06-IP组播配置指导
04-组播VLAN配置
本章节下载 04-组播VLAN配置  (262.14 KB)
docurl=/cn/Service/Document_Software/Document_Center/Wlan/PoE/H3C_WP3000/Configure/Operation_Manual/H3C_WP3000_CG-Release_2101-6W100/06/201112/733819_30005_0.htm
04-组播VLAN配置
1 组播VLAN配置............................................................................................................................... 1-1
1.1 组播VLAN简介....................................................................................................................... 1-1
1.2 组播VLAN配置任务简介.......................................................................................................... 1-3
1.3 配置基于子VLAN的组播VLAN................................................................................................. 1-3
1.3.1 配置准备........................................................................................................................ 1-3
1.3.2 配置基于子VLAN的组播VLAN....................................................................................... 1-3
1.4 配置基于端口的组播VLAN........................................................................................................ 1-4
1.4.1 配置准备........................................................................................................................ 1-4
1.4.2 配置用户端口属性........................................................................................................... 1-4
1.4.3 配置组播VLAN端口....................................................................................................... 1-5
1.5 配置组播VLAN内IGMP Snooping转发表项的最大数量............................................................... 1-6
1.6 组播VLAN显示和维护.............................................................................................................. 1-6
1.7 组播VLAN典型配置举例.......................................................................................................... 1-7
1.7.1 基于子VLAN的组播VLAN配置举例................................................................................ 1-7
1.7.2 基于端口的组播VLAN配置举例..................................................................................... 1-11
1 组播VLAN配置
1.1  组播VLAN简介
图1-1所示,在传统的组播点播方式下,当属于不同VLAN的主机Host A、Host B和Host C同时点播同一组播组时,三层设备(Router A)需要把组播数据在每个用户VLAN(即主机所属的VLAN)内都复制一份发送给二层设备(WP A)。这样既造成了带宽的浪费,也给三层设备增加了额外的负担。
图1-1 未运行组播VLAN时的组播数据传输
可以使用组播VLAN功能解决这个问题。在二层设备上配置了组播VLAN后,三层设备只需把组播数据在组播VLAN内复制一份发送给二层设备,而不必在每个用户VLAN内都复制一份,从而节省了网络带宽,也减轻了三层设备的负担。
组播VLAN有以下两种实现和配置方式:
1. 基于子VLAN的组播VLAN
图1-2所示,接收者主机Host A、Host B和Host C分属不同的用户VLAN。在WP A上配置VLAN 10为组播VLAN,将所有的用户VLAN都配置为该组播VLAN的子VLAN,并在组播VLAN内使能IGMP Snooping。
图1-2 基于子VLAN的组播VLAN示意图
配置完成后,IGMP Snooping将在组播VLAN中对路由器端口进行维护,而在各子VLAN中对成员端口进行维护。这样,Router A只需把组播数据在组播VLAN内复制一份发送给WP A即可,WP A会将其分发给该组播VLAN内那些有接收者的子VLAN。
2. 基于端口的组播VLAN
图1-3所示,接收者主机Host A、Host B和Host C分属不同的用户VLAN,WP A上的所有用户端口(即连接主机的端口)均为Hybrid类型。在WP A上配置VLAN 10为组播VLAN,将所有用户端口都添加到该组播VLAN内,并在组播VLAN和所有用户VLAN内都使能IGMP Snooping。
图1-3 基于端口的组播VLAN示意图
配置完成后,当WP A上的用户端口收到来自主机的IGMP报文时,会为其打上组播VLAN的Tag并上送给IGMP查询器,于是IGMP Snooping就可以在组播VLAN中对路由器端口和成员端口进行统一的维护。这样,Router A只需把组播数据在组播VLAN内复制一份发送给WP A即可,WP A会将其分发给该组播VLAN内的所有成员端口。
l          有关IGMP Snooping的相关配置,以及路由器端口和成员端口的详细介绍,请参见“IP组播配置指导”中的“IGMP Snooping”。
l          有关VLAN Tag的详细介绍,请参见“二层技术-以太网交换配置指导”中的“VLAN”。
1.2  组播VLAN配置任务简介
表1-1 组播VLAN配置任务简介
配置任务
详细配置
配置基于子VLAN的组播VLAN
二者必选其一
1.3
配置基于端口的组播VLAN
配置用户端口属性
1.4.2
配置组播VLAN端口
1.4.3
1.5
若在设备上同时配置了基于子VLAN和基于端口的组播VLAN,则基于端口的组播VLAN将优先生效。
1.3.1  配置准备
在配置基于子VLAN的组播VLAN之前,需完成以下任务:
l              创建相应的VLAN
l              在欲配置为组播VLAN的VLAN内使能IGMP Snooping
首先需要把某个VLAN配置为组播VLAN,再将用户VLAN添加到该组播VLAN内,使其成为组播VLAN的子VLAN。
表1-2 配置基于子VLAN的组播VLAN
配置指定VLAN为组播VLAN,并进入组播VLAN视图
multicast-vlan vlan-id
缺省情况下,VLAN不是组播VLAN
向组播VLAN内添加子VLAN
subvlan vlan-list
缺省情况下,组播VLAN内没有子VLAN
l          在已使能了IP组播路由的设备上不允许再配置组播VLAN。
l          要配置为组播VLAN的指定VLAN必须存在。
l          要添加到组播VLAN内的子VLAN必须存在,且不能是组播VLAN或其它组播VLAN的子VLAN。
l          组播VLAN内子VLAN的总数不得超过系统限制。
1.4  配置基于端口的组播VLAN
在配置基于端口的组播VLAN时,需要先配置各用户端口的属性,然后再将配置好的用户端口添加到组播VLAN内。
l          只允许将以太网端口或二层聚合接口类型的用户端口配置为组播VLAN的端口。
l          二层以太网端口视图下的配置只对当前端口有效;二层聚合接口视图下的配置对当前接口有效;端口组视图下的配置对当前端口组中的所有端口有效。
1.4.1  配置准备
在配置基于端口的组播VLAN之前,需完成以下任务:
l              创建相应的VLAN
l              在所有的用户VLAN内都内使能IGMP Snooping
1.4.2  配置用户端口属性
配置用户端口为Hybrid类型,允许用户VLAN的报文通过,缺省VLAN为其所属的用户VLAN。
配置用户端口允许组播VLAN的报文通过,且不携带Tag。这样,当二层设备通过组播VLAN收到来自上游、打有组播VLAN Tag的组播数据报文时,会将其Tag去掉后再向下游转发。
表1-3 配置用户端口属性
进入相应视图
进入二层以太网端口视图
二者必选其一
进入端口组视图
port-group manual port-group-name
配置用户端口的链路类型为Hybrid类型
port link-type hybrid
缺省情况下,端口的链路类型为Access类型
配置用户端口的缺省VLAN为其所属的用户VLAN
port hybrid pvid vlan vlan-id
缺省情况下,Hybrid端口的缺省VLAN为VLAN 1
允许组播VLAN通过用户端口,且不携带Tag
port hybrid vlan vlan-id-list untagged
缺省情况下,Hybrid端口只允许VLAN 1通过
有关port link-typeport hybrid pvid vlanport hybrid vlan命令的详细介绍,请参见“二层技术-以太网交换命令参考”中的“VLAN”。
1.4.3  配置组播VLAN端口
首先需要把某个VLAN配置为组播VLAN,再将用户端口添加到该组播VLAN内——既可以在组播VLAN内添加端口,也可以在端口上指定其所属的组播VLAN——这两种配置方式是等效的。
1. 在组播VLAN内配置组播VLAN端口
表1-4 在组播VLAN内配置组播VLAN端口
缺省情况下,VLAN不是组播VLAN
向组播VLAN内添加端口
port interface-list
缺省情况下,组播VLAN内没有端口
2. 在端口上配置组播VLAN端口
表1-5 在端口上配置组播VLAN端口
缺省情况下,VLAN不是组播VLAN
退回系统视图
进入相应视图
进入二层以太网端口视图
二者必选其一
进入端口组视图
指定端口所属的组播VLAN
port multicast-vlan vlan-id
缺省情况下,端口不属于任何组播VLAN
l          一个端口只能属于一个组播VLAN。
用户可以调整组播VLAN内IGMP Snooping转发表项的最大数量,当所有组播VLAN内维护的表项总数达到最大数量后,将不再创建新的表项,直至有表项被老化或被手工删除。
表1-6 配置组播VLAN内IGMP Snooping转发表项的最大数量
multicast-vlan entry-limit limit
缺省情况下,组播VLAN内IGMP Snooping转发表项的最大数量为2000
在对组播VLAN内IGMP Snooping转发表项的最大数量进行配置时,如果所有组播VLAN内的表项总数已超过了配置值,系统将提示用户删除多余表项,但并不会自动删除任何已存在的表项,同时也不再继续创建新的表项。
1.6  组播VLAN显示和维护
在完成上述配置后,在任意视图下执行display命令可以显示配置后组播VLAN的运行情况,通过查看显示信息验证配置的效果。
表1-7 组播VLAN显示和维护
查看组播VLAN的信息
display multicast-vlan [ vlan-id ] [ | { begin | exclude | include } regular-expression ]
1.7  组播VLAN典型配置举例
l              图1-4所示,Router A通过端口Ethernet1/0/1连接组播源(Source),通过端口Ethernet1/0/2连接WP A;Router A上运行IGMPv2,WP A~WP C上都运行版本2的IGMP Snooping,并由Router A充当IGMP查询器。
l              组播源向组播组224.1.1.1发送组播数据,Host A~Host D都是该组播组的接收者(Receiver),且分别属于VLAN 2~VLAN 5。
l              通过在WP A上配置基于子VLAN的组播VLAN,使Router A通过组播VLAN向WP A下分属不同用户VLAN的主机分发组播数据。
图1-4 基于子VLAN的组播VLAN配置组网图
(1)        配置IP地址
请按照图1-4配置各接口的IP地址和子网掩码,具体配置过程略。
(2)        配置Router A
# 使能IP组播路由,在各接口上使能PIM-DM,并在主机侧端口Ethernet1/0/2上使能IGMP。
[RouterA] multicast routing-enable
[RouterA] interface ethernet 1/0/1
[RouterA-Ethernet1/0/1] pim dm
[RouterA-Ethernet1/0/1] quit
[RouterA] interface ethernet 1/0/2
[RouterA-Ethernet1/0/2] pim dm
[RouterA-Ethernet1/0/2] igmp enable
(3)        配置WP A
# 全局使能IGMP Snooping。
<WPA> system-view
[WPA] igmp-snooping
[WPA-igmp-snooping] quit
# 创建VLAN 2~VLAN 5。
[WPA] vlan 2 to 5
# 配置端口Ethernet1/0/2为Trunk端口,并允许VLAN 2和VLAN 3通过。
[WPA] interface ethernet 1/0/2
[WPA-Ethernet1/0/2] port link-type trunk
[WPA-Ethernet1/0/2] port trunk permit vlan 2 3
[WPA-Ethernet1/0/2] quit
# 配置端口Ethernet1/0/3为Trunk端口,并允许VLAN 4和VLAN 5通过。
[WPA] interface ethernet 1/0/3
[WPA-Ethernet1/0/3] port link-type trunk
[WPA-Ethernet1/0/3] port trunk permit vlan 4 5
[WPA-Ethernet1/0/3] quit
# 创建VLAN 10,把端口Ethernet1/0/1添加到该VLAN中,并在该VLAN内使能IGMP Snooping。
[WPA] vlan 10
[WPA-vlan10] port ethernet 1/0/1
[WPA-vlan10] igmp-snooping enable
[WPA-vlan10] quit
# 配置VLAN 10为组播VLAN,并把VLAN 2~VLAN 5都配置为该组播VLAN的子VLAN。
[WPA] multicast-vlan 10
[WPA-mvlan-10] subvlan 2 to 5
[WPA-mvlan-10] quit
(4)        配置WP B
<WPB> system-view
[WPB] igmp-snooping
[WPB-igmp-snooping] quit
# 创建VLAN 2,把端口Ethernet1/0/2添加到该VLAN中,并在该VLAN内使能IGMP Snooping。
[WPB] vlan 2
[WPB-vlan2] port ethernet 1/0/2
[WPB-vlan2] igmp-snooping enable
[WPB-vlan2] quit
# 创建VLAN 3,把端口Ethernet1/0/3添加到该VLAN中,并在该VLAN内使能IGMP Snooping。
[WPB] vlan 3
[WPB-vlan3] port ethernet 1/0/3
[WPB-vlan3] igmp-snooping enable
[WPB-vlan3] quit
# 配置端口Ethernet1/0/1为Trunk端口,并允许VLAN 2和VLAN 3通过。
[WPB] interface ethernet 1/0/1
[WPB-Ethernet1/0/1] port link-type trunk
[WPB-Ethernet1/0/1] port trunk permit vlan 2 3
(5)        配置WP C
WP C的配置与WP B相似,配置过程略。
(6)        检验配置效果
# 查看WP A上所有组播VLAN的信息。
[WPA] display multicast-vlan
 Total 1 multicast-vlan(s)
 Multicast vlan 10
   subvlan list:
    vlan 2-5
   port list:
    no port
# 查看WP A上IGMP Snooping组播组的信息。
[WPA] display igmp-snooping group
  Total 5 IP Group(s).
  Total 5 IP Source(s).
  Total 5 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):2.
    Total 1 IP Group(s).
    Total 1 IP Source(s).
    Total 1 MAC Group(s).
    Router port(s):total 0 port(s).
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:224.1.1.1
        (0.0.0.0, 224.1.1.1):
          Host port(s):total 1 port(s).
            Eth1/0/2                (D)
    MAC group(s):
      MAC group address:0100-5e01-0101
            Eth1/0/2
  Vlan(id):3.
            Eth1/0/2                (D)
    MAC group(s):
            Eth1/0/2
  Vlan(id):4.
            Eth1/0/3                (D)
    MAC group(s):
            Eth1/0/3
  Vlan(id):5.
            Eth1/0/3                (D)
    MAC group(s):
            Eth1/0/3
  Vlan(id):10.
    Router port(s):total 1 port(s).
            Eth1/0/1                (D)
          Host port(s):total 0 port(s).
    MAC group(s):
由此可见,IGMP Snooping在组播VLAN(VLAN 10)中维护路由器端口,而在各子VLAN(VLAN 2~VLAN 5)中维护各自的成员端口。
l              图1-5所示,Router A通过端口Ethernet1/0/1连接组播源(Source),通过端口Ethernet1/0/2连接WP A;Router A上运行IGMPv2,WP A上运行版本2的IGMP Snooping,并由Router A充当IGMP查询器。
l              组播源向组播组224.1.1.1发送组播数据,Host A~Host C都是该组播组的接收者(Receiver),且分别属于VLAN 2~VLAN 4。
l              通过在WP A上配置基于端口的组播VLAN,使Router A通过组播VLAN向WP A下分属不同用户VLAN的主机分发组播数据。
图1-5 基于端口的组播VLAN配置组网图
(1)        配置IP地址
(2)        配置Router A
(3)        配置WP A
<WPA> system-view
[WPA] igmp-snooping
[WPA] vlan 10
[WPA-vlan10] quit
# 创建VLAN 2,并在该VLAN内使能IGMP Snooping。
[WPA] vlan 2
[WPA-vlan2] igmp-snooping enable
[WPA-vlan2] quit
VLAN 3与VLAN 4的配置与VLAN 2相似,配置过程略。
# 配置端口Ethernet1/0/2为Hybrid类型,缺省VLAN为VLAN 2;允许VLAN 2和VLAN 10的报文通过,且均不携带Tag。
[WPA-Ethernet1/0/2] port link-type hybrid
[WPA-Ethernet1/0/2] port hybrid pvid vlan 2
[WPA-Ethernet1/0/2] port hybrid vlan 2 untagged
[WPA-Ethernet1/0/2] port hybrid vlan 10 untagged
Ethernet1/0/3与Ethernet1/0/4的配置与Ethernet1/0/2相似,配置过程略。
# 配置VLAN 10为组播VLAN。
# 将端口Ethernet1/0/2到Ethernet1/0/3添加到组播VLAN 10内。
[WPA-mvlan-10] port ethernet 1/0/2 to ethernet 1/0/3
[WPA-mvlan-10] quit
# 配置端口Ethernet1/0/4也属于组播VLAN 10。
[WPA] interface ethernet 1/0/4
[WPA-Ethernet1/0/4] port multicast-vlan 10
[WPA-Ethernet1/0/4] quit
(4)        检验配置效果
 Multicast vlan 10
   subvlan list:
    no subvlan
   port list:
    Eth1/0/2                 Eth1/0/3                 Eth1/0/4
  Vlan(id):10.
            Eth1/0/1                (D)
          Host port(s):total 3 port(s).
            Eth1/0/2                (D)
            Eth1/0/3                (D)
            Eth1/0/4                (D)
    MAC group(s):
            Eth1/0/2
            Eth1/0/3
            Eth1/0/4
由此可见,IGMP Snooping统一在组播VLAN(VLAN 10)中维护路由器端口和成员端口。
