- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Emergency shell configuration
- 10-Automatic configuration
- 11-Device management configuration
- 12-Tcl configuration
- 13-Python configuration
- 14-License management
- 15-Preprovisioning feature configuration
| 15-Preprovisioning feature configuration | 51.28 KB |
Restrictions and guidelines: Preprovisioning
Display and maintenance commands for preprovisioned settings
Configuring preprovisioning
About preprovisioning
Preprovisioning allows you to preconfigure offline modules, including interface cards, subcards, PEXs, and IRF member devices.
When a preprovisioned module comes online, the preprovisioned settings are applied. After the module goes offline, you can continue to change the existing settings or add new settings for the module. The final settings are applied when the module comes online again.
For the preprovisioned settings to survive a reboot, you must use the save command to save the settings to the next-startup configuration file.
Enabling preprovisioning
1. Enter system view.
2. Select the slot to preprovision and enter slot view.
In standalone mode:
slot slot-number
In IRF mode:
chassis chassis-number slot slot-number
3. Enable preprovisioning on the slot.
provision model model
By default, preprovisioning is disabled.
The specified model must be the same as the model of the module you want to install. If not, the preprovisioned settings cannot be applied to the module.
4. Enable preprovisioning on a subslot for a subcard.
provision subslot subslot-number model model
The specified model must be the same as the model of the subcard you want to install. If not, the preprovisioned settings cannot be applied to the subcard.
CAUTION: · When you disable preprovisioning on a slot, the device removes all preprovisioned commands for the slot, including the preprovisioned commands on the subslots. · When you disable preprovisioning on a subslot, the device removes preprovisioned commands for the subslot. |
Execute display commands in any view. Execute the reset command in user view.
Task |
Command |
Display preprovisioned-commands application failure records. |
display provision failed-config |
Clear preprovisioned-commands application failure records. |
reset provision failed-config |
