11-Segment Routing Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command Reference-R8630Pxx-6W10011-Segment Routing Command Reference
05-SRv6 VPN commands
05-SRv6 VPN commands 681.42 KB
SRv6 VPN commands· 1
backup-peer 1
bfd static evpn-vpls-srv6· 2
bfd static evpn-vpws-srv6· 3
bum-forwarding dx2l-based· 4
bypass-peer 5
default color 6
display l2vpn forwarding srv6· 7
display l2vpn peer srv6· 10
display l2vpn statistics srv6-pw inbound· 17
display l2vpn traffic-statistics srv6-pw· 18
display l2vpn vsi 20
display l2vpn xconnect-group· 24
encapsulation source-address· 28
evpn encapsulation srv6· 29
evpn encapsulation srv6 binding instance· 29
evpn vpws local-service-id remote-service-id· 30
export route-policy· 31
forwarding mode· 32
import route-policy· 33
learning mode· 34
locator-sbfd enable· 35
nexthop interface (BGP IPv4 SR next hop view/BGP-VPN IPv4 SR next hop view/BGP-VPN IPv4 EVPN SR next hop view) 36
nexthop interface (BGP IPv6 SR next hop view/BGP-VPN IPv6 SR next hop view/BGP-VPN IPv6 EVPN SR next hop view) 38
peer 39
peer advertise encap-type srv6· 40
peer advertise original-route· 41
peer prefix-sid· 42
peer re-originated (BGP EVPN address family view) 43
peer re-originated (BGP VPNv4/VPNv6 address family view) 45
peer srv6-endr-type· 47
peer srv6-vpn compatible· 48
peer suppress re-originated· 49
ping evpn vpls srv6· 51
ping { evpn | static } vpws srv6· 53
reset l2vpn statistics srv6-pw· 55
restrain· 56
revertive wtr 57
segment-routing ipv6· 58
segment-routing ipv6 apply-sid all-nexthop (BGP IPv4/IPv6 address family view) 59
segment-routing ipv6 apply-sid all-nexthop (BGP-VPN IPv4/IPv6 address family view) 61
segment-routing ipv6 apply-sid compress (BGP IPv4/IPv6 address family view/BGP-VPN IPv4/IPv6 address family view) 62
segment-routing ipv6 apply-sid compress (cross-connect view, EVPN instance view, and VSI EVPN instance view) 64
segment-routing ipv6 apply-sid specify-nexthop (BGP IPv4/IPv6 address family view) 65
segment-routing ipv6 apply-sid specify-nexthop (BGP-VPN IPv4/IPv6 address family view) 66
segment-routing ipv6 best-effort 67
segment-routing ipv6 locator 69
segment-routing ipv6 locator (cross-connect view/EVPN instance view/VSI EVPN instance view) 71
segment-routing ipv6 primary-path-detect sid-bfd· 73
segment-routing ipv6 route-select delay· 76
segment-routing ipv6 traffic-engineering· 77
srv6-inter-as balance· 80
srv6-inter-as enable· 81
srv6-mpls-interworking enable· 82
srv6-pw-type· 83
static-srv6 local-service-id remote-service-id· 84
statistics enable· 85
tracert evpn vpls srv6· 86
tracert { evpn | static } vpws srv6· 88
unicast-forwarding dx2-based· 90
SRv6 VPN commands
backup-peer
Use backup-peer to configure a static backup SRv6 PW for a cross-connect and enter cross-connect static backup SRv6 PW view, or enter the view of an existing cross-connect static backup SRv6 PW.
Use undo backup-peer to delete a static backup SRv6 PW.
backup-peer ipv6-address end-dx2-sid remote-locator locator-name opcode opcode [ compress [ coc-next | next [ wlib ] ] ] [ color color-value | tunnel-policy tunnel-policy-name ]
undo backup-peer ipv6-address end-dx2-sid remote-locator locator-name opcode opcode
No static backup SRv6 PW exists for a cross-connect.
Cross-connect static SRv6 PW view
ipv6-address: Specifies the address of the remote PE on the backup SRv6 PW.
remote-locator locator-name: Specifies the remote locator name, a case-sensitive string of 1 to 31 characters.
opcode opcode: Specifies the opcode for SRv6 SIDs, in the range of 1 to 2static-length-1, where the static-length is determined by the remote-locator command.
compress: Indicates that the corresponding remote SID is compressible. If you do not specify this keyword, the corresponding remote SID is not compressible.
coc-next: Indicates that the compressible remote SRv6 SID carries the COC and NEXT flavors.
next: Indicates that the compressible remote SRv6 SID carries the NEXT flavor.
next wlib: Indicates that the compressible remote SRv6 SID carries the NEXT flavor and uses the W-LIB space to allocate G-SID.
color color-value: Specifies the color value for the backup SRv6 PW, in the range of 0 to 4294967295. If you do not specify this option, the color of the backup SRv6 PW is not specified.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 126 characters. If you do not specify a tunnel policy, the tunnel policy specified by the static-srv6 local-service-id remote-service-id command is used for the backup SRv6 PW.
A static backup SRv6 PW provides PW redundancy for its primary SRv6 PW, and is used when the primary SRv6 PW fails.
The remote PE's IPv6 address and remote SID specified for a static backup SRv6 PW cannot both be the same as those of an existing static or dynamic SRv6 PW.
SRv6 PW redundancy and bypass SRv6 PW are mutually exclusive with each other. If you have configured a backup SRv6 PW for a cross-connect by using the backup-peer command, you cannot configure a bypass SRv6 PW for the cross-connect by using the bypass-peer command, and vice versa.
# Configure a static backup SRv6 PW for a cross-connect and enter its view. Specify the IPv6 address of the remote PE of the PW as 4::4, the remote locator as aaa, and the opcode as 1.
[Sysname] xconnect-group svpws0
[Sysname-xcg-svpws0] connection 1
[Sysname-xcg-svpws0-1] static-srv6 local-service-id 1 remote-service-id 2 tunnel-policy 1
[Sysname-xcg-svpws0-1-1-2] peer 1::1 end-dx2-sid remote-locator aaa opcode 1
[Sysname-xcg-svpws0-1-1-2-1::1-aaa-1] backup-peer 3::3 end-dx2-sid remote-locator bbb opcode 2
[Sysname-xcg-svpws0-1-1-2-1::1-aaa-1-3::3-bbb-2]
bypass-peer
peer
Use bfd static evpn-vpls-srv6 to create a static BFD session for SRv6 PW connectivity detection in an EVPN VPLS over SRv6 network and enter static BFD session view, or enter the view of an existing static BFD session.
Use undo bfd static to delete a static BFD session and all settings in static BFD session view.
bfd static session-name evpn-vpls-srv6 vsi vsi-name remote-peer remote-ipv6-address [ discriminator auto ]
undo bfd static session-name
No static BFD sessions exist.
session-name: Specifies the name of the static BFD session, a case-sensitive string of 1 to 64 characters.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
remote-peer remote-ipv6-address: Specifies a remote PE by its IPv6 address.
discriminator auto: Enables the device to automatically assign a local discriminator value to the static BFD session. If you do not specify the keywords, you must use the discriminator command to specify the local and remote discriminators for the session.
Enable BFD on both ends of an SRv6 PW for quick link connectivity detection. The PEs periodically send BFD control packets to each other through the SRv6 PW associated with the specified VSI. A PE sets the PW state to Down if it does not receive control packets from the remote end within a detection interval. To avoid packet forwarding failure, the PE switches packets to the backup SRv6 PW or an equal-cost SRv6 PW.
Make sure the static BFD session is in Asynchronous mode.
Use this command on both PEs at the two ends of an SRv6 PW.
In a primary/backup SRv6 PW scenario or an equal-cost SRv6 PW scenario, you must configure a static BFD session for each SRv6 PW to detect their connectivity.
# Create a static BFD session named abc to test the connectivity of the SRv6 PW associated with VSI aaa. The IPv6 address of the remote PE is 20::1.
[Sysname] bfd static abc evpn-vpls-srv6 vsi aaa remote-peer 20::1
[Sysname-bfd-static-session-abc]
Use bfd static evpn-vpws-srv6 to create a static BFD session for SRv6 PW connectivity detection in an EVPN VPWS over SRv6 network and enter static BFD session view, or enter the view of an existing static BFD session.
bfd static session-name evpn-vpws-srv6 interface interface-type interface-number remote-peer remote-ipv6-address [ discriminator auto ]
interface interface-type interface-number: Specifies a Layer 3 interface mapped to a cross-connect. The interface-type argument represents the interface type and the interface-number argument represents the interface number.
Enable BFD on both ends of an SRv6 PW for quick link connectivity detection. The PEs periodically send BFD control packets to each other out of the Layer 3 interfaces mapped to the cross-connect of the SRv6 PW. A PE sets the PW state to Down if it does not receive control packets from the remote end within a detection interval. To avoid packet forwarding failure, the PE switches packets to the backup SRv6 PW or an equal-cost SRv6 PW.
# Create a static BFD session named abc to test the connectivity of the SRv6 PW associated with a cross-connect mapped to Ten-GigabitEthernet 3/1/1. The IPv6 address of the remote PE is 20::1.
[Sysname] bfd static abc evpn-vpws-srv6 interface ten-gigabitethernet 3/1/1 remote-peer 20::1
Use bum-forwarding dx2l-based to forward BUM traffic based on an End.DX2L SID through the bypass PW when an AC fails in an EVPN VPLS over SRv6 multihomed network.
Use undo bum-forwarding dx2l-based to restore the default.
In an EVPN VPLS over SRv6 multihomed network, BUM traffic is not forwarded through the bypass PW when an AC fails.
In an EVPN VPLS over SRv6 multihomed network, a PE by default broadcasts a received packet to all ACs mapped to a VSI in the following situations:
·     The packet contains an End.DT2M SID.
·     The packet contains an End.DT2U SID, but the PE fails to find a matching MAC address entry for the packet in the VSI to which the End.DT2U SID belongs.
In the situations described above, the packet cannot reach the site connected to an AC when the AC fails.
With this command, the PE assigns an End.DX2L SID to each AC and advertises the SIDs to the peer PE (redundant PE for multihoming) at the local site. When an AC on the peer PE fails, that PE encapsulates the End.DX2L SID corresponding to the AC to BUM traffic and forwards the traffic to the local PE through the bypass PW. Then, the local PE forwards the traffic to the local AC corresponding to the End.DX2L SID. When the peer PE receives traffic that contains an End.DX2L SID, it does not forward the traffic to the bypass PW when the AC corresponding to the End.DX2L SID fails.
# Configure the device to forward BUM traffic based on an End.DX2L SID through the bypass PW when an AC fails in an EVPN VPLS over SRv6 multihomed network.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation srv6
[Sysname-vsi-aaa-evpn-srv6] bum-farwarding dx2l-based
bypass-peer
Use bypass-peer to configure a bypass SRv6 PW for the AC of a cross-connect and enter cross-connect bypass SRv6 PW view, or enter the view of an existing cross-connect bypass SRv6 PW.
undo bypass-peer to delete a bypass SRv6 PW.
bypass-peer ipv6-address end-dx2l-sid remote-locator locator-name opcode opcode [ color color-value | tunnel-policy tunnel-policy-name ] ac-bypass
undo bypass-peer ipv6-address end-dx2l-sid remote-locator locator-name opcode opcode ac-bypass
No bypass SRv6 PW exists for a cross-connect.
Cross-connect AC view
ipv6-address: Specifies the address of the remote PE on the bypass SRv6 PW.
color color-value: Specifies the color value for the bypass SRv6 PW, in the range of 0 to 4294967295. If you do not specify this option, the color of the bypass SRv6 PW is not specified.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 126 characters. If you do not specify a tunnel policy, the tunnel policy specified by the static-srv6 local-service-id remote-service-id command is used for the bypass SRv6 PW.
The remote PE's IPv6 address and remote SID specified for a bypass SRv6 PW cannot both be the same as those of an existing SRv6 PW.
SRv6 PW redundancy and bypass SRv6 PW are mutually exclusive with each other. If you have configured a bypass SRv6 PW for a cross-connect by using the bypass-peer command, you cannot configure a static backup SRv6 PW for the cross-connect by using the backup-peer command, and vice versa.
# Configure a bypass SRv6 PW for the AC of a cross-connect and enter its view. Specify the IPv6 address of the remote PE of the PW as 2::2, the remote locator as aaa, and the opcode as 1.
[Sysname-xcg-svpws0-1] ac interface ten-gigabitethernet 3/1/1
[Sysname-xcg-svpws0-1-Ten-GigabitEthernet3/1/1] bypass-peer 2::2 end-dx2l-sid remote-locator aaa opcode 1 color 100 ac-bypass
[Sysname-xcg-svpws0-1-Ten-GigabitEthernet3/1/1-bypass]
backup-peer
peer
default color
Use default color to specify the default color.
Use undo default color to restore the default.
default color color-value
undo default color
No default color is specified.
EVPN instance view
Cross-connect static SRv6 view
color-value: Specifies the default color, in the range of 0 to 4294967295.
In case of color-based traffic steering, the default color is used in the following scenarios:
·     A BGP EVPN route does not have the color extended community attribute or match a routing policy to obtain a color.
·     A static SRv6 PW is not specified with a color value.
If multiple traffic steering methods are available on the device, the priorities of the methods in descending order are traffic steering based on tunnel binding policy, color, and tunnel load balancing policy. For more information about tunnel policies, see tunnel policy configuration in MPLS Configuration Guide.
# In VSI EVPN instance view, set the default color to 100.
[Sysname] vsi aaa
[Sysname-vsi-aaa-mpls-srv6] default color 100
# In cross-connect group EVPN instance view, set the default color to 100.
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] evpn encapsulation srv6
[Sysname-xcg-vpna-evpn-srv6] default color 100
# In cross-connect static SRv6 view, set the default color to 100.
[Sysname-xcg-vpna] connection pw1
[Sysname-xcg-vpna-pw1] static-srv6 local-service-id 1 remote-service-id 2
[Sysname-xcg-vpna-pw1-1-2] default color 100
Use display l2vpn forwarding srv6 to display L2VPN SRv6 forwarding information.
display l2vpn forwarding srv6 [ vsi vsi-name | xconnect-group group-name ] [ verbose ]
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. The group name cannot contain hyphens (-).
verbose: Displays detailed L2VPN SRv6 forwarding information. If you do not specify this keyword, the command displays only brief L2VPN SRv6 forwarding information.
If you do not specify a VSI or a cross-connect group, this command displays L2VPN SRv6 forwarding information for all VSIs and cross-connect groups.
# Display brief L2VPN SRv6 forwarding information.
<Sysname> display l2vpn forwarding srv6
Total number of cross-connections: 1
Total number of VSIs: 1
Total number of SRv6 tunnels: 2, 2 up, 0 blocked, 0 down
VSI Name : vpnb
Link ID  : 0x9000000   Type: BE     State: Up
In SID   : 100::2
Out SID  : 200::3
Xconnect-group Name : vpna
Connection Name     : pw1
Link ID             : 0x1         Type: BE    State: Up
In SID              : 100::1
Out SID             : 200::1
Link ID
Link ID of the SRv6 tunnel on the VSI or cross-connect group.
Route recursion mode.
After the PE receives a customer packet destined for an End.DX2, End.DT2M, or End.DT2U SID, it forwards the packet according to the route recursion mode.
·     BE—SRv6 BE mode. In this mode, the PE first encapsulates the End.DX2, End.DT2M, or End.DT2U SID into the packet. Then, the PE searches the IPv6 routing table based on the SID encapsulated in the packet to forward the encapsulated packet.
·     TE—SRv6 TE mode. In this mode, the PE first searches the tunnel policies for a matching SRv6 TE policy based on the next hop of a matching route. Then, the PE adds an SRH to the packet. The SRH includes the End.DX2, End.DT2M, or End.DT2U SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy.
·     BE/TE—SRv6 TE and SRv6 BE hybrid mode. In this mode, the PE preferentially uses the SRv6 TE mode to forward the packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6 BE mode.
SRv6 tunnel status:
·     Up—The SRv6 tunnel is up.
·     Down—The SRv6 tunnel is down.
·     Blocked—The SRv6 tunnel is a bakup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly.
In SID
Input SID, which is a local SID.
Out SID
Output SID, which is a remote SID.
# Display detailed L2VPN SRv6 forwarding information.
<Sysname> display l2vpn forwarding srv6 verbose
VSI Name: vpnb
  Link ID                : 0x9000000
  SRv6 Tunnel Type       : Ethernet
  SRv6 Tunnel State      : Up
  In  SID                : 200::3
  Out SID                : 100::2
  MTU                    : 1500
  SRv6 Tunnel Attributes : Main
  SRv6 Forwarding IDs    : -
  Nexthop/interface      : -
  Remote Leaf Argument   : -
Xconnect-group Name: vpna
 Connection Name: pw1
  Link ID                : 0x1
  In  SID                : 200::1
  Out SID                : 100::1
  MTU                    : 1500
Link ID
SRv6 Tunnel Type
SRv6 PW data encryption type, Ethernet or VLAN.
SRv6 Tunnel State
SRv6 tunnel status:
In SID
Out SID
MTU
Maximum transmission unit, in bytes.
SRv6 tunnel attributes:
·     Main—The primary tunnel.
·     Backup—The backup tunnel.
·     ac-Bypass—The Bypass tunnel for AC bypass.
·     ECMP—ECMP tunnel.
SRv6 Forwarding IDs
SRv6 forwarding entry IDs.
If service traffic is not forwarded through SRv6, this field displays a hyphen (-).
If SRv6 has been configured to forward service traffic but does not take effect yet, this field displays an asterisk (*).
This field displays the equal-cost SRv6 policy forwarding entries that actually take effect, which are calculated by the device based on the information such as network topology and available path status. The number of IDs might be fewer than the configured value. For the specific value that actually takes effect, see the command output.
Nexthop/interface
Next hop and outgoing interface of each path included in SRv6 BE when service traffic is forwarded through SRv6 BE tunnels.
Argument value used by the remote PE to identify leaf ACs.
If no argument value exists, this field displays a hyphen (-).
Use display l2vpn peer srv6 to display L2VPN SRv6 information.
display l2vpn peer srv6 [ vsi vsi-name | xconnect-group group-name ] [ state-machine | verbose ]
state-machine: Displays L2VPN SRv6 state machine information.
verbose: Displays detailed L2VPN SRv6 information.
If you do not specify a VSI or a cross-connect group, this command displays L2VPN SRv6 information for all VSIs and cross-connect groups.
If you do not specify the state-machine or verbose keyword, this command displays brief information about L2VPN SRv6.
# Display brief information about L2VPN SRv6.
<Sysname> display l2vpn peer srv6
Total number of SRv6 Tunnels: 2
VSI Name: vpnb
   Peer            : 2::2
   Flag            : Main
   State           : Up
   Peer            : 2::2
   Flag            : Main
   State           : Up
   Remote SrvID    : 2
# Display detailed information about L2VPN SRv6.
<Sysname> display l2vpn peer srv6 verbose
VSI Name: vpnb
  Peer: 2::2
   Signaling Protocol            : EVPN
   Link ID                       : 0x9000000
   In SID                        : 100::2
   Out SID                       : 200::3
   Wait to Restore Time          : 200
   Remaining Time                : 100
   MTU                           : 1500
   Tunnel Group ID               : 0x1000000030000000
   Tunnel NHLFEIDs               : 2150629380
   Nexthop/interface             : FE80::64BA:7AFF:FE48:317/ XGE3/1/1
   Color                         : -
   Color-Only                    : -
   Slice ID                      : -
   Slice Prefix                  : -
   Slice Encap Mode              : -
   Recursion Mode                : SID based
   Forwarding Mode               : double-vid
   Output Statistics             :
     Octets             : 0
     Packets            : 0
     UcastPkt           : 0
     BrdcastPkt         : 0
     MuticastPkt        : 0
     Errors             : 0
     Discards           : 0
   Output Rate                   :
     Bytes per second   : 0
     Packets per second : 0
  Peer: 2::2
   Remote Service ID             : 2
   Link ID                       : 0x1
   In SID                        : 100::1
   Out SID                       : 200::1
   MTU                           : 1500
   SRv6 Forwarding IDs           : 0
   Color                         : -
   Color-Only                    : -
   Slice ID                      : -
   Slice Prefix                  : -
   All Peer Input Statistics     :
     Octets             : 0
     Packets            : 0
     UcastPkt           : 0
     BrdcastPkt         : 0
     MuticastPkt        : 0
     Errors             : 0
     Discards           : 0
   Output Statistics             :
     Octets             : 0
     Packets            : 0
     UcastPkt           : 0
     BrdcastPkt         : 0
     MuticastPkt        : 0
     Errors             : 0
     Discards           : 0
   All Peer Input Rate           :
   Output Rate                   :
Peer
IPv6 address of the peer PE.
Flag
SRv6 tunnel flags:
·     ECMP—ECMP tunnel.
State/SRv6 Tunnel State
SRv6 tunnel status:
·     Blocked—The SRv6 tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly.
Remote SrvID/Remote Service ID
Remote service ID.
Signaling Protocol
Signaling protocol used to establish the SRv6 tunnel. Supported values:
·     EVPN.
·     Static SRv6.
Link ID
In SID
Out SID
Switchback delay, in seconds. If revertive switching is disabled, this field displays Infinite.
This field is supported only when both primary and backup PWs exist and is displayed only for the primary PW.
Remaining Time
Switchback delay remainng time, in seconds.
This field is displays only if the switchback delay timer is started.
MTU
·     ECMP—ECMP tunnel.
Tunnel Group ID
ID of the public network tunnel group that carries the SRv6 tunnel.
Tunnel NHLFEIDs
NHLFE ID of the public tunnel that carries the SRv6 tunnel when SRv6 TE route recursion mode is used for traffic fowarding.
Nexthop/interface
Next hop and outgointg interface of the public tunnel that carries the SRv6 tunnel when SRv6 BE route recursion mode is used for traffic fowarding.
Color
Color attribute of the expected SRv6 TE policy for route recursion.
If no color attribute is available, this field displays a hyphen (-).
Color-Only
Color-Only flag, indicating that the Extended Color Community is used to steering traffic to an SRv6 TE policy or SR-MPLS TE policy. Values include:
·     00—A BGP route can be recursed to an SRv6 TE policy/SR-MPLS TE policy when the route strictly matches both the endpoint and color of the policy.
·     01—Besides the strictly matching BGP routes, the BGP routes with only matching color value can also be recursed to an SRv6 TE policy/SR-MPLS TE policy when the policy endpoint is 0.0.0.0 or 0::0.
·     10—A BGP route can be recursed to an SRv6 TE policy or SR-MPLS TE policy when the route matches the color of the policy. The endpoint of the policy can be any IPv4 or IPv6 address.
·     11—Undefined.
Slice ID
ID of the network slice instance. If no slice ID is mapped to the color, this field displays a hyphen (-).
Slice Prefix
Source IPv6 prefix carrying the slice ID.
Slice Encap Mode
Network slice type. Values include:
·     1—HBH.
·     2—Source prefix.
A hyphen (-) represents an invalid value.
Recursion Mode
Route recursion mode of the SRv6 tunnel:
·     SID based—SRv6 BE mode.
·     Nexthop based—SRv6 TE mode.
·     Nexthop based/SID based—SRv6 TE and SRv6 BE hybrid mode.
Forwarding Mode
Layer 2 forwarding mode for EVPN VPLS over SRv6 networking. Options include:
·     double-vid—Double-VID forwarding mode, which performs Layer 2 forwarding based on both the inner and outer VLAN IDs of a data frame.
·     mac—MAC forwarding mode, which performs Layer 2 forwarding based on the destination MAC address of a data frame.
·     svid-only—SVID-only forwarding mode, which performs Layer 2 forwarding based on the outer VLAN ID of a data frame.
Down Reason
SRv6 tunnel down reason:
·     MTU not match—The MTUs at the two ends of the SRv6 tunnel do not match.
·     Local AC Down—The local AC is down.
·     Local VSI admin Down—The local VSI is administratively down.
·     EVPN VPWS AD per EVI route received from peer—In the EVPN VPWS over SRv6 network, the local end does not receive A-D per EVI routes sent from the peer end.
·     EVPN VPWS AD per ES route not received from peer—In the EVPN VPWS over SRv6 network, the local end does not receive A-D per ES routes sent from the peer end.
·     SRv6 not configured with best effort or traffic engineering—No route recursion mode is configured for the SRv6 tunnel.
·     Tunnel Down—The route is not reachable in SRv6 BE recursion mode or no SRv6 TE policy is configured in SRv6 TE recursion mode.
·     BFD session for SRv6 PW down—BFD detects that the SRv6 tunnel is down.
·     Unknown.
Total SRv6 PW incoming traffic statistics:
·     Octets—Number of incoming bytes.
·     Packets—Number of incoming packets.
·     UcastPkt—Number of incoming unicast packets.
·     BrdcastPkt—Number of incoming broadcast packets.
·     MuticastPkt—Number of incoming multicast packets.
·     Errors—Number of error packets.
·     Discards—Number of dropped packets.
This field is not available in an EVPN VPLS over SRv6 network.
Output statistics
SRv6 PW outgoing traffic statistics:
·     Octets—Number of outgoing bytes.
·     Packets—Number of outgoing packets.
·     UcastPkt—Number of outgoing unicast packets.
·     BrdcastPkt—Number of outgoing broadcast packets.
·     MuticastPkt—Number of outgoing multicast packets.
All Peer Input Rate
Total SRv6 PW incoming traffic rate:
·     Bytes per second—Number of incoming bytes per second.
·     Packets per second—Number of incoming packets per second.
Output Rate
SRv6 PW outgoing traffic rate:
·     Bytes per second—Number of outgoing bytes per second.
·     Packets per second—Number of outgoing packets per second.
# Display state machine information about L2VPN SRv6.
<Sysname> display l2vpn peer srv6 state-machine
SRv6 tunnel group state:
  Idle: Idle    N: Normal    UA: Unavailable    PF: Protecting failure
  P: Protection tunnel failure    W: Working tunnel failure    L: Local
VSI Name: vpnb
  SRv6 Group Link ID            : 0x9000000
    Main SRv6 Tunnel:
      Peer                      : 2::2
    Backup SRv6 Tunnel          : -
    Main SRv6 Defect State      : No defect
    Backup SRv6 Defect State    : -
    Switch Result               : Working
    Switch Reason               : None
    Remote Event                : -
    Local Event                 : SFCW
    SRv6 Group Old State        : Idle
    SRv6 Group State            : UA:P:L
  SRv6 Group Link ID            : 0x1
    Main SRv6 Tunnel:
      Peer                      : 2::2
      Service ID                : 2
    Remote Event                : -
    Local Event                 : SFCW
Main SRv6 Tunnel
Primary SRv6 tunnel.
Peer
IPv6 address of the remote PE for the SRv6 tunnel.
Service ID
Service ID of the remote PE.
Backup SRv6 Tunnel
Backup SRv6 tunnel.
Signaling Protocol
Signaling protocol used to establish the SRv6 tunnels. The value is EVPN.
Defect state of the primary SRv6 tunnel:
·     No defect.
·     Signal defect—The signaling protocol detected defects.
Defect state of the backup SRv6 tunnel:
·     No defect.
If no backup SRv6 tunnel exists, this field displays a hyphen (-).
Switch Result
SRv6 tunnel in use after a primary/backup tunnel switchover:
·     None—Neither the primary nor the backup SRv6 tunnel is in use.
·     Working—The primary SRv6 tunnel is in use.
·     Backup—The backup SRv6 tunnel is in use.
Switch Reason
Reason that causes the primary/backup tunnel switchover:
·     Config changed—An SRv6 tunnel is added to or removed from the tunnel redundancy group.
·     Fault detected—An SRv6 tunnel fault is detected.
·     SRv6 down—The state of an SRv6 tunnel changes from active to down.
·     SRv6 up—The state of an SRv6 tunnel changes from active to up.
·     None—No primary/backup tunnel switchover has occurred.
Remote Event
Remote state machine event.
Local Event
Local state machine event:
·     SFW—Local primary SRv6 tunnel defect event.
·     SFP—Local backup SRv6 tunnel defect event.
·     SFCW—Local primary SRv6 tunnel up event.
·     SFCP—Local backup SRv6 tunnel up event.
·     None—No local event.
SRv6 tunnel redundancy group state before switchover:
·     Idle—Both the primary and backup SRv6 tunnels are not available.
·     Normal—Both the primary and backup SRv6 tunnels are available. The primary SRv6 tunnel is up and the backup SRv6 tunnel is blocked. The primary SRv6 tunnel is used to forward traffic.
·     UA:P:L—The backup SRv6 tunnel has defects and the primary SRv6 tunnel is up.
·     PF:W:L—The primary SRv6 tunnel has defects and the back SRv6 tunnel is up.
SRv6 Group State
SRv6 tunnel redundancy group state after switchover. The supported values are the same as those of the SRv6 Group Old State field.
Use display l2vpn statistics srv6-pw inbound to display incoming packet statistics for SRv6 PWs in an EVPN VPLS over SRv6 network.
display l2vpn statistics srv6-pw inbound [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays incoming packet statistics for all SRv6 PWs on all VSIs.
Use this command to display incoming packet statistics for all SRv6 PWs on the specified VSI or all VSIs.
To display outgoing packet statistics, use the display l2vpn peer srv6 verbose command.
# Display incoming packet statistics for all SRv6 PWs on VSI aaa.
<Sysname> display l2vpn statistics srv6-pw inbound vsi aaa
VSI name: aaa
  Input statistics:
    Octets             : 0
    Packets            : 0
    UcastPkt           : 0
    BrdcastPkt         : 0
    MuticastPkt        : 0
    Errors             : 0
    Discards           : 0
  Input rate      :
Table 5 Command output
Input statistics
Incoming packet statistics for all SRv6 PWs:
·     Octets—Number of received bytes.
·     Packets—Number of received packets.
·     UcastPkt—Number of received unicast packets.
·     BrdcastPkt—Number of received broadcast packets.
·     MuticastPkt—Number of received multicast packets.
·     Discards—Number of discarded packets.
Input rate
Incoming traffic rate for all SRv6 PWs:
statistics enable
Use display l2vpn traffic-statistics srv6-pw command to display SRv6 PW packet statistics.
display l2vpn traffic-statistics srv6-pw [ vsi vsi-name | xconnect-group group-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays SRv6 PW statistics in all VSIs.
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a cross-connect group, this command displays SRv6 PW statistics in all cross-connect groups.
# Display SRv6 PW packet statistics.
<Sysname> display l2vpn traffic-statistics srv6-pw
Vsi-name: svpls0
Input statistics for all peer :
Last 900 seconds input rate : 0 bytes/sec, 38 packets/sec
Input : 0 bytes, 90056 packets
Input :
  Unicast : 90008 packets
  Multicast: 90016 packets
  Broadcast: 90024 packets
  Errors  : 0 packets
  Discards : 0 packets
Output statistics for peer: 3::3
Last 900 seconds output rate : 0 bytes/sec, 20 packets/sec
Output : 0 bytes, 45432 packets
Output :
  Unicast : 45416 packets
  Multicast: 45420 packets
  Broadcast: 45424 packets
  Errors  : 0 packets
Output statistics for peer: 2::2
Last 900 seconds output rate : 0 bytes/sec, 21 packets/sec
Output : 0 bytes, 45832 packets
Output :
  Unicast : 45816 packets
  Multicast: 45820 packets
  Broadcast: 45824 packets
  Errors  : 0 packets
Xconnect-group Name: vpws0
Peer-address: 3::3
Last 900 seconds input rate : 0 bytes/sec, 22 packets/sec
Last 900 seconds output rate : 0 bytes/sec, 22 packets/sec
Input : 0 bytes, 47628 packets
Output : 0 bytes, 47632 packets
Input :
  Unicast : 47604 packets
  Multicast: 47608 packets
  Broadcast: 47612 packets
  Errors  : 0 packets
Output :
  Unicast : 47616 packets
  Multicast: 47620 packets
  Broadcast: 47624 packets
  Errors  : 0 packets
Table 6 Command output
Vsi-name
Name of a VSI.
Incoming traffic statistics for all SRv6 PWs.
Outgoing traffic statistics for the SRv6 PW to the specified peer.
Xconnect-group Name
Name of a cross-connect group.
Connection Name
Name of a cross-connect.
Packet input rate statistics in the last 900 seconds, including the number of bytes received per second and number of packets received per second.
Packet output rate statistics in the last 900 seconds, including the number of bytes sent per second and number of packets sent per second.
Input
Incoming packet statistics:
·     bytes: Number of bytes.
·     packets: Number of packets.
·     Unicast: Number of unicast packets.
·     Multicast: Number of multicast packets.
·     Broadcast: Number of broadcast packets.
·     Errors: Number of error packets.
·     Discards: Number of discarded packets.
Output
Outgoing packet statistics:
statistics enable
display l2vpn vsi
Use display l2vpn vsi to display L2VPN VSI information.
display l2vpn vsi [ evpn-srv6 | name vsi-name ] [ count | verbose ]
evpn-srv6: Specifies VSIs in the EVPN VPLS over SRv6 network.
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
count: Displays VSI statistics.
verbose: Displays detailed VSI information.
If you do not specify a VSI or the evpn-srv6 keyword, this command displays L2VPN VSI information for all VSIs.
If you do not specify the count or verbose keyword, this command displays brief VSI information.
# Display brief information about all VSIs in the EVPN VPLS over SRv6 network.
<Sysname> display l2vpn vsi evpn-srv6
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpnb                            0               1500   Up
# Display statistics about all VSIs in the EVPN VPLS over SRv6 network.
<Sysname> display l2vpn vsi evpn-srv6 count
Table 7 Command output
MTU
Maximum transmission unit of the VSI.
VSI state:
·     Up—The VSI is up.
·     Down—The VSI is down.
·     Admin down—The VSI is manually shut down by using the shutdown command.
# Display detailed information about all VSIs in the EVPN VPLS over SRv6 network.
<Sysname> display l2vpn vsi evpn-srv6 verbose
VSI Name: vpnb
  VSI Index               : 0
  VSI Description         : vsi for vpnb
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  Broadcast Restrain      : 5120 kbps
  Multicast Restrain      : 5120 kbps
  Unknown Unicast Restrain: 5120 kbps
  MAC Table Limit         : -
  MAC Learning rate       : Unlimited
  Local MAC aging time    : 300 sec
  Remote MAC aging time   : 300 sec
  Drop Unknown            : Disabled
  PW Redundancy Mode      : Slave
  ESI                     : 0000.0000.0000.0000.0000
  Redundancy Mode         : All-active
  Straight-fwd PW-to-AC   : Disabled
  Statistics              : Disabled
  VXLAN ID                : -
  EVPN Encapsulation      : SRv6
  SRv6 SIDs:
    Dt2U SID  : 222::1(64/64/0)
    Dt2UL SID : 222::2(64/64/0)
    Dt2M SID  : 222::3(64/64/0)
  SRv6 tunnels:
   Peer        : 2::2
   Link ID     : 0x9000000
   State       : Up
  ACs:
    AC                                 Link ID    State
    XGE3/1/1                           0x0        Up
    Statistics: Disabled
Table 8 Command output
VSI Description
VSI description.
If no description is configured, this field is not available.
VSI State
VSI state:
·     Up—The VSI is up.
MTU
Diffserv Mode
DiffServ mode. Options include the following:
·     ingress—DiffServ mode for the inbound direction.
·     egress—DiffServ mode for the outbound direction.
·     pipe—Pipe mode.
·     short-pipe—Short-pipe mode.
·     uniform—Uniform mode
·     trust—Priority trust mode
¡     inner-dot1p—Trusts the inner 802.1p priority in packets.
¡     dscp—Trusts the DSCP in packets.
af1, af2, af3, af4, be, cs6, cs7, or ef represents the MPLS EXP value.
If no DiffServ mode is configured, this field displays a hyphen (-).
Bandwidth
Maximum bandwidth (in kbps) for known unicast traffic on the VSI.
Broadcast Restrain
Broadcast restraint bandwidth (in kbps).
Multicast Restrain
Multicast restraint bandwidth (in kbps).
Unknown unicast restraint bandwidth (in kbps).
MAC Learning
State of the MAC learning feature.
MAC Tabel Limit
Maximum number of MAC address entries on the VSI.
If the VSI does not limit the maximum number of MAC address entries, this field displays Unlimited.
MAC Learning rate
MAC address entry learning rate of the VSI.
MAC aging time for dynamic local-MAC entries, in seconds.
If dynamic local-MAC entries do not age out, this field displays NotAging.
MAC aging time for dynamic remote-MAC entries, in seconds.
If dynamic remote-MAC entries do not age out, this field displays NotAging.
Drop Unknown
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached.
PW Redundancy Mode
PW redundancy operation mode:
·     Slave—Master/slave mode and the local PE operates as the slave node.
·     Master—Master/slave mode and the local PE operates as the master node.
·     Independent—Independent mode.
Flooding
State of the VSI's flooding feature.
This field is not supported by VPLS.
ESI
Ethernet segment identifier of the VSI.
Redundancy Mode
Redundancy backup mode:
·     All-active.
·     Single-active.
Whether PW-to-AC straight forwarding has been enabled for the VSI.
Statistics
Packet statistics state.
Input Statistics
Incoming traffic statistics:
Output statistics
Outgoing traffic statistics:
Input Rate
Incoming traffic rate:
Output Rate
Outgoing traffic rate:
VXLAN ID
VXLAN ID.
EVPN Encapsulation
EVPN encapsulation type:
·     VXLAN.
·     MPLS.
·     SRv6.
SRv6 SIDs
SRv6 SIDs of the VSI.
Dt2U SID
SRv6 SID used for unicast forwarding in the EVPN VPLS over SRv6 network. The values in parentheses are the length of each segment in the SID, which are the locator length, opcode length, and argument length in sequence. The total length of those segments is 128.
Dt2Ul SID
SRv6 SID used for unicast forwarding over the bypass tunnel at the multihomed EVPN VPLS over SRv6 site. The values in parentheses are the length of each segment in the SID, which are the locator length, opcode length, and argument length in sequence. The total length of those segments is 128.
Dt2M SID
SRv6 SID used for flood forwarding in the EVPN VPLS over SRv6 network. The values in parentheses are the length of each segment in the SID, which are the locator length, opcode length, and argument length in sequence. The total length of those segments is 128.
SRv6 Tunnels
SRv6 tunnels on the VSI.
Peer
IPv6 address of the PW remote PE.
Link ID
Link ID of the SRv6 tunnel on the VSI.
SRv6 tunnel state, which can be Up, Down, Blocked, or Defect.
ACs
ACs of the VSI.
AC
For a Layer 3 interface, this field displays the interface name.
For an Ethernet service instance, this field displays the name of the Ethernet service instance and the name of the Layer 2 interface where the Ethernet service instance name resides.
Link ID
Link ID of the AC on the VSI.
AC state, which can be Up or Down.
Statistics
AC packet statistics state.
Use display l2vpn xconnect-group to display L2VPN cross-connect group information.
display l2vpn xconnect-group [ evpn-srv6 | name group-name | static-srv6 ] [ count | verbose ]
display l2vpn xconnect-group name group-name connection connection-name [ verbose ]
evpn-srv6: Specifies cross-connect groups in the EVPN VPWS over SRv6 network using dynamically established SRv6 PWs.
name group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters.
connection connection-name: Specifies a cross-connect by its name, a case-sensitive string of 1 to 20 characters. The cross-connect name cannot contain hyphens (-). If you do not specify a cross-connect, this command displays information about all cross-connects in the specified cross-connect group.
static-srv6: Specifies cross-connect groups in the EVPN VPWS over SRv6 network using statically established SRv6 PWs.
count: Displays cross-connect group statistics.
verbose: Displays detailed cross-connect group information.
If you do not specify a cross-connect group, the evpn-srv6 keyword, or the static-srv6 keyword, this command displays information for all cross-connect groups.
If you do not specify the count or verbose keyword, this command displays brief cross-connect group information.
# Display brief information about all cross-connect groups in the EVPN VPWS over SRv6 network.
<Sysname> display l2vpn xconnect-group evpn-srv6
Status Codes: UP - Up, DN - Down, DF - Defect, BD - Blocked, AD - Admin Down,
              DL - Idle, DP - Duplicate
Total number of cross-connections: 1, 1 up, 0 down, 0 admin down
Xconnect-group                          Connection                          ST
Segment1                            ST  Segment2                            ST
vpna                                    pw1                                 UP
XGE3/1/2                            UP  EVPN   2::2                         UP
# Display statistics about all cross-connect groups in the EVPN VPWS over SRv6 network.
<Sysname> display l2vpn xconnect-group evpn-srv6 count
Table 9 Command output
ST
State of the cross-connect:
·     UP—The cross-connect is up.
·     DN—The cross-connect is down.
·     AD—The cross-connect is manually shut down by using the shutdown command.
Segment1 / Segment2
For an AC segment:
·     If the AC is a Layer 3 interface, this field displays the interface name.
·     If the AC is an Ethernet service instance, this field displays the Ethernet service instance name.
For an SRv6 tunnel segment, this field displays the establishment method of the SRv6 tunnel and the IPv6 address of the remote PE. Only the EVPN establishment method is supported.
ST
If this field displays AC state, the following options are available:
·     UP—The AC is up.
·     DN—The AC is down.
If this field displays SRv6 tunnel state, the following options are available:
·     UP—The tunnel is up.
·     DN—The tunnel is down.
·     DF—BFD detects that the tunnel has defects.
·     BD—The tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly.
·     DL—The input SID of the tunnel is not available.
·     DP—This option is not supported in the current software version.
# Display detailed information about all cross-connect groups in the EVPN VPWS over SRv6 network.
<Sysname> display l2vpn xconnect-group verbose
  Connection ID         : 1
  State                 : Up
  MTU                   : 1500
  Diffserv Mode         : -
  Compress              : Disabled
  Flavor                : -
  SRv6 tunnels:
   Peer        : 2::2
   Link ID     : 0x1
   Sub Link ID : 0x1
   State       : Up
  ACs:
    AC                                 Link ID    State
    XGE3/1/1                           0x0        Up
Xconnect-group Name: vpnb
 Connection Name        : pw2
  Connection ID         : 1
  State                 : Up
  MTU                   : 1500
  Diffserv Mode         : -
  Compress              : Disabled
  Flavor                : -
  Static SRv6 tunnels:
   Peer                 : 11::9
   Link ID              : 0x0
   Sub Link ID          : 0x1
   State                : Up
   Remote Compress      : Disabled
  ACs:
    AC                                 Link ID    State
    XGE3/1/2                           0x0        Up
Table 10 Command output
Description of the cross-connect group.
Cross-connect group state:
·     Up—The cross-connect group is up.
·     Down—The cross-connect group is down.
·     Administratively down—The cross-connect group is manually shut down by using the shutdown command.
MTU
Maximum transmission unit of cross-connects.
PW Redundancy Mode
Diffserv Mode
·     pipe—Pipe mode.
Compress
Whether SID compression is enabled.
·     Enabled.
·     Disabled.
Flavor
Flavor attribute of the compressible SID.
·     coc-next—Indicates that the compressible SID carries the COC and NEXT flavors.
·     next—Indicates that the compressible SID carries the NEXT flavor.
·     next wlib—Indicates that the compressible SID carries the NEXT flavor and uses the W-LIB space to allocate G-SID.
SRv6 tunnels
Information about dynamic SRv6 PWs.
Static SRv6 tunnels
Information about static SRv6 PWs.
Peer
IPv6 address of the SRv6 PW remote PE.
Link ID
Link ID of the SRv6 PW on the cross-connect.
Sub Link ID
Sublink ID of the SRv6 PW on the cross-connect. The sublink ID of an SRv6 PW identifies the SRv6 PW among all SRv6 PWs with the same link ID.
SRv6 PW state, which can be Up, Down, Blocked, or Defect.
Remote Compress
Whether remote SID compression is enabled.
·     Enabled.
·     Disabled.
ACs
AC information.
AC
Link ID
Link ID of the AC on the cross-connect.
Statistics
Use encapsulation source-address to specify a source address for the outer IPv6 header of SRv6 VPN packets.
Use undo encapsulation source-address to restore the default.
encapsulation source-address ipv6-address [ ip-ttl ttl-value ]
No source address is specified for the outer IPv6 header of SRv6 VPN packets.
SRv6 view
ipv6-address: Specifies a source IPv6 address. The IPv6 address cannot be a loopback address (0:0:0:0:0:0:0:0 or ::), link-local address, multicast address, or unspecified address.
ip-ttl ttl-value: Specifies the TTL of the outer IPv6 header, in the range of 1 to 255. The default value is 255.
To ensure correct VPN traffic forwarding in an SRv6 VPN network, you must specify a source address for the outer IPv6 header of SRv6 VPN packets.
You must specify an IPv6 address of the local device as the source IPv6 address, and make sure the IPv6 address has been advertised by a routing protocol. As a best practice, specify a loopback interface address of the local device as the source IPv6 address.
# Specify 1::1 as the source address of SRv6 VPN packets in the outer IPv6 header and set the TTL of the outer IPv6 header to 200.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] encapsulation source-address 1::1 ip-ttl 200
Use evpn encapsulation srv6 to create an EVPN instance, specify it to use SRv6 encapsulation, and enter its view, or enter the view of an existing EVPN instance that uses SRv6 encapsulation.
Use undo evpn encapsulation to restore the default.
No EVPN instance is created.
VSI view
Cross-connect group view
Before you can configure EVPN settings for a VSI or cross-connect group, you must create an EVPN instance on it.
This command is mutually exclusive with the evpn encapsulation binding instance command. You cannot use them together on the same VSI.
# Create an EVPN instance and specify it to use SRv6 encapsulation on VSI aaa and enter its view.
[Sysname] vsi aaa
Use evpn encapsulation srv6 binding instance to bind a VSI to an EVPN instance and enter EVPN instance view.
evpn encapsulation srv6 binding instance instance-name [ vsi-tag tag-id ]
A VSI is not bound to any EVPN instance.
VSI view
instance-name: Specifies an EVPN instance by its name, a case-sensitive string of 1 to 31 characters.
vsi-tag tag-id: Specifies a VSI tag ID in the range of 1 to 4094. An EVPN instance uses tag IDs to identify VSIs when it is bound to multiple VSIs.
You can bind a VSI only to one EVPN instance.
This command is mutually exclusive with the evpn encapsulation srv6 command. You cannot use them together on the same VSI.
# Bind VSI vpna to EVPN instance evpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation srv6 binding instance evpna vsi-tag 1000
[Sysname-vsi-vpna-evpn-srv6-bind]
Use evpn vpws local-service-id remote-service-id to create an SRv6 PW on a VSI EVPN instance for intercommunication with an EVPN VPWS over SRv6 network.
Use undo evpn vpws local-service-id remote-service-id to delete an SRv6 PW from a VSI EVPN instance.
evpn vpws local-service-id local-service-id remote-service-id remote-service-id forwarding-preferred
Undo evpn vpws local-service-id local-service-id remote-service-id remote-service-id forwarding-preferred
No SRv6 PW exists on a VSI EVPN instance for intercommunication with an EVPN VPWS over SRv6 network.
local-service-id local-service-id: Specifies a local service ID in the range of 4096 to 16777215.
remote-service-id remote-service-id: Specifies a remote service ID in the range of 4096 to 16777215.
forwarding-preferred: Forwards BUM traffic received from ACs only through the PW created by using this command.
Use this command in VSI EVPN instance view to create an SRv6 PW for intercommunication between EVPN VPLS over SRv6 and EVPN VPWS over SRv6 networks.
# On the EVPN instance for VSI vpna, create an SRv6 PW for intercommunication with an EVPN VPWS over SRv6 network. The local service ID for the SRv6 PW is 5001 and the remote service ID is 5000.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-srv6] evpn vpws local-service-id 5001 remote-service-id 5000 forwarding-preferred
export route-policy
Use export route-policy to apply an export routing policy to an EVPN instance.
Use undo export route-policy to restore the default.
No export routing policy is applied to an EVPN instance.
EVPN instance view
route-policy: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can specify an export routing policy to filter advertised routes or modify their route attributes for EVPN.
# Apply export routing policy poly-1 to the EVPN instance on VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna-evpn-srv6] route-distinguisher 1:1
[Sysname-vsi-vpna-evpn-srv6] export route-policy poly-1
route-policy (Layer 3—IP Routing Command Reference)
forwarding mode
Use forwarding mode to configure the Layer 2 forwarding mode for the EVPN VPLS over SRv6 network.
Use undo forwarding mode to restore the default.
forwarding mode { double-vid | mac | svid-only }
The MAC forwarding mode is used. The device performs Layer 2 forwarding based on the destination MAC addresses of data frames.
Ethernet service instance view
EVPN instance view
double-vid: Specifies double-VID forwarding mode, in which the device performs Layer 2 forwarding based on both the inner and outer VLAN IDs (CVLAN and SVLAN tags) of data frames.
mac: Specifies MAC forwarding mode, in which the device performs Layer 2 forwarding based on the destination MAC addresses of data frames.
svid-only: Specifies SVID-only forwarding mode, in which the device performs Layer 2 forwarding based on the outer VLAN IDs (SVLAN tags) of data frames.
Application scenarios
Typically in an EVPN VPLS over SRv6 network, the access device must learn the MAC addresses of all users to the MAC address table. If a large number of users exist, the MAC address table space might become insufficient. To address this issue, you can configure the device to use the MAC address entries carrying VLAN information to guide packet forwarding.
This feature is supported only in the EVPN VPLS over SRv6 network.
To use the VLAN forwarding mode, make sure the MAC address table of the VSI contains MAC address entries based on VLAN information.
The Layer 2 forwarding mode specified by this command must match the MAC learning mode specified by the learning mode command.
Operating mechanism
EVPN VPLS over SRv6 supports the following Layer 2 forwarding modes:
·     MAC forwarding mode—The device searches the MAC address table based on the destination MAC address of data frames to forward the Layer 2 data frames.
·     Double-VID forwarding mode—Upon receiving a Layer 2 data frame, the device searches the MAC address table based on the VLAN information carried in the frame to forward the data frame. In this mode, the device forwards the data frame based on both the inner and outer VLAN IDs of the data frame.
·     SVID-only forwarding mode—Upon receiving a Layer 2 data frame, the device searches the MAC address table based on the VLAN information carried in the frame to forward the data frame. In this mode, the device forwards the data frame based on only the outer VLAN ID of the data frame.
# In Ethernet service instance view, set double-VID forwarding mode to perform Layer 2 forwarding based on both inner and outer VLAN IDs of data frames.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] service-instance 200
[Sysname-Ten-GigabitEthernet3/1/1-srv200] forwarding mode double-vid
learning mode
import route-policy
Use import route-policy to apply an import routing policy to an EVPN instance.
Use undo import route-policy to restore the default.
No import routing policy is applied to an EVPN instance. The EVPN instance accepts a route when the route targets of the route match local import route targets.
EVPN instance view
You can specify an import routing policy to filter received routes or modify their route attributes for EVPN.
# Apply import routing policy poly-1 to the EVPN instance on VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna-evpn-srv6] import route-policy poly-1
learning mode
Use learning mode to specify the MAC learning mode for the EVPN VPLS over SRv6 network.
Use undo learning mode to restore the default.
learning mode { disable | double-vid | mac | svid-only }
undo learning mode
Source MAC learning mode is enabled.
disable: Disables MAC learning. In this situation, you can only configure static MAC address entries.
double-vid: Specifies double-VID learning mode, in which the device generates MAC entries based on both the inner and outer VLAN IDs (CVLAN and SVLAN tags) of data frames.
mac: Specifies source MAC learning mode, in which the device generates MAC entries based on the source MAC addresses of data frames.
svid-only: Specifies SVID-only learning mode, in which the device generates MAC entries based on the outer VLAN IDs (SVLAN tags) of data frames.
Typically in an EVPN VPLS over SRv6 network, the access device must learn the MAC addresses of all users to the MAC address table. If a large number of users exist, the MAC address table space might become insufficient. To address this issue, you can enable learning MAC address entries that carry VLAN information. This type of MAC learning can avoid MAC address table space shortages caused by learning original MAC address entries from users.
The learning mode specified by this command must match the Layer 2 forwarding mode specified by the forwarding mode command.
Operating mechanism
The device supports the following MAC learning modes:
·     Source MAC learning mode—The device generates MAC address entries based on the source MAC addresses of data frames.
·     SVID-only learning mode—The device generates MAC address entries based on the outer VLAN IDs (SVLAN tags) of data frames. The MAC address in a MAC address entry uses the 0-SVLAN tag-0 format.
·     Double-VID learning mode—The device generates MAC address entries based on the inner and outer VLAN IDs (CVLAN and SVLAN tags) of data frames. The MAC address in a MAC address entry uses the 0-SVLAN tag-CVLAN tag format.
# In Ethernet service instance view, enable double-VID learning mode for MAC address entries.
[Sysname-Ten-GigabitEthernet3/1/1-srv200] learning mode double-vid
forwarding mode
locator-sbfd enable
Use locator-sbfd enable to enable SBFD for SRv6 locators.
Use undo locator-sbfd enable to restore the default.
locator-sbfd enable [ template template-name ] [ prefix-list prefix-list-name ]
SBFD is not configured for SRv6 locators.
SRv6 view
template template-name: Specifies a BFD template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, an SBFD session uses the multihop BFD parameters configured in system view.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the system performs SBFD on all locators which are the recursive nexthops of routes.
In the IP L3VPN over SRv6 BE, EVPN L3VPN over SRv6 BE, EVPN VPWS over SRv6 BE, EVPN VPLS over SRv6 BE, or public IP over SRv6 BE scenario, with FRR enabled on a local PE, the PE can use the backup path upon failure of the primary path when a peer CE is dualhomed to two PEs. For fast traffic switchover to the backup path when the primary path fails, configure this feature on the local PE to detect connectivity of the SRv6 locator advertised by the peer PE (the SRv6 locator is the recursive nexthop address of private or public network routes).
Operating mechanism
SBFD uses the following procedure to detect connectivity of SRv6 locators:
1.     The initiator (local PE) sends an SBFD packet with the destination IP address as the network segment for the SID identified by an SRv6 locator.
2.     Upon receiving the SBFD packet, the reflector (peer PE) identifies whether the discriminator in the packet is consistent with the local discriminator. If they are consistent, the reflector sends an SBFD response to the initiator through IPv6 routing. If they are inconsistent, the reflector discards the SBFD packet.
3.     The initiator switches to the backup path if it does not receive an SBFD response before the timeout timer expires. If it receives an SBFD response before the timeout timer expires, the SRv6 locator is reachable.
For this feature to take effect, perform the following tasks:
·     Execute the sbfd destination ipv6 remote-discriminator command on the local PE to associate the destination IPv6 address of the detected path with the remote discriminator of the SBFD session for the initiator.
·     Execute the sbfd local-discriminator command on the peer device of the main path to set the local discriminator for the reflector and make sure the discriminator is consistent on the local PE and peer PE.
# Enable SBFD for SRv6 locators.
[Sysname-segment-routing-ipv6] locator-sbfd enable
sbfd destination ipv6 remote-discriminator (High Availability Command Reference)
sbfd local-discriminator (High Availability Command Reference)
Use nexthop interface to specify a next hop to which an End.DX4 SID can be dynamically allocated and specify the output interface of the next hop.
Use undo nexthop to restore the default.
nexthop nexthop-address interface interface-type interface-number
undo nexthop nexthop-address
No End.DX4 SID is allocated to a next hop.
nexthop-address: Specifies a next hop by its IPv4 address.
interface-type interface-number: Specifies an output interface by its type and number.
This command is applicable to the IPv4 MPLS L3VPN over SRv6, IPv4 EVPN L3VPN over SRv6, or public network IPv4 over SRv6 scenario to accelerate traffic forwarding. This command allocates an End.DX4 SID to the specified next hop for BGP IPv4 routes and associates the next hop with an output interface.
Use one of the following methods to allocate End.DX4 SIDs to next hops:
·     Use this command to dynamically allocate an End.DX4 SID to a next hop from the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in this command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot dynamically allocate an End.DX4 SID to the next hop.
·     Use the opcode end-dx4 vpn-instance command to manually configure an End.DX4 SID in the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in the opcode end-dx4 vpn-instance command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot use the manually configured End.DX4 SID to forward traffic.
If both methods are used for the same next hop, the manually configured End.DX4 SID takes precedence over the dynamically allocated one.
You can specify only one output interface for one next hop. To change the output interface of a next hop, first use the undo nexthop command to remove the original next hop and output interface association.
The device might be unable to dynamically allocate SIDs to BGP IPv4 routes based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX4 SIDs, it allocates the End.DT4 SID or End.DT46 SID of the VPN instance or public instance to the routes.
# In BGP IPv4 SR next hop view, allow the system to allocate an End.DX4 SID to next hop 10.1.1.2 and specify Ten-GigabitEthernet 3/1/1 as the output interface of the next hop.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv4] segment-routing ipv6 apply-sid specify-nexthop
[Sysname-bgp-default-sid-np-ipv4] nexthop 10.1.1.2 interface ten-gigabitethernet 3/1/1
opcode
Use nexthop interface to specify a next hop to which an End.DX6 SID can be dynamically allocated and specify the output interface of the next hop.
nexthop nexthop-ipv6-address interface interface-type interface-number
undo nexthop nexthop-ipv6-address
No End.DX6 SID is allocated to a next hop.
BGP-VPN SRv6 next hop view
BGP SRv6 next hop view
nexthop-ipv6-address: Specifies a next hop by its IPv6 address.
This command is applicable to the IPv6 MPLS L3VPN over SRv6, IPv6 EVPN L3VPN over SRv6, or public network IPv6 over SRv6 scenario to accelerate traffic forwarding. This command allocates an End.DX6 SID to the specified next hop for BGP IPv6 routes and associates the next hop with an output interface.
Use one of the following methods to allocate End.DX6 SIDs to next hops:
·     Use this command to dynamically allocate an End.DX6 SID to a next hop from the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in this command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot dynamically allocate an End.DX6 SID to the next hop.
·     Use the opcode end-dx6 vpn-instance command to manually configure an End.DX6 SID in the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in the opcode end-dx6 vpn-instance command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot use the manually configured End.DX6 SID to forward traffic.
If both methods are used for the same next hop, the manually configured End.DX6 SID takes precedence over the dynamically allocated one.
The device might be unable to dynamically allocate SIDs to BGP IPv6 routes based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX6 SIDs, it allocates the End.DT6 SID or End.DT46 SID of the VPN instance or public instance to the routes.
# In BGP SRv6 next hop view, allow the system to allocate an End.DX6 SID to next hop 10::1:2 and specify Ten-GigabitEthernet 3/1/1 as the output interface of the next hop.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 unicast
[Sysname-bgp-default-ipv6] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv6] segment-routing ipv6 apply-sid specify-nexthop
[Sysname-bgp-default-sid-np-ipv6] nexthop 10::1:2 interface ten-gigabitethernet 3/1/1
opcode
peer
Use peer to configure a static SRv6 PW for a cross-connect and enter cross-connect static SRv6 PW view, or enter the view of an existing cross-connect static SRv6 PW.
Use undo peer to delete a static SRv6 PW.
peer ipv6-address end-dx2-sid remote-locator locator-name opcode opcode [ compress [ coc-next | next [ wlib ] ] ] [ color color-value | tunnel-policy tunnel-policy-name ]
undo peer ipv6-address end-dx2-sid remote-locator locator-name opcode opcode
No static SRv6 PWs exist.
ipv6-address: Specifies the IPv6 address of the remote PE on the static SRv6 PW.
remote-locator locator-name: Specifies the remote locator name, a case-sensitive string of 1 to 31 characters.
opcode opcode: Specifies the opcode for SRv6 SIDs, in the range of 1 to 2static-length-1, where the static-length is determined by the remote-locator command.
compress: Indicates that the corresponding remote SID is compressible. If you do not specify this keyword, the corresponding remote SID is not compressible.
coc-next: Indicates that the compressible remote SRv6 SID carries the COC and NEXT flavors.
next: Indicates that the compressible remote SRv6 SID carries the NEXT flavor.
next wlib: Indicates that the compressible remote SRv6 SID carries the NEXT flavor and uses the W-LIB space to allocate G-SID.
color color-value: Specifies the color value for the static SRv6 PW, in the range of 0 to 4294967295. If you do not specify this option, the color of the static SRv6 PW is not specified.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 126 characters. If you do not specify a tunnel policy, the tunnel policy specified by the static-srv6 local-service-id remote-service-id command is used for the static SRv6 PW.
Execute this command on the local PE. The local PE obtains the SRv6 SID assigned by the remote PE to the cross-connect through the locally configured locator and opcode.
# Configure a static SRv6 PW for a cross-connect and enter its view. Specify the IPv6 address of the remote PE of the PW as 1::1, the remote locator as aaa, and the opcode as 1.
[Sysname-xcg-vpna-pw1] static-srv6 local-service-id 1 remote-service-id 2 tunnel-policy 1
[Sysname-xcg-vpna-pw1-1-2] peer 1::1 end-dx2-sid remote-locator aaa opcode 1
[Sysname-xcg-vpna-pw1-1-2-1::1-aaa-1]
backup-peer
bypass-peer
peer advertise encap-type srv6
Use peer advertise encap-type srv6 to enable SRv6 encapsulation for the EVPN IP prefix advertisement routes advertised to a peer or peer group.
Use undo peer advertise encap-type srv6 to disable SRv6 encapsulation for the EVPN IP prefix advertisement routes advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise encap-type srv6
undo peer { group-name | ipv6-address [ prefix-length ] } advertise encap-type srv6
IP prefix advertisement routes use VXLAN encapsulation.
BGP EVPN address family view
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ipv6-address: Specifies a peer by its IPv6 address. The peer must exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify a subnet, you must specify both the ipv6-address and prefix-length arguments.
Use this command to enable the device to advertise EVPN IP prefix advertisement routes with SRv6 encapsulation in an EVPN L3VPN over SRv6 network.
Execute this command on the edge nodes of the EVPN L3VPN network and RRs.
# Enable SRv6 encapsulation for the IP prefix advertisement routes advertised to peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] peer 1::1 advertise encap-type srv6
peer advertise original-route
Use peer advertise original-route to enable the device to advertise original BGP VPNv4, VPNv6, or EVPN routes to a peer or peer group.
Use undo peer advertise original-route to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise original-route
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise original-route
The device advertises reoriginated BGP VPNv4, VPNv6, or EVPN routes to peers and peer groups after the peer re-originated command is executed.
BGP VPNv4 address family view
BGP VPNv6 address family view
ipv4-address: Specifies a peer by its IPv4 address. The peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. To specify a subnet, you must specify both the ipv4-address and mask-length arguments.
For this command to take effect, you must execute the peer re-originated command.
The device configured with the peer re-originated command advertises only reoriginated BGP VPNv4, VPNv6, or EVPN routes. For the device to advertise both original and reoriginated BGP VPNv4, VPNv6, or EVPN routes to a peer or peer group, execute the peer advertise original-route command on the device.
# In BGP VPNv4 address family view, enable the device to advertise original BGP VPNv4 routes to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 advertise original-route
peer re-originated
peer suppress re-originated
peer prefix-sid
Use peer prefix-sid to enable BGP to exchange SRv6 SID information with an IPv6 peer or peer group.
Use undo peer prefix-sid to restore the default.
peer { group-name | ipv6-address [ prefix-length ] } prefix-sid
undo peer { group-name | ipv6-address [ prefix-length ] } prefix-sid
BGP does not exchange SRv6 SID information with an IPv6 peer or peer group.
BGP IPv4 unicast address family view
BGP IPv6 unicast address family view
Use this command to enable IPv6 peers in an SRv6 VPN network to exchange SRv6 SID information through BGP VPNv4, VPNv6, IPv4 unicast, or IPv6 unicast routes.
# In BGP VPNv4 address family view, enable BGP to exchange SRv6 SID information with peer 2001:1::1.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 2001:1::1 prefix-sid
peer re-originated (BGP EVPN address family view)
Use peer re-originated to enable the device to reoriginate BGP EVPN routes based on the BGP EVPN routes received from a peer or peer group.
Use undo peer re-originated to disable the device from reoriginating BGP EVPN routes based on the BGP EVPN routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] [ replace-rt | stitch-l3vpn ]
peer { group-name | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] { [ replace-rt ] replace-sid | replace-sid [ replace-rt ] }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ]
The device does not reoriginate BGP EVPN routes based on received EVPN routes.
ip-prefix: Modifies IP prefix advertisement routes.
replace-rt: Replaces the L3 VXLAN ID, RD, and route targets of EVPN IP prefix advertisement routes with those of the matching local VPN instance, and adds MPLS labels or SRv6 SIDs to the routes if the replace-sid keyword is not specified or reallocates SRv6 SIDs to the routes in the matching local VPN instance if the replace-sid keyword is specified. If you do not specify the replace-rt keyword, the device performs the same operations except that it does not replace the route targets.
replace-sid: Deletes the SRv6 SIDs carried in the received BGP EVPN routes and reallocates SRv6 SIDs to the routes in the matching local VPN instance. If you do not specify this keyword, the device does not replace the SRv6 SIDs of routes.
stitch-l3vpn: Reoriginates IP prefix advertisement routes as VPNv4/VPNv6 routes without modifying the RD and route targets of the routes.
Use this command without the stitch-l3vpn keyword on an ASBR that connects the EVPN L3VPN and EVPN L3VPN over SRv6 networks. This command enables the ASBR to modify EVPN route information to realize intercommunication between the MPLS and SRv6 networks.
Use this command with the stitch-l3vpn keyword on an ASBR that connects the MPLS L3VPN and EVPN L3VPN over SRv6 networks or connects the EVPN L3VPN and IP L3VPN over SRv6 networks. This command enables conversion between EVPN routes and VPNv4/VPNv6 routes to realize intercommunication between the MPLS and SRv6 networks.
After you execute this command without the stitch-l3vpn keyword on an ASBR, the ASBR performs the following operations:
·     After receiving BGP EVPN routes from the EVPN L3VPN network, the ASBR performs the following operations:
a.     Matches the route targets of the routes with the import route targets of local VPN instances.
b.     Replaces the RD and route targets of the routes with those of the matching local VPN instance. In addition, the ASBR adds an SRv6 SID to the routes and maps the SRv6 SID of the routes to the private label of the routes.
c.     Advertises the reoriginated routes to the SRv6 network.
·     After receiving BGP EVPN routes from the SRv6 network, the ASBR performs the following operations:
d.     Matches the route targets of the routes with the import route targets of local VPN instances.
e.     Replaces the RD and route targets of the routes with those of the matching local VPN instance. In addition, the ASBR adds MPLS labels to the routes and maps the private label of the routes to the SRv6 SID of the routes.
f.     Advertises the reoriginated routes to the EVPN L3VPN network.
To allow inter-AS communication in an inter-AS SRv6 VPN network with SRv6 deployed in each AS, inter-AS advertisement of the locator subnet route information is required. For example, you can redistribute the locator subnet routing information from an IGP into BGP for inter-AS route advertisement. After the locator subnet routing information is advertised across the ASs, PE devices in different ASs can establish inter-AS SRv6 forwarding paths. However, in some scenarios, locator subnet routing information should not be advertised across ASs due to security concerns. In this case, you can specify the replace-sid keyword in this command to replace the SRv6 SID carried in a route with an SRv6 SID of the matching local VPN instance. In this way, the locator subnet routing information is not advertised to other ASs and the PEs in different ASs can establish inter-AS SRv6 fowarding paths.
After you execute this command with the stitch-l3vpn keyword on an ASBR, the ASBR performs the following operations after receiving BGP EVPN routes from the SRv6 network or MPLS network:
2.     Matches the route targets of the routes with the import route targets of local VPN instances.
3.     Reoriginates the matching IP prefix advertisement routes as VPNv4 or VPNv6 routes without modifying the RD or route targets of the routes. In addition, the ASBR adds MPLS labels to the routes and maps the private label of the routes to the SRv6 SID of the routes.
4.     Advertises the reoriginated routes to the MPLS L3VPN network.
This command enables the device to advertise only reoriginated routes to the specified peer or peer group. The original routes are not advertised.
If the RD of a received BGP EVPN route is identical to the RD of the matching local VPN instance, a device does not modify the route or reoriginate the route. As a result, the device does not advertise the route. As a best practice, assign unique RDs to VPN instances on different devices if you use this command.
# In BGP EVPN address family view, replace the RD and route targets of the EVPN routes received from peer 1.1.1.1 and add an MPLS label or SRv6 SID to the routes.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 re-originated replace-rt
peer re-originated (BGP VPNv4/VPNv6 address family view)
Use peer re-originated to enable the device to reoriginate BGP VPNv4 or VPNv6 routes based on the BGP VPNv4 or VPNv6 routes received from a peer or peer group.
Use undo peer re-originated to disable the device from reoriginating BGP VPNv4 or VPNv6 routes based on the BGP VPNv4 or VPNv6 routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ replace-rt | stitch-evpn ]
peer { group-name | ipv6-address [ prefix-length ] } re-originated { [ replace-rt ] replace-sid | replace-sid [ replace-rt ] }
The device does not reoriginate BGP VPNv4 or VPNv6 routes based on received BGP VPNv4 or VPNv6 routes.
replace-rt: Replaces the RD and route targets of VPNv4 or VPNv6 routes with those of the matching local VPN instance, and adds MPLS labels or SRv6 SIDs to the routes if the replace-sid keyword is not specified or reallocates SRv6 SIDs to the routes in the matching local VPN instance if the replace-sid keyword is specified. If you do not specify the replace-rt keyword, the device performs the same operations except that it does not replace the route targets.
replace-sid: Deletes the SRv6 SIDs carried in the received BGP VPNv4 or VPNv6 routes and reallocates SRv6 SIDs to the routes in the matching local VPN instance. If you do not specify this keyword, the device does not replace the SRv6 SIDs of routes.
stitch-evpn: Reoriginates VPNv4/VPNv6 routes as EVPN IP prefix advertisement routes without modifying the RD and route targets of the routes.
Use this command without the stitch-evpn keyword on an ASBR that connects the MPLS L3VPN and IP L3VPN over SRv6 networks. This command enables the ASBR to modify VPNv4 or VPNv6 route information to realize intercommunication between the MPLS and SRv6 networks.
Use this command with the stitch-evpn keyword on an ASBR that connects the EVPN L3VPN and IP L3VPN over SRv6 networks or connects the MPLS L3VPN and EVPN L3VPN over SRv6 networks. This command enables conversion between VPNv4/VPNv6 routes and EVPN routes to realize intercommunication between the MPLS and SRv6 networks.
After you execute this command without the stitch-evpn keyword on an ASBR, the ASBR performs the following operations:
·     After receiving BGP VPNv4 or VPNv6 routes from the MPLS L3VPN network, the ASBR performs the following operations:
·     After receiving BGP VPNv4 or VPNv6 routes from the SRv6 network, the ASBR performs the following operations:
f.     Advertises the reoriginated routes to the MPLS L3VPN network.
After you execute this command with the stitch-evpn keyword on an ASBR, the ASBR performs the following operations after receiving BGP VPNv4 or VPNv6 routes from the SRv6 network or MPLS network:
3.     Reoriginates the matching BGP VPNv4 or VPNv6 routes as EVPN IP prefix advertisement routes without modifying the RD or route targets of the routes. In addition, the ASBR adds MPLS labels to the routes and maps the private label of the routes to the SRv6 SID of the routes.
4.     Advertises the reoriginated routes to the EVPN L3VPN network.
If the RD of a received BGP VPNv4 or VPNv6 route is identical to the RD of the matching local VPN instance, a device does not modify the route or reoriginate the route. As a result, the device does not advertise the route. As a best practice, assign unique RDs to VPN instances on different devices if you use this command.
# In BGP VPNv4 address family view, replace the RD and route targets of the BGP VPNv4 routes received from peer 1.1.1.1 and add an MPLS label or SRv6 SID to the routes.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 re-originated replace-rt
peer srv6-endr-type
Use peer srv6-endr-type to configure the Endpoint Behavior value corresponding to the End.R SID carried in the routes sent to a peer or peer group.
Use undo peer srv6-endr-type to restore the default.
peer { group-name | ipv6-address [ prefix-length ] } srv6-endr-type type-value
undo peer { group-name | ipv6-address [ prefix-length ] } srv6-endr-type
The Endpoint Behavior value is 0x8018 for the End.R SID in the routes sent to peers.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command applies to all dynamic peers in the subnet.
type-value: Endpoint Behavior value, a hexadecimal number in the range of 1 to ffff. If the specified hexadecimal number contains less than four digits, the device regards the digits as low-order digits and automatically pads the high-order digits with zeros. For example, if you enter ab, the actual effective Endpoint Behavior value is 00ab.
In SRv6 VPN inter-AS option B scenarios, BGP VPNv4/VPNv6 or BGP EVPN routes between H3C ASBRs or between ASBRs and PEs must carry the H3C-proprietary End.R SID to guide the cross-AS forwarding of VPN packets.
In a BGP route, the SRv6 SID value is included in the Prefix-SID attribute. The Endpoint Behavior is also a field in the Prefix-SID attribute. Different types of SRv6 SIDs correspond to different Endpoint Behavior values. H3C sets the Endpoint Behavior value for End.R SID to 0x8018. Other vendors might use a different Endpoint Behavior value for the SRv6 SID for SRv6 VPN inter-AS option B. To avoid intercommunication issues between H3C devices and devices from other vendors, you can use this command to change the Endpoint Behavior value on H3C devices.
Recommended configuration
First identify the Endpoint Behavior value for the SRv6 SID used by a device to implement SRv6 VPN inter-AS option B. Then, execute this command on the H3C device to set the type-value to that Endpoint Behavior value. This ensures that the devices from other vendors can recognize the BGP routes carrying End.R SID sent from H3C devices.
# Set the Endpoint Behavior value to 10 for the End.R SID carried in the BGP VPNv4 routes sent to peer 2::2.
[Sysname] bgp 10
[Sysname-bgp-default-vpnv4] peer 2::2 srv6-endr-type 10
srv6-inter-as enable
peer srv6-vpn compatible
Use peer srv6-vpn compatible to enable SRv6 VPN compatibility for a peer or peer group.
Use undo peer srv6-vpn compatible to disable SRv6 VPN compatibility for a peer or peer group.
BGP VPNv4 address family view/BGP VPNv6 address family view:
peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible [ srv6-sid-transposition ]
undo peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible
BGP EVPN address family view:
peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible srv6-sid-transposition
SRv6 VPN compatibility is disabled. The device uses the non-transposition scheme defined in RFC 9252 to encapsulate the SRv6 SIDs carried in advertised BGP routes.
group-name: Specifies an existing peer group by its name, a case-sensitive string of 1 to 47 characters.
ipv6-address: Specifies an existing peer by its IPv6 address.
prefix-length: Specifies the prefix length, in the range of 0 to 128. If you specify this argument, you specify the dynamic peers in the specified network.
srv6-sid-transposition: Uses the transposition scheme defined in RFC 9252 to encapsulate the SRv6 SIDs carried in advertised BGP routes. If you do not specify this keyword, the device encapsulates the SRv6 SIDs carried in advertised BGP routes in the format defined in draft-dawra-idr-srv6-vpn.
In an IP L3VPN over SRv6 or EVPN L3VPN over SRv6 network, the BGP VPNv4, VPNv6, or EVPN routes exchanged between PEs carry SRv6 SIDs. When the SRv6 SIDs are encapsulated in different formats, the BGP route advertisement fails. To resolve this issue, you can execute this command to configure the SRv6 SID encapsulation format to be the same as that supported by the peer device.
# Configure the device to use the Transposition Scheme format defined in RFC 9252 to encapsulate the SRv6 SIDs in the BGP routes sent to peer 2::2.
[Sysname] bgp 1
[Sysname-bgp-default-vpnv4] peer 2::2 srv6-vpn compatible srv6-sid-transposition
Use peer suppress re-originated to suppress advertisement of reoriginated BGP EVPN, BGP VPNv6, or BGP VPNv4 routes to a peer or peer group.
Use undo peer suppress re-originated to restore the default.
In BGP VPNv4 address family view/BGP VPNv6 address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated
In BGP EVPN address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated ip-prefix
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated ip-prefix
The device advertises reoriginated BGP EVPN, BGP VPNv6, or BGP VPNv4 routes to peers and peer groups after the peer re-originated command is executed.
ip-prefix: Suppresses advertisement of reoriginated IP prefix advertisement routes.
The device configured with the peer re-originated and peer advertise original-route commands advertises both original and reoriginated BGP EVPN, BGP VPNv6, or BGP VPNv4 routes. For the device to advertise only original BGP EVPN, BGP VPNv6, or BGP VPNv4 routes to a peer or peer group, execute the peer suppress re-originated command on the device.
# In BGP VPNv4 address family view, suppress advertisement of reoriginated BGP VPNv4 routes to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 suppress re-originated
peer re-originated
ping evpn vpls srv6
Use ping evpn vpls srv6 to test the connectivity of an SRv6 PW in an EVPN VPLS over SRv6 network by pinging a remote PE from the local PE.
ping evpn vpls srv6 vsi vsi-name mac mac-address [ end-op endop ] [ force-match-slice ] [ -a source-ipv6 | -c count | -h hop-limit | -m interval | -r reply-mode | -s packet-size | { -service-class class-value | -te-class te-class-value } | -t time-out | -tc tc ] *
mac mac-address: Specifies a host attached to a remote PE by its MAC address in H-H-H format. Do not specify a broadcast MAC address, multicast MAC address, or all-zeros MAC address.
end-op endop: Specifies an End.OP SID to be added to MPLS echo requests. The End.OP SID is used to locate the destination node. If you do not specify an End.OP SID, the device does not add an End.OP SID to MPLS echo requests.
force-match-slice: Enables force matching of network slice instance IDs. If source address slicing is used, you must specify this option. In addition, to have this option take effect, you must specify the strict-mode keyword when you execute the network-slice command to specify the NSI ID for an SRv6 TE policy candidate path. When this parameter is specified, if an MPLS echo request to be forwarded by the SRv6 PW contains a slice ID, the request can be sent successfully only if the slice ID in the request is the same as the network slice instance ID of the network slice channel on the packet output interface. If the IDs are inconsistent, the device discards the MPLS echo request, causing the ping to fail. If this parameter is not specified, the device does not check the slice ID in MPLS echo requests before sending the requests. For MPLS echo requests without a slice ID, this parameter does not take effect.
-a source-ipv6: Specifies the source IPv6 address of MPLS echo requests. The specified IPv6 address must be advertised to remote PEs through a routing protocol. If you do not specify a source IPv6 address, the source IPv6 address of MPLS echo requests is the IPv6 address specified by using the encapsulation source-address command.
-c count: Specifies the number of MPLS echo requests to be sent. The value range for the count argument is 1 to 4294967295, and the default value is 5.
-h hop-limit: Specifies the maximum number of hops allowed for an MPLS echo request. The value range for the hop-limit argument is 1 to 255, and the default value is 255.
-m interval: Specifies the interval at which an MPLS echo request is sent, in milliseconds. The value range for the interval argument is 1 to 10000, and the default value is 2000.
-r reply-mode: Specifies the reply mode used by the receiver (the remote PE) to reply to MPLS echo requests. The value for the reply-mode argument can be 2 or 4, and the default value is 2. If the mode is 2, the receiver replies using UDP. If the mode is 4, the receiver replies through the control channel of the application plane, where the reply packets are encapsulated with an SRH.
-s packet-size: Specifies the length of MPLS echo requests, in bytes. The value range for the packet-size argument is 80 to 1200, and the default value is 100. The specified packet length does not include the IPv6 header and UDP header length.
-service-class class-value: Specifies the service class value for MPLS echo requests. The value range is 1 to 15.  The default service class value is 255.
-te-class te-class-value: Specifies the TE class value for MPLS echo requests. The value range for the te-class-value argument is 1 to 65535, and the default value is 0.
-t time-out: Specifies the timeout time of MPLS echo replies, in milliseconds. The value range for the time-out argument is 0 to 65535, and the default value is 2000. If the local PE does not receive an MPLS echo reply within the timeout time after sending an MPLS echo request, it determines that the MPLS echo reply times out.
-tc tc: Specifies the traffic class value in MPLS echo requests. The value range for the tc argument is 0 to 255 and the default value is 0.
In an EVPN VPLS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to test the connectivity of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs.
# Test the connectivity of the SRv6 PW from the local PE to the remote PE attached to the host with MAC address 2-2-2 in VSI vpna.
<System> ping evpn vpls srv6 vsi vpna mac 2-2-2
Ping a remote PE in VSI vpna over SRv6 by reaching remote-MAC 0002-0002-0002: 100 data bytes.
Press CTRL+C to break.
100 bytes from 11::2: sequence=1 time=1 ms
100 bytes from 11::2: sequence=2 time=2 ms
100 bytes from 11::2: sequence=3 time=1 ms
100 bytes from 11::2: sequence=4 time=2 ms
100 bytes from 11::2: sequence=5 time=1 ms
--- Ping statistics for MAC 0002-0002-0002 ---
5 packets transmitted, 5 packets received, 0.0% packet lost
Round-trip min/avg/max = 1/1/2 ms
Table 11 Command output
Ping a remote PE through an SRv6 PW in VSI vpna by reaching remote-MAC 0002-0002-0002.
Each MPLS echo request contains 100 bytes.
Press escape key Ctrl+C to abort the ping operation.
Received MPLS echo replies from the device whose IPv6 address is 11::2.
·     bytes—Number of bytes in the MPLS echo reply.
·     Sequence—Packet sequence, used to determine whether a segment is lost, disordered or repeated.
·     time—Response time.
If no MPLS echo reply is received when the echo reply timeout time expires, the device displays Request time out.
Statistics on data received and sent in the ping operation.
Number of MPLS echo requests sent.
5 packets received
Number of MPLS echo replies received.
0.0% packet lost
Percentage of unacknowledged packets to the total packets sent.
Minimum, average, or maximum response time, in milliseconds.
tracert evpn vpls srv6
ping { evpn | static } vpws srv6
Use ping { evpn | static } vpws srv6 to test the connectivity of an SRv6 PW in an EVPN VPWS over SRv6 network by pinging a remote PE from the local PE.
ping { evpn | static } vpws srv6 xconnect-group group-name local-service-id remote-service-id [ peer ipv6-address ] [ end-op endop ] [ force-match-slice ] [ -a source-ipv6 | -c count | -h hop-limit | -m interval | -r reply-mode | -s packet-size | { -service-class class-value | -te-class te-class-value } | -t time-out | -tc tc ] *
evpn: Specifies a dynamic SRv6 PW.
static: Specifies a static SRv6 PW.
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. The string cannot contain a hyphen (-).
local-service-id: Specifies a local service ID in the range of 1 to 16777215.
remote-service-id: Specifies a remote service ID in the range of 1 to 16777215.
peer ipv6-address: Specifies a remote PE by its IPv6 address. You can specify this option in a multihomed EVPN VPWS over SRv6 network to detect the specified remote SRv6 PW. If you do not specify this option, this command detects only one of the SRv6 PWs.
end-op endop: Specifies an End.OP SID to be added to MPLS echo requests. The End.OP SID is used to locate the destination node. If you do not specify an End.OP SID, the local PE does not add an End.OP SID to MPLS echo requests.
force-match-slice: Enables force matching of network slice instance IDs. If source address slicing is used, you must specify this option. In addition, to have this option take effect, you must specify the strict-mode keyword when you execute the network-slice command to specify the NSI ID for an SRv6 TE policy candidate path. When this parameter is specified, if an MPLS echo request to be forwarded by the SRv6 PW contains a slice ID, the request can be sent successfully only if the slice ID in the request is the same as the network slice instance ID of the network slice channel on the packet output interface. If the IDs are inconsistent, the device discards the MPLS echo request, causing the ping to fail. If this parameter is not specified, the device does not check the slice IDs in MPLS echo requests before sending the requests. For MPLS echo requests without a slice ID, this parameter does not take effect.
-h hop-limit: Specifies the maximum number of hops allowed for an MPLS echo request. The value range for the hop-limit argument is 1 to 255 and the default value is 255.
-m interval: Specifies the interval at which an MPLS echo request is sent. The value range for the interval argument is 1 to 10000 milliseconds and the default value is 2000 milliseconds.
In an EVPN VPWS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to test the connectivity of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs.
# Ping a remote PE through an SRv6 PW with local service ID 2 and remote service ID 1 in cross-connect group xcga.
<Sysname> ping evpn vpws srv6 xconnect-group xcga 2 1
Ping a remote PE over SRv6 through a PW with local service ID 2 and remote service ID 1 in cross-connect group xcga: 100 data bytes.
100 bytes from 111::100: sequence=1 time=2 ms
100 bytes from 111::100: sequence=2 time=2 ms
100 bytes from 111::100: sequence=3 time=1 ms
100 bytes from 111::100: sequence=4 time=1 ms
100 bytes from 111::100: sequence=5 time=2 ms
--- Ping statistics for the PW with local ID 2 and remote ID 1 ---
5 packets transmitted,5 packets received,0.0% packet lost
Table 12 Command output
100 bytes from 111::100: sequence=5 time=1 ms
Received MPLS echo replies from the device whose IPv6 address is 111::100.
·     sequence—Packet sequence, used to determine whether a segment is lost, disordered or repeated.
5 packets received
0.0% packet lost
tracert { evpn | static } vpws srv6
reset l2vpn statistics srv6-pw
Use reset l2vpn statistics srv6-pw to clear SRv6 PW packet statistics.
reset l2vpn statistics srv6-pw [ vsi vsi-name [ peer ipv6-address ] | xconnect-group group-name [ connection connection-name ] ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
peer ipv6-address: Specifies a remote PE by its IPv6 address to clear outgoing packet statistics for the SRv6 PWs between the local PE and the specified remote PE. If you do not specify a remote PE, this command clears all SRv6 PW packet statistics for the specified VSI.
connection connection-name: Specifies a cross-connect by its name, a case-sensitive string of 1 to 20 characters. If you do not specify a cross-connect, this command clears all SRv6 PW packet statistics for the specified cross-connect group.
This command clears packet statistics for both primary and backup SRv6 PWs.
If you do not specify any parameters, this command clears all SRv6 PW packet statistics.
# Clear all SRv6 PW packet statistics.
<Sysname> reset l2vpn statistics srv6-pw
statistics enable
restrain
Use restrain to configure the restraint bandwidth for broadcast, multicast, or unknown unicast traffic.
Use undo restrain to restore the default.
restrain { broadcast | multicast | unknown-unicast } bandwidth
undo restrain { broadcast | multicast | unknown-unicast }
The restraint bandwidth for broadcast, multicast, or unknown unicast traffic is 5120 kbps.
broadcast: Specifies the restraint bandwidth for broadcast traffic.
multicast: Specifies the restraint bandwidth for multicast traffic.
unknown-unicast: Specifies the restraint bandwidth for unknown unicast traffic. Unknown unicast packets refer to unicast packets whose destination MAC addresses are not in the MAC address table.
bandwidth: Restraint bandwidth value in kbps. The value range is 0 to 4194303.
When the bandwidth of broadcast, multicast, or unknown unicast traffic exceeds the configured restraint bandwidth, the device drops the exceeding traffic.
# In the VSI EVPN instance view, set the restraint bandwidths for broadcast, multicast, and unknown unicast all to 100 kbps.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation srv6
[Sysname-vsi-aaa-evpn-srv6] restrain broadcast 100
[Sysname-vsi-aaa-evpn-srv6] restrain multicast 100
[Sysname-vsi-aaa-evpn-srv6] restrain unknown-unicast 100
revertive wtr
Use revertive wtr to configure the switchback delay (wait-to-restore time).
Use undo revertive to restore the default.
revertive wtr wtr-time
undo revertive wtr
The switchback delay time to 0, which means switchback delay is disabled.
EVPN instance view
Cross-connect view
wtr wtr-time: Specifies the switchback delay time (wait-to-restore time), in the range of 0 to 3600, in seconds.
In a multihomed EVPN VPLS over SRv6 network, upon recovery of the primary PE or access link attached to the primary PE, the primary PE generates an AD Per EVI route. It then advertises the AD Per EVI route to the remote PE through the BGP EVPN peer relationship. Upon receiving the AD Per EVI route, the remote PE generates an associated forwarding entry, and switches traffic from the backup-PE-attached path over to the primary-PE-attached path. Packet loss might occur because the associated forwarding entries are not completely generated on the primary PE. To prevent this issue, you can configure an appropriate switchover delay timer on the remote PE. This configuration prevents the remote PE from immediately generating a forwarding entry upon receiving the EVI AD route. When the forwarding entries become stable on the primary PE, and the delay timer expires, the remote PE generates a new forwarding entry, and switches traffic to the primary PE, avoiding packet loss.
In a multihomed EVPN VPWS over SRv6 network, upon recovery of the primary PW or PE, service traffic is switched back to the primary PW. Packet loss might occur because the associated forwarding entries are not completely generated on the primary PE. To prevent this issue, you can configure an appropriate switchover delay timer on the remote PE. Traffic is sent to the primary PE when the forwarding entries become stable on the primary PE, avoiding packet loss.
To configure this command in cross-connect view, you must also configure the route-select delay command.
# Set the switchback delay to 120 seconds.
[Sysname] vsi xxx
[Sysname-vsi-xxx] evpn encapsulation srv6
[Sysname-vsi-xxx-evpn-srv6] revertive wtr 120
Use segment-routing ipv6 to specify a route recursion mode.
Use undo segment-routing ipv6 to restore the default.
In EVPN instance view:
segment-routing ipv6 { best-effort | traffic-engineering | traffic-engineering best-effort [ local-preference ] }
In cross-connect group EVPN instance view/VSI EVPN instance view/cross-connect static SRv6 view:
segment-routing ipv6 { best-effort | traffic-engineering [ track-bfd ] | traffic-engineering [ track-bfd ] best-effort [ local-preference ] }
The device searches the IPv6 routing table based on the next hop of a matching route to forward traffic.
EVPN instance view
Cross-connect group EVPN instance view
Cross-connect static SRv6 view
best-effort: Specifies the SRv6 BE mode.
traffic-engineering: Specifies the SRv6 TE mode.
traffic-engineering best-effort: Specifies the SRv6 TE and SRv6 BE hybrid mode.
local-preference: For multilevel FRR formed by multiple SRv6 TE and SRv6 BE paths, this keyword makes the FRR primary path consist of one primary SRv6 TE path and one primary SRv6 BE path, and the FRR backup path consist of one backup SRv6 TE path and one backup SRv6 BE path. The device selects the traffic forwarding path in primary SRv6 TE path, primary SRv6 BE path, backup SRv6 TE path, and backup SRv6 BE path order. This keyword is applicable only to dual-homing scenarios.
track-bfd: Associates the SRv6 TE policy that contains paths between two PEs with the static BFD session specified for testing the IP connectivity between the PEs in SRv6 TE mode. For this purpose, you must specify this keyword and create a static BFD session to test the IP connectivity between the two PEs. If the static BFD session goes down, the state of the SRv6 TE policy also changes to down. This mechanism avoids traffic forwarding failure caused by path disconnectivity.
Use this command in an EVPN VPWS over SRv6 or EVPN VPLS over SRv6 network.
After the PE receives a customer packet destined for an End.DX2, End.DT2M, or End.DT2U SID, it forwards the packet according to the route recursion mode.
·     SRv6 BE mode—This mode is also called SID-based forwarding mode. In this mode, the PE first encapsulates the End.DX2, End.DT2M, or End.DT2U SID into the packet. Then, the PE searches the IPv6 routing table based on the SID encapsulated in the packet to forward the packet.
·     SRv6 TE mode—This mode is also called next hop-based forwarding mode. In this mode, when the PE forwards the packet, it first searches the tunnel policies for a matching SRv6 TE policy based on the next hop of a matching route. Then, the PE adds an SRH to the packet. The SRH includes the End.DX2, End.DT2M, or End.DT2U SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy.
·     SRv6 TE and SRv6 BE hybrid mode—In this mode, the PE preferentially uses the SRv6 TE mode to forward the packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6 BE mode.
# In VSI EVPN instance view, specify the SRv6 BE route recursion mode.
[Sysname] vsi aaa
[Sysname-vsi-aaa-mpls-srv6] segment-routing ipv6 best-effort
# In cross-connect group EVPN instance view, specify the SRv6 BE route recursion mode.
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] evpn encapsulation srv6
[Sysname-xcg-vpna-evpn-mpls] segment-routing ipv6 best-effort
bfd static (High Availability Command Reference)
segment-routing ipv6 apply-sid all-nexthop (BGP IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid all-nexthop to dynamically allocate an End.DX4 or End.DX6 SID to each next hop of BGP IPv4 or IPv6 routes in the public network.
Use undo segment-routing ipv6 apply-sid all-nexthop to restore the default.
A PE allocates the End.DT4, End.DT6, or End.DT46 SID of the public instance to BGP IPv4 or IPv6 routes in the public network.
Use this command to forward an SRv6 decapsulated public network packet to the next hop without looking up the routing table of the public network.
This command is applicable to the public network IPv4 or IPv6 over SRv6 scenario. By default, a PE allocates the same SID to all BGP public network routes. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the public network based on the SID for an optimal route. To forward the packet to the next hop without looking up the routing table, use this command.
This command dynamically allocates an End.DX4 or End.DX6 SID to each next hop for the BGP public network IPv4 or IPv6 routes. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
Before you use this command in BGP IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
In the same view, the segment-routing ipv6 apply-sid all-nexthop command is mutually exclusive with the segment-routing ipv6 apply-sid specify-nexthop command. Do not use both commands in the same view.
The device might be unable to dynamically allocate SIDs to BGP public network routes based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX4 or End.DX6 SIDs, it allocates the End.DT4 SID, End.DT6 SID, or End.DT46 SID of the public instance to the routes.
The segment-routing ipv6 apply-sid all-nexthop command does not assign End.DX4 or End.DX6 SIDs to direct routes.
# In BGP IPv4 unicast address family view, enable the system to automatically allocate an End.DX4 SID to each next hop of BGP public network routes.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing ipv6 apply-sid all-nexthop
segment-routing ipv6 apply-sid all-nexthop (BGP-VPN IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid all-nexthop to dynamically allocate an End.DX4 or End.DX6 SID to each next hop of BGP private network routes.
segment-routing ipv6 apply-sid all-nexthop [ evpn ]
undo segment-routing ipv6 apply-sid all-nexthop [ evpn ]
VPN instance-based SID allocation is used for BGP private network routes.
BGP-VPN IPv4 unicast address family view
BGP-VPN IPv6 unicast address family view
evpn: Allocates SIDs to private network routes based on the route next hops when the routes are converted to EVPN routes. If you do not specify this keyword, the command allocates SIDs to private network routes based on the route next hops when the routes are converted to BGP VPNv4 or VPNv6 routes.
Use this command to forward an SRv6 decapsulated VPN packet to the next hop without looking up the routing table of the matching VPN instance.
This command is applicable to MPLS L3VPN over SRv6 and EVPN L3VPN over SRv6 networks. By default, a PE allocates the same SID to all BGP private network routes of a VPN instance. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the VPN instance based on the SID for an optimal route. Then, the PE forwards the packet to a CE. To forward the packet to the next hop without looking up the routing table, use this command.
This command dynamically allocates an End.DX4 or End.DX6 SID to each next hop of the BGP private network routes in a VPN instance based on the next hop addresses. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
Before you use this command in BGP-VPN IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
The device might be unable to dynamically allocate SIDs to BGP private network routes in a VPN instance based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX4 or End.DX6 SIDs, it allocates the End.DT4 SID, End.DT6 SID, or End.DT46 SID of the VPN instance to the routes.
# In BGP-VPN IPv4 unicast address family view, enable the device to dynamically allocate an End.DX4 or End.DX6 SID to each next hop of BGP private network routes.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 apply-sid all-nexthop
segment-routing ipv6 apply-sid compress (BGP IPv4/IPv6 address family view/BGP-VPN IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid compress to configure the flavors carried by SIDs dynamically allocated from the COC16 locator.
Use undo segment-routing ipv6 apply-sid compress to restore the default.
In BGP IPv4 unicast address family view/BGP IPv6 unicast address family view:
segment-routing ipv6 apply-sid compress { coc-next | next [ wlib ] } [ end-dt46 ]
In BGP-VPN IPv4 unicast address family view/BGP-VPN IPv6 unicast address family view:
segment-routing ipv6 apply-sid compress { coc-next | next [ wlib ] } [ evpn ] [ end-dt46 ]
undo segment-routing ipv6 apply-sid compress [ evpn ]
For COC16 locators in default mode, SRv6 SIDs carrying the COC and NEXT flavors are allocated from the compressed Function portion.
For COC16 locators in next mode, SRv6 SIDs carrying the NEXT flavor are allocated from the compressed Function portion.
For COC16 locators in W-LIB mode, SRv6 SIDs carrying the NEXT flavor are allocated from the W-LIB space.
coc-next: Indicates that the dynamically allocated SRv6 SID carries the COC and NEXT flavors. The SRv6 SID supports the replace and move actions. This keyword takes effect on COC16 locators in default mode.
next: Indicates that the dynamically allocated SRv6 SID carries the NEXT flavor. The SRv6 SID supports displacement. This keyword takes effect on COC16 locators.
wlib: Indicates that the SRv6 SID allocated from the W-LIB space carries the NEXT flavor. This keyword takes effect on COC16 locators in W-LIB mode. If you do not specify this keyword, the device does not allocate SRv6 SIDs carrying the NEXT flavor from the W-LIB space.
evpn: Indicates that a private network route supports SID and flavor allocation when it is converted to an EVPN route. If you do not specify this keyword, a private network route supports SID and flavor allocation when it is converted to a VPNv4 or VPNv6 route.
end-dt46: Specifies the flavor for dynamically allocated End.DT46 SIDs. If you do not specify this keyword, the device does not modify the flavor of dynamically allocated End.DT46 SIDs.
Before you execute this command in an address family view, execute the segment-routing ipv6 locator command with the compress-16 keyword specified in the address family view to allocate SIDs from the COC16 locator. This command does not take effect if the locator type is not COC16.
Application scenarios
In a 16-bit compressed G-SRv6 scenario, you can execute the segment-routing ipv6 locator command with the compress-16 keyword specified to allocate End.DT4, End.DT6, End.DT46, End.DX4, End.DX6 SIDs carrying the COC&NEXT or NEXT flavor from the specified locator. During SRv6 packet encapsulation, the source node compresses the VPN SIDs into 16 bits and encapsulates them into the SRv6 packet, reducing the SRv6 header length. When the PE (tail node) receives the compressed SRv6 packet, it takes the replace or move action based on the COC or NEXT flavor carried by the VPN SID. For more information about the replace and move actions, see SRv6 configuration in Segment Routing Configuration Guide.
Operating mechanism
After BGP references the COC16 locator, you can execute this command to configure the flavors carried by the SRv6 SIDs allocated from the locator to meet the requirements of the 16-bit G-SID compressed SRv6 packet encapsulation and forwarding. Different modes of Locators support different flavor parameters. Configure the Locator type and flavor parameters based on service requirements.
·     For COC16 locators in default mode, you can specify the coc-next or next keyword to perform the SRv6 SID replace or move action. These SRv6 SIDs are allocated from the compressed Function portion of the COC16 locator. If you specify the wlib keyword, the keyword does not take effect and no VPN SID will be allocated.
·     For COC16 locators in next mode, you can specify the next keyword to perform SRv6 SID displacement. These SRv6 SIDs are allocated from the compressed Function portion of the COC16 locator. If you specify the coc-next or wlib keyword, the keyword does not take effect and no VPN SID will be allocated.
·     For COC16 locators in W-LIB mode, you can specify the next or next wlib keyword to perform SRv6 SID displacement.
¡     If you specify the next keyword, SIDs carrying the NEXT flavor will be allocated from the compressed Function portion of the Locator in W-LIB mode.
¡     If you specify the next wlib keyword, SIDs carrying the NEXT flavor will be allocated from the W-LIB space of the non-compressed Function portion of the Locator in W-LIB mode.
·     For COC16 locators in W-LIB mode, if you specify the coc-next keyword, the keyword does not take effect and the device cannot allocate VPN SIDs.
# In BGP IPv4 unicast address family view, configure the SIDs dynamically allocated from the COC16 locator to carry the NEXT flavor.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing ipv6 locator a compress-16
[Sysname-bgp-default-ipv4] segment-routing ipv6 apply-sid compress next
segment-routing ipv6 apply-sid compress (cross-connect view, EVPN instance view, and VSI EVPN instance view)
Use segment-routing ipv6 apply-sid compress to configure the flavors for compressible SRv6 SIDs.
No flavor is configured for compressible SRv6 SIDs.
Cross-connect view
VSI instance EVPN instance view
EVPN instance view
coc-next: Indicates that the compressible SRv6 SID carries the COC and NEXT flavors.
next: Indicates that the compressible SRv6 SID carries the NEXT flavor.
next wlib: Indicates that the compressible SRv6 SID carries the NEXT flavor and uses the W-LIB space to allocate G-SID.
Before executing this command, you must execute the segment-routing ipv6 locator command to configure the locator used by the cross-connect or VSI.
This command takes effect on dynamic SRv6 SIDs.
# Configure the compressible SRv6 SIDs to carry the COC and NEXT flavors.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-srv6] segment-routing ipv6 locator 1 compress
[Sysname-vsi-aaa-evpn-srv6] segment-routing ipv6 apply-sid compress coc-next
segment-routing ipv6 apply-sid specify-nexthop (BGP IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid specify-nexthop to configure next hop-specific dynamic End.DX4 or End.DX6 SID allocation for BGP public network IPv4 or IPv6 routes, and create and enter BGP IPv4 SR or SRv6 next hop view. If the view already exists, the command directly places you in the view.
Use undo segment-routing ipv6 apply-sid specify-nexthop to restore the default.
A PE allocates the End.DT4, End.DT6, or End.DT46 SID of the public instance to BGP public network IPv4 or IPv6 routes.
By default, a PE allocates the same SID to all BGP public network routes. When a PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the public network based on the SID for an optimal route. To forward the packet to the next hop without looking up the routing table, use this command and the nexthop interface command.
This command and the nexthop interface command dynamically allocate an End.DX4 or End.DX6 SID to the specified next hop. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
Before you use the segment-routing ipv6 apply-sid specify-nexthop command in BGP IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
In the same view, the segment-routing ipv6 apply-sid specify-nexthop command is mutually exclusive with the segment-routing ipv6 apply-sid all-nexthop command. Do not use both commands in the same view.
The segment-routing ipv6 apply-sid specify-nexthop command does not assign End.DX4 or End.DX6 SIDs to direct routes.
# In BGP IPv4 unicast address family view, configure next hop-specific dynamic End.DX4 SID allocation for BGP public network IPv4 routes, and create and enter BGP IPv4 SR next hop view.
[Sysname] bgp 100
nexthop interface
segment-routing ipv6 apply-sid specify-nexthop (BGP-VPN IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid specify-nexthop to configure next hop-specific dynamic End.DX4 or End.DX6 SID allocation for BGP private network IPv4 or IPv6 routes, and create and enter BGP-VPN IPv4 SR or SRv6 next hop view. If the view already exists, the command directly places you in the view.
segment-routing ipv6 apply-sid specify-nexthop [ evpn ]
undo segment-routing ipv6 apply-sid specify-nexthop [ evpn ]
A PE allocates the End.DT4, End.DT6, or End.DT46 SID of a VPN instance to the BGP private network IPv4 or IPv6 routes of that VPN instance.
evpn: Enables next hop-specific dynamic End.DX4 or End.DX6 SID allocation for private network routes when the routes are converted to BGP EVPN routes in an EVPN L3VPN over SRv6 network. If you do not specify this keyword, this command enables nexthop-specific dynamic End.DX4 or End.DX6 SID allocation for private network routes when the routes are converted to BGP VPNv4 or VPNv6 routes.
This command is applicable to the MPLS L3VPN over SRv6 and EVPN L3VPN over SRv6 scenarios.
By default, a PE allocates the same SID to all BGP routes of a VPN instance. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the VPN instance based on the SID for an optimal route. Then, the PE forwards the packet to a CE. To forward the packet to the next hop without looking up the routing table, use this command and the nexthop interface command.
Before you use the segment-routing ipv6 apply-sid specify-nexthop command in BGP-VPN IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
# In BGP-VPN IPv4 unicast address family view, configure next hop-specific dynamic End.DX4 SID allocation for BGP private network IPv4 routes, and create and enter BGP-VPN IPv4 SR next hop view.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4 unicast
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 apply-sid specify-nexthop
nexthop interface
Use segment-routing ipv6 best-effort to recurse routes to SRv6 BE tunnels.
Use undo segment-routing ipv6 best-effort to restore the default.
In BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view:
segment-routing ipv6 best-effort [ evpn ]
undo segment-routing ipv6 best-effort [ evpn ]
In BGP VPNv4 address family view or BGP VPNv6 address family view:
In BGP IPv4 unicast address family view or BGP IPv6 unicast address family view:
segment-routing ipv6 best-effort evpn
undo segment-routing ipv6 best-effort evpn
A PE searches the IPv6 routing table based on the next hop of a matching route to forward traffic.
evpn: Recurses EVPN routes to SRv6 BE tunnels. If you do not specify this keyword, the device recurses BGP VPNv4 or VPNv6 routes to SRv6 BE tunnels.
This command is applicable to the MPLS L3VPN over SRv6 and EVPN L3VPN over SRv6 networks. This command enables a PE to forward packets by looking up the IPv6 routing table based on the SRv6 SIDs in the packets.
Use this command in different address family views according to your network scenario.
·     In the private network IPv4 or IPv6 over SRv6 scenario, use this command in BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view.
·     In the public network IPv4 or IPv6 over SRv6 scenario, use this command in BGP IPv4 unicast address family view or BGP IPv6 unicast address family view.
·     In the inter-AS option B VPN scenario, use this command in BGP VPNv4 address family view, BGP VPNv6 address family view, or BGP EVPN address family view.
This command is mutually exclusive with the segment-routing ipv6 traffic-engineering command.
# In BGP-VPN IPv4 unicast address family view, recurse private network routes to SRv6 BE tunnels.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
# In BGP-VPN IPv6 unicast address family view, recurse private network routes to SRv6 BE tunnels.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv6
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 best-effort
Use segment-routing ipv6 locator to apply a locator to a BGP family.
Use undo segment-routing ipv6 locator to restore the default.
segment-routing ipv6 locator locator-name [ auto-sid-disable | auto-sid-dt46 ] [ compress-16 ]
segment-routing ipv6 locator locator-name [ evpn ] [ auto-sid-disable | auto-sid-dt46 ] [ compress-16 ]
undo segment-routing ipv6 locator [ evpn ]
segment-routing ipv6 locator locator-name evpn
undo segment-routing ipv6 locator evpn
No locator is applied to a BGP family.
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. The specified locator must exist.
evpn: Adds the SID attribute to private network routes when the routes are converted to EVPN routes. If you do not specify this keyword, the command adds the SID attribute to private network routes when the routes are converted to BGP VPNv4 or VPNv6 routes.
auto-sid-disable: Disables automatic SRv6 SID allocation. If you do not specify this keyword, the device allows dynamically allocated SRv6 SIDs. If static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the static SRv6 SIDs take precedence. If no static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the system dynamically allocates SRv6 SIDs.
auto-sid-dt46: Specifies the type of dynamically allocated SRv6 SIDs as End.DT46. If you do not specify this keyword, the device dynamically allocates End.DT4 or End.DT6 SRv6 SIDs.
compress-16: Specifies the COC16 locator and allocates SRv6 SIDs used for 16-bit compression from the locator.
Operating mechanism
Execute this command to enable BGP to allocate SRv6 SIDs from the referenced locator address space and enable BGP routes in the specified address family to carry Prefix SID attributes to advertise SRv6 SIDs.
In L3VPN over SRv6 and public IP over SRv6 scenarios, PEs can dynamically allocate SRv6 SIDs for private network routes or public IPv4/IPv6 routes of the VPN instances within the referenced locator. By default, the device dynamically allocates End.DT4 SIDs for public or private IPv4 routes and End.DT6 SIDs for public or private IPv6 routes. When both IPv4 and IPv6 routes coexist in the public network or a specific VPN instance, you can specify the auto-sid-dt46 keyword to allocate only one End.DT46 SID for both IPv4 and IPv6 routes.
In a 16-bit compressed G-SRv6 scenario, you can execute this command with the compress-16 keyword specified to allocate End.DT4, End.DT6, End.DT46, End.DX4, End.DX6 SIDs carrying the COC&NEXT or NEXT flavor from the specified locator. During SRv6 packet encapsulation, the source node compresses the VPN SIDs into 16 bits and encapsulates them into the SRv6 packet, reducing the SRv6 header length. When the PE (tail node) receives the compressed SRv6 packet, it takes the replace or move action based on the COC or NEXT flavor carried by the VPN SID. For more information about replacement or displacement, see SRv6 configuration in Segment Routing Configuration Guide.
When you execute this command with the compress-16 keyword specified, make sure the COC16 locator is used:
·     If the locator type is not COC16, the compress-16 keyword does not take effect and no SID can be allocated from the locator.
·     If a COC16 locator in default mode or next mode is used and you do not specify the compress-16 keyword, common SIDs will be allocated from the non-compressed Function portion of the locator. Common SIDs do not carry the COC or NEXT flavor, and they do not support 16-bit compression.
·     If a COC16 locator in W-LIB mode is used and you do not specify the compress-16 keyword, no SID can be allocated from the locator.
After executing this command with the compress-16 keyword specified, you can execute the segment-routing ipv6 apply-sid compress command to edit the flavor carried by the SIDs allocated from the locator.
If you execute this command multiple times for the same address family, the most recent configuration takes effect.
# Apply locator abc to BGP-VPN IPv4 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
# Apply locator abc to BGP-VPN IPv6 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc evpn
segment-routing ipv6 locator (cross-connect view/EVPN instance view/VSI EVPN instance view)
Use segment-routing ipv6 locator to apply an SRv6 locator to a cross-connect or a VSI.
Use undo segment-routing ipv6 locator to remove the specified SRv6 locator from a cross-connect or a VSI.
In cross-connect view:
segment-routing ipv6 locator locator-name [ dx2l-locator dx2l-locator-name ] [ auto-sid-disable ] [ compress ]
In VSI EVPN instance view:
segment-routing ipv6 locator locator-name [ dt2u-locator dt2u-locator-name ] [ dt2ul-locator dt2ul-locator-name ] [ dx2-locator dx2-locator-name ] [ dx2l-locator dx2l-locator-name ] [ auto-sid-disable ] [ compress ]
segment-routing ipv6 locator locator-name [ dt2u-locator dt2u-locator-name ] [ dt2ul-locator dt2ul-locator-name ] [ auto-sid-disable ] [ compress ]
No SRv6 locators are applied to a cross-connect or a VSI.
Cross-connect view
EVPN instance view
dx2l-locator dx2l-locator-name: Specifies the locator used to apply for End.DX2L SIDs. The dx2l-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
dt2u-locator dt2u-locator-name: Specifies the locator used to apply for End.DT2U SIDs. The dt2u-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
dt2ul-locator dt2ul-locator-name: Specifies the locator used to apply for End.DT2UL SIDs. The dt2ul-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
dx2-locator dx2-locator-name: Specifies the locator used to apply for End.DX2 SIDs. The dx2-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
auto-sid-disable: Disables automatic SID allocation. If no opcode is configured for the locator specified in this command when automatic SID allocation is disabled, SID application fails. If you do not specify this keyword, automatic SID allocation is enabled and static SRv6 SIDs and dynamic SRv6 SIDs can coexist. The static SRv6 SIDs take precedence over the dynamically allocated SRv6 SIDs.
compress: Indicates that the SIDs support G-SID compression. If you do not specify this keyword, the SIDs do not support G-SID compression.
Use this command to enable a cross-connect or VSI to apply for SRv6 SIDs from the specified locator.
·     If you specify the dx2l-locator dx2l-locator-name option, the locator-name argument applies for End.DX2 SIDs and the dx2l-locator-name argument applies for End.DX2L SIDs.
·     If you do not specify the dx2l-locator dx2l-locator-name option, the locator-name argument applies for both End.DX2 SIDs and End.DX2L SIDs.
·     If you do not specify the dt2u-locator dt2u-locator-name, dt2ul-locator dt2ul-locator-name, dx2-locator dx2-locator-name, or dx2l-locator dx2l-locator-name option, the locator-name argument applies for End.DT2M, End.DT2U, End.DT2UL, End.DX2, and End.DX2L SIDs.
·     If you specify the dt2u-locator dt2u-locator-name, dt2ul-locator dt2ul-locator-name, dx2-locator dx2-locator-name, or dx2l-locator dx2l-locator-name option, the option applies for End.DT2U, End.DT2UL, End.DX2, or End.DX2L SIDs and the locator-name argument applies for other SRv6 SIDs.
·     If you do not specify the dt2u-locator dt2u-locator-name or dt2ul-locator dt2ul-locator-name option, the locator-name argument applies for End.DT2M, End.DT2U, and End.DT2UL SIDs.
·     If you specify the dt2u-locator dt2u-locator-name or dt2ul-locator dt2ul-locator-name option, the option applies for End.DT2U or End.DT2UL SIDs and the locator-name argument applies for other SRv6 SIDs.
# Configure VSI aaa to use locator test1 to apply for End.DT2M, End.DT2UL, End.DX2, and End.DX2L SIDs and use locator test2 to apply for End.DT2U SIDs.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-srv6] segment-routing ipv6 locator test1 dt2u-locator test2
# Configure cross-connect aaa in cross-connect group bbb to use locator test3 to apply for End.DX2 and End.DX2L SIDs and disable automatic SID allocation.
[Sysname] xconnect-group bbb
[Sysname-xcg-bbb] evpn encapsulation srv6
[Sysname-xcg-bbb-evpn-srv6] quit
[Sysname-xcg-bbb] connection aaa
[Sysname-xcg-bbb-connection-aaa] segment-routing ipv6 locator test3 auto-sid-disable
segment-routing ipv6 primary-path-detect sid-bfd
Use segment-routing ipv6 primary-path-detect sid-bfd to enable using the static BFD session for the SRv6 SID to detect the reachability of the primary path for SRv6 VPN FRR.
Use undo segment-routing ipv6 primary-path-detect sid-bfd to restore the default.
segment-routing ipv6 primary-path-detect sid-bfd [ evpn ]
undo segment-routing ipv6 primary-path-detect sid-bfd [ evpn ]
The device uses the static BFD session for the locator to detect the reachability of the primary path for SRv6 VPN FRR.
evpn: Applies the configuration only to BGP EVPN FRR. If you do not specify this keyword, the command applies to BGP VPNv4 or BGP VPNv6 FRR.
In IP L3VPN over SRv6, public network IP over SRv6, or EVPN L3VPN over SRv6 networks that use the SRv6 BE route recursion mode, the public instance or VPN instance IP routing table does not have SRv6 SID route information by default. As a result, to use BFD to detect the primary path between PEs, FRR can only use the static BFD session for the locator network address.
If the address families of multiple VPN instances or those of the public instance have used the same locator, FRR in these address families might use the same static BFD session to detect the primary path. Once the BFD session detects that the path is not available, the BGP routes in all these address families will perform path switching simultaneously.
For refined FRR management, this command is provided to enable BFD for the primary path of SRv6 VPN FRR by using the static BFD session for the SRv6 SID.
Operating mechanism
After this command is executed, when the device adds a BGP IPv4/IPv6 unicast route, BGP VPNv4/VPNv6 route, or IP prefix route that contains an SRv6 SID to a VPN instance/public instance IP routing table, it adds the SRv6 SID as the next hop of the route. This allows FRR to automatically and preferentially associate the static BFD session for the SRv6 SID to detect the primary path. Once BFD detects that an SRv6 SID is not reachable, it triggers the BGP routes in only one address family or one VPN instance to perform path switching. This mechanism provides a smaller control granularity for FRR.
For example, the device has created two static BFD sessions, one for a locator and the other for an SRv6 SID.
·     Before this command is executed, only BFD session frr1 can be used to detect the primary path's reachability for FRR.
<Sysname> display bfd session verbose
 Total sessions: 2        Up sessions: 2        Init mode: Active
 IPv6 session working in control packet mode:
         Session name: frr
          Local discr: 33793                      Remote discr: 33793
            Source IP: 1:2::106
       Destination IP: 6:5::106
     Destination port: 4784                      Session state: Up
            Interface: N/A
      Min Tx interval: 500ms                Actual Tx interval: 500ms
      Min Rx interval: 500ms                    Detection time: 2500ms
             Rx count: 30533                          Tx count: 25954
      Connection type: Indirect                    Up duration: 03:09:06
            Hold time: 2257ms                        Auth mode: None
       Detection mode: Async                              Slot: 0
             Protocol: STATIC_IPv6
              Version: 1
            Diag info: No Diagnostic
        Hardware mode: Disable
         Session name: frr1
          Local discr: 33794                      Remote discr: 33794
            Source IP: 1:2::
            Interface: N/A
             Rx count: 30412                          Tx count: 25948
            Hold time: 2332ms                        Auth mode: None
             Protocol: IPFRR/STATIC_IPv6
              Version: 1
·     After this command is executed, BFD session frr is used to detect the reachability of the primary path with SRv6 SID 6:5::106.
         Session name: frr
            Source IP: 1:2::106
            Interface: N/A
              Version: 1
         Session name: frr1
            Source IP: 1:2::
            Interface: N/A
              Version: 1
This command applies only to routes that use the SRv6 BE route recursion mode. If the route recursion mode is SRv6 TE and SRv6 BE hybrid, SRv6 TE/SRv6 BE FRR, or SRv6 TE and SRv6 BE multilevel FRR, this command takes effect only when the SRv6 TE path is not available.
# In BGP IPv4 unicast address family, enable using the BFD session for the SRv6 SID to detect the reachability of the primary path for SRv6 VPN FRR.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] segment-routing ipv6 primary-path-detect sid-bfd
segment-routing ipv6 route-select delay
Use segment-routing ipv6 route-select delay to configure the optimal route selection delay timer for BGP routes with End.T SIDs or End.R SIDs requested.
Use undo segment-routing ipv6 route-select delay to restore the default.
segment-routing ipv6 route-select delay delay-value
The optimal route selection delay timer is 60 seconds for BGP routes with End.T SIDs or End.R SIDs requested.
BGP instance view
delay-value: Specifies the optimal route selection delay timer in the range of 0 to 600 seconds.
In the SRv6 and MPLS network intercommunication scenario or the inter-AS option B VPN scenario, the network border device must request End.T or End.R SIDs for BGP routes. After requesting the SIDs, the device must generate IPv6 FIB entries for packet forwarding. If a BGP route changes from the ECMP or FRR state to the non-ECMP and non-FRR state, the device must re-request an End.T or End.R SID for that route. At this time, the device immediately sends a route update, and traffic is forwarded based on the new SID. When traffic reaches the device that originated the SID, if the IPv6 FIB entry on that device has not been generated, traffic forwarding fails, resulting in packet loss.
Operating mechanism
To resolve this issue, you can execute this command to set the optimal route selection delay timer for BGP routes with End.T or End.R SIDs requested. After a BGP route requests or re-requests an End.T SID or an End.R SID, it needs to wait for a certain period of time before it can participate in optimal route selection. This allows the device to have sufficient time to generate the associated IPv6 FIB entry, avoiding packet loss.
# Configure the optimal route selection delay timer as 100 seconds for BGP routes with End.T SIDs or End.R SIDs requested.
[Sysname] bgp 100
[Sysname-bgp-default] segment-routing ipv6 route-select delay 100
Use segment-routing ipv6 traffic-engineering to recurse routes to SRv6 TE policy tunnels.
Use undo segment-routing ipv6 traffic-engineering to restore the default.
segment-routing ipv6 traffic-engineering [ best-effort [ local-preference ] ]
undo segment-routing ipv6 traffic-engineering [ best-effort [ local-preference ] ]
segment-routing ipv6 traffic-engineering [ best-effort [ local-preference ] ] [ evpn ]
undo segment-routing ipv6 traffic-engineering [ best-effort [ local-preference ] ] [ evpn ]
segment-routing ipv6 traffic-engineering [ best-effort ]
undo segment-routing ipv6 traffic-engineering [ best-effort ]
segment-routing ipv6 traffic-engineering [ best-effort ] evpn
undo segment-routing ipv6 traffic-engineering [ best-effort ] evpn
best-effort: Switches to the SRv6 BE route recursion mode when the matching SRv6 TE policy tunnel fails for L3VPN traffic.
·     For BGP IPv4 unicast routes, BGP IPv6 unicast routes, BGP-VPN IPv4 unicast routes, and BGP-VPN IPv6 unicast routes, if the BGP route can recurse to both an SRv6 TE policy (SRv6 TE path) and SRv6 BE tunnel (SRv6 BE path), then the SRv6 TE path and SRv6 BE path form an FRR relationship. Service traffic prefers to pass through the SRv6 TE path. When the SRv6 TE path encounters a fault or if it doesn't exist, you can quickly switch the service traffic to the SRv6 BE backup path for forwarding. This allows for quick protection and prevents long-term traffic loss.
When a BGP route can recurse to multiple SRv6 TE paths and multiple SRv6 BE paths, the SRv6 TE paths and SRv6 BE paths form multi-level FRR. The device calculates an FRR primary path and FRR backup path. The FRR primary path consists of one primary SRv6 TE path and one backup SRv6 TE path. The FRR backup path consists of one primary SRv6 BE path and one backup SRv6 BE path. The device selects the traffic forwarding path in primary SRv6 TE path, backup SRv6 TE path, primary SRv6 BE path, and backup SRv6 BE path order.
·     When there is a fault in the SRv6 TE policy for a BGP VPNv4, BGP VPNv6, or BGP EVPN route, the BGP route recurses to another available SRv6 TE policy or SRv6 BE tunnel.
evpn: Recurses the private network routes based on the SID attribute in EVPN routes. If you do not specify this keyword, the device recurses the private network routes based on the SID attribute in BGP VPNv4 or VPNv6 routes.
This command is applicable to the IP L3VPN over SRv6, EVPN L3VPN over SRv6, and public network IP over SRv6 scenarios. This command enables PEs to recurse routes to SRv6 TE policy tunnels and use the tunnels to forward traffic between the PEs.
Operating mechanism
To improve high availability for packet forwarding, specify the best-effort keyword in this command.
If the best-effort keyword is specified in this command, the device forwards a service packet as follows:
1.     The device forwards the packet through the matching SRv6 TE policy tunnel.
2.     If the matching SRv6 TE policy tunnel fails, the PE forwards the packet through another path.
¡     For service packets forwarded as instructed by a BGP IPv4 unicast route, BGP IPv6 unicast route, BGP-VPN IPv4 unicast route, or BGP-VPN IPv6 unicast route:
-     In a single-homing scenario, the SRv6 BE tunnel (SRv6 BE path) acts as an FRR backup path for the SRv6 TE policy tunnel (SRv6 TE path). Service packets are switched to the SRv6 BE backup path for forwarding.
-     In a dual-homing scenario where multiple SRv6 TE paths and multiple SRv6 BE paths form multi-level FRR, if the local-preference keyword is not specified, the device selects a forwarding path for the service packets in the following order: primary SRv6 TE path -> backup SRv6 TE path -> primary SRv6 BE path -> backup SRv6 BE path. If the local-preference keyword is specified, the device selects a forwarding path for the service packets in the following order: primary SRv6 TE path -> primary SRv6 BE path -> backup SRv6 TE path -> backup SRv6 BE path.
¡     For service packets forwarded as instructed by a BGP VPNv4 route, BGP VPNv6 route, or BGP EVPN route: The BGP route recurses to another available SRv6 TE policy or SRv6 BE tunnel.
3.     If both the SRv6 TE policy tunnel and the SRv6 BE tunnel fail, the device forwards the packet by looking up the routing table based on the destination IP address of the packet.
4.     If the routing table lookup fails, the device discards the packet.
If the best-effort keyword is not specified, when the matching SRv6 TE policy tunnel fails, the device forwards user service packets by looking up the routing table according to the destination IP address of the packets.
This command is mutually exclusive with the segment-routing ipv6 best-effort command.
To configure this command to implement multilevel FRR in dual-homing scenarios, if you do not specify the local-preference keyword in this command, you must also configure the bestroute nexthop-type tunnel command.
To implement multilevel FRR in dual-homing scenarios, if you specify the local-preference keyword in this command, you cannot configure the bestroute nexthop-type function.
In single-homing scenarios, the local-preference keyword does not take effect.
# In BGP IPv4 unicast address family view, recurse routes to SRv6 TE policy tunnels.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing ipv6 traffic-engineering
srv6-inter-as balance
Use srv6-inter-as balance to set the number of routes for load sharing supported by an ASBR in SRv6 VPN inter-AS option B scenario.
Use undo srv6-inter-as balance to restore the default.
srv6-inter-as balance balance-value
In SRv6 VPN inter-AS option B scenario, an ASBR does not perform load sharing for BGP VPNv4/VPNv6 or BGP EVPN routes.
balance-value: Number of routes for load sharing. Valid values are 1 and 2, where 1 means no load sharing.
In an SRv6 VPN inter-AS option B scenario, if an ASBR received VPN routes for the same prefix from multiple neighbors, this indicates that multiple paths exist between the ASBR and the VPN site. By default, the ASBR will select only one of the routes, resulting in the VPN traffic being forwarded on a single path. This cannot fully utilize the network bandwidth and redundant links.
After configuring this command on the ASBR, the ASBR can select a maximum of two routes with the same prefix for load sharing. The ASBR allocates the same End.R SID to the two routes. The IPv6 FIB entry generated based on the End.R SID has two next hops, which also form load sharing. Consequently, the ASBR can use two paths to achieve load sharing when forwarding packets to the VPN site.
Use this command only in SRv6 VPN inter-AS option B scenarios.
# In the BGP VPNv4 address family, configure an ASBR in SRv6 VPN inter-AS option B scenario supports two routes for load sharing.
[Sysname] bgp 10
[Sysname-bgp-default-vpnv4] srv6-inter-as balance 2
srv6-inter-as enable
Use srv6-inter-as enable to enable SRv6 inter-AS communication.
Use undo srv6-inter-as enable to disable SRv6 inter-AS communication.
SRv6 inter-AS communication is disabled.
The biggest challenge faced by SRv6 inter-AS communication is how to establish SRv6 forwarding paths across ASs. The current practices require propagating the SRv6 SID information of the intermediate nodes in one AS to another AS. Different ASs usually belong to different operators, and operators generally do not want to have node information leaked to other networks.
To resolve this issue, H3C has launched the SRv6 VPN inter-AS option B solution, which does not require advertising the Locator subnet routes of the devices in an AS to another AS. With this solution, you can simply configure this command on ASBRs to implement inter-AS communication for the following types of VPNs:
·     Communication between IP L3VPN over SRv6 network and EVPN L3VPN over SRv6 network
·     Communication between IP L3VPN over SRv6 network and IP L3VPN over SRv6 network
·     Communication between EVPN L3VPN over SRv6 network and EVPN L3VPN over SRv6 network
Operating mechanism
With this command executed, an ASBR will allocate an End.R SID for a received BGP VPNv4/VPNv6/EVPN route that carries an SRv6 SID.
An End.R SID is an H3C proprietary SRv6 SID to implement SRv6 VPN inter-AS option B. An End.R SID functions as follows:
1.     Removes the outer IPv6 header of a packet.
2.     Looks up the IPv6 FIB according to the End.R SID.
3.     Encapsulates a new outer IPv6 header by using the lookup result to forward the packet.
Recommended configuration
When you configure inter-AS communication between IP L3VPN over SRv6 network and EVPN L3VPN over SRv6 network, besides executing this command on ASBRs, you must also complete the following configuration:
·     If a BGP VPNv4 or BGP VPNv6 session is established between ASBRs, you must configure the following commands on the ASBR in the EVPN L3VPN over SRv6 network:
¡     The peer re-originated stitch-evpn command with the peer being the remote ASBR.
¡     The peer re-originated stitch-l3vpn command with the peer being the PE in the local AS.
These commands enable the ASBR to translate BGP VPNv4/VPNv6 routes and BGP EVPN routes, ensuring the inter-AS propagation of VPN routing information.
·     If a BGP EVPN session is established between ASBRs, you must configure the following commands on the ASBR in the IP L3VPN over SRv6 network:
¡     The peer re-originated stitch-l3vpn command with the peer being the remote ASBR.
¡     The peer re-originated stitch-evpn command with the peer being the PE in the local AS.
To ensure ASBRs to allocate End.R SIDs to routes, you must use the segment-routing ipv6 locator command to specify a locator in BGP VPNv4/VPNv6 or BGP EVPN address family view.
To enable ASBRs to perform BGP VPNv4/VPNv6 or BGP EVPN route recursion in SRv6 TE mode, execute the segment-routing ipv6 traffic-engineering command in BGP VPNv4/VPNv6 or BGP EVPN address family view.
An End.R SID is an H3C proprietary SRv6 SID to implement SRv6 VPN inter-AS option B. To ensure that the devices from other vendors can recognize the BGP routes carrying End.R SIDs sent from H3C devices, perform the following:
·     Identify the Endpoint Behavior value for the SRv6 SID used by a device to implement SRv6 VPN inter-AS option B.
·     Execute the peer srv6-endr-type command on the H3C device to set the type-value to that Endpoint Behavior value.
# In BGP VPNv4 address family view, enable SRv6 inter-AS communication.
[Sysname] bgp 10
[Sysname-bgp-default-vpnv4] srv6-inter-as enable
peer re-originated
peer srv6-endr-type
srv6-mpls-interworking enable
Use srv6-mpls-interworking enable to enable SRv6 and MPLS interworking.
Use undo srv6-mpls-interworking enable to disable SRv6 and MPLS interworking.
SRv6 and MPLS interworking is disabled.
For intercommunication between an MPLS network in one AS and an SRv6 network in another AS, enable SRv6 and MPLS interworking on the ASBR in the SRv6 network. This feature enables End.T SID allocation and establishes mappings between End.T SIDs and MPLS labels.
With this feature, the ASBR in the SRv6 network allocates End.T SIDs based on FECs and advertises the SIDs to other SRv6 nodes through an IGP. An FEC is a destination IPv4 address/mask or destination IPv6 address/prefix length. The function of an End.T SID is removing the outer IPv6 header and looking up the IPv6 FIB table based on the End.T SID to forward packets.
For SRv6-to MPLS packets, the ingress node in the SRv6 network encapsulates an End.T SID to the packets when forwarding the packets to the ASBR in the SRv6 network. When the ASBR in the SRv6 network receives the packets, it looks up the IPv6 FIB table based on the End.T SID for a matching route. Then, the ASBR recurses the route to an LSP to forward the packets to the MPLS network.
For MPLS-to-SRv6 packets, the ASBR in the SRv6 network looks up the label forwarding table to forward the packets. The out label is an End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SID in the SRv6 network. After the ASBR in the SRv6 network encapsulates the End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SID to the packets, it forwards the packets in SRv6 BE or SRv6 TE mode.
# Enable SRv6 and MPLS interworking.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] srv6-mpls-interworking enable
srv6-pw-type
Use srv6-pw-type to specify the SRv6 PW data encryption type.
Use undo srv6-pw-type to restore the default.
srv6-pw-type { ethernet | vlan }
undo srv6-pw-type
The SRv6 PW data encryption type is Ethernet.
PW class view
ethernet: Specifies the SRv6 PW data encryption type as Ethernet.
vlan: Specifies the SRv6 PW data encryption type as VLAN.
With Ethernet specified as the SRv6 PW data encryption type, the frames transmitted on the SRv6 PW cannot carry P-Tags (service delimiters added to distinguish users as required by ISPs).
·     If the PE receives a packet carrying a P-Tag from the CE, it removes the P-Tag, adds an SRv6 SID, and then forwards the packet.
·     If the PE receives a packet without a P-Tag from the CE, it directly adds an SRv6 SID, and then forwards the packet.
·     For a packet to be sent to the CE, if the access mode is specified as VLAN with the ac interface command, the PE adds the P-Tag and then forwards the packet to the CE. If the access mode is specified as Ethernet, the PE forwards the packet to the CE without adding a P-Tag. In addition, it does not rewrite or remove any tags.
With VLAN specified as the SRv6 PW data encryption type, the frames transmitted on the SRv6 PW must carry P-Tags.
·     If the PE receives a packet carrying a P-Tag from the CE, it retains the P-Tag, adds an SRv6 SID, and then forwards the packet.
·     If the PE receives a packet without a P-Tag from the CE, it adds an empty P-Tag with value 1, adds an SRv6 SID, and then forwards the packet.
·     For a packet to be sent to the CE, if the access mode is specified as VLAN with the ac interface command, the PE rewrites or retains the P-Tag and then forwards the packet to the CE. If the access mode is specified as Ethernet, the PE removes the P-Tag and then forwards the packet to the CE.
# Specify the SRv6 PW data encryption type as Ethernet.
[Sysname] pw-class pw100
[Sysname-pw-pw100] srv6-pw-type ethernet
static-srv6 local-service-id remote-service-id
Use static-srv6 local-service-id remote-service-id to configure the SRv6 PW setup mode on a cross-connect as static and enter cross-connect static SRv6 view.
Use undo static-srv6 local-service-id remote-service-id to restore the default.
static-srv6 local-service-id local-service-id remote-service-id remote-service-id [ tunnel-policy tunnel-policy-name ]
undo static-srv6 local-service-id local-service-id remote-service-id remote-service-id
The SRv6 PW setup mode is not specified.
Cross-connect view
local-service-id local-service-id: Specifies a local service ID in the range of 1 to 16777215.
remote-service-id remote-service-id: Specifies a remote service ID in the range of 1 to 16777215.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 126 characters. If you do not specify a tunnel policy, the default tunnel policy is used.
After you enter cross-connect static SRv6 view by using this command, you can execute the peer command to configure a static SRv6 PW for the cross-connect.
In cross-connect view, this command and the peer command is mutually exclusive with each other.
# Enter cross-connect static SRv6 view, and specify local service ID 1 and remote service ID 2.
[Sysname] xconnect-group svpws0
[Sysname-xcg-svpws0] connection 1
[Sysname-xcg-svpws0-1] static-srv6 local-service-id 1 remote-service-id 2
[Sysname-xcg-svpws0-1-1-2]
statistics enable
Use statistics enable to enable SRv6 PW packet statistics.
Use undo statistics enable to disable SRv6 PW packet statistics.
statistics enable
The SRv6 PW packet statistics feature is disabled.
Cross-connect EVPN PW view
In an EVPN VPWS over SRv6 network, use this command to enable SRv6 PW packet statistics in cross-connect EVPN PW view. To display SRv6 PW packet statistics, use the display l2vpn peer srv6 verbose command. To clear SRv6 PW packet statistics, use the reset l2vpn statistics srv6-pw command. If you configure Deterministic Networking (DetNet) in the VPWS over SRv6 network, the SRv6 PW packet statistics feature cannot take effect, To use the SRv6 PW packet statistics feature, avoid configuring DetNet in the VPWS over SRv6 network.
The statistics enable command is not supported by PWs in a cross-connect group EVPN instance that uses MPLS encapsulation.
In an EVPN VPLS over SRv6 network, use the statistics enable command to enable packet statistics for all SRv6 PWs in a VSI EVPN instance. To display inbound packet statistics for all SRv6 PWs, use the display l2vpn statistics srv6-pw inbound command. To display outbound packet statistics for each SRv6 PW, use the display l2vpn peer srv6 verbose command. To clear SRv6 PW packet statistics, use the reset l2vpn statistics srv6-pw command.
The statistics enable command is supported only by VSI EVPN instances that use SRv6 encapsulation.
# In an EVPN VPWS over SRv6 network, enable packet statistics for an SRv6 PW.
[Sysname] xconnect-group vpws
[Sysname-xcg-vpws] connection aa
[Sysname-xcg-vpws-aa] evpn local-service-id 2 remote-service-id 4
[Sysname-xcg-vpws-aa-2-4] statistics enable
# In an EVPN VPLS over SRv6 network, enable packet statistics for all SRv6 PWs in an EVPN instance.
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation srv6
[Sysname-vsi-vpna-evpn-srv6] stastics enable
tracert evpn vpls srv6
Use tracert evpn vpls srv6 to trace the path of an SRv6 PW from the local PE to the remote PE in an EVPN VPLS over SRv6 network.
tracert evpn vpls srv6 vsi vsi-name mac mac-address [ end-op endop ] [ force-match-slice ] [ -a source-ipv6 | -h hop-limit | -r reply-mode | { -service-class class-value | -te-class te-class-value } | -t time-out | -tc tc ] *
mac mac-address: Specifies a host attached to a remote PE by its MAC address in H-H-H format. Do not specify a broadcast MAC address, multicast MAC address, or all-zeros MAC address.
end-op endop: Specifies an End.OP SID to be added to MPLS echo requests. The End.OP SID is used to locate the destination node. If you do not specify an End.OP SID, the local PE does not add an End.OP SID to MPLS echo requests.
force-match-slice: Enables force matching of network slice instance IDs. If source address slicing is used, you must specify this option. In addition, to have this option take effect, you must specify the strict-mode keyword when you execute the network-slice command to specify the NSI ID for an SRv6 TE policy candidate path. When this parameter is specified, if an MPLS echo request to be forwarded by the SRv6 PW contains a slice ID, the request can be sent successfully only if the slice ID in the request is the same as the network slice instance ID of the network slice channel on the packet output interface. If the IDs are inconsistent, the device discards the MPLS echo request, causing the tracert to fail. If this parameter is not specified, the device does not check the slice IDs in MPLS echo requests before sending the requests. For MPLS echo requests without a slice ID, this parameter does not take effect.
-a source-ipv6: Specifies the source IPv6 address of MPLS echo requests. If you do not specify a source IPv6 address, the IPv6 address of the traffic output interface is used as the source IPv6 address of MPLS echo requests.
-h hop-limit: Specifies the maximum number of hops allowed for an MPLS echo request. The value range for the hop-limit argument is 1 to 255, and the default value is 255.
-r reply-mode: Specifies the reply mode used by the receiver (the remote PE) to reply to MPLS echo requests. The value for the reply-mode argument can be 2 or 4, and the default value is 2. If the mode is 2, the receiver replies using UDP. If the mode is 4, the receiver replies through the control channel of the application plane, where the reply packets are encapsulated with an SRH.
-service-class class-value: Specifies the service class value for MPLS echo requests. The value range is 1 to 15.  The default service class value is 255.
-te-class te-class-value: Specifies the TE class value for MPLS echo requests. The value range for the te-class-value argument is 1 to 65535, and the default value is 0.
-t time-out: Specifies the timeout time of MPLS echo replies, in milliseconds. The value range for the time-out argument is 0 to 65535, and the default value is 2000. If the local PE does not receive an MPLS echo reply within the timeout time after sending an MPLS echo request, it determines that the MPLS echo reply times out.
-tc tc: Specifies the traffic class value in MPLS echo replies. The value range for the tc argument is 0 to 255 and the default value is 0.
In an EVPN VPLS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to trace the path of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs. This command helps you locate the failed nodes on the path.
# Trace route to a remote PE through an SRv6 PW in VSI vpna by reaching remote-MAC 0002-0002-0002.
<Sysname> tracert evpn vpls srv6 vsi vpna mac 2-2-2
Trace route to a remote PE in VSI vpna over SRv6 by reaching remote-MAC 0002-0002-0002.
Press CTRL+C to break.
  Hop  Wait time     Type       Replier
  0    0 ms           Ingress
  1    4 ms           Transit    1111::2
  2    5 ms           Transit    2222::2
  3    6 ms           Transit    3333::2
  4    6 ms           Egress     4444::2
Table 13 Command output
Press escape key Ctrl+C to abort the tracert operation.
Hop
Hop number.
Wait time
Interval between the time when an echo request was sent and the time when the reply of the echo request was received. The unit is millisecond.
Node type:
·     Ingress.
·     Transit.
·     Egress.
Replier
IPv6 address of the node.
Request time out
This field is available if the local PE does not receive any MPLS echo reply to an MPLS echo request when the echo reply timeout time expires.
ping evpn vpls srv6
tracert { evpn | static } vpws srv6
Use tracert { evpn | static } vpws srv6 to trace the path of an SRv6 PW from the local PE to the remote PE in an EVPN VPWS over SRv6 network.
tracert { evpn | static } vpws srv6 xconnect-group group-name local-service-id remote-service-id [ peer ipv6-address ] [ end-op endop ] [ force-match-slice ] [ -a source-ip | -h hop-limit | -r reply-mode | { -service-class class-value | -te-class te-class-value } | -t time-out | -tc tc ] *
evpn: Specifies a dynamic SRv6 PW.
static: Specifies a static SRv6 PW.
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. The string cannot contain a hyphen (-).
peer ipv6-address: Specifies a remote PE by its IPv6 address. You can specify this option in a multihomed EVPN VPWS over SRv6 network to detect the specified remote SRv6 PW. If you do not specify this option, this command detects only one of the SRv6 PWs.
end-op endop: Specifies an End.OP SID to be added to MPLS echo requests. The End.OP SID is used to locate the destination node. If you do not specify an End.OP SID, the device does not add an End.OP SID to MPLS echo requests.
-a source-ip: Specifies the source IPv6 address of MPLS echo requests. If you do not specify a source IPv6 address, the IPv6 address of the traffic output interface is used as the source IPv6 address of MPLS echo requests.
-r reply-mode: Specifies the reply mode used by the receiver (the remote PE) to reply to an MPLS echo request. The value for the reply-mode argument can be 2 or 4, and the default value is 2. If the mode is 2, the receiver replies using UDP. If the mode is 4, the receiver replies through the control channel of the application plane, where the reply packets are encapsulated with an SRH.
In an EVPN VPWS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to trace the path of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs. This command helps you locate the failed nodes on the path.
# Trace the route that an SRv6 PW traverses from the local PE to the remote PE in an EVPN VPWS over SRv6 network. The SRv6 PW belongs to cross-connect group xcga, its local service ID is 2, and its remote service ID is 1.
<Sysname> tracert evpn vpws srv6 xconnect-group xcga 1 2
Trace route to a remote PE over SRv6 through a PW with local service ID 2 and remote service ID 1 in cross-connect group xcga.
  0     0 ms            Ingress
  4     6 ms            Egress     3333::2
Table 14 Command output
Trace route to a remote PE through an SRv6 PW with local service ID 2 and remote service ID 1 in cross-connect group xcga.
Hop
Hop number.
Wait time
Node type:
·     Ingress.
·     Transit.
·     Egress.
Replier
Request time out
ping { evpn | static } vpws srv6
unicast-forwarding dx2-based
Use unicast-forwarding dx2-based to configure unicast traffic forwarding based on End.DX2 and End.DX2L SIDs in an EVPN VPLS over SRv6 network.
Use undo unicast-forwarding dx2-based to restore the default.
Unicast traffic is forwarded based on End.DT2U and End.DT2UL SIDs in an EVPN VPLS over SRv6 network.
By default, when a PE receives a packet that includes an End.DT2U or End.DT2UL SID, it looks up the MAC address table of the SID's VSI to forward the packet.
To improve forwarding efficiency, use this command. This command enables the PE to allocate an End.DX2 or End.DX2L SID to each AC associated with a VSI and advertise the SIDs to remote PEs through MAC/IP advertisement routes. When the PE receives an SRv6 packet that includes a locally allocated End.DX2 or End.DX2L SID, it does not look up the MAC address table. The PE directly forwards the packet to the AC that is associated with the SID after removing the SRv6 encapsulation.
The unicast-forwarding dx2-based command and the unknown-mac-route command are mutually exclusive with each other. If you execute both commands, unknown MAC routes (UMRs) cannot be advertised correctly.
# Configure EVPN VPLS over SRv6 to forward unicast traffic based on End.DX2 and End.DX2L SIDs.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation srv6
[Sysname-vsi-aaa-evpn-srv6] unicast-forwarding dx2-based
segment-routing ipv6 locator (cross-connect view and VSI EVPN instance view)
