- 20-DPI Configuration Guide
- 01-DPI overview
- 02-Bandwidth management configuration
- 03-DPI engine configuration
- 04-IPS configuration
- 05-URL filtering configuration
- 06-Data filtering configuration
- 07-File filtering configuration
- 08-Anti-virus configuration
- 09-Data analysis center configuration
| 00-Preface | 110.62 KB |
Preface
This configuration guide describes fundamentals and configuration of deep packet inspection (DPI). DPI inspects application layer payloads to protect the network against application layer malicious activities.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
