47-PoE-PoE Profile命令
本章节下载 (157.02 KB)
1.1.2 display poe interface power
1.1.4 display poe temperature-protection
1.1.11 poe temperature-protection
display poe interface [ interface-type interface-number ]
interface-type interface-number:端口类型和端口编号。
【描述】
display poe interface命令用来显示端口的供电状态
l 指定interface-type interface-number参数时,该命令用来显示指定端口的供电状态;
l 不带interface-type interface-number参数时,该命令用来显示所有端口的供电状态。
# 显示端口Ethernet1/0/10的供电状态。
<Sysname> display poe interface Ethernet1/0/10
Port power enabled :enable
Port power ON/OFF :on
Port power status :Standard PD was detected
Port power mode :signal
Port PD class :0
port power priority :low
Port max power :15400 mW
Port current power :460 mW
Port peak power :552 mW
Port average power :547 mW
Port current :10 mA
Port voltage :51 V
表1-1 display poe interface显示信息描述表
Port power enabled |
端口上已开启远程供电功能 |
Port power ON/OFF |
端口电源开启/关闭 |
Port power status |
端口供电状态: user command set port to off:用户关闭端口供电 Standard PD was detected:检测到一个标准PD Legacy PD was detected:检测到一个非标准PD detection is in process:正在检测PD |
Port power mode |
端口供电方式: signal:信号线供电方式 |
Port PD class |
端口供电功率等级 |
Port power priority |
端口供电优先级: critical:最高 high:高 low:低 |
Port max power |
端口最大可用功率 |
Port current power |
端口当前功率 |
Port average power |
端口平均功率 |
Port peak power |
端口峰值功率 |
Port current |
端口当前电流 |
Port voltage |
端口当前电压 |
# 显示所有端口的供电状态。
PORT INDEX POWER ENABLE MODE PRIORITY STATUS
Ethernet1/0/1 off disable signal low user command set port to off
Ethernet1/0/2 off disable signal low user command set port to off
Ethernet1/0/3 off disable signal low user command set port to off
Ethernet1/0/4 off disable signal low user command set port to off
Ethernet1/0/5 off disable signal low user command set port to off
Ethernet1/0/6 off disable signal low user command set port to off
<略>
表1-2 display poe interface显示信息描述表
PORT INDEX |
端口索引 |
POWER |
端口电源状态:on/off |
ENABLE |
端口PoE使能状态:enable/disable |
MODE |
端口供电方式: signal:信号线供电方式 spare:空闲线供电方式 |
PRIORITY |
STATUS |
display poe interface power [ interface-type interface-number ]
【描述】
display poe interface power命令用来显示设备指定端口的供电功率信息。如果不指定端口参数,则显示设备所有端口的供电功率信息。
# 显示端口Ethernet1/0/10的供电功率信息。
<Sysname> display poe interface power Ethernet1/0/10
Port power :12400 mW
# 显示所有端口的供电功率信息。
PORT INDEX POWER (mW) PORT INDEX POWER (mW)
Ethernet1/0/1 0 Ethernet1/0/2 0
Ethernet1/0/3 0 Ethernet1/0/4 0
Ethernet1/0/5 0 Ethernet1/0/6 0
Ethernet1/0/7 0 Ethernet1/0/8 0
Ethernet1/0/9 0 Ethernet1/0/10 12400
<略>
display poe powersupply
无
【描述】
display poe powersupply命令用来显示PSE电源设备的参数。
# 显示电源设备的参数。
<Sysname> display poe powersupply
Unit 1
PSE ID :0
PSE Legacy Detection :disable
PSE Total Power Consumption :0 mW
PSE Available Power :370000 mW
PSE Peak Value :0 mW
PSE Average Value :0 mW
PSE Software Version :501
PSE Hardware Version :000
PSE CPLD Version :001
PSE Power-Management mode :auto
表1-3 display poe powersupply显示信息描述表
PSE ID |
电源设备号 |
PSE Legacy Detection |
检测非标准PD使能开关 |
PSE Total Power Consumption |
电源设备当前消耗功率 |
PSE Available Power |
电源设备当前剩余可用功率 |
Power Peak Value |
电源设备峰值消耗功率 |
Power Average Value |
电源设备平均消耗功率 |
Power Software Version |
电源设备软件版本号 |
Power Hardware Version |
电源设备硬件版本号 |
PSE CPLD Version |
电源设备软件序列号 |
PSE Power-Management mode |
电源设备过载时端口供电管理方式 auto表示采用自动方式,即基于端口供电优先级的供电管理方式 manual表示采用手动的端口供电管理方式 |
无
【描述】
display poe temperature-protection命令用来显示设备PoE过温保护功能设置状态。
相关命令可参考poe temperature-protection enable。
# 显示设备PoE过温保护功能设置状态。
<Sysname> display poe temperature-protection
The temperature protection is enabled.
poe enable
undo poe enable
以太网端口视图
无
【描述】
poe enable命令用来开启端口远程供电功能。undo poe enable命令用来关闭端口远程供电功能。
缺省情况下,端口的远程供电功能处于关闭状态。
通过命令display poe interface可以查看端口上是否开启PoE功能。
# 开启端口Ethernet1/0/3的远程供电功能。
[Sysname] interface Ethernet 1/0/3
[Sysname-Ethernet1/0/3] poe enable
poe legacy enable
undo poe legacy enable
无
【描述】
poe legacy enable命令用来开启PD设备兼容性检测功能。undo poe legacy enable命令用来关闭PD设备兼容性检测功能。
符合IEEE 802.3af协议标准的PD设备为标准PD设备。
缺省情况下,PD设备兼容性检测功能处于关闭状态。
#开启PD设备兼容性检测功能。
[Sysname] poe legacy enable
Legacy detection is enabled
poe max-power max-power
undo poe max-power
以太网端口视图
max-power:为端口分配的最大功率,取值范围100~15400,单位为毫瓦。
【描述】
poe max-power命令用来配置当前端口的最大供电功率。undo poe max-power用来恢复当前端口最大供电功率为缺省值。
缺省情况下,端口的最大供电功率为15400毫瓦。
需要注意的是,设置功率大小的最小调整单位是1毫瓦。考虑到瞬时峰值功率的影响,实际可用的最大功率比设置的要多5%左右的额度。
通过命令display poe interface和display poe interface power可以查看端口上的供电功率信息。
# 配置端口Ethernet1/0/3的最大供电功率为15000毫瓦。
[Sysname-Ethernet1/0/3] poe max-power 15000
poe mode { signal | spare }
undo poe mode
以太网端口视图
signal:端口供电方式为采用信号线供电。
spare:端口供电方式为采用空闲线供电。
【描述】
poe mode命令用来配置当前端口供电的方式。undo poe mode用来恢复当前端口供电的方式为缺省值。
缺省情况下,端口采用信号线供电方式。
需要注意的是,当前本系列设备暂不支持空闲线供电方式。
# 配置端口Ethernet 1/0/3的供电方式为信号线供电方式。
[Sysname-Ethernet1/0/3] poe mode signal
poe power-management { auto | manual }
undo poe power-management
auto:采用自动方式,即基于端口供电优先级的供电管理方式。
manual:采用手动的端口供电管理方式。
【描述】
poe power-management命令用来配置电源设备过载时,端口供电的管理方式。undo poe power-management命令用来恢复端口供电的管理方式为缺省情况。
缺省情况下,端口供电的管理方式为自动方式。
可以通过命令poe priority设置端口供电优先级。
# 配置端口供电管理方式为自动方式,即基于端口供电优先级。
[Sysname] poe power-management auto
Auto Power Management is enabled
poe priority { critical | high | low }
undo poe priority
以太网端口视图
critical:配置端口供电优先级为最高。
high:配置端口供电优先级为高。
low:配置端口供电优先级为低。
【描述】
poe priority命令用来配置端口供电的优先级。undo poe priority命令用来恢复配置端口供电优先级为缺省值。
缺省情况下,端口的供电优先级为low。
端口供电优先级与端口供电管理方式配合使用,用于决策当整机剩余功率过小时,如何为新加入的PD分配PoE供电功率。
(1) 端口供电管理方式为手动方式:
若整机剩余功率小于15W,设备拒绝给新加入的PD设备供电。
(2) 端口供电管理方式为自动方式:
l 若整机剩余功率小于15W,有优先级高的端口插上PD时,要将优先级最低的端口组中端口号最大的端口禁止供电,使优先级低的端口释放一部分功率,供给新加入的PD。
l 若整机剩余功率小于15W,且没有优先级更低的端口,新插上PD的端口不能供电。
# 配置端口Ethernet 1/0/3的供电优先级为最高。
[Sysname-Ethernet1/0/3] poe priority critical
undo poe temperature-protection enable
无
【描述】
poe temperature-protection enable命令用来开启设备PoE过温保护功能。undo poe temperature-protection enable命令用来关闭设备PoE过温保护功能。
PoE过温保护功能是指:
l 当设备内部温度超过65摄氏度时,设备进行自我保护,关闭所有端口的PoE供电功能;
l 当设备内部温度低于60摄氏度时,设备恢复所有端口的PoE供电功能。
缺省情况下,设备PoE过温保护功能处于开启状态。
可以通过命令display poe temperature-protection查看设备的PoE过温保护是否开启。
# 关闭设备PoE过温保护功能。
[Sysname] undo poe temperature-protection enable
The temperature protection is disabled.
poe update { refresh | full } filename
refresh:电源设备中存在可用的处理软件时使用refresh升级模式。refresh升级模式是在PSE中原有处理软件的基础上对其进行升级更新。
full:电源设备中的处理软件被损坏时使用full升级模式。full升级模式是将PSE中原有损坏处理软件彻底删除,重新装入。
filename:升级文件的名称,长度为1~64个字符,文件扩展名为.s19。
【描述】
poe update命令用来对电源设备的处理软件进行在线升级。
l full模式的升级方式是在用refresh模式升级出现异常的情况下使用的,其它情况下,请使用refresh模式进行升级。
l PSE处理软件被损坏的情况下(表现为所有的PoE命令执行不成功),请用full模式进行升级,使软件恢复。
l 如果在PSE处理软件的在线升级过程中因意外而中断(例如发生错误导致设备重启),重启后用full方式升级失败时,请将设备断电重启后再用full方式升级即可成功。升级后再手动重启设备,才能使原来的PoE配置恢复作用。
# 在线升级电源设备的处理软件。
[Sysname] poe update refresh 0400_001.S19
Update PoE board successfully
系统视图下命令如下:
apply poe-profile profile-name interface interface-type interface-number [ to interface-type interface-number ]
undo apply poe-profile profile-name interface interface-type interface-number [ to interface-type interface-number ]
以太网端口视图下命令如下:
系统视图/以太网端口视图
profile-name:PoE Profile名称,为1~15个字符的字符串,以英文字母[a-z,A-Z]开始,并且不能为保留关键字all、interface、user、undo、mode。
interface-type interface-number:端口类型和端口编号。通过配置该参数可以在系统视图下指定应用该PoE Profile的端口
【描述】
apply poe-profile命令用来在指定的以太网端口上应用已经存在的PoE Profile的配置。undo apply poe-profile命令用来取消应用在指定以太网端口上的PoE Profile配置。
每个以太网端口上只能应用一个PoE Profile。
PoE Profile是一组配置的集合,一个PoE Profile中可以设置多个PoE特性。使用apply poe-profile命令将PoE Profile应用到端口时,有些配置可以成功应用,有些配置不能成功应用。在本系列设备上应用PoE Profile配置时遵循如下规则:
l 使用apply poe-profile命令将PoE Profile应用到某端口时,只要PoE Profile中有一个PoE特性被正确应用,则应用PoE Profile的操作成功。使用display current-configuration命令查询时就会显示此PoE Profile被该端口正确应用。
l 若PoE Profile中有一个或多个PoE特性未被端口正确应用,则设备会明确的提示该PoE Profile中哪个PoE特性在哪个端口上未被正确应用。
l 使用display current-configuration命令查询时可以显示端口应用了哪个PoE Profile,但是不能显示PoE Profile下的哪些PoE特性应用成功。
# 将已存在的PoE Profile(profile-test)的配置,应用到设备以太网端口Ethernet1/0/1~Ethernet1/0/9上。
[Sysname] apply poe-profile profile-test interface Ethernet1/0/1 to Ethernet1/0/9
display poe-profile { all-profile | interface interface-type interface-number | name profile-name }
all-profile:显示所有的PoE Profile。
profile-name:显示指定名字的PoE profile。
【描述】
display poe-profile命令用来显示设备上已经创建的PoE Profile的详细配置信息。
# 显示名称为profile-test的PoE Profile的详细配置信息。
[Sysname] display poe-profile name profile-test
Poe-profile: profile-test, 3 action
poe enable
poe max-power 5000
undo poe-profile profile-name
【描述】
poe-profile命令用来创建一个PoE Profile并进入其视图(若该PoE Profile已创建,则直接进入其视图)。undo poe-profile命令用来删除已经创建的PoE Profile。
在PoE Profile模式下可以配置PoE的下列特性:
poe enable
本系列设备上最多可配100个PoE Profile。
# 创建一个名称为profile-test的PoE Profile。
[Sysname] poe-profile profile-test
