| 01-Hardware Information and Specifications | 3.22 MB |
1 Product models and technical specifications
S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G-Q)
S5130S-36F-EI-G/S5130S-36S-EI-G/S5130S-54S-EI-G
S5130S-30C-EI-G/S5130S-54C-EI-G
S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G)/S5130S-52MS-EI-G
S5130S-36S-PWR-EI-G/S5130S-54S-PWR-EI-G/S5130S-32MS-PWR-EI-G/S5130S-52MS-PWR-EI-G
S5130S-8UN40PN6X-EI-G/S5130S-8UN16PN12X-EI-G
3 FRUs and compatibility matrixes
SFP port (applicable to the S5130S-36F-EI-G switch)
10/100/1000BASE-T Ethernet port
2.5G/1000/100/10BASE-T autosensing Ethernet port
Removable power supply status LED
10/100/1000BASE-T autosensing Ethernet port LED
2.5G/1000/100/10BASE-T autosensing Ethernet port LED
Port LED on an interface module
Cloudnet management status LED
Product models
Table1-1 describes the S5130S-EI-G switch series models.
Table1-1 S5130S-EI-G switch series models
Switch series |
Product code (PID) |
Model |
S5130S-EI-G switch series |
Non-PoE models |
LS-5130S-36F-EI-G |
S5130S-36F-EI-G |
LS-5130S-36S-EI-G |
S5130S-36S-EI-G |
LS-5130S-54S-EI-G |
S5130S-54S-EI-G |
LS-5130S-30C-EI-G |
S5130S-30C-EI-G |
LS-5130S-54C-EI-G |
S5130S-54C-EI-G |
LS-5130S-32MS-EI-G |
S5130S-32MS-EI-G |
LS-5130S-32MS-EI-G-Q |
LS-5130S-52MS-EI-G |
S5130S-52MS-EI-G |
LS-5130S-10T4X-EI-Q-G3 |
S5130S-10T4X-EI-Q-G |
LS-5130S-28T4X-EI-Q-G3 |
S5130S-28T4X-EI-Q-G |
LS-5130S-16T4X-EI-Q-G3 |
S5130S-16T4X-EI-Q-G |
PoE models |
LS-5130S-36S-PWR-EI-G |
S5130S-36S-PWR-EI-G |
LS-5130S-54S-PWR-EI-G |
S5130S-54S-PWR-EI-G |
LS-5130S-32MS-PWR-EI-G |
S5130S-32MS-PWR-EI-G |
LS-5130S-52MS-PWR-EI-G |
S5130S-52MS-PWR-EI-G |
LS-5130S-10PT4X-EI-Q-G3 |
S5130S-10PT4X-EI-Q-G |
LS-5130S-8UN40PN6X-EI-G1 |
S5130S-8UN40PN6X-EI-G |
LS-5130S-8UN16PN12X-EI-G1 |
S5130S-8UN16PN12X-EI-G |
NOTE: · Switches of the same model but different PIDs might differ in hardware and software features. You can view the PID of a switch on the label located on its rear panel or top panel. · To obtain the purchase information, see the product data sheet at https://www.h3c.com/en/Products_and_Solutions/InterConnect/Switches/ and pay attention to the switch product lifecycle management announcement at https://www.h3c.com/en/Support/Policy_Dynamics/Management_Strategy/Products_End_of_Life_Announcement/Switches/. · For information about product and software compatibility, see the release notes. |
Technical specifications
Table1-2 Technical specifications for the S5130S-EI-G non-PoE switch models (1)
Item |
S5130S-30C-EI-G |
S5130S-54C-EI-G |
Dimensions (H × W × D) |
43.6 × 440 × 360 mm (1.72 × 17.32 × 14.17 in) |
Weight |
≤ 5.0 kg (11.02 lb) |
Console port |
· 1 × micro USB console port · 1 × serial console port Only the micro USB console port is available when you connect both ports. |
USB port |
1 |
Management Ethernet port |
1 |
SFP+ port |
4 |
10/100/1000BASE-T autosensing Ethernet port |
24 |
48 |
Interface module slot |
1, on the rear panel |
Power supply slot |
2, on the rear panel |
Fan module slot |
Input voltage |
AC input for the PSR150-A power supply: · Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz · Max voltage range: 90 to 264 VAC @ 47 to 63 Hz DC input for the PSR150-D power supply: · Rated voltage range: –48 to –60 VDC · Max voltage range: –36 to –72 VDC You can use a –48 VDC power source in the equipment room or an H3C RPS. |
Power consumption (static) |
26 W |
35 W |
Power consumption (full load) |
61 W |
69 W |
Chassis leakage current compliance |
IEC60950-1/UL62368-1/EN62368-1/IEC62368-1/GB4943.1 |
Melting current of power supply fuse |
· PSR150-A: 5 A/250 V · PSR150-D: 8 A/250 V |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
Fire resistance compliance |
Table1-3 Technical specifications for the S5130S-EI-G non-PoE switch models (2)
Item |
S5130S-36F-EI-G |
S5130S-36S-EI-G |
S5130S-54S-EI-G |
44 × 440 × 260 mm (1.73 × 17.32 × 10.24 in) |
Weight |
≤ 3.5 kg (7.72 lb) |
≤ 3.9 kg (8.60 lb) |
Console port |
1 × serial console port |
USB port |
1 |
1 |
SFP+ port |
8 |
8 |
6 |
SFP port |
28 (The four highest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively) |
N/A |
N/A |
4 (each forms a combo interface with the corresponding SFP port) |
28 |
48 |
Input voltage |
· Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz · Max voltage range: 90 to 264 VAC @ 47 to 63 Hz |
· Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz · Max voltage range: 90 to 290 VAC @ 47 to 63 Hz |
Single AC input: 24 W Dual AC inputs: 25 W |
Single AC input: 22 W Dual AC inputs: 23 W |
Single AC input: 27 W Dual AC inputs: 27 W |
Single AC input: 63 W Dual AC inputs: 63 W |
Single AC input: 47 W Dual AC inputs: 47 W |
Single AC input: 60 W Dual AC inputs: 61 W |
UL62368-1/EN62368-1/IEC62368-1/UL60950-1/IEC60950-1/GB4943.1 |
3.15 A/250 V |
–5°C to +45°C (23°F to 113°F) |
Table1-4 Technical specifications for the S5130S-EI-G non-PoE switch models (3)
Item |
S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G-Q) |
Physical specifications |
44 × 266 × 160 mm (1.73 × 10.47 × 6.30 in) |
Dimensions (H × W × D, with package materials) |
92 × 352 × 264 mm (3.62 × 13.86 × 10.39 in) |
155 × 585 × 370 mm (6.10 × 23.03 × 14.57 in) |
Weight |
≤ 1.5 kg (3.31 lb) |
≤ 4.0 kg (8.82 lb) |
Technical specifications |
Memory (RAM) |
1 GB |
Flash |
8 GB |
4 GB |
Port types and quantity |
Console port |
1 |
USB port |
1 |
1 |
SFP+ port |
4 |
2 |
2.5G SFP port |
N/A |
2 |
10 |
28 |
Power supply specifications |
Power input type |
AC input |
Input voltage |
UL62368-1/EN62368 -1/IEC62368 -1/GB4943.1 |
2 A/250 V |
3.15 A/250 V |
System power consumption |
Power consumption (static) Data collection standard: no load |
18 W |
22 W |
Power consumption (typical) Data collection standard: fully configured with copper cables or network cables, 30% traffic |
24 W |
37 W |
Power consumption (full load) Data collection standard: fully configured with transceiver modules or network cables, 100% traffic |
28 W |
40 W |
System thermal consumption |
Thermal consumption (static) Data collection standard: no load |
62 BTU/h |
76 BTU/h |
Thermal consumption (typical) Data collection standard: fully configured with copper cables or network cables, 30% traffic |
82 BTU/h |
127 BTU/h |
Thermal consumption (full load) Data collection standard: fully configured with transceiver modules or network cables, 100% traffic |
96 BTU/h |
137 BTU/h |
Heat dissipation |
Heat dissipation method |
Fanless, passive cooling |
Ventilation aisles |
N/A |
Reliability and availability |
Mean time between failure (MTBF) (year) |
271.8 |
178.4 |
Mean time to repair (MTTR) (hour) |
1 |
Availability |
99.999958% |
99.999936% |
Environment specifications |
Sound pressure level at 27°C (80.6°F) |
N/A |
Altitude |
0 to 5000 m (0 to 16404.20 ft) |
–5°C to +45°C (23°F to 113°F) Note: The maximum acceptable temperature decreases by 0.33°C (0.59°F) for every 100 m (328.08 ft) increase in altitude from 0 m (0 ft). |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Compliance |
Product compliance |
· Safety standards · EMC standards · Environmental and eco-friendly standards |
Table1-5 Technical specifications for the S5130S-EI-G non-PoE switch models (4)
Item |
S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G) |
S5130S-52MS-EI-G |
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in) |
Weight |
≤ 3.4 kg (7.50 lb) |
≤ 3.7 kg (8.16 lb) |
Console port |
· 1 |
USB port |
1 |
1 |
2.5G SFP port |
2 |
SFP+ port |
4 |
28 |
48 |
Input voltage |
23 W |
26 W |
Power consumption (typical) |
33 W |
49 W |
46 W |
59 W |
3.15 A/250 V |
Table1-6 Technical specifications for the S5130S-EI-G non-PoE switch models (5)
Item |
44 × 330 × 230 mm (1.73 × 12.99 × 9.06 in) |
155 × 585 × 370 mm ( 6.10 × 23.03 × 14.57 in) |
125 × 430 × 350 mm (4.92 × 16.93 × 13.78 in) |
Weight |
≤ 5.2 kg (11.46 lb) |
≤ 3.8 kg (8.38 lb) |
Memory (RAM) |
1 GB |
Flash |
8 GB |
Console port |
1 |
USB port |
1 |
1 |
SFP+ port |
4 |
28 |
16 |
Power input type |
AC input |
Input voltage |
· Rated voltage range: 100 to 240 VAC · Max voltage range: 90 to 264 VAC |
3.15 A/250 V |
20 W |
16 W |
34 W |
26 W |
43 W |
31 W |
69 BTU/h |
55 BTU/h |
117 BTU/h |
89 BTU/h |
147 BTU/h |
106 BTU/h |
Heat dissipation |
N/A |
MTBF (year) |
190.3 |
228.3 |
MTTR (hour) |
1 |
Availability |
99.99994% |
99.99995% |
N/A |
Altitude |
Compliance |
Table1-7 Technical specifications for the S5130S-EI-G PoE switch models (1)
Item |
43.6 × 440 × 320 mm (1.72 × 17.32 × 12.60 in) |
Weight |
≤ 4.5 kg (9.92 lb) |
≤ 4.8 kg (10.58 lb) |
Console port |
USB port |
1 |
1 |
SFP+ port |
8 |
6 |
28 |
48 |
Input voltage |
AC input · Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz · Max voltage range: 90 to 290 VAC @ 47 to 63 Hz |
Max PoE power per port |
30 W |
Total PoE power |
370 W |
Single AC input: 28 W |
Single AC input: 35 W |
N/A |
Single AC input: 477 W |
Single AC input: 498 W |
10 A/250 V |
Table1-8 Technical specifications for the S5130S-EI-G PoE switch models (2)
Item |
Weight |
Console port |
USB port |
1 |
1 |
2.5G SFP port |
2 |
2 |
SFP+ port |
2 |
2 |
28 |
48 |
Input voltage |
30 W |
Total PoE power |
370 W |
Single AC input: 27 W |
Single AC input: 34 W |
Single AC input: 42 W |
Single AC input: 58 W |
10 A/250 V |
Table1-9 Technical specifications for the S5130S-EI-G PoE switch models (3)
Item |
Weight |
≤ 2.5 kg (5.51 lb) |
Memory (RAM) |
1 GB |
Flash |
8 GB |
Console port |
USB port |
1 |
1 |
SFP+ port |
4 |
10 Note: Only ports 1 to 8 support PoE |
Power input type |
AC input |
Input voltage |
6.3 A/250 V |
22 W |
29 W |
Power consumption (full load) Data collection standard: fully configured with transceiver modules or network cables, 100% traffic, PoE at full load |
170 W |
PoE power capacity |
30 W |
Total PoE power |
120 W |
76 BTU/h |
99 BTU/h |
Thermal consumption (full load) Data collection standard: fully configured with transceiver modules or network cables, 100% traffic, PoE at full load |
581 BTU/h |
Heat dissipation |
N/A |
MTBF (year) |
173 |
MTTR (hour) |
1 |
Availability |
99.999934% |
N/A |
Altitude |
Compliance |
Table1-10 Technical specifications for the S5130S-EI-G PoE switch models (4)
Item |
44 × 440 × 320 mm (1.73 × 17.32 × 12.60 in) |
155 × 585 × 430 mm (6.10 × 23.03 × 16.93 in) |
Weight |
≤ 4.3 kg (9.48 lb) |
Memory (RAM) |
1 GB |
1 GB |
Flash |
8 GB |
8 GB |
Console port |
USB port |
1 |
1 |
1 |
1 |
SFP+ port |
6 |
12 |
2.5G/1000/100/10BASE-T autosensing Ethernet port |
48 Note: Ports 1 to 8 support PoE++, and ports 9 to 48 support PoE+. |
24 Note: Ports 1 to 8 support PoE++, and ports 9 to 24 support PoE+. |
Power input type |
AC input |
AC input |
Input voltage |
10 A/250 V |
16 A/250 V |
39 W |
39 W |
97 W |
64 W |
845 W |
438 W |
Ports 1 to 8: 100 W Ports 9 to 48: 35 W |
Ports 1 to 8: 100 W Ports 9 to 24: 35 W |
Total PoE power |
740 W |
370 W |
331 BTU/h |
218 BTU/h |
379 BTU/h |
303 BTU/h |
2986 BTU/h |
1495 BTU/h |
Heat dissipation |
Fixed fans |
Fixed fans |
Left-to-right air aisle |
MTBF (year) |
33 |
28 |
MTTR (hour) |
1 |
1 |
Availability |
99.9997% |
99.9996% |
51.9 dB |
51.9 dB |
Altitude |
Compliance |
2 Chassis views
Front panels
S5130S-10T4X-EI-Q-G
Figure2-1 S5130S-10T4X-EI-Q-G front panel
(1) 10/100/1000BASE-T autosensing Ethernet port |
(2) SFP+ port |
(3) Management Ethernet port |
(4) Console port |
(5) USB port |
(6) Mode button (Cloudnet management status LED) |
(7) Mode LED (MODE) |
(8) System status LED (SYS) |
(9) Management Ethernet port LED (LINK/ACT) |
(10) SFP+ port LED |
(11) 10/100/1000BASE-T autosensing Ethernet port LED |
Figure2-2 S5130S-10PT4X-EI-Q-G front panel
(2) SFP+ port |
(4) Console port |
(5) USB port |
(7) Reset button (RESET) |
(8) Mode LED (MODE) |
(9) System status LED (SYS) |
(10) Management Ethernet port LED (LINK/ACT) |
(11) SFP+ port LED |
(12) 10/100/1000BASE-T autosensing Ethernet port LED |
S5130S-36F-EI-G
Figure2-3 S5130S-36F-EI-G front panel
(1) SFP port |
(2) SFP port LED |
(3) 10/100/1000BASE-T autosensing Ethernet port LED |
(4) SFP+ port |
(5) Management Ethernet port |
(6) Console port |
(7) Mode button |
(8) USB port |
(10) Mode LED (MODE) |
(11) AC power supply status LED (PWR2) |
(12) AC power supply status LED (PWR1) |
(13) Management Ethernet port LED (LINK/ACT) |
(14) SFP+ port LED |
(15) 10/100/1000BASE-T autosensing Ethernet port |
S5130S-36S-EI-G
Figure2-4 S5130S-36S-EI-G front panel
(2) 10/100/1000BASE-T autosensing Ethernet port LED |
(3) SFP+ port |
(4) Management Ethernet port |
(5) Console port |
(6) Mode button |
(7) USB port |
(9) Mode LED (MODE) |
(10) AC power supply status LED (PWR2) |
(11) AC power supply status LED (PWR1) |
(12) Management Ethernet port LED (LINK/ACT) |
(13) SFP+ port LED |
S5130S-54S-EI-G
Figure2-5 S5130S-54S-EI-G front panel
(3) Console port |
(4) Mode LED (MODE) |
(5) System status LED (SYS) |
(6) AC power supply status LED 1 (PWR1) |
(7) AC power supply status LED 2 (PWR2) |
(8) Mode button |
(9) USB port |
(11) Management Ethernet port |
(12) SFP+ port LED |
(13) SFP+ port |
S5130S-30C-EI-G
Figure2-6 S5130S-30C-EI-G front panel
(3) Management Ethernet port LED (ACT/LINK) |
(5) Console port |
(6) Micro USB console port |
(7) Mode button |
(8) USB port |
(10) SFP+ port |
(11) SFP+ port mode LED (MODE) |
(12) Interface module status LED (SLOT) |
(13) Power supply 2 status LED (PWR2) |
(14) Power supply 1 status LED (PWR1) |
(15) SFP+ port LED |
S5130S-54C-EI-G
Figure2-7 S5130S-54C-EI-G front panel
(5) Console port |
(7) Mode button |
(8) USB port |
(10) SFP+ port |
S5130S-32MS-EI-G
Figure2-8 S5130S-32MS-EI-G front panel
(3) 2.5G SFP port |
(4) Management Ethernet port (MGMT) |
(5) AC power supply status LED (PWR) |
(6) Console port |
(7) Mode button |
(8) USB port |
(12) SFP+ port |
(14) 2.5G SFP port LED |
S5130S-52MS-EI-G
Figure2-9 S5130S-52MS-EI-G front panel
(3) 2.5G SFP port |
(4) SFP+ port |
(5) Console port |
(6) System status LED (SYS) |
(7) AC power supply status LED (PWR) |
(9) Mode button |
(10) USB port |
(11) Management Ethernet port LED (LINK/ACT) |
(12) Management Ethernet port (MGMT) |
S5130S-28T4X-EI-Q-G
Figure2-10 S5130S-28T4X-EI-Q-G front panel
(2) SFP+ port |
(3) Management Ethernet port (MGMT) |
(4) Console port |
(5) USB port |
(10) Management Ethernet port LED (LINK) |
S5130S-16T4X-EI-Q-G
Figure2-11 S5130S-16T4X-EI-Q-G front panel
(2) SFP+ port |
(3) Console port |
(4) USB port |
(5) Mode button (Cloudnet management status LED) |
(6) Reset button (RESET) |
(10) Management Ethernet port (MGMT) |
S5130S-36S-PWR-EI-G
Figure2-12 S5130S-36S-PWR-EI-G front panel
(3) SFP+ port |
(5) Console port |
(6) Mode button |
(7) USB port |
(10) AC power supply status LED (PWR) |
S5130S-54S-PWR-EI-G
Figure2-13 S5130S-54S-PWR-EI-G front panel
(3) SFP+ port |
(4) SFP+ port LED |
(5) Console port |
(9) Mode button |
(10) USB port |
(12) Management Ethernet port |
Figure2-14 S5130S-32MS-PWR-EI-G front panel
(3) 2.5G SFP port |
(6) Console port |
(7) Mode button |
(8) USB port |
(12) SFP+ port |
Figure2-15 S5130S-52MS-PWR-EI-G front panel
(3) 2.5G SFP port |
(4) SFP+ port |
(5) Console port |
(9) Mode button |
(10) USB port |
Figure2-16 S5130S-8UN16PN12X-EI-G front panel
(1) 2.5G/1000/100/10BASE-T autosensing Ethernet port (PoE++) |
(2) 2.5G/1000/100/10BASE-T autosensing Ethernet port LED (PoE++) |
(3) 2.5G/1000/100/10BASE-T autosensing Ethernet port (PoE+) |
(4) 2.5G/1000/100/10BASE-T autosensing Ethernet port LED (PoE+) |
(5) SFP+ port |
(6) SFP+ port LED |
(7) Console port |
(8) USB port |
(9) Mode button |
(10) System status LED (SYS) |
(11) Mode LED (MODE) |
(12) Reset button (RESET) |
(13) ID LED (ID) |
(14) Management Ethernet port LED (LINK/ACT) |
(15) Management Ethernet port (MGMT) |
Figure2-17 S5130S-8UN40PN6X-EI-G front panel
(5) SFP+ port |
(6) SFP+ port LED |
(7) Console port |
(8) USB port |
(9) Mode button |
(13) ID LED (ID) |
Rear panels
S5130S-10T4X-EI-Q-G
Figure2-18 S5130S-10T4X-EI-Q-G rear panel
(1) Grounding screw |
(2) AC power receptacle |
(3) Reset button (RESET) |
Figure2-19 S5130S-32MS-EI-G rear panel
(1) AC power receptacle |
(2) Grounding screw |
Figure2-20 S5130S-54S-EI-G rear panel
(1) AC power receptacle 1 |
(2) AC power receptacle 2 |
(3) Grounding screw |
The rear views of the S5130S-36F-EI-G, S5130S-36S-EI-G, and S5130S-54S-EI-G switches are similar. This figure uses the S5130S-54S-EI-G switch as an example.
Figure2-21 S5130S-54C-EI-G rear panel
(2) Interface module |
(3) Fan module 1 |
(4) Fan module 2 |
(5) Power supply 1 |
(6) Power supply 2 |
The rear views of the S5130S-30C-EI-G and S5130S-54C-EI-G switches are similar. This figure uses the S5130S-54C-EI-G switch as an example.
The switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. For information about installing and removing power supplies, see H3C S5130S-EI-G Switch Series Installation Guide.
The switch came with the two fan module slots empty. In Figure2-21, two LSPM1FANSB fan modules are installed in the fan module slots. For information about installing and removing fan modules, see H3C S5130S-EI-G Switch Series Installation Guide.
The switch came with the interface module slot installed with a filler panel. You can select an interface module for the switch as required. For information about installing and removing interface modules, see H3C S5130S-EI-G Switch Series Installation Guide.
Figure2-22 S5130S-32MS-EI-G rear panel
The rear views of the S5130S-32MS-EI-G and S5130S-52MS-EI-G switches are similar. This figure uses the S5130S-32MS-EI-G switch as an example.
S5130S-28T4X-EI-Q-G
Figure2-23 S5130S-28T4X-EI-Q-G rear panel
S5130S-16T4X-EI-Q-G
Figure2-24 S5130S-16T4X-EI-Q-G rear panel
Figure2-25 S5130S-54S-PWR-EI-G rear panel
Figure2-26 S5130S-8UN40PN6X-EI-G/S5130S-8UN16PN12X-EI-G rear panel
Only the S5130S-30C-EI-G and S5130S-54C-EI-G switches use modular design and support FRUs.
Table3-1 FRUs and compatibility matrixes
FRUs |
S5130S-30C-EI-G |
S5130S-54C-EI-G |
Removable power supplies |
PSR150-A |
Supported |
Supported |
PSR150-D |
Supported |
Supported |
Removable fan modules |
LSPM1FANSA |
Supported |
Supported |
LSPM1FANSB |
Supported |
Supported |
Interface modules |
LSWM2SP4P |
Supported |
Supported |
The power supplies support asset management. You can use the display device manuinfo command to view the name, sequence number, and vendor of the power supplies you have installed on the switch.
On an S5130S-30C-EI-G or S5130S-54C-EI-G switch, you can install one power supply, or two power supplies for 1+1 redundancy. The switch supports installation of both an AC power supply and a DC power supply.
Table3-2 Removable power supplies
Power supply model |
Item |
Specification |
PSR150-A |
41.1 × 101.6 × 177 mm (1.62 × 4.00 × 6.97 in) |
AC input |
Rated input voltage range |
100 to 240 VAC @ 50 or 60 Hz |
Max input current |
2 A |
HVDC input |
Rated input voltage |
240 VDC |
Max input current |
2 A |
Output voltage |
12 V |
Max output current |
12.5 A |
Max power |
150 W |
PSR150-D |
–48 to –60 VDC |
Max input current |
6 A |
Output voltage |
12 V |
12.5 A |
Max power |
150 W |
Table3-3 Removable fan modules
Item |
LSPM1FANSA |
LSPM1FANSB |
Number of fans |
1 |
1 |
Dimensions (H × W × D, including the handle) |
41 × 40 × 105 mm (1.61 × 1.57 × 4.13 in) |
Max fan speed |
20000 R.P.M |
20000 R.P.M |
Max air flow rate |
20 CFM (0.57 m3/min) |
Input voltage |
12 V |
12 V |
Max power consumption |
9.8 W |
9.8 W |
Airflow direction |
Blows air from the power supply side to the port side |
Draws air from the port side to the power supply side |
Interface modules
Interface module model |
Item |
Specification |
LSWM2SP4P |
Name |
4-port 10GE SFP+ interface module |
Port quantity and type |
Four 1/10 Gbps SFP+ fiber ports |
Available transceiver modules and cables |
10GE SFP+ transceiver modules and SFP+ cables |
Reference |
H3C LSWM2SP4P Interface Card User Manual |
To connect cables to the ports on interface modules, follow these guidelines:
· Use category 6A or above cables and connectors.
· Do not bundle cables in their first 20 m (65.62 ft).
· Separate power cords and twisted pair cables at and around the distribution frame.
· For ports adjacent to one another on the device, the peer ports on the distribution frame is preferably not adjacent, for example:
¡ If the device connects to one distribution frame, connect port 1 on the device to port 1 on the distribution frame and port 2 on the device to port 3 on the distribution frame.
¡ If the device connects to two distribution frames, connect port 1 on the device to port 1 on distribution frame 1 and port 2 on the device to port 1 on distribution frame 2.
· Keep the device and cables away from the interference source.
4 Ports, LEDs, and buttons
Ports
Console port
Table4-1 Console port specifications
Item |
Connector type |
Serial console port |
RJ-45 |
USB micro-type B |
Compliant standard |
EIA/TIA-232 |
USB 2.0 |
Transmission baud rate |
9600 bps (default) to 115200 bps |
Supported services |
· Serial console port |
· Provides connection to an ASCII terminal. · Provides connection to the serial port of a local or remote terminal running a terminal emulation program |
· Micro USB console port |
· Provides connection to an ASCII terminal. · Provides connection to the USB port of a local terminal running a terminal emulation program |
Compatible switch models |
All switch models |
S5130S-30C-EI-G, S5130S-54C-EI-G |
Restrictions and guidelines |
The switch has one management Ethernet port on the front panel. You can connect the port to a local PC for software loading and debugging or to a remote management station for remote management.
Table4-2 Management Ethernet port specifications (applicable to the S5130S-30C-EI-G and S5130S-54C-EI-G switches)
Item |
Connector type |
RJ-45 |
· 10 Mbps, half/full duplex · 100 Mbps, half/full duplex · 1000 Mbps, full duplex · MDI/MDI-X autosensing |
Transmission medium |
Category 5 or above twisted pair cable |
Max transmission distance |
100 m (328.08 ft) |
IEEE 802.3i, 802.3u, 802.3ab |
Functions and services |
Connects to a computer or remote network management station for upgrading and managing applications and Boot ROM |
Table4-3 Management Ethernet port specifications (applicable to the switch models except for the S5130S-30C-EI-G and S5130S-54C-EI-G switches)
Item |
Connector type |
RJ-45 |
· 10 Mbps, full duplex · 100 Mbps, full duplex · 1000 Mbps, full duplex · MDI/MDI-X autosensing |
100 m (328.08 ft) |
USB port
Table4-4 USB port specifications
Item |
Port type |
USB2.0 |
OHCI |
Uploads and downloads data at a rate up to 480 Mbps |
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files |
All switch models |
NOTE: USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor. |
Table4-5 SFP port specifications
Item |
Port name |
1GE SFP fiber port |
S5130S-36F-EI-G |
Connector type |
LC/RJ-45 |
The 1GE SFP fiber ports support autosensing to 100 Mbps, and the ports are mainly used for transmitting and receiving GE/FE fiber port services |
IEEE 802.3ab |
· FE SFP transceiver modules described in Table4-6. · GE SFP transceiver modules and cables described in Table4-7. |
· When you use the SFP-GE-T or SFP-GE-T-D copper transceiver module, the ports can operate only at 1000 Mbps. · The S5130S-36F-EI-G switch supports a maximum of 14 GE copper transceiver modules (SFP-GE-T and SFP-GE-T-D). · The S5130S-36F-EI-G switch does not support the SFP-GE-LH100-SM1550, SFP-GE-LH40-SM1310-BIDI, SFP-GE-LH40-SM1550-BIDI, SFP-GE-LH70-SM1490-BIDI, and SFP-GE-LH70-SM1550-BIDI transceiver modules. |
Table4-6 FE SFP transceiver modules available for the SFP ports
Transceiver module model |
Central wavelength (nm) |
Connector type |
Cable/fiber type and diameter (µm) |
SFP-FE-SX-MM1310-A |
1310 |
LC |
50/125, MMF |
2 km (1.24 miles) |
62.5/125, MMF |
SFP-FE-LX-SM1310-A |
1310 |
LC |
9/125, SMF |
15 km (9.32 miles) |
SFP-FE-LH40-SM1310 |
1310 |
LC |
9/125, SMF |
40 km (24.86 miles) |
SFP-FE-LX-SM1310-BIDI |
TX: 1310 RX: 1550 |
LC |
9/125, SMF |
SFP-FE-LX-SM1550-BIDI |
TX: 1550 RX: 1310 |
LC |
9/125, SMF |
IMPORTANT: The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-FE-LX-SM1550-BIDI transceiver module. |
Table4-7 GE SFP transceiver modules and cables available for the SFP ports
Transceiver module/cable type |
Transceiver module/cable model |
Connector type |
Mode bandwidth (MHz*km) |
SFP copper transceiver module |
SFP-GE-T |
N/A |
RJ-45 |
Twisted pair cable |
N/A |
100 m (328.08 ft) |
SFP-GE-T-D |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP optical transceiver module |
SFP-GE-SX-MM850-A |
850 |
LC |
50/125, MMF |
500 |
550 m (1804.46 ft) |
400 |
500 m (1640.42 ft) |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-D |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-LX-SM1310-A |
1310 |
LC |
9/125, SMF |
N/A |
10 km (6.21 miles) |
50/125, MMF |
500/400 |
62.5/125, MMF |
500 |
SFP-GE-LH40-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1310-D |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH80-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
80 km (49.71 miles) |
SFP-GE-LH80-SM1550-D |
1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH100-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
TX: 1310 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1490-BIDI |
TX: 1490 RX: 1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1310-BIDI |
TX: 1310 RX: 1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1550-BIDI |
TX: 1550 RX: 1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH70-SM1490-BIDI |
TX: 1490 RX: 1550 |
LC |
9/125, SMF |
N/A |
70 km (43.50 miles) |
SFP-GE-LH70-SM1550-BIDI |
TX: 1550 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP cable |
SFP-STACK-Kit |
N/A |
N/A |
SFP cable |
N/A |
1.5 m (4.92 ft) |
IMPORTANT: The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module. |
NOTE: · As a best practice, use H3C transceiver modules and cables for the switch. · The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact H3C Support or marketing staff. · For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide. |
2.5G SFP port
Table4-8 SFP port specifications
Item |
Port type |
SFP port |
· GE SFP transceiver modules and cables described in Table4-7. · 2.5G SFP transceiver modules and cables described in Table4-9. |
· S5130S-52MS-EI-G · S5130S-32MS-EI-G · S5130S-52MS-PWR-EI-G · S5130S-32MS-PWR-EI-G |
Table4-9 2.5G SFP transceiver modules and cables available for the 2.5G SFP ports
Connector type |
2.5G SFP transceiver module |
SFP-2.5G-LX10-SM1310-DR-I |
1310 |
LC |
9/125, SMF |
N/A |
SFP+ port
Table4-10 SFP+ port specifications (1)
Item |
Port name |
SFP+ fiber Ethernet port |
All switch models except the S5130S-30C-EI-G, S5130S-54C-EI-G, S5130S-10T4X-EI-Q-G, S5130S-10PT4X-EI-Q-G, S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G-Q), S5130S-16T4X-EI-Q-G, S5130S-28T4X-EI-Q-G, S5130S-8UN40PN6X-EI-G, and S5130S-8UN16PN12X-EI-G |
Connector type |
LC |
The 10GE SFP+ ports are mainly used for transmitting and receiving 10GE fiber port services |
IEEE802.3ae |
Port attribute |
Depends on the transceiver module or cable installed |
· GE SFP transceiver modules and cables described in Table4-7. · 10GE SFP+ transceiver modules and cables described in Table4-13. |
· To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on the S5130S-36F-EI-G, S5130S-36S-EI-G, S5130S-54S-EI-G, S5130S-30C-EI-G, S5130S-54C-EI-G, S5130S-36S-PWR-EI-G, or S5130S-54S-PWR-EI-G switch, follow these guidelines: ¡ Make sure the operating temperature does not exceed 40°C (104°F). ¡ You can install a maximum of two such transceiver modules on the switch. ¡ Do not install the transceiver modules in adjacent ports. · The S5130S-36F-EI-G, S5130S-36S-EI-G, S5130S-54S-EI-G, S5130S-30C-EI-G, S5130S-54C-EI-G, S5130S-36S-PWR-EI-G, and S5130S-54S-PWR-EI-G switches do not support the following transceiver modules: ¡ SFP-XG-CPRI-IR-SM1310. ¡ SFP-XG-CPRI-LR-SM1310. ¡ SFP-XG-LH40-SM1270-BIDI. ¡ SFP-XG-LH40-SM1330-BIDI. ¡ SFP-XG-LH80-SM1490-BIDI. ¡ SFP-XG-LH80-SM1550-BIDI. · Only the LS-5130S-32MS-EI-G and LS-5130S-52MS-EI-G switches support the SFP-10GE-T copper transceiver module. To use the SFP-10GE-T copper transceiver module on an LS-5130S-52MS-EI-G switch, make sure the the operating temperature does not exceed 40°C (104°F). |
Table4-11 SFP+ port specifications (2)
Item |
Port name |
· S5130S-10T4X-EI-Q-G · S5130S-10PT4X-EI-Q-G · S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G-Q) · S5130S-16T4X-EI-Q-G · S5130S-28T4X-EI-Q-G |
Connector type |
LC |
The ports are mainly used for transmitting and receiving 10GE fiber port services |
IEEE802.3ae |
Port attribute |
Operating mode |
10 Gbps, autosensing |
· GE SFP transceiver modules and cables described in Table4-16. · 10GE SFP+ transceiver modules and cables described in Table4-14. · Cables with a length of 7 m (22.97 ft) are not supported. |
· The S5130S-10PT4X-EI-Q-G switch does not support copper transceiver modules or transceiver modules with a maximum transmission distance greater than or equal to 40 km (24.86 miles). · To install copper transceiver modules or transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on an S5130S-10T4X-EI-Q-G, S5130S-32MS-EI-G, S5130S-28T4X-EI-Q-G, or S5130S-16T4X-EI-Q-G switch, make sure the ambient temperature does not exceed 40°C (104°F). |
Table4-12 SFP+ port specifications (3)
Item |
Port name |
· S5130S-8UN40PN6X-EI-G · S5130S-8UN16PN12X-EI-G |
Connector type |
LC |
IEEE802.3ae |
Port attribute |
Operating mode |
· GE SFP transceiver modules and cables described in Table4-16. · 10GE SFP+ transceiver modules and cables described in Table4-15. · 2.5GE SFP+ transceiver modules and cables described in Table4-17. |
The same type of port on the switch might support different port speeds. For more information, see Ethernet interface configuration in Layer 2—LAN Switching Configuration Guide. |
NOTE: The S5130S-30C-EI-G and S5130S-54C-EI-G switches each provide four fixed SFP+ ports on the front panel. To connect peer SFP+ ports over a long distance, use SFP+ transceiver modules and fibers. To connect peer SFP+ ports over a short distance, use H3C SFP+ cables. Select 10GE SFP+ transceiver modules and cables as required. For information about the transceiver modules and cables available for the SFP+ ports on the S5130S-30C-EI-G and S5130S-54C-EI-G switches, see H3C S5130S-EI-G Switch Series Transceiver Module Compatibility Matrix. For information about the transceiver modules and cables available for the SFP+ ports on the other switch models, see Table4-13, Table4-14, and Table4-16. For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide. |
Table4-13 10GE SFP+ transceiver modules and cables available for the SFP+ ports (1)
Connector type |
SFP+ copper transceiver module |
SFP-10GE-T |
N/A |
RJ-45 |
N/A |
30 m (98.43 ft) |
SFP+ optical transceiver module |
SFP-XG-SX-MM850-A |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-D |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-E |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1310-D |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1310-E |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-CPRI-IR-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
1.4 km (0.87 miles) |
SFP-XG-CPRI-LR-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1270-BIDI |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1330-BIDI |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1270-BIDI |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1330-BIDI |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1490-BIDI |
TX: 1490 RX: 1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1550-BIDI |
TX: 1550 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP+ copper cable |
LSWM1STK |
N/A |
N/A |
SFP+ copper cable |
N/A |
0.65 m (2.13 ft) |
LSWM2STK |
1.2 m (3.94 ft) |
LSWM3STK |
3 m (9.84 ft) |
LSTM1STK |
5 m (16.40 ft) |
SFP+ fiber cable |
SFP-XG-D-AOC-7M |
N/A |
N/A |
SFP+ fiber cable |
N/A |
7 m (22.97 ft) |
SFP-XG-D-AOC-10M |
10 m (32.81 ft) |
SFP-XG-D-AOC-20M |
20 m (65.62 ft) |
IMPORTANT: The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, the SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and the SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module. |
Table4-14 10GE SFP+ transceiver modules and cables available for the SFP+ ports (2)
Connector type |
SFP-XG-SX-MM850-A |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-D |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-E |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-H |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1310-F |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1310-S |
1310 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1550-D |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1550-S |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1550-D |
1550 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1270-BIDI-S |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1330-BIDI-S |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
TX: 1490 RX: 1550 |
LC |
9/125, SMF |
N/A |
TX: 1550 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP+ copper cable |
LSWM1STK |
N/A |
N/A |
SFP+ copper cable |
N/A |
0.65 m (2.13 ft) |
LSWM2STK |
1.2 m (3.94 ft) |
LSWM3STK |
3 m (9.84 ft) |
LSTM1STK |
5 m (16.40 ft) |
SFP+ fiber cable |
SFP-XG-D-AOC-7M |
N/A |
N/A |
SFP+ fiber cable |
N/A |
7 m (22.97 ft) |
SFP-XG-D-AOC-7M-H |
7 m (22.97 ft) |
SFP-XG-D-AOC-10M |
10 m (32.81 ft) |
SFP-XG-D-AOC-10M-H |
10 m (32.81 ft) |
SFP-XG-D-AOC-20M |
20 m (65.62 ft) |
SFP-XG-D-AOC-20M-H |
20 m (65.62 ft) |
IMPORTANT: The following transceiver modules must be used in pairs: · SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules. · SFP-XG-LX-SM1270-BIDI-S and SFP-XG-LX-SM1330-BIDI-S transceiver modules. · SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules. · SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module. |
Table4-15 10GE SFP+ transceiver modules and cables available for the SFP+ ports (3)
Connector type |
SFP-XG-SX-MM850-A |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-D |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-E |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-H |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-S |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
TX: 1490 RX: 1550 |
LC |
9/125, SMF |
N/A |
TX: 1550 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP+ copper cable |
LSWM1STK |
N/A |
N/A |
SFP+ copper cable |
N/A |
0.65 m (2.13 ft) |
LSWM2STK |
1.2 m (3.94 ft) |
LSWM3STK |
3 m (9.84 ft) |
LSTM1STK |
5 m (16.40 ft) |
SFP-10G-D-CAB-5M-S |
5 m (16.40 ft) |
SFP+ fiber cable |
SFP-XG-D-AOC-7M |
N/A |
N/A |
SFP+ fiber cable |
N/A |
7 m (22.97 ft) |
SFP-XG-D-AOC-7M-H |
7 m (22.97 ft) |
SFP-XG-D-AOC-10M |
10 m (32.81 ft) |
10 m (32.81 ft) |
SFP-XG-D-AOC-20M |
20 m (65.62 ft) |
20 m (65.62 ft) |
Table4-16 GE SFP transceiver modules and cables available for the SFP+ ports
Connector type |
Maximum transmission distance |
SFP-GE-T |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP-GE-T-D |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP-GE-T-S |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP-GE-SX-MM850-A |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-D |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-S |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
1310 |
LC |
9/125, SMF |
N/A |
50/125, MMF |
500/400 |
62.5/125, MMF |
500 |
SFP-GE-LX10-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1310-D |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1310-S |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1310-F |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH20-SM1310-I |
1310 |
LC |
9/125, SMF |
N/A |
20 km (12.43 miles) |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1310-I |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1310-S |
1310 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1310-BIDI-S |
TX: 1310 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1490-BIDI-S |
TX: 1490 RX: 1310 |
LC |
9/125, SMF |
N/A |
TX: 1310 Rx: 1490 |
LC |
9/125, SMF |
N/A |
TX: 1490 RX: 1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1310-BIDI-I |
TX: 1310 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1490-BIDI-I |
TX: 1490 RX: 1310 |
LC |
9/125, SMF |
N/A |
TX: 1310 RX: 1550 |
LC |
9/125, SMF |
N/A |
TX: 1550 RX: 1310 |
LC |
9/125, SMF |
N/A |
TX: 1490 RX: 1550 |
LC |
9/125, SMF |
N/A |
TX: 1550 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP cable |
SFP-STACK-Kit |
N/A |
N/A |
SFP cable |
N/A |
1.5 m (4.92 ft) |
SFP-STACK-Kit-S |
N/A |
N/A |
SFP cable |
N/A |
1.5 m (4.92 ft) |
IMPORTANT: The following transceiver modules must be used in pairs: · SFP-GE-LX-SM1310-BIDI-S and SFP-GE-LX-SM1490-BIDI-S transceiver modules. · SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules. · SFP-GE-LX-SM1310-BIDI-I and SFP-GE-LX-SM1490-BIDI-I transceiver modules. · SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules. · SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules. For example, if one end uses an SFP-GE-LX-SM1310-BIDI-S transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI-S transceiver module. |
Table4-17 2.5GE SFP transceiver modules and cables available for the SFP+ ports
Connector type |
2.5GE SFP copper transceiver module |
1310 |
LC |
9/125, SMF |
N/A |
SFP-2.5G-LX10-SM1310-DR-I-F |
1310 |
PoDLC |
9/125, SMF |
N/A |
(1) Connector |
(2) Pull latch |
The switch provides 10/100/1000BASE-T Ethernet ports.
Table4-18 10/100/1000BASE-T Ethernet port specifications
Item |
Port name |
10/100/1000BASE-T Ethernet port |
All models |
Connector type |
RJ-45 |
The 10/100/1000BASE-T Ethernet ports are mainly used for transmitting and receiving GE/FE/10M fiber port services |
Compatible standards |
IEEE 802.3i/802.3u/802.3ab |
Transmission rate, duplex mode, and auto MDI/MDI-X |
· 10 Mbps, half/full duplex · 100 Mbps, half/full duplex · 1000 Mbps, full duplex · MDI/MDI-X, autosensing |
100 m (328.08 ft) |
Only the 10/100/1000BASE-T Ethernet ports on an S5130S-30C-EI-G or S5130S-54C-EI-G switch support the half duplex mode. |
Table4-19 2.5G/1000/100/10BASE-T autosensing Ethernet port specifications
Item |
Connector type |
RJ-45 |
· 10 Mbps, full duplex · 100 Mbps, full duplex · 1000 Mbps, full duplex · 2500 Mbps, full duplex · MDI/MDI-X autosensing |
· 110 m (360.89 ft) over Category 5e or above twisted pair cables when the transmission rate is 2.5 Gbps · 110 m (360.89 ft) over Category 5e or above twisted pair cables when the transmission rate is 1 Gbps, 100 Mbps, or 10 Mbps |
Category 5e or above twisted pair cable |
IEEE 802.3i/802.3u/802.3ab/802.3bz |
Port rate limit restrictions
IMPORTANT: · A port group includes ports that must operate at the same rate. When the ports in a port group operate in autonegotiation mode, they automatically operate at the rate of the first inserted transceiver module. You cannot install transceiver modules with different transmission rates on these ports. · Switch models or ports not mentioned in this section do not have rate limit restrictions. |
Table4-20 Port rate limit restrictions
Switch model |
Ports |
Supported rates |
Rate limit restrictions |
Ports 49 to 52 |
12 Gbps, 10 Gbps, 2.5 Gbps, 1 Gbps |
When the switch operates independently, the ports can operate at a maximum of two rates (10 Gbps and another rate) simultaneously. When the switch operates as an IRF member device, an SFP+ port can operate only at 10 Gbps or 12 Gbps. An SFP+ port can operate at 12 Gbps only when it operates as a physical IRF port. |
Ports 25 to 30 |
In standalone mode, the ports can operate at a maximum of two speeds simultaneously. (10 Gbps and one other speed) When the switch operates as an IRF member device, an SFP+ port can operate only at 10 Gbps or 12 Gbps. |
Ports 31 to 34 |
S5130S-36F-EI-G |
Ports 29 to 36 |
12 Gbps, 10 Gbps, 1 Gbps |
Ports 29 to 32 can operate at a maximum of two speeds simultaneously. Ports 33 to 36 can operate at a maximum of two speeds simultaneously. Ports 29 to 36 can operate at a maximum of three speeds simultaneously. An SFP+ port can be used as a physical IRF port only when it operates in 12 Gbps. |
S5130S-36S-EI-G |
Ports 29 to 36 |
Ports 29 to 36 |
S5130S-32MS-EI-G |
Ports 29 and 30 |
2.5 Gbps, 1 Gbps, 100 Mbps |
Ports 29 and 30 can operate at a maximum of two speeds simultaneously. Ports 31 and 32 can operate at a maximum of two speeds simultaneously. Ports 29 to 32 can operate at a maximum of three speeds simultaneously. An SFP+ port can be used as a physical IRF port only when it operates in 12 Gbps. |
Ports 31 and 32 |
Ports 29 and 30 |
Ports 31 and 32 |
S5130S-10T4X-EI-Q-G S5130S-10PT4X-EI-Q-G |
Ports 11 to 14 |
Ports 11 to 14 can operate at a maximum of two speeds simultaneously. An SFP+ port can be used as a physical IRF port only when it operates in 12 Gbps. |
Ports 29 to 32 |
Ports 29 to 32 can operate at a maximum of two speeds simultaneously. An SFP+ port can be used as a physical IRF port only when it operates in 12 Gbps. |
S5130S-54S-PWR-EI-G (LS-5130S-54S-PWR-EI-G-H3) |
Ports 49 to 52 |
Ports 49 to 52 can operate at a maximum of two speeds simultaneously. An SFP+ port can be used as a physical IRF port only when it operates in 12 Gbps. |
S5130S-54S-EI-G |
Ports 49 to 52 |
S5130S-54S-PWR-EI-G (LS-5130S-54S-PWR-EI-G) |
Ports 49 to 52 |
Ports 17 to 20 |
Ports 17 to 20 can operate at a maximum of two speeds simultaneously. An SFP+ port can be used as a physical IRF port only when it operates in 12 Gbps. |
Port rate limit
IMPORTANT: · After you execute the speed auto command, the interfaces in the same interface group will autosense the rate of the first inserted transceiver module, and the transceiver modules of different rates are not supported on these interfaces. After you execute the speed command to specify a specific speed for the interfaces in the same interface group, these interface will match the transceiver modules of the corresponding rate and does not support matching transceiver modules of other rates. · Switch models or ports not mentioned in Table4-21 do not have rate limit. |
Switch model |
Port |
Supported rate |
Limit description |
Ports 49 to 52 |
In standalone mode, the ports can operate at a maximum of two speeds simultaneously. (10 Gbps and one other speed) In an IRF fabric, an SFP+ port can operate only in 10 Gbps. An SFP+ port can be used as a physical IRF port only when it operates in 12 Gbps. |
Ports 25 to 30 |
In standalone mode, the ports can operate at a maximum of two speeds simultaneously. (10 Gbps and one other speed) In an IRF fabric, an SFP+ port can operate only in 10 Gbps. |
Ports 31 to 34 |
S5130S-36F-EI-G |
Ports 29 to 36 |
S5130S-36S-EI-G |
Ports 29 to 36 |
Ports 29 to 36 |
S5130S-32MS-EI-G |
Ports 29 and 30 |
Ports 31 and 32 |
Ports 29 and 30 |
Ports 31 and 32 |
Ports 11 to 14 |
Ports 29 to 32 |
S5130S-54S-PWR-EI-G(LS-5130S-54S-PWR-EI-G-H3) |
Ports 49 to 52 |
S5130S-54S-EI-G |
Ports 49 to 52 |
S5130S-54S-PWR-EI-G(LS-5130S-54S-PWR-EI-G) |
Ports 49 to 52 |
Ports 17 to 20 |
LEDs
System status LED
The system status LED shows the operating status of the switch, as shown in Table4-22.
Table4-22 System status LED description
LED mark |
Status |
SYS |
Steady green |
The switch has started up correctly. |
Flashing green (1 Hz) |
The switch is performing power-on self test (POST). |
Steady red |
The switch has failed POST or the switch is faulty. |
Alternating between red and green (4 Hz) (supported in R8336P05 and later versions) |
Helps you to locate the switch without an ID LED. Note: After you execute the locator blink blink-time command, the LED flashes at specific intervals for switch locating. |
Off |
The switch is powered off. |
S5130S-EI-G switches (except the S5130S-30C-EI-G and S5130S-54C-EI-G) each provide an AC power receptacle on the rear panel.
The power supply status LEDs on the front panel of S5130S-EI-G switches (except the S5130S-10T4X-EI-Q-G, S5130S-10PT4X-EI-Q-G, S5130S-28T4X-EI-Q-G, S5130S-16T4X-EI-Q-G, S5130S-8UN40PN6X-EI-G, and S5130S-8UN16PN12X-EI-G) indicate the power supply operating status.
Table4-23 AC power supply status LED description
LED mark |
Status |
PWR/PWR1/PWR2 |
Steady green |
Normal AC power input. |
Off |
Abnormal or no AC power input. |
The S5130S-30C-EI-G and S5130S-54C-EI-G switches each provide two removable power supply slots on the rear panel. The power supply status LEDs on the front panel indicate the operating status of the power supplies.
Table4-24 Removable power supply status LED description
LED mark |
Status |
PWR1/PWR2 |
Steady green |
A power supply is installed in the power supply slot, and the power supply is outputting power correctly. |
Steady yellow |
A power supply is installed in the power supply slot, but the power supply is faulty or not powered on. |
Off |
No power supply is installed in the power supply slot. |
Mode LED
The mode LED (MODE) works in conjunction with the port status LEDs to show more information about the switch.
· The mode LED indicates the type of information that the port status LEDs are showing.
· You can use the mode button to change the indication of the mode LED.
¡ S5130S-30C-EI-G and S5130S-54C-EI-G switches—The mode LED changes in color and indication after you press the mode button and keeps that state until you press the mode button again.
¡ Other switch models—After you press the mode button to change the mode LED status into flashing green or flashing yellow, the mode LED keeps in that state for only 45 seconds and then turns steady green automatically.
Table4-25 Mode LED description (applicable to the S5130S-30C-EI-G and S5130S-54C-EI-G switches)
LED mark |
Status |
MODE |
Steady green |
The port LEDs are showing the link state of the ports. |
Steady yellow |
The port LEDs are showing the duplex mode of the ports. |
Table4-26 Mode LED description (applicable to the S5130S-36F-EI-G, S5130S-36S-EI-G, S5130S-54S-EI-G, S5130S-28T4X-EI-Q-G, S5130S-16T4X-EI-Q-G, S5130S-36S-PWR-EI-G, S5130S-54S-PWR-EI-G, S5130S-52MS-EI-G, S5130S-32MS-EI-G, S5130S-52MS-PWR-EI-G, and S5130S-32MS-PWR-EI-G switches)
LED mark |
Status |
MODE |
Steady green |
Flashing green (only for PoE models) |
The port LEDs are showing the PoE status of the ports. |
Flashing yellow |
The port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 4 is steady green, the IRF member ID of the switch is 4. |
Table4-27 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Steady green |
A link is present on the port. |
Flashing yellow |
The port is receiving or sending data. |
Off |
No link is present on the port. |
The 10/100/1000BASE-T autosensing Ethernet port LEDs work in conjunction with the mode LED to indicate the operating status of the Ethernet ports and the switch from different aspects.
Mode LED status |
Ethernet port LED status |
Steady green (rate mode) |
Steady green |
A link is present on the port and the port is operating at 1000 Mbps. |
Flashing green |
The port is receiving or sending data at 1000 Mbps. |
Steady yellow |
A link is present on the port and the port is operating at 10/100 Mbps. |
Flashing yellow |
The port is receiving or sending data at 10/100 Mbps. |
Off |
Steady yellow (duplex mode) |
Steady green |
A link is present on the port and the port is operating in full duplex mode. |
Steady yellow |
A link is present on the port and the port is operating in half duplex mode. |
Off |
Table4-29 10/100/1000BASE-T autosensing Ethernet port LED description (applicable to the S5130S-36F-EI-G, S5130S-36S-EI-G, S5130S-54S-EI-G, S5130S-36S-PWR-EI-G, S5130S-54S-PWR-EI-G, S5130S-52MS-EI-G, S5130S-32MS-EI-G, S5130S-52MS-PWR-EI-G, and S5130S-32MS-PWR-EI-G switches)
Mode LED status |
Steady green |
A link is present on the port and the port is operating at 10/100/1000 Mbps. |
Flashing green |
The port is receiving or sending data at 10/100/1000 Mbps. |
Off |
Steady green |
PoE power supply is normal. |
· The maximum PoE power provided by the port fails to meet the power requirement of the PD. · PoE power supply overcurrent, overvoltage, or shortcircuit occurs. · The remaining power of the switch fails to meet the power supply requirement of the port. |
Off |
The port is not connected to a PD or PoE is not enabled on the port. |
Flashing yellow (IRF mode) |
Steady green |
The 2.5G/1000/100/10BASE-T autosensing Ethernet port LEDs work in conjunction with the mode LED to indicate the operating status of the Ethernet ports and the switch from different aspects.
Table4-30 2.5G/1000/100/10BASE-T autosensing Ethernet port LED description
Mode LED status |
Steady green |
A link is present on the port and the port is operating at 2500 Mbps. |
Flashing green |
The port is receiving or sending data at 2500 Mbps. |
Steady yellow |
Flashing yellow |
Off |
Steady green |
Flashing green (PoE mode, available only for PoE models) |
Steady green |
Off |
SFP port LED
The SFP port LEDs work in conjunction with the mode LED to indicate the operating status of the SFP ports and the switch from different aspects.
Table4-31 SFP port LED description
Mode LED status |
SFP port LED status |
Steady green |
Flashing green |
Steady yellow |
Flashing yellow |
Off |
Steady green |
The SFP port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 4 is steady green, the IRF member ID of the switch is 4. |
2.5G SFP port LED
Table4-32 2.5G SFP port LED description
Mode LED status |
2.5G SFP port LED status |
Steady green |
Flashing green |
Steady yellow |
Flashing yellow |
Off |
Off |
The mode LED is operating in IRF mode. |
Flashing green (PoE mode) |
Off |
The mode LED is operating in PoE mode (available only for PoE switch models). |
SFP+ port LED
Table4-33 SFP+ port LED description (applicable to the S5130S-30C-EI-G and S5130S-54C-EI-G switches)
Mode LED status |
SFP+ port LED status |
Steady green |
A link is present on the port and the port is operating at 10 Gbps. |
Flashing green |
The port is receiving or sending data at 10 Gbps. |
Steady yellow |
A link is present on the port and the port is operating at 1 Gbps. |
Flashing yellow |
The port is receiving or sending data at 1 Gbps. |
Off |
Steady green |
Steady yellow |
Off |
Table4-34 SFP+ port LED description (applicable to switch models on which the SFP+ ports cannot operate at 2.5 Gbps)
Mode LED status |
Steady green |
A link is present on the port and the port is operating at 1/10 Gbps. |
Flashing green |
The port is receiving or sending data at 1/10 Gbps. |
Off |
Off |
Off |
Table4-35 SFP+ port LED description (applicable to switch models on which the SFP+ ports can operate at 2.5 Gbps)
Mode LED status |
Steady green |
A link is present on the port and the port is operating at 1/2.5/10 Gbps. |
Flashing green |
The port is receiving or sending data at 1/2.5/10 Gbps. |
Off |
Off |
Off |
The S5130S-30C-EI-G and S5130S-54C-EI-G switches each provide an interface module slot on the rear panel. The interface module status LED on the front panel indicates the operating status of the interface module.
Table4-36 Interface module status LED description
LED mark |
Status |
SLOT |
Steady green |
The interface module is operating correctly. |
Flashing yellow |
The interface module in the slot is not supported or the interface module is faulty. |
Off |
No interface module is installed. |
An interface module provides a LED for each port. For more information about the LEDs, see the manual for the interface module.
Status LED on a fan module
The LSPM1FANSA and LSPM1FANSB fan modules each provide a LED to indicate the fan module operating status.
ID LED
Table4-37 ID LED description
LED mark |
Status |
ID |
Flashing blue |
Helps you to locate the switch. Note: To locate the switch in the rack, execute the locator blink blink-time command. The LED then flashes blue. |
After you execute the push-button mode enable command on an S5130S-10T4X-EI-Q-G, S5130S-10PT4X-EI-Q-G, S5130S-16T4X-EI-Q-G, or S5130S-28T4X-EI-Q-G switch, the operations that can be performed by pressing the mode button depend on the duration of the press.
· 5 to 10 seconds—Connect the switch to or disconnect the switch from Cloudnet.
· Less than 5 seconds—Change the type of information that the port LEDs are showing.
· More than 10 seconds—Invalid operation.
Table4-38 Cloudnet management status LED description
LED status |
Steady blue |
The switch has been managed by Cloudnet. |
Flashing blue (1 Hz) |
The switch is being connected to Cloudnet. |
Flashing blue (3 Hz) |
Invalid operation. |
Off |
The switch is not connected to Cloudnet. |
Buttons
Mode button
You can use the mode button to change the indication of the mode LED and cloud management status LED. For more information about the mode LED, see "Mode LED." For more information about the cloud management status LED, see "Cloudnet management status LED."
Reset button
Some switch models provide a reset button on the rear panel. Table4-39 shows the description for the reset button.
Table4-39 Reset button description
Button |
When the switch operates independently, perform either of the following tasks: · To restart the switch, press and hold the button for no more than 5 seconds. · To restore the factory defaults and restart the switch, press and hold the button for more than 5 seconds. When the switch operates as an IRF member device, pressing the button only restarts the switch. |
5 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
CAUTION: To ensure adequate heat dissipation for an S5130S-30C-EI-G or S5130S-54C-EI-G switch, follow these guidelines: · You must install two fan modules of the same model for the switch. · If a fan module operates abnormally (for example, it is in the absent, fault, inconsistent airflow direction, or being just inserted state), the other fan module will operate at the highest speed. |
Table5-1 Cooling system
Switch model |
Fan type |
Airflow direction |
S5130S-30C-EI-G S5130S-54C-EI-G |
LSPM1FANSA |
From the power supply side to the port side and chassis two sides (S5130S-54C-EI-G switch as an example) |
LSPM1FANSB |
From the port side and chassis two sides to the power supply side (S5130S-54C-EI-G switch as an example) |
S5130S-36F-EI-G S5130S-36S-EI-G S5130S-54S-EI-G S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G) S5130S-52MS-EI-G S5130S-36S-PWR-EI-G S5130S-54S-PWR-EI-G S5130S-32MS-PWR-EI-G S5130S-52MS-PWR-EI-G S5130S-8UN40PN6X-EI-G S5130S-8UN16PN12X-EI-G |
Fixed fans |
From the left side to the right side (S5130S-54S-PWR-EI-G switch as an example) |
S5130S-10T4X-EI-Q-G S5130S-10PT4X-EI-Q-G S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G-Q) S5130S-28T4X-EI-Q-G S5130S-16T4X-EI-Q-G |
N/A |
