| Title | Size | Downloads |
| H3C_SECPATHF1000_AI_75-CMW710-R9900P40_Release_Notes_(Software_Feature_Changes)_0502A6Y6_.pdf | 590.16 KB | |
| H3C_SECPATHF1000_AI_75-CMW710-R9900P40_Release_Notes_0502A6Y6_.pdf | 1.02 MB | |
| SECPATHF1000_AI_75-CMW710-R9900P40_IPE.zip | 148.11 MB | |
| SECPATHF1000_AI_75-CMW710-R9900P40_BIN.zip | 148.11 MB |
H3C SECPATHF1000_AI_75-CMW710-R9900P40 |
Release Notes |
Software feature and command updates........................................................... 6
Open problems and workarounds.................................................................... 13
Appendix D Using BootWare menus............................................................... 26
List of tables
Table 1 Version history............................................................................................................................................................. 1
Table 2 Hardware and software compatibility matrix.................................................................................................... 3
Table 3 ISSU version compatibility matrix.......................................................................................................................... 5
Table 5 MIB updates................................................................................................................................................................. 6
Table 6 Hardware specifications............................................................................................................................................ 1
Table 7 Firewall software features........................................................................................................................................ 1
Table 8 Default login information...................................................................................................................................... 16
Table 11 BootWare menus.................................................................................................................................................... 26
Table 12 BootWare shortcut keys....................................................................................................................................... 26
Table 14 BASIC ASSISTANT menu options...................................................................................................................... 30
Table 16 Serial submenu options....................................................................................................................................... 34
Table 19 File Control submenu options........................................................................................................................... 36
Table 20 BootWare Operation submenu options......................................................................................................... 48
Table 21 DEVICE CONTROL menu options...................................................................................................................... 49
Table 22 EXTEND ASSISTANT submenu options........................................................................................................... 49
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version R9900P40. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction with H3C SECPATHF1000_AI_75-CMW710-R9900P40 Release Notes (Software Feature Changes) and the documents listed in "Related documentation."
Version information
Version number
H3C Comware software, Version 7.1.064, Release 9900P40
Note: You can see the version number with the display version command in any view. Please see Note①.
Version history
Version number | Last version | Release date | Release type | Remarks |
R9900P40 | R9900P38 | 2026-07-28 | Release version | Annual version, production release, technical support |
R9900P38 | R9900P37 | 2026-05-28 | Release version | Fixed bugs and released for the use of Technical Support. |
R9900P37 | R9900P35 | 2026-04-26 | Release version | Fixed bugs and released for the use of Technical Support. |
R9900P35 | R9900P2706 | 2026-01-28 | Release version | Fixed bugs and released for the use of Technical Support. |
R9900P2706 | R9900P2704 | 2025-11-29 | Release version | Fixed bugs and released for the use of Technical Support. |
R9900P2704 | R9900P2701 | 2025-09-26 | Release version | Fixed bugs and released for the use of Technical Support. |
R9900P2701 | F9900P24 | 2025-06-28 | Release version | Fixed bugs and released for the use of Technical Support. |
F9900P24 | R9900P22 | 2025-02-28 | Feature version | This version has solved problems and is restricted to the use of Technical Support. |
R9900P22 | R8890P20 | 2024-12-31 | Release version | Fixed bugs and released for production use and the use of Technical Support. |
R8890P23 | R8890P20 | 2024-10-29 | Release version | Fixed bugs and released for the use of Technical Support. |
R8890P20 | R8860P46 | 2024-07-21 | Release version | Fixed bugs and released for the use of Technical Support. |
R8860P46 | R8860P43 | 2024-05-21 | Release version | Fixed bugs and released for the use of Technical Support. |
R8860P43 | R8860P41 | 2024-02-26 | Release version | Fixed bugs and released for the use of Technical Support. |
R8860P41 | R8860P40 | 2023-11-17 | Release version | Fixed bugs and released for the use of Technical Support. |
R8860P40 | R8860P27 | 2023-10-30 | Release version | Fixed bugs and released for the use of Technical Support. |
R8860P27 | R8860P24 | 2022-08-29 | Release version | Fixed bugs and released for the use of Technical Support. |
R8860P24 | R8860P22 | 2022-05-30 | Release version | Fixed bugs and released for the use of Technical Support. |
R8860P22 | R8860P18 | 2022-03-31 | Release version | Fixed bugs and released for the use of Technical Support. |
R8860P18 | F8860P17 | 2021-11-26 | Release version | Fixed bugs and released for production use and the use of Technical Support. |
F8860P17 | R8860P1212 | 2021-10-30 | Feature version | Fixed bugs and released for the use of Technical Support. |
R8860P1212 | R8860P1211 | 2021-08-28 | Release version | Fixed bugs and released for production use and the use of Technical Support. |
R8860P1211 | R8860P1210 | 2021-07-28 | Release version | Fixed bugs and released for production use and the use of Technical Support. |
R8860P1210 | R8860P12 | 2021-06-25 | Release version | Fixed bugs and released for production use and the use of Technical Support. |
R8860P12 | R8860P11 | 2021-05-28 | Release version | Fixed bugs and released for production use and the use of Technical Support. |
R8860P11 | E8860P09 | 2021-04-30 | Release version | TR6. Released for the use of Technical Support and production. |
E8860P09 | E8860P08 | 2021-03-05 | ESS version | TR5. Released for the use of Technical Support and production. |
E8860P08 | A8860P0302 | 2021-02-09 | ESS version | TR4A trial release. Released for the use of Technical Support and production. |
A8860P0302 | A8860P01 | 2020-09-17 | Alpha version | This version has solved problems and is a trial release for production. |
A8860P01 | First release | 2020-07-16 | Alpha version | This version is released for TR4A and production. |
CAUTION: To avoid an upgrade failure, use Table 2 to verify the hardware and software compatibility before performing an upgrade. |
Item | Specifications |
Hardware platform | F1000-AI-65/F1000-AI-75 |
Memory | 8 GB |
EMMC flash (stores the IPE file) | 4 GB |
BootWare version | 1.08(Note: Execute the display version command in any view to view the version information. Please see Note②) |
Host software (MD5 value) | SECPATHF1000_AI_75-CMW710-R9900P40.ipe d4cd00ca2f79158dd94c7428490b1bab f1078fw-cmw710-boot-R9900P40.bin: c90b2dee4cd44942a45c8fb60bdc6a81 f1078fw-cmw710-system-R9900P40.bin: 93b1e769de0461138c6c85c1f2b5d639
iMC version | iMC-ACLM 7.3 (E0705P12) iMC-DM 7.3 (E0705P12) iMC-EIA(TAM) 7.3 (E0611P13) iMC-EIA(UAM) 7.3 (E0611P13) iMC-iCC 7.3 (E0705P12) iMC IVM 7.3 (E0506) iMC PLAT 7.3 (E0705P12) iMC SSM(SSM) 7.3 (E0506H01) iMC-VLAN 7.3 (E0705P12) iNode PC (E0646) 1. The time on the iMC server must be consistent with the time on the device. 2. As a best practice, do not use the wildcard subnet address type when you configure address groups on the device management page of security services on iMC. 3. Enable action parameters before you configure them on the device management page of security services on iMC. The EIA component is not supported. |
H3C SecCenter CSAP-S version | E1143P05 |
SMP version | E1111P05 |
H3C SecCloud OMP version | E1301P01 |
AD-NET | E0713 |
U-Center | E0709 |
U-Center AOM | Not support |
AD-Campus | Not support |
AD-DC | Not support |
AD-WAN | Not support |
Cloudnet | OASIS V100R001 |
Sample: To display the host software and BootWare version of F1000-AI-75, perform the following:
<H3C> display version
H3C Comware Software, Version 7.1.064, Release 9900P40
Copyright (c) 2004-2026 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath F1000 uptime is 0 weeks, 0 days, 0 hours, 11 minutes
Last reboot reason: UserReboot
Boot image: flash:/F1078FW-CMW710-BOOT-R9900P40.bin
Boot image version: 7.1.064, Release 9900P40
Compiled Apr 09 2026 15:00:00
System image: flash:/F1078FW-CMW710-SYSTEM-R9900P40.bin
System image version: 7.1.064, Release 9900P40
SLOT 1
CPU type: Multi-core CPU
DDR4 SDRAM Memory: 8192M bytes
FLASH: 3728M bytes
CPLD_A Version: 3.0
CPLD_B Version: 2.0
Release Version:H3C SecPath F1000-9900P40
Basic BootWare Version:1.08
Extend BootWare Version:1.08
BuckleBoard Version:Ver.A
BaseBoard Version:Ver.B
BackBoard Version:Ver.A
HDD BackBoard Version:Ver.A
[SUBCARD 0] NSQ1F1G2MSPUOTXA(Hardware)Ver.A, (Driver)1.0, (Cpld)3.0
[SUBCARD 1] NSQM1F1KGMC(Hardware)Ver.C, (Driver)1.0, (Cpld)3.0
Boot Type: Warm
ISSU upgrade type matrix
ISSU provides two upgrade types: compatible upgrade and incompatible upgrade. Table 3 provides the approved ISSU upgrade types only between the current version and the history versions within the past 18 months. This matrix does not include history versions that are 18 months earlier than the current version, for which, no ISSU upgrade verification is performed.
For more information about ISSU, see the fundamentals configuration guide for the device.
Current version | History version | ISSU upgrade method |
SECPATHF1000_AI_75-CMW710-R9900P40 | SECPATHF1000_AI_75-CMW710-R9900P38 |
SECPATHF1000_AI_75-CMW710-R9900P37 | Compatible | |
SECPATHF1000_AI_75-CMW710-R9900P35 | Compatible | |
SECPATHF1000_AI_75-CMW710-R9900P2706 | Compatible | |
SECPATHF1000_AI_75-CMW710-R9900P2704 | Compatible | |
SECPATHF1000_AI_75-CMW710-R9900P2701 | Incompatible | |
SECPATHF1000_AI_75-CMW710-F9900P24 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R9900P22 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8890P23 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8890P20 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P46 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P43 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P41 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P40 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P27 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P24 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P22 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P18 | Incompatible | |
SECPATHF1000_AI_75-CMW710-F8860P17 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P1212 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P1211 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P1210 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P12 | Incompatible | |
SECPATHF1000_AI_75-CMW710-R8860P11 | Incompatible | |
SECPATHF1000_AI_75-CMW710-E8860P09 | Incompatible | |
SECPATHF1000_AI_75-CMW710-E8860P08 | Incompatible | |
SECPATHF1000_AI_75-CMW710-E8860P0302 | Incompatible | |
SECPATHF1000_AI_75-CMW710-E8860P01 | Incompatible |
Upgrade restrictions and guidelines
· To ensure hardware compatibility, do not downgrade the factory software version.
· The BootWare image is included in the IPE image package. When the device starts up, it compares the current BootWare image with that in the IPE image package. If the current BootWare version is earlier than that in the IPE image package, the system automatically upgrades the BootWare to the version in the IPE image package.
· When you manually upgrade the AV/URL signature library, follow these restrictions and guidelines: For the signature libraries for anti-virus and URL filtering, the official website provides two sizes for different device storage spaces. The letter H in the name indicates a large signature library. For example, V7-AV-H-1.0.68.dat is a large signature library and V7-AV-1.0.68.dat is a small one. When you perform a manual upgrade, examine your device storage capacity to determine which signature library should be downloaded. The large signature libraries are supported when the memory is larger than 8 GB, and the capacity of the storage medium (flash memory, SD card, or CF card) is larger than 1 GB. Otherwise, only the small signature libraries are supported.
· After an ISSU, clear the browser cache for the Web interface to correctly display the configuration information of modified features.
· You can check the Upgrade Way field in the output from the display version comp-matrix command for recommended ISSU methods.
Table 4 ISSU compatibility list
Version description | Version identifier | Version number | ISSU compatibility |
Baseline version | V0 | R8860P23 | POK |
Last software version | Vn-1 | R8890P23 | POK |
Last Release version | Vk | / | / |
Hardware feature updates
This release has the following changes:
· New Feature - Added Auxiliary Control Channel Keepalive Message Control Parameter Items
· New Feature - Enable DPI Gradual Bypass Function When Single-Core CPU Utilization Is High
For information about the software feature and command update history, see H3C SECPATHF1000_AI_75-CMW710-R9900P40 Release Notes (Software Feature Changes).
MIB updates
Item | MIB file | Module | Description |
R9900P40 | |||
New | None | None | None |
Modified | None | None | None |
R9900P38 | |||
R9900P37 | |||
R9900P35 | |||
R9900P2706 | |||
R9900P2704 | |||
R9900P2701 | |||
F9900P24 | |||
R9900P22 | |||
R8890P23 | |||
New | New | New | New |
Modified | Modified | Modified | Modified |
R8890P20 | |||
R8860P46 | |||
R8860P43 | |||
R8860P41 | |||
R8860P40 | |||
R8860P27 | |||
R8860P24 | |||
R8860P22 | |||
R8860P18 | |||
F8860P17 | |||
R8860P1212 | |||
R8860P1211 | |||
R8860P1210 | |||
R8860P11 | |||
E8860P09 | |||
E8860P08 | |||
A8860P0302 | |||
A8860P01 | |||
Operation changes
R9900P2701 Operation changes
· For versions prior to R9900P2701, SM2 key pairs were established on the encryption card. Starting with R9900P2701 and later versions, the encryption card by default only registers SM1, while SM2 is registered in software. Therefore, upgrading from an older version to R9900P2701 or later may cause SM2-encrypted services to fail. If the SM2 encryption algorithm (EA) is used, this change must be noted during version upgrade.
R9900P37 Operation changes
When upgrading the device from R9660PXX to R9900PXX, the following features will change:
Feature Modification - Password Recovery Function
About this feature
The default status of the password recovery function is now enabled.
Password recovery function command
Modified - password-recovery enable
password-recovery enable This command enables the password recovery function.
undo password-recovery enable This command disables the password recovery function.
Change description
The default status of the password recovery function changed from disabled to enabled.
After configuring the password recovery function, if you forget the console authentication password or fail login authentication and cannot operate the device via the command line, you can clear the authentication password through the BootWare menu and continue using the device. If you disable the password recovery function, the device will be in a more secure state. In such cases, to continue using the console for command line operations, you must select restoring the device to factory configuration through the BootWare menu before proceeding. This effectively prevents unauthorized users from obtaining the startup configuration file.
The options supported in the BootWare menu for configuration are related to the password recovery function. For details, see the device's Release Notes.
# Disable the password recovery function.
[Sysname] undo password-recovery enable
Feature Modification - Subscriber Line View
About this feature
Trim AUX view in subscriber line view.
Subscriber line view command
Modified - line class
Use line class to enter user line class view.
Old syntax
line class { aux | console | vty }
New syntax
line class { console | vty }
context-admin
Change description
Remove aux parameter.
Feature Modification - ACL Rule Acceleration
About this feature
ACL rules automatically accelerate after creation.
Traffic log collection command
Modified - accelerate
accelerate This command enables accelerated matching for ACL rules.
undo accelerate This command restores the default settings.
accelerate
undo accelerate
Accelerated matching for ACL rules is disabled by default.
IPv4 basic/advanced ACL view
IPv6 basic/advanced ACL view
Layer 2 ACL view
context-admin
Change description
ACL rules automatically accelerate after creation. Manual execution of acceleration will not display the configuration accelerate.
Feature Modification - Traffic Log Collection
About this feature
Changes in traffic log collection commands.
Traffic log configuration
Before modification:
# Enable DPI traffic service log collection function.
[Sysname] dac log-collect service dpi traffic enable
[Sysname] dac storage service dpi traffic limit usage 40
[Sysname] dac storage service traffic limit usage 40
After modification:
[Sysname] dac log-collect service traffic-monitor traffic-statistics enable
[Sysname] dac log-collect service traffic-monitor traffic-log enable
[Sysname] dac storage service traffic-monitor traffic-statistics limit usage 40
[Sysname] dac storage service traffic-monitor traffic-log limit usage 40
Instructions:
1. When enabling traffic logs in the D060SP version, session statistics must also be enabled simultaneously.
2. After upgrading to the D100SP version:
· A new command, `traffic-log session-end global enable`, will be added.
· Traffic logs can be controlled independently and do not require enabling session statistics. Enabling session statistics consumes significant processor and memory resources. If it is unnecessary, it is recommended to disable it.
Restrictions and cautions
Before performing an upgrade, see H3C SECPATHF1000_AI_75-CMW710-R9900P40 Release Notes (Software Feature Changes) and related documentation to see the software feature changes and evaluate the influence on the service.
· Use the following browsers:
¡ Chrome 31 or higher.
¡ Firefox v19 or higher.
¡ Safari 5 or higher.
¡ Internet Explorer 9 or higher.
· The Web interface and CLI cannot be used together. Do not configure a feature through both the Web interface and CLI.
· Only devices of the same model can form an IRF fabric.
· As from R8860P12, the device supports global NAT. However, VPN and DNS mapping are to be supported yet. Global NAT is supported only in a new site and cannot replace or coexist with interface-based NAT.
· Because global NAT determines the destination security zone according to the FIB table, a destination security zone cannot be used by global NAT to match traffic that has been permitted by PBR or LLB. If a destination security zone is not used by a global NAT rule, packets to the destination security zone cannot match the global NAT rule, or services will be interrupted if application changes or configuration changes occur.
· As from R8860P1212, the device supports configuring remote backup management (RBM), but it is configurable only in the default context. As from R8860P18, the device supports configuring RBM in non-default contexts.
· SSL VPN Web access to WeChat, Alipay, and hao123 webpages might fail because of missing URL rewriting for some of the contents to be accessed.
· As from R9660P22, the IP address of an email server on the report subscription page can be an IP address or a host name.
· The standby device in RBM cannot process SSL VPN dialup traffic.
· The MAC addresses of a main interface and its subinterfaces must be the same.
· When domain name-based address object groups are used:
¡ If the local DNS server for the terminal is the device, the device acts as the DNS proxy, and you do not need to enable DNS snooping.
¡ If the local DNS server for the terminal is a DNS server on the external network, the device transmits packets for the terminal transparently. To avoid service interruption, you must enable DNS snooping after upgrading to R8860P24.
· Use fixed ports of the device as long as possible. Use expansion interface modules only when fixed ports are not sufficient. Expansion slot 2 is a low-speed slot and provides 1 Gbps bandwidth. Expansion slot 1 is a high-speed slot and provides 10 Gbps bandwidth.
· RBM networking, when upgrading to D100SP36 and later new versions, previously synchronized certificates and key pair files cannot be deleted synchronously.
· In an RBM master-backup networking setup, when upgrading from an older version to a new version D100SP36 or later, if the existing PKI domain is removed on the RBM master, this action cannot be synchronized to the RBM backup (because there is no synchronization marker during the upgrade from the old version, so the deletion action will not be synchronized). Additionally, the PKI domain cannot be directly deleted on the RBM backup. Users need to manually delete the certificates under the PKI domain and then perform batch backup before the PKI domain can be deleted.
· In an RBM networking scenario, after upgrading from a version that does not support certificate/key pair synchronization to a version that synchronizes based on synchronization tags, the following phenomenon occurs: The original certificates of the active/standby devices were separate sets and used independently. After the version upgrade, the PKI domain and certificate/key pair files of both the active and standby devices exist simultaneously on each device.
· In an RBM networking scenario, when upgrading from a version that does not support configuration synchronization (or where the configurations of the primary and backup devices were originally different) to a version that supports configuration synchronization, the configuration of the backup device will be overwritten by the primary device's synchronization. At this point, it is necessary to manually check and compare the backup device's configuration and make corrections as needed.
· In an RBM active/standby networking setup, when upgrading from an older version to D100SP36 or later versions, if the cryptographic key pair on the standby device does not match the certificate, SSL services referencing this PKI domain will fail.
· In an RBM active/standby networking setup, under abnormal scenarios, if the cryptographic key pair on the standby device does not match the certificate, SSL services referencing this PKI domain will fail.
· In an RBM active/standby networking setup, after downgrading from D100SP36 or later versions to D100SP06, if the cryptographic key pair is lost, re-importing the certificate and generating a new key pair, followed by restarting the lbd process or rebooting the overall system, can achieve recovery.
· In an RBM active/standby networking setup, when downgrading from D100SP36 or later versions to a version below D100SP36, the hostkey of the management standby device will be overwritten, and the public-key will be changed, resulting in SSH login prompts indicating a key change.
· In a dual-system hot backup (RBM) networking environment, before performing a version upgrade on member devices, the administrator should ensure that the automatic backup function for configuration information is enabled. This can be done by executing the command `configuration auto-sync enable` in the RBM management view.
License management
About licenses
To use license-based features, you must purchase licenses from H3C and install the licenses.
For more information about license-based features and supported licenses, see H3C SecPath F1000 & F5000 Firewall Series License Matrixes.
License registration and installation
H3C License Management Platform provides product licensing services for H3C customers. You can access this system to obtain an activation file or transfer licenses.
H3C License Management Platform is accessible at http://www.h3c.com/en/License/.
For more information about license registration, activation file installation, and license transfer, see H3C Security Products Licensing Configuration Demonstration Video (Comware 7), H3C Security Products Licensing Configuration Demonstration (Comware 7), H3C Security Products Licensing Configuration Examples (Comware 7), and H3C Security Products Licensing Guide (Comware 7).
H3C provides license-related FAQ. For more information, see H3C Security Products Licensing FAQ (Comware 7).
None
List of resolved problems
Resolved problems in R9900P40
202605091222
· Symptom: When exporting security policies from the English WEB interface in CSV format, all content is displayed in Chinese.
· Condition: Exporting security policies from the English WEB interface.
202606111481
· Symptom: Abnormal certificate display when accessing an internal server via SSL proxy.
· Condition: The firewall acts as an SSL proxy, and the client hello message sent to the server does not include the client's SNI extension.
Resolved problems in R9900P38
202602250663
· Symptom: Newly created DDNS policies cannot be deployed, with the prompt "Interface binding list is in edit state".
· Condition: In Network-DNS-DDNS Policy, clicking to create an associated interface, then canceling without configuring the interface.
202604300030
· Symptom: Configuring `service slot` on an aggregate interface does not take effect, or even has the opposite effect.
· Condition: Private network traffic forwarded through an SDWAN over L2TP tunnel interface traverses a cross-board aggregate interface.
Resolved problems in R9900P37
202603300827
· Symptom: IKEv2 SA cannot be deleted.
· Condition: In RBM networking, after the primary device switches to standby, if the IKEv2 SA is in a "del" state and the hard timeout timer does not exist.
202603250053
· Symptom: Causes negotiation packet failure. Executing the command `display ike sa count` shows residual negotiation counts.
· Condition: The device receives a negotiation packet, but no related IPsec configuration exists locally.
202604021859
· Symptom: Problem 1 causes traffic interruption; Problem 2: After the changeover completes, the error recovery timer triggers DPD probing, but the RBM standby role cannot send packets, leading to incorrect deletion of IPsec/IKE SA on the standby device and inconsistent data between primary and standby.
· Condition: Problem 1: Restart IKED once; Problem 2: In RBM networking with DPD function enabled, after the RBM standby device backs up entries, switch the IPsec process once on the RBM standby device.
202603160107
· Symptom: Occasionally, two Phase 1 SAs and two IPsec tunnels appear.
· Condition: In RBM primary-standby networking, bidirectional UDP traffic triggers IKEv2 negotiation to establish an IPsec tunnel, and the RBM channel disconnects and reconnects.
202601160822
· Symptom: Web page cannot be opened.
· Condition: After configuring LB outbound link load balancing and enabling web cache http/https.
Resolved problems in R9900P35
202510301412
· Symptom:Abnormal processor utilization displayed, reaching 40%.
· Condition: The device processes 20K new traffic sessions.
202512090657
· Symptom:Standby device configuration lost.
· Condition: Manual synchronization of BGP module configuration.
202512100715
· Symptom:System prompts "Failed to enable HTTPS server because of port conflict", affecting HTTPS service.
· Condition: The default configuration command `autodeploy url enable` occupies port 443. After the device references an SSL server policy, enabling the HTTPS service fails.
202511140676
· Symptom:Advanced query page is sluggish.
· Condition: Performing advanced queries on the security policy page.
202511050051
· Symptom:Device does not print serial port prompt information.
· Condition: After a BIST test fails on a device equipped with FPGA.
202511070922
· Symptom:Device frequently sends ARP probes.
· Condition: In RBM networking, learned ARP entries are synchronized to the peer. When there is an ARP conflict in the environment.
202601070554
· Symptom:SPU forwarding failure.
· Condition: Device configured for IPoE.
202601081923
· Symptom:Web page configuration save is slow.
· Condition: Saving configuration via the device's web page.
Resolved problems in R9900P2706
202510240342
· Symptom: Missing threat logs.
· Condition: After adding a dynamic denylist to IPS and triggering the rule.
202510140329
· Symptom: Abnormal increase in device memory.
· Condition: Enabling full signature database auto-upgrade.
Condition: With SMB breakpoint resume, file filtering, and sandbox function enabled,
Resolved problems in R9900P2704
202508071963
· Symptom: Device reboot.
· Condition: Complex SQLite3 queries (including GROUP BY/DISTINCT/ORDER BY/JOIN/CTE, etc.) may generate temporary files (dependent on data volume; these files address excessive memory demands for large temporary datasets by overflowing data to disk). The default SQLite3 temporary directory is `/var/tmp` (e.g., `/var/tmp/etilqs_efbc3772f20a95fd`), which remains cached and cannot be released.
202508010488
· Symptom: Fixed `context-id` range bug causes reduced vFirewall instances after version upgrade.
· Condition: Occurs when upgrading devices to versions below R9900P2704. Driver teams must verify all branches/models for potential `context-id` range issues. Thank you.
202507250807
· Symptom: Device memory alarm.
· Condition: On devices running Kylin kernel, if a service process has an empty capability set and executes scripts or executable files via `exec`, it triggers a one-time credential leak.
202506190557
· Symptom: Isolation action not triggered.
· Condition: Configured single-core high-attack prevention isolation fails when device hardware buffer is exhausted and processor utilization exceeds 95%.
202507170036
· Symptom: One power supply (W) displays as 0.
· Condition: Occurs when two power supplies are connected to the device.
Condition: Global DNAT malfunction prevents proper conversion.
Resolved problems in R9900P2701
202504250312
· Symptom: Interface abnormality.
· Condition: After removing the Combo port on F1000-AK1125/1205.
202406071244
· Symptom:The device currently does not support this configuration.
· Condition:Configuring the ipmac module on the device to support IP-MAC binding in cross-Layer 3 scenarios.
202501070131
· Symptom: Causes insufficient device memory; NTOP requires optimization of memory usage.
· Condition: High NTOP resource consumption on the device.
202503251511
· Symptom: The directly connected route for the interface's IP address subnet was not delivered.
· Condition: After configuring an IP address and a VRRP address from a different subnet on the interface, modifying the interface address to the VRRP address, and then deleting the VRRP backup group.
202506100720
· Symptom:Unable to reach the active kernel, causing pending kernels and deletion chains to continuously accumulate, leading to persistent growth in dpid memory usage.
· Condition:Repeatedly upgrading or rolling back the signature database while the device has insufficient memory and the active process fails.
Resolved problems in F9990P24
202411270026
· Symptom If switchover to primary and backup, the connection works normally, ping test is normal, and other services are also normal.
· Condition: RBM + OSPF active-active networking, Oracle service cannot connect when in active-active mode.Packet capture shows that some packets are not sent out. After enabling inspect bypass, the service works normally.
Resolved problems in R9900P22
None.
Resolved problems in R8890P23
None.
Resolved problems in R8890P20
202401221409
· Symptom: The next hop address is a required field, and if the next hop address is not clear, the configuration cannot be successful. It needs to be changed to an optional item.
· Condition: Static routes on the WEB interface are set to the dialer interface.
Resolved problems in R8860P46
None.
Resolved problems in R8860P43
202311162067
· Symptom: The device reboots when it receives GTP packets with ICMP packets embedded.
· Condition: This symptom occurs if the device receives GTP packets with ICMP packets embedded. ICMP packets do not go through the session establishment process. Instead, the current ICMP nested memory packet is used to match the session. When the session goes through the deletion and release process, there is no return value to release the empty cache.
Resolved problems in R8860P41
None.
Resolved problems in R8860P40
None.
Resolved problems in R8860P27
202208081324
· Symptom: A NAT server mapping received from the controller loses the VRRP configuration.
· Condition: This symptom occurs if the same NAT server mapping already exists on the device.
202208050455
· Symptom: NAT server mappings are deployed slowly.
· Condition: This symptom occurs if 30000 NAT server mappings are configured.
202208050453
· Symptom: Static NAT mappings are deployed slowly.
· Condition: This symptom occurs if 30000 static NAT mappings are configured.
202208050452
· Symptom: NAT server mappings are deployed slowly through NETCONF.
· Condition: This symptom occurs if a large number of NAT server mappings are configured and deployed through NETCONF.
202207190036
· Symptom: On the Dashboard page, an error message is displayed indicating that the used storage space reaches the limit.
· Condition: This symptom occurs if the device is not installed with a hard disk and the size of ntop logs stored in the memory has reached the limit.
202203160861
· Symptom: On a non-default context, a subinterface created based on a shared interface uses the all-zero MAC address. Packets cannot be forwarded on that subinterface.
· Condition: This symptom occurs if the shared interface is a physical interface or an aggregate interface.
Resolved problems in R8860P24
202203310385
· Symptom: On the Web interface, the editing of an IPv6 security policy cannot succeed, and the Please wait dialog box exists all the time.
· Condition: This symptom occurs after you edit an IPv6 security policy and click OK on the Edit Security Policy page.
202204200077
· Symptom: In active mode, the FTP data channel fails to forward packets.
· Condition: This symptom occurs if a one-to-one mapping for outbound static NAT is configured with the reversible keyword and an ACL specified.
202204191526
· Symptom: FTP access fails.
· Condition: This symptom occurs if you configure three rules in a security policy as follows:
a. Configure an FTP filtering criterion in the first rule.
b. Configure any application as a filtering criterion in the second rule.
c. Configure the drop action in the third rule.
202205050998
· Symptom: On an IRF fabric, the dns snooping enable command does not take effect after the IRF fabric is rebooted.
· Condition: This symptom occurs if you perform the following operations on an IRF fabric:
a. Execute the dns snooping enable command.
b. Save the configuration and reboot the IRF fabric.
202204150051
· Symptom: A service interface on a subordinate device cannot be pinged successfully after it changes to Layer 3 mode.
a. Use a VLAN interface for MAD.
b. Configure the service interface on the subordinate device to operate in Layer 2 mode.
c. Assign the service interface to the same VLAN as the VLAN interface used for MAD.
d. Configure the service interface on the subordinate device to operate in Layer 3 mode.
Resolved problems in R8860P22
202202250905
· Symptom: Only four users come online.
· Condition: This symptom occurs if the following operations are performed:
a. Enable and disable MAC authentication repeatedly.
b. Configure a RADIUS scheme with the maximum amount of configuration.
c. Send traffic with unknown source MAC addresses of 4000 users.
202112161429
· Symptom: Failed to send emails.
· Condition: This symptom occurs if the mail server address is configured as a domain name.
202202210546
· Symptom: The memory usage is high for the ntopd process.
a. Insert a hard disk.
b. Send many flows with different source and destination IP addresses.
c. Enable traffic logging and session statistics collection.
202203091501
· Symptom: The serial port of the device gets stuck. The device cannot be pinged. Traffic interruption occurs.
· Condition: This symptom occurs if the kernel version of the device is 4.4 and IRF is configured on the device.
202201280915
· Symptom: The CLI PlugIn license Register Cmd Failed error message is displayed during an ISSU on an IRF active/standby fabric.
a. Perform an ISSU from D060SP18 to D060SP20.
b. Execute the issu run switchover command on the master device after the subordinate device is upgraded.
202112220320
· Symptom: The RBM connection fails to be established.
· Condition: This symptom occurs if you configure the dual-active mode for RBM and use an IPv6 address for the control channel.
202203181737
· Symptom: The OpenSSL BN_mod_sqrt DoS vulnerability (CVE-2022-0778) exists on the device.
· Condition: This symptom occurs when a system vulnerability scan is performed on the device.
202107281498
· Symptom: A security policy containing an object group cannot work correctly after an IRF fabric is rebooted.
· Condition: This symptom occurs if the object group contains domain names.
202112310557
· Symptom: Core files are generated because the SSH process experiences exceptions.
202201040413
· Symptom: Nessus found the FTP Privileged Port Bounce Scan high-risk vulnerability.
· Condition: This symptom might occur if you use Nessus to scan the system for vulnerabilities when multiple protocols are enabled.
202110291292
· Symptom: The device reboots when it processes an abnormal IPv4 packet.
· Condition: This symptom might occur when the device processes abnormal IPv4 packets.
202111110695
· Symptom: The SSL VPN service with the 0x81d0049 memory tag leaks memory during SSL VPN login.
· Condition: This symptom occurs if you obtain verification codes repeatedly but do not log in.
202201181541
· Symptom: IPsec traffic refreshes session interface information. Subsequent negotiation packets are dropped by ASPF.
a. Set up a NAT traversal IPsec tunnel.
b. Configure an interzone policy to permit the IPsec tunnel output interface in zone Untrust to zone local. Do not configure an interzone policy to permit traffic from any to zone Local on the headquarters.
c. Use the addresses in the private networks connected by the tunnel to ping each other.
202201190694
· Symptom: NTP clock synchronization fails. The reason is that Comware determines that a string that has more than 3 bytes and contains characters and digits is valid, but the OS determines that only the characters are valid and ignores the digits. To resolve the issue, restrictions on glibc time zone specifications are added to Comware. Comware determines that a string that has more than 3 bytes and contains characters and digits is invalid.
· Condition: This symptom occurs when NTP clock synchronization is configured on the device.
202201261656
· Symptom: The IP address corresponding to the host name-based IPv4 address object is not deleted when the host name-to-IPv4 address mapping for DNS is aged out.
· Condition: This symptom occurs when the host name-to-IPv4 address mapping for DNS is aged out.
Resolved problems in R8860P18
202105060373
· Symptom: In an IRF fabric, memory leaks occur on the subordinate device after the input interface of the forward flow is changed.
· Condition: This symptom occurs if you have enabled last hop holding and last hop backup.
202108020312
· Symptom: In an IRF fabric, a domain-name-based security policy does not take effect after the subordinate device is rebooted.
· Condition: This symptom occurs if a large number of address object groups containing domain names exist.
Resolved problems in F8860P17
202107220778
· Symptom: Memory leaks occur.
· Condition: This symptom occurs if you enable auto refresh and real-time traffic data collection for the Real-time user ranking and Real-time application ranking widgets from the Web interface.
202107151060
· Symptom: Memory leaks occur for ntopd.
· Condition: This symptom occurs if log aggregation is enabled from the Web interface and the device receives traffic.
202109020467
· Symptom: The device reboots after you execute the session persistent acl 3000 aging-time 0 command and its undo form repeatedly.
· Condition: This symptom occurs if you execute the session persistent acl 3000 aging-time 0 command and its undo form repeatedly.
202109220429
· Symptom: A security policy cannot be moved after another security policy.
· Condition: None.
202110080402
· Symptom: Traffic rate statistics about IPsec tunnels are not supported.
· Condition: None.
202109280720
· Symptom: The memory is not released for the dpid process.
· Condition: This symptom occurs if the dpid process uses the memory management library glibc instead of tcmalloc.
202108280160
· Symptom: The device reboots.
· Condition: This symptom occurs when the packet accessing the SSL VPN gateway carries the svnp_rewrite_code field.
Resolved problems in R8860P1212
202107090909
· Symptom: The web https-authorization username command is lost after the binary configuration file recovers, and the Web interface cannot accessed.
· Condition: This symptom occurs if a certificate is used to log in to the Web interface.
202107220895
202107151103
Resolved problems in R8860P1211
202101070348
· Symptom: During reboot, the device still provides power for its connected PFC device. As a result, traffic forwarding fails.
· Condition: This symptom occurs if the device cooperates with the PFC device.
202106160240
· Symptom: In a Layer 2 dual-active IRF fabric, the device reboots during transparent transmission.
· Condition: This symptom occurs if the session synchronization enable asymmetric command is executed.
Resolved problems in R8860P1210
None.
None.
Resolved problems in R8860P11
None.
Resolved problems in E8860P09
None.
Resolved problems in E8860P08
Resolved problems in A8860P0302
None.
Resolved problems in A8860P01
None.
· H3C SecPath F1000-AI-X5 Firewall Series Installation Quick Start
· H3C SecPath F1000-AI-X5 Firewall Series Installation Guide
· H3C SecPath F1000-AI-X0 Firewall Series Installation Guide
· H3C SecPath Firewall Series Configuration Guides(V7)
· H3C SecPath Firewall Series Command References(V7)
· H3C Security Products Comware 7 System Log Messages Reference-6W600
· H3C Firewall Products Comware 7 Web Configuration Guide
· H3C SecPath PSR150-A1 & PSR150-D1 Power Modules User Manual
Technical support
Dimensions (W × D × H) excluding rubber feet and mounting brackets | 440 × 435 × 44.2 mm (17.32 × 17.13 × 1.74 in) |
Weight (net) | 5.6 Kg |
Ports | · 1 × console port · 1 × management Ethernet port · 16 × GE copper ports · 4 × combo ports · 6 × 10GE fiber ports · 4 × GE fiber ports · 2 × USB 2.0 ports |
Expansion slots | 2 |
Hard disk slots | 2 |
Memory | 8 GB |
Flash | 4 GB EMMC flash |
Power consumption | 150 W |
Operating temperature | · Operating: ¡ Without hard disks: 0°C to 45°C (32°F to 113°F) ¡ With hard disks: 5°C to 40°C (41°F to 104°F) · Storage: –40°C to 70°C (–40°F to 158°F) |
Relative humidity (noncondensing) | · Operating: ¡ Without hard disks: 5% RH to 95% RH ¡ With hard disks: 10% RH to 90% RH · Storage: 5% RH to 95% RH |
Category | Features | |
AAA | RADIUS/HWTACACS+ authentication. CHAP authentication. PAP authentication. Domain authentication. | |
Firewall | Packet filtering. Security zone-based access control. Time-based access control. ASPF. Virtual firewall. Attack defense. Detecting and preventing Land, Smurf, Fraggle, WinNuke, Ping of Death, Tear Drop, IP Spoofing, IP fragment, fragment, TCP flag, large ICMP packet, address scanning, port scanning, SYN flood, ICMP flood attacks. Control of ICMP redirection and destination unreachable messages. Tracert message control. Control of IP packets with the RR option. Static and dynamic blacklists | |
Security management | Real-time attack protection logs. Blacklist logs. Session logs. Binary logs. Traffic statistic collection and analysis. Security event statistics. | |
NAT | NAT support for address pools. NAT control using ACLs. Easy IP. NAT server. Effective period of NAT. NAT ALGs, including FTP, DNS, QQ, MSN, H323, NBT, ILS, RTSP, SQLNET, SIP, RSH, and MGCP. NAT444. | |
Content filtering and audit | Recipient and sender filtering Attachment name and content checking Email subject and content checking FTP upload and download file filtering APR signature library. PBAR. NBAR. Application group. | |
Bandwidth management | Maximum uplink bandwidth Maximum downlink bandwidth Guaranteed uplink bandwidth Guaranteed downlink bandwidth Traffic policy (source security zone, destination security zone, source address, destination address, application or application group, time range, and user) Child traffic profile. Interface bandwidth limit. Reports and logs. | |
IPS | IPS policy. IPS working mode. IPS signature. IPS signature action. Reports and logs. | |
IPSec/IKE | AH and ESP. Manual SA setup and IKE SA setup. ESP support for DES, 3DES, and AES encryption algorithms. Support for MD5 and SHA-1 authentication algorithms. Support for IKE main mode and aggressive mode. DPD. NAT traversal. | |
L2TP | L2TP. | |
GRE | GRE tunnel. | |
SSL VPN | IP access. TCP access. Smart terminal access. User authentication. | |
LAN | Ethernet_II. VLAN. | |
IP services | ARP. Static domain name resolution. IP address borrowing. DHCP relay. DHCP server. DHCP client. | |
IP routing | Static route management. RIP-1/RIP-2. OSPF. BGP. Routing policy. PBR. | |
Basic IPv6 protocols. | Protocol processing. Ethernet link layer. ICMPv6. IPv6 address management. PMTU. Socket. TCP6. UDP6. RAWIP6. Ping6. DNS6. Tracert6. Telnet6. FIB6. DHCPv6 client. DHCPv6 relay. | |
IPv6 routing and multicast | RIPng. OSPFv3. BGP4+. Static routes. PBR. PIM-SM. PIM-DM. | |
IPv6 security | NAT-PT. Manual tunnel. IPv6 over IPv4 GRE tunnel (RFC 2784). 6to4 tunnel (RFC 3056). ISATAP tunnel. IPv6 packet filtering. RADIUS. DS-Lite | |
VRRP | VRRP. | |
IRF | IRF fabric. | |
Hot backup | Session hot backup. Configuration synchronization. | |
CLI | Local configuration through a console port. Local or remote configuration through Telnet or SSH. Control of user access to commands. Debugging. Network diagnostic tools, including tracert and ping. Telnetting from the device to other devices. FTP server/client, and file and application upload and download. TFTP file transmission. Logging. File system management. User line configuration. | |
Web management interface | Web administrator timeout (logout). Web login authentication and authorization. Web-based device management, device monitoring, and firewall policy configuration. | |
Network management | Support for SNMPv3 and compatibility with SNMPv2C and SNMPv1. NTP time synchronization. | |
Appendix B List of severe vulnerabilities
Severe vulnerabilities in R9900P40 and earlier versions
CVE-2017-3735
An attacker can exploit this vulnerability to bypass security protections and execute unauthorized operations.
CVE-2019-3855
An integer overflow flaw which could lead to an out of bounds write was discovered in libssh2 in the way packets are read from the server. libssh2 is a client-side C library implementing the SSH2 protocol. A remote attacker who compromises an SSH server may be able to execute code on the client system when a user connects to the server.
HSVD-201904-001
TCP/IP SYN + FIN packet filtering vulnerability: A remote host does not discard TCP SYN packets with the FIN flag set. An attacker might bypass the firewall, depending on the type of firewall used.
HSVD-201902-001
A remote host can exploit the TCP timestamp vulnerability to obtain the online time.
HSVD-201901-016
CVE-2019-0548: A Linux kernel vulnerability that can cause information revealing.
JavaScript library vulnerability
Internal IP addresses in destination URLs might be revealed.
CVE-2020-10188
utility.c in telnetd in netkit telnet through 0.17 allows remote attackers to execute arbitrary code via short writes or urgent data, because of a buffer overflow involving the netclear and nextitem functions.
Web JavaScript vulnerability
A medium-risk vulnerability found during Web vulnerability scanning.
Web CSRF vulnerability
An CSRF vulnerability was found on the SSL VPN Web login interface.
HTTP method vulnerability
An attacker can use the OPTIONS method to determine the HTTP methods allowed by each directory.
CRLF injection vulnerability
This vulnerability can be exploited when an HTTP request contains a user-configured domain in the cookies or the request is GET /enterdomain.cgi?domain=%0d%0aSomeCustomInjectedHeader:%0d%0aset-cookie:iamyy HTTP1/1.
CVE-2019-1547
An attacker can exploit this vulnerability to obtain sensitive information.
CVE-2019-1563
An attacker, after sending a very large number of messages to be decrypted, can recover a CMS/PKCS7 transported encryption key or decrypt any RSA encrypted message that was encrypted with the public RSA key.
CVE-2016-7056
A timing attack flaw was found in OpenSSL 1.0.1u and before that could allow a malicious user with local access to recover ECDSA P-256 private keys.
CVE-2018-0739
Constructed ASN.1 types with a recursive definition (such as can be found in PKCS7) could eventually exceed the stack given malicious input with excessive recursion. This could result in a Denial Of Service attack.
CVE-2019-1559
An attacker can exploit this vulnerability to bypass access controls and obtain sensitive information.
CVE-2018-0737
An attacker with sufficient access to mount cache timing attacks during the RSA key generation process could recover the private key.
CVE-2018-0732
An attacker can exploit this vulnerability to launch a DoS attack.
CVE-2019-1552
This vulnerability is related to OpenSSL. An attacker can exploit this vulnerability to bypass security controls.
CVE-2019-1563
CVE-2018-5407
This vulnerability is related to OpenSSL. An attacker can exploit this vulnerability to obtain sensitive information and launch more attacks.
X-Frame-Options vulnerability
A missing X-Frame-Options header can cause a clickjacking attack.
CVE-2011-1473
SSL in the kernel does not process the field for disabling SSL renegotiation. As a result, an SSL client can renegotiate successfully.
CVE-2021-23841/CVE-2021-23840/CVE-2020-1971
This vulnerability is related to OpenSSL. The X.509 GeneralName type is a generic type for representing different types of names. One of those name types is known as EDIPartyName. OpenSSL provides a function GENERAL_NAME_cmp that compares different instances of a GENERAL_NAME to see if they are equal or not. This function behaves incorrectly and NULL pointer dereference might occur when both GENERAL_NAMEs contain an EDIPARTYNAME.
CAUTION: Do not power off or reboot the device during the upgrade process. |
The software upgrade procedure is the same for all security devices. This chapter describes how to upgrade software from the CLI, Web interface, and BootWare menus. The default storage medium varies by device model. This chapter uses the CF card as the default storage medium.
The following software types are available:
· BootWare image—A .btw file that contains a basic segment and an extended segment. The basic segment is the minimum code that bootstraps the system. The extended segment enables hardware initialization and provides system management menus. You can use these menus to load software and the startup configuration file or manage files when the device cannot start up correctly.
· System software image—Includes the following image subcategories:
¡ Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
¡ System image—A .bin file that contains the Comware kernel and standard features, including device management, interface management, configuration management, and routing.
¡ Patch image—A .bin file that is released for fixing bugs without rebooting the device. A patch image does not add or remove features.
You can assign the following attributes to a system software image:
¡ Main—The image is the primary image. The system always attempts to load the main image at startup in preference to the backup image.
¡ Backup—The image is the backup image. It is used only if the primary image is corrupt or not available.
Software images are released in one of the following forms:
· Separate .bin files. You must verify compatibility between software images.
· As a whole in one .ipe package file. The images in an .ipe package file are compatible. The system decompresses the file automatically, loads the .bin images and sets them as startup software images.
You can save settings you made to a configuration file so they can survive a reboot.
The device supports .cfg configuration files. The default .cfg configuration file is named startup.cfg.
To upgrade system software, use one of the following methods:
· Upgrading system software from the CLI
· Upgrading system software from the Web interface
· Upgrading system software from BootWare menus
To upgrade the BootWare, use either of the following methods:
· Upgrading the BootWare from the CLI
· Upgrading BootWare from BootWare menus
You must reboot the device after a system software or BootWare upgrade. A device reboot interrupts services.
Before a software upgrade, read the release notes to identify the command changes. Some commands in the configuration file might not be supported after a software upgrade.
The device can function as the TFTP client, FTP client, or FTP server. In the following examples that use TFTP or FTP, the device functions as the TFTP or FTP client.
To use a PC as the TFTP or FTP server, prepare the TFTP or FTP server software by yourself. The device is not shipped with the software.
Before you upgrade system software, complete the following tasks:
· Set up the upgrade environment as shown in Figure 1. The IP address and subnet mask of the PC are 192.168.0.2 and 255.255.255.0, respectively.
· Run a TFTP or FTP server on the file server. (Skip this task if you upgrade software from the Web interface.)
· Assign an IP address to the file server. Make sure the management Ethernet port on the device and the file server can reach each other.
By default, the IP address of the management Ethernet port GigabitEthernet 1/0/0 is 192.168.0.1/24 and the management Ethernet port belongs to the Management security zone. The Management security zone and the Local security zone can communicate with each other.
You can also change the IP address of the management Ethernet port from its default and add it to a security zone other than Management. Then, you configure a zone pair to make sure the security zone and the Local security zone can communicate with each other. For more information about security zones and zone pairs, see the security zone configuration in the fundamentals configuration guide.
· Transfer the software upgrade file to the file server and set the working directory on the TFTP or FTP server.
· Log in to the CLI of the device through the console port. (Skip this task if you upgrade software from the Web interface.)
· Make sure the upgrade has minimal impact on the network services. During the upgrade, the device cannot provide any services.
Figure 1 Setting up the upgrade environment
This configuration example upgrades system software from R8513 to R8514. The system software image file name is main.ipe.
You can use TFTP or FTP on the device to access the TFTP or FTP server to back up or download software files.
Using TFTP to upgrade system software
1. Back up the running system software image and configuration file:
a. Display current software images and startup software images.
<Sysname> display boot-loader
Software images on slot 1:
Current software images:
cfa0:/main-cmw710-boot-R8513.bin
cfa0:/main-cmw710-system-R8513.bin
Main startup software images:
Backup startup software images:
None
b. Back up the current software images.
<Sysname> copy main-cmw710-boot-R8513.bin boot_backup.bin
<Sysname> copy main-cmw710-system-R8513.bin system_backup.bin
c. Specify boot_backup.bin and system_backup.bin as the backup startup image files.
<Sysname> boot-loader file boot cfa0:/boot_backup.bin system cfa0:/system_backup.bin backup
d. Execute the save command in any view to save the running configuration.
<Sysname> save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
e. Execute the dir command in user view to identify the system software image and configuration file names and verify that the CF card has sufficient space for the new system software image.
<Sysname> dir
Directory of cfa0:
0 -rw- 4269 Jul 12 2018 13:34:36 + attachmentname + .ak
1 -rw- 5723136 Oct 24 2018 13:03:16 boot_backup.bin
2 drw- - Sep 26 2018 15:21:36 diagfile
3 drw- - Sep 14 2018 08:04:50 dpi
4 -rw- 5723136 Oct 23 2018 16:52:51 main-cmw710-boot-R8513.bin
5 -rw- 137090048 Oct 23 2018 16:58:19 main-cmw710-system-R8513.bin
6 -rw- 735 Sep 13 2018 19:16:22 hostkey
7 -rw- 730 Oct 23 2018 16:58:50 ifindex.dat
8 drw- - Jul 12 2018 13:34:36 license
9 drw- - Sep 13 2018 18:29:20 logfile
10 drw- - Sep 13 2018 19:16:24 pki
11 drw- - Sep 13 2018 18:33:24 seclog
12 -rw- 591 Sep 13 2018 19:16:24 serverkey
13 -rw- 5109 Oct 23 2018 16:58:50 startup.cfg
14 -rw- 134782 Oct 23 2018 16:58:51 startup.mdb
15 -rw- 137090048 Oct 24 2018 13:11:57 system_backup.bin
16 drw- - Oct 23 2018 17:04:21 versionInfo
4088468 KB total (3972960 KB free)
f. Execute the tftp put command in user view to upload the startup.cfg file to the TFTP server.
<Sysname> tftp 192.168.0.2 put startup.cfg
Press CTRL+C to abort.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 3950 0 0 100 3950 0 204k --:--:-- --:--:-- --:--:-- 642k
2. Upgrade the system software:
a. Execute the tftp get command in user view to download the system software image file to the CF card on the device.
<Sysname> tftp 192.168.0.2 get main.ipe
100 102M 100 102M 0 0 461k 0 0:03:48 0:03:48 --:--:-- 554k
Writing file...Done.
<Sysname>
b. Execute the boot-loader file command in user view to load the main.ipe file and specify it as the main image file at the next reboot.
<Sysname> boot-loader file cfa0:/main.ipe all main
Verifying the file cfa0:/main.ipe on slot 1.........Done.
H3C SecPath T5020 images in IPE:
main-cmw710-boot-R8514.bin
main-cmw710-system-R8514.bin
This command will set the main startup software images. Please do not reboot any MPU during the upgrade. Continue? [Y/N]:y
Add images to slot 1.
File cfa0:/main-cmw710-boot-R8514.bin already exists on slot 1.
File cfa0:/main-cmw710-system-R8514.bin already exists on slot 1.
Overwrite the existing files? [Y/N]:y
Decompressing file main-cmw710-boot-R8514.bin to cfa0:/main-cmw710-boot-R8514.bin..........Done.
Decompressing file main-cmw710-system-R8514.bin to cfa0:/main-cmw710-system-R8514.bin............................................................................................................................................................................Done.
Verifying the file cfa0:/main-cmw710-boot-R8514.bin on slot 1...Done.
Verifying the file cfa0:/main-cmw710-system-R8514.bin on slot 1.........Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
Decompression completed.
Do you want to delete cfa0:/main.ipe now? [Y/N]:N
<Sysname>
c. Execute the display boot-loader command in user view to verify that the file has been loaded.
<Sysname>
d. Execute the reboot command in user view to reboot the device.
<Sysname> reboot
Start to check configuration with next startup configuration file, please wait.
........DONE!
System is starting...
e. After the reboot is complete, execute the display version command to verify that the system software image is correct.
<Sysname> display version
H3C Comware Software, Version 7.1.064, Release 8514
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath T5020 uptime is 0 weeks, 2 days, 5 hours, 53 minutes
Last reboot reason: User reboot
Boot image: cfa0:/main-cmw710-boot-R8514.bin
Boot image version: 7.1.064, Release 8514
Compiled Sep 18 2018 15:00:00
System image: cfa0:/main-cmw710-system-R8514.bin
System image version: 7.1.064, Release 8514
SLOT 1
Uptime is 0 weeks, 2 days, 5 hours, 53 minutes
DDR3 SDRAM Memory 32766M bytes
CF0 Card 4002M bytes
Board PCB Version:Ver.A
CPLD_A Version: 1.0
CPLD_B Version: 2.0
Release Version:SecPath T5020-8514
Basic BootWare Version: 2.04
Extend BootWare Version: 2.04
<Sysname>
Using FTP to upgrade system software
None
<Sysname>
<Sysname> save
<Sysname>
<Sysname> dir
Directory of cfa0:
<Sysname>
f. Execute the ftp command in user view to access the FTP server.
<Sysname> ftp 192.168.0.2
Connected to 192.168.0.2 (192.168.0.2).
220 3Com 3CDaemon FTP Server Version 2.0
User (192.168.0.2:(none)): user123
331 User name ok, need password
Password:
230 User logged in
Remote system type is UNIX.
Using binary mode to transfer files.
ftp>
g. Execute the put command in FTP client view to upload the startup.cfg file to the FTP server.
ftp> put startup.cfg
227 Entering passive mode (192,168,0,2,26,3).
125 Using existing data connection.
226 Closing data connection; File transfer successful.
3950 bytes sent in 0.001 seconds (4.13 Mbytes/s)
ftp>
a. Execute the get command in FTP client view to download the system software image file to the CF card on the device.
ftp> get main.ipe
227 Entering passive mode (192,168,0,2,8,252)
107934720 bytes received in 187.994 seconds (560.68 Kbytes/s)
ftp>
b. Execute the quit command in FTP client view to return to user view.
ftp> quit
221 Service closing control connection
<Sysname>
c. Execute the boot-loader file command in user view to load the main.ipe file and specify it as the main image file at the next reboot.
<Sysname>
d. Execute the display boot-loader command in user view to verify that the file has been loaded.
Software images on slot 2:
<Sysname>
e. Execute the reboot command in user view to reboot the device.
<Sysname> reboot
........DONE!
f. After the reboot is complete, execute the display version command to verify that the system software image is correct.
SLOT 1
CPLD_A Version: 1.0
CPLD_B Version: 2.0
<Sysname>
CAUTION: · You can use the default account settings or create a new account to log in to the Web interface for the first time. This section uses the default account settings. For security purposes, if you use the default account settings, modify the default password or create a new account and delete the default account after the first login. · Do not perform any operation on the Web interface while the system is upgrading software. |
Table 8 describes the default settings for you to log in to the Web interface.
Table 8 Default login information
Login information | Default setting |
Username | admin |
Password | admin |
IP address of GigabitEthernet 1/0/0 | 192.168.0.1/24 |
| NOTE: The default management Ethernet port varies by device model. In this example, the default management Ethernet port is GigabitEthernet 1/0/0. |
To upgrade the system software from the Web interface:
1. Use an Ethernet cable to connect the PC to an Ethernet port on the device. As a best practice, connect the PC to the management Ethernet port on the device.
2. Assign an IP address on the same subnet as the management port GigabitEthernet 1/0/0 to the PC.
In this example, assign 192.168.0.2 to the PC.
3. Launch the Web browser, and enter 192.168.0.1 in the address bar.
The Web login page appears.
4. Type the default username and password, and click Login.
5. Select System > Upgrade Center > Software Upgrade from the navigation tree.
6. Click Upgrade immediately on the Software Upgrade page.
7. Select the startup file to be used, and click OK.
Figure 2 Upgrade Immediately page
To upgrade Comware images from BootWare menus, use one of the following methods:
· Using TFTP to upgrade system software through the management Ethernet port
· Using FTP to upgrade system software through the management Ethernet port
Preparing for the upgrade
1. Connect the configuration terminal to the MPU's console port.
2. Connect the MPU's management Ethernet port to the TFTP or FTP file server.
The TFTP or FTP server can be co-located with the configuration terminal (typically, a PC).
3. Prepare the upgrade file:
¡ If you are using TFTP, store the upgrade file on the TFTP server, and specify the directory.
¡ If you are using FTP, store the upgrade file on the FTP server, and specify the directory, FTP username, and password.
4. Run the terminal emulation program on the configuration terminal.
5. Power on the device, and then press Ctrl+B within 5 seconds at prompt to access the EXTEND-BOOTWARE menu (see "Using the EXTENDED-BOOTWARE menu").
1. Enter 3 in the EXTEND-BOOTWARE menu to access the Ethernet submenu.
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is sda0 |
|<1> Download Image Program To SDRAM And Run |
|<2> Update Main Image File |
|<3> Update Backup Image File |
|<4> Download Files(*.*) |
|<5> Modify Ethernet Parameter |
|<0> Exit To Main Menu |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-5):
2. Enter 5 in the Ethernet submenu to configure the network settings.
| NOTE: To use the existing setting for a field, press Enter without modifying the setting. |
======================<ETHERNET PARAMETER SET>==============================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP):tftp
Load File Name :main.ipe
Target File Name :main.ipe
Server IP Address :192.168.0.2
Local IP Address :192.168.0.1
Subnet Mask :255.255.255.0
Gateway IP Address :0.0.0.0
Table 9 Network parameter fields and shortcut keys
Field | Description |
'.' = Clear field | Press a dot (.) and then press Enter to clear the setting for a field. |
'-' = Go to previous field | Press a hyphen (-) and then press Enter to return to the previous field. |
Ctrl+D = Quit | Press Ctrl+D to exit the ETHERNET PARAMETER SET menu. |
Protocol (FTP or TFTP) | Set the file transfer protocol to TFTP. |
Load File Name | Set the name of the file to be downloaded. |
Target File Name | Set a file name for saving the file on the device. The target file name must have the same extension as the source file. By default, the target file name is the same as the source file name. |
Server IP Address | Set the IP address of the TFTP server. |
Local IP Address | Set the IP address of the Ethernet interface that connects to the TFTP server. |
Subnet Mask | Set the IP address mask. |
Gateway IP Address | Set a gateway IP address if the device is on a different network than the server. |
After you finish setting the TFTP parameters, the system returns to the Ethernet submenu.
3. Enter 2 or 3 in the Ethernet submenu to upgrade the main or backup software images. For example, enter 2 to upgrade the main software images.
Loading.....................................................................
.........................Done!
94786560 bytes downloaded!
Image file main-cmw710-boot-A9615.bin is self-decompressing...
Saving file sda0:/main-cmw710-boot-A9615.bin ......Done.
Image file main-cmw710-system-A9615.bin is self-decompressing...
Saving file sda0:/main-cmw710-system-A9615.bin .......................
..................Done. .
4. Enter 0 in the Ethernet submenu to return to the EXTEND-BOOTWARE menu.
5. Enter 1 in the EXTEND-BOOTWARE menu to run the new Comware images.
| Ctrl+D = Quit. |
Protocol (FTP or TFTP):ftp
FTP User Name :admin
FTP User Password :******
Table 10 Network parameter fields and shortcut keys
Protocol (FTP or TFTP) | Set the file transfer protocol to FTP. |
Server IP Address | Set the IP address of the FTP or TFTP server. |
Local IP Address | Set the IP address of the Ethernet interface that connects to the TFTP or FTP server. |
FTP User Name | Set the username for accessing the FTP server. This username must be the same as the username configured on the FTP server. |
FTP User Password | Set the password for accessing the FTP server. This password must be the same as the password configured on the FTP server. |
After you finish setting the FTP parameters, the system returns to the Ethernet submenu.
5. Enter 1 in the EXTEND-BOOTWARE menu to run the new system software.
You can upgrade the BootWare from the CLI or BootWare menus.
Whether a .btw file is compressed together with an .ipe file depends on the device model and software release. Please check it with H3C technical support. This section describes only how to upgrade the BootWare from the CLI.
To upgrade the BootWare from the CLI:
1. Use FTP or TFTP to download or upload the new BootWare image file to the root directory of the storage medium on the device.
2. Execute the bootrom update command to upgrade the BootWare.
<System> bootrom update file cfa0:/main.btw slot 2
This command will update bootrom file, Continue? [Y/N]:y
Now updating bootrom, please wait...
Updating basic bootrom!
Update basic bootrom success!
Updating extended bootrom!
Update extended bootrom success!
Update bootrom success!
<System>
3. Execute the reboot command to reboot the device.
To upgrade the BootWare image from BootWare menus, use one of the following methods:
· Using TFTP to upgrade BootWare through the management Ethernet port
· Using FTP to upgrade BootWare through the management Ethernet port
For more information about BootWare menus, see "Using BootWare menus."
| NOTE: This section uses the MPU as an example to describe how to upgrade BootWare. |
1. Connect the MPU's console port to the configuration terminal.
¡ If you are using TFTP, store the upgrade file on the TFTP server, and specify the file directory.
¡ If you are using FTP, store the upgrade file on the FTP server, and specify the file directory, FTP username, and password.
1. Enter 7 in the BootWare menu to access the BootWare Operation submenu.
=========================<BootWare Operation Menu>==========================
|<1> Backup Full BootWare |
|<2> Restore Full BootWare |
|<3> Update BootWare By Serial |
|<4> Update BootWare By Ethernet |
Enter your choice(0-4):
2. Enter 4 in the BootWare Operation submenu to enter the Ethernet submenu.
===================<BOOTWARE OPERATION ETHERNET SUB-MENU>===================
|<1> Update Full BootWare |
|<2> Update Extended BootWare |
|<3> Update Basic BootWare |
|<4> Modify Ethernet Parameter |
3. Enter 4 in the Ethernet submenu to configure the network settings.
==========================<ETHERNET PARAMETER SET>==========================
| Ctrl+D = Quit. |
Load File Name :Main.btw
Target File Name :Main.btw
For more information about the fields, see Table 9.
After you finish setting the TFTP parameters, the system returns to the BOOTWARE OPERATION ETHERNET submenu.
4. Choose an option from options 1 to 3. For example, enter 1 to upgrade the entire BootWare image.
Loading..............Done.
64245 bytes downloaded!
Updating Basic BootWare? [Y/N]
5. Enter Y to upgrade the basic BootWare segment.
Updating Basic BootWare........Done.
Updating Extended BootWare? [Y/N]
6. Enter Y to upgrade the extended BootWare segment.
Updating Extended BootWare.........Done!
7. Enter 0 to return to the BootWare Operation menu.
8. Enter 0 in the BootWare Operation menu to return to the EXTEND-BOOTWARE menu.
9. Enter 0 in the EXTEND-BOOTWARE menu to reboot the system.
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :ftp
For more information about the fields, see Table 10.
After you finish setting the FTP parameters, the system returns to the BOOTWARE OPERATION ETHERNET submenu.
Loading.......Done.
Updating Extended BootWare.........Done.
Handling software upgrade failures
If a software upgrade fails, the system runs the old software version. To handle a software failure:
1. Check the physical ports for a loose or incorrect connection, and verify that the LEDs are reflecting the correct port status.
2. If you are using the console port for file transfer, check the HyperTerminal settings (including the baud rate and data bits) for any wrong setting.
3. Check the file transfer settings:
¡ If TFTP is used, you must enter the same server IP addresses, file name, and working directory as set on the TFTP server.
¡ If FTP is used, you must enter the same FTP server IP address, source file name, working directory, and FTP username and password as set on the FTP server.
4. Check the FTP or TFTP server for incorrect settings.
5. Check that the CF card has sufficient space for the upgrade file.
6. If the message "Something is wrong with the file" appears, check the file for file corruption.
Appendix D Using BootWare menus
BootWare provides a menu method to perform basic file operations, software upgrade, and system management when the Comware CLI is inaccessible because of image corruption.
BootWare is stored in each MPU's built-in the SD card. It has one basic segment and one extended segment. The basic segment enables the system to complete basic initialization, and the extended segment bootstraps the Comware images.
Table 11 lists the menus that each segment provides and the major tasks you can perform using these menus. You can access these menus only during system startup.
BootWare segment | Menu | Tasks | Reference |
Basic | BASIC-BOOTWARE | · Modify serial port parameters. · Upgrade BootWare. · Start the primary or backup BootWare extended segment. | Using the BASIC-BOOTWARE menu |
Basic | BASIC ASSISTANT | Perform RAM test. | Accessing the BASIC-BOOTWARE menu |
Extended | EXTEND-BOOTWARE | · Upgrade Comware software. · Manage files. · Access the system when the console login password is lost. · Clear user privilege passwords. | Using the EXTENDED-BOOTWARE menu |
Extended | EXTEND-ASSISTANT | · Examine system memory. · Search system memory. | Accessing the EXTEND ASSISTANT submenu |
BootWare provides the shortcut keys listed in Table 12.
Table 12 BootWare shortcut keys
Shortcut keys | Prompt message | Function |
Ctrl+B | access EXTENDED-BOOTWARE MENU | Accesses the EXTENDED-BOOTWARE menu while the device is starting up. |
Ctrl+C | Please Start To Transfer File, Press <Ctrl+C> To Exit. | Stops the ongoing file transfer and exits the current operation interface. |
Info: Press Ctrl+C to abort or return to EXTENDED ASSISTANT MENU. | Returns to the EXTENDED ASSISTANT menu. If the system is outputting the result of an operation, this shortcut key combination aborts the display first. | |
Ctrl+D | Press Ctrl+D to access BASIC-BOOTWARE MENU | Accesses the BASIC-BOOTWARE menu while the device is starting up. |
Ctrl+D = Quit | Exits the parameter settings menu. | |
Ctrl+E | Memory Test(press Ctrl+C to skip it,press Ctrl+E to ECHO INFO) | Prints information during the memory test. |
Ctrl+F | Ctrl+F: Format File System | Formats the current storage medium. |
Ctrl+T | Press Ctrl+T to start memory test | Performs a memory test. |
Ctrl+U | Access BASIC ASSISTANT MENU | Accesses the BASIC ASSISTANT menu from the BASIC-BOOTWARE menu. |
Ctrl+Z | Ctrl+Z: Access EXTENDED ASSISTANT MENU | Accesses the EXTENDED ASSISTANT menu from the EXTENDED-BOOTWARE menu. |
1. Power on the device.
2. Press Ctrl+D within 4 seconds after the "Press Ctrl+D to access BASIC-BOOTWARE MENU" prompt message appears. If you fail to do this within the time limit, the system starts to run the extended BootWare segment.
======================<BASIC-BOOTWARE MENU(Ver 1.19)>=======================
|<1> Modify Serial Interface Parameter |
|<3> Update Full BootWare |
|<4> Boot Extended BootWare |
|<5> Boot Backup Extended BootWare |
|<0> Reboot |
Ctrl+U: Access BASIC ASSISTANT MENU
Table 13 BASIC-BOOTWARE menu options
Option | Task | Reference |
<1> Modify Serial Interface Parameter | Change the baud rate of the console port. Perform this task before downloading an image through the console port for software upgrade. | Modifying serial port parameters |
<2> Update Extended BootWare | Upgrade the extended BootWare segment. If the extended segment is corrupt, choose this option to repair it. | Upgrading the extended BootWare segment |
<3> Update Full BootWare | Upgrade the entire BootWare, including the basic segment and the extended segment. | Upgrading the entire BootWare |
<4> Boot Extended BootWare | Run the primary extended BootWare segment. | Running the primary extended BootWare segment |
<5> Boot Backup Extend BootWare | Run the backup extended BootWare segment. | Running the backup extended BootWare segment |
<0> Reboot | Reboot the device. | N/A |
Ctrl+U: Access BASIC ASSISTANT MENU | Press Ctrl+U to access the BASIC ASSISTANT menu. | Accessing the BASIC ASSISTANT menu |
To change the baud rate of the console port:
1. Enter 1 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 1
===============================<BAUDRATE SET>===============================
|Note:'*'indicates the current baudrate |
| Change The HyperTerminal's Baudrate Accordingly |
|---------------------------<Baudrate Available>---------------- ----------|
|<1> 9600(Default)* |
|<2> 19200 |
|<3> 38400 |
|<4> 57600 |
|<5> 115200 |
|<0> Exit |
2. Enter the number that represents the baud rate you want to choose. For example, enter 5 to set the baud rate to 115200 bps.
| NOTE: Baud rate change is a one-time operation. The baud rate will restore to the default (9600 bps) at reboot. To set up a console session with the device after a reboot, you must change the baud rate of the configuration terminal back to 9600 bps. |
Enter 2 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 2
Waiting ...CCC
Enter 3 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 3
Waiting ...CCC
Enter 4 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 4
Booting Normal Extended BootWare.
The Extended BootWare is self-decompressing....Done.
* H3C SecPath BootWare, Version 1.05 *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date : Aug 31 2017
Memory Type : DDR3 SDRAM
Memory Size : 16384MB
Sda0 Size : 8MB
sda0 Size : 3728MB
CPLD Version : 1.0
PCB Version : Ver.B
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Loading the main image files...
Loading file sda0:/Main-CMW710-SYSTEM-A9615.bin. ......................
Image file sda0:/Main-CMW710-BOOT-A9615.bin is self-decompressing......
System image is starting...
Enter 5 in the BASIC-BOOTWARE menu.
For information about backing up the extended BootWare segment, see "Accessing the BootWare Operation submenu."
Enter your choice(0-5): 5
Booting Backup Extended BootWare.
The Extended BootWare is self-decompressing............................Done!
| NOTE: This option is not supported if the password recovery capability is enabled. For more information about configuring the password recovery capability at the CLI, see "Controlling the password recovery capability." |
Press Ctrl+U in the BASIC-BOOTWARE menu.
===========================<BASIC-ASSISTANT MENU>===========================
|<1> RAM Test |
Enter your choice(0-1):
Table 14 BASIC ASSISTANT menu options
Option | Description |
<1> RAM Test | Test the memory. |
<2> Exit To Main Menu | Return to the BASIC-BOOTWARE menu. |
IMPORTANT: To avoid unexpected exceptions, perform this task under the guidance of H3C Support. |
To test the memory, use one of the following methods:
· In the BASIC-BOOTWARE menu, press Ctrl+T within 4 seconds after the "Press Ctrl+T to start memory test" prompt message appears.
· In the BASIC-BOOTWARE menu, press Ctrl+U to access the BASIC ASSISTANT menu.
Accessing the EXTENDED-BOOTWARE menu
2. Press Ctrl+B within 5 seconds after the "Press Ctrl+B to access EXTENDED-BOOTWARE MENU..." prompt message appears. If you fail to do this within the time limit, the system starts up.
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test..
Sda0 Size : 8MB
sda0 Size : 3728MB
CPLD Version : 1.0
PCB Version : Ver.B
Password recovery capability is enabled.
Note: The current operating device is sda0
Enter < Storage Device Operation > to select device.
3. Press Enter to access the EXTENDED-BOOTWARE menu.
===========================<EXTENDED-BOOTWARE MENU>=========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot |
Enter your choice(0-9):
Availability of some options in this menu depends on the password recovery capability state (displayed on top of the EXTEND-BOOTWARE menu). For more information about the feature, see "Controlling the password recovery capability."
Table 15 EXTENDED-BOOTWARE menu options
Option | Tasks | Reference |
<1> Boot System | Run the Comware software without rebooting the device. Choose this option after completing operations in the EXTENDED-BOOTWARE menu. | N/A |
<2> Enter Serial SubMenu | Accessing the Serial submenu. | |
<3> Enter Ethernet SubMenu | Use FTP or TFTP to upgrade Comware images through the management Ethernet port. | |
<4> File Control | · Display files on the current storage medium. · Set a Comware image file as the main or backup startup software image file. · Delete files to release storage space. | |
<5> Restore to Factory Default Configuration | Restore the factory-default configuration. This option is available only if password recovery capability is disabled. | |
<6> Skip Current System Configuration | Start the device with the factory-default configuration without loading any configuration file. This option is available only if password recovery capability is enabled. | |
<7> BootWare Operation Menu | Back up, recover, and upgrade the BootWare image. | |
<8> Skip Authentication for Console Login | Skip console login authentication. This option is available only if password recovery capability is enabled. This is a one-time operation and takes effect only for the first system boot or reboot after you choose this option. | |
<9> Storage Device Operation | Set the storage medium from which the device will start up. Set the storage medium where file operations are performed. This storage medium is referred to as the "current storage medium." | |
Ctrl+F: Format File System | Format the file system. | |
Ctrl+Z: Access EXTENDED ASSISTANT MENU | Access the EXTENDED ASSISTANT menu. | Accessing the EXTEND ASSISTANT submenu |
Password recovery capability controls console user access to the device configuration from BootWare menus. This feature decides the method to handle a password loss situation.
· If password recovery capability is enabled, a console user can handle a password loss situation as follows:
¡ If the console login password is lost, the user can skip console login authentication, and then access the CLI to configure a new password.
¡ If a user role password is lost, the user can skip the configuration file, and then access the CLI to configure a new password.
· If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords.
To enhance system security, disable password recovery capability.
To enable or disable password recovery capability:
Step | Command | Remarks |
4. Enter system view. | system-view | N/A |
5. Enable or disabled password recovery capability. | · Enable the feature: · Disable the feature: | By default, password recovery capability is enabled. |
Enter 1 in the EXTEND-BOOTWARE menu.
Enter your choice(0-9): 1
Loading file cfa0:/main-cmw710-system-e8526.bin.........................
Loading file cfa0:/main-cmw710-boot-e8526.bin...........................
Image file cfa0:/main-cmw710-boot-e8526.bin is self-decompressing.......
........Done.
Enter 2 in the EXTEND-BOOTWARE menu.
Enter your choice(0-9): 2
===========================<Enter Serial SubMenu>===========================
|<5> Modify Serial Interface Parameter |
Table 16 Serial submenu options
Option | Tasks |
<1> Download Image Program To SDRAM And Run | Load and run Comware images in SDRAM. This option is available only if password recovery capability is enabled. |
<2> Update Main Image File | Download Comware images to the current storage medium as the main images (the file attribute is set to M). As a result, the M file attribute of the original main images is removed. |
<3> Update Backup Image File | Download Comware images to the current storage medium as backup images (the file attribute is set to B). As a result, the B file attribute of the original backup images is removed. |
<4> Download Files(*.*) | Download files from the server to the device. |
<5> Modify Serial Interface Parameter | Change the baud rate of the console port. The baud rate change is a one-time operation. The baud rate will restore to the default (9600 bps) at reboot. To set up a console session with the device after a reboot, you must change the baud rate setting on the configuration terminal to 9600 bps. |
<0> Exit To Main Menu | Return to the EXTENDED-BOOTWARE menu. |
| NOTE: To set the current storage medium, see "Managing storage media." |
Accessing the Ethernet submenu
You can upgrade the Comware software through the management Ethernet port from the Ethernet submenu and configure file transfer settings.
1. Enter 3 in the EXTENDED-BOOTWARE menu and press Enter to access the Ethernet submenu.
Enter your choice(0-9):3
Table 17 Ethernet submenu options
<1> Download Image Program To SDRAM And Run | Load and run software images in SDRAM. If password recovery capability is enabled, this option is not available. |
<2> Update Main Image File | Download software images to the current storage medium as main images (the file attribute is set to M). As a result, the M file attribute of the original main images is removed. |
<3> Update Backup Image File | Download software images to the current storage medium as backup images (the file attribute is set to B). As a result, the B file attribute of the original backup images is removed. |
<5> Modify Ethernet Parameter | Configure FTP or TFTP file transfer settings. |
2. Enter 4 in the Ethernet submenu to configure file transfer settings on the MPU.
Enter your choice(0-4):4
| Ctrl+D = Quit. |
Table 18 Setting Ethernet parameters for file transfer
'.' = Clear field | Press the dot (.), and then press Enter to clear the setting for a field. |
'-' = Go to previous field | Press the hyphen (-), and then press Enter to return to the previous field. |
Ctrl+D = Quit | Press Ctrl + D to exit the Ethernet parameter settings menu. |
Protocol (FTP or TFTP) | Set the file transfer protocol to FTP or TFTP. |
Target File Name | Set a file name for saving the file in the current storage medium on the device. By default, the target file name is the same as the source file name. |
Local IP Address | Set the IP address of the device. |
FTP User Name | Set the username for accessing the FTP server. This username must be the same as configured on the FTP server. This field is not available for TFTP. |
FTP User Password | Set the password for accessing the FTP server. This password must be the same as configured on the FTP server. This field is not available for TFTP. |
You can display all files, set the attribute for a file, and delete a file from the File Control submenu.
Enter 4 in the EXTEND-BOOTWARE menu and then press Enter to access the File Control submenu.
Enter your choice(0-9):4
===============================<File CONTROL>===============================
|Note:the operating device is cfa0 |
|<1> Display All File(s) |
|<2> Set Image File type |
|<3> Set Bin File type |
|<4> Set Configuration File type |
|<5> Delete File |
Table 19 File Control submenu options
<1> Display All File(s) | Display all files. |
<2> Set Image File type | Set the attribute for a software image file. |
<3> Set Bin File type | Set the attribute for a .bin file. |
<4> Set Configuration File type | Set the type for a configuration file. |
<5> Delete File | Delete a file. |
<0> Exit To Main Menu | Return to the EXTEND-BOOTWARE menu. |
Displaying all files
Enter 1 in the File Control submenu.
Display all file(s) in cfa0:
'M' = MAIN 'B' = BACKUP 'N/A' = NOT ASSIGNED
|NO. Size(B) Time Type Name |
|1 956 Jan/21/2019 17:59:34 N/A cfa0:/ifindex.dat |
|2 24671 Mar/28/2018 09:08:56 N/A cfa0:/wdydiudie.cfg |
|3 735 Mar/28/2018 09:18:22 N/A cfa0:/hostkey |
|4 116549 Oct/09/2017 13:51:02 N/A cfa0:/lwb-t5k.cfg |
|5 963 Mar/27/2018 15:24:12 N/A cfa0:/license/history/deviceid_2|
|0180327152412.did |
|6 965 Mar/27/2018 15:24:12 N/A cfa0:/license/210235a1rsh1640000|
|06.did |
|7 3237 Dec/25/2017 15:14:54 N/A cfa0:/license/ngips2017122515235|
|923325.ak |
|8 3249 Apr/16/2018 16:40:28 N/A cfa0:/license/ngips2018041616523|
|608292.ak |
|9 1611429 Jan/22/2019 14:14:22 N/A cfa0:/logfile/logfile.log |
|10 1048575 Apr/16/2018 17:57:26 N/A cfa0:/logfile/ips.log |
|11 5230 Mar/19/2018 14:40:30 N/A cfa0:/logfile/uflt.log |
|12 1048405 Apr/16/2018 17:57:26 N/A cfa0:/logfile/anti-vir.log |
|13 44840 Aug/10/2017 15:25:46 N/A cfa0:/logfile/dfilter.log |
|14 14195 Jan/21/2019 16:47:54 N/A cfa0:/logfile/cfglog.log |
|15 251751 Jan/03/2019 09:09:56 N/A cfa0:/diagfile/diagfile.log |
|16 69784 Mar/28/2018 09:18:28 N/A cfa0:/dpi/ips/predefined/ips_sig|
|pack_curr.dat |
|17 2373992 Mar/28/2018 09:18:28 N/A cfa0:/dpi/ips/predefined/ips_sig|
|pack_back.dat |
|18 32027352 Apr/16/2018 16:56:28 N/A cfa0:/dpi/av/predefined/av_sigpa|
|ck_curr.dat |
|19 9574536 Apr/16/2018 16:48:00 N/A cfa0:/dpi/av/predefined/av_sigpa|
|ck_back.dat |
|20 68040 Mar/28/2018 09:18:28 N/A cfa0:/dpi/uflt/predefined/uflt_s|
|igpack_curr.dat |
|21 10330760 Mar/28/2018 09:18:36 N/A cfa0:/dpi/uflt/predefined/uflt_s|
|igpack_back.dat |
|22 342232 Mar/28/2018 09:18:24 N/A cfa0:/dpi/apr/predefined/apr_sig|
|pack_curr.dat |
|23 979448 Mar/28/2018 09:18:24 N/A cfa0:/dpi/apr/predefined/apr_sig|
|pack_back.dat |
|24 2840 Jan/22/2019 14:12:46 N/A cfa0:/dpi/filereg/predefined/fil|
|ereg_sigpack_curr.dat |
|25 30 Jan/21/2019 16:53:16 N/A cfa0:/dpi/dpi_sigpack.log |
|26 1566 Mar/28/2018 09:18:20 N/A cfa0:/pki/https-server.p12 |
|27 591 Mar/28/2018 09:18:22 N/A cfa0:/serverkey |
|28 259308 Mar/28/2018 09:08:58 N/A cfa0:/wdydiudie.mdb |
|29 723419 Oct/09/2017 13:51:04 N/A cfa0:/lwb-t5k.mdb |
|30 22692 Jan/21/2019 17:59:36 M cfa0:/startup.cfg |
|31 686202 May/20/2017 19:15:56 N/A cfa0:/pn.cfg |
|32 9275 Oct/28/2017 13:50:12 N/A cfa0:/zp.cfg |
|33 807 Oct/09/2017 15:59:54 N/A cfa0:/.trash/.trashinfo |
|34 5327872 Aug/15/2017 13:06:42 N/A cfa0:/.trash/main-cmw710-boo|
|t-e8518.bin_0001 |
|35 5331968 Aug/15/2017 10:30:04 N/A cfa0:/.trash/main-cmw710-boo|
|t-e8519.bin_0001 |
|36 9048064 Aug/21/2017 13:54:12 N/A cfa0:/.trash/main-cmw710-boo|
|t-e8520.bin_0001 |
|37 2056192 Aug/12/2017 18:05:54 N/A cfa0:/.trash/main-cmw710-dev|
|kit-e8518.bin_0001 |
|38 163840 Aug/14/2017 16:57:06 N/A cfa0:/.trash/main-cmw710-dev|
|kit-e8519.bin_0001 |
|39 163840 Aug/21/2017 14:07:26 N/A cfa0:/.trash/main-cmw710-dev|
|kit-e8520.bin_0001 |
|40 103891968 Aug/15/2017 13:07:04 N/A cfa0:/.trash/main-cmw710-sys|
|tem-e8518.bin_0001 |
|41 107120640 Aug/15/2017 10:30:58 N/A cfa0:/.trash/main-cmw710-sys|
|tem-e8519.bin_0001 |
|42 171900928 Aug/21/2017 14:07:02 N/A cfa0:/.trash/main-cmw710-sys|
|tem-e8520.bin_0001 |
|43 2238 Jan/22/2019 14:14:22 N/A cfa0:/context/context3/logfile/l|
|ogfile.log |
|44 24 Jan/21/2019 17:59:50 N/A cfa0:/context/context3/ifindex.d|
|at |
|45 1192 Jan/21/2019 17:59:50 N/A cfa0:/context/context3/startup.c|
|fg |
|46 34023 Jan/21/2019 17:59:50 N/A cfa0:/context/context3/startup.m|
|db |
|47 18468 Jan/22/2019 14:14:22 N/A cfa0:/context/context4/logfile/l|
|ogfile.log |
|48 1566 Mar/28/2018 09:19:08 N/A cfa0:/context/context4/pki/https|
|-server.p12 |
|49 1671 Jan/22/2019 09:27:00 N/A cfa0:/context/context4/startup.c|
|fg |
|50 37050 Jan/22/2019 09:27:00 N/A cfa0:/context/context4/startup.m|
|db |
|51 52 Jan/22/2019 09:27:00 N/A cfa0:/context/context4/ifindex.d|
|at |
|52 9054208 Apr/20/2018 13:27:02 N/A cfa0:/main-cmw710-boot-e8526|
|.bin |
|53 227919 Jan/21/2019 17:59:36 N/A cfa0:/startup.mdb |
|54 186294272 Apr/20/2018 13:27:30 N/A cfa0:/main-cmw710-system-e85|
|26.bin |
|55 123384832 Jan/21/2019 17:20:04 N/A cfa0:/main.ipe |
|56 3920 Jul/19/2017 18:32:04 N/A cfa0:/86.raw |
|57 3242 Jul/07/2017 09:36:50 N/A cfa0:/ngips2017070709142354252.a|
|k |
|58 120804 Jun/17/2017 17:00:30 N/A cfa0:/1.cfg |
|59 822025 Jun/17/2017 17:00:34 N/A cfa0:/1.mdb |
|60 120727 Jun/17/2017 17:01:02 N/A cfa0:/2.cfg |
|61 821866 Jun/17/2017 17:01:06 N/A cfa0:/2.mdb |
|62 16 Jan/21/2019 17:48:10 N/A cfa0:/versioninfo/versionctl.dat|
|63 536 Jan/21/2019 17:48:10 N/A cfa0:/versioninfo/version0.dat |
|64 796 Mar/20/2018 16:23:44 N/A cfa0:/versioninfo/version1.dat |
|65 796 Mar/20/2018 16:30:22 N/A cfa0:/versioninfo/version2.dat |
|66 796 Mar/20/2018 16:32:22 N/A cfa0:/versioninfo/version3.dat |
|67 796 Mar/20/2018 16:39:04 N/A cfa0:/versioninfo/version4.dat |
|68 536 Mar/27/2018 12:36:40 N/A cfa0:/versioninfo/version5.dat |
|69 796 Mar/27/2018 14:23:12 N/A cfa0:/versioninfo/version6.dat |
|70 536 Mar/28/2018 09:18:16 N/A cfa0:/versioninfo/version7.dat |
|71 796 Apr/16/2018 18:06:04 N/A cfa0:/versioninfo/version8.dat |
|72 536 Jul/24/2018 11:50:02 N/A cfa0:/versioninfo/version9.dat |
|73 9696 Sep/11/2017 17:41:56 N/A cfa0:/libpty.so |
|74 500446 Jul/29/2017 17:59:46 N/A cfa0:/ips.rules |
|75 19586056 Oct/16/2017 17:58:08 N/A cfa0:/50w-2.dat |
|76 117405304 Oct/16/2017 15:38:20 N/A cfa0:/500w-2.dat |
|77 7125 Sep/11/2017 19:43:30 N/A cfa0:/new1.rules |
|78 963 Oct/16/2017 17:12:58 N/A cfa0:/210235a1rsh164000006.did |
|79 9172 Oct/26/2017 11:30:30 N/A cfa0:/uzi.cfg |
|80 792001 May/20/2017 19:15:58 N/A cfa0:/pn.mdb |
|81 554834 May/18/2017 15:40:52 N/A cfa0:/fullconfig.cfg |
|82 684919 May/19/2017 13:50:20 N/A cfa0:/fullconfig2.cfg |
|83 554834 May/18/2017 16:20:36 N/A cfa0:/fullconfig1.cfg |
|84 788347 May/19/2017 13:50:22 N/A cfa0:/fullconfig2.mdb |
|85 154433 Oct/26/2017 11:30:30 N/A cfa0:/uzi.mdb |
|86 685411 May/23/2017 14:08:56 N/A cfa0:/wdy0523.cfg |
|87 791322 May/23/2017 14:08:58 N/A cfa0:/wdy0523.mdb |
|88 3246 Oct/16/2017 17:38:58 N/A cfa0:/ngips2017101617275868747.a|
|k |
|89 164864 Apr/20/2018 13:36:44 N/A cfa0:/main-cmw710-devkit-e85|
|26.bin |
|90 582397 Dec/25/2017 16:17:00 N/A cfa0:/1024.rules |
|91 93544 Dec/25/2017 16:17:30 N/A cfa0:/url.dat |
|92 5684224 Jul/24/2018 11:39:04 N/A cfa0:/main-cmw710-boot-e8530|
|.bin |
|93 154961 Oct/28/2017 13:50:14 N/A cfa0:/zp.mdb |
|94 504464 Oct/28/2017 19:22:12 N/A cfa0:/5e9dd320d3c7fd6fbec3a81a85|
|788002.6d9ada99 |
|95 2491008 Oct/29/2017 15:57:14 N/A cfa0:/8ac3b6bff681d9be6a20f865ac|
|e15a14 |
|96 20 Jan/31/2018 14:20:10 N/A cfa0:/.snmpboots |
|97 2216 Apr/16/2018 18:05:22 N/A cfa0:/pcap/excpt-currentcpu11-20|
|180117140659.cap |
|98 128016 Jan/17/2018 14:29:32 N/A cfa0:/firewall.exp |
|99 2812 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/cn/subthreatrep|
|ort.html |
|100 1139 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/cn/threatid.htm|
|l |
|101 2148 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/cn/threatlog.ht|
|ml |
|102 2370 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/cn/threatrank.h|
|tml |
|103 2067 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/cn/threatrankdl|
|g.html |
|104 4122 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/cn/threatreport|
|.html |
|105 3571 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/cn/threattrend.|
|html |
|106 2857 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/en/subthreatrep|
|ort.html |
|107 1429 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/en/threatlog.ht|
|ml |
|108 2651 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/en/threatrank.h|
|tml |
|109 2419 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/en/threatrankdl|
|g.html |
|110 4213 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/en/threatreport|
|.html |
|111 2721 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/en/threattrend.|
|html |
|112 14068 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/nc.js |
|113 36539 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/netconf.rbac |
|114 19541 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/subthreatreport|
|.js |
|115 13032 Jan/17/2018 20:07:28 N/A cfa0:/web/threat/threatid.js |
|116 98591 Jan/17/2018 20:10:04 N/A cfa0:/web/threat/threatlog.js |
|117 55749 Jan/17/2018 20:07:30 N/A cfa0:/web/threat/threatrank.js |
|118 37582 Jan/17/2018 20:07:30 N/A cfa0:/web/threat/threatrankdlg.j|
|s |
|119 31328 Jan/17/2018 20:07:30 N/A cfa0:/web/threat/threatreport.js|
|120 133659 Jan/17/2018 20:07:30 N/A cfa0:/web/threat/threattrend.js |
|121 106004480 Jul/24/2018 11:39:24 N/A cfa0:/main-cmw710-system-e85|
|30.bin |
|122 5692416 Jan/21/2019 17:29:52 M cfa0:/main-cmw710-boot-e8524|
|p15.bin |
|123 117685248 Jan/21/2019 17:30:12 M cfa0:/main-cmw710-system-e85|
|24p15.bin |
|124 7300 Jan/24/2018 08:53:08 N/A cfa0:/0a704f6998e9602ac5203b1306|
|7b2317 |
|125 151348 Jun/05/2017 16:40:44 N/A cfa0:/o.mdb |
|126 17704 Jan/31/2018 09:44:08 N/A cfa0:/dpi.cfg |
|127 235207 Jan/31/2018 09:44:10 N/A cfa0:/dpi.mdb |
|128 17659 Jan/31/2018 10:53:24 N/A cfa0:/dpi1.cfg |
|129 231817 Jan/31/2018 10:53:26 N/A cfa0:/dpi1.mdb |
|130 110592 Jan/31/2018 14:31:18 N/A cfa0:/core/node16_dpid_202565_11|
|_20180131-143118_1517409078.core |
|131 118784 Jul/24/2018 11:51:10 N/A cfa0:/core/node16_ntopd_820_11_2|
|0180724-115110_1532433070.core |
|132 118784 Dec/17/2018 08:32:20 N/A cfa0:/core/node16_ntopd_803_11_2|
|0181217-083220_1545035540.core |
|133 3249 Apr/16/2018 16:40:28 N/A cfa0:/ngips2018041616523608292.a|
|k |
Setting the attribute for software images
1. Enter 2 in the File Control submenu.
|<5> Delete File |
|1 123384832 Jan/21/2019 17:20:04 N/A cfa0:/main.ipe |
|0 Exit |
2. Enter the numbers of the files you are working with. For example, enter 1.
Enter file No.:1
Modify the file attribute:
|<1>+Main |
|<2>+Backup |
|<0> Exit |
Enter your choice(0-2):
3. Enter a number in the range of 0 to 2 to add or delete a file attribute for the files. For example, enter 1 to assign the M attribute to the files.
Enter your choice(0-2):1
This operation may take several minutes. Please wait....
The file is exist,will you overwrite it? [Y/N]Y
Image file main-cmw710-boot-E8524P15.bin is self-decompressing...
Saving file cfa0:/main-cmw710-boot-E8524P15.bin ........................
Image file main-cmw710-system-E8524P15.bin is self-decompressing...
Saving file cfa0:/main-cmw710-system-E8524P15.bin ......................
Set the file attribute success!
Setting the attribute for .bin files
Enter 3 in the File Control submenu.
|1 9054208 Apr/20/2018 13:27:02 N/A cfa0:/main-cmw710-boot-e8526|
|.bin |
|2 186294272 Apr/20/2018 13:27:30 N/A cfa0:/main-cmw710-system-e85|
|26.bin |
|3 164864 Apr/20/2018 13:36:44 N/A cfa0:/main-cmw710-devkit-e85|
|26.bin |
|4 5684224 Jul/24/2018 11:39:04 N/A cfa0:/main-cmw710-boot-e8530|
|.bin |
|5 106004480 Jul/24/2018 11:39:24 N/A cfa0:/main-cmw710-system-e85|
|30.bin |
|6 5692416 Jan/22/2019 14:47:32 M cfa0:/main-cmw710-boot-e8524|
|p15.bin |
|7 117685248 Jan/22/2019 14:47:50 M cfa0:/main-cmw710-system-e85|
|24p15.bin |
|0 Exit |
Note:Select .bin files. One but only one boot image and system image must
be included.
Enter file No.(Allows multiple selection):1
Enter another file No.(0-Finish choice):2
Enter another file No.(0-Finish choice):0
You have selected:
|<1>+Main |
|<2>+Backup |
|<0> Exit |
Deleting a file
1. Enter 5 in the File Control submenu.
Deleting the file in cfa0:
|0180327152412.did |
|06.did |
|923325.ak |
|608292.ak |
|pack_curr.dat |
|pack_back.dat |
|ck_curr.dat |
|ck_back.dat |
|igpack_curr.dat |
|igpack_back.dat |
|pack_curr.dat |
|pack_back.dat |
|t-e8518.bin_0001 |
|t-e8519.bin_0001 |
|t-e8520.bin_0001 |
|ogfile.log |
|at |
|fg |
|db |
|ogfile.log |
|-server.p12 |
|fg |
|db |
|at |
|52 9054208 Apr/20/2018 13:27:02 M cfa0:/main-cmw710-boot-e8526|
|.bin |
|54 186294272 Apr/20/2018 13:27:30 M cfa0:/main-cmw710-system-e85|
|26.bin |
|k |
|k |
|26.bin |
|.bin |
|788002.6d9ada99 |
|e15a14 |
|180117140659.cap |
|ort.html |
|l |
|ml |
|tml |
|g.html |
|.html |
|html |
|ort.html |
|ml |
|tml |
|g.html |
|.html |
|html |
|.js |
|s |
|30.bin |
|122 5692416 Jan/22/2019 14:47:32 N/A cfa0:/main-cmw710-boot-e8524|
|p15.bin |
|123 117685248 Jan/22/2019 14:47:50 N/A cfa0:/main-cmw710-system-e85|
|24p15.bin |
|7b2317 |
|k |
|0 Exit |
Enter file No.:
2. Enter the number of the file to delete. For example, enter 13 to delete the sda0:/test.cfg file.
3. When the following message appears, enter Y.
The file you selected is sda0:/test.cfg,Delete it? [Y/N]
If the following message appears, the file is successfully deleted.
Deleting.....Done!
Restoring the factory-default configuration
CAUTION: Restoring the factory-default configuration will permanently delete startup configuration files and backup configuration files in the current storage medium. |
To restore the factory-default configuration from the EXTENDED-BOOTWARE menu, make sure password recovery capability is disabled. If the capability is enabled, you cannot perform the task.
After you perform this task, the device uses the factory-default configuration instead of the configuration file for the next startup.
To restore the factory-default configuration:
1. Enter 5 in the EXTEND-BOOTWARE menu and then press Enter.
Enter your choice(0-9): 5
2. Follow the system instruction to complete the task.
¡ If password recovery capability is enabled, first disable the capability from the CLI, and then reboot the device to access the EXTENDED-BOOTWARE menu.
Password recovery capability is enabled. To perform this operation, first disable the password recovery capability using the undo password-recovery enable command in CLI.
¡ If password recovery capability is disabled, enter Y at the prompt to complete the task.
Because the password recovery capability is disabled, this operation can cause the configuration files to be deleted, and the system will start up with factory defaults. Are you sure to continue?[Y/N]Y
Setting...Done.
Skipping the configuration file
To perform this task, make sure password recovery capability is enabled. If the capability is disabled, you cannot perform the task.
To start the device with the factory-default configuration:
1. Enter 6 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9): 6
Flag Set Success.
¡ If password recovery capability is enabled, the device uses the factory-default configuration instead of the configuration file for the next startup.
¡ If password recovery capability is disabled, first enable the capability from the CLI, and then reboot the device to access the EXTENDED-BOOTWARE menu.
Password recovery capability is disabled. To perform this operation, first enable the password recovery capability using the password-recovery enable command in CLI.
Enter 7 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9): 7
Table 20 BootWare Operation submenu options
<1> Backup Full BootWare | Back up the entire BootWare image. |
<2> Restore Full BootWare | Recover the entire BootWare image. |
<3> Update BootWare By Serial | Upgrade the BootWare image through the serial port. |
<4> Update BootWare By Ethernet | Upgrade BootWare through the management Ethernet port. |
Skipping console login authentication
To perform this task, make sure password recovery capability is enabled. If the capability is disabled, you cannot perform this task.
This is a one-time operation and takes effect only for the reboot after you perform this task.
To enable the device to load the next-startup configuration file with the console login password ignored:
1. Enter 8 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9): 8
¡ If password recovery capability is enabled, the device clears the password for user privilege change.
Clear Image Password Success!
Enter 9 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9):9
==============================<DEVICE CONTROL>==============================
|<1> Display All Available Nonvolatile Storage Device(s) |
|<2> Set The Operating Device |
|<3> Set The Default Boot Device |
Enter your choice(0-3):
Table 21 DEVICE CONTROL menu options
<1> Display All Available Nonvolatile Storage Device(s) | Display all storage media on the MPU you are working with. |
<2> Set The Operating Device | Set the current storage medium. All file operations in BootWare menus are performed on the current storage medium. |
<3> Set The Default Boot Device | Set the default storage medium from which the system will start up. |
Press Ctrl+Z in the EXTEND-BOOTWARE menu.
==========================<EXTENDED ASSISTANT MENU>=========================
|<1> Display Memory |
|<2> Search Memory |
Table 22 EXTEND ASSISTANT submenu options
<1> Display Memory | View memory information that meets certain requirements. |
<2> Search Memory | Search memory for data that meets certain requirements. |
CAUTION: Formatting the file system clears all files and directories in a storage medium permanently. The cleared files and directories cannot be recovered. |
Press Ctrl+F in the EXTEND-BOOTWARE menu.
Warning:All files on sda0 will be lost! Are you sure to format? [Y/N]
