15-IPv6 PIM命令
本章节下载: 15-IPv6 PIM命令 (378.11 KB)
1.1.1 bidir-pim enable (IPv6 PIM view)
1.1.2 bsm-fragment enable (IPv6 PIM view)
1.1.3 bsr-policy (IPv6 PIM view)
1.1.5 c-bsr admin-scope (IPv6 PIM view)
1.1.6 c-bsr hash-length (IPv6 PIM view)
1.1.7 c-bsr holdtime (IPv6 PIM view)
1.1.8 c-bsr interval (IPv6 PIM view)
1.1.9 c-bsr priority (IPv6 PIM view)
1.1.12 c-rp advertisement-interval (IPv6 PIM view)
1.1.13 c-rp holdtime (IPv6 PIM view)
1.1.14 crp-policy (IPv6 PIM view)
1.1.15 display pim ipv6 bsr-info
1.1.16 display pim ipv6 claimed-route
1.1.17 display pim ipv6 control-message counters
1.1.18 display pim ipv6 df-info
1.1.19 display pim ipv6 grafts
1.1.20 display pim ipv6 interface
1.1.21 display pim ipv6 join-prune
1.1.22 display pim ipv6 neighbor
1.1.23 display pim ipv6 routing-table
1.1.24 display pim ipv6 rp-info
1.1.27 hello-option dr-priority (IPv6 PIM view)
1.1.28 hello-option holdtime (IPv6 PIM view)
1.1.29 hello-option lan-delay (IPv6 PIM view)
1.1.30 hello-option neighbor-tracking (IPv6 PIM view)
1.1.31 hello-option override-interval (IPv6 PIM view)
1.1.32 holdtime assert (IPv6 PIM view)
1.1.33 holdtime join-prune (IPv6 PIM view)
1.1.34 jp-pkt-size (IPv6 PIM view)
1.1.35 jp-queue-size (IPv6 PIM view)
1.1.40 pim ipv6 hello-option dr-priority
1.1.41 pim ipv6 hello-option holdtime
1.1.42 pim ipv6 hello-option lan-delay
1.1.43 pim ipv6 hello-option neighbor-tracking
1.1.44 pim ipv6 hello-option override-interval
1.1.45 pim ipv6 holdtime assert
1.1.46 pim ipv6 holdtime join-prune
1.1.47 pim ipv6 neighbor-policy
1.1.50 pim ipv6 state-refresh-capable
1.1.51 pim ipv6 timer graft-retry
1.1.53 pim ipv6 timer join-prune
1.1.54 pim ipv6 triggered-hello-delay
1.1.55 probe-interval (IPv6 PIM view)
1.1.56 prune delay (IPv6 PIM view)
1.1.57 register-policy (IPv6 PIM view)
1.1.58 register-suppression-timeout (IPv6 PIM view)
1.1.59 register-whole-checksum (IPv6 PIM view)
1.1.60 reset pim ipv6 control-message counters
1.1.61 source-lifetime (IPv6 PIM view)
1.1.62 source-policy (IPv6 PIM view)
1.1.63 spt-switch-threshold infinity (IPv6 PIM view)
1.1.64 ssm-policy (IPv6 PIM view)
1.1.66 state-refresh-interval (IPv6 PIM view)
1.1.67 state-refresh-rate-limit (IPv6 PIM view)
1.1.68 static-rp (IPv6 PIM view)
1.1.69 timer hello (IPv6 PIM view)
1.1.70 timer join-prune (IPv6 PIM view)
· 本文所指的路由器代表运行了路由协议的三层设备。
· IPv6 PIM功能中所指的“接口”为三层口,包括VLAN接口、三层以太网端口等。三层以太网端口是指被配置为三层模式的以太网端口,有关以太网端口模式切换的操作,请参见“二层技术-以太网交换配置指导”中的“以太网端口配置”。
bidir-pim enable
undo bidir-pim enable
IPv6 PIM视图
【缺省级别】
2:系统级
无
【描述】
bidir-pim enable命令用来使能IPv6双向PIM。undo bidir-pim enable命令用来关闭IPv6双向PIM。
缺省情况下,IPv6双向PIM处于关闭状态。
需要注意的是,只有在设备上先使能了IPv6组播路由,本命令才能生效。
相关配置可参考命令pim ipv6,以及“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 routing-enable。
# 使能IPv6组播路由,进入IPv6 PIM视图。
[Sysname] multicast ipv6 routing-enable
[Sysname] pim ipv6
[Sysname-pim6] bidir-pim enable
bsm-fragment enable
undo bsm-fragment enable
IPv6 PIM视图
【缺省级别】
2:系统级
无
【描述】
bsm-fragment enable命令用来使能自举报文语义分片功能。undo bsm-fragment enable命令用来关闭自举报文语义分片功能。
缺省情况下,自举报文语义分片功能处于使能状态。
需要注意的是,当IPv6 PIM-SM域中存在不支持自举报文语义分片的设备时,请关闭本功能。
相关配置可参考命令c-bsr admin-scope。
# 关闭自举报文语义分片功能。
[Sysname] pim ipv6
[Sysname-pim6] undo bsm-fragment enable
bsr-policy acl6-number
undo bsr-policy
IPv6 PIM视图
【缺省级别】
2:系统级
acl6-number:指定基本IPv6访问控制列表编号,取值范围为2000~2999。在定义该IPv6 ACL时,使用rule命令中的source参数来指定合法BSR的源IPv6地址范围。
【描述】
bsr-policy命令用来配置合法的BSR地址范围,以防止BSR欺骗。undo bsr-policy命令用来取消BSR地址范围的限制。
缺省情况下,BSR的地址范围不受任何限制,即认为来自任意源的自举报文都是合法的。
# 配置合法的BSR地址范围,只允许网段2001::2/64中的设备充当BSR。
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source 2001::2 64
[Sysname-acl6-basic-2000] quit
[Sysname] pim ipv6
[Sysname-pim6] bsr-policy 2000
c-bsr ipv6-address [ hash-length [ priority ] ]
undo c-bsr
IPv6 PIM视图
【缺省级别】
2:系统级
ipv6-address:指定接口的IPv6地址,将该接口配置为C-BSR。
hash-length:指定哈希掩码长度,取值范围为0~128。如果未指定本参数,则取相应的全局值。
priority:指定该C-BSR的优先级,取值范围为0~255。数值越大,优先级越高。如果未指定本参数,则取相应的全局值。
【描述】
c-bsr命令用来配置某接口为C-BSR。undo c-bsr命令用来删除C-BSR的相关配置。
缺省情况下,没有配置C-BSR。
需要注意的是,充当C-BSR的接口上必须使能IPv6 PIM-SM。
相关配置可参考命令pim ipv6 sm、c-bsr hash-length、c-bsr priority和c-rp。
# 配置IPv6地址1101::1为C-BSR。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr 1101::1
c-bsr admin-scope
undo c-bsr admin-scope
IPv6 PIM视图
【缺省级别】
2:系统级
无
【描述】
c-bsr admin-scope命令用来使能IPv6管理域机制。undo c-bsr admin-scope命令用来关闭IPv6管理域机制。
缺省情况下,IPv6管理域机制处于关闭状态,即每个IPv6 PIM-SM域中只能有一个BSR。
相关配置可参考命令c-bsr和c-bsr scope。
# 使能IPv6管理域机制。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr admin-scope
c-bsr hash-length hash-length
undo c-bsr hash-length
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
c-bsr hash-length命令用来配置哈希掩码长度的全局值。undo c-bsr hash-length命令用来恢复缺省情况。
缺省情况下,哈希掩码长度为126。
相关配置可参考命令c-bsr。
# 配置哈希掩码长度的全局值为16。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr hash-length 16
c-bsr holdtime interval
undo c-bsr holdtime
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定自举超时时间,取值范围为1~2147483647,单位为秒。
【描述】
c-bsr holdtime命令用来配置自举超时时间,即C-BSR等待接收来自BSR的自举报文的超时时间。undo c-bsr holdtime命令用来恢复缺省情况。
缺省情况下,自举超时时间由如下公式决定:自举超时时间=自举时间间隔×2+10。
缺省情况下,自举时间间隔为60秒,则自举超时时间的缺省值=60×2+10=130(秒)。
相关配置可参考命令c-bsr和c-bsr interval。
# 配置自举超时时间为150秒。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr holdtime 150
c-bsr interval interval
undo c-bsr interval
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定自举时间间隔,取值范围为10~2147483647,单位为秒。
【描述】
c-bsr interval命令用来配置自举时间间隔,即BSR发送自举报文的时间间隔。undo c-bsr interval命令用来恢复缺省情况。
缺省情况下,自举时间间隔由如下公式决定:自举时间间隔=(自举超时时间-10)÷2。
缺省情况下,自举超时时间为130秒,则自举时间间隔的缺省值=(130-10)÷2=60(秒)。
相关配置可参考命令c-bsr和c-bsr holdtime。
# 配置自举时间间隔为30秒。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr interval 30
c-bsr priority priority
undo c-bsr priority
IPv6 PIM视图
【缺省级别】
2:系统级
priority:指定C-BSR的优先级,取值范围为0~255。该数值越大,优先级越高。
【描述】
c-bsr priority命令用来配置C-BSR优先级的全局值。undo c-bsr priority命令用来恢复缺省情况。
缺省情况下,C-BSR的优先级为64。
相关配置可参考命令c-bsr。
# 配置C-BSR优先级的全局值为5。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr priority 5
c-bsr scope { scope-id | admin-local | global | organization-local | site-local } [ hash-length hash-length | priority priority ] *
undo c-bsr scope { scope-id | admin-local | global | organization-local | site-local }
IPv6 PIM视图
【缺省级别】
2:系统级
scope-id:指定Scope字段的值,取值范围为3~15。
admin-local:指定Scope字段为管理本地范围,对应的Scope值为4。
global:指定Scope字段为全球范围,对应的Scope值为14。
organization-local:指定Scope字段为机构本地范围,对应的Scope值为8。
site-local:指定Scope字段为站点本地范围,对应的Scope值为5。
hash-length:指定某Scope值所对应IPv6管理域中的哈希掩码长度,取值范围为0~128。如果未指定本参数,则取相应的全局值。
priority:指定某Scope值所对应IPv6管理域中C-BSR的优先级,取值范围为0~255。数值越大,优先级越高。如果未指定本参数,则取相应的全局值。
【描述】
c-bsr scope命令用来配置IPv6管理域的C-BSR。undo c-bsr scope命令用来删除IPv6管理域C-BSR的配置。
缺省情况下,没有配置IPv6管理域的C-BSR。
相关配置可参考命令c-bsr admin-scope、c-bsr hash-length和c-bsr priority。
# 配置本设备为Scope值为全球范围时所对应IPv6管理域的C-BSR,其优先级为10。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr scope global priority 10
c-rp ipv6-address [ { group-policy acl6-number | scope scope-id } | priority priority | holdtime hold-interval | advertisement-interval adv-interval ] * [ bidir ]
undo c-rp ipv6-address
IPv6 PIM视图
【缺省级别】
2:系统级
ipv6-address:指定接口的IPv6地址,将该接口配置为C-RP。
acl6-number:指定基本IPv6访问控制列表号,取值范围为2000~2999。该IPv6 ACL规则并不用来进行匹配过滤,而是定义了该C-RP所服务的IPv6组播组范围,只要是permit的IPv6组播组都会作为RP的服务组范围通告出去,其它诸如deny等的配置不起作用。
priority:指定C-RP的优先级,取值范围为0~255,缺省值为192。该数值越大,优先级越低。
hold-interval:指定C-RP的超时时间,取值范围为1~65535,单位为秒。如果未指定本参数,则取相应的全局值。
adv-interval:指定发送宣告报文的间隔时间,取值范围为1~65535,单位为秒。如果未指定本参数,则取相应的全局值。
bidir:指定该C-RP服务于IPv6双向PIM。如果未指定本参数,该C-RP将服务于IPv6 PIM-SM。
【描述】
c-rp命令用来配置某接口为C-RP。undo c-rp命令用来删除C-RP的相关配置。
缺省情况下,没有配置C-RP。
· 充当C-RP的接口上必须使能IPv6 PIM-SM。
· 若没有为C-RP指定其所服务的IPv6组播组范围,在IPv6非管理域机制下,该C-RP将为所有IPv6组播组服务;而在IPv6管理域机制下,该C-RP将为IPv6 Global域服务。
· 如果设备想要成为多个组范围的C-RP,则需要在配置group-policy所对应的IPv6 ACL时将多个组范围用多个rule规则表示出来。
· 如果对于同一接口多次执行本命令,则最新配置将覆盖旧配置。
相关配置可参考命令c-bsr。
# 配置IPv6地址为2001::1的接口为组播组FF0E:0:1391::/96的C-RP,C-RP的优先级为10。
[Sysname-acl6-basic-2000] rule permit source ff0e:0:1391:: 96
[Sysname] pim ipv6
[Sysname-pim6] c-rp 2001::1 group-policy 2000 priority 10
c-rp advertisement-interval interval
undo c-rp advertisement-interval
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定发送宣告报文的时间间隔,取值范围为1~65535,单位为秒。
【描述】
c-rp advertisement-interval命令用来配置发送宣告报文时间间隔的全局值。undo c-rp advertisement-interval命令用来恢复缺省情况。
缺省情况下,发送宣告报文的时间间隔为60秒。
相关配置可参考命令c-rp。
# 配置发送宣告报文时间间隔的全局值为30秒。
[Sysname] pim ipv6
[Sysname-pim6] c-rp advertisement-interval 30
c-rp holdtime interval
undo c-rp holdtime
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
c-rp holdtime命令用来配置C-RP超时时间的全局值,即BSR等待接收来自C-RP的宣告报文的超时时间。undo c-rp holdtime命令用来恢复缺省情况。
缺省情况下,C-RP的超时时间为150秒。
需要注意的是,由于非BSR通过BSR自举报文来更新C-RP的超时时间,所以在配置时,C-RP的超时时间不要小于BSR发送自举报文的时间间隔,且最好为该间隔的2.5倍以上,以防止BSR自举报文中的C-RP信息丢失。
相关配置可参考命令c-rp和c-bsr interval。
# 配置C-RP超时时间的全局值为200秒。
[Sysname] pim ipv6
[Sysname-pim6] c-rp holdtime 200
crp-policy acl6-number
undo crp-policy
IPv6 PIM视图
【缺省级别】
2:系统级
acl6-number:指定高级IPv6访问控制列表编号,取值范围为3000~3999。在定义该IPv6 ACL时,使用rule命令中的source参数来指定C-RP的IPv6地址,destination参数来指定该C-RP所服务的IPv6组播组地址范围。
【描述】
crp-policy命令用来配置合法的C-RP地址范围及其所服务的IPv6组播组范围,以防止C-RP欺骗。undo crp-policy命令用来取消C-RP地址范围及其所服务的IPv6组播组范围的限制。
缺省情况下,C-RP地址范围及其所服务的IPv6组播组范围不受任何限制,即认为所有收到的C-RP报文都是合法的。
需要注意的是,本命令在对C-RP所宣告的IPv6组播组范围进行过滤时,只依据其组前缀进行过滤。譬如,当C-RP宣告的IPv6组播组范围为FF0E:0:1::/96,crp-policy命令所规定的合法IPv6组播组范围为FF0E:0:1::/120时,最终通过过滤的IPv6组播组范围为FF0E:0:1::/96。
相关配置可参考命令c-rp。
# 配置C-RP策略,只允许2001::2/64范围内的设备充当C-RP,且只允许其为FF03::101/64范围内的IPv6组播组服务。
[Sysname-acl6-adv-3000] rule permit ipv6 source 2001::2 64 destination ff03::101 64
[Sysname-acl6-adv-3000] quit
[Sysname] pim ipv6
[Sysname-pim6] crp-policy 3000
display pim ipv6 bsr-info [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display pim ipv6 bsr-info命令用来查看IPv6 PIM-SM域中的BSR信息,以及本地配置并生效的C-RP信息。
相关配置可参考命令c-bsr和c-rp。
# 查看IPv6 PIM-SM域中的BSR信息,以及本地配置并生效的C-RP信息。
<Sysname> display pim ipv6 bsr-info
Elected BSR Address: 2004::2
Priority: 64
Hash mask length: 126
State: Elected
Scope: 14
Uptime: 00:01:10
Next BSR message scheduled at: 00:00:48
Candidate BSR Address: 2004::2
Priority: 64
State: Elected
Scope: 14
Candidate RP: 2001::1(LoopBack1)
Priority: 192
HoldTime: 130
Advertisement Interval: 60
Next advertisement scheduled at: 00:00:48
Candidate RP: 2002::1(Vlan-interface1)
Priority: 200
HoldTime: 90
Advertisement Interval: 50
Next advertisement scheduled at: 00:00:28
Candidate RP: 2003::1(Vlan-interface2)
Priority: 192
HoldTime: 80
表1-1 display pim ipv6 bsr-info命令显示信息描述表
Elected BSR Address |
当选BSR的IPv6地址 |
Candidate BSR Address |
候选BSR的地址 |
Priority |
BSR的优先级 |
Hash mask length |
哈希掩码长度 |
State |
BSR的状态 |
Scope |
BSR所服务的IPv6管理域 |
Uptime |
BSR已经存在的时间 |
Next BSR message scheduled at |
BSR超时剩余时间 |
Candidate RP |
候选RP的地址 |
Priority |
候选RP的优先级 |
HoldTime |
候选RP的超时时间 |
Advertisement Interval |
候选RP发送宣告报文时间间隔 |
Next advertisement scheduled at |
候选RP发送下一个宣告报文的剩余时间 |
display pim ipv6 claimed-route [ ipv6-source-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ipv6-source-address:组播源的IPv6地址,查看到达指定组播源的IPv6单播路由信息。如果未指定本参数,将显示IPv6 PIM所使用的所有IPv6单播路由信息。
【描述】
display pim ipv6 claimed-route命令用来查看IPv6 PIM所使用的IPv6单播路由信息。
如果某(S,G)表项的标志是SPT,则该(S,G)表项会使用IPv6单播路由。
# 查看IPv6 PIM使用的所有IPv6单播路由信息。
<Sysname> display pim ipv6 claimed-route
RPF information about: 2001::2
RPF interface: Vlan-interface1, RPF neighbor: FE80::A01:100:1
Referenced prefix/prefix length: 2001::/64
Referenced route type: igp
RPF-route selecting rule: preference-preferred
The (S, G) or (*, G) list dependent on this route entry
(2001::2, FF03::101)
表1-2 display pim ipv6 claimed-route命令显示信息描述表
RPF information about: 2001::2 |
到IPv6组播源2001::2的RPF路由信息 |
RPF interface |
RPF接口的名称和编号 |
RPF neighbor |
RPF邻居的IPv6地址 |
Referenced prefix/prefix length |
所用的路由项 |
Referenced route type |
所引用的路由类型,可以是下列类型之一: · igp:IPv6单播路由(内部网关协议) · egp:IPv6单播路由(外部网关协议) · unicast (direct):IPv6单播路由(直连) · unicast:其它IPv6单播路由(如IPv6单播静态路由等) · mbgp:IPv6 MBGP路由 |
RPF-route selecting rule |
RPF路由的选择规则 |
The (S,G) or (*,G) list dependent on this route entry |
基于此RPF路由的(S,G)或(*,G)列表 |
display pim ipv6 control-message counters [ message-type { probe | register | register-stop } | [ interface interface-type interface-number | message-type { assert | bsr | crp | graft | graft-ack | hello | join-prune | state-refresh } ] * ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
probe:查看空注册报文的数量。
register:查看注册报文的数量。
register-stop:查看注册停止报文的数量。
interface-type interface-number:接口类型和接口编号,查看指定接口上的IPv6 PIM控制报文数量。
assert:查看断言报文的数量。
bsr:查看自举报文的数量。
crp:查看宣告报文的数量。
graft:查看嫁接报文的数量。
graft-ack:查看嫁接应答报文的数量。
hello:查看Hello报文的数量。
join-prune:查看加入/剪枝报文的数量。
state-refresh:查看状态刷新报文的数量。
【描述】
display pim ipv6 control-message counters命令用来查看IPv6 PIM控制报文的数量。
# 查看所有接口上所有类型的IPv6 PIM控制报文数量。
<Sysname> display pim ipv6 control-message counters
PIM global control-message counters:
Received Sent Invalid
Register 20 37 2
Register-Stop 25 20 1
Probe 10 5 0
PIM control-message counters for interface: Vlan-interface1
Assert 10 5 0
Graft 20 37 2
Graft-Ack 25 20 1
Hello 1232 453 0
Join/Prune 15 30 21
State-Refresh 8 7 1
BSR 3243 589 1
C-RP 53 32 0
表1-3 display pim ipv6 control-message counters命令显示信息描述表
PIM global control-message counters |
统计IPv6 PIM全局控制报文 |
PIM control-message counters for interface |
统计IPv6 PIM控制报文的接口 |
Received |
收到的报文数量 |
Sent |
发送的报文数量 |
Invalid |
无效报文的数量 |
Register |
注册报文 |
Register-Stop |
注册停止报文 |
Probe |
空注册报文 |
Assert |
断言报文 |
Graft |
嫁接报文 |
Graft-Ack |
嫁接应答报文 |
Hello |
Hello报文 |
Join/Prune |
加入/剪枝报文 |
State Refresh |
状态刷新报文 |
BSR |
自举报文 |
C-RP |
宣告报文 |
display pim ipv6 df-info [ rp-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
rp-address:指定IPv6双向PIM的RP地址。
【描述】
display pim ipv6 df-info命令用来查看IPv6双向PIM的DF信息。
# 查看IPv6双向PIM的DF信息。
<Sysname> display pim ipv6 df-info
RP Address: 2010::1
Interface State DF-Pref DF-Metric DF-Uptime DF-Address
Vlan1 Win 100 1 01:24:09 FE80::20F:E2FF:
FE38:4E01 (local)
Vlan2 Win 100 1 01:24:09 FE80::200:5EFF:
FE71:2801 (local)
Vlan3 Lose 0 0 01:23:12 FE80::20F:E2FF:
FE15:5601
表1-4 display pim ipv6 df-info命令显示信息描述表
RP Address |
IPv6双向PIM的RP地址 |
接口名称 |
State |
DF的选举状态: · Win:表示获选 · Lose:表示落选 |
DF-Pref |
DF通告的路由优先级 |
DF-Metric |
DF通告的路由度量值 |
DF-Uptime |
DF的存在时间 |
DF-Address |
DF的IPv6地址,local表示为本地地址 |
display pim ipv6 grafts [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display pim ipv6 grafts命令用来查看尚未确认的IPv6 PIM-DM嫁接信息。
# 查看尚未确认的IPv6 PIM-DM嫁接信息。
<Sysname> display pim ipv6 grafts
Source Group Age RetransmitIn
1004::2 ff03::101 00:00:24 00:00:02
表1-5 display pim ipv6 grafts命令显示信息描述表
Source |
嫁接报文中的IPv6组播源地址 |
Group |
嫁接报文中的IPv6组播组地址 |
Age |
嫁接报文的老化剩余时间 |
RetransmitIn |
重发嫁接报文的剩余时间 |
display pim ipv6 interface [ interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:接口类型和接口编号,查看指定接口上的IPv6 PIM信息。
verbose:查看IPv6 PIM接口的详细信息。
【描述】
display pim ipv6 interface命令用来查看接口上的IPv6 PIM信息。
# 查看接口Vlan-interface1上的IPv6 PIM详细信息。
<Sysname> display pim ipv6 interface vlan-interface 1 verbose
Interface: Vlan-interface1, FE80::200:5EFF:FE04:8700
PIM version: 2
PIM mode: Sparse
PIM DR: FE80::200:AFF:FE01:101
PIM DR Priority (configured): 1
PIM neighbor count: 1
PIM hello interval: 30 s
PIM LAN delay (negotiated): 500 ms
PIM LAN delay (configured): 500 ms
PIM override interval (negotiated): 2500 ms
PIM override interval (configured): 2500 ms
PIM neighbor tracking (negotiated): disabled
PIM neighbor tracking (configured): disabled
PIM generation ID: 0xF5712241
PIM require generation ID: disabled
PIM hello hold interval: 105 s
PIM assert hold interval: 180 s
PIM triggered hello delay: 5 s
PIM J/P interval: 60 s
PIM J/P hold interval: 210 s
PIM BSR domain border: disabled
Number of routers on network not using DR priority: 0
Number of routers on network not using LAN delay: 0
Number of routers on network not using neighbor tracking: 2
表1-6 display pim ipv6 interface命令显示信息描述表
接口名称与IPv6地址 |
PIM version |
IPv6 PIM协议的版本号 |
PIM mode |
IPv6 PIM协议的模式,是密集模式还是稀疏模式 |
PIM DR |
DR的IPv6地址 |
PIM DR Priority (configured) |
竞选DR的优先级 |
PIM neighbor count |
IPv6 PIM邻居的总数 |
PIM hello interval |
发送IPv6 PIM Hello报文的时间间隔 |
PIM LAN delay (negotiated) |
发送剪枝报文延迟时间的协商值 |
PIM LAN delay (configured) |
发送剪枝报文延迟时间的配置值 |
PIM override interval (negotiated) |
剪枝否决时间的协商值 |
PIM override interval (configured) |
剪枝否决时间的配置值 |
PIM neighbor tracking (negotiated) |
邻居跟踪使能与否的协商情况 |
PIM neighbor tracking (configured) |
邻居跟踪使能与否的配置情况 |
PIM generation ID |
Generation_ID参数值 |
PIM require generation ID |
是否使能不接受无Generation ID的Hello报文 |
PIM hello hold interval |
保持IPv6 PIM邻居的可达状态的时间 |
PIM assert hold interval |
保持断言状态的时间 |
PIM triggered hello delay |
发送Hello报文的最大延迟时间 |
PIM J/P interval |
发送加入/剪枝报文的时间间隔 |
PIM J/P hold interval |
保持加入/剪枝状态的时间 |
PIM BSR domain border |
该接口是否配置了BSR的服务边界 |
Number of routers on network not using DR priority |
该接口所在网段上没有使用DR优先级字段的路由器数量 |
Number of routers on network not using LAN delay |
该接口所在网段上未使用LAN-delay字段的路由器数量 |
Number of routers on network not using neighbor tracking |
该接口所在网段上未使能邻居跟踪的路由器数量 |
display pim ipv6 join-prune mode { sm [ flags flag-value ] | ssm } [ interface interface-type interface-number | neighbor ipv6-neighbor-address ] * [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
mode:查看指定IPv6 PIM模式下待发送的加入/剪枝报文信息。IPv6 PIM模式包括sm和ssm,分别表示IPv6 PIM-SM和IPv6 PIM-SSM类型的路由项。
flags flag-value:查看含有指定标志的IPv6 PIM路由表项。flag-value的取值及含义如下:
· rpt:表示共享树上的路由表项;
· spt:表示最短路径树上的路由表项;
· wc:表示带WC通配符的路由表项。
interface-type interface-number:接口类型和接口编号,查看指定接口上待发送的加入/剪枝报文信息。
ipv6-neighbor-address:PIM邻居的IPv6地址,查看待发送给指定IPv6 PIM邻居的加入/剪枝报文信息。
verbose:查看待发送的加入/剪枝报文的详细信息。
【描述】
display pim ipv6 join-prune命令用来查看待发送的加入/剪枝报文信息。
# 查看IPv6 PIM-SM模式下待发送的加入/剪枝报文信息。
<Sysname> display pim ipv6 join-prune mode sm
Expiry Time: 50 sec
Upstream nbr: FE80::2E0:FCFF:FE03:1004 (Vlan-interface1)
1 (*, G) join(s), 0 (S, G) join(s), 1 (S, G, rpt) prune(s)
Total (*, G) join(s): 1, (S, G) join(s): 0, (S, G, rpt) prune(s): 1
表1-7 display pim ipv6 join-prune命令显示信息描述表
Expiry Time: |
发送加入/剪枝报文的剩余时间 |
Upstream nbr: |
上游IPv6 PIM邻居的IPv6地址和所在接口 |
(*, G) join(s) |
待发送的(*,G)加入项数量 |
(S, G) join(s) |
待发送的(S,G)加入项数量 |
(S, G, rpt) prune(s) |
待发送的(S,G,rpt)剪枝项数量 |
display pim ipv6 neighbor [ interface interface-type interface-number | ipv6-neighbor-address | verbose ] * [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:接口类型和接口编号,查看指定接口上的IPv6 PIM邻居信息。
ipv6-neighbor-address:PIM邻居的IPv6地址,查看指定IPv6 PIM邻居的信息。
verbose:查看IPv6 PIM邻居的详细信息。
【描述】
display pim ipv6 neighbor命令用来查看IPv6 PIM邻居信息。
# 查看所有IPv6 PIM邻居的信息。
<Sysname> display pim ipv6 neighbor
Total Number of Neighbors = 2
Neighbor Interface Uptime Expires Dr-Priority Mode
FE80::A01:101:1 Vlan1 02:50:49 00:01:31 1 B
FE80::A01:102:1 Vlan2 02:49:39 00:01:42 1 B
# 查看IPv6地址为FE80::A01:101:1的IPv6 PIM邻居的详细信息。
<Sysname> display pim ipv6 neighbor fe80::a01:101:1 verbose
Neighbor: FE80::A01:101:1
Interface: Vlan-interface3
Uptime: 00:00:10
Expiry time: 00:00:30
DR Priority: 1
Generation ID: 0x2ACEFE15
Holdtime: 105 s
LAN delay: 500 ms
Override interval: 2500 ms
State refresh interval: 60 s
Neighbor tracking: Disabled
Bidirectional PIM: Disabled
Neighbor Secondary Address(es):
1::1
表1-8 display pim ipv6 neighbor命令显示信息描述表
Total Number of Neighbors |
IPv6 PIM邻居的总数 |
Neighbor |
IPv6 PIM邻居的IPv6主地址(链路本地地址) |
IPv6 PIM邻居所在接口的名称 |
Uptime |
IPv6 PIM邻居已存在的时间 |
Expires/Expiry time |
IPv6 PIM邻居超时的剩余时间,never表示IPv6 PIM邻居永不超时,即永远可达 |
Dr-Priority/DR Priority |
IPv6 PIM邻居的优先级 |
Mode |
IPv6 PIM邻居的模式,B表示IPv6双向PIM模式,显示为空则表示非IPv6双向PIM模式 |
Generation ID |
IPv6 PIM邻居的Generation ID(状态随机数) |
Holdtime |
IPv6 PIM邻居的生存时间,forever表示IPv6 PIM邻居永远存在,即永远可达 |
LAN delay |
发送剪枝报文的延迟时间 |
Override interval |
剪枝否决的时间间隔 |
State refresh interval |
状态刷新的时间间隔,只有当IPv6 PIM邻居工作在IPv6 PIM-DM模式下且具备状态刷新能力时才会显示本字段 |
Neighbor tracking |
邻居跟踪功能是否已使能 |
Bidirectional PIM |
IPv6双向PIM是否已使能 |
Neighbor Secondary Address(es) |
IPv6 PIM邻居的IPv6从地址(非链路本地地址) |
display pim ipv6 routing-table [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | incoming-interface [ interface-type interface-number | register ] | outgoing-interface { include | exclude | match } { interface-type interface-number | register } | mode mode-type | flags flag-value | fsm ] * [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ipv6-group-address:IPv6组播组地址,查看指定IPv6组播组的IPv6 PIM路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
ipv6-source-address:IPv6组播源地址,查看包含指定IPv6组播源的IPv6 PIM路由项。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
incoming-interface:查看指定入接口的IPv6 PIM路由项。
interface-type interface-number:查看指定接口类型和接口编号的入接口的IPv6 PIM路由项。
register:查看入接口为IPv6 PIM-SM注册接口的IPv6 PIM路由项。本参数只有在未指定mode-type,或mode-type取sm时才有效。
outgoing-interface:查看指定出接口的IPv6 PIM路由项。
include:查看出接口列表中包含指定接口的IPv6 PIM路由项。
exclude:查看出接口列表中不包含指定接口的IPv6 PIM路由项。
match:查看出接口列表中包含且仅包含指定接口的IPv6 PIM路由项。
mode mode-type:IPv6 PIM模式,查看指定模式下的IPv6 PIM路由项。mode-type的取值及含义如下:
· dm:表示IPv6 PIM-DM模式;
· sm:表示IPv6 PIM-SM模式;
· ssm:表示IPv6 PIM-SSM模式。
flags flag-value:IPv6 PIM标志,查看包含指定标志的IPv6 PIM路由项。flag-value的取值及含义如下:
· act:表示已经有实际数据到达的IPv6 PIM路由项;
· bidir:表示由IPv6双向PIM创建的IPv6 PIM路由项;
· del:表示计划删除的IPv6 PIM路由项;
· exprune:表示某些出接口被其它IPv6组播路由协议剪枝的IPv6 PIM路由项;
· ext:表示包含了由其它IPv6组播路由协议提供出接口的IPv6 PIM路由项;
· loc:表示在与IPv6组播源处于同一网段的设备上的IPv6 PIM路由项;
· niif:表示未确定入接口的IPv6 PIM路由项;
· nonbr:表示IPv6 PIM邻居查找失败的IPv6 PIM路由项;
· rpt:表示向RP方向发送过(S,G)RPT位剪枝的IPv6 PIM路由项;
· spt:表示SPT上的IPv6 PIM路由项;
· swt:表示正处于向SPT切换过程中的IPv6 PIM路由项;
· wc:表示带WC通配符的IPv6 PIM路由项。
fsm:查看状态机信息。
【描述】
display pim ipv6 routing-table命令用来查看IPv6 PIM路由表的内容。
相关配置可参考“IP组播命令参考/IPv6组播路由与转发”中的命令display ipv6 multicast routing-table。
# 查看IPv6 PIM路由表的内容。
<Sysname> display pim ipv6 routing-table
(2001::2, FFE3::101)
Protocol: pim-sm, Flag: SPT LOC ACT
UpTime: 02:54:43
Upstream interface: Vlan-interface1
Upstream neighbor: NULL
RPF prime neighbor: NULL
1: Vlan-interface2
Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
# 查看IPv6 PIM路由表的状态机信息。
<Sysname> display pim ipv6 routing-table fsm
Abbreviations for FSM states:
NI - no info, J - joined, NJ - not joined, P - pruned,
NP - not pruned, PP - prune pending, W - winner, L - loser,
F - forwarding, AP - ack pending, DR - designated router,
NDR - non-designated router, RCV - downstream receivers
RP: FE80::A01:100:1
UpTime: 02:54:43
Join/Prune FSM: [SPT: J] [RPT: NP]
1: Vlan-interface2
DR state: [DR]
Join/Prune FSM: [NI]
Assert FSM: [NI]
FSM information for non-downstream interfaces: None
表1-9 display pim ipv6 routing-table命令显示信息描述表
Total 0 (*, G) entry; 1 (S, G) entry |
IPv6 PIM路由表中(S,G)与(*,G)表项的总数 |
Abbreviations for FSM states: NI - no info, J - joined, NJ - not joined, P – pruned NP - not pruned, PP - prune pending, W - winner, L – loser F - forwarding, AP - ack pending, DR - designated router NDR - non-designated router, RCV - downstream receivers |
状态机的缩写:NI表示初始状态,J表示加入状态,P表示剪枝状态,NP表示未剪枝状态,PP表示剪枝未决状态,W表示断言当选,L表示断言落选,F表示转发状态,AP表示嫁接确认状态,DR表示指定路由器,NDR表示非指定路由器,RCV表示下游接收者 |
(2001::2, FFE3::101) |
IPv6 PIM路由表中的(S,G)表项 |
RP |
RP的地址 |
Protocol |
IPv6 PIM的模式 |
Flag |
IPv6 PIM路由表中(S,G)或(*,G)表项的标志: · ACT:表示已有实际数据到达 · BIDIR:表示由IPv6双向PIM创建 · DEL:表示计划要删除 · EXPRUNE:表示某些出接口被其它IPv6组播路由协议剪枝 · EXT:表示包含了由它IPv6组播路由协议提供的出接口 · LOC:表示与IPv6组播源处于同一网段 · NIIF:表示未确定入接口 · NONBR:表示IPv6 PIM邻居查找失败 · RPT:表示向RP方向发送过(S,G)RPT位剪枝 · SPT:表示在SPT上 · SWT:表示正在向SPT切换 · WC:表示带WC通配符 |
Uptime |
(S,G)或(*,G)表项已存在的时间 |
Upstream interface |
(S,G)或(*,G)表项的上游接口名称 |
Upstream neighbor |
(S,G)或(*,G)表项的上游邻居 |
RPF prime neighbor |
(S,G)或(*,G)表项的RPF邻居: · 对(*,G)表项来说,当该路由器是RP时,(*,G)表项的RPF邻居是NULL · 对(S,G)表项来说,当该路由器直连源时,(S,G)表项的RPF邻居是NULL |
DR state |
DR的状态 |
Join/Prune FSM |
加入/剪枝状态机 |
Assert FSM |
断言状态机 |
Downstream interface(s) information |
下游接口的信息,包括: · 下游接口的总数 · 下游接口的名称 · 下游接口使用的协议类型 · 下游接口的存在时间 · 下游接口的超时时间 |
FSM information for non-downstream interfaces |
非下游接口的状态机信息 |
display pim ipv6 rp-info [ ipv6-group-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ipv6-group-address:IPv6组播组地址,查看指定IPv6组播组所对应的RP信息,取值范围为FFxy::/16(但不包括下列地址:FFx0::/16、FFx1::/16、FFx2::/16和FF0y::),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组对应的RP信息。
【描述】
display pim ipv6 rp-info命令用来查看RP的信息。
需要注意的是,RP信息包括通过BSR机制动态发现的RP信息和静态RP的信息。
# 查看IPv6组播组FF0E::101所对应的RP信息。
<Sysname> display pim ipv6 rp-info ff0e::101
PIM-SM BSR RP information:
prefix/prefix length: FF0E::101/64 [B]
RP: 2004::2
Priority: 192
HoldTime: 130
Uptime: 00:05:19
Expires: 00:02:11
表1-10 display pim ipv6 rp-info命令显示信息描述表
RP所服务的IPv6组播组 |
[B] |
表示RP服务于IPv6双向PIM,不显示本字段则表示RP服务于IPv6 PIM-SM |
RP |
RP的IPv6地址 |
Priority |
RP的优先级 |
HoldTime |
RP的超时时间 |
Uptime |
RP已存在的时间 |
Expires |
RP超时的剩余时间 |
dscp dscp-value
undo dscp
IPv6 PIM视图
【缺省级别】
2:系统级
dscp-value:报文的DSCP优先级,取值范围为0~63。
【描述】
dscp命令用来配置IPv6 PIM报文的DSCP优先级。undo dscp命令用来恢复缺省情况。
缺省情况下,IPv6 PIM报文的DSCP优先级为48。
#配置IPv6 PIM报文的DSCP优先级为63。
[Sysname] pim ipv6
[Sysname-pim6] dscp 63
embedded-rp [ acl6-number ]
undo embedded-rp [ acl6-number ]
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
embedded-rp命令用来使能嵌入式RP功能。undo embedded-rp命令用来关闭嵌入式RP功能或者恢复缺省情况。
缺省情况下,默认嵌入式RP地址范围内的IPv6组播组均可以使用嵌入式RP功能。
默认的嵌入式RP地址范围为FF7x::/12和FFFx::/12,其中x表示任意合法的scope。有关scope字段的详细介绍,请参见“IP组播配置指导”中的“组播概述”。
· 使用embedded-rp命令时,如果未指定acl6-number参数,则默认嵌入式RP地址范围内的所有IPv6组播组均可以使用嵌入式RP功能;如果指定了acl6-number参数,则只有在默认嵌入式RP地址范围内且通过了IPv6 ACL检查的IPv6组播组才能使用嵌入式RP功能。
· 使用undo embedded-rp命令时,如果未指定acl6-number参数,则关闭所有IPv6组播组的嵌入式RP功能;如果指定了acl6-number参数,则恢复缺省情况。
# 通过配置,使只有在FF7E:140:20::101/64范围内的IPv6组播组才能使用嵌入式RP功能。
[Sysname-acl6-basic-2000] rule permit source ff7e:140:20::101 64
[Sysname] pim ipv6
[Sysname-pim6] embedded-rp 2000
undo hello-option dr-priority
IPv6 PIM视图
【缺省级别】
2:系统级
priority:指定竞选DR的优先级,取值范围为0~4294967295。该数值越大,优先级越高。
【描述】
hello-option dr-priority命令用来全局配置竞选DR的优先级。undo hello-option dr-priority命令用来恢复缺省情况。
缺省情况下,竞选DR的优先级为1。
相关配置可参考命令pim ipv6 hello-option dr-priority。
# 全局配置竞选DR的优先级为3。
[Sysname] pim ipv6
[Sysname-pim6] hello-option dr-priority 3
hello-option holdtime interval
undo hello-option holdtime
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定保持IPv6 PIM邻居可达状态的超时时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
【描述】
hello-option holdtime命令用来全局配置保持IPv6 PIM邻居可达状态的时间。undo hello-option holdtime命令用来恢复缺省情况。
缺省情况下,保持IPv6 PIM邻居可达状态的时间为105秒。
相关配置可参考命令pim ipv6 hello-option holdtime。
# 全局配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname] pim ipv6
[Sysname-pim6] hello-option holdtime 120
hello-option lan-delay interval
undo hello-option lan-delay
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定发送剪枝报文的延迟时间,取值范围为1~32767,单位为毫秒。
【描述】
hello-option lan-delay命令用来全局配置发送剪枝报文的延迟时间。undo hello-option lan-delay命令用来恢复缺省情况。
缺省情况下,发送剪枝报文的延迟时间为500毫秒。
相关配置可参考命令hello-option override-interval、pim ipv6 hello-option override-interval和pim ipv6 hello-option lan-delay。
# 全局配置发送剪枝报文的延迟时间为200毫秒。
[Sysname] pim ipv6
[Sysname-pim6] hello-option lan-delay 200
undo hello-option neighbor-tracking
IPv6 PIM视图
【缺省级别】
2:系统级
无
【描述】
hello-option neighbor-tracking命令用来全局禁止加入报文抑制能力,即使能邻居跟踪。undo hello-option neighbor-tracking命令用来使能加入报文抑制能力。
缺省情况下,加入消息抑制能力处于使能状态,即禁止邻居跟踪。
相关配置可参考命令pim ipv6 hello-option neighbor-tracking。
# 全局禁止加入报文抑制能力。
[Sysname] pim ipv6
[Sysname-pim6] hello-option neighbor-tracking
undo hello-option override-interval
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定剪枝否决时间,取值范围为1~65535,单位为毫秒。
【描述】
hello-option override-interval命令用来全局配置剪枝否决时间。undo hello-option override-interval命令用来恢复缺省情况。
缺省情况下,剪枝否决时间为2500毫秒。
相关配置可参考命令hello-option lan-delay、pim ipv6 hello-option lan-delay和pim ipv6 hello-option override-interval。
# 全局配置剪枝否决时间为2000毫秒。
[Sysname] pim ipv6
[Sysname-pim6] hello-option override-interval 2000
holdtime assert interval
undo holdtime assert
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定保持断言状态的时间,取值范围为7~2147483647,单位为秒。
【描述】
holdtime assert命令用来全局配置保持断言状态的时间。undo holdtime assert命令用来恢复缺省情况。
缺省情况下,保持断言状态的时间为180秒。
相关配置可参考命令holdtime join-prune、pim ipv6 holdtime join-prune和pim ipv6 holdtime assert。
# 全局配置保持断言状态的时间为100秒。
[Sysname] pim ipv6
[Sysname-pim6] holdtime assert 100
holdtime join-prune interval
undo holdtime join-prune
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定保持加入/剪枝状态的时间,取值范围为1~65535,单位为秒。
【描述】
holdtime join-prune命令用来全局配置保持加入/剪枝状态的时间。undo holdtime join-prune命令用来恢复缺省情况。
缺省情况下,保持加入/剪枝状态的时间为210秒。
相关配置可参考命令holdtime assert、pim ipv6 holdtime assert和pim ipv6 holdtime join-prune。
# 全局配置保持加入/剪枝状态的时间为280秒。
[Sysname] pim ipv6
[Sysname-pim6] holdtime join-prune 280
jp-pkt-size packet-size
undo jp-pkt-size
IPv6 PIM视图
【缺省级别】
2:系统级
packet-size:指定加入/剪枝报文的最大长度,取值范围为100~64000,单位为字节。
【描述】
jp-pkt-size命令用来配置加入/剪枝报文的最大长度。undo jp-pkt-size命令用来恢复缺省情况。
缺省情况下,加入/剪枝报文的最大长度为8100字节。
相关配置可参考命令jp-queue-size。
如果IPv6 PIM网络中部署了配置IPv6 PIM Snooping功能的交换机,请在接收者侧的边缘IPv6 PIM设备上配置加入/剪枝报文的最大长度不能大于IPv6 路径MTU。
# 配置加入/剪枝报文的最大长度为1500字节。
[Sysname] pim ipv6
[Sysname-pim6] jp-pkt-size 1500
jp-queue-size queue-size
undo jp-queue-size
IPv6 PIM视图
【缺省级别】
2:系统级
queue-size:指定加入/剪枝报文中(S,G)表项的最大数量,取值范围为1~4096。
【描述】
jp-queue-size命令用来配置加入/剪枝报文中(S,G)表项的最大数量。undo jp-queue-size命令用来恢复缺省情况。
缺省情况下,加入/剪枝报文中(S,G)表项的最大数量为1020个。
· 在使用jp-queue-size命令进行配置时,需要考虑产品转发表的实际规格。对于某些不支持分片的网络,当queue-size值配置得较大时,加入/剪枝报文中可能包含较多的组,使该报文的长度可能超过网络所规定的MTU(Maximum Transmission Unit,最大传输单元),某些不支持超过MTU报文传输的产品会将其丢弃。
· 在使用jp-queue-size命令进行配置时,还需要考虑上游设备(S,G)保持加入/剪枝状态的时间。当queue-size值配置得很小时,在队列中的最后一个加入/剪枝报文送达上游设备之前,上游设备相应表项的出接口有可能由于已超时而被剪枝。
相关配置可参考命令jp-pkt-size,holdtime join-prune和pim ipv6 holdtime join-prune。
# 配置加入/剪枝报文中(S,G)表项的最大数量为2000。
[Sysname] pim ipv6
[Sysname-pim6] jp-queue-size 2000
pim ipv6
undo pim ipv6
【缺省级别】
2:系统级
无
【描述】
pim ipv6命令用来进入IPv6 PIM视图。undo pim ipv6命令用来清除IPv6 PIM视图下的所有配置。
相关配置可参考“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 routing-enable。
[Sysname] pim ipv6
[Sysname-pim6]
pim ipv6 bfd enable
undo pim ipv6 bfd enable
【缺省级别】
2:系统级
无
【描述】
pim ipv6 bfd enable命令用来使能IPv6 PIM与BFD联动功能。undo pim ipv6 bfd enable命令用来关闭IPv6 PIM与BFD联动功能。
缺省情况下,IPv6 PIM与BFD联动功能处于关闭状态。
需要注意的是,只有在接口上先使能了IPv6 PIM-DM或IPv6 PIM-SM,pim ipv6 bfd enable命令才能生效。
相关配置可参考命令pim ipv6 dm和pim ipv6 sm。
# 使能IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-SM,并使能IPv6 PIM与BFD联动功能。
[Sysname-Vlan-interface100] pim ipv6 sm
[Sysname-Vlan-interface100] pim ipv6 bfd enable
pim ipv6 bsr-boundary
undo pim ipv6 bsr-boundary
【缺省级别】
2:系统级
无
【描述】
pim ipv6 bsr-boundary命令用来配置BSR的服务边界,即IPv6 PIM-SM域的边界。undo pim ipv6 bsr-boundary命令用来删除BSR的服务边界。
缺省情况下,没有配置BSR的服务边界。
相关配置可参考命令c-bsr,以及“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 boundary。
# 配置接口Vlan-interface100为BSR的服务边界。
[Sysname-Vlan-interface100] pim ipv6 bsr-boundary
pim ipv6 dm
undo pim ipv6 dm
【缺省级别】
2:系统级
无
【描述】
pim ipv6 dm命令用来使能IPv6 PIM-DM。undo pim ipv6 dm命令用来关闭IPv6 PIM-DM。
缺省情况下,IPv6 PIM-DM处于关闭状态。
· 只有在设备上先使能了IPv6组播路由,本命令才能生效。
· 在运行IPv6 PIM-DM时不能使用处于IPv6 SSM组地址范围内的IPv6组播组。
相关配置可参考命令pim ipv6 sm和ssm-policy,以及“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 routing-enable。
# 使能IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-DM。
[Sysname-Vlan-interface100] pim ipv6 dm
pim ipv6 hello-option dr-priority priority
undo pim ipv6 hello-option dr-priority
【缺省级别】
2:系统级
【描述】
pim ipv6 hello-option dr-priority命令用来在接口上配置竞选DR的优先级。undo pim ipv6 hello-option dr-priority命令用来恢复缺省情况。
缺省情况下,竞选DR的优先级为1。
相关配置可参考命令hello-option dr-priority。
# 在接口Vlan-interface100上配置竞选DR的优先级为3。
[Sysname-Vlan-interface100] pim ipv6 hello-option dr-priority 3
pim ipv6 hello-option holdtime interval
undo pim ipv6 hello-option holdtime
【缺省级别】
2:系统级
interval:指定保持IPv6 PIM邻居可达状态的时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
【描述】
pim ipv6 hello-option holdtime命令用来在接口上配置保持IPv6 PIM邻居的可达状态的时间。undo pim ipv6 hello-option holdtime命令用来恢复缺省情况。
相关配置可参考命令hello-option holdtime。
# 在接口Vlan-interface100上配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname-Vlan-interface100] pim ipv6 hello-option holdtime 120
pim ipv6 hello-option lan-delay interval
undo pim ipv6 hello-option lan-delay
【缺省级别】
2:系统级
【描述】
pim ipv6 hello-option lan-delay命令用来在接口上配置发送剪枝报文的延迟时间。undo pim ipv6 hello-option lan-delay命令用来恢复缺省情况。
相关配置可参考命令pim ipv6 hello-option override-interval、hello-option override-interval和hello-option lan-delay。
# 在接口Vlan-interface100上配置发送剪枝报文的延迟时间为200毫秒。
[Sysname-Vlan-interface100] pim ipv6 hello-option lan-delay 200
undo pim ipv6 hello-option neighbor-tracking
【缺省级别】
2:系统级
无
【描述】
pim ipv6 hello-option neighbor-tracking命令用来在接口上禁止加入报文抑制能力,即使能邻居跟踪。undo pim ipv6 hello-option neighbor-tracking命令用来使能加入报文抑制能力。
缺省情况下,加入报文抑制能力处于使能状态,即禁止邻居跟踪。
相关配置可参考命令hello-option neighbor-tracking。
# 在接口Vlan-interface100上禁止加入报文抑制能力。
[Sysname-Vlan-interface100] pim ipv6 hello-option neighbor-tracking
pim ipv6 hello-option override-interval interval
undo pim ipv6 hello-option override-interval
【缺省级别】
2:系统级
【描述】
pim ipv6 hello-option override-interval命令用来在接口上配置剪枝否决时间。undo pim ipv6 hello-option override-interval命令用来恢复缺省情况。
相关配置可参考命令pim ipv6 hello-option lan-delay、hello-option lan-delay和hello-option override-interval。
# 在接口Vlan-interface100上配置剪枝否决时间为2000毫秒。
[Sysname-Vlan-interface100] pim ipv6 hello-option override-interval 2000
pim ipv6 holdtime assert interval
undo pim ipv6 holdtime assert
【缺省级别】
2:系统级
【描述】
pim ipv6 holdtime assert命令用来在接口上配置保持断言状态的时间。undo pim ipv6 holdtime assert命令用来恢复缺省情况。
相关配置可参考命令holdtime join-prune、pim ipv6 holdtime join-prune和holdtime assert。
# 在接口Vlan-interface100上配置保持断言状态的时间为100秒。
[Sysname-Vlan-interface100] pim ipv6 holdtime assert 100
pim ipv6 holdtime join-prune interval
undo pim ipv6 holdtime join-prune
【缺省级别】
2:系统级
【描述】
pim ipv6 holdtime join-prune命令用来在接口上配置保持加入/剪枝状态的时间。undo pim ipv6 holdtime join-prune命令用来恢复缺省情况。
相关配置可参考命令holdtime assert、pim ipv6 holdtime assert和holdtime join-prune。
# 在接口Vlan-interface100上配置保持加入/剪枝状态的时间为280秒。
[Sysname-Vlan-interface100] pim ipv6 holdtime join-prune 280
pim ipv6 neighbor-policy acl6-number
undo pim ipv6 neighbor-policy
【缺省级别】
2:系统级
acl6-number:指定基本IPv6访问控制列表编号,取值范围为2000~2999。在定义该IPv6 ACL时,使用rule命令中的source参数来指定合法Hello报文的源地址范围。
【描述】
pim ipv6 neighbor-policy命令用来配置合法Hello报文的源地址范围,以防止Hello报文欺骗。undo pim ipv6 neighbor-policy命令用来恢复缺省情况。
缺省情况下,Hello报文的源地址范围不受任何限制,即认为所有收到的Hello报文都是合法的。
# 在接口Vlan-interface100上配置合法Hello报文的源地址范围,只允许与来自网段FE80:101::101/64中的设备建立IPv6 PIM邻居关系。
[Sysname-acl6-basic-2000] rule permit source fe80:101::101 64
[Sysname-Vlan-interface100] pim ipv6 neighbor-policy 2000
pim ipv6 require-genid
undo pim ipv6 require-genid
【缺省级别】
2:系统级
无
【描述】
pim ipv6 require-genid命令用来配置不接受无Generation ID的Hello报文。undo pim ipv6 require-genid命令用来恢复缺省情况。
缺省情况下,接受无Generation ID的Hello报文。
# 配置接口Vlan-interface100不接受无Generation ID的Hello报文。
[Sysname-Vlan-interface100] pim ipv6 require-genid
pim ipv6 sm
undo pim ipv6 sm
【缺省级别】
2:系统级
无
【描述】
pim ipv6 sm命令用来使能IPv6 PIM-SM。undo pim ipv6 sm命令用来关闭IPv6 PIM-SM。
缺省情况下,IPv6 PIM-SM处于关闭状态。
相关配置可参考命令pim ipv6 dm,以及“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 routing-enable。
# 使能IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-SM。
undo pim ipv6 state-refresh-capable
【缺省级别】
2:系统级
无
【描述】
pim ipv6 state-refresh-capable命令用来使能状态刷新能力。undo pim ipv6 state-refresh-capable命令用来关闭状态刷新能力。
缺省情况下,状态刷新能力处于使能状态。
相关配置可参考命令state-refresh-interval、state-refresh-rate-limit和state-refresh-hoplimit。
# 在接口Vlan-interface100上关闭状态刷新能力。
[Sysname-Vlan-interface100] undo pim ipv6 state-refresh-capable
pim ipv6 timer graft-retry interval
undo pim ipv6 timer graft-retry
【缺省级别】
2:系统级
interval:指定嫁接报文的重传时间,取值范围为1~65535,单位为秒。
【描述】
pim ipv6 timer graft-retry命令用来配置嫁接报文的重传时间。undo pim ipv6 timer graft-retry命令用来恢复缺省情况。
缺省情况下,嫁接报文的重传时间为3秒。
# 在接口Vlan-interface100上配置嫁接报文的重传时间为80秒。
[Sysname-Vlan-interface100] pim ipv6 timer graft-retry 80
pim ipv6 timer hello interval
undo pim ipv6 timer hello
【缺省级别】
2:系统级
interval:指定发送Hello报文的时间间隔,取值范围为1~2147483647,单位为秒。
【描述】
pim ipv6 timer hello命令用来在接口上配置发送Hello报文的时间间隔。undo pim ipv6 timer hello命令用来恢复缺省情况。
缺省情况下,发送Hello报文的时间间隔为30秒。
相关配置可参考命令timer hello。
# 在接口Vlan-interface100上配置发送Hello报文的时间间隔为40秒。
[Sysname-Vlan-interface100] pim ipv6 timer hello 40
pim ipv6 timer join-prune interval
undo pim ipv6 timer join-prune
【缺省级别】
2:系统级
interval:指定发送加入/剪枝报文的时间间隔,取值范围为1~2147483647,单位为秒。
【描述】
pim ipv6 timer join-prune命令用来在接口上配置发送加入/剪枝报文的时间间隔。undo pim ipv6 timer join-prune命令用来恢复缺省情况。
缺省情况下,发送加入/剪枝报文的时间间隔为60秒。
相关配置可参考命令timer join-prune。
# 在接口Vlan-interface100上配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname-Vlan-interface100] pim ipv6 timer join-prune 80
pim ipv6 triggered-hello-delay interval
undo pim ipv6 triggered-hello-delay
【缺省级别】
2:系统级
interval:指定触发Hello报文的最大延迟时间,取值范围为1~60,单位为秒。
【描述】
pim ipv6 triggered-hello-delay命令用来配置触发Hello报文的最大延迟时间。undo pim ipv6 triggered-hello-delay命令用来恢复缺省情况。
缺省情况下,触发Hello报文的最大延迟时间为5秒。
# 在接口Vlan-interface100上配置触发Hello报文的最大延迟时间为3秒。
[Sysname-Vlan-interface100] pim ipv6 triggered-hello-delay 3
probe-interval interval
undo probe-interval
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定注册探测时间,取值范围为1~1799,单位为秒。
【描述】
probe-interval命令用来配置注册探测时间。undo probe-interval命令用来恢复缺省情况。
缺省情况下,注册探测时间为5秒。
相关配置可参考命令register-suppression-timeout。
# 配置注册探测时间为6秒。
[Sysname] pim ipv6
[Sysname-pim6] probe-interval 6
prune delay interval
undo prune delay
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定剪枝延迟时间,取值范围1~128,单位为秒。
【描述】
prune delay命令用来配置剪枝延迟时间。undo prune delay命令用来恢复缺省情况。
缺省情况下,未配置剪枝延迟时间。
# 配置剪枝延迟时间为75秒。
[Sysname] pim ipv6
[Sysname-pim6] prune delay 75
register-policy acl6-number
undo register-policy
IPv6 PIM视图
【缺省级别】
2:系统级
acl6-number:指定高级IPv6访问控制列表编号,取值范围为3000~3999。只有与IPv6 ACL的permit语句匹配的注册报文才会被RP接受。
【描述】
register-policy命令用来配置注册报文的过滤规则。undo register-policy命令用来删除注册报文的过滤规则。
缺省情况下,没有配置注册报文的过滤规则。
# 配置RP上对注册报文的过滤规则,只接收来自3:1::/64网段的IPv6组播源发向FF0E:13::/64网段的IPv6组播组的注册报文。
[Sysname-acl6-adv-3000] rule permit ipv6 source 3:1:: 64 destination ff0e:13:: 64
[Sysname] pim ipv6
[Sysname-pim6] register-policy 3000
undo register-suppression-timeout
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定注册抑制时间,取值范围为1~65535,单位为秒。
【描述】
register-suppression-timeout命令用来配置注册抑制时间。undo register-suppression-timeout命令用来恢复缺省情况。
缺省情况下,注册抑制时间为60秒。
相关配置可参考命令probe-interval和register-policy。
# 配置注册抑制时间为70秒。
[Sysname] pim ipv6
[Sysname-pim6] register-suppression-timeout 70
undo register-whole-checksum
IPv6 PIM视图
【缺省级别】
2:系统级
无
【描述】
register-whole-checksum命令用来配置根据注册报文的全部内容来计算校验和。undo register-whole-checksum命令用来恢复缺省情况。
缺省情况下,仅根据注册报文头来计算校验和。
相关配置可参考命令register-policy和register-suppression-timeout。
# 配置根据注册报文的全部内容来计算校验和。
[Sysname] pim ipv6
[Sysname-pim6] register-whole-checksum
reset pim ipv6 control-message counters [ interface interface-type interface-number ]
【缺省级别】
1:监控级
interface-type interface-number:接口类型和接口编号,重置指定接口的IPv6 PIM控制报文计数器。如果未指定本参数,将重置所有接口的IPv6 PIM控制报文数量。
【描述】
reset pim ipv6 control-message counters命令用来重置IPv6 PIM控制报文计数器。
# 重置IPv6 PIM控制报文计数器。
<Sysname> reset pim ipv6 control-message counters
source-lifetime interval
undo source-lifetime
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定IPv6组播源的生存时间,取值范围为1~31536000,单位为秒。
【描述】
source-lifetime命令用来配置IPv6组播源的生存时间。undo source-lifetime命令用来恢复缺省情况。
缺省情况下,IPv6组播源的生存时间为210秒。
# 配置IPv6组播源的生存时间为200秒。
[Sysname] pim ipv6
[Sysname-pim6] source-lifetime 200
source-policy acl6-number
undo source-policy
IPv6 PIM视图
【缺省级别】
2:系统级
acl6-number:指定基本或高级IPv6访问控制列表编号,取值范围为2000~3999。
【描述】
source-policy命令用来配置IPv6组播数据过滤器。undo source-policy命令用来删除IPv6组播数据过滤器。
缺省情况下,没有配置IPv6组播数据过滤器。
· 如果指定的是基本访问控制列表,则对收到的IPv6组播数据报文匹配源地址,未通过匹配的报文将被丢弃。
· 如果指定的是高级访问控制列表,则对收到的IPv6组播数据报文匹配源地址和组地址,未通过匹配的报文将被丢弃。
· 重复执行本命令,新的配置会覆盖原有配置。
# 配置接收IPv6组播源3121::1的IPv6组播数据报文,丢弃IPv6组播源3121::2的IPv6组播数据报文。
[Sysname-acl6-basic-2000] rule permit source 3121::1 128
[Sysname-acl6-basic-2000] rule deny source 3121::2 128
[Sysname] pim ipv6
[Sysname-pim6] source-policy 2000
[Sysname-pim6] quit
spt-switch-threshold infinity [ group-policy acl6-number [ order order-value ] ]
undo spt-switch-threshold [ group-policy acl6-number ]
IPv6 PIM视图
【缺省级别】
2:系统级
group-policy acl6-number:表示IPv6组策略列表中的一项,与该IPv6组策略相匹配的IPv6组播组将应用本配置。acl6-number表示基本IPv6访问控制列表编号,取值范围为2000~2999。如果未指定本参数,本配置将应用于所有IPv6组播组。
order order-value:指定IPv6 ACL在组策略列表中的序号。order-value的取值范围为1~现有组策略列表中的最大序号+1,但取值范围中不包括该IPv6 ACL在组策略列表中的原有序号。如果已为某IPv6 ACL指定了order-value,则不允许为该IPv6 ACL指定相同的order-value,否则系统将报错;如果未指定本参数,则不改变该IPv6 ACL在组策略列表中的序号。
【描述】
spt-switch-threshold infinity命令用来配置发起SPT切换的条件。undo spt-switch-threshold命令用来恢复缺省情况。
缺省情况下,设备收到第一个IPv6组播数据包后便立即向SPT切换。
· 当需要调整组策略列表中已有IPv6 ACL的次序时,可以通过配置参数acl6-number指定该IPv6 ACL,并设置其order-value,将该IPv6 ACL插入到组策略列表的order-value位置。组策略列表中已有的其它IPv6 ACL保持先后排列次序不变。
· 当需要启用组策略列表中没有的IPv6 ACL时,可以通过配置参数acl6-number指定该IPv6 ACL,并设置其order-value,将该IPv6 ACL插入到组策略列表的order-value位置。如果未指定order-value,则将其插入组策略列表的尾部。
· 如果对同一IPv6组播组配置了多条该命令,则该IPv6组播组按顺序匹配到的第一个命令将生效。
· 由于某些设备无法将IPv6组播报文封装在注册报文中发给RP,因此在可能成为RP的设备上不建议配置永不发起SPT切换,以免导致IPv6组播报文转发失败。
# 在接收者侧DR上,配置RPT永不发起SPT切换。
[Sysname] pim ipv6
[Sysname-pim6] spt-switch-threshold infinity
ssm-policy acl6-number
undo ssm-policy
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
ssm-policy命令用来配置IPv6 SSM组播组的范围。undo ssm-policy命令用来恢复缺省情况。
缺省情况下,IPv6 SSM组播组的范围为FF3x::/32,其中x表示任意合法的scope。
通过本命令可以定义允许或拒绝的IPv6组播组的地址范围:如果匹配通过,则组播运行模式为IPv6 PIM-SSM,否则为IPv6 PIM-SM。
# 配置IPv6 SSM组播组的范围为FF3E:0:8192::/96。
[Sysname-acl6-basic-2000] rule permit source ff3e:0:8192:: 96
[Sysname] pim ipv6
[Sysname-pim6] ssm-policy 2000
state-refresh-hoplimit hoplimit-value
undo state-refresh-hoplimit
IPv6 PIM视图
【缺省级别】
2:系统级
hoplimit-value:指定状态刷新报文的Hop Limit值,取值范围为1~255。
【描述】
state-refresh-hoplimit命令用来配置状态刷新报文的Hop Limit值。undo state-refresh-hoplimit命令用来恢复缺省情况。
缺省情况下,状态刷新报文的Hop Limit值为255。
相关配置可参考命令pim ipv6 state-refresh-capable、state-refresh-interval和state-refresh-rate-limit。
# 配置状态刷新报文的Hop Limit值为45。
[Sysname] pim ipv6
[Sysname-pim6] state-refresh-hoplimit 45
undo state-refresh-interval
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定发送状态刷新报文的时间间隔,取值范围为1~255,单位为秒。
【描述】
state-refresh-interval命令用来配置发送状态刷新报文的时间间隔。undo state-refresh-interval命令用来恢复缺省情况。
缺省情况下,发送状态刷新报文的时间间隔为60秒。
相关配置可参考命令pim ipv6 state-refresh-capable、state-refresh-rate-limit和state-refresh-hoplimit。
# 配置发送状态刷新报文的时间间隔为70秒。
[Sysname] pim ipv6
[Sysname-pim6] state-refresh-interval 70
state-refresh-rate-limit interval
undo state-refresh-rate-limit
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定接收新状态刷新报文的等待时间,取值范围为1~65535,单位为秒。
【描述】
state-refresh-rate-limit命令用来配置接收新状态刷新报文的等待时间。undo state-refresh-rate-limit命令用来恢复缺省情况。
缺省情况下,接收新状态刷新报文的等待时间为30秒。
相关配置可参考命令pim ipv6 state-refresh-capable、state-refresh-interval和state-refresh-hoplimit。
# 配置接收新状态刷新报文的等待时间为45秒。
[Sysname] pim ipv6
[Sysname-pim6] state-refresh-rate-limit 45
static-rp ipv6-rp-address [ acl6-number ] [ preferred ] [ bidir ]
undo static-rp ipv6-rp-address
IPv6 PIM视图
【缺省级别】
2:系统级
ipv6-rp-address:指定静态RP的IPv6地址。该地址必须是实际存在且有效的IPv6全球单播地址;但对于服务于IPv6双向PIM的静态RP来说,允许将其IPv6地址指定为一个实际不存在的IPv6地址。
acl6-number:指定基本IPv6访问控制列表编号,取值范围为2000~2999。如果指定了本参数,则配置的静态RP只为能够通过匹配的IPv6组播组服务;如果未指定本参数,则配置的静态RP将为所有IPv6组播组服务。
preferred:指定当静态RP与动态RP冲突时,优先选择静态RP。如果未指定本参数,则优先选择动态RP,如果网络中没有动态RP或动态RP失效,静态RP才能生效。
bidir:指定该静态RP服务于IPv6双向PIM。如果未指定本参数,该静态RP将服务于IPv6 PIM-SM。
【描述】
static-rp命令用来配置静态RP。undo static-rp命令用来删除静态RP。
缺省情况下,没有配置静态RP。
· 作为静态RP的接口不必使能IPv6 PIM-SM或IPv6 PIM-DM。
· 当某个静态RP引用的IPv6 ACL规则发生变化时,需要为所有IPv6组播组重新选举RP。
· 重复执行本命令,可以配置多个静态RP。但是,如果配置时所指定的静态RP地址或IPv6 ACL规则相同,则新配置将覆盖旧配置;如果存在多个静态RP服务于同一IPv6组播组的情况,则选择IPv6地址最大的静态RP为该组服务。
· 一台设备上最多可以配置50个不同的静态RP。
相关配置可参考命令display pim ipv6 rp-info。
# 配置IPv6地址为2001::2的接口为静态RP,为IPv6 ACL 2001所定义的IPv6组播组FF03::101/64提供服务,并优先选择静态RP。
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source ff03::101 64
[Sysname-acl6-basic-2001] quit
[Sysname] pim ipv6
[Sysname-pim6] static-rp 2001::2 2001 preferred
undo timer hello
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
timer hello命令用来全局配置发送Hello报文的时间间隔。undo timer hello命令用来恢复缺省情况。
相关配置可参考命令pim ipv6 timer hello。
# 全局配置发送Hello报文的时间间隔为40秒。
[Sysname] pim ipv6
[Sysname-pim6] timer hello 40
undo timer join-prune
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
timer join-prune命令用来全局配置发送加入/剪枝报文的时间间隔。undo timer join-prune命令用来恢复缺省情况。
相关配置可参考命令pim ipv6 timer join-prune。
# 全局配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname] pim ipv6
[Sysname-pim6] timer join-prune 80
