- 10-MPLS Command Reference
- 01-Basic MPLS commands
- 02-Static LSP commands
- 03-LDP commands
- 04-MPLS TE commands
- 05-Static CRLSP commands
- 06-RSVP commands
- 07-Tunnel policy commands
- 08-MPLS L3VPN commands
- 09-MPLS L2VPN commands
- 10-VPLS commands
- 11-L2VPN access to L3VPN or IP backbone commands
- 12-MPLS OAM commands
- 13-MPLS protection switching commands
- 14-MCE commands
| 05-Static CRLSP commands | 92.12 KB |
The following compatibility matrixes show the support of hardware platforms for static CRLSP:
Hardware |
Static CRLSP compatibility |
MSR610 |
No |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G, MSR1004S-5G-CN |
Yes |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR2630-G-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
Yes |
MSR3600-28-G-X1-DP, MSR3600-51-G-X1-DP |
Yes |
Yes |
MSR-iMC |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
MSR3620-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2600-15-X1-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
display mpls static-cr-lsp
Use display mpls static-cr-lsp to display information about static CRLSPs.
display mpls static-cr-lsp [ lsp-name lsp-name ] [ verbose ]
lsp-name lsp-name: Displays information about the static CRLSP specified by its name, a case-sensitive string of 1 to 15 characters. If you do not specify a static CRLSP, this command displays information about all static CRLSPs.
verbose: Displays detailed information about static CRLSPs. If you do not specify this keyword, the command displays brief information about static CRLSPs.
# Display brief information about static CRLSPs.
<Sysname> display mpls static-cr-lsp
Name LSR Type In/Out Label Out Interface State
static-cr-lsp-1 Ingress Null/20 GE1/0/1 Up
Name |
Name of the static CRLSP. |
LSR Type |
LSR type of the local node on the static CRLSP: Ingress, Transit, or Egress. |
In/Out Label |
Incoming label/outgoing label. |
Out Interface |
Output interface. |
State |
Current state of the static CRLSP: · Down—The static CRLSP is not available. · Up—The static CRLSP is available. · Idle—The incoming label of the static CRLSP is not available. · Dup—The incoming label of the static CRLSP is being used by a static LSP or a static PW. |
# Display detailed information about static CRLSPs.
<Sysname> display mpls static-cr-lsp verbose
Type : Ingress
In-Label : -
Out-Label : 60
Out-Interface : GE1/0/1
Nexthop : 20.1.1.2
Class Type : CT0
Bandwidth : 0 kbps
State : Up
Name |
Type |
In-Label |
Incoming label. |
Out-Label |
Outgoing label. |
Out-Interface |
Output interface. |
Nexthop |
Next hop address. |
Class Type |
Class type of the static CRLSP: CT0, CT1, CT2, or CT3. |
Bandwidth |
Bandwidth required by the static CRLSP, in kbps. |
State |
Current state of the static CRLSP: · Down—The static CRLSP is not available. · Up—The static CRLSP is available. · Idle—The incoming label of the static CRLSP is not available. · Duplicate—The incoming label of the static CRLSP is being used by a static LSP or a static PW. |
static-cr-lsp egress
static-cr-lsp ingress
static-cr-lsp transit
Use static-cr-lsp egress to configure the egress node of a static CRLSP.
Use undo static-cr-lsp egress to delete the egress node configuration of a static CRLSP.
static-cr-lsp egress lsp-name in-label in-label-value
undo static-cr-lsp egress lsp-name
No static CRLSPs exist.
lsp-name: Specifies a name for the static CRLSP, a case-sensitive string of 1 to 15 characters.
in-label in-label-value: Specifies an incoming label. The value range for the incoming label is 16 to 10240.
A static CRLSP must have a different incoming label than an existing static LSP or static PW. If they are the same, the static CRLSP is not available, even if you change the incoming label of the static LSP or the static PW. To make the static CRLSP available, delete the static CRLSP, and reconfigure it with an unused incoming label.
# On the egress node, configure a static CRLSP with name static-te-1 and incoming label 233.
[Sysname] static-cr-lsp egress static-te-1 in-label 233
Use static-cr-lsp ingress to configure the ingress node of a static CRLSP.
Use undo static-cr-lsp ingress to delete the ingress node configuration of a static CRLSP.
static-cr-lsp ingress lsp-name { nexthop ip-address | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp ingress lsp-name
nexthop ip-address: Specifies the next hop IP address. The address cannot be a public IP address on the local device.
outgoing-interface interface-type interface-number: Specifies an outgoing interface by its type and number. The specified interface must be a P2P interface.
out-label out-label-value: Specifies an outgoing label. The value range for the outgoing label is 0, 3, and 16 to 1048575.
bandwidth: Specifies the CT and required bandwidth for the static CRLSP. If you do not specify this keyword, the bandwidth required by the static CRLSP is 0 kbps. If you specify this keyword but do not specify a CT, the static CRLSP belongs to CT 0.
ct0: Specifies CT 0 for the static CRLSP.
ct1: Specifies CT 1 for the static CRLSP.
ct2: Specifies CT 2 for the static CRLSP.
ct3: Specifies CT 3 for the static CRLSP.
bandwidth-value: Specifies the bandwidth required by the static CRLSP, in the range of 1 to 4294967295 kbps. The default is 0 kbps.
CT 2 and CT 3 are valid only in IETF DS-TE mode. In prestandard DS-TE mode, CT 2 and CT 3 are invalid and the tunnel cannot be established.
If the specified outgoing interface is a tunnel interface, you must use the mpls te enable command to enable the MPLS TE capability on it for the static CRLSP to come up.
# Configure a static CRLSP on the ingress node: specify its name as static-te-2, next hop IP address as 202.55.25.33, outgoing label as 237, CT as CT 0, and required bandwidth as 20 kbps.
[Sysname] static-cr-lsp ingress static-te-2 nexthop 202.55.25.33 out-label 237 bandwidth ct0 20
Use static-cr-lsp transit to configure a transit node for a static CRLSP.
Use undo static-cr-lsp transit to delete the transit node configuration of a static CRLSP.
static-cr-lsp transit lsp-name in-label in-label-value { nexthop ip-address | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp transit lsp-name
# Configure a static CRLSP on the transit node: specify its name as static-te-3, incoming label as 123, next hop IP address as 1.1.1.1, outgoing label as 253, CT as CT 0, and required bandwidth as 20 kbps.
[Sysname] static-cr-lsp transit static-te-3 in-label 123 nexthop 1.1.1.1 out-label 253 bandwidth ct0 20
