H3C UniServer R4900 G7 U Series Air-Cooled and Cold Plate-Based Liquid-Cooled Server User Guide-5W100
HomeSupportServersH3C UniServer R4900 G7Technical DocumentsInstall & UpgradeInstallation GuidesH3C UniServer R4900 G7 U Series Air-Cooled and Cold Plate-Based Liquid-Cooled Server User Guide-5W100
03-Appendix B Managed Hot Removal of OCP Network Adapters
To view the operating systems that support hot swapping of OCP network adapters, use the OS Compatibility Lookup Tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
Make sure the following software version requirements are met:
·     BIOS: 6.00.15 or later.
·     HDM2: 1.13 or later.
·     CPLD: V004 or later.
This section uses the OCP network adapter in slot 16 as an example.
1.     Access the operating system.
2.     Execute the dmidecode -t 9 command to search for the bus address of the OCP network adapter. As shown in Figure 1, the bus address of the OCP network adapter in slot 16 is 0000:31:00.0.
Figure 1 Searching for the bus address of an OCP network adapter by slot number
3.     Execute the echo 0 > /sys/bus/pci/slots/slot_number/power command to power off the network adapter, where slot_number represents the number of the slot where the OCP network adapter resides.
Figure 2 Executing the echo 0 > /sys/bus/pci/slots/slot_number/power command
4.     Identify whether the OCP network adapter has been disconnected:
¡     Observe the OCP network adapter LED. If the LED is off, it indicates that the OCP network adapter has been disconnected.
¡     In Figure 3, the bus address is 0000:31:00.0. Execute the lspci –vvv –s 0000:31:00.0 command. If no output is displayed, it indicates that the OCP network adapter has been disconnected.
Figure 3 Identifying OCP network adapter status
5.     Reinstall the OCP network adapter.
6.     Execute the echo 1 > /sys/bus/pci/slots/slot_number/power command to power off the network adapter, where slot_number represents the number of the slot where the OCP network adapter resides.
Figure 4 Executing the echo 1 > /sys/bus/pci/slots/slot_number/power command
7.     Identify whether the OCP network adapter has been connected:
¡     Observe the OCP network adapter LED. If the LED is on, it indicates that the OCP network adapter has been connected.
¡     In Figure 5, the bus address is 0000:31:00.0. Execute the lspci –vvv –s 0000:31:00.0 command. If the command output is displayed, it indicates that the OCP network adapter has been connected.
Figure 5 Identifying OCP network adapter status
8.     Identify whether any exception exists. If any exception occurs, contact Technical Support.
