05-MBGP命令
本章节下载 (295.84 KB)
1.1.1 aggregate (MBGP Family view)
1.1.2 balance (MBGP Family view)
1.1.3 bestroute as-path-neglect (MBGP Family view)
1.1.4 bestroute compare-med (MBGP Family view)
1.1.5 bestroute med-confederation (MBGP Family view)
1.1.6 compare-different-as-med (MBGP Family view)
1.1.7 dampening (MBGP Family view)
1.1.8 default local-preference (MBGP Family view)
1.1.9 default med (MBGP Family view)
1.1.10 default-route imported (MBGP Family view)
1.1.11 display ip multicast routing-table
1.1.12 display ip multicast routing-table ip-address
1.1.13 display bgp multicast group
1.1.14 display bgp multicast network
1.1.15 display bgp multicast paths
1.1.16 display bgp multicast peer
1.1.17 display bgp multicast routing-table
1.1.18 display bgp multicast routing-table as-path-acl
1.1.19 display bgp multicast routing-table cidr
1.1.20 display bgp multicast routing-table community
1.1.21 display bgp multicast routing-table community-list
1.1.22 display bgp multicast routing-table dampened
1.1.23 display bgp multicast routing-table dampening parameter
1.1.24 display bgp multicast routing-table different-origin-as
1.1.25 display bgp multicast routing-table flap-info
1.1.26 display bgp multicast routing-table peer
1.1.27 display bgp multicast routing-table regular-expression
1.1.28 display bgp multicast routing-table statistic
1.1.29 filter-policy export (MBGP Family view)
1.1.30 filter-policy import (MBGP Family view)
1.1.31 import-route (MBGP Family view)
1.1.33 network (MBGP Family view)
1.1.34 peer advertise-community (MBGP Family view)
1.1.35 peer advertise-ext-community (MBGP Family view)
1.1.36 peer allow-as-loop (MBGP Family view)
1.1.37 peer as-path-acl (MBGP Family view)
1.1.38 peer default-route-advertise (MBGP Family view)
1.1.39 peer enable (MBGP Family view)
1.1.40 peer filter-policy (MBGP Family view)
1.1.41 peer group (MBGP Family view)
1.1.42 peer ip-prefix (MBGP Family view)
1.1.43 peer keep-all-routes (MBGP Family view)
1.1.44 peer next-hop-local (MBGP Family view)
1.1.45 peer preferred-value (MBGP Family view)
1.1.46 peer public-as-only (MBGP Family view)
1.1.47 peer reflect-client (MBGP Family view)
1.1.48 peer route-limit (MBGP Family view)
1.1.49 peer route-policy (MBGP Family view)
1.1.50 preference (MBGP Family view)
1.1.51 reflect between-clients (MBGP Family view)
1.1.52 reflector cluster-id (MBGP Family view)
1.1.53 refresh bgp ipv4 multicast
1.1.54 reset bgp ipv4 multicast
1.1.55 reset bgp ipv4 multicast dampening
1.1.56 reset bgp ipv4 multicast flap-info
1.1.57 summary automatic (MBGP Family view)
l 本章所指的路由器代表了一般意义下的路由器,以及运行了路由协议的以太网交换机。为提高可读性,在手册的描述中将不另行说明。
l MBGP中有关定义路由策略的命令,请参见“IP路由分册”中的“路由策略命令”。
aggregate ip-address { mask | mask-length } [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ] *
undo aggregate ip-address { mask | mask-length }
MBGP地址族视图
【缺省级别】
2:系统级
ip-address:聚合路由的目的IP地址。
mask-length:网络掩码长度,取值范围为0~32。
as-set:生成具有AS集合段的路由。
attribute-policy route-policy-name:根据指定的路由策略route-policy-name设置聚合路由的属性。route-policy-name表示路由策略名,为1~19个字符的字符串。
detail-suppressed:仅通告聚合路由。
suppress-policy route-policy-name:根据指定的路由策略route-policy-name抑制选定的具体路由,不通告部分具体路由。route-policy-name为1~19个字符的字符串。
origin-policy route-policy-name:根据指定的路由策略route-policy-name选择用于聚合的源路由。route-policy-name表示路由策略名,为1~19个字符的字符串。
上述命令的关键字的用法如表1-1所示。
关键字 |
用法 |
as-set |
通过设置该关键字,可创建一条聚合路由,该路由的AS路径包含了具体路由的AS路径信息。若需聚合较多AS路径时,请慎用此关键字,因为当具体路由的变化较频繁时,会导致路由振荡 |
detail-suppressed |
该关键字不抑制聚合路由,但抑制所有具体路由的通告。如果只想对一部分具体路由进行抑制,可以使用peer filter-policy命令 |
suppress-policy |
该关键字能产生聚合路由,但抑制指定路由的通告。可以用route-policy的if-match子句有选择地抑制一些具体路由,其它具体路由仍被通告 |
origin-policy |
该关键字仅选择符合路由策略的具体路由来生成聚合路由 |
attribute-policy |
该关键字可设置聚合路由的属性。通过peer route-policy等方式也可以完成实现相同的功能。该关键字不能设置聚合路由的AS-PATH属性 |
【描述】
aggregate命令用来在MBGP路由表中创建一条聚合路由。undo aggregate命令用来删除该条聚合路由。
缺省情况下,没有进行路由聚合。
# 在MBGP路由表中创建一条聚合路由10.40.0.0/16。
[Sysname] bgp 100
[Sysname-bgp] ipv4-family multicast
[Sysname-bgp-af-mul] aggregate 10.40.0.0 255.255.0.0
balance number
undo balance
MBGP地址族视图
【缺省级别】
2:系统级
number:进行负载分担的BGP路由条数,取值为1时,相当于不进行负载分担。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
【描述】
balance命令用来配置进行BGP负载分担的路由条数。undo balance命令用来恢复缺省情况。
缺省情况下,没有进行路由负载分担。
与IGP路由的负载分担不同,BGP没有明确的度量值决定是否对路由进行负载分担。BGP的负载分担是通过改变BGP选路规则来实现的。
相关配置可参考命令display ip multicast routing-table。
# 配置BGP负载分担的路由条数为2条。
[Sysname] bgp 100
[Sysname-bgp-af-mul] balance 2
undo bestroute as-path-neglect
MBGP地址族视图
【缺省级别】
2:系统级
无
【描述】
bestroute as-path-neglect命令用来配置MBGP在选择最优路由时忽略AS路径属性。undo bestroute as-path-neglect命令用来恢复缺省情况。
缺省情况下,MBGP在选择最优路由时不忽略AS路径属性。
# 禁止路由器将AS_PATH当作选路算法中的一个因素。
[Sysname] bgp 100
[Sysname-bgp-af-mul] bestroute as-path-neglect
undo bestroute compare-med
MBGP地址族视图
【缺省级别】
2:系统级
无
【描述】
bestroute compare-med命令用来配置根据路由来自的AS进行分组,对MED排序优选。undo bestroute compare-med命令用来恢复缺省情况。
缺省情况下,不根据路由来自的AS进行分组对MED排序优选。
# 设置在选择最佳路由时,根据路由来自的AS进行分组对MED排序优选。
[Sysname] bgp 100
[Sysname-bgp-af-mul] bestroute compare-med
undo bestroute med-confederation
MBGP地址族视图
【缺省级别】
2:系统级
无
【描述】
bestroute med-confederation命令用来比较联盟对等体的路由按MED值进行优选。undo bestroute med-confederation命令用来恢复缺省情况。
缺省情况下,比较联盟对等体的路由时不考虑MED值。
只有不包括外部自治系统(不在联盟内)的路径才可比较MED值。如果包含外部自治系统的路径,其MED将在联盟内传播,而不进行比较。
# 配置联盟对等体的路由按MED值进行优选。
[Sysname] bgp 100
[Sysname-bgp-af-mul] bestroute med-confederation
undo compare-different-as-med
MBGP地址族视图
【缺省级别】
2:系统级
无
【描述】
compare-different-as-med命令用来配置允许比较来自不同AS邻居的路由路径的MED值。undo compare-different-as-med命令用来恢复缺省情况。
缺省情况下,不允许比较来自不同AS邻居的路由路径的MED属性值。
l 如果到达同一目的地址有多条可选有效路径,可以选择MED参数较小的路由作为最终实际使用的路由项。
l 除非能够确认不同的自治系统采用了同样的IGP和路由选择方式,否则不要使用此命令。
# 配置允许比较来自不同AS邻居的路由路径的MED属性值。
[Sysname] bgp 100
[Sysname-bgp-af-mul] compare-different-as-med
undo dampening
MBGP地址族视图
【缺省级别】
2:系统级
half-life-reachable:指定可达路由的半衰期,取值范围为1~45,单位为分钟,缺省值为15分钟。
half-life-unreachable:指定不可达路由的半衰期,取值范围为1~45,单位为分钟,缺省值为15分钟。
reuse:指定路由解除抑制状态的阈值。当惩罚值降低到该值以下,路由就被再使用,取值范围为1~20000,缺省值为750。
suppress:指定路由进入抑制状态的阈值。当惩罚值超过该极限时,路由受到抑制,取值范围为1~20000,缺省值为2000。
ceiling:惩罚上限值,惩罚值到达该值后将不再增加。取值范围为1001~20000,实际配置的值必须大于suppress,缺省值为16000。
route-policy-name:路由策略名,为1~19个字符的字符串。
【描述】
dampening命令用来配置MBGP路由衰减。undo dampening命令用来取消MBGP路由衰减。
缺省情况下,没有配置MBGP路由衰减。
该命令只对从EBGP邻居学到的路由进行衰减,对IBGP路由不进行衰减。
# 配置路由衰减,其中可达路由半衰期取值为15,不可达路由半衰期取值为15,路由解除抑制状态的阈值为1000,路由进入抑制状态的阈值为2000,惩罚上限值为10000。
[Sysname] bgp 100
[Sysname-bgp-af-mul] dampening 15 15 1000 2000 10000
undo default local-preference
MBGP地址族视图
【缺省级别】
2:系统级
value:指定的本地优先级的缺省值,取值范围为0~4294967295,该值越大则优先级越高。
【描述】
default local-preference命令用来配置本地优先级的缺省值。undo default local-preference命令用来恢复缺省情况。
缺省情况下,本地优先级的缺省值为100。
可以用配置不同本地优先级的方法来影响BGP的路由选择。
# 配置本地优先级的缺省值为180。
[Sysname] bgp 100
[Sysname-bgp-af-mul] default local-preference 180
default med med-value
undo default med
MBGP地址族视图
【缺省级别】
2:系统级
med-value:指定的MED的缺省值,取值范围为0~4294967295。
【描述】
default med命令用来配置系统MED的缺省值。undo default med命令用来恢复缺省情况。
缺省情况下,MED的缺省值为0。
多出口区分(MED)属性是一个路由的外部度量(Metric),与本地优先级属性不同,MED在自治系统间交换,但进入自治系统的MED不会再发送到该自治系统以外。MED属性用于选择最佳路由,MED较小的路由被选择。当一个运行BGP的路由器通过不同的外部对等体(External Peer)得到目的地址相同、下一跳不同的路由时,将根据不同路由的MED值进行优先选择。在其它条件相同的情况下,MED较小的路由作为自治系统的外部路由。
# 配置系统MED的缺省值为25。
[Sysname] bgp 100
[Sysname-bgp-af-mul] default med 25
undo default-route imported
MBGP地址族视图
【缺省级别】
2:系统级
无
【描述】
default-route imported命令用来允许将缺省路由引入到MBGP路由表中。undo default-route imported命令用来恢复缺省情况。
缺省情况下,BGP不允许将缺省路由引入到MBGP路由表中。
default-route imported命令不能引入缺省路由,如果要引入缺省路由,必须使用import-route命令。
相关配置可参考命令import-route。
# 将缺省路由从OSPF引入到MBGP路由表中。
[Sysname] bgp 100
[Sysname-bgp-af-mul] default-route imported
[Sysname-bgp-af-mul] import-route ospf 1
display ip multicast routing-table [ verbose ]
所有视图
【缺省级别】
1:监控级
verbose:显示全部MBGP路由表的详细信息,包括处于inactive和active状态的组播路由。如果不带此参数,将只显示处于active状态的MBGP路由。
【描述】
display ip multicast routing-table命令用来查看MBGP路由表中的路由信息。
在MBGP路由表中的路由有两种状态:一种是active状态,表示该条路由是通过MBGP选出来的最优路由,将用于执行RPF检查;另外一种是inactive状态,表示该条路由不是最优路由,不会用来执行RPF检查。
# 查看MBGP路由表中当前激活路由的摘要信息。
<Sysname> display ip multicast routing-table
Routing Tables: Public
Destinations : 6 Routes : 6
2.2.2.0/24 Direct 0 0 2.2.2.1 Vlan-interface2
2.2.2.1/32 Direct 0 0 127.0.0.1 InLoopBack0
127.0.0.0/8 Direct 0 0 127.0.0.1 InLoopBack0
127.0.0.1/32 Direct 0 0 127.0.0.1 InLoopBack0
192.168.80.0/24 Direct 0 0 192.168.80.10 Vlan-interface1
192.168.80.10/32 Direct 0 0 127.0.0.1 InLoopBack0
表1-2 display ip multicast routing-table命令显示信息描述表
Routing Tables: Public |
表示此路由信息是公网的路由信息 |
Destinantions |
目的地址个数 |
Routes |
路由条数 |
Destination/Mask |
目的地址/掩码长度 |
Proto |
发现该路由的路由协议 |
Pre |
路由的优先级 |
Cost |
路由的度量值 |
Nexthop |
此路由的下一跳地址 |
出接口,即到该目的网段的数据报文将从此接口发出 |
# 查看MBGP路由表的全部详细信息。
<Sysname> display ip multicast routing-table verbose
Routing Table : Public
Destinations : 2 Routes : 2
Destination: 192.168.80.0/24
Protocol: Direct Process ID: 0
Preference: 0 Cost: 0
NextHop: 192.168.80.10 Interface: Vlan-interface1
RelyNextHop: 0.0.0.0 Neighbour: 0.0.0.0
Tunnel ID: 0x0 Label: NULL
State: Active Adv Age: 00h14m49s
Tag: 0
Destination: 192.168.80.10/32
NextHop: 127.0.0.1 Interface: InLoopBack0
State: Active NoAdv Age: 00h14m49s
Tag: 0
表1-3 display ip multicast routing-table verbose命令显示信息描述表
Destination |
目的地址/掩码 |
Protocol |
发现该路由的路由协议 |
Process ID |
进程号 |
Preference |
路由的优先级 |
Cost |
路由的度量值 |
NextHop |
此路由的下一跳地址 |
RelyNextHop |
路由迭代出来得到的下一跳地址 |
Neighbour |
路由协议的邻居地址,表示该路由是从哪个邻居学到的 |
Tunnel ID |
隧道ID |
Lable |
标签 |
State |
路由状态,包括:Active(激活)、Inactive(非激活)、Adv(向外发布)、NoAdv(不向外发布)等 |
Age |
此路由在路由表中存在的时间,从左至右依次为小时、分钟、秒 |
Tag |
路由标记 |
display ip multicast routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
【缺省级别】
1:监控级
ip-address:目的IP地址,点分十进制格式。
mask-length:IP地址掩码,取值范围为0~32。
mask:点分十进制格式。
longer-match:显示在前缀长度范围内匹配目的地址的路由。
verbose:当使用该参数时,显示处于active状态和inactive状态的路由的详细信息。如果不使用该参数,将只显示处于active状态的路由的摘要信息。
【描述】
display ip multicast routing-table命令用来查看指定目的地址的组播路由信息。使用不同的可选参数,命令的输出也不相同,以下是对该命令不同形式的输出说明:
l display ip multicast routing-table ip-address,如果目的地址ip-address在自然掩码范围内有相应的组播路由,则将显示其全部子网组播路由,否则只显示与目的地址ip-address最长匹配的组播路由。只显示处于active状态的匹配组播路由。
l display ip multicast routing-table ip-address mask、display ip multicast routing-table ip-address mask length只显示与指定目的地址及掩码精确匹配的组播路由。
# 在自然掩码范围内有相应组播路由,查看摘要信息。
<Sysname> display ip multicast routing-table 169.0.0.0
Summary Count : 1
169.0.0.0/16 Static 60 0 2.1.1.1 LoopBack1
以上显示的信息域的解释请参见表1-2。
# 在自然掩码范围内没有相应的组播路由(只显示最长匹配的组播路由),查看摘要信息。
<Sysname> display ip multicast routing-table 169.253.0.0
Summary Count : 1
169.0.0.0/8 Static 60 0 2.1.1.1 LoopBack1
以上显示的信息域的解释请参见表1-2。
# 在自然掩码范围内有相应组播路由,查看详细信息。
<Sysname> display ip multicast routing-table 2.2.2.1 verbose
Summary Count : 1
Destination: 2.2.2.1/32
State: Active NoAdv Age: 05h38m46s
Tag: 0
以上显示的信息域的解释请参见表1-3。
# 在自然掩码范围内没有相应的组播路由(只显示最长匹配的路由),查看详细信息。
<Sysname> display ip multicast routing-table 169.253.2.1 verbose
Summary Count : 1
Destination: 169.0.0.0/8
NextHop: 169.1.1.1 Interface: Vlan-interface1
State: Active Adv Age: 00h00m32s
Tag: 0
以上显示的信息域的解释请参见表1-3。
display bgp multicast group [ group-name ]
【缺省级别】
1:监控级
group-name:MBGP对等体组的名称,为1~47个字符的字符串。
【描述】
display bgp multicast group命令用来显示MBGP对等体组信息。
# 显示MBGP对等体组信息。
<Sysname> display bgp multicast group aaa
BGP peer-group is aaa
remote AS 200
Type : external
Threshold: 75%
Configured hold timer value: 180
Keepalive timer value: 60
Minimum time between advertisement runs is 30 seconds
Peer Preferred Value: 0
Members:
Peer V AS MsgRcvd MsgSent OutQ PrefRcv Up/Down State
2.2.2.1 4 200 0 0 0 0 00:00:35 Active
表1-4 display bgp multicast group命令显示信息描述表
BGP peer-group |
MBGP对等体组名 |
remote AS |
对等体组AS号 |
Type |
对等体组类型 |
Maximum allowed prefix number |
可接受最大路由数 |
Threshold |
配置了允许从MBGP对等体/MBGP对等体组收到的最大路由数后,路由器开始生成告警消息时的路由数量的百分比 |
Configured hold timer value |
保持时间间隔 |
Keepalive timer value |
存活时间间隔 |
Minimum time between advertisement runs |
路由发布最小时间间隔 |
Peer Preferred Value |
为来自对等体路由指定的首选值 |
No routing policy is configured |
没有针对该对等体组指定任何路由策略 |
Members |
对等体组中包含的成员的详细信息 |
Peer |
对等体的IPv4地址 |
V |
对等体运行的BGP版本号 |
AS |
对等体所在的自治系统号 |
MsgRcvd |
收到的消息数 |
MsgSent |
发送的消息数 |
OutQ |
待发送的消息数 |
PrefRcv |
收到的前缀数 |
Up/Down |
会话已建立的时长/(会话未建立时)当前状态的时长 |
State |
对等体的状态 |
【缺省级别】
1:监控级
无
【描述】
display bgp multicast network命令用来显示MBGP地址族下已经发布的路由信息。
# 显示MBGP地址族下已经发布的路由信息。
<Sysname> display bgp multicast network
BGP Local Router ID is 10.1.4.2.
Local AS Number is 400.
Network Mask Route-policy Short-cut
100.1.2.0 255.255.255.0
100.1.1.0 255.255.255.0 Short-cut
表1-5 display bgp multicast network命令显示信息描述表
BGP Local Router ID |
本地路由器标识符 |
Local AS Number |
本地自治系统号 |
Network |
网络地址 |
Mask |
掩码 |
Route-policy |
配置的路由策略 |
Short-cut |
是否为Short-cut路由 |
display bgp multicast paths [ as-regular-expression ]
【缺省级别】
1:监控级
as-regular-expression:表示正则表达式,为1~80个字符的字符串,包括空格,区分大小写。
【描述】
display bgp multicast paths命令用来显示匹配AS路径正则表达式的MBGP路由的AS路径信息。
# 显示MBGP路由的AS路径信息。
<Sysname> display bgp multicast paths ^200
Address Hash Refcount MED Path/Origin
0x5917100 11 1 200 300i
表1-6 display bgp multicast paths命令显示信息描述表
Address |
本地数据库中的路由地址,十六进制格式 |
Hash |
哈希值 |
Refcount |
使用该路径的路由条数 |
MED |
该路由的度量值 |
Path |
路由的AS路径(AS_PATH)属性,记录了此路由所穿过的所有AS区域,可以避免路由环路的出现 |
Origin |
路由的起源(ORIGIN)属性,表示路由相对于发出它的自治系统的路由更新起点,它有如下3种取值: l i:此路由是AS内部的;BGP把聚合路由和用network命令定义的路由看成是AS内部的,起点类型设置为IGP。 l e:此路由是从外部网关协议EGP学习到的。 l ?:此路由的来源无法确定,例如,引入的其它路由协议的路由信息。 |
display bgp multicast peer [ ip-address ] [ verbose ]
【缺省级别】
1:监控级
ip-address:指定要显示的MBGP对等体的IP地址。
verbose:显示MBGP对等体的详细信息。
【描述】
display bgp multicast peer命令用来显示MBGP对等体的信息。
# 显示MBGP对等体10.110.25.20的详细信息。
<Sysname> display bgp multicast peer 10.110.25.20 verbose
Peer: 10.110.25.20 Local: 2.2.2.2
Type: EBGP link
BGP version 4, remote router ID 1.1.1.1
BGP current state: Established, Up for 00h01m51s
BGP current event: RecvKeepalive
BGP last state: OpenConfirm
Port: Local - 1029 Remote - 179
Configured: Active Hold Time: 180 sec Keepalive Time: 60 sec
Received : Active Hold Time: 180 sec
Negotiated: Active Hold Time: 180 sec
Peer optional capabilities:
Peer support bgp multi-protocol extended
Peer support bgp route refresh capability
Address family IPv4 Unicast: advertised and received
Received: Total 5 messages, Update messages 1
Sent: Total 4 messages, Update messages 0
Threshold: 75%
Optional capabilities:
BFD: Enabled
Routing policy configured:
表1-7 display bgp multicast peer命令显示信息描述表
Peer |
对等体的IP地址 |
Local |
本地的路由器ID |
Type |
对等体的类型,IBGP link 表示是IBGP对等体,EBGP link是EBGP对等体 |
BGP version |
协议版本号 |
remote router ID |
对等体的路由器ID |
BGP current state |
对等体当前状态 |
BGP current event |
对等体当前事件 |
BGP last state |
对等体前一状态 |
Port |
建立TCP连接时本地和对等体分别使用的端口号 |
Configured: Active Hold Time |
本地配置的与对等体连接的保持时间 |
Keepalive Time |
本地配置的与对等体连接的存活时间间隔 |
Received: Active Hold Time |
对等体配置的与对等体连接的保持时间 |
Negotiated: Active Hold Time |
协商后的保持时间 |
Peer optional capabilities |
对等体所支持的可选扩展能力,包括BGP多协议扩展和路由刷新 |
Address family IPv4 Unicast |
支持IPv4单播地址族 |
Address family IPv4 Multicast |
支持IPv4组播地址族 |
Received |
本地接收的总报文数和Update报文数 |
Sent |
本地发送的总报文数和Update报文数 |
可接受最大路由数 |
Threshold |
门槛值 |
路由发布最小时间间隔 |
Optional capabilities |
对等体使能的可选扩展能力 |
为来自对等体路由指定的首选值 |
BFD |
对等体是否配置了BFD功能 |
Routing policy configured |
本地采取的路由策略 |
display bgp multicast routing-table [ ip-address [ { mask | mask-length } [ longer-prefixes ] ] ]
【缺省级别】
1:监控级
ip-address:目的IP地址。
mask:网络掩码,点分十进制格式。
longer-prefixes:匹配最长前缀。
【描述】
display bgp multicast routing-table命令用来显示MBGP路由信息。
# 查看MBGP的路由信息。
<Sysname> display bgp multicast routing-table
Total Number of Routes: 1
BGP Local router ID is 10.10.10.1
Status codes: * - valid, > - best, d - damped,
h - history, i - internal, s - suppressed, S - Stale
Origin : i - IGP, e - EGP, ? - incomplete
*> 40.40.40.0/24 20.20.20.1 0 200 300i
表1-8 display bgp multicast routing-table命令显示信息描述表
Total Number of Routes |
路由总数 |
BGP Local router ID |
BGP本地路由器标识符 |
Status codes |
路由状态代码: l *:表示valid(合法) l >:表示best(最佳路由) l d:表示damped(震荡抑制) l h:表示history(历史路由) l i:表示internal(内部路由) l s:表示suppressed(聚合抑制) l S:表示Stale(过期路由) |
Origin |
Network |
目的网络地址 |
Next Hop |
下一跳IP地址 |
MED |
MULTI_EXIT_DISC属性值 |
LocPrf |
本地优先级 |
PrefVal |
路由首选值 |
Path |
Ogn |
display bgp multicast routing-table as-path-acl as-path-acl-number
【缺省级别】
1:监控级
as-path-acl-number:指定匹配的AS路径过滤列表号,取值范围为1~256。
【描述】
display bgp multicast routing-table as-path-acl命令用来显示匹配指定AS路径过滤列表的MBGP路由信息。
# 显示匹配过滤列表1的MBGP路由信息。
<Sysname> display bgp multicast routing-table as-path-acl 1
BGP Local router ID is 20.20.20.1
*> 40.40.40.0/24 30.30.30.1 0 0 300i
以上显示的信息域的解释请参见表1-8。
【缺省级别】
1:监控级
无
【描述】
display bgp multicast routing-table cidr命令用来显示CIDR(Classless Inter-Domain Routing,无类别域间路由)的MBGP路由信息。
# 显示CIDR的MBGP路由信息。
<Sysname> display bgp multicast routing-table cidr
以上显示的信息域的解释请参见表1-8。
display bgp multicast routing-table community [ aa:nn ]&<1-13> [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ]
【缺省级别】
1:监控级
aa:nn:指定团体号,aa和nn的取值范围为0~65535。
&<1-13>:表示前面的参数可以输入1~13次。
no-advertise:具有此属性的路由在收到后,不能被通告给任何其他的BGP对等体。
no-export:具有此属性的路由在收到后,不能被发布到本地AS之外。如果使用了联盟,则不能被发布到联盟之外,但可以发布给联盟中的其他子AS。
no-export-subconfed:具有此属性的路由在收到后,既不能被发布到本地AS之外,也不能发布到联盟中的其他子AS。
whole-match:精确匹配。
【描述】
display bgp multicast routing-table community命令用来显示属于指定BGP团体的MBGP路由信息。
# 显示属于指定BGP团体的MBGP路由信息。
<Sysname> display bgp multicast routing-table community 11:22
*> 10.10.10.0/24 0.0.0.0 0 0 i
以上显示的信息域的解释请参见表1-8。
display bgp multicast routing-table community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16>
【缺省级别】
1:监控级
basic-community-list-number:为基本团体列表号,取值范围为1~99。
adv-community-list-number:为高级团体列表号,取值范围为100~199。
whole-match:为确切匹配,即有且仅有basic-community-list-number定义的团体必须出现。
&<1-16>:表示前面的参数可以输入1~16次。
【描述】
display bgp multicast routing-table community-list命令用来显示匹配指定的BGP团体列表的MBGP路由信息。
# 显示指定BGP团体列表100的MBGP路由信息。
<Sysname> display bgp multicast routing-table community-list 100
BGP Local router ID is 1.2.3.4
Origin codes: i - IGP, e - EGP, ? - incomplete
Network NextHop Metric LocPrf PrefVal Path
*> 3.3.3.0/30 1.2.3.4 0 ?
*> 4.4.0.0/20 1.2.3.4 0 ?
*> 4.5.6.0/26 1.2.3.4 0 ?
BGP Local router ID is 30.30.30.1
*> 30.30.30.0/24 0.0.0.0 0 0 i
*> 40.40.40.0/24 0.0.0.0 0 0 i
以上显示的信息域的解释请参见表1-8。
【缺省级别】
1:监控级
无
【描述】
display bgp multicast routing-table dampened命令用来显示BGP衰减的MBGP路由信息。
# 显示BGP衰减的MBGP路由信息。
<Sysname> display bgp multicast routing-table dampened
BGP Local router ID is 2.2.2.2
Network From Reuse Path/Origin
*d 77.0.0.0 12.1.1.1 00:29:20 100?
表1-9 display bgp multicast routing-table dampened命令部分显示信息描述表
From |
路由的源IP地址 |
Reuse |
路由恢复可用时间,即还需要等待多长时间该路由将由不可用状态转为可用状态 |
其他显示信息域的解释请参见表1-8。
【缺省级别】
1:监控级
无
【描述】
display bgp multicast routing-table dampening parameter命令用来显示已配置的MBGP路由衰减参数。
相关配置可参考命令dampening。
# 显示MBGP路由衰减参数。
<Sysname> display bgp multicast routing-table dampening parameter
Maximum Suppress Time(in second) : 3069
Ceiling Value : 16000
Reuse Value : 750
Reach HalfLife Time(in second) : 900
Unreach HalfLife Time(in second): 900
Suppress-Limit : 2000
表1-10 display bgp multicast routing-table dampening parameter命令显示信息描述表
Maximum Suppress Time |
最大抑制时间 |
Ceiling Value |
惩罚上限值 |
Reuse Value |
路由解除抑制状态的阈值 |
Reach HalfLife Time(in second) |
可达路由的半衰期 |
Unreach HalfLife Time(in second) |
不可达路由的半衰期 |
Suppress-Limit |
路由进入抑制状态的阈值 |
【缺省级别】
1:监控级
无
【描述】
display bgp multicast routing-table different-origin-as命令用来显示不同起源AS的MBGP路由信息。
# 显示具有不同起源AS的MBGP路由信息。
<Sysname> display bgp multicast routing-table different-origin-as
*> 55.0.0.0 12.1.1.1 0 0 100?
* 14.1.1.2 0 0 300?
以上显示的信息域的解释请参见表1-8。
display bgp multicast routing-table flap-info [ regular-expression as-regular-expression | as-path-acl as-path-acl-number | ip-address [ { mask | mask-length } [ longer-match ] ] ]
【缺省级别】
1:监控级
as-regular-expression:显示匹配指定的AS路径正则表达式的振荡路由的信息,为1~80个字符的字符串,包括空格,区分大小写。
as-path-acl-number:显示匹配指定的AS路径过滤列表号的振荡路由的信息,取值范围为1~256。
ip-address:目的IP地址。
mask:网络掩码,点分十进制格式。
longer-match:匹配最长前缀。
【描述】
display bgp multicast routing-table flap-info命令用来显示MBGP地址族下BGP路由振荡统计信息。
如果不指定任何参数,将显示MBGP地址族下所有BGP振荡路由的统计信息。
# 显示MBGP地址族下所有BGP路由的振荡统计信息。
<Sysname> display bgp multicast routing-table flap-info
Network From Flaps Duration Reuse Path/Origin
*> 55.0.0.0 12.1.1.1 2 00:00:16 100?
*d 77.0.0.0 12.1.1.1 5 00:34:02 00:27:08 100?
表1-11 display bgp multicast routing-table flap-info命令部分显示信息描述表
From |
路由的源IP地址 |
Flaps |
路由振荡的次数 |
Duration |
路由持续时间 |
Reuse |
路由复用时间 |
其他显示信息域的解释请参见表1-8。
display bgp multicast routing-table peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistic ]
【缺省级别】
1:监控级
ip-address:对等体的IP地址。
advertised-routes:显示向指定的MBGP对等体发布的路由信息。
received-routes:显示从指定的MBGP对等体接收到的路由信息。
network-address:目的网段的IP地址。
mask:目的网段的网络掩码,点分十进制格式。
mask-length:目的网段的网络掩码长度,取值范围为0~32。
statistic:显示路由的统计信息。
【描述】
display bgp multicast routing-table peer命令用来显示向指定的MBGP对等体发送或者从MBGP对等体收到的路由信息。
相关配置命令可参考命令display bgp multicast peer。
# 显示向MBGP对等体20.20.20.1发布的路由信息。
<Sysname> display bgp multicast routing-table peer 20.20.20.1 advertised-routes
Total Number of Routes: 2
以上显示的信息域的说明请参见表1-8。
display bgp multicast routing-table regular-expression as-regular-expression
【缺省级别】
1:监控级
as-regular-expression:匹配的AS路径正则表达式,as-regular-expression为1~80个字符的字符串,包括空格,区分大小写。
【描述】
display bgp multicast routing-table regular-expression命令用来显示与指定的AS路径正则表达式相匹配的MBGP路由信息。
# 显示与AS正则表达式300$相匹配的MBGP路由信息。
<Sysname> display bgp multicast routing-table regular-expression 300$
以上显示的信息域的说明请参见表1-8。
【缺省级别】
1:监控级
无
【描述】
display bgp multicast routing-table statistic命令用来显示MBGP的路由统计信息。
# 显示MBGP的路由统计信息。
<Sysname> display bgp multicast routing-table statistic
Total Number of Routes: 4
表1-12 display bgp multicast routing-table statistic命令显示信息描述表
路由总数 |
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ direct | isis process-id | ospf process-id | rip process-id | static ]
undo filter-policy export [ direct | isis process-id | ospf process-id | rip process-id | static ]
MBGP地址族视图
【缺省级别】
2:系统级
acl-number:指定用于匹配路由信息目的地址域的访问列表号,取值范围为2000~3999。
ip-prefix-name:指定用于匹配路由信息目的地址域的地址前缀列表,为1~19个字符的字符串。
direct:直连路由。
isis process-id:协议进程号为process-id的isis路由,process-id的取值范围为1~65535。
ospf process-id:协议进程号为process-id的ospf路由,process-id的取值范围为1~65535。
rip process-id:协议进程号为process-id的rip路由,process-id的取值范围为1~65535。
static:静态路由。
【描述】
filter-policy export命令用来配置引入的路由在发布时进行过滤。undo filter-policy export命令用来取消引入的路由在发布时进行过滤。
缺省情况下,不对引入的路由在发布时进行过滤。
如果省略路由协议参数,将对所有引入的路由在发布时进行过滤。
# 使用ACL 2000对所有BGP发布路由进行过滤。
[Sysname] bgp 100
[Sysname-bgp-af-mul] filter-policy 2000 export
filter-policy { acl-number | ip-prefix ip-prefix-name } import
undo filter-policy import
MBGP地址族视图
【缺省级别】
2:系统级
【描述】
filter-policy import命令用来配置对接收的路由信息进行过滤。undo filter-policy import命令用来取消对接收的路由信息进行过滤。
缺省情况下,不对接收的路由信息进行过滤。
# 使用ACL 2000对所有接收的MBGP路由进行过滤。
[Sysname] bgp 100
[Sysname-bgp-af-mul] filter-policy 2000 import
import-route protocol [ process-id [ med med-value | route-policy route-policy-name ] * ]
undo import-route protocol [ process-id ]
MBGP地址族视图
【缺省级别】
2:系统级
protocol:指定可引入的源路由协议,包括direct、isis、nat、ospf、rip和static。
process-id:路由协议进程号,取值范围为1~65535,缺省值为1。只有当protocol是isis、ospf或rip时该参数可选。
med-value:指定引入路由的MED度量值,取值范围为0~4294967295。如果没有指定度量值,将使用被引入路由的cost作为引入BGP域之后的MED值。
route-policy-name:从其他路由协议引入路由时,需使用该参数指定的路由策略过滤路由,为1~19个字符的字符串。
【描述】
import-route命令用来引入其它协议路由信息并通告。undo import-route命令用来取消已有的配置。
缺省情况下,MBGP不引入且不通告其它协议的路由。
通过import-route命令引入到MBGP路由表中的路由的origin属性为incomplete。
# 引入RIP的路由。
[Sysname] bgp 100
[Sysname-bgp-af-mul] import-route rip
undo ipv4-family multicast
BGP视图
【缺省级别】
2:系统级
无
【描述】
ipv4-family multicast命令用来进入BGP的IPv4组播地址族视图。undo ipv4-family multicast命令用来删除IPv4组播地址族视图下的所有配置,并退回到BGP视图。
# 创建并进入MBGP地址族视图。
[Sysname] bgp 100
network ip-address [ mask | mask-length ] [ short-cut | route-policy route-policy-name ]
undo network ip-address [ mask | mask-length ] [ short-cut ]
MBGP地址族视图
【缺省级别】
2:系统级
ip-address:目的IP地址。
mask:网络掩码,点分十进制格式。
short-cut:当EBGP路由的管理优先级比本地生成的路由的管理优先级高时,如果一条EBGP路由被配置成short-cut,那么这条路由在加入到路由表时将使用本地生成路由的路由管理值,而不是EBGP路由的路由管理值,此时,这条路由成为最佳路由的优先级被降低了很多。
route-policy-name:对发布的路由使用的路由策略,为1~19个字符的字符串。
【描述】
network命令用来将网段路由发布到MBGP路由表中。undo network命令用来取消已有的配置。
缺省情况下,MBGP不发布任何网段路由。
l 要发布的网段路由必须存在于本地的IP路由表中,使用路由策略可以更为灵活的控制所发布的路由。
l 使用network命令发布到MBGP路由表中的网段路由的ORIGIN属性为IGP。
# 发布到达10.0.0.0/16网段的路由。
[Sysname] bgp 100
[Sysname-bgp-af-mul] network 10.0.0.0 255.255.0.0
peer { group-name | ip-address } advertise-community
undo peer { group-name | ip-address } advertise-community
MBGP地址族视图
【缺省级别】
2:系统级
ip-address:MBGP对等体的IP地址。
【描述】
peer advertise-community命令用来配置向MBGP对等体/MBGP对等体组发布团体属性。undo peer advertise-community命令用来恢复缺省情况。
缺省情况下,不向MBGP对等体/MBGP对等体组发布团体属性。
相关配置可参考“IP路由分册/路由策略命令”中的命令ip community-list、if-match community和apply community。
# 向已创建的对等体组test发布团体属性。
[Sysname] bgp 100
[Sysname-bgp] group test external
[Sysname-bgp] peer test as-number 200
[Sysname-bgp-af-mul] peer test enable
[Sysname-bgp-af-mul] peer test advertise-community
peer { group-name | ip-address } advertise-ext-community
undo peer { group-name | ip-address } advertise-ext-community
MBGP地址族视图
【缺省级别】
2:系统级
【描述】
peer advertise-ext-community命令用来配置向MBGP对等体/MBGP对等体组发布扩展团体属性。undo peer advertise-ext-community命令用来恢复缺省情况。
缺省情况下,不向MBGP对等体/MBGP对等体组发布扩展团体属性。
相关配置可参考“IP路由分册/路由策略命令”中的命令ip extcommunity-list、if-match extcommunity和apply extcommunity。
# 向已经创建的对等体组test发布扩展团体属性。
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test advertise-ext-community
peer { group-name | ip-address } allow-as-loop [ number ]
undo peer { group-name | ip-address } allow-as-loop
MBGP地址族视图
【缺省级别】
2:系统级
number:表示本地AS号的的重复次数,取值范围为1~10,缺省值为1。
【描述】
peer allow-as-loop命令用来配置允许本地AS号在所接收的路由的AS_PATH属性中出现,并可同时配置允许重复的次数。undo peer allow-as-loop命令用来恢复缺省情况。
缺省情况下,不允许本地AS号重复。
相关配置可参考命令display bgp multicast routing-table peer。
# 配置允许本地AS号在从对等体1.1.1.1接收的路由的AS_PATH属性中出现,重复次数为2。
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 as-number 200
[Sysname-bgp]ipv4-family multicast
[Sysname-bgp-af-mul] peer 1.1.1.1 enable
[Sysname-bgp-af-mul] peer 1.1.1.1 allow-as-loop 2
peer { group-name | ip-address } as-path-acl as-path-acl-number { export | import }
undo peer { group-name | ip-address } as-path-acl as-path-acl-number { export | import }
MBGP地址族视图
【缺省级别】
2:系统级
group-name:对等体组的名称,为1~47个字符的字符串。
as-path-acl-number:AS路径过滤列表号,取值范围为1~256。
export:对向指定MBGP对等体/MBGP对等体组发布的路由应用过滤策略。
import:对从指定MBGP对等体/MBGP对等体组接收的路由应用过滤策略。
【描述】
peer as-path-acl命令用来为MBGP对等体/MBGP对等体组设置基于AS路径过滤列表的MBGP路由过滤策略。undo peer as-path-acl命令用来取消已有的配置。
缺省情况下,没有基于AS路径过滤列表的MBGP路由过滤策略。
相关配置可参考“IP路由分册/路由策略命令”中的命令ip as-path、if-match as-path和apply as-path。
# 配置向已创建的对等体组test发布的路由应用编号为1的AS路径过滤列表进行过滤。
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test as-path-acl 1 export
peer { group-name | ip-address } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ip-address } default-route-advertise
MBGP地址族视图
【缺省级别】
2:系统级
route-policy-name:指定路由策略名称,为1~19个字符的字符串。
【描述】
peer default-route-advertise命令用来配置向MBGP对等体/MBGP对等体组发送缺省路由。undo peer default-route-advertise命令用来恢复缺省情况。
缺省情况下,不向MBGP对等体/MBGP对等体组发送缺省路由。
该命令不需要在路由表中存在缺省路由,而是无条件地向对等体/对等体组发送一个下一跳为自身的缺省路由。
# 设置向已经创建的对等体组test发布缺省路由。
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test default-route-advertise
peer { group-name | ip-address } enable
undo peer { group-name | ip-address } enable
MBGP地址族视图
【缺省级别】
2:系统级
group-name:MBGP对等体组的名称,取值范围为1~47个字符。
【描述】
peer enable命令用来激活BGP视图下创建的指定对等体及对等体组。undo peer enable命令用来取消激活BGP视图下创建的指定对等体及对等体组。
如果取消激活指定的对等体,则本路由器与指定对等体之间不再交换路由信息。
# 激活对等体18.10.0.9。
[Sysname] bgp 100
[Sysname-bgp] peer 18.10.0.9 as-number 100
[Sysname-bgp-af-mul] peer 18.10.0.9 enable
peer { group-name | ip-address } filter-policy acl-number { export | import }
undo peer { group-name | ip-address } filter-policy [ acl-number ] { export | import }
MBGP地址族视图
【缺省级别】
2:系统级
acl-number:访问控制列表号,取值范围为2000~3999。
【描述】
peer filter-policy命令用来为MBGP对等体/MBGP对等体组设置基于ACL的过滤策略。undo peer filter-policy命令用来取消已有的设置。
缺省情况下,没有为MBGP对等体/MBGP对等体组设置基于ACL的过滤策略。
相关配置可参考命令peer as-path-acl。
# 配置向已经创建的对等体组test发布的路由应用ACL 2000表进行过滤。
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test filter-policy 2000 export
peer ip-address group group-name
undo peer ip-address group group-name
MBGP地址族视图
【缺省级别】
2:系统级
【描述】
peer group命令用来向MBGP对等体组中加入MBGP对等体。undo peer group命令将MBGP对等体从MBGP对等体组中移出。
缺省情况下,MBGP对等体不属于任何MBGP对等体组。
# 将IP地址为10.1.1.1的对等体加入到EBGP对等体组test。
[Sysname] bgp 100
[Sysname-bgp] peer 10.1.1.1 group test
[Sysname-bgp-af-mul] peer 10.1.1.1 group test
peer { group-name | ip-address } ip-prefix ip-prefix-name { export | import }
undo peer { group-name | ip-address } ip-prefix { export | import }
MBGP地址族视图
【缺省级别】
2:系统级
ip-prefix-name:指定的IP前缀列表名称,为1~19个字符的字符串。
export:对向指定对等体/对等体组发布的MBGP路由应用过滤策略。
import:对从指定对等体/对等体组接收的MBGP路由应用过滤策略。
【描述】
peer ip-prefix命令用来为MBGP对等体/MBGP对等体组设置基于IP前缀列表的路由过滤策略。undo peer ip-prefix命令用来取消已有的配置。
缺省情况下,无基于IP前缀列表的路由过滤策略。
# 配置向已经创建的对等体组test发布的MBGP路由应用地址前缀列表list1进行过滤。
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test ip-prefix list1 export
peer { group-name | ip-address } keep-all-routes
undo peer { group-name | ip-address } keep-all-routes
MBGP地址族视图
【缺省级别】
2:系统级
【描述】
peer keep-all-routes命令用来配置保存所有来自MBGP对等体/MBGP对等体组的原始路由信息,无论这些路由没有通过已配置的入口策略。undo peer keep-all-routes命令用来恢复缺省情况。
缺省情况下,不保存MBGP对等体/MBGP对等体组的原始路由信息。
# 配置保存所有来自对等体131.108.1.1的原始路由信息。
[Sysname] bgp 100
[Sysname-bgp] peer 131.108.1.1 as-number 100
[Sysname-bgp-af-mul] peer 131.108.1.1 enable
[Sysname-bgp-af-mul] peer 131.108.1.1 keep-all-routes
peer { group-name | ip-address } next-hop-local
undo peer { group-name | ip-address } next-hop-local
MBGP地址族视图
【缺省级别】
2:系统级
【描述】
peer next-hop-local命令用来配置向MBGP对等体/MBGP对等体组发布路由时,将自身地址作为下一跳。undo peer next-hop-local命令用来取消已有的设置。
缺省情况下,向EBGP对等体/对等体组发布路由时,将自身地址作为下一跳;向IBGP对等体/对等体组发布路由时,不将自身地址作为下一跳。
# 配置向已经创建的对等体组test发布MBGP路由时,将自身地址作为下一跳。
[Sysname] bgp 100
[Sysname-bgp] group test internal
[Sysname-bgp-af-mul] peer test next-hop-local
peer { group-name | ip-address } preferred-value value
undo peer { group-name | ip-address } preferred-value
MBGP地址族视图
【缺省级别】
2:系统级
value:要分配的路由首选值,取值范围0~65535。
【描述】
peer preferred-value命令用来为从MBGP对等体/MBGP对等体组接收的路由分配首选值。undo peer preferred-value命令用来恢复缺省情况。
缺省情况下,从MBGP对等体/MBGP对等体组接收的路由的首选值为0。
l 所有从邻居学来的路由都有一个初始首选值。在从不同邻居学来的相同目的地址/掩码的多条路由中,拥有最高首选值的路由将被选作到达指定网络的路由。
l 如果同时通过路由策略和peer preferred-value命令为从对等体/对等体组接收的路由设置首选值,通过路由策略过滤的路由信息的首选值将取路由策略中设置的首选值而不是peer preferred-value命令里设置的首选值;
l 只有当路由策略里设置的首选值为0时,路由信息的首选值才会取peer preferred-value命令里设置的值;
l 没有通过路由策略过滤的路由信息的首选值仍取peer preferred-value命令里设置的首选值。
通过路由策略配置BGP路由信息首选值的相关配置可参考命令peer route-policy和“IP路由分册/路由策略命令”中命令的apply preferred-value。
# 配置来自对等体131.108.1.1的路由的首选值为50。
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer 131.108.1.1 preferred-value 50
peer { group-name | ip-address } public-as-only
undo peer { group-name | ip-address } public-as-only
MBGP地址族视图
【缺省级别】
2:系统级
【描述】
peer public-as-only命令用来配置发送MBGP更新报文时不携带私有自治系统号。undo peer public-as-only命令用来恢复缺省情况。
缺省情况下,发送MBGP更新报文时,携带私有自治系统号。
如果发送的MBGP更新报文同时带有公有AS号和私有AS号,命令不生效。私有AS号的范围为64512~65535。
# 配置向已经创建的对等体组test发送MBGP更新报文时不携带私有自治系统号。
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test public-as-only
peer { group-name | peer-address } reflect-client
undo peer { group-name | peer-address } reflect-client
MBGP地址族视图
【缺省级别】
2:系统级
peer-address:MBGP对等体的IP地址。
【描述】
peer reflect-client命令用来配置将本机作为路由反射器,并将MBGP对等体/MBGP对等体组作为路由反射器的客户。undo peer reflect-client命令用来取消已有的配置。
缺省情况下,没有配置路由反射器及其客户。
相关配置可参考命令reflect between-clients和reflector cluster-id。
# 设置本地设备为路由反射器,将已经创建的IBGP对等体组test作为路由反射器的客户。
[Sysname] bgp 100
[Sysname-bgp] peer test as-number 100
[Sysname-bgp-af-mul] peer test reflect-client
peer { group-name | ip-address } route-limit limit [ percentage ]
undo peer { group-name | ip-address } route-limit
MBGP地址族视图
【缺省级别】
2:系统级
limit:指定允许从MBGP对等体/MBGP对等体组接收的最大地址前缀数,不同设备支持的取值范围不同,请以设备的实际情况为准。
percentage:指定路由器开始生成告警消息时的路由数量的百分比,取值范围1~100,缺省值为75。
【描述】
peer route-limit命令用来设置允许从MBGP对等体/MBGP对等体组收到的最大路由数。undo peer route-limit命令用来恢复缺省情况。
缺省情况下,允许从MBGP对等体/MBGP对等体组接收的最大路由数无限制。
# 设置允许从对等体131.108.1.1收到的最大路由数为10000。
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer 131.108.1.1 route-limit 10000
peer { group-name | ip-address } route-policy route-policy-name { export | import }
undo peer { group-name | ip-address } route-policy route-policy-name { export | import }
MBGP地址族视图
【缺省级别】
2:系统级
route-policy-name:指定路由策略,为1~19个字符的字符串。
export:对向MBGP对等体/MBGP对等体组发布的路由应用路由策略。
import:对从MBGP对等体/MBGP对等体组接收的路由应用路由策略。
【描述】
peer route-policy命令用来对来自MBGP对等体/MBGP对等体组的路由或发布给MBGP对等体/MBGP对等体组的路由指定路由策略。undo peer route-policy命令用来取消已有设置。
缺省情况下,不对来自MBGP对等体/MBGP对等体组的路由或发布给MBGP对等体/MBGP对等体组的路由指定路由策略。
peer route-policy命令不过滤路由策略中的if-match interface策略。相关命令可参考“IP路由分册”中的“路由策略命令”。
# 配置向已经创建的对等体组test发布的IPv4 BGP路由应用名为test-policy的路由策略。
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test route-policy test-policy export
undo preference
MBGP地址族视图
【缺省级别】
2:系统级
external-preference:EBGP路由(从EBGP对等体学来的路由)的管理优先级,取值范围为1~255。
internal-preference:IBGP路由(从IBGP对等体学来的路由)的管理优先级,取值范围为1~255。
local-preference:本地产生的BGP路由的管理优先级,取值范围为1~255。
route-policy-name:路由策略名称,为1~19个字符的字符串。应用路由策略,可以为匹配过滤条件的特定路由配置优先级。对于那些没有匹配的路由,使用缺省优先级。
【描述】
preference命令用来配置BGP路由的管理优先级。undo preference命令用来恢复缺省情况。
缺省情况下,EBGP路由的管理优先级为255,IBGP路由的管理优先级为255,本地产生的BGP路由的管理优先级为130。
# 设置EBGP路由、IBGP路由和本地产生的MBGP路由的管理优先级分别为20、20和200。
[Sysname] bgp 100
[Sysname-bgp-af-mul] preference 20 20 200
undo reflect between-clients
MBGP地址族视图
【缺省级别】
2:系统级
无
【描述】
reflect between-clients命令用来允许客户到客户的路由反射。undo reflect between-clients命令用来禁止客户到客户的路由反射。
缺省情况下,允许客户到客户的路由反射。
路由反射器的客户之间不要求是全连接的,路由缺省通过反射器从一个客户反射到其它客户;如果客户之间是全连接的,建议使用undo reflect between-clients命令禁止客户间的路由反射,以减少系统开销。
相关配置可参考命令reflector cluster-id和peer reflect-client。
# 关闭客户到客户的路由反射功能。
[Sysname] bgp 100
[Sysname-bgp-af-mul] undo reflect between-clients
undo reflector cluster-id
MBGP地址族视图
【缺省级别】
2:系统级
cluster-id:路由反射器的集群ID,取值范围为1~4294967295。
ip-address:以IP地址格式指定的路由反射器集群ID。
【描述】
reflector cluster-id命令用来配置路由反射器的集群ID。undo reflector cluster-id命令用来删除路由反射器的集群ID。
缺省情况下,每个路由反射器是使用自己的Router ID作为集群ID。
通常,一个集群里只有一个路由反射器。此时,由反射器的Router ID来识别该集群。设置多个路由反射器可提高网络的稳定性。如果一个集群中配有多个路由反射器,请使用reflector cluster-id命令为所有的路由反射器配置同样的集群ID,以避免路由环路的产生。
相关配置可参考命令reflect between-clients和peer reflect-client。
# 本地路由器是集群中的路由反射器之一,设置它的集群ID为80。
[Sysname] bgp 100
[Sysname-bgp-af-mul] reflector cluster-id 80
refresh bgp ipv4 multicast { all | ip-address | group group-name | external | internal } { export | import }
【缺省级别】
1:监控级
all:软复位所有BGP的连接。
external:EBGP连接。
internal:IBGP连接。
export:触发输出方向的软复位。
import:触发输入方向的软复位。
【描述】
refresh bgp ipv4 multicast命令用来手工对MBGP连接进行软复位。BGP软复位可以在不中断BGP连接的情况下重新刷新BGP路由表,并应用新的策略。
BGP软复位要求网络中的所有BGP路由器支持Route-refresh功能。如果有的路由器不支持此特性,则需要配置peer keep-all-routes命令,以便保留对等体的所有原始路由信息,供BGP软复位时使用。
# 对MBGP连接进行软复位。
<Sysname> refresh bgp ipv4 multicast all import
reset bgp ipv4 multicast { all | as-number | ip-address | group group-name | external | internal }
【缺省级别】
1:监控级
all:复位所有BGP的连接。
as-number:复位与指定自治系统号的BGP邻居的BGP连接。
ip-address:复位与指定BGP对等体的连接。
group group-name:复位与指定BGP对等体组的连接。
external:复位所有EBGP连接。
internal:复位所有IBGP连接。
【描述】
reset bgp ipv4 multicast命令用来复位指定的BGP连接。
# 复位所有MBGP连接。
<Sysname> reset bgp ipv4 multicast all
reset bgp ipv4 multicast dampening [ ip-address [ mask | mask-length ] ]
【缺省级别】
1:监控级
ip-address:目的IP地址。
mask:网络掩码,点分十进制格式,缺省值为255.255.255.255。
mask-length:网络掩码长度,取值范围为0~32,缺省值为32。
【描述】
reset bgp ipv4 multicast dampening命令用来清除路由振荡衰减信息以及解除对已抑制路由的抑制。
相关配置可参考命令dampening和display bgp multicast routing-table dampened。
# 清除到网络20.1.0.0/16的路由衰减信息,且对受抑制的路由解除其抑制。
<Sysname> reset bgp ipv4 multicast dampening 20.1.0.0 255.255.0.0
reset bgp ipv4 multicast flap-info [ regexp as-path-regular-expression | as-path-acl as-path-acl-number | ip-address [ mask | mask-length ] ]
【缺省级别】
1:监控级
as-path-regular-expression:清除匹配AS路径正则表达式的振荡统计信息,as-path-regular-expression表示正则表达式,为1~80个字符的字符串,包括空格,区分大小写。
as-path-acl-number:清除匹配AS路径过滤列表的振荡统计信息。列表号的取值范围为1~256。
ip-address:清除指定路由的振荡统计信息。
【描述】
reset bgp ipv4 multicast flap-info命令用来清除MBGP地址族下的震荡统计信息。
如果没有指定参数和关键字,系统将清除所有路由振荡统计信息。
# 清除所有匹配AS路径过滤列表10的MBGP路由的振荡统计信息。
<Sysname> reset bgp ipv4 multicast flap-info as-path-acl 10
summary automatic
undo summary automatic
MBGP地址族视图
【缺省级别】
2:系统级
无
【描述】
summary automatic命令用来配置对引入的子网路由进行自动聚合。undo summary automatic命令用来恢复缺省情况。
缺省情况下,不对引入的子网路由进行自动聚合。
l 自动聚合除缺省路由外,用network命令引入的路由也不能进行自动聚合。
l 配置summary automatic后,MBGP抑制从IGP引入的子网路由,从而减少路由选择信息的数量。
# 对子网路由进行自动聚合。
[Sysname] bgp 100
[Sysname-bgp-af-mul] summary automatic
