23-Segment Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10323-Segment Routing Command Reference
05-SRv6 OAM commands
05-SRv6 OAM commands 152.35 KB
SRv6 OAM commands
ping ipv6-sid
Use ping ipv6-sid to detect connectivity of an SRv6 path.
ping ipv6-sid [ -a source-ipv6 | -c count | -m interval | -q | -s packet-size | -t timeout | -tc traffic-class | -v ] * [ segment-by-segment ] { sid }&<1-11> [ network-slice slice-id slice-prefix ipv6-address [ force-match-slice ] ]
-a source-ipv6: Specifies an IPv6 address of the device as the source IP address of ICMP echo requests. If you do not specify this option, the source address specified in the encapsulation source-address command applies. If the encapsulation source-address command is not configured, the IPv6 address of the outbound interface for the ICMP echo requests applies.
-c count: Specifies the number of ICMPv6 echo requests to be sent to the destination. The value range is 1 to 4294967295, and the default is 5.
-m interval: Specifies the interval (in milliseconds) to send ICMPv6 echo requests. The value range is 1 to 65535, and the default is 1000.
-q: Displays only the summary statistics. If you do not specify this keyword, the system displays all the ping statistics.
-s packet-size: Specifies the length (in bytes) of ICMPv6 echo requests (excluding the IPv6 packet header and the ICMPv6 packet header). The value range is 20 to 9600, and the default is 56.
-t timeout: Specifies the timeout time (in milliseconds) of an ICMPv6 echo reply. The value range is 0 to 65535, and the default is 2000.
-tc traffic-class: Specifies the traffic class value in ICMPv6 packets. The value range is 0 to 255 and the default is 0.
-v: Displays detailed information about ICMPv6 echo replies. If you do not specify this keyword, the system only displays brief information about ICMPv6 echo replies.
segment-by-segment: Performs segment-by-segment ping. If you do not specify this keyword, end-to-end ping is performed.
{ sid }&<1-11>: Specifies a space-separated list of up to 11 SRv6 SIDs. This argument applies only to end-to-end ping. You must configure the End.OP SID by using this argument.
network-slice slice-id: Specifies a network slice instance (NSI) ID in the range of 0 to 4294967295. If you specify this option, the device adds the NSI ID to the ICMPv6 echo request packets. If you do not specify this option, the device does not encapsulate an IPv6 header containing the NSI ID for ICMPv6 echo request packets.
slice-prefix ipv6-address: Specifies the IPv6 source address prefix for network slice packets. After you specify this option, the highest bit of the source address in the ICMPv6 echo request packets will be modified to the IPv6 source address prefix specified in this command. In addition, the lowest 32 bits of the source address will be modified to the NSI ID specified in this command. If the total length of the IPv6 source address prefix and the NSI ID is less than 128 bits, zeroes are padded after the IPv6 source address prefix. If this option is not specified, ICMPv6 packets will be encapsulated according to the HBH slicing method.
force-match-slice: Forcibly matches the specified NSI ID. If you specify this keyword, the device sends ICMPv6 echo request packets only when the specified NSI ID is the same as that of the network slice channel for the packet output interface. If the NSI IDs are different, the device discards ICMPv6 echo request packets, resulting in ping failure. If you do not specify this keyword, the device forwards ICMPv6 echo request packets without verifying the NSI ID of the packets.
To perform end-to-end ping, make sure the following conditions are met:
·     An End.OP SID has been configured on the destination node.
·     When specifying the SRv6 SID list, specify the End.OP SID before the SRv6 SID of the destination node.
Take an end-to-end ping to detect the SRv6 path A>B>C for example (where A, B, and C are the source node, intermediate node, and destination node, respectively). The SRv6 SID of node B is 1010::1:0:1b, the End.OP SID of node C is 1020::32, and the SRv6 SID of node C is 1020::1:0:3. To perform end-to-end ping on source node A, execute the ping ipv6-sid 1010::1:0:1b 1020::32 1020::1:0:3 command.
To identify one of the multiple SRv6 paths between the source and destination nodes, you can specify the SRv6 SIDs of multiple nodes on the specific path.
To abort the SRv6 SID-based ping operation during the execution of the command, press Ctrl+C.
When both the -a and slice-prefix keywords are specified, the source IPv6 address in the ICMPv6 echo request packet takes the configuration of the slice-prefix keyword.
When you specify the slice-prefix keyword, the value of the configured NSI ID cannot exceed 2147483647.
# Perform end-to-end ping to detect the SRv6 path connectivity (the SRv6 SID of the intermediate node is 1010::1:0:1b, the End.OP SID of the destination node is 1020::32, and the SRv6 SID of the destination node is 1020::1:0:3).
<sysname> ping ipv6-sid 1010::1:0:1b 1020::32 1020::1:0:3
Ping SRv6(56 data bytes) 1::1 --> 1010::1:0:1b 1020::32 1020::1:0:3, press CTRL_C to break
56 bytes from 1020::1:0:3, icmp_seq=0 ttl=64 time=62.000 ms
56 bytes from 1020::1:0:3, icmp_seq=1 ttl=64 time=23.000 ms
56 bytes from 1020::1:0:3, icmp_seq=2 ttl=64 time=20.000 ms
56 bytes from 1020::1:0:3, icmp_seq=3 ttl=64 time=4.000 ms
56 bytes from 1020::1:0:3, icmp_seq=4 ttl=64 time=16.000 ms
--- Ping6 SRv6 statistics ---
round-trip min/avg/max/std-dev = 4.000/25.000/62.000/20.000 ms
# Perform segment-by-segment ping to detect the SRv6 path connectivity (the SRv6 SID of the intermediate node is 1010::1:0:1b and the SRv6 SID of the destination node is 1020::1:0:3).
<sysname> ping ipv6-sid segment-by-segment 1010::1:0:1b 1020::1:0:3
Ping SRv6(56 data bytes) 1::1 --> 1010::1:0:1b 1020::1:0:3, press CTRL_C to break
56 bytes from 1010::1:0:1b, icmp_seq=0 ttl=64 time=36.000 ms
56 bytes from 1020::1:0:3, icmp_seq=0 ttl=63 time=62.000 ms
56 bytes from 1010::1:0:1b, icmp_seq=1 ttl=64 time=23.000 ms
56 bytes from 1020::1:0:3, icmp_seq=1 ttl=63 time=43.000 ms
56 bytes from 1010::1:0:1b, icmp_seq=2 ttl=64 time=10.000 ms
56 bytes from 1020::1:0:3, icmp_seq=2 ttl=63 time=20.000 ms
56 bytes from 1010::1:0:1b, icmp_seq=3 ttl=64 time=4.000 ms
56 bytes from 1020::1:0:3, icmp_seq=3 ttl=63 time=12.000 ms
56 bytes from 1010::1:0:1b, icmp_seq=4 ttl=64 time=7.000 ms
56 bytes from 1020::1:0:3, icmp_seq=4 ttl=63 time=16.000 ms
5 packet(s) transmitted, 10 packet(s) received
round-trip min/avg/max/std-dev = 4.000/23.000/62.000/20.000 ms
# Detect reachability of the node whose SRv6 SID is 1020::1:0:3. Only summary statistics are displayed.
<Sysname> ping ipv6-sid –q 1010::1:0:1b 1020::32 1020::1:0:3
Ping SRv6 (56 data bytes) 1::1 --> 1010::1:0:1b 1020::32 1020::1:0:3, press CTRL_C to break
# Detect reachability of the node whose SRv6 SID is 1020::1:0:3. Detailed ping statistics are displayed.
<Sysname> ping ipv6-sid –v 1010::1:0:1b 1020::32 1020::1:0:3
56 bytes from 1020::1:0:3, icmp_seq=0 ttl=64 dst=1010::1:0:1a idx=129 time=62.000 ms
56 bytes from 1020::1:0:3, icmp_seq=1 ttl=64 dst=1010::1:0:1a idx=129 time=23.000 ms
56 bytes from 1020::1:0:3, icmp_seq=2 ttl=64 dst=1010::1:0:1a idx=129 time=20.000 ms
56 bytes from 1020::1:0:3, icmp_seq=3 ttl=64 dst=1010::1:0:1a idx=129 time=4.000 ms
56 bytes from 1020::1:0:3, icmp_seq=4 ttl=64 dst=1010::1:0:1a idx=129 time=16.000 ms
Ping SRv6 1::1 --> 1010::1:0:1b 1020::32 1020::1:0:3, 56 data bytes, press CTRL_C to break
ICMPv6 echo requests with a data length of 56 bytes are sent through an intermediate SRv6 node with SID 1010::1:0:1b to the destination node with End.OP SID 1020::32 and SRv6 SID 1020::1:0:3.
Press Ctrl+C to abort the ping operation.
icmp_seq=1 ttl=64 dst=12::1 idx=129 time=62.000 ms
Received ICMPv6 echo replies from the SRv6 node whose SID is 1020::1:0:3.
·     The number of data bytes is 56.
·     The SRv6 SID of the destination node is 1020::1:0:3.
·     The packet sequence is 1.
·     The hop limit value is 64.
·     The destination address is 12::1. Specify the -v keyword to display this field.
·     The index for the packet inbound interface is 129. Specify the -v keyword to display this field.
·     The response time is 62 milliseconds.
Statistics on data received and sent in a ping operation.
Number of ICMPv6 echo requests sent.
5 packet(s) received
Number of ICMPv6 echo replies received.
0.0% packet loss
Percentage of unacknowledged requests to the total requests sent.
round-trip min/avg/max/ std-dev =4.000/25.000/62.000/20.000 ms
Minimum/average/maximum/standard deviation response time, in milliseconds.
Opcode
ping srv6-te policy
Use ping srv6-te policy to detect path connectivity and forwarding capability of an SRv6 TE policy.
ping srv6-te policy { policy-name policy-name | color color-value end-point ipv6 ipv6-address | binding-sid bsid } [ force-match-slice ] [ end-op end-op | endpoint ] [ -a source-ipv6 | -c count | -h hop-limit | -m interval | -s packet-size | -t timeout | -tc traffic-class ] *
policy-name policy-name: Specifies an SRv6 TE policy by its name, a case-sensitive string of 1 to 59 characters.
color color-value end-point ipv6 ipv6-address: Specifies an SRv6 TE policy by its color attribute value and endpoint IPv6 address. The color-value argument is in the range of 0 to 4294967295. The ipv6-address argument specifies the endpoint IPv6 address.
binding-sid bsid: Specifies an SRv6 TE policy by its BSID value. The BSID value is the SID value of the ingress node.
force-match-slice: Forcibly matches the NSI ID specified for the candidate path of the SRv6 TE policy. If you specify this keyword, the device sends ICMPv6 echo request packets only when the specified NSI ID is the same as the that of the network slice channel for the packet output interface. If the NSI IDs are different, the device discards ICMPv6 echo request packets, resulting in ping failure. If you do not specify this keyword, the device forwards ICMPv6 echo request packets normally without verifying the NSI ID of the packets.
end-op end-op: Adds an End.OP SID to the SID list of ICMPv6 echo requests (and adds the SL value in the SRH by 1) for identifying the destination node. If you do not specify this option, no End.OP SID is added to ICMPv6 echo requests.
endpoint: Adds the endpoint IP address of the SRv6-TE policy to the SID list of ICMPv6 echo requests (and adds the SL value in the SRH by 1). If you do not specify this keyword, the endpoint IP address of the SRv6-TE policy is not added to the ICMPv6 echo requests.
-h hop-limit: Specifies the value for the Hop Limit field in ICMPv6 echo requests. The value range is 0 to 255, and the default is 255.
The source address of the ICMPv6 echo request packet takes the source address encapsulated by the network-slice command configured in SRv6 TE policy candidate path view when the following conditions exist:
·     The SRv6 TE policy candidate path uses an NSI ID and the source address slicing method to encapsulate the slice ID in the network slice packet.
·     The -a keyword is specified in this command.
To detect path connectivity and forwarding capability of an SRv6 TE policy, make sure an End.OP SID has been configured on the destination node.
When the SID list in the detected SRv6 TE policy contains only one local End.X SID, to ensure successful detection, first execute the encapsulation-mode encaps include local-end.x command in SRv6 TE policy view. Alternatively, execute the srv6-policy encapsulation-mode encaps include local-end.x command in SRv6 TE view.
# Detect path connectivity and forwarding capability of SRv6 TE policy p1.
<Sysname> ping srv6-te policy policy-name p1 end-op 8000::2
Ping SRv6-TE policy (56 data bytes) 8000::2, press CTRL_C to break
  Segment list ID: 0
    Preference=10, Path Type=primary, Protocol-Origin=local, Originator=0,0.0.0.0, Discriminator=10, End.OP=8000::2
56 bytes from 8000::2, icmp_seq=0 ttl=64 time=2.000 ms
56 bytes from 8000::2, icmp_seq=1 ttl=64 time=1.000 ms
56 bytes from 8000::2, icmp_seq=2 ttl=64 time=1.000 ms
56 bytes from 8000::2, icmp_seq=3 ttl=64 time=1.000 ms
56 bytes from 8000::2, icmp_seq=4 ttl=64 time=1.000 ms
--- Ping6 SRv6-TE Policy statistics ---
round-trip min/avg/max/std-dev = 1.000/1.200/2.000/0.400 ms
ICMPv6 echo requests with a data length of 56 bytes are sent to the destination node with End.OP SID 8000::2 in the SRv6 TE policy.
Segment list ID
Segment list ID.
Preference
Preference of the candidate path.
Path Type
Path type:
·     Main—Main path.
·     Backup—Candidate path.
·     None—The path is not selected.
Protocol-Origin
Protocol origin:
·     PCEP—The SRv6 TE policy is obtained through PCEP (not supported in the current software version).
·     BGP—The SRv6 TE policy is obtained through BGP.
·     Local—Local configuration.
·     Unknown—Unknown origin.
Originator=ASN Node-address
Information about the SRv6 TE policy obtained through BGP:
·     ASN—AS number. A value of 0 means the SRv6 TE policy is not obtained through BGP.
·     Node-address—BGP node address. The value is 0.0.0.0 for a manually configured SRv6 TE policy, and is the router ID of the BGP peer if the SRv6 TE policy information is obtained from the BGP peer.
Discriminator
Discriminator of the candidate path. A candidate path can be uniquely identified by the Protocol-Origin, Originator, and Discriminator fields.
End.OP
End.OP SID
Received ICMPv6 echo replies from the SRv6 node whose SID is 8000::2.
·     The SRv6 SID of the destination node is 8000::2.
·     The packet sequence is 0.
·     The response time is 2.000 milliseconds.
5 packets transmitted
5 packets received
0.0% packet loss
tracert ipv6-sid
Use tracert ipv6-sid to display the path that the IPv6 packets containing the specified SRv6 SID list traverse from the source node to the destination node.
tracert ipv6-sid [ -a source-ipv6 | -f first-hop  | -m max-hops | -p port | -q packet-number | -t traffic-class | -w timeout ] * [ overlay ] { sid }&<1-11> [ network-slice slice-id slice-prefix ipv6-address [ force-match-slice ] ]
-a source-ipv6: Specifies a valid IPv6 address on the device as the source IPv6 address of the probe packets. If you do not specify this option, the source address specified in the encapsulation source-address command applies. If the encapsulation source-address command is not configured, the IPv6 address of the outbound interface for the probe packets applies.
-f first-hop: Specifies the TTL value of the first packet. The value range is 1 to 255, and the default is 1. The value must be no greater than the value of the max-hops argument.
-m max-hops: Specifies the maximum number of hops allowed for a packet. The value range is 1 to 255, and the default is 30. The value must be no smaller than the value of the first-hop argument.
-p port: Specifies an invalid UDP port of the destination. The value range is 1 to 65535, and the default is 33434.
-q packet-number: Specifies the number of probe packets sent each time. The value range is 1 to 65535, and the default is 3.
-t traffic-class: Specifies the traffic class value in an IPv6 probe packet. The value range is 0 to 255, and the default is 0.
-w timeout: Specifies the timeout time (in milliseconds) of the reply packet of a probe packet. The value range is 1 to 65535, and the default is 5000.
overlay: Performs overlay tracert. If you do not specify this keyword, hop-by-hop tracert is performed. If you specify this keyword, you cannot specify the -f or -m keyword.
{ sid }&<1-11>: Specifies a space-separated list of up to 11 SRv6 SIDs. This argument applies only to hop-by-hop tracert. You must configure the End.OP SID by using this argument.
network-slice slice-id: Specifies an NSI ID in the range of 0 to 4294967295. If you specify this option, the device adds the NSI ID to the IPv6 tracert packets. If you do not specify this option, the device does not encapsulate an IPv6 header containing the NSI ID for IPv6 tracert packets.
slice-prefix ipv6-address: Specifies the IPv6 source address prefix for network slice packets. After you specify this option, the highest bit of the source address in the IPv6 tracert packets will be modified to the IPv6 source address prefix specified in this command. In addition, the lowest 32 bits of the source address will be modified to the NSI ID specified in this command. If the total length of the IPv6 source address prefix and the NSI ID is less than 128 bits, zeroes are padded after the IPv6 source address prefix. If this option is not specified, ICMPv6 packets will be encapsulated according to the HBH slicing method.
force-match-slice: Forcibly matches the specified NSI ID. If you specify this keyword, the device sends IPv6 tracert packets only when the specified NSI ID is the same as that of the network slice channel for the packet output interface. If the NSI IDs are different, the device discards IPv6 tracert packets, resulting in tracert failure. If you do not specify this keyword, the device forwards IPv6 tracert packets normally without verifying the NSI ID of the packets.
After identifying network failure with the ping ipv6-sid command, you can use the tracert ipv6-sid command to locate failed nodes.
The output from the tracert ipv6-sid command includes SRv6 SIDs of all the devices that the packets traverse from source to destination. Asterisks (* * *) are displayed if the device cannot reply with an ICMP error message. The reason might be the destination is unreachable or sending ICMP timeout/destination unreachable packets is disabled.
Before starting a tracert operation, you must enable sending of ICMPv6 destination unreachable messages on the intermediate devices between the source and destination. The tracert operation stops if any of the following ICMPv6 destination unreachable messages is received:
·     !N—No route to destination.
·     !P—Communication with destination administratively prohibited by filtering policies.
·     !A—Address unreachable. The unreachable reason is unknown.
·     !S—Beyond scope of source address. This message is displayed if the probe packet has a link-local source address and a non-link-local destination address. Such a packet cannot be delivered to the destination without leaving the scope of the source address.
To perform hop-by-hop tracert, make sure the following conditions are met:
Take a hop-by-hop tracert to detect the SRv6 path A>B>C for example (where A, B, and C are the source node, intermediate node, and destination node, respectively). The SRv6 SID of node B is 1010::1:0:1b, the End.OP SID of node C is 1020::32, and the SRv6 SID of node C is 1020::1:0:3. To perform hop-by-hop tracert on source node A, execute the tracert ipv6-sid 1010::1:0:1b 1020::32 1020::1:0:3 command.
When both the -a and slice-prefix keywords are specified, the source IPv6 address in the IPv6 tracert packet takes the configuration of the slice-prefix keyword.
To abort the tracert operation during the execution of the command, press Ctrl+C.
# Perform hop-by-hop tracert to display information about the SRv6 path (the SRv6 SID of the intermediate node is 1010::1:0:1b, the End.OP SID of the destination node is 1020::32, and the SRv6 SID of the destination node is 1020::1:0:3).
<Sysname> tracert ipv6-sid 1010::1:0:1b 1020::32 1020::1:0:3
Traceroute SRv6 1010::1:0:1b 1020::32 1020::1:0:3 from 1::1, 30 hops at most, 60 bytes packets, press CTRL_C to break
1  15::1 [SRH: 1020::1:0:3, 1020::32, 1010::1:0:1b, SL=2]  0.661 ms  0.618ms  0.579ms
2  12::2 [SRH: 1020::1:0:3, 1020::32, 1010::1:0:1b, SL=1]  0.861 ms  0.718ms  0.679ms
Display the SRv6 path that the IPv6 packets traverse through the intermediate node (whose SRv6 SID is 1010::1:0:1b) to the destination node (whose End.OP SID is 1020::32 and SRv6 SID is 1020::1:0:3).
hops at most
Maximum number of hops of the probe packets.
byte packets
Number of bytes of a probe packet.
Probe result of the probe packets that contain a hop limit value of 2, including the following information about the second hop:
·     IPv6 address of the hop.
·     SRH information in the ICMPv6 reply message, including the SRv6 SID list and number of remaining SRv6 SIDs (SL).
·     The round-trip time of the probe packets, in milliseconds.
ipv6 unreachables enable (Layer 3—IP Services Command Reference)
opcode
ping ipv6-sid
tracert srv6-te policy
Use tracert srv6-te policy to display the path to the destination node of an SRv6 TE policy.
tracert srv6-te policy { policy-name policy-name | color color-value end-point ipv6 ipv6-address | binding-sid bsid } [ force-match-slice ] [ end-op end-op | endpoint ] [ -a source-ipv6 | -f first-hop | -m max-hops | -p port | -q packet-number | -s packet-size | -tc traffic-class | -w timeout ] *
force-match-slice: Forcibly matches the NSI ID specified for the candidate path of the SRv6 TE policy. If you specify this keyword, the device sends IPv6 tracert packets only when the specified NSI ID is the same as the that of the network slice channel for the packet output interface. If the NSI IDs are different, the device discards IPv6 tracert packets, resulting in tracert failure. If you do not specify this keyword, the device forwards IPv6 tracert packets normally without verifying the NSI ID of the packets.
end-op end-op: Adds an End.OP SID to the SID list of ICMPv6 probe packets (and adds the SL value in the SRH by 1) for identifying the destination node. If you do not specify this option, no End.OP SID is added to probe packets.
endpoint: Adds the endpoint IP address of the SRv6-TE policy to the SID list of probe packets (and adds the SL value in the SRH by 1). If you do not specify this keyword, the endpoint IP address of the SRv6-TE policy is not added to the probe packets.
-s packet-size: Specifies the length (in bytes) of probe packets, in the range of 20 to 9600, and the default is 56.
-tc traffic-class: Specifies the traffic class value in an IPv6 probe packet. The value range is 0 to 255, and the default is 0.
After identifying network failure with the ping srv6-te policy command, you can use the tracert srv6-te policy command to locate failed nodes.
The output from the tracert srv6-te policy command includes SRv6 SIDs of all the devices that the packets traverse from source to destination. Asterisks (* * *) are displayed if the device cannot reply with an ICMP error message. The reason might be the destination is unreachable or sending ICMP timeout/destination unreachable packets is disabled.
The source address of the IPv6 tracert packet takes the source address encapsulated by the network-slice command configured in SRv6 TE policy candidate path view when the following conditions exist:
# Perform tracert to display information about the tunnel for SRv6 TE policy p1.
<Sysname> tracert srv6-te policy policy-name p1 end-op 8000::1
Traceroute SRv6-TE policy from 1::1, 30 hops at most, 60 byte packets, press CTRL_C to break
  Segment list ID: 1
    Preference=10, Path Type=primary, Protocol origin=local, Originator=0, 0.0.0.0, Discriminator=10, End.OP=8000::1
 1  1000::2 [SRH: 8000::1, 8000::1, 7000::1, 6000::1, SL=3]  1.000 ms  1.000 ms  1.000 ms
 2  2000::3 [SRH: 8000::1, 8000::1, 7000::1, 6000::1, SL=2]  1.000 ms  1.000 ms  1.000 ms
 3  4000::4 [SRH: 8000::1, 8000::1, 7000::1, 6000::1, SL=1]  0.000 ms  0.000 ms  1.000 ms
Display information about the tunnel for the SRv6 TE policy.
hops at most
byte packets
Press Ctrl+C to abort the tracert operation.
Segment list ID
Segment list ID.
Preference
Path Type
Path type:
·     Main—Main path.
Protocol origin
Protocol origin:
Discriminator
Discriminator of the candidate path. A candidate path can be uniquely identified by the Protocol origin, Originator, and Discriminator fields.
End.OP
End.OP SID
Probe result of the probe packets that contain a hop limit value of 1, including the following information about the second hop:
ping srv6-te policy
