HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath M9000 Configuration Guide(V7)(R9900)-6W10101-Fundamentals Configuration Guide
03-Configuration file management configuration
03-Configuration file management configuration 213.71 KB
Managing configuration files· 1
About configuration file management 1
Configuration types· 1
Configuration file types and file selection process at startup· 2
Next-startup configuration file redundancy· 2
Configuration file content organization and format 2
Configuration rollback· 3
vSystem support for features· 3
Enabling configuration encryption· 3
Saving the running configuration· 4
Comparing configurations for their differences· 7
Archiving the running configuration· 7
About running configuration archiving· 7
Restrictions and guidelines for archiving the running configuration· 8
Configuring local configuration archiving· 8
Configuring remote configuration archiving· 9
Executing the configuration in a configuration file· 10
Rolling back the running configuration· 11
About configuration rollback· 11
Restrictions and guidelines for configuration rollback· 11
Performing a local configuration rollback· 12
Scheduling or performing a remote configuration rollback· 12
Specifying a next-startup configuration file· 14
Backing up and restoring the main next-startup configuration file· 15
About backing up and restoring the main next-startup configuration file· 15
Prerequisites for configuration backup and restoration· 15
Backing up the main next-startup configuration file to a TFTP server 15
Restoring the main next-startup configuration file from a TFTP server 15
Deleting a next-startup configuration file· 16
Enabling configuration change logging· 16
Bulk deploying configuration· 17
Display and maintenance commands for configuration files· 17
You can manage configuration files from the CLI or the BootWare menu. The following information explains how to manage configuration files from the CLI.
A configuration file saves a set of commands for configuring software features on the device. You can save any configuration to a configuration file so the configuration can survive a reboot. You can also back up configuration files to a host for future use.
Configuration types
Initial configuration
Initial configuration is the collection of initial default settings for the configuration commands in software.
The device starts up with the initial configuration if you access the BootWare menu and select the Skip Current System Configuration option. In this situation, the device might also be described as starting up with empty configuration.
No commands are available to display the initial configuration. To view the initial default settings for the configuration commands, see the Default sections in the command references.
Factory defaults
Factory defaults are custom basic settings that came with the device. Factory defaults vary by device models and might differ from the initial default settings for the commands.
The device starts up with the factory defaults if no next-startup configuration files are available.
To display the factory defaults, use the display default-configuration command.
Startup configuration
The device uses startup configuration to configure software features during startup. After the device starts up, you can specify the configuration file to be loaded at the next startup. This configuration file is called the next-startup configuration file. The configuration file that has been loaded is called the current startup configuration file.
You can display the startup configuration by using one of the following methods:
·     To display the contents of the current startup configuration file, execute the display current-configuration command before changing the configuration after the device reboots.
·     To display the contents of the next-startup configuration file, use the display saved-configuration command.
·     Use the display startup command to display names of the current startup configuration file and next-startup configuration files. Then, you can use the more command to display the contents of the specified startup configuration file.
Running configuration
The running configuration includes unchanged startup settings and new settings. The running configuration is stored in memory and is cleared at a device reboot or power off. To use the running configuration after a power cycling or reboot, save it to a configuration file.
To display the running configuration, use the display current-configuration command.
When you save the configuration, the system saves the settings to a .cfg configuration file and to an .mdb file.
·     A .cfg configuration file is a human-readable text file and its contents can be displayed by using the more command. Configuration files you specify for saving the configuration must use the .cfg extension.
·     An .mdb file is a user-inaccessible binary file that has the same name as the .cfg file. The device loads an .mdb file faster than loading a .cfg file.
At startup, the device uses the following procedure to identify the configuration file to load:
1.     The device searches for a valid .cfg next-startup configuration file. For more information about the file selection rules, see "Next-startup configuration file redundancy."
2.     If a valid .cfg next-startup configuration file is found, the device searches for an .mdb file that has the same name and checksum as the .cfg file.
3.     If a matching .mdb file is found, the device starts up with the .mdb file. If none is found, the device starts up with the .cfg file.
If no .cfg next-startup configuration files are available, the device starts up with the factory defaults.
Unless otherwise stated, the term "configuration file" in this document refers to a .cfg configuration file.
You can specify one main next-startup configuration file and one backup next-startup configuration file for redundancy.
At startup, the device tries to select the .cfg startup configuration in the following order:
1.     The main next-startup configuration file.
2.     The backup next-startup configuration file if the main next-startup configuration file does not exist or is corrupt.
If no next-startup configuration files are available, the device starts up with the factory defaults.
IMPORTANT
IMPORTANT:
To run on the device, a configuration file must meet the content and format requirements. To ensure a successful configuration load at startup, use a configuration file created on the device. If you edit the configuration file, edit it on the device, and make sure all edits are compliant with the requirements. Do not download the configuration file locally for editing.
A configuration file must meet the following requirements:
·     All commands are saved in their complete form.
·     Commands are sorted into sections by different command views, including system view, interface views, protocol views, and user line views.
·     Two adjacent sections are separated by a pound sign (#).
·     The configuration file starts with a pound sign (#).
·     The configuration file ends with the word return.
The following is a sample configuration file excerpt:
local-user root class manage
 password hash $h$6$Twd73mLrN8O2vvD5$Cz1vgdpR4KoTiRQNE9pg33gU14Br2p1VguczLSVyJLO2huV5Syx/LfDIf8ROLtVErJ/C31oq2rFtmNuyZf4STw==
interface Vlan-interface1
 ip address 192.168.1.84 255.255.255.0
Configuration rollback allows you to replace the running configuration with the configuration at a rollback point or in a configuration file without rebooting the device. You can use this feature for the following purposes:
·     Reverting to a previous configuration state.
·     Adapting the running configuration to different network environments.
Non-default vSytems support only saving the running configuration and some display commands.
For information about the support of non-default vSystems for the commands, see configuration file management command reference. For information about vSystem, see Virtual Technologies Configuration Guide.
Configuration encryption enables the device to use the master key to encrypt a startup configuration file automatically when it saves the running configuration. For more information about the master key, see public key management in Security Configuration Guide.
After a configuration file is encrypted by using this feature on the device, only devices that use the same master key as the device can decrypt the encrypted configuration file.
You cannot use the more command to view the contents of an encrypted configuration file.
You cannot compare an encrypted configuration file with any configuration for their differences.
2.     Enable configuration encryption.
By default, configuration encryption is disabled.
When you save the running configuration to a .cfg configuration file, you can specify the file as a next-startup configuration file or not.
To reduce the amount of time used for saving the configuration to a .cfg file, you can save the configuration only to a binary configuration file.
The device supports the following methods to save the running configuration:
·     Manual configuration saving—You use the save command to save the running configuration to a configuration file or to the main or backup next-startup configuration file.
To reduce the amount of time used for saving the configuration to a .cfg file, you can use binary-only configuration saving. This method saves configuration only to the .mdb binary main next-startup configuration file.
·     Automatic configuration saving—The device automatically saves the running configuration to both the .cfg and .mdb main next-startup configuration files at intervals as configured. At each interval, the device performs an automatic saving operation only if the running configuration contains different settings than the main next-startup configuration files. If no main next-startup configuration files exist, the device automatically creates configuration files startup.cfg and startup.mdb to save the running configuration and specifies the files as the main next-startup configuration files.
·     Binary-only automatic configuration saving—The device automatically saves the running configuration only to the .mdb binary main next-startup configuration file at intervals. At each interval, the device performs an automatic saving operation only if the running configuration contains different settings than the .mdb binary main next-startup configuration file.
To save the running configuration of non-default vSystems, use one of the following methods:
·     On the default vSystem, use the save command to save the running configuration of the default vSystem and all non-default vSystems.
·     On the default vSystem, use the save vsys command to save the running configuration of a vSystem to a .cfg configuration file. This command does not save the running configuration of the vSystem to the binary file of the .cfg file.
·     On a non-default vSystem, use the save command without any parameter to save the running configuration of the current vSystem to the .cfg main next-startup configuration file on the default vSystem. The configuration is saved to all MPUs but it is not saved to the binary file of the .cfg file.
Hardware and command compatibility
Only the vFW virtual firewalls support the save binary-only command.
To prevent the loss of next-startup configuration, make sure no one reboots or power cycles the device while the device is saving the running configuration.
If there are settings that must be read from the .cfg configuration file at startup, binary-only configuration saving will cause the loss of those settings at startup. As a best practice, use binary-only configuration saving only when you must save a large number of NAT entries, IP static routes, or VPN instances.
When you use the binary-only configuration saving, follow these restrictions and guidelines:
·     Make sure a .cfg main next-startup configuration file exists on the device and the .cfg file has the same name as the .mdb main next-startup configuration file. If no .cfg main next-startup configuration file exists, the save operation will fail.
·     If the binary main next-startup configuration file is not available at the next startup, the device uses an available .cfg next-startup configuration file. The configuration saved only in the binary startup file will be lost.
·     You cannot use the display saved-configuration command to display the settings in the binary main next-startup configuration file.
When an IRF member device splits from the IRF fabric, its settings are retained in memory but removed from the running configuration on the IRF fabric. Saving the running configuration before the IRF fabric recovers will remove the member device's settings from the next-startup configuration file.
If you have saved the running configuration before the member device rejoins the IRF fabric, perform the following steps to restore the member device settings to the next-startup configuration file:
1.     Resolve the split issue.
2.     Reboot the member device to rejoin the IRF fabric.
3.     After the member device rejoins the IRF fabric, execute the display current-configuration command to verify that the member device's settings have been restored from memory to the running configuration.
4.     Save the running configuration to the next-startup configuration file on the IRF fabric.
IMPORTANT
IMPORTANT:
To ensure a successful configuration restoration, make sure the IRF fabric has not rebooted after the member device left.
When a card is removed from the system, its settings are retained in memory but removed from the running configuration on the device. Saving the running configuration before installing the replacement card will remove the card's settings from the next-startup configuration file.
If you have saved the running configuration after removing a card, perform the following steps to restore the card settings to the next-startup configuration file:
5.     Install the replacement card.
6.     After the replacement card comes online, execute the display current-configuration command to verify that the card's settings have been automatically restored from memory to the running configuration.
7.     Save the running configuration to the next-startup configuration file.
IMPORTANT
IMPORTANT:
To ensure a successful configuration restoration, make sure the system has not rebooted after the card was removed.
(In standalone mode.) Automatic configuration saving saves the running configuration to both active and standby MPUs.
(In IRF mode.) Automatic configuration saving saves the running configuration to each MPU on each member device.
Manually saving the running configuration
(In standalone mode.) To save the running configuration, perform one of the following tasks in any view:
·     Save the running configuration to a configuration file without specifying the file as a next-startup configuration file.
·     Save the running configuration to a configuration file in the root directory of the storage medium on each MPU, and specify the file as a next-startup configuration file.
save [ safely ] [ backup | main ] [ force ] [ context-all | changed ]
As a best practice, specify the safely keyword for reliable configuration saving.
CAUTION
CAUTION:
Use caution when you save the running configuration. This operation will overwrite the settings in the target configuration file. When you perform this operation, carefully read the messages displayed by the system and make sure you fully understand the impact of the operation on services.
(In IRF mode.) To save the running configuration, perform one of the following tasks in any view:
save file-url [ all | chassis chassis-number slot slot-number ]
·     Save the running configuration to a configuration file in the root directory of the storage medium on each MPU, and specify the file as a startup configuration file.
CAUTION
CAUTION:
To save the running configuration of a vSystem to a .cfg file, execute the following command in any view:
save vsys vsysname [ file-url ]
CAUTION
CAUTION:
Configuring automatic configuration saving
2.     Enable the device to automatically save the running configuration and set the automatic saving interval.
¡     Enable the automatic configuration saving feature and set the automatic saving interval.
save current-configuration interval interval
By default, the automatic configuration saving feature is disabled.
This feature saves the running configuration to both the .cfg and .mdb main next-startup configuration files.
¡     Enable the binary-only automatic configuration saving feature and set the automatic saving interval.
save current-configuration binary-only interval interval
By default, the binary-only automatic configuration saving feature is disabled.
This feature saves the running configuration only to the .mdb binary main next-startup configuration file.
You can compare configuration files or compare a configuration file with the running configuration for their differences.
If you specify the next-startup configuration for a comparison, the system selects the next-startup configuration file to be compared with in the following order:
2.     The backup next-startup configuration file if the main next-startup configuration file is unavailable.
If both configuration files are unavailable, the system displays a message indicating that no next-startup configuration files exist.
If you specify a configuration file for a comparison, the configuration file must be a .cfg configuration file.
To compare configurations for their differences, perform one of the following tasks in any view:
·     Display the differences that a configuration file, the running configuration, or the next-startup configuration has as compared with the specified source configuration file.
display diff configfile file-name-s { configfile file-name-d | current-configuration | startup-configuration }
·     Display the differences that a configuration file or next-startup configuration has as compared with the running configuration.
display diff current-configuration { configfile file-name-d | startup-configuration }
·     Display the differences that a configuration file has as compared with the next-startup configuration.
display diff startup-configuration configfile file-name-d
·     Display the differences that the running configuration has as compared with the next-startup configuration.
¡     Method 1:
display diff startup-configuration current-configuration
¡     Method 2:
display current-configuration diff
You can perform local or remote configuration archiving to archive the running configuration to a directory on the device or to a remote server, respectively.
The remote server can be an FTP, TFTP, SCP, or SFTP server.
The following are methods for archiving the running configuration:
·     Automatic configuration archiving—The system automatically archives the running configuration at intervals as configured.
·     Manual configuration archiving—You can disable automatic configuration archiving and manually archive the running configuration if the configuration will be rarely changed. You can also use this method to back up configuration before performing complicated configuration tasks.
Local archiving (the archive configuration location command) and remote archiving (the archive configuration server command) are mutually exclusive. You cannot use the two features at the same time.
If you configure parameters multiple times for an archiving method, the most recent configuration takes effect.
Local configuration archives are named in the format of prefix_serial number.cfg (for example, archive_1.cfg and archive_2.cfg). The serial number is automatically assigned from 1 to 1000, increasing by 1. After the serial number reaches 1000, it restarts from 1.
If you change the file directory or file name prefix, the following events occur:
·     The old configuration archives change to common configuration files.
·     The configuration archive counter is reset. The serial number for new configuration archives starts at 1.
·     The display archive configuration command no longer displays the old configuration archives.
The configuration archive counter does not restart when you delete configuration archives from the archive directory. However, if the device reboots after all configuration archives have been deleted, the configuration archive counter restarts. The serial number for new configuration archives starts at 1.
If an archiving has started based on the existing archive parameters when an archive parameter is changed, the archive will still be retained in the old directory. However, the display archive configuration command will not display the record about this archiving.
After the maximum number of configuration archives is reached, the system deletes the oldest archive to make room for the new archive.
The undo archive configuration location command removes the local configuration archive directory and file name prefix settings, but it does not delete the configuration archives on the device. In addition, the command performs the following operations:
·     Disables both the manual and automatic configuration archiving features.
·     Restores the default settings for the archive configuration interval and archive configuration max commands.
·     Clears the configuration archive information displayed by using the display archive configuration command.
(In standalone mode.) The local archiving feature saves the running configuration only on the active MPU. To make sure the system can archive the running configuration after an active/standby switchover, create the configuration archive directory on both the active and standby MPUs.
(In IRF mode.) The local archiving feature saves the running configuration only on the active MPU of the master device. To make sure the system can archive the running configuration after an active/standby or master/subordinate switchover, create the configuration archive directory on all MPUs.
2.     Set the directory and file name prefix for archiving the running configuration to the local device.
archive configuration location directory filename-prefix filename-prefix
By default, no path or file name prefix is set for configuration archives on the device, and the system does not regularly archive the running configuration.
(In standalone mode.) The configuration archive directory must already exist on the active MPU and cannot include a slot number.
(In IRF mode.) The configuration archive directory must already exist on the global active MPU and cannot include a chassis or slot number.
3.     (Optional.) Set the maximum number of configuration archives that can be stored on the device.
archive configuration max file-number
The default number is 5.
Change the setting depending on the amount of storage available on the device.
4.     Archive the running configuration to the configuration archive directory. Choose one of the following methods:
¡     Enable automatic configuration archiving and set the archiving interval.
archive configuration interval interval
By default, automatic configuration archiving is disabled.
¡     Execute the following commands in sequence to manually archive the running configuration in user view:
If you archive the running configuration to a remote server, configuration archives are named in the format of prefix_YYYYMMDD_HHMMSS.cfg (for example, archive_20170526_203430.cfg).
The undo archive configuration server command removes the remote configuration archive directory and file name prefix settings from the device, but it does not delete the configuration archives on the server. In addition, the command performs the following operations:
·     Restores the default setting for the archive configuration server user and archive configuration server password commands.
When you modify parameters (for example, the username or password) for remote archiving, make sure the changes are consistent between the device and the server. A manual or automatic remote archiving will fail if it has started before you change the device and the server settings to be consistent.
2.     Configure parameters for archiving the running configuration to a remote server.
archive configuration server { ftp | tftp | scp | sftp } { ipv4-address | ipv6 ipv6-address } [ port port-number ] [ vpn-instance vpn-instance-name ] [ directory directory ] filename-prefix filename-prefix [ interval interval ]
By default, no parameters are configured for archiving the running configuration to a remote server.
To automatically archive the running configuration regularly to the server, specify the interval interval option.
3.     If an FTP, SCP, or SFTP server is used, configure the username and password for accessing the server.
a.     Configure the username.
archive configuration server user user-name
By default, no username is configured for accessing the FTP, SCP, or SFTP server.
b.     Configure the password.
archive configuration server password { cipher | simple } string
By default, no password is configured for accessing the FTP, SCP, or SFTP server.
Make sure the username and password are the same as the FTP, SCP, or SFTP account settings on the FTP, SCP, or SFTP server.
4.     To manually archive the running configuration to the remote server:
a.     Return to user view.
b.     Manually archive the running configuration to the remote server.
When the device executes the configuration replace file command, it checks the settings in the replacement configuration file specified by using this command. If the replacement configuration file contains a large number of settings, the configuration rollback operation will take a long time. In this case, if only specific settings in the file need to be deployed, you can save these settings in another file and execute the configuration execute file command to deploy only these settings to reduce the configuration rollback time.
The configuration execute file command allows you to deploy the settings in the specified configuration file to the device without rebooting the device.
If the settings in the specified configuration file conflict with the current configuration or fail to be executed, the device will skip them and not deploy them.
CAUTION
CAUTION:
·     This task might cause running configuration loss. As a best practice to avoid running configuration loss, back up the running configuration before you perform this task.
·     This task might cause service interruption. When you perform this task, make sure you fully understand its impact on your network.
Make sure the specified configuration file is created by using the configuration archive feature or the save command on the device. If the configuration file is not created on the device, make sure the command lines in the configuration file are fully compatible with the device. As a best practice, use a configuration file created by using the configuration archive feature.
Commands or command settings that the device does not support cannot be added to the running configuration.
The specified configuration file must be stored unencrypted on the device.
1.     Enter system view
2.     Execute the configuration in a configuration file on the device.
configuration execute file filename
Configuration rollback allows you to replace the running configuration with the configuration in a replacement configuration file without rebooting the device. The replacement configuration file can be saved on the local device or on an FTP or TFTP server.
The configuration rollback feature compares the running configuration with the specified replacement configuration file and handles configuration differences as follows:
·     If a command in the running configuration is not in the replacement file, the rollback feature executes the undo form of the command.
·     If a command in the replacement file is not in the running configuration, the rollback feature adds the command to the running configuration.
·     If a command has different settings in the running configuration and the replacement file, the rollback feature replaces the running command setting with the setting in the replacement file.
If configuration rollback fails for some command lines, the system outputs a rollback failure message. To identify those command lines, use the display diff current-configuration configfile file-name-d command, with the replacement file specified for the file-name-d argument. The command lines that have failed to roll back are displayed as configuration differences between the running configuration and the replacement configuration file.
The configuration rollback feature might fail to reconfigure some commands in the running configuration for one of the following reasons:
·     A command cannot be undone because prefixing the undo keyword to the command does not result in a valid undo command. For example, if the undo form designed for the A [B] C command is undo A C, the configuration rollback feature cannot undo the A B C command. This is because the system does not recognize the undo A B C command.
·     A command (for example, a hardware-dependent command) cannot be deleted, overwritten, or undone due to system restrictions.
·     The commands in different views are dependent on each other.
·     Commands or command settings that the device does not support cannot be added to the running configuration.
·     In an HA networking environment, execute the configuration manual-sync command to back up configuration information from the primary device to the secondary device after configuration rollback is configured to ensure configuration consistency between the primary and secondary devices. For more information about HA, see High Availability Configuration Guide.
The replacement configuration file must be stored unencrypted on the local system.
2.     Roll the running configuration back to the configuration in a configuration file.
CAUTION
CAUTION:
This operation will cause settings not in the replacement configuration file to be lost, which might cause service interruption. When you perform configuration rollback, make sure you fully understand its impact on your network.
You can roll back the running configuration by using a configuration file stored on an FTP or TFTP server.
When you perform this task, you can roll back the running configuration immediately or schedule a rollback for a future date and time.
The device performs a remote rollback as follows:
1.     Downloads a replacement configuration file from a remote server.
2.     Saves the downloaded file as a temporary file.
3.     Replaces the running configuration with the configuration in the temporary file.
4.     Deletes the temporary file after the configuration rollback finishes.
The undo configuration replace server command performs the following operations:
·     Disables the running configuration remote rollback feature.
·     Restores the default settings for the configuration replace server user and configuration replace server password commands.
·     Clears the configuration rollback information displayed by using the display configuration replace server command.
You can cancel a configuration rollback schedule anytime before its scheduled date and time. When you schedule a rollback, you can specify the date and time or specify only the time to execute the rollback.
·     If you specify a rollback date with the rollback time, the specified date must be the same or later than the current system date. If the specified date is the same as the current system date, the specified time must be later than the current system time. After you create the rollback schedule, be careful with changing the system clock backward. The rollback schedule will be canceled automatically if it expires before it could be executed because the system date or time is changed backward.
·     If you do not specify a rollback date with the rollback time, the device compares the specified rollback time with the current system time.
¡     If the specified rollback time is later than the current system time, the device performs a rollback at the specified time on the current day.
¡     If the specified rollback time is earlier than the current system time, the device performs a rollback at the specified time on the next day.
2.     Configure server parameters for remote configuration rollback.
configuration replace server { ftp | tftp } { ipv4-address | ipv6 ipv6-address }[ port port-number ] [ vpn-instance vpn-instance-name ] [ directory directory ] file filename
By default, no server parameters are configured for remote configuration rollback.
The configuration file specified by using this command will be used for rollback if no configuration file is specified when you perform or schedule a remote rollback.
3.     If an FTP server is used, configure the username and password for accessing the remote FTP server.
configuration replace server user user-name
By default, no username is configured for accessing the FTP server.
If no username is configured, the username will be anonymous.
configuration replace server password { cipher | simple } string
By default, no password is configured for accessing the FTP server.
Make sure the username and password are the same as the FTP account settings on the FTP server.
4.     Roll the running configuration back to the configuration in a replacement configuration file.
¡     Roll the running configuration back immediately.
configuration replace server file [ filename ]
¡     Schedule a configuration rollback.
configuration replace server file [ filename ] at time [ date ]
If no replacement configuration file is specified, the configuration file specified by using the configuration replace server command is used for rollback.
CAUTION
CAUTION:
CAUTION
CAUTION:
Using the undo startup saved-configuration command can cause an IRF split after the IRF fabric or an IRF member reboots. When you execute this command, make sure you understand its impact on your network.
As a best practice, specify different files as the main and backup next-startup configuration files.
The undo startup saved-configuration command changes the attribute of the main or backup next-startup configuration file to NULL instead of deleting the file.
(In standalone mode.) Make sure the specified configuration file is valid and has been saved to the root directory of a storage medium on both active and standby MPUs. In addition, make sure the storage media are the same type across the MPUs.
(In IRF mode.) Make sure the specified configuration file is valid and has been saved to the root directory of a storage medium on each MPU in the IRF fabric. In addition, make sure the storage media are the same type across all the MPUs.
1.     Specify a next-startup configuration file. Choose one of the following methods:
¡     Execute the following command in user view to specify a next-startup configuration file:
startup saved-configuration cfgfile [ anchor-ac | anchor-fit | fat ] [ backup | main ]
By default, no next-startup configuration files are specified.
¡     Execute the following command in any view to save the running configuration to a file and specify the file as a next-startup configuration file:
For more information about this command, see "Saving the running configuration."
If you do not specify the backup or main keyword, this command specifies the configuration file as the main next-startup configuration file.
2.     (Optional.) Verify the configuration. Use one of the following commands in any view:
¡     Display the names of the configuration files for this startup and the next startup.
display startup
¡     Display the contents of the configuration file for the next system startup.
You can back up the main next-startup configuration file to a TFTP server or restore the main next-startup configuration file from a TFTP server.
Before you back up or restore the main next-startup configuration file, perform the following tasks:
·     Make sure the following requirements are met:
¡     The server is reachable.
¡     The server is enabled with TFTP service.
¡     You have read and write permissions to the server.
·     For configuration backup, use the display startup command to verify that the main next-startup configuration file has been specified in user view. If no next-startup configuration file has been specified or the specified configuration file does not exist, the backup operation will fail.
To back up the main next-startup configuration file to a TFTP server, execute the following command in user view:
backup startup-configuration to { ipv4-server | ipv6 ipv6-server } [ dest-filename ] [ vpn-instance vpn-instance-name ]
1.     Restore the main next-startup configuration file from a TFTP server in user view.
restore startup-configuration from { ipv4-server | ipv6 ipv6-server } src-filename [ vpn-instance vpn-instance-name ]
2.     (Optional.) Verify that the specified configuration file has been set as the main next-startup configuration file. Use one of the following commands in any view:
display startup
You can perform this task to delete a next-startup configuration file.
If both the main and backup next-startup configuration files are deleted, the device uses the factory defaults at the next startup.
To delete a file that is set as both main and backup next-startup configuration files, you must execute both the reset saved-configuration backup command and the reset saved-configuration main command. Using only one of the commands removes the specified file attribute instead of deleting the file.
For example, if the reset saved-configuration backup command is executed, the backup next-startup configuration file setting is set to NULL. However, the file is still used as the main file. To delete the file, you must also execute the reset saved-configuration main command.
CAUTION
CAUTION:
(In IRF mode.) This task permanently deletes a next-startup configuration file from all IRF member devices. As a best practice, make sure you have a configuration backup before you perform this task.
If you do not specify the backup or main keyword when you perform this task, the main next-startup configuration is deleted.
To delete a next-startup configuration file, execute the following command in user view:
Configuration change logging enables the system to generate log messages when the configuration is changed, for example, from the CLI or through NETCONF, CWMP, or SNMP. The configuration change logs have a module name of CFGLOG and a mnemonic of CFGLOG_CFGOPERATE. They can help you locate configuration errors. For example, the CFGLOG/6/CFGLOG_CFGOPERATE: -Client=CLI-User=**-IPAddr=**-Role=network-admin; Config in system-view changed: -Old setting=sysname TEST -New setting=sysname NewTEST log indicates that the system name has been changed from TEST to NewTEST at the CLI.
The system generates a configuration change log only if the configuration you make is different from the existing configuration. When the system has a significant number of configurations, generating configuration change logs is time-consuming and might degrade system performance. In such cases, disable configuration change logging.
The device sends the configuration change logs to the information center. You can configure the information center to output the logs to a specific destination. For more information about the information center, see Network Management and Monitoring Configuration Guide.
2.     Enable configuration change logging.
cfg-change log enable
By default, configuration change logging is enabled.
After performing this task, the system will sequentially deploy the command lines from the command line set starting from the current view. After the task is complete, the system will return to the current view. When editing the command line set, you must consider the logical relationship between the command lines and the current view, and avoid deploying command lines that do not exist in the current view. To exit the current view, use the quit command.
When the system bulk deploy configuration, the following rules apply:
·     The system does not deploy the repeat command. It skips the repeat command and proceeds to deploy the next command line. For more information about the repeat command, see CLI commands in Fundamentals Command Reference.
·     For an interactive command line, you must input the interactive information before the next command line can be deployed. If no interactive information is input within the timeout period, the service module will automatically determine whether the command line has failed to be deployed.
·     If a command line fails to be deployed, the configuration will be rolled back to the state before the bulk deployment. In addition, the system generates the following message: Rolling back the configuration. Please wait.
·     You can press Ctrl+C to interrupt the command line deployment process. This operation also rolls back the configuration to the state before the bulk deployment and generates the following message: Rolling back the configuration. Please wait.
Pound signs (#) and braces ({}) are used as separators between command lines for bulk deployment. A space must exist between a separator and a command line. To ensure correct command line deployment, do not use the separators in the command lines to be deployed. If you use the separators in the command lines, the system might falsely identify them as separators rather than parameters.
To bulk deploy configuration in the current view:
batch-configuration text
IMPORTANT
IMPORTANT:
Non-default vSystems do not support some of the display and maintenance commands. For information about vSystem support for these commands, see configuration file management command reference.
Display configuration archive information.
Display information about remote configuration rollback.
Display the running configuration.
display current-configuration [ configuration [ module-name ] | interface [ interface-type [ interface-number ] ] | vpn-instance [ vpn-instance-name ] | vsys vsys-name ] [ by-section { begin | exclude | include } regular-expression ]
Display the factory defaults.
Display the differences between configurations.
·     display diff configfile file-name-s { configfile file-name-d | current-configuration | startup-configuration }
·     display diff current-configuration { configfile file-name-d | startup-configuration }
·     display diff startup-configuration { configfile file-name-d | current-configuration }
display saved-configuration [ by-section { begin | exclude | include } regular-expression | filename ]
display startup
Display the valid configuration in the current view.
display this [ by-section { begin | exclude | include } regular-expression ]
