| 02-DPI engine commands | 368.20 KB |
display inspect smb-breakpoint-resume table
inspect block-source parameter-profile
inspect capture parameter-profile
inspect email parameter-profile
inspect file-fixed-length enable
inspect logging parameter-profile
inspect real-ip detect-field priority
inspect real-ip detect-field tcp-option
inspect real-ip detect-field xff
inspect real-ip extraction mode
inspect record-filename nfs maximum
inspect redirect parameter-profile
inspect signature auto-update proxy
inspect signature auto-update source
inspect signature auto-update vpn-instance
inspect source-port-identify enable
inspect stream-fixed-length disable
inspect tcp-reassemble max-segment
inspect url-filter warning parameter-profile
inspect waf http-log-details enable
inspect warning parameter-profile
DPI engine commands
The following compatibility matrixes show the support of hardware platforms for the DPI engine:
Hardware |
DPI engine compatibility |
MSR610 |
Yes |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G, MSR1004S-5G-CN |
Yes |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR2630-G-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
Yes |
MSR3600-28-G-X1-DP, MSR3600-51-G-X1-DP |
Yes |
Yes |
MSR-IMC |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
MSR3620-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2600-15-X1-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
app-profile
Use app-profile to create a deep packet inspection (DPI) application profile and enter its view, or enter the view of an existing DPI application profile.
Use undo app-profile to delete a DPI application profile.
app-profile profile-name
undo app-profile profile-name
No DPI application profiles exist.
profile-name: Specifies a DPI application profile name. The profile name is a case-insensitive string of 1 to 63 characters. Valid characters are letters, digits, and underscores (_).
The DPI application profile is a security service template that can include DPI service policies such as IPS policies.
A DPI application profile takes effect after an object policy rule or a security policy rule uses it as the action. The DPI engine inspects the packets matching the rule and submits the packets to the associated DPI service module for processing.
# Create a DPI application profile named abc and enter its view.
[Sysname] app-profile abc
[Sysname-app-profile-abc]
authentication enable
Use authentication enable to enable email client authentication.
Use undo authentication enable to disable email client authentication.
Email client authentication is enabled.
Email parameter profile view
Use this command when the email server specified by the email-server command requires client authentication.
# Disable email client authentication.
[Sysname] inspect email parameter-profile c1
[Sysname-inspect-email-c1] undo authentication enable
block-period
Use block-period to set the block period during which a source IP address is blocked.
Use undo block-period to restore the default.
block-period period
undo block-period
A source IP address is blocked for 1800 seconds.
Block source parameter profile view
period: Specifies the block period in the range of 1 to 86400 seconds.
For the block period to take effect, make sure the blacklist feature is enabled.
The device drops the packet that matches an inspection rule and adds the packet's source IP address to the IP blacklist.
· If the blacklist feature is enabled, the device directly drops subsequent packets from the source IP address during the block period.
· If the blacklist feature is disabled, the block period does not take effect. The device inspects all packets and drops the matching ones.
For more information about the blacklist feature, see attack detection and prevention in the Security Configuration Guide.
# Set the block period to 3600 seconds in block source parameter profile b1.
[Sysname] inspect block-source parameter-profile b1
[Sysname-inspect-block-source-b1] block-period 3600
blacklist enable (security zone view) (Security Command Reference)
blacklist global enable (Security Command Reference)
capture-limit
Use capture-limit to set the maximum volume of captured packets that can be cached.
Use undo capture-limit to restore the default.
capture-limit Kilobytes
undo capture-limit
The device can cache a maximum of 512 Kilobytes of captured packets.
Capture parameter profile view
Kilobytes: Specifies the maximum volume in the range of 0 to 1024 Kilobytes.
The device caches captured packets locally. It exports the cached captured packets to a URL when the volume of cached captured packets reaches the maximum, and clears the cache. After the export, the device starts to capture packets again.
If you set the maximum volume of cached captured packets to 0 Kilobytes, the device immediately exports a packet to the URL after the packet is captured.
# Set the maximum volume of cached captured packets to 1024 Kilobytes in the capture parameter profile c1.
[Sysname] inspect capture parameter-profile c1
[Sysname-inspect-capture-c1] capture-limit 1024
export repeating-at
export url
Use display inspect smb-breakpoint-resume table to display the breakpoint resumption table for the SMB protocol.
In standalone mode:
display inspect smb-breakpoint-resume table { ipv4 | ipv6 }
In IRF mode:
display inspect smb-breakpoint-resume table { ipv4 | ipv6 } [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the breakpoint resumption table for all member devices. (In IRF mode.)
The SMB protocol supports breakpoint resumption. When a file is interrupted during transmission, SMB can transfer subsequent files by creating a new session. When a file transferred via the SMB protocol is processed by the drop, block source, redirect, or reset DPI action, the device creates a breakpoint resumption table to record the source IP, destination IP, source VRF, destination VRF, MDC ID, and file name of the file. When the device receives a subsequent file of the SMB protocol, it matches the file information with the breakpoint resumption table. If a match is found, the device takes the same action on the file. In this manner, subsequent files can be blocked.
You can use this command to analyze the files dropped.
# Display the breakpoint resumption table for the SMB protocol.
<Sysname> display inspect smb-breakpoint-resume table ipv4
Slot 1:
Smb-breakpoint-resume table information:
Source IP: 1.1.1.1
Destination IP: 2.2.2.2
Source VRF: public
Destination VRF: public
MDC ID: 1
File name: test.txt
Source IP: 3.3.3.3
Destination IP: 4.4.4.4
Source VRF: public
MDC ID: 2
File name: test.doc
Source VRF |
If the file is from the public network, this field displays public. |
Destination VRF |
If the file is destined for the public network, this field displays public. |
display inspect status
Use display inspect status to display the status of the DPI engine.
# Display the status of the DPI engine.
<Sysname> display inspect status
Chassis 0 Slot 1:
Running status: Normal
Running status |
Status of the DPI engine: · DPI administratively disabled. · DPI auto-bypass for protocol xxx. · DPI disabled due to high CPU usage. · Normal—The DPI engine is running correctly. |
Usage threshold has already been reached for the following CPU cores: xxx |
This sentence appears when one or more CPU cores reach the CPU core usage alarm threshold. DPI will not use these CPU cores to process services. |
monitor cpu-usage threshold core (Fundamentals Command Reference)
email-limit
Use email-limit to configure output limit for log entries sent to the email server.
Use undo email-limit to restore the default.
email-limit interval interval max-number value
undo email-limit
The device allows sending a maximum of 10 log entries within five minutes.
interval interval: Specifies email sending interval in the range of 1 to 10 minutes.
max-number max-number: Specifies the maximum number of emails per interval, in the range of 1 to 100.
This command prevents the device from frequently sending too many log entries to the email server.
The device caches the log entries and sends them when the specified interval is reached.
If the number of cached log entries has reached the upper limit, the device compares the severity level of a new log entry with the severity levels of the cached log entries. If the severity level of the new log entry is higher than that of a cached log entry, the new log entry will overwrite the most recently cached log entry with the lowest severity level. The severity level of a new log entry is the severity level of the matching IPS signatures.
# Allow the device to send a maximum of 20 log entries within five minutes to the email server.
[Sysname] inspect email parameter-profile test
[Sysname-inspect-email-test] email-limit interval 5 max-number 20
email-server
Use email-server to specify the email server.
Use undo email-server to restore the default.
email-server address-string
undo email-server
No email server is specified.
address-string: Specifies the email server address, a case-sensitive string of 3 to 63 characters.
The email server address can be an IP address or a host name.
If you specify the email server by host name, make sure the device can resolve the host name into its IP address through static or dynamic DNS. Make sure the device and the email server can reach each other. For more information about DNS, see DNS configuration in Layer 3—IP Services Configuration Guide.
If you execute this command multiple times for the same email parameter profile, the most recent configuration takes effect.
# Specify the email server rndcas.123.com.
[Sysname-inspect-email-c1] email-server rndcas.123.com
# Specify the email server at 192.168.1.1.
[Sysname-inspect-email-c1] email-server 192.168.1.1
export repeating-at
Use export repeating-at to set the daily export time for cached captured packets.
Use export repeating-at to restore the default.
export repeating-at time
undo export repeating-at
The system exports cached captured packets at 1:00 a.m. every day.
time: Specifies the daily export time in the format of hh:mm:ss in the range of 00:00:00 to 23:59:59.
The device exports cached captured packets to a URL and clears the cache at the daily export time, whether or not the volume of cached captured packets reaches the maximum.
# Configure the device to export cached captured packets at 2:00 a.m. every day in the capture parameter profile c1.
[Sysname-inspect-capture-c1] export repeating-at 02:00:00
capture-limit
export url
export url
Use export url to specify the URL to which the cached captured packets are exported.
Use export url to restore the default.
export url url-string
undo export url
No URL is specified for exporting the cached captured packets.
url-string: Specifies the URL, a string of 1 to 255 characters.
The device exports the cached captured packets to the specified URL at the daily export time or when the volume of cached captured packets reaches the maximum. After the captured packets are exported, the system clears the cache.
If you do not specify a URL, the device still exports the cached captured packets but the export fails.
# Configure the device to export cached captured packets to URL tftp://192.168.100.100/upload in the capture parameter profile c1.
[Sysname-inspect-capture-c1] export url tftp://192.168.100.100/upload
capture-limit
export repeating-at
import warning-file
Use import warning-file to import a user-defined alarm message from a warning file for URL filtering.
import warning-file file-path
The device uses the default alarm message in the warning file named uflt-xxx.html. The xxx in the file name is the profile name.
URL filtering warning parameter profile view
file-path: Specifies the warning file path, a string of 1 to 200 characters.
The default alarm message is as follows:
Web Access Blocked
Your access to this website was denied. To access this webpage, contact Technical Support.
· Reason: XXX
· Category: XXX
· URL: XXX
The Reason field has the following values:
· The URL of the website hit the URL blacklist.
· The URL of the website hit a user-defined URL category.
· The URL of the website hit a predefined URL category.
· No matching whitelist entry was found for the website in whitelist mode.
· The URL of the website did not match any accessible URL category.
· The URL of the website hit the URL reputation signature library.
The Category field displays the user-defined or predefined URL category, or the attack category of URL reputation.
The URL field displays the URL accessed by the client.
If an end-point user visits a virus-infected website, the device will block the website access and displays the alarm message on the browser of the end-point user.
You can execute the import warning-file command to specify a user-defined alarm message from a file. Only HTML and TXT files are supported.
The device supports the following import methods:
· Local import—Imports the message from the warning file that is stored locally.
(In IRF mode.) Store the warning file on the master device for successful import.
The format of the file-path argument varies by the location of the warning file to be imported.
The warning file is stored… |
Format of file-path |
Remarks |
In the current working directory |
filename |
To display the current working directory, use the pwd command. For information about the pwd command, see file system management in Fundamentals Command Reference. |
In a directory different from the working directory on the same storage medium |
filename |
Before importing the warning file, you must first use the cd command to open the directory where the file is stored. For information about the cd command, see file system management in Fundamentals Command Reference. |
On a storage medium different from the working directory |
path/filename |
Before importing the warning file, you must first use the cd command to open the root directory of the storage medium where the file is stored. For information about the cd command, see file system management in Fundamentals Command Reference. |
· FTP/TFTP import—Imports the message from the warning file that is stored on an FTP or TFTP server.
The warning file is stored on |
Remarks |
An FTP server |
ftp://username:password@server/filename |
The username and password arguments represent the FTP login username and password, respectively. The server argument represents the IP address or host name of the FTP server. If a colon (:), at sign (@), or forward slash (/) exists in the username or password, you must convert it into its escape characters. The escape characters are %3A or %3a for a colon, %40 for an at sign, and %2F or %2f for a forward slash. |
A TFTP server. |
tftp://server/filename |
The server argument represents the IP address or host name of the TFTP server. |
NOTE: To specify a warning file on an FTP or TFTP server, make sure the device and the server can reach each other. If you specify the server by its host name, you must also make sure the device can resolve the host name into an IP address through static or dynamic DNS. For more information about DNS, see DNS configuration in Layer 3—IP Services Configuration Guide. |
# Import a user-defined alarm message from the warning file on a TFTP server.
[Sysname] inspect url-filter warning parameter-profile warn
[Sysname-inspect-url-filter-warning-warn] import warning-file tftp://192.168.0.1/warning.txt
# Import a user-defined alarm message from the warning file on an FTP server. The FTP login username and password are user and password, respectively.
[Sysname-inspect-url-filter-warning-warn] import warning-file ftp://user:[email protected]/warning.txt
# Import a user-defined alarm message from the warning file stored locally. The file is stored in directory cfa0:/warning.txt, and the current working directory is cfa0.
[Sysname-inspect-url-filter-warning-warn] import warning-file warning.txt
inspect activate
Use inspect activate to activate the policy and rule configurations for DPI service modules.
inspect activate
The creation, modification, and deletion of DPI service policies and rules will be activated automatically.
CAUTION: This command causes transient DPI service interruption. DPI-based services might also be interrupted. For example, security policies cannot control access to applications. |
By default, the system will detect whether another configuration change (such as creation, modification, or deletion) occurs within a 20-second interval after a configuration change for DPI service modules such as URL filtering:
· If no configuration change occurs within the interval, the system performs an activation operation at the end of the next interval to make the configuration take effect.
· If a configuration change occurs within the interval, the system continues to periodically check whether a configuration change occurs within the interval.
To activate the policy and rule configurations for DPI service modules immediately, you can execute the inspect activate command.
# Activate the policy and rule configurations for DPI service modules.
[Sysname] inspect activate
inspect auto-bypass
Use inspect auto-bypass enable to enable automatic bypass of the DPI engine.
Use undo inspect auto-bypass enable to disable automatic bypass of the DPI engine.
Automatic bypass of the DPI engine is disabled.
With this feature enabled, the DPI engine automatically disables inspection on packets of the specified protocol after a device reboot caused by packet inspection errors.
# Enable automatic bypass of the DPI engine.
[Sysname] inspect auto-bypass enable
This feature might cause some functions of the DPI engine to be unavailable. Continue? [Y/N]:y
Use inspect block-source parameter-profile to create a block source parameter profile and enter its view, or enter the view of an existing block source parameter profile.
Use undo inspect block-source parameter-profile to delete a block source parameter profile.
inspect block-source parameter-profile parameter-name
undo inspect block-source parameter-profile parameter-name
No block source parameter profiles exist.
parameter-name: Specifies a block source parameter profile name, a case-insensitive string of 1 to 63 characters.
In block source parameter profile view, you can set parameters for the block source action, such as the block period.
# Create a block source parameter profile named b1 and enter its view.
block-period
inspect bypass
Use inspect bypass to disable the DPI engine.
Use undo inspect bypass to enable the DPI engine.
inspect bypass
undo inspect bypass
The DPI engine is enabled.
CAUTION: This command causes packets of any protocols not to be processed by DPI. DPI-based services might also be interrupted. For example, security policies cannot control access to applications. |
Packet inspection in the DPI engine is a complex and resource-consuming process. When the CPU usage is high, you can disable the DPI engine to guarantee the device performance.
# Disable the DPI engine.
[Sysname] inspect bypass
inspect bypass protocol
Use inspect bypass protocol to specify the protocols to bypass the DPI engine.
Use undo inspect bypass protocol to disable DPI engine bypass for protocols.
inspect bypass protocol { dns | ftp | ftp-data | http | https | imap | nfs | pop3 | rtmp | sip | smb | smtp | telnet | tftp } *
undo inspect bypass protocol [ dns | ftp | ftp-data | http | https | imap | nfs | pop3 | rtmp | sip | smb | smtp | telnet | tftp ] *
The DPI engine inspects all supported protocols.
dns: Specifies the DNS protocol.
ftp: Specifies the FTP protocol.
ftp-data: Specifies the FTP data protocol.
http: Specifies the HTTP protocol.
https: Specifies the HTTPS protocol.
imap: Specifies the IMAP protocol.
nfs: Specifies the NFS protocol.
pop3: Specifies the POP3 protocol.
rtmp: Specifies the RTMP protocol.
sip: Specifies the SIP protocol.
smb: Specifies the SMB protocol.
smtp: Specifies the SMTP protocol.
telnet: Specifies the Telnet protocol.
tftp: Specifies the TFTP protocol.
If you do not specify any keyword when executing the undo inspect bypass protocol command, the DPI engine inspects all supported protocols.
As a best practice, you can specify the protocols to bypass the DPI engine when either of the following conditions is met:
· Inspection on packets of the specified protocols is not required. You can disable the DPI engine for the specified protocols to reduce the occupation of device resources and improve the device performance.
· Inspection on packets of the specified protocols causes device reboot. You can specify the protocols to bypass the DPI engine to avoid device reboot caused by inspection error and ensure the inspection on packets of other protocols.
# Specify the HTTP protocol to bypass the DPI engine.
[Sysname] inspect bypass protocol http
This feature might cause the DPI engine to be unavailable for the specified protocol. Continue? [Y/N]:y
inspect cache-option maximum
Use inspect cache-option maximum to set the maximum number of options to be cached per TCP or UDP data flow for further inspection.
Use undo inspect cache-option to restore the default.
inspect cache-option maximum max-number
The DPI engine can cache a maximum of 32 options per TCP or UDP data flow.
max-number: Specifies the maximum number of options to be cached per TCP or UDP data flow. The value range is 1 to 254.
An inspection rule can contain multiple AC patterns, and each AC pattern can be associated with multiple options. A TCP or UDP data flow matches an inspection rule if the packets of the flow match all the AC patterns and options in the rule.
If a packet of a TCP or UDP data flow matches one AC pattern in an inspection rule, the DPI engine cannot determine whether the flow matches the rule. The DPI engine continues to match packets of the flow against the remaining options and AC patterns in the rule. For any options that cannot be matched, the DPI engine caches them to match subsequent packets. The DPI engines determines that the flow matches the rule when all options and AC patterns in the rule are matched.
The more options DPI engine caches, the more likely that DPI engine identifies the application information and the more accurate the DPI engine inspection. However, caching more options requires more memory. If the device has a high memory usage, configure the DPI engine to cache less options to improve the device performance.
Typically, the default setting is sufficient for most scenarios.
# Configure the DPI engine to cache a maximum of four options per TCP or UDP data flow for further inspection.
[Sysname] inspect cache-option maximum 4
Use inspect capture parameter-profile to create a capture parameter profile and enter its view, or enter the view of an existing capture parameter profile.
Use undo inspect capture parameter-profile to delete a capture parameter profile.
inspect capture parameter-profile parameter-name
undo inspect capture parameter-profile parameter-name
No capture parameter profiles exist.
profile-name: Specifies a capture parameter profile name, a case-insensitive string of 1 to 63 characters.
In capture parameter profile view, you can set parameters for the packet capture action, such as the maximum volume of cached captured packets.
Only the IPS module supports the packet capture action.
# Create a capture parameter profile named c1 and enter its view.
capture-limit
export repeating-at
export url
inspect cloud-server
Use inspect cloud-server to specify the server used by DPI services for cloud query.
Use undo inspect cloud-server to remove the cloud query server specified for DPI services.
inspect cloud-server host-name
DPI services use the cloud query server with host name sec.h3c.com.
host-name: Specifies the cloud query server by its host name, a case-insensitive string of 1 to 255 characters. Valid characters include letters, digits, underscores (_), hyphens (-), and dots (.).
The cloud query server supports URL filtering cloud query.
For successful cloud query, make sure the device can resolve the host name of the cloud query server into an IP address through DNS. For more information about DNS, see DNS configuration in Layer 3—IP Services Configuration Guide.
# Specify the server with host name service.h3c.com for cloud query.
[Sysname] inspect cloud-server service.h3c.com
cloud-query enable (URL filtering policy view)
inspect coverage
Use inspect coverage to configure a DPI engine inspection mode.
Use undo inspect coverage to restore the default.
inspect coverage { balanced | large-coverage | high-performance | user-defined }
The DPI engine uses the balanced mode.
balanced: Specifies the balanced mode. This mode makes a tradeoff between the device performance and inspection coverage.
large-coverage: Specifies the large coverage mode. This mode appropriately reduces device performance to achieve the best inspection coverage.
high-performance: Specifies the high performance mode. This mode appropriately reduces the inspection coverage to ensure the best device performance.
user-defined: Specifies the user-defined mode. This mode allows you to adjust the inspection length of the DPI engine as required.
Select an inspection mode as required:
· Balanced mode—Applicable to most scenarios. This mode makes a tradeoff between the device performance and inspection coverage. The maximum length is 64 Kilobytes for FTP, HTTP, SMB, NFS, and email streams.
· Large coverage mode—Applicable to the scenarios that require large inspection coverage. This mode improves the inspection coverage at the cost of device performance. The maximum length is 128 Kilobytes for FTP, HTTP, SMB, NFS, and email streams.
· High performance mode—Applicable to the scenarios that requires high device performance. This mode improves the device performance while ensuring a certain inspection coverage. The maximum length is 32 Kilobytes for FTP, HTTP, SMB, NFS, and email streams.
· User-defined mode—Applicable to the scenarios that have specific requirements for inspection coverage and device performance. In this mode, you can execute the inspect stream-fixed-length command to set the maximum stream length for inspection.
# Configure the user-defined mode as the DPI engine inspection mode.
[Sysname] inspect coverage user-defined
inspect stream-fixed-length enable
inspect cpu-threshold disable
Use inspect cpu-threshold disable to disable inspection suspension upon excessive CPU usage.
Use undo inspect cpu-threshold disable to enable inspection suspension upon excessive CPU usage.
Inspection suspension upon excessive CPU usage is enabled.
Inspection suspension upon excessive CPU usage works as follows:
· When the device's CPU usage rises to or above the CPU usage threshold, the DPI engine suspends packet inspection to guarantee the device performance.
· When the device's CPU usage drops to or below the CPU usage recovery threshold, the DPI engine resumes packet inspection.
Do not disable inspection suspension upon excessive CPU usage if the device's CPU usage is high.
# Disable inspection suspension upon excessive CPU usage.
[Sysname] inspect cpu-threshold disable
inspect bypass
inspect dual-active enable
Use inspect dual-active enable to enable support for HA dual-active mode.
Use undo inspect dual-active enable to disable support for HA dual-active mode.
Support for HA dual-active mode is disabled.
The feature ensures the device in dual-active mode can correctly process DPI services in a network with asymmetric forwarding of flows.
This feature takes effect only when the device operates in HA dual-active mode HA HA .
This feature takes effect only after you enable transparent service traffic transmission between the remote backup group members (see RBM-based hot backup configuration in High Availability Configuration Guide).
For more information about HA dual-active mode, see high availability group configuration in High Availability Configuration Guide.
# Enable support for HA dual-active mode.
[Sysname] inspect dual-active enable
backup-mode dual-active (High Availability Command Reference)
transparent-transmit enable (High Availability Command Reference)
Use inspect email parameter-profile to create an email parameter profile and enter its view, or enter the view of an existing email parameter profile.
Use undo inspect email parameter-profile to delete an email parameter profile.
inspect email parameter-profile parameter-name
undo inspect email parameter-profile parameter-name
No email parameter profiles exist.
parameter-name: Specifies an email parameter profile name, a case-insensitive string of 1 to 63 characters.
In email parameter profile view, you can set parameters for the email action. Email parameters include the email server, the email sender and receiver, and the username and password for logging in to the email server.
# Create an email parameter profile named c1 and enter its view.
Use inspect file-fixed-length to set the fixed length for file inspection.
Use undo inspect file-fixed-length to restore the default.
inspect file-fixed-length { email | ftp | http | nfs | smb } * length-value
The fixed length is 64 Kilobytes for FTP, HTTP, NFS, SMB, and email files.
email: Specifies email protocols, including SMTP, POP3, and IMAP.
length-value: Specifies the fixed length in the range of 1 to 2048 Kilobytes.
This command can be executed only if the DPI engine inspection mode is user-defined mode.
Typically, virus signatures are embedded in the first half of a file. Narrowing the inspection scope of each file improves the file inspection efficiency.
If a data stream contains multiple files, this feature inspects only the fixed length data of each file.
Because files are transmitted in a data stream, the fixed length of files must not be longer than that of the data stream configured by the inspect stream-fixed-length command.
# Set the fixed length to 128 Kilobytes for inspecting each HTTP file.
[Sysname] inspect file-fixed-length http 128
Use inspect file-fixed-length enable to enable file fixed length inspection.
Use undo inspect file-fixed-length enable to disable file fixed length inspection.
The file fixed length inspection is disabled and the file inspection length is not limited.
The file fixed length inspection feature enables the DPI engine to inspect only a fixed length of file data instead of the entire file in each data stream.
With this feature configured, the DPI engine cannot identify the remaining file data that exceeds the defined fixed length, affecting the data filtering service.
# Enable file fixed length inspection.
[Sysname] inspect file-fixed-length enable
Use inspect logging parameter-profile to create a logging parameter profile and enter its view, or enter the view of an existing logging parameter profile.
Use undo inspect logging parameter-profile to delete a logging parameter profile.
inspect logging parameter-profile parameter-name
undo inspect logging parameter-profile parameter-name
No logging parameter profiles exist.
profile-name: Specifies a logging parameter profile name, a case-insensitive string of 1 to 63 characters.
In logging parameter profile view, you can set parameters for the logging action, such as the log output method.
# Create a logging parameter profile named log1 and enter its view.
[Sysname] inspect logging parameter-profile log1
[Sysname-inspect-logging-log1]
log
inspect optimization disable
Use inspect optimization disable to disable a DPI engine optimization feature.
Use undo inspect optimization disable to enable a DPI engine optimization feature.
inspect optimization [ chunk | no-acsignature | raw | uncompress | url-normalization ] disable
undo inspect optimization [ chunk | no-acsignature | raw | uncompress | url-normalization ] disable
All DPI engine optimization features are enabled.
chunk: Specifies the chunked packet decoding feature.
no-acsignature: Specifies the inspection rules that do not contain AC patterns.
raw: Specifies the application layer payload decoding feature.
uncompress: Specifies the HTTP body uncompression feature.
url-normalization: Specifies the HTTP URL normalization feature.
If you do not specify any parameter, this command applies to all DPI engine optimization features.
DPI engine supports the following optimization features:
· Chunked packet decoding—Chunk is a packet transfer mechanism of the HTTP body. DPI engine must decode a chunked HTTP body before it inspects the HTTP body. When the device throughput is too low to ensure basic communication, you can disable DPI engine from decoding chunked packets to improve the device performance. However, when chunked packet decoding is disabled, the DPI engine cannot identify some attacks that exploit security vulnerabilities.
· Inspection rules that do not contain AC patterns—Inspection rules that do not contain AC patterns contain only options. These rules match packets by fields such as port numbers and error codes rather than by character strings. These rules by default are enabled to improve the inspection accuracy. However, when the device throughput is too low to ensure basic communication, you can disable these rules to improve the device performance.
· Application layer payload decoding—For application layer protocols featuring encoding and decoding, such as HTTP, SMTP, POP3, and IMAP4, DPI engine must decode the payload before inspection. When the device throughput is too low to ensure basic communication, you can disable DPI engine from decoding application layer payloads to improve the device performance. However, disabling application layer payload decoding affects the inspection accuracy of the DPI engine.
· HTTP body uncompression—If the HTTP body field is compressed, DPI engine must uncompress the body before inspection. When the device throughput is too low to ensure basic communication, you can disable DPI engine from uncompressing the HTTP body field to improve the device performance. However, when HTTP body uncompression is disabled, the DPI engine cannot identify some attacks that exploit security vulnerabilities.
· HTTP URL normalization—HTTP URL normalization is the process by which the absolute path in a URL is normalized and special URLs are standardized and checked. For example, the absolute path test/dpi/../index.html is normalized as test/index.html. When the device throughput is too low to ensure basic communication, you can disable DPI engine from normalizing HTTP URLs to improve the device performance. However, when HTTP URL normalization is disabled, the DPI engine cannot identify some attacks that exploit security vulnerabilities.
# Disable all DPI engine optimization features.
[Sysname] inspect all disable
inspect packet maximum
Use inspect packet maximum to set the maximum number of payload-carrying packets to be inspected per data flow.
Use undo inspect packet to restore the default.
inspect packet maximum max-number
undo inspect packet
The DPI engine can inspect a maximum of 32 payload-carrying packets per data flow.
max-number: Specifies the maximum number of payload-carrying packets to be inspected per data flow, in the range of 1 to 254.
If DPI engine finds that the first payload-carrying packet of a data flow does not match any inspection rule, it continues to inspect the next payload-carrying packet, and so on. If DPI engine has inspected the maximum number of payload-carrying packets but finds no matching inspection rule, it determines the flow does not match any rule and allows the flow to pass.
The more payload-carrying packets DPI engine inspects, the more likely that DPI engine identifies the application information and the more accurate the DPI engine inspection.
Typically, the default setting is sufficient for most scenarios. You can adjust the setting according to your network condition.
· If the device throughput is high, increase the maximum number value.
· If the device throughput is low, decrease the maximum number value.
# Allow the DPI engine to inspect a maximum of 16 payload-carrying packets per data flow for application identification.
[Sysname] inspect packet maximum 16
Use inspect real-ip detect-field priority to set the priority of an inspected field for real source IP inspection.
Use undo inspect real-ip detect-field priority to cancel the priority of an inspected field for real source IP inspection.
inspect real-ip detect-field { cdn-src-ip | tcp-option | x-real-ip | xff } priority priority-value
undo inspect real-ip detect-field { cdn-src-ip | tcp-option | x-real-ip | xff } priority
No priority is specified for any inspected field in the real source IP inspection, and all inspected fields use priority value 0. The device inspects the fields in the order of the xff, cdn-src-ip, x-real-ip, and tcp-option fields.
cdn-src-ip: Specifies the Cdn-Src-Ip field in the HTTP header.
tcp-option: Specifies the TCP Options field.
xff: Specifies the X-Forwarded-For field in the HTTP header.
x-real-ip: Specifies the X-Real-IP field in the HTTP header.
priority priority-value: Specifies a priority for an inspected field, in the range of 1 to 100. The larger the priority value, the higher the priority. Each inspected filed must have a unique priority value.
If the extraction mode for real source IP inspection is priority, the device obtains the real source IP address of the client by inspecting multiple fields in the packets. The device uses the IP address extracted from the field with the highest priority as the final real source IP address.
# Set the priority to 10 for the X-Forwarded-For field.
[Sysname] inspect real-ip detect-field xff priority 10
inspect real-ip extraction mode priority
Use inspect real-ip detect-field tcp-option to configure real source IP inspection for the TCP Options field.
Use undo inspect real-ip detect-field tcp-option to restore the default.
inspect real-ip detect-field tcp-option hex hex-vector [ offset offset-value ] [ depth depth-value ] [ ip-offset ip-offset-value ]
Real source IP inspection is not configured for the TCP Options field, and the device does not obtain the real source IP address from the TCP Options field.
hex hex-vector: Specifies a case-sensitive hexadecimal string of 6 to 66 characters. Specify an even number of characters, and enclose the string with two vertical bars (|), for example |1234f5b6|.
offset offset-value: Specifies an offset in bytes after which the hexadecimal string lookup starts, in the range of 0 to 32. If you do not specify this option, the lookup starts from the beginning of the TCP Options field.
depth depth-value: Specifies the number of bytes to locate the hexadecimal string, in the range of 2 to 40. If you do not specify this option, the device searches the whole TCP Options field for the hexadecimal string.
ip-offset ip-offset-value: Specifies an offset in bytes after which the real source IP address is, in the range of 0 to 32. If you do not specify this option, the data after the hexadecimal string is the real source IP address.
To enable the device to locate the real source IP address in the TCP Option field, you must first define a hexadecimal string. If no hexadecimal string is found, the device will stop searching the TCP Options field for the real IP address.
# Configure the device to search bytes 3 to 12 for the hexadecimal string |0102| in the TCP Options field, and define that the real source IP address is 2 bytes away from the hexadecimal string.
[Sysname] inspect real-ip detect-field tcp-option hex |0102| offset 2 depth 10 ip-offset 2
Use inspect real-ip detect-field xff to configure real source IP address inspection for the X-Forwarded-For field.
Use undo inspect real-ip detect-field xff to restore the default.
inspect real-ip detect-field xff { head | tail [ number ] }
The rightmost IP address in the X-Forwarded-For field is the real source IP address.
head: Specifies the first IP address in the X-Forwarded-For field as the real source IP address.
tail: Specifies the last IP address in the X-Forwarded-For field as the real source IP address.
number: Extracts the last number addresses in the X-Forwarded-For field. The value range for this argument is 2 to 10. If you do not specify this argument, the last IP address in the X-Forwarded-For field is extracted.
When a client connects to a Web server through an HTTP proxy, the HTTP header might contain the X-Forwarded-For field that carries multiple IP addresses. The standard syntax of the X-Forwarded-For field is <client>, <proxy1>, <proxy2>,…<proxyn>. If a request goes through multiple proxies, the IP addresses of each successive proxy are listed. The rightmost IP address is the IP address of the most recent proxy and the leftmost IP address is the IP address of the originating client.
You can specify the number argument to extract multiple IP addresses for proxy analysis for clients.
# Specify the leftmost IP address in the X-Forwarded-For field as the real source IP address.
[Sysname] inspect real-ip detect-field xff head
inspect real-ip enable
Use inspect real-ip enable to enable real source IP inspection.
Use undo inspect real-ip enable to disable real source IP inspection.
Real source IP inspection is disabled.
When a client connects to a Web server through HTTP proxies, the source IP address of the request packet will change. To identify the source IP attacks accurately, you can enable this feature to obtain the real source IP address from the corresponding fields in the request.
# Enable real source IP inspection.
[Sysname] inspect real-ip enable
Use inspect real-ip extraction mode to specify the extraction mode for real source IP inspection.
Use undo inspect real-ip extraction mode to restore the default.
inspect real-ip extraction mode { cdn-src-ip-only | priority | tcp-option-only | x-real-ip-only | xff-only }
The extraction mode for real source IP inspection is xff-only.
cdn-src-ip-only: Extracts the IP address only in the Cdn-Src-IP field as the real source IP address.
priority: Extracts the IP addresses in the Cdn-Src-IP, TCP-Option, X-Real-IP, and X-Forwarded-For fields and uses the IP address in the field with the highest priority as the real source IP address.
tcp-option-only: Extracts the IP address only in the TCP-Option field as the real source IP address.
x-real-ip-only: Extracts the IP address only in the X-Real-IP field as the real source IP address.
xff-only: Extracts the IP address only in the X-Forwarded-For field as the real source IP address.
You can configure one of the following extraction modes for real source IP inspection:
· Extract from a single field—If you know from which filed to extract the real source IP address, you can configure extracting the real source IP address from that field (XXX-only mode).
· Extract based on field priorities—If you do not know from which filed to extract the real source IP address, use this mode. This mode allows the device to extract the real source IP address of the client by inspecting multiple fields in the packets in priority order. The device uses the IP address extracted from the field with the highest priority as the final real source IP address. You can adjust the priority of each field as needed.
# Specify x-real-ip-only as the extraction mode for real source IP inspection.
[Sysname] inspect real-ip extraction mode x-real-ip-only
inspect real-ip reuse enable
Use inspect real-ip reuse enable to enable real source IP reuse.
Use undo inspect real-ip reuse enable to disable real source IP reuse.
Real source IP reuse is disabled.
If a session has multiple requests, the device extracts a real source IP address from each request and records the extraction result. By default, if the device fails to extract a real source IP address from a request, it considers that the real source IP address is empty in the request. In some proxy scenarios, a proxy server carries the real source IP address only in the first HTTP request of a session. In this case, the device can extract the real source IP address only in the first HTTP request, and therefore the IPS whitelist service is affected. To solve this problem, you can execute this command. The device will use the real source IP address extracted from the first request for the subsequent requests to successfully match the IPS whitelist.
# Enable real source IP reuse.
[Sysname] inspect real-ip reuse enable
Use inspect record-filename nfs maximum to set the maximum number of NFS file names recorded.
Use undo inspect record-filename nfs maximum to restore the default.
inspect record-filename nfs maximum max-number
The maximum number of NFS file names recorded is calculated according to the actual memory size of the device.
max-number: Specifies the maximum number of NFS file names recorded, in the range of 0 to 4294967295. The value 0 indicates that the number of NFS file names recorded is not limited.
The DPI engine records file names during file detection for users to obtain file information in logs. The record process occupies memory resources. The more files detected, the more memory resources occupied. In an environment using NFS to transfer a large number of files, Execute this command to limit the memory resources consumed by recording file names.
In scenarios requiring high performance, you can set a small limit to reduce memory consumption. In scenarios not requiring high performance, you can set a great limit to enable users to obtain more file information.
# Set the maximum number of NFS file names recorded to 110000.
[Sysname] inspect record-filename nfs maximum 110000
Use inspect redirect parameter-profile to create a redirect parameter profile and enter its view, or enter the view of an existing redirect parameter profile.
Use undo inspect redirect parameter-profile to delete a redirect parameter profile.
inspect redirect parameter-profile parameter-name
undo inspect redirect parameter-profile parameter-name
No redirect parameter profiles exist.
parameter-name: Specifies a redirect parameter profile name, a case-insensitive string of 1 to 63 characters.
In redirect parameter profile view, you can set parameters for the redirect action, such as the URL to which packets are redirected.
# Create a redirect parameter profile named r1 and enter its view.
[Sysname] inspect redirect parameter-profile r1
[Sysname-inspect-redirect-r1]
Use inspect signature auto-update proxy to specify the proxy server used by DPI services for online signature update.
Use undo inspect signature auto-update proxy to restore the default.
inspect signature auto-update proxy { domain domain-name | ip ip-address } [ port port-number ] [ user user-name password { cipher | simple } string ]
The proxy server used by DPI services for online signature update is not specified.
domain domain-name: Specifies a proxy server by its domain name, a case-insensitive string of 3 to 63 characters.
ip ip-address: Specifies a proxy server by its IPv4 address.
port port-number: Specifies the port number used by the proxy server. The value range is 1 to 65535, and the default is 80.
user user-name: Specifies the username used to log in to the proxy server. The username is a case-insensitive string of 1 to 31 characters.
password: Specifies the password used to log in to the proxy server.
simple: Specifies a password in plaintext form. For security purposes, the password in plaintext form will be stored in encrypted form.
string: Specifies the password string. Its plaintext form is a case-sensitive string of 1 to 31 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
The device must access the company's website for online signature update of DPI services such as URL filtering. If direct connectivity is not available, the device can access the company's website through the specified proxy server. For more information about online signature update, see DPI Configuration Guide.
# Specify server http://www.abc.com/ on port 8888 as the proxy server and set the login username and password to admin.
[Sysname] inspect signature auto-update proxy domain www.abc.com port 8888 user admin password simple admin
Use inspect signature auto-update source to specify the source address for the request packet for online DPI service signature update.
Use undo inspect signature auto-update source to restore the default.
inspect signature auto-update source { ip | ipv6 } { ip-address | interface interface-type interface-number }
The source address of the request packet is the IP address of the outgoing interface in the matching route.
ip ip-address: Specifies the source IPv4 address.
ipv6 ip-address: Specifies the source IPv6 address.
interface interface-type interface-number: Uses the primary IPv4 address or the lowest IPv6 address of the interface as the source IP address.
You can execute this command to specify the source IP address for the request packet sent from the device to the library server for online DPI service signature update. For example, if the packet sent by the device must be NATed, you must specify a source IP address that matches the NAT rule. If the packet traverses an independent NAT device, the specified source IP address must be able to reach the NAT device.
If you also specify a VPN instance by using the inspect signature auto-update vpn-instance command, make sure the specified VPN instance is the VPN instance to which the source address belongs.
# Specify 1.1.1.1 as the source address for the request packet for online DPI service signature update.
[Sysname] inspect signature auto-update source ip 1.1.1.1
Use inspect signature auto-update vpn-instance to specify a VPN instance for online DPI service signature update.
Use undo inspect signature auto-update vpn-instance to restore the default.
inspect signature auto-update vpn-instance vpn-instance-name
The VPN instance used by DPI services for online signature update is not specified.
vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters.
The device must access the company's website for online signature update of DPI services. If the device accesses the company's website through a VPN instance, perform this task to avoid update failures.
If you also specify the source address by using the inspect signature auto-update source command, make sure the specified VPN instance is the VPN instance to which the source address belongs.
# Specify a VPN instance for online DPI service signature update.
[Sysname] inspect signature auto-update vpn-instance vpn1
inspect smb-reassemble enable
Use inspect smb-reassemble enable to enable SMB protocol packet reassembly.
Use undo inspect smb-reassemble enable to disable SMB protocol packet reassembly.
SMB protocol packet reassembly is disabled.
A large number of out-of-order packets of the SMB protocol might cause the DPI engine to fail to detect this protocol. This command can improve the accuracy of the DPI engines to detect SMB protocol packets.
When the device receives out-of-order SMB packets, it temporarily saves these packets and subsequent packets from the same flow to the buffer for packet reassembly. After being reassembled, the packets are forwarded for further processing.
# Enable SMB protocol packet reassembly.
[Sysname] inspect smb-reassemble enable
Use inspect source-port-identify enable to enable source port-based application identification.
Use undo inspect source-port-identify enable to disable source port-based application identification.
Source port-based application identification is disabled.
You can use this feature to identify traffic of applications that use fixed source ports when the following conditions are true:
· The types of traffic transmitted over networks are relatively unvaried and use fixed source ports.
· Destination port-based application identification or signature-based traffic content identification is not supported.
The application identification results produced by this feature might not be accurate. Configure this feature according to your live network as a best practice.
# Enable source port-based application identification.
<sysname> system-view
[sysname] inspect source-port-identify enable
Use inspect stream-fixed-length to set the maximum length for stream inspection.
Use undo inspect stream-fixed-length to restore the default.
inspect stream-fixed-length { audio-video | dns | email | ftp | http | https | imaps | nfs | pop3s | rtmp | sip | smb | smtps | telnet | tftp } * length
The maximum length is 64 Kilobytes for FTP, HTTP, NFS, SMB, SMTP, POP3, and IMAP protocols (including SMTP, POP3, and IMAP). For audio/video applications and DNS, HTTPS, IMAPS, POP3S, RTMP, SIP, SMTPS, Telnet, and TFTP protocols, the length for stream inspection is not limited.
audio-video: Specifies audio/video applications.
email: Specifies email protocols, including SMTP, POP3 and IMAP.
imaps: Specifies the IMAPS protocol.
pop3s: Specifies the POP3S protocol.
smtps: Specifies the SMTPS protocol.
length: Specifies the fixed length in the range of 1 to 2048 Kilobytes.
The larger the inspection length value, the lower the device throughput, and the higher the packet inspection accuracy.
# Set the maximum length to 35 Kilobytes for inspecting each FTP stream and 40 Kilobytes for inspecting each HTTP stream.
[Sysname] inspect stream-fixed-length ftp 35 http 40
Use inspect stream-fixed-length disable to disable stream maximum length inspection.
Use undo inspect stream-fixed-length disable to enable stream maximum length inspection.
The stream maximum length inspection feature is enabled.
The stream maximum length inspection feature enables the DPI engine to inspect only a specified stream length for a protocol or an audio/video application instead of the whole packet data in a stream.
Disable this feature if your network requires high packet inspection accuracy.
# Disable stream maximum length inspection.
[Sysname] inspect stream-fixed-length disable
inspect tcp-reassemble enable
Use inspect tcp-reassemble enable to enable the TCP segment reassembly feature.
Use undo inspect tcp-reassemble enable to disable the TCP segment reassembly feature.
The TCP segment reassembly feature is disabled.
DPI engine inspection might fail if TCP segments arrive at the engine out of order. For example, the DPI engine searches for the keywords this is a secret. If the TCP segment containing a secret arrives before the one containing this is, the inspection fails.
The TCP segment reassembly feature enables the device to cache out-of-order TCP segments of the same TCP flow and reassembles the segments before submitting them to the DPI engine for inspection. This helps improve the DPI engine inspection accuracy.
The segment reassembly fails due to missing segments when the number of cached TCP segments of a flow reaches the limit. In this case, the device submits the cached segments without reassembling them and all subsequent segments of the flow to the DPI engine. This helps reduces degradation of the device performance.
# Enable the TCP segment reassembly feature.
[Sysname] inspect tcp-reassemble enable
inspect tcp-reassemble max-segment
Use inspect tcp-reassemble max-segment to set the maximum number of TCP segments that can be cached per TCP flow.
Use undo inspect tcp-reassemble max-segment to restore the default.
inspect tcp-reassemble max-segment max-number
A maximum of 10 TCP segments can be cached for reassembly per TCP flow.
max-number: Specifies the maximum number in the range of 10 to 50.
Set the limit for the number of TCP segments that can be cached per flow according to your network requirements. The higher the limit, the higher the inspection accuracy, and the lower the device performance.
This command takes effect only when the TCP segment reassembly feature is enabled.
# Allow the device to cache a maximum of 20 TCP segments for each TCP flow.
[Sysname] inspect tcp-reassemble max-segment 20
inspect uncompress maximum
Use inspect uncompress maximum to set the maximum number of file decompression operations.
Use undo inspect uncompress maximum to restore the default.
inspect uncompress maximum max-number
The maximum number of file decompression operations is calculated according to the actual memory size of the device.
max-number: Specifies the maximum number of file decompression operations, in the range of 0 to 4294967295. The value 0 indicates that the number of file decompression operations is not limited.
The DPI engine consumes memory resources each time it performs a file decompression operation. A large number of file decompression operations might consume a large number of memory resources. Execute this command to limit the memory resources consumed by file decompression operations.
This command is supported only on the default MDC. For more information about MDCs, see Virtual Technologies Configuration Guide.
# Set the maximum number of file decompression operations to 120000.
[Sysname] inspect uncompress maximum 120000
Use inspect url-filter warning parameter-profile to create a warning parameter profile for URL filtering and enter its view, or enter the view of an existing warning parameter profile for URL filtering.
Use undo inspect url-filter warning parameter-profile to delete a warning parameter profile for URL filtering.
inspect url-filter warning parameter-profile profile-name
undo inspect url-filter warning parameter-profile profile-name
No warning parameter profiles exist.
profile-name: Specifies a warning parameter profile name, a case-insensitive string of 1 to 63 characters. Valid characters are letters, digits, underscores (_).
After you create a warning parameter profile for URL filtering, you can import a user-defined alarm message from a file.
# Create a warning parameter profile for URL filtering named c1 and enter its view.
[Sysname] inspect url-filter warning parameter-profile c1
[Sysname-inspect-url-filter-warning-c1]
import warning-file
inspect waf http-log-details enable
Use inspect waf http-log-details enable to enable WAF logging to record HTTP packet details.
Use undo inspect waf http-log-details enable to disable this feature.
HTTP packet details are not recorded.
The feature enables the device to record more fields of HTTP packets in WAF logs.
· For HTTP requests, when this feature is disabled, the device records only the request line and request method. When this feature is enabled, the device records all fields.
· For HTTP responses, when this feature is disabled, the device does not record any fields. When this feature is enabled, the device records the status line information.
This feature does not take effect on WAF logs generated before it is enabled.
To save system resources, enable this feature only when necessary.
# Enable WAF logging to record HTTP packet details.
[Sysname] inspect waf http-log-details enable
inspect warning parameter-profile
Use inspect warning parameter-profile to create an anti-virus warning parameter profile and enter its view, or enter the view of an existing anti-virus warning parameter profile.
Use undo inspect warning parameter-profile to delete an anti-virus warning parameter profile.
inspect warning parameter-profile profile-name
undo inspect warning parameter-profile profile-name
No anti-virus warning parameter profiles exist.
profile-name: Specifies an anti-virus warning parameter profile name, a case-insensitive string of 1 to 63 characters. Valid characters are letters, digits, underscores (_).
After you create an anti-virus warning parameter profile, you can import a user-defined alarm message from a file.
# Create an anti-virus warning parameter profile named w1 and enter its view.
[Sysname] inspect warning parameter-profile w1
[Sysname-inspect-warning-w1]
import block warning-file
reset block warning-file
language
Use language to set the language for log emails.
Use undo language to restore the default.
language { chinese | english }
undo language
Log emails are are sent in Chinese.
Email parameter profile view
Only IPS, anti-virus, and WAF support Chinese log emails, and only the following fields in a log email support Chinese:
· IPS; application, attack name, attack category, and attack subcategory.
· Anti-virus: application.
· WAF: application, signature name, attack category, attack subcategory, and source location.
# Set the language for log emails to English.
[Sysname-inspect-email-test] language english
log
Use log to specify the log storage method.
Use undo log to cancel the specified log storage method.
log { email | syslog }
undo log { email | syslog }
Logs are exported to the information center.
Logging parameter profile view
email: Emails the logs to a receiver.
syslog: Exports the logs to the information center.
# Configure the device to export logs to the information center in logging parameter profile log1.
[Sysname-inspect-logging-log1] log syslog
log language
Use log language to set the language for IPS log output to Chinese.
Use undo log language to restore the default.
log language chinese
undo log language chinese
IPS logs are output in English.
After you execute this command, only the attack name field of the IPS logs supports displaying in Chinese. For more information about IPS logs, see "IPS commands."
# Set the language for IPS log output to Chinese.
[Sysname-inspect-log-para-log1] log language chinese
password
Use password to specify the password for logging in to the email server.
Use undo password to restore the default.
undo password
No password is specified for logging in to the email server.
pwd-string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
# Specify abc123 as the plaintext password for logging in to the email server.
[Sysname] inspect email parameter-profile c1
[Sysname-inspect-email-c1] password simple abc123
authentication enable
receiver
Use receiver to specify the email receiver address.
Use undo receiver to restore the default.
receiver address-string
undo receiver
No email receiver address is specified.
address-string: Specifies the address of the email receiver, a case-sensitive string of 3 to 502 characters.
You can specify multiple semicolon-separated email receiver addresses in one command.
# Specify the email receiver addresses [email protected] and [email protected].
[Sysname-inspect-email-c1] receiver [email protected];[email protected]
redirect-url
Use redirect-url to specify the URL to which packets are redirected.
Use undo redirect-url to restore the default.
redirect-url url-string
undo redirect-url
No URL is specified for packet redirecting.
Redirect parameter profile view
url-string: Specifies the URL, a case-sensitive string of 9 to 63 characters. The URL must start with http:// or https://, for example, http://www.baidu.com.
After you specify a URL, matching packets will be redirected to the webpage that the URL identifies.
# Specify http://www.abc.com/upload as the URL for packet redirecting.
[Sysname-inspect-redirect-r1] redirect-url http://www.abc.com/upload
reset inspect smb-breakpoint-resume table
Use reset inspect smb-breakpoint-resume table to clear the breakpoint resumption table for the SMB protocol.
In standalone mode:
reset inspect smb-breakpoint-resume table { ipv4 | ipv6 }
In IRF mode:
reset inspect smb-breakpoint-resume table { ipv4 | ipv6 } [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears the breakpoint resumption table for all member devices. (In IRF mode.)
# Clear the breakpoint resumption table for the SMB protocol.
<Sysname> reset inspect smb-breakpoint-resume table ipv4
display inspect smb-breakpoint-resume table
reset warning-file
Use reset warning-file to restore the default alarm message for URL filtering.
reset warning-file
This command allows you to clear the user-defined alarm message and restore the default message for URL filtering.
# Restore the default alarm message in the warning parameter profile for URL filtering c1.
[Sysname-inspect-url-filter-warning-c1] reset warning-file
import warning-file
secure-authentication enable
Use secure-authentication enable to enable the secure password transmission feature.
Use undo secure-authentication enable to disable the secure password transmission feature.
The secure password transmission feature is disabled.
After the secure password transmission feature is enabled, a security channel is established between the device and the email server to transmit the password for email server login.
# Enable the secure password transmission feature.
[Sysname-inspect-email-c1] secure-authentication enable
sender
Use sender to specify the email sender address.
Use undo sender to restore the default.
sender address-string
undo sender
No email sender address is specified.
address-string: Specifies the address of the email sender, a case-sensitive string of 3 to 63 characters.
The email sender address is the source address that the device uses to send emails to destinations.
# Specify the email sender address [email protected].
[Sysname-inspect-email-c1] sender [email protected]
username
Use username to specify the username for logging in to the email server.
Use undo username to restore the default.
username name-string
undo username
No username is specified for logging in to the email server.
name-string: Specifies the username, a case-sensitive string of 1 to 63 characters.
If you execute this command multiple times for the same email parameter profile, the most recent configuration takes effect.
# Specify han as the username for logging in to the email server.
[Sysname-inspect-email-c1] username han
