03-二层技术-以太网交换命令参考
15-EPON-OLT命令
本章节下载 15-EPON-OLT命令  (685.03 KB)
docurl=/cn/Service/Document_Software/Document_Center/Switches/Catalog/S7600/H3C_S7600/Command/Command_Manual/H3C_S7600(R6700)-S7600-X(R6900)CR-6W102/03/201304/781740_30005_0.htm
15-EPON-OLT命令
  录
1 OLT配置命令
1.1 OLT配置命令
1.1.1 dba-algorithm enable
1.1.2 dba-algorithm update
1.1.3 dba-parameters
1.1.4 display epon-capability interface
1.1.5 display epon-oam interface
1.1.6 display epon-parameter slot
1.1.7 display epon-version interface
1.1.8 display epon-workmode interface
1.1.9 display epon statistics interface
1.1.10 display fiber-backup group
1.1.11 display onu-event interface
1.1.12 display onuinfo
1.1.13 display onuinfo mac-address
1.1.14 display onuinfo silent
1.1.15 display optics-parameters interface
1.1.16 display transceiver diagnosis interface onu
1.1.17 display transceiver diagnosis interface olt
1.1.18 encryption timer
1.1.19 epon-parameter ouilist
1.1.20 fiber-backup group
1.1.21 grant-filtering enable
1.1.22 group member
1.1.23 max-rtt
1.1.24 multicast vlan-id dest-ip
1.1.25 port fiber-backup group
1.1.26 port hybrid pvid vlan
1.1.27 port hybrid vlan
1.1.28 port link-type hybrid
1.1.29 port switch-over
1.1.30 sme enable
1.1.31 using onu
2 ONU远程管理配置命令
2.1 ONU远程管理配置命令
2.1.1 bind onuid
2.1.2 dba-report queue-id threshold
2.1.3 dba-report queue-set-number
2.1.4 deregister onu
2.1.5 display dhcp-client
2.1.6 display epon-multicast information
2.1.7 display onu-protocol
2.1.8 display vendor-specific information
2.1.9 display uni-information
2.1.10 encrypt enable
2.1.11 encrypt key
2.1.12 forward-error-correction enable
2.1.13 ip address
2.1.14 linktest
2.1.15 loopback enable
2.1.16 management-vlan
2.1.17 multicast-control host-aging-time
2.1.18 multicast-mode
2.1.19 onu bind auto
2.1.20 onu bind batch
2.1.21 onu-event
2.1.22 onu port-isolate enable
2.1.23 onu-protocol enable
2.1.24 onu-protocol igmp-snooping
2.1.25 port access vlan
2.1.26 port link-type
2.1.27 port trunk pvid vlan
2.1.28 reboot onu
2.1.29 reset counters uni
2.1.30 shutdown management-vlan-interface
2.1.31 uni auto-negotiation
2.1.32 uni description
2.1.33 uni duplex
2.1.34 uni flow-control
2.1.35 uni igmp-snooping fast-leave
2.1.36 uni mdi
2.1.37 uni multicast vlan
2.1.38 uni multicast-control multicast-address
2.1.39 uni multicast-group-number
2.1.40 uni multicast-strip-tag enable
2.1.41 uni port-isolate
2.1.42 uni restart auto-negotiation
2.1.43 uni shutdown
2.1.44 uni speed
2.1.45 uni virtual-cable-test
2.1.46 uni vlan-mode tag pvid
2.1.47 uni vlan-mode translation pvid
2.1.48 uni vlan-mode transparent
2.1.49 upstream-sla
2.1.50 upstream-sla service-mode enable
2.1.51 upstream-sla service
2.1.52 update onu filename
2.1.53 update onu onu-type
3 告警配置命令
3.1 告警配置命令
3.1.1 alarm bit-error-rate
3.1.2 alarm bit-error-rate enable
3.1.3 alarm device-fatal-error enable
3.1.4 alarm frame-error-rate
3.1.5 alarm frame-error-rate enable
3.1.6 alarm llid-mismatch enable
3.1.7 alarm llid-mismatch threshold
3.1.8 alarm local-stable enable
3.1.9 alarm oam critical-event enable
3.1.10 alarm oam dying-gasp enable
3.1.11 alarm oam error-symbol-period
3.1.12 alarm oam error-symbol-period enable
3.1.13 alarm oam error-frame-period
3.1.14 alarm oam error-frame-period enable
3.1.15 alarm oam error-frame
3.1.16 alarm oam error-frame enable
3.1.17 alarm oam error-frame-seconds-summary
3.1.18 alarm oam error-frame-seconds-summary enable
3.1.19 alarm oam local-link-fault enable
3.1.20 alarm oam-vendor-specific enable
3.1.21 alarm onu-over-limitation enable
3.1.22 alarm port bit-error-rate enable
3.1.23 alarm registration-error enable
3.1.24 alarm remote-stable enable
3.1.25 alarm software-error enable
3.1.26 monitor enable
3.1.27 sample enable
3.1.28 timer monitor
3.1.29 timer sample
4 与交换机特性相关的配置命令
4.1 OLT端口支持的命令
4.2 ONU端口支持的命令
1 OLT配置命令
当S7600系列以太网交换机安装上EPON业务板后,交换机就可以充当EPON系统的OLT设备。需要注意的是:
·       当交换机工作在独立运行模式时(未开启IRF功能),OLT功能能够正常使用;当交换机工作在IRF模式时(开启了IRF功能),OLT功能无法正常使用。
·       当S7600系列交换机上开启了IRF功能后,即使该交换机上安装了EPON业务板也无法实现OLT设备的功能(OLT相关的命令无法生效)。
·       当S7600系列交换机上安装了EPON业务板具备了OLT功能时(此时交换机处于独立运行模式),如果再开启IRF功能交换机会重启并切换到IRF模式,此时交换机IRF功能能够正常运行、OLT功能失效。
·       本手册主要介绍了EPON(Ethernet Passive Optical Network,以太网无源光网络)特有的命令,与OLT(Optical Line Terminal,光线路终端)端口和ONU(Optical Network Unit,光网络单元)端口相关的交换机特性所对应的手册参考模块请参见“4 与交换机特性相关的配置命令”。
·       本手册中所涉及的显示信息仅供参考,请以实际的显示为准。
1.1  OLT配置命令
dba-algorithm enable { extdba | intdba }
undo dba-algorithm update
OLT端口视图
【缺省级别】
2:系统级
extdba:采用外部DBA算法,外部DBA算法通过加载外部DBA算法文件来实现。
intdba:采用内部DBA算法,内部DBA算法由芯片内部实现。
【描述】
dba-algorithm enable命令用来指定OLT采用内部DBA算法或外部DBA算法来实时改变各ONU的上行带宽。undo dba-algorithm update命令用来删除已加载的外部DBA算法文件并恢复为采用内部DBA算法。
缺省情况下,采用内部DBA算法实时改变各ONU的上行带宽。
需要注意的是,当使用本命令指定采用外部DBA算法时,必须先使用dba-algorithm update命令加载指定外部DBA算法文件。
相关配置可参考命令dba-algorithm update
·       用户在使用dba-algorithm update命令升级外部DBA算法时,自动会将外部DBA算法升级文件同步到备用主控板中。如果备用控板中存在此文件,那么将会被覆盖;如果同步操作失败(比如:备用控板FLASH容量不够),会导致主、备板DBA算法不一致,产生配置错误。
·       建议用户在没有业务存在的情况下进行DBA算法切换,否则,在切换过程中会影响该OLT下所有业务的运行。
# 加载外部DBA算法文件plato3.2.app。
[Sysname] interface olt 3/0/1
[Sysname-Olt3/0/1] dba-algorithm update Plato3.2.app
# 启动外部DBA算法。
[Sysname-Olt3/0/1] dba-algorithm enable extdba
Warning: Switching DBA may cause some onus of this olt to re-register. Are you
sure?(Y/N)y
dba-algorithm update file-url
OLT端口视图
【缺省级别】
2:系统级
file-url:由设备名与DBA算法文件的文件名组成,为不超过64个字符的字符串,如果不输入设备名,则表示主控板的FLASH,且不能使用备用主控板上的DBA算法文件进行升级。
【描述】
dba-algorithm update命令用来加载指定外部DBA算法。
相关配置可参考命令dba-algorithm enable
# 加载外部DBA算法文件plato2.app。
[Sysname-Olt3/0/1] dba-algorithm update plato2.app
 Updating external DBA-algorithm.......
dba-parameters { discovery-frequency value | discovery-length value | cycle-length value } *
undo dba-parameters { discovery-frequency | discovery-length | cycle-length } *
OLT端口视图
【缺省级别】
2:系统级
discovery-frequency value:OLT以授权周期(grant cycles:由cycle-length指定)为基准发送发现GATE消息的频率,value的取值范围为25~100,缺省值为50(即:OLT每50个cycle-length发送一次发现GATE消息)。
discovery-length value:OLT用于进行ONU发现的时间长度,单位为TQ,value的取值范围为21845~87381,缺省值为41500TQ。
cycle-length value:组成grant cycles的最小单位,单位为TQ,取值范围为32768~131070,缺省值为65535TQ。
TQ(Time Quantum,时间量子)为时间单位,1TQ=16ns,也即是以1Gbps的速率传送2字节数据所花费的时间。
【描述】
dba-parameters命令用来设置OLT每隔多长时间发起一次ONU发现过程以及为这次发现过程所分配的时间长度。undo dba-parameters命令用于恢复这些DBA参数为缺省值。
需要注意的是,一般情况下不建议用户对此命令进行配置。
# 设置OLT3/0/1以30个cycle-length为基准发送一次发现GATE消息。
[Sysname-Olt3/0/1] dba-parameters discovery-frequency 30
display epon-capability interface interface-type interface-number
【缺省级别】
2:系统级
interface-type:端口类型,取值为OLT或者ONU。
interface-number:OLT端口号或者ONU端口号。
·       interface-number:当为OLT端口时,格式采用业务板槽位编号/子板槽位编号/OLT端口编号;当为ONU端口时,格式采用业务板槽位编号/子板槽位编号/OLT端口编号:ONU端口编号,以下不再赘述。
·       需要注意的是,必须先在OLT端口视图下使用using onu命令创建了ONU端口,才会产生相应的ONU端口。
【描述】
display epon-capability interface命令用来显示OLT或ONU能力信息。
·              如果为OLT端口,可以显示其AGC(Automatic Gain Control,自动增益控制)时间和CDR(Clock Data Recovery,时钟数据恢复)时间;
·              如果为ONU端口,可以显示ONU授权阶段激光器打开时间(Laser On Time)、激光器关闭时间(Laser Off Time)和授权队列深度(Grant FIFO deep)。
·       仅当ONU端口和ONU绑定,且ONU端口处于Up的状态(即:ONU在线)时,才能显示ONU的能力信息,相关配置请参见“2.1.1  bind onuid”;
·       仅当OLT处于Up的状态时,才能显示OLT的能力信息。
·       由于各个ONU所处的位置远近和外界环境不同,所以OLT接收到的信号有强有弱。AGC时间是OLT用于自动恢复接收信号的强度使其达到允许的接收状态所花费的时间。
·       CDR时间是OLT用于对接收到信号进行相位和频率同步花费的时间。
·       ONU激光器打开时间为ONU激光器打开到稳定的时间间隔,关闭时间为ONU激光器关闭到稳定的时间间隔。
# 显示OLT能力信息。
<Sysname> display epon-capability interface olt 3/0/1
 OLT device capability information:
 AGC lock time(TQ): 14
 CDR lock time(TQ): 20
# 显示ONU能力信息。
<Sysname> display epon-capability interface onu 3/0/1:1
 ONU device capability information:
 Laser on time(TQ) : 32
 Laser off time(TQ): 32
 Grant FIFO deep   : 8
表1-1 display epon-capability interface命令显示信息描述表
OLT设备能力信息
自动增益控制时间,单位为TQ
时钟和数据恢复时间,单位为TQ
ONU设备能力信息
激光器打开时间,单位为TQ
激光器关闭时间,单位为TQ
Grant FIFO deep   : 8
授权队列深度,即FIFO队列的大小(以时隙的个数度量)
display epon-oam interface interface-type interface-number
【缺省级别】
2:系统级
interface-type:端口类型,取值为ONU。
interface-number:ONU端口号。
【描述】
display epon-oam interface命令是用于显示ONU的OAM(Operations、Administration and Maintenance,操作、管理与维护)信息。
仅当ONU在线时,才能显示ONU的OAM信息。
# 显示ONU的OAM信息。
<Sysname> display epon-oam interface onu 3/0/1:1
 OAM information:
 OAM version: 3.3
 Multiplexer action: forwarding non-OAM PDUs to the lower sublayer
 Parser action     : forwarding non-OAM PDUs to higher layer
 Organization specific information TLVs: support
 Organization specific events          : support
 Organization specific OAM PDUs        : support
 Sending variable response OAM PDUs    : support
 Interpreting link events              : not support
 OAM mode              : passive
 Unidirectional support: disable
 Loopback support      : enable
 Maximal PDU size(byte): 1518
 Enterprise number     : 1111
 Device identifier     : 6301
 Version identifier    : 0
 Board vendor code     : 0
 Board model identifier: 0
表1-2 display epon-oam interface命令显示信息描述表
OAM version
OAM版本
多路复用器动作:向底层发送非OAM PDU
解析器动作:向高层发送非OAM PDU
企业特定信息TLV格式
企业特定事件
企业特定OAM PDU
在响应OAM PDU报文中发送变量
解释连接事件
OAM mode
OAM模式
单向支持模式
Loopback support
环回支持模式
最大PDU长度,单位为字节
Enterprise number
企业标识
Device identifier
设备标识
Version identifier
版本标识
Board vendor code
板卡供应商代码
板卡标识
display epon-parameter slot slot-number
【缺省级别】
1:监控级
slot-number:EPON业务板所在的槽位号。
【描述】
display epon-parameter slot命令用来显示EPON参数的相关信息。
相关命令可参考epon-parameter ouilistencryption timer
# 显示EPON参数的相关信息。
<Sysname> display epon-parameter slot 3
 Parameters:
     oui: 111111     oam-version: 1 (default)
     oui: 111111     oam-version: 2
 encryption-timing :
     update-key-time : 10s
     no-reply-timeout : 3.0s
 eoam-discovery-timeout : 3.0s
表1-3 display epon-parameter命令显示信息描述表
EPON系统参数
EPON业务板的缺省OUI(Organizationally Unique Identifier,机构唯一性标识)和扩展OAM版本号
用户配置的OUI和扩展OAM版本号
encryption-timing
加密时间参数
密钥更新周期,单位为秒
加密响应超时时间,单位为秒
扩展OAM连接过程中消息超时时间,单位为秒
display epon-version interface interface-type interface-number
【缺省级别】
2:系统级
【描述】
display epon-version interface命令用来显示OLT或ONU的版本信息。
·              仅当ONU在线时,才能显示ONU的版本信息;
·              仅当OLT端口处于Up状态时,才能显示OLT的版本信息。
# 显示OLT版本信息。
<Sysname> display epon-version interface olt 3/0/1
 OLT device version information:
 Firmware major version: 5
 Firmware minor version: 1
 Hardware major version: 5201
 Hardware minor version: 1
 Supported LLID number : 127
# 显示ONU版本信息。
<Sysname> display epon-version interface onu 3/0/1:1
 ONU device version information:
 Hardware major version: A
 Hardware minor version: 0
 MAC type of UNI port  : GMII
表1-4 display epon-version命令显示信息描述表
固件主版本
固件小版本
硬件主版本
硬件小版本
支持的LLID数目
UNI(User Network Interface,用户网络接口)MAC类型:
·       GMII(Gigabit Media Independent Interface):千兆媒质无关接口
·       MII:百兆媒质无关接口
LLID(Logical Link Identifier,逻辑链路标识)是OLT动态分配给ONU并且能够唯一识别一个ONU的身份标识码。
display epon-workmode interface interface-type interface-number
【缺省级别】
2:系统级
【描述】
display epon-workmode interface命令用来查询OLT或ONU的当前工作模式。如果端口类型是OLT,那么还可以显示其MAC地址和DBA(Dynamic Bandwidth Allocation,动态带宽分配)算法模式。
仅当ONU在线时,才能显示ONU的当前工作模式。
表1-5 工作状态及含义描述
项目
状态
含义
OLT
open
OLT打开
closed
OLT关闭
ONU
open
ONU打开
closed
ONU关闭
DBA算法模式
internal
内部DBA算法
external
外部DBA算法
# 显示OLT的工作模式。
<Sysname> display epon-workmode interface olt 3/0/1
 OLT work mode:
 Status  : open
 MAC ADDR: 000f-e2a1-1027
 DBA mode: internal
# 显示ONU的工作模式。
<Sysname> display epon-workmode interface onu 3/0/1:1
 ONU work mode:
 Working status: open
 FEC mode : disable
表1-6 display epon-workmode命令显示信息描述表
Status: open
OLT已经打开
OLT端口的MAC地址为000f-e2a1-1027
同一台交换机下的所有OLT端口共用一个MAC地址
DBA mode: internal
OLT采用的是内部DBA算法
ONU已经打开
FEC mode : disable
FEC功能关闭
display epon statistics interface interface-type interface-number
【缺省级别】
2:系统级
【描述】
display epon statistics interface命令用来显示OLT或者ONU的统计数据,包括OLT与ONU之间转发数据的数据位平均错误率和数据帧平均错误率。
·       仅当OLT端口处于Up的状态时,才能显示该OLT的统计数据。
·       仅当ONU在线时,才能显示该ONU的统计数据。
·       该命令统计的是某个采样时间段内的错误率,并非为累计值,且当统计值小于1e-9时则也显示0。
# 显示OLT端口下的统计数据。
<Sysname> display epon statistics interface olt 3/0/1
 OLT statistics:
 PON Bit error rate(in 1e-9 unit): 0
 CNI Bit error rate(in 1e-9 unit): 0
# 显示ONU端口下的统计数据。
<Sysname> display epon statistics interface onu 3/0/1:1
 ONU statistics:
 Bit error rate(in 1e-9 unit)  : 0
 Frame error rate(in 1e-9 unit): 0
表1-7 display epon statistics interface命令显示信息描述表
PON口平均数据位错误率
CNI口平均数据位错误率,其中CNI(Core Network Interface,核心网接口)是S7600交换机OLT芯片和交换芯片连接的接口
平均数据位错误率
平均数据帧错误率
display fiber-backup group { all | group-number }
【缺省级别】
2:系统级
all:所有光纤备份组。
group-number:光纤备份组编号,取值范围为1~80。
【描述】
display fiber-backup group命令用来显示光纤备份组中的OLT端口信息及其主备关系。
# 显示光纤备份组1中的OLT端口信息及其主备关系。
<Sysname> display fiber-backup group 1
 fiber backup group 1 information:
 Member         Role       State
 Olt3/0/3       MASTER     ACTIVE
 Olt3/0/4       SLAVE      READY
表1-8 display fiber-backup group命令显示信息描述表
光纤备份组1的信息
Member
光纤备份组成员端口
Role
OLT端口在备份组中的角色:
·       MASTER:主端口
·       SLAVE:备份端口
OLT端口状态:
·       ACTIVE:主端口准备好(芯片准备好且光模块插入)
·       READY:备份端口准备好,主备倒换的必要条件
·       DOWN:其它情况
display onu-event interface interface-type interface-number
【缺省级别】
2:系统级
【描述】
display onu-event interface命令用来显示ONU的注册和注销记录。
·       每个ONU最多支持50条记录,超过最大值后,旧记录将被最新的记录所覆盖。
·       当解除了ONU端口与ONU的绑定或者将EPON单板复位之后,记录信息将被清除。
# 显示ONU的注册和注销记录。
<Sysname> display onu-event interface onu 3/0/1:1
Date         Time       ONU Event       ONU Status
2007/07/28   13:57:03   Registration    Down
2007/07/28   18:00:06   Deregistration  Up
表1-9 display onu-event interface命令显示信息描述表
Date
ONU事件发生的日期
Time
ONU事件发生的时间
ONU Event
ONU事件:
·       Registration:注册
·       Deregistration:取消注册
ONU Status
发生ONU事件时,ONU的状态:
·       Up:当ONU状态为UP时,取消ONU注册
·       Down:当ONU状态为Down时,进行ONU注册
display onuinfo { interface interface-type interface-number | slot slot-number }
【缺省级别】
2:系统级
slot-number:EPON单板所在的槽位号。
【描述】
display onuinfo命令用来显示指定OLT端口、ONU端口或指定槽位EPON单板上所有ONU信息。
显示信息包括:ONU的MAC地址、OLT分配给ONU的LLID、OLT与ONU间的实际光纤长度、绑定的ONU端口号、ONU的类型及硬件版本、软件版本、EEPROM版本、ONU状态和ONU的MAC老化时间。
# 显示OLT4/0/1端口下所有ONU信息。
<Sysname> display onuinfo interface Olt 4/0/1
 ONU Mac Address LLID Dist(M)         Port    Board/Ver  Sft/Epm   State  Aging
 000f-e276-4b90     1       2   Onu4/0/1:2  ET704-A-L/B  110/100      Up    N/A
 000f-e234-5678     0     N/A   Onu4/0/1:1          N/A      N/A Offline    N/A
 000f-e276-4b93     0     N/A          N/A          N/A      N/A  Silent   284s
 ---  3 entries found  ---
# 显示单个ONU端口ONU4/0/1:2所对应的ONU的信息。
<Sysname> display onuinfo interface Onu 4/0/1:2
 000f-e276-4b93     1       2   Onu4/0/1:2  ET704-A-L/B  110/100      Up    N/A
 ---  1 entry found  ---
#显示4号槽位EPON单板上所有ONU信息。
<Sysname> display onuinfo slot 4
-------------------------------- Olt4/0/1 -------------------------------
-------------------------------- Olt4/0/2 -------------------------------
 Error: The port's state should be up!
-------------------------------- Olt4/0/3 -------------------------------
-------------------------------- Olt4/0/4 -------------------------------
 ---  2 entries found  ---
表1-10 display onuinfo命令显示信息描述表
ONU Mac Address
ONU的MAC地址
LLID
OLT为注册成功的ONU自动分配的链路标识。若ONU未注册成功,则显示为0
Dist(M)
OLT与ONU之间的实际光纤长度。如果ONU未注册成功,则显示N/A
Port
被绑定的ONU端口号,若未绑定,则显示为N/A
Board/Ver
ONU的型号和PCB版本号。若ONU未注册成功,则显示为N/A
Sft/Eeprom
ONU的软件版本号和EEPROM的版本号。若ONU未注册成功,则显示为N/A
ONU状态:
·       若该ONU已上电,但没有和ONU端口绑定,则显示为Silent;
·       若ONU未上电,但已和ONU端口绑定,则显示为Offline;
·       若ONU已经绑定且ONU端口打开,则显示为Up;
·       若ONU已经绑定,但ONU端口被手工SHUTDOWN,则显示为Down
Aging
显示处于静默(Silent)状态的ONU的MAC地址老化时间。对于非静默状态的ONU,则显示为N/A
OLT端口没有UP
display onuinfo mac-address mac-address
【缺省级别】
2:系统级
mac-address:ONU的MAC地址。
【描述】
display onuinfo mac-address命令用来显示指定MAC地址的合法ONU信息。
# 根据ONU的MAC地址来显示合法ONU信息。
<Sysname> display onuinfo mac-address 000f-e276-4b93
关于各显示字段的详细解释请参见表1-10
display onuinfo silent { interface interface-type interface-number | slot slot-number }
【缺省级别】
2:系统级
interface-type:端口类型,取值为OLT。
interface-number:OLT端口号。
【描述】
display onuinfo silent命令用来显示指定OLT端口或指定槽位EPON单板上所有处于静默状态的ONU信息。
# 显示4号槽位EPON单板下所有静默状态的ONU信息。
<Sysname> display onuinfo silent slot 4
 000f-e276-4b90     0     N/A          N/A          N/A      N/A  Silent   266s
 000f-e276-4b91     0     N/A          N/A          N/A      N/A  Silent   252s
 000f-e276-4b93     0     N/A          N/A          N/A      N/A  Silent   300s
# 显示OLT端口号OLT 4/0/1下所有静默状态的ONU信息。
<sysname> display onuinfo silent interface Olt 4/0/1
 000f-e276-4b90     0     N/A          N/A          N/A      N/A  Silent   243s
display optics-parameters interface interface-type interface-number
【缺省级别】
1:监控级
【描述】
display optics-parameters interface命令用来显示OLT端口的光参数信息。
# 显示OLT端口的光参数信息。
<Sysname> display optics-parameters interface olt 2/0/8
 Configuration source:                               HOST
 AGC lock time(TQ):                                  11
 EPON AGC gate offset(8-nanosecond units):           18
 EPON AGC discovery offset(8-nanosecond units):      18
 EPON AGC duration(8-nanosecond units):              0
 EPON AGC polarity:                                  low
 CDR lock time(TQ):                                  13
 EPON CDR gate offset(8-nanosecond units):           26
 EPON CDR discovery offset(8-nanosecond units):      26
 EPON CDR duration(8-nanosecond units):              0
 EPON CDR polarity:                                  high
 CDR end of grant gate offset(8-nanosecond units):   36
 CDR end of grant duration(8-nanosecond units):      2
 CDR end of grant polarity:                          low
 Optics end of grant gate offset(8-nanosecond units):36
 Optics end of grant duration(8-nanosecond units):   2
 Optics end of grant polarity:                       low
 Discovery re-locking:                               disable
 Laser Rx loss signal polarity:                      low
 EPON optics transmission signal polarity:           low
 Optics dead zone(8-nanosecond units):               8
 Use optics signal loss:                             false
 EPON port link indication polarity:                 low
 CNI port link indication polarity:                  high
 EPON tbc polarity:                                  low
 Discovery laser on time(TQ):                        32
 Discovery laser off time(TQ):                       32
 EPON Tx signal:                                     enable
表1-11 display optics-parameters interface命令显示信息描述表
光参数配置源:HOST
AGC lock time:                            14
EPON上行流量自动增益控制锁定时间,单位为TQ
EPON AGC gate offset:                     18
AGC重置激活在正常授权CDR重置激活之前的时间偏移
EPON AGC discovery offset:                18
AGC重置激活在发现CDR重置激活之前的时间偏移
EPON AGC duration:                        0
EPON自动增益控制持续时间
EPON AGC重置脉冲电平
·       low:低电平
·       high:高电平
CDR lock time:                            20
EPON接收信号同步时间
EPON CDR gate offset:                     32
EPON CDR重置激活早于正常授权开始时刻的偏移时间
EPON CDR discovery offset:                32
EPON CDR重置激活相对于发现窗口开始时刻的时间偏移
EPON CDR duration:                        0
EPON CDR持续时间
EPON CDR重置脉冲电平
CDR end of grant gate offset:             36
CDR的EoG(End of Grant,授权结束)重置激活偏移
CDR end of grant duration:                2
CDR的EoG重置脉冲持续时间
CDR的EoG重置脉冲电平
Optics end of grant gate offset:          36
Optics的EoG重置激活偏移
Optics end of grant duration:             2
Optics的EoG重置脉冲持续时间
Optics的EoG重置脉冲电平
在发现窗口内重锁功能是否开启
激光器接收损失信号电平
EPON光传输信号电平
Optics dead zone:                         10
授权间隔的最小长度
是否使用了光信号损失
·       false:没有使用
·       true:使用了
EPON端口链路指示时钟电平
CNI端口链路指示时钟电平
输出TBC时钟电平
Discovery laser on time:                  32
ONU发现过程中,激光器打开时间
Discovery laser off time:                 32
ONU发现过程中,激光器关闭时间
EPON下行传输信号发送功能是否开启(enable或者disable)
当功能关闭时,EPON系统中将无数据传送
display transceiver diagnosis interface onu interface-number
【缺省级别】
1:监控级
【描述】
display transceiver diagnosis interface onu命令用来显示ONU设备的当前温度、接收光功率和发送光功率。
·       目前只有LSQ4PT4PSC、LSQ4PT8PSC和LSQ4PT16PSC这三款单板支持本命令。
·       温度、接收光功率和发送光功率的显示需ONU设备支持数字诊断功能。ONU设备是否支持数字诊断功能,请查询ONU设备的相关手册。
#显示端口ONU3/0/4:4对应ONU设备的收发光功率信息。
<Sysname> display transceiver diagnosis interface onu3/0/4:4
Onu3/0/4:4 transceiver diagnostic information:
  Current ONU optical module diagnostic parameters:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    37.00      N/A         N/A       -17.64         1.42
  OLT SFP diagnostic parameters on this ONU:
  RX power: N/A
表1-12 display transceiver diagnosis interface命令显示信息描述表
ONU设备上的光收发诊断信息
Temp(°C)
ONU设备温度
Voltage(V)
电压(暂不支持)
Bias(mA)
偏置电流(暂不支持)
RX power(dBm)
ONU侧PON口接收光功率
TX power(dBm)
ONU侧PON口发送光功率
OLT设备上与该ONU相关诊断信息
RX power
OLT侧PON口接收光功率
display transceiver diagnosis interface olt interface-number
【缺省级别】
1:监控级
【描述】
display transceiver diagnosis interface olt命令用来显示OLT光模块的当前运行参数,包括温度、电压、电流、接收光功率和发送光功率。
#显示端口OLT2/0/4上光模块的收发光功率信息。
<Sysname>display transceiver diagnosis interface olt2/0/4
Olt2/0/4 transceiver diagnostic information:
  Temperature: 37.7 degree centigrade.
  Voltage: 3.3 V.
  Bias current: 19.2 mA.
  Tx power: 2.359 mW 3.73 dBm.
  Rx power: 0.000 mW -33.3 dBm.
表1-13 display transceiver diagnosis interface olt命令显示信息描述表
OLT光模块的光收发诊断信息
Temperature
OLT光模块温度
Voltage
OLT光模块电压
Bias current
OLT光模块偏置电流
Tx power
OLT光模块接收光功率
Rx power
OLT光模块发送光功率
encryption timer { update-time update-time | no-reply-timeout timeout }* slot slot-number
undo encryption timer slot slot-number
FTTH视图
【缺省级别】
2:系统级
update-time:密钥更新的时间,单位为秒,取值范围为1~255,缺省值为10。
timeout:加密响应超时时间,以100ms为单位,取值范围是1~2550,缺省值为30。
slot-numberEPON业务板所在的槽位号。
【描述】
encryption timer命令用来配置加密过程中密钥更新的时间和加密响应的超时时间。undo encryption timer命令用来恢复加密过程中密钥更新的时间和加密响应的超时时间为缺省值。
相关命令可参考display epon-parameter
加密响应超时时间必须小于等于更新密钥的时间。
# 配置3号槽位上EPON业务板的密钥更新时间为20s,加密响应超时时间为5s(50*100ms)。
[Sysname] ftth
[Sysname-ftth] encryption timer update-time 20 no-reply-timeout 50 slot 3
epon-parameter ouilist { oui oui-value oam-version version-value } &<1-9> slot slot-number
undo epon-parameter ouilist slot slot-number
FTTH视图
【缺省级别】
2:系统级
oui-value:ONU的OUI(Organizationally Unique Identifier,全球统一标识)。
version-value :ONU的OAM(Operation、Administration and Maintenance,操作、管理和维护)版本号。
&<1-9>:表示前面的参数最多可以输入9次。
【描述】
epon-parameter ouilist命令用来配置ONU的OUI及扩展OAM版本号列表。undo epon-parameter ouilist命令用来取消指定槽位的EPON业务板上用户配置的OUI和扩展OAM版本号列表,缺省配置不能取消。
缺省情况下,每个EPON业务板启动后都有一个ONU的OUI和扩展OAM版本号分别为111111和1。这样,当OLT下挂H3C的ONU时,只需绑定ONU到指定的ONU端口,ONU即可上线(H3C的ONU对应的OUI和扩展OAM版本号分别为111111和1)。
·              一个EPON业务板不能配置OUI和扩展OAM版本号都完全相同的两条记录。
·              当某EPON业务板的OUI和OAM版本号列表有变动(新增或取消用户配置的列表)时,该单板下的所有ONU会重新注册。
# 配置3号槽位EPON业务板接入的ONU对应的OUI及扩展OAM版本号列表。
[Sysname] ftth
[Sysname-ftth] epon-parameter ouilist oui 111111 oam-version 2 slot 3
fiber-backup group group-number
undo fiber-backup group group-number
FTTH视图
【缺省级别】
2:系统级
【描述】
fiber-backup group命令用来创建光纤备份组并进入光纤备份组视图,若光纤备份组已创建,则直接进入光纤备份组视图。undo fiber-backup group用于删除指定光纤备份组。
当光纤备份组内有成员存在时,则不允许删除该备份组。
# 创建光纤备份组1并进入光纤备份组视图。
[Sysname] ftth
[Sysname-ftth] fiber-backup group 1
 Create group 1 successfully.
[Sysname-fiber-group1]
undo grant-filtering enable
OLT端口视图
【缺省级别】
2:系统级
【描述】
grant-filtering enable命令用来开启OLT端口的授权过滤功能。undo grant-filtering enable用于关闭OLT端口的授权过滤功能。
缺省情况下,OLT端口授权过滤功能处于开启状态。
# 开启OLT端口OLT 3/0/1的授权过滤功能。
[Sysname-Olt3/0/1] grant-filtering enable
1.1.22  group member
group member interface-type interface-number
undo group member interface-type interface-number
光纤备份组视图
【缺省级别】
2:系统级
【描述】
group member命令用来在光纤备份组(需已创建)中加入OLT端口。undo group member用于从光纤备份组中删除指定的OLT端口。
相关配置可参考命令fiber-backup group
# 将OLT端口OLT3/0/1加入到光纤备份组1。
[Sysname] ftth
Create group ID successfully.
[Sysname-fiber-group1] group member olt3/0/1
1.1.23  max-rtt
max-rtt value
undo max-rtt
OLT端口视图
【缺省级别】
3:管理级
max-rtt value:最大RTT(Round Trip Time,往返时间)值,单位为TQ,取值范围为1000~25000,缺省值为13524TQ。
【描述】
max-rtt命令是用于配置ONU到OLT的最大RTT值。undo max-rtt命令用于恢复缺省情况。
·       不建议用户对ONU到OLT的最大往返时间进行配置,除非有特殊需求。RTT和Distance(OLT与ONU之间的距离,单位为米)的关系大致为:RTT=(Distance+157)/1.6393。
·       max-rtt值配置只是对未注册的ONU有效,对已注册的ONU不起作用。
·       关于RTT的详细介绍请参考操作手册相应部分。
# 设置OLT 3/0/1端口下接入的ONU最大RTT往返时间为25000TQ。
[Sysname-Olt3/0/1] max-rtt 25000
multicast vlan-id vlan-id dest-ip ip-address-list
undo multicast vlan-id vlan-id dest-ip ip-address-list
FTTH视图
【缺省级别】
2:系统级
vlan-id :组播VLAN,取值范围为1~4094。
ip-address-list:组播IP地址,ip-address-list = { ip-address | ip-address to ip-address } &<1-10>。其中,&<1-10>表示前面的参数最多可以重复输10次。
【描述】
multicast vlan-id dest-ip命令用来将组播IP地址加入到某个组播VLAN中,以形成一种对应关系。当OLT接收到IGMP Join报文后,如果该报文中所包含的组播IP地址在该对应关系中,则OLT会在该组播IP地址所对应的组播VLAN内形成组播转发表项,否则直接丢弃该IGMP Join报文。undo multicast vlan-id dest-ip命令用来取消该配置。
需要注意的是,一个组播IP地址只能属于一个组播VLAN。
# 将组播IP地址225.1.2.1加入到组播VLAN 1002中。
[Sysname] ftth
[Sysname-ftth] multicast vlan-id 1002 dest-ip 225.1.2.1
port fiber-backup group group-number
undo port fiber-backup group
OLT端口视图
【缺省级别】
2:系统级
【描述】
port fiber-backup group命令用来将OLT端口加入指定的光纤备份组(需已创建)。undo group member用于将OLT端口从该光纤备份组中删除。
光纤备份组创建的相关配置请参见“1.1.20  fiber-backup group”。
# 将OLT端口加入光纤备份组1。
[Sysname] ftth
[Sysname-fiber-group1] quit
[Sysname-Olt3/0/1] port fiber-backup group 1
port hybrid pvid vlan vlan-id
undo port hybrid pvid
OLT端口视图
【缺省级别】
2:系统级
vlan-id:为当前OLT端口指定缺省的VLAN ID,取值范围为14094
【描述】
port hybrid pvid vlan命令用来为当前OLT端口设置缺省VLAN IDundo port hybrid pvid命令用来恢复缺省情况。
缺省情况下,OLT端口的缺省VLANVLAN1
相关配置可参考命令port hybrid vlanport link-type hybrid
在配置OLT端口缺省VLAN的同时,还要开启本端口的QinQ功能(通过qinq enable命令),这样才能保证进入端口的不带Tag的报文成功添加缺省VLANTag标签。
# 将OLT端口OLT3/0/1(Hybrid类型)的缺省VLAN设为100。
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-Olt3/0/1] port hybrid pvid vlan 100
undo port hybrid vlan vlan-id-list
OLT端口视图
【缺省级别】
2:系统级
vlan-id-list:VLAN列表,OLT端口要加入的VLAN的范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,&<1-10>表示前面的参数最多可以重复输入10次。
untagged:发送指定VLAN的报文时不带Tag标签。
【描述】
port hybrid vlan命令用来允许指定的VLAN通过当前OLT端口。undo port hybrid vlan命令用来取消指定的VLAN通过当前OLT端口。
缺省情况下,OLT端口只允许VLAN1的报文通过,并且发送VLAN1的报文时携带Tag。
如果多次使用port hybrid vlan命令,那么OLT端口上允许通过的VLAN是这些vlan-id-list的合集。
需要注意的是,在设置允许指定的VLAN通过OLT端口之前,允许通过的VLAN必须已经存在。
相关配置可参考命令port hybrid pvid vlan port link-type hybrid
·       若当前OLT端口开启了QinQ功能、则该端口要去掉出方向报文的外层Tag,因此port hybrid vlan命令选用untagged参数。
·       若当前OLT端口未开启QinQ功能、则该端口无需去掉出方向报文的外层Tag,因此port hybrid vlan命令选用tagged参数。
# 配置OLT端口OLT3/0/1(Hybrid类型)允许VLAN2、VLAN4、VLAN50~VLAN100通过(指定的VLAN都已经创建),并且发送这些VLAN的报文时携带Tag。
[Sysname-Olt3/0/1] port link-type hybrid
[Sysname-Olt3/0/1] port hybrid vlan 2 4 50 to 100 tagged
OLT端口视图
【缺省级别】
2:系统级
【描述】
port link-type hybrid命令用来设置OLT端口的链路类型为Hybrid。
缺省情况下,所有OLT端口的链路类型均为Hybrid类型。
相关配置可参考命令port hybrid pvid vlan port hybrid vlan
# 将OLT端口OLT3/0/1设置为Hybrid类型端口。
port switch-over
光纤备份组视图
【缺省级别】
2:系统级
【描述】
port switch-over命令用来将光纤备份组中的两个OLT端口手动进行主备切换,即执行该命令后,原主用OLT端口切换成了备用,原备用OLT端口则切换成了主用。
需要注意的是,仅当备用OLT端口状态为ready时,切换才会生效。
完成主备切换后,光纤备份组中的OLT端口信息及其主备关系的查看可参见“1.1.10  display fiber-backup group”。
# 将光纤备份组1中的两个OLT端口手动进行主备切换。
[Sysname] ftth
[Sysname-fiber-group1] port switch-over
1.1.30  sme enable
sme enable
undo sme enable
OLT端口视图
【缺省级别】
2:系统级
【描述】
sme enable命令用来开启同一个OLT端口下不同ONU间的二层互通功能。undo sme enable命令用来关闭同一个OLT端口下不同ONU间的二层互通功能。
缺省情况下,同一个OLT端口下不同ONU间的二层互通功能处于关闭状态。
·              开启同一个OLT端口下不同ONU间的二层互通功能后,这个OLT端口下连接的所有ONU都能够二层互通。
·              开启同一个OLT端口下不同ONU间的二层互通功能后,如果在这个OLT上创建一个新的ONU端口时,新的ONU端口连接的ONU同样可以跟该OLT端口下其它所有ONU进行二层互通。
# 开启OLT3/0/1端口下不同ONU间的二层互通功能。
[Sysname-Olt3/0/1] sme enable
1.1.31  using onu
using onu { onu-number1 [ to onu-number2 ] } &<1-10>
undo using onu { onu-number1 [ to onu-number2 ] } &<1-10>
OLT端口视图
【缺省级别】
2:系统级
onu-number1:ONU端口的编号,取值范围为1~64。
to onu-number2:指定ONU端口编号范围,onu-number2为ONU端口的编号,取值范围为1~64。
&<1-10>:表示前面的参数可以连续输入10次。
【描述】
using onu命令用来为当前OLT端口创建虚拟的ONU端口。undo using onu命令用来删除当前OLT端口下指定的ONU端口。
缺省情况下,在EPON业务板启动后,没有为任何OLT端口创建ONU端口。
·              必须先使用using onu命令创建了ONU端口,才能使用interface命令进入相应的ONU端口视图。
·              为了避免系统资源浪费,请创建和在线ONU数量相当的ONU端口,以免系统留有大量空ONU端口。
在配置了ONU全自动绑定模式下,不能再使用undo using onu 命令删除已创建的ONU端口。
# 为OLT3/0/1端口创建子通道号为5的ONU端口ONU3/0/1:5。
[Sysname-Olt3/0/1] using onu 5
Please wait…Done.
# 为接口OLT3/0/1创建子通道号为1到5的ONU端口。
[Sysname-Olt3/0/1] using onu 1 to 5
Please wait….Done.
[Sysname-Olt3/0/1] display interface onu brief
The brief information of interface(s) under bridge mode:
Interface            Link      Speed        Duplex   Link-type  PVID
Onu3/0/1:1           DOWN      --           --       access     1
Onu3/0/1:2           DOWN      --           --       access     1
Onu3/0/1:3           DOWN      --           --       access     1
Onu3/0/1:4           DOWN      --           --       access     1
Onu3/0/1:5           DOWN      --           --       access     1
2 ONU远程管理配置命令
2.1  ONU远程管理配置命令
2.1.1  bind onuid
bind onuid onuid
undo bind onuid
ONU端口视图
【缺省级别】
2:系统级
onuid:需要进行绑定的ONU的MAC地址,形如H-H-H
【描述】
bind onuid命令是用于将ONU端口与ONU进行绑定。undo bind onuid命令用来取消ONU和ONU端口的绑定关系。
·       一个ONU端口上只能绑定一台ONU,且一台ONU也只能绑定到一个OLT下的一个ONU端口,即:在一个OLT端口下,ONU端口和ONU设备是一一对应的关系。
·       在光纤备份情况下,一台ONU可以绑定到互为备份的两个OLT端口下的两个ONU端口。
# 将ONU3/0/2:1端口与MAC地址为000f-e200-0104的ONU进行绑定。
[Sysname] interface onu 3/0/2:1
[Sysname-Onu3/0/2:1] bind onuid 000f-e200-0104
dba-report queue-id queue-id { active | inactive } threshold threshold-value
undo dba-report queue-id
ONU端口视图
【缺省级别】
2:系统级
queue-id:队列编号,取值范围为1~8。
threshold-value:单个队列所对应的阈值,取值范围为0~65535。
active:阈值生效。
inactive:阈值不生效。
缺省状态下,队列1~3缺省阈值为0,阈值生效;队列4~5缺省阈值为65535,阈值生效;队列6~8缺省阈值为0,阈值不生效。
【描述】
dba-report queue-id threshold命令用来配置单个队列所对应的阈值。undo dba-report queue-id命令用来恢复单个队列所对应的阈值为缺省值。
# 配置队列1所对应的阈值为200,且生效。
[Sysname] interface onu 3/0/1:1
[Sysname-Onu3/0/1:1] dba-report queue-id 1 active threshold 200
dba-report queue-set-number queue-set-number
undo dba-report queue-set-number
ONU端口视图
【缺省级别】
2:系统级
queue-set-number:队列集个数,取值范围为2~4,缺省值为2。
【描述】
dba-report queue-set-number命令用来配置ONU Report帧支持的队列集个数。undo dba-report queue-set-number命令用来恢复ONU Report帧支持的队列集个数为缺省值。
H3C的ONU Report帧支持2个队列集。
# 配置ONU Report帧支持的队列集个数为2。
[Sysname-Onu3/0/1:1] dba-report queue-set-number 2
deregister onu
ONU端口视图
【缺省级别】
2:系统级
【描述】
deregister onu命令用来将ONU取消注册,之后ONU会重新进行注册。
# 将ONU(ONU3/0/1:1)取消注册。
[Sysname-Onu3/0/1:1] deregister onu
display dhcp-client
ONU端口视图
【缺省级别】
1:监控级
【描述】
display dhcp-client命令用来显示ONU作为DHCP Client端时的地址分配信息。
# 显示ONU作为DHCP Client端时的地址分配信息。
[Sysname-Onu3/0/1:1] display dhcp-client
 DHCP client statistic information:
  Current machine state : BOUND
  Allocated IP          : 192.168.0.7        255.255.255.0
  Gateway IP            : 192.168.0.2
  Server IP             : 192.168.0.1
  Allocated lease       : 86400  seconds
  T1 to renew           : 43200  seconds
  T2 to rebind          : 75600  seconds
  T1 left               : 43197  seconds
  T2 left               : 75597  seconds
从以上信息可以看到获得的IP地址是192.168.0.7,子网掩码是255.255.255.0,网关地址是192.168.0.2。
表2-1 display dhcp-client命令显示信息描述表
DHCP Client状态机状态
Allocated IP
DHCP Client分配到IP地址
Gateway IP
网关IP地址
Server IP
选择的DHCP server地址
Allocated lease
租约时长
T1 to renew
DHCP Client的1/2租约时间(以秒为单位)
T2 to rebind
DHCP Client的7/8租约时间(以秒为单位)
Server IP
选择的DHCP server地址
ONU端口视图
【缺省级别】
1:监控级
【描述】
display epon-multicast information命令用来显示可控组播模式下的组播相关信息。
# ONU的组播模式为IGMP Snooping模式时显示可控组播相关信息。
[Sysname-Onu3/0/1:1] display epon-multicast information
 ONU is not in multicast-control mode.
# ONU的组播模式为可控组播模式但未生成组播控制表项时显示可控组播相关信息。
 Multicast-control information: None.
# ONU的组播模式为可控组播模式且生成了组播控制表项时显示可控组播相关信息。
 UNI number 1:
 Multicast vlan 10
 Current channel list:
 multicast ip:225.0.0.2
 status:permit
 Multicast vlan 10
 multicast ip:225.0.0.3
 status:preview
 preview times:16
 preview remain time:144s
表2-2 display epon-multicast information命令显示信息描述表
表示ONU组播控制模式为IGMP Snooping,此时无组播控制信息
表示ONU组播控制模式为可控组播模式,但没有生成组播控制表项,原因有两种:
·       未配置组播控制内容;
·       组播客户端没有发送组播加入报文
Multicast-control infomation
可控组播信息
UNI number 1
UNI端口编号
Multicast vlan 10
组播VLAN编号
当前组播频道列表
multicast ip
组播频道对应的组播IP地址
status:permit
组播控制策略
·       permit:允许观看对应的组播频道(无时间限制)
·       preview:允许预览对应的组播频道(有时间限制)
preview times:16
表示这是对相应组播频道的第16次预览
表示离本次预览结束还有144s
display onu-protocol [ stp | igmp-snooping | dhcp-snooping information ]
ONU端口视图
【缺省级别】
1:监控级
stp:支持RSTP协议。
igmp-snooping:支持IGMP Snooping协议。
dhcp-snooping information:支持DHCP-Snooping Option 82协议。
【描述】
display onu-protocol命令用来显示ONU(必须处于Up的状态)所支持的协议信息。
如果用户不指定参数,缺省情况下则显示ONU所支持的所有协议信息。
对于不同型号的ONU设备,该命令的显示信息可能有所不同。
# 显示ONU所支持的IGMP Snooping协议信息。
[Sysname-Onu3/0/1:1] display onu-protocol igmp-snooping
 Protocol name: IGMP snooping
 Protocol status: enabled
 Total 4 MAC Group(s).
 group:0100-5e01-0140
 port :9
 group:0100-5e01-013f
 port :9
 group:0100-5e01-013e
 port :9
 group:0100-5e01-013d
 port :9
表2-3 display onu-protocol igmp-snooping命令显示信息描述表
协议名
协议状态:enable或者disable
ONU上记录的组播MAC地址总数
group
组播MAC地址
port
UNI端口号
ONU端口视图
【缺省级别】
1:监控级
【描述】
display vendor-specific information命令用来显示ONU(必须处于Up的状态)详细信息。
# 显示ONU端口ONU3/0/1:1对应的ONU详细信息。
[Sysname-Onu3/0/1:1] display vendor-specific information
serial number
     vendor id : H3C
     onu mac address : 000f-e276-4b93
     onu model : 0x704
     onu hardware version : A
     onu software version : 110
 firmware version : 0x214
 chipset information :
     vendor id : 0x4536
     chip model : 6301
     revision version : 0x00
     design date : 07/09/27
 onu capability :
     gigabit ethernet interface :  not support
     fast ethernet interface :  support
     voip service :  not support
     tdm ces service :  not support
     gigabit ethernet ports number :  0
     fast ethernet ports number :  4
     fast ethernet ports :
       0x1
       0x2
       0x3
       0x4
     pots ports number :  0
     e1 ports number :  0
     upstream queues number :  4
     Maximum queues per port upstream :  4
     downstream queues number :  4
     Maximum queues per port downstream :  4
     battery backup :  not support
 forward error correction ability : support
 forward error correction mode : disable
 DBA-Report parameters :
      queue sets number : 2
      queue 1 : state:1 , value:0
      queue 2 : state:1 , value:0
      queue 3 : state:1 , value:0
      queue 4 : state:1 , value:65535
      queue 5 : state:1 , value:65535
      queue 6 : state:1 , value:0
      queue 7 : state:1 , value:0
      queue 8 : state:1 , value:0
 Multicast-mode : multicast control
表2-4 display vendor-specific information命令显示信息描述表
serial number
序列号
     vendor id : H3C
ONU厂商ID
ONU的MAC地址
     onu model : 0x704
ONU类型
     onu hardware version : B
ONU硬件版本
ONU软件版本
固件版本
芯片信息
     vendor id : 0x4536
芯片厂商ID
     chip model : 6301
芯片类型
修订版本
设计日期
onu capability :
ONU能力信息
是否具有千兆以太网接口
是否具有百兆以太网端口
是否支持Voice over IP业务
是否支持时分复用电路仿真(Circuit Emulation Service)业务
千兆以太网端口数目
百兆以太网端口数目
       0x1
       0x2
       0x3
       0x4
百兆以太网端口编号:1、2、3、4
POTS(Plain Old Telephone Service,传统电话业务)端口数量
     e1 ports number :  0
E1端口数目
上行队列数目
每端口上行支持的最大队列数目
下行队列数目
每端口下行支持的最大队列数目
是否支持电池备份
是否支持FEC功能
是否开启FEC功能
DBA Report消息参数
支持的队列集数目
各队列的状态及阈值,当state为0表示该队列关闭(disable),为1表示该队列开启(enable)
组播模式:IGSP(IGMP Snooping)或者multicast control
display uni-information uni-number
ONU端口视图
【缺省级别】
1:监控级
uni-number:UNI端口号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为80。
【描述】
display uni-information命令用来显示当前UNI端口状态信息。
# 显示ONU的UNI端口1的状态信息。
[Sysname-Onu3/0/1:1] display uni-information 1
uni-number : 1
 Configuration :
 PHY admin state for ethernet port : UP
 Flow-control : closed
 Auto-negotiation state : enable
 Port-isolate : disable
 Mid-type : auto
 Port-policy :
   inbound : none
   outbound : none
 Vlan-configuration :
     Current-vlan-mode : transparent
 Multicast-vlan : none
 Multicast-group-number : 64
 Multicast-strip-tag : disable
 Current Status :
 Link-state : UP
 Auto-negotiation local technology ability :
     100BASE-TX
     Full duplex 100BASE-TX
     Full duplex 10BASE-T
     10BASE-T
     Symmetric PAUSE operation for full duplex links
     Asymmetric PAUSE operation for full duplex links
 Auto-negotiation advertised technology ability :
     100BASE-TX
     10BASE-T
 100Mbps-speed mode, Full-duplex mode
 Link speed type is autonegotiation, Link duplex type is autonegotiation
Input(total):  202 packets, 15270 bytes
          8 broadcasts, 0 multicasts, 194 unicasts, 0 pauses
 Input:  0 input errors, 0 runts, 0 giants, 0 InRxErr, 0 CRC
         0 buffer failures
 Output(total): 44644 packets, 2959256 bytes
          37035 broadcasts, 7312 multicasts, 297 unicasts, 0 pauses
 Output: 0 output errors, 0 deferred, 0 collisions, 0 InTxErr
表2-5 display uni-information命令显示信息描述表
uni-number : 1
UNI端口号
Configuration :
显示UNI端口配置情况
端口的管理状态:
·       UP:undo shutdown状态
·       DOWN:手工shutdown状态
流量控制情况:
·       open:流量控制功能开启
·       closed:流量控制功能关闭
自协商功能状态:
·       enable:自协商功能开启
·       disable:自协商功能关闭
端口是否加入端口隔离组:
·       enable:端口加入端口隔离组
·       disable:端口不加入端口隔离组
Mid-type : auto
端口支持的网线类型:
·       across:支持交叉网线
·       auto:即可以支持交叉网线也可以支持直连网线
·       normal:支持直连网线
Port-policy :
   inbound : none
   outbound : none
UNI端口的上下行流量监管参数
·       inbound:上行流量监管参数
·       outbound:下行流量监管参数
Vlan-configration :
VLAN操作模式
UNI端口支持的组播频道数目
是否开启了删除UNI端口下行组播流的VLAN Tag功能
Current Status
显示当前状态
Link-state : UP
二层链路状态
     100BASE-TX
     10BASE-T
本地自协商能力:
·       100BASE-TX
·       Full duplex 100BASE-TX
·       Full duplex 10BASE-T
·       10BASE-T
·       全双工同步PAUSE帧
·       全双工异步PAUSE
     100BASE-TX
     10BASE-T
自协商通告能力:
·       100BASE-TX
·       10BASE-T
百兆全双工模式
链路速率自协商,全双工模式自协商
共接收202个数据包,15270字节。其中,8个广播包,0个组播包,194个单播包,0个pause帧
         0 buffer failures
收到的错误帧0个,超小帧(runt)0个,超大帧(giant)0个
0个因端口发送缓冲区不足而丢弃的报文
共发送44644个数据包,2959256字节,其中:37035广播包,7312组播包,297单播包,0 pause帧
0个输出错误,0个延迟报文,0冲突帧,0个发送过程出现错误的报文
·       runt是指长度小于64字节、格式正确且包含有效的CRC字段的帧;
·       giant是指有效长度大于1518字节(如果不带VLAN Tag)或大于1522字节(如果带VLAN Tag报文)的帧;
·       buffer failures由于端口发送缓冲区不足而丢弃的报文数量;
·       延迟报文是指发送前检测到冲突而被延迟发送的报文;
·       冲突帧是指在发送过程中检测到冲突的而停止发送的报文。
encrypt enable
undo encrypt enable
ONU端口视图
【缺省级别】
2:系统级
【描述】
encrypt enable命令用来启动下行流量加密。undo encrypt enable命令用来关闭流量加密。
缺省情况下,下行流量加密。
# 启动下行流量加密。
[Sysname-Onu3/0/1:1] encrypt enable
2.1.11  encrypt key
encrypt key key-value
undo encrypt key
ONU端口视图
【缺省级别】
2:系统级
key-value:加密密钥,为16位以内的字符串。
【描述】
encrypt key命令用来设置流量加密密钥。undo encrypt命令用来恢复系统采用缺省的流量加密密钥。
当前,暂不支持encrypt key命令。
# 配置流量加密密钥。
[Sysname-Onu3/0/1:1] encrypt key test
 This operation is not supported in current version!
undo forward-error-correction enable
ONU端口视图
【缺省级别】
2:系统级
【描述】
forward-error-correction enable命令用来配置OLT和ONU的FEC(Forward Error Correction,前向错误纠错)功能。undo forward-error-correction enable命令用来取消该功能。
缺省情况下,OLT和ONU的FEC功能关闭。
# 开启OLT和ONU的FEC功能。
[Sysname-Onu3/0/1:1] forward-error-correction enable
2.1.13  ip address
ip address { dhcp-alloc | ip-address mask gateway gateway }
undo ip address
ONU端口视图
【缺省级别】
2:系统级
dhcp-alloc:通过DHCP功能自动获取IP地址。
ip-address:IPv4地址。
mask:子网掩码,可采用点分十进制的形式或0~32之间的整数(表示网络地址长度)
gateway:网关IP地址。
【描述】
ip address命令用来设置ONU的IP地址的获取方式:手工配置或通过DHCP协议自动获取。undo ip address命令用来恢复ONU的IP地址为缺省情况。
缺省情况下,没有为ONU手工配置IP地址,也没有设置通过DHCP自动获取。
# 配置ONU的IP地址为192.168.0.1/24,网关为192.168.0.99。
[Sysname-Onu3/0/1:1] ip address 192.168.0.1 24 gateway 192.168.0.99
2.1.14  linktest
linktest [ frame-number value | frame-size value | delay { on | off } | vlan-tag
{ on [ vlan-priority value | vlan-id value ] | off } ] *
ONU端口视图
【缺省级别】
2:系统级
frame-number value:测试帧数,value值的取值范围为1~250,缺省值为20。
frame-size value:测试帧长,单位为字节,value值的取值范围为60~1514,缺省值为1000字节。
delay:是否包括时延测试,on表示包括,off则表示不包括,缺省情况下包括时延测试。
vlan-tag:测试帧是否包括VLAN Tag,on表示包括,off则表示不包括,缺省情况下测试帧不包括VLAN Tag。
vlan-priority value:测试帧的VLAN优先级,value的取值范围为0~7,0表示优先级最低,7表示优先级最高,缺省情况下测试帧不包括VLAN Tag,因此也没有VLAN优先级。
vlan-id value:测试帧所属VLAN的值,value的取值范围为1~4094,缺省值为1。
【描述】
linktest命令用来对OLT和ONU之间的光纤链路进行连通性测试。
只有当ONU在线时才能进行连通性测试。
# 设置测试帧数为100,对ONU(ONU3/0/1:1)和OLT间的链路进行测试。
[Sysname-Onu3/0/1:1] linktest frame-number 100
 It may affect data transmission, continue?[Y/N]:y
 Maximum delay(in TQ): 26408
 Mean delay(in TQ)   : 24777
 Minimum delay(in TQ): 19922
 Sent frames         : 100
 Received frames     : 100
 Error frames        : 0
当显示结果为“The link is disconnected!”时,表明在ONU发出的帧不为0的情况下,却没有收到任何正确帧,即“Received frames”字段为0。
loopback enable
undo loopback  enable
ONU端口视图
【缺省级别】
2:系统级
【描述】
loopback enable命令用于开启ONU的MAC环回。undo loopback  enable命令用于取消环回。
缺省情况下,没有开启ONU的MAC环回。
相关配置可参考“端口基本配置命令”中的loopback命令
·       开启ONU的MAC环回会影响设备性能,建议用户谨慎使用。
·       MAC环回不会自动结束,可通过undo loopback  enable命令取消环回。
# 开启ONU的MAC环回功能,并于1分钟后手工取消。
[Sysname-Onu3/0/1:1]loopback enable
 Warning: enable loopback will affect system performance and business, are you sure?(Y/N)y
[Sysname-Onu3/0/1:1]undo loopback enable
management-vlan vlan-id
undo management-vlan
ONU端口视图
【缺省级别】
2:系统级
vlan-id:管理VLAN ID,取值范围为1~4094。
【描述】
management-vlan命令用来配置ONU的管理VLAN,undo management-vlan命令用来恢复ONU的管理VLAN为缺省值。
缺省情况下,ONU的管理VLAN为VLAN 1。
# 配置ONU的管理VLAN为VLAN10。
[Sysname-Onu3/0/1:1] management-vlan 10
multicast-control host-aging-time host-aging-time
undo multicast-control host-aging-time
ONU端口视图
【缺省级别】
1:监控级
host-aging-time:可控组播模式下组播组成员端口老化时间,单位为秒,取值范围为200~1000,缺省值为260。
【描述】
multicast-control host-aging-time命令用来配置可控组播模式下组播组成员端口老化时间。undo multicast-control host-aging-time命令用来恢复可控组播模式下组播组成员端口老化时间为缺省值。
缺省情况下,组播组成员端口老化时间为260秒。
需要注意的是,本命令只能在可控组播模式下配置。
# 配置可控组播模式下组播组成员端口老化时间为500秒。
[Sysname-Onu3/0/1:1] multicast-control host-aging-time 500
multicast-mode { igmp-snooping | multicast-control }
undo multicast-mode
ONU端口视图
【缺省级别】
2:系统级
igmp-snooping:IGMP Snooping模式。
multicast-control:可控组播模式。
【描述】
multicast-mode命令用来配置ONU的组播模式。undo multicast-mode命令用来恢复ONU的组播模式为缺省情况。
缺省情况下,ONU的组播模式为IGMP Snooping模式。
# 配置ONU的组播模式为可控组播模式。
[Sysname-Onu3/0/1:1] multicast-mode multicast-control
onu bind auto [ slot slot-id ]
undo onu bind auto [ slot slot-id ]
FTTH视图
【缺省级别】
2:系统级
slot-id:槽位号。
【描述】
onu bind auto命令用来开启ONU全自动绑定功能。undo onu bind auto命令用来关闭ONU全自动绑定功能。
缺省情况下,ONU全自动绑定功能处于关闭状态。
·       在配置了ONU全自动绑定模式下,不能再使用undo using onu 命令删除已创建的ONU端口。
·       该命令不能与onu bind batch命令同时使用。
# 开启ONU全自动绑定功能。
[Sysname] ftth
[Sysname-ftth] onu bind auto
onu bind batch [ slot slot-id ]
FTTH视图
【缺省级别】
2:系统级
slot-id:槽位号。
【描述】
onu bind batch命令用来触发设备ONU批量绑定功能。
缺省情况下,ONU批量绑定功能关闭状态。
·       执行该命令后,只将当前静默的ONU MAC绑定到ONU接口上,对于后加入的ONU不会再进行绑定处理。
·       该命令不能与onu bind auto命令同时使用。
# 对槽位2启动ONU批量绑定功能。
[Sysname] ftth
[Sysname-ftth] onu bind batch slot 2
2.1.21  onu-event
onu-event { debug | log | trap } enable level severity
undo onu-event { debug | log | trap }
ONU端口视图
【缺省级别】
2:系统级
debugOLT设备上查看通过该命令允许ONU上报的debug信息。
logOLT设备上查看ONU设备产生的相关日志信息。
trapOLT设备上查看ONU设备产生的相关告警信息。
severityONUOLT上报信息的级别,根据上报信息的优先级由高到低分别为以下8类:
emergenciesalertscriticalerrorswarningsnotificationsinformationdebugging
【描述】
onu-event { debug | log | trap } enable level命令用来设置ONU是否向OLT上报logdebug或者trap信息。undo onu-event { debug | log | trap }命令用来将设置恢复为缺省情况。
缺省情况下,ONU的所有事件信息均不上报OLT。
需要注意的是:由于OLT下挂的ONU数量众多,因此开启ONU向OLT上报信息功能后可能会有大量的ONU上报的信息、这样很容易造成链路阻塞。所以建议用户根据需要选择只上报必要的信息。
# 设置Onu3/0/1:1所有通过ONU打印通道的log信息,且比errors更紧急的信息(也就是级别号比errors小的(level<=3))log信息上报,其它不上报。
[Sysname-Onu3/0/1:1] onu-event log enable level ?
  alerts         <=ALERT level memssages to OLT    (severity=1)
  critical       <=CRIT level messages to OLT      (severity=2)
  debugging      <=DEBUG level messages to OLT     (severity=7)
  emergencies    <=EMERG Level Switch to OLT       (severity=0)
  errors         <=ERR level messages to OLT       (severity=3)
  information    <=INFO level messages to OLT      (severity=6)
  notifications  <=NOTICE level messages to OLT    (severity=5)
  warnings       <=WARN level messages to OLT      (severity=4)
[Sysname-Onu3/0/1:1] onu-event log enable level errors
# 设置Onu3/0/3:1所有通过ONU打印通道的log信息都不上报。
[Sysname] interface onu 3/0/3:1
[Sysname-Onu3/0/3:1] undo onu-event log enable
表2-6 onu-event log enable level命令信息级别描述表
告警级别
emergencies
0
系统不可用信息
alerts
1
需要立刻做出反应的信息
critical
2
严重信息
errors
3
错误信息
warnings
4
警告信息
notifications
5
正常出现但是重要的信息
information
6
需要记录的通知信息
debugging
7
调试过程产生的信息
undo onu port-isolate enable
ONU端口视图
【缺省级别】
2:系统级
【描述】
onu port-isolate enable命令用来隔离指定ONU下所有UNI端口。undo onu port-isolate enable命令用来取消UNI端口隔离。
缺省情况下,UNI端口隔离功能关闭。
# 隔离ONU3/0/1:1端口对应的ONU下所有UNI端口。
[Sysname-Onu3/0/1:1] onu port-isolate enable
onu-protocol { stp | dhcp-snooping | dhcp-snooping information | pppoe } enable
undo onu-protocol { stp | dhcp-snooping | dhcp-snooping information | pppoe } enable
ONU端口视图
【缺省级别】
2:系统级
stp:支持RSTP协议。
dhcp-snooping:支持DHCP-Snooping协议。
dhcp-snooping information:支持DHCP-Snooping Option82协议。
pppoe:支持PPPoE+协议。
【描述】
onu-protocol enable命令用来开启ONU的RSTP、DHCP-Snooping、DHCP-Snooping Option82或PPPoE+功能。undo onu-protocol enable命令用来关闭指定功能。
缺省情况下,RSTP功能处于开启状态,DHCP-Snooping、DHCP-Snooping Option82及PPPoE+功能均处于关闭状态。
在S7600交换机全局开启STP功能的情况下,所有ONU都必须开启STP功能,且ONU不能作为STP根桥,以免网络出现异常。
# 开启ONU的DHCP-Snooping功能。
[Sysname-Onu3/0/1:1] onu-protocol dhcp-snooping enable
onu-protocol igmp-snooping { host-aging-time host-aging-time | leave-aggregation enable | max-response-time max-response-time | report-aggregation enable | router-aging-time router-aging-time }
undo onu-protocol igmp-snooping { host-aging-time | leave-aggregation enable | max-response-time | report-aggregation enable | router-aging-time }
ONU端口视图
【缺省级别】
2:系统级
host-aging-time:组播组成员端口老化时间,单位为秒,取值范围为200~1000,缺省值为260。
leave-aggregation enable:开启IGMP离开报文抑制功能。
max-response-time:特定组查询报文的响应超时时间,单位为秒,取值范围为1~25,缺省值为1。
report-aggregation enable:开启IGMP加入报文抑制功能。
router-aging-time:路由器端口老化时间,单位为秒,取值范围为1~1000,缺省值为105。
onu-protocol igmp-snooping命令中由max-response-time参数设置的特定组查询报文的响应超时时间,当设备第一次在超过该时间后还没有收到响应报文时,会再发一次特定组查询报文,如果在该响应时间内还没有收到响应报文,则删除相应ONU上的该组播组。
【描述】
onu-protocol igmp-snooping命令用来配置IGMP-Snooping相关定时器和IGMP成员关系报告报文抑制。undo onu-protocol igmp-snooping命令用来恢复IGMP-Snooping相关定时器和IGMP成员关系报告报文抑制配置为缺省值。
缺省情况下,IGMP加入报文抑制功能处于关闭状态,IGMP离开报文抑制功能处于开启状态。
·              设置组播组成员端口化时间用来控制组播组成员的刷新频率。在组成员频繁变化的环境下,相应的需要把老化时间设置的短一些,反之亦然。
·              路由器端口是指连接路由器的端口,ONU通过它接收来自路由器的通用查询报文。定时器时长应设置为网络上使用的通用查询时间间隔的2.5倍左右。
# 开启ONU的IGMP加入报文抑制功能。
[Sysname-Onu3/0/1:1] onu-protocol igmp-snooping report-aggregation enable
port access vlan vlan-id
undo port access vlan
ONU端口视图
【缺省级别】
2:系统级
vlan-id:指定的VLAN编号,取值范围为1~4094。
【描述】
port access vlan命令用来将当前Access端口加入到指定的VLAN中。undo port access vlan命令用来把Access端口恢复到缺省VLAN中。
缺省情况下,ONU端口属于VLAN1。
此命令使用的条件是vlan-id所指定的VLAN必须已创建。
# 将ONU端口ONU3/0/1:1加入到VLAN3中。
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname-Onu3/0/1:1] port access vlan 3
port link-type { access | trunk }
undo port link-type
ONU端口视图
【缺省级别】
2:系统级
access:设置ONU端口的链路类型为Access类型。
trunk:设置ONU端口的链路类型为Trunk类型。
【描述】
port link-type命令用来设置ONU端口的链路类型。undo port link-type命令用来恢复缺省情况。
缺省情况下,所有ONU端口的链路类型均为Access类型。
配置ONU端口的链路类型为Trunk后,ONU端口即允许所有VLAN的报文通过。
# 将ONU端口ONU3/0/1:1设置为Trunk类型端口。
[Sysname-Onu3/0/1:1] port link-type trunk
port trunk pvid vlan vlan-id
undo port trunk pvid
ONU端口视图
【缺省级别】
2:系统级
vlan-id:指定ONU端口的缺省VLAN ID,取值范围为14094
【描述】
port trunk pvid vlan命令用来设置ONU端口配置为Trunk类型后的缺省VLAN IDundo port trunk pvid命令用来恢复缺省情况。
缺省情况下,Trunk端口的缺省VLANVLAN1
Trunk端口,执行undo vlan命令删除端口的缺省VLAN后,端口的缺省VLAN配置不会改变,即使用已经不存在的VLAN作为缺省VLAN
相关配置可参考命令port link-type
# ONU端口ONU3/0/1:1Trunk类型)的缺省VLAN设置为100
[Sysname-Onu3/0/1:1] port trunk pvid vlan 100
2.1.28  reboot onu
reboot onu
ONU端口视图
【缺省级别】
2:系统级
【描述】
reboot onu命令可以用于将ONU设备重新启动。
需要注意的是,只有在线ONU设备才能通过本命令远程重启。
# 将ONU(ONU3/0/1:1)重新启动。
[Sysname-Onu3/0/1:1] reboot onu
reset counters uni [ uni-number ]
ONU端口视图
【缺省级别】
2:系统级
uni-number:UNI端口号,取值范围为1~当前ONU支持的最大UNI端口数,缺省情况下,上限值为80。
【描述】
reset counters uni命令用来清空指定UNI端口的统计计数信息。
如果UNI端口不指定,缺省情况下则清空当前ONU所有UNI端口的计数信息。
ONU必须处于Up的状态。
相关配置请参见“2.1.9  display uni-information”。
# 清空UNI端口1计数信息。
[Sysname-Onu3/0/1:1] reset counters uni 1
undo shutdown management-vlan-interface
ONU端口视图
【缺省级别】
2:系统级
【描述】
shutdown management-vlan-interface命令用来关闭ONU的管理VLAN接口。undo shutdown management-vlan-interface命令用来打开ONU的管理VLAN接口。
缺省情况下,管理VLAN接口为Shutdown状态。当执行undo shutdown management-vlan-interface命令后,管理VLAN接口的状态与该VLAN内以太网端口(即UNI端口)状态有关:
·              当ONU的管理VLAN接口对应VLAN下的所有以太网端口状态为Down时,则管理VLAN接口为关闭状态;
·              当ONU的管理VLAN接口对应VLAN下有一个或一个以上的以太网端口处于Up状态,则管理VLAN接口处于打开状态。
# 打开ONU的管理VLAN接口。
[Sysname-Onu3/0/1:1] undo shutdown management-vlan-interface
uni uni-number auto-negotiation
undo uni uni-number auto-negotiation
ONU端口视图
【缺省级别】
2:系统级
uni-numberUNI端口号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为80。
【描述】
uni auto-negotiation命令用来开启UNI端口的自协商功能。undo uni auto-negotiation用来关闭UNI端口的自协商功能。
缺省情况下,UNI端口自协商功能开启。
UNI端口自协商功能不能与双工状态、MDI模式和速率配置同时执行。
# 开启UNI端口1的自协商功能。
[Sysname-Onu3/0/1:1] uni 1 auto-negotiation
uni uni-number description text
undo uni uni-number description
ONU端口视图
【缺省级别】
2:系统级
text:UNI端口的描述字符串,长度为140个字符。
【描述】
uni description命令用来描述UNI端口。undo uni description命令用来恢复UNI端口描述为缺省值。
缺省情况下,未对UNI端口进行描述。
# 将UNI 1端口描述为Test。
[Sysname-Onu3/0/1:1] uni 1 description Test
2.1.33  uni duplex
uni uni-number duplex { full | half | auto }
undo uni uni-number duplex
ONU端口视图
【缺省级别】
2:系统级
full:端口处于全双工状态。
half:端口处于半双工状态。
auto:端口处于自协商状态。
【描述】
uni duplex命令用来设置UNI端口双工状态。undo uni duplex命令用来将端口的双工状态恢复为缺省值。
缺省情况下,端口处于全双工状态。
# 设置UNI端口1为自协商状态。
[Sysname-Onu3/0/1:1] uni 1 duplex auto
uni uni-number flow-control
undo uni uni-number flow-control
ONU端口视图
【缺省级别】
2:系统级
【描述】
uni flow-control命令用来开启UNI端口流量控制功能。undo uni flow-control命令用来关闭该功能。
缺省情况下,UNI端口流量控制功能关闭。
# 开启UNI端口1流量控制功能。
[Sysname-Onu3/0/1:1] uni 1 flow-control
uni uni-number igmp-snooping fast-leave
undo uni uni-number igmp-snooping fast-leave
ONU端口视图
【缺省级别】
2:系统级
【描述】
uni igmp-snooping fast-leave命令用来开启UNI端口快速离开功能。undo uni igmp-snooping fast-leave命令用来关闭该功能。
缺省情况下,UNI端口快速离开功能关闭。
# 开启UNI端口1快速离开功能。
[Sysname-Onu3/0/1:1] uni 1 igmp-snooping fast-leave
2.1.36  uni mdi
uni uni-number mdi { across | auto | normal }
undo uni uni-number mdi
ONU端口视图
【缺省级别】
2:系统级
uni-numberUNI端口号,取值范围为1~当前ONUUNI端口数,且支持最大的UNI端口数为80
across:连接的网线类型为交叉网线。
auto:自动识别是平行网线还是交叉网线。
normal:连接的网线类型为平行网线。
【描述】
uni mdi命令用来设置UNI端口MDI模式。undo uni mdi命令用来将UNI端口MDI模式恢复为缺省情况。
缺省情况下,UNI端口MDI模式为auto,即能自动识别所连接的网线类型。
# 设置UNI端口1的MDI模式为自动识别auto
[Sysname-Onu3/0/1:1] uni 1 mdi auto
uni uni-number multicast vlan { vlan-id } & <1-50>
undo uni-number multicast vlan { { vlan-id } & <1-50> | all }
ONU端口视图
【缺省级别】
2:系统级
vlan-id组播VLAN ID,取值范围1~4094,&<1-50>表示前面的参数最多可以重复输50次。
all:所有的组播VLAN ID。
【描述】
uni multicast vlan命令用来将UNI端口加入用户指定的组播VLAN中。undo uni multicast vlan命令用来取消将UNI端口加入用户指定的组播VLAN中。
仅当ONU处于IGMP Snooping模式下时,该命令才能执行,相关命令请参见multicast-mode
# 将UNI端口1加入组播VLAN 2000和VLAN 3000中。
[Sysname-Onu3/0/1:1] uni 1 multicast vlan 2000 3000
uni uni-number multicast-control multicast-address { multicast-address [ to multicast-address ] } &<1-10> [ source-ip ip-address [ to ip-address ] ] rule { deny | permit [ channel-limit channel-number ] | preview time-slice  preview-time [ preview-interval interval-time | preview-times preview-times [ reset-interval reset-interval-time ] ]* }
undo uni uni-number multicast-control multicast-address [ multicast-address [ to multicast-address ] ] &<1-10>
ONU端口视图
【缺省级别】
1:监控级
【缺省级别】
1:监控级
multicast-address:指定的组播频道对应的组播IP地址。&<1-10>表示前面的参数最多可以重复输10次。
source-ip ip-address [ to ip-address ] :指定下发组播频道的组播源地址范围,ip-address为组播源的IP地址。
rule:设定ONU设备的UNI端口下用户对组播频道的访问权限,包括deneypermitpreview time-slice
deny:禁止用户点播命令中指定的组播频道。
permit:允许用户点播命令中指定的组播频道。
channel-number在“permit”权限下,允许用户同时访问的频道数,取值范围为15
preview time-slice:允许用户预览指定时间长度的组播频道。
preview-time:允许预览的时间,单位为分钟,取值范围为13
interval-time:允许预览的时间间隔,单位为分钟,取值范围为110
preview-times:允许预览的次数,取值范围为13
reset-interval-time:预览复位的时间间隔(即设定的预览次数完成多长时间后可以再次预览),单位为分钟,取值范围为143200
【描述】
uni multicast-control multicast-address命令用来配置ONU设备的UNI端口下用户对组播频道业务的访问权限(允许、预览或禁止)。undo uni multicast-control multicast-address命令用来取消该配置。
需要注意的是,本命令执行在可控组播模式下。
如果配置了本命令中的source-ip字段,那么OLT将对收到的IGMPv3报文做如下处理:
·              如果报文类型为IS_IN、TO_IN或ALLOW,当报文中携带的组播IP地址和源IP地址都在组播权限配置的范围内时,OLT才能正常创建组播表项,否则将丢弃报文;
·              如果报文类型为IS_EX或TO_EX,OLT将丢弃报文;
·              如果报文类型为BLOCK,OLT将不对报文做权限判断,直接删除相应的组播表项。
关于IS_IN、TO_IN、ALLOW、IS_EX、TO_EX和BLOCK类型的IGMPv3报文的详细介绍请参见“IP组播配置指导”的“IGMP配置”。
使用uni multicast-control命令配置用户对组播频道业务的预览权限时,若在单条此命令中设置了UNI端口下用户对多个组播频道具有预览权限,则同一时刻只允许该条配置中的一个组播频道被点播。
# 配置允许UNI端口1下的所有用户可观看组播IP 224.1.1.2所对应的组播频道业务。
[Sysname-Onu3/0/1:1] uni 1 multicast-control multicast-address 224.1.1.2 rule permit
uni uni-number multicast-group-number number
undo uni uni-number multicast-group-number
ONU端口视图
【缺省级别】
2:系统级
number组播频道个数,范围是0~255。
【描述】
uni multicast-group-number命令用来配置ONU的UNI端口下允许用户同时点播的组播频道的数量。undo uni multicast-group-number命令用来恢复允许用户同时点播的组播频道的数量为缺省值。
缺省情况下,每个UNI端口下允许用户同时点播64个组播频道。
H3C ONU的UNI端口所支持的最大组播频道数因ONU类型而异,具体支持情况请参见表2-7
表2-7 H3C不同类型ONU所支持的最大组播频道数
H3C ONU类型
UNI端口支持的最大组播频道数
S3100-SI系列
256
S3100-EI系列
512
ET704系列
64
ET254-L
不支持组播
如果ONU的UNI端口所支持的最大组播频道数小于OLT远程能够配置的最大频道数:
·              当ONU在线时,如果通过OLT远程配置的UNI端口最大组播频道数大于UNI端口所支持的最大数目,则将配置失败。如:ET704系列ONU的UNI端口最大支持64个组播频道,如果通过OLT远程配置uni multicast-group-number命令时,命令中指定的number参数值大于64,则将提示配置失败;
·              当ONU不在线时,如果通过OLT远程配置的UNI端口最大组播频道数大于UNI端口所支持的最大数目,待ONU上线后,会尽量匹配已配置的最大数目。如OLT端配置的UNI端口最大数目为255,而ET704系列ONU的UNI最大支持64,所以ONU会以支持64个组播频道作为对OLT远程配置的匹配结果。
# 配置ONU的UNI端口1下允许用户同时点播的组播频道的数量为32。
[Sysname-Onu3/0/1:1] uni 1 multicast-group-number 32
uni uni-number multicast-strip-tag enable
undo uni uni-number multicast-strip-tag enable
ONU端口视图
【缺省级别】
2:系统级
【描述】
uni multicast-strip-tag enable命令用来配置ONU的UNI端口删除下行组播流的VLAN Tag。undo uni multicast-group-number enable命令用来取消该配置。
缺省情况下,ONU的UNI端口不删除下行组播流的VLAN Tag。
# 删除ONU的UNI端口1下行组播流的VLAN Tag。
[Sysname-Onu3/0/1:1] uni 1 multicast-strip-tag enable
uni uni-number port-isolate
undo uni uni-number port-isolate
ONU端口视图
【缺省级别】
2:系统级
【描述】
uni port-isolate命令用来将UNI端口加入隔离组。undo uni port-isolate命令用来将UNI端口从隔离组中删除。
一台ONU只支持建立一个隔离组。
缺省情况下,UNI端口未加入隔离组。
ET254-L类型ONU的UNI端口只有在VLAN操作模式为透传模式时,才能加入端口隔离组。
# 将UNI端口1和UNI端口2加入隔离组。
[Sysname-Onu3/0/1:1] uni 1 port-isolate
[Sysname-Onu3/0/1:1] uni 2 port-isolate
uni uni-number restart auto-negotiation
ONU端口视图
【缺省级别】
2:系统级
【描述】
uni restart auto-negotiation命令用来强制UNI端口重新进行自协商。
需要注意的是,本命令只有在UNI端口自协商功能开启的情况下才可执行。
# 强制UNI端口 1重新进行自协商。
[Sysname-Onu3/0/1:1] uni 1 restart auto-negotiation
2.1.43  uni shutdown
uni uni-number shutdown
undo uni uni-number shutdown
ONU端口视图
【缺省级别】
2:系统级
【描述】
uni shutdown命令用来关闭UNI端口。undo uni shutdown命令用来打开UNI端口。
缺省情况下,UNI端口处于开启的状态。
# 关闭UNI端口 1。
[Sysname-Onu3/0/1:1] uni 1 shutdown
2.1.44  uni speed
uni uni-number speed { 10 | 100 | auto }
undo uni uni-number speed
ONU端口视图
【缺省级别】
2:系统级
10:端口速率为10Mbps
100:端口速率为100Mbps
auto:端口速率处于双方自协商状态。
【描述】
uni uni-number speed命令用来设置UNI端口速率。undo uni uni-number speed命令用来恢复端口的速率为缺省值。
缺省情况下,UNI端口速率为100Mbps。
# 设置UNI端口1速率为10Mbps。
[Sysname-Onu3/0/1:1] uni 1 speed 10
uni uni-number virtual-cable-test
ONU端口视图
【缺省级别】
2:系统级
uni-numberONU设备的UNI端口号,取值范围为1~当前ONUUNI端口数,且支持最大的UNI端口数为80
【描述】
uni virtual-cable-test命令用来对相应ONU设备上指定的UNI接口所连接的电缆进行一次连通性测试,并显示检测结果。
·              当电缆状态为正常时,OLT不会显示被检测的ONU设备上相应UNI接口所连线缆的长度,相应参数处显示“- metres”;
·              当电缆状态非正常时,OLT显示信息中的长度是指从本接口到异常位置的长度。
·       执行该操作会使得已经up的UNI口链路自动down、up一次。
·       检测结果仅供参考,检测到的长度最大可能存在的误差为10米,如果显示值为“-”,则表示不支持该项参数的检测。
·       是否能通过uni virtual-cable-test命令实现对UNI接口所连接电缆的测试,取决于ONU设备的支持情况。
# 使用uni virtual-cable-test命令对OLT上ONU3/0/11端口所对应ONU设备的UNI端口1连接的电缆进行一次连通性测试,并显示检测结果。
[Sysname-Onu3/0/1:1] uni 1 virtual-cable-test
Cable status: abnormal(open), 5 metres
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: - db
表2-8 uni virtual-cable-test命令显示参数描述
operator
Cable status
电缆状态,包括normal(正常)、abnormal(异常)、abnormal(open)(异常开路)、abnormal(short)(异常短路)、failure(检测失败)
线阻抗失配,“-”表示不支持此参数的检测
Pair skew
线对不对称,“-”表示不支持此参数的检测
Pair swap
线对交换,“-”表示不支持此参数的检测
Pair polarity
是否极性交换,“-”表示不支持此参数的检测
Insertion loss
插入信号衰减,“-”表示不支持此参数的检测
Return loss
返回信号衰减,“-”表示不支持此参数的检测
Near-end crosstalk
近端串扰,“-”表示不支持此参数的检测
uni uni-number vlan-mode tag pvid pvid [ priority priority-value ]
undo uni uni-number vlan-mode
ONU端口视图
【缺省级别】
2:系统级
priority-value报文的802.1p优先级,取值范围为07
pvid:缺省VLAN ID,取值范围为14094
【描述】
uni vlan-mode tag pvid命令用来配置UNI端口VLAN操作模式为VLAN标记模式及该模式下的相关参数。undo uni vlan-mode命令用来恢复UNI端口VLAN操作模式为缺省值。
缺省情况下,UNI端口VLAN操作模式为VLAN透明传输模式。
相关命令可参考uni vlan-mode translation pviduni vlan-mode transparent
·       如果ET254-L类型ONUUNI端口加入了端口隔离组,则该UNI端口的操作模式只能设置为透明传输模式,不能设置为VLAN 标记模式或VLAN Translation模式。
·       OLT端口下的所有ONU端口类型为Access时,UNI端口操作模式只能为透明传输模式,这样才能保证ONU端口和用户PC接收的是不带Tag的报文。
# 配置UNI端口1 VLAN操作模式为VLAN 标记模式,给进入本端口的untag报文打上VLAN 100的Tag,并设置报文802.1p优先级为3。
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] uni 1 vlan-mode tag pvid 100 priority 3
uni uni-number vlan-mode translation pvid pvid [ priority priority-value ] { oldvid to newvid } &<1-15>
ONU端口视图
【缺省级别】
2:系统级
priority-value报文的802.1p优先级,取值范围为0~7
oldvid:原VLAN ID,取值范围为14094
newvid:新VLAN ID,取值范围为14094
&<1-15>:表示前面的参数最多可以重复输15次。
【描述】
uni vlan-mode translation pvid命令用来配置UNI端口VLAN操作模式为VLAN Translation模式以及该模式下的相关参数。undo uni vlan-mode命令用来恢复UNI端口VLAN操作模式为缺省值。
相关命令可参考uni vlan-mode tag pviduni vlan-mode transparent
# 配置UNI端口1 VLAN操作模式为VLAN Translation模式,缺省VLAN ID100 ,对于进入本端口VLAN ID2的报文,将其VLAN ID替换成5,并设置报文802.1p优先级为3
[Sysname-Onu3/0/1:1] uni 1 vlan-mode translation pvid 100 priority 3 2 to 5
uni uni-number vlan-mode transparent
ONU端口视图
【缺省级别】
2:系统级
【描述】
uni vlan-mode transparent命令用来配置UNI端口VLAN操作模式为VLAN透明传输模式。undo uni vlan-mode命令用来恢复UNI端口VLAN操作模式为缺省值。
相关命令可参考uni vlan-mode tag pviduni vlan-mode translation pvid
# 配置UNI端口1 VLAN操作模式为VLAN 透明传输模式。
[Sysname-Onu1/0/1:1] uni 1 vlan-mode transparent
2.1.49  upstream-sla
upstream-sla { minimum-bandwidth value1 | maximum-bandwidth value2 | delay { low | high } } *
undo upstream-sla
ONU端口视图
【缺省级别】
2:系统级
minimum-bandwidth value1:上行的最小带宽,单位为64Kbps,取值范围为8~15200,缺省情况下为32。
maximum-bandwidth value2:上行的最大带宽,单位为64Kbps,取值范围为8~16000,缺省情况下为368。
delay:延时参数,low表示低延时,high表示高延时,缺省情况下为low
【描述】
upstream-sla命令是用于设置ONU的上行最小带宽、最大带宽和报文通过EPON系统转发的延时参数。undo upstream-sla命令可以用于恢复ONU的上行最小带宽、最大带宽和延时参数为缺省值。
一个OLT端口下,所有已经创建的ONU端口下的上行最小带宽总和不能超过972800kbps(即950Mbps)。
# 设置ONU上行最小带宽为9600Kbps,最大带宽为12800Kbps。
[Sysname-Onu3/0/1:1] upstream-sla minimum-bandwidth 150 maximum-bandwidth 200
 Info: The minimum-bandwidth of upstream is 9600 Kbps
 Info: The maximum-bandwidth of upstream is 12800 Kbps
undo upstream-sla service-mode enable
ONU端口视图
【缺省级别】
2:系统级
【描述】
upstream-sla service-mode enable命令用于使能ONU的基于优先级队列的上行带宽分配功能。undo upstream-sla service-mode enable命令用于关闭ONU的基于优先级队列的上行带宽分配功能。关闭基于优先级队列的上行带宽分配功能后,优先级队列的带宽配置恢复为默认情况。
# 使能ONU基于优先级队列的上行带宽分配功能。
[Sysname-Onu1/0/1:1] upstream-sla service-mode enable
upstream-sla service service-number { fixed-packet-size fixed-packet-size | fixed-bandwidth fixed-bandwidth | minimum-bandwidth minimum-bandwidth | maximum-bandwidth maximum-bandwidth } *
undo upstream-sla service service-number
ONU端口视图
【缺省级别】
2:系统级
service-number:优先级队列编号,取值范围为0~3。
fixed-packet-size:固定报文长度,单位为字节,取值范围为0~1522,缺省情况下为0字节。配置此参数后,ONU将认为该队列中的报文长度固定为该参数值,可以配合fixed-bandwidth参数使用,增强该队列固定带宽分配的准确性。
fixed-bandwidth:上行的固定带宽,单位为64Kbps,取值范围为0~14400,缺省情况下取值为0。配置此参数后,该优先级队列的带宽将固定为该参数值。
minimum-bandwidth:上行的最小带宽,单位为64Kbps,取值范围为0~15200,缺省情况下取值为0。配置此参数后,该优先级队列的上行带宽将不低于该参数值。
maximum-bandwidth:上行的最大带宽,单位为64Kbps,取值范围为0~16000,缺省情况下取值为16000。配置此参数后,该优先级队列的最大带宽将不高于该参数值。
【描述】
upstream-sla service命令用于配置ONU优先级队列的上行带宽。优先级0,1的报文对应service 0;优先级2,3的报文对应service 1;优先级4,5的报文对应service 2;优先级6,7的报文对应service 3。undo upstream-sla service命令用于恢复优先级队列上行带宽为默认值。
配置队列的固定带宽和最小带宽时:
·          所有配置了固定带宽的队列的固定带宽之和为X。
·          所有仅配置了带宽范围的队列的最小带宽之和为Y。
·          通过upstream-sla命令配置的ONU的最大上行带宽为Z。
需要注意的是,必须保证X+Y≤Z。
# 配置service 0的最大带宽为10Mbps,最小带宽为2Mbps。
[Sysname-Onu1/0/1:1] upstream-sla service 0 minimum-bandwidth 32 maximum-bandwidth 160
update onu filename file-url
undo update onu
OLT端口视图、ONU端口视图
【缺省级别】
2:系统级
file-url:升级文件名,由设备名与ONU升级文件的文件名组成,为1~64个字符的字符串。如果不指定设备名,则默认为主控板的FLASH,且不能使用备用主控板中的文件进行升级。
【描述】
update onu filename命令用来配置通过在OLT上存放ONU升级文件来实现对ONU的远程升级。undo update onu用来取消远程升级ONU的配置。
·              如果在OLT端口视图下执行此命令,可以升级该OLT端口下所有已创建ONU端口对应的ONU;
·              如果在ONU端口视图下执行此命令,则仅升级该ONU端口所对应的ONU。
需要注意的是,本命令为配置命令,在OLT端口或ONU端口视图下配置本命令后,升级命令会下发到对应的ONU端口:
·              如果该ONU端口对应的ONU在线且和升级文件匹配,则直接进行升级;
·              如果该ONU端口对应的ONU在线但和升级文件不匹配,则不能成功升级;
·              如果该ONU端口对应的ONU不在线(ONU端口未绑定任何ONU或已绑定ONU扩展OAM连接未成功建立),则待其上线后再对其进行升级操作。
·       为了实现批量升级,节省系统资源,升级命令配置后,OLT会延迟15~20s时间后再执行升级命令。
·       update onu filename命令为配置命令,即此升级命令执行后会保存到设备的配置文件中,如果新上线的ONU所对应的端口在升级命令配置之前已创建,则直接升级(当然,和升级文件不匹配的ONU是不能升级成功的)。反之(即:对应ONU端口在升级命令配置之后创建),则不升级。如果用户只想对当前在线的ONU进行一次升级,对当前不在线ONU和以后注册加入的ONU均不进行升级处理,可以先执行该升级命令,然后在确认了当前在线的ONU均已完成升级的情况下,通过对该命令进行undo操作,即可达到一次性升级的目的。
·       在ONU软件更新过程中,建议用户不要对ONU断电,以免更新失败。
·       升级文件传送到ONU后,ONU将自动重启完成升级过程。
# 升级单个ONU。
[Sysname-Onu3/0/1:1] update onu filename file.app
Update flash:/file.app?[Y/N]
# 如果键入Y,则进行更新;键入N,则表明退出,以键入Y为例。
 Info: Download file to onu may take a long time, please wait...
 Please wait while the firmware is being burnt, and check the software version after re-registration!
update onu onu-type onu-type filename file-url
undo update onu onu-type onu-type
FTTH视图
【缺省级别】
2:系统级
onu-type:ONU类型,如ET704-A和ET704-A-L等,为1~16个字符的字符串,不区分大小写。
【描述】
update onu onu-type命令用来配置按类型远程升级ONU。undo update onu onu-type用来取消按类型远程升级ONU的配置。
需要注意的是,本命令为配置命令,仅对ONU端口下没有配置升级命令且匹配本命令所指定类型的ONU有效。
·              如果ONU在线且和升级文件匹配,则直接进行升级;
·              如果ONU在线但和升级文件不匹配,则不能成功升级;
·              如果ONU不在线(ONU端口未绑定任何ONU或已绑定ONU扩展OAM连接未成功建立),则待其上线后再对其进行升级操作,鉴于整网同类型ONU版本统一的维护具有效率高、操作简单和方便管理等优点,建议用户优先选择配置按类型升级。
·       端口下配置的升级命令优先级高于FTTH视图下的升级命令。即:假如ONU端口ONU3/0/1:1对应的ONU为A类型,在FTTH视图下配置了升级A类型ONU的升级文件为1.app,同时在ONU3/0/1:1端口视图下配置了升级文件为2.app,则该ONU会选择2.app文件进行升级。
·       OLT最多可同时对64种类型的ONU进行升级,即可通过按类型升级ONU的命令行为64种不同类型的ONU指定升级文件。
·       update onu onu-type命令为配置命令,即此升级命令执行后会保存到设备的配置文件中,只要有新ONU注册,相应的升级命令就会尝试对其进行升级。如果用户只想对当前在线的ONU进行一次升级,对当前不在线ONU和以后注册加入的ONU均不进行升级处理,可以先执行该升级命令,然后在确认了当前在线的ONU均已完成升级的情况下,通过对该命令进行undo操作,即可达到一次性升级的目的。
# 升级交换机下挂的类型为ET704-A-L的所有ONU。
[Sysname] ftth
[Sysname-ftth] update onu onu-type et704-a-l filename file.app
命令配置完成后,OLT即开始对ONU端口下没有配置升级命令且类型为ET704-A-L的所有ONU进行升级。
3 告警配置命令
·       如果告警命令可在FTTH视图下执行,则表示对系统中所有的OLT端口或该端口下所有的ONU生效;
·       如果可在OLT端口视图下执行,则表示对本端口或其下所有的ONU生效;
·       如果在ONU端口视图下执行,则仅对本端口所对应的ONU生效。
3.1  告警配置命令
alarm bit-error-rate { direction { uplink | downlink | up-down-link } | threshold threshold } *
undo alarm bit-error-rate { direction | threshold } *
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
uplink:监控方向,只对ONU向OLT转发的上行通信数据进行监控。
downlink:监控方向,只对OLT向ONU转发的下行通信数据进行监控。
up-down-link:监控方向,对OLT和ONU之间的上下行通信数据进行监控。
threshold threshold:bit error rate告警阈值,取值范围为1~109,缺省值为10(单位为10-9)。
【描述】
alarm bit-error-rate命令用来配置监控方向和bit error rate告警阈值。undo alarm bit-error-rate命令用来恢复监控方向和bit error rate告警阈值的缺省值。
当OLT和ONU之间转发数据时的错误比特总数或比特错误率超过了告警阈值,则产生bit error rate告警。
缺省情况下,对OLT和ONU之间的上下行通信数据都进行监控。
相关命令可参考alarm bit-error-rate enable
# 配置端口OLT1/0/1只对ONU向OLT转发的上行通信数据进行监控,并且配置bit error rate告警阈值为20。
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] alarm bit-error-rate direction uplink threshold 20
undo alarm bit-error-rate enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm bit-error-rate enable命令用来开启bit error rate告警功能。undo alarm bit-error-rate enable用于关闭bit error rate告警功能。
缺省情况下,bit error rate告警功能开启。
# 开启端口OLT3/0/1的bit error rate告警功能。
[Sysname-Olt3/0/1] alarm bit-error-rate enable
undo alarm device-fatal-error enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm device-fatal-error enable命令用来开启device fatal error告警功能。undo alarm device-fatal-error enable命令用来关闭device fatal error告警功能。
缺省情况下,device fatal error告警功能开启。
当设备上发生了一系列的致命错误时,就会引起device fatal error告警,若设备在持续两分钟内没有检测到同样的错误,将产生device fatal error恢复告警。
# 开启端口OLT3/0/1的device fatal error告警功能。
[Sysname-Olt3/0/1] alarm device-fatal-error enable
alarm frame-error-rate { direction { uplink | downlink | up-down-link} | threshold threshold } *
undo alarm frame-error-rate { direction | threshold } *
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
threshold threshold:frame error rate告警阈值,取值范围为1~109,缺省值为1(单位为10-9)。
【描述】
alarm frame-error-rate命令用来配置监控方向和frame error rate告警阈值。undo alarm frame-error-rate命令用来恢复监控方向和frame error rate告警阈值的缺省值。
当OLT和ONU之间转发数据时的帧误码总数和帧误码率都超过了告警阈值,则产生frame error rate告警。
相关命令可参考alarm frame-error-rate enable
# 配置端口OLT1/0/1对OLT和ONU之间的上下行通信数据进行监控,并且配置frame error rate告警阈值为20。
[Sysname-Olt1/0/1] alarm frame-error-rate direction up-down-link threshold 20
undo alarm frame-error-rate enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm frame-error-rate enable命令用来开启frame error rate告警功能。undo alarm frame-error-rate enable用于关闭frame error rate告警功能。
缺省情况下,frame error rate告警功能开启。
# 开启端口OLT3/0/1的frame error rate告警功能。
[Sysname-Olt3/0/1] alarm frame-error-rate enable
undo alarm llid-mismatch enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm llid-mismatch enable命令用来开启LLID匹配错误帧告警功能。undo alarm llid-mismatch enable命令用来关闭LLID匹配错误帧告警功能。
缺省情况下,LLID匹配错误帧告警功能关闭。
# 开启端口OLT3/0/1的LLID匹配错误帧告警功能。
[Sysname-Olt3/0/1] alarm llid-mismatch enable
alarm llid-mismatch threshold threshold
undo alarm llid-mismatch threshold
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
threshold threshold:LLID匹配错误帧,单位为帧,取值范围为1000~109,缺省值为5000帧。
【描述】
alarm llid-mismatch threshold命令用来配置LLID匹配错误帧阈值。undo alarm llid-mismatch threshold命令用来恢复LLID匹配错误帧阈值为缺省值。
当时隙错乱导致ONU不在自己的时隙内转发数据时,就会引起LLID匹配错误帧告警。
相关命令可参考alarm llid-mismatch enable
# 配置端口OLT1/0/1的LLID匹配错误帧阈值为6000帧。
[Sysname-Olt1/0/1] alarm llid-mismatch threshold 6000
3.1.8  alarm local-stable enable
undo alarm local-stable enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm local-stable enable命令用来开启local stable告警功能。undo alarm local-stable enable用于关闭local stable告警功能。
local stable告警指OLT侧产生的告警。当系统中有ONU误用时,比如把OAM2.0的ONU与OAM3.3的ONU混用时(因为同一系统下的ONU必须采用同一OAM版本),就会引起local stable告警。
local stable告警与remote stable告警的区别如下:
·              local stable告警是OLT侧产生的告警;
·              remote stable告警是ONU侧产生的告警,并且将其告警反馈给OLT。
缺省情况下,local stable告警功能开启。
remote stable告警命令可参见“3.1.24  alarm remote-stable enable”。
# 开启端口OLT3/0/1的local stable告警功能。
[Sysname-Olt3/0/1] alarm local-stable enable
3.1.9  alarm oam critical-event enable
undo alarm oam critical-event enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm oam critical-event enable命令用来开启critical event告警功能。undo alarm oam critical-event enable命令用来关闭critical event告警功能。
缺省情况下,critical event告警功能开启。
critical event包含local link fault与dying gasp两种事件,当其中一个事件发生时,就会引起critical event告警。
# 开启端口OLT3/0/1的critical event告警功能。
[Sysname-Olt3/0/1] alarm oam critical-event enable
3.1.10  alarm oam dying-gasp enable
undo alarm oam dying-gasp enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm oam dying-gasp enable命令用来开启dying gasp告警功能。undo alarm oam dying-gasp enable命令用来关闭dying gasp告警功能。
缺省情况下,dying gasp告警功能开启。
当遇到系统出错,数据加载错误或者其它无法恢复的错误时,就会引起dying gasp告警。
# 开启端口OLT3/0/1的dying gasp告警功能。
[Sysname-Olt3/0/1] alarm oam dying-gasp enable
3.1.11  alarm oam error-symbol-period
alarm oam error-symbol-period { window-high windowhigh | window-low windowlow | threshold-high thresholdhigh | threshold-low thresholdlow } *
undo alarm oam error-symbol-period { window-high | window-low | threshold-high | threshold-low } *
OLT端口视图、ONU端口视图、FTTH视图
【缺省级别】
2:系统级
window-high windowhigh:窗口高位大小,取值范围为0~4294967295(232-1),缺省值为0。
window-low windowlow:窗口低位大小,取值范围为0~4294967295(232-1),缺省值为1。
threshold-high thresholdhigh:阈值高位大小,取值范围为0~4294967295(232-1),缺省值为0。
threshold-low thresholdlow:阈值低位大小,取值范围为0~4294967295(232-1),缺省值为20。
·       该命令中窗口大小与阈值大小都是由16位的高位与16位的低位所组成。
·       窗口的单位为秒,即缺省值为1秒;阈值的单位为字节,即缺省值为20字节。
【描述】
alarm oam error-symbol-period命令用来配置窗口和阈值大小。undo alarm oam error-symbol-period命令用来恢复窗口和阈值大小的缺省值。
在一个给定的时间段内(即窗口大小),如果发生的字节错误数超过了预先设定的门限阈值,就会引起error symbol period告警。
相关命令可参考alarm oam error-symbol-period enable
·       当此告警的阈值高位和低位都设置成0时,就会马上产生大量的告警,而告警事件是承载在OAM报文里的,所以会有大量的OAM报文产生,此时可能会导致OAM报文丢失。
·       此命令只对OAM 2.0及以上版本有效。
# 配置ONU端口ONU1/0/1:1 对应ONU设备上error symbol period告警功能的窗口高位和低位分别为1和3 ,阈值高位和低位分别为10 和30。
[Sysname-Onu1/0/1:1] alarm oam error-symbol-period window-high 1 window-low 3 threshold-high 10 threshold-low 30
3.1.12  alarm oam error-symbol-period enable
undo alarm oam error-symbol-period enable
【缺省级别】
2:系统级
【描述】
alarm oam error-symbol-period enable命令用来开启error symbol period告警功能。undo alarm oam error-symbol-period enable命令用来关闭error symbol period告警功能。
缺省情况下,error symbol period告警功能开启。
# 开启ONU端口ONU3/0/1:1 对应ONU的error symbol period告警功能。
[Sysname-Onu3/0/1:1] alarm oam error-symbol-period enable
3.1.13  alarm oam error-frame-period
alarm oam error-frame-period { window window | threshold threshold } *
undo alarm oam error-frame-period { window | threshold } *
【缺省级别】
2:系统级
window window:窗口大小,单位为秒,取值范围为0~4294967295(232-1),缺省值为1秒。
threshold threshold:阈值大小,单位为帧,取值范围为0~4294967295(232-1),缺省值为20帧。
【描述】
alarm oam error-frame-period命令用来配置窗口和阈值大小。undo alarm oam error-frame-period命令用来恢复窗口和阈值大小的缺省值。
在一个给定的周期内(即窗口大小),如果发生的错误帧数超过了预先设定的门限阈值,就会引起error frame period告警。
相关命令可参考alarm oam error-frame-period enable
·       当此告警的阈值设置成0时,就会马上产生大量的告警,而告警事件是承载在OAM报文里的,所以会有大量的OAM报文产生,此时可能会导致OAM报文丢失。
# 配置ONU端口ONU1/0/1:1 对应ONU设备上error frame period告警功能的窗口大小为2秒,阈值大小为30帧。
[Sysname-Onu1/0/1:1] alarm oam error-frame-period window 2 threshold 30
3.1.14  alarm oam error-frame-period enable
undo alarm oam error-frame-period enable
【缺省级别】
2:系统级
【描述】
alarm oam error-frame-period enable命令用来开启error frame period告警功能。undo alarm oam error-frame-period enable命令用来关闭error frame period告警功能。
缺省情况下,error frame period告警功能开启。
# 开启ONU端口ONU3/0/1:1 对应ONU的error frame period告警功能。
[Sysname-Onu3/0/1:1] alarm oam error-frame-period enable
3.1.15  alarm oam error-frame
alarm oam error-frame { window window | threshold threshold } *
undo alarm oam error-frame { window | threshold } *
【缺省级别】
2:系统级
window window:窗口大小,单位为秒,取值范围为0~65535,缺省值为10秒。
【描述】
alarm oam error-frame命令用来配置窗口和阈值大小。undo alarm oam error-frame命令用来恢复窗口和阈值大小的缺省值。
在给定时间段内(即窗口大小),如果错误帧的数目超过了预先设定的门限阈值,就会引起error frame告警。
相关命令可参考alarm oam error-frame enable
# 配置ONU端口ONU1/0/1:1 对应ONU设备上error frame告警功能的窗口大小为20秒,阈值大小为30帧。
[Sysname-Onu1/0/1:1] alarm oam error-frame window 20 threshold 30
3.1.16  alarm oam error-frame enable
undo alarm oam error-frame enable
【缺省级别】
2:系统级
【描述】
alarm oam error-frame enable命令用来开启error frame告警功能。undo alarm oam error-frame enable命令用来关闭error frame告警功能。
缺省情况下,error frame告警功能开启。
# 开启ONU端口ONU3/0/1:1 对应ONU的error frame告警功能。
[Sysname-Onu3/0/1:1] alarm oam error-frame enable
3.1.17  alarm oam error-frame-seconds-summary
alarm oam error-frame-seconds-summary { window window | threshold threshold } *
undo alarm oam error-frame-seconds-summary { window | threshold } *
【缺省级别】
2:系统级
window window:窗口大小,单位为100毫秒,取值范围为100~9000,缺省值为600。
threshold threshold:阈值大小,单位为秒,取值范围为1~900,缺省值为1秒。
【描述】
alarm oam error-frame-seconds-summary命令用来配置窗口和阈值大小。undo alarm oam error-frame-seconds-summary命令用来恢复窗口和阈值大小的缺省值。
在特定时间段(比如1分钟)内,如果检测到的错误帧秒个数(错误帧秒是指在1秒的间隔内,至少有一个错误帧出现)的值大于预先设定的门限阈值,就会引起error frame seconds summary告警。
相关命令可参考alarm oam error-frame-seconds-summary enable
# 配置ONU端口ONU1/0/1:1 对应ONU设备上error frame seconds summary 告警功能的窗口大小为800,阈值大小为2秒。
[Sysname-Onu1/0/1:1] alarm oam error-frame-seconds-summary window 800 threshold 2
3.1.18  alarm oam error-frame-seconds-summary enable
undo alarm oam error-frame-seconds-summary enable
【缺省级别】
2:系统级
【描述】
alarm oam error-frame-seconds-summary enable命令用来开启error frame seconds summary 告警功能。undo alarm oam error-frame-seconds-summary enable命令用来关闭error frame seconds summary告警功能。
缺省情况下,error frame seconds summary告警功能开启。
# 开启ONU端口ONU3/0/1:1 对应ONU的error frame seconds summary 告警功能。
[Sysname-Onu3/0/1:1] alarm oam error-frame-seconds-summary enable
3.1.19  alarm oam local-link-fault enable
undo alarm oam local-link-fault enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm oam local-link-fault enable命令用来开启local link fault告警功能。undo alarm oam local-link-fault enable命令用来关闭local link fault告警功能。
缺省情况下,local link fault告警功能开启
当本地数据终端设备的接收方向出现故障时,就会引起local link fault告警。
# 开启端口OLT3/0/1的local link fault告警功能。
[Sysname] interface olt 3/0/1
[Sysname-Olt3/0/1] alarm oam local-link-fault enable
3.1.20  alarm oam-vendor-specific enable
undo alarm oam-vendor-specific enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm oam-vendor-specific enable命令用来开启oam vendor specific告警功能。undo alarm oam-vendor-specific enable命令用来关闭oam vendor specific告警功能。
此告警属于厂商自定义的告警。
缺省情况下,oam vendor specific告警功能开启。
# 开启端口OLT3/0/1的oam vendor specific告警功能。
[Sysname-Olt3/0/1] alarm oam-vendor-specific enable
3.1.21  alarm onu-over-limitation enable
undo alarm onu-over-limitation enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm onu-over-limitation enable命令用来开启onu over limitation告警功能。undo alarm onu-over-limitation enable命令用来关闭onu over limitation告警功能。
当OLT下所挂的ONU总数超过系统所支持的规格,就会引起onu over limitation告警。
缺省情况下,onu over limitation告警功能开启。
# 开启端口OLT3/0/1的onu over limitation告警功能。
[Sysname-Olt3/0/1] alarm onu-over-limitation enable
3.1.22  alarm port bit-error-rate enable
undo alarm port bit-error-rate enable
ONU端口视图、OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm port bit-error-rate enable用于开启port bit error rate告警功能。undo alarm port bit-error-rate enable用于关闭port bit error rate告警功能。
当OLT和ONU之间转发数据时的比特错误总数和比特错误率都超过了告警阈值,则产生port bit error rate告警。
port bit error rate告警阈值的设置与bit error rate告警一样,相关命令请参见“3.1.1  alarm bit-error-rate”。
缺省情况下,port bit error rate告警功能开启。
# 开启端口OLT3/0/1的port bit error rate告警功能。
[Sysname] interface olt3/0/1
[Sysname-Olt3/0/1] alarm port bit-error-rate enable
3.1.23  alarm registration-error enable
undo alarm registration-error enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm registration-error enable命令用来开启registration error告警功能。undo alarm registration-error enable命令用来关闭registration error告警功能。
当ONU在注册过程中发生错误时,就会引起registration error告警。
缺省情况下,registration error告警功能开启。
# 开启端口OLT3/0/1的registration error告警功能。
[Sysname-Olt3/0/1] alarm registration-error enable
undo alarm remote-stable enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
【描述】
alarm remote-stable enable命令用来开启remote stable告警功能。undo alarm remote-stable enable命令用来关闭remote stable告警功能。
当系统中有ONU误用时,比如把OAM2.0的ONU与OAM3.3的ONU混用时(因为同一系统下的ONU必须采用同一OAM版本),就会引起remote stable告警。
·              remote stable告警是ONU侧产生的告警,并且将其反馈给OLT。
缺省情况下,remote stable告警功能开启。
local stable告警命令可以参见“3.1.7  alarm llid-mismatch threshold”。
# 开启端口OLT3/0/1的remote stable告警功能。
[Sysname-Olt3/0/1] alarm remote-stable enable
3.1.25  alarm software-error enable
undo alarm software-error enable
FTTH视图
【缺省级别】
2:系统级
【描述】
alarm software-error enable命令用来开启系统的software error告警功能。undo alarm software-error enable命令用来关闭系统的software error告警功能。
当信号量错误、DA异常(数据访问异常)或者内存分配失败时,就会产生software error告警。
缺省情况下,software error告警功能开启。
# 开启EPON系统software error告警功能。
[Sysname] ftth
[Sysname-ftth] alarm software-error enable
3.1.26  monitor enable
monitor enable
undo monitor enable
FTTH视图
【缺省级别】
2:系统级
【描述】
monitor enable命令用来开启EPON系统的告警监视功能。undo monitor enable命令用来关闭EPON系统的告警监视功能。
缺省情况下,EPON系统的告警监视功能开启。
# 开启EPON系统的告警监视功能。
[Sysname] ftth
[Sysname-ftth] monitor enable
3.1.27  sample enable
sample enable
undo sample enable
FTTH视图
【缺省级别】
2:系统级
【描述】
sample enable命令用来开启系统的统计采样功能。undo sample enable命令用来关闭系统的统计采样功能。
缺省情况下,系统的统计采样功能打开。
# 开启EPON系统的统计采样功能。
[Sysname] ftth
[Sysname-ftth] sample enable
3.1.28  timer monitor
timer monitor seconds
undo timer monitor
FTTH视图
【缺省级别】
2:系统级
seconds:告警监视周期,单位为秒,取值范围为1~3600,缺省值为80秒。
【描述】
timer monitor命令用来配置系统的告警监视周期。undo timer monitor命令用来恢复系统告警监视周期的缺省值。
# 配置EPON系统的告警监视周期为100秒。
[Sysname] ftth
[Sysname-ftth] timer monitor 100
3.1.29  timer sample
timer sample  seconds
undo timer sample
FTTH视图
【缺省级别】
2:系统级
seconds:统计采样周期,单位为秒,取值范围为1~3600,缺省值为4秒。
【描述】
timer sample命令用来配置系统的统计采样周期。undo timer sample命令用来恢复系统统计采样周期为缺省值。
# 配置EPON系统的统计采样周期为10秒。
[Sysname] ftth
[Sysname-ftth] timer sample 10
4 与交换机特性相关的配置命令
4.1  OLT端口支持的命令
表4-1 OLT端口支持的命令
特性
手册参考
基本参数
·       description
·       shutdown
·       interface
·       display interface
“二层技术-以太网交换命令参考”中的“以太网端口配置命令”
流量控制
·       flow-control
风暴抑制比
·       broadcast-suppression
·       multicast-suppression
·       unicast-suppression
端口隔离
·       port-isolate enable
·       display port-isolate group
“二层技术-以太网交换命令参考”中的“端口隔离命令”
端口的Trap功能
enable snmp trap updown
“网络管理和监控配置指导”中的“SNMP配置命令”
IGMP Snooping
igmp-snooping source-deny
“IP组播命令参考”中的“IGMP Snooping配置命令”
MLD Snooping
mld-snooping source-deny
“IP组播命令参考”中的“MLD Snooping配置命令”
QinQ
·       qinq enable
·       qinq enable downlink
·       qinq enable uplink
·       qinq ethernet-type service-tag
·       qinq transparent-vlan
“二层技术-以太网交换命令参考”中的“QinQ配置命令”/“二层技术-以太网交换命令参考”中的“VLAN映射配置命令”
端口镜像
·       display mirroring-group
·       mirroring-group mirroring-port
·       mirroring-group monitor-port
·       mirroring-group monitor-egress
·       mirroring-port
·       monitor-port
“网络管理和监控命令参考”中的“端口镜像配置命令”
IP Source Guard
·       display ip check source
·       display user-bind
·       ip check source
·       user-bind
“安全命令参考”中的“IP Source Guard配置命令”
QoS
·       bandwidth downstream priority-queue
·       priority-queue-mapping
·       qos gts
·       qos lr
·       qos apply policy
·       qos sp
·       qos wrr
·       qos wfq
·       qos wred
·       qos priority
·       qos trust
·       display qos gts interface
·       display qos lr interface
·       display qos policy interface
·       display qos sp interface
·       display qos wrr interface
·       display qos wfq interface
·       display qos wred interface
·       display qos trust interface
“ACL和QoS命令参考”中的“EPON系统的QoS配置命令”
Smart Link
smart-link flush enable [ control-vlan vlan-id ]
“可靠性命令参考”中的“Smart Link配置命令”
当处于UP状态的OLT端口因某种原因(如运行shutdown命令或拔出光纤等)转为DOWN状态后,若需要恢复端口的UP状态、请于5s后再进行恢复操作(如运行undo shutdown命令或插入光纤),以防止因端口状态频繁变化导致ONU频繁注销注册引起的异常现象。
4.2  ONU端口支持的命令
表4-2 ONU端口支持的特性
特性
手册参考
基本参数
·       description
·       shutdown
·       link-delay
·       interface
·       display interface
·       reset counters interface
端口环回测试
loopback
端口的Trap功能
MAC地址表管理
·       mac-address
·       mac-address max-mac-count
·       display mac-address
·       display mac-address mac-learning
“二层技术-以太网交换命令参考”中的“MAC地址表配置命令”
DHCP Snooping
·       dhcp-snooping information enable
·       dhcp-snooping information format
·       dhcp-snooping information strategy
·       dhcp-snooping information circuit-id format-type
·       dhcp-snooping information circuit-id string
·       dhcp-snooping information remote-id format-type
·       dhcp-snooping information remote-id string
“三层技术-IP业务命令参考”中的“DHCP Snooping配置命令”
IGMP Snooping
·       igmp-snooping fast-leave
·       igmp-snooping group-limit
·       igmp-snooping group-policy
·       igmp-snooping host-join
·       igmp-snooping overflow-replace
·       igmp-snooping static-group
·       igmp-snooping static-router-port
MLD Snooping
·       mld-snooping fast-leave
·       mld-snooping group-limit
·       mld-snooping group-policy
·       mld-snooping host-join
·       mld-snooping overflow-replace
·       mld-snooping static-group
·       mld-snooping static-router-port
QoS
·       bandwidth downstream high-priority enable
·       bandwidth downstream policy enable
·       qos apply policy
·       qos cos-local-precedence-map
·       qos sp
·       qos wrr
·       qos wfq
·       qos priority
·       qos trust
·       uni classification-marking
·       uni port-policing
EPON系统中,如果要实现组播流量从用户端到组播源互通,需要在ONU和OLT上都有相应的组播表项:
·       在FTTH视图下绑定组播IP和组播VLAN的对应关系,然后通过用户发送组播加入报文可实现ONU和OLT上组播表项的成功创建。
·       在ONU端口视图下执行igmp-snooping host-joinigmp-snooping static-group命令可以实现在OLT上创建组播表项,但ONU上却无法创建。即,无法实现组播流量的互通。
