11-Segment Routing Command Reference
HomeSupportRoutersSR8800-X SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command Reference-R8630Pxx-6W10011-Segment Routing Command Reference
04-SRv6 TE policy commands
04-SRv6 TE policy commands 1.86 MB
Content
SRv6 TE policy commands· 1
address-family ipv6 sr-policy· 1
advertise ebgp enable· 1
affinity (SRv6 TE ODN dynamic view) 2
affinity (SRv6 TE policy constraints view) 2
affinity-map· 3
autoroute enable (SRv6 TE policy view) 4
autoroute enable (SRv6 TE policy group view) 5
autoroute isis· 6
autoroute metric (SRv6 TE policy view) 7
autoroute metric (SRv6 TE policy group view) 8
backup hot-standby· 9
bestroute encap-type· 9
best-effort match dscp (DSCP forward type view) 10
best-effort match dscp (SRv6 TE policy group view) 12
best-effort match service-class (service class forward type view) 15
best-effort match service-class (SRv6 TE policy group view) 17
bfd { no-bypass | bypass } 18
bfd echo· 20
bfd srv6-encapsulation-mode encap· 22
bfd trigger path-down· 23
binding-sid (SRv6 TE policy view) 25
bypass enable· 26
candidate-paths· 26
cmi threshold· 27
color end-point 28
color match dot1p· 28
color match dscp (DSCP forward type view) 30
color match dscp (SRv6 TE policy group view) 32
color match service-class (service class forward type view) 33
color match service-class (SRv6 TE policy group view) 35
constraints· 37
default-color (public instance IPv4/IPv6 address family view) 38
default-color (VPN instance IPv4/IPv6 address family view) 38
default match (APN ID-based traffic steering) 39
default match (ARN ID-based traffic steering) 41
default match (TE class ID-based traffic steering) 43
delay threshold· 45
delete-delay (SRv6 TE ODN view) 46
delete-delay (SRv6 TE ODN policy group view) 46
description· 47
display bgp mirror remote-sid· 48
display bgp routing-table ipv6 sr-policy· 49
display evpn srv6 mirror remote-sid· 57
display pce segment-routing ipv6 policy database· 58
display pce segment-routing ipv6 policy initiate-cache· 61
display segment-routing ipv6 te bfd· 63
display segment-routing ipv6 te database· 65
display segment-routing ipv6 te forwarding· 76
display segment-routing ipv6 te forwarding traffic-statistics· 79
display segment-routing ipv6 te path-segment 81
display segment-routing ipv6 te policy· 83
display segment-routing ipv6 te policy ifit 92
display segment-routing ipv6 te policy last-down-reason· 96
display segment-routing ipv6 te policy statistics· 98
display segment-routing ipv6 te policy status· 100
display segment-routing ipv6 te policy-group· 101
display segment-routing ipv6 te policy-group apn-id-ipv6· 107
display segment-routing ipv6 te policy-group last-down-reason· 108
display segment-routing ipv6 te policy-group statistics· 110
display segment-routing ipv6 te sbfd· 112
display segment-routing ipv6 te segment-list 114
display segment-routing ipv6 te source-sid· 117
display segment-routing ipv6 te ipr 119
distribute bgp-ls· 120
drop-upon-invalid· 121
drop-upon-mismatch enable· 122
dynamic (SRv6 TE policy path preference view) 123
dynamic (SRv6 TE ODN view) 124
encapsulation-mode (SRv6 TE policy view) 124
encapsulation-mode encaps include local-end.x· 126
encapsulation-mode insert include local-end.x· 127
end-point 128
exclude-any· 129
explicit segment-list 130
fast-reroute mirror delete-delay· 132
fast-reroute mirror enable· 133
forwarding statistics· 134
forward-type (SRv6 TE ODN policy group view) 135
forward-type (SRv6 TE policy group view) 138
forward { no-bypass | bypass } 140
group-color 142
ifit delay-measure· 143
ifit interval 145
ifit loss-measure· 146
ifit measure mode· 148
import-route sr-policy· 150
include-all 150
include-any· 151
index· 152
index apn-id match· 159
index arn-id match· 162
index te-class match· 164
intelligent-policy-route· 166
ipr-policy· 167
jitter threshold· 168
local-binding-sid· 169
loss threshold· 170
maximum-sid-depth· 171
measure count 172
metric· 173
metric-inherit (SRv6 TE policy view) 174
metric-inherit (SRv6 TE policy group view) 175
metric-type (SRv6 TE policy view) 176
metric-type (SRv6 TE policy group view) 178
mirror remote-sid delete-delay· 180
name· 181
name bit-position· 182
on-demand· 183
on-demand-group· 184
path verification· 185
pce capability segment-routing ipv6· 187
pce delegation· 187
pce passive-delegate report-only· 188
pcep (SRv6 TE policy path preference dynamic view) 189
pcep (SRv6 TE ODN dynamic view) 190
policy· 191
policy-group· 191
preference· 192
rate-limit 193
refresh-period· 193
reoptimization· 194
reset segment-routing ipv6 te forwarding statistics· 195
restrict 196
reverse-binding-sid· 196
router-id filter 197
sbfd· 199
segment-list 201
segments· 202
service-class· 202
shutdown· 203
sid-algorithm·· 204
sid-limit 205
snmp-agent trap enable srv6-policy· 206
sr-policy steering· 207
sr-te frr enable· 208
srv6-policy alarm-threshold· 209
srv6-policy autoroute enable· 210
srv6-policy backup hot-standby enable· 212
srv6-policy bfd echo· 213
srv6-policy bfd first-fail-timer 214
srv6-policy bfd no-bypass· 215
srv6-policy bfd trigger path-down enable· 217
srv6-policy calc-schedule-interval 218
srv6-policy color priority· 219
srv6-policy drop-upon-invalid enable· 221
srv6-policy encapsulation-mode· 222
srv6-policy encapsulation-mode encaps include local-end.x· 223
srv6-policy encapsulation-mode insert include local-end.x· 224
srv6-policy forward no-bypass· 225
srv6-policy forwarding statistics enable· 227
srv6-policy forwarding statistics interval 228
srv6-policy ifit delay-measure enable· 228
srv6-policy ifit interval 230
srv6-policy ifit loss-measure enable· 231
srv6-policy ifit measure mode· 233
srv6-policy immediate-reoptimization· 235
srv6-policy locator 236
srv6-policy log enable· 237
srv6-policy metric-inherit enable· 237
srv6-policy path verification enable· 238
srv6-policy pce delegation enable· 240
srv6-policy pce passive-delegate report-only enable· 241
srv6-policy reoptimization· 242
srv6-policy sbfd· 242
srv6-policy suppress-flapping· 244
srv6-policy suppress-flapping disable· 246
srv6-policy switch-delay delete-delay· 246
srv6-policy up-delay· 247
strict-sid-only enable· 248
switch-period· 249
te ipv6-router-id· 250
traffic-engineering· 251
ttl-mode· 251
type· 252
up-delay· 253
validation-check enable· 254
wait-to-restore-period (SRv6 TE IPR policy view) 255
Use address-family ipv6 sr-policy to create the BGP IPv6 SR policy address family and enter its view, or enter the view of the existing BGP IPv6 SR policy address family.
Use undo address-family ipv6 sr-policy to delete the BGP IPv6 SR policy address family and all the configuration in the BGP IPv6 SR policy address family.
The BGP IPv6 SR policy address family does not exist.
BGP instance view
The configuration in BGP IPv6 SR policy address family view applies only to routes and peers in the BGP IPv6 SR policy address family.
# In BGP instance view, create the BGP IPv6 SR policy address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6]
Use advertise ebgp enable to enable advertising BGP IPv6 SR policy routes to EBGP peers.
Use undo advertise ebgp enable to restore the default.
BGP IPv6 SR policy routes are not advertised to EBGP peers.
By default, BGP IPv6 SR policy routes are advertised among IBGP peers. To advertise BGP IPv6 SR policy routes to EBGP peers, you must execute this command to enable the advertisement capability.
# Enable advertising BGP IPv6 SR policy routes to EBGP peers.
[Sysname] bgp 100
[Sysname-bgp-default] address ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] advertise ebgp enable
Use affinity to create the affinity attribute rule and enter its view, or enter the view of the existing affinity attribute rule.
Use undo affinity to delete the affinity attribute rule view and all the configurations in the view.
affinity { include-all | include-any | exclude-any }
undo affinity { include-all | include-any | exclude-any }
The affinity attribute rule is not created for an SRv6 TE policy.
include-all: Uses the links that include all specific affinity attributes.
include-any: Uses the links that include any specific affinity attribute.
exclude-any: Uses the links that do not include any specific affinity attribute.
# Create the include-all affinity attribute rule and enter affinity attribute rule view.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] on-demand color 1
[Sysname-srv6-te-odn-1] dynamic
[Sysname-srv6-te-odn-1-dynamic] affinity include-all
[Sysname-srv6-te-odn-1-dynamic-aff-include-all]
Use affinity to create and enter the affinity attribute view, or enter the existing affinity attribute view.
Use undo affinity to delete the affinity attribute view and all the configurations in the view.
affinity
undo affinity
The affinity attribute is not created for an SRv6 TE policy.
Constraints view
# Enter affinity attribute view.
[Sysname] segment-routing-ipv6
[Sysname-srv6-te] policy a1
[Sysname-srv6-te-policy-a1] candidate-paths
[Sysname-srv6-te-policy-a1-path] preference 200
[Sysname-srv6-te-policy-a1-path-pref-200] constraints
[Sysname-srv6-te-policy-a1-path-pref-200-const] affinity
[Sysname-srv6-te-policy-a1-path-pref-200-const-aff]
affinity-map
Use affinity-map to create the constraints mapping and enter its view, or enter the view of the existing constraints mapping.
Use undo affinity-map to delete the constraints mapping view and all the configurations in the view.
affinity-map
undo affinity-map
No constraints mapping exists.
SRv6 TE view
# Create the constraints mapping and enter its view
[Sysname-srv6-te] affinity-map
[Sysname-srv6-te-affinity-map]
Use autoroute enable to enable automatic route advertisement for an SRv6 TE policy.
Use undo autoroute enable to disable automatic route advertisement for an SRv6 TE policy.
autoroute enable [ isis | ospfv3 ]
Automatic route advertisement is disabled for an SRv6 TE policy.
SRv6 TE policy view
isis: Enables automatic route advertisement for IPv6 IS-IS.
ospfv3: Enables automatic route advertisement for OSPFv3.
The automatic route advertisement feature takes an SRv6 TE policy tunnel as a direct link to participate in IGP (OSPFv3 or IPv6 IS-IS) route computation, allowing traffic to be forwarded through the SRv6 TE policy tunnel.
An SRv6 TE policy supports only automatic route advertisement in IGP shortcut mode, which is also called autoroute announce. Autoroute announce regards the SRv6 TE policy tunnel as a link that connects the tunnel ingress and egress. The tunnel ingress includes the SRv6 TE policy tunnel in IGP route computation.
If you do not specify the isis or ospfv3 keyword, both OSPFv3 and IPv6 IS-IS will include the SRv6 TE policy tunnel in route computation.
If you use the autoroute enable command both for an SRv6 TE policy group and an SRv6 TE policy, and the SRv6 TE policy group tunnel and SRv6 TE policy tunnel form ECMP routes, the device preferentially forwards traffic through the SRv6 TE policy group tunnel.
# Enable automatic route advertisement for an SRv6 TE policy.
[Sysname-srv6-te] policy srv6policy
[Sysname-srv6-te-policy-srv6policy] autoroute enable
Use autoroute enable to enable automatic route advertisement for an SRv6 TE policy group.
Use undo autoroute enable to disable automatic route advertisement for an SRv6 TE policy group.
autoroute enable isis
Automatic route advertisement is disabled for an SRv6 TE policy group.
Operating mechanism
The automatic route advertisement feature takes an SRv6 TE policy group tunnel as an ingress-to-egress direct link to participate in IGP (IPv6 IS-IS) route computation, allowing traffic to be forwarded through the SRv6 TE policy group tunnel.
An SRv6 TE policy group supports only automatic route advertisement in IGP shortcut mode, which is also called autoroute announce. Autoroute announce regards the SRv6 TE policy group tunnel as a link that connects the tunnel ingress and egress. The tunnel ingress includes the SRv6 TE policy group tunnel in IGP route computation.
After automatic route advertisement is enabled for an SRv6 TE policy group, traffic destined for the public network can be steered to the SRv6 TE policy group for further forwarding. The SRv6 TE policy group cannot correctly forward traffic to public-network IP addresses if one of the following conditions exists:
·     The SRv6 TE policy group is configured to forward traffic only in SRv6 BE mode.
·     The SRv6 TE policy group forwards traffic only in SRv6 BE mode, because all members in the SRv6 TE policy group are in down state and do not take effect.
# Enable automatic route advertisement for an SRv6 TE policy group.
[Sysname-srv6-te] policy-group 1
[Sysname-srv6-te-policy-group-1] autoroute enable isis
autoroute isis
Use autoroute isis to configure a policy for automatic route advertisement in IS-IS.
Use undo autoroute isis to restore the default.
autoroute isis { host-only | include-ipv4 | route-policy route-policy-name } *
undo autoroute isis
All IPv6 IS-IS routes can be automatically redirected and recursed to an SRv6 TE policy group or SRv6 TE policy tunnel. IPv4 IS-IS routes cannot be automatically redirected or recursed to an SRv6 TE policy group or SRv6 TE policy tunnel.
SRv6 TE policy view
host-only: Allows only host routes to recurse to an SRv6 TE policy group or SRv6 TE policy tunnel.
include-ipv4: Allows both IPv4 IS-IS routes and IPv6 IS-IS routes to recurse to an SRv6 TE policy group or SRv6 TE policy tunnel. With this keyword, the device includes the SRv6 TE policy group or SRv6 TE policy tunnel as a direct link in the route calculation of IPv4 IS-IS and IPv6 IS-IS. If you do not specify this keyword, the device allows only IPv6 IS-IS routes to recurse to the SRv6 TE policy group or SRv6 TE policy tunnel.
route-policy route-policy-name: Specifies a routing policy by its name. The route-policy-name argument is a case-sensitive string of 1 to 63 characters. If you specify a routing policy, this command allows only routes that match the specified routing policy to recurse to an SRv6 TE policy group or SRv6 TE policy tunnel.
By default, IPv6 IS-IS takes an SRv6 TE policy or SRv6 TE policy group tunnel as an ingress-to-egress direct link to participate in all IPv6 IS-IS route computations. If the link has the optimal IS-IS metric value, traffic destined for IPv6 IS-IS routes will be steered to the SRv6 TE policy or SRv6 TE policy group tunnel for forwarding.
To use an SRv6 TE policy or SRv6 TE policy group tunnel to guarantee traffic destined for specific routes, and to control the forwarding path of the traffic, you can use this command. This command recurses only the routes that meet the specified conditions to the SRv6 TE policy or SRv6 TE policy group tunnel.
For the autoroute isis command to take effect in SRv6 TE policy view or SRv6 TE policy group view, you must execute the following commands:
·     The autoroute enable command in SRv6 TE policy view or SRv6 TE policy group view.
·     The srv6-policy autoroute enable command in IS-IS IPv6 address family view.
If you execute the autoroute isis command multiple times in the same view, the most recent configuration takes effect.
# Configure IS-IS automatic route advertisement to allow only host routes to recurse to SRv6 TE policy p1.
[Sysname-srv6-te] policy p1
[Sysname-srv6-te-policy-p1] autoroute enable isis
[Sysname-srv6-te-policy-p1] autoroute isis host-only
# Configure IS-IS automatic route advertisement to allow only host routes to recurse to SRv6 TE policy group 1.
[Sysname-srv6-te-policy-group-1] autoroute isis host-only
autoroute enable (SRv6 TE Policy group view)
autoroute enable (SRv6 TE Policy view)
Use autoroute metric to configure an autoroute metric for an SRv6 TE policy.
Use undo autoroute metric to restore the default.
autoroute metric { absolute value | relative value }
The autoroute metric of an SRv6 TE policy equals its IGP metric.
SRv6 TE policy view
absolute value: Specifies an absolute metric, an integer in the range of 1 to 65535.
relative value: Specifies a relative metric, an integer in the range of –10 to +10. The specified relative metric plus the shortest IGP metric of the SRv6 TE policy tunnel from the ingress to the egress is the actual metric of the SRv6 TE policy.
After automatic route advertisement is enabled for an SRv6 TE policy, the policy is included in IGP route computation as a link. You can use this command to configure the metric of this link used for IGP route computation.
# Set an absolute metric of 15 for SRv6 TE policy srv6policy.
[Sysname-srv6-te-policy-srv6policy] autoroute metric absolute 15
autoroute enable
Use autoroute metric to configure an autoroute metric for an SRv6 TE policy group.
The autoroute metric of an SRv6 TE policy group equals the default IGP metric. For IPv6 IS-IS, the autoroute metric of an SRv6 TE policy group is 10.
relative value: Specifies a relative metric, an integer in the range of –10 to +10. The specified relative metric plus the shortest IGP metric of the SRv6 TE policy group tunnel from the ingress to the egress is the actual metric of the SRv6 TE policy group.
After automatic route advertisement is enabled for an SRv6 TE policy group, the policy group is included in IGP route computation as a direct link. You can use this command to configure the metric of this link used for IGP route computation.
# Set an absolute metric of 15 for SRv6 TE policy group 1.
[Sysname-srv6-te-policy-group-1] autoroute metric absolute 15
backup hot-standby
Use backup hot-standby to configure hot standby for an SRv6 TE policy.
Use undo backup hot-standby to restore the default.
backup hot-standby { disable | enable }
Hot standby is not configured for an SRv6 TE policy.
SRv6 TE policy view
disable: Disables hot standby for the SRv6 TE policy.
enable: Enables hot standby for the SRv6 TE policy.
The hot standby feature takes the candidate path with the greatest preference value in the SRv6 TE policy as the primary path and that with the second greatest preference value as the standby path. When the forwarding paths corresponding to all SID lists of the primary path fail, the standby path immediately takes over to minimize service interruption.
You can enable hot standby for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable hot standby for SRv6 TE policy 1.
[Sysname-srv6-te] policy 1
[Sysname-srv6-te-policy-1] backup hot-standby enable
Use bestroute encap-type to specify the packet encapsulation type preferred in optimal route selection.
Use undo bestroute encap-type to restore the default.
bestroute encap-type { mpls | srv6 } [ preferred ]
The device does not select optimal routes according to the packet encapsulation type.
BGP-VPN instance view.
mpls: Prefers to use MPLS-encapsulated routes during optimal route selection.
srv6: Prefers to use SRv6-encapsulated routes during optimal route selection.
preferred: Increases the priority of packet encapsulation type in BGP route selection.
For more information about the priority order of the configuration in this command in BGP route selection, see BGP overview in Layer 3—IP Routing Configuration Guide.
# Configure BGP to prefer SRv6-encapsulated routes during optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] bestroute encap-type srv6
Use best-effort match dscp to specify DSCP values to match traffic that will be forwarded in SRv6 BE mode in an SRv6 TE policy group ODN template.
Use undo best-effort match dscp to remove the DSCP values specified for the SRv6 BE mode to match traffic in an SRv6 TE policy group ODN template.
best-effort match dscp { ipv4 | ipv6 } dscp-value-list
undo best-effort match dscp { ipv4 | ipv6 } [ dscp-value-list ]
best-effort { ipv4 | ipv6 } default
undo best-effort { ipv4 | ipv6 } default
No DSCP values are specified for the SRv6 BE mode to match traffic.
ipv4: Specifies DSCP values of IPv4 packets.
ipv6: Specifies DSCP values of IPv6 packets.
dscp-value-list: Specifies a space-separated list of up to 32 DSCP value items. Each item specifies a DSCP value or a range of DSCP values in the form of dscp-value1 to dscp-value2. The value range for DSCP values in 0 to 63. The value for the dscp-value2 argument must be greater than or equal to the value for the dscp-value1 argument. If you do not specify a DSCP value for the undo best-effort match dscp command, the command removes all DSCP values specified for the SRv6 BE mode to match traffic.
default: Specifies SRv6 BE mode as the default forwarding mode for packets in a specific address family. If the DSCP values of the packets do not match any SRv6 TE policy or SRv6 BE forwarding policy, the device will forward the packets in SRv6 BE mode. Typically, SRv6 BE mode is used as a backup method for SRv6 TE policy-based forwarding.
Use this command to configure traffic with the specified DSCP values to be forwarded in SRv6 BE mode after the traffic is steered to an SRv6 TE policy group created based on the SRv6 TE policy group ODN template. When the device forwards packets in SRv6 BE mode, it encapsulates the original packets with a new IPv6 header. The destination address in the new IPv6 header is the VPN SID assigned to routes by the egress node of the SRv6 TE policy group. Then, the device performs an IPv6 routing table lookup to forward the encapsulated packets. If the VPN SID is unreachable, the SRv6 BE mode is invalid.
Operating mechanism
After a packet is steered to an SRv6 TE policy group, the device searches for a matching forwarding policy for the packet based on the DSCP value in the packet and the configuration status of the color match dscp, best-effort match dscp, and drop-upon-mismatch enable commands. If the device finds a matching forwarding policy by a match criterion and the forwarding policy is valid, it uses the forwarding policy to forward the packet. If no matching forwarding policy is found or the matching forwarding policy is invalid, the device proceeds to use the next match criterion to find a matching forwarding policy. The procedure to find a matching forwarding policy is as follows:
1.     Matches the DSCP value in the packet with the mappings configured by using the color match dscp and best-effort match dscp commands for the address family of the packet. If a match is found, the device uses the matching SRv6 TE policy to forward the packet or forwards the packet in SRv6 BE mode.
2.     Uses the default SRv6 TE policy specified by using the color match dscp default command for the address family of the packet to forward the packet.
3.     Identifies whether SRv6 BE mode has been specified as the default forwarding mode for the address family of the packet by using the best-effort { ipv4 | ipv6 } default command. If yes, the device forwards the packet in SRv6 BE mode.
4.     Uses the default SRv6 TE policy specified by using the color match dscp default command for the other address family to forward the packet.
5.     Identifies whether SRv6 BE mode has been specified as the default forwarding mode for the other address family by using the best-effort { ipv4 | ipv6 } default command. If yes, the device forwards the packet in SRv6 BE mode.
6.     Handles the packet according to whether the drop-upon-mismatch enable command is used.
¡     If the drop-upon-mismatch enable command is used, the device discards the packet.
¡     If the drop-upon-mismatch enable command is not used, the device identifies whether the SRv6 TE policy group is configured with color-to-DSCP mappings in the current address family:
-     If yes, the device searches the current address family for a mapping with the smallest DSCP value and a valid SRv6 TE policy. The device will use that SRv6 TE policy to forward the packet.
-     If not, the device turns to other address families (where the SRv6 TE policy group is configured with color-to-DSCP mappings) for a mapping with the smallest DSCP value and a valid SRv6 TE policy. The device will use that SRv6 TE policy to forward the packet.
In an SRv6 TE policy group, you can configure DSCP-based traffic steering separately for the IPv4 address family and IPv6 address family. For a specific address family, a DSCP value can be mapped to only one SRv6 TE policy or to only the SRv6 BE mode.
If one of the following conditions exists, an SRv6 TE policy group will not be used for traffic forwarding:
·     All SRv6 TE policies in the SRv6 TE policy group are invalid.
·     The SRv6 TE policy group is enabled with SRv6 BE-based traffic forwarding, and no SRv6 TE policy is specified for traffic forwarding.
# In an SRv6 TE policy group ODN template, configure the system to forward IPv6 packets with DSCP value 30 in SRv6 BE mode.
[Sysname-srv6-te] on-demand-group color 1
[Sysname-srv6-te-odn-group-1] forward-type dscp
[Sysname-srv6-te-odn-group-1-dscp] best-effort match dscp ipv6 30
# In an SRv6 TE policy group ODN template, configure the system to forward IPv6 packets that do not match any DSCP-based forwarding policy in SRv6 BE mode.
[Sysname-srv6-te-odn-group-1-dscp] best-effort ipv6 default
Use best-effort match dscp to specify DSCP values to match traffic that will be forwarded in SRv6 BE mode.
Use undo best-effort match dscp to remove the DSCP values specified for the SRv6 BE mode to match traffic.
dscp-value-list: Specifies a space-separated list of up to 32 DSCP value items. Each item specifies a DSCP value or a range of DSCP values in the form of dscp-value1 to dscp-value2. The value range for DSCP values is 0 to 63. The value for the dscp-value2 argument must be greater than or equal to the value for the dscp-value1 argument. If you do not specify a DSCP value for the undo best-effort match dscp command, the command removes all DSCP values specified for the SRv6 BE mode to match traffic.
Use this command to configure traffic with the specified DSCP values to be forwarded in SRv6 BE mode after the traffic is steered to the SRv6 TE policy group for forwarding. When the device forwards packets in SRv6 BE mode, it encapsulates the original packets with a new IPv6 header. The destination address in the new IPv6 header is the VPN SID assigned to routes by the egress node of the SRv6 TE policy group. Then, the device performs an IPv6 routing table lookup to forward the encapsulated packets. If the VPN SID is unreachable, the SRv6 BE mode is invalid.
Operating mechanism
# In an SRv6 TE policy group named 10, configure the system to forward IPv4 packets with DSCP value 5 in SRv6 BE mode.
[Sysname-srv6-te] policy-group 10
[Sysname-srv6-te-policy-group-10] best-effort match dscp ipv4 5
# In an SRv6 TE policy group named 10, configure the system to forward IPv4 packets that do not match any DSCP-based forwarding policy in SRv6 BE mode.
[Sysname-srv6-te-policy-group-10] best-effort ipv4 default
Use best-effort match service-class to specify service class values with which traffic will be forwarded in SRv6 BE mode in an SRv6 TE policy group ODN template.
Use undo best-effort match service-class to remove the service class values specified for forwarding traffic in SRv6 BE mode in an SRv6 TE policy group ODN template.
best-effort match service-class service-class-value-list
undo best-effort match service-class service-class-value-list
best-effort match service-class default
undo best-effort match service-class [ default ]
No service class values are specified for the device to forward traffic in SRv6 BE mode in an SRv6 TE policy group ODN template.
Service class forward type view
service-class-value-list: Specifies a space-separated list of up to eight service class value items. Each item specifies a service class value or a range of service class values in the form of service-class-value1 to service-class-value2. The value range for service class values is 1 to 15. The value for the service-class-value2 argument must be greater than or equal to the value for the service-class-value1 argument.
default: Forwards packets that do not match any SRv6 BE-to-service class mapping in SRv6 BE mode.
About this command
Use this command to configure traffic with the specified service class values to be forwarded in SRv6 BE mode after the traffic is steered to an SRv6 TE policy group for forwarding. When the device forwards packets in SRv6 BE mode, it encapsulates the original packets with a new IPv6 header. The destination address in the new IPv6 header is the VPN SID assigned to public or private network routes by the egress node of the SRv6 TE policy group. Then, the device performs an IPv6 routing table lookup to forward the encapsulated packets. If the VPN SID is unreachable, the SRv6 BE mode is invalid.
The service class is a type of local ID on the device. You can use the remark service-class command to mark the service class of traffic. For more information about the remark service-class command, see QoS commands in ACL and QoS Command Reference.
Operating mechanism
When service class-based traffic steering is used, the device uses the following process to forward a packet:
1.     Matches the service class value in the packet with the mappings configured by using the color match service-class and best-effort match service-class commands. If a match is found, the device uses the matching SRv6 TE policy to forward the packet or forwards the packet in SRv6 BE mode.
2.     Uses the default SRv6 TE policy specified by using the color match service-class default command to forward the packet in the following situations:
¡     The service class value in the packet does not match an SRv6 TE policy or the SRv6 BE mode.
¡     The service class value in the packet matches an SRv6 TE policy or the SRv6 BE mode. However, the matching SRv6 TE policy or the SRv6 BE mode is invalid.
3.     Forwards the packet in SRv6 BE mode if both of the following requirements are met:
¡     No default SRv6 TE policy is specified by using the color match service-class default command, or the default SRv6 TE policy is invalid.
¡     The best-effort match service-class default command is used and the SRv6 BE mode is valid.
4.     Handles the packet according to whether the drop-upon-mismatch enable command is used if the best-effort match service-class default command is not used or the SRv6 BE path is invalid.
¡     If the drop-upon-mismatch enable command is not used, the device uses the method specified in the mapping with the smallest service class value to forward the packet.
For an SRv6 TE policy group, a service class value can be mapped only to the SRv6 BE mode or to one SRv6 TE policy.
# In SRv6 TE policy group ODN template, steer packets with service class 5 to the SRv6 BE path.
[Sysname-srv6-te-odn-group-1] forward-type service-class
[Sysname-srv6-te-odn-group-1-service-class] best-effort match service-class 6
Use best-effort match service-class to specify service class values with which traffic will be forwarded in SRv6 BE mode.
Use undo best-effort match service-class to remove the service class values specified for forwarding traffic in SRv6 BE mode.
No service class values are specified for the device to forward traffic in SRv6 BE mode.
Execute the forward-type service-class command before using this command.
About this command
Operating mechanism
# In SRv6 TE policy group, steer packets with service class 5 to the SRv6 BE path.
[Sysname-srv6-te-policy-group-10] forward-type service-class
[Sysname-srv6-te-policy-group-10] best-effort match service-class 5
Use bfd no-bypass to enable the BFD No-Bypass feature for an SRv6 TE policy.
Use bfd bypass to enable the BFD Bypass feature for an SRv6 TE policy.
Use undo bfd { no-bypass | bypass } to restore the default.
bfd { bypass | no-bypass }
undo bfd { bypass | no-bypass }
The BFD No-Bypass and BFD Bypass features are not configured for an SRv6 TE policy. The configuration in SRv6 TE view applies.
SRv6 TE policy view
bypass: Enables the BFD Bypass feature to forward BFD or SBFD packets through the local protection path.
no-bypass: Enables the BFD No-Bypass feature to prevent BFD or SBFD packets from being forwarded through the local protection path (for example, the backup path calculated with TI-LFA).
When you use BFD/SBFD to detect connectivity of an SRv6 TE policy, the following conditions might exist:
·     All SID lists for the primary candidate path fail.
·     A local protection path (for example, a backup path calculated with TI-LFA) is available.
In this situation, all the BFD/SBFD packets will be forwarded through the local protection path. The BFD/SBFD session and primary candidate path will remain in up status, and traffic will be forwarded through the local protection path.
In certain scenarios, the local protection path might have unstable bandwidth and delay issues and fail to meet specific service requirements. In this case, the local protection path can only be used to protect traffic temporarily. When you enable the BFD No-Bypass feature, if all SID lists for the primary candidate path fail, the local protection path does not forward BFD/SBFD packets. The associated BFD/SBFD session then goes down, and the primary candidate path goes down as a result. Traffic will switch over to the backup candidate path or another SRv6 TE policy for forwarding. The BFD No-Bypass feature prevents traffic from being forwarded through the local protection path for a long time.
You can enable the BFD No-Bypass feature for the source node and SRH flag check for transit nodes of the SRv6 TE policy to meet the following requirements:
·     Prevent traffic from being forwarded through the local protection path for a long time.
·     Prevent BFD/SBFD packets from being forwarded through the local protection path.
After you can enable the BFD No-Bypass feature for the source node of the SRv6 TE policy, the source node sets the No-Bypass and No-FRR flag bits when encapsulating the SRH for packets.
You can enable the BFD No-Bypass feature for all SRv6-TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
The Bypass and No-Bypass features of an SRv6 TE policy also take effect on BFD or SBFD packets of that SRv6 TE policy. For BFD or SBFD packets, the status of the Bypass and No-Bypass features is determined by the following commands in descending order:
1.     The forward { no-bypass | bypass } command in SRv6 TE policy view.
2.     The srv6-policy forward no-bypass command in SRv6 TE view.
3.     The bfd { no-bypass | bypass } command in SRv6 TE policy view.
4.     The srv6-policy bfd no-bypass command in SRv6 TE view.
In an SRv6 network slicing scenario, the Bypass or BFD Bypass feature in an SRv6 TE policy cannot take effect on BFD or SBFD packets of that SRv6 TE policy if NSIs are applied to the candidate paths of that SRv6 TE policy and BFD or SBFD is configured to detect the connectivity of that SRv6 TE policy. BFD or SBFD packets are forced to not be forwarded through the local protection path.
# Enable the BFD No-Bypass feature for SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] bfd no-bypass
bfd echo
Use bfd echo to configure the echo packet mode BFD for an SRv6 TE policy.
Use undo bfd echo to restore the default.
bfd echo { disable | enable [ source-ipv6 ipv6-address ] [ template template-name ] [ backup-template backup-template-name ] [ oam-sid sid ] [ encaps | insert ] [ reverse-path { reverse-binding-sid | xsid } }
undo bfd echo
The echo packet mode BFD is not configured for an SRv6 TE policy. An SRv6 TE policy uses the echo BFD settings configured in SRv6 TE view.
SRv6 TE policy view
disable: Disables the echo packet mode BFD for the SRv6 TE policy.
enable: Enables the echo packet mode BFD for the SRv6 TE policy.
source-ipv6 ipv6-address: Specifies the source IPv6 address of the BFD session. If you do not specify this option, the configuration in SRv6 TE view applies.
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the template specified in SRv6 TE view applies.
backup-template backup-template-name e: Specifies a BFD session parameter template for the backup SID list. The backup-template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the backup template specified in SRv6 TE view applies.
oam-sid sid: Adds an OAM SID to BFD packets to identify the destination node. The sid argument represents the SRv6 SID of the destination node. If you do not specify this option, no OAM SID will be added to BFD packets.
encaps: Uses the normal encapsulation mode to encapsulate BFD packets.
insert: Uses the insertion mode to encapsulate BFD packets.
reverse-path: Specifies the reverse path for BFD packets. If you do not specify this keyword, the device forwards BFD packets back to the source node based on the IP forwarding path.
reverse-binding-sid: Uses the SID list associated with the reverse BSID as the reverse path for BFD packets.
xsid: Uses the SID list associated with the End.XSID as the reverse path for BFD packets. An End.XSID is a BSID that directs traffic to the forwarding path identified by the SID list of the SRv6 TE policy associated with the BSID.
To use echo BFD to detect an SRv6 TE policy, the device needs to encapsulate the SID list of the SRv6 TE policy for the BFD packets. The following encapsulation modes are available:
·     Encaps—Normal encapsulation mode. It adds a new IPv6 header and an SRH to the original packets. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH.
·     Insert—Insertion mode. It inserts an SRH after the original IPv6 header. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH.
If you do not specify the encaps or insert keyword, the encapsulation mode configured by the bfd srv6-encapsulation-mode encap command applies.
By default, the BFD return packets used for SRv6 TE policy connectivity detection are forwarded based on the IP forwarding path. If a transit node fails, all the return packets will be discarded, and the BFD sessions will go down as a result. BFD thus will mistakenly determine that all the SID lists of the SRv6 TE policy are faulty. To resolve this issue, you can enable BFD return packets to be forwarded based on the specified SID list to implement BFD forward and reverse path consistency.
The following methods are available to implement BFD forward and reverse path consistency:
·     Specifying a reverse BSID—After the reverse-path reverse-binding-sid parameters are configured, the source node will insert an SRH header into a BFD packet and encapsulate the reverse BSID to the SL=1 position in the SRH header. You can specify the reverse BSID by using the explicit segment-list or reverse-binding-sid command. Upon receiving the BFD packet, the endpoint node retrieves the reverse BSID. If the reverse BSID matches the local BSID of an SRv6 TE policy on the endpoint node, the endpoint node inserts a new SRH into the BFD packet and forwards the packet along the SID list of that SRv6 TE policy. (To specify a local BSID for an SRv6 TE policy, use the local-binding-sid command.)
·     Specifying an End.XSID—End.XSID is also a type of BSID. After the reverse-path xsid parameters are configured, the source node will add a new IPv6 header and SRH header for the original BFD packet (the Encaps mode). The End.XSID will be encapsulated to the SL=0 position in the new SRH. You can specify this End.XSID by using the local-xsid parameter in the explicit segment-list command. Upon receiving the BFD packet, the endpoint node retrieves the End.XSID information. If the End.XSID matches the local BSID of an SRv6 TE policy at the endpoint node, the endpoint nodes executes the End.XSID forwarding behavior. This involves decapsulating the IPv6 and SRH headers of the BFD packet and then encapsulating new IPv6 and SRH headers. The new SRH extension header carries the SID list in the candidate path of the SRv6 TE policy, directing the return packet to follow this SID list.
After the reverse-path reverse-binding-sid keywords are specified, BFD packets can be encapsulated only in Insert mode. The encaps keyword does not take effect.
After the reverse-path xsid keywords are specified, BFD packets can be encapsulated only in Encaps mode. The insert keyword does not take effect.
To encapsulate the BFD packets for SRv6 TE policy connectivity detection, the device uses the encapsulation mode configured for BFD packets. The encapsulation mode configured for the SRv6 TE policy in SRv6 TE view or SRv6 TE policy view does not take effect on BFD packets.
You can configure the echo packet mode BFD for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
The device supports the echo packet mode BFD and the SBFD for an SRv6 TE policy. If both modes are configured for the same SRv6 TE policy, the SBFD takes effect.
If the SID lists of an SRv6 TE policy end with a 16-bit G-SID that carries a COC flavor, use the normal encapsulation mode to encapsulate BFD or SBFD packets. If BFD or SBFD packets are encapsulated in insertion mode, BFD or SBFD session setup might fail.
# Enable the echo packet mode BFD for SRv6 TE policy 1, and specify the source IPv6 address of the BFD session as 11::11.
[Sysname-srv6-te-policy-1] bfd echo enable source-ipv6 11::11
Use bfd srv6-encapsulation-mode encap to specify the Encap mode for the BFD or SBFD packets used for SRv6 forwarding paths connectivity detection.
Use undo bfd srv6-encapsulation-mode encap to restore the default.
The device uses the Insert mode to encapsulate the BFD or SBFD packets for SRv6 forwarding paths connectivity detection.
To use BFD or SBFD to detect an SRv6 TE policy, the device needs to encapsulate the SID list of the SRv6 TE policy for the BFD or SBFD packets. The following encapsulation modes are available:
·     Insert—Insertion mode. It inserts an SRH after the original IPv6 header. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH. If the length of the SID list is 0, the SRH is not inserted.
·     Encaps—Normal encapsulation mode. It adds a new IPv6 header and an SRH to the original packets. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH. If the length of the SID list is 0, the SRH is not inserted.
The encapsulation mode configured using this command cannot take effect immediately when a BFD or SBFD session has been established. You must first execute the bfd echo or sbfd command with the disable keyword specified to disable BFD or SBFD for the SRv6 TE policy and then enable BFD or SBFD for the SRv6 TE policy.
# Configure the device to use the Encap mode to encapsulate the BFD or SBFD packets for SRv6 forwarding paths connectivity detection.
[Sysname] bfd srv6-encapsulation-mode encap
bfd echo
sbfd
Use bfd trigger path-down to configure BFD session down events to trigger SRv6 TE policy path reselection.
Use undo bfd trigger path-down to restore the default.
bfd trigger path-down { disable | enable }
The feature is not configured for an SRv6 TE policy, and the configuration in SRv6 TE view applies.
SRv6 TE policy view
disable: Disables BFD session down events from triggering SRv6 TE policy path reselection.
enable: Enables BFD session down events to trigger SRv6 TE policy path reselection.
By default, when the SRv6 TE policy has multiple valid candidate paths, the following conditions exist:
·     If the hot standby feature is disabled, BFD or SBFD detects all SID lists for only the optimal valid candidate path of the SRv6 TE policy. The device establishes a BFD or SBFD session for each SID list. When all BFD or SBFD sessions go down, the SRv6 TE policy will not select other valid candidate paths, and the device will not forward packets through the SRv6 TE policy.
·     If the hot standby feature is enabled, BFD or SBFD detects all SID lists for the primary and backup paths of the SRv6 TE policy. The device establishes a BFD or SBFD session for each SID list.
¡     If all BFD or SBFD sessions for the primary path go down, the SRv6 TE policy will use the backup path to forward packets without reselecting other valid candidate paths.
¡     If all BFD or SBFD sessions for the primary and backup paths go down, the SRv6 TE policy will not select other valid candidate paths, and the device will not forward packets through the SRv6 TE policy.
If you enable BFD session down events to trigger SRv6 TE policy path reselection, the following conditions exist when the SRv6 TE policy has multiple valid candidate paths:
·     If the hot standby feature is disabled, BFD or SBFD detects all SID lists for only the optimal valid candidate path of the SRv6 TE policy. The device establishes a BFD or SBFD session for each SID list. When all BFD or SBFD sessions go down, the SRv6 TE policy will reselect other valid candidate paths for packet forwarding. If no valid candidate paths are available for the SRv6 TE policy, the device cannot forward packets through the SRv6 TE policy.
¡     If all BFD or SBFD sessions for the primary path go down, the SRv6 TE policy will use the backup path to forward packets, and reselect the primary and backup paths.
¡     If all BFD or SBFD sessions for the primary and backup paths go down, the SRv6 TE policy will reselect other valid candidate paths as the primary and backup paths. The device will forward packets through the new primary path of the SRv6 TE policy.
¡     During optimal path reselection, if no valid candidate paths are available for the SRv6 TE policy, the device cannot forward packets through the SRv6 TE policy.
Before you enable this feature for an SRv6 TE policy, create a BFD or SBFD session for the policy first.
You can configure BFD session down events to trigger candidate path reselection for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable BFD session down events to trigger candidate path reselection for SRv6 TE policy a1.
[Sysname-srv6-te-policy-a1] bfd trigger path-down enable
bfd echo
sbfd
srv6-policy sbfd
Use binding-sid to configure a BSID for an SRv6 TE policy.
Use undo binding-sid to delete the BSID.
binding-sid ipv6 ipv6-address [ coc-next | next ]
undo binding-sid
No static BSID is configured for an SRv6 TE policy.
SRv6 TE policy view
ipv6 ipv6-address: Specifies the BSID value, which is an IPv6 address.
coc-next: Adds the COC and NEXT flavors to the BSID. If neither of the coc-next and next keywords is specified, the BSID does not carry the COC or NEXT flavor.
next: Adds the NEXT flavors to the BSID. If neither of the coc-next and next keywords is specified, the BSID does not carry the COC or NEXT flavor.
You can use this command to manually configure a BSID for an SRv6 TE policy or leave the SRv6 TE policy to obtain a BSID automatically. If an SRv6 TE policy has only color and endpoint configuration, the SRv6 TE policy will automatically request a BSID.
The manually configured BSID has a higher priority over the automatically obtained BSID.
The BSID configured by this command must be on the locator specified for SRv6 TE policies in SRv6 TE view. Otherwise, the SRv6 TE policy cannot forward packets.
When a BSID carries the COC and NEXT flavors or only the NEXT flavor, it can be encapsulated into SRv6 packet headers as a 16-bit G-SID, which shortens SRv6 packet headers.
Support for BSID flavors varies by locator type. When you use this command to specify flavors for a BSID, follow these restrictions and guidelines:
·     Make sure the locator specified in the srv6-policy locator command meets the related requirements. For example:
¡     The BSID can carry the COC and NEXT flavors only if the specified locator is a COC16 locator in default mode.
¡     The BSID can carry the NEXT flavor only if the specified locator is a COC16 locator.
·     If the specified locator is a COC16 locator in W-LIB mode, you must specify the next keyword to ensure successful BSID assignment.
The real encapsulation mode for the current SRv6 TE policy is normal encapsulation under the following conditions:
·     The encapsulation mode specified for the SRv6 TE policy is insertion.
·     A compressed BSID is used for traffic steering to the SRv6 TE policy.
# Set the BSID of SRv6 TE policy srv6policy to 1000::1.
[Sysname-srv6-te-policy-srv6policy] binding-sid ipv6 1000::1
bypass enable
Use bypass enable to enable the bypass feature for an SRv6 TE policy.
Use undo bypass enable to disable the SRv6 TE policy bypass feature.
bypass enable
undo bypass enable
The SRv6 TE policy bypass feature is disabled.
SRv6 TE policy view
If the first SID in the SID list of an SRv6 TE policy is unreachable, the source node of the SRv6 TE policy will place the policy to down state. The device cannot forward packets through the SRv6 TE policy or trigger SRv6 TE FRR.
To resolve this issue, you can enable the bypass feature for the SRv6 TE policy on the source node. This feature enables the source node to generate a route that uses the first SID as the destination address and the NULL0 interface as the outgoing interface. The route ensures that the SRv6 TE policy is in up state when the first SID is unreachable, so as to trigger SRv6 TE FRR.
# Enable the bypass feature for an SRv6 TE policy.
[Sysname-srv6–te] policy 1
[Sysname-srv6–te-policy-1] bypass enable
sr-te frr enable
candidate-paths
Use candidate-paths to create and enter the candidate path view for an SRv6 TE policy, or enter the existing SRv6 TE policy candidate path view.
Use undo candidate-paths to delete the SRv6 TE policy candidate path view and all the configurations in the view.
candidate-paths
The candidate path view for an SRv6 TE policy does not exist.
SRv6 TE policy view
# Create the SRv6 TE policy candidate paths instance and enter its view.
[Sysname-srv6-te-policy-srv6policy] candidate-paths
[Sysname-srv6-te-policy-srv6policy-path]
cmi threshold
Use cmi threshold to set the Composite Measure Indicator (CMI) threshold in an IPR policy.
Use undo cmi threshold to restore the default.
cmi threshold threshold-value
undo cmi threshold
The CMI threshold in an IPR policy is 9000.
threshold-value: Specifies a CMI threshold value in the range of 0 to 9000.
CMI is a comprehensive indicator for measuring service quality. The CMI of a service = delay (milliseconds) + jitter (milliseconds) + packet loss rate (‰). The smaller the CMI value, the higher the link quality requirements.
An SRv6 TE policy can participate in optimal SRv6 TE policy selection as a candidate forwarding path only when the sum of the iFIT packet loss rate, delay, and jitter detected for that SRv6 TE policy does not cross the specified CMI threshold.
# Set the CMI threshold to 300 in IPR policy ipr1.
[Sysname-srv6-te] intelligent-policy-route
[Sysname-srv6-ipr] ipr-policy ipr1
[Sysname-srv6-ipr-policy-ipr1] cmi threshold 300
color end-point
Use color end-point to configure the color and endpoint attributes of an SRv6 TE policy.
Use undo color to delete the color and endpoint settings of an SRv6 TE policy.
color color-value end-point ipv6 ipv6-address
undo color
The color and endpoint attributes of an SRv6 TE policy are not configured.
SRv6 TE policy view
color-value: Specifies the color attribute value, in the range of 0 to 4294967295.
ipv6-address: Specifies the endpoint IPv6 address.
Different SRv6 TE policies cannot have the same color or endpoint IP address.
# Configure the color as 20 and endpoint IPv6 address as 1000::1 for SRv6 TE policy srv6policy.
[Sysname-srv6-te-policy-srv6policy] color 20 end-point ipv6 1000::1
color match dot1p
Use color match dot1p to create color-to-802.1p mappings for an SRv6 TE policy group.
Use undo color match dot1p to delete color-to-802.1p mappings for an SRv6 TE policy group.
color color-value match dot1p dot1p-value-list
undo color color-value match dot1p dot1p-value-list
color color-value match dot1p default
undo color color-value match dot1p [ default ]
No color-to-802.1p mappings are created for an SRv6 TE policy group.
color-value: Specifies the color attribute value of an SRv6 TE policy, in the range of 0 to 4294967295.
dot1p-value-list: Specifies a space-separated list of up to four 802.1p value items. Each item specifies an 802.1p value in the range of 0 to 7 or a range of 802.1p values in the form of dot1p-value1 to dot1p-value2. The value for the dot1p-value2 argument must be greater than or equal to the value for the dot1p-value1 argument.
default: Configures a default color-to-802.1p mapping. Packets that do not match any color-to-802.1p mappings are steered to the default SRv6 TE policy (the policy specified in the default mapping).
To use this command, you must first use the forward-type dot1p command.
Use this command to create color-to-802.1p mappings for 802.1p-based traffic steering.
You can map the color values of only valid SRv6 TE policies to 802.1p values. For an SRv6 TE policy group, an 802.1p value can be mapped to only one color value.
Use the color match dot1p default command to specify the default SRv6 TE policy for an SRv6 TE policy group. If no SRv6 TE policy in an SRv6 TE policy group matches a specific 802.1p value, the default SRv6 TE policy is used to forward packets containing the 802.1p value. Only one default SRv6 TE policy can be specified for an SRv6 TE policy group.
After the traffic is directed to an SRv6 TE policy group, when the device receives a packet that does not match any color-to-802.1p mapping, the device uses the following procedure to forward the packet:
1.     Uses the default SRv6 TE policy to forward the packet if the default SRv6 TE policy is valid.
2.     Handles the packet depending on whether the drop-upon-mismatch enable command is used.
¡     If the drop-upon-mismatch enable command is not used, the device uses the SRv6 TE policy mapped to the smallest 802.1p value to forward the packet in case that the SRv6 TE policy is valid.
# In SRv6 TE policy group 1, map 802.1p value 3 to color value 20, so that packets with a matching 802.1p value are steered to the associated SRv6 TE policy.
[Sysname-srv6-te-policy-group-1] forward-type dot1p
[Sysname-srv6-te-policy-group-1] color 20 match dot1p 3
forward-type dot1p
Use color match dscp to create color-to-DSCP mappings for the SRv6 TE policy group ODN template.
Use undo color match dscp to delete color-to-DSCP mappings from the SRv6 TE policy group ODN template.
color color-value match dscp { ipv4 | ipv6 } dscp-value-list
undo color color-value match dscp { ipv4 | ipv6 }
color color-value match dscp { ipv4 | ipv6 } default
undo color color-value match dscp { ipv4 | ipv6 } default
No color-to-DSCP mappings are created for the SRv6 TE policy group ODN template.
dscp-value-list: Specifies a space-separated list of up to 32 DSCP value items. Each item specifies a DSCP value in the range of 0 to 63 or a range of DSCP values in the form of dscp-value1 to dscp-value2. The value for the dscp-value2 argument must be greater than or equal to the value for the dscp-value1 argument.
default: Configures a default color-to-DSCP mapping. Packets that do not match any mappings are steered to the SRv6 TE policy associated with the color attribute value in the default mapping. This SRv6 TE policy is used as the default SRv6 TE policy for packets in the specified address family.
Typically, an SRv6 TE policy group created by an ODN template has multiple SRv6 TE policy tunnels with the same endpoint address but different color attribute values. After traffic is steered to the SRv6 TE policy group, the device matches the DSCP value of the traffic with the color-to-DSCP mappings configured by using this command. If a match is found, the device will forward the traffic through the SRv6 TE policy associated with the color attribute value in the matching mapping.
Operating mechanism
Only one default SRv6 TE policy can be specified for an address family in an SRv6 TE policy group.
# In an SRv6 TE policy group ODN template, map DSCP value 30 to color value 20 for IPv4 packets, so that IPv4 packets with DSCP value 30 are steered to the SRv6 TE policy with color value 20.
[Sysname-srv6-te-odn-group-1-dscp] color 20 match dscp ipv4 30
Use color match dscp to create color-to-DSCP mappings for an SRv6 TE policy group.
Use undo color match dscp to delete color-to-DSCP mappings for the SRv6 TE policy group.
undo color color-value match dscp { ipv4 | ipv6 } dscp-value-list
undo color color-value match dscp { ipv4 | ipv6 } [ default ]
No color-to-DSCP mappings are created for an SRv6 TE policy group.
default: Configures a default color-to-DSCP mapping. Packets that do not match any mappings are steered to the SRv6 TE policy associated with the color attribute value in the default mapping. This SRv6 TE policy is used as the default SRv6 TE policy for packets in the specified address family. If you do not specify this keyword for the undo color match dscp command, the command deletes all color-to-DSCP mappings for the current SRv6 TE policy group.
Typically, an SRv6 TE policy group has multiple SRv6 TE policy tunnels with the same endpoint address but different color attribute values. After traffic is steered to the SRv6 TE policy group, the device matches the DSCP value of the traffic with the color-to-DSCP mappings configured by using this command. If a match is found, the device will forward the traffic through the SRv6 TE policy associated with the color attribute value in the matching mapping.
Operating mechanism
# In SRv6 TE policy group 10, map DSCP value 30 to color value 20 for IPv4 packets, so that IPv4 packets with a matching DSCP value are steered to the associated SRv6 TE policy.
[Sysname-srv6-te-policy-group-10] color 20 match dscp ipv4 30
Use color match service-class to create color-to-service class mappings for an SRv6 TE policy group ODN template.
Use undo color match service-class to delete color-to-service class mappings from an SRv6 TE policy group ODN template.
color color-value match service-class service-class-value-list
undo color color-value match service-class service-class-value-list
color color-value match service-class default
undo color color-value match service-class [ default ]
No color-to-service class mappings are created for an SRv6 TE policy group ODN template.
default: Configures a default color-to-service class mapping. Packets that do not match any color-to-service class mappings are steered to the default SRv6 TE policy (the policy with the color attribute value specified in the default mapping).
About this command
After traffic is steered to an SRv6 TE policy group for forwarding, the device matches the service class value of the traffic with the color-to-service class mappings specified by using this command. If a matching mapping is found, the device forwards the traffic through the SRv6 TE policy with the color attribute value mapped to the service class value.
Operating mechanism
# In SRv6 TE policy group ODN template, map service class value 3 to color value 20 for packets, so that packets with service class value 3 are steered to the SRv6 TE policy with color value 20.
[Sysname-srv6-te-odn-group-1-service-class] color 20 match service-class 3
best-effort match service-class (service class forward type view)
color match service-class (SRv6 TE policy group view)
Use color match service-class to create color-to-service class mappings for an SRv6 TE policy group.
Use undo color match service-class to delete color-to-service class mappings for an SRv6 TE policy group.
No color-to-service class mappings are created for an SRv6 TE policy group.
Execute the forward-type service-class command in SRv6 TE policy group view before using this command.
About this command
Operating mechanism
# In SRv6 TE policy group 10, map service class value 3 to color value 20 for packets, so that packets with a matching service class value are steered to the associated SRv6 TE policy.
[Sysname-srv6-te-policy-group-10] color 20 match service-class 3
best-effort match service-class (SRv6 TE policy group view)
constraints
Use constraints to create and enter SRv6 TE policy constraints view, or enter the existing SRv6 TE policy constraints view.
Use undo constraints to delete the SRv6 TE policy constraints view and all configurations in the view.
constraints
undo constraints
No SRv6 TE policy constraints exist.
SRv6 TE policy path preference view
In constraints view, you can configure the affinity attribute and segment constraints for an SRv6 TE policy for flexible forwarding path control.
When both affinity attribute and segment constraints are configured in constraints view, segment constraints apply.
# Create SRv6 TE policy constraints and enter constraints view.
default-color (public instance IPv4/IPv6 address family view)
Use default-color to configure a default color value for public route recursion to an SRv6 TE policy.
Use undo default-color to restore the default.
default-color color-value
undo default-color
No default color value is configured.
Public instance IPv4 address family view
Public instance IPv6 address family view
color-value: Default color value in the range of 0 to 4294967295.
The local PE uses the default color value to match an SRv6 TE policy for a received public network route if the route does not carry a color extended community and no color is added to the route through a routing policy.
This command applies only to the public network routes learned from a remote PE.
The default color value configured by this command is used only for SRv6 TE policy traffic steering. It does not used in route advertisement.
# In public instance IPv4 address family view, set the default color to 100 for public network route recursion to an SRv6 TE policy.
[Sysname] ip public-instance
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4] default-color 100
default-color (VPN instance IPv4/IPv6 address family view)
Use default-color to configure a default color value for L3VPN route recursion to an SRv6 TE policy.
default-color color-value [ evpn ]
undo default-color [ evpn ]
VPN instance IPv4 address family view
VPN instance IPv6 address family view
evpn: Specifies the EVPN L3VPN service. If you do not specify this keyword, the default color applies to MPLS L3VPN route recursion to an SRv6 TE policy.
The local PE uses the default color value to match an SRv6 TE policy for a received VPNv4, VPNv6, or EVPN IP prefix route if the route does not carry a color extended community and no color is added to the route through a routing policy.
This command applies only to the VPN routes learned from a remote PE.
# In IPv4 address family view for VPN instance vpn1, set the default color to 100 for EVPN L3VPN route recursion to an SRv6 TE policy.
[Sysname-vpn-instance-vpn1] address-family ipv4
[Sysname-vpn-ipv4-vpn1] default-color 100 evpn
default match (APN ID-based traffic steering)
Use default match to configure the default forwarding policy for APN ID-based traffic forwarding.
Use undo default match to remove a default forwarding policy setting for APN ID-based traffic forwarding.
default match best-effort
default match srv6-policy color color-value
undo default match { best-effort | srv6-policy }
No default forwarding policy is configured for APN ID-based traffic forwarding.
APN ID forward type view
best-effort: Specifies SRv6 BE mode in the default forwarding policy.
srv6-policy color color-value: Specifies an SRv6 TE policy by its color attribute value in the default forwarding policy. The value range for the color-value argument is 0 to 4294967295.
This command can take effect only when the forward type of the SRv6 TE policy group is APN ID. To specify the forward type, you can use the forward-type apn-id command in SRv6 TE policy group view or SRv6 TE ODN policy group view.
Application scenario
Once service traffic is steered to an SRv6 TE policy group for forwarding, the device matches the APN ID value in IPv6 packets with the APN ID mappings in the SRv6 TE policy group. If a matching mapping is found, the device forwards the traffic through the SRv6 TE policy associated with the color attribute value in the mapping or forwards the traffic in SRv6 BE mode. The default forwarding policy configured by using the default match command can be applied to the following scenarios:
·     When forwarding different types of service flows through the same SRv6 TE policy or through the SRv6 BE mode can meet the service quality requirements, you can use this command to configure the default forwarding policy. The service flows identified by an APN ID will be forwarded through the default forwarding policy.
·     When the device receives a packet that does not carry an APN ID, whose APN ID does not match any mapping configured by using the index apn-id match command, or whose APN ID matches an invalid SRv6 TE policy or matches the SRv6 BE mode that is invalid, the device forwards the packet through the default forwarding policy.
Operating mechanism
In SRv6 BE mode, the device encapsulates packets with a new IPv6 header. The destination address in the new IPv6 header is the VPN SID that the egress node of the SRv6 TE policy group assigned to public- or private-network routes. Then, the device looks up for IPv6 routes to forward the encapsulated packets.
The device might receive a packet that does not carry an APN ID or carries one of the following APN IDs:
·     APN ID that does not match any APN ID mapping.
·     APN ID that matches an invalid SRv6 TE policy or SRv6 BE mode.
In this situation, the device forwards that packet as follows:
1.     If the default match command is used to specify a default SRv6 TE policy and the specified default SRv6 TE policy is valid, the device uses the default SRv6 TE policy to forward the packet.
If the default match command is used to enable SRv6 BE-mode packet forwarding and the SRv6 BE mode is valid, the device forwards the packet in SRv6 BE mode.
2.     If the default match command is not executed, or the forwarding policy configured by using the default match command is invalid, the device handles the packet according to the configuration of the drop-upon-mismatch enable command.
¡     If the drop-upon-mismatch enable command is not used, the device identifies whether APN ID-to-forwarding policy mappings are configured by using the index apn-id match command. If yes, the device searches for a mapping with the smallest APN ID and a valid forwarding policy. The device will use the SRv6 TE policy pointed by the mapping to forward the packet or forward the packet in SRv6 BE mode.
In an SRv6 TE policy group, you can specify only one SRv6 TE policy in the default forwarding policy.
You can specify both SRv6 TE policy forwarding and SRv6 BE forwarding in the default forwarding policy. The device preferentially uses SRv6 TE policy forwarding.
# In a manually created SRv6 TE policy group, specify the SRv6 TE policy associated with color attribute value 20 in the default forwarding policy for APN ID-based traffic forwarding.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te-policy-group-10] forward-type apn-id
[Sysname-srv6-te-policy-group-10] default match srv6-policy color 20
# In an SRv6 TE policy group ODN template, specify the SRv6 TE policy associated with color attribute value 20 in the default forwarding policy for APN ID-based traffic forwarding.
[Sysname-srv6-te-odn-group-1] forward-type apn-id
[Sysname-srv6-te-odn-group-1-apn-id] default match srv6-policy color 20
index apn-id match
forward-type (SRv6 TE policy group view)
forward-type (SRv6 TE ODN policy group view)
default match (ARN ID-based traffic steering)
Use default match to configure the default forwarding policy for ARN ID-based traffic forwarding.
Use undo default match to remove a default forwarding policy setting for ARN ID-based traffic forwarding.
No default forwarding policy is configured for ARN ID-based traffic forwarding.
ARN ID forward type view
best-effort: Specifies SRv6 BE mode in the default forwarding policy. In SRv6 BE mode, the device encapsulates packets with a new IPv6 header. The destination address in the new IPv6 header is the VPN SID that the egress node of the SRv6 TE policy group assigned to public- or private-network routes. Then, the device looks up for IPv6 routes to forward the encapsulated packets.
This command can take effect only when the forward type of the SRv6 TE policy group is ARN ID. To specify the forward type, you can use the forward-type arn-id command in SRv6 TE policy group view or SRv6 TE ODN policy group view.
Once service traffic is steered to an SRv6 TE policy group for forwarding, the device matches the ARN ID value in IPv6 packets with the ARN ID mappings in the SRv6 TE policy group. If a matching mapping is found, the device forwards the traffic through the SRv6 TE policy associated with the color attribute value in the mapping or forwards the traffic in SRv6 BE mode. The default forwarding policy configured by using the default match command can be applied to the following scenarios:
·     When forwarding different types of service flows through the same SRv6 TE policy or through the SRv6 BE mode can meet the service quality requirements, you can use this command to configure the default forwarding policy. The service flows identified by an ARN ID will be forwarded through the default forwarding policy.
·     When the device receives a packet that does not carry an ARN ID or carries one of the following ARN IDs, it can forward that packet through the default forwarding policy:
¡     ARN ID that does not match any mapping configured by using the index arn-id match command.
¡     ARN ID that matches an invalid SRv6 TE policy or SRv6 BE mode.
Operating mechanism
The device might receive a packet that does not carry an ARN ID or carries one of the following ARN IDs:
·     ARN ID that does not match any ARN ID mapping.
·     ARN ID that matches an invalid SRv6 TE policy or SRv6 BE mode.
¡     If the drop-upon-mismatch enable command is not used, the device identifies whether ARN ID-to-forwarding policy mappings are configured by using the index arn-id match command. If yes, the device searches for a mapping with the smallest ARN ID and a valid forwarding policy. The device will use the SRv6 TE policy pointed by the mapping to forward the packet or forward the packet in SRv6 BE mode.
You can specify both SRv6 TE policy-based forwarding and SRv6 BE-based forwarding in the default forwarding policy. The device preferentially uses SRv6 TE policy-based forwarding.
# In a manually created SRv6 TE policy group, specify the SRv6 TE policy associated with color attribute value 20 in the default forwarding policy for ARN ID-based traffic forwarding.
[Sysname-srv6-te-policy-group-10] forward-type arn-id
# In an SRv6 TE policy group ODN template, specify the SRv6 TE policy associated with color attribute value 20 in the default forwarding policy for ARN ID-based traffic forwarding.
[Sysname-srv6-te-odn-group-1] forward-type arn-id
[Sysname-srv6-te-odn-group-1-arn-id] default match srv6-policy color 20
index arn-id match
default match (TE class ID-based traffic steering)
Use default match to configure the default forwarding policy for TE class ID-based traffic steering.
Use undo default match to remove a default forwarding policy setting for TE class ID-based traffic steering.
undo default match best-effort
default match { ipr-policy ipr-name | srv6-policy color color-value }
undo default match { ipr-policy [ ipr-name ] | srv6-policy color [ color-value ] }
No default forwarding policy is configured for TE class ID-based traffic steering.
TE class forward type view
best-effort: Specifies SRv6 BE mode in the default forwarding policy. In this mode, the device adds a new IPv6 header to original packets and performs an IPv6 routing table lookup to forward the packets.
ipr-policy ipr-name: Specifies an IPR policy by its name in the default forwarding policy. The ipr-name argument represents the name of the IPR policy, which is a case-sensitive string of 1 to 31 characters.
This command can take effect on an SRv6 TE policy group only when the forward type of the SRv6 TE policy group is TE class. To specify the forward type, you can use the forward-type te-class command in SRv6 TE policy group view.
The device uses the default forwarding policy to forward the following packets after the packets are steered to the SRv6 TE policy group for forwarding:
·     Packets that do not have a TE class ID.
·     Packets that have a TE class ID not mapped to any forwarding policy specified by using the index te-class match command.
·     Packets that have a TE class ID mapped to an invalid forwarding policy.
You can configure a maximum of two forwarding methods in the default forwarding policy. However, IPR forwarding and SRv6 TE policy forwarding cannot coexist. When packets are forwarded according to the default forwarding policy, the device selects a forwarding method in the following order:
1.     If a color attribute value or an IPR policy is specified in the default forwarding policy and the SRv6 TE policy used to forward the packets is valid, the device steers the traffic to that SRv6 TE policy for forwarding.
2.     If the SRv6 BE mode is specified in the default forwarding policy and the SRv6 BE mode is valid, the device encapsulates a new IPv6 header to the packets and looks up the IPv6 routing table to forward the packets.
3.     If the default match command is not executed, or the forwarding policy configured by using the default match command is invalid, the device handles the packet according to the configuration of the drop-upon-mismatch enable command.
¡     If the drop-upon-mismatch enable command is not used, the device identifies whether TE class ID-to-forwarding policy mappings are configured by using the index te-class match command. If yes, the device searches for a mapping with the smallest index value and a valid forwarding policy. The device will use the SRv6 TE policy pointed by the mapping to forward the packet or forward the packet in SRv6 BE mode.
# In an SRv6 TE policy group, specify the SRv6 TE policy associated with color attribute value 8 in the default forwarding policy for TE class ID-based traffic forwarding.
[Sysname-srv6-te-policy-group-1] forward-type te-class
[Sysname-srv6-te-policy-group-1] default match srv6-policy color 8
delay threshold
Use delay threshold to set the delay threshold in an IPR policy.
Use undo delay threshold to restore the default.
delay threshold time-value
The delay threshold is 5000 milliseconds in an IPR policy.
SRv6 TE IPR policy view
time-value: Specifies a delay threshold value in the range of 0 to 5000, in milliseconds.
An SRv6 TE policy can be used as a candidate forwarding path and participate in optimal SRv6 TE policy selection only when the iFIT delay and jitter measurement feature detects that the delay of the SRv6 TE policy does not exceed the delay threshold set by this command.
If the optimal candidate path of an SRv6 TE policy has multiple valid SID lists with weight values, the device uses the weighted sum of the iFIT delays of all of these valid SID lists as the delay value of that SRv6 TE policy when intelligent policy routing computes whether the delay of that SRv6 TE policy crosses the threshold.
# Set the delay threshold to 50 milliseconds in IPR policy ipr1.
[Sysname-srv6-ipr-policy-ipr1] delay threshold 50
delete-delay (SRv6 TE ODN view)
Use delete-delay to configure the deletion delay time for SRv6 TE policies generated by ODN templates.
Use undo delete-delay to restore the default.
delete-delay delay-time
undo delete-delay
The deletion delay time for SRv6 TE policies generated by ODN templates is 180000 milliseconds.
SRv6 TE ODN view
delay-time: Specifies the deletion delay time, in the range of 0 to 600000 milliseconds.
ODN automatically creates an SRv6 TE policy based on the specified BGP route. The SRv6 TE policy is deleted immediately when the BGP route is deleted. To avoid packet loss before the new forwarding path is computed, you can use this command to configure a proper deletion delay time for the SRv6 TE policy.
# Set the deletion delay time to 300000 milliseconds for SRv6 TE policies generated by ODN templates.
[Sysname-srv6-te] on-demand color 1
[Sysname-srv6-te-odn-1] delete-delay 300000
delete-delay (SRv6 TE ODN policy group view)
Use delete-delay to configure the deletion delay time for SRv6 TE policy groups generated by an ODN template.
undo delete-delay
The deletion delay time for SRv6 TE policies generated by an ODN template is 180000 milliseconds.
delay-time: Specifies the deletion delay time, in milliseconds. The value range is 0 to 600000.
ODN automatically creates an SRv6 TE policy group based on the specified BGP route. The SRv6 TE policy group is deleted immediately when the BGP route is deleted. To avoid packet loss before the new forwarding path is computed, you can use this command to configure a proper deletion delay time for the SRv6 TE policy group.
# Set the deletion delay time to 300000 milliseconds for SRv6 TE policy groups generated by an ODN template.
[Sysname-srv6-te-odn-group-1] delete-delay 300000
description
Use description to configure the description of the SRv6 TE policy group ODN template.
The description of the SRv6 TE policy group ODN template is not configured.
text: Specifies the description of the SRv6 TE policy group ODN template, a case-sensitive string of 1 to 242 characters.
To facilitate management, use this command to configure the description of the SRv6 TE policy group ODN template.
# Configure the description of the SRv6 TE policy group ODN template.
[Sysname-srv6-te-odn-group-1] description abc
display bgp mirror remote-sid
Use display bgp mirror remote-sid to display remote SRv6 SIDs protected by mirror SIDs.
display bgp [ instance instance-name ] mirror remote-sid [ end-dt4 | end-dt46 | end-dt6 ] [ sid ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays information about the default instance.
end-dt4: Specifies remote SRv6 SIDs of the End.DT4 type.
end-dt46: Specifies remote SRv6 SIDs of the End.DT46 type.
end-dt6: Specifies remote SRv6 SIDs of the End.DT6 type.
sid: Specifies a remote SRv6 SID.
This command can display information about remote SRv6 SIDs protected by mirror SIDs on IP L3VPN over SRv6, EVPN L3VPN over SRv6, and IP public network over SRv6 networks.
If you do not specify any parameters, this command displays all remote SRv6 SIDs protected by mirror SIDs.
# Display all remote SRv6 SIDs protected by mirror SIDs.
<Sysname> display bgp mirror remote-sid
Total number of SIDs: 3
Remote SID: 3001::1:0:0
Remote SID type: End.DT4
Mirror locator: 3001::1/64
VPN instance name: vrf1
Remote SID: 3001::1:0:1
Remote SID type: End.DT6
VPN instance name: vrf2
Remote SID: 1111:2222:3333:4444::1
Mirror locator: 1111:2222:3333:4444:5555:6666:7777:8888/64
Total number of remote SRv6 SIDs.
Remote SID
Remote SRv6 SID.
Remote SID type
Type of the remote SRv6 SID:
·     End.DT4.
·     End.DT6.
·     End.DT46.
Mirror locator
IPv6 prefix and prefix length of the locator for the remote SRv6 SID.
VPN instance name
Name of the VPN instance associated with the remote SRv6 SID.
Public instance
Name of the public instance.
display bgp routing-table ipv6 sr-policy
Use display bgp routing-table ipv6 sr-policy to display route information of a BGP SRv6 TE policy.
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ sr-policy-prefix [ advertise-info ] ]
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression ]
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ color color-value [ end-point ipv6 ipv6-address ] | end-point ipv6 ipv6-address ]
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ sr-policy-prefix [ verbose ] | color color-value [ end-point ipv6 ipv6-address ] | end-point ipv6 ipv6-address | statistics [ color color-value [ end-point ipv6 ipv6-address ] | end-point ipv6 ipv6-address ] ] ]
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ statistics [ color color-value [ end-point ipv6 ipv6-address ] | end-point ipv6 ipv6-address ] ]
display bgp [ instance instance-name ] routing-table ipv6 sr-policy peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes }
display bgp [ instance instance-name ] routing-table ipv6 sr-policy time-range start-time end-time
sr-policy-prefix: Specifies a BGP IPv6 SR policy route prefix, which is a case-insensitive string of 1 to 512 characters in the format of SRv6 policy route/prefix length.
verbose: Displays detailed route information. If you do not specify this keyword, the command displays brief route information.
as-path-acl as-path-acl-number: Specifies an AS path ACL by its number, in the range of 1 to 256.
as-path-acl as-path-acl-name: Specifies an AS path ACL by its name, a case-sensitive string of 1 to 51 characters. The AS path ACL name cannot contain only digits.
as-path-regular-expression regular-expression: Specifies an AS path regular expression, a case-sensitive string of 1 to 256 characters.
color color-value: Specifies the color attribute value of a BGP IPv6 SR policy route, in the range of 1 to 4294967295.
end-point ipv6 ipv6-address: Specifies the endpoint IPv6 address of a BGP IPv6 SR policy route.
advertise-info: Displays advertisement information about BGP IPv6 SR policy routes.
peer { ipv4-address | ipv6-address }: Specifies a peer by its IPv4 or IPv6 address.
advertised-routes: Displays detailed information about the BGP IPv6 SR policy routes advertised to the specified peer.
received-routes: Displays detailed information about the BGP IPv6 SR policy routes received from the specified peer.
statistics: Displays route statistics.
accepted-routes: Displays information about the routes received from the specified peer and permitted by the specified policy.
not-accepted-routes: Displays information about the routes received from the specified peer and not permitted by the specified policy.
time-range min-time max-time: Displays information for routes that have persisted for a duration within the specified range since the last update. The min-time argument represents the minimum duration, and the max-time argument represents the maximum duration. The min-time and max-time arguments are in the format of <0-10000>d<0-23>h<0-59>m<0-59>s, where d represents days, h represents hours, m represents minutes, and s represents seconds, and <0-10000>, <0-23>, <0-59>, and <0-59> represent the value ranges for days, hours, minutes, and seconds, respectively. The duration specified by using the max-time argument must be longer than the duration specified by using the min-time argument.
If you do not specify any parameters, this command displays brief information about all BGP IPv6 SR policy routes.
# Display brief information about all BGP IPv6 SR policy routes.
<Sysname> display bgp routing-table ipv6 sr-policy
 Total number of routes: 1
 Status codes: * - valid, > - best, d - dampened, h - history
               a – additional-path
>i Network : [46][46][8::8]/192
   NextHop : 1::2                                  LocPrf    : 100
   PrefVal : 0                                     MED       : 0
   Path/Ogn: i
# Display information for BGP IPv6 SR policy routes that have persisted for a duration within the specified range since the last update in BGP instance default.
<Sysname> display bgp routing-table ipv6 sr-policy time-range 1d1h1m1s 7d3h1m1s
               a – additional-path
   PrefVal : 0                                     MED       : 0
   Route age: 06d01h12m44s
Status codes
Status codes of the route.
Origin
Origin of the route:
·     i – IGP—Originated in the AS.
·     e – EGP—Learned through an EGP.
·     ? – incomplete—Unknown origin.
Network
BGP IPv6 SR policy route, comprised of the following elements:
·     SRv6 TE policy candidate path preference.
·     SRv6 TE policy color attribute value.
·     Endpoint IPv6 address.
NextHop
Next hop IP address.
LocPrf
Local preference value.
PrefVal
Preferred value of the route.
MED
Multi-Exit Discriminator attribute value.
Path/Ogn
AS_PATH and ORIGIN attributes of the route:
·     AS_PATH—Records the ASs the route has passed.
·     ORIGIN—Identifies the origin of the route.
Route age
Duration that the route has persisted since the last time it was updated. The duration is in the format of <0-10000>d<0-23>h<0-59>m<0-59>s, where d represents days, h represents hours, m represents minutes, and s represents seconds, and <0-10000>, <0-23>, <0-59>, and <0-59> represent the value ranges for days, hours, minutes, and seconds, respectively.
# Display detailed information about BGP IPv6 SR policy route [46][46][8::8]/192.
<Sysname> display bgp routing-table ipv6 sr-policy [46][46][8::8]/192
BGP local router ID: 5.5.5.1
Local AS number: 100
Paths: 1 available, 1 best
 BGP routing table information of [46][46][8::8]/192
 Imported route.
 Original nexthop: ::
 Output interface: p1
 Route age       : 19h45m02s
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : igp
 Attribute value : MED 0, localpref 100, pref-val 32768
 State           : valid, local, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Tunnel encapsulation info:
    Type: 15 (SR policy)
     Policy name: p1
     Binding SID: 2::6
     SRv6 Binding SID:
       Binding SID: 3::6
       Flags: 0/I/B/0/0/0/0/0
       Endpoint Behavior: 0x1B
       LB Length: 64
       LN Length: 16
       Function Length: 16
       Args Length: 8
     Preference: 100
     Network slice ID: 10
     Path: 1
      Weight: 1
      Local BSID: 4000::3
      Reverse BSID: 5000::4
      Segment list ID: 100
      Metric type: IGP      Value: 100
      Metric type: TE       Value: 100
      Metric type: delay    Value: 100
      Metric type: loss     Value: 100
      SIDs: {2::2}
      Local Path Segment : 100::1
      Reverse Path Segment : 200::3
Paths
Route information:
·     available—Number of valid routes.
·     best—Number of optimal routes.
Information of the BGP IPv6 SR policy route [46][46][8::8]/192, where:
·     [46] is the SRv6 TE policy candidate path preference
·     [46] is the SRv6 TE policy color attribute value.
·     [8::8] is the endpoint IPv6 address.
From
IP address of the BGP peer that advertised the route.
Rely Nexthop
Recursive nexthop IP address. If no next hop is found by route recursion, this field displays not resolved.
Original nexthop
Original nexthop IP address. If the route was obtained from a BGP update message, the original next hop is the nexthop IP address in the message.
Output interface
Outgoing interface information, which is the SRv6 TE policy name of the forwarding tunnel.
Route age
Time elapsed since the last update for the route.
OutLabel
Outgoing label of the route.
RxPathID
Received Add-Path ID of the route.
TxPathID
Advertised Add-Path ID of the route.
AS-path
AS_PATH attribute of the route.
Origin
·     igp—Originated in the AS.
·     egp—Learned through an EGP.
·     incomplete—Unknown origin.
Attribute value
BGP path attributes:
·     MED—MED value.
·     localprefLocal preference value.
·     pref-val—Preferred value.
·     pre—Protocol preference.
Originator
Peer that generated the route.
Cluster list
CLUSTER_LIST attribute of the route. This field is not displayed if the CLUSTER_LIST attribute is not available.
Current state of the route. Options include:
·     valid—Valid route.
·     internal—Internal route.
·     external—External route.
·     local—Locally generated route.
·     synchronize—Synchronized route.
·     best—Optimal route.
·     delay—Delayed route. The route will be delayed for optimal route selection. This value is available only in detailed information of the route.
·     not preferred for reason—Reason why the route is not selected as the optimal route. For more information, see Table 4.
IP precedence
IP precedence of the route, in the range of 0 to 7. N/A indicates that the route does not support this field.
QoS local ID
QoS local ID of the route, in the range of 1 to 4095. N/A indicates that the route does not support this field.
Traffic index
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field.
Type: 15 (SR Policy)
The tunnel encryption type is 15, which represents SR policy.
Preference
Candidate path preference.
Binding SID
BSID value.
SRv6 Binding SID
SRv6 Binding SID Sub-TLV information:
·     Binding SID—BSID value of the SRv6 TE policy candidate path.
·     Flags (S/I/B)—BSID flags.
¡     SSpecified-BSID-only flag. The current software version does not support this flag. If this flag is set, the system takes restrictive Specified-BSID-only behaviors on the candidate path. The system does not bind a BSID to the candidate path and determines that it is invalid if it has an unspecified BSID or if the specified BSID is not available when it becomes active.
¡     I—Invalid flag. This flag has the same effect as the drop-upon-invalid enable command. When this flag is set, the device discards traffic that matches an invalid SRv6 TE policy.
¡     B—Behavior flag. When this flag is set in a packet, the packet carries an SRv6 SID endpoint behavior.
¡     0—Reserved flag bits.
·     Endpoint Behavior—Endpoint behavior for BSID-based traffic steering.
¡     0xE—End.B6.Encaps, that is, normal encapsulation mode.
¡     0x1B—End.B6.Encaps.Red, that is, reduced mode of the normal encapsulation mode.
¡     0xD—End.B6.Insert, that is, insertion encapsulation mode.
¡     0x1A—End.B6.Insert.Red, that is, reduced insertion encapsulation mode.
·     LB Length—Common prefix length, in bits.
·     LN Length—Node ID length, in bits.
·     Function Length—Function length, in bits.
·     Argument Length—Argument length, in bits.
Network slice ID
Network slice instance ID associated with the candidate path of the SRv6 TE policy.
Path
ID of the candidate path.
Weight
Weight of the SID list.
Local BSID
Local BSID carried in the SID list, used to ensure BFD or SBFD forward and reverse path consistency for SRv6 TE policy connectivity verification.
Reverse BSID
Reverse BSID carried in the SID list, used to ensure BFD or SBFD forward and reverse path consistency for SRv6 TE policy connectivity verification.
Segment list ID
ID of the SID list, which is specified by using the explicit segment-list command or obtained from BGP routes.
Metric type
Supported metric types include:
·     IGP—IGP metric.
·     TE—TE metric.
·     delay—Delay metric.
·     loss—Packet loss metric.
Value
Metric value. Link delay is measured in microseconds and packet loss ratio is measured in 0.000003%.
Local Path Segment
Local path segment SID carried in the SID list, used to ensure SBFD forward and reverse path consistency for SRv6 TE policy connectivity verification.
Reverse path segment SID carried in the SID list, used to ensure SBFD forward and reverse path consistency for SRv6 TE policy connectivity verification.
SIDs
List of SIDs.
The format is {sid-value, flags}, where sid-value is the SID value and flags represents the flags carried in the SID. At present, only the V flag is supported, which means to verify the SID's validity during the SRv6 TE policy path verification.
When the SID is a 32-bit G-SID, it is displayed in the format of {sid-value, coc32, prefix-length, flags }.
When the SID is a 16-bit G-SID, it is displayed in the format of {sid-value, compress-16 prefix-length,node-length,function-length,compress-flavor,flags}.
·     sid-value—SID value.
·     prefix-length—Length of the common prefix or the Block portion.
·     flags—Flags carried in the SID. In the current software version, only the V flag is supported, which means to verify the SID's validity during the SRv6 TE policy path verification.
·     node-length—Length of the Node ID portion.
·     function-length—Length of the Function portion after compression.
·     compress-flavor—Flavor of the 16-bit G-SID.
¡     0—NO-FLAVOR.
¡     1—COC & NEXT
¡     2—COC.
¡     3—NEXT.
Table 4 Reason why the route is not selected as the optimal route
Reason
preferred-value
Routes with larger preferred values exist.
local-preference
Routes with larger local preference values exist.
as-path
Routes with smaller AS_PATH attribute values exist.
origin
There are routes whose origin has a higher priority. The route origins are IGP, EGP, and INCOMPLETE in descending order of priority.
med
Routes with smaller MED values exist.
remote-route
There are routes whose remote-route attribute has a higher priority.
BGP selects the optimal route from remote routes in this order:
·     Route learned from an EBGP peer.
·     Route learned from a confederation EBGP peer.
·     Route learned from a confederation IBGP peer.
·     Route learned from an IBGP peer.
igp-cost
Routes with smaller IGP metrics exist.
relydepth
Routes with smaller recursion depth values exist.
rfc5004
A route received from an EBGP peer is the current optimal route. BGP does not change the optimal route when it receives routes from other EBGP peers.
router-id
Routes with smaller router IDs exist.
If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routes. Then, BGP selects the route with the smallest ID as the optimal route.
cluster-list
Routes with smaller CLUSTER_LIST attribute values exist.
peer-address
Routes advertised by peers with lower IP addresses exist.
received
Earlier learned routes exist.
# Displays advertisement information about the BGP IPv6 SR policy route [46][46][8::8]/192.
<Sysname> display bgp routing-table ipv6 sr-policy [46][46][8::8]/192 advertise-info
 BGP local router ID: 2.2.2.2
 Local AS number: 1
 Paths:   1 best
 BGP routing table information of [46][46][8::8]/192(TxPathID:0):
 Advertised to peers (2 in total):
    1::1
    3::3
Table 5 Command output
Paths
Number of optimal paths to reach the destination network.
Advertisement information about the BGP IPv6 SR policy route [46][46][8::8]/192. TxPathID represents the advertised Add-Path ID of the route.
Indicates the peers to which the route has been advertised. The number in the parentheses indicates the total number of the peers.
# Display statistics about the BGP IPv6 SR policy routes advertised to peer 2::2.
<Sysname> display bgp routing-table ipv6 sr-policy peer 2::2 advertised-routes statistics
 Advertised routes total: 2
# Display statistics about the BGP IPv6 SR policy routes received from peer 2::2.
<Sysname> display bgp routing-table ipv6 sr-policy peer 2::2 received-routes statistics
 Received routes total: 1
Table 6 Command output
Total number of routes advertised to the specified peer.
Total number of routes received from the specified peer.
# Display statistics about BGP IPv6 SR policy routes.
<Sysname> display bgp routing-table ipv6 sr-policy statistics
 Total number of routes: 3
display evpn srv6 mirror remote-sid
Use display evpn srv6 mirror remote-sid to display remote SRv6 SIDs protected by mirror SIDs on EVPN VPWS/VPLS over SRv6 networks.
display evpn srv6 mirror remote-sid [ sid | type { end-dt2u | end-dx2 } ]
type: Specifies a type of remote SRv6 SIDs.
end-dt2u: Specifies the End.DT2U type.
end-dx2: Specifies the End.DX2 type.
If you do not specify any parameters, this command displays all remote SRv6 SIDs protected by mirror SIDs on EVPN VPWS/VPLS over SRv6 networks.
# Display all remote SRv6 SIDs protected by mirror SIDs on EVPN VPWS/VPLS over SRv6 networks.
<Sysname> display evpn srv6 mirror remote-sid
Total number of SIDs: 2
End.DT2U SID        : 111::100
Mirror locator      : 111::/64
VSI name            : svpls
End.DX2 SID         : 111::200
Xconnect group name : svpws
Connection name     : pw1
Table 7 Command output
End.DT2U SID
Remote End.DT2U SID.
End.DX2 SID
Remote End.DX2 SID.
Mirror locator
VSI name
Name of the VSI associated with the remote SRv6 SID.
Xconnect group name
Name of the cross-connect group associated with the remote SRv6 SID.
Connection name
Name of the cross-connect associated with the remote SRv6 SID.
display pce segment-routing ipv6 policy database
Use display pce segment-routing ipv6 policy database to display SRv6 TE policy information stored in the PCE database.
display pce segment-routing ipv6 policy database [ color color-value endpoint ipv6 ipv6-address | policyname policy-name] [ verbose ]
color color-value endpoint ipv6 ipv6-address: Specifies an SRv6 TE policy by its color attribute value and end-point IPv6 address. The value range for the color attribute value is 0 to 4294967294.
policyname policy-name: Specifies an SRv6 TE policy by its name, a case-sensitive string of 1 to 59 characters.
verbose: Displays detailed SRv6 TE policy information in the PCE database. If you do not specify this keyword, the command displays brief SRv6 TE policy information in the PCE database.
If you do not specify the color color-value endpoint ipv6 ipv6-address option or the policyname policy-name option, this command displays information about all SRv6 TE policies in the PCE database.
# Display brief SRv6 TE policy information in the PCE database.
<Sysname> display pce segment-routing ipv6 policy database
Color       Preference  Association  Delegated address  State  Endpoint
1           100         1            192.168.56.1       Up     4:4::4:4
2           10          2            192.168.56.2       Up     4:4::4:4
Table 8 Command output
Color
Color attribute value of the SRv6 TE policy.
Preference
Preference of the candidate path of the SRv6 TE policy.
Association ID
Association ID for the candidate path of the SRv6 TE policy. The PCE database uses an association ID to identify an SRv6 TE policy.
Delegated address
IP address of the delegated PCE. If the candidate path is not delegated or the delegation fails, this field displays a hyphen (-).
Candidate path state:
·     Up—The candidate path has been established.
·     Down—The candidate path has not been established or the establishment fails.
Endpoint
Endpoint IPv6 address of the SRv6 TE policy.
# Display detailed SRv6 TE policy information in the PCE database.
<Sysname> display pce segment-routing ipv6 policy database verbose
PLSP ID: 1046537                           Policy name: p1
 Color: 10
 Endpoint: 4:4::4:4
 Preference: 10
 Protocol Original: 30
 BGP Instance: 0
 ASN: 0              Node address: 0.0.0.0
 Binding SID: 8::1
 Association ID: 1
 Protection type: Unprotected
 Path role: Primary
 SRP ID: 0                                  PCE initiated: No
 PCE-setup-type: SRv6-TE Policy
 Delegatable: Yes                           Delegated address: 192.168.56.1
 Operational state: Up                      Speaker address: 192.168.56.1
 PCEP status: -
 Candidate path/4:  path state: Up
  SRv6-EROs: 3
  SID type: SID without NAI           Strict
    SID: 6000::1                      NAI: N/A
    SID: 7000::1                      NAI: N/A
    SID: 8000::1                      NAI: N/A
  SRv6-RROs: 3
Table 9 Command output
PLSP ID
The PLSP ID uniquely identifies a candidate path.
Policy name
Name of the SRv6 TE policy.
Color
Endpoint
Preference
Protocol Original
Candidate path source:
·     10—PCE created.
·     20—BGP created.
·     30—Command created.
BGP Instance
Number of the BGP instance that is created by BGP.
This field displays a hyphen (-) if the candidate path is not created by BGP.
ASN
AS number. A value of 0 means that the device has not obtained SRv6 TE policy information from a BGP peer.
Node address
BGP node address.
This field displays the router ID of the BGP peer when the SRv6 TE policy information was obtained from a BGP peer, and it displays 0.0.0.0 when the SRv6 TE policy information was obtained by using other methods.
Binding SID
BSID of the SRv6 TE policy. If the SRv6 TE policy does not have a BSID, this field displays a hyphen (-).
Association ID
Protection type
Protection type for the candidate path:
·     Unprotected.
·     (Full)Rerouting—Normal backup.
·     Rerouting without Extra-Traffic—Hot-standby backup.
·     1:N Protection with Extra-Traffic.
·     1+1 Unidirectional Protection.
·     1+1 Bidirectional Protection.
Path role
Role of the candidate path:
·     Primary.
·     Backup.
·     Other.
SRP ID
ID of the stateful PCE request parameter.
PCE initiated
Whether the candidate path is initiated by PCE: Yes or No.
PCE-setup-type
Type of the protocol that created the candidate path. The value can be SRv6-TE Policy.
Delegatable
Whether the candidate path is delegable: Yes or No.
Delegated address
Operational state
Speaker address
IP address of the PCE.
PCEP status
Candidate path delegation state:
·     Delegated—The candidate path has been delegated to the PCE.
·     Updated—The PCE has updated the candidate path.
·     Redelegating—The device is redelegating the candidate path to another PCE.
·     Report-only—The device has only reported the candidate path's information to the PCE but it does not delegate the candidate path to the PCE.
·     State reverted—The candidate path has restored to the state prior to the delegation.
Candidate path/path-id
SID list used by the candidate path. The path-id is the ID of the SID list.
path state
State of the SID list:
·     Up—The SID list has been established.
·     Down—The SID list has not been established or the establishment fails.
SRv6-EROs
Number of Segment Routing IPv6 Explicit Route Objects (SR-EROs) and the SR-ERO information.
SID Type
SID and NAI information contained in the ERO or RRO.
The value can be SID without NAI.
Strict
The current node is a strict node.
SID
SRv6 SID of the node.
NAI
Node or Adjacency Identifier.
SRv6-RROs
Number of Segment Routing IPv6 Record Route Objects (SRv6-RROs) and the SRv6-RRO information.
display pce segment-routing ipv6 policy initiate-cache
Use display pce segment-routing ipv6 policy initiate-cache to display information about the SRv6 TE policy Initiate messages cached in the PCE process.
After a PCE and a PCC establishes an active-stateful PCEP session, the PCE sends Initiate messages to the PCC to create candidate paths. This command displays the cached unprocessed Initiate messages.
# Displays SRv6 TE policy Initiate messages cached in the PCE process.
<Sysname> display pce segment-routing ipv6 policy initiate-cache
Policy name: 111111
 Color: 17
 Endpoint: 3::3
 Preference: 17
 Originator: -
 Binding SID: 8::17
 Association ID: 17
 SRP ID: 1                                 PCE initiated: Yes
 Operational state: Down
 Candidate path/0:  path state: Down
  SRv6-EROs: 1
    SID: 2::2                         NAI: N/A
  SRv6-RROs: 0
Table 10 Command output
Policy name
Name of an SRv6 TE policy. If an SRv6 TE policy does not have a name, this field displays a hyphen (-).
Color
Endpoint
Preference
Originator
BGP node address.
Binding SID
Association ID
Protection type
·     Unprotected.
SRP ID
PCE initiated
·     Whether the candidate path is initiated by PCE: Yes or No.
Operational state
path state
SRv6-EROs
Number of SR-EROs and the SR-ERO information.
SID Type
Strict
SID
SRv6 SID (IPv6 address) of the node.
NAI
SRv6-RROs
Number of SRv6-RROs and the SRv6-RRO information.
display segment-routing ipv6 te bfd
Use display segment-routing ipv6 te bfd to display BFD information for SRv6 TE policies.
display segment-routing ipv6 te bfd [ down | policy { { color color-value | end-point ipv6 ipv6-address } * | name policy-name } | up ]
down: Displays BFD information for SRv6 TE policies in down state.
policy: Displays BFD information for the specified SRv6 TE policy.
color color-value: Specifies the color attribute value of an SRv6 TE policy, in the range of 0 to 4294967295.
end-point ipv6 ipv6-address: Specifies the IPv6 address of the endpoint of an SRv6 TE policy.
name policy-name: Specifies the name of an SRv6 TE policy, a case-sensitive string of 1 to 59 characters.
up: Displays BFD information for SRv6 TE policies in up state.
If you do not specify any parameters, this command displays BFD information for all SRv6 TE policies.
# Display BFD information for all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te bfd
 Color: 10
 Endpoint: 4::4
 Policy name: p1
 State: Up
   Forwarding index: 2149580801
   Encapsulation mode: Encaps
   Source IPv6 address: 1::1
   State: Up
   Timer: 37
   VPN index: 1
   Template name: abc
   Reverse path type: None
   Reverse BSID: -
   Flush add time: 2022-12-22 17:01:48
Table 11 Command output
Color
Color attribute value of an SRv6 TE policy.
Endpoint
Endpoint IP address of the SRv6 TE policy.
Policy name
BFD session state of the SRv6 TE policy:
·     Up.
·     Down.
Forwarding index
Forwarding entry index for an SID list.
Encapsulation mode
Encapsulation mode for BFD packets:
·     Encaps—Normal encapsulation mode.
·     Insert—Insertion encapsulation mode.
If the encapsulation mode for BFD packets is not configured, this field displays a hyphen (-).
Source IPv6 address
Source IPv6 address of the BFD session.
BFD session state of the SID list:
·     Up.
·     Down.
Timer
BFD session timer, in seconds.
VPN index
Index of the VPN instance.
Template name
Name of the echo mode BFD template.
Reverse path type
Reverse path type for BFD packets:
·     Reverse BSID—Uses the SID list associated with the reverse BSID as the reverse path for BFD packets.
·     Reverse XSID—Uses the SID list associated with the End.XSID as the reverse path for BFD packets.
·     None—The reverse path for BFD packets is not configured.
Reverse BSID
Reverse BSID of the BFD session.
Reverse XSID
Reverse End.XSID of the BFD session.
Flush add time
The most recent time when the SRv6 TE policy flushed path information to BFD. BFD establishes a detection session based on the path information. If no BFD session is established, this field displays a hyphen (-).
display segment-routing ipv6 te database
Use display segment-routing ipv6 te database to display SRv6 TE policy database information.
display segment-routing ipv6 te database [ link | node | prefix | srv6-sid ]
link: Displays the link information reported by the IGP to the SRv6 TE policy database.
node: Displays the node information reported by the IGP to the SRv6 TE policy database.
prefix: Displays the prefix information reported by the IGP to the SRv6 TE policy database.
srv6-sid: Displays the SRv6 SID information reported by the IGP to the SRv6 TE policy database.
If you do not specify any parameters, this command displays all information reported by the IGP to the SRv6 TE policy database.
# Display link information reported by the IGP to the SRv6 TE policy database.
<Sysname> display segment-routing ipv6 te database link
Link-state information: Link, count: 3
  Public instance, MT-ID: 2, IS-IS instance ID: 0, Link count: 3
    IS-IS P2P:
    Local node: System ID 0000.0000.0020.00, IS level: 1
    Remote node: System ID 0000.0000.0019.00, IS level: 1
    Topology ID: 2
      Link source: ProcID 100, TLV type: MT-IS-reach, FragID: 0x0
        TE local router ID: 2.2.2.2
        TE remote router ID: 1.2.3.4
        IPv6 remote router ID: 1::1
        IGP metric: 10
        SR/SRv6 link maximum SID depths:
          MPLS MSD    : 5
        SRLG: 0
        SRLG: 1
        SRv6 End.X SID
          SID            : 200::1:0:0
          Function type  : End.X (no PSP, no USP)
          Algorithm      : 0
          Weight         : 0
          Flags (B/S/P/C): 0/0/0/0
        SRv6 End.X SID
          SID            : 200::1:0:2
          Function type  : End.X with PSP
          Algorithm      : 0
          Weight         : 0
    IS-IS P2P:
    Local node: System ID 0000.0000.0019.00, IS level: 1
    Remote node: System ID 0000.0000.0020.00, IS level: 1
    IPv6 local address: 2001:1::2
    IPv6 remote address: 2001:1::16
    Topology ID: 2
        TE local router ID: 1.2.3.4
        TE remote router ID: 2.2.2.2
        IPv6 local router ID: 1::1
        TE administrative group: 0x10
        TE maximum bandwidth (kbits/sec): 0
        TE maximum reservable bandwidth (kbits/sec): 0
        TE class  0 unreserved bandwidth (kbits/sec): 0
        TE class  1 unreserved bandwidth (kbits/sec): 0
        TE class  2 unreserved bandwidth (kbits/sec): 0
        TE class  3 unreserved bandwidth (kbits/sec): 0
        TE class  4 unreserved bandwidth (kbits/sec): 0
        TE class  5 unreserved bandwidth (kbits/sec): 0
        TE class  6 unreserved bandwidth (kbits/sec): 0
        TE class  7 unreserved bandwidth (kbits/sec): 0
        TE class  8 unreserved bandwidth (kbits/sec): 0
        TE class  9 unreserved bandwidth (kbits/sec): 0
        TE class 10 unreserved bandwidth (kbits/sec): 0
        TE class 11 unreserved bandwidth (kbits/sec): 0
        TE class 12 unreserved bandwidth (kbits/sec): 0
        TE class 13 unreserved bandwidth (kbits/sec): 0
        TE class 14 unreserved bandwidth (kbits/sec): 0
        TE class 15 unreserved bandwidth (kbits/sec): 0
        TE metric: 10
        IGP metric: 10
          MPLS MSD    : 5
        SRv6 End.X SID
          SID            : 11::A
          Algorithm      : 0
          Weight         : 0
        SRv6 End.X SID
          SID            : 11::1:0:6
          Function type  : End.X (NO-FLAVOR)
          Algorithm      : 0
          Weight         : 0
        SRv6 End.X SID
          SID            : 12:1:2:3:0:A::
          Algorithm      : 0
          Weight         : 0
          Flags (B/S/P/C): 0/0/0/1
          Common prefix length: 64
          Node length         : 26
          Function length     : 6
          Args length         : 0
        SRv6 End.X SID
          SID            : 12:1:2:3:0:6::
          Algorithm      : 0
          Weight         : 0
          Node length         : 26
          Function length     : 6
          Args length         : 0
        SRv6 End.X SID
          SID            : 12:1:2:3:0:7::
          Function type  : End.X with PSP, USP & USD
          Algorithm      : 0
          Weight         : 0
          Node length         : 26
          Function length     : 6
          Args length         : 0
    IS-IS P2P:
    Local node: System ID 0000.0000.0002.00, IS level: 1
    Remote node: System ID 0000.0000.0001.00, IS level: 1
    IPv6 local address: 1001::2
    IPv6 remote address: 1001::1
    Topology ID: 2
      Link source: ProcID 1, TLV type: MT-IS-reach, FragID: 0x0
        IGP metric: 10
        Flag: 0, Average delay(us): 50
        Application specific link attributes
          SA-Length: 8, UDA-Length: 8
          Standard applications: 0x100000000 Flex-Algo
          User-defined applications: 0x100000000 Flex-Algo
        SRv6 End.X SID
          SID            : 2000::1:0:2
          Algorithm      : 130
          Weight         : 0
        SRv6 End.X SID
          SID            : 2000::1:0:3
          Algorithm      : 130
          Weight         : 0
        SRv6 End.X SID
          SID            : 2000::1:0:4
          Algorithm      : 130
          Weight         : 0
Table 12 Command output
Link information.
count
Number of links reported by the IGP to the SRv6 TE policy database.
Public instance
Public network instance.
MT-ID
Topology information:
·     0—Standard topology.
·     2—IPv6 unicast topology.
Link count
Number of links in the IS-IS instance.
IS-IS P2P
IS-IS P2P link.
IS-IS to DIS
IS-IS link to the pseudonode.
IS-IS from DIS
IS-IS link from the pseudonode.
Local node
Local node of the link.
Remote node
Remote node of the link.
System ID
System ID of the node.
IS level
IS-IS level of the node.
Topology ID
Topology ID:
·     0—IPv4 topology.
·     2—IPv6 topology.
Link source
Advertisement source of the link.
ProcID
IS-IS process ID.
TLV type
TLV type:
·     none—Invalid TLV.
·     nbr—Neighbor TLV.
·     wide-nbr—Wide neighbor TLV.
·     ip-internal—IP internal reachability TLV.
·     ip-external—IP external reachability TLV.
·     router-id—Router ID TLV.
·     ip-extended—Extended IP reachability TLV.
·     ipv6-reach—IPv6 reachability TLV.
·     ipv6 router-id—IPv6 router ID TLV.
·     MT-IS-reach—Multi-topology IS reachability TLV.
·     MT-IP-reach—Multi-topology IP reachability TLV.
·     MT-ipv6-reach—Multi-topology IPv6 reachability TLV.
·     srlg—SRLG TLV.
·     locator—Locator TLV.
·     rtr-cap—Routing capability TLV.
·     unknown—Unknown TLV.
FragID
Fragment ID of the packet.
TE class  XX unreserved bandwidth (kbits/sec)
Reservable bandwidth for the specified TE class.
Information about application-specific link attributes.
SA-Length
Standard Application Identifier Bit Mask Length, in bytes.
UDA-Length
User Defined Application Identifier Bit Mask Length, in bytes.
The 0x10 Flex-Algo value represents Flexible Algorithm.
Maximum SID Depths (MSD) information for the MPLS SR or IPv6 SR link.
MPLS MSD
Maximum number of SIDs that MPLS SR can encapsulate into a packet.
SRLG
Shared risk link group information.
SRv6 LAN End.X SID
IPv6 SR End.X SID sub TLV information about the LAN adjacency link.
SRv6 End.X SID
IPv6 SR End.X SID sub TLV information about the P2P adjacency link.
SID
SRv6 SID.
Function type
SID forwarding action and flavor:
·     End.X (NO-FLAVOR)—End.X SID without any flavors.
·     End.X with PSP—End.X SID with PSP.
·     End.X with USP—End.X SID with USP.
·     End.X with PSP&USP—End.X SID with PSP and USP.
·     End.X with PSP&USD—End.X SID with PSP and Ultimate Segment Decapsulation (USD).
·     End.X with PSP, USP&USD—End.X SID with PSP, USP, and USD.
·     End.X with COC (NO-FLAVOR)—Compressed End.X SID without any flavors..
·     End.X with PSP&COC—Compressed End.X SID with PSP.
·     End.X with PSP&USP&COCCompressed End.X SID with PSP and USP.
·     End.X with PSP&USP&USD&COCCompressed End.X SID with PSP, USP, and USD.
If a SID function type contains NO-FLAVOR, for example, End.X (NO-FLAVOR) or End.X with COC (NO-FLAVOR), it indicates that the flavor attribute is canceled for the SID and the SID has only the USP flag.
Flags (B/S/P/C)
IPv6 SR flag information:
·     B—Backup flag. If set, it indicates link protection.
·     S—Collection flag. If set, it indicates a collection of neighbor devices. The SID can be assigned to multiple neighbors.
·     P—Permanent flag. If set, it indicates that the SID can be permanently assigned to the neighbor even if the neighbor relationship is reestablished.
·     C—SRv6 SID compression flag. If set, it indicates that the SID is compressed.
Common prefix length of the compressed SID.
Node length
Node length of the compressed SID.
Function length
Function length of the compressed SID.
Args length
Args length of the compressed SID.
# Display node information reported by the IGP to the SRv6 TE policy database.
<Sysname> display segment-routing ipv6 te database node
Link-state information: Node, count: 2
  Public instance, MT-ID: 2, IS-IS instance ID: 0, Node count: 2
    IS-IS node: System ID 0000.0000.0020.00, IS level: 1
      Node source: ProcID 100, TLV type: none, FragID: 0x0
        Node topology ID: 0 2
        IS-IS area: 10
        SRv6 capability flag (O/C): 0/0
        SR/SRv6 node maximum SID depths:
          MPLS MSD    : 5
          Segment Left: 11
          End Pop MSD : 11
          H.Encaps MSD: 11
          End D MSD   : 11
        Flex-Algo: 130
          Priority: 255
          Metric type: 0
          MFlag: 0
          SRPLS node attribute Flex-Algo exclude-any
              0x00000000  0x00000000
              0x00000004
    IS-IS node: System ID 0000.0000.0019.00, IS level: 1
        Node flag: 0x1
        IS-IS area: 10
        SRv6 capability flag (O/C): 0/1
          MPLS MSD    : 5
          Segment Left: 11
          End Pop MSD : 11
          H.Encaps MSD: 11
          End D MSD   : 11
Table 13 Command output
Node information.
count
Number of nodes reported by the IGP to the SRv6 TE policy database.
Public instance
MT-ID
Node count
Number of nodes in the IS-IS instance.
System ID
IS level
Node source
Advertisement source of the node.
ProcID
IS-IS process ID.
TLV type
TLV type:
·     none—Invalid TLV.
·     nbr—Neighbor TLV.
·     srlg—SRLG TLV.
FragID
Node flag
Flag of the node. 0x01 indicates root node.
SRv6 capability flag:
·     O—O flag in the SRH. If set, it indicates that the node supports OAM.
MSD information for the MPLS SR or IPv6 SR link.
MPLS MSD
Segment Left
Maximum value of the Segments Left field in the SRH.
End Pop MSD
Maximum number of SIDs in the SRH to which the node can apply PSP or USP behavior.
For a packet destined to the local SID on the device, the device is the endpoint of the packet.
H.Encaps MSD
Maximum number of SIDs that can be included as part of the H.Encaps behavior.
End D MSD
Maximum number of SIDs in the SRH when performing decapsulation associated with End.Dx behaviors.
Flex-Algo
Flexible algorithm ID.
Priority
Flex-Algo priority.
Metric type
Metric type of the Flex-Algo:
·     0—IS-IS link cost.
·     1—Link latency.
·     2—TE metric.
MFlag
Metric flag. A value of 2 indicates that the prefix uses the metric type of the Flex-Algo.
Flex-Algo excludes the links with any specific affinity attribute.
SRLG info
Shared Risk Link Group information.
# Display prefix information reported by the IGP to the SRv6 TE policy database.
<Sysname> display segment-routing ipv6 te database prefix
Link-state information: Prefix, count: 21
  Public instance, MT-ID: 2, IS-IS instance ID: 0, Prefix count: 7
    IS-IS IPv6 prefix:
    Local node: System ID 0000.0000.0001.00, IS level: 1
    Prefix: 100::1/128, Topology ID: 2
      Prefix source: ProcID 1, TLV type: ipv6-reach, FragID: 0x0
        Route tag: 100
        Prefix metric: 10
        Locator information
          Metric     : 0
          Algorithm  : 0
          Flags (D/A): 0/0
          Admin tag  : 20
Table 14 Command output
Prefix information.
count
Number of prefixes reported by the IGP to the SRv6 TE policy database.
Public instance
MT-ID
Prefix count
Number of prefixes in the IS-IS instance.
Local node
Local node information of the link.
System ID
IS level
Prefix
Prefix address.
Topology ID
Topology ID:
·     0—IPv4 topology.
·     2—IPv6 topology.
Prefix source
Advertisement source of the prefix.
ProcID
IS-IS process ID.
TLV type
TLV type:
·     none—Invalid TLV.
·     nbr—Neighbor TLV.
·     srlg—SRLG TLV.
FragID
Route tag
Tag value of the interface associated with the prefix.
Locator information
Locator sub-TLV information carried in the prefix.
Algorithm
ID of the algorithm associated with the locator:
·     0—SPF algorithm.
·     128 to 288—Flex-Algo algorithm.
Flags (D/A)
Locator flag:
·     D—Leakage flag, set when the Locator TLV cannot be leaked from Level-1 to Level-2.
·     A—Anycast locator flag, set when the locator is an Anycast Locator.
Admin tag
Admin tag value of the SRv6 locator.
# Display SRv6 SID information reported by the IGP to the SRv6 TE policy database.
<Sysname> display segment-routing ipv6 te database srv6-sid
Link-state information: SRv6 SID, count: 20
  Public instance, MT-ID: 2, IS-IS instance ID: 0, SRv6 SID count: 1
    IS-IS SRv6 SID:
    SID: 300::2, Topology ID: 2
      SID source: ProcID 1, TLV type: locator, FragID: 0x0
        SRv6 endpoint function
          Function type: End with PSP
          Algorithm    : 0
          Flags        : 0x01
    IS-IS SRv6 SID:
    SID: 100:200:DB8:ABCD:0:1::, Topology ID: 0
          Function type: End (NO-FLAVOR)
          Algorithm    : 0
          Flags        : 0x0
    IS-IS SRv6 SID:
    SID: 100:200:DB8:ABCD:0:2::, Topology ID: 0
          Function type: End with PSP, USP & USD
          Algorithm    : 0
          Flags        : 0x0
Table 15 Command output
SRv6 SID information.
count
Number of SRv6 SIDs reported by the IGP to the SRv6 TE policy database.
Public instance
MT-ID
SRv6 SID count
Number of SRv6 SIDs in the IS-IS instance.
IS-IS SRv6 SID
SRv6 SID advertised by IS-IS.
Local node
System ID
IS level
SID
SRv6 SID.
Topology ID
Topology ID:
·     0—IPv4 topology.
·     2—IPv6 topology.
SID source
Advertisement source of the SID.
ProcID
IS-IS process ID.
TLV type
TLV type:
·     none—Invalid TLV.
·     nbr—Neighbor TLV.
·     srlg—SRLG TLV.
FragID
SRv6 SID function.
SID
SRv6 SID.
Function type
·     End (NO-FLAVOR)—End SID without any flavors.
·     End with PSP—End SID with PSP.
·     End with USP—End SID with USP.
·     End with PSP&USP—End SID with PSP and USP.
·     End with PSP&USD—End SID with PSP and Ultimate Segment Decapsulation (USD).
·     End with PSP, USP&USD—End SID with PSP, USP, and USD.
·     End.T with PSP—End.T SID with PSP.
·     End.T with USP—End.T SID with USP.
·     End.T with PSP&USP—End.T SID with PSP and USP.
·     End.DT6—End.DT6 SID.
·     End.DX6—End.DX6 SID.
·     End with COC (NO-FLAVOR)—Compressed End SID without any flavors.
·     End with PSP&COC—Compressed End SID with PSP.
·     End with PSP&USP&COC—Compressed End SID with PSP and USP.
·     End with PSP&USP&USD&COC—Compressed End SID with PSP, USP, and USD.
·     End.X with PSP&USP&COC—Compressed End.X SID with PSP and USP.
·     End.X with PSP&USP&USD&COC—Compressed End.X SID with PSP, USP, and USD.
If a SID function type contains NO-FLAVOR, for example, End (NO-FLAVOR) or End.X (NO-FLAVOR), it indicates that the flavor attribute is canceled for the SID and the SID has only the USP flag.
Algorithm
Algorithm value.
Flags
Compression flag:
·     0x01—End SID compression flag.
·     0x10—End.X SID compression flag.
display segment-routing ipv6 te forwarding
Use display segment-routing ipv6 te forwarding to display SRv6 TE forwarding information.
display segment-routing ipv6 te forwarding [ binding-sid bsid | path-segment psid | policy { name policy-name | { color color-value | end-point ipv6 ipv6-address } * } | xsid xsid ] [ verbose ]
binding-sid bsid: Specifies the BSID of an SRv6 TE policy, which is an IPv6 address.
path-segment psid: Specifies the PSID of an SRv6 TE policy, which is an IPv6 address.
policy: Displays forwarding information of the specified SRv6 TE policy. If you do not specify an SRv6 TE policy, this command displays forwarding information of all SRv6 TE policies.
color color-value: Specifies the color of an SRv6 TE policy, in the range of 0 to 4294967295.
end-point ipv6 ip-address: Specifies the endpoint IPv6 address of an SRv6 TE policy.
xsid xsid: Specifies the End.XSID (IPv6 address) of an SRv6 TE policy.
verbose: Displays detailed SRv6 TE forwarding information. If you do not specify this keyword, the command displays brief SRv6 TE forwarding information.
# Display brief information about all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te forwarding
Total forwarding entries: 1
Policy name/ID: p1/0
 Binding SID: 8000::1
 Forwarding index: 2150629377
 Main path:
   Seglist ID: 1
     Seglist forwarding index: 2149580801
     Weight: 1
     Outgoing forwarding index: 2148532225
       Interface: XGE3/1/1
       Nexthop: FE80::6CCE:CBFF:FE91:206
       Discriminator: 100
 XSID: 8000::1
 Backup path:
   Seglist ID: 2
     Seglist forwarding index: 2149580802
     Weight: 1
     Outgoing forwarding index: 2148532226
       Interface: XGE3/1/2
       Nexthop: FE80::6CCE:CBFF:FE91:207
       Discriminator: 100
# Display detailed information about all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te forwarding verbose
Policy name/ID: lls/9
 Binding SID: 18::1:0:18
 Forwarding index: 2150629384
 Outbound statistics:
   Total octets: 813605400190
   Total packets: 7396412729
   Erroneous packets: 0
   Dropped packets: 0
   Output rate in the last 300 seconds:
     44001488 bits/sec, 50002 pkts/sec
   Output rate in the last statistical period (5 sec):
     44001760 bits/sec, 50002 pkts/sec
 Main path:
   Seglist ID: 3
     Seglist forwarding index: 2149580809
     Weight: 1
       Dropped packets: 0
       Output service-class 2
         813604577940 octets, 7396405254 packets
         0 errors, 0 dropped packets
         Output rate in last 300 seconds:
       Output service-class 255
         822250 octets, 7475 packets
           0 bits/sec, 0 pkts/sec
       Interface: XGE3/1/1
       Nexthop: FE80::366B:5BFF:FE21:3095
       Discriminator: 10
       LoadShareWeight: 1
         Path ID: 0
         SID list: {7:5::2}
Table 16 Command output
Total number of SRv6 TE forwarding entries.
Policy name/ID
Name/ID of an SRv6 TE policy.
Binding SID
SID value of the ingress node.
Path SID
End.PSID of the ingress node.
Forwarding index
Index of the SRv6 TE policy forwarding entry.
Total octets
Total number of octets forwarded.
Total packets
Total number of packets forwarded.
Erroneous packets
Number of erroneous packets.
Dropped packets
Number of dropped packets.
Outbound statistics
Statistics on outbound traffic.
Statistics on outbound traffic of the specified service class.
A value of 255 means the SRv6 TE policy is not configured with a service class and has the lowest forwarding priority.
Main path
Main path for traffic forwarding.
Backup path
Backup path for traffic forwarding.
Seglist ID
ID of the SID list.
Forwarding entry index of the SID list.
Weight
Delay timer type
Delay timer type:
·     LSP—LSP refresh delay timer.
·     BFD—BFD DOWN flag bit clearing delay timer.
·     SBFD—SBFD DOWN flag bit clearing delay timer.
Delay time
Up delay time, in milliseconds.
Remaining time
Remaining up delay time, in milliseconds.
The next hop forwarding entry index of the first address in the SID list.
ECMP-backup indicates backup path for an ECMP route.
Brief name of the outgoing interface.
If the outgoing interface is NULL0, it indicates that SRv6 TE FRR has been enabled and triggered.
Nexthop
Next hop IPv6 address.
Discriminator
Discriminator of the SRv6 forwarding path.
Discriminator
Load sharing weight of the equal-cost output interfaces corresponding to the parallel SID.
XSID
SID of End.XSID type.
Path ID
ID of the SRv6 TE policy candidate path.
SID list
List of SIDs.
SID
SID of the node, which is an IPv6 address.
Common prefix length of the next G-SID. If the next SID is a non-compressed SID, the common prefix length is 0.
G-SID length
Length of the next G-SID. If the next SID is a non-compressed SID, the SID length is 128.
Whether the SID is compressed when it is encapsulated into the SRH:
·     Compressed—The SID is compressed when it is encapsulated into the SRH.
·     Normal—The SID is not compressed when it is encapsulated into the SRH.
display segment-routing ipv6 te forwarding traffic-statistics
Use display segment-routing ipv6 te forwarding traffic-statistics to display SRv6 TE traffic statistics.
# Display SRv6 TE traffic statistics.
<Sysname> display segment-routing ipv6 te forwarding traffic-statistics
Policy name: p1
  Policy ID: 0
  Color: 10
  Endpoint: 4::4
  Binding SID: 1::1:0:1
  Output rate within last 300 seconds: 0 bits/sec, 0 packets/sec
  Output rate within last statistics interval (100 sec): 0 bits/sec, 0 packets/sec
  Output: 0 bytes, 0 packets
  Primary candidate path:
    Preference: 20
    Discriminator: 20
    Protocol origin: CLI
    Segment list name: s2
    Segment list ID: 2
  Backup candidate path:
    Preference: 10
    Discriminator: 10
    Segment list name: s1
    Segment list ID: 1
Table 17 Command output
Policy name
Policy ID
Color
Color attribute of the SRv6 TE policy.
Endpoint
IPv6 address of the destination node for the SRv6 TE policy.
Binding SID
BSID value.
Outbound traffic rate statistics within the most recent 300 seconds.
Outbound traffic rate statistics within the most recent statistics interval. To set the statistics interval, use the srv6-policy forwarding statistics interval command.
Total bytes and total number of packets for outbound traffic.
Primary candidate path for forwarding traffic.
Backup candidate path for forwarding traffic.
Preference
Candidate path preference of the SRv6 TE policy.
Discriminator
Discriminator of the forwarding path.
Protocol origin
Protocol that obtained the candidate path:
·     PCEP.
·     BGP.
·     CLI—Locally configured.
·     Unknown—Unknown source.
Segment list name
Name of the SID list.
Segment list ID
ID of the SID list.
display segment-routing ipv6 te path-segment
Use display segment-routing ipv6 te path-segment to display SRv6 TE policy information for path segments.
display segment-routing ipv6 te path-segment [ local | reverse ] [ ipv6-address ]
local: Display SRv6 TE policy information for local path segments.
reverse: Display SRv6 TE policy information for reverse path segments.
ipv6-address: Specifies a path segment by its IPv6 address. If you do not specify a path segment, this command displays SRv6 TE policy information for all path segments of the specified type.
If you do not specify any parameters, this command displays SRv6 TE policy information for all path segments.
# Display SRv6 TE policy information for all path segments.
<Sysname> display segment-routing ipv6 te path segment
  Path Segment   : 100::100
  Type           : Local
  Reference count: 2
  Policy Name/ID : p1/0           Flag         : -
    Color        : 10             Endpoint     : 4::4
     CpathName   :
      ProtoOrigin: CLI            Discriminator: 10
       Originator: 0, ::
       Explicit SID list ID: 1    Name         : Sl1
  Policy Name/ID : p2/1           Flag         : CF
    Color        : 20             Endpoint     : 4::4
     CpathName   :
       Originator: 0, ::
       Explicit SID list ID: 1    Name         : Sl2
Table 18 Command output
Path Segment
SID of the path segment.
Type of the path segment.
Reference count
Number of times the path segment has been referenced.
Flag
Flag for the path segment:
·     F—Failed to request the path segment, for example, failed to request the path segment from the local locator.
·     CF—Conflicted with an existing path segment SID or BSID. For example, the new path segment requested in the local locator conflicted with an existing BSID, or the same path segment value was specified for different SID lists during local path segment configuration.
·     If the path segment request succeeds, this field displays a hyphen (-).
Policy Name/ID
Name/ID of the SRv6 TE policy.
Color
Endpoint
Endpoint IPv6 address of the SRv6 TE policy. If the address is not configured, this field display none.
CpathName
Name of the candidate path obtained from the BGP route. If no candidate path was obtained, this field is empty.
ProtoOrigin
Protocol that obtains the SRv6 TE policy:
·     PCEP.
·     BGP.
·     CLI—Local configuration.
·     Unknown—Unknown origin.
Discriminator
Discriminator for the SRv6 TE policy.
Originator
SRv6 TE policy information obtained from BGP:
·     ASN—AS number. A value of 0 indicates that no SRv6 TE policy information was obtained from BGP.
·     Peer-address—BGP node address. The peer address is 0.0.0.0 for a manually configured SRv6 TE policy. For an SRv6 TE policy obtained from a BGP peer, the peer address is the router ID of the BGP peer.
Explicit SID ID
SID list index.
Name
SID list name.
display segment-routing ipv6 te policy
Use display segment-routing ipv6 te policy to display SRv6 TE policy information.
display segment-routing ipv6 te policy [ odn | pce ] [ name policy-name | down | up | { color color-value | end-point ipv6 ipv6-address } * ]
odn: Specifies SRv6 TE policies created by ODN.
pce: Specifies SRv6 TE policies whose SID lists are computed by a PCE.
down: Specifies the SRv6 TE policies in down state.
up: Specifies the SRv6 TE policies in up state.
end-point ipv6 ipv6-address: Specifies the endpoint IPv6 address of an SRv6 TE policy.
If you do not specify any parameters, this command displays information about all SRv6 TE policies.
# Display information about all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te policy
Name/ID: p1/0
 Color: 10
 Endpoint: 1000::1
 Name from BGP:
Name from PCE:
 BSID:
  Mode: Dynamic              Type: Type_2              Request state: Succeeded
  Current BSID: 8000::1      Explicit BSID: -          Dynamic BSID: 8000::1
  BSID compress mode: COC-NEXT
 Reference counts: 3
 Flags: A/BS/NC
 Status: Up
 AdminStatus: Up
 Up time: 2020-03-09 16:09:40
 Down time: 2020-03-09 16:09:13
 Hot backup: Enabled
 Statistics: Enabled
  Statistics by service class: Enabled
 Path verification: Enabled
 Drop-upon-invalid: Enabled
 BFD trigger path-down: Enabled
 SBFD: Enabled
  Remote: 1000
  SBFD template name: abc
  SBFD backup template name: -
  OAM SID: -
 BFD Echo: Disabled
 Forward no-bypass: Enabled
 Association ID: 1
 Service-class: -
 Rate-limit: 15000 kbps
 PCE delegation: Disabled
 PCE delegate report-only: Disabled
 Reoptimization: Disabled
 Encapsulation mode: -
Flapping suppression Remaining interval: -
 Metric inherit: Disabled
 SRv6 policy metric :
   IGP metric       : 10                       TE metric        : 10
   Delay metric     : 10                       Loss metric      : 1000000
 Candidate paths state: Configured
 Candidate paths statistics:
  CLI paths: 1       BGP paths: 0       PCEP paths: 0       ODN paths: 0
 Candidate paths:
  Preference : 20
   Network slice ID: 1
   B Flag: Set
   CpathName:
   CPathPolicyName:
   Instance ID: 0          Node address: 0.0.0.0
   Originator:  0, ::
   SRv6 Binding SID:
     Binding SID: 100::1
     Flags (S/I/B): 0/1/1
     Endpoint Behavior: End.B6.Encaps
     Locator Block Length: 64
     Locator Node Length: 16
     Function Length: 16
     Argument Length: 8
   SRv6 Binding SID:
     Binding SID: 200::2
     Endpoint Behavior: End.B6.Encaps.Red
     Locator Node Length: 8
     Function Length: 24
     Argument Length: 16
   Optimal: Y              Flags: V/A
   Dynamic: Not configured
   PCEP: Not configured
   Explicit SID list:
    ID: 1                     Name: Sl1
    Weight: 1                 Forwarding index: 2149580801    State: Up                 State(Echo BFD): Down    Segment list ID: 100      Verification State: -
    Path MTU: 1500            Path MTU Reserved: 0
    SID list flags: None
    Local BSID: -
    Reverse BSID: -
    Local XSID: -
    Reverse XSID: 7000::2
    Local Path Segment: -
    Reverse Path Segment: -
    SID list metric    :
Table 19       Delay metric     : 10                    Loss metric      : 1000000Command output
Name/ID
SRv6 TE policy name/ID.
Color
Endpoint
Endpoint IPv6 address of the SRv6 TE policy. If the endpoint is not configured, this field displays None.
Name from BGP
Name of the SRv6 TE policy obtained from BGP. If no SRv6 TE policy was obtained from BGP, this field is empty.
Name from PCE
Name of the SRv6 TE policy obtained from PCE. If no SRv6 TE policy was obtained from PCE, this field is empty.
BSID
Mode
BSID configuration mode:
·     Explicit—Manually configured.
·     Dynamic—Dynamically requested.
·     None—Not configured.
BSID type:
·     Type_2—IPv6 address.
Request state
BSID request state:
·     Conflicted.
·     Failed.
·     Succeeded.
Explicit BSID
Manually configured BSID.
Dynamic BSID
Dynamically requested BSID.
BSID compress mode
Compression-related flavors of the BSID:
·     COC-NEXT—COC and NEXT flavors. The BSID supports 16-bit compression and the replace and move actions.
·     NEXT—NEXT flavor. The BSID supports 16-bit compression and the move action.
·     Hyphen (-)—No compression-related flavors.
Reference counts
Number of times that the SRv6 TE policy has been referenced.
Flags
SRv6 TE policy flags:
·     A—Active SRv6 TE policy.
·     C—Optimal SRv6 TE policy.
·     N—In optimal SRv6 TE policy selection progress.
·     BA—Requesting BSID.
·     BS—Optimal BSID.
·     D—Deleted SRv6 TE policy.
·     CF—Conflicted with an existing BSID.
·     NC (Name from configuaration)—Manually configured SRv6 TE policy.
·     NB (Name from BGP)—SRv6 TE policy obtained from a BGP route.
Status
SRv6 TE policy state. The SRv6 TE policy is up if a minimum of one SID list in the candidate paths of the SRv6 TE policy is up. The SRv6 TE policy is down if no SID list in the candidate paths of the SRv6 TE policy is up.
·     Up—Active state.
·     Down—Inactive state. The SRv6 TE policy went down because of reasons other than BFD or SBFD session collaboration.
·     Down (BFD down)—A BFD or SBFD session detected that the forwarding paths of all SID lists in the candidate paths of the SRv6 TE policy are not reachable. In this state, the first next hop in the forwarding path of each SID list is reachable, but the subsequent nodes are not reachable.
AdminStatus
Administrative state of the SRv6 TE policy:
·     Down—The policy is shut down by the shutdown command.
·     Up—The policy is not shut down by the shutdown command.
Up time
Date and time when the SRv6 TE policy became up.
Down time
Date and time when the SRv6 TE policy became down.
Hot backup
Hot standby status for the SRv6 TE policy:
·     Enabled.
·     Disabled.
Statistics
Traffic statistics status for the SRv6 TE policy:
·     Disabled.
·     Enabled.
Service class based traffic statistics status for the SRv6 TE policy:
·     Enabled.
·     Disabled.
Path verification
Status of the path verification feature:
·     Enabled—Verifies the validity of all SIDs in the segment list.
·     Specified SIDs—Verifies the validity of the specified SIDs in the segment list.
·     Disabled.
·     Not configured.
Drop-upon-invalid
Drops traffic when the SRv6 TE policy becomes invalid:
·     Disabled.
·     Enabled.
Whether to enable SRv6 TE policy path reselection when the BFD session for the SRv6 TE policy goes down:
·     Disabled.
·     Enabled.
SBFD
SBFD status for the SRv6 TE policy:
·     Enabled.
·     Disabled.
Encapsulation mode
Encapsulation mode for BFD or SBFD packets:
If the encapsulation mode for BFD or SBFD packets is not configured, this field displays a hyphen (-).
Remote
Remote discriminator of the SBFD session.
If the default value is used, this field displays a hyphen (-).
SBFD template name
Name of the SBFD template for the main path.
Name of the SBFD template for the backup SID list.
OAM SID
OAM SID added to SBFD packets or Echo BFD packets.
Reverse path type
Reverse path type for SBFD packets:
·     Reverse BSID—Uses the SID list associated with the reverse BSID as the reverse path for SBFD packets.
·     None—The reverse path for SBFD packets is not configured. The SBFD packets are forwarded back to the source node through IP forwarding.
BFD echo
Echo packet mode BFD status for the SRv6 TE policy:
·     Enabled.
·     Disabled.
Source IPv6 address
Source IPv6 address of the echo packet mode BFD session.
Echo BFD template name
Name of the echo BFD template.
Echo BFD backup template name
Name of the echo BFD template for the backup SID list.
Reverse path type
Reverse path type for BFD echo packets:
·     Reverse Path Segment—Uses the SID list associated with the reverse path segment as the reverse path for SBFD packets.
Forward no-bypass
Status of the No-Bypass feature for the SRv6 TE policy:
·     Disabled—The No-Bypass feature is disabled for the SRv6 TE policy. Packets steered to the SRv6 TE policy can be forwarded through the local protection path.
·     Enabled—The No-Bypass feature is enabled for the SRv6 TE policy. Packets steered to the SRv6 TE policy cannot be forwarded through the local protection path.
Forwarding index
Forwarding entry index of the SRv6 TE policy.
Association ID
Association ID for the candidate path of the SRv6 TE policy. An association ID can identify an SRv6 TE policy.
Service-class
Service class value of the SRv6 TE policy. If the default service class is used, this field displays a hyphen (-).
Rate-limit
Rate limit for the SRv6 TE policy. If no rate limit is configured, this field displays a hyphen (-).
PCE delegation
PCE delegation state for the SRv6 TE policy:
·     Disabled.
·     Enabled.
Only reports SRv6 TE policy information without delegating the SRv6 TE policy to the PCE:
·     Disabled.
·     Enabled.
Encapsulation mode
Encapsulation mode for the SRv6 TE policy:
·     Encaps.
·     Encaps Reduced.
·     Encaps include local End.X.
·     Insert.
·     Insert Reduced.
·     Insert include local End.X.
If the encapsulation mode is not configured for the SRv6 TE policy, this field displays a hyphen (-).
Remaining interval for flapping suppression.
Whether candidate paths are configured:
·     Configured.
·     Not configured.
Metric inherit
Whether the metric sharing feature is enabled for the SRv6 TE policy:
·     Disabled.
Enabled.
SRv6 policy metric
Metric information of the SRv6 TE policy.
IGP metric
IGP metric value.
TE metric
TE metric value.
Delay metric
Link delay metric value, in microseconds.
Loss metric
Packet loss metric value. The measurement unit is 0.000003%. The displayed value might exceed the upper limit of 16777214. In this situation, the real metric value is 16777214.
Candidate paths statistics by path origin.
CLI paths
Number of manually configured candidate paths.
BGP paths
Number of candidate paths obtained from BGP SRv6 TE policy routes.
PCEP paths
Number of candidate paths obtained from PCEP.
ODN paths
Number of candidate paths created by ODN.
Candidate paths
SRv6 TE policy candidate path information.
Preference
Network slice ID
Network slice ID of the SRv6 TE policy candidate path.
B Flag
First flag bit in the IPv6 Hop-by-Hop extension header:
·     If the fist flag bit is set (value 1), packets fail to match a network slice instance ID on the output interface can be forwarded through the output interface.
·     If the fist flag bit is not set (value 0), packets fail to match a network slice instance ID on the output interface will be discarded.
CPathName
Name of the candidate path obtained from a BGP route. If no path name was obtained, this field is empty.
CPathPolicyName
Name of the candidate path inherited from the SRv6 TE policy. If no path name was obtained, this field is empty.
ProtoOrigin
Protocol that obtained the SRv6 TE policy:
·     PCEP.
·     BGP.
Discriminator
Discriminator of the SRv6 TE policy.
Instance ID
BGP instance ID. A value of 0 indicates that the device does not obtain SRv6 TE policy information from BGP peers.
Node address
BGP node address.
For an SRv6 TE policy obtained from a BGP peer, the node address is the Router ID of the BGP peer.
For an SRv6 TE policy obtained in other methods, the node address is 0.0.0.0.
Originator: ASN, Peer-address
Information of the SRv6 TE policy obtained through BGP, where:
·     ASN—AS number. A value of 0 indicates that the device does not obtain SRv6 TE policy information from BGP peers.
·     Peer-address—BGP node address. For a manually configured SRv6 TE policy, the peer address is 0.0.0.0. For an SRv6 TE policy obtained from a BGP peer, the peer address is the address of the BGP peer.
SRv6 Binding SID
¡     S—Specified-BSID-only flag. The current software version does not support this flag. If this flag is set, the system takes restrictive Specified-BSID-only behaviors on the candidate path. The system does not bind a BSID to the candidate path and determines that it is invalid if it has an unspecified BSID or if the specified BSID is not available when it becomes active.
¡     End.B6.Encaps—Normal encapsulation mode.
¡     End.B6.Encaps.Red—Reduced mode of the normal encapsulation mode.
·     Locator Block Length—Common prefix length, in bits.
·     Locator Node Length—Node ID length, in bits.
Peer address
BGP peer address.
For a manually configured SRv6 TE policy, the peer address is ::.
Optimal
Whether the path is the optimal path:
·     Y—Yes.
·     N—No.
Flags
Flags of the SRv6 TE policy candidate path:
·     V—Valid candidate path.
·     A—Active candidate path.
·     B—Backup candidate path.
·     SStale candidate path.
·     BN (Name from BGP)—Candidate path obtained from a BGP route.
·     PN (Name from PCEP)—Candidate path obtained from PCE.
·     None—No candidate path.
Dynamic
Dynamic SID list computation: Configured or Not configured.
Last calculation started at
Time when the most recent dynamic calculation started.
Duration
Period of time that the most recent dynamic calculation lasted, in seconds.
Reason for last calculation failure
Failure reason for the most recent dynamic calculation:
·     Endpoint is 0.0.0.0.
·     The destination node does not exist.
·     The destination node is the same as the source node.
·     Flex-Algo is not configured.
·     Destination node is unreachable.
·     The topology information is incomplete.
·     The link has no adjacent SID.
·     Cannot get valid SIDs.
·     SID list exceeds the maximum SID depth.
·     Failed to create SID list.
·     Internal error.
PCEP
Configuration state of PCEP: Configured or Not configured.
Explicit SID list
Explicit SID list in the candidate path of the SRv6 TE policy.
ID
SID list ID.
Name
SID list name.
Weight
Weight of the SID list in the candidate path.
Forwarding index
SID list state:
·     UPThe first next hop on the forwarding path of the SID list is reachable.
·     DOWN—The first next hop on the forwarding path of the SID list is not reachable.
·     Down(BFD down)—The first next hop on the forwarding path of the SID list is reachable. However, BFD detected that the subsequent nodes on the forwarding path are not reachable.
State(type)
SBFD or echo BFD session state for the SID list:
·     Up.
·     Down.
·     Path Inactive—The candidate path contains no available SID list.
·     Unknown—The SBFD or echo BFD result is unknown.
The type variable represents SBFD or echo BFD session or no BFD session.
If SBFD or echo BFD is not configured, this field displays a hyphen (-) and (No BFD).
Segment list ID
Verification state
Verification result of the SID list:
·     Down—The verification fails.
·     Up—The verification succeeds.
If verification is not configured, this field displays a hyphen (-).
SID list flags
SID list flags of the SRv6 TE policy:
·     O—The number of SIDs in the SID list exceeds the maximum depth for the SID label stack on the device.
·     None—Stateless.
Local BSID
This value is specified by using the explicit segment-list command with the local-binding-sid parameter.
If this value is not specified, this field displays a hyphen (-).
Reverse BSID
This value is specified by using the explicit segment-list command with the reverse-binding-sid parameter.
Local XSID
Local XSID used for BFD.
Reverse XSID
Reverse XSID used for BFD.
Local Path Segment
This value is specified by using the explicit segment-list command with the local-path-segment parameter.
This value is specified by using the explicit segment-list command with the reverse-path-segment parameter.
SID list metric
Metric information of the SID list.
IGP metric
IGP metric value.
TE metric
TE metric value.
Delay metric
Loss metric
display segment-routing ipv6 te policy ifit
Use display segment-routing ipv6 te policy ifit to display iFIT measurement information for SRv6 TE policies.
display segment-routing ipv6 te policy ifit [ name policy-name | down | up | { color color-value | end-point ipv6 ipv6-address } * ]
down: Specifies SRv6 TE policies in down state.
up: Specifies SRv6 TE policies in up state.
color color-value: Specifies an SRv6 TE policy by its color attribute value in the range of 0 to 4294967295.
end-point ipv6 ipv6-address: Specifies an SRv6 TE policy by its endpoint IPv6 address.
If you do not specify any parameters, this command displays iFIT measurement information for all SRv6 TE policies.
# Display iFIT measurement information for all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te policy ifit
SRv6 TE policy name/ID: p1/0
Color: 10
End-point          : 1000::1
Status             : Up                     AdminStatus        : Up
Up time            : 2020-03-09 16:09:40
Down time          : 2020-03-09 16:09:13
IFIT loss measure  : Enabled                IFIT delay measure : Enabled
IFIT interval(s)  : 10                      IFIT measure mode  : e2e
Measurement values :
  One-Way Delay(ms)           : 10
  One-Way Jitter(ms)          : 100
  One-Way Loss(per-thousand)  : 123
  Two-Way Delay(ms)           : 12
  Two-Way Jitter(ms)          : 111
Candidate paths:
Preference : 20
 CpathName     :
 ProtoOrigin   : CLI                Discriminator     : 30
 Instance ID   : 0                  Node address      : 0.0.0.0
 Originator    : 0, ::
 Explicit SID list:
 ID: 1                      Name: Sl1
 Global segment list ID: 1
 State: Up                  State(-): -
 Latest measurement values:
  One-Way Loss(per-thousand)  : 122
  Two-Way Delay(ms)           : 0
  Two-Way Jitter(ms)          : 0
Table 20 Command output
Name/ID
Name and ID of an SRv6 TE policy.
Color
Endpoint
Endpoint IPv6 address of the SRv6 TE policy. If no endpoint IPv6 address is configured, this field displays none.
Status
State of the SRv6 TE policy:
·     Up—Active state.
AdminStatus
·     Down—The SRv6 TE policy is shut down by using the shutdown command.
·     Up—The SRv6 TE policy is not shut down by using the shutdown command.
Up time
Date and time when the SRv6 TE policy came up.
Down time
Date and time when the SRv6 TE policy went down.
IFIT loss measure
State of iFIT packet loss measurement in the SRv6 TE policy:
·     Enabled.
·     Disabled.
IFIT delay measure
State of iFIT delay measurement in the SRv6 TE policy:
·     Enabled.
·     Disabled.
IFIT interval(s)
iFIT measurement interval, in seconds.
IFIT measure mode
iFIT measurement mode:
·     e2e.
·     trace.
Measurement values
iFIT measurement values.
One-Way Delay(ms)
One-way iFIT delay weight value of all SID lists in the optimal candidate path of the SRv6 TE policy, measured in milliseconds.
One-Way Jitter(ms)
One-way iFIT jitter weight value of all SID lists in the optimal candidate path of the SRv6 TE policy, measured in milliseconds.
Weight value of the one-way iFIT packet loss rate of all SID lists in the optimal candidate path of the SRv6 TE policy, measured in per mille (‰).
Two-Way Delay(ms)
Two-way iFIT delay weight value of all SID lists in the optimal candidate path of the SRv6 TE policy, measured in milliseconds.
Two-Way Jitter(ms)
Two-way iFIT jitter weight value of all SID lists in the optimal candidate path of the SRv6 TE policy, measured in milliseconds.
Configuration state of candidate paths:
·     Configured.
·     Not configured.
Source statistics for candidate paths in the SRv6 TE policy.
CLI paths
BGP paths
Number of candidate paths obtained from BGP SRv6 policy routes.
PCEP paths
Number of candidate paths obtained by PCEP.
ODN paths
Candidate paths
Candidate path information of the SRv6 TE policy.
Preference
Preference of a candidate path.
CPathName
Name of the candidate path obtained from a BGP route. If the name is not obtained, this field is empty.
ProtoOrigin
Protocol obtained the SRv6 TE policy information:
·     PCEP—Obtained by PCEP. This value is not supported in the current software version.
·     BGP—Obtained by BGP.
·     CLI—Local configured.
·     Unknown—Source unknown.
Discriminator
Instance ID
BGP instance ID. This field displays 0 if SRv6 TE policy information is not obtained from a BGP peer.
Node address
BGP node address.
If SRv6 TE policy information is obtained from a BGP peer, the node address is the router ID of the BGP peer. If SRv6 TE policy information is not obtained from a BGP peer, the node address is 0.0.0.0.
Originator information:
·     ASN—AS number. The value of 0 indicates that the SRv6 TE policy information is not obtained from BGP.
·     Peer-address—BGP node address. If the SRv6 TE policy is manually configured, the peer address is ::. If the SRv6 TE policy information is obtained from a BGP peer, the peer address is the router ID of the BGP peer.
Explicit SID list
ID
SID list ID. When creating an SID list, the system automatically assigns an ID to it. Different SRv6 TE policies referencing the same SID list will maintain the same ID for the SID list.
Name
SID list name.
Weight
Weight value of the SID list in the candidate path.
Global unique ID of the SID list. When the SID list is applied to the SRv6 TE policy, the system automatically assigns a global unique ID to the SID list. Each iFIT flow corresponds to one global SID list ID.
Forwarding index
SID list state:
·     UP.
·     DOWN.
State(type)
State of the SBFD or echo BFD session in the SID list:
·     Up.
·     Down.
·     Path Inactive—The SID list is not available in the candidate path.
·     Unknown—No results from SBFD or echo BFD detection.
If SBFD or echo BFD is not configured, this field displays a hyphen (-) for the state.
The type variable represents the BFD session type. Supported values:
·     SBFD.
·     Echo BFD.
If SBFD or echo BFD is not configured, this field displays a hyphen (-) for the type.
The most recent five iFIT measurement results of the SID list. If the number of iFIT measurements is less than 5, this field displays all iFIT measurement results. If iFIT cannot correctly measure data, this field is not displayed.
One-Way Delay(ms)
The most recent five one-way iFIT delay values of the SID list, measured in milliseconds.
One-Way Jitter(ms)
The most recent five one-way iFIT jitter values of the SID list, measured in milliseconds.
The most recent five one-way iFIT packet loss rate values of the SID list, measured in per mille (‰).
Two-Way Delay(ms)
The most recent five two-way iFIT delay values of the SID list, measured in milliseconds.
Two-Way Jitter(ms)
The most recent five two-way iFIT jitter values of the SID list, measured in milliseconds.
ifit delay-measure
ifit interval
ifit loss-measure
srv6-policy ifit delay-measure enable
srv6-policy ifit interval
srv6-policy ifit loss-measure enable
display segment-routing ipv6 te policy last-down-reason
Use display segment-routing ipv6 te policy last-down-reason to display information about the most recent down event for SRv6 TE policies.
display segment-routing ipv6 te policy last-down-reason [ binding-sid bsid | color color-value endpoint ipv6 ipv6-address | policy-name policy-name ]
binding-sid bsid: Specifies an SRv6 TE policy by its BSID, which is an IPv6 address.
color color-value endpoint ipv6 ipv6-address: Specifies an SRv6 TE policy by its color attribute value and endpoint IPv6 address. The value range for the color attribute value is 0 to 4294967295.
policy-name policy-name: Specifies an SRv6 TE policy by its name, a case-sensitive string of 1 to 59 characters.
If you do not specify any parameters, this command displays information about the most recent down event for all SRv6 TE policies.
# Display information about the most recent down event for SRv6 TE policy abc.
<Sysname> display segment-routing ipv6 te policy last-down-reason policy-name abc
Name/ID: p1/1
  Color: 10
  Endpoint: 4::4
  BSID: 5000::2
  Up time: 2020-06-23 15:42:14
  Down time: 2020-06-23 15:41:15
  Down reason: Candidate path invalid segment list
  Candidate paths:
    Preference : 10
      CPathName:
      Explicit SID list:
        ID: 1                     Name: s1
        Down reason: No SRv6 SID Out
Table 21 Command output
Name/ID
Color
Color attribute value of the SRv6 TE policy. If the color attribute is not configured, this field displays 0.
Endpoint
Endpoint address of the SRv6 TE policy. If the endpoint address is not configured, this field displays None.
BSID
Up time
Time when the SRv6 TE policy came up.
Down time
Time when the SRv6 TE policy went down.
Down reason
Reason for the down event of the SRv6 TE policy:
·     Admin down—The SRv6 TE policy has been shut down by the shutdown command.
·     No Endpoint.
·     No candidate path.
·     No valid candidate path.
·     Candidate path invalid segment list—All SID lists in the candidate path are down.
·     Policy unconfiguredThe SRv6 TE policy is being deleted.
·     Internal error.
Candidate paths
Preference
Preference of the candidate path.
CPathName
Name of the candidate path. If no candidate path name is obtained from BGP, this field is empty.
Explicit SID List
ID
SID list index.
Name
SID list name.
Up time
Time when the SID list came up.
Down time
Time when the SID list went down.
Down reason
Reason for the down event of the SID list:
·     No SID list—The SID list does not exist.
·     No SRv6 SID Out—The first SID in the SID list has no outgoing interface.
·     Internal error.
·     BFD Detect Down—The first next hop on the forwarding path of the SID list is reachable. However, BFD detected that the subsequent nodes on the forwarding path are not reachable.
display segment-routing ipv6 te policy statistics
Use display segment-routing ipv6 te policy statistics to display SRv6 TE policy statistics.
# Display SRv6 TE policy statistics.
<Sysname> display segment-routing ipv6 te policy statistics
         IPv6 TE Policy Database Statistics
Total policies: 0 (0 up 0 down)
    Configured: 0 (0 up 0 down)
    From BGP: 0 (Added 0 deleted 0   0 up 0 down)
    From ODN: 0 (Added 0 deleted 0   0 up 0 down)
    From PCE: 0 (Added 0 deleted 0   0 up 0 down)
Total candidate paths: 0
    Configured: 0
    From BGP: 0 (Added 0 deleted 0)
    From ODN: 0 (Added 0 deleted 0)
    From PCE: 0 (Added 0 deleted 0)
Total SID lists: 0 (0 up 0 down)
    Dynamic : 0 (0 up 0 down)
    From BGP: 0 (0 up 0 down)
    From PCE: 0 (0 up 0 down)
SRv6-TE policy group resource information:
  Max resources: 1024
  Used resources: 0
  Upper threshold: 820 (80%)
  Lower threshold: 768 (75%)
SRv6-TE policy resource information:
  Max resources: 32768
  Used resources: 0
  Upper threshold: 26215 (80%)
  Lower threshold: 24576 (75%)
SID list resource information:
  Max resources: 32769
  Used resources: 1
  Upper threshold: 26216 (80%)
Forwarding path resource information:
  Max resources: 65536
  Used resources: 0
  Upper threshold: 52429 (80%)
  Lower threshold: 49152 (75%)
Table 22 Command output
Total policies
Total number of SRv6 TE policies:
·     up—Number of SRv6 TE policies in up state.
·     down—Number of SRv6 TE policies in down state or BFD down state.
Configured
Number of manually configured SRv6 TE policies.
Dynamic
Number of dynamically calculated SRv6 TE policies:
From BGP
Number of SRv6 TE policies learned through BGP.
·     Added—Number of BGP-added SRv6 TE policies.
·     deleted—Number of BGP-deleted SRv6 TE policies.
From ODN
Number of SRv6 TE policies created by ODN.
·     Added—Number of ODN-added SRv6 TE policies.
·     deleted—Number of ODN-deleted SRv6 TE policies.
From PCE
Number of SRv6 TE policies created by PCE.
·     Added—Number of PCE-added SRv6 TE policies.
·     deleted—Number of PCE-deleted SRv6 TE policies.
Total number of SRv6 TE policy candidate paths.
Total SID lists
Total number of SID lists.
Max resources
Total number of resources.
Upper threshold
Upper resource threshold.
Lower threshold
Lower resource threshold.
display segment-routing ipv6 te policy status
Use display segment-routing ipv6 te policy status to display status information about SRv6 TE policies.
display segment-routing ipv6 te policy status [ policy-name policy-name ]
policy-name policy-name: Specifies an SRv6 TE policy by its name, a case-sensitive string of 1 to 59 characters. If you do not specify this option, the command displays status information about all SRv6 TE policies.
The device executes the check items for an SRv6 TE policy one by one.
If the result for a check item is Passed, it means that the SRv6 TE policy passed the check for this item and the next item check starts.
If the result for a check item is Failed, the subsequent items will not be checked and the check result for those items is displayed as a hyphen (-).
# Display status information about all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te policy status
Name/ID: p1/0
Status: Up
  Check admin status                  : Passed
  Check for endpoint & color          : Passed
  Check for segment list              : Passed
  Check valid candidate paths         : Passed
  Check for BSIDs                     : Passed
Table 23 Command output
Name/ID
Status
·     Up.
·     Down.
Check admin status
Check the administrative status of the SRv6 TE policy:
·     Passed—The SRv6 TE policy is administratively up.
·     Failed—The SRv6 TE policy is administratively shut down by using the shutdown command.
Check for the endpoint and color configuration for the SRv6 TE policy:
·     Passed—The endpoint address and color are configured.
·     Failed—The endpoint address or color is not configured.
Check for segment lists
Check for valid SID lists in the candidate paths of the SRv6 TE policy:
·     Passed—A valid SID list exists.
·     Failed—No valid SID list exists.
Check for an up candidate path in the SRv6 TE policy:
·     Passed—An up candidate path exists.
·     Failed—No up candidate path exists.
Check for BSIDs
Check for the binding SID configuration for the SRv6 TE policy:
·     Passed—A BSID is specified for the SRv6 TE policy.
·     Failed—No BSID is specified for the SRv6 TE policy.
display segment-routing ipv6 te policy-group
Use display segment-routing ipv6 te policy-group to display information about SRv6 TE policy groups.
display segment-routing ipv6 te policy-group [ odn ] [ group-id | { color color-value | end-point ipv6 ipv6-address } * ] [ verbose ]
odn: Specifies SRv6 TE policy groups automatically created by ODN. If you do not specify this keyword, the command displays information about both SRv6 TE policy groups automatically created by ODN and statically created SRv6 TE policy groups.
group-id: Specifies an SRv6 TE policy group by its ID in the range of 1 to 4294967295.
color color-value: Specifies an SRv6 TE policy group by its color attribute value in the range of 0 to 4294967295.
end-point ipv6 ipv6-address: Specifies an SRv6 TE policy group by its endpoint IPv6 address.
verbose: Displays detailed SRv6 TE policy information. If you do not specify this keyword, the command displays brief SRv6 TE policy information.
If you do not specify the group-id argument, the color color-value option, or the end-point ipv6 ipv6-address option, the command displays information about all SRv6 TE policy groups.
# Display brief information about all SRv6 TE policy groups.
<Sysname> display segment-routing ipv6 te policy-group
Total number of policy groups: 1
GroupID      GroupState    UPMappings     TotalMappings
10           Up            26             26
# Display detailed information about all SRv6 TE policy groups.
<Sysname> display segment-routing ipv6 te policy-group verbose
Total number of policy groups: 5
GroupID: 10                         GroupState: Up
GroupNID: 2151677953                Referenced: 1
Flags:  A                           Group type: Static DSCP
Group color: 100
StateChangeTime: 2021-03-18 09:57:43
Endpoint: 4::4
BSID:
  Explicit BSID: 8000::12                Request state: Succeeded
Drop upon mismatch: Disabled
Delete delay time(ms) : 180000
Delete remain time(ms): -
Metric             :
UP/Total Mappings: 26/26
  Color       Type       DSCP
  10          IPv4       10, 12, 14, 16, 18, 20
Best-effort   IPv4       11, 12, 13, default
Best-effort   IPv6       1, 2, 3, default
GroupID: 20                         GroupState: Down
Flags:  None                        Group type: Static Dot1p
Group color: 100
StateChangeTime: 2021-10-27 10:09:22
Endpoint: 44::44
UP/Total Mappings: 0/5
  Color       Dot1p
  20          4
  30          5~7
GroupID: 30                         GroupState: Down
GroupNID: 0                         Referenced: 1
Flags:  None                        Group type: Static service-class
Group color: 201
StateChangeTime: 2023-07-06 07:39:28
Endpoint: 3:3::3
BSID:
  Explicit BSID: -                       Request state: -
Best-effort NID: 0
UP/Total Mappings: 0/2
  Color       Service-class
  10          10
  Best-effort 2
GroupID: 40                          GroupState: Up
Flags: A                             Group type: Dynamic APN-ID
Group color: 100
StateChangeTime: 2022-10-18 09:57:43
Endpoint: 444::444
  Index     APN-ID/APN-INSTANCE       Color/Best-effort
  10        test1                     100
  15        test2                     200
  20        test3                     best-effort
GroupID: 50                       GroupState: Up
GroupNID: 2151677963              Best-effort NID: 2156920832
Referenced: 1                     Flags: A
Group type: Static TE Class
Group color: 10
StateChangeTime: 2022-08-10 01:50:17
Endpoint: 4::4
UP/Total Mappings: 6/6
  Default Match Type: IPR Policy/SRv6 BE
    Default SRv6 TE Policy Color: -
    Default IPR Policy   : Spr1
    Color : 1              Priority : 1
    Color : 2              Priority : 1
  Index : 1                TE Class : 3
    Match Type           : IPR Policy(active)
    SRv6 TE Policy Color : -
    IPR Policy           : test
    Color : 10             Priority : 1
    Color : 20             Priority : 1
  Index : 2                TE Class : 1
    Match Type           : SRv6 TE Policy
    SRv6 TE Policy Color : 1
    IPR Policy           : -
  Index : 3                TE Class : 2
    Match Type           : SRv6 BE
    IPR Policy           : -
GroupID: 60                          GroupState: Up
Flags: A                             Group type: Dynamic ARN-ID
Group color: 100
Endpoint: 444::444
  Index     ARN-ID               Color/Best-effort
  16        test1                100
  17        test2                200
Table 24 Command output
UPMappings
Total number of valid mappings in the SRv6 TE policy group.
TotalMappings
Total number of mappings configured in the SRv6 TE policy group.
GroupNID
Index of the forwarding entry for the SRv6 TE policy group.
Referenced
Number of times that the SRv6 TE policy group has been used.
Flags
Flags of the SRv6 TE policy group:
·     A—Assign the forwarding entry index of the SRv6 TE policy group.
·     F—Issue the forwarding entry of the SRv6 TE policy group.
·     W—Waiting for assigning the forwarding entry index of the SRv6 TE policy group.
·     D—Delete the SRv6 TE policy group.
·     None—The SRv6 TE policy group is in initial or stable state.
·     BA—Requesting a BSID.
·     BS—Preferred BSID.
·     BC—Conflicts with an existing BSID.
Group type
SRv6 TE policy group type:
·     Static DSCP—Statically created SRv6 TE policy group that uses DSCP-based traffic steering.
·     Static Dot1p—Statically created SRv6 TE policy group that uses 802.1p-based traffic steering.
·     Static service-class—Statically created SRv6 TE policy group that uses service class-based traffic steering.
·     Static APN-ID—Statically created SRv6 TE policy group that uses APN ID-based traffic steering.
·     Static TE Class—Statically created SRv6 TE policy group that uses TE class ID-based traffic steering.
·     Static ARN-ID—Statically created SRv6 TE policy group that uses ARN ID-based traffic steering.
·     Dynamic—Dynamically created SRv6 TE policy group. No forward type is configured.
·     Dynamic APN-ID—Dynamically created SRv6 TE policy group that uses APN ID-based traffic steering.
·     Dynamic DSCP—Dynamically created SRv6 TE policy group that uses DSCP-based traffic steering.
·     Dynamic service-class—Dynamically created SRv6 TE policy group that use service class-based traffic steering.
·     Dynamic TE Class—Dynamically created SRv6 TE policy group that use TE class ID-based traffic steering.
·     Dynamic ARN-ID—Dynamically created SRv6 TE policy group that use ARN ID-based traffic steering.
Group color
Color value of the SRv6 TE policy group.
StateChangeTime
Time when the SRv6 TE policy group state changed.
Endpoint
Destination node IP address of the SRv6 TE policy group. None indicates that the endpoint is not configured.
BSID
BSID information of the SRv6 TE policy group:
·     Explicit BSID—BSID allocated by the system.
·     Request state—Request state of the BSID. Supported values:
¡     Succeeded.
¡     Failed.
Best-effort NID
NID for best effort forwarding.
Drop upon mismatch
Whether the feature of discarding packets that do not match any valid SRv6 TE policy or SRv6 BE path is enabled:
·     Disabled.
·     Enabled.
Deletion delay time for the ODN template-created SRv6 TE policy group, in milliseconds.
Remaining time of the deletion delay time for the SRv6 TE policy group, in milliseconds.
Metric inherit
Whether the metric sharing feature is enabled for the SRv6 TE policy group:
·     Disabled.
·     Enabled.
Metric
Metric information of the SRv6 TE policy group.
IGP metric
IGP metric value.
TE metric
TE metric value.
Delay metric
Loss metric
UP/Total Mappings
Ratio of valid mappings to configured mappings in the SRv6 TE policy group.
Color
Color value
Best-effort
SRv6 BE forwarding mode.
Packet type: IPv4 or IPv6.
DSCP
DSCP value. This field displays default if the SRv6 TE policy or SRv6 BE mode is used as the default forwarding policy for the address family.
Dot1p
802.1p value.
Service-class
Service class value.
Index
Index for a mapping between an APN ID or ARN ID, and a forwarding policy.
APN-ID/APN-INSTANCE
APN ID instance name.
ARN-ID
ARN ID value.
Color/Best-effort
Forwarding policy mapped to the APN ID or ARN ID.
·     When the value is a number, it represents the color attribute value of an SRv6 TE policy. Traffic with the specified APN ID or ARN ID will be forwarded through this SRv6 TE policy.
·     When the value is best-effort, traffic with the specified APN ID or ARN ID will be forwarded in SRv6 BE mode.
Default MatchType
Default forwarding policy for TE class ID-based traffic steering:
·     IPR Policy.
·     SRv6 TE Policy.
·     SRv6 BE.
If the default forwarding policy is SRv6 TE policy forwarding, this field represents the color attribute value of an SRv6 TE policy.
If the default forwarding policy is not SRv6 TE policy forwarding, this field displays a hyphen (-).
Default IPR Policy
If the default forwarding policy is IPR policy forwarding, this field represents the name of an IPR policy.
If the default forwarding policy is not IPR policy forwarding, this field displays a hyphen (-).
Color
Color attribute value of the optimal SRv6 TE policy in the IPR policy.
This field is not displayed if no TE class ID is mapped to the IPR policy.
Priority
Priority of the optimal SRv6 TE policy in the IPR policy.
Index
Index of a mapping between a TE class ID and a forwarding policy.
TE Class
TE class ID.
Match Type
Mapping between the TE class ID and an SRv6 TE policy, an IPR policy, or the SRv6 BE mode. Supported values:
·     IPR Policy—Traffic identified by the TE class ID is forwarded through the forwarding method defined in an IPR policy. If the forwarding method takes effect, this field displays active in a pair of brackets. If the forwarding method does not take effect, this field does not display active.
·     SRv6 TE Policy—Traffic identified by the TE class ID is forwarded through an SRv6 TE policy.
·     SRv6 BE—Traffic identified by the TE class ID is forwarded in SRv6 BE mode.
Color attribute value of the SRv6 TE policy mapped to the TE class ID.
IPR Policy
Name of the IPR policy mapped to the TE class ID.
display segment-routing ipv6 te policy-group apn-id-ipv6
Use display segment-routing ipv6 te policy-group apn-id-ipv6 instance to display APN ID instance information for SRv6 TE policies.
display segment-routing ipv6 te policy-group apn-id-ipv6 instance [ name instance-name ]
name instance-name: Specifies an APN ID instance by its name, a case-sensitive string of 1 to 31 characters.
After an APN ID instance is created, the SRv6 TE policy module can obtain information about that APN ID instance to perform APN ID-based traffic steering. To identify whether the APN6 module and the SRv6 TE policy module correctly exchange APN ID instance information, use this command. For more information about APN ID instances, see APN6 configuration in Application-aware Networking Configuration Guide.
# Display APN ID instance information for SRv6 TE policies.
<Sysname> display segment-routing ipv6 te policy-group apn-id-ipv6 instance
Instance name  : inst1
Instacne ID    : 1          APN ID length      : 64
App Group Len  : 32         App Group Mask Len : 10
Usr Group Len  : 32         Usr Group Mask Len : 8
APN ID         : 0x4b400000 0xc9000000
APN Mask       : 0xffc00000 0xff000000
Table 25 Command output
Instance name
Name of the APN ID instance.
Instance ID
Instance ID assigned to the APN ID instance.
APN ID length
Total length of the APN ID. An APN ID consists of the APP-Group-ID, User-Group-ID, and Reserved fields.
AppGroupLen
Length of the APP-Group-ID field.
AppGroupMaskLen
Mask length of the APP-Group-ID field.
UsrGroupLen
Length of the User-Group-ID field.
UsrGroupMaskLen
Mask length of the User-Group-ID field.
APN ID
Hexadecimal values for the APP-Group-ID and User-Group-ID fields. The value for the APP-Group-ID field is followed by that for the User-Group-ID field.
APN mask
Mask length values for the APP-Group-ID and User-Group-ID fields. The value for the APP-Group-ID field is followed by that for the User-Group-ID field. For example, if the value for the APP-Group-ID field is 0x02000000 and its mask length is 0xff000000, only the highest eight bits carry a value of 2.
index apn-id match
display segment-routing ipv6 te policy-group last-down-reason
Use display segment-routing ipv6 te policy-group last-down-reason to display the reason why the specified or all SRv6 TE policy groups went down most recently.
display segment-routing ipv6 te policy-group last-down-reason [ group-id | endpoint ipv6-address color color-value ]
group-id: Specifies an SRv6 TE policy group by its ID in the range of 1 to 4294967295. If you do not specify this argument, the command displays information about all SRv6 TE policy groups.
endpoint ipv6-address color color-value: Specifies the IPv6 address of the destination node and the color value in the range of 0 to 4294967295.
# Display the reason why SRv6 TE policy group 10 went down most recently.
<Sysname> display segment-routing ipv6 te policy-group last-down-reason 10
Group ID   : 10                        Group type : Static DSCP
Group color: 100                       Endpoint   : 4::4
Group NID  : 2151677956
Create time: 2021-03-18 09:57:43
Up time    : -
Down time  : 2021-03-18 09:57:43
Down reason: No active SRv6-TE Policies
  Color: 20                     Address family: IPv4
    Up time    : 2021-03-18 01:52:20.785
    Down time  : 2021-03-18 09:59:23
    Down reason: No endpoint
Table 26 Command output
Group type
·     Dynamic service-class—Dynamically created SRv6 TE policy group that uses service class-based traffic steering.
·     Dynamic TE Class—Dynamically created SRv6 TE policy group that uses TE class ID-based traffic steering.
·     Dynamic ARN-ID—Dynamically created SRv6 TE policy group that uses ARN ID-based traffic steering.
Group color
Endpoint
Group NID
Create time
Time when the SRv6 TE policy group state was created.
Up time
Time when the SRv6 TE policy group came up.
Down time
Time when the SRv6 TE policy group went down.
Down reason
Reason why the SRv6 TE policy group went down:
·     No endpoint.
·     No color-DSCP mappings.
·     No active SRv6 TE policies.
·     No color-Dot1p mappings—No color-to-802.1p mappings are configured.
·     No color-service-class mappings—No color-to-service class mappings are configured.
·     No color-apn-id mappings—No color-to-APN ID mappings are configured.
·     No color-TE Class mappingsNo color-to-TE class ID mappings are configured.
·     Forwarding down—No FIB entries exist.
Color
Color value mapped to the traffic steering marker.
Up time
Time when the color-to-traffic steering marker mapping came up.
Down time
Time when the color-to-traffic steering marker mapping went down.
Down reason
Reason why the color-to-traffic steering marker mapping went down.
·     No endpoint.
·     The SRv6-TE policy is used by another group.
·     SRv6-TE policy doesn't exist.
·     SRv6-TE policy down.
·     No color-Dot1p mappings.
·     No color-TE Class mappings.
·     No selected by intelligent route policy.
·     APNID conflict.
display segment-routing ipv6 te policy-group statistics
Use display segment-routing ipv6 te policy-group statistics to display SRv6 TE policy group statistics.
# Display SRv6 TE policy group statistics.
<Sysname> display segment-routing ipv6 te policy-group statistics
Statistics type                 Total                Up
Dynamic DSCP groups             0                    0
Static DSCP groups              1                    0
Color-DSCP mappings             0                    0
SRv6-BE-DSCP mappings           0                    0
Static Dot1p groups             0                    0
Color-Dot1p mappings            0                    0
Dynamic service-class groups    0                    0
Static service-class groups     0                    0
Color-service-class mappings    0                    0
SRv6-BE-service-class mappings  0                    0
Dynamic APN ID groups           0                    0
Static APN ID groups            0                    0
Color-APN ID mappings           0                    0
SRv6-BE-APN ID mappings         0                    0
Dynamic TE Class groups         0                    0
Static TE Class groups          0                    0
Color-TE Class mappings         0                    0
IPR-TE Class mappings           0                    0
SRv6-BE-TE Class mappings       0                    0
Dynamic ARN ID groups           0                    0
Static ARN ID groups            0                    0
Color-ARN ID mappings           0                    0
SRv6-BE-ARN ID mappings         0                    0
Table 27 Command output
Statistics type
Statistics objects:
·     Dynamic DSCP groups—Dynamically created SRv6 TE policy groups that use DSCP-based traffic steering.
·     Static DSCP groups—Statically created SRv6 TE policy groups that use DSCP-based traffic steering.
·     Color-DSCP mappings—Color-to-DSCP mappings in all SRv6 TE policy groups.
·     SRv6-BE-DSCP mappings—SRv6 BE-to-DSCP mappings in all SRv6 TE policy groups.
·     Static Dot1p groups—Statically created SRv6 TE policy groups that use 802.1p-based traffic steering.
·     Color-Dot1p mappings—Color-to-802.1p mappings in all SRv6 TE policy groups.
·     Dynamic service-class groups—Dynamically created SRv6 TE policy groups that use service class-based traffic steering.
·     Static service-class groups—Statically created SRv6 TE policy groups that use service class-based traffic steering.
·     Color-service-class mappings—Color-to-service class mappings in all SRv6 TE policy groups.
·     SRv6-BE-service-class mappings—SRv6 BE-to-service class mappings in all SRv6 TE policy groups.
·     Dynamic APN ID groups—Dynamically created SRv6 TE policy groups that use APN ID-based traffic steering.
·     Static APN ID groups—Statically created SRv6 TE policy groups that use APN ID-based traffic steering.
·     Color-APN ID mappings—Color-to-APN ID mappings in all SRv6 TE policy groups.
·     SRv6-BE-APN ID mappings—SRv6 BE-to-APN ID mappings in all SRv6 TE policy groups.
·     Dynamic TE Class groups—Dynamically created SRv6 TE policy groups that use TE class ID-based traffic steering.
·     Static TE Class groups—Statically created SRv6 TE policy groups that use TE class ID-based traffic steering.
·     Color-TE Class mappings—Color-to-TE class ID mappings in all SRv6 TE policy groups.
·     IPR-TE Class mappings—All IPR policy-to-TE class ID mappings.
·     SRv6-BE-TE Class mappingsSRv6 BE-to-TE class ID mappings in all SRv6 TE policy groups.
·     Dynamic ARN ID groups—Dynamically created SRv6 TE policy groups that use ARN ID-based traffic steering. This type is not supported in the current software version.
·     Static ARN ID groups—Statically created SRv6 TE policy groups that use ARN ID-based traffic steering. This type is not supported in the current software version.
·     Color-ARN ID mappings—Color-to-ARN ID mappings in all SRv6 TE policy groups. This type is not supported in the current software version.
·     SRv6-BE-ARN ID mappings—SRv6 BE-to-ARN ID mappings in all SRv6 TE policy groups. This type is not supported in the current software version.
Total
Total number of statistics objects.
UP
Number of effective statistics objects.
display segment-routing ipv6 te sbfd
Use display segment-routing ipv6 te sbfd to display SBFD information for SRv6 TE policies.
display segment-routing ipv6 te sbfd [ down | policy { { color color-value | end-point ipv6 ipv6-address } * | name policy-name } | up ]
down: Displays SBFD information for SRv6 TE policies in down state.
policy: Displays SBFD information for the specified SRv6 TE policy.
color color-value: Specifies the color attribute value of an SRv6 TE policy, in the range of 0 to 4294967295.
end-point ipv6 ipv6-address: Specifies the IPv6 address of the endpoint of an SRv6 TE policy.
name policy-name: Specifies the name of an SRv6 TE policy, a case-sensitive string of 1 to 59 characters.
up: Displays SBFD information for SRv6 TE policies in up state.
If you do not specify any parameters, this command displays SBFD information for all SRv6 TE policies.
# Display SBFD information for all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te sbfd
 Color: 10
 Endpoint: 4::4
 Policy name: p1
 State: Down
   Nid: 2149580801
   BFD type: SBFD
   Encapsulation mode: Encaps
   Remote Discr: 100
   State: Down
   Timer: 30
   VPN index: 0
   Template name: abc
   Reverse path type: None
   Reverse BSID: -
   Local Path Segment:-
   Flush add time: 2022-12-22 17:01:48
Table 28 Command output
Color
Color attribute value of an SRv6 TE policy.
Endpoint
Endpoint IP address of the SRv6 TE policy.
Policy name
Name of the SRv6 TE policy.
SBFD session state:
·     Up.
·     Down.
·     Delete.
Nid
Forwarding entry index for an SID list.
BFD type
The current software version supports only the SBFD type.
Encapsulation mode
Encapsulation mode for SBFD packets:
·     Encaps—Normal encapsulation mode.
·     Insert—Insertion encapsulation mode.
If the encapsulation mode for SBFD packets is not configured, this field displays a hyphen (-).
Remote Discr
Remote discriminator.
Timer
SBFD session timer, in seconds.
Reverse path type
Reverse BSID
Reverse BSID of the SBFD session.
Local Path Segment
Local path segment of the SBFD session.
Flush add time
The most recent time when the SRv6 TE policy flushed path information to SBFD. SBFD establishes a detection session based on the path information. If no SBFD session is established, this field displays a hyphen (-).
display segment-routing ipv6 te segment-list
Use display segment-routing ipv6 te segment-list to display SRv6 TE SID list information.
display segment-routing ipv6 te segment-list [ name seglist-name | id id-value ]
name segment-list-name: Specifies a SID list by its name, a case-sensitive string of 1 to 128 characters.
id id-value: Specifies a SID list by its ID. The value range for the SID list ID is 1 to 4294967295.
If you do not specify a SID list name or ID, this command displays information about all SRv6 TE SID lists.
To view SID list ID information, execute the display segment-routing ipv6 te policy command.
# Display information about all SRv6 TE SID lists.
<Sysname> display segment-routing ipv6 te segment-list
Total Segment lists: 1
Name/ID: A/1
 Origin: CLI
 Status: Up
 Verification State: Down
 Nodes: 1
 Flags: None
 Local BSID: -
 Reverse BSID: -
 Reference counts: 0
  Index                 : 1                            SID: 1::2
  Status                : Up                    TopoStatus: Nonexistent
  Type                  : Type_2                     Flags: V
  Coc Type              : Compress-16 Common prefix length: 0
  Function length       : 0                    Args length: 0
  Compressed function   : 0                    Node length: 16
  Endpoint Behavior: -
Table 29 Command output
Total Segment lists
Number of SID lists.
Name/ID
SID list name/ID.
Origin
Origin of the SID list. Options include:
·     CLI—Locally configured in the CLI.
·     BGP—Issued by BGP.
·     PCE—Issued by a PCE.
·     Dynamic—Dynamically calculated by the source node.
If the SID list does not have a valid origin, this field displays a hyphen (-).
Status
SID list status, Down or Up.
Verification State
Nodes
Number of nodes in the SID list.
Flags
Flags bit of the node.
·     None—No flags.
·     V—Verifies the validity of the SID during SRv6 TE policy path verification.
·     CF—The local BSID or reverse BSID conflicts with an existing BSID.
Index
Node index.
SID
SID value (IPv6 address) of the node.
TopoStatus
Whether the SID exists in the IGP topology:
·     Existent.
·     Nonexistent.
SID type of the node:
Flags
Node flags, which are not defined and displayed as None.
Coc type
Compression type of the SID:
·     COC32—32-bit compression.
·     Compress-16—16-bit compression.
·     Hyphen (-)—The SID is not compressed.
Common prefix length of the G-SID.
Function length
Length of the SID function.
Args length
Args length of the specified SRv6 SID.
Compressd Function
Function length of the 16-bit G-SID, which can be 0 or 16.
Node length
Node ID length of the 16-bit G-SID, which can be 0 or 16.
Endpoint Behavior
Endpoint behavior:
·     End (no PSP, no USP)
·     End with PSP
·     End with USP
·     End with PSP&USP
·     End.X (no PSP, no USP)
·     End.X with PSP
·     End.X with USP
·     End.X with PSP&USP
·     End.T (no PSP, no USP)
·     End.T with PSP
·     End.T with USP
·     End.T with PSP&USP
·     End with USD
·     End with PSP&USD
·     End with USP&USD
·     End with PSP&USP&USD
·     End.X with USD
·     End.X with PSP&USD
·     End.X with USP&USD
·     End.X with PSP&USP&USD
·     End.T with USD
·     End.T with PSP&USD
·     End.T with USP&USD
·     End.T with PSP&USP&USD
·     End with COC
·     End with PSP&COC
·     End with PSP&USP&COC
·     End.X with COC
·     End.X with PSP&COC
·     End.X with PSP&USP&COC
·     End.T with COC
·     End.T with PSP&COC
·     End.T with PSP&USP&COC
·     End with PSP&USD&COC
·     End with PSP&USP&USD&COC
·     End.X with PSP&USD&COC
·     End.X with PSP&USP&USD&COC
·     End.T with PSP&USD&COC
·     End.T with PSP&USP&USD&COC
·     End with NEXT
·     End with PSP&USD&NEXT
·     End with NEXT&COC
·     End with USP&USD&NEXT&COC
·     End with PSP&USP&USD&NEXT&COC
·     End.X with NEXT
·     End.X with PSP&USD&NEXT
·     End.X with NEXT&COC
·     End.X with USP&USD&NEXT&COC
·     Src.DT6 with COC
·     Src.DT4 with COC
·     End.B6.INSERT with NEXT&COC
·     End.B6.Encaps with NEXT&COC
·     End.B6.INSERT with NEXT&COC REDUCE
·     End.B6.INSERT with NEXT REDUCE
·     End.B6.Encaps with NEXT&COC REDUCE
·     End.B6.Encaps with NEXT REDUCE
·     End.DX6 with NEXT
·     End.DX6 with NEXT&COC
·     End.DX4 with NEXT
·     End.DX4 with NEXT&COC
·     End.DT6 with NEXT
·     End.DT6 with NEXT&COC
·     End.DT4 with NEXT
·     End.DT4 with NEXT&COC
·     End.DT46 with NEXT
·     End.DT46 with NEXT&COC
·     End.DX2 with NEXT
·     End.DX2 with NEXT&COC
·     End.DT2U with NEXT
·     End.DT2U with NEXT&COC
·     End.DT2M with NEXT
·     End.DT2M with NEXT&COC
·     End.DT2UL with NEXT&COC
·      End.DX2L with NEXT
·     End.DX2L with NEXT&COC
This field displays a hyphen (-) for an invalid endpoint behavior.
display segment-routing ipv6 te source-sid
Use display segment-routing ipv6 te source-sid to display information about SRv6 SIDs collected from the LS database.
display segment-routing ipv6 te source-sid [ end | end-x | sid ]
end: Displays End SID information.
end-x: Displays End.X SID information.
sid: Displays information about the specified SRv6 SID.
If you do not specify any parameters, this command displays information about all SRv6 SIDs collected from the LS database.
# Display information about all SRv6 SIDs collected from the LS database.
<Sysname> display segment-routing ipv6 te source-sid
  SID         : 11::1:0:8, Count: 1
   Type       : End.X(LAN), Topology ID: 0
   Instance ID: 0
    Source    : IS-IS, ProcID 100, IS-Level-1
    Node      : 0000.0000.0019.00
    Local     : 0000.0000.0019.00
    Peer      : 0000.0000.0022.01
  SID         : 12:1:2:3:0:1::, Count: 2
   Type       : End, Topology ID: 0
   Instance ID: 0
   Type       : End, Topology ID: 2
   Instance ID: 0
  SID         : 12:1:2:3:0:6::, Count: 2
   Type       : End.X, Topology ID: 0
   Instance ID: 0
    Local     : 2001:1::2
    Peer      : 2001:1::16
   Type       : End.X, Topology ID: 2
   Instance ID: 0
    Local     : 2001:1::2
    Peer      : 2001:1::16
Table 30 Command output
SID
SRv6 SID.
Count
Number of advertising sources for the SID.
SID type:
·     End.
·     End.X.
·     End.X (LAN).
ProcID
Process ID.
IS-Level-X
IS level on the node: IS-Level-1 or IS-Level-2.
Node
Node where the SID advertising source resides.
Local
For an End.X SID, this field displays the system ID of the IS-IS process to which the SID-associated local interface belongs.
If the link type is P2P and the IPv6 link attribute is enabled for the IS-IS process, this field displays the IPv6 address of the SID-associated local interface.
Peer
For an End.X SID, this field displays the system ID of the IS-IS process to which the SID-associated neighbor interface belongs.
If the link type is P2P and the IPv6 link attribute is enabled for the IS-IS process, this field displays the IPv6 address of the SID-associated neighbor interface.
display segment-routing ipv6 te ipr
Use display segment-routing ipv6 te ipr to display information about IPR policies.
display segment-routing ipv6 te ipr [ name ipr-name ]
name ipr-name: Specifies an IPR policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify an IPR policy, this command displays information about all IPR policies.
# Display information about IPR policy ipr1.
<Sysname> display segment-routing ipv6 te ipr name ipr1
IPR policy name: ipr1
Delay threshold       : 1000         Jitter threshold   : 1000
Packet loss threshold : 300          CMI threshold      : 5000
Switch period         : 6            WTR period         : 6
Color                 : 2            Priority           : 2
Color                 : 3            Priority           : 1
Color                 : 4            Priority           : 2
Instance:
  Group ID       : 1                 Endpoint : 1::1
  Selected color : 2 3 4
  Group ID       : 2                 Endpoint : 2::2
Table 31 Command output
IPR Policy Name
Name of an IPR policy.
Delay threshold
Delay threshold in the IPR policy, in milliseconds.
Jitter threshold
Jitter threshold in the IPR policy, in milliseconds.
Packet loss rate threshold in the IPR policy, in ‰.
CMI threshold
CMI threshold in the IPR policy,
Switch period
Switchover period between different SRv6 TE policies in the IPR policy, measured in seconds.
WTR period
WTR period in the IPR policy, in seconds.
Color
Color attribute value of an SRv6 TE policy in the IPR policy.
Priority
Path selection priority for the color attribute value of the SRv6 TE policy.
Instance
Instance information about the SRv6 TE policy groups to which the IPR policy is applied.
Group ID
SRv6 TE policy group to which the IPR policy is applied.
Endpoint
Endpoint address of the SRv6 TE policy group.
Selected color
Color attribute value of the optimal SRv6 TE policy obtained by computation based on the IPR policy.
ipr-policy
distribute bgp-ls
Use distribute bgp-ls to enable the device to distribute SRv6 TE policy candidate path information to BGP-LS.
Use undo distribute bgp-ls to restore the default.
distribute bgp-ls
The device does not distribute SRv6 TE policy candidate path information to BGP-LS.
SRv6 TE view
Operating mechanism
After this command is executed, the device distributes SRv6 TE policy candidate path information to BGP-LS. BGP-LS advertises the SRv6 TE policy candidate path information in routes to meet application requirements.
After BGP-LS receives SRv6 TE policy routing information, it generates and advertises link state information to other BGP-LS peers. As a best practice, configure the te ipv6-router-id command to specify the IPv6 TE router ID in link state information. You can identify different source nodes of SRv6 TE Policy by their IPv6 TE router IDs. If you do not configure the te ipv6-router-id command, the IPv6 TE router ID in link state information will be 0::0. This route might be discarded when it is exchanged between devices from different vendors, which affects the normal advertisement of link state information.
# Enable the device to distribute SRv6 TE policy candidate path information to BGP-LS.
[Sysname] segment-routing-ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] distribute bgp-ls
te ipv6-router-id
drop-upon-invalid
Use drop-upon-invalid to configure the device to drop traffic when an SRv6 TE policy becomes invalid.
Use undo drop-upon-invalid to disable the drop-upon-invalid feature for an SRv6 TE policy.
drop-upon-invalid { disable | enable }
undo drop-upon-invalid enable
The drop-upon-invalid feature is not configured for an SRv6 TE policy. The configuration in SRv6 TE view applies.
SRv6 TE policy view
Enable this feature for an SRv6 TE policy if you want to use only the SRv6 TE policy to forward traffic.
By default, if all forwarding paths of an SRv6 TE policy become invalid, the device forwards the packets through IPv6 routing table lookup based on the packet destination IPv6 addresses.
After you execute the drop-upon-invalid enable command, the device drops the packets if all forwarding paths of the SRv6 TE policy become invalid.
The command does not take effect when the SRv6 TE policy is invalid. To check the SRv6 TE policy validity, see the Forwarding index field in the display segment-routing ipv6 te policy command output. If the value is 0, the SRv6 TE policy is invalid.
The drop-upon-invalid command configured on the remote device does not affect an SRv6 TE policy generated based on a BGP IPv6 SR-TE policy route. The SRv6 TE policy is controlled by only the drop-upon-invalid command configured on the local device.
You can configure the drop-upon-invalid feature globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable the device to drop traffic when SRv6 TE policy a1 becomes invalid.
[Sysname] segment-routing ipv6
[Sysname-srv6-te] policy a1
[Sysname-srv6-te-policy-a1] drop-upon-invalid enable
srv6-policy drop-upon-invalid
drop-upon-mismatch enable
Use drop-upon-mismatch enable to enable the feature of discarding packets that do not match any valid SRv6 TE policy or SRv6 BE path.
Use undo drop-upon-mismatch enable to disable the feature of discarding packets that do not match any valid SRv6 TE policy or SRv6 BE path.
The device does not discard packets that do not match any valid SRv6 TE policy or SRv6 BE path.
SRv6 TE ODN policy group view
SRv6 TE policy group view
Use this command if you want to forward traffic only through SRv6 TE policies based on color-to-DSCP, color-to-802.1p, and color-to-service class mappings, through the default SRv6 TE policy, or in SRv6 BE mode.
# In SRv6 TE policy group 10, enable the feature of discarding packets that do not match any valid SRv6 TE policy or SRv6 BE path.
[Sysname-srv6-te] policy-group 10
[Sysname-srv6-te-policy-group-10] drop-upon-mismatch enable
# In SRv6 TE ODN policy group view, enable the feature of discarding packets that do not match any valid SRv6 TE policy or SRv6 BE path.
[Sysname-srv6-te] on-demand-group color 1
[Sysname-srv6-te-odn-group-1] drop-upon-mismatch enable
best-effort match service-class (service class forward type view)
best-effort match service-class (SRv6 TE policy group view)
color match dscp (DSCP forward type view)
color match dscp (SRv6 TE policy group view)
color match dot1p
color match service-class (service class forward type view)
color match service-class (SRv6 TE policy group view)
forward-type (SRv6 TE ODN policy group view)
forward-type (SRv6 TE policy group view)
dynamic (SRv6 TE policy path preference view)
Use dynamic to create and enter SRv6 TE policy path preference dynamic view, or enter the existing SRv6 TE policy path preference dynamic view.
Use undo dynamic to delete the SRv6 TE policy path preference dynamic view and all the configuration in the view.
dynamic
undo dynamic
The SRv6 TE policy path preference dynamic view does not exist.
In SRv6 TE policy path preference dynamic view, you can enable the device to dynamically create SID lists for an SRv6 TE policy candidate path.
# Create and enter SRv6 TE policy path preference dynamic view.
[Sysname-srv6-te] policy 1
[Sysname-srv6-te-policy-1] candidate-paths
[Sysname-srv6-te-policy-1-path] preference 20
[Sysname-srv6-te-policy-1-path-pref-20] dynamic
[Sysname-srv6-te-policy-1-path-pref-20-dyna]
dynamic (SRv6 TE ODN view)
Use dynamic to create and enter SRv6 TE ODN dynamic view, or enter the existing SRv6 TE ODN dynamic view.
Use undo dynamic to delete the SRv6 TE ODN dynamic view and all the configuration in the view.
dynamic
undo dynamic
The SRv6 TE ODN dynamic view does not exist.
SRv6 TE ODN view
In SRv6 TE ODN dynamic view, you can enable dynamic generation of SRv6 TE policies and dynamic generation of SID lists for SRv6 TE policy candidate paths.
# Create and enter SRv6 TE ODN dynamic view.
[Sysname-srv6-te] on-demand color 1
[Sysname-srv6-te-odn-1] dynamic
[Sysname-srv6-te-odn-1-dynamic]
encapsulation-mode (SRv6 TE policy view)
Use encapsulation-mode to configure the encapsulation mode for an SRv6 TE policy.
Use undo encapsulation-mode to restore the default.
encapsulation-mode encaps reduced [ disable ]
undo encapsulation-mode encaps reduced
encapsulation-mode insert
undo encapsulation-mode insert
encapsulation-mode insert reduced [ disable ]
undo encapsulation-mode insert reduced
The encapsulation mode is not configured for an SRv6 TE policy, and the encapsulation mode configured in SRv6 TE view applies.
SRv6 TE policy view
encaps reduced: Specifies the encapsulation mode as reduced encapsulation mode.
insert: Specifies the encapsulation mode as insertion mode.
insert reduced: Specifies the encapsulation mode as reduced insertion mode.
disable: Disables the specified encapsulation mode.
When the device forwards a packet through an SRv6 TE policy, it must encapsulate that packet with the SID list of the SRv6 TE policy. Supported encapsulation modes include:
·     Encaps—Normal encapsulation mode. It adds a new IPv6 header and an SRH to the original packets. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH. The destination IPv6 address in the new IPv6 header is the first SID in the SID list of the SRv6 TE policy. The source IPv6 address is the IPv6 address specified by using the encapsulation source-address command.
·     Encaps.Red—Reduced mode of the normal encapsulation mode. It adds a new IPv6 header and an SRH to the original packets. The first SID in the SID list of the SRv6 TE policy is not encapsulated in the SRH to reduce the SRH length. All other SIDs in the SID list are encapsulated in the SRH. The destination IPv6 address in the new IPv6 header is the first SID in the SID list of the SRv6 TE policy. The source IPv6 address is the IPv6 address specified by using the encapsulation source-address command.
·     Insert—Insertion mode. It inserts an SRH after the original IPv6 header. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH. The destination IPv6 address in the original IPv6 header is changed to the first SID in the SID list of the SRv6 TE policy. The source IPv6 address in the original IPv6 header is not changed.
·     Insert.Red—Reduced insertion mode. It inserts an SRH after the original IPv6 header. The first SID in the SID list of the SRv6 TE policy is not encapsulated in the SRH to reduce the SRH length. All other SIDs in the SID list are encapsulated in the SRH. The destination IPv6 address in the original IPv6 header is changed to the first SID in the SID list of the SRv6 TE policy. The source IPv6 address in the original IPv6 header is not changed.
You can configure the encapsulation mode for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
The normal encapsulation modes are exclusive with the insertion modes. If you configure a normal encapsulation mode and an insertion mode for an SRv6 TE policy, the most recent configuration takes effect.
If you configure the Insert or Insert.Red mode for an SRv6 TE policy, it uses the Encaps mode to encapsulate received IPv4 packets.
If you execute both the encapsulation-mode encaps reduced command and the encapsulation-mode encaps include local-end.x command for an SRv6 TE policy, the encapsulation-mode encaps include local-end.x command takes effect.
If you execute both the encapsulation-mode insert reduced command and the encapsulation-mode insert include local-end.x command for an SRv6 TE policy, the encapsulation-mode insert include local-end.x command takes effect.
# Configure SRv6 TE policy 1 to use the Encaps.Red encapsulation.
[Sysname-srv6-te-policy-1] encapsulation-mode encaps reduced
srv6-policy encapsulation-mode
Use encapsulation-mode encaps include local-end.x to configure local End.X SID encapsulation in the SRH of the packets forwarded by an SRv6 TE policy with a normal encapsulation mode.
Use undo encapsulation-mode encaps include local-end.x to restore the default.
encapsulation-mode encaps include local-end.x [ disable ]
The local End.X SID encapsulation is not configured for an SRv6 TE policy with a normal encapsulation mode, and the local End.X SID encapsulation setting configured in SRv6 TE view applies.
SRv6 TE policy view
disable: Disables encapsulating the local End.X SID into the SRH header of packets forwarded by an SRv6 TE policy with a normal encapsulation mode. If you do not specify this keyword, the local End.X SID will be encapsulated into the SRH of the packets.
If traffic is steered to an SRv6 TE policy and the SRv6 SID of the ingress node is an End.X SID, the device does not encapsulate the End.X SID into the SRH by default.
To obtain complete SRv6 forwarding path information from the SRH of packets, use this command to configure the device to encapsulate the local End.X SID in the SRH.
You can configure the local End.X SID encapsulation for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
If you execute the encapsulation-mode encaps include local-end.x command and the encapsulation-mode insert include local-end.x command for an SRv6 TE policy, the most recent configuration takes effect.
In SRv6 TE policy view, if you execute both the encapsulation-mode encaps include local-end.x command and the encapsulation-mode encaps reduced command, the encapsulation-mode encaps include local-end.x command takes effect.
# Include the End.X SID in the SRH of the packets forwarded by an SRv6 TE policy with a normal encapsulation mode.
[Sysname-srv6-te-policy-1] encapsulation-mode encaps include local-end.x
srv6-policy encapsulation-mode encaps include local-end.x
Use encapsulation-mode insert include local-end.x to configure local End.X SID encapsulation in the SRH of the packets forwarded by an SRv6 TE policy with an insertion encapsulation mode.
Use undo encapsulation-mode insert include local-end.x to restore the default.
encapsulation-mode insert include local-end.x [ disable ]
The local End.X SID encapsulation is not configured for an SRv6 TE policy with an insertion encapsulation mode, and the local End.X SID encapsulation setting configured in SRv6 TE view applies.
SRv6 TE policy view
disable: Disables encapsulating the local End.X SID into the SRH header inserted into the packets forwarded by an SRv6 TE policy with an insertion encapsulation mode. If you do not specify this keyword, the local End.X SID will be encapsulated into the SRH of the packets.
If you execute the encapsulation-mode encaps include local-end.x command and the encapsulation-mode insert include local-end.x command alternately for an SRv6 TE policy, the most recent configuration takes effect.
In SRv6 TE policy view, if you execute both the encapsulation-mode insert include local-end.x command and the encapsulation-mode encaps reduced command, the encapsulation-mode insert include local-end.x command takes effect.
# Include the End.X SID in the SRH of the packets forwarded by an SRv6 TE policy with an insertion encapsulation mode.
[Sysname-srv6-te-policy-1] encapsulation-mode insert include local-end.x
srv6-policy encapsulation-mode insert include local-end.x
end-point
Use end-point to configure the endpoint IP address for the SRv6 TE policy group.
Use undo end-point to restore the default.
undo end-point ipv6
No endpoint address is configured for the SRv6 TE policy group.
ipv6 ipv6-address: Specifies the endpoint IPv6 address for the SRv6 TE policy group.
The SRv6 TE policies added to the SRv6 TE policy group must use the same endpoint IPv6 address as the SRv6 TE policy group.
# Configure the endpoint address as 100::2 for SRv6 TE policy group 10.
[Sysname-srv6-te-policy-group-10] end-point ipv6 100::2
exclude-any
Use exclude-any to configure the exclude-any affinity attribute rule and enter affinity attribute rule view, or enter the view of the existing affinity attribute rule.
Use undo exclude-any to delete the affinity attribute rule view and all configurations in the view.
exclude-any
undo exclude-any
No affinity attribute rules exist.
Affinity attribute view
With the exclude-any affinity attribute rule configured, an SRv6 TE policy does not use a link if it contains any of the specific affinity attributes.
# Configure the exclude-any affinity attribute rule and enter affinity attribute rule view.
[Sysname-srv6-te-policy-a1] candidate-paths
[Sysname-srv6-te-policy-a1-path] preference 200
[Sysname-srv6-te-policy-a1-path-pref-200] constraints
[Sysname-srv6-te-policy-a1-path-pref-200-const] affinity
[Sysname-srv6-te-policy-a1-path-pref-200-const-aff] exclude-any
[Sysname-srv6-te-policy-a1-path-pref-200-const-aff-exclude-any]
affinity (SRv6 TE policy constraints view)
Use explicit segment-list to specify a SID list for a candidate path.
Use undo explicit segment-list to delete a SID list of a candidate path or restore the default weight and global path MTU of a SID list.
explicit segment-list segment-list-name [ local-binding-sid ipv6 ipv6-address | local-path-segment ipv6 ipv6-address | local-xsid ipv6 ipv6-address | path-mtu mtu-value | reverse-binding-sid ipv6 ipv6-address | reverse-path-segment ipv6 reverse-ipv6-address | reverse-xsid ipv6 reverse-ipv6-address | segment-list-id segment-list-id | weight weight-value ] *
undo explicit segment-list segment-list-name [ local-binding-sid | local-path-segment | local-xsid | path-mtu | reverse-binding-sid | reverse-path-segment | reverse-xsid | segment-list-id | weight ] *
No SID lists are specified for an SRv6 TE policy candidate path.
segment-list-name: Specifies an SID list name, a case-sensitive string of 1 to 128 characters.
local-binding-sid ipv6 ipv6-address: Specifies a local BSID for BFD detection. If you do not specify this option, the local BSID configured for the SID list applies.
·     The specified BSID cannot be the same as the BSID configured with the local-binding-sid command for the SID list.
·     The BSID specified in this option takes precedence over the BSID configured with the local-binding-sid command for the SID list.
local-path-segment ipv6 ipv6-address: Specifies the local path segment (End.PSID) used for SBFD. Specify this option on the source node of an SRv6 TE policy tested by SBFD. The local path segment will be encapsulated into the SRH of the SBFD packets. If the reverse path segment of an SID list at the endpoint node matches the local path segment encapsulated in the SBFD packet, the forwarding path represented by that SID list can be used as the reverse path (return path) for the SBFD packet.
local-xsid ipv6 ipv6-address: Specifies the local End.XSID used for echo BFD (BFD in echo packet mode). If you enable echo BFD for an SRv6 TE policy on the source node, the source node will encapsulate the local End.XSID into the SRH of the BFD echo packet. If the endpoint node has a SID list whose reverse End.XSID matches the local End.XSID in the BFD echo packet, the endpoint node uses this SID list as the reverse path for the BFD echo packet.
path-mtu mtu-value: Specifies the path MTU (in bytes) for the SID list. The value range for the path MTU is 1280 to 9600.  If you do not specify this option, the global path MTU set in SRv6 view applies to the SID list.
reverse-binding-sid ipv6 ipv6-address: Specifies a reverse BSID for BFD or SBFD detection. If you do not specify this option, the reverse BSID configured for the SID list applies.
·     The specified BSID cannot be the same as the BSID configured with the reverse-binding-sid command for the SID list.
·     The BSID specified in this option takes precedence over the BSID configured with the reverse-binding-sid command for the SID list.
reverse-path-segment ipv6 reverse-ipv6-address: Specifies the reverse path segment (End.PSID) used for SBFD. Specify this option at the endpoint node of the SRv6 TE policy tested by SBFD. If the reverse path segment in an SID list at the endpoint node matches the local path segment encapsulated in the SRH of the SBFD packet at the source node, the forwarding path represented by that SID list can be used as the reverse path (return path) for the SBFD packet.
reverse-xsid ipv6 reverse-ipv6-address: Specifies the reverse End.XSID used for BFD. If you enable echo BFD for an SRv6 TE policy on the source node, the source node will encapsulate the local End.XSID into the SRH of the BFD echo packet. If the endpoint node has a SID list whose reverse End.XSID matches the local End.XSID in the BFD echo packet, the endpoint node uses this SID list as the reverse path for the BFD echo packet.
segment-list-id segment-list-id: Specifies an SID list by its ID, in the range of 1 to 4294967295.
weight weight-value: Specifies a weight for the SID list, in the range of 1 to 4294967295. The default weight is 1.
Operating mechanism
An SRv6 TE policy uses the SID list specified for the highest-preference candidate path as a traffic forwarding subpath.
An SRv6 TE policy candidate path can have multiple SID lists. All the SID lists can be used to forward traffic for load sharing based on their weights. Assume SID lists a, b, and c are assigned weights x, y, z, respectively. The load of SID list a is x/(x+y+z) of the total traffic.
If you assign weight values for the same SID list multiple times, the most recent configuration takes effect.
Restrictions and guidelines on path MTU
You can configure the path MTU for all SRv6 TE candidate paths globally in SRv6 view or for a specific forwarding path in SRv6 TE policy path preference view. The path-specific configuration takes precedence over the global configuration. A forwarding path identified by a SID list of an SRv6 TE policy uses the global configuration only when it has no path-specific configuration.
Before forwarding an SRv6 packet encapsulated with the SID list specified by this command, the device can use the MTU of that SID list to control the SRv6 packet size. This approach avoids packet loss caused by the fact that IPv6 packets do not support fragmentation. If this command specifies a path MTU for the SID list, the device takes the smaller value out of the path MTU of the SID list and the IPv6 MTU of the output interface. Then, the device uses the following formula to calculate the active MTU, which is used for real packet forwarding:
Active MTU = Smaller value - global reserved path MTU
Restrictions and guidelines on SID list ID
Before you execute the explicit segment-list command with the segment-list-id keyword specified, make sure each SID list associated with the same candidate path has a unique ID.
Restrictions and guidelines on BFD/SBFD return path
If both the reverse-binding-sid and local-xsid parameters are specified in this command, the effective reverse path is determined by the bfd echo command in SRv6 TE policy view or the srv6-policy bfd echo command in SRv6 TE view.
The local End.XSID specified with the local-xsid parameter must differ from the BSID configured with the local-binding-sid command.
If both the reverse-binding-sid and reverse-path-segment keywords are specified in this command, the effective reverse path is determined by the sbfd command in SRv6 TE policy view or the srv6-policy sbfd command in SRv6 TE view.
If an SID list has already specified a local path segment, that segment cannot be allocated to another SID list. The same SID list with the same local path segment cannot be configured in different candidate paths. Otherwise, the later configured local path segment will not take effect and will be displayed as a conflict in the display segment-routing ipv6 te path segment command output. For instance, if a candidate path with preference 100 in SRv6 TE policy p1 has SID list abc configured with the local path segment value 100::1 assigned to it, you cannot configure SID list abc with local path segment 100::1 for any candidate path of any SRv6 TE policy.
You can check the state of the reverse path segment (End.PSID) on the endpoint node by using the display segment-routing ipv6 local-sid command. If the state field shows active, it means the reverse path segment request was successful.
# Configure SID list abc for the SRv6 TE policy candidate path with preference 20, and the set the SID list weight to 20.
[Sysname-srv6-te-policy-a1-path-pref-20] explicit segment-list abc weight 20
bfd echo
path-mtu
sbfd
segment-list
srv6-policy sbfd
fast-reroute mirror delete-delay
Use fast-reroute mirror delete-delay to configure the mirror FRR deletion delay time.
Use undo fast-reroute mirror delete-delay to restore the default.
fast-reroute mirror delete-delay delete-delay-time
The mirror FRR deletion delay time is 60 seconds.
IS-IS IPv6 unicast address family view
OSPFv3 view
delete-delay-time: Specifies the deletion delay time, in the range of 1 to 21845 seconds.
In an egress protection scenario, the transit node deletes the mirror FRR path after completing route convergence. If the deletion occurs before the ingress node switches traffic back from the mirror FRR path, the traffic will be dropped because of no mirror FRR path.
To resolve this issue, you can configure a proper mirror FRR deletion delay time on the transit node to delay the deletion of the mirror FRR route. So, packets can be forwarded over the mirror FRR path before the ingress finishes the path switchover.
# In IS-IS process 1, set the mirror FRR deletion delay time to 100 seconds.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] fast-reroute mirror delete-delay 100
# In OSPFv3 process 1, set the mirror FRR deletion delay time to 100 seconds.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute mirror delete-delay 100
fast-reroute mirror enable
Use fast-reroute mirror enable to enable egress protection.
Use undo fast-reroute mirror enable to disable egress protection.
Egress protection is disabled.
OSPFv3 view
Operating mechanism
Egress protection enables an SRv6 node to compute a backup path (mirror FRR path) for the egress node based on the End.M SID carried in a received IPv6 IS-IS route or OSPFv3 route. When the egress node fails, the transit node can forward traffic to the node that protects the egress node according to the End.M SID.
To enable egress protection in a view on a transit node, you must also enable TI-LFA FRR in that view for the transit node to compute a backup path.
# Enable IS-IS egress protection.
[Sysname] isis 1
[Sysname-isis-1-ipv6] fast-reroute mirror enable
# Enable OSPFv3 egress protection.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute mirror enable
forwarding statistics
Use forwarding statistics to configure traffic forwarding statistics for an SRv6 TE policy.
Use undo forwarding statistics to restore the default.
forwarding statistics { disable | [ service-class ] enable }
An SRv6 TE policy uses the traffic forwarding statistics configuration in SRv6 TE view.
SRv6 TE policy view
disable: Disables the SRv6 TE policy forwarding statistics.
enable: Enables the SRv6 TE policy forwarding statistics.
service-class: Enables the SRv6 TE policy forwarding statistics by service class. This feature collects statistics on the total traffic as well as the traffic of each service class that are forwarded by the SRv6 TE policy tunnel. If you do not specify this keyword, the device only collects statistics on the total traffic forwarded by the SRv6 TE policy tunnel.
You can configure traffic forwarding statistics for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable traffic forwarding statistics for SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] forwarding statistics enable
display segment-routing ipv6 te forwarding
reset segment-routing ipv6 te forwarding statistics
srv6-policy forwarding statistic enable
srv6-policy forwarding statistic interval
Use forward-type to create a forward type and enter its view, or enter the view of an existing forward type.
Use undo forward-type to restore the default.
forward-type { apn-id | arn-id | dscp | service-class | te-class }
undo forward-type { apn-id | arn-id | dscp | service-class | te-class }
No forward type is created. Traffic cannot be steered to the SRv6 TE policy group automatically created by the ODN template.
apn-id: Sets the forward type to APN ID, which represents APN ID-based traffic steering.
arn-id: Sets the forward type to ARN ID, which represents ARN ID-based traffic steering.
dscp: Sets the forward type to DSCP, which represents DSCP-based traffic steering.
service-class: Sets the forward type to service class, which represents service class-based traffic steering.
te-class: Sets the forward type to TE class, which represents TE class ID-based traffic steering.
Use this command to specify the method for steering traffic in to the SRv6 TE policy group automatically created by the ODN template. SRv6 TE policy groups automatically created by an ODN template only support APN ID-, ARN ID-, TE class ID-, DSCP-, and service class-based traffic steering in the current software version.
When the forward type is DSCP, the device steers traffic by using the following procedure:
1.     Matches the DSCP value in a packet with the mappings configured by using the color match dscp and best-effort match dscp commands.
2.     Forwards the traffic based on the matching result.
¡     If the DSCP value matches a color-to-DSCP mapping configured by using the color match dscp command and the SRv6 TE policy assigned the color attribute value in the mapping is valid, the device uses that SRv6 TE policy to forward the packet.
¡     If the DSCP value matches a mapping configured by using the best-effort match dscp command, the device forwards the packet in SRv6 BE mode. In this mode, the device encapsulates a new IPv6 header to the packet and forwards the encapsulated packet based on the IPv6 routing table.
When the forward type is service class, the device steers traffic by using the following procedure:
3.     Matches the service class value in the traffic with the mappings configured by using the color match service-class and best-effort match service-class commands.
4.     Forwards the traffic based on the matching result.
¡     If the service class value matches a color-to-service class mapping, the device uses the SRv6 TE policy with the color attribute value mapped to the service class value to forward the traffic in case that the SRv6 TE policy is valid.
¡     If the service class value is found among the service class values specified in the best-effort match service-class command, the device forwards the traffic in SRv6 BE mode. In this mode, the device encapsulates a new IPv6 header to packets and performs an IPv6 routing table lookup to forward the encapsulated packets.
When the forward type is APN ID, the device steers traffic by using the following procedure:
5.     Matches the APN ID value in the traffic with the mappings configured by using the index apn-id match command.
6.     If a match is found and the forwarding policy (SRv6 TE policy or SRv6 BE) pointed by the matching mapping is valid, the device uses the forwarding policy for traffic forwarding.
7.     If no match is found, the device forwards the traffic according to the forwarding steps in the usage guidelines of the index apn-id match command.
When the forward type is TE class, the device steers traffic by using the following procedure:
8.     Matches the TE class ID in packets with the TE class ID and forwarding policy mappings configured in the SRv6 TE policy group.
9.     Forwards the packets based on the matching result.
¡     If the TE class ID is mapped to a color attribute value, the device steers the packets to the SRv6 TE policy with that color attribute value for forwarding.
¡     If the TE class ID is mapped to an IPR policy, the device steers the packets to the optimal SRv6 TE policy for forwarding according to the path selection policy defined in that IPR policy.
¡     If the TE class ID is mapped to SRv6 BE mode, the device forwards the packets in SRv6 BE mode. In this mode, the device encapsulates a new IPv6 header to the packets and looks up the IPv6 routing table to forward the packets.
10.     If the TE class ID of the packets is not mapped to any forwarding policy, the device forwards the packets according to the default forwarding policy configured by using the default match command.
On the source node of the SRv6 TE policy group, you can use the remark te-class command in a QoS policy to mark the TE class ID value for traffic that matches rules in the QoS policy. You can also use the remark service-class command in a QoS policy to mark the service class value for traffic that matches rules in the QoS policy.
When the forward type is ARN ID, the device steers traffic by using the following procedure:
11.     Matches the ARN ID value in the traffic with the mappings configured by using the index arn-id match command.
12.     If a match is found and the forwarding policy (SRv6 TE policy or SRv6 BE) pointed by the matching mapping is valid, the device uses the forwarding policy for traffic forwarding.
13.     If no match is found, the device forwards the traffic according to the forwarding steps in the usage guidelines of the index arn-id match command.
# Create the DSCP forward type and enter DSCP forward type view.
[Sysname-srv6-te-odn-group-1] forward-type dscp
[Sysname-srv6-te-odn-group-1-dscp]
# Specify the TE class forward type and enter TE class forward type view.
[Sysname-srv6-te-odn-group-1] forward-type te-class
[Sysname-srv6-te-odn-group-1-te-class]
# Specify the ARN ID forward type and enter ARN ID forward type view.
[Sysname-srv6-te-odn-group-1] forward-type arn-id
[Sysname-srv6-te-odn-group-1-arn-id]
best-effort match dscp (SRv6 TE ODN policy group view)
color match service-class (Service class forward type view)
index apn-id match
index arn-id match
remark arn-id (ACL and QoS Command Reference)
remark service-class (ACL and QoS Command Reference)
remark te-class (ACL and QoS Command Reference)
Use forward-type to configure the forward type for an SRv6 TE policy group.
forward-type { apn-id | arn-id | dot1p | service-class | te-class }
undo forward-type { apn-id | arn-id | dot1p | service-class | te-class }
DSCP-based traffic steering is used for packets that match an SRv6 TE policy group.
dot1p: Sets the forward type to Dot1p, which represents 802.1p-based traffic steering.
Use this command to specify the method for steering traffic in to a statically created SRv6 TE policy group. Statically created SRv6 TE policy groups only support DSCP-, TE class ID-, APN ID-, ARN ID-, 802.1p-, and service class-based traffic steering in the current software version.
On the source node of the SRv6 TE policy group, you can use the remark te-class command in a QoS policy to mark the TE class ID value for traffic that matches rules in the QoS policy. The TE class ID only holds local significance. You can also use the remark service-class command in a QoS policy to mark the service class value for traffic that matches rules in the QoS policy.
When the forward type is Dot1p, the device steers traffic by using the following procedure:
1.     Identifies the color attribute based on the 802.1p value of the packet.
2.     Locates an SRv6 TE policy in the SRv6 TE policy group based on the color attribute of the packet.
3.     Forwards the packet with the 802.1p value through the specified SRv6 TE policy.
4.     Matches the DSCP value in a packet with the mappings configured by using the color match dscp and best-effort match dscp commands.
5.     Forwards the traffic based on the matching result.
6.     Matches the service class value in the traffic with the mappings configured by using the color match service-class and best-effort match service-class commands.
7.     Forwards the traffic based on the matching result.
8.     Matches the APN ID value in the traffic with the mappings configured by using the index apn-id match command.
9.     If a match is found and the forwarding policy (SRv6 TE policy or SRv6 BE) pointed by the matching mapping is valid, the device uses the forwarding policy for traffic forwarding.
10.     If no match is found, the device forwards the traffic according to the forwarding steps in the usage guidelines of the index apn-id match command.
11.     Matches the TE class ID in packets with the TE class ID and forwarding policy mappings configured in the SRv6 TE policy group.
12.     Forwards the packets based on the matching result.
13.     If the TE class ID of the packets is not mapped to any forwarding policy, the device forwards the packets according to the default forwarding policy configured by using the default match command.
14.     Matches the ARN ID value in the traffic with the mappings configured by using the index arn-id match command.
15.     If a match is found and the forwarding policy (SRv6 TE policy or SRv6 BE) pointed by the matching mapping is valid, the device uses the forwarding policy for traffic forwarding.
16.     If no match is found, the device forwards the traffic according to the forwarding steps in the usage guidelines of the index arn-id match command.
# Specify APN ID-based traffic steering for SRv6 TE policy group 1.
[Sysname-srv6-te-policy-group-1] forward-type apn-id
# Specify TE class ID-based traffic steering for SRv6 TE policy group 1.
[Sysname-srv6-te-policy-group-1] forward-type te-class
# Specify ARN ID-based traffic steering for SRv6 TE policy group 1.
[Sysname-srv6-te-policy-group-1] forward-type arn-id
best-effort match dscp (SRv6 TE policy group view)
default match (ARN ID-based traffic steering)
index apn-id match
index arn-id match
forward { no-bypass | bypass }
Use forward no-bypass to enable the No-Bypass feature for an SRv6 TE policy.
Use forward bypass to enable the Bypass feature for an SRv6 TE policy.
Use undo forward { no-bypass | bypass } to restore the default.
forward { bypass | no-bypass }
undo forward { bypass | no-bypass }
The No-Bypass and Bypass features are not configured for an SRv6 TE policy. The configuration in SRv6 TE view applies.
SRv6 TE policy view
bypass: Enables the Bypass feature to forward packets steered to the SRv6 TE policy through the local protection path.
no-bypass: Enables the No-Bypass feature to prevent packets steered to the SRv6 TE policy from being forwarded through the local protection path (for example, the backup path calculated with SRv6 TE FRR or TI-LFA FRR).
Application scenarios
When a node or link on the primary candidate path of the SRv6 TE policy fails and a local protection path (for example, the backup path calculated with SRv6 TE FRR or TI-LFA FRR) is available for the upstream node of the failed node or link, traffic will be forwarded through the local protection path. In this situation, the traffic might skip the failed node.
If you do not want traffic to bypass certain special SIDs in the SID lists of the SRv6 TE policy, you can enable the No-Bypass feature for the SRv6 TE policy. This feature prevents traffic steered to the SRv6 TE policy from being forwarded through the local protection path. For example, in an SRv6 SFC service chain scenario that uses an SRv6 TE policy, some SIDs represent application service nodes such as firewalls. If you do not want traffic to bypass these SIDs through the local protection path, you can enable the No-Bypass feature for the SRv6 TE policy.
To allow traffic steered to an SRv6 TE policy to be forwarded through the local protection path when the No-Bypass feature is enabled globally for all SRv6 TE policies, you can enable the Bypass feature for that SRv6 TE policy. To globally enable the No-Bypass feature for all SRv6 TE policies, use the srv6-policy forward no-bypass command in SRv6 TE view. To enable the Bypass feature for an SRv6 TE policy, use the forward bypass command.
Operating mechanism
Two flags are defined in the Flags field of an SRH, which are the No-Bypass flag and the No-FRR flag. When both flag bits are set, none of the SIDs in the SRH can be bypassed.
If the Bypass feature is enabled on the source node of the SRv6 TE policy, both the No-Bypass and No-FRR flag bits are not set in the SRH encapsulated into data packets. That is, the values for both the flag bits are 0. If the No-Bypass feature is enabled on the source node of the SRv6 TE policy, both the No-Bypass and No-FRR flag bits are set in the SRH encapsulated into data packets. That is, the values for both the flag bits are 1.
·     You can configure the Bypass and No-Bypass features for SRv6 TE policies in both SRv6 TE view and SRv6 TE policy view. The configuration in SRv6 TE view applies to all SRv6 TE policies. The configuration in SRv6 TE policy view applies only to one SRv6 TE policy. For an SRv6 TE policy, the configuration in the view of that SRv6 TE policy takes precedence over that in SRv6 TE view. If the features are not configured in the view of that SRv6 TE policy, the configuration in SRv6 TE view applies to that SRv6 TE policy.
·     The Bypass and No-Bypass features of an SRv6 TE policy also take effect on BFD or SBFD packets of that SRv6 TE policy. For BFD or SBFD packets, the status of the Bypass and No-Bypass features is determined by the following commands in descending order:
a.     The forward { no-bypass | bypass } command in SRv6 TE policy view.
b.     The srv6-policy forward no-bypass command in SRv6 TE view.
c.     The bfd { no-bypass | bypass } command in SRv6 TE policy view.
d.     The srv6-policy bfd no-bypass command in SRv6 TE view.
·     In an SRv6 network slicing scenario, the Bypass or BFD Bypass feature in an SRv6 TE policy cannot take effect on BFD or SBFD packets of that SRv6 TE policy if NSIs are applied to the candidate paths of that SRv6 TE policy and BFD or SBFD is configured to detect the connectivity of that SRv6 TE policy. BFD or SBFD packets are forced to not be forwarded through the local protection path.
·     If one SRv6 TE policy is stitched to another SRv6 TE policy through a BSID, the SID list of the first SRv6 TE policy includes the BSID of the other SRv6 TE policy. In such a scenario, SRH will modify the No-Bypass and No-FRR flag bits on the source node (stitching node) of the second SRv6 TE policy. Only when the No-Bypass feature is enabled for the second SRv6 TE policy, these two flag bits will be set.
# Enable the No-Bypass feature for SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] forward no-bypass
group-color
Use group-color to configure the color value for an SRv6 TE policy group.
Use undo group-color to restore the default.
group-color color-value
undo group-color
The color value is not configured for an SRv6 TE policy group.
color-value: Specifies the color attribute value, in the range of 0 to 4294967295.
You can use the color value specified in this command to perform color-based traffic steering to the specified SRv6 TE policy group.
You can specify the same color value for an SRv6 TE policy group and an SRv6 TE policy in it. The color values do not affect each other.
# Configure the color value as 1 for the SRv6 TE policy group.
[Sysname-srv6-te-policy-group-1] group-color 1
ifit delay-measure
Use ifit delay-measure to configure iFIT delay and jitter measurement in an SRv6 TE policy.
Use undo ifit delay-measure to restore the default.
ifit delay-measure { disable | enable }
iFIT delay and jitter measurement is not configured for an SRv6 TE policy. The SRv6 TE policy uses the configuration in SRv6 TE view.
SRv6 TE policy view
disable: Disables iFIT delay and jitter measurement.
enable: Enable iFIT delay and jitter measurement.
For this command to take effect on an SRv6 TE policy, you must complete the following tasks:
·     On the source node of the SRv6 TE policy, enable iFIT, configure the iFIT device ID, set the iFIT operating mode to analyzer, and execute the service-type srv6-segment-list command.
·     On the egress node or transit nodes of the SRv6 TE policy, enable iFIT, set the iFIT operating mode to collector, and execute the service-type srv6-segment-list command.
In-situ Flow Information Telemetry (iFIT) is a type of in-situ flow OAM measurement technology. This technology measures the actual packet loss, delay, and jitter of services in the network by directly encapsulating the measurement interval, packet loss indicator, and delay indicator information in the iFIT option field of service packets. For more information about iFIT, see Network Management and Monitoring Configuration Guide.
When service packets are steered to an SRv6 TE policy group for forwarding and the SRv6 TE policy group uses TE class ID-based traffic forwarding, the device can select an SRv6 TE policy to forward the service packets with a specific TE class ID according to the path selection policy defined in an IPR policy.
When the iFIT delay and jitter measurement feature is enabled for the SRv6 TE policy, the device performs the following operations:
1.     Measures the delay and jitter of the SRv6 TE policy through iFIT.
2.     Compares the measured delay and jitter values with the delay and jitter thresholds defined in the IPR policy. The measured delay and jitter values of the SRv6 TE policy are used as conditions for optimal SRv6 TE policy selection. If the measured values cross the delay and jitter thresholds, it cannot be used as a traffic forwarding path.
Operating mechanism
After iFIT delay and jitter measurement is enabled on the source node of an SRv6 TE policy, the source node and egress node of the SRv6 TE policy will measure the end-to-end delay and jitter for packets forwarded through the SRv6 TE policy. The measurement procedure is as follows:
3.     The source node automatically creates an iFIT instance and assigns a flow ID to the iFIT instance.
4.     As the data sender, the source node encapsulates the original packets with the DOH header that carries the iFIT option field and the SRH header when it forwards the packets through the SRv6 TE policy. In addition, the source node records the timestamps when the packets are forwarded through the SRv6 TE policy within an iFIT measurement interval.
5.     As the data receiver, the egress node decodes the iFIT option field of the packets to obtain the iFIT measurement interval of the SRv6 TE policy, and records the timestamps when the packets are received through the SRv6 TE policy within the iFIT measurement interval.
6.     The egress node uses the source address of the received packets to establish a UDP session with the source node and returns the packet timestamps recorded within the iFIT measurement interval to the source node. The source address can be configured by using the encapsulation source-address command on the source node.
7.     The source node analyzes and calculates the delay and jitter for the packets forwarded through the SRv6 TE policy.
iFIT can measure the delay and jitter of an SRv6 TE policy only when data traffic is being forwarded through that SRv6 TE policy.
If both the ifit delay-measure command and the srv6-policy ifit delay-measure enable command in SRv6 TE view are used, the ifit delay-measure command takes effect.
If the egress node is not an H3C device, enable iFIT and set the iFIT operating mode to collector on the penultimate hop (an H3C device along the forwarding path). This H3C device will act as the data receiver, record timestamps, establish a UDP session, and provide the timestamps back to the source node to fulfill the functions of the egress node.
If multiple nodes feed back measurement data to the source node, the source node handles the data as follows:
·     If the egress node and multiple other nodes feed back measurement data to the source node, the source node prefers the data fed back from the egress node for calculating delay and jitter.
·     If multiple non-egress nodes feed back measurement data to the source node, the source node prefers the data fed back from the node closest to the egress node for calculating delay and jitter.
To ensure that iFIT measurement can correctly operate, make sure the clock on all devices participating in iFIT measurement has been synchronized. A violation causes the iFIT calculation results to be inaccurate. You can use NTP and PTP to synchronize clock between devices.
# Enable iFIT delay and jitter measurement in SRv6 TE policy 1.
[Sysname-srv6-te-policy-1]ifit delay-measure enable
ifit enable (Network Management and Monitoring Command Reference)
ifit interval
service-type srv6-segment-list (Network Management and Monitoring Command Reference)
srv6-policy ifit interval
work-mode analyzer (Network Management and Monitoring Command Reference)
work-mode collector (Network Management and Monitoring Command Reference)
ifit interval
Use ifit interval to set the iFIT measurement interval in an SRv6 TE policy.
Use undo ifit interval to restore the default.
ifit interval time-value
undo ifit interval
No iFIT measurement interval is set for an SRv6 TE policy. The SRv6 TE policy uses the configuration in SRv6 TE view.
SRv6 TE policy view
time-value: Specifies an iFIT measurement interval, in seconds. The value can be 1, 10, 30, 60, or 300.
Use this command only on the source node of an SRv6 TE policy.
After you set the iFIT measurement interval, the source node of the SRv6 TE policy incorporates the measurement interval into iFIT packets and uses this measurement interval to perform the following operations:
1.     Counts the number of packets forwarded through the SRv6 TE policy and the timestamps of the packets at measurement intervals.
2.     Calculates the delay, jitter, and packet loss rate of the SRv6 TE policy at measurement intervals.
The egress node of the SRv6 TE policy obtains the measurement interval from iFIT packets and uses this interval to perform the following operations:
3.     Counts the number of packets forwarded through the SRv6 TE policy and the timestamps of the packets at measurement intervals.
4.     Provides feedback on the count and timestamps of packets to the source node of the SRv6 TE policy at measurement intervals.
If you execute both this command and the srv6-policy ifit interval command in SRv6 TE view, this command has higher priority.
# Set the iFIT measurement interval to 60 seconds for SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] ifit interval 60
ifit delay-measure
ifit loss-measure
srv6-policy ifit loss-measure enable
ifit loss-measure
Use ifit loss-measure to configure iFIT packet loss measurement in an SRv6 TE policy.
Use undo ifit loss-measure to restore the default.
ifit loss-measure { disable | enable }
iFIT packet loss measurement is not configured in an SRv6 TE policy. The SRv6 TE policy uses the configuration in SRv6 TE view.
SRv6 TE policy view
disable: Disables iFIT packet loss measurement.
enable: Enables iFIT packet loss measurement.
In-situ Flow Information Telemetry (iFIT) is a type of in-situ flow OAM measurement technology. This technology measures the actual packet loss, delay, and jitter of services in the network by directly encapsulating the measurement interval, packet loss flag, and delay flag information in the iFIT option field of service packets. For more information about iFIT, see Network Management and Monitoring Configuration Guide.
When the iFIT packet loss measurement feature is enabled for the SRv6 TE policy, the device performs the following operations:
1.     Measures the packet loss rate of the SRv6 TE policy through iFIT.
2.     Compares the measured packet loss rate with the packet loss rate threshold defined in the IPR policy. The measured packet loss rate of the SRv6 TE policy is used as a condition for optimal SRv6 TE policy selection. If the measured value crosses the packet loss rate threshold, it cannot be used as a traffic forwarding path.
Operating mechanism
After iFIT packet loss measurement is enabled on the source node of an SRv6 TE policy, the source node and egress node of the SRv6 TE policy will measure the end-to-end packet loss rate for packets forwarded through the SRv6 TE policy. The measurement procedure is as follows:
4.     As the data sender, the source node encapsulates the original packets with the DOH header that carries the iFIT option field and the SRH header when it forwards the packets through the SRv6 TE policy. In addition, the source node counts the number of packets forwarded through the SRv6 TE policy within an iFIT measurement interval.
5.     As the data receiver, the egress node decodes the iFIT option field of the packets to obtain the iFIT measurement interval of the SRv6 TE policy, and counts the number of packets received through the SRv6 TE policy within the iFIT measurement interval.
6.     The egress node uses the source address of the received packets to establish a UDP session with the source node and returns the packet count statistics within the iFIT measurement interval to the source node. The source address can be configured by using the encapsulation source-address command on the source node.
7.     The source node analyzes and calculates the packet loss rate for the packets forwarded through the SRv6 TE policy.
iFIT can measure the packet loss rate of an SRv6 TE policy only when data traffic is being forwarded through that SRv6 TE policy.
If both the ifit loss-measure command and the srv6-policy ifit loss-measure enable command in SRv6 TE view are used, the ifit loss-measure command takes effect.
If the egress node is not an H3C device, enable iFIT and set the iFIT operating mode to collector on the penultimate hop (an H3C device along the forwarding path). This H3C device will act as the data receiver to collect packet statistics, establish a UDP session with the source node, and provide the packet statistics back to the source node to fulfill the functions of the egress node.
·     If the egress node and multiple other nodes feed back measurement data to the source node, the source node prefers the data fed back from the egress node for calculating packet loss rate.
·     If multiple non-egress nodes feed back measurement data to the source node, the source node prefers the data fed back from the node closest to the egress node for calculating packet loss rate.
# Enable iFIT packet loss measurement in SRv6 TE policy aaa.
[Sysname-srv6-te] policy aaa
[Sysname-srv6-te-policy-aaa] ifit loss-measure enable
ifit interval
ifit measure mode
Use ifit measure mode to specify an iFIT measurement mode for an SRv6 TE policy.
Use undo ifit measure mode to restore the default.
ifit measure mode { e2e | trace }
No iFIT measurement mode is specified for an SRv6 TE policy. The SRv6 TE policy uses the configuration in SRv6 TE view.
SRv6 TE policy view
e2e: Specifies the end-to-end mode. In this mode, only the egress node of the SRv6 TE policy feeds back iFIT measurement results to the source node for calculating the network quality of the SRv6 TE policy.
trace: Specifies the hop-by-hop mode. In this mode, a node along the forwarding path of a target flow feeds back measurement results to the source node of the SRv6 TE policy for calculating the network quality of the SRv6 TE policy as long as iFIT is enabled and iFIT packets are detected on that node.
Recommended configuration
·     If the egress node of an SRv6 TE policy is not an H3C device, you must set the iFIT measurement mode to hop-by-hop mode. In this case, enable iFIT and set the iFIT operating mode to collector on the penultimate hop (an H3C device along the forwarding path). This H3C device will act as the data receiver to collect packet statistics, establish a UDP session with the source node, and provide the packet statistics back to the source node to fulfill the functions of the egress node. Typically, hop-by-hop mode is applicable to scenarios where the egress node of an SRv6 TE policy is not an H3C device.
·     If both the source and egress nodes of an SRv6 TE policy are H3C devices, set the iFIT measurement mode to end-to-end mode as a best practice. In this mode, the egress node feeds back the iFIT measurement results to the source node of the SRv6 TE policy for calculating the network quality of the SRv6 TE policy. Even if the transit nodes along the forwarding path of a target flow have enabled iFIT and detected iFIT packets, they will not feed back the iFIT measurement results to the source node of the SRv6 TE policy. This mechanism reduces the complexity of device processing.
Operating mechanism
After you specify an iFIT measurement mode for an SRv6 TE policy, the source node of the SRv6 TE policy includes the iFIT measurement mode in the iFIT option field of packets. The packets notify the devices along the forwarding path of the iFIT measurement mode during the forwarding process.
When the iFIT measurement mode of an SRv6 TE policy is set to end-to-end mode, only the egress node that has enabled iFIT and detected iFIT packets feeds back measurement data to the source node through a UDP session. Transit nodes do not feed back measurement data to the source node.
When the iFIT measurement mode of an SRv6 TE policy is set to hop-by-hop mode, all nodes along the forward path of a target flow that have enabled iFIT and detected iFIT packets feed back measurement data to the source node through UDP sessions. The source node selects measurement data for calculating network quality. If multiple non-egress nodes feed back data to the source node, the source node prefers the data fed back from the node closest to the egress node of the SRv6 TE policy for calculating network quality.
If both the ifit measure mode command in SRv6 TE policy view and the srv6-policy ifit measure mode command in SRv6 TE view, the ifit measure mode command in SRv6 TE policy view takes effect.
# Set the iFIT measurement mode to hop-by-hop mode for SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] measure mode trace
import-route sr-policy
Use import-route sr-policy to enable BGP to redistribute routes from the SRv6 TE policy.
Use undo import-route sr-policy to restore the default.
BGP does not redistribute IPv6 SR policy routes.
BGP IPv6 SR policy address family
After you execute this command, the system will redistribute the local IPv6 SR policy routes to the BGP routing table and advertise the routes to IBGP peers. Then, the peers can forward traffic based on the SRv6 TE policy.
# In BGP IPv6 SR policy address family view, enable BGP to redistribute routes from the SRv6 TE policy.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] import-route sr-policy
include-all
Use include-all to configure the include-all affinity attribute rule and enter affinity attribute rule view, or enter the view of the existing affinity attribute rule.
Use undo include-all to delete the affinity attribute rule view and all configurations in the view.
include-all
undo include-all
With the include-all affinity attribute rule configured, an SRv6 TE policy uses a link only if it contains all of the specific affinity attributes.
# Configure the include-all affinity attribute rule and enter affinity attribute rule view.
[Sysname-srv6-te-policy-a1-path-pref-200-const-aff] include-all
[Sysname-srv6-te-policy-a1-path-pref-200-const-aff-include-all]
affinity (constraints view)
include-any
Use include-any to configure the include-any affinity attribute rule and enter affinity attribute rule view, or enter the view of the existing affinity attribute rule.
Use undo include-any to delete the affinity attribute rule view and all configurations in the view.
include-any
undo include-any
With the include-any affinity attribute rule configured, an SRv6 TE policy uses a link only if it contains any of the specific affinity attributes.
# Configure the include-any affinity attribute rule and enter affinity attribute rule view.
[Sysname-segment-routing] traffic-engineering
[Sysname-sr-te] policy a1
[Sysname-sr-te-policy-a1] candidate-paths
[Sysname-sr-te-policy-a1-path] preference 200
[Sysname-sr-te-policy-a1-path-pref-200] constraints
[Sysname-sr-te-policy-a1-path-pref-200-const] affinity
[Sysname-sr-te-policy-a1-path-pref-200-const-aff] include-any
[Sysname-sr-te-policy-a1-path-pref-200-const-aff-rule]
index
Use index to add a node to a SID list.
Use undo index to delete a node from a SID list.
index index-number ipv6 ipv6-address [ verification ]
index index-number coc32 ipv6 ipv6-address common-prefix-length [ verification ]
index index-number compress-16 ipv6 ipv6-address block block-length node-length node-length function-length function-length [ compress-flavor { coc | coc-next | next } ] [ verification ]
undo index index-number
No nodes exist in a SID list.
SID list view
index-number: Specifies the node index, in the range of 1 to 65535.
ipv6 ipv6-address: Specifies the IPv6 address of the node. For a 16-bit G-SID, the IPv6 node address is concatenated based on the node-length and function-length arguments in the command. For example, the 128-bit compressible SID of the node is 1:2:3:4:5:6::. If the values for the block-length, node-length and function-length arguments are 64, 0, and 16, respectively, the value for the ipv6-address argument should be 1:2:3:4:6::, excluding the Node ID portion. If the value for the function-length argument is 0, the value for the ipv6-address argument should be 1:2:3:4:5::, excluding the Function portion.
coc32: Adds the COC flavor. Upon packet encapsulation, this flavor indicates that the next SID is a 32-bit G-SID.
common-prefix-length: Specifies the length of the common prefix of the next G-SID. The value range for this argument is 1 to 94.
verification: Enables SID validity verification. A SID is valid if the SID exists in the topology and the associated locator network route is routable. If you do not specify this keyword, path verification does not verify the validity of the SID. Do not specify this keyword for the BSID or a SID not in the local AS. If you do so, path verification will determine that the segment list has failed, affecting packet forwarding.
compress-16: Specifies 16-bit compression as the G-SRv6 packet encapsulation mode.
block block-length: Specifies the length of the Block portion (also called the common prefix length) in the 16-bit G-SID. The value range for the block-length argument is 16 to 88.
node-length node-length: Specifies the length of the Node ID portion in the 16-bit G-SID. The value for the node-length argument is 0 or 16. The sum of the node-length and function-length arguments must be 16.
function-length function-length: Specifies the length of the compressed Function portion in the 16-bit G-SID. The value for the function-length argument is 0 or 16. The sum of the node-length and function-length arguments must be 16.
compress-flavor: Specifies a compression-related flavor for the SID. If you do not specify this keyword, the SID does not carry the COC or NEXT flavor.
coc: Specifies the COC flavor for the SID. Upon packet encapsulation, this flavor indicates that the next SID is a 16-bit G-SID.
coc-next: Specifies the COC and NEXT flavors for the SID. Upon packet encapsulation, this flavor indicates that the current SID is a 16-bit G-SID and the next SID is a 16-bit G-SID.
next: Specifies the NEXT flavor for the SID. Upon packet encapsulation, this flavor indicates that the current SID is a 16-bit G-SID.
This command is used to control the SRv6 packet encapsulation format for SRv6 packet forwarding on the source node of an SRv6 TE policy.
To encapsulate a 32-bit G-SID into SRv6 packets in 32-bit compression scenarios, specify the coc32 keyword.
To encapsulate a 16-bit G-SID into SRv6 packets in 16-bit compression scenarios, specify the compress-16 keyword.
When you add a G-SID to the SID list, the common prefix length configured by this command must be the same as that of the locator where the next node belongs.
When you add a 32-bit G-SID to the SID list, make sure the following requirements are met:
·     The SRv6 SID previous to the G-SID is an End(COC32) SID or End.X(COC32) SID.
·     The last SRv6 SID in the SID list does not carry the COC flavor.
If multiple SRv6 TE policies have a common path, you can configure the common path as an SRv6 TE policy. When you configure the SRv6 TE policies, you can add the BSID of the common SRv6 TE policy to the SID lists of the SRv6 TE policies. In this way, you recurse the SRv6 TE policies to the common SRv6 TE policy, simplifying the SID list configuration.
If the first SID in the SID list of an SRv6 TE policy is a BSID, note the following restrictions and guidelines:
·     Nested SRv6 TE policy recursions are not supported, that is, the first SID in the SID list of the recursion SRv6 TE policy (the SRv6 TE policy with that BSID) cannot be a BSID.
·     The first SID cannot be the BSID of this SRv6 TE policy itself.
·     Do not configure path connectivity verification for this SRv6 TE policy.
·     The BSID cannot be configured as a local BSID or a reverse BSID.
·     The traffic statistics, BFD, and SBFD features of this SRv6 TE policy are not affected by the status of those features for the recursion SRv6 TE policy.
·     The BFD/SBFD detection time of this SRv6 TE policy cannot be shorter than that of the recursion SRv6 TE policy.
·     The path MTU of this SRv6 TE policy cannot be smaller than that of the recursion SRv6 TE policy.
After path connectivity verification is enabled for an SRv6 TE policy, the device verifies the validity of all SIDs in the SID list. If the SID list contains an inter-AS SID (for example, the BGP Peer SID allocated by BGP EPE) or contains the BSID of another SRv6 TE policy, the path connectivity verification will fail. This is because a BSID or BGP Peer SID cannot be flooded in the IGP topology.
To resolve this issue, you can execute the following commands to configure the path connectivity verification only verifies the validity of specific SIDs:
·     Use the index command to specify the verification keyword for the SIDs to be verified. Do not specify this keyword for a BSID or BGP EPE SID in the SID list.
·     Specify the specified-sid keyword when you execute the path verification command in SRv6 TE policy view or the srv6-policy path verification enable command in SRv6 TE view.
G-SID container is a 128-bit address space used by 16-bit or 32-bit G-SIDs. Both destination addresses in IPv6 packets and SIDs in SRHs can act as containers to carry G-SIDs.
You can use this command to specify the COC flavor for the last SID in the SID list. Support for this operation depends on whether the SID following the SID list in the SRH extension header is compressible. For example, in an L3VPN over SRv6 TE Policy scenario, if the SID following the SID list in the SRH extension header is a compressible End.DT4 SID, you can use this command to specify the COC flavor for the last SID in the SID list.
The coc, coc-next, and next keywords significantly impacts the encapsulation format of G-SRv6 packets. G-SRv6 packet encapsulation is performed under the following rules:
1.     Encapsulation rule 1—If the first SID in the SID list is specified with the coc-next or next keyword, the SID is a 16-bit G-SID. The 128-bit destination address in the IPv6 packet header will be used as the first container. The Block portion to which the G-SID belongs will be encapsulated into the highest bits of the container, followed by the G-SID.
2.     Encapsulation rule 2—If the first SID in the SID list is specified with the coc keyword, the SID is a 128-bit SID, completely occupying a container. The container will be encapsulated in the SID list of the SRH. The next SID is a 16-bit G-SID and will be encapsulated in the lowest 16 bits of a new container that does not carry the Block portion.
3.     Encapsulation rule 3—In the container carrying the Block portion, if consecutive G-SIDs from the first G-SID are specified with the coc-next or next keyword, those SIDs are all 16-bit G-SIDs. They are encapsulated into the current container from left to right according to the index-number order until one of the following conditions is met:
¡     The container does not have sufficient space for G-SID encapsulation.
¡     The last SID in the container is not a 16-bit G-SID.
¡     The next SID has a different common prefix.
In this situation, the next SID will be encapsulated into a new container.
4.     Encapsulation rule 4The first SID in the new container is a 16-bit G-SID under the following conditions:
¡     The SID is specified with the coc-next or next keyword.
¡     The last SID in the previous container is not specified with the coc-next or coc keyword.
In this situation, the Block portion to which the G-SID belongs will be encapsulated into the highest bits of the container, followed by the G-SID.
5.     Encapsulation rule 5—If the last SID in the previous container is specified with the coc-next or coc keyword, the SID is a 16-bit G-SID, inheriting the common prefix from the previous container. The G-SID will be encapsulated into the lowest bits of a new container, which does not carry a Block portion. In this container, if consecutive SIDs from the first SID are specified with the coc-next or coc keyword, those SIDs are all 16-bit G-SIDs. They are encapsulated into the container from right to left according to the index-number order until one of the following conditions is met:
¡     A G-SID in the container is not specified with the coc-next or coc keyword.
Based on the previous encapsulation rules for 16-bit G-SIDs, the following encapsulation and configuration schemes are recommended:
·     Scheme 1: 16-bit G-SRv6 encapsulation with a combination of the NEXT and COC flavors. G-SIDs encapsulated into G-SRv6 packets can carry both the COC and NEXT flavors. During packet forwarding, the device can take the move or replace action accordingly.
Figure 1 Packet encapsulation with scheme 1
Scheme 1 achieves the highest compression efficiency. If the forwarding path only contains a few of nodes, all G-SIDs can be encapsulated into the container provided by the destination address of IPv6 packets. G-SID encapsulation into SRH is not required.
·     Scheme 2: 16-bit G-SRv6 encapsulation with only the NEXT flavor. G-SIDs encapsulated into G-SRv6 packets carry only the NEXT flavor. During packet forwarding, the device can take the move action accordingly.
Figure 2 Packet encapsulation with scheme 2
Scheme 2 is similar to scheme 1. If the forwarding path only contains a few of nodes, all G-SIDs can be encapsulated into the container provided by the destination address of IPv6 packets. G-SID encapsulation into SRH is not required. Compared with scheme 1, the last G-SID of each container in scheme 2 is not specified with the coc-next or coc keyword. Therefore, each container must be encapsulated with the G-SID common prefix carried in the Block portion. In addition, G-SIDs are encapsulated into the container carrying the Block portion, from left to right. This encapsulation method allows continuous common prefix changes at the sacrifice of compression efficiency.
·     Scheme 3: 16-bit G-SRv6 encapsulation with only the COC flavor. G-SIDs encapsulated into G-SRv6 packets carry only the COC flavor. During packet forwarding, the device can take the replace action accordingly.
Figure 3 Packet encapsulation with scheme 3
Scheme 3 is similar to the 32-bit compression scheme. The first SID must carry and only carry the COC flavor. This SID is encapsulated into the SID list of the SRH. The 128-bit address space provided by the IPv6 destination address cannot be used as a container for direct encapsulation of G-SIDs. Therefore, scheme 3 has the lowest compression efficiency.
If the value for the node-length argument is 0 and the verification keyword is specified, SID validity verification is not available for a 16-bit G-SID. In this situation, the SRv6 SID is always determined valid and reachable regardless of whether it is reachable.
# Add a node to SID list abc, and set the node index to 1 and IPv6 address to 1000::1.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] segment-list abc
[Sysname-srv6-te-sl-abc] index 1 ipv6 1000::1
# In a 32-bit G-SRv6 encapsulation scenario, add nodes to SID list text as follows:
·     Add a node whose index is 10, IPv6 address is 100::1, next node as 32-bit G-SID, and the common prefix length of the G-SID is 64.
·     Add a node whose index is 20, IPv6 address is 200::1:0:0, next node as 32-bit G-SID, and the common prefix length of the G-SID is 64.
·     Add a node whose index is 30, IPv6 address is 200::2:0:0, next node as 32-bit G-SID, and the common prefix length of the G-SID is 64.
·     Add a node whose index is 40, IPv6 address is 200::3:0:0, next node as 32-bit G-SID, and the common prefix length of the G-SID is 64.
·     Add a node whose index is 50 and IPv6 address is 200::4:0:0.
·     Add a node whose index is 60 and IPv6 address is 300::3.
[Sysname-srv6-te] segment-list text
[Sysname-srv6-te-sl-abc] index 10 coc32 ipv6 100::1 64
[Sysname-srv6-te-sl-abc] index 20 coc32 ipv6 200::1:0:0 64
[Sysname-srv6-te-sl-abc] index 30 coc32 ipv6 200::2:0:0 64
[Sysname-srv6-te-sl-abc] index 40 coc32 ipv6 200::3:0:0 64
[Sysname-srv6-te-sl-abc] index 50 ipv6 200::4:0:0
[Sysname-srv6-te-sl-abc] index 60 ipv6 300::3
# In a scenario where 16-bit G-SRv6 encapsulation scheme 1 is used, add nodes to SID list text as follows:
·     Add a node whose index is 1, IPv6 address is 100:A:B:1::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC&NEXT, respectively.
·     Add a node whose index is index is 2, IPv6 address is 100:A:B:2::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC&NEXT, respectively.
·     Add a node whose index is 3, IPv6 address is 100:A:B:3::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC&NEXT, respectively.
·     Add a node whose index is 4, IPv6 address is 100:A:B:4::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC&NEXT, respectively.
·     Add a node whose index is 5, IPv6 address is 100:A:B:5::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC&NEXT, respectively.
·     Add a node whose index is 6, IPv6 address is 100:A:B:6::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC&NEXT, respectively.
·     Add a node whose index is 7, IPv6 address is 100:A:B:7::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and NEXT, respectively.
The first five G-SIDs are encapculated into the IPv6 destination address container and the last two G-SIDs are encapculated into the first container of the SID list.
[Sysname-srv6-te-sl-text] index 1 compress-16 ipv6 100:A:B:1:: block 48 node-length 16 function-length 0 compress-flavor coc-next
[Sysname-srv6-te-sl-text] index 2 compress-16 ipv6 100:A:B:2:: block 48 node-length 16 function-length 0 compress-flavor coc-next
[Sysname-srv6-te-sl-text] index 3 compress-16 ipv6 100:A:B:3:: block 48 node-length 16 function-length 0 compress-flavor coc-next
[Sysname-srv6-te-sl-text] index 4 compress-16 ipv6 100:A:B:4:: block 48 node-length 16 function-length 0 compress-flavor coc-next
[Sysname-srv6-te-sl-text] index 5 compress-16 ipv6 100:A:B:5:: block 48 node-length 16 function-length 0 compress-flavor coc-next
[Sysname-srv6-te-sl-text] index 6 compress-16 ipv6 100:A:B:6:: block 48 node-length 16 function-length 0 compress-flavor coc-next
[Sysname-srv6-te-sl-text] index 7 compress-16 ipv6 100:A:B:7:: block 48 node-length 16 function-length 0 compress-flavor next
# In a scenario where 16-bit G-SRv6 encapsulation scheme 2 is used, add nodes to SID list text as follows:
·     Add a node whose index is 1, IPv6 address is 100:A:B:1::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and NEXT, respectively.
·     Add a node whose index is index is 2, IPv6 address is 100:A:B:2::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and NEXT, respectively.
·     Add a node whose index is 3, IPv6 address is 100:A:B:3::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and NEXT, respectively.
·     Add a node whose index is 4, IPv6 address is 100:B:B:4::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and NEXT, respectively.
·     Add a node whose index is 5, IPv6 address is 100:B:B:4:100::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 0, 16, and NEXT, respectively. Ignore the Node ID portion and retain only the Function portion during configuration.
·     Add a node whose index is 6, IPv6 address is 100:B:B:5::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and NEXT, respectively.
·     Add a node whose index is 7, IPv6 address is 100:B:B:5:100::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 0, 16, and NEXT, respectively. Ignore the Node ID portion and retain only the Function portion during configuration.
The first three G-SIDs are encapculated into the IPv6 destination address container and the last four G-SIDs are encapculated into the first container of the SID list.
[Sysname-srv6-te-sl-text] index 1 compress-16 ipv6 100:A:B:1:: block 48 node-length 16 function-length 0 compress-flavor next
[Sysname-srv6-te-sl-text] index 2 compress-16 ipv6 100:A:B:2:: block 48 node-length 16 function-length 0 compress-flavor next
[Sysname-srv6-te-sl-text] index 3 compress-16 ipv6 100:A:B:3:: block 48 node-length 16 function-length 0 compress-flavor next
[Sysname-srv6-te-sl-text] index 4 compress-16 ipv6 100:B:B:4:: block 48 node-length 16 function-length 0 compress-flavor coc-next
[Sysname-srv6-te-sl-text] index 5 compress-16 ipv6 100:B:B:100:: block 48 node-length 0 function-length 16 compress-flavor coc-next
[Sysname-srv6-te-sl-text] index 6 compress-16 ipv6 100:B:B:5:: block 48 node-length 16 function-length 0 compress-flavor coc-next
[Sysname-srv6-te-sl-text] index 7 compress-16 ipv6 100:B:B:100:: block 48 node-length 0 function-length 16 compress-flavor next
# In a scenario where 16-bit G-SRv6 encapsulation scheme 3 is used, add nodes to SID list text as follows:
·     Add a node whose index is 1, IPv6 address is 100:A:B:1::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC, respectively.
·     Add a node whose index is index is 2, IPv6 address is 100:A:B:2::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC, respectively.
·     Add a node whose index is 3, IPv6 address is 100:A:B:3::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC, respectively.
·     Add a node whose index is 4, IPv6 address is 100:A:B:4::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC, respectively.
·     Add a node whose index is 5, IPv6 address is 100:A:B:4:100::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 0, 16, and COC, respectively. Ignore the Node ID portion and retain only the Function portion during configuration.
·     Add a node whose index is 6, IPv6 address is 100:A:B:5::, and next node is 16-bit G-SID. The Block length, Node ID length, compressed Function length, and flavor of the G-SID is 48, 16, 0, and COC, respectively.
·     Add a node whose index is 7, IPv6 address is 100:A:B:5:100::, and next node is 16-bit G-SID. The Block length, Node ID length, and compressed Function length of the G-SID is 48, 0, and 16, respectively. The G-SID does not carry the COC or NEXT flavor. Ignore the Node ID portion and retain only the Function portion during configuration.
The first SID is a 128-bit SID carrying the COC flavor, and is encapculated into the first container of the SID list. The following six G-SIDs are encapculated into the second container of the SID list.
[Sysname-srv6-te-sl-text] index 5 compress-16 ipv6 100:A:B:100:: block 48 node-length 0 function-length 16 compress-flavor coc
[Sysname-srv6-te-sl-text] index 6 compress-16 ipv6 100:A:B:5:: block 48 node-length 16 function-length 0 compress-flavor coc
[Sysname-srv6-te-sl-text] index 7 compress-16 ipv6 100:A:B:100:: block 48 node-length 0 function-length 16
locator
path verification
srv6 compress enable
index apn-id match
Use index apn-id match to configure a mapping between an APN ID and a forwarding policy.
Use undo index to delete the mapping between an APN ID and a forwarding policy.
index index-value apn-id instance instance-name match { best-effort | srv6-policy color color-value }
undo index index-value
No mapping is configured between an APN ID and a forwarding policy.
APN ID forward type view
index-value: Specifies an index for the mapping, in the range of 1 to 4294967294.
instance instance-name: Specifies an APN ID instance by its name, a case-sensitive string of 1 to 31 characters.
best-effort: Forwards traffic identified by the specified APN ID in SRv6 BE mode.
srv6-policy color color-value: Specifies a color attribute value. If you specify a color attribute value, the device will forward traffic identified by the specified APN ID through the SRv6 TE policy associated with the specified color attribute value. The value range for the color-value argument is 0 to 4294967295.
This command can take effect only when the forward type of the SRv6 TE policy group is APN ID. To specify the forward type, you can use the forward-type apn-id command in SRv6 TE policy group view or SRv6 TE ODN policy group view.
Once service traffic is steered to an SRv6 TE policy group for forwarding, the device matches the APN ID value in IPv6 packets with the APN ID mappings in the SRv6 TE policy group. If a matching mapping is found, the device forwards the traffic through the SRv6 TE policy associated with the color attribute value in the mapping or forwards the traffic in SRv6 BE mode.
Operating mechanism
In SRv6 BE mode, the device encapsulates packets with a new IPv6 header. The destination address in the new IPv6 header is the VPN SID that the egress node of the SRv6 TE policy group assigned to public- or private-network routes. Then, the device looks up for IPv6 routes to forward the encapsulated packets.
After the traffic is directed to an SRv6 TE policy group, when the device receives a packet that does not carry an APN ID, whose APN ID does not match any APN ID mapping, or whose APN ID matches an invalid SRv6 TE policy or matches the SRv6 BE mode that is invalid, it forwards the packet as follows:
1.     If the default match command is used to specify a default SRv6 TE policy and the specified default SRv6 TE policy is valid, the device uses the default SRv6 TE policy to forward the packet.
If the default match command is used to enable SRv6 BE-mode packet forwarding and the SRv6 BE mode is valid, the device forwards the packet in SRv6 BE mode.
2.     If the default match command is not executed, or the forwarding policy configured by using the default match command is invalid, the device handles the packet according to the configuration of the drop-upon-mismatch enable command.
¡     If the drop-upon-mismatch enable command is used, the device discards the packet.
¡     If the drop-upon-mismatch enable command is not used, the device searches for the APN ID-to-forwarding policy mapping with the smallest index value and a valid forwarding policy. The device will use the SRv6 TE policy pointed by the mapping to forward the packet or forward the packet in SRv6 BE mode.
An APN ID can establish a mapping relationship with an SRv6 TE policy only when that SRv6 TE policy is valid. Only when the mapping relationship is established, traffic that carries the APN ID can be forwarded through that SRv6 TE policy.
An APN ID can establish a mapping relationship with the SRv6 BE mode only when the SRv6 BE mode is valid. The SRv6 BE mode is valid only if the IPv6 routing table on the device contains a route destined for the VPN SID that the egress node of the SRv6 TE policy group assigned to public- or private-network routes. Only when the mapping relationship is established, traffic that carries the APN ID can be forwarded in SRv6 BE mode.
For an SRv6 TE policy group, an APN ID value can be mapped only to the SRv6 BE mode or to one SRv6 TE policy associated with a color attribute value.
If you execute the index apn-id match command multiple times for the same APN ID, only the most recent configuration can take effect.
If you execute the index apn-id match command multiple times for the same index value, only the most recent configuration can take effect.
You can execute the index apn-id match command multiple times in an SRv6 TE policy group to map multiple APN ID instance names to the same forwarding policy. If those APN ID instance names all correspond to the same APN ID, the forwarding policy forwards packets by using the path corresponding to the mapping with the smallest index.
If one of the following conditions exists, an SRv6 TE policy group will not be used for traffic forwarding:
·     All SRv6 TE policies in the SRv6 TE policy group are invalid.
·     The SRv6 TE policy group is enabled with SRv6 BE-based traffic forwarding, and no SRv6 TE policy is specified for traffic forwarding.
# Map APN ID instance aaa and color attribute value 20 in an SRv6 TE policy group. Packets from APN ID instance aaa will be steered to the SRv6 TE policy associated with color attribute value 20 for forwarding.
[Sysname-srv6-te] policy-group 10
[Sysname-srv6-te-policy-group-10] forward-type apn-id
[Sysname-srv6-te-policy-group-10] index 10 apn-id instance aaa match srv6-policy color 20
# Map APN ID instance aaa and color attribute value 20 in an SRv6 TE policy group ODN template. Packets from APN ID instance aaa will be steered to the SRv6 TE policy associated with color attribute value 20 for forwarding.
[Sysname-srv6-te] on-demand-group color 1
[Sysname-srv6-te-odn-group-1] forward-type apn-id
[Sysname-srv6-te-odn-group-1-apn-id] index 10 apn-id instance aaa match srv6-policy color 20
default match
forward-type (SRv6 TE policy group view)
forward-type (SRv6 TE ODN policy group view)
index arn-id match
Use index arn-id match to configure a mapping between an ARN ID and a forwarding policy.
Use undo index to delete the mapping between an ARN ID and a forwarding policy.
index index-value arn-id arn-id match { best-effort | srv6-policy color color-value }
No mapping is configured between an ARN ID and a forwarding policy.
arn-id: Specifies an ARN ID. The value range is 1 to 4294967295.
best-effort: Forwards traffic identified by the specified ARN ID in SRv6 BE mode. In SRv6 BE mode, the device encapsulates packets with a new IPv6 header. The destination address in the new IPv6 header is the VPN SID that the egress node of the SRv6 TE policy group assigned to public- or private-network routes. Then, the device looks up for IPv6 routes to forward the encapsulated packets.
srv6-policy color color-value: Specifies a color attribute value. If you specify a color attribute value, the device will forward traffic identified by the specified ARN ID through the SRv6 TE policy associated with the specified color attribute value. The value range for the color-value argument is 0 to 4294967295.
This command can take effect only if the forward type of the SRv6 TE policy group is ARN ID. To specify the forward type, you can use the forward-type arn-id command in SRv6 TE policy group view or SRv6 TE ODN policy group view.
Once service traffic is steered to an SRv6 TE policy group for forwarding, the device matches the ARN ID value in IPv6 packets with the ARN ID mappings in the SRv6 TE policy group. If a matching mapping is found, the device forwards the traffic through the SRv6 TE policy associated with the color attribute value in the mapping or forwards the traffic in SRv6 BE mode.
Operating mechanism
The device might receive a packet that does not carry an ARN ID or carries one of the following ARN IDs:
·     ARN ID that does not match any ARN ID mapping.
·     ARN ID that matches an invalid SRv6 TE policy or SRv6 BE mode.
In this situation, the device forwards that packet as follows:
¡     If the drop-upon-mismatch enable command is not used, the device identifies whether ARN ID-to-forwarding policy mappings are configured by using the index arn-id match command. If yes, the device searches for a mapping with the smallest index value and a valid forwarding policy. The device will use the SRv6 TE policy pointed by the mapping to forward the packet or forward the packet in SRv6 BE mode.
An ARN ID can establish a mapping relationship with an SRv6 TE policy only when that SRv6 TE policy is valid. Only when the mapping relationship is established, traffic that carries the ARN ID can be forwarded through that SRv6 TE policy.
An ARN ID can establish a mapping relationship with the SRv6 BE mode only when the SRv6 BE mode is valid. The SRv6 BE mode is valid only if the IPv6 routing table on the device contains a route destined for the VPN SID that the egress node of the SRv6 TE policy group assigned to public- or private-network routes. Only when the mapping relationship is established, traffic that carries the ARN ID can be forwarded in SRv6 BE mode.
For an SRv6 TE policy group, an ARN ID value can be mapped only to the SRv6 BE mode or to one SRv6 TE policy associated with a color attribute value.
If you execute the index arn-id match command multiple times for the same ARN ID, only the most recent configuration can take effect.
If you execute the index arn-id match command multiple times for the same index value, only the most recent configuration can take effect.
# Map ARN ID 3 and color attribute value 20 in an SRv6 TE policy group. Packets with an ARN ID of 3 will be steered to the SRv6 TE policy associated with color attribute value 20 for forwarding.
[Sysname-srv6-te-policy-group-10] forward-type arn-id
[Sysname-srv6-te-policy-group-10] index 10 arn-id 3 match srv6-policy color 20
# Map ARN ID 3 and color attribute value 20 in an SRv6 TE policy group ODN template. Packets with an ARN ID of 3 will be steered to the SRv6 TE policy associated with color attribute value 20 for forwarding.
[Sysname-srv6-te-odn-group-1-arn-id] index 10 arn-id 3 match srv6-policy color 20
default match
index te-class match
Use index te-class match to configure a mapping between a TE class ID and an SRv6 TE policy, an IPR policy, or the SRv6 BE mode.
Use undo index te-class match to delete a mapping between a TE class ID and an SRv6 TE policy, an IPR policy, or the SRv6 BE mode.
index index-value te-class te-class-id match { best-effort | ipr-policy ipr-name | srv6-policy color color-value }
No mapping is configured between a TE class ID and an SRv6 TE policy, an IPR policy, or the SRv6 BE mode.
index-value: Specifies an index for the mapping, in the range of 0 to 4294967294.
te-class-id: Specifies a TE class ID in the range of 1 to 65535.
best-effort: Specifies the SRv6 BE mode. In this mode, the device encapsulates a new IPv6 header in original packets and looks up the IPv6 routing table to forward the packets.
ipr-policy ipr-name: Specifies an IPR policy by its name, a case-sensitive string of 1 to 31 characters.
srv6-policy color color-value: Specifies an SRv6 TE policy by its color attribute value in the range of 0 to 4294967295.
For this command to take effect on an SRv6 TE policy, you must use the forward-type te-class command to enable TE class ID-based traffic steering for that SRv6 TE policy.
When service packets are steered to an SRv6 TE policy group configured with the index te-class match command, the device matches the TE class ID in the packets with the mappings between TE class IDs and forwarding policies. If a matching mapping is found, the device forwards the packets according to the matching forwarding policy.
Operating mechanism
The device selects a matching forwarding policy for traffic as follows:
·     If the TE class ID in a packet is mapped to a color attribute value, the device steers the packet to the SRv6 TE policy containing the color attribute value.
·     If the TE class ID in a packet is mapped to an IPR policy, the device uses the path selection policy defined in the IPR policy to steer the packet to the optimal SRv6 TE policy for forwarding.
·     If the TE class ID in a packet is mapped to the SRv6 BE mode, the device forwards the packet in SRv6 BE mode. In this mode, the device encapsulates a new IPv6 header in the packet and looks up the IPv6 routing table to forward the packet.
·     The device uses the default forwarding policy (specified by using the default match command) to forward the following packets after the packets are steered to the SRv6 TE policy group for forwarding:
¡     The packets that do not have a TE class ID.
¡     The packets that have a TE class ID not mapped to any forwarding policy specified by using the index te-class match command.
¡     The packets that have a TE class ID mapped to an invalid forwarding policy.
After the traffic is directed to an SRv6 TE policy group, when packets are forwarded according to the default forwarding policy, the device selects a forwarding method in the following order:
1.     If a color attribute value or an IPR policy is specified in the default forwarding policy and the SRv6 TE policy used to forward the packets is valid, the device steers the traffic to that SRv6 TE policy for forwarding.
2.     If the SRv6 BE mode is specified in the default forwarding policy and the SRv6 BE mode is valid, the device encapsulates a new IPv6 header to the packets and looks up the IPv6 routing table to forward the packets.
3.     If the default match command is not executed, or the forwarding policy configured by using the default match command is invalid, the device handles the packet according to the configuration of the drop-upon-mismatch enable command.
¡     If the drop-upon-mismatch enable command is not used, the device searches for the TE class ID-to-forwarding policy mapping with the smallest index value and a valid forwarding policy. The device will use the SRv6 TE policy pointed by the mapping to forward the packet or forward the packet in SRv6 BE mode.
One TE class ID can be associated only with one index value.
If you execute the index te-class match command multiple times to configure mappings with the same index value, only the most recent configuration takes effect.
One TE class ID can be mapped only to one forwarding policy. For example,if TE class ID 10 has been mapped to IPR policy ipr1, it cannot be mapped to any other IPR policy, an SRv6 TE policy, or the SRv6 BE mode. If you map one TE class ID to multiple forwarding policies, only the most recent configuration takes effect.
As a best practice, configure different endpoint addresses for different SRv6 TE policy groups. If you configure the same endpoint address for multiple SRv6 TE policy groups, SRv6 TE policies with that endpoint address will belong to multiple SRv6 TE policy groups.
# Map TE class ID 100 to IPR policy ipr1 for traffic forwarding.
[Sysname-srv6-te-policy-group-1] index 10 te-class 100 match ipr-policy ipr1
default match (TE class ID-based traffic steering)
forward-type (SRv6 TE Policy group view)
forward-type (SRv6 TE ODN Policy group view)
intelligent-policy-route
Use intelligent-policy-route to enable Intelligent Policy Route (IPR) and enter SRv6 TE IPR view.
Use undo intelligent-policy-route to disable IPR and delete all settings in SRv6 TE IPR view.
IPR is disabled.
SRv6 TE view
IPR dynamically selects the optimal SRv6 TE policy from the SRv6 TE policies in an SRv6 TE policy group based on the iFIT measurements results of these SRv6 TE policies.
By defining different IPR policies, you can configure different network quality thresholds, priority orders of SRv6 TE policies, and switchover policies. Different IPR policies are used to meet the network quality requirements of different services.
To dynamically select the optimal SRv6 TE policy, IPR must collaborate with the iFIT packet loss, delay, and jitter measurements of SRv6 TE policies.
# Enable IPR and enter SRv6 TE IPR view.
[Sysname-srv6-te] intelligent-policy-route
[Sysname-srv6-te-ipr]
ipr-policy
Use ipr-policy to create an IPR policy and enter SRv6 TE IPR policy view, or enter the SRv6 TE IPR policy view of an existing IPR policy.
Use undo ipr-policy to delete the IPR policy and its settings.
ipr-policy ipr-name
undo ipr-policy
No IPR policy exists.
SRv6 TE IPR view
ipr-name: Specifies a name for the IPR policy, a case-sensitive string of 1 to 31 characters.
Application scenarios
When service packets are steered to an SRv6 TE policy group configured with TE class ID-based traffic steering, the device matches the TE class ID in the packets with the mappings between TE class IDs and IPR policies in the SRv6 TE policy group. To configure the mappings, use the index te-class match command. If a matching mapping is found, the device selects an SRv6 TE policy to forward the packets according to the path selection policy defined in the matching IPR policy.
Operating mechanism
You can create multiple IPR policies in SRv6 TE IPR view. Each IPR policy is an SLA-based policy for selecting the optimal SRv6 TE policy. You can define the following contents in an IPR policy:
·     SLA thresholds for service traffic, including the delay threshold, packet loss rate threshold, jitter threshold, and Composite Measure Indicator (CMI) threshold.
·     Mappings between color attribute values of SRv6 TE policies and path selection priority values.
·     Switchover period between SRv6 TE policies and WTR period.
An IPR policy must cooperate with the iFIT packet loss measurement and iFIT delay and jitter measurement features of SRv6 TE policies for intelligent forwarding path selection. The cooperative mechanism between an IPR policy and the iFIT measurement features of SRv6 TE policies is as follows:
1.     iFIT measures the network quality.
You can enable iFIT packet loss measurement and iFIT delay and jitter measurement for SRv6 TE policies on the source node of an SRv6 TE policy group. iFIT then performs the following operations:
a.     Measures the link quality of different SRv6 TE policies in the SRv6 TE policy group.
b.     Sends the SLA measurement data to IPR on the source node for path calculation and selection according to the iFIT measurement interval.
2.     The source node calculates candidate paths.
The source node of SRv6 TE policies calculates the optimal SRv6 TE policy based on the optimal path calculation period set by using the refresh-period command. If the source node finds that any value of the delay, packet loss rate, jitter, and CMI values obtained from the most recent iFIT measurement data for an SRv6 TE policy crosses a threshold set in an IPR policy, that SRv6 TE policy does not comply with the SLA requirements. As a result, the source node does not use that SRv6 TE policy as a candidate path for service traffic forwarding. If iFIT fails to measure the delay, packet loss rate, jitter, and CMI values of an SRv6 TE policy, but the SRv6 TE policy is valid, the source node still uses this SRv6 TE policy as a candidate path for service traffic forwarding.
3.     The source node selects the optimal path.
The source node selects the SRv6 TE policy with the highest priority as the optimal forwarding path according to the priority order defined in the IPR policy, and steers service traffic to this SRv6 TE policy. When multiple SRv6 TE policies have the same priority, traffic can be load-balanced among these SRv6 TE policies.
To delete an IPR policy that has been mapped to a TE class ID, you must first delete the mapping between the IPR policy and the TE class ID.
# Create IPR policy ipr1 and enter SRv6 TE IPR policy view.
[Sysname-srv6-te-ipr] ipr-policy ipr1
[Sysname-srv6-ipr-policy-ipr1]
jitter threshold
Use jitter threshold to set the jitter threshold in an IPR policy.
Use undo jitter threshold to restore the default.
jitter threshold time-value
The jitter threshold is 3000 milliseconds in an IPR policy.
time-value: Specifies a jitter threshold value in the range of 0 to 3000, in milliseconds.
An SRv6 TE policy can be used as a candidate forwarding path and participate in optimal SRv6 TE policy selection only when the iFIT delay and jitter measurement feature detects that the jitter of the SRv6 TE policy does not exceed the jitter threshold set by this command.
If the optimal candidate path of an SRv6 TE policy has multiple valid SID lists with weight values, the device uses the weighted sum of the iFIT jitters of all of these valid SID lists as the jitter value of that SRv6 TE policy when intelligent policy routing computes whether the jitter of that SRv6 TE policy crosses the threshold.
# Set the jitter threshold to 20 milliseconds in IPR policy ipr1.
[Sysname-srv6-ipr] ipr-policy ipr1
[Sysname-srv6-ipr-policy-ipr1] jitter threshold 20
local-binding-sid
Use local-binding-sid to configure a local BSID.
Use undo local-binding-sid to restore the default.
local-binding-sid ipv6 ipv6-address
No local BSID exists.
SID list view
ipv6 ipv6-address: Specifies an IPv6 address as a local BSID.
By default, the return BFD echo or SBFD packets used for SRv6 TE policy connectivity detection are forwarded based on the IP forwarding path. If a transit node fails, the return packets will be discarded, the BFD or SBFD session will go down, and the SID list will be mistakenly considered as faulty.
To resolve this issue, you can enable the return BFD or SBFD packets to be forwarded based on the specified SID list to ensure connectivity as follows:
1.     Configure a reverse BSID in SID list view on the ingress node, and configure a local BSID with the same value in SID list view on the egress node.
2.     When the ingress node forwards a BFD or SBFD packet, it performs the following operations:
¡     For a BFD packet, it encapsulates an SID list in the SRH. In addition, it encapsulates the reverse BSID associated with the SID list to the SL=1 location.
¡     For an SBFD packet, it encapsulates the Aux Path TLV to the packet. This TLV contains the reverse BSID.
3.     When the egress node receives the BFD or SBFD packet, it compares the reverse BSID in the packet with the configured local BSID. If the values are the same, the egress node encapsulates an SRH for the return BFD or SBFD packet and forwards the packet based on the SID list associated with the local BSID.
The BSID specified in this command cannot be the same as the BSID of the SRv6 TE policy. If they are the same, the SID list becomes invalid and cannot be used to forward packets.
The BSID specified in this command must be within the static length of the locator specified in SRv6 TE view. If this condition is not met, the SID list associated with the BSID cannot be used to forward packets.
# Configure the local BSID for SID list s1 as 1::1.
[Sysname-srv6-te] segment-list s1
[Sysname-srv6-te-sl-s1] local-binding-sid ipv6 1::1
reverse-binding-sid
loss threshold
Use loss threshold to set the packet loss rate threshold in an IPR policy.
Use undo loss threshold to restore the default.
loss threshold threshold-value
undo loss threshold
The packet loss rate threshold is 1000‰ in an IPR policy.
threshold-value: Specifies a packet loss threshold value in the range of 0 to 1000, in per mille (‰).
An SRv6 TE policy can be used as a candidate forwarding path and participate in optimal SRv6 TE policy selection only when the iFIT packet loss measurement feature detects that the packet loss rate of the SRv6 TE policy does not exceed the packet loss rate threshold set by this command.
If the optimal candidate path of an SRv6 TE policy has multiple valid SID lists with weight values, the device uses the weighted sum of the iFIT packet loss rates of all of these valid SID lists as the packet loss rate of that SRv6 TE policy when intelligent policy routing computes whether the packet loss rate of that SRv6 TE policy crosses the threshold.
# Set the packet loss threshold to 5‰ in IPR policy ipr1.
[Sysname-srv6-ipr-policy-ipr1] loss threshold 5
maximum-sid-depth
Use maximum-sid-depth to configure the maximum depth for the SID label stack.
Use undo maximum-sid-depth to restore the default.
maximum-sid-depth value
The maximum depth for the SID label stack is 10 for the following cards:
Card category
Cards
CEPC
CEPC-CQ8L, CEPC-CQ16L1, CEPC-DQ2L1-G
CSPEX
CSPEX-1802XB, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-2304X-LG, CSPEX-2314X-G, CSPEX-2314X-G1, CSPEX-2314X-G2, CSPEX-2612X-E
SPE
RX-SPE200-E
The maximum depth for the SID label stack is 5 for the following cards:
Card category
Cards
CEPC
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RX-L
CSPEX
CSPEX-1304X, CSPEX-1304S, CSPEX-1404X, CSPEX-1404S, CSPEX-1502X, CSPEX-1504X, CSPEX-1504S, CSPEX-1602X, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X
SPE
RX-SPE200
OAA
IM-NGFWX-IV
SRv6 TE ODN view
value: Specifies the maximum depth for the SID label stack, in the range of 1 to 255.
To implement dynamic path calculation for ODN-generated SRv6 TE policies, use this command to control the number of SIDs in the SID lists for the candidate paths of the SRv6 TE policies.
The actual effective SID label stack depth takes the smaller value among the following settings:
·     Maximum depth of the SID label stack configured in this command.
·     Default setting for this command.
# Configure the maximum depth of the SID label stack as 10.
[Sysname-srv6-te] on-demand color 1
[Sysname-srv6-te-odn-1] maximum-sid-depth 10
measure count
Use measure count to set the data calculation mode for IPR.
Use undo measure count to restore the default.
measure count { one-way | two-way-average }
undo measure count
IPR uses the one-way data calculation mode.
SRv6 TE IPR view
one-way: Specifies the one-way data calculation mode for IPR.
two-way-average: Specifies the two-way data calculation mode for IPR.
By using the service packets forwarded by an SRv6 TE policy, iFIT measurement can obtain network quality of the following paths:
·     Forward path from the source node to the endpoint node of the SRv6 TE policy.
·     Return path from the endpoint node to the source node of the SRv6 TE policy.
IPR supports the following data calculation modes for SRv6 TE policy network quality measurement through iFIT:
·     One-way mode—IPR uses the one-way iFIT data collected for the source-to-endpoint path to measure the network quality.
·     Two-way mode—IPR uses the average of round-trip iFIT data collected for the source-to-endpoint path and the endpoint-to-source path to measure the network quality.
If the two-way mode is specified, iFIT cannot accurately measure the packet loss rate of the SRv6 TE policy tunnel. Therefore, the device still uses the measurement results of the one-way mode as the packet loss rate data.
# Specify the two-way data calculation mode for IPR.
[Sysname-srv6-te-ipr] measure count two-way-average
metric
Use metric to create a metric type and enter its view, or enter the view of an existing metric type.
Use undo metric to delete the metric type view and all the configuration in the view.
metric
undo metric
No metric types exist.
SRv6 TE policy path preference dynamic view
SRv6 TE ODN dynamic view
Use this command to specify the method for implementing dynamic path calculation for SRv6 TE policies.
# In SRv6 TE policy path preference dynamic view, create a metric type and enter metric type view.
[Sysname-srv6-te] policy 1
[Sysname-srv6-te-policy-1] candidate-paths
[Sysname-srv6-te-policy-1-path] preference 20
[Sysname-srv6-te-policy-1-path-pref-20] dynamic
[Sysname-srv6-te-policy-1-path-pref-20-dyna] metric
[Sysname-srv6-te-policy-1-path-pref-20-dyna-metric]
# In SRv6 TE ODN dynamic view, create a metric type and enter metric type view.
[Sysname-srv6-te-odn-1] dynamic
[Sysname-srv6-te-odn-1-dynamic] metric
[Sysname-srv6-te-odn-1-dynamic-metric]
metric-inherit (SRv6 TE policy view)
Use metric-inherit to configure the metric sharing feature for an SRv6 TE policy.
Use undo metric-inherit to restore the default.
metric-inherit { disable | enable }
undo metric-inherit
The metric sharing feature is not configured for an SRv6 TE policy. The SRv6 TE policy uses the metric sharing configuration in SRv6 TE view.
SRv6 TE policy view
disable: Disables the metric sharing feature for the SRv6 TE policy.
enable: Enables the metric sharing feature for the SRv6 TE policy.
If an SRv6 TE policy network meets the following requirements, BGP will perform SRv6 TE policy selection based on the specified SRv6 TE policy metric type:
·     A CE is homed to multiple peer PE devices.
·     The local PE device has learned several BGP routes with the same prefix, and those routes are recursed to different SRv6 TE policies.
Operating mechanism
After the metric sharing feature is enabled for an SRv6 TE policy, the PE device preferentially selects a BGP route based on the metric type specified by using the bestroute srv6-policy-metric command and the related SRv6 TE policies' metric values.
You can configure the metric sharing feature for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. For an SRv6 TE policy, the policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable the metric sharing feature for SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] metric-inherit enable
bestroute srv6-policy-metric (Layer 3—IP Routing Command Reference)
metric-type (SRv6 TE policy view)
srv6-policy metric-inherit enable
metric-inherit (SRv6 TE policy group view)
Use metric-inherit to configure the metric sharing feature for an SRv6 TE policy group.
undo metric-inherit
The metric sharing feature is not configured for an SRv6 TE policy group. The SRv6 TE policy group uses the metric sharing configuration in SRv6 TE view.
disable: Disables the metric sharing feature for the SRv6 TE policy group.
enable: Enables the metric sharing feature for the SRv6 TE policy group.
If an SRv6 TE policy network meets the following requirements, BGP will perform SRv6 TE policy group selection based on the specified SRv6 TE policy metric type:
·     The local PE device has learned several BGP routes with the same prefix, and those routes are recursed to different SRv6 TE policy groups.
Operating mechanism
After the metric sharing feature is enabled for an SRv6 TE policy group, the PE device preferentially selects a BGP route based on the metric type specified by using the bestroute srv6-policy-metric command and the related SRv6 TE policies' metric values.
You can configure the metric sharing feature for all SRv6 TE policy groups globally in SRv6 TE view or for a specific SRv6 TE policy group in SRv6 TE policy group view. For an SRv6 TE policy group, the group-specific configuration takes precedence over the global configuration. An SRv6 TE policy group uses the global configuration only when it has no group-specific configuration.
# Enable the metric sharing feature for SRv6 TE policy group 1.
[Sysname-srv6-te]policy-group 1
[Sysname-srv6-te-policy-group-1] metric-inherit enable
metric-type (SRv6 TE policy group view)
Use metric-type configure metric values for an SRv6 TE policy.
Use undo metric-type to delete metric values for an SRv6 TE policy.
metric-type igp absolute igp-value
metric-type te absolute te-value
metric-type delay absolute delay-value
metric-type loss absolute loss-value
undo metric-type { igp | te | delay | loss } absolute
No metric values are configured for an SRv6 TE policy.
SRv6 TE policy view
igp: Specifies IGP metric configuration.
absolute igp-value: Specifies an absolute IGP metric value. The value range for the igp-value argument is 1 to 4294967295.
te: Specifies TE metric configuration.
absolute te-value: Specifies an absolute TE metric value. The value range for the te-value argument is 1 to 4294967295.
delay: Specifies link delay metric configuration.
absolute delay-value: Specifies an absolute link delay metric value. The value range for the delay-value argument is 1 to 4294967295, in microseconds.
loss: Specifies packet loss metric configuration.
absolute loss-value: Specifies an absolute packet loss metric value. The value range and measurement unit for the loss-value argument is 1 to 16777214 and 0.000003%, respectively.
Enable the metric sharing feature for the SRv6 TE policy by using one of the following methods:
·     Execute the metric-inherit command in SRv6 TE policy view.
·     Execute the srv6-policy metric-inherit enable command in SRv6 TE view.
If you do not enable the metric sharing feature for the SRv6 TE policy, metric-based SRv6 TE policy selection cannot take effect.
Operating mechanism
SRv6 TE policies support the following metrics:
·     IGP: Use this metric when each SRv6 TE policy is treated as a link and only link cost is taken into account during link selection. The smaller the IGP metric value, the better the SRv6 TE policy.
·     TE: Use this metric in traffic engineering scenarios where the TE metric is used to measure the bandwidth usage and path congestion of an SRv6 TE policy. The smaller the TE metric value, the better the SRv6 TE policy.
·     Link delay: Use this metric in link delay-sensitive scenarios. This metric is used to measure the link delay of an SRv6 TE policy forwarding path. The smaller the link delay metric value, the better the SRv6 TE policy.
·     Packet loss: Use this metric in packet loss-sensitive scenarios. This metric is used to measure the packet loss of an SRv6 TE policy forwarding path. The smaller the packet loss metric value, the better the SRv6 TE policy.
Each SRv6 TE policy on the source node can have multiple types of metric values. In this situation, the source node preferentially selects a BGP route associated with those SRv6 TE policies based on the metric type specified by using the bestroute srv6-policy-metric command and their related metric values. If multiple SRv6 TE policies have the same metric value for the same type, the source node continues to select a BGP route, according to the BGP route selection rules.
·     If the metric sharing feature is enabled for SRv6 TE policies on the source node and an SRv6 TE policy is not configured with metric values, the metric value is 0 for all metrics of that SRv6 TE policy. In this situation, the source node always selects the SRv6 TE policy as the optimal. As a best practice to implement metric-based SRv6 TE policy selection, make sure all SRv6 TE policies are configured with appropriate metric values.
·     If multiple SRv6 TE policies have the same metric value for the same metric type, they can be used for load sharing.
·     An SRv6 TE policy obtains metric values with one of the following methods:
¡     Static configuration: Execute the metric-type command on the source node to configure metric values for SRv6 TE policies. Static metric values have the highest precedence.
¡     Dynamic acquisition: Dynamically obtain SRv6 TE policy metric values from the controller through BGP IPv6 SR policy or BGP-LS routing. Static metric values take precedence over dynamic metric values. An SRv6 TE policy uses dynamic metric values only if it does not have static metric values.
·     During dynamic acquisition of SRv6 TE policy metric values, both BGP IPv6 SR policy routes and BGP-LS routes use Metric sub-TLVs to carry metric values of the related SID lists. Therefore, metric value information might vary by SID list. Different SIDs can have different metric values. The metric value of a candidate path equals the maximum metric value of its associated SID lists. The metric value of an SRv6 TE Policy equals that of its optimal candidate path.
# Set the TE metric value to 15 for SRv6 TE policy a.
[Sysname-srv6-te] policy a
[Sysname-srv6-te-policy-a] metric type te absolute 15
Use metric-type configure metric values for an SRv6 TE policy group.
Use undo metric-type to delete metric values for an SRv6 TE policy group.
No metric values are configured for an SRv6 TE policy group.
Enable the metric sharing feature for the SRv6 TE policy group by using one of the following methods:
·     Execute the metric-inherit command in SRv6 TE policy group view.
If you do not enable the metric sharing feature for the SRv6 TE policy group, metric-based SRv6 TE policy group selection cannot take effect.
Operating mechanism
SRv6 TE policy groups support the following metrics:
·     IGP: Use this metric when each SRv6 TE policy group is treated as a link and only link cost is taken into account during link selection. The smaller the IGP metric value, the better the SRv6 TE policy group.
·     TE: Use this metric in traffic engineering scenarios where the TE metric is used to measure the bandwidth usage and path congestion of an SRv6 TE policy group. The smaller the TE metric value, the better the SRv6 TE policy group.
·     Link delay: Use this metric in link delay-sensitive scenarios. This metric is used to measure the link delay of forwarding paths in an SRv6 TE policy group. The smaller the link delay metric value, the better the SRv6 TE policy group.
·     Packet loss: Use this metric in packet loss-sensitive scenarios. This metric is used to measure the packet loss of forwarding paths in an SRv6 TE policy group. The smaller the packet loss metric value, the better the SRv6 TE policy group.
Each SRv6 TE policy group on the source node can have multiple types of metric values. In this situation, the source node preferentially selects a BGP route associated with those SRv6 TE policy groups based on the metric type specified by using the bestroute srv6-policy-metric command and their related metric values. If multiple SRv6 TE policy groups have the same metric value for the same type, the source node continues to select a BGP route, according to the BGP route selection rules.
When the device forwards traffic through an SRv6 TE policy group, it must perform traffic steering based on the forward type of the SRv6 TE policy group and the specified mapping.
·     If the metric sharing feature is enabled for SRv6 TE policy groups on the source node and an SRv6 TE policy group is not configured with metric values, the metric value is 0 for all metrics of that SRv6 TE policy group. In this situation, the source node always selects the SRv6 TE policy group as the optimal. As a best practice to implement metric-based SRv6 TE policy group selection, make sure all SRv6 TE policy groups are configured with appropriate metric values.
·     If multiple SRv6 TE policy groups have the same metric value for the same metric type, they can be used for load sharing.
·     An SRv6 TE policy group obtains metric values with one of the following methods:
¡     Static configuration: Execute the metric-type command on the source node to configure metric values for SRv6 TE policy groups. Static metric values have the highest precedence.
¡     Dynamic acquisition from SRv6 TE policies: Identify all valid SRv6 TE policies within the SRv6 TE policy group, and then select the maximum metric value of those valid policies. Static metric values take precedence over dynamic metric values. An SRv6 TE policy group uses dynamic metric values only if it does not have static metric values.
# Set the TE metric value to 15 for SRv6 TE policy group 1.
[Sysname-srv6-te-policy-group-1] metric type te absolute 15
bestroute srv6-policy inherit-metric (Layer 3—IP Routing Command Reference)
mirror remote-sid delete-delay
Use mirror remote-sid delete-delay to configure the deletion delay time for remote SRv6 SID mappings with VPN instances/cross-connects/VSIs.
Use undo mirror remote-sid delete-delay to restore the default.
mirror remote-sid delete-delay delete-delay-time
The deletion delay time for remote SRv6 SID and VPN instance/cross-connect/VSI mappings is 60 seconds.
SRv6 view
delete-delay-time: Specifies the deletion delay time, in the range of 1 to 21845 seconds.
In an egress protection scenario, if the egress node and the egress node's protection node are disconnected, the protection node will delete the BGP routes received from the egress node. The remote SRv6 SID and VPN instance/cross-connect/VSI mappings will then be deleted as a result. To avoid this issue, you can configure the mappings deletion delay time on the protection node. This ensures that traffic is forwarded through the protection node before the ingress detects the egress failure and computes a new forwarding path.
# Set the deletion delay time for remote SRv6 SID and VPN instance/cross-connect/VSI mappings to 100 seconds.
[Sysname-segment-routing-ipv6] mirror remote-sid delete-delay 100
name
Use name to specify an affinity attribute for an affinity attribute rule.
Use undo name to restore the default.
name name
undo name name
No affinity attribute is specified for an affinity attribute rule.
Affinity attribute rule view
SRv6 TE ODN dynamic affinity attribute rule view
name: Specifies an affinity attribute by its name, a case-sensitive string of 1 to 32 characters.
This command enables the SRv6 TE policy to select links containing the bit values associated with the specified affinity attribute as required by the affinity attribute rule.
·     Link attribute—A 32-bit binary number. Each bit represents an attribute with a value of 0 or 1.
·     Affinity attribute bit position—The value range is 0 to 32. When the affinity attribute value is N, it is compared with the N+1 bit of the link attribute. The affinity attribute applies to the link only if the N+1 bit value of the link attribute is 1.
For example, for affinity attribute names blue and red, if you configure the name blue bit-position 1 and name red bit-position 5 commands, the link selection varies by affinity attribute rule type:
·     For the include-any affinity attribute rule, a link is available for use if the link attribute has the second bit (associated with affinity attribute blue) or sixth bit (associated with affinity attribute red) set to 1.
·     For the include-all affinity attribute rule, a link is available for use if the link attribute has both the second bit (associated with affinity attribute blue) and sixth bit (associated with affinity attribute red) set to 1.
·     For the exclude-any affinity attribute rule, a link is not available for use if the link attribute has the second bit (associated with affinity attribute blue) or sixth bit (associated with affinity attribute red) set to 1.
# In affinity attribute rule view, specify affinity attribute red for the include-any affinity attribute rule.
[Sysname] segment-routing-ipv6
[Sysname-srv6-te] policy a1
[Sysname-srv6-te-policy-a1] candidate-paths
[Sysname-srv6-te-policy-a1-path] preference 200
[Sysname-srv6-te-policy-a1-path-pref-200] constraints
[Sysname-srv6-te-policy-a1-path-pref-200-const] affinity
[Sysname-srv6-te-policy-a1-path-pref-200-const-aff] include-any
[Sysname-srv6-te-policy-a1-path-pref-200-const-aff-include-any] name red
# In SRv6 TE ODN dynamic affinity attribute rule view, specify affinity attribute red for the include-any affinity attribute rule.
[Sysname-srv6-te-odn-1-dynamic] affinity include-any
[Sysname-srv6-te-odn-1-dynamic-aff-include-any] name red
mpls te link-attribute (MPLS Command Reference)
name bit-position
name bit-position
Use name bit-position to create a name-to-bit mapping for an affinity attribute.
Use undo name bit-position to restore the default.
name name bit-position bit-position-number
undo name name bit-position
No name-to-bit mapping is configured for an affinity attribute.
Constraints mapping view
bit-position-number: Specifies a bit by its position value in the range of 0 to 31.
# Map affinity attribute red to bit 3 in the affinity attribute.
[Sysname-srv6-te] affinity-map
[Sysname-srv6-te-affinity-map] name red bit-position 3
name
on-demand
Use on-demand to create an on-demand next-hop (ODN) template for creating SRv6 TE policies and enter SRv6 TE ODN view, or enter the SRv6 TE ODN view of an existing ODN template.
Use undo on-demand to delete an ODN template and all the configuration in the view.
on-demand color color-value
undo on-demand color color-value
No SRv6 TE policy ODN templates exist.
SRv6 TE view
color color-value: Specifies the color value for the ODN template, in the range of 0 to 4294967295.
When the device receives a BGP route, it compares the color extended attribute value of the BGP route with the color value of the ODN template. If the color values match, the device automatically generates an SRv6 TE policy and two candidate paths for the policy.
·     The policy uses the BGP route's next hop address as the end-point address and the ODN template's color value as the color attribute value of the policy.
·     The candidate paths use preferences 100 and 200. You need to manually configure the SID lists for the candidate path with preference 200, and use PCE to compute the SID lists for the candidate path with preference 100.
You can also manually create candidate paths for an ODN-created SRv6 TE policy.
# Create an SRv6 TE policy ODN template with color value 1 and enter SRv6 TE ODN view.
on-demand-group
Use on-demand-group to create an ODN template for creating SRv6 TE policy groups and enter SRv6 TE ODN policy group view, or enter the SRv6 TE ODN policy group view of an existing ODN template.
Use undo on-demand-group to delete an ODN template and all the configuration in the view.
on-demand-group color color-value
undo on-demand-group color color-value
No SRv6 TE policy group ODN templates exist.
SRv6 TE view
When the device receives a BGP route, it compares the color extended attribute value of the BGP route with the color value of the ODN template. If the color values match, the device automatically generates an SRv6 TE policy group. The device will assign the smallest ID that are not in use to the SRv6 TE policy group.
After an SRv6 TE policy group is automatically generated, you need to configure color-to-DSCP mappings for the template for DSCP-based traffic steering.
# Create an SRv6 TE policy group ODN template with color value 1 and enter SRv6 TE ODN policy group view.
path verification
Use path verification to configure path connectivity verification for an SRv6 TE policy.
Use undo path verification to restore the default.
path verification { disable | [ specified-sid ] enable }
Path connectivity verification is not configured for an SRv6 TE policy. The setting configured in SRv6 TE view applies.
SRv6 TE policy view
disable: Disables path connectivity verification for the SRv6 TE policy.
enable: Enables path connectivity verification for the SRv6 TE policy.
specified-sid: Enables path connectivity verification only for the SIDs specified with the verification keyword in the index command. If you do not specify the specified-sid keyword, the path verification command verifies the validity for all SIDs in the SID list.
To configure path verification for an SRv6 TE policy, you must configure this command on the source node of the SRv6 TE policy. Even if you configure this feature on the controller and the controller deploys the BGP IPv6 SR policy route to the device, you still need to configure this feature on the source node of the SRv6 TE policy.
Typically, the controller deploys the SID list of an SRv6 TE policy. Without BFD configured, the source node cannot immediately detect path failures in the SRv6 TE policy. It only changes the SID list of the SRv6 TE policy as instructed by the controller that completes path recalculation upon detecting a topology change. If the controller or the link to the controller fails, the source node will be unable to detect failures and change SID lists, resulting in traffic loss.
For fast traffic switchover and high availability, you can enable path connectivity verification for the source node of the SRv6 TE policy. This feature enables the source node to collect network topology information, and verify all SID lists in the SRv6 TE policy as follows:
·     If all SRv6 SIDs exist in the topology and the associated locator prefixes are routable, the SID list is valid.
·     If any SRv6 SIDs do not exist in the topology or any of the associated locator prefixes are not routable, the SID list is invalid.
Upon detecting an invalid SID list (SID list failure), the source node changes paths as follows:
·     If the valid candidate paths of the SRv6 TE policy contain multiple SID lists, and one of the SID list fails, traffic is distributed to other valid SID lists.
·     If the SRv6 TE policy has valid primary and backup candidate paths, and all SID lists for the primary candidate path fail, traffic is distributed to the backup candidate path.
·     If all valid candidate paths of the SRv6 TE policy fail, the SRv6 TE policy is faulty and an associated protection action is taken (for example, MPLS L3VPN FRR).
You can configure SRv6 TE policy path connectivity verification in both SRv6 TE view and SRv6 TE policy view. The configuration in SRv6 TE policy view takes precedence over the configuration in SRv6 TE view. If path connectivity verification is not configured for an SRv6 TE policy, the configuration in SRv6 TE applies.
The source node must have all SRv6 SIDs and routes in the IGP domain to detect their status through the following settings:
·     Enable the IGP domain to forward routing information through IPv6 IS-IS.
·     Configure the distribute link-state command in IS-IS view for the source node to report link status.
If a BSID exists in the segment list path, path connectivity verification will fail because the BSID cannot be flooded in the IGP topology. Do not configure this command in the scenario where BSID is deployed.
After path connectivity verification is enabled for an SRv6 TE policy, the device verifies the validity of all SIDs in the SID list. If the SID list contains an inter-AS SID (for example, the BGP Peer SID allocated by BGP EPE) or contains the BSID of another SRv6 TE policy, the path connectivity verification will fail. This is because a BSID or BGP Peer SID cannot be flooded in the IGP topology.
To resolve this issue, you can execute the following commands to configure the path connectivity verification only verifies the validity of specific SIDs:
·     Use the index command to specify the verification keyword for the SIDs to be verified. Do not specify this keyword for a BSID or BGP EPE SID in the SID list.
·     Specify the specified-sid keyword when you execute the path verification command in SRv6 TE policy view or the srv6-policy path verification enable command in SRv6 TE view.
If the first SID in a segment list is the local End SID of the source node in the SRv6 TE policy, the segment list will fail the verification. As a best practice, do not enable this feature in such a situation. To enable this feature, you must specify the specified-sid keyword to verify only the SIDs specified with the verification keyword in the index command.
# Enable path connectivity verification for SRv6 TE policy 1.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te-policy-1] path verification enable
distribute (Layer 3—IP Routing Command Reference)
index
pce capability segment-routing ipv6
Use pce capability segment-routing ipv6 to enable the SRv6 capability for a PCC device.
Use undo pce capability segment-routing ipv6 to disable the SRv6 capability for a PCC device.
A PCC device does not have the SR capability.
PCC view
To establish an SRv6-capable PCEP session, you need to enable the SRv6 capability on both peers of the PCEP session. An SRv6-capable active PCEP session supports computation, report, delegation, and update of SR-based LSPs.
In the current software version, a PCE device does not have the SRv6 capability.
# Enable the SRv6 capability for the PCC device.
[Sysname] pce-client
[Sysname-pcc] pce capability segment-routing ipv6
pce delegation
Use pce delegation to enable PCE delegation for an SRv6 TE policy.
Use undo pce delegation to restore the default.
pce delegation { enable | disable }
undo pce delegation
An SRv6 TE policy uses the PCE delegation configuration in SRv6 TE view.
SRv6 TE policy view
enable: Enables PCE delegation for the SRv6 TE policy.
disable: Disables PCE delegation for the SRv6 TE policy.
After PCE delegation for an SRv6 TE policy is enabled, the PCC delegates the policy's candidate paths to a PCE. The PCC creates or updates candidate paths according to the creation or update requests received from the PCE.
You can configure PCE delegation for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
If you execute both the pce delegation command and the pce passive-delegate report-only command for an SRv6 TE policy, the pce passive-delegate report-only command takes effect.
# Enable PCE delegation for an SRv6 TE policy.
[Sysname-srv6-te-policy-1] pce delegation enable
srv6-policy pce delegation enable
Use pce passive-delegate report-only to enable the device to report candidate path information of an SRv6 TE policy to the PCE without delegating the policy to the PCE.
Use undo pce passive-delegate report-only to restore the default.
pce passive-delegate report-only { enable | disable }
An SRv6 TE policy uses the passive delegation report only setting configured in SRv6 TE view.
SRv6 TE policy view
enable: Enables the passive delegation report only feature for the SRv6 TE policy.
disable: Disables the passive delegation report only feature for the SRv6 TE policy.
When the device delegates only part of its SRv6 TE policies to a PCE, the PCE does not have complete SRv6 TE policy candidate path information to calculate global bandwidth information. You can enable the device to report information about the undelegated SRv6 TE policies to the PCE without using the PCE to compute candidate paths for the policies.
You can configure the passive delegation report only feature for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable the device to report an SRv6 TE policy's candidate path information to the PCE without delegating the policy to the PCE.
[Sysname-srv6-te-policy-1] pce passive-delegate report-only enable
pce delegation
srv6-policy pce passive-delegate report-only enable
pcep (SRv6 TE policy path preference dynamic view)
Use pcep to enable an SRv6 TE policy candidate path to use PCE to compute the SID lists.
Use undo pcep to restore the default.
pcep
undo pcep
An SRv6 TE policy candidate path does not use PCE to compute SID lists. You need to manually configure the SID lists for the candidate path.
The device uses PCE to compute SID lists for a manually created SRv6 TE policy candidate path in the following procedure:
1.     The device that acts as a PCC sends a path computation request to the PCE.
2.     The PCE computes paths after it receives the request.
3.     The PCE replies the PCC with the computed path information.
4.     The PCC creates SID lists for the SRv6 TE policy candidate path according to the path information computed by PCE.
# Enable an SRv6 TE policy candidate path to use PCE to compute the SID lists.
[Sysname-srv6-te-policy-1-path-pref-20-dyna] pcep
pcep (SRv6 TE ODN dynamic view)
Use pcep to enable path computation using PCE.
Use undo pcep to disable path computation using PCE.
pcep
undo pcep
Dynamic path computation using PCE is disabled.
The SID lists for ODN-created SRv6 TE policy candidate path 100 can only be computed by PCE. For this candidate path, you must execute this command to enable path computation using PCE. The path computation procedure is as follows:
4.     The PCC creates SID lists for candidate path 100 according to the path information computed by PCE.
# Enable dynamic path computation using PCE.
[Sysname-srv6-te-odn-1-dynamic] pcep
policy
Use policy to create an SRv6 TE policy and enter its view, or enter the view of an existing SRv6 TE policy.
Use undo policy to delete an SRv6 TE policy and all the configuration in the SRv6 TE policy.
policy policy-name
undo policy policy-name
No SRv6 TE policies exist.
SRv6 TE view
policy-name: Specifies an SRv6 TE policy name, a case-sensitive string of 1 to 59 characters.
# Create an SRv6 TE policy named srv6policy and enter its view.
[Sysname-srv6-te] policy p1
[Sysname-srv6-te-policy-p1]
policy-group
Use policy-group to create an SRv6 TE policy group and enter its view, or enter the view of an existing SRv6 TE policy group.
Use undo policy-group to delete an SRv6 TE policy group and all the configuration in the SRv6 TE policy group.
policy-group group-id
undo policy-group group-id
No SRv6 TE policy groups exist.
SRv6 TE view
group-name: Specifies an SRv6 TE policy group by its ID in the range of 1 to 4294967295.
You can add SRv6 TE policies to an SRv6 TE policy group to implement SRv6 TE policy based forwarding according to DSCP values of packets.
# Create SRv6 TE policy group 1 and enter its view.
preference
Use preference to set the preference for an SRv6 TE policy candidate path and enter SRv6 TE policy path preference view, or enter an existing SRv6 TE policy path preference view.
Use undo preference to delete an SRv6 TE policy candidate path preference and all the configuration in the SRv6 TE policy path preference view.
preference preference-value
undo preference preference-value
The preference is not set for an SRv6 TE policy candidate path.
SRv6 TE policy candidate path view
preference-value: Specifies a candidate path preference in the range of 1 to 65535. A bigger value represents a higher preference.
A preference represents a candidate path of an SRv6 TE policy.
# Set the preference of an SRv6 TE policy candidate path to 20, and enter SRv6 TE policy path preference view.
[Sysname-srv6-te-policy-a1-path-pref-20]
rate-limit
Use rate-limit to set a rate limit for an SRv6 TE policy.
Use undo rate-limit to restore the default.
rate-limit kbps
undo rate-limit
No rate limit is set for an SRv6 TE policy.
SRv6 TE policy view
kbps: Specifies the rate limit, in the range of 1 to 4294967295, in kbps.
When the rate of the packets forwarded by an SRv6 TE policy exceeds the rate limit, the device drops the packets that exceed the rate limit.
# Set the rate limit for SRv6 TE policy aaa to 15000 kbps.
[Sysname-srv6-te] policy aaa
[Sysname-srv6-te-policy-aaa] rate-limit 15000
refresh-period
Use refresh-period to set the interval at which IPR calculates the optimal path.
Use undo refresh-period to restore the default.
refresh-period time-value
undo refresh-period
IPR calculates the optimal path at intervals of 60 seconds.
SRv6 TE IPR view
time-value: Specifies an interval for IPR to calculate the optimal path, in the range of 2 to 60 seconds.
If the source node of an SRv6 TE policy group has mappings between TE class IDs and IPR policies (configured by using the index te-class match command), it will calculate the optimal SRv6 TE policy according to the period set by using the refresh-period command. Then, it will forward traffic through this optimal SRv6 TE policy.
Periodically calculating the optimal path can ensure that services are always forwarded through an SRv6 TE policy that meets the SLA requirements and has the highest priority. You can set the period for calculating the optimal path as needed. The shorter the period, the higher the system overhead.
# Set the interval at which IPR calculates the optimal path to 20 seconds.
[Sysname-srv6-te-ipr] refresh-period 20
reoptimization
Use reoptimization to configure candidate path reoptimization for an SRv6 TE policy.
Use undo reoptimization to restore the default.
reoptimization { disable | enable [ frequency seconds ] }
undo reoptimization
Candidate path reoptimization is not configured for an SRv6 TE policy and the configuration in SRv6 TE view applies.
SRv6 TE policy view
disable: Disables candidate path reoptimization for an SRv6 TE policy.
enable: Enables candidate path reoptimization for an SRv6 TE policy.
frequency seconds: Sets the candidate path reoptimization frequency, in the range of 1 to 604800 seconds. The default frequency is 3600 seconds. If you set a frequency smaller than 60 seconds, the device performs reoptimization every 60 seconds.
This feature enables the PCE to periodically compute paths and notify the PCC to update path information, so that the SRv6 TE policy can use the optimal path to establish the candidate path.
For example, an SRv6 TE policy uses a path other than the optimal path to establish the candidate path because the optimal path does not have sufficient link bandwidth. This feature enables the SRv6 TE policy to switch the candidate path to the optimal path when the link bandwidth becomes sufficient.
You can configure candidate path reoptimization for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable candidate path reoptimization for SRv6 TE policy p1.
[Sysname-srv6-te-p1] reoptimization enable
srv6-policy reoptimization
reset segment-routing ipv6 te forwarding statistics
Use reset segment-routing ipv6 te forwarding statistics to clear forwarding statistics for SRv6 TE policies.
reset segment-routing ipv6 te forwarding statistics [ binding-sid binding-sid | color color-value endpoint endpoint-ipv6 | name name-value ]
binding-sid bsid: Specifies the BSID of an SRv6 TE policy, which is an IPv6 address.
color color-value endpoint endpoint-ipv6: Specifies the color value and end-point IPv6 address of an SRv6 TE policy. The value range for the color-value argument is 0 to 4294967295.
name policy-name: Specifies the name of an SRv6 TE policy, a case-sensitive string of 1 to 59 characters.
If you do not specify any parameters, this command clears forwarding statistics for all SRv6 TE policies.
# Clear forwarding statistics for all SRv6 TE policies.
<Sysname> reset segment-routing ipv6 te forwarding statistics
display segment-routing ipv6 te forwarding
srv6-policy forwarding statistics enable
srv6-policy forwarding statistics interval
restrict
Use restrict to configure the ODN SRv6 TE policy generation policy.
Use undo restrict to restore the default.
restrict prefix-list-name
undo restrict
A BGP route can trigger ODN to create an SRv6 TE policy when the route's color attribute value is the same as the ODN color value.
SRv6 TE ODN view
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
You can specify an IPv6 prefix list to filter BGP routes. The BGP routes permitted by the specified IPv6 prefix list can trigger ODN to create SRv6 TE policies. The BGP routes denied by the specified IPv6 prefix list cannot trigger ODN to create SRv6 TE policies.
# Permit the BGP routes in subnet 1000::/96 to trigger ODN to create SRv6 TE policies.
[Sysname] ipv6 prefix-list policy permit 1000:: 96
[Sysname-srv6-te-odn-1] restrict policy
ipv6 prefix-list (Layer 3—IP Routing Command Reference)
reverse-binding-sid
Use reverse-binding-sid to configure a reverse BSID.
Use undo reverse-binding-sid to restore the default.
reverse-binding-sid ipv6 ipv6-address
No reverse BSID exists.
SID list view
ipv6 ipv6-address: Specifies an IPv6 address as a reverse BSID.
# Configure the reverse BSID for SID list s1 as 1::1.
[Sysname-segment-routing] traffic-engineering
[Sysname-srv6-te-sl-s1] reverse-binding-sid ipv6 1::1
local-binding-sid
router-id filter
Use router-id filter to enable Router ID filtering.
Use undo router-id filter to disable Router ID filtering.
router-id filter [ bgp-rib-only ]
Router ID filtering is disabled.
BGP IPv6 SR policy address family.
bgp-rib-only: When the device receives a BGP IPv6 SR policy route and the Route Target attribute of the route does not carry the local Router ID, it accepts the route but does not generate an SRv6 TE policy accordingly.
For the device to process only part of the received BGP IPv6 SR policy routes, you can execute this command to enable filtering the routes by Router ID.
This command enables the device to check the Route Target attribute of a received BGP IPv6 SR policy route.
·     If the Route Target attribute contains the Router ID of the local device, the device accepts the route and generates an SRv6 TE policy accordingly.
·     If the Route Target attribute does not contain the Router ID of the local device, the device processes the route as follows:
¡     If the bgp-rib-only keyword is not specified in the command, the device drops the route.
¡     If the bgp-rib-only keyword is specified in the command, the device accepts the route but does not generate the corresponding SRv6 TE policy.
When the controller advertises a BGP IPv6 SR policy route to the source node, the transit nodes between the controller and the source node only need to forward the BGP IPv6 SR policy route. They do not need to generate the SRv6 TE policy. In this case, you can execute the router-id filter bgp-rib-only command on the transit nodes. Then, when a transit node receives a BGP IPv6 SR policy route, it forwards the route even if the route's Route Target attribute does not contain the Router ID of the local device. Meanwhile, it does not generate an SRv6 TE policy in order to not affect packet forwarding.
To use Router ID filtering, make sure you add Route Target attributes to BGP IPv6 SR policy routes properly by using routing policy or other methods. Otherwise, Router ID filtering might learn or drop BGP IPv6 SR policy routes incorrectly.
# Enable Router ID filtering.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] router-id filter
sbfd
Use sbfd to configure SBFD for an SRv6 TE policy.
Use undo sbfd to restore the default.
sbfd { disable | enable [ remote remote-id ] [ template template-name ] [ backup-template backup-template-name ] [ oam-sid sid ] [ encaps | insert ] [ reverse-path { path-segment | reverse-binding-sid } ] }
undo sbfd
SBFD is disabled for an SRv6 TE policy. An SRv6 TE policy uses the SBFD configuration in SRv6 TE view.
SRv6 TE policy view
disable: Disables SBFD for the SRv6 TE policy.
enable: Enables SBFD for the SRv6 TE policy.
remote remote-id: Specifies the remote discriminator of the SBFD session, in the range of 1 to 4294967295. If you do not specify this option, the configuration in SRv6 TE view applies.
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the template specified in SRv6 TE view applies.
backup-template backup-template-name: Specifies a BFD session parameter template for the backup SID list. The backup-template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option but a primary template is specified, the primary template applies. If neither the primary nor the backup template is specified in this command, the backup template specified in SRv6 TE view applies.
oam-sid sid: Adds an OAM SID to SBFD packets to identify the destination node. The sid argument represents the SRv6 SID of the endpoint destination node. If you do not specify this option, no OAM SID will be added to SBFD packets. In the current software version, specify the OAM SID as the End.OP SID of the destination node.
encaps: Uses the normal encapsulation mode to encapsulate SBFD packets.
insert: Uses the insertion mode to encapsulate SBFD packets.
reverse-path: Specifies a reverse path for SBFD packets. If you do not specify this keyword, the egress node looks up the IP forwarding table based on the source address of the received SBFD packets and forwards the return SBFD packets back to the ingress node.
path-segment: Uses the SID list with a specific path segment (End.PSID) as the reverse path for SBFD packets. A path segment is a BSID that directs traffic to the forwarding path identified by the SID list of the SRv6 TE policy associated with the BSID.
reverse-binding-sid: Uses the SID list associated with the reverse BSID as the reverse path for SBFD packets.
To use SBFD to detect an SRv6 TE policy, the device needs to encapsulate the SID list of the SRv6 TE policy for the SBFD packets. The following encapsulation modes are available:
·     Encaps—Normal encapsulation mode. It adds a new IPv6 header and an SRH to the original packets. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH.
·     Insert—Insertion mode. It inserts an SRH after the original IPv6 header. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH.
If you do not specify the encaps or insert keyword, the encapsulation mode configured by the bfd srv6-encapsulation-mode encap command applies.
To encapsulate the SBFD packets for SRv6 TE policy connectivity detection, the device uses the encapsulation mode configured for SBFD packets. The encapsulation mode configured for the SRv6 TE policy in SRv6 TE view or SRv6 TE policy view does not take effect on SBFD packets.
By default, the SBFD return packets used for SRv6 TE policy connectivity detection are forwarded based on the IP forwarding path. If a transit node fails, all the return packets will be discarded, and the SBFD sessions will go down as a result. SBFD thus will mistakenly determine that all the SID lists of the SRv6 TE policy are faulty. To resolve this issue, you can enable SBFD return packets to be forwarded based on the specified SID list, implementing SBFD forward and reverse path consistency. The following methods are available to implement SBFD forward and reverse path consistency:
·     Specifying a reverse BSID—If you specify the reverse-path reverse-binding-sid option, the source node encapsulates the Aux Path TLV that contains the reverse BSID in SBFD packets. The reverse BSID can be specified by using the explicit segment-list command with the reverse-binding-sid parameter or the reverse-binding-sid command. When the endpoint node receives the SBFD packets, it parses the Aux Path TLV to obtain the reverse BSID. If the reverse BSID is the same as the local BSID of an SRv6 TE policy on the endpoint node, the endpoint node encapsulates an SRH in the SBFD packets and forwards the packets along the SID list of the SRv6 TE policy to which the local BSID belongs. To configure a local BSID, you can use the local-binding-sid command. In this method, the Aux Path TLV is carried in the payload of an SBFD packet, which might cause incompatibility issues with other vendors.
·     Specifying a path segment—A path segment is a type of BSID. With the reverse-path path-segment keyword specified, the source node encapsulates a path segment, or End.PSID, in the SRH header's SID list at the SRH[SL+1] position. SL+1 equals the sum of the number of SIDs in the SID list on the source node, and the source node's next hop is SRH[SL]. The encapsulated path segment can be specified by using the local-path-segment parameter in the explicit segment-list command. At the same time, set the fifth bit of the Flags field in the SRH header, known as the P-flag, to indicate that the SRH header carries a path segment. After the endpoint node receives the SBFD packet and finds that the P-flag is set, it retrieves the path segment. If the path segment in the packet’s SRH matches the reverse path segment specified for an SID list of an SRv6 TE policy, the endpoint node encapsulated the SBFD packet with SRH carrying that SID list, and forwards the packet along the represented path. Using path segment can prevent compatibility issues between vendors.
You can configure SBFD for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
The remote discriminator specified in this command must be the same as that specified in the sbfd local-discriminator command on the reflector. Otherwise, the reflector will not send responses to the initiator.
The device supports the echo packet mode BFD and the SBFD for an SRv6 TE policy. If both modes are configured for the same SRv6 TE policy, the SBFD takes effect.
When this command specifies both the oam-sid and path-segment parameters, and the explicit segment-list command is executed with the local-path-segment parameter specified, the oam-sid parameter will not take effect.
If the SID lists of an SRv6 TE policy end with a 16-bit G-SID that carries a COC flavor, use the normal encapsulation mode to encapsulate BFD or SBFD packets. If BFD or SBFD packets are encapsulated in insertion mode, BFD or SBFD session setup might fail.
# Enable SBFD for SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] sbfd enable
display segment-routing ipv6 te sbfd
local-binding-sid
reverse-binding-sid
sbfd local-discriminator (High Availability Command Reference)
srv6-policy sbfd
segment-list
Use segment-list to create a SID list and enter its view, or enter the view of an existing SID list.
Use undo segment-list to delete a SID list and all the configuration in the SID list.
segment-list segment-list-name
undo segment-list segment-list-name
No SID lists exist.
SRv6 TE view
segment-list-name: Specifies the SID list name, a case-sensitive string of 1 to 128 characters.
# Create a SID list named abc and enter its view.
[Sysname-srv6-te] segment-list abc
[Sysname-srv6-te-sl-abc]
segments
Use segments to create the segment constraints and enter its view, or enter the existing segment constraints view.
Use undo segments to delete the segment constraints view and all its configurations.
segments
undo segments
No segment constraints exist.
Constraints view
# Create the segment constraints and enter its view.
[Sysname-srv6-te-policy-a1-path-pref-200-const] segments
[Sysname-srv6-te-policy-a1-path-pref-200-const-seg]
service-class
Use service-class to set a service class value for an SRv6 TE policy.
Use undo service-class to restore the default.
service-class service-class-value
undo service-class
No service class value is set for an SRv6 TE policy. The service class value is 255 with the lowest forwarding priority.
SRv6 TE policy view
service-class-value: Specifies a service class value. The value range for this argument is 1 to 15. The smaller the service class value, the lower the SRv6 TE policy priority. An SRv6 TE policy that is not assigned a service class value has the lowest priority.
The device compares the service class value of the traffic with the service class values of SRv6 TE policies and forwards the traffic to a matching tunnel. The device uses the following rules to select an SRv6 TE policy to forward the traffic:
·     If the traffic matches only one SRv6 TE policy, the device uses this SRv6 TE policy.
·     If the traffic matches multiple SRv6 TE policies, the device selects an SRv6 TE policy based on the flow identification and load sharing mode:
¡     If only one flow exists and flow-based load sharing is used, the device randomly selects a matching SRv6 TE policy for packets of the flow.
¡     If multiple flows exist or if one flow exists but packet-based load sharing is used, the device uses all matching SRv6 TE policies to load share the packets.
For more information about the flow identification and load sharing mode, see the ip load-sharing mode command.
·     If the traffic does not match any SRv6 TE policy, the device randomly selects an SRv6 TE policy from all SRv6 TE policies with the lowest forwarding priority. An SRv6 TE policy that has a smaller service class value has a lower forwarding priority. An SRv6 TE policy that is not configured with a service class value has the lowest priority.
To set a service class value for traffic, use the remark service-class command in traffic behavior view.
# Set the service class value to 5 for SRv6 TE policy.
[Sysname-srv6-te-policy-1] service-class 5
ip load-sharing mode (Layer 3IP Services Command Reference)
remark service-class (ACL and QoS Command Reference)
shutdown
Use shutdown to shut down an SRv6 TE policy.
Use undo shutdown to bring up an SRv6 TE policy.
shutdown
An SRv6 TE policy is not administratively shut down.
SRv6 TE policy view
If multiple SRv6 TE policies exist on the device, you can shut down unnecessary SRv6 TE policies to prevent them from affecting traffic forwarding.
# Shut down SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] shutdown
sid-algorithm
Use sid-algorithm to specify a Flex-Algo for an SRv6 TE policy.
Use undo sid-algorithm to restore the default.
sid-algorithm algorithm-id
undo sid-algorithm
No Flex-Algo is associated with an SRv6 TE policy.
Segment constraints view
algorithm-id: Specifies a Flex-Algo by its ID in the range of 128 to 255.
The SRv6 TE policy will use the specified Flex-Algo to calculate forwarding paths.
# In segment constraints view, specify Flex-Algo 128 for the SRv6 TE policy.
[Sysname-srv6-te-policy-a1-path-pref-200-const-seg] sid-algorithm 128
# In SRv6 TE ODN dynamic view, specify Flex-Algo 128 for the SRv6 TE policy.
[Sysname-srv6-te-odn-1-dynamic] sid-algorithm 128
sid-limit
Use sid-limit to configure the maximum number of SIDs in an SID list.
Use undo sid-limit to restore the default.
sid-limit limit-value
undo sid-limit
The maximum number of SIDs in an SID list is 10 for the following cards:
Card category
Cards
CEPC
CSPEX
SPE
RX-SPE200-E
The maximum number of SIDs in an SID list is 5 for the following cards:
Card category
Cards
CEPC
CSPEX
SPE
RX-SPE200
OAA
IM-NGFWX-IV
Metric type view
limit-value: Specifies the maximum number of SIDs in an SID list, in the range of 1 to 255.
If the number of SIDs for the calculated paths exceeds the specified value, path calculation based on the specified metric (in the type command) fails for the SRv6 TE policy. The SRv6 TE policy cannot be used to forward traffic.
The effective maximum number of SIDs takes the smaller value among the following settings:
·     Maximum number of SIDs configured in this command.
# Specify the maximum number of SIDs in the SID list as 10.
[Sysname-srv6-te-policy-a1-path-pref-200] dynamic
[Sysname-srv6-te-policy-a1-path-pref-200-dyna] metric
[Sysname-srv6-te-policy-a1-path-pref-200-dyna-metric] sid-limit 10
snmp-agent trap enable srv6-policy
Use snmp-agent trap enable srv6-policy to enable SNMP notifications for SRv6 TE policies.
Use undo snmp-agent trap enable srv6-policy to disable SNMP notifications for SRv6 TE policies.
SNMP notifications for SRv6 TE policies are disabled.
This command enables the device to send SNMP notifications about state changes and resource usage anomalies of SRv6 TE policies. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
SRv6 TE policy resources include the following:
·     Number of SRv6 TE policy forwarding paths.
·     Number of forwarding entry IDs of SRv6 TE policy groups.
·     Number of forwarding entry IDs of SRv6 TE policies.
·     Number of forwarding entry IDs of SID lists.
# Enable SNMP notifications for SRv6 TE policies.
[Sysname] snmp-agent trap enable srv6-policy
sr-policy steering
Use sr-policy steering to configure the traffic steering mode for SRv6 TE policies.
Use undo sr-policy steering to restore the default.
sr-policy steering { disable | policy-based }
The device steers data packets to SRv6 TE policies based on colors of the packets.
BGP instance view
disable: Disables the color-based mode. The tunnel policy-based mode is enabled. The device selects a tunnel policy from the following tunnel policies (listed in descending order of priority) for traffic steering:
1.     Tunnel binding policy configured by using the binding-destination command.
2.     Preferred tunnel policy configured by using the preferred-path command.
3.     Tunnel load sharing policy configured by using the select-seq load-balance-number command.
policy-based: Enables both the tunnel policy-based mode and the color-based mode.
·     If the BGP route contains a color extended community, the device selects a traffic steering method from the following methods (listed in descending order of priority):
a.     Tunnel binding policy configured by using the binding-destination command.
b.     Tunnel load sharing policy configured by using the select-seq load-balance-number command.
If this method is selected, the device will preferentially select the tunnel that matches the color extended community of the BGP route, and then perform route recursion accordingly. The device looks up for a tunnel in the configured tunnel selection order only if it cannot find a tunnel that matches the color extended community of the BGP route.
c.     Color-based traffic steering.
·     If the BGP route does not contain a color extended community, the device selects a traffic steering method from the following methods (listed in descending order of priority):
d.     Tunnel binding policy configured by using the binding-destination command.
e.     Preferred tunnel policy configured by using the preferred-path command.
f.     Tunnel load sharing policy configured by using the select-seq load-balance-number command.
SRv6 TE policies support color-based traffic steering and tunnel policy-based traffic steering. The two traffic steering modes function as follows:
·     Based on color—The device searches for an SRv6 TE policy with the color value and end-point that match the color extended community attribute and nexthop address of a BGP route. If a matching SRv6 TE policy exists, the device recurse the BGP route to that SRv6 TE policy. Then, when the device receives packets that match the BGP route, it forwards the packets through the SRv6 TE policy.
·     Based on tunnel policy—The device looks up the configured tunnel policies for a matching SRv6 TE policy, and then uses that policy as the public-network tunnel to forward packets that match the BGP route. Tunnel policies can be further divided into tunnel binding policies, preferred tunnel policies, and tunnel load sharing policies. If multiple of them are configured, their priorities are different during tunnel policy selection. For more information about the tunnel policy configuration, see tunnel policy configuration in MPLS Configuration Guide.
This command does not take effect in L2VPN networks.
# Enable both color-based traffic steering and tunnel policy-based traffic steering to SRv6 TE policies.
[Sysname] bgp 100
[Sysname-bgp-default] sr-policy steering policy-based
sr-te frr enable
Use sr-te frr enable to enable SRv6 TE FRR.
Use undo sr-te frr enable to disable SRv6 TE FRR.
sr-te frr enable [ downgrade ]
SRv6 TE FRR is disabled.
SRv6 view
downgrade: Enables SRv6 BE FRR. If you specify this keyword, the proxy forwarding node uses the last SRv6 SID in the SID list as the destination address, and forwards packets to the destination node in SRv6 BE mode.
After SRv6 TE FRR (also called transit node protection) is enabled, when a transit node of an SRv6 TE policy fails, the upstream node of the faulty node can take over to forward packets. The upstream node is called a proxy forwarding node.
After SRv6 TE FRR is enabled on a node, upon receiving a packet that contains an SRH and the SL in the SRH is greater than 1 (SL>1), the node will act as a proxy forwarding node in any of the following scenarios:
·     The node does not find a matching forwarding entry in the IPv6 FIB.
·     The next hop address of the packet is the destination address of the packet, and the outgoing interface for the destination address is in DOWN state.
·     The matching local SRv6 SID is an END.X SID, and the outgoing interface for the END.X SID is in DOWN state.
·     The outgoing interface in the matching route is NULL0.
A proxy forwarding node forwards packets as follows:
·     Decrements the SL value in the SRH of a packet by 1.
·     Copies the next SID to the DA field in the outer IPv6 header, so as to use the SID as the destination address of the packet.
·     Looks up the forwarding table by the destination address and then forwards the packet.
In this way, the proxy forwarding node bypasses the faulty node. This transit node failure protection technology is referred to as SRv6 TE FRR.
In a complex network, any node might act as a transit node. As a best practice to improve the whole network security, enable SRv6 TE FRR on all nodes.
As a best practice to ensure fast path switchover, do not enable SRv6 TE policy transit node protection and TI-LFA FRR on a node simultaneously. If they are enabled simultaneously, TI-LFA FRR takes precedence over SRv6 TE policy transit node protection. Traffic forwarding restores to normal only after the node finishes route convergence.
Transit node failure protection might fail if SRv6 compression is also enabled. Traffic cannot bypass the SRv6 SID of the faulty node, because the SRv6 SIDs in the SID list of the SRv6 TE policy are related with each another. To address this issue, configure the sr-te frr enable command with the downgrade keyword specified, and make sure the last SRv6 SID in the SID list is not compressed. The proxy forwarding node can then use the last SRv6 SID in the SID list as the destination address for forwarding to implement transit node failure protection.
Suppose you configure the sr-te frr enable command with the downgrade keyword specified for the transit node. Then, a transit node failure occurs and triggers transit node failure protection. To enable echo packet mode BFD for the SRv6 TE policy, you must specify the encaps keyword (normal encapsulation mode) when executing the bfd echo command.
# Enable SRv6 TE FRR.
[Sysname-segment-routing-ipv6] sr-te frr enable
bfd echo
srv6-policy alarm-threshold
Use srv6-policy alarm-threshold to configure the alarm thresholds for resource usage of SRv6 TE policies.
Use undo srv6-policy alarm-threshold to restore the default.
srv6-policy { forwarding-path | policy | policy-group | segment-list } alarm-threshold upper-limit upper-limit-value lower-limit lower-limit-value
undo srv6-policy { forwarding-path | policy | policy-group | segment-list } alarm-threshold
The upper and lower alarm thresholds are 80% and 75% for all resources of SRv6 TE policies.
SRv6 TE view
forwarding-path: Specifies the number of SRv6 TE policy forwarding paths.
policy: Specifies the number of forwarding entry IDs assigned to SRv6 TE policies.
policy-group: Specifies the number of forwarding entry IDs assigned to SRv6 TE policy groups.
segment-list: Specifies the number of forwarding entry IDs assigned to SID lists.
upper-limit upper-limit-value: Specifies the upper threshold in percentage for SRv6 TE policy resources. The value range for the upper-limit-value argument is 1 to 100.
lower-limit lower-limit-value: Specifies the lower threshold in percentage for SRv6 TE policy resources. The value range for the upper-limit-value argument is 1 to 100.
When the number of SRv6 TE policy resources crosses the upper threshold or lower threshold, the device generates log and alarm information. The administrator can then obtain the resource usage status of SRv6 TE policies.
Before configuring this command, enable the logging and SNMP notifications features for SRv6 TE policies.
To view resource usage for the current SRv6 TE policy, use the display segment-routing ipv6 te policy statistics command.
# Configure the upper and lower thresholds as 90% and 60% for the number of forwarding entry IDs assigned to SID lists.
[Sysname-srv6-te] srv6-policy segment-list alarm-threshold upper-limit 90 lower-limit 60
srv6-policy log enable
srv6-policy autoroute enable
Use srv6-policy autoroute enable to enable automatic route advertisement for SRv6 TE policies and SRv6 TE policy groups.
Use undo srv6-policy autoroute enable to disable automatic route advertisement for SRv6 TE policies and SRv6 TE policy groups.
In IS-IS IPv6 address family view:
srv6-policy autoroute enable [ level-1 | level-2 ]
In OSPFv3 view:
Automatic route advertisement for SRv6 TE policies and SRv6 TE policy groups is disabled.
OSPFv3 view
level-1: Enables automatic route advertisement for Level-1 IS-IS SRv6 TE policies and SRv6 TE policy groups.
level-2: Enables automatic route advertisement for Level-2 IS-IS SRv6 TE policies and SRv6 TE policy groups.
Only IPv6 IS-IS supports automatic route advertisement for both SRv6 TE policies and SRv6 TE policy groups. OSPFv3 supports automatic route advertisement only for SRv6 TE policies.
·     For IPv6 IS-IS:
With automatic route advertisement enabled, the system takes an SRv6 TE policy or SRv6 TE policy group tunnel as a direct link to participate in IGP route computation, allowing traffic to be forwarded through the SRv6 TE policy or SRv6 TE policy group tunnel.
If you do not specify the level-1 or level-2 keyword, the srv6-policy autoroute enable command enables automatic route advertisement for both levels of SRv6 TE policies and SRv6 TE policy groups.
Use the srv6-policy autoroute enable command in conjunction with the autoroute enable command in SRv6 TE policy view and SRv6 TE policy group view. The autoroute enable command allows an SRv6 TE policy tunnel or an SRv6 TE policy group tunnel to participate in route computation.
If you use the autoroute enable command both for an SRv6 TE policy group and an SRv6 TE policy, and the SRv6 TE policy group tunnel and SRv6 TE policy tunnel form ECMP routes, the device preferentially forwards traffic through the SRv6 TE policy group tunnel.
·     For OSPFv3:
With automatic route advertisement enabled, the system takes an SRv6 TE policy tunnel as a direct link to participate in IGP route computation, allowing traffic to be forwarded through the SRv6 TE policy tunnel.
Use the srv6-policy autoroute enable command in conjunction with the autoroute enable command in SRv6 TE policy view. The autoroute enable command allows an SRv6 TE policy tunnel to participate in route computation.
# Enable automatic route advertisement for SRv6 TE policies of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] srv6-policy autoroute enable
# Enable automatic route advertisement for SRv6 TE policies of OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] srv6-policy autoroute enable
autoroute enable
srv6-policy backup hot-standby enable
Use srv6-policy backup hot-standby enable to enable hot standby for all SRv6 TE policies.
Use undo srv6-policy backup hot-standby enable to disable hot standby for all SRv6 TE policies.
Hot standby is disabled for all SRv6 TE policies.
SRv6 TE view
The hot standby feature takes the candidate path with the greatest preference value in the SRv6 TE policy as the primary path and that with the second greatest preference value as the standby path. When the forwarding paths corresponding to all SID lists of the primary path fails, the standby path immediately takes over to minimize service interruption.
You can enable hot standby for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable hot standby for all SRv6 TE policies.
[Sysname-srv6-te] srv6-policy backup hot-standby enable
backup hot-standby
srv6-policy bfd echo
Use srv6-policy bfd echo to enable the echo packet mode BFD for all SRv6 TE policies.
Use undo srv6-policy bfd echo to disable the echo packet mode BFD for all SRv6 TE policies.
srv6-policy bfd echo source-ipv6 ipv6-address [ template template-name ] [ backup-template backup-template-name ] [ reverse-path { reverse-binding-sid | xsid } ]
The echo packet mode BFD is disabled for all SRv6 TE policies.
SRv6 TE view
source-ipv6 ipv6-address: Specifies the source IPv6 address of the BFD session.
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the BFD session uses multihop BFD session settings configured in system view.
backup-template backup-template-name e: Specifies a BFD session parameter template for the backup SID list. The backup-template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the BFD session uses multihop BFD session settings configured in system view.
reverse-path: Specifies the reverse path for BFD packets. If you do not specify this keyword, the device forwards BFD packets back to the source node based on the IP forwarding path.
reverse-binding-sid: Uses the SID list associated with the reverse BSID as the reverse path for BFD packets.
xsid: Used the SID list associated with the End.XSID as the reverse path for BFD packets. An End.XSID is a BSID that directs traffic to the forwarding path identified by the SID list of the SRv6 TE policy associated with the BSID.
You can configure the echo packet mode BFD for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
By default, the BFD return packets used for SRv6 TE policy connectivity detection are forwarded based on the IP forwarding path. If a transit node fails, all the return packets will be discarded, and the BFD sessions will go down as a result. BFD thus will mistakenly determine that all the SID lists of the SRv6 TE policy are faulty. To resolve this issue, you can enable BFD return packets to be forwarded based on the specified SID list to implement BFD forward and reverse path consistency. The following methods are available to implement BFD forward and reverse path consistency:
·     Specifying a reverse BSID—After the reverse-path reverse-binding-sid parameters are configured, the source node will insert an SRH header into a BFD packet and encapsulate the reverse BSID to the SL=1 position in the SRH header. You can specify the reverse BSID by using the explicit segment-list or reverse-binding-sid command. Upon receiving the BFD packet, the endpoint node retrieves the reverse BSID. If the reverse BSID matches the local BSID of an SRv6 TE policy on the endpoint node, the endpoint node inserts a new SRH into the BFD packet and forwards the packet along the SID list of that SRv6 TE policy. (To specify a local BSID for an SRv6 TE policy, use the local-binding-sid command.)
·     Specifying an End.XSID—End.XSID is also a type of BSID. After the reverse-path xsid parameters are configured, the source node will add a new IPv6 header and SRH header for the original BFD packet (the Encaps mode). The End.XSID will be encapsulated to the SL=0 position in the new SRH. You can specify this End.XSID by using the local-xsid parameter in the explicit segment-list command. Upon receiving the BFD packet, the endpoint node retrieves the End.XSID information. If the End.XSID matches the local BSID of an SRv6 TE policy at the endpoint node, the endpoint nodes executes the End.XSID forwarding behavior. This involves decapsulating the IPv6 and SRH headers of the BFD packet and then encapsulating new IPv6 and SRH headers. The new SRH extension header carries the SID list in the candidate path of the SRv6 TE policy, directing the return packet to follow this SID list.
# Enable the echo packet mode BFD for all SRv6 TE policies, and specify the source IPv6 address of the BFD session as 11::11.
[Sysname-srv6-te] srv6-policy bfd echo source-ipv6 11::11
bfd echo
display segment-routing ipv6 te bfd
srv6-policy bfd first-fail-timer
Use srv6-policy bfd first-fail-timer to configure the timer that delays reporting the first BFD or SBFD session establishment failure to an SRv6 TE policy.
Use undo srv6-policy bfd first-fail-timer to restore the default.
srv6-policy bfd first-fail-timer seconds
The timer that delays reporting the first BFD or SBFD session establishment failure to an SRv6 TE policy is 60 seconds.
SRv6 TE view
seconds: Specifies the timeout time that reports the first BFD or SBFD session establishment failure to an SRv6 TE policy. The value range for this argument is 1 to 600 seconds. The default value is 60.
The device attempts to establish a BFD or SBFD session to detect an SRv6 TE policy when all the following conditions exist:
·     The SRv6 TE policy is in up state.
·     The SID list of the SRv6 TE policy is in up state.
·     BFD or SBFD is enabled for the SRv6 TE policy.
When the BFD/SBFD session detection timer expires, if the BFD or SBFD session is not in up state, the device considers that the BFD or SBFD session establishment fails. The device does not immediately report the failure to the SRv6 TE policy. You can configure this command to set a delay timer for reporting the session establishment failure. The device will report the session establishment failure to the SRv6 TE policy upon expiration of the delay timer.
# Configure the timer that delays reporting the first BFD or SBFD session establishment failure to an SRv6 TE policy as 30 seconds.
[Sysname-srv6-te] srv6-policy bfd first-fail-timer 30
srv6-policy bfd no-bypass
Use srv6-policy bfd no-bypass to globally enable the BFD No-Bypass feature for all SRv6 TE policies.
Use undo srv6-policy bfd no-bypass to globally disable the BFD No-Bypass feature for all SRv6 TE policies.
The BFD No-Bypass feature is disabled. When all SID lists for the primary candidate path fail, BFD/SBFD packets can be forwarded through the local protection path.
SRv6 TE view
When you use BFD/SBFD to detect connectivity of an SRv6 TE policy, the following conditions might exist:
·     All SID lists for the primary candidate path fail.
·     A local protection path (for example, a backup path calculated with TI-LFA) is available.
In this situation, all the BFD/SBFD packets will be forwarded through the local protection path. The BFD/SBFD session and primary candidate path will remain in up status, and traffic will be forwarded through the local protection path.
In certain scenarios, the local protection path might have unstable bandwidth and delay issues and fail to meet specific service requirements. In this case, the local protection path can only be used to protect traffic temporarily. When you enable the BFD No-Bypass feature, if all SID lists for the primary candidate path fail, the local protection path does not forward BFD/SBFD packets. The associated BFD/SBFD session then goes down, and the primary candidate path goes down as a result. Traffic will switch over to the backup candidate path or another SRv6 TE policy for forwarding. The BFD No-Bypass feature prevents traffic from being forwarded through the local protection path for a long time.
You can enable the BFD No-Bypass feature for the source node and SRH flag check for transit nodes of the SRv6 TE policy to meet the following requirements:
·     Prevent traffic from being forwarded through the local protection path for a long time.
·     Prevent BFD/SBFD packets from being forwarded through the local protection path.
After you can enable the BFD No-Bypass feature for the source node of the SRv6 TE policy, the source node sets the No-Bypass and No-FRR flag bits when encapsulating the SRH for packets.
You can enable the BFD No-Bypass feature for all SRv6-TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
The Bypass and No-Bypass features of an SRv6 TE policy also take effect on BFD or SBFD packets of that SRv6 TE policy. For BFD or SBFD packets, the status of the Bypass and No-Bypass features is determined by the following commands in descending order:
1.     The forward { no-bypass | bypass } command in SRv6 TE policy view.
2.     The srv6-policy forward no-bypass command in SRv6 TE view.
3.     The bfd { no-bypass | bypass } command in SRv6 TE policy view.
4.     The srv6-policy bfd no-bypass command in SRv6 TE view.
In an SRv6 network slicing scenario, the Bypass or BFD Bypass feature in an SRv6 TE policy cannot take effect on BFD or SBFD packets of that SRv6 TE policy if NSIs are applied to the candidate paths of that SRv6 TE policy and BFD or SBFD is configured to detect the connectivity of that SRv6 TE policy. BFD or SBFD packets are forced to not be forwarded through the local protection path.
# Globally enable the BFD No-Bypass feature for all SRv6 TE policies.
[Sysname-srv6-te] srv6-policy bfd no-bypass
srv6-policy bfd trigger path-down enable
Use srv6-policy bfd trigger path-down enable to enable BFD session down events to trigger SRv6 TE policy path reselection globally.
Use undo srv6-policy bfd trigger path-down enable to disable BFD session down events to trigger SRv6 TE policy path reselection globally.
The feature for triggering SRv6 TE policy path reselection with BFD session down events is disabled globally.
SRv6 TE view
By default, when the SRv6 TE policy has multiple valid candidate paths, the following conditions exist:
·     If the hot standby feature is disabled, BFD or SBFD detects all SID lists for only the optimal valid candidate path of the SRv6 TE policy. The device establishes a BFD or SBFD session for each SID list. When all BFD or SBFD sessions go down, the SRv6 TE policy will not select other valid candidate paths, and the device will not forward packets through the SRv6 TE policy.
·     If the hot standby feature is enabled, BFD or SBFD detects all SID lists for the primary and backup paths of the SRv6 TE policy. The device establishes a BFD or SBFD session for each SID list.
¡     If all BFD or SBFD sessions for the primary path go down, the SRv6 TE policy will use the backup path to forward packets without reselecting other valid candidate paths.
¡     If all BFD or SBFD sessions for the primary and backup paths go down, the SRv6 TE policy will not select other valid candidate paths, and the device will not forward packets through the SRv6 TE policy.
If you enable BFD session down events to trigger SRv6 TE policy path reselection, the following conditions exist when the SRv6 TE policy has multiple valid candidate paths:
·     If the hot standby feature is disabled, BFD or SBFD detects all SID lists for only the optimal valid candidate path of the SRv6 TE policy. The device establishes a BFD or SBFD session for each SID list. When all BFD or SBFD sessions go down, the SRv6 TE policy will reselect other valid candidate paths for packet forwarding. If no valid candidate paths are available for the SRv6 TE policy, the device cannot forward packets through the SRv6 TE policy.
¡     If all BFD or SBFD sessions for the primary path go down, the SRv6 TE policy will use the backup path to forward packets, and reselect the primary and backup paths.
¡     If all BFD or SBFD sessions for the primary and backup paths go down, the SRv6 TE policy will reselect other valid candidate paths as the primary and backup paths. The device will forward packets through the new primary path of the SRv6 TE policy.
·     During optimal path reselection, if no valid candidate paths are available for the SRv6 TE policy, the device cannot forward packets through the SRv6 TE policy.
Before you enable this feature for an SRv6 TE policy, create a BFD or SBFD session for the policy first.
You can configure BFD session down events to trigger candidate path reselection for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable BFD session down events to trigger candidate path reselection for SRv6 TE policies globally.
[Sysname-srv6-te] srv6-policy bfd trigger path-down enable
bfd echo
sbfd
srv6-policy sbfd
srv6-policy calc-schedule-interval
Use srv6-policy calc-schedule-interval to configure the dynamic path calculation timers.
Use undo srv6-policy calc-schedule-interval to restore the default.
srv6-policy calc-schedule-interval { maximum-interval [ minimum-interval [ incremental-interval [ conservative ] ] ] | millisecond interval }
The maximum, minimum, and incremental intervals for dynamic path calculation are 5 seconds, 50 milliseconds, and 200 milliseconds, respectively.
SRv6 TE view
maximum-interval: Specifies the maximum dynamic path calculation interval in the range of 1 to 60 seconds. The default value is 5.
minimum-interval: Specifies the minimum dynamic path calculation interval in the range of 10 to 60000 milliseconds. The default value is 50.
incremental-interval: Specifies the incremental dynamic path calculation interval in the range of 10 to 60000 milliseconds. The default value is 200.
conservative: Uses the maximum dynamic path calculation interval in case of SRv6 TE policy flappings. If you do not specify this keyword, in case of SRv6 TE policy flappings, the maximum interval applies for three consecutive times, and then the minimum interval applies. If no SRv6 TE policy flappings occur, the maximum dynamic interval applies for once, and then the minimum interval applies, regardless of whether the conservative keyword is specified.
millisecond interval: Specifies a fixed dynamic path calculation interval in the range of 0 to 10000 milliseconds.
Use this command to avoid excessive resource consumption caused by frequent network changes.
If you specify the maximum-interval, minimum-interval, and incremental-interval settings for the command, the following situations will occur:
·     For the first path calculation triggered for the SRv6 TE policy, the minimum-interval setting applies.
·     For the nth (n > 1) path calculation triggered for the SRv6 TE policy, the device adds a value of incremental-interval × 2n-2 based on the minimum-interval setting. The total value does not exceed the maximum-interval setting.
If the value of minimum-interval + incremental-interval × 2n-2 is larger than or equal to the value of maximum-interval, the device uses the conservative keyword and SRv6 TE policy flapping condition to adjust the path calculation intervals:
·     If the conservative keyword is specified:
¡     If SRv6 TE policy flappings occur, the maximum-interval setting applies.
¡     If no SRv6 TE policy flappings occur, the maximum interval applies for once, and then the minimum interval applies.
·     If the conservative keyword is not specified:
¡     If SRv6 TE policy flappings occur, the maximum interval applies for three consecutive times, and then the minimum interval applies.
The value of the minimum-interval or incremental-interval argument cannot be greater than the maximum-interval argument.
To increase path calculation frequency for faster path calculation, configure a fixed interval.
# Configure the maximum, minimum, and incremental intervals for dynamic path calculation as 10 seconds, 500 milliseconds, and 300 milliseconds, respectively.
[Sysname-srv6-te] srv6-policy calc-schedule-interval 10 500 300
srv6-policy color priority
Use srv6-policy color priority to configure a mapping between the color attribute value of an SRv6 TE policy and a path selection priority in an IPR policy.
Use undo srv6-policy color to delete a mapping between the color attribute value of an SRv6 TE policy and a path selection priority in an IPR policy.
srv6-policy color color-value priority priority-value
undo srv6-policy color color-value
No mapping is configured between the color attribute value of an SRv6 TE policy and a path selection priority in an IPR policy.
SRv6 TE IPR policy view
color-value: Specifies the color attribute value of an SRv6 TE policy, in the range of 0 to 4294967295.
priority-value: Specifies a path selection priority in the range of 1 to 8. The smaller the value, the higher the priority.
Operating mechanism
Multiple SRv6 TE policies in an SRv6 TE policy group are distinguished by their color attribute values. You can use this command to establish a mapping between the color attribute value of each SRv6 TE policy and a path selection priority. In this way, these SRv6 TE policies are associated with different path selection priorities. If the network quality of multiple SRv6 TE policies meets the SLA requirements defined in the IPR policy, the SRv6 TE policy with the smallest priority value will be selected as the optimal forwarding path.
A valid SRv6 TE policy can be used for packet forwarding and be used as a candidate optimal forwarding path even if the following conditions exist:
·     iFIT fails to measure the network quality of that SRv6 TE policy.
·     The source node of the SRv6 TE policy group fails to obtain the network quality of that SRv6 TE policy due to reasons such as absence of traffic in the SRv6 TE policy.
If different color attribute values are mapped to the same priority and the SRv6 TE policies associated with this priority all meet the SLA requirements defined in the IPR policy, the traffic will be load-balanced among the SRv6 TE policies identified by these color attribute values.
You can specify a maximum of eight color attribute values in one IPR policy, meaning that you can specify a maximum of eight different SRv6 TE policies in a single IPR policy.
# Map the color attribute value of 1 to priority 1 in IPR policy ipr1.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] intelligent-policy-route
[Sysname-srv6-ipr] ipr-policy ipr1
[Sysname-srv6-ipr-policy-ipr1] srv6-policy color 1 priority 1
srv6-policy drop-upon-invalid enable
Use srv6-policy drop-upon-invalid enable to globally enable the feature of dropping traffic when SRv6 TE policies become invalid.
Use undo srv6-policy drop-upon-invalid enable to globally disable the drop-upon-invalid feature.
The drop-upon-invalid feature is disabled globally.
SRv6 TE view
Enable this feature for an SRv6 TE policy if you want to use only the SRv6 TE policy to forward traffic.
By default, if all forwarding paths of an SRv6 TE policy become invalid, the device forwards the packets through IPv6 routing table lookup based on the packet destination IPv6 addresses.
After you execute the drop-upon-invalid enable command, the device drops the packets if all forwarding paths of the SRv6 TE policy become invalid.
The command does not take effect when the SRv6 TE policy is invalid. To check the SRv6 TE policy validity, see the Forwarding index field in the display segment-routing ipv6 te policy command output. If the value is 0, the SRv6 TE policy is invalid.
The drop-upon-invalid command configured on the remote device does not affect an SRv6 TE policy generated based on a BGP IPv6 SR-TE policy route. The SRv6 TE policy is controlled by only the drop-upon-invalid command configured on the local device.
You can configure the drop-upon-invalid feature globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Globally enable the feature of dropping traffic when SRv6 TE policies become invalid.
[Sysname-srv6-te] srv6-policy drop-upon-invalid enable
drop-upon-invalid
srv6-policy encapsulation-mode
Use srv6-policy encapsulation-mode to enable the reduced encapsulation mode for all SRv6 TE policies globally.
Use undo srv6-policy encapsulation-mode to restore the default.
srv6-policy encapsulation-mode encaps reduced
undo srv6-policy encapsulation-mode encaps reduced
srv6-policy encapsulation-mode insert
undo srv6-policy encapsulation-mode insert
srv6-policy encapsulation-mode insert reduced
undo srv6-policy encapsulation-mode insert reduced
An SRv6 TE policy uses the normal encapsulation (Encaps) mode.
SRv6 TE view
encaps reduced: Specifies the encapsulation mode as reduced encapsulation mode.
insert: Specifies the encapsulation mode as insertion mode.
insert reduced: Specifies the encapsulation mode as reduced insertion mode.
When the device forwards a packet through an SRv6 TE policy, it must encapsulate that packet with the SID list of the SRv6 TE policy. Supported encapsulation modes include:
·     Encaps—Normal encapsulation mode. It adds a new IPv6 header and an SRH to the original packets. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH. The destination IPv6 address in the new IPv6 header is the first SID in the SID list of the SRv6 TE policy. The source IPv6 address is the IPv6 address specified by using the encapsulation source-address command.
·     Encaps.Red—Reduced mode of the normal encapsulation mode. It adds a new IPv6 header and an SRH to the original packets. The first SID in the SID list of the SRv6 TE policy is not encapsulated in the SRH to reduce the SRH length. All other SIDs in the SID list are encapsulated in the SRH. The destination IPv6 address in the new IPv6 header is the first SID in the SID list of the SRv6 TE policy. The source IPv6 address is the IPv6 address specified by using the encapsulation source-address command.
·     Insert—Insertion mode. It inserts an SRH after the original IPv6 header. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH. The destination IPv6 address in the original IPv6 header is changed to the first SID in the SID list of the SRv6 TE policy. The source IPv6 address in the original IPv6 header is not changed.
·     Insert.Red—Reduced insertion mode. It inserts an SRH after the original IPv6 header. The first SID in the SID list of the SRv6 TE policy is not encapsulated in the SRH to reduce the SRH length. All other SIDs in the SID list are encapsulated in the SRH. The destination IPv6 address in the original IPv6 header is changed to the first SID in the SID list of the SRv6 TE policy. The source IPv6 address in the original IPv6 header is not changed.
You can configure the encapsulation mode for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
The normal encapsulation modes are exclusive with the insertion modes. If you configure a normal encapsulation mode and an insertion mode alternately, the most recent configuration takes effect.
If you configure the Insert or Insert.Red mode for an SRv6 TE policy, it uses the Encaps mode to encapsulate received IPv4 packets.
In SRv6 TE view, if you execute both the srv6-policy encapsulation-mode encaps reduced command and the srv6-policy encapsulation-mode encaps include local-end.x command, the srv6-policy encapsulation-mode encaps include local-end.x command takes effect.
In SRv6 TE view, if you execute both the srv6-policy encapsulation-mode insert reduced command and the srv6-policy encapsulation-mode insert include local-end.x command, the srv6-policy encapsulation-mode insert include local-end.x command takes effect.
# Configure the Encaps.Red mode for all SRv6 TE policies globally.
[Sysname-srv6-te] srv6-policy encapsulation-mode encaps reduced
encapsulation-mode
Use srv6-policy encapsulation-mode encaps include local-end.x to configure local End.X SID encapsulation for all SRv6 TE policies using a normal encapsulation mode.
Use undo srv6-policy encapsulation-mode encaps include local-end.x to restore the default.
The device does not encapsulate the local End.X SID into the SRH of the packets forwarded by an SRv6 TE policy using a normal encapsulation mode.
SRv6 TE view
If traffic is steered to an SRv6 TE policy and the SRv6 SID of the ingress node is an End.X SID, the device does not encapsulate the End.X SID into the SRH by default.
To obtain complete SRv6 forwarding path information from the SRH of packets, use this command to configure the device to encapsulate the local End.X SID into the SRH.
You can configure the local End.X SID encapsulation for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
If you execute the srv6-policy encapsulation-mode encaps include local-end.x command and the srv6-policy encapsulation-mode insert include local-end.x command for an SRv6 TE policy, the most recent configuration takes effect.
In SRv6 TE view, if you execute both the srv6-policy encapsulation-mode encaps include local-end.x command and the srv6-policy encapsulation-mode encaps reduced command, the srv6-policy encapsulation-mode encaps include local-end.x command takes effect.
# Configure the device to include the local End.X SID in the SRH of the packets forwarded by SRv6 TE policies using a normal encapsulation mode.
[Sysname-srv6-te] srv6-policy encapsulation-mode encaps include local-end.x
Use srv6-policy encapsulation-mode insert include local-end.x to configure local End.X SID encapsulation for all SRv6 TE policies with an insertion encapsulation mode.
Use undo srv6-policy encapsulation-mode insert include local-end.x to restore the default.
The device does not encapsulate the local End.X SID into the SRH of the packets forwarded by an SRv6 TE policy with an insertion encapsulation mode.
SRv6 TE view
# Enable the device to include the local End.X SID in the SRH of the packets forwarded by SRv6 TE policies with an insertion encapsulation mode.
[Sysname-srv6-te] srv6-policy encapsulation-mode insert include local-end.x
Use srv6-policy forward no-bypass to globally enable the No-Bypass feature for SRv6 TE policies.
Use undo srv6-policy forward no-bypass to globally disable the No-Bypass feature for SRv6 TE policies.
The No-Bypass feature is disabled for SRv6 TE policies. When any SID list in the primary candidate path of an SRv6 TE policy fails, packets forwarded through that SID list can be forwarded through the local protection path.
SRv6 TE view
Application scenarios
When a node or link on the primary candidate path of an SRv6 TE policy fails and a local protection path (for example, the backup path calculated with SRv6 TE FRR or TI-LFA FRR) is available for the upstream node of the failed node or link, traffic will be forwarded through the local protection path. In this situation, the traffic might skip the failed node.
If you do not want traffic to bypass certain special SIDs in the SID lists of the SRv6 TE policy, you can enable the No-Bypass feature for the SRv6 TE policy. This feature prevents traffic steered to the SRv6 TE policy from being forwarded through the local protection path. For example, in an SRv6 SFC service chain scenario that uses an SRv6 TE policy, some SIDs represent application service nodes such as firewalls. If you do not want traffic to bypass these SIDs through the local protection path, you can enable the No-Bypass feature for the SRv6 TE policy.
To allow traffic steered to an SRv6 TE policy to be forwarded through the local protection path when the No-Bypass feature is enabled globally for all SRv6 TE policies, you can enable the Bypass feature for that SRv6 TE policy. To globally enable the No-Bypass feature for all SRv6 TE policies, use the srv6-policy forward no-bypass command in SRv6 TE view. To enable the Bypass feature for an SRv6 TE policy, use the forward bypass command.
Operating mechanism
Two flags are defined in the Flags field of an SRH, which are the No-Bypass flag and the No-FRR flag. When both flag bits are set, none of the SIDs in the SRH can be bypassed.
If the Bypass feature is enabled on the source node of an SRv6 TE policy, both the No-Bypass and No-FRR flag bits are not set in the SRH encapsulated into data packets. That is, the values for both the flag bits are 0. If the No-Bypass feature is enabled on the source node of an SRv6 TE policy, both the No-Bypass and No-FRR flag bits are set in the SRH encapsulated into data packets. That is, the values for both the flag bits are 1.
·     You can configure the Bypass and No-Bypass features for SRv6 TE policies in both SRv6 TE view and SRv6 TE policy view. The configuration in SRv6 TE view applies to all SRv6 TE policies. The configuration in SRv6 TE policy view applies only to one SRv6 TE policy. For an SRv6 TE policy, the configuration in the view of that SRv6 TE policy takes precedence over that in SRv6 TE view. If the features are not configured in the view of that SRv6 TE policy, the configuration in SRv6 TE view applies to that SRv6 TE policy.
·     The Bypass and No-Bypass features of an SRv6 TE policy also take effect on BFD or SBFD packets of that SRv6 TE policy. For BFD or SBFD packets, the status of the Bypass and No-Bypass features is determined by the following commands in descending order:
a.     The forward { no-bypass | bypass } command in SRv6 TE policy view.
b.     The srv6-policy forward no-bypass command in SRv6 TE view.
c.     The bfd { no-bypass | bypass } command in SRv6 TE policy view.
d.     The srv6-policy bfd no-bypass command in SRv6 TE view.
·     In an SRv6 network slicing scenario, the Bypass or BFD Bypass feature in an SRv6 TE policy cannot take effect on BFD or SBFD packets of that SRv6 TE policy if NSIs are applied to the candidate paths of that SRv6 TE policy and BFD or SBFD is configured to detect the connectivity of that SRv6 TE policy. BFD or SBFD packets are forced to not be forwarded through the local protection path.
·     If one SRv6 TE policy is stitched to another SRv6 TE policy through a BSID, the SID list of the first SRv6 TE policy includes the BSID of the other SRv6 TE policy. In such a scenario, SRH will modify the No-Bypass and No-FRR flag bits on the source node (stitching node) of the second SRv6 TE policy. Only when the No-Bypass feature is enabled for the second SRv6 TE policy, these two flag bits will be set.
# Globally enable the No-Bypass feature for SRv6 TE policies.
[Sysname-srv6-te] srv6-policy forward no-bypass
srv6-policy bfd { no-bypass | bypass }
srv6-policy forwarding statistics enable
Use srv6-policy forwarding statistics enable to enable traffic forwarding statistics for all SRv6 TE policies.
Use undo srv6-policy forwarding statistics enable to disable traffic forwarding statistics for all SRv6 TE policies.
srv6-policy forwarding statistics [ service-class ] enable
Traffic forwarding statistics is disabled for all SRv6 TE policies.
SRv6 TE view
service-class: Enables the SRv6 TE policy forwarding statistics by service class. This feature collects statistics on the total traffic as well as the traffic of each service class that are forwarded by SRv6 TE policies. If you do not specify this keyword, the device only collects statistics on the total traffic forwarded by SRv6 TE policies.
You can configure traffic forwarding statistics for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable traffic forwarding statistics for all SRv6 TE policies.
[Sysname-srv6-te] srv6-policy forwarding statistics enable
display segment-routing ipv6 te forwarding
reset segment-routing ipv6 te forwarding statistics
srv6-policy forwarding statistics interval
Use srv6-policy forwarding statistics interval to configure the traffic forwarding statistics interval for all SRv6 TE policies.
Use undo srv6-policy forwarding statistics interval to restore the default.
srv6-policy forwarding statistics interval interval
The SRv6 TE policies forwarding statistics interval is 30 seconds.
SRv6 TE view
interval: Specifies the SRv6 TE policy traffic forwarding statistics interval in the range of 5 to 65535, in seconds.
This command takes effect only all SRv6 TE policies.
# Set the SRv6 TE policy traffic forwarding statistics interval to 90 seconds.
[Sysname-srv6-te] srv6-policy forwarding statistics interval 90
srv6-policy ifit delay-measure enable
Use srv6-policy ifit delay-measure enable to globally enable iFIT delay and jitter measurement for SRv6 TE policies.
Use undo srv6-policy ifit delay-measure enable to restore the default.
iFIT delay and jitter measurement is globally disabled for SRv6 TE policies.
SRv6 TE view
For this command to take effect on an SRv6 TE policy, you must complete the following tasks:
·     On the source node of the SRv6 TE policy, enable iFIT, configure the iFIT device ID, set the iFIT operating mode to analyzer, and execute the service-type srv6-segment-list command.
·     On the egress node or transit nodes of the SRv6 TE policy, enable iFIT, set the iFIT operating mode to collector, and execute the service-type srv6-segment-list command.
In-situ Flow Information Telemetry (iFIT) is a type of in-situ flow OAM measurement technology. This technology measures the actual packet loss, delay, and jitter of services in the network by directly encapsulating the measurement interval, packet loss flag, and delay flag information in the iFIT option field of service packets. For more information about iFIT, see Network Management and Monitoring Configuration Guide.
When service packets are steered to an SRv6 TE policy group for forwarding and the SRv6 TE policy group uses TE class ID-based traffic forwarding, the device can select an SRv6 TE policy to forward the service packets with a specific TE class ID according to the path selection policy defined in an IPR policy.
When the iFIT delay and jitter measurement feature is enabled for SRv6 TE policies, the device performs the following operations:
1.     Measures the delay and jitter of an SRv6 TE policy through iFIT.
2.     Compares the measured delay and jitter values with the delay and jitter thresholds defined in the IPR policy where the SRv6 TE policy is specified. The measured delay and jitter values of the SRv6 TE policy are used as conditions for optimal SRv6 TE policy selection. If the measured values cross the delay and jitter thresholds, it cannot be used as a traffic forwarding path.
Operating mechanism
After iFIT delay and jitter measurement is enabled on the source node of an SRv6 TE policy, the source node and egress node of the SRv6 TE policy will measure the end-to-end delay and jitter for packets forwarded through the SRv6 TE policy. The measurement procedure is as follows:
3.     The source node automatically creates an iFIT instance and assigns a flow ID to the iFIT instance.
4.     As the data sender, the source node encapsulates the original packets with the DOH header that carries the iFIT option field and the SRH header when it forwards the packets through the SRv6 TE policy. In addition, the source node records the timestamps when the packets are forwarded through the SRv6 TE policy within an iFIT measurement interval.
5.     As the data receiver, the egress node decodes the iFIT option field of the packets to obtain the iFIT measurement interval of the SRv6 TE policy, and records the timestamps when the packets are received through the SRv6 TE policy within the iFIT measurement interval.
6.     The egress node uses the source address of the received packets to establish a UDP session with the source node and returns the packet timestamps recorded within the iFIT measurement interval to the source node. The source address can be configured by using the encapsulation source-address command on the source node.
7.     The source node analyzes and calculates the delay and jitter for the packets forwarded through the SRv6 TE policy.
iFIT can measure the delay and jitter of an SRv6 TE policy only when data traffic is being forwarded through that SRv6 TE policy.
If both the srv6-policy ifit delay-measure enable command in SRv6 TE view and the ifit delay-measure command in SRv6 TE policy view are used, the ifit delay-measure command takes effect.
If the egress node is not an H3C device, enable iFIT and set the iFIT operating mode to collector on the penultimate hop (an H3C device along the forwarding path). This H3C device will act as the data receiver to record timestamps, establish a UDP session, and provide the timestamps back to the source node to fulfill the functions of the egress node.
If multiple nodes feed back measurement data to the source node, the source node handles the data as follows:
·     If the egress node and multiple other nodes feed back measurement data to the source node, the source node prefers the data fed back from the egress node for calculating delay and jitter.
·     If multiple non-egress nodes feed back measurement data to the source node, the source node prefers the data fed back from the node closest to the egress node for calculating delay and jitter.
To ensure that iFIT measurement can correctly operate, make sure the clock on all devices participating in iFIT measurement has been synchronized. A violation causes the iFIT calculation results to be inaccurate. You can use NTP and PTP to synchronize clock between devices.
# Globally enable iFIT delay and jitter measurement for SRv6 TE policies.
[Sysname-srv6-te] srv6-policy ifit delay-measure enable
ifit enable (Network Management and Monitoring Command Reference)
ifit interval
service-type srv6-segment-list (Network Management and Monitoring Command Reference)
srv6-policy ifit interval
work-mode analyzer (Network Management and Monitoring Command Reference)
work-mode collector (Network Management and Monitoring Command Reference)
Use srv6-policy ifit interval to globally set the iFIT measurement interval for SRv6 TE policies.
Use undo srv6-policy ifit interval to restore the default.
srv6-policy ifit interval time-value
The global iFIT measurement interval is 30 seconds for SRv6 TE policies.
SRv6 TE view
time-value: Specifies an iFIT measurement interval, in seconds. The value can be 1, 10, 30, 60, or 300.
Use this command only on the source node of an SRv6 TE policy.
After you set the iFIT measurement interval, the source node of the SRv6 TE policy incorporates the measurement interval into iFIT packets and uses this measurement interval to perform the following operations:
1.     Counts the number of packets forwarded through the SRv6 TE policy and the timestamps of the packets at measurement intervals.
2.     Calculates the delay, jitter, and packet loss rate of the SRv6 TE policy at measurement intervals.
The egress node of the SRv6 TE policy obtains the measurement interval from iFIT packets and uses this interval to perform the following operations:
3.     Counts the number of packets forwarded through the SRv6 TE policy and the timestamps of the packets at measurement intervals.
4.     Provides feedback on the count and timestamps of packets to the source node of the SRv6 TE policy at measurement intervals.
If you execute both this command and the ifit interval command in SRv6 TE policy view, the ifit interval command in SRv6 TE policy view takes effect.
# Globally set the iFIT measurement interval to 60 seconds for SRv6 TE policies.
[Sysname-srv6-te] srv6-policy ifit interval 60
ifit delay-measure
ifit interval
ifit loss-measure
srv6-policy ifit loss-measure enable
Use srv6-policy ifit loss-measure enable to globally enable iFIT packet loss measurement for SRv6 TE policies.
Use undo srv6-policy ifit loss-measure enable to restore the default.
iFIT packet loss measurement is disabled globally for SRv6 TE policies.
SRv6 TE view
When the iFIT packet loss measurement feature is enabled for SRv6 TE policies, the device performs the following operations:
1.     Measures the packet loss rate of an SRv6 TE policy through iFIT.
2.     Compares the measured packet loss rate with the packet loss rate threshold defined in the IPR policy where the SRv6 TE policy is specified. The measured packet loss rate of the SRv6 TE policy is used as a condition for optimal SRv6 TE policy selection. If the measured packet loss rate crosses the packet loss rate threshold, it cannot be used as a traffic forwarding path.
Operating mechanism
After iFIT packet loss measurement is enabled on the source node of an SRv6 TE policy, the source node and egress node of the SRv6 TE policy will measure the end-to-end packet loss rate for packets forwarded through the SRv6 TE policy. The measurement procedure is as follows:
4.     As the data sender, the source node encapsulates the original packets with the DOH header that carries the iFIT option field and the SRH header when it forwards the packets through the SRv6 TE policy. In addition, the source node counts the number of packets forwarded through the SRv6 TE policy within an iFIT measurement interval.
5.     As the data receiver, the egress node decodes the iFIT option field of the packets to obtain the iFIT measurement interval of the SRv6 TE policy, and counts the number of packets received through the SRv6 TE policy within the iFIT measurement interval.
6.     The egress node uses the source address of the received packets to establish a UDP session with the source node and returns the packet count statistics within the iFIT measurement interval to the source node. The source address can be configured by using the encapsulation source-address command on the source node.
7.     The source node analyzes and calculates the packet loss rate for the packets forwarded through the SRv6 TE policy.
iFIT can measure the packet loss rate of an SRv6 TE policy only when data traffic is being forwarded through that SRv6 TE policy.
If both the srv6-policy ifit loss-measure enable command in SRv6 TE view and the ifit loss-measure command in SRv6 TE policy view are used, the ifit loss-measure command takes effect.
If the egress node is not an H3C device, enable iFIT and set the iFIT operating mode to collector on the penultimate hop (an H3C device along the forwarding path). This H3C device will act as the data receiver to collect packet statistics, establish a UDP session with the source node, and provide the packet statistics back to the source node to fulfill the functions of the egress node.
·     If the egress node and multiple other nodes feed back measurement data to the source node, the source node prefers the data fed back from the egress node for calculating packet loss rate.
·     If multiple non-egress nodes feed back measurement data to the source node, the source node prefers the data fed back from the node closest to the egress node for calculating packet loss rate.
# Globally enable iFIT packet loss measurement for SRv6 TE policies.
[Sysname-srv6-te] srv6-policy ifit loss-measure enable
ifit interval
srv6-policy ifit measure mode
Use srv6-policy ifit measure mode to globally specify an iFIT measurement mode for SRv6 TE policies.
Use undo srv6-policy ifit measure mode to restore the default.
srv6-policy ifit measure mode { e2e | trace }
The iFIT measurement mode is end-to-end mode for SRv6 TE policies.
SRv6 TE view
e2e: Specifies the end-to-end mode. In this mode, only the egress node of an SRv6 TE policy feeds back iFIT measurement results to the source node for calculating the network quality of the SRv6 TE policy.
trace: Specifies the hop-by-hop mode. In this mode, a node along the forwarding path of a target flow feeds back measurement results to the source node of an SRv6 TE policy for calculating the network quality of the SRv6 TE policy as long as iFIT is enabled and iFIT packets are detected on that node.
Recommended configuration
·     If the egress node of an SRv6 TE policy is not an H3C device, you must set the iFIT measurement mode to hop-by-hop mode. In this case, enable iFIT and set the iFIT operating mode to collector on the penultimate hop (an H3C device along the forwarding path). This H3C device will act as the data receiver to collect packet statistics, establish a UDP session with the source node, and provide the packet statistics back to the source node to fulfill the functions of the egress node. Typically, hop-by-hop mode is applicable to scenarios where the egress node of an SRv6 TE policy is not an H3C device.
·     If both the source and egress nodes of an SRv6 TE policy are H3C devices, set the iFIT measurement mode to end-to-end mode as a best practice. In this mode, the egress node feeds back the iFIT measurement results to the source node of the SRv6 TE policy for calculating the network quality of the SRv6 TE policy. Even if the transit nodes along the forwarding path of a target flow have enabled iFIT and detected iFIT packets, they will not feed back the iFIT measurement results to the source node of the SRv6 TE policy. This mechanism reduces the complexity of device processing.
Operating mechanism
After you specify an iFIT measurement mode for an SRv6 TE policy, the source node of the SRv6 TE policy includes the iFIT measurement mode in the iFIT option field of packets. The packets notify the devices along the forwarding path of the iFIT measurement mode during the forwarding process.
When the iFIT measurement mode of an SRv6 TE policy is set to end-to-end mode, only the egress node that has enabled iFIT and detected iFIT packets feeds back measurement data to the source node through a UDP session. Transit nodes do not feed back measurement data to the source node.
When the iFIT measurement mode of an SRv6 TE policy is set to hop-by-hop mode, all nodes along the forward path of a target flow that have enabled iFIT and detected iFIT packets feed back measurement data to the source node through UDP sessions. The source node selects measurement data for calculating network quality. If multiple non-egress nodes feed back data to the source node, the source node prefers the data fed back from the node closest to the egress node of the SRv6 TE policy for calculating network quality.
If both the ifit measure mode command in SRv6 TE policy view and the srv6-policy ifit measure mode command in SRv6 TE view, the ifit measure mode command in SRv6 TE policy view takes effect.
# Globally set the iFIT measurement mode to hop-by-hop mode for SRv6 TE policies.
[Sysname-srv6-te] srv6-policy ifit measure mode trace
ifit measure mode
srv6-policy immediate-reoptimization
Use srv6-policy immediate-reoptimization to immediately reoptimize all SRv6 TE policies enabled with candidate path optimization.
After an SRv6 TE policy is enabled with candidate path optimization, you can execute this command to trigger an immediate optimization to switch the candidate path of the SRv6 TE policy to the optimal path.
# Immediately reoptimize all SRv6 TE policies enabled with candidate path optimization.
<Sysname> srv6-policy immediate-reoptimization
srv6-policy locator
Use srv6-policy locator to specify a locator for SRv6 TE.
Use undo srv6-policy locator to cancel the locator configuration.
srv6-policy locator locator-name [ coc-next | next ]
No locator is specified for SRv6 TE.
SRv6 TE view
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters.
coc-next: Adds the COC and NEXT flavors to BSIDs assigned from the locator. If neither of the coc-next and next keywords is specified, those BSID do not carry the COC or NEXT flavor.
next: Adds the NEXT flavors to BSIDs assigned from the locator. If neither of the coc-next and next keywords is specified, those BSID do not carry the COC or NEXT flavor.
The locator specified in SRv6 TE view is used for BSID assignment, restricting the BSID range. After you execute the binding-sid command, only BSIDs within the locator specified in the srv6-policy locator command can take effect.
You cannot change the locator for SRv6 TE by repeatedly executing this command. To change the locator, first execute the undo srv6-policy locator command to remove the specified locator and then execute the srv6-policy locator command to specify a new locator.
When a BSID carries the COC and NEXT flavors or only the NEXT flavor, it can be encapsulated into SRv6 packet headers as a 16-bit G-SID, which shortens SRv6 packet headers.
Support for BSID flavors varies by locator type. When you use the binding-sid command to specify flavors for a BSID, follow these restrictions and guidelines:
·     Make sure the locator specified in the srv6-policy locator command meets the related requirements. For example:
¡     The coc-next keyword is available only if the specified locator is a COC16 locator in default mode.
¡     The next keyword is available only if the specified locator is a COC16 locator.
·     If the specified locator is a COC16 locator in W-LIB mode, you must specify the next keyword to ensure successful BSID assignment.
# Specify locator test1 in SRv6 TE view.
[Sysname-srv6-te] srv6-policy locator test1
Use srv6-policy log enable to enable SRv6 TE policy logging.
Use undo srv6-policy log enable to disable SRv6 TE policy logging.
SRv6 TE policy logging is disabled.
SRv6 TE view
This command enables the device to generate logs for SRv6 TE policy state changes and resource usage anomalies. The administrator can use the logging information to audit SRv6 TE policies. The device delivers logs to its information center. The information center processes the logs according to user-defined output rules (whether to output logs and where to output). For more information about the information center, see the network management and monitoring configuration guide for the device.
# Enable SRv6 TE policy logging.
[Sysname-srv6-te] srv6-policy log enable
srv6-policy metric-inherit enable
Use srv6-policy metric-inherit enable to enable the metric sharing feature for all SRv6 TE policies and SRv6 TE policy groups.
Use undo srv6-policy metric-inherit enable to disable the metric sharing feature for all SRv6 TE policies and SRv6 TE policy groups.
The metric sharing feature is disabled for all SRv6 TE policies and SRv6 TE policy groups.
SRv6 TE view
Operating mechanism
After the metric sharing feature is enabled for all SRv6 TE policies and SRv6 TE policy groups, the tunnel management module can obtain all types of metric values from those SRv6 TE policies and SRv6 TE policy groups. Then, the tunnel management module preferentially selects a forwarding path group from the configured SRv6 TE policies and SRv6 TE policy groups based on the metric type specified by using the bestroute srv6-policy-metric command and their related metric values.
·     You can configure the metric sharing feature for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. For an SRv6 TE policy, the policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
·     You can configure the metric sharing feature for all SRv6 TE policy groups globally in SRv6 TE view or for a specific SRv6 TE policy group in SRv6 TE policy group view. For an SRv6 TE policy group, the group-specific configuration takes precedence over the global configuration. An SRv6 TE policy group uses the global configuration only when it has no group-specific configuration.
# Enable the metric sharing feature for all SRv6 TE policies and SRv6 TE policy groups.
[Sysname-srv6-te] srv6-policy metric-inherit enable
bestroute srv6-policy-metric (Layer 3—IP Routing Command Reference)
metric-inherit (SRv6 TE policy view)
metric-inherit (SRv6 TE policy group view)
metric-type (SRv6 TE policy view)
metric-type (SRv6 TE policy group view)
srv6-policy path verification enable
Use srv6-policy path verification enable to enable path connectivity verification for all SRv6 TE policies.
Use undo srv6-policy path verification enable to disable path connectivity verification for all SRv6 TE policies.
srv6-policy path verification [ specified-sid ] enable
Path connectivity verification is disabled for all SRv6 TE policies.
SRv6 TE view
specified-sid: Enables path connectivity verification only for the SIDs specified with the verification keyword in the index command. If you do not specify the specified-sid keyword, all SIDs in the SID list will be verified.
You must configure this command on the source node of the SRv6 TE policy.
Typically, the controller deploys the SID list of an SRv6 TE policy. Without BFD configured, the source node cannot immediately detect path failures in the SRv6 TE policy. It only changes the SID list of the SRv6 TE policy as instructed by the controller that completes path recalculation upon detecting a topology change. If the controller or the link to the controller fails, the source node will be unable to detect failures and change SID lists, resulting in traffic loss.
For fast traffic switchover and high availability, you can enable path connectivity verification for the source node of the SRv6 TE policy. This feature enables the source node to collect network topology information, and verify all SID lists in the SRv6 TE policy as follows:
·     If all SRv6 SIDs exist in the topology and the associated locator prefixes are routable, the SID list is valid.
·     If any SRv6 SIDs do not exist in the topology or any of the associated locator prefixes are not routable, the SID list is invalid.
Upon detecting an invalid SID list (SID list failure), the source node changes paths as follows:
·     If the valid candidate paths of the SRv6 TE policy contain multiple SID lists, and one of the SID list fails, traffic is distributed to other valid SID lists.
·     If the SRv6 TE policy has valid primary and backup candidate paths, and all SID lists for the primary candidate path fail, traffic is distributed to the backup candidate path.
·     If all valid candidate paths of the SRv6 TE policy fail, the SRv6 TE policy is faulty and an associated protection action is taken (for example, MPLS L3VPN FRR).
You can configure SRv6 TE policy path connectivity verification in both SRv6 TE view and SRv6 TE policy view. The configuration in SRv6 TE policy view takes precedence over the configuration in SRv6 TE view. If path connectivity verification is not configured for an SRv6 TE policy, the configuration in SRv6 TE applies.
The source node must have all SRv6 SIDs and routes in the IGP domain to detect their status through the following settings:
·     Enable the IGP domain to forward routing information through IPv6 IS-IS.
·     Configure the distribute link-state command in IS-IS view for the source node to report link status.
After path connectivity verification is enabled for an SRv6 TE policy, the device verifies the validity of all SIDs in the SID list. If the SID list contains an inter-AS SID (for example, the BGP Peer SID allocated by BGP EPE) or contains the BSID of another SRv6 TE policy, the path connectivity verification will fail. This is because a BSID or BGP Peer SID cannot be flooded in the IGP topology.
To resolve this issue, you can execute the following commands to configure the path connectivity verification only verifies the validity of specific SIDs:
·     Use the index command to specify the verification keyword for the SIDs to be verified. Do not specify this keyword for a BSID or BGP EPE SID in the SID list.
·     Specify the specified-sid keyword when you execute the path verification command in SRv6 TE policy view or the srv6-policy path verification enable command in SRv6 TE view.
# Enable path connectivity verification for all SRv6 TE policies.
[Sysname-srv6-te] srv6-policy path verification enable
distribute (Layer 3—IP Routing Command Reference)
index
path verification
srv6-policy pce delegation enable
Use srv6-policy pce delegation enable to enable PCE delegation for SRv6 TE policies globally.
Use undo srv6-policy pce delegation enable to disable PCE delegation for SRv6 TE policies globally.
PCE delegation for SRv6 TE policies is disabled globally.
SRv6 TE view
After PCE delegation for an SRv6 TE policy is enabled, the PCC delegates the policy's candidate paths to a PCE. The PCC creates or updates candidate paths according to the creation or update requests received from the PCE.
You can configure PCE delegation for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
If you execute both the srv6-policy pce delegation enable command and the srv6-policy pce passive-delegate report-only enable command in SRv6 TE view, the srv6-policy pce passive-delegate report-only enable command takes effect.
# Enable PCE delegation for SRv6 TE policies globally.
[Sysname-srv6-te] srv6-policy pce delegation enable
pce delegation
Use srv6-policy pce passive-delegate report-only enable to enable the passive delegation report only feature globally.
Use undo srv6-policy pce passive-delegate report-only enable to disable the passive delegation report only feature globally.
The passive delegation report only feature is disabled globally.
SRv6 TE view
The passive delegation report only feature enables the device to report candidate path information of an SRv6 TE policy to the PCE without delegating the policy to the PCE.
When the device delegates only part of its SRv6 TE policies to a PCE, the PCE does not have complete SRv6 TE policy candidate path information to calculate global bandwidth information. You can enable the device to report information about the undelegated SRv6 TE policies to the PCE without using the PCE to compute candidate paths for the policies.
You can configure the passive delegation report only feature for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable the passive delegation report only feature globally for all SRv6 TE policies.
[Sysname-srv6-te] srv6-policy pce passive-delegate report-only enable
srv6-policy reoptimization
Use srv6-policy reoptimization to enable candidate path reoptimization for SRv6 TE policies globally.
Use undo srv6-policy reoptimization to disable candidate path reoptimization for SRv6 TE policies globally.
srv6-policy reoptimization [ frequency seconds ]
Candidate path reoptimization for SRv6 TE policies is globally disabled.
SRv6 TE policy view
frequency seconds: Sets the candidate path reoptimization frequency, in the range of 1 to 604800 seconds. The default frequency is 3600 seconds. If you set a frequency smaller than 60 seconds, the device performs reoptimization every 60 seconds.
This feature enables the PCE to periodically compute paths and notify the PCC to update path information, so that SRv6 TE policies can use the optimal path to establish the candidate path.
For example, an SRv6 TE policy uses a path other than the optimal path to establish the candidate path because the optimal path does not have sufficient link bandwidth. This feature enables the SRv6 TE policy to switch the candidate path to the optimal path when the link bandwidth becomes sufficient.
You can configure candidate path reoptimization for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable candidate path reoptimization for SRv6 TE policies globally.
[Sysname-srv6-te] srv6-policy reoptimization
reoptimization
srv6-policy sbfd
Use srv6-policy sbfd to enable SBFD for all SRv6 TE policies and configure the SBFD session parameters.
Use undo srv6-policy sbfd to disable SBFD for all SRv6 TE policies.
srv6-policy sbfd [ remote remote-id ] [ template template-name ] [ backup-template backup-template-name ] [ reverse-path { path-segment | reverse-binding-sid } ]
SBFD for all SRv6 TE policies is disabled.
SRv6 TE view
remote remote-id: Specifies the remote discriminator of the SBFD session, in the range of 1 to 4294967295. If you do not specify this option, the remote discriminator configured with the sbfd destination ipv6 remote-discriminator command applies.
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the SBFD session uses the multihop SBFD session settings configured in system view.
backup-template backup-template-name: Specifies a BFD session parameter template for the backup SID list. The backup-template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the SBFD session uses the multihop BFD session settings configured in system view.
reverse-path: Specifies a reverse path for SBFD packets. If you do not specify this keyword, the egress node looks up the IP forwarding table based on the source address of the received SBFD packets and forwards the return SBFD packets back to the ingress node.
path-segment: Uses the SID list with a specific path segment (End.PSID) as the reverse path for SBFD packets. A path segment is a BSID that directs traffic to the forwarding path identified by the SID list of the SRv6 TE policy associated with the BSID.
reverse-binding-sid: Uses the SID list associated with the reverse BSID as the reverse path for SBFD packets.
You can configure SBFD for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
By default, the SBFD return packets used for SRv6 TE policy connectivity detection are forwarded based on the IP forwarding path. If a transit node fails, all the return packets will be discarded, and the SBFD sessions will go down as a result. SBFD thus will mistakenly determine that all the SID lists of the SRv6 TE policy are faulty. To resolve this issue, you can enable SBFD return packets to be forwarded based on the specified SID list, implementing SBFD forward and reverse path consistency. The following methods are available to implement SBFD forward and reverse path consistency:
·     Specifying a reverse BSID—If you specify the reverse-path reverse-binding-sid option, the source node encapsulates the Aux Path TLV that contains the reverse BSID in SBFD packets. The reverse BSID can be specified by using the explicit segment-list command with the reverse-binding-sid parameter or the reverse-binding-sid command. When the endpoint node receives the SBFD packets, it parses the Aux Path TLV to obtain the reverse BSID. If the reverse BSID is the same as the local BSID of an SRv6 TE policy on the endpoint node, the endpoint node encapsulates an SRH in the SBFD packets and forwards the packets along the SID list of the SRv6 TE policy to which the local BSID belongs. To configure a local BSID, you can use the local-binding-sid command. In this method, the Aux Path TLV is carried in the payload of an SBFD packet, which might cause incompatibility issues with other vendors.
·     Specifying a path segment—A path segment is a type of BSID. With the reverse-path path-segment keyword specified, the source node encapsulates a path segment, or End.PSID, in the SRH header's SID list at the SRH[SL+1] position. SL+1 equals the sum of the number of SIDs in the SID list on the source node, and the source node's next hop is SRH[SL]. The encapsulated path segment can be specified by using the local-path-segment parameter in the explicit segment-list command. At the same time, set the fifth bit of the Flags field in the SRH header, known as the P-flag, to indicate that the SRH header carries a path segment. After the endpoint node receives the SBFD packet and finds that the P-flag is set, it retrieves the path segment. If the path segment in the packet’s SRH matches the reverse path segment specified for an SID list of an SRv6 TE policy, the endpoint node encapsulated the SBFD packet with SRH carrying that SID list, and forwards the packet along the represented path. Using path segment can prevent compatibility issues between vendors.
The remote discriminator specified in this command must be the same as that specified in the sbfd local-discriminator command on the reflector. Otherwise, the reflector will not send responses to the initiator.
If the SID lists of an SRv6 TE policy end with a 16-bit G-SID that carries a COC flavor, use the normal encapsulation mode to encapsulate BFD or SBFD packets. If BFD or SBFD packets are encapsulated in insertion mode, BFD or SBFD session setup might fail.
The device supports the echo packet mode BFD and the SBFD for an SRv6 TE policy. If both modes are configured for the same SRv6 TE policy, the SBFD takes effect.
# Enable SBFD for all SRv6 TE policies, and specify the SBFD session remote discriminator as 1000001.
[Sysname-srv6-te] srv6-policy sbfd remote 1000001
display segment-routing ipv6 te sbfd
local-binding-sid
reverse-binding-sid
sbfd
sbfd destination ipv6 remote-discriminator (High Availability Command Reference)
sbfd local-discriminator (High Availability Command Reference)
srv6-policy suppress-flapping
Use srv6-policy suppress-flapping to configure flapping suppression parameters for SRv6 TE policies.
Use undo srv6-policy suppress-flapping to restore the default.
srv6-policy suppress-flapping { detect-interval detect-interval | threshold threshold | resume-interval resume-interval } *
undo srv6-policy suppress-flapping { detect-interval | threshold | resume-interval } *
The SRv6 TE policy flapping detection interval is 60 seconds, the flapping suppression threshold is 10, and the flapping detection resumption interval is 120 seconds.
SRv6 TE view
detect-interval detect-interval: Specifies the flapping detection interval, in the range of 1 to 300 seconds. The default detection interval is 60 seconds.
threshold threshold: Specifies the flapping suppression threshold, in the range of 1 to 1000. The default threshold value is 10.
resume-interval resume-interval: Specifies the resumption interval for flapping suppression, in the range of 2 to 1000 seconds. The default resumption interval is 120 seconds.
After SRv6 TE policy flapping suppression is enabled, the device starts a counter for an SRv6 TE policy to count the SID list flapping events for the policy.
·     If the state of a SID list changes from down to up within the flapping detection interval, an SID list flapping event occurs, and the flapping count increases by 1.
·     If the time for a SID list to change from down to up is longer than the resumption interval, the flapping counter is cleared.
·     If the flapping count exceeds the flapping suppression threshold, the SRv6 TE policy enters flapping suppression state. In this state, the SRv6 TE policy does not update the SID list state but keep the SID list in down state, and the flapping counter is not cleared.
·     When the suppression state lasts for the resumption interval, the device ends the suppression state of the SRv6 TE policy and clears the flapping counter.
The resumption interval (set by resume-interval) must be greater than the flapping detection interval (set by detect-interval).
# Configure flapping suppression parameters for SRv6 TE policies.
[Sysname-srv6-te] srv6-policy suppress-flapping detect-interval 70 threshold 5 resume-interval 130
srv6-policy suppress-flapping disable
Use srv6-policy suppress-flapping disable to disable flapping suppression for SRv6 TE policies globally.
Use undo srv6-policy suppress-flapping disable to enable flapping suppression for SRv6 TE policies globally.
Flapping suppression for SRv6 TE policies is enabled globally.
SRv6 TE view
When SRv6 TE polices flap frequently, you can enable this feature to reduce the impact of the flappings on traffic forwarding.
# Disable flapping suppression for SRv6 TE policies globally.
[Sysname-srv6-te] srv6-policy suppress-flapping disable
srv6-policy switch-delay delete-delay
Use srv6-policy switch-delay delete-delay to configure the switchover delay time and deletion delay time for the SRv6 TE policy forwarding path.
Use undo srv6-policy switch-delay to restore the default.
srv6-policy switch-delay switch-delay-time delete-delay delete-delay-time
The switchover delay time and deletion delay time for the SRv6 TE policy forwarding path is 5000 milliseconds and 20000 milliseconds, respectively.
SRv6 TE view
switch-delay-time: Sets the forwarding path switchover delay time in the range of 0 to 600000 milliseconds.
delete-delay-time: Sets the forwarding path deletion delay time in the range of 0 to 600000 milliseconds.
The switchover delay and deletion delay mechanism is used to avoid traffic forwarding interruption during a forwarding path switchover.
When updating an SRv6 TE policy forwarding path, the device first establishes the new forwarding path before it deletes the old one. During the new path setup process, the device uses the old path to forward traffic until the switchover delay timer expires. When the switchover delay timer expires, the device switches traffic to the new path. The old path is deleted when the deletion delay timer expires.
# Set the SRv6 TE policy forwarding path switchover delay time to 8000 milliseconds and the deletion delay time to 15000 milliseconds.
[Sysname-srv6-te] srv6-policy switch-delay 8000 delete-delay 15000
srv6-policy up-delay
Use srv6-policy up-delay to set the delay time for bringing up SRv6 TE policies.
Use undo srv6-policy up-delay to restore the default.
srv6-policy up-delay delay-time
The device does not delay bringing up SRv6 TE policies.
SRv6 TE view
delay-time: SRv6 TE policy up delay time, in the range of 1 to 600000 milliseconds.
After an SRv6 TE policy recovers from a fault, the device waits for the delay time before bringing up the SRv6 TE policy. This is to ensure that the fault is completely removed so as to avoid packet loss caused by SRv6 TE policy flapping.
After this command is executed, the device starts different delay timers for an SRv6 TE policy according to the BFD/SBFD configuration for the SRv6 TE policy.
·     If BFD/SBFD is not enabled, the device starts an LSP delay timer when the SID list state changes from Down to Up.
·     If BFD is enabled, the device starts a BFD delay timer when the BFD session state changes from Down to Up.
·     If SBFD is enabled, the device starts an SBFD delay timer when the SBFD session state changes from Down to Up.
To view the BFD/SBFD configuration, SID list state, and BFD/SBFD session state, execute the display segment-routing ipv6 te policy command.
Set a proper SRv6 TE policy-up delay time according to your network conditions. A very long delay time will cause an SRv6 TE policy to be unable to process user traffic for a long time.
You can set the delay time for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
If you execute this command for multiple times, the most recent configuration takes effect. A new delay time setting does not apply to the SRv6 TE policies that are already in a delay process.
# Set the policy-up delay time to 10000 milliseconds for all SRv6 TE policies.
[Sysname-srv6-te] srv6-policy up-delay 10000
up-delay
strict-sid-only enable
Use strict-sid-only enable to enable strict SID encapsulation for SID lists.
Use undo strict-sid-only enable to disable strict SID encapsulation for SID lists.
Strict SID encapsulation is disabled for SID lists.
SRv6 TE policy path preference dynamic view
SRv6 TE ODN dynamic view
delay-time: SRv6 TE policy-up delay time, in the range of 1 to 600000 milliseconds.
Configure this command on the source node of an SRv6 TE policy.
The SID list of an SRv6 TE policy can be formed by End SIDs and End.X SIDs. An End SID cannot uniquely identify a link. When the links in the network flap frequently, the forwarding paths of the SRv6 TE policy might change. To ensure stability of forwarding paths, use this command to enable the SRv6 TE policy to include only End.X SIDs in the calculated SID lists.
# In SRv6 TE policy path preference dynamic view, enable strict SID encapsulation for SID lists.
[Sysname-srv6-te] policy a1
[Sysname-srv6-te-policy-a1] candidate-paths
[Sysname-srv6-te-policy-a1-path] preference 200
[Sysname-srv6-te-policy-a1-path-pref-200] dynamic
[Sysname-srv6-te-policy-a1-path-pref-200-dyna] strict-sid-only enable
# In SRv6 TE ODN dynamic view, enable strict SID encapsulation for SID lists.
[Sysname-srv6-te] on-demand color 1
[Sysname-srv6-te-odn-1] dynamic
[Sysname-srv6-te-odn-1-dyna] strict-sid-only enable
switch-period
Use switch-period to set the switchover period between SRv6 TE policies in an IPR policy.
Use undo switch-period to restore the default.
switch-period time-value
undo switch-period
The switchover period between SRv6 TE policies is 6 seconds in an IPR policy.
time-value: Specifies a switchover period in the range of 1 to 7200, in seconds.
If the source node of an SRv6 TE policy group calculates that the optimal SRv6 TE policy for a service differs from the one currently used by that service, and the path selection priority of the optimal SRv6 TE policy is lower than that of the currently used SRv6 TE policy, iFIT has detected that the packet loss, delay, or jitter of the currently used SRv6 TE policy does not meet the SLA requirements in the IPR policy. The traffic of that service needs to be switched over to the lower-priority SRv6 TE policy for forwarding. The device will then initiate a switchover delay timer, with the delay configured by using this command. Before the switchover delay timer times out, if the iFIT measurement result of the currently used SRv6 TE policy does not cross the SLA thresholds, the switchover delay timer will be reset. If the iFIT measurement result of the currently used SRv6 TE policy has crossed the SLA thresholds, the traffic of that service will be switched over to the optimal SRv6 TE policy calculated by IPR for forwarding after the switchover delay timer expires.
You can reasonably set the switchover delay based on the characteristics of services. For example, voice services require high real-time performance. When the network quality of SRv6 TE policy downgrades, voice services require timely switchover of forwarding paths to ensure the real-time performance of voice service traffic. In this case, a shorter switchover delay can be set to achieve rapid service switchover.
# Set the switchover period between SRv6 TE policies to 3 seconds in IPR policy ipr1.
[Sysname-srv6-ipr-policy-ipr1] switch-period 3
te ipv6-router-id
Use te ipv6-router-id to configure the TE IPv6 router ID.
Use undo te ipv6-router-id to restore the default.
te ipv6-router-id router-id
The TE IPv6 router ID is not configured.
router-id: Specifies the TE IPv6 router ID, in the format of an IPv6 address. The value cannot be :: or FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF.
The TE IPv6 router ID is used to identify the source node in PCE requests. The TE IPv6 router ID of a device must be unique on the IPv6 network.
When the local node uses BGP-LS messages to report the candidate path information of an SRv6 TE policy to the controller, it can use the address specified by using this command as the IPv6 TE router ID in BGP-LS NLRI.
# Set the TE IPv6 router ID to 1::1.
[Sysname] te ipv6-router-id 1::1
distribute bgp-ls
traffic-engineering
Use traffic-engineering to create and enter the SRv6 TE view, or enter the existing SR TE view.
Use undo traffic-engineering to delete the SRv6 TE view and all the configuration in the view.
traffic-engineering
The SRv6 TE view does not exist.
SRv6 view
# Create and enter the SRv6 TE view.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te]
ttl-mode
Use ttl-mode to configure the TTL processing mode of SRv6 TE policies.
Use undo ttl-mode to restore the default.
ttl-mode { pipe | uniform }
undo ttl-mode
The TTL processing mode of SRv6 TE policies is pipe.
SRv6 view
pipe: Specifies the pipe TTL processing mode.
uniform: Specifies the uniform TTL processing mode.
An SRv6 TE policy used as a public tunnel supports the following TTL processing modes:
·     Uniform—When the ingress node adds a new IPv6 header to an IP packet, it copies the TTL value of the original IP packet to the Hop Limit field of the new IPv6 header. Each node on the SRv6 TE policy forwarding path decreases the Hop Limit value in the new IPv6 header by 1. The node that de-encapsulates the packet copies the remaining Hop Limit value back to the original IP packet when it removes the new IPv6 header. The TTL value can reflect how many hops the packet has traversed in the public network. The tracert facility can show the real path along which the packet has traveled.
·     Pipe—When the ingress node adds a new IPv6 header to an IP packet, it does not copy the TTL value of the original IP packet to the Hop Limit field of the new IPv6 header. It sets the Hop Limit value in the new IPv6 header to 255. Each node on the SRv6 TE policy forwarding path decreases the Hop Limit value in the new IPv6 header by 1. The node that de-encapsulates the packet does not change the IPv6 Hop Limit value according to the remaining Hop Limit value in the new IPv6 header. Therefore, the public network nodes are invisible to user networks, and the tracert facility cannot show the real path in the public network.
# Configure the TTL processing mode of SRv6 TE policies to uniform.
[Sysname-segment-routing-ipv6] ttl-mode uniform
type
Use type to specify a metric for the SRv6 TE policy to perform dynamic path calculation.
Use undo type to restore the default.
type { hopcount | igp | latency | te }
undo type
No metric is specified. The SRv6 TE policy cannot perform dynamic path calculation.
Metric type view
SRv6 TE ODN dynamic metric type view
hopcount: Specifies the hop count metric to select the link with minimum hops.
igp: Specifies the IGP link cost metric to select the link with minimum IGP link cost.
latency: Specifies the interface latency metric to select the link with the minimum interface latency.
te: Specifies the TE cost metric to select the link with minimum TE cost.
# Specify the hop count metric in metric type view.
[Sysname-srv6-te] policy p1
[Sysname-srv6-te-policy-p1] candidate-paths
[Sysname-srv6-te-policy-p1-path] preference 10
[Sysname-srv6-te-policy-p1-path-pref-10] dynamic
[Sysname-srv6-te-policy-p1-path-pref-10-dyna] metric
[Sysname-srv6-te-policy-p1-path-pref-10-dyna-metric] type hopcount
# Specify the hop count metric in SRv6 TE ODN dynamic metric type view.
[Sysname-srv6-te-odn-1-dynamic] metric
[Sysname-srv6-te-odn-1-dynamic-metric] type hopcount
up-delay
Use up-delay to set the delay time for bringing up an SRv6 TE policy.
Use undo up-delay to restore the default.
up-delay delay-time
undo up-delay
No policy-up delay time is set for an SRv6 TE policy, and the policy-up delay time set in SRv6 TE view applies.
SRv6 TE policy view
To view the BFD/SBFD configuration, SID list state, and BFD/SBFD session state, execute the display segment-routing te policy command.
# Set the policy-up delay time to 10000 milliseconds for SRv6 TE policy p1.
[Sysname-segment-routing] traffic-engineering
[Sysname-sr-te ]policy p1
[Sysname-sr-te-policy-p1] up-delay 10000
sr-policy up-delay
validation-check enable
Use validation-check enable to enable validity check for BGP IPv6 SR policy routes.
Use undo validation-check enable to disable validity check for BGP IPv6 SR policy routes.
Validity check for BGP IPv6 SR policy routes is disabled. The device does not check the validity of the BGP IPv6 SR policy routes received from peers or peer groups.
BGP IPv6 SR policy address family view
After validity check is enabled for BGP IPv6 SR policy routes, the device determines that a BGP IPv6 SR policy route is invalid and will not preferentially select the route if the route does not contain the IPv4 address format RT extended community attribute or the NO_ADVERTISE community attribute.
You can configure this feature on the RR in networks where the controller and the RR establish BGP peer relationship and the RR establishes BGP peer relationship with the source nodes of multiple SRv6 TE policies.
The RR checks whether the BGP IPv6 SR policy routes issued by the controller carry the IPv4 address format RT attribute or the NO_ADVERTISE attribute. If yes, the RR accepts the routes and reflects the routes that do not carry the NO_ADVERTISE attribute to the source nodes of the SRv6 TE policies.
On the source nodes, you can use the router-id filter command to enable BGP IPv6 SR policy route filtering by router ID. After a source node receives a BGP IPv6 SR policy route, it compares the local router ID with the IPv4 address in the RT attribute of the route. If they are the same, the source node accepts the route. If they are different, the source node drops the route.
# Enable validity check for BGP IPv6 SR policy routes.
[Sysname] bgp 100
[Sysname-bgp-default] address ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] validation-check enable
router-id filter
wait-to-restore-period (SRv6 TE IPR policy view)
Use wait-to-restore-period to set the WTR period in an IPR policy.
Use undo wait-to-restore-period to restore the default.
wait-to-restore-period time-value
The WTR period is 6 seconds in an IPR policy.
time-value: Specifies a WTR period in the range of 1 to 259200, in seconds.
If the source node of an SRv6 TE policy group calculates that the optimal SRv6 TE policy for a service differs from the one currently used by that service, and the path selection priority of the optimal SRv6 TE policy is higher than that of the currently used SRv6 TE policy, iFIT has detected that the packet loss, delay, or jitter of the high-priority SRv6 TE policy has returned to a value that does not cross the corresponding SLA threshold. The traffic of that service needs to be switched back to the high-priority SRv6 TE policy for forwarding. At this point, the device will initiate a WTR delay timer, and the WTR delay is configured by using this command. Before the WTR delay timer times out, if the iFIT measurement result of the high-priority SRv6 TE policy crosses the SLA thresholds, the WTR delay timer will be reset. If the iFIT measurement result of this high-priority SRv6 TE policy consistently meets the SLA threshold requirements, the traffic of that service will be switched back to the optimal SRv6 TE policy calculated by IPR for forwarding after the WTR delay timer expires.
If you do not set the WTR period, the device immediately switches service traffic back to the high-priority SRv6 TE policy for forwarding. The switchback might result in packet loss or jitter due to link quality instability of the high-priority SRv6 TE policy.
# Set the WTR period to 30 seconds in IPR policy ipr1.
[Sysname-srv6-te] intelligent-policy-route
[Sysname-srv6-ipr] ipr-policy ipr1
[Sysname-srv6-ipr-policy-ipr1] wait-to-restore-period 30
