP视图
filename:文件名,为1~255个字符的字符串。
·     当CAPWAP隧道建立成功后,用户可以通过文件下载操作将AC上存储的版本文件下发给AP。
·     需要注意的是,只有在AP和AC建立了CAPWAP隧道并且当前AC为主AC时,才能下发指定文件到AP。
# 将版本文件main.ipe下发到ap1。
[Sysname-wlan–ap-ap1] download file main.ipe
echo-interval命令用来配置AP发送回声请求的时间间隔。
undo echo-interval命令用来恢复缺省情况。
echo-interval interval
undo echo-interval
AP视图:继承AP组配置。
AP组视图:AP发送回声请求的时间间隔为10秒。
AP视图/AP组视图
interval:指定AP发送回声请求的时间间隔,取值范围为5~80,单位为秒。
AP和AC之间通过保活机制来检查控制隧道是否正常工作。AP周期性地向AC发送回声请求Echo request报文,若一定时间内没有收到AC回复的Echo response报文,则AP断开控制隧道;若AC在一定时间内没有收到Echo request报文,则AC断开控制隧道。
AP视图下配置的优先级高于AP组视图下的配置。
# 配置AP向AC发送回声请求的时间间隔为15秒。(AP视图)
[Sysname] wlan ap ap3 model WA4320H
[Sysname-wlan-ap-ap3] echo-interval 15
# 配置AP向AC发送的回声请求时间间隔为15秒。(AP组视图)
[Sysname-wlan-ap-group-group1] echo-interval 15
firmware-upgrade enable命令用来开启AP版本升级功能。
firmware-upgrade disable命令用来关闭AP版本升级功能。
undo firmware-upgrade命令用来恢复缺省情况。
firmware-upgrade { disable | enable }
AP视图:若AP组下存在版本升级配置,则继承AP组配置,若AP组下不存在版本升级配置,则继承全局配置。
AP组视图:继承全局配置。
全局配置视图:AP版本升级功能处于开启状态。
AP视图/AP组视图/全局配置视图
disable:关闭AP版本升级功能。
enable:开启AP版本升级功能。
·     建立CAPWAP隧道过程中,如果AP版本升级功能处于开启状态,AC会将AP的软件版本与AC上保存的该AP型号的软硬件版本对应关系进行比较。如果软件版本一致,则允许CAPWAP隧道建立;如果软件版本不一致,则将此情况告知AP。AP收到版本不一致的消息后,会向AC请求版本并进行版本升级后,再重新与AC建立CAPWAP隧道连接。
·     建立CAPWAP隧道过程中,如果关闭AP版本升级功能,则AC不对AP当前的软件版本进行比较,直接与AP建立CAPWAP隧道连接。
·     AP视图下的配置优先级高于AP组视图下的配置,AP组视图下的配置优先级高于全局配置视图下的配置。
# 开启AP版本升级功能。(AP视图)
[Sysname-wlan-ap-ap3] firmware-upgrade enable
# 开启AP版本升级功能。(AP组视图)
[Sysname-wlan-ap-group-group1] firmware-upgrade enable
# 开启AP版本升级功能。(全局配置视图)
[Sysname-wlan-global-configuration] firmware-upgrade enable
·     wlan apdb
fragment-size命令用来配置CAPWAP控制报文或数据报文分片的最大长度。
undo fragment-size命令用来将指定的CAPWAP报文分片长度恢复为缺省情况。
fragment-size { control control-size | data data-size }
undo fragment-size { control | data }
AP视图:继承AP组配置。
AP组视图:CAPWAP控制报文分片的最大长度为1450字节,CAPWAP数据报文分片的最大长度为1500字节。
AP视图/AP组视图
control control-size:指定CAPWAP控制报文分片的最大长度,取值范围为1000~1450,单位为字节。
data data-size:指定CAPWAP数据报文分片的最大长度,取值范围为1000~1748,单位为字节。
当AC与AP跨越Internet建立连接时,由于传输路径上的设备可能对报文分片大小进行限制,超过分片门限的报文将被丢弃,因此,需要配置CAPWAP控制报文与数据报文分片长度,使其顺利通过中间设备。
修改CAPWAP报文分片长度后,新配置对已在线的AP立即生效。
AP视图下的配置优先级高于AP组视图下的配置。
# 配置CAPWAP数据报文最大长度为1500字节。(AP视图)
[Sysname-ap-ap1] fragment-size data 1500
# 配置CAPWAP数据报文最大长度为1500字节。(AP组视图)
[Sysname-wlan-ap-group-group1] fragment-size data 1500
1.1.25  gateway
gateway命令用来配置AP的网关地址。
undo gateway命令用来恢复缺省情况。
gateway { ip ipv4-address | ipv6 ipv6-address }
undo gateway { ip | ipv6 }
未配置AP的网关地址。
AP provision视图
ip ipv4-address:指定AP的网关的IPv4地址。对于输入的IP地址要保证合法性。非法地址有:环回地址、全网广播、0.X.X.X、D类E类IP地址。
ipv6 ipv6-address:指定AP的网关的IPv6地址。
最多可分别配置1个IPv4地址和1个IPv6地址。
# 配置ap1的网关地址为192.168.100.1。
[Sysname-wlan-ap-ap1-prvs] gateway ip 192.168.100.1
hybrid-remote-ap enable命令用来开启Remote AP功能。
hybrid-remote-ap disable命令用来关闭Remote AP功能。
undo hybrid-remote-ap命令用来恢复缺省情况。
hybrid-remote-ap { disable | enable }
AP视图:继承AP组配置。
AP组视图:Remote AP功能处于关闭状态。
AP视图/AP组视图
缺省情况下,当AP与AC之间的隧道断开后,AP将停止为客户端提供服务。Remote AP功能支持在AP与AC之间的隧道断开后,AP能够继续为客户端提供服务。
仅当客户端数据报文的转发位置在AP上时,Remote AP功能才会生效。
# 开启Remote AP功能(AP视图)。
[Sysname-wlan-ap-ap1] hybrid-remote-ap enable
# 开启Remote AP功能(AP组视图)。
[Sysname-wlan-ap-group-group1] hybrid-remote-ap enable
1.1.27  if-match ip
if-match ip命令用来配置IPv4网段入组规则。
undo if-match ip命令用来删除指定的或所有IPv4网段入组规则。
if-match ip ip-address { mask-length | mask }
undo if-match ip [ ip-address { mask-length | mask } ]
未配置IPv4网段入组规则。
AP组视图
ip-address:IPv4地址,为点分十进制格式。
mask-length:子网掩码长度,即掩码中连续“1”的个数,取值范围为1~31。
mask:子网掩码,为点分十进制格式。
如果AP使用IPv4地址接入AC,则上线时会与AP组的IPv4网段进行匹配。如果AP的IP地址在AP组的IP网段范围内,AP会加入该AP组。
·     default-group视图下不能配置IPv4网段入组规则。
·     同一AP组(或者不同AP组)的IPv4网段入组规则不能重叠或相互包含。
·     同一AP组下最多能够配置32条IPv4网段入组规则。
·     可以在AP组内同时配置IPv4和IPv6网段入组规则。
·     对于undo if-match ip命令,不指定任何参数,则表示删除所有IPv4网段入组规则。
# 配置IPv4网段入组规则,在192.168.0.0/16网段的AP加入名为group1的AP组。
[Sysname-ap-group-group1] if-match ip 192.168.0.0 16
if-match ipv6命令用来配置IPv6网段入组规则。
undo if-match ipv6命令用来删除指定的或所有IPv6网段入组规则。
if-match ipv6 { ipv6-address prefix-length | ipv6-address/prefix-length }
undo if-match ipv6 [ ipv6-address prefix-length | ipv6-address/prefix-length ]
未配置IPv6网段入组规则。
AP组视图
ipv6-address:IPv6地址。
prefix-length:IPv6地址前缀长度,取值范围为1~128。
如果AP使用IPv6地址接入AC,则上线时会与AP组的IPv6网段进行匹配。如果AP的IPv6地址在AP组的IPv6网段范围内,AP会加入该AP组。
·     default-group视图下不能配置IPv6网段入组规则。
·     同一AP组(或者不同AP组)的IPv6网段匹配条件不能重叠或相互包含。
·     同一AP组下最多能够配置32条IPv6网段入组规则。
·     对于undo if-match ipv6命令,不指定任何参数,则表示删除所有IPv6网段入组规则。
# 配置IPv6网段入组规则,在2001:DB0::/28网段的AP加入名为group1的AP组。
[Sysname-ap-group-group1] if-match ipv6 2001:DB8:: 28
1.1.29  ip address
ip address命令用来配置AP的管理VLAN接口的IP地址。
undo address命令用来恢复缺省情况。
ip address ip-address { mask | mask-length }
undo ip address
未配置AP的管理VLAN接口的IP地址。
AP provision视图
ip-address:AP的管理VLAN的IPv4地址,为点分十进制格式。
mask:子网掩码,为点分十进制格式。
·     对于输入的IP地址要保证合法性。非法地址有:环回地址、全网广播、0.X.X.X 、D类E类IP地址。
·     AP的管理VLAN的IP地址不能与其它任意AP provision视图下的AP管理VLAN的IP地址,及任意AP provision视图下的指定的AC的IP地址相同。
# 配置ap1的管理VLAN接口的IPv4地址为10.1.1.1,掩码为24。
[Sysname-wlan-ap-ap1-prvs] ip address 10.1.1.1 24
1.1.30  ipv6 address
ipv6 address命令用来配置AP的管理VLAN接口的IPv6地址。
 undo ipv6 address命令用来恢复缺省情况。
undo ipv6 address
未配置AP的管理VLAN接口的IPv6地址。
AP provision视图
ipv6-address:AP的管理VLAN接口的IPv6地址。
prefix-length:前缀长度,取值范围为1~128。
AP的管理VLAN的IPv6地址不能与其它任意AP provision视图下的AP的管理VLAN的IPv6地址,及任意AP provision视图下的指定的AC的IPv6地址相同。
# 配置ap1的管理VLAN接口的IPv6地址为2001::1/64。
[Sysname-wlan-ap-ap1-prvs] ipv6 address 2001::1/64
1.1.31  led-mode
led-mode命令用来配置AP的LED闪烁模式。
undo led-mode命令用来恢复缺省情况。
led-mode { always-on | awake | normal | quiet }
undo led-mode
AP视图:继承AP组配置。
AP组视图:LED闪烁模式为normal模式。
AP视图/AP组视图
quiet:指定LED闪烁模式为quiet模式,表示所有LED常灭。
awake:指定LED闪烁模式为awake模式,表示所有LED每分钟闪烁一次。本参数的支持情况与AP设备的型号有关,请以设备的实际情况为准。
always-on:指定LED闪烁模式为always-on模式,表示所有LED常亮。本参数的支持情况与AP设备的型号有关,请以设备的实际情况为准。
normal:指定LED闪烁模式为normal模式,normal模式的LED闪烁情况与AP型号有关,请以设备的实际情况为准。
在AP组视图下配置LED闪烁模式为awake模式或always-on模式时,仅对组内支持该模式的AP生效。
# 配置LED闪烁模式为normal。(AP视图)
[Sysname] wlan ap ap1 model WA2620i-AGN
[Sysname-wlan-ap-ap1] led-mode normal
# 配置LED闪烁模式为awake。(AP组视图)
[Sysname] wlan ap-group g1
[Sysname-wlan-ap-group-g1] led-mode awake
mac-address命令用来配置AP MAC 地址入组规则。
undo mac-address命令用来删除AP MAC 地址入组规则。
mac-address mac-address
undo mac-address mac-address
未配置AP MAC地址入组规则。
AP组视图
mac-address:AP的MAC地址,形式为H-H-H。
·     本命令不检查指定的AP是否存在。
·     同一AP组下AP MAC地址可配置多个。
·     若其它组已经存在该MAC地址入组规则,在新组配置该MAC地址入组规则,则原AP组将删除该MAC地址入组规则。
·     默认组视图下不能进行该配置。
# 在AP组视图下添加AP MAC地址入组规则0AC1-F9B2-B1C2。
[Sysname-wlan-ap-group-group1] mac-address 0AC1-F9B2-B1C2
·     wlan ap-group
mac-address命令用来配置AP的MAC地址。
undo mac-address用来恢复缺省情况。
undo mac-address
AP未配置MAC地址。
AP视图
如果AP已经与AC建立CAPWAP隧道连接,改变和删除MAC地址将触发CAPWAP隧道的拆除,AP将会重新发现AC并与AC建立CAPWAP隧道。
# 配置ap1的MAC地址为0001-0000-0000。
[Sysname-wlan-ap-ap1] mac-address 0001-0000-0000
1.1.34  priority
priority命令用来配置AC上AP连接的优先级。
undo priority命令用来恢复缺省情况。
priority priority
undo priority
AP视图:继承AP组配置。
AP组视图:AP连接的优先级为4。
AP视图/AP组视图
priority:AP连接的优先级,取值范围为0~7。该数值越大,优先级越高。
·     建立CAPWAP隧道的过程中,AP会优先选择优先级高的AC建立隧道连接。
·     本命令配置的优先级,仅在AP建立CAPWAP隧道连接前生效。
·     AP视图下配置的优先级高于AP组视图下的配置。
# 配置AP连接的优先级为7。(AP视图)
[Sysname-wlan-ap-ap3] priority 7
# 配置AP链接的优先级为7。(AP组视图)
[Sysname-wlan-ap-group-group1] priority 7
1.1.35  provision
provision命令用来开启预配置功能,并进入预配置视图。如果预配置功能已开启,则直接进入预配置视图。
undo provision命令用来关闭预配置功能。
provision
undo provision
AP视图:继承AP组配置。
AP组视图:预配置功能处于关闭状态。
AP视图/AP组视图
预配置提供了一种在AC上对AP的基本网络参数进行配置,并将预配置信息下发至AP的方法。
关闭预配置功能,则AC上创建的预配置将被删除,但不影响已下发到AP上的预配置。
# 开启预配置功能,并进入AP预配置视图。(AP视图)
# 开启预配置功能,并进入AP组预配置视图。(AP组视图)
provision auto-recover enable命令用来开启预配置智能加载功能。
provision auto-recover disable 命令用来关闭预配置智能加载功能。
undo provision auto-recover命令用来恢复缺省情况。
provision auto-recover { disable | enable }
AP视图:继承AP组配置。
AP组视图:预配置智能加载功能处于开启状态。
AP视图/AP组视图
预配置智能加载功能用于确保AP尽可能的与AC建立CAPWAP连接。开启预配置智能加载功能后:
·     如果AP使用预配置无法找到存在手工AP或自动AP配置的AC,当AP重启后,则不使用预配置来发现AC。
·     如果AP不使用预配置也无法找到存在手工AP或自动AP配置的AC,当AP重启后,将再次使用预配置来发现AC。
如果AP一直无法找到AC来建立CAPWAP隧道,将重复上述过程。
# 关闭预配置智能加载功能。(AP视图)
[Sysname-ap-ap1] provision auto-recover disable
# 关闭预配置智能加载功能。(AP组视图)
[Sysname-wlan-ap-group-group1] provision auto-recover disable
provision auto-update enable命令用来开启AC自动下发预配置功能。
provision auto-update disable命令用来关闭AC自动下发预配置功能。
undo provision auto-update命令用来恢复缺省情况。
provision auto-update { disable | enable }
AP视图:继承AP组配置。
AP组视图:AC自动下发预配置功能处于关闭状态。
AP视图/AP组视图
在AP上线的过程中,如果本功能处于开启状态,则AC将自动下发预配置信息到AP,且AP会使用该预配置完成上线。
用户可通过save wlan ap provision命令直接下发预配置到已经在线的AP,且预配置立即生效。如果用户需要为即将上线或重新上线的AP下发预配置,则需要使用provision auto-update enable命令开启AC自动下发预配置功能。
AP预配置视图下的配置优先级高于AP组预配置视图下的配置。
# 开启AC自动下发预配置功能。(AP视图)
[Sysname-ap-ap1] provision auto-update enable
# 开启AC自动下发预配置功能。(AP组视图)
[Sysname-wlan-ap-group-group1] provision auto-update enable
reset wlan ap命令用来重启AP。
reset wlan ap { all | ap-group group-name | model model-name | name ap-name }
all:重启连接到当前AC的所有AP。
ap-group group-name:重启指定AP组内的所有AP。group-name为AP组的名称,为1~31个字符的字符串,不区分大小写。
model model-name:重启指定型号的AP。model-name为AP型号的名称。
name ap-name:重启指定名称的AP。ap-name为AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
当AC要断开与AP的CAPWAP隧道连接时,输入此命令,AP重启,AC端与AP相关的连接资源将被清除。
# 重启ap1。
<Sysname> reset wlan ap name ap1
Reset the AP that has established or is to establish a primary tunnel with the AC. Continue? [Y/N]:
reset wlan ap provision命令用来删除AP上的预配置文件。
reset wlan ap provision { all | name ap-name }
all:删除所有AP上的预配置文件。
name ap-name:删除指定AP上的预配置文件,ap-name为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
只有在AP和AC建立了CAPWAP隧道并且当前AC为主AC时,才能删除AP上的预配置文件。
# 删除ap1的预配置文件。
<Sysname> reset wlan ap provision name ap1
reset wlan ap reboot-log命令用来清除指定AP或全部AP的重启日志信息。
reset wlan ap reboot-log { all | name ap-name }
all:清除所有AP的重启日志信息。
name ap-name:清除指定AP的重启日志信息,ap-name为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
# 清除ap1的重启日志信息。
<Sysname> reset wlan ap reboot-log name ap1
·     display wlan ap reboot-log
reset wlan tunnel latency ap命令用来清除AP的隧道延迟信息。
reset wlan tunnel latency ap { all | name ap-name }
all:清除所有AP的CAPWAP隧道延迟信息。
name ap-name:清除指定AP的CAPWAP隧道延迟信息,ap-name为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写
本命令仅对当前处于Run状态且与AC建立主隧道的AP生效。
# 清除ap1的隧道延迟信息。
<Sysname> reset wlan tunnel latency ap name ap1
·     display wlan tunnel latency ap name
retransmit-count命令用来设置AC发送给AP的请求报文重传次数。
undo retransmit-count命令用来恢复缺省情况。
retransmit-count value
AP视图:继承AP组配置。
AP组视图:请求报文重传次数为3次。
AP视图/AP组视图
value:指定请求报文重传次数,取值范围为2~5。
为了使AC的请求报文尽可能的发送到AP,提高报文的可靠传输能力,AC会对请求报文进行重传,重传次数为配置的请求报文重传次数。
AC发送给AP的请求报文包括Image Data Request报文、Configuration Update Request报文、Reset Request报文、Data Transfer Request报文、IEEE 802.11 WLAN Configuration Request报文和Station Configuration Request报文。
# 配置AC发往AP的请求报文重传次数为4。(AP视图)
[Sysname-wlan-ap-ap3] retransmit-count 4
# 配置AC发往AP的请求报文重传次数为4。(AP组视图)
[Sysname-wlan-ap-group-group1] retransmit-count 4
·     retransmit-interval
retransmit-interval命令用来设置请求报文重传的时间间隔。
undo retransmit-interval命令用来恢复缺省情况。
retransmit-interval interval
AP视图:继承AP组配置。
AP组视图:请求报文重传的时间间隔为5秒。
AP视图/AP组视图
interval:指定请求报文重传的时间间隔,取值范围为3~8,单位为秒。
为了使AC的请求报文尽可能的发送到AP,提高报文的可靠传输能力,AC会对请求报文进行重传,重传时间间隔为配置的请求报文重传时间。
# 配置AC发往AP的请求报文重传的时间间隔为6秒。(AP视图)
[Sysname-wlan-ap-ap3] retransmit-interval 6
# 配置AC发往AP的请求报文重传的时间间隔为6秒。(AP组视图)
[Sysname-wlan-ap-group-group1] retransmit-interval 6
·     retransmit-count
save wlan ap provision命令用来将预配置信息下发到AP。
save wlan ap provision { all | name ap-name }
all:将预配置信息下发到所有AP上。
name ap-name:将预配置信息下发到指定AP上,ap-name为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
·     本命令仅对已上线且与AC建立主隧道的AP生效。
·     如果在AC上新增或修改了预配置,则需要通过执行本命令将预配置下发到AP上,AP会将下发的预配置信息保存为私有预配置文件wlan_ap_prvs.xml,并立即生效。
·     如果provision视图未创建,执行save wlan ap-provision命令等效于reset wlan ap provision命令。
# 将AP provision视图下的预配置信息保存到AP1的预配置文件中。
[Sysname-wlan-ap-ap1-prvs] ac ip 192.168.0.1
[Sysname-wlan-ap-ap1-prvs] save wlan ap provision name ap1
serial-id命令用来配置AP序列号入组规则。
undo serial-id命令用来删除AP序列号入组规则。
serial-id serial-id
undo serial-id serial-id
未配置AP序列号入组规则。
AP组视图
serial-id:AP序列号,为1~63个字符的字符串,输入后的字母自动改为大写形式。
·     本命令不检查指定的AP是否存在。
·     同一AP组下AP序列号可配置多个。配置后符合该序列号的AP可以入组。
·     若其它组已经存在该序列号入组规则,在新组配置该序列号入组规则,则原AP组将删除该序列号入组规则。
·     默认组视图下不能进行该配置。
# 在AP组视图下添加序列号入组规则serial-id 219801A0YG8165E00001。
[Sysname-wlan-ap-group-group1] serial-id 219801A0YG8165E00001
·     wlan ap-group
serial-id命令用来配置AP的序列号。
undo serial-id命令用来恢复缺省情况。
serial-id serial-id
undo serial-id
未配置AP的序列号。
AP视图
serial-id:指定AP的序列号,序列号为每个AP的唯一标识,为1~63个字符的字符串,不区分大小写。
如果AP已经与AC建立CAPWAP隧道连接,改变和删除序列号将触发CAPWAP隧道的拆除,AP将会重新发现AC并与AC建立CAPWAP隧道。
# 将ap1的序列号设置为219801A0YG8165E00001。
[Sysname-ap-ap1] serial-id 219801A0YG8165E00001
snmp-agent trap enable wlan ap命令用来开启AP管理的告警功能。
undo snmp-agent trap enable wlan ap命令用来恢复缺省情况。
AP管理的告警功能处于关闭状态。
开启了告警功能之后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。(有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。)
# 开启AP管理的告警功能。
[Sysname] snmp-agent trap enable wlan ap
snmp-agent trap enable wlan capwap命令用来开启CAPWAP的告警功能。
undo snmp-agent trap enable wlan capwap命令用来恢复缺省情况。
CAPWAP的告警功能处于关闭状态。
# 开启CAPWAP的告警功能。
[Sysname] snmp-agent trap enable wlan capwap
statistics-interval命令用来配置AP向AC上报Radio统计信息的时间间隔。
undo statistics-interval命令用来恢复缺省情况。
statistics-interval interval
AP视图:继承AP组配置。
AP组视图:AP向AC上报Radio统计信息的时间间隔为50秒。
AP视图/AP组视图
interval:指定AP向AC上报Radio统计信息的时间间隔,取值范围为2~120,单位为秒。
为了对AP的运行情况进行有效监控,AP会周期性的向AC上报Radio统计信息。
# 配置ap1上报Radio统计信息的时间间隔为10秒。(AP视图)
[Sysname-wlan-ap-ap1] statistics-interval 10
# 配置AP上报Radio统计信息的时间间隔为10秒。(AP组视图)
[Sysname-wlan-ap-group-group1] statistics-interval 10
tunnel latency-detect命令用来配置CAPWAP隧道延迟检测。
tunnel latency-detect { start | stop }
未启动CAPWAP隧道延迟检测。
AP视图
start:启动CAPWAP隧道延迟检测。
stop:停止CAPWAP隧道延迟检测。
CAPWAP隧道延迟检测用于统计AP和AC之间的CAPWAP隧道延迟时间,便于及时了解CAPWAP隧道报文传输的延迟状况。
只有在AP和AC建立了CAPWAP隧道并且当前AC为主AC时,CAPWAP隧道延迟检测才会启动。
当AP下线,CAPWAP隧道延迟检测将自动停止。AP重新上线后,如果需要再次进行CAPWAP隧道延迟检测,则需要重新执行tunnel latency-detect start命令。
使用display wlan tunnel latency ap name命令查看CAPWAP隧道延迟检测信息。
# 启动CAPWAP隧道延迟检测。
[Sysname-wlan-ap-ap1] tunnel latency-detect start
1.1.51  wlan ap
wlan ap命令用来创建并进入AP视图。如果指定的AP已创建,则直接进入AP视图。
undo wlan ap命令用来删除指定的AP。
wlan ap ap-name [ model model-name ]
undo wlan ap ap-name
未创建手工AP。
ap-name:AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
model model-name:AP的型号名称,在创建AP时,该参数必须配置。
执行undo wlan ap命令时,如果AP已经与AC建立了CAPWAP隧道连接,则会导致隧道连接断开。
# 创建ap1。
1.1.52  wlan apdb
wlan apdb命令用来配置AP型号的软硬件版本对应关系。
undo wlan apdb命令用来恢复缺省情况。
wlan apdb model-name hardware-version software-version
undo wlan apdb model-name hardware-version
AP型号的硬件版本所对应的软件版本为APDB脚本文件中存储的软件版本。
model-name:配置指定AP型号的软硬件版本对应关系。
hardware-version:配置指定硬件版本所对应的软件版本。
software-version:AP软件版本,为1~31个字符的字符串,不区分大小写。
版本升级处于开启状态下,配置AP型号的软硬件版本对应关系后,AC将比较AP的软件版本与配置的软硬件版本关系是否一致。仅当期望AP使用的软件版本与APDB中存储的该AP型号对应的软件版本不一致时才需要配置本命令。
本命令通常用于向AP下发临时版本,建议用户不要自行配置,以免导致AP无法与AC建立CAPWAP隧道。
# 配置AP型号为WA4320H的硬件版本Ver.C对应的软件版本为E2108。
[Sysname] wlan apdb WA4320H Ver.C E2108
·     firmware-upgrade
wlan apdb file命令用来加载APDB用户脚本文件。
undo wlan apdb file命令用来卸载APDB用户脚本文件。
wlan apdb file user.apdb
undo wlan apdb file
未加载APDB用户脚本文件。
user.apdb:指定需要加载的APDB用户脚本文件名,为1~63个字符的字符串,区分大小写。apdb为文件后缀。
加载APDB用户脚本文件时,需要注意以下几点:
·     加载APDB脚本文件时,需要保证脚本文件的合法性,不合法的脚本文件会导致加载失败。
·     用户脚本中的AP型号加载时不能与系统脚本中AP型号重复。
·     用户脚本只能加载一个,多次加载用户脚本,最后一次加载的脚本生效。
·     若AC上已加载的脚本中某个AP型号已经被配置为手工AP或者已经存在上线的自动AP,则不允许重新加载脚本文件,需要将对应的AP型号删除后才能重新加载。
·     若已加载的脚本中的某个AP型号已经被加入AP组,则不允许重新加载脚本文件,需要将对应的AP型号从AP组删除后才能重新加载。
·     若在文件系统中将用户脚本文件进行重命名,需要重新加载脚本文件,否则当AC重启后将丢失对应该用户脚本文件的AP型号配置。
·     若在文件系统中将用户脚本文件进行替换,需要重新加载新脚本文件,如果新脚本中不包含被替换脚本中的AP型号信息,当AC重启后将丢失对应被替换脚本文件的AP型号配置。
·     若在文件系统中将用户脚本文件进行删除,当AC重启后将丢失该用户脚本文件的AP型号配置。
·     若旧脚本中的某个AP型号已经进行了软件版本配置,则不允许替换操作,需要使用wlan apdb命令将对应的软件版本还原到初始版本后才能重新加载。
# 加载名为user.apdb的用户脚本。
[Sysname] wlan apdb file user.apdb
·     wlan apdb
wlan ap-group命令用来创建AP组并进入AP组视图。
undo wlan ap-group命令用来删除一个AP组。
wlan ap-group group-name
undo wlan ap-group group-name
存在默认组default-group,不允许删除。
group-name:AP组的名称,为1~31个字符的字符串,不区分大小写。
# 创建一个名为group1的AP组。
wlan auto-ap enable命令用来开启自动AP功能。
undo wlan auto-ap enable命令用来关闭自动AP功能。
wlan auto-ap enable
自动AP功能处于关闭状态。
·     在无线网络中部署的AP数量较多时,使用自动AP功能可以减少管理员的配置工作量,并可以简化配置,避免多次配置AP序列号,同时降低了配置出错的概率。
·     自动AP不能单独配置,需要固化为手工AP或者通过AP Group进行配置。
# 开启自动AP功能。
[Sysname] wlan auto-ap enable
wlan auto-ap persistent命令用来将自动AP固化为手工AP。
wlan auto-ap persistent { all | name auto-ap-name [ new-ap-name ] }
all:将所有自动AP固化为手工AP,AP名称保持不变。
auto-ap-name:自动AP的名称。
new-ap-name:固化为手工AP以后的AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。如果未指定本参数,则表示将名称为auto-ap-name的自动AP固化为手工AP,且其名称保持不变。
使用自动AP固化功能后,可以对固化后的手工AP进行配置。
# 将自动AP转换为固化AP,转换后的固化AP的名称为ap2。
[Sysname] wlan auto-ap persistent name 0001-ab12-cd36 ap2
wlan auto-persistent enable命令用来开启自动固化功能。
undo wlan auto-persistent enable命令用来关闭自动固化功能。
自动固化功能处于关闭状态。
该命令仅对配置本命令后上线的自动AP生效,对于已上线的自动AP,只能使用wlan auto-ap persistent命令将自动AP固化为手工AP。
# 开启自动固化功能。
[Sysname] wlan auto-persistent enable
wlan capwap discovery-policy unicast命令用来开启单播发现策略功能。
undo wlan capwap discovery-policy命令用来恢复缺省情况。
单播发现策略功能处于关闭状态。
AP可以通过单播、组播及广播三种方式发现AC并建立CAPWAP隧道。开启了单播发现策略功能后,AC只对发送单播Discovery request报文的AP进行响应,不对发送组播、广播Discovery request报文的AP进行响应,即只允许单播发现的AP与AC建立CAPWAP隧道连接。
# 开启单播发现策略功能。
[Sysname] wlan capwap discovery-policy unicast
wlan global-configuration命令用来进入全局配置视图。
AP的生效配置取决于AP、AP组及全局配置中优先级最高的配置,优先级从高到低为AP视图配置、AP组视图配置、全局视图配置。若优先级高的配置不存在,则AP使用优先级低的配置。若都不存在AP的配置,则使用优先级最低的视图下的缺省值。
# 进入全局配置视图。
wlan image-load filepath命令用来配置AC向AP下发版本时,优先获取AP镜像文件的位置。
undo wlan image-load filepath命令用来恢复缺省情况。
wlan image-load filepath { local | ram }
AC优先获取内存中的AP镜像文件下发给AP。
local:指定AC优先获取本地文件夹中的AP镜像文件,若本地文件夹中没有AP镜像文件,再从内存中获取,若AC内存中也没有AP镜像文件,则获取AP镜像文件失败。
ram:指定AC优先获取内存中的AP镜像文件,若内存中没有AP镜像文件,再从本地文件夹中获取,若本地文件夹中也没有AP镜像文件,则获取AP镜像文件失败。
AC内存中的AP镜像文件来自于AC镜像文件,AC设备启动后会将AP镜像文件读取到内存中。
只有存放在文件系统根路径下的AP镜像文件,才能被AC从本地文件夹中获取并下发给AP。
仅在以下两种情况下,才需要将AP镜像文件放至本地文件夹,并将AC优先获取AP镜像文件的位置指定为本地文件夹。
·     AC镜像文件中缺少所需的AP镜像文件。
·     通过修改AP软硬件版本关系来指定AP上线时使用的软件版本。
本命令仅在以CF卡为缺省文件系统的AC设备上生效。
仅能将格式为.ipe的AP镜像文件下发给AP。
# 指定AC优先获取本地文件夹中的AP镜像文件下发给AP。
[Sysname] wlan image-load filepath local
wlan re-group命令用于将一个或者一组AP规则迁移到指定AP组。
wlan re-group { ap ap-name | ap-group old-group-name | mac-address mac-address | serial-id serial-id } group-name
ap ap-name:将指定的AP名字入组规则迁移到目的AP组。
ap-group old-group-name:将指定的AP组的入组规则迁移到目的AP组。old-group-name不能是默认组。
mac-address mac-address:将指定的MAC地址入组规则迁移到目的AP组。
serial-id serial-id:将指定的序列号地址入组规则迁移到目的AP组。
group-name:目的AP组名字,不能是默认组。
# 创建AP组group1与group2,在group1下配置三个AP名字规则ap1、ap2、ap3,并将ap1移至group2。
[Sysname-wlan-ap-group-group1] quit
[Sysname] wlan ap-group group2
[Sysname-wlan-ap-group-group2] quit
[Sysname] wlan re-group ap ap1 group2
wlan rename-ap命令用来重命名指定的手工AP。
wlan rename-ap ap-name new-ap-name
ap-name:AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。ap-name不能为自动AP的名称。
new-ap-name:重命名后的AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。new-ap-name不能和已有的AP名称相同。
# 重命名手工ap1的名称为ap1-office。
[Sysname] wlan rename-ap ap1 ap1-office
