| 09-Frame Relay commands | 449.24 KB |
fr compression iphc rtp-connections
fr compression iphc tcp-connections
ipv6 ind solicitation retrans-timer
Multilink Frame Relay commands
This feature is supported only on the following modules:
· CE3.
· CPOS.
· CT3.
· E1.
· E1-F.
· POS.
· SAE.
· T1.
· T1-F.
The following compatibility matrixes show the support of hardware platforms for Frame Relay:
Hardware |
Frame Relay compatibility |
MSR610 |
No |
No |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
No |
MSR1004S-5G, MSR1004S-5G-CN |
No |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL |
No |
Yes |
MSR2600-10-X1 |
Yes |
MSR2630-G-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
Yes |
Yes |
Yes |
MSR3600-28-G-X1-DP, MSR3600-51-G-X1-DP |
Yes |
Yes |
MSR-iMC |
Yes |
Yes |
MSR3610, MSR3620, MSR3620-DP, MSR3640, MSR3660 |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet, MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
MSR3620-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2600-15-X1-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
Basic Frame Relay commands
broadcast
Use broadcast to allow broadcast packets on a virtual circuit (VC).
Use undo broadcast to forbid broadcast packets on a VC.
broadcast
undo broadcast
Broadcast packets are forbidden on static VCs and allowed on dynamic VCs.
Frame Relay virtual circuit view
Configure this command if a static VC needs to allow broadcast or multicast packets.
When a VC allows broadcast packets, the broadcast or multicast packets on the Frame Relay interface of the VC are also transmitted on the VC.
# Allow broadcast packets on the VC identified by DLCI 200.
[Sysname] interface serial 2/1/0
[Sysname-Serial2/1/0] fr dlci 200
[Sysname-Serial2/1/0-fr-dlci-200] broadcast
display fr compression iphc
Use display fr compression iphc to display statistics for Frame Relay IPHC.
display fr compression iphc { rtp | tcp } [ interface interface-type interface-number [ dlci dlci-number ] ]
rtp: Displays statistics for RTP header compression.
tcp: Displays statistics for TCP header compression.
interface interface-type interface-number: Specifies an interface by its type and number. It can be a main interface or subinterface. If you specify a main interface, this command displays IPHC statistics for the main interface and its subinterfaces. If you specify a subinterface, this command displays IPHC statistics for the subinterface. If you do not specify an interface, this command displays IPHC statistics for all interfaces.
dlci dlci-number: Specifies a VC by its DLCI in the range of 16 to 1007.
· If you specify a main interface and a VC that is not on the main interface or any of its subinterfaces, this command does not display IPHC statistics for the VC.
· If you specify a subinterface and a VC that is not on the subinterface, this command does not display IPHC statistics for the VC.
· If you specify only an interface, this command displays IPHC statistics for all VCs on the interface.
Frame Relay IPHC statistics are displayed on a per-VC basis. An interface (main interface or subinterface) can have one or more VCs.
# Display RTP header compression statistics for the VC with DLCI 17 on Serial 2/1/0.
<Sysname> display fr compression iphc rtp interface serial 2/1/0 dlci 17
DLCI: 17, Serial2/1/0
Received:
Compressed/Error/Total: 0/0/0 packets
Sent:
Compressed/Total: 0/0 packets
Sent/Saved/Total: 0/0/0 bytes
Packet-based compression ratio: 0%
Byte-based compression ratio: 0%
Connections:
Rx/Tx: 16/16
Five-Minute-Miss: 0 (Misses/5Mins)
Max-Miss: 0
# Display TCP header compression statistics for Serial 2/1/0.
<Sysname> display fr compression iphc tcp interface serial 2/1/0
DLCI: 16, Serial2/1/0
Received:
Sent:
Connections:
Rx/Tx: 16/16
Max-Miss: 0
Received:
Sent:
Connections:
Rx/Tx: 16/16
Max-Miss: 0
Received: Compressed/Error/Total: 0/0/0 packets |
Statistics on received packets: · Compressed—Number of compressed packets. · Error—Number of error packets. · Total—Total number of packets. |
Sent: Compressed/Total: 0/0 packets Sent/Saved/Total: 0/0/0 bytes Packet-based compression ratio: 0% Byte-based compression ratio: 0% |
Statistics on sent packets: · Compressed—Number of compressed packets. · Total—Total number of packets. · Sent—Actual number of bytes sent. · Saved—Number of bytes reduced due to the compression. · Total—Number of bytes that need to be sent if no compression is performed. · Packet-based compression ratio—Ratio of compressed packets to the total number of packets (Compressed/Total x 100%). · Byte-based compression ratio—Ratio of saved bytes to the total number of bytes (Saved/Total x 100%). |
Connections: Rx/Tx Five-Minute-Miss: x (Misses/5Mins) Max-Miss: x |
Statistics on sent packets: · Rx—Maximum number of decompression connections when the device acts as the receiving end. · Tx—Maximum number of compression connections when the device acts as the transmitting end. · Five-Minute-Miss—Number of times an entry failed to be found over the most recent 5 minutes. · Max-Miss—Maximum number of times an entry failed to be found. |
fr compression iphc enable
reset fr compression iphc
display fr compression stac
Use display fr compression stac to display statistics for Frame Relay STAC compression.
display fr compression stac [ interface interface-type interface-number [ dlci dlci-number ] ]
interface interface-type interface-number: Specifies an interface by its type and number. It can be a main interface or subinterface. If you specify a main interface, this command displays STAC compression statistics for the main interface and its subinterfaces. If you specify a subinterface, this command displays STAC compression statistics for the subinterface. If you do not specify an interface, this command displays STAC compression statistics for all interfaces.
· If you specify a main interface and a VC that is not on the main interface or any of its subinterfaces, this command does not display STAC compression statistics for the VC.
· If you specify a subinterface and a VC that is not on the subinterface, this command does not display STAC compression statistics for the VC.
· If you specify only an interface, this command displays STAC compression statistics for all VCs on the interface.
Frame Relay STAC compression statistics are displayed on a per-VC basis. An interface (main interface or subinterface) can have one or more VCs.
# Display Frame Relay STAC compression statistics for all interfaces.
<Sysname> display fr compression stac
Serial2/1/0
DLCI: 22
Uncompressed bytes sent/received: 0/0
Compressed bytes sent/received: 0/0
1 min avg ratio output/input: 0.000/0.000
5 min avg ratio output/input: 0.000/0.000
Uncompressed bytes sent/received |
Number of sent/received bytes before compression. |
Compressed bytes sent/received |
Number of bytes sent/received after compression. |
1 min avg ratio output/input |
Average ratio of bytes after compression to bytes before compression for every second over the last 1 minute (sent/received). |
5 min avg ratio output/input |
Average ratio of bytes after compression to bytes before compression for every minute over the last 5 minutes (sent/received). |
display fr fragment
Use display fr fragment to display statistics for Frame Relay FRF.12 fragmentation.
display fr fragment [ interface interface-type interface-number [ dlci dlci-number ] ]
interface interface-type interface-number: Specifies an interface by its type and number. It can be a main interface or subinterface. If you specify a main interface, this command displays FRF.12 fragmentation statistics for the main interface and its subinterfaces. If you specify a subinterface, this command displays FRF.12 fragmentation statistics for the subinterface. If you do not specify an interface, this command displays FRF.12 fragmentation statistics for all interfaces.
· If you specify a main interface and a VC that is not on the main interface or any of its subinterfaces, this command does not display FRF.12 fragmentation statistics for the VC.
· If you specify a subinterface and a VC that is not on the subinterface, this command does not display FRF.12 fragmentation compression statistics for the VC.
· If you specify only an interface, this command displays FRF.12 fragmentation statistics for all VCs on the interface.
# Display Frame Relay FRF.12 fragmentation statistics for all interfaces.
<Sysname> display fr fragment
Interface Serial2/1/0:
DLCI Interface Type Size (byte) In/Out/Dropped
200 Serial2/1/0 FRF12(end-to-end) 80 0/0/0
# Display FRF.12 fragmentation statistics for the VC with DLCI 200 on Serial 2/1/0.
<Sysname> display fr fragment interface serial2/1/0 dlci 200
Type: FRF12(end-to-end)
Pre-fragment:
Output: 0 packets, 0 bytes
Fragmented:
Input: 0 packets, 0 bytes
Assembled:
Dropped:
Out-of-sequence packets: 0
Size (byte) |
Fragment size in bytes. |
In/Out/Dropped |
Numbers of fragments received/sent/dropped. |
Size |
Pre-fragment |
Number of packets to be fragmented. |
Fragmented |
Number of fragments. |
Assembled |
Number of fragments reassembled. |
Dropped |
Number of fragments dropped. |
Out-of-sequence packets |
Number of out-of-sequence fragments. |
Output: 0 packets, 0 bytes |
Number of packets or fragments sent, and number of bytes sent. |
Input: 0 packets, 0 bytes |
Number of fragments received, and number of bytes received. |
display fr inarp
Use display fr inarp to display statistics for Frame Relay InARP packets.
display fr inarp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. It can be a main interface or subinterface. If you specify a main interface, this command displays statistics for the main interface and its subinterfaces. If you specify a subinterface, this command displays statistics for the subinterface. If you do not specify an interface, this command displays statistics for all interfaces.
You can determine whether Frame Relay InARP is operating correctly based on the output from this command.
# Display statistics for Frame Relay InARP packets.
<Sysname> display fr inarp
Frame relay InARP statistics for interface Serial2/1/0 (DTE)
Recvd InARP request Sent InARP reply Sent InARP request Recvd InARP reply
0 0 1 1
Recvd InARP request |
Number of received InARP requests. |
Sent InARP reply |
Number of sent InARP replies. |
Sent InARP request |
Number of sent InARP requests. |
Recvd InARP reply |
Number of received InARP replies. |
fr inarp
display fr ipv6 map
Use display fr ipv6 map to display Frame Relay IPv6 address mapping.
display fr ipv6 map [ static | dynamic ] [ interface interface-type interface-number [ dlci dlci-number ] ]
static: Specifies static address mapping.
dynamic: Specifies dynamic address mapping.
interface interface-type interface-number: Specifies an interface by its type and number. It can be a main interface or subinterface. If you specify a main interface, this command displays IPv6 address mapping for the main interface and its subinterfaces. If you specify a subinterface, this command displays IPv6 address mapping for the subinterface. If you do not specify an interface, this command displays IPv6 address mapping for all interfaces.
· If you specify a main interface and a VC that is not on the main interface or any of its subinterfaces, this command does not display IPv6 address mapping for the VC.
· If you specify a subinterface and a VC that is not on the subinterface, this command does not display IPv6 address mapping for the VC.
· If you specify only an interface, this command displays IPv6 address mapping for all VCs on the interface.
If you do not specify the static or dynamic keyword, this command displays both static and dynamic address mapping.
# Display Frame Relay IPv6 address mapping.
<Sysname> display fr ipv6 map
Map statistics for interface Serial2/1/0 (DTE)
DLCI: 100 IPv6 IND: FE80::56FF:FE00:0 Interface: Serial2/1/0
Create time: 2014/10/11 09:57:28 Status: Active
Encapsulation: IETF Broadcast
DLCI: 100 IPv6 IND: 10::1 Interface: Serial2/1/0
DLCI: 100 IPv6: 10::3 Interface: Serial2/1/0
Table 5 Command output
Map Statistics for interface Serial2/1/0 (DTE) |
IPv6 address-to-DLCI maps for Serial 2/1/0 (a DTE interface). |
DLCI: 100 |
VC identified by the DLCI number. |
IPv6 IND 10::1 |
Address map established with the peer IPv6 address 10::1 through IND. If IND is absent, the address map is manually configured. |
Interface: Serial2/1/0 |
Interface where the VC was created. |
Create time: 2014/10/11 09:57:28 |
Time when the address map was created. |
Status: Active |
Status of the address map: Active or Inactive. |
Encapsulation: IETF |
Encapsulation type for the VC: IETF or Nonstandard. |
Broadcast |
Broadcast packets are allowed on the VC. |
display fr lmi
Use display fr lmi to display LMI information.
display fr lmi [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a main interface by its type and number. If you do not specify an interface, this command displays LMI information for all main interfaces.
The LMI protocol sends status enquiry messages and status messages for maintaining Frame Relay links. The output from the command helps you diagnose faults.
# Display LMI information for all interfaces.
<Sysname> display fr lmi
Frame relay LMI information for interface Serial2/1/0 (DTE, Q933)
T391DTE: 10 seconds, N391DTE: 6, N392DTE: 3, N393DTE: 4
Sent status enquiry: 96, Received status: 85
Status timeout: 3, Discarded messages: 3
Frame relay LMI information for interface Serial2/1/0 (DCE, Q933)
T392DCE: 15 seconds, N392DCE: 3, N393DCE: 4
Received status enquiry: 0, Sent status: 0
Status enquiry timeout: 0, Discarded messages: 0
Table 6 Command output
Frame relay LMI information for interface Serial2/1/0 (DTE, Q933) |
Serial 2/1/0 (a Frame Relay interface) is a DTE interface that complies with Q.933 Annex A. |
T391DTE: 10 seconds, N391DTE: 6, N392DTE: 3, N393DTE: 4 |
DTE-side T391 timer (in seconds) configured by using the timer-hold command, N391 counter, N392 counter, and N393 counter. |
Sent status enquiry: 96, Received status: 85 |
Number of status enquiry messages sent out of the interface and number of status messages received on the interface. |
Status timeout: 3, Discarded messages: 3 |
Number of status messages that timed out and number of discarded messages. |
Frame relay LMI information for interface Serial2/1/0 (DCE, Q933) |
Serial 2/1/0 (a Frame Relay interface) is a DCE interface that complies with Q.933 Annex A. |
T392DCE: 15 seconds, N392DCE: 3, N393DCE: 4 |
DCE-side T392, N392, and N393 values. |
Received status enquiry: 0, Sent status: 0 |
Number of status enquiry messages received on the interface and number of status messages sent out of the interface. |
Status enquiry timeout: 0, Discarded messages : 0 |
Number of status enquiry messages that timed out and number of discarded messages. |
fr lmi n391dte
fr lmi n392dce
fr lmi n392dte
fr lmi n393dce
fr lmi n393dte
fr lmi t392dce
fr lmi type
timer-hold
display fr map
Use display fr map to display Frame Relay address mapping.
display fr map [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. It can be a main or subinterface. If you specify a main interface, this command displays information for the main interface and its subinterfaces. If you specify a subinterface, this command displays information for the subinterface. If you do not specify an interface, this command displays information for all interfaces.
Based on the output from this command, you can determine whether the static address-to-DLCI maps are correct and whether dynamic address mapping is operating correctly.
# Display Frame Relay address mapping for all interfaces.
<Sysname> display fr map
Map information for interface Serial2/1/0 (DTE)
DLCI: 100, IP InARP 100.100.1.1, Serial2/1/0
Creation time: 2012/10/21 14:48:44, Status: Active
DLCI: 200, IP InARP 100.100.1.1, Serial2/1/0
Creation time: 2012/10/21 14:34:42, Status: Active
DLCI: 300, IP 1.1.1.1, Serial2/1/0
Creation time: 2012/10/21 15:03:35, Status: Active
Table 7 Command output
Map information for interface Serial2/1/0 (DTE) |
Frame Relay address mapping for DTE interface Serial 2/1/0. |
DLCI: 100, IP InARP 100.100.1.1, Serial2/1/0 |
The VC identified by DLCI 100 is mapped to the peer IP address 100.100.1.1 through InARP. The VC is configured on the interface Serial 2/1/0. If the InARP keyword is not displayed, the address-to-DLCI map is a static map manually configured. |
Creation time: 2012/10/21 14:48:44 |
Time when the map was created. |
Status: Active |
State of the address-to-DLCI map: · Active. · Inactive. The state of an address-to-DLCI map is the same as the state of the mapped VC. |
fr inarp
fr map ip
display fr pvc
Use display fr pvc to display information on Frame Relay PVCs and statistics about sent and received data.
display fr pvc [ interface interface-type interface-number ] [ dlci dlci-number ]
interface interface-type interface-number: Specifies an interface by its type and number. It can be a main interface or subinterface. If you specify a main interface, this command displays information for the main interface and its subinterfaces. If you specify a subinterface, this command displays information for the subinterface. If you do not specify an interface, this command displays information for all interfaces.
dlci dlci-number: Specifies a PVC by its DLCI in the range of 16 to 1007. If you specify a PVC, this command displays detailed information about the PVC. If you do not specify a PVC, this command displays brief information about PVCs. In addition to the brief information, the detailed information includes Frame Relay traffic management information.
# Display brief information on all Frame Relay PVCs and statistics about sent and received data.
<Sysname> display fr pvc
PVC information for interface Serial2/1/0 (DTE, physically up)
DLCI: 100 Type: Dynamic Interface: Serial2/1/0
Creation time: 2012/04/01 23:55:39 Status: Active
Input: 0 packets, 0 bytes, 0 dropped
Output: 0 packets, 0 bytes, 0 dropped
DLCI: 102 Type: Static Interface: Serial2/1/0.1
Encapsulation: Nonstandard
Creation time: 2012/04/01 23:56:14 Status: Active
# Display detailed information on the PVC identified by DLCI 100 and statistics about data sent and received on the PVC.
<Sysname> display fr pvc dlci 100
DE list: 3 DE set packets: 0
Traffic policing: Active
CIR ALLOW: 56000 bps CBS: 56000 bits EBS: 56000 bits
Input: 0 packets, 0 bytes, 0 dropped, 0 set DE packets
Traffic shaping: Inactive
CIR ALLOW: 56000 bps CIR: 56000 bps
Current CIR: 56000 bps
Output: 0 packets, 0 bytes, 0 dropped packets
Delayed: 0 packets, 0 bytes
Output queue: (Urgent queuing: Size/Length/Discards) 0/100/0
Output queue: (Protocol queuing: Size/Length/Discards) 0/500/0
Output queue: (FIFO queuing: Size/Length/Discards) 0/75/0
Table 8 Command output
PVC information for interface Serial2/1/0 (DTE, physically up) |
Information about PVCs on the Frame Relay interface Serial 2/1/0. The interface is a DTE interface and is physically up. The interface types include: · DTE. · DCE. · NNI. The physical states include: · physically up. · physically down. |
DLCI: 100, Type: Dynamic, Interface: Serial2/1/0 |
The type of the PVC identified by DLCI 100 is Dynamic. It is created on Serial 2/1/0. The PVC types include: · Dynamic—The PVC is dynamically learned through LMI. · Static—The PVC is statically configured by using the fr map ip or fr dlci command. |
Encapsulation: IETF Broadcast |
The encapsulation type of the PVC is IETF. The PVC allows broadcast packets. The encapsulation types include: · IETF. · Nonstandard. |
Creation time: 2012/1/04/01 23:55:39, Status: Active |
Time when the PVC was created and the state of the PVC, which can be Active or Inactive. |
Input: 0 packets, 0 bytes, 0 dropped |
Number of received packets, number of received bytes, and number of dropped packets. |
Output: 0 packets, 0 bytes, 0 dropped |
Number of sent packets, number of sent bytes, and number of dropped packets. |
DE list: 3 DE set packets: 0 |
DE list number and number of packets with the DE bit set. |
Traffic policing: Inactive |
Status of traffic policing: · Active. · Inactive. |
Input : 0 packets, 0 bytes, 0 dropped, 0 set DE packets |
Number of received packets, number of received bytes, number of dropped packets, and number of packets with the DE bit set. |
Traffic shaping: Inactive |
Status of traffic shaping: · Active. · Inactive. |
Output: 0 packets, 0 bytes, 0 dropped packets |
Number of sent packets, number of sent bytes, and number of dropped packets after traffic shaping is enabled. |
Delayed: 0 packets, 0 bytes |
Number of outgoing packets delayed and number of outgoing bytes delayed. |
broadcast
fr dlci
fr encapsulation
fr interface-type
fr map ip
reset fr pvc
Use fr compression iphc enable to enable Frame Relay IPHC on a Frame Relay interface or VC.
Use undo fr compression iphc enable to disable Frame Relay IPHC on a Frame Relay interface or VC.
fr compression iphc enable [ nonstandard ]
Frame Relay IPHC is disabled.
Interface view
nonstandard: Specifies the nonstandard encapsulation type. Specify this keyword when the device is interoperating with third-party devices. This keyword supports RTP header compression (but not TCP header compression).
IPHC includes the following types:
· RTP header compression—Compresses the IP/UDP/RTP header in packets.
· TCP header compression—Compresses the TCP/IP header in packets.
Enabling/disabling IPHC enables/disables both RTP header compression and TCP header compression.
To make IPHC take effect on a link, you must enable Frame Relay IPHC on both ends of the link.
You can configure Frame Relay IPHC on either an interface or VC. The setting on an interface takes effect on all VCs of the interface. The setting on a VC takes effect only on the VC. When the interface setting is different from the VC setting, the VC setting takes effect.
When the encapsulation type is IETF, IPHC negotiation is triggered after you enable IPHC. IPHC takes effect only if IPHC negotiation succeeds.
When the encapsulation type is nonstandard, IPHC takes effect without negotiation. In this case, the encapsulation type must be nonstandard on both ends of the link.
Compression does not stop after you disable IPHC. To stop compression on an interface or PVC, you must also execute the shutdown/undo shutdown command sequence on the interface or PVC.
# Enable Frame Relay IPHC on Serial 2/1/0.
[Sysname-Serial2/1/0] fr compression iphc enable
# Enable Frame Relay IPHC on the VC with DLCI 100 on Serial 2/1/0.
[Sysname-Serial2/1/0] fr dlci 100
[Sysname-fr-dlci-Serial2/1/0-100] fr compression iphc enable
fr encapsulation
Use fr compression iphc rtp-connections to set the maximum number of RTP header-compression connections allowed on a Frame Relay interface or VC.
Use undo fr compression iphc rtp-connections to restore the default.
fr compression iphc rtp-connections number
The maximum number of RTP header-compression connections is 16.
Interface view
number: Specifies the maximum number of RTP header-compression connections allowed, in the range of 3 to 1000. When this argument is less than or equal to 256, packets are compressed in COMPRESSED_RTP_8 format. When this argument is greater than 256, packets are compressed in COMPRESSED_RTP_16 format.
RTP is a connection-oriented protocol and can carry many RTP connections on one link. The compression algorithm maintains information for each RTP header-compression connection. To save memory resources, you can use this command to specify the maximum number of RTP header-compression connections allowed. For example, if you specify the maximum number as 3, packets of the fourth RTP connection are not compressed.
The maximum number of RTP header-compression connections configured on an interface is inherited by all VCs of the interface. If you set a different maximum number on a VC of the interface, the setting on the VC takes effect.
You can configure this command on an interface or PVC only after you enable IPHC on the interface or PVC. The configuration takes effect on an interface or PVC after you execute the shutdown/undo shutdown command sequence on the interface or PVC. After you disable IPHC, the configuration is deleted.
# Set the maximum number of RTP header-compression connections to 200 for Serial 2/1/0.
[Sysname-Serial2/1/0] fr compression iphc rtp-connections 200
# Set the maximum number of RTP header-compression connections to 200 for the VC with DLCI 100 on Serial 2/1/0.
[Sysname-fr-dlci-Serial2/1/0-100] fr compression iphc rtp-connections 200
Use fr compression iphc tcp-connections to set the maximum number of TCP header-compression connections allowed on a Frame Relay interface or VC.
Use undo fr compression iphc tcp-connections to restore the default.
fr compression iphc tcp-connections number
The maximum number of TCP header-compression connections is 16.
Interface view
number: Specifies the maximum number of TCP header-compression connections allowed, in the range of 3 to 256.
TCP is a connection-oriented protocol and can carry many TCP connections on one link. The compression algorithm maintains information for each TCP header-compression connection. To save memory resources, you can use this command to specify the maximum number of TCP header-compression connections allowed. For example, if you specify the maximum number as 3, packets of the fourth TCP connection are not compressed.
The maximum number of TCP header-compression connections configured on an interface is inherited by all VCs of the interface. If you set a different maximum number on a VC of the interface, the setting on the VC takes effect.
You can configure this command on an interface or PVC only after you enable IPHC without specifying the nonstandard keyword on the interface or PVC. The configuration takes effect on an interface or PVC after you execute the shutdown/undo shutdown command sequence on the interface or PVC. After you disable IPHC or re-enable IPHC with the nonstandard keyword, the configuration is deleted.
# Set the maximum number of TCP header-compression connections to 200 for Serial 2/1/0.
[Sysname-Serial2/1/0] fr compression iphc tcp-connections 200
# Set the maximum number of TCP header-compression connections to 200 for the VC with DLCI 100 on Serial 2/1/0.
[Sysname-fr-dlci-Serial2/1/0-100] fr compression iphc tcp-connections 200
fr compression stac enable
Use fr compression stac enable to enable Frame Relay STAC compression on a Frame Relay VC.
Use undo fr compression stac enable to disable Frame Relay STAC compression on a Frame Relay VC.
Frame Relay STAC compression is disabled on a Frame Relay VC.
To make STAC compression take effect on a PVC, you must enable STAC compression on both ends of the PVC.
STAC compression works only when the encapsulation type is IETF on both ends of a PVC. If the encapsulation type is not IETF when you enable STAC compression, the system automatically changes the encapsulation type to IETF.
Frame Relay IPHC and STAC compression are mutually exclusive.
# Enable Frame Relay STAC compression on the VC with DLCI 100 on Serial 2/1/0.
[Sysname-Serial2/1/0-fr-dlci-100]fr compression stac enable
fr dlci
Use fr dlci to create a VC and enter its view, or enter the view of an existing VC.
Use undo fr dlci to delete a VC.
fr dlci dlci-number
undo fr dlci [ dlci-number ]
No VCs exist.
Interface view (main interface or subinterface view)
dlci-number: Specifies a VC by its DLCI in the range 16 to 1007. DLCIs 0 through 15 and 1008 through 1023 are reserved.
The undo form of this command deletes all VCs if you do not specify the dlci-number argument.
The DLCI of a VC must be unique on a main interface and all its subinterfaces.
On a main DCE or NNI Frame Relay interface or subinterface, you must manually create VCs.
On a main DTE interface, the device can automatically create VCs according to the settings received from the DCE side. If you create VCs manually, make sure the DLCIs of the VCs are the same as those used on the DCE side.
On a DTE subinterface, you must manually create VCs.
When a DCE interface and an NNI interface perform LMI negotiation, the VC information is transmitted. When too many VCs are configured on an interface, the negotiation packet carrying the PVC information exceeds the maximum frame length allowed on the interface. In this case, the LMI negotiation fails.
# Create a VC with DLCI 100 on the Frame Relay interface (Serial 2/1/0).
fr encapsulation
Use fr encapsulation to configure the encapsulation type for a Frame Relay interface or VC.
Use undo fr encapsulation to restore the default.
fr encapsulation { ietf | nonstandard }
The encapsulation type is IETF on a Frame Relay interface. The encapsulation type of a VC is the same as that configured on its Frame Relay interface.
Interface view
ietf: Specifies the IETF encapsulation type.
The Frame Relay encapsulation types include:
· IETF—The IETF encapsulation type conforms to RFC 1490.
· Nonstandard—The nonstandard encapsulation type is compatible with dedicated encapsulation types of mainstream routers.
When a Frame Relay interface is configured with an encapsulation type:
· The interface sends packets encapsulated in this type.
· The interface can recognize packets encapsulated in either type.
For the local end and the peer to communicate:
· If the peer can recognize packets in either type, you can set different encapsulation types on the two ends.
· If the peer cannot recognize packets in either type,, you must set the same encapsulation type on the two ends.
By default, a VC uses the encapsulation type configured on its Frame Relay interface. The encapsulation type configured for a VC takes precedence over the encapsulation type configured on its Frame Relay interface.
If a VC is enabled with STAC compression, its encapsulation type can only be IETF.
# Enable Frame Relay encapsulation on Serial 2/1/0, and set the encapsulation type to nonstandard.
[Sysname-Serial2/1/0] link-protocol fr
[Sysname-Serial2/1/0] fr encapsulation nonstandard
# Set the Frame Relay encapsulation type to IETF on the VC with DLCI 200.
[Sysname-Serial2/1/0-fr-dlci-200] fr encapsulation ietf
fr fragment enable
Use fr fragment enable to enable Frame Relay FRF.12 fragmentation on a Frame Relay interface.
Use undo fr fragment enable to disable Frame Relay FRF.12 fragmentation on a Frame Relay interface.
fr fragment enable
Frame Relay FRF.12 fragmentation is disabled on a Frame Relay interface.
Interface view
This command enables FRF.12 fragmentation on all PVCs of an interface and its subinterfaces.
FRF.12 fragmentation enabled by using this command is end-to-end type.
This command and the fr traffic-shaping command are mutually exclusive on an interface. For more information about Frame Relay traffic shaping, see ACL and QoS Configuration Guide.
# Enable Frame Relay FRF.12 fragmentation on Serial 2/1/0.
[Sysname-Serial2/1/0] fr fragment enable
fr fragment size
Use fr fragment size to set the fragment size allowed on a Frame Relay interface.
Use undo fr fragment size to restore the default.
fr fragment size size
The fragment size allowed on a Frame Relay interface is 45 bytes.
Interface view
size: Specifies the fragment size in the range of 16 to 1600 bytes.
# Set the fragment size to 300 bytes on Serial 2/1/0.
[Sysname-Serial2/1/0] fr fragment size 300
fr inarp
Use fr inarp to enable Frame Relay InARP on a Frame Relay interface.
Use undo fr inarp to disable Frame Relay InARP on a Frame Relay interface.
fr inarp ip [ dlci-number ]
undo fr inarp ip [ dlci-number ]
Frame Relay InARP is enabled on a Frame Relay interface.
Interface view
ip: Performs inverse address resolution for IPv4 addresses.
dlci-number: Specifies a VC by its DLCI number. The value range for this argument is 16 to 1007. If you do not specify a VC, all VCs on the interface and on all its subinterfaces are specified.
When Frame Relay sends data over an interface, the peer IP addresses must be mapped to the local DLCIs. The address-to-DLCI mapping can be configured automatically through InARP or manually.
If you enable or disable InARP on a Frame Relay interface without specifying a VC, InARP is enabled or disabled on the following VCs:
· All VCs on the Frame Relay interface.
· All VCs on each subinterface of the Frame Relay interface.
# Enable InARP on all VCs of the Frame Relay interface Serial 2/1/0.
[Sysname-Serial2/1/0] fr inarp ip
display fr inarp
fr inarp interval
fr inarp interval
Use fr inarp interval to set the InARP request interval during an InARP learning process.
Use undo fr inarp interval to restore the default.
fr inarp interval interval
The InARP request interval during an InARP learning process is 60 seconds.
Interface view
interval: Specifies the InARP request interval during an InARP learning process. The value range for this argument is 15 to 300 seconds.
The InARP request interval takes effect only when InARP is enabled.
# Set the InARP request interval during an InARP learning process to 15 seconds on the Frame Relay interface Serial 2/1/0.
[Sysname-Serial2/1/0] fr inarp interval 15
display fr inarp
fr inarp
fr interface-type
Use fr interface-type to set the type of a Frame Relay interface.
Use undo fr interface-type to restore the default.
fr interface-type { dce | dte | nni }
The type of a Frame Relay interface is DTE.
Interface view
dce: Specifies DCE.
dte: Specifies DTE.
nni: Specifies NNI.
# Set the type of the Frame Relay interface Serial 2/1/0 to DCE.
[Sysname-Serial2/1/0] fr interface-type dce
fr ipv6 ind
Use fr ipv6 ind to enable IND for dynamic address mapping on a Frame Relay interface.
Use undo fr ipv6 ind to disable IND for dynamic address mapping on a Frame Relay interface.
fr ipv6 ind [ dlci-number ]
undo fr ipv6 ind [ dlci-number ]
IND is disabled on a Frame Relay interface.
Interface view
dlci-number: Specifies a VC by its DLCI number in the range of 16 to 1007. If you do not specify a VC, all VCs on the interface and on all its subinterfaces are specified.
IND automatically creates IPv6 address-to-DLCI maps on an interface.
If you enable or disable IND on a Frame Relay interface without specifying a VC, IND is enabled or disabled on the following VCs:
# Enable IND for all VCs on Serial 2/1/0.
[Sysname-Serial2/1/0] fr ipv6 ind
fr lmi n391dte
Use fr lmi n391dte to set the DTE-side N391 counter.
Use undo fr lmi n391dte to restore the default.
fr lmi n391dte n391-value
undo fr lmi n391dte
The DTE-side N391 counter is 6.
Interface view
n391-value: Sets the DTE-side N391 counter in the range of 1 to 255.
This command is available on DTE and NNI interfaces.
A DTE sends status enquiry messages at an interval set by the T391 timer to a DCE. The status enquiry messages include link integrity verification enquiry messages and full status enquiry messages. The ratio of sent link integrity verification enquiry messages to sent full status enquiry messages is (N391–1):1.
# Set the type of the Frame Relay interface (Serial 2/1/0) to DTE. Set the N391 counter to 10.
[Sysname-Serial2/1/0] fr interface-type dte
[Sysname-Serial2/1/0] fr lmi n391dte 10
fr lmi n392dce
Use fr lmi n392dce to set the DCE-side N392 counter.
Use undo fr lmi n392dce to restore the default.
fr lmi n392dce n392-value
undo fr lmi n392dce
The DCE-side N392 counter is 3.
Interface view
n392-value: Sets the DCE-side N392 counter in the range of 1 to 10.
This command is available on DCE and NNI interfaces.
A DCE requires a DTE to send a status enquiry message at an interval set by the T392 timer. If the DCE has not received a status enquiry message when the T392 timer expires, the error counter on the DCE increments by one.
The N392 counter sets an error threshold for the total number of monitored events set by the N393 counter. If the number of errors during N393 events reaches N392, the DCE considers the physical link and all VCs unavailable and will not use them to forward packets.
N392 must be less than N393 on the DCE side.
# Set the type of the Frame Relay interface (Serial 2/1/0) to DCE. Set N392 to 5 and N393 to 6.
[Sysname-Serial2/1/0] fr lmi n392dce 5
[Sysname-Serial2/1/0] fr lmi n393dce 6
fr lmi n392dte
Use fr lmi n392dte to set the DTE-side N392 counter.
Use undo fr lmi n392dte to restore the default.
fr lmi n392dte n392-value
undo fr lmi n392dte
The DTE-side N392 counter is 3.
Interface view
n392-value: Sets the DTE-side N392 counter in the range of 1 to 10.
A DTE sends a status enquiry message at an interval to a DCE to request the link status. When the DCE receives a status enquiry message, the DCE immediately sends a status message. If the DTE has not received the status message when the T391 timer expires, the error counter on the DTE increments by one.
The N392 counter sets an error threshold for the total number of monitored events set by the N393 counter. If the number of errors during N393 events reaches N392, the DTE considers the physical link and all VCs unavailable and will not use them to forward packets.
N392 must be less than N393 on the DTE side.
# Set the type of the Frame Relay interface (Serial 2/1/0) to DTE. Set N392 to 5 and N393 to 6.
[Sysname-Serial2/1/0] fr lmi n392dte 5
[Sysname-Serial2/1/0] fr lmi n393dte 6
fr lmi n393dce
Use fr lmi n393dce to set the DCE-side N393 counter.
Use undo fr lmi n393dce to restore the default.
fr lmi n393dce n393-value
undo fr lmi n393dce
The DCE-side N393 counter is 4.
Interface view
n393-value: Sets the DCE-side N393 counter in the range of 1 to 10.
A DCE requires a DTE to send a status enquiry message at an interval set by the T392 timer. If the DCE has not received the status enquiry message when the T392 timer expires, the error counter on the DCE increments by one.
[Sysname] interface serial2/1/0
fr lmi n393dte
Use fr lmi n393dte to set the DTE-side N393 counter.
Use undo fr lmi n393dte to restore the default.
fr lmi n393dte n393-value
undo fr lmi n393dte
The DTE-side N393 counter is 4.
Interface view
n393-value: Sets the DTE-side N393 counter in the range of 1 to 10.
A DTE sends status enquiry messages at an interval to a DCE to request the link status. When the DCE receives a status enquiry message, the DCE immediately sends a status message. If the DTE has not received the status message when the T391 timer expires, the error counter on the DTE increments by one.
fr lmi t392dce
Use fr lmi t392dce to set the DCE-side T392 timer.
Use undo fr lmi t392dce to restore the default.
fr lmi t392dce t392-value
undo fr lmi t392dce
The DCE-side T392 timer is 15 seconds.
Interface view
t392-value: Sets the DCE-side T392 timer in the range of 5 to 30 seconds.
The DCE-side T392 timer defines the longest period that a DCE can wait for a status enquiry message.
The DCE-side T392 timer must be greater than the DTE-side T391 timer set by using the timer-hold command.
# Set the type of the Frame Relay interface (Serial 2/1/0) to DCE. Set the T392 timer to 10 seconds.
[Sysname-Serial2/1/0] fr lmi t392dce 10
fr lmi type
Use fr lmi type to configure the Frame Relay LMI protocol type.
Use undo fr lmi type to restore the default.
fr lmi type { ansi | nonstandard | q933a }
undo fr lmi type
The Frame Relay LMI protocol type is q933a.
Interface view
ansi: Specifies the standard LMI protocol defined in ANSI T1.617 Annex D.
nonstandard: Specifies the nonstandard compatible LMI protocol.
q933a: Specifies the standard LMI protocol defined in Q.933 Annex A.
The LMI protocol maintains the Frame Relay PVC table. It can perform the following operations:
· Notifies the addition of a PVC.
· Detects the deletion of a PVC.
· Monitors PVC status changes.
· Verifies link integrity.
The system usually supports the following LMI protocols:
· ITU-T Q.933 Annex A.
· ANSI T1.617 Annex D.
· Nonstandard compatible LMI protocol.
# Configure the Frame Relay LMI type as nonstandard compatible protocol on Serial 2/1/0.
[Sysname-Serial2/1/0] fr lmi type nonstandard
fr map
Use fr map to create a static address-to-DLCI map.
Use undo fr map to delete a static address-to-DLCI map.
fr map ip { ip-address | default } dlci-number
fr map ipv6 { ipv6-address | default } dlci-number
undo fr map ip { ip-address | default } dlci-number
undo fr map ipv6 { ipv6-address | default } dlci-number
No static address-to-DLCI maps exist.
Interface view (main interface view or P2MP subinterface view)
ip-address: Specifies the peer IPv4 address.
ipv6-address: Specifies the peer IPv6 address.
default: Creates a default address-to-DLCI map.
dlci-number: Specifies the local VC by its DLCI in the range of 16 to 1007. DLCIs 0 through 5 and 1008 through 1023 are reserved.
An address-to-DLCI map can be created automatically by using InARP or IND, or created manually.
· InARP or IND is suitable for a complex network where the peer devices also support InARP or IND.
· As a best practice, create address-to-DLCI maps manually when the number of peer hosts is small or when default routes exist.
The IPv4 or IPv6 address in an address-to-DLCI map must be a valid unicast IPv4 or IPv6 address.
When the VC specified in this command does not exist, the VC is automatically created.
Up to one default address-to-DLCI map can be configured on one interface.
Only one address-to-DLCI map can be configured for one IPv4 or IPv6 address on one interface.
# Create a static address-to-DLCI map on Serial 2/1/0 to map the VC with DLCI 50 to the peer IP address 202.38.163.252.
[Sysname-Serial2/1/0] fr map ip 202.38.163.252 50
display fr map
ipv6 ind holdtime
Use ipv6 ind holdtime to set the IND request interval during the IND learning process.
Use undo ipv6 ind holdtime to restore the default.
ipv6 ind holdtime seconds
The IND request interval during the IND learning process is 30 seconds.
Interface view
seconds: Specifies the IND request interval in the range of 10 to 120 seconds.
This command takes effect only when IND is enabled.
# Set the type of the Frame Relay interface Serial 2/1/0 to DTE, and set the IND request interval to 15 seconds for Serial 2/1/0.
[Sysname-Serial2/1/0] ipv6 ind holdtime 15
Use ipv6 ind solicitation retrans-timer to set the interval between IND requests that are sent continuously.
Use undo ipv6 ind solicitation retrans-timer to restore the default.
ipv6 ind solicitation retrans-timer seconds
The interval between IND requests that are sent continuously is 1 second.
Interface view
seconds: Specifies the interval between IND requests that are sent continuously, in the range of 1 to 5 seconds.
An interface that fails to receive IND responses within the IND request interval continuously sends IND requests up to three times at the interval set by using this command.
# Set the type of the Frame Relay interface Serial 2/1/0 to DTE, and set the interval between continuous IND requests to 2 seconds for Serial 2/1/0.
[Sysname-Serial2/1/0] ipv6 ind solicitation retrans-timer 2
link-protocol fr
Use link-protocol fr to enable Frame Relay encapsulation on an interface.
Use undo link-protocol fr to restore the default.
link-protocol fr
PPP encapsulation is enabled on all interfaces except Ethernet interfaces, ATM interfaces, and VLAN interfaces.
NOTE: The following routers do not support ATM interfaces: · MSR3620-X1. · MSR3620-X1-WiNet. · MSR3620-X1-XS. · MSR3640-X1. · MSR3640-XS. · MSR3640-X1-HI. · MSR3660-XS. |
Interface view
# Enable Frame Relay encapsulation on Serial 2/1/0.
Use reset fr compression iphc to clear Frame Relay IPHC statistics.
reset fr compression iphc { rtp | tcp } [ interface interface-type interface-number [ dlci dlci-number ] ]
rtp: Clears RTP header compression statistics.
tcp: Clears TCP header compression statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears IPHC statistics for all interfaces.
dlci dlci-number: Specifies a VC by its DLCI in the range of 16 to 1007. Before you specify a VC, you must specify an interface. If you do not specify a VC, this command clears IPHC statistics for all VCs on an interface.
# Clear IPHC statistics for all interfaces.
<Sysname> reset fr compression iphc
reset fr inarp
Use reset fr inarp to clear dynamic IPv4 address-to-DLCI maps.
reset fr inarp [ interface interface-type interface-number [ dlci dlci-number ] ]
· If you specify a main interface, this command clears information for the main interface and its subinterfaces.
· If you specify a subinterface, this command clears information for the subinterface.
· If you do not specify an interface, this command clears information for all interfaces.
dlci dlci-number: Specifies a VC by its DLCI in the range of 16 to 1007. DLCIs 0 through 15 and 1008 through 1023 are reserved.
· If you specify a main interface and a VC that is not on the main interface or any of its subinterfaces, this command does not clear IPv4 address mapping for the VC.
· If you specify a subinterface and a VC that is not on the subinterface, this command does not clear IPv4 address mapping for the VC.
· If you specify only an interface, this command clears IPv4 address mapping for all VCs on the interface.
In some situations, for example, when the network topology changes, the dynamic address-to-DLCI maps will become invalid. Before dynamic address-to-DLCI maps are established again, clear all dynamic address-to-DLCI maps.
# Clear all dynamic IPv4 address-to-DLCI maps.
<Sysname> reset fr inarp
fr inarp
reset fr ipv6 ind
Use reset fr ipv6 ind to clear dynamic IPv6 address-to-DLCI maps.
reset fr ipv6 ind [ interface interface-type interface-number [ dlci dlci-number ] ]
· If you specify a main interface and a VC that is not on the main interface or any of its subinterfaces, this command does not clear IPv6 address mapping for the VC.
· If you specify a subinterface and a VC that is not on the subinterface, this command does not clear IPv6 address mapping for the VC.
· If you specify only an interface, this command clears IPv6 address mapping for all VCs on the interface.
# Clear all dynamic IPv6 address-to-DLCI maps.
<Sysname> reset fr ipv6 ind
reset fr pvc
Use reset fr pvc to clear statistics for PVCs.
reset fr pvc [ interface interface-type interface-number [ dlci dlci-number ] ]
interface interface-type interface-number: Specifies an interface by its type and number. It can be a main interface or subinterface. If you specify a main interface, this command clears statistics for the main interface and its subinterfaces. If you specify a subinterface, this command clears statistics for the subinterface. If you do not specify an interface, this command clears statistics for all interfaces.
# Clear statistics for all PVCs on Serial 2/1/0.
<Sysname> reset fr pvc interface serial 2/1/0
snmp-agent trap enable fr
Use snmp-agent trap enable fr to enable SNMP notifications for Frame Relay.
Use undo snmp-agent trap enable fr to disable SNMP notifications for Frame Relay.
SNMP notifications are disabled for Frame Relay.
# Enable SNMP notifications for Frame Relay.
[Sysname] snmp-agent trap enable fr
timer-hold
Use timer-hold to set the DTE-side T391 timer.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The DTE-side T391 timer is 10 seconds.
Interface view
seconds: Specifies the DTE-side T391 timer in the range of 0 to 32767 seconds. The value 0 indicates that the LMI protocol is disabled.
The DTE-side T391 timer defines the interval at which the DTE sends status enquiry messages.
The DTE-side T391 timer must be smaller than the DCE-side T392 timer.
# Set the type of the Frame Relay interface (Serial 2/1/0) to DTE. Set the T391 timer to 15 seconds.
[Sysname-Serial2/1/0] timer-hold 15
bandwidth
Use bandwidth to set the expected bandwidth for an MFR interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) for an MFR interface is the interface baud rate divided by 1000.
MFR interface view
# Set the expected bandwidth to 1000 kbps for MFR4.
[Sysname] interface mfr 4
[Sysname-MFR4] bandwidth 1000
default
Use default to restore the default settings for an MFR interface.
default
MFR interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you execute it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for MFR4.
[Sysname-MFR4] default
description
The description of an MFR interface is interface name Interface, for example, MFR4 Interface.
MFR interface view
# Configure the description of MFR4 as mfr4-interface.
[Sysname-MFR4] description mfr4-interface
display interface mfr
Use display interface mfr to display MFR interface information.
display interface [ mfr [ interface-number ] ] [ brief [ description | down ] ]
mfr [ interface-number ]: Specifies MFR interfaces. If you do not specify the mfr keyword, this command displays information about all interfaces supported by the device. If you specify the mfr keyword but not the interface-number argument, this command displays information about all MFR interfaces.
brief: Displays brief information about interfaces. If you do not specify this keyword, the command displays detailed information about interfaces.
down: Displays information about the interfaces in physically down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about MFR4.
<Sysname> display interface mfr 4
MFR4
Current state: DOWN
Line protocol state: DOWN
Description: MFR4 Interface
Bandwidth: 0kbps
Hold timer: 10 seconds, retry times: 5
Link layer protocol is FR IETF
LMI DLCI is 0, LMI type is Q.933a, frame relay DTE
LMI status enquiry sent 0, LMI status received 0
LMI status timeout 0, LMI message discarded 0
Physical: MFR
Input: 0 packets, 0 bytes, 0 dropps
Output: 0 packets, 0 bytes, 0 dropps
Table 9 Command output
Current state |
Physical state and administrative state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface: · UP—The data link layer protocol is up. · DOWN—The data link layer protocol is down. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. |
Hold timer |
Interval for the interface to send keepalive messages. |
retry times |
Maximum number of times that the interface can resend a hello message when waiting for a hello acknowledgement. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2—WAN Access Configuration Guide. · Unnumbered—IP address borrowed from another interface. · Cellular-allocated—IP address allocated through the modem-manufacturer's proprietary protocol. For more information, see 3G/4G modem management in Layer 2—WAN Access Configuration Guide. · MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide. · MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide. |
Link layer protocol is FR IETF |
Encapsulation type of the interface: · IETF. · Nonstandard. |
LMI DLCI is 0, LMI type is Q.933a, Frame Relay DTE |
DLCI number used by LMI, LMI type, and port type. Q.933a LMI and ANSI LMI use DLCI 0, and nonstandard LMI uses DLCI 1023. |
LMI status enquiry sent 0, LMI status received 0 |
Number of sent status enquiry messages and number of received status messages. |
LMI status timeout 0, LMI message discarded 0 |
Physical |
Physical type of the interface. |
Output queue - Urgent queuing: Size/Length/Discards 0/100/0 Output queue - Protocol queuing: Size/Length/Discards 0/500/0 Output queue - FIFO queuing: Size/Length/Discards 0/75/0 |
Statistics on the packets of the following interface output queues: · Urgent queue. · Protocol queue. · FIFO queue. |
Last clearing of counters: Never |
Time when the interface statistics were last cleared. Never indicates that the interface statistics have never been cleared since device startup. |
Last 300 seconds input rate: 0 bytes/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 packets/sec |
Average input rate of the interface in the last 5 minutes. Average output rate of the interface in the last 5 minutes. |
Input: 0 packets, 0 bytes, 0 dropps |
Number of incoming packets, number of incoming bytes, and number of incoming packets discarded. |
Output: 0 packets, 0 bytes, 0 dropps |
Number of outgoing packets, number of outgoing bytes, and number of outgoing packets discarded. |
# Display brief information about MFR4.
<Sysname> display interface mfr 4 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface Link Protocol Main IP Description
MFR4 DOWN DOWN --
# Display brief information about the MFR interfaces in physically down state.
<Sysname> display interface mfr brief down
Interface Link Cause
MFR4 ADM Administratively
Table 10 Command output
Brief information on interface(s) under route mode |
Brief information about Layer 3 interfaces. |
Interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface , use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Partial or complete interface description set by using the description command: · If you do not specify the description keyword for the display interface brief command, this field displays only the first 27 characters of the interface description. · If you specify the description keyword for the display interface brief command, this field displays the complete interface description. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty). · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. |
fr interface-type
fr lmi type
timer-hold
display mfr
Use display mfr to display information about MFR bundles and bundle links.
display mfr [ interface interface-type interface-number ] [ verbose ]
interface interface-type interface-number: Specifies an interface by its type and number. The specified interface must be a main interface (MFR interface or physical interface).
verbose: Displays detailed information, including the number of control messages sent and received. If you do not specify this keyword, the command displays only configuration and status information.
If you specify an MFR interface without the verbose keyword, this command displays the configuration and status information for the specified bundle and all its bundle links.
If you specify a physical interface without the verbose keyword, this command displays the configuration and status information for the specified bundle link and its bundle.
If you specify an MFR interface with the verbose keyword, this command displays detailed information about the specified n MFR interface and all its bundle links.
If you specify a physical interface with the verbose keyword, this command displays detailed information about the specified bundle link and its bundle.
# Display the configuration and status information for all MFR bundles and bundle links.
<Sysname> display mfr
Bundle interface: MFR1 Bundle state: Up Bundle class: A
Bundle name: MFR1 Peer bundle name: MFR2
Fragment: Enabled MFR bundle fragment size: 222 bytes
Original packets assembled/fragmented (input/output): 0/0
Dropped fragments (input/output): 0/0
Unassigned fragments: 0
Bundle links:
Serial2/1/0 Physical state: Up Link state: Up Link name: Serial2/1/0
Table 11 Command output
Bundle state |
Operating state of the MFR interface: · Up—The interface is physically up. · Down—The interface is physically down. · Administratively down—The interface is administratively down. |
Bundle class |
Bandwidth class, which is fixed at class A. A class A bundle is brought up when one or more bundle links come up. The bundle goes down when the last bundle link is down. |
Fragment |
Indicates whether fragmentation is enabled. |
MFR bundle fragment size |
Maximum fragment size allowed for bundle links. |
Original packets assembled/fragmentized (input/output) |
Number of assembled packets on the bundle interface and number of unfragmented packets before being sent by the MFR interface. |
Dropped fragments (input/output) |
Number of incoming/outgoing packets dropped on the MFR interface. |
Unassigned fragments |
Number of fragments that have not been assembled. |
Serial2/1/0 Physical state: Up Link state: Up Link name: Serial2/1/0 |
Information about a bundle link: · Physical layer state: ¡ Up. ¡ Down. ¡ Administratively down. · Link layer state: ¡ Add sent—The interface sent an Add_link message and started connection establishment. ¡ Ack rx—The interface received an Add_link acknowledgement and is expecting an Add_link message from the peer. ¡ Add rx—The interface received an Add_link message and is expecting an Add_link acknowledgement from the peer. ¡ Up—The bundle link was successfully negotiated, and the interface can send frames. ¡ Idle—The bundle link was removed. ¡ Down—The bundle link was physically down. ¡ Down idle—The bundle link was physically down and removed. · The bundle link name is the name of the physical interface by default. |
# Display detailed information about all MFR bundles and bundle links.
<Sysname> display mfr verbose
Bundle links:
Serial2/1/0
Link name: Serial2/1/0 Peer link name: Serial2/1/0
Physical state: Up Link state: Up Cause code: None
Timer: ACK 4 seconds Hello 10 seconds
Retry: Max 2 Current 0
Bundle link negotiation statistics:
Hello (Tx/Rx): 10/10 packets
Hello_ack (Tx/Rx): 10/10 packets
Add_link (Tx/Rx): 4/2 packets
Add_link_ack (Tx/Rx): 2/1 packets
Add_link_rej (Tx/Rx): 0/0 packets
Remove_link (Tx/Rx): 0/0 packets
Remove_link_ack (Tx/Rx): 0/0 packets
Packets dropped (input/output): 0/0
Bundle link fragment statistics:
MFR fragments(input/output): 0/0
Table 12 Command output
Physical state |
Operating state of the physical interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · Administratively down—The interface has been administratively shut down. |
Link state |
Operating state of the link protocol on the bundle link: · Add sent—The interface sent an Add_link message and started connection establishment. · Ack rx—The interface received an Add_link acknowledgement and is expecting an Add_link message from the peer. · Add rx—The interface received an Add_link message and is expecting an Add_link acknowledgement from the peer. · Up—The bundle link was successfully negotiated, and the interface can send frames. · Idle—The bundle link was removed. · Down—The bundle link was physically down. · Down idle—The bundle link was physically down and removed. |
Cause code |
Cause code for a bundle link state: · None—Initial state. · Ack timer expired—The ACK timer expires. · Bundle link idle—The bundle link is not operational. · Inconsistent bundle—Possible configuration mismatch detected. · Loopback detected—The bundle link has detected a potential loopback condition. · Unexpected add_link—An ADD_LINK message was received when the bundle link was in up state. · Other—Generic failure cause described by text in diagnostic element. |
Timer: Ack |
Amount of time for which the bundle link waits for a hello or Add_link acknowledgement before retransmitting a hello message or an Add_link message (for initial synchronization). |
Hello |
Interval for the bundle link to send hello messages. |
Retry: Max |
Maximum number of times that the bundle link can retransmit a hello or Add_link message before receiving a hello or Add_link acknowledgement. |
Current |
Number of retries that have been made. |
Hello (Tx/Rx) |
Number of hello messages sent/received. |
Hello_ack (Tx/Rx) |
Number of hello acknowledgements sent/received. |
Add_link_ack (Tx/Rx) |
Number of Add_link acknowledgements sent/received. An Add_link acknowledgement notifies the peer that the local end received an Add_link message. |
Add_link_rej (Tx/Rx) |
Number of Add_link reject messages sent/received. An Add_link_rej message notifies the peer that the local end rejected an Add_link message. |
Remove_link (Tx/Rx) |
Number of Remove_link messages sent/received. A Remove_link message notifies that the local end is removing a bundle link from the bundle. |
Remove_link_ack (Tx/Rx) |
Number of Remove_link acknowledgements sent/received. A Remove_link acknowledgement notifies the peer that the local end received a Remove_link message. |
Packets dropped (input/output) |
Number of incoming/outgoing packets dropped. |
MFR fragments (input/output) |
Number of fragments sent/received by the bundle link. |
mfr bundle-name
mfr fragment size
mfr fragment enable
mfr link-name
mfr retry
mfr timer ack
mfr timer hello
fr mfr
Use fr mfr to bind a physical interface to an MFR interface.
Use undo fr mfr to remove all physical interfaces from an MFR interface.
fr mfr mfr interface-number
undo fr mfr
A physical interface is not bound to any MFR interface.
Interface view
interface-number: Specifies an MFR interface by its number. The value range for this argument is 0 to 1023.
Before configuring this command, make sure the physical interface is enabled with MFR encapsulation. A maximum of 16 physical interfaces can be bound to an MFR interface.
You can bind a physical interface to a nonexistent MFR interface. However, the binding takes effect only when the MFR interface is created. When a physical interface is removed from an MFR interface, MFR settings on the physical interface are not deleted.
To remove a physical interface from an MFR interface, you can also configure a different encapsulation type from MFR by using the link-protocol command.
After MFR encapsulation is enabled on a physical interface, the interface cannot be configured with any FR-related commands except MFR commands. In addition, the queuing type on the interface can be configured only as FIFO. If the interface uses another queuing type before you enable MFR encapsulation, the interface is forced to use FIFO after you enable MFR encapsulation.
Make sure a physical interface is on the same card as the MFR interface to which the interface is to be bound.
# Enable MFR encapsulation on Serial 2/1/0, and bind it to MFR4.
[Sysname] interface serial 2/1/0
[Sysname-Serial2/1/0] link-protocol mfr
[Sysname-Serial2/1/0] fr mfr mfr 4
link-protocol mfr
interface mfr
Use interface mfr to create an MFR interface or subinterface and enter its view, or enter the view of an existing MFR interface or subinterface.
Use undo interface mfr to delete an MFR interface or subinterface.
interface mfr { interface-number | interface-number.subnumber [ p2mp | p2p ] }
undo interface mfr { interface-number | interface-number.subnumber }
No MFR interface or subinterfaces exist.
interface-number: Specifies a number for the MFR interface. The value range for this argument is 0 to 1023.
interface-number.subnumber: Specifies a number for the MFR subinterface. The interface-number argument represents the number of the main MFR interface. The subnumber argument represents the number of the MFR subinterface. The value range for this argument is 0 to 1023.
p2mp: Specifies an MFR subinterface as a point-to-multipoint subinterface. By default, an MFR subinterface is a point-to-multipoint subinterface.
p2p: Specifies an MFR subinterface as a point-to-point subinterface.
Before creating an MFR subinterface, make sure the main MFR interface already exists.
An MFR interface is physically up when a minimum of one of its physical interfaces is up. An MFR interface is physically down when its last physical interface is down. The link layer state of an MFR interface is negotiated by using LMI messages.
# Create an interface named MFR4, and create a point-to-multipoint subinterface.
[Sysname-MFR4] quit
[Sysname] interface mfr 4.1
[Sysname-MFR4.1]
link-protocol mfr
Use link-protocol mfr to enable MFR encapsulation on an interface.
link-protocol mfr
Interface view
# Enable MFR encapsulation on Serial 2/1/0.
fr mfr
mfr bundle-name
Use mfr bundle-name to set a bundle name for an MFR interface.
Use undo mfr bundle-name to restore the default.
mfr bundle-name name
The bundle name is represented by MFR plus the bundle number, for example, MFR4.
MFR interface view
name: Specifies a bundle name, a case-sensitive string of 1 to 49 characters.
You cannot set a bundle name as a string in the form of MFR + number.
Each MFR bundle has a bundle name, and the peer device can identify an MFR bundle by using the bundle name. Bundle names at the two ends of a bundle can be different. Bundle names must be unique on the same device.
The bundle names at both ends are used during the bundle link negotiation phase. After changing the bundle name of an MFR interface, you must execute the shutdown and undo shutdown commands on the interface to make the new bundle name take effect.
# Set the bundle name to bundle1 for MFR4.
[Sysname-MFR4] mfr bundle-name bundle1
display mfr
mfr fragment enable
Use mfr fragment enable to enable fragmentation on an MFR interface.
Use undo mfr fragment enable to disable fragmentation on an MFR interface.
mfr fragment enable
Fragmentation is disabled on an MFR interface.
MFR interface view
With fragmentation enabled, an MFR interface fragments packets larger than the set fragment size and sends the fragments over bundle links in a round robin manner. The receiving end reassembles the fragments.
# Enable fragmentation on MFR 4.
[Sysname-MFR4] mfr fragment enable
display mfr
mfr fragment size
Use mfr fragment size to set the maximum fragment size allowed on an MFR interface.
Use undo mfr fragment size to restore the default.
mfr fragment size size
The maximum fragment size allowed on an MFR interface is 300 bytes.
MFR interface view
size: Specifies the fragment size in the range of 60 to 1500 bytes.
With fragmentation enabled, an MFR interface fragments packets larger than the set fragment size and sends the fragments over bundle links in a round robin manner. This reduces the transmission delay of real-time packets.
# Set the maximum fragment size allowed on MFR 4 to 70 bytes.
[Sysname-MFR4] mfr fragment-size 70
display mfr
mfr link-name
Use mfr link-name to set the bundle link name for a Frame Relay interface.
Use undo mfr link-name to restore the default.
mfr link-name name
undo mfr link-name
The bundle link name is the name of the physical interface, for example, Serial 2/1/0.
Frame Relay interface view
name: Specifies the bundle link name, a case-sensitive string of 1 to 49 characters.
Use link-protocol mfr to enable MFR encapsulation on a Frame Relay interface before configuring the mfr link-name command on the interface.
The bundle link name identifies the bundle link to the peer device and enables the local device to determine which bundle links are bound to which bundles. The bundle link names in a bundle must be unique on the same device. The local and peer bundle link names can be different.
The local and peer bundle link names are used during the bundle link negotiation phase. After changing the bundle link name on an interface, you must execute the shutdown and undo shutdown commands on the interface to make the new bundle link name take effect.
# Set the bundle link name to bl1 for Serial 2/1/0.
[Sysname-Serial2/1/0] mfr link-name bl1
link-protocol mfr
mfr retry
Use mfr retry to set the maximum number of times that a bundle link can resend a hello message when waiting for a hello acknowledgement.
Use undo mfr retry to restore the default.
mfr retry retries
undo mfr retry
The maximum number of retries is 2.
retries: Specifies the maximum number of retries, in the range 1 to 5.
A bundle link maintains link status by periodically sending hello messages to its peer end. If the bundle link sends a hello message but does not receive a hello acknowledgement, it will resend the hello message. If the bundle link still receives no acknowledgements after the maximum number of retries is reached, the system determines that the line protocol on the bundle link is down.
Before configuring this command, make sure you have used the link-protocol mfr command to enable MFR encapsulation on the Frame Relay interface.
# Set the maximum number of retries to 3 for Serial 2/1/0.
[Sysname-Serial2/1/0] mfr retry 3
link-protocol mfr
mfr timer ack
mfr timer hello
mfr timer ack
Use mfr timer ack to set the amount of time that a bundle link waits for a hello acknowledgment before resending the hello message.
Use undo mfr timer ack to restore the default.
mfr timer ack seconds
undo mfr timer ack
The wait time for a hello acknowledgment is 4 seconds.
seconds: Specifies the wait time in the range 1 to 10 seconds.
# Set the wait time to 6 seconds for Serial 2/1/0.
[Sysname-Serial2/1/0] mfr timer ack 6
link-protocol mfr
mfr timer hello
mfr retry
mfr timer hello
Use mfr timer hello to set the interval at which a bundle link sends hello messages.
Use undo mfr timer hello to restore the default.
mfr timer hello seconds
A bundle link sends hello messages at the interval of 10 seconds.
seconds: Specifies the interval in the range 1 to 180 seconds.
Before configuring this command, make sure you have used the link-protocol fr mfr command to enable MFR encapsulation on the Frame Relay interface.
# Configure Serial 2/1/0 to send a hello message every 15 seconds.
[Sysname-Serial2/1/0] mfr timer hello 15
link-protocol mfr
mfr retry
mfr timer ack
mfr timer lost-fragment
Use mfr timer lost-fragment to set the amount of time that an MFR interface waits for an expected fragment.
Use undo mfr timer lost-fragment to restore the default.
mfr timer lost-fragment seconds
An MFR interface waits for an expected fragment for 30 seconds before it declares the fragment lost.
MFR interface view
seconds: Specifies a value for the wait timer, in the range of 1 to 255 seconds.
The receiving end buffers the fragments of a packet before receiving all fragments of the packet. If any fragments are missing, the received fragments stay in the buffer. This processing wastes buffer resources.
The wait timer starts when the receiving end receives the first fragment of a packet. When the wait timer expires, the receiving end checks whether all fragments are received. If not all fragments are received, the receiving end discards all received fragments of the packet to release buffer resources.
# Set the wait time to 20 seconds for MFR 4.
[Sysname-MFR4] mfr timer lost-fragment 20
mfr fragment enable
mfr window-size
Use mfr window-size to set the maximum number of fragments that can be held by the window used in the sliding window algorithm when an MFR interface reassembles received fragments.
Use undo mfr window-size to restore the default.
mfr window-size number
The sliding window size is the number of physical interfaces in an MFR bundle.
MFR interface view
number: Specifies the sliding window size in the range 1 to 16.
# Set the sliding window size to 8 for MFR4.
[Sysname-MFR4] mfr window-size 8
fr mfr
reset counters interface
Use reset counters interface to clear interface statistics.
reset counters interface [ mfr [ interface-number | interface-number.subnumber ] ]
mfr: Specifies MFR interfaces or subinterfaces.
interface-number.subnumber: Specifies an MFR subinterface. The interface-number argument represents the number of the main MFR interface. The subnumber argument represents the number of the MFR subinterface. The value range for this argument is 0 to 1023.
Use this command to clear history statistics before you collect traffic statistics for a time period.
· If you do not specify the mfr keyword, this command clears statistics for all interfaces.
· If you specify the mfr keyword but without the interface-number or interface-number.subnumber argument, this command clears statistics for all MFR interfaces or subinterfaces.
# Clear statistics for MFR4.
<Sysname> reset counters interface mfr 4
shutdown
Use shutdown to shut down an MFR interface.
Use undo shutdown to restore the default.
shutdown
An MFR interface is up.
MFR interface view
# Shut down MFR4.
[Sysname-MFR4] shutdown
sub-interface rate-statistic
Use sub-interface rate-statistic to enable subinterface rate statistics collection on an MFR interface.
Use undo sub-interface rate-statistic to disable subinterface rate statistics collection on an MFR interface.
Subinterface rate statistics collection is disabled on an MFR interface.
MFR interface view
This command is resource intensive. When you use this command, make sure you fully understand its impact on system performance.
# Enable subinterface rate statistics collection on MFR 4.
[Sysname-MFR4] sub-interface rate-statistic
