H3C S5136S-EI Switch Series Hardware Information and Specifications-6W103
HomeSupportSwitchesS5136 SeriesS5136S-EI SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C S5136S-EI Switch Series Hardware Information and Specifications-6W103
01-Text
01-Text 10.75 MB
1 Product models and technical specifications· 1-1
Product models· 1-1
Technical specifications for non-PoE switch models· 1-2
Technical specifications for PoE switch models· 1-11
2 Chassis views· 2-1
S5136S-8T4XS-EI-Q·· 2-1
S5136S-10T4X-EI-Q·· 2-2
S5136S-16T4X-EI-Q·· 2-2
S5136S-24S8T4X-EI 2-3
S5136S-24T4S-EI-Q·· 2-4
S5136S-24T4X-EI-Q·· 2-5
S5136S-48S2T4X-EI 2-5
S5136S-48ST4X-EI 2-6
S5136S-48T4S-EI-Q·· 2-7
S5136S-48T4X-EI-Q·· 2-8
S5136S-8N2X-EI 2-8
S5136S-8FP4XS-EI-Q·· 2-9
S5136S-10FPT4X-EI-Q·· 2-10
S5136S-16FP4X-EI 2-11
S5136S-24FP4S4X-EI 2-11
S5136S-24FP4T4S-EI 2-12
S5136S-24P4X-EI 2-13
S5136S-48FP4S-EI 2-13
S5136S-48FP4X-EI 2-14
S5136S-48P4S-EI 2-15
S5136S-48P4X-EI 2-15
S5136S-8UN2X-EI 2-16
S5136S-8FP4UN4X-EI 2-17
3 Removable components· 3-1
4 Removable power supplies· 4-1
70 W power supply (CA-70A12) 4-1
75 W power supply (PSR75-12A) 4-2
180 W power supply (PSR180-12D-B) 4-3
5 Ports and LEDs· 5-1
Ports· 5-1
Console port 5-1
Management Ethernet port 5-1
USB port 5-2
10/100/1000BASE-T autosensing Ethernet port 5-2
2.5G/1000/100BASE-T autosensing Ethernet port 5-3
SFP port 5-3
SFP+ port 5-9
Combo interface· 5-15
LEDs· 5-15
System status LED·· 5-15
Management Ethernet port LED·· 5-16
Power supply status LED·· 5-16
Mode LED·· 5-16
SFP/SFP+ port LED·· 5-17
2.5G/1000/100BASE-T autosensing Ethernet port LED·· 5-17
10/100/1000BASE-T Ethernet port LED·· 5-18
Cloudnet management status LED·· 5-19
Location LED·· 5-19
6 Buttons· 6-1
Reset button· 6-1
7 Cooling system·· 7-1
Product models
Table1-1 describes the S5136S-EI switch series models.
Table1-1 S5136S-EI switch series models
Model
Product code (PID)
Non-PoE switch models
S5136S-8T4XS-EI-Q
LS-5136S-8T4XS-EI-Q-GL
S5136S-10T4X-EI-Q
LS-5136S-10T4X-EI-Q-GL
S5136S-16T4X-EI-Q
LS-5136S-16T4X-EI-Q-GL
S5136S-24S8T4X-EI
LS-5136S-24S8T4X-EI-GL
S5136S-24T4S-EI-Q
LS-5136S-24T4S-EI-Q-GL
S5136S-24T4X-EI-Q
LS-5136S-24T4X-EI-Q-GL
S5136S-48S2T4X-EI
LS-5136S-48S2T4X-EI-GL
S5136S-48ST4X-EI
LS-5136S-48ST4X-EI-GL
S5136S-48T4S-EI-Q
LS-5136S-48T4S-EI-Q-GL
S5136S-48T4X-EI-Q
LS-5136S-48T4X-EI-Q-GL
S5136S-8N2X-EI
LS-5136S-8N2X-EI-GL
PoE switch models
S5136S-8FP4XS-EI-Q
LS-5136S-8FP4XS-EI-Q-GL
S5136S-10FPT4X-EI-Q
LS-5136S-10FPT4X-EI-Q-GL
S5136S-16FP4X-EI
LS-5136S-16FP4X-EI-GL
S5136S-24FP4S4X-EI
LS-5136S-24FP4S4X-EI-GL
S5136S-24FP4T4S-EI
LS-5136S-24FP4T4S-EI-GL
S5136S-24P4X-EI
LS-5136S-24P4X-EI-GL
S5136S-48FP4S-EI
LS-5136S-48FP4S-EI-GL
S5136S-48FP4X-EI
LS-5136S-48FP4X-EI-GL
S5136S-48P4S-EI
LS-5136S-48P4S-EI-GL
S5136S-48P4X-EI
LS-5136S-48P4X-EI-GL
S5136S-8UN2X-EI
LS-5136S-8UN2X-EI-GL
S5136S-8FP4UN4X-EI
LS-5136S-8FP4UN4X-EI-GL
·     To obtain the purchase information, see the product data sheet at https://www.h3c.com/en/Products_and_Solutions/InterConnect/Switches/ and pay attention to the switch product lifecycle management announcement at https://www.h3c.com/en/Support/Policy_Dynamics/Management_Strategy/Products_End_of_Life_Announcement/Switches/.
·     For information about product and software compatibility, see the release notes.
Table1-2 Technical specifications for non-PoE switch models (1)
Item
S5136S-8T4XS-EI-Q
S5136S-10T4X-EI-Q
S5136S-16T4X-EI-Q
Physical specifications
Dimensions (H × W × D, without package materials)
44 × 266 × 161 mm (1.73 × 10.47 × 6.34 in)
44 × 440 × 160 mm (1.73 × 17.32 × 6.30 in)
Dimensions (H × W × D, with package materials)
85 × 368 × 275 mm (3.35 × 14.49 × 10.83 in)
85 × 368 × 277 mm (3.35 × 14.49 × 10.91 in)
86 × 540 × 280 mm (3.39 × 21.26 × 11.02 in)
Weight
≤ 1.1 kg (2.43 lb)
≤ 1.2 kg (2.65 lb)
≤ 1.8 kg (3.97 lb)
Memory (RAM)
2 GB
Flash
1 GB
Port types and quantity
Console port
·     1 × serial console port
·     1 × Type-C USB console port
Only the Type-C USB console port is available when you connect both ports.
USB port
1
8
10
16
SFP port
2
N/A
N/A
SFP+ port
2
4
4
Power supply specifications
Power input
AC input
·     Rated voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Max voltage range: 90 VAC to 264 VAC @ 47 Hz to 63 Hz
Melting current of power supply fuse
3.15 A/250 V
10A/250V
10 A/250 V
Power consumption
Power consumption (static)
Data collection standard: no load
5 W
5 W
6 W
Power consumption (with typical configuration)
Data collection standard: fully configured with DAC cables or twisted pair cables, 30% loaded
8 W
16 W
13 W
Power consumption (fully configured)
Data collection standard: fully configured with transceiver modules or twisted pair cables, 100% loaded
16 W
16 W
17 W
Thermal consumption
Static thermal consumption
15 BTU/hr
18 BTU/hr
20 BTU/hr
Typical thermal consumption
28 BTU/hr
55 BTU/hr
43 BTU/hr
Maximum thermal consumption
53 BTU/hr
55 BTU/hr
57 BTU/hr
Heat dissipation
Heat dissipation method
Fanless, passive cooling
Mean Time Between Failure (MTBF) (Year)
209.501
182.211
142.5
Mean time to repair (MTTR) (Hour)
1
Availability
99.999919%
99.999937%
99.9999%
Environment specifications
Altitude
5000 m (16404.20 ft)
Operating temperature
–5°C to +50°C (23°F to 122°F)
Note:
The maximum acceptable temperature decreases by 0.33°C (0.59°F) for every 100 m (328.08 ft) increase in altitude from 0 m (0 ft).
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Relative humidity
5% RH to 95% RH, noncondensing
Product compliance
Product compliance
·     Safety standards
·     EMC standards
·     Environmental protection and eco-friendly standards
Table1-3 Technical specifications for non-PoE switch models (2)
Item
S5136S-24T4S-EI-Q
S5136S-24T4X-EI-Q
S5136S-48T4S-EI-Q
S5136S-48T4X-EI-Q
44 × 440 × 260 mm (1.73 × 17.32 × 10.24 in)
125 × 550 × 380 mm (4.92 × 21.65 × 14.96 in)
Weight
≤ 2 kg (4.41 lb)
≤ 2 kg (4.41 lb)
≤ 3.6 kg (7.94 lb)
≤ 3.6 kg (7.94 lb)
Memory (RAM)
2 GB
Flash
1 GB
Console port
USB port
1
24
24
48
48
SFP port
4
N/A
4
N/A
SFP+ port
N/A
4
N/A
4
Power input
AC input
10 A/250 V
10 A/250 V
3.15 A/250 V
3.15 A/250 V
Power consumption
6 W
6 W
13 W
13 W
16 W
16 W
30 W
31 W
18 W
21 W
37 W
42 W
Thermal consumption
20 BTU/hr
20 BTU/hr
45 BTU/hr
45 BTU/hr
52 BTU/hr
54 BTU/hr
103 BTU/hr
106 BTU/hr
61 BTU/hr
70 BTU/hr
127 BTU/hr
144 BTU/hr
Heat dissipation
129.95
129.87
128.043
118.731
1
Availability
99.9999%
99.9999%
99.999911%
99.999904%
Altitude
Note:
Storage temperature
Relative humidity
Product compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-4 Technical specifications for non-PoE models switch (3)
Item
S5136S-24S8T4X-EI
S5136S-48S2T4X-EI
S5136S-48ST4X-EI
44 × 440 × 360 mm (1.73 × 17.32 × 14.17 in)
125 × 562 × 550 mm (4.92 × 22.13 × 21.65 in)
Weight
≤ 5.4 kg (11.90 lb)
≤ 5.5 kg (12.13 lb)
≤ 5.5 kg (12.13 lb)
Memory (RAM)
2 GB
Flash
1 GB
Console port
USB port
1
8 (Each and its corresponding SFP port form a combo interface.)
2 (Each and its corresponding SFP port form a combo interface.)
24
SFP port
24 (The eight highest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively.)
48 (The two highest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively.)
24
SFP+ port
4
4
4
Power input
·     Removable AC power supply input (no support for HVDC input)
·     Removable DC power supply input
·     RPS input (RPS1600-A)
See "Removable power supplies"
Power consumption
Single AC: 11 W
Dual AC: 13 W
Single DC: 15 W
Dual DC: 22 W
Single AC: 19 W
Dual AC: 21 W
Single DC: 21 W
Dual DC: 29 W
Single AC: 17 W
Dual AC: 19 W
Single DC: 20 W
Dual DC: 27 W
Single AC: 12 W
Dual AC: 14 W
Single DC: 16 W
Dual DC: 23 W
Single AC: 20 W
Dual AC: 23 W
Single DC: 23 W
Dual DC: 31 W
Single AC: 27 W
Dual AC: 29 W
Single DC: 29 W
Dual DC: 29 W
Single AC: 35 W
Dual AC: 37 W
Single DC: 37 W
Dual DC: 44 W
Single AC: 54 W
Dual AC: 55 W
Single DC: 55 W
Dual DC: 61 W
Single AC: 47 W
Dual AC: 49 W
Single DC: 47 W
Dual DC: 53 W
Thermal consumption
Single AC: 37 BTU/hr
Dual AC: 44 BTU/hr
Single DC: 49 BTU/hr
Dual DC: 74 BTU/hr
Single AC: 62 BTU/hr
Dual AC: 69 BTU/hr
Single DC: 72 BTU/hr
Dual DC: 97 BTU/hr
Single AC: 57 BTU/hr
Dual AC: 64 BTU/hr
Single DC: 65 BTU/hr
Dual DC: 90 BTU/hr
Single AC: 41 BTU/hr
Dual AC: 48 BTU/hr
Single DC: 54 BTU/hr
Dual DC: 77 BTU/hr
Single AC: 68 BTU/hr
Dual AC: 76 BTU/hr
Single DC: 78 BTU/hr
Dual DC: 103 BTU/hr
Single AC: 91 BTU/hr
Dual AC: 99 BTU/hr
Single DC: 98 BTU/hr
Dual DC: 99 BTU/hr
Single AC: 118 BTU/hr
Dual AC: 127 BTU/hr
Single DC: 124 BTU/hr
Dual DC: 149 BTU/hr
Single AC: 184 BTU/hr
Dual AC: 187 BTU/hr
Single DC: 185 BTU/hr
Dual DC: 206 BTU/hr
Single AC: 158 BTU/hr
Dual AC: 167 BTU/hr
Single DC: 160 BTU/hr
Dual DC: 180 BTU/hr
Heat dissipation
Air cooling
Air cooling
Air cooling
Ventilation aisles
Left to right (facing the front panel)
127.7
108.3
100.9
1
Availability
99.9999%
99.9998%
99.9998%
Sound pressure level at 27°C (80.6°F)
35.2 dB
35.2 dB
35.2 dB
Altitude
Note:
Storage temperature
Operating relative humidity
Product compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-5 Technical specifications for non-PoE switch models (4)
Item
S5136S-8N2X-EI
Weight
≤ 1.2 kg (2.65 lb)
Memory (RAM)
2 GB
Flash
1 GB
Console port
USB port
1
8
SFP+ port
2
Power input
AC input
·     Max voltage range: 90 VAC to 290 VAC @ 47 Hz to 63 Hz
2 A/250 V
Power consumption
8 W
12 W
13 W
Thermal consumption
28 BTU/hr
41 BTU/hr
45 BTU/hr
Heat dissipation
163.6
1
Availability
99.99993%
Altitude
Note:
Storage temperature
Relative humidity
Product compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-6 Technical specifications for PoE switch models (1)
Item
S5136S-8FP4XS-EI-Q
S5136S-16FP4X-EI
S5136S-24FP4S4X-EI
S5136S-24FP4T4S-EI
S5136S-10FPT4X-EI-Q
44 × 266 × 160 mm (1.73 × 10.47 × 6.30 in)
44 × 330 × 230 mm (1.73 × 12.99 × 9.06 in)
135 × 555 × 385 mm (5.32 × 21.85 × 15.16 in)
90 × 425 × 365 mm (3.54 × 16.73 × 14.37 in)
Weight
≤ 1.5 kg (3.31 lb)
≤ 3.6 kg (7.94 lb)
≤ 3.6 kg (7.94 lb)
≤ 3.8 kg (8.38 lb)
≤ 2.3 kg (5.07 lb)
Memory (RAM)
2 GB
Flash
1 GB
Console port
USB port
1
8
16
24 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.)
28 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.)
10
Ports 1 to 8 support PoE.
SFP port
2
N/A
4 (Each and its corresponding 10/100/1000BASE-T autosensing Ethernet port form a combo interface.)
N/A
SFP+ port
2
4
4
N/A
4
Power input
AC input
6.3 A/250 V
8 A/250 V
10 A/250 V
10 A/250 V
6.3A/250V
PoE power capacity
Maximum PoE power per port
30 W
Total PoE power
125 W
248 W
405 W
405 W
125 W
Power consumption
8 W
25 W
23 W
19 W
7 W
10 W
38 W
35 W
29 W
18 W
152 W
317 W
465 W
461 W
147 W
Thermal consumption
28 BTU/hr
86 BTU/hr
78 BTU/hr
65 BTU/hr
24 BTU/hr
35 BTU/hr
130 BTU/hr
119 BTU/hr
99 BTU/hr
62 BTU/hr
519 BTU/hr
1055 BTU/hr
1467 BTU/hr
1454 BTU/hr
502 BTU/hr
Heat dissipation
Air cooling
Air cooling
Air cooling
Ventilation aisles
N/A
N/A
137.985
67.616
50.001
51.111
133.708
1
Availability
99.999917%
99.999831%
99.999772%
99.999777%
99.999915%
N/A
37.6 dB
37.6 dB
37.6 dB
N/A
Altitude
Note:
Storage temperature
Relative humidity
Product compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-7 Technical specifications for PoE switch models (2)
Item
S5136S-24P4X-EI
S5136S-48FP4S-EI
S5136S-48FP4X-EI
S5136S-48P4S-EI
S5136S-48P4X-EI
Weight
≤ 3.6 kg (7.94 lb)
≤ 4.2 kg (9.26 lb)
≤ 4.2 kg (9.26 lb)
≤ 4.1 kg (9.04 lb)
≤ 4.1 kg (9.04 lb)
Memory (RAM)
2 GB
Flash
1 GB
Console port
USB port
1
24
48
48
48
48
SFP port
N/A
4
N/A
4
N/A
SFP+ port
4
N/A
4
N/A
4
Power input
AC input
8 A/250 V
16 A/250 V
16 A/250 V
10 A/250 V
10 A/250 V
PoE power capacity
30 W
Total PoE power
248 W
770 W
770 W
390 W
390 W
Power consumption
29 W
35 W
35 W
29 W
29 W
42 W
56 W
56 W
54 W
54 W
321 W
964 W
969 W
517 W
512 W
Thermal consumption
99 BTU/hr
120 BTU/hr
120 BTU/hr
99 BTU/hr
99 BTU/hr
144 BTU/hr
192 BTU/hr
192 BTU/hr
185 BTU/hr
185 BTU/hr
1069 BTU/hr
3187 BTU/hr
3204 BTU/hr
1696 BTU/hr
1679 BTU/hr
Heat dissipation
Air cooling
Air cooling
Air cooling
Air cooling
Air cooling
Ventilation aisles
62.64
44.653
43.464
44.366
43.192
1
Availability
99.999818%
99.999744%
99.999737%
99.999743%
99.999736%
37.6 dB
32.9 dB
32.9 dB
37.6 dB
37.6 dB
Altitude
––5°C to +50°C (23°F to 122°F)
Note:
Storage temperature
Relative humidity
Product compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-8 Technical specifications for PoE switch models (3)
Item
S5136S-8UN2X-EI
S5136S-8FP4UN4X-EI
44 × 294 × 206 mm (1.73 × 11.57 × 8.11 in)
80 × 365 × 306 mm (3.15 × 14.37 × 12.05 in)
Weight
2.3 kg (5.07 lb)
2.0 kg (4.41 lb)
Memory (RAM)
2 GB
Flash
1 GB
Console port
USB port
1
N/A
8
8
4
SFP+ port
2
4
Power input
AC input
10 A/250 V
6.3 A/250 V
PoE power capacity
100 W
PoE+: 35W
PoE++: 100 W
Total PoE power
410 W
250 W
Power consumption
16 W
13 W
19 W
17 W
488 W
301 W
Thermal consumption
55 BTU/hr
45 BTU/hr
65 BTU/hr
59 BTU/hr
1666 BTU/hr
1028 BTU/hr
Heat dissipation
Air cooling
Ventilation aisles
N/A
100.5
99.8
1
Availability
99.999886%
99.999885%
39.4 dB
N/A
Altitude
Note:
Storage temperature
Relative humidity
Product compliance
Product compliance
·     Safety standards
·     EMC standards
2 Chassis views
S5136S-8T4XS-EI-Q
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) SFP port
(3) SFP+ port
(4) Console port
(5) USB port
(6) Type-C USB console port
(7) Reset button (RESET)
(8) Mode button (Cloudnet management status LED)
(9) Location LED (ID)
(10) System status LED (SYS)
(11) Mode LED (MODE)
(12) Management Ethernet port LED (LINK/ACT)
(13) Management Ethernet port
(14) SFP+ port LED
(15) SFP port LED
(16) 10/100/1000BASE-T autosensing Ethernet port LED
Figure2-2 Rear panel
(1) Grounding screw
(2) AC power receptacle
S5136S-10T4X-EI-Q
Figure2-3 Front panel
(2) SFP+ port
(3) Console port
(4) Type-C USB console port
(5) Reset button (RESET)
(6) USB port
(7) Mode button (Cloudnet management status LED)
(8) Location LED (ID)
(9) System status LED (SYS)
(10) Mode LED (MODE)
(11) Management Ethernet port LED (LINK/ACT)
(13) SFP+ port LED
(14) 10/100/1000BASE-T autosensing Ethernet port LED
Figure2-4 Rear panel
(1) Grounding screw
S5136S-16T4X-EI-Q
Figure2-5 Front panel
(2) SFP+ port
(3) Management Ethernet port
(4) USB port
(5) Type-C USB console port
(6) Mode LED (MODE)
(12) Console port
(13) LED SFP+ port LED
Figure2-6 Rear panel
(1) Grounding screw
S5136S-24S8T4X-EI
Figure2-7 Front panel
(1) SFP port
(2) 10/100/1000BASE-T autosensing Ethernet port
(3) SFP+ port
(4) Console port
(5) USB port
(8) Reset button (RESET)
(12) Power supply 2 status LED (PWR2)
(13) Power supply 1 status LED (PWR1)
(14) LED Management Ethernet port LED (LINK/ACT)
(15) Management Ethernet port
(16) SFP+ port LED
(17) 10/100/1000BASE-T autosensing Ethernet port LED
(18) SFP port LED
Figure2-8 Rear panel
(1) Grounding screw
(2) Power supply 1 (PWR1)
(3) Power supply 2 (PWR2)
The S5136S-24S8T4X-EI switch has two power supply slots on the rear panel. You can install one or two power supplies for the switch as needed. In Figure2-8, two CA-70A12 AC power supplies are installed.
S5136S-24T4S-EI-Q
Figure2-9 Front panel
(2) SFP port
(3) Console port
(4) USB port
(6) Mode LED (MODE)
(13) SFP port LED
Figure2-10 Rear panel
(1) Grounding screw
S5136S-24T4X-EI-Q
Figure2-11 Front panel
(2) SFP+ port
(4) Console port
(5) USB port
(9) Mode LED (MODE)
(10) Location LED (ID)
(11) System status LED (SYS)
(13) SFP+ port LED
Figure2-12 Rear panel
(1) Grounding screw
S5136S-48S2T4X-EI
Figure2-13 Front panel
(1) SFP port
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) 10/100/1000BASE-T autosensing Ethernet port
(4) Power supply 2 status LED (PWR2)
(5) USB port
(6) Mode button (Cloudnet management status LED)
(7) Location LED (ID)
(8) System status LED (SYS)
(9) Mode LED (MODE)
(10) Power supply 1 status LED (PWR1)
(11) SFP+ port LED
(12) SFP+ port
(13) SFP port LED
Figure2-14 Rear panel
(1) Grounding screw
(2) Management Ethernet port
(3) Management Ethernet port LED (LINK)
(4) Management Ethernet port LED (ACT)
(5) Console port
(8) Power supply 1 (PWR1)
(9) Power supply 2 (PWR2)
The S5136S-48S2T4X-EI switch has two power supply slots on the rear panel. You can install one or two power supplies for the switch as needed. In Figure2-14, two CA-70A12 AC power supplies are installed.
S5136S-48ST4X-EI
Figure2-15 Front panel
(2) SFP port
(3) Management Ethernet port LED (LINK/ACT)
(5) Power supply 1 status LED (PWR1)
(6) Console port
(7) System status LED (SYS)
(8) USB port
(9) Mode button (Cloudnet management status LED)
(10) Type-C USB console port
(11) Reset button (RESET)
(12) Location LED (ID)
(13) Mode LED (MODE)
(14) Power supply 2 status LED (PWR2)
(15) SFP+ port LED
(16) SFP+ port
(17) SFP port LED
(18) 10/100/1000BASE-T autosensing Ethernet port LED
Figure2-16 Rear panel
(1) Grounding screw
The S5136S-48ST4X-EI switch has two power supply slots on the rear panel. You can install one or two power supplies for the switch as needed. In Figure2-16, two CA-70A12 AC power supplies are installed.
S5136S-48T4S-EI-Q
Figure2-17 Front panel
(2) Management Ethernet port LED (LINK/ACT)
(4) Mode LED (MODE)
(5) Console port
(6) System status LED (SYS)
(7) USB port
(9) Type-C USB console port
(10) Reset button (RESET)
(11) Location LED (ID)
(12) SFP port LED
(13) SFP port
Figure2-18 Rear panel
(1) Grounding screw
S5136S-48T4X-EI-Q
Figure2-19 Front panel
(4) Mode LED (MODE)
(5) Console port
(7) USB port
(12) SFP+ port
(13) SFP+ port LED
Figure2-20 Rear panel
(1) Grounding screw
S5136S-8N2X-EI
Figure2-21 Front panel
(1) 2.5G/1000/100BASE-T autosensing Ethernet port
(2) SFP+ port
(3) Console port
(5) USB port
(13) SFP+ port LED
(14) 2.5G/1000/100BASE-T autosensing Ethernet port LED
Figure2-22 Rear panel
(1) Grounding screw
S5136S-8FP4XS-EI-Q
Figure2-23 Front panel
(2) SFP port
(3) SFP+ port
(4) Console port
(5) USB port
(14) SFP+ port LED
(15) SFP port LED
Figure2-24 Rear panel
(1) Grounding screw
S5136S-10FPT4X-EI-Q
Figure2-25 Front panel
(2) SFP+ port
(3) Console port
(6) USB port
(13) SFP+ port LED
Figure2-26 Rear panel
(1) AC power receptacle
(2) Grounding screw
S5136S-16FP4X-EI
Figure2-27 Front panel
(2) SFP+ port
(3) Console port
(4) USB port
(5) Mode button (Cloudnet management status LED)
(13) SFP+ port LED
Figure2-28 Rear panel
(1) Grounding screw
S5136S-24FP4S4X-EI
Figure2-29 Front panel
(2) SFP port
(3) SFP+ port
(4) Console port
(5) USB port
(7) Type-C USB console port
(14) SFP+ port LED
(15) SFP port LED
Figure2-30 Rear panel
(1) Grounding screw
S5136S-24FP4T4S-EI
Figure2-31 Front panel
(2) SFP port
(3) Console port
(4) USB port
(13) SFP port LED
Figure2-32 Rear panel
(1) Grounding screw
S5136S-24P4X-EI
Figure2-33 Front panel
(2) SFP+ port
(3) Console port
(4) USB port
(13) SFP+ port LED
Figure2-34 Rear panel
(1) Grounding screw
S5136S-48FP4S-EI
Figure2-35 Front panel
(4) Mode LED (MODE)
(5) Console port
(7) USB port
(12) SFP port LED
(13) SFP port
Figure2-36 Rear panel
(1) Grounding screw
S5136S-48FP4X-EI
Figure2-37 Front panel
(4) Mode LED (MODE)
(5) Console port
(7) USB port
(12) SFP+ port LED
(13) SFP+ port
Figure2-38 Rear panel
(1) Grounding screw
S5136S-48P4S-EI
Figure2-39 Front panel
(4) Mode LED (MODE)
(5) Console port
(7) USB port
(12) SFP port LED
(13) SFP port
Figure2-40 Rear panel
(1) Grounding screw
S5136S-48P4X-EI
Figure2-41 Front panel
(4) Mode LED (MODE)
(5) Console port
(7) USB port
(12) SFP+ port
(13) SFP+ port LED
Figure2-42 Rear panel
(1) Grounding screw
S5136S-8UN2X-EI
Figure2-43 Front panel
(2) SFP+ port
(3) Console port
(5) USB port
(13) SFP+ port LED
Figure2-44 Rear panel
(1) Grounding screw
S5136S-8FP4UN4X-EI
Figure2-45 Front panel
(2) 2.5G/1000/100BASE-T autosensing Ethernet port
(3) SFP+ port
(4) Console port
(5) Management Ethernet port
(6) USB port
(13) Management Ethernet port LED (LINK/ACT)
(14) SFP+ port LED
(15) 2.5G/1000/100BASE-T autosensing Ethernet port LED
Figure2-46 Rear panel
(1) Grounding screw
Some switch models use removable power supplies. Table3-1 describes the removable components available for the switch.
Table3-1 Compatibility matrix between switches and removable components
Removable component model
S5136S-24S8T4X-EI
S5136S-48ST4X-EI
S5136S-48S2T4X-EI
CA-70A12
Supported
PSR75-12A
Supported
PSR180-12D-B
Supported
One power supply can meet the power requirement of the switch. You can install two power supplies on the switch for 1+1 redundancy. The device supports installation of both an AC power supply and a DC power supply.
The removable components available for the switch are subject to change over time. For the most recent list of the removable components, see the release notes for the switch.
You can use the display device manuinfo power command to read the electrical label information of the power supplies. The CA-70A12 power supply does not support electrical label information reading.
View
Figure4-1 CA-70A12 power supply view
Functions
The CA-70A12 is an AC and DC input and DC output power supply. It provides a maximum output of 70 W.
Table4-1 CA-70A12 power supply features
Feature
Protection function
The power supply provides protection against input overcurrent, input undervoltage, output overvoltage, output current limiting, output shortcircuit, and overtemperature conditions.
Support for redundancy
Two power supplies can be connected in parallel to achieve 1+1 redundancy and load balancing.
Support for hot swapping
You can remove one of the power supplies in 1+1 redundancy when the switch is operating.
Table4-2 Technical specifications
Item
Specification
Dimensions (H × W × D, including the handle)
41.1 × 101.6 × 207 mm (1.62 × 4.00 × 8.15 in)
Weight
0.6 kg (1.32 lb)
Rated input voltage range
AC input: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
HVDC input: 240 VDC
Max input voltage range
AC input: 90 VAC to 290 VAC @ 47 Hz to 63 Hz
HVDC input: 180 VDC to 320 VDC
Rated input current
N/A
Rated output current
5.83 A
Rated output voltage
12 V
Rated output power
70 W
10 A/250 V
View
Figure4-2 PSR75-12A power supply view
(1) Mounting screws
(2) Power input receptacle
(3) Latch
(4) Handle
Functions
The PSR75-12A is an AC and DC input and DC output power supply. It provides a maximum output of 75 W.
Table4-3 PSR75-12A power supply features
Feature
Protection function
Table4-4 Technical specifications
Item
Specification
Weight
0.72 kg (1.59 lb)
HVDC input: 240 VDC
Rated input current
N/A
6.3 A
12 V
Rated output power
75 W
3.15 A/250 V
View
Figure4-3 PSR180-12D-B power supply view
Functions
The PSR180-12D-B is a DC input and DC output power supply. It provides a maximum output of 180 W.
Table4-5 PSR180-12D-B power supply features (1)
Feature
Protection function
The power supply provides protection against output overvoltage, shortcircuit, current limiting, and overtemperature conditions.
You can remove one of the power supplies in 1+1 redundancy when the switch is operating. Before removing the power supply, disconnect the power supply from the external power supply system.
Table4-6 PSR180-12D-B power supply features (2)
Protection function
PSR180-12D-B
Protection state
Support for auto-recovery
Protection function
The power supply is locked and does not supply power.
Not supported.
Shortcircuit protection
Not supported.
Overcurrent protection
Not supported.
Overtemperature protection
The power supply does not supply power.
The power supply automatically restores power supply after the temperature decreases to an acceptable range.
After a power supply is locked, it cannot automatically restore power supply after the problems are resolved. Follow this procedure to restore the power supply operation:
1.     Disconnect the power cord from the external power supply system.
2.     Disconnect the power cord from the power supply and then reconnect it.
3.     Connect the power cord to the external power supply system.
Table4-7 Technical specifications
Item
Specification
101.6 × 41.1 × 177 mm (4.00 × 1.62 × 6.97 in)
Weight
0.8 kg (1.76 lb)
–48 VDC to –60 VDC
–36 VDC to –72 VDC
Rated input current
N/A
15 A
12 V
Rated output power
180 W
8 A/125 V
5 Ports and LEDs
Ports
Console port
Table5-1 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal
·     Provides connection to the serial port of a local PC running terminal emulation program
Compatible switch models
All switch models
Table5-2 Type-C USB console port specifications
Item
Specification
Connector type
USB Type-C
Compliant standard
USB2.0
Port transmission rate
Services
All switch models
The switch has one management Ethernet port on the front panel. You can connect the port to a local PC for software loading and debugging or to a remote management station for remote management.
Table5-3 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
Transmission rate, duplex mode, and auto MDI/MDI-X
·     10 Mbps, half/full-duplex
·     100 Mbps, half/full-duplex
·     MDI/MDI-X, autosensing
Transmission medium
Category-5 or above twisted pair cable
Max transmission distance
100 m (328.08 ft)
Compliant standard
IEEE 802.3i
IEEE 802.3u
IEEE 802.3ab
Functions and services
Used for upgrading and managing applications and Boot ROM
All switch models
File transfer through the management Ethernet port on the switch is relatively slow
USB port
Table5-4 USB port specifications
Item
Specification
Port type
USB 2.0
Compliant standard
OHC
Uploads and downloads data at a rate up to 480 Mbps
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files
All switch models
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
Table5-5 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     1000 Mbps, full-duplex
100 m (328.08 ft)
Transmission medium
Compliant standard
IEEE 802.3i
IEEE 802.3u
IEEE 802.3ab
All switch models
The S5136S-8N2X-EI, S5136S-8UN2X-EI, and S5136S-8FP4UN4X-EI switches provide 2.5G/1000/100BASE-T autosensing Ethernet ports.
Table5-6 2.5G/1000/100BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     1/2.5 Gbps, full-duplex
·     2.5 Gbps: 100 m (328.08 ft)
·     1 Gbps: 140 m (459.32 ft)
·     100 Mbps: 200 m (656.17 ft)
The maximum transmission distance between a PSE and PD depends on the peer device capacity and the twisted pair cable quality.
Transmission medium
Category-5e or above twisted pair cable
Compliant standard
IEEE 802.3u
IEEE 802.3ab
IEEE 802.3bz
S5136S-8N2X-EI
S5136S-8UN2X-EI
S5136S-8FP4UN4X-EI
SFP port
Table5-7 SFP port specifications
Item
Specification
Available transceiver modules and cables
·     See FE SFP transceiver modules described in Table5-8
·     See GE SFP transceiver modules and cables described in Table5-9
·     See 2.5GE SFP transceiver modules and cables described in Table5-11
S5136S-8FP4XS-EI-Q, S5136S-8T4XS-EI-Q, S5136S-24T4S-EI-Q, S5136S-48T4S-EI-Q, S5136S-24FP4S4X-EI, S5136S-24FP4T4S-EI, S5136S-24S8T4X-EI, S5136S-48FP4S-EI, S5136S-48P4S-EI, S5136S-48S2T4X-EI, S5136S-48ST4X-EI
·     To use the SFP-GE-T, SFP-GE-T-D, or transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on the following switch models, make sure the ambient temperature does not exceed 40°C (104°F).
¡     S5136S-8T4XS-EI-Q
¡     S5136S-8FP4XS-EI-Q
¡     S5136S-48T4S-EI-Q
¡     S5136S-48S2T4X-EI
¡     S5136S-48ST4X-EI
¡     S5136S-24S8T4X-EI
¡     S5136S-24T4S-EI-Q
·     When you use the following transceiver modules on an S5136S-48S2T4X-EI or S5136S-48ST4X-EI switch, make sure the number of the transceiver modules does not exceed 30.
¡     SFP-GE-T.
¡     SFP-GE-T-D.
¡     Transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles).
·     The S5136S-8T4XS-EI-Q, S5136S-8FP4XS-EI-Q, S5136S-48T4S-EI-Q, S5136S-24T4S-EI-Q, S5136S-48P4S-EI, and S5136S-48FP4S-EI switches do not support FE SFP transceiver modules.
·     Only the SFP ports on the following models support 2.5GE SFP transceiver modules: S5136S-8T4XS-EI-Q, S5136S-24T4S-EI-Q, S5136S-48T4S-EI-Q, S5136S-8FP4XS-EI-Q, S5136S-48FP4S-EI, and S5136S-48P4S-EI. However, the port speed can only be autonegotiated as 2500 Mbps and cannot be configured as 2500 Mbps.
Table5-8 FE SFP transceiver modules available for the SFP ports
Central wavelength (nm)
Connector
Fiber type and diameter (µm)
SFP-FE-SX-MM1310-A
1310
LC
Multi-mode, 50/125
2 km (1.24 miles)
Multi-mode, 62.5/125
SFP-FE-LX-SM1310-A
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
Single-mode, 9/125
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
Single-mode, 9/125
80 km (49.71 miles)
SFP-FE-LX-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-BX15-U-SM1310
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
IMPORTANT
IMPORTANT:
The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-FE-LX-SM1550-BIDI transceiver module.
Table5-9 GE SFP transceiver modules and cables available for the SFP ports (1)
GE SFP transceiver module/cable
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz*km)
Max. transmission distance
SFP copper transceiver modules
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP optical transceiver modules
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500/400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
·     As a best practice, use H3C transceiver modules and cables for the switch.
·     The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff.
·     For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
Table5-10 GE SFP transceiver modules and cables available for the SFP ports (2)
Connector
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-I
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-I
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500/400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX10-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH20-SM1310-I
1310
LC
Single-mode, 9/125
N/A
20 km ( 12.43 miles)
SFP-GE-LH40-SM1310-I
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-I
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-BIDI-S
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI-S
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-BIDI-I
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI-I
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH20-SM1310-BIDI-I
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
SFP-GE-LH20-SM1490-BIDI-I
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
TX: 1310
RX: 1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
TX: 1550
RX: 1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-BIDI-I
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1490-BIDI-I
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules , and the SFP-GE-LX-SM1310-BIDI-S and SFP-GE-LX-SM1490-BIDI-S transceiver modules, and the SFP-GE-LX-SM1310-BIDI-I and SFP-GE-LX-SM1490-BIDI-I transceiver modules, and the SFP-GE-LH20-SM1310-BIDI-I and SFP-GE-LH20-SM1490-BIDI-I transceiver modules, and the SFP-GE-LH40-SM1310-BIDI-I and SFP-GE-LH40-SM1490-BIDI-I transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
Table5-11 2.5GE SFP transceiver modules
Connector
SFP-2.5G-LX10-SM1310-DR
1310
LC
Single-mode, 9/125
10 km (6.21 miles)
SFP-2.5G-LX10-SM1310-DR-L
1310
LC
Single-mode, 9/125
10 km (6.21 miles)
SFP-2.5G-LX10-SM1310-DR-I
1310
LC
Single-mode, 9/125
10 km (6.21 miles)
SFP-2.5G-LX10-SM1310-DR-I-F
1550
LC
Single-mode, 9/125
10 km (6.21 miles)
SFP+ port
Table5-12 SFP+ port specifications (1)
Item
Specification
·     See 10GE SFP+ transceiver modules and cables described in Table5-14 and Table5-16
S5136S-8FP4XS-EI-Q, S5136S-10FPT4X-EI-Q, S5136S-8T4XS-EI-Q, S5136S-10T4X-EI-Q, S5136S-16T4X-EI-Q, S5136S-24T4X-EI-Q, S5136S-48T4X-EI-Q, S5136S-16FP4X-EI, S5136S-24FP4S4X-EI, S5136S-24P4X-EI, S5136S-24S8T4X-EI, S5136S-48FP4X-EI, S5136S-48P4X-EI, S5136S-48S2T4X-EI, S5136S-48ST4X-EI
¡     S5136S-8T4XS-EI-Q
¡     S5136S-10T4X-EI-Q
¡     S5136S-10FPT4X-EI-Q
¡     S5136S-48T4X-EI-Q
¡     S5136S-48S2T4X-EI
¡     S5136S-48ST4X-EI
¡     S5136S-24S8T4X-EI
¡     S5136S-24T4X-EI-Q
¡     S5136S-16T4X-EI-Q
¡     SFP-GE-T.
¡     SFP-GE-T-D.
·     The following switches do not support the SFP-XG-CPRI-IR-SM1310 and SFP-XG-CPRI-LR-SM1310 transceiver modules:
¡     S5136S-48S2T4X-EI
¡     S5136S-48ST4X-EI
¡     S5136S-24S8T4X-EI
¡     S5136S-24T4X-EI-Q
¡     S5136S-16T4X-EI-Q
¡     S5136S-24T4S-EI-Q
·     After SFP+ ports are installed with 2.5GE SFP transceiver modules, the port speed can only be autonegotiated as 2500 Mbps and cannot be configured as 2500 Mbps.
Table5-13 SFP+ port specifications (2)
Item
Specification
·     See GE SFP transceiver modules and cables described in Table5-10
·     See 10GE SFP+ transceiver modules and cables described in Table5-15 and Table5-16
S5136S-8N2X-EI, S5136S-8UN2X-EI, S5136S-8FP4UN4X-EI
·     To use the SFP-GE-T, SFP-GE-T-I, or transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on the following switch models, make sure the ambient temperature does not exceed 40°C (104°F).
¡     S5136S-8N2X-EI
¡     S5136S-8UN2X-EI
¡     S5136S-8FP4UN4X-EI
·     The S5136S-8FP4UN4X-EI switch does not support the SFP-10GE-T copper transceiver module.
Table5-14 10GE SFP+ transceiver modules available for the SFP+ ports (1)
Connector
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-S
1310
LC
Single-mode
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
1310
LC
Single-mode, 9/125
N/A
1.4 km (0.87 miles)
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH80-SM1490-BIDI
Tx: 1490
Rx: 1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-BIDI
Tx: 1550
Rx: 1490
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, and SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table5-15 10GE SFP+ transceiver modules available for the SFP+ ports (2)
Connector
SFP-XG-SX-MM850-A
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-S
1310
LC
Single-mode
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-S
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
1310
LC
Single-mode, 9/125
N/A
1.4 km (0.87 miles)
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Tx: 1490
Rx: 1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
Tx: 1550
Rx: 1490
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XGSPON-STICK-N2-SM1270-I
Tx: 1270
Rx: 1577
SC
Single-mode, 9/125
N/A
SFP-XG-LX-SM1271-A
1271
LC
Single-mode, 9/125
N/A
8 km (4.97 miles)
SFP-XG-LX-SM1291-A
1291
LC
Single-mode, 9/125
N/A
8 km (6.21 miles)
SFP-XG-LX-SM1311-A
1311
LC
Single-mode, 9/125
N/A
8 km (6.21 miles)
SFP-XG-LX-SM1331-A
1331
LC
Single-mode, 9/125
N/A
8 km (6.21 miles)
SFP+ copper transceiver modules
SFP-10GE-T
N/A
RJ-45
Category 6a STP/Category 7 twisted pair cable
N/A
30 m (98.43 ft)
IMPORTANT
IMPORTANT:
Table5-16 10GE SFP+ copper and fiber cables available for the SFP+ ports
10GE SFP+ cable
Cable length
SFP+ copper cable
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
SFP+ fiber cable
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure5-1 SFP+ cable
(1) Connector
(2) Pull latch
Combo interface
An S5136S-48S2T4X-EI switch provides two fixed combo interfaces on the front panel. An S5136S-24FP4S4X-EI or S5136S-24FP4T4S-EI switch provides four fixed combo interfaces on the front panel. An S5136S-24S8T4X-EI switch provides eight fixed combo interfaces on the front panel.
Each combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports operates at a time.
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table5-17 System status LED description
LED mark
Status
SYS
Steady yellow
Boot ROM booting stage.
Steady green
Linux kernel booting stage, or the switch has started up correctly.
Flashing green (1 Hz)
Software image loading and decompressing stage, or software booting stage.
Steady red
The switch has failed POST or the switch is faulty.
Off
The switch is powered off or has not started up correctly.
Table5-18 Management Ethernet port LED description
LED mark
Status
ACT/LINK
Steady green
A link is present on the port.
Flashing green
The port is receiving or sending data.
Off
No link is present on the port.
The S5136S-24S8T4X-EI, S5136S-48S2T4X-EI, and S5136S-48ST4X-EI switches each provide two removable power supply slots on the rear panel. The power supply status LEDs on the front panel indicate the operating status of the power supplies.
Table5-19 Power supply status LED description
LED mark
Status
PWR1/PWR2
Steady green
A power supply is installed in the power supply slot, and the power supply is outputting power correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply is faulty or not powered on.
Off
No power supply is installed in the power supply slot.
Mode LED
The mode LED works in conjunction with the port LEDs to indicate the operating state of the ports and the switch.
·     The mode LED indicates the type of information that the port LEDs are showing.
·     You can use the mode button to change the indication of the mode LED. After you press the mode button for the mode LED to steady yellow, flashing green, or flashing yellow, the mode LED keeps that state for only 45 seconds and then turns steady green automatically.
·     You can use the mode button to change the indication of the mode LED. After you press the mode button for the mode LED to steady yellow, the LED for the uplink port turns off and is not displayed.
·     With the push-button mode enable command executed on the device, if you press the mode button for 5 to 10 seconds, the device will be deployed to Cloudnet or will be disconnected from Cloudnet based on the connection status with Cloudnet. Pressing the mode button for up to 5 seconds can change the port information for the port LED. Pressing the mode button for more than 10 seconds does not take effect, because the device is not managed by Cloudnet or has been disconnected from Cloudnet.
Table5-20 Mode LED description
LED mark
Status
MODE
Steady green
The port LEDs are showing link state of the ports.
Flashing green
The port LEDs are showing the PoE status of the ports.
Steady yellow
The port LEDs are showing the duplex status of the ports.
Flashing yellow
The port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 3 is steady green, the IRF member ID of the switch is 3.
SFP/SFP+ port LED
Table5-21 SFP/SFP+ port LED description
LED status
Steady green
Flashing green
Off
·     No link is present on the port.
·     The mode LED is operating in PoE mode (available only for PoE switch models).
·     The mode LED is operating in duplex mode.
Table5-22 2.5G/1000/100BASE-T autosensing Ethernet port LED description
Mode LED status
2.5G/1000/100BASE-T autosensing Ethernet port LED status
Steady green (link/active mode)
Steady green
Flashing green
The port is sending or receiving data.
Off
Flashing green (PoE mode, available only for PoE models)
Steady green
Normal PoE power supply.
·     The device attached to the port requires power higher than the maximum PoE output power of the port.
·     PoE overvoltage, overcurrent, or short circuit has occurred.
·     The remaining power of the switch is not sufficient for the PoE output requirement of the port.
Off
No link is present on the port, or PoE is not enabled on the port.
Flashing yellow (IRF mode)
Off
The Ethernet port LEDs work in conjunction with the mode LED to indicate the operating state of the Ethernet ports and the switch from different aspects. Table5-23 describes the Ethernet port LEDs on a PoE switch. Table5-24 describes the Ethernet port LEDs on a non-PoE switch.
Table5-23 Ethernet port LED description for PoE switch models
Mode LED status (MODE)
Steady green (Link/Active mode)
Steady green
Flashing green
Off
Flashing green (PoE mode)
Steady green
PoE power supply is normal.
·     The maximum PoE power provided by the port fails to meet the power requirement of the PD.
·     PoE power supply overcurrent, overvoltage, or shortcircuit occurs.
·     The remaining power of the switch fails to meet the power supply requirement of the port.
Off
The port is not connected to a PD or PoE is not enabled on the port.
Steady yellow
Steady green
The downlink port is operating in half duplex mode.
Flashing green
The downlink port is operating in full duplex mode.
Off
No link is present on the downlink port.
Steady green
The Ethernet port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green, the IRF member ID of the switch is 5.
Table5-24 Ethernet port LED description for non-PoE switch models
Steady green
Flashing green
Off
Steady yellow
Steady green
Flashing green
Off
Steady green
Table5-25 Cloudnet management status LED description
LED status
Steady blue
The switch has been managed by Cloudnet.
Flashing blue (1 Hz)
The switch is being connected to Cloudnet.
Flashing blue (3 Hz)
Invalid action. The switch is not managed by Cloudnet or has been disconnected from Cloudnet.
Off
The switch is not connected to Cloudnet.
Location LED
To identify the switch location, execute the locator blink blink-time command. This LED will flash blue at 1 Hz.
6 Buttons
Reset button
Figure6-1 Reset button description
Button
Reset button
·     To reboot the switch, press and hold the button for less than 5 seconds and release the button when the SYS LED flashes red slowly (1 Hz).
·     To restore the factory default and reboot the switch, press and hold the button for more than 5 seconds and release the button when the SYS LED flashes red rapidly (8 Hz). After the switch joins an IRF fabric, the operation does not take effect and the system generates a message. To restore the factory default and reboot the switch via the reset button, first remove the switch from the IRF fabric.
7 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
Table7-1 Cooling system
Switch model
Fan tray type
Airflow direction
S5136S-8FP4XS-EI-Q
S5136S-8T4XS-EI-Q
S5136S-10FPT4X-EI-Q
S5136S-10T4X-EI-Q
S5136S-16T4X-EI-Q
S5136S-24T4S-EI-Q
S5136S-24T4X-EI-Q
S5136S-48T4S-EI-Q
S5136S-48T4X-EI-Q
S5136S-8N2X-EI
S5136S-8FP4UN4X-EI
Fanless
Passive cooling
S5136S-16FP4X-EI
S5136S-24FP4S4X-EI
S5136S-24FP4T4S-EI
S5136S-24P4X-EI
S5136S-24S8T4X-EI
S5136S-48FP4S-EI
S5136S-48FP4X-EI
S5136S-48P4S-EI
S5136S-48P4X-EI
S5136S-48S2T4X-EI
S5136S-48ST4X-EI
S5136S-8UN2X-EI
Fixed fans
From the left side to the right side
Figure7-1 Airflow through the S5136S-48S2T4X-EI chassis
