03-Interface Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR610[810][830][1000S][2600][3600] Routers Configuration Guides(V7)-R6749-6W10303-Interface Configuration Guide
02-Ethernet interface configuration
02-Ethernet interface configuration 438.92 KB
Configuring Ethernet interfaces· 1
About Ethernet interface· 1
Configuring a management Ethernet interface· 1
Configuring common Ethernet interface settings· 2
Configuring the physical type for a combo interface (single combo interface) 2
Configuring basic settings of an Ethernet interface· 3
Configuring basic settings of an Ethernet subinterface· 4
Configuring basic settings for an Ethernet interface group· 5
Configuring the link mode of an Ethernet interface· 7
Configuring jumbo frame support 8
Configuring physical state change suppression on an Ethernet interface· 9
Configuring dampening on an Ethernet interface· 11
Enabling link flapping protection on an interface· 13
Configuring storm suppression· 14
Configuring generic flow control on an Ethernet interface· 16
Setting the statistics polling interval 17
Enabling subinterface rate statistics collection on an Ethernet interface· 18
Enabling loopback testing on an Ethernet interface· 18
Configuring interface alarm functions· 19
Shutting down all physical interfaces· 22
Restoring the default settings for an interface· 22
Configuring a Layer 2 Ethernet interface· 23
Setting speed options for autonegotiation on an Ethernet interface· 23
Setting the MDIX mode of an Ethernet interface· 26
Testing the cable connection of an Ethernet interface· 27
Configuring an interface to operate in promiscuous mode· 29
Configuring a Layer 3 Ethernet interface or subinterface· 30
Setting the MTU for an Ethernet interface or subinterface· 30
Setting the MAC address of an Ethernet interface· 31
Configuring an interface to operate in promiscuous mode· 31
Enabling statistics collection on a Layer 3 Ethernet subinterface· 31
Display and maintenance commands· 32
Appendix Hardware compatibility with link mode switchover 33
The device supports Ethernet interfaces, management Ethernet interfaces, Console interfaces, and USB interfaces. For the interface types and the number of interfaces supported by a device model, see the installation guide.
This chapter describes how to configure management Ethernet interfaces and Ethernet interfaces.
A management interface uses an RJ-45 connector. You can connect the interface to a PC for software loading and system debugging, or connect it to a remote NMS for remote system management.
(In IRF mode.)
Each member device in an IRF system has a management Ethernet interface. For management link backup, perform the following tasks:
1.     Connect your PC to the management Ethernet interface on the master device.
2.     Connect the PC to a management Ethernet interface with the same interface number on a subordinate device.
The two management Ethernet interfaces operate as follows:
·     When the IRF system has multiple management Ethernet interfaces, only the management Ethernet interface on the master device processes management traffic.
·     When the management Ethernet interface on the master device fails, the management Ethernet interface on the subordinate device takes over to process management traffic.
·     When the management Ethernet interface on the master device recovers, it takes over to process management traffic again.
2.     Enter management Ethernet interface view.
interface M-GigabitEthernet interface-number
3.     (Optional.) Set the interface description.
The default setting is M-GigabitEthernet0/0/0 Interface.
4.     (Optional.) Set the duplex mode for the management Ethernet interface.
duplex { auto | full | half }
By default, the duplex mode is auto for a management Ethernet interface.
5.     (Optional.)_Set the speed for the management Ethernet interface.
speed { 10 | 100 | 1000 | auto }
By default, the speed is auto for a management Ethernet interface.
6.      (Optional.) Shut down the interface.
shutdown
By default, the management Ethernet interface is up.
CAUTION
CAUTION:
Executing the shutdown command on an interface will disconnect the link of the interface and interrupt communication. Use this command with caution.
This section describes the settings common to Layer 2 Ethernet interfaces, Layer 3 Ethernet interfaces, and Layer 3 Ethernet subinterfaces. For more information about the settings specific to Layer 2 Ethernet interfaces, see "Configuring a Layer 2 Ethernet interface." For more information about the settings specific to Layer 3 Ethernet interfaces or subinterfaces, see "Configuring a Layer 3 Ethernet interface or subinterface."
A combo interface is a logical interface that physically comprises one fiber combo port and one copper combo port. The two ports share one forwarding channel and one interface view. As a result, they cannot work simultaneously. When you activate one port, the other port is automatically disabled. In the interface view, you can activate the fiber or copper combo port, and configure other port attributes such as the interface rate and duplex mode.
When an HMIM-8GSW Layer 2 Ethernet switching module is installed in an MSR3620-G router, the combo interfaces on the module can only be copper combo ports and cannot be switched to fiber combo ports by using the combo enable fiber command.
Before you configure combo interfaces, complete the following tasks:
·     Determine the combo interfaces on your device. Identify the two physical interfaces that belong to each combo interface according to the marks on the device panel.
·     Use the display interface command to determine which port (fiber or copper) of each combo interface is active:
¡     If the copper port is active, the output includes "Media type is twisted pair, Port hardware type is 1000_BASE_T."
¡     If the fiber port is active, the output does not include this information.
Also, you can use the display this command in the view of each combo interface to display the combo interface configuration:
¡     If the fiber port is active, the combo enable fiber command exists in the output.
¡     If the copper port is active, the combo enable fiber command does not exist in the output.
2.     Enter Ethernet interface view.
3.     Activate the copper combo port or fiber combo port.
combo enable { copper | fiber }
By default, the copper combo port is active.
You can configure an Ethernet interface to operate in one of the following duplex modes:
·     Full-duplex mode—The interface can send and receive packets simultaneously.
·     Half-duplex mode—The interface can only send or receive packets at a given time.
·     Autonegotiation mode—The interface negotiates a duplex mode with its peer.
You can set the speed of an Ethernet interface or enable it to automatically negotiate a speed with its peer.
Among the fixed copper GE ports on the MSR3600-28-G-DP, MSR3600-51-G-DP, and MSR3640-X1-HI devices, only GE0/0 supports the half-duplex mode.
Among the fixed copper GE ports on the MSR3600-28-G-X1-DP and MSR3600-51-G-X1-DP, only GE0/0, GE0/1, and GE0/2 support the half-duplex mode.
If an Ethernet interface supports setting the duplex mode, the configuration can be deployed successfully when you execute the duplex command. If an Ethernet interface does not support setting the duplex mode, the system displays a message when you execute the duplex command.
The shutdown and loopback commands are mutually exclusive.
3.     Set the description for the Ethernet interface.
When the device starts with initial configuration, the interface description is interface name Interface, for example, GigabitEthernet1/0/1 Interface. When the device starts with factory default configuration, the interface description depends on that configuration. To check the factory default for this command, execute the display default-configuration command in any view. For more information about starting with initial or factory default configuration, see configuration file management in Fundamentals Configuration Guide.
4.     Set the duplex mode for the Ethernet interface.
By default, the duplex mode is auto for Ethernet interfaces.
Fiber ports do not support the half keyword.
5.     Set the speed for the Ethernet interface.
speed { 10 | 100 | 1000 | 10000 | auto }
By default, an interface autonegotiates its speed.
6.     Set the expected bandwidth for the Ethernet interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
7.     Bring up the Ethernet interface.
By default, an Ethernet interface is up.
By default, a Layer 3 Ethernet subinterface processes packets with the VLAN tag numbered the same as the subinterface number.
Restrictions and guidelines for Ethernet subinterface basic settings
·     To transmit and receive packets through an Ethernet subinterface, you must associate it with a VLAN. For more information, see VLAN termination configuration in Layer 2—LAN Switching Configuration Guide.
·     To transmit packets between a local Ethernet subinterface and a remote Ethernet subinterface, configure them with the same subinterface number and VLAN ID.
·     Before creating a Layer 3 Ethernet subinterface, do not reserve a resource for the VLAN interface whose interface number is the subinterface number. After you reserve a VLAN interface resource, do not create a Layer 3 Ethernet subinterface whose subinterface number is the VLAN interface number. A Layer 3 Ethernet subinterface uses the VLAN interface resource in processing tagged packets whose VLAN ID matches the subinterface number. For more information about reserving resources for VLAN interfaces, see Layer 2—LAN Switching Configuration Guide.
·     The shutdown command cannot be configured on an Ethernet interface in a loopback test.
2.     Create an Ethernet subinterface.
interface interface-type interface-number.subnumber
3.     Set the description for the Ethernet subinterface.
4.     Set the expected bandwidth for the Ethernet subinterface.
5.     Bring up the Ethernet subinterface.
By default, an Ethernet subinterface is up.
When a device is shipped, some Ethernet interfaces are organized into Ethernet interface groups by default. You can set the speed for an Ethernet interface group. Then, all interfaces in the group are configured with the speed.
Interfaces on an MSR3640-X1-HI and MSR3660-XS are grouped as follows:
Device/SPU module
Interface grouping
MSR3640-X1-HI
·     SFP28 fiber ports 26 and 27 are in the same interface group.
·     SFP28 fiber ports 28 and 29 are in the same interface group.
MSR3660-XS
·     SFP+ fiber ports 22 and 23 are in the same interface group.
·     SFP+ fiber ports 24 and SFP+ 25 are in the same interface group.
The Ethernet interface groups are defined by hardware and cannot be modified. In the current software version, the device supports 10-GE Ethernet interface groups and 25-GE Ethernet interface groups.
Hardware and Ethernet interface group compatibility
Models
Feature compatibility
MSR610
No
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
No
MSR1004S-5G, MSR1004S-5G-CN
No
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL
No
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
No
MSR2600-10-X1
No
MSR2630-G-X1
No
MSR 2630
No
MSR3600-28, MSR3600-51
No
MSR3600-28-SI, MSR3600-51-SI
No
No
No
MSR3600-28-G-X1-DP, MSR3600-51-G-X1-DP
No
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
No
MSR-iMC
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
No
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
No
MSR3610-G, MSR3620-G
No
MSR3640-G
No
MSR3640-X1-HI
Yes
Models
MSR810-W-WiNet, MSR810-LM-WiNet
No
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
MSR3620-X1-WiNet
No
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
No
Models
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2600-15-X1-XS
No
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
No
MSR3640-XS
No
MSR3660-XS
Yes
Models
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
Operating mechanism
For the number of Ethernet interface groups, Ethernet interface group IDs, and Ethernet interfaces in a group, execute the port-group ? command in system view.
When you execute the port-group speed command to set the speed for Ethernet interfaces in an interface group in bulk, the system automatically checks the types and speeds of all transceiver modules installed on the Ethernet interfaces in the interface group. The device will not deploy the speed configuration if it detects inconsistent trasceiver module speeds in the group and output relevant error messages.
Bulk speed setting succeeds only when all trasceiver modules on the Ethernet interfaces in the interface group have identical types and speeds. As a best practice, plan and prepare trasceiver modules before configuration.
SFP28 fiber ports 26 through 29 on an MSR3640-X1-HI and SFP+ fiber ports 22 through 25 on an MSR3660-XS do not support speed autonegotiation. If you install a transceiver module in such a port, you must use this command to set the speed for it.
If you install a 10-GE or 1-GE transceiver module in a 25-GE Ethernet fiber port on an MSR3640-X1-HI or MSR3660-XS, use this command to set the speed for the port. If you do not do so, you will receive the fiber port and transceiver module mismatch error message.
2.     Set the speed for an Ethernet interface group.
port-group group-id speed speed-value
Ethernet interfaces operate differently depending on the hardware structure of the device. Some Ethernet interfaces can operate only as Layer 3 Ethernet interfaces (in route mode). Some Ethernet interfaces can operate either as Layer 2 or Layer 3 Ethernet interfaces. You can set the link mode to bridge or route for these Ethernet interfaces.
Support of link mode switchover for fixed interfaces on the device panel depends on the device model. For more information, see hardware compatibility with link mode switchover. If interface modules are installed on the device, see the interface module user guide for interface module information and hardware compatibility.
3.     Configure the link mode of the Ethernet interface.
Support for the link modes of Ethernet interfaces depends on the interface card model.
CAUTION
CAUTION:
Changing the link mode of an Ethernet interface also restores all commands (except shutdown and combo enable) on the Ethernet interface to their defaults in the new link mode.
Jumbo frames are frames larger than a device-specific size and are typically received by an Ethernet interface during high-throughput data exchanges, such as file transfers.
The Ethernet interface processes jumbo frames in the following ways:
·     When the Ethernet interface is configured to deny jumbo frames (by using the undo jumboframe enable command), the Ethernet interface discards jumbo frames.
·     When the Ethernet interface is configured with jumbo frame support, the Ethernet interface performs the following operations:
¡     Processes jumbo frames within the specified length.
¡     Discards jumbo frames that exceed the specified length.
3.     Configure jumbo frame support.
jumboframe enable [ size ]
By default, the device allows jumbo frames within the specified length to pass through. For more information, see Interface Command Reference.
If you set the size argument multiple times, the most recent configuration takes effect.
The physical link state of an Ethernet interface is either up or down. Each time the physical link of an interface comes up or goes down, the interface immediately reports the change to the CPU. The CPU then performs the following operations:
·     Notifies the upper-layer protocol modules (such as routing and forwarding modules) of the change for guiding packet forwarding.
·     Automatically generates traps and logs to inform users to take the correct actions.
To prevent frequent physical link flapping from affecting system performance, configure physical state change suppression. You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event to the CPU.
Feature and hardware compatibility
Models
MSR610
No
No
No
No
No
No
No
No
MSR2600-10-X1
No
MSR2630-G-X1
Yes
MSR 2630
No
No
No
No
Yes
Yes
No
MSR-iMC
No
No
No
No
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Models
No
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
MSR3620-X1-WiNet
No
No
Models
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2600-15-X1-XS
No
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
No
MSR3640-XS
No
MSR3660-XS
Yes
Models
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
Do not enable this feature on an interface that has spanning tree protocols enabled.
You can configure different suppression intervals for link-up and link-down events.
If you configure this command multiple times for link-up or link-down events on an Ethernet interface, the most recent configuration takes effect.
The link-delay, dampening, and port link-flap protect enable commands are mutually exclusive on an Ethernet interface.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you configure the link-delay command multiple times for link-up or link-down events, the most recent configuration takes effect.
3.     Configure physical state change suppression.
link-delay [ msec ] delay-time [ mode { up | updown }]
By default, physical state change suppression is disabled.
To suppress only link-down events, do not specify the mode keyword. To suppress only link-up events, specify the mode up keywords. To suppress both link-down and link-up events, specify the mode updown keywords.
The interface dampening feature uses an exponential decay mechanism to prevent excessive interface flapping events from adversely affecting routing protocols and routing tables in the network. Suppressing interface state change events protects the system resources.
If an interface is not dampened, its state changes are reported. For each state change, the system also generates an SNMP trap and log message.
After a flapping interface is dampened, it does not report its state changes to the CPU. For state change events, the interface only generates SNMP trap and log messages.
·     Penalty—The interface has an initial penalty of 0. When the interface flaps, the penalty increases by 1000 for each down event until the ceiling is reached. It does not increase for up events. When the interface stops flapping, the penalty decreases by half each time the half-life timer expires until the penalty drops to the reuse threshold.
·     Ceiling—The penalty stops increasing when it reaches the ceiling.
·     Suppress-limit—The accumulated penalty that triggers the device to dampen the interface. In dampened state, the interface does not report its state changes to the CPU. For state change events, the interface only generates SNMP traps and log messages.
·     Reuse-limit—When the accumulated penalty decreases to this reuse threshold, the interface is not dampened. Interface state changes are reported to the upper layers. For each state change, the system also generates an SNMP trap and log message.
·     Decay—The amount of time (in seconds) after which a penalty is decreased.
·     Max-suppress-time—The maximum amount of time the interface can be dampened. If the penalty is still higher than the reuse threshold when this timer expires, the penalty stops increasing for down events. The penalty starts to decrease until it drops below the reuse threshold.
When configuring the dampening command, follow these rules to set the values mentioned above:
·     The ceiling is equal to 2(Max-suppress-time/Decay)  × reuse-limit. It is not user configurable.
·     The configured suppress limit is lower than or equal to the ceiling.
·     The ceiling is lower than or equal to the maximum suppress limit supported.
Figure 1 shows the change rule of the penalty value. The lines t0 and t2 indicate the start time and end time of the suppression, respectively. The period from t0 to t2 indicates the suppression period, t0 to t1 indicates the max-suppress-time, and t1 to t2 indicates the complete decay period.
Figure 1 Change rule of the penalty value
The dampening, link-delay, and port link-flap protect enable commands are mutually exclusive on an Ethernet interface.
The dampening command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the upper-layer protocols.
·     Do not enable the dampening feature on an interface with spanning tree protocols enabled.
3.     Enable dampening on the interface.
By default, interface dampening is disabled on Ethernet interfaces.
Link flapping on an interface changes network topology and increases the system overhead. For example, in an active/standby link scenario, when interface status on the active link changes between UP and DOWN, traffic switches between active and standby links. To solve this problem, configure this feature on the interface.
With this feature enabled on an interface, when the interface goes down, the system enables link flapping detection. During the link flapping detection interval, if the number of detected flaps reaches or exceeds the link flapping detection threshold, the system shuts down the interface.
This feature takes effect only if it is configured in both the system view and interface view.
IRF system stability might be affected by IRF physical link flapping. For IRF system stability, this feature is enabled by default on IRF physical interfaces and the enabling status of this feature is not affected by the status of global link flapping protection. When the number of flaps detected on an IRF physical interface exceeds the threshold within the detection interval, the device outputs a log rather than shuts down the IRF physical interface.
To bring up an interface that has been shut down by link flapping protection, execute the undo shutdown command.
In the display interface command output, the Link-Flap DOWN value of the Current state field indicates that the interface has been shut down by link flapping protection.
2.     Enable link flapping protection globally.
By default, link flapping protection is disabled globally.
3.     Enter Ethernet interface view.
4.     Enable link flapping protection on the Ethernet interface.
port link-flap protect enable [ interval interval | threshold threshold ] *
By default, link flapping protection is disabled on an Ethernet interface.
The storm suppression feature ensures that the size of a particular type of traffic (broadcast, multicast, or unknown unicast traffic) does not exceed the threshold on an interface. When the broadcast, multicast, or unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the traffic drops below this threshold.
Hardware and feature compatibility
Hardware
MSR610
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
MSR2600-10-X1
Yes
MSR2630-G-X1
Yes
MSR 2630
No
Yes
Yes
Yes
Yes
Yes
Yes
MSR-iMC
Yes
No
No
No
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
No
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
No
MSR3620-X1-WiNet
No
No
Hardware
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2600-15-X1-XS
Yes
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
No
MSR3640-XS
No
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
Yes
·     The configured suppression threshold value in pps or kbps might be converted into a multiple of the step value supported by the chip. As a result, the effective suppression threshold might be different from the configured one. For information about the suppression threshold that takes effect, see the prompt on the device. Support for the ratio, pps, and kbps parameters varies by device model. For more information, see Interface Command Reference.
·     For the MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, and MSR1104S-W-5GGL, you can configure storm suppression for only one type of traffic on the same Ethernet interface. To configure storm suppression for another type of traffic, execute the corresponding command.
3.     Enable broadcast suppression and set the broadcast suppression threshold.
By default, broadcast suppression is disabled.
4.     Enable multicast suppression and set the multicast suppression threshold.
By default, multicast suppression is disabled.
5.     Enable unknown unicast suppression and set the unknown unicast suppression threshold.
By default, unknown unicast suppression is disabled.
To avoid dropping packets on a link, you can enable generic flow control at both ends of the link. When traffic congestion occurs at the receiving end, the receiving end sends a flow control (Pause) frame to ask the sending end to suspend sending packets. Generic flow control includes the following types:
·     TxRx-mode generic flow control—Enabled by using the flow-control command. With TxRx-mode generic flow control enabled, an interface can both send and receive flow control frames:
¡     When congestion occurs, the interface sends a flow control frame to its peer.
¡     When the interface receives a flow control frame from its peer, it suspends sending packets to its peer.
·     Rx-mode generic flow control—Enabled by using the flow-control receive enable command. With Rx-mode generic flow control enabled, an interface can receive flow control frames, but it cannot send flow control frames:
¡     When congestion occurs, the interface cannot send flow control frames to its peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end and the flow-control command at the other end. To enable both ends of a link to handle traffic congestion, configure the flow-control command at both ends.
Whether the device supports this command is relevant to its Ethernet interface. If the Ethernet interface supports the generic flow control, the device can issue commands; if the Ethernet interface does not support this function, the device will print relevant prompt.
3.     Enable generic flow control.
¡     Enable TxRx-mode generic flow control.
flow-control
¡     Enable Rx-mode generic flow control.
By default, generic flow control is disabled on an Ethernet interface.
By setting the statistics polling interval, you can collect statistics of packets and analyze packets at the specified interval. Based on the interface traffic statistics, you can take traffic control measures promptly to avoid network congestion and service interruption.
·     When network congestion is detected, you can set the statistics polling interval to be smaller than 300 seconds (30 seconds when congestion deteriorates). Then, check traffic distribution on interfaces within a short period of time. For data packets that cause congestion, take traffic control measures.
·     When the network bandwidth is sufficient and services are operating normally, you can set the statistics polling interval to be greater than 300 seconds. Once traffic parameter anomalies occur, modify the statistics polling interval promptly so that you can observe the traffic parameter trend in real time.
To display the interface statistics collected in the last statistics polling interval, use the display interface command. To clear the interface statistics, use the reset counters interface command.
Restrictions and guidelines for setting the statistics polling interval
·     As a best practice, use the default setting when you set the statistics polling interval in system view. A short statistics polling interval might decrease the system performance and result in inaccurate statistics.
Setting the statistics polling interval in system view
2.     Set the statistics polling interval.
flow-interval interval
By default, the statistics polling interval is 300 seconds.
This feature is resource intensive. When you use this feature, make sure you fully understand its impact on system performance.
After you enable subinterface rate statistics collection on an Ethernet interface, the device periodically refreshes the rate statistics on the subinterfaces of this Ethernet interface.
3.     Enable subinterface rate statistics collection on the Ethernet interface.
sub-interface rate-statistic
By default, subinterface rate statistics collection is disabled on an Ethernet interface.
4.     (Optional.) View the subinterface rate statistics.
display interface
Perform this task to determine whether an Ethernet link works correctly.
Loopback testing supports only internal loopback testing, which tests the device where the Ethernet interface resides. The Ethernet interface sends outgoing packets back to the local device. If the device fails to receive the packets, the device fails.
·     After you enable this feature on an Ethernet interface, the interface does not forward data traffic.
·     The shutdown and loopback commands are mutually exclusive.
·     To enable this feature on an Ethernet interface, make sure the Ethernet interface operates in full duplex mode.
3.     Enable loopback testing.
loopbackinternal
With the interface alarm functions enabled, when the input or output bandwidth usage on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the input or output bandwidth usage on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
Hardware and feature compatibiity
Hardware
MSR610
Yes
Yes
No
Yes
No
Yes
Yes
Yes
MSR2600-10-X1
Yes
MSR2630-G-X1
Yes
MSR 2630
Yes
Yes
Yes
Yes
Yes
Yes
Yes
MSR-iMC
Yes
Yes
Yes
Yes
MSR3640-G
Yes
MSR3640-X1-HI
No
Hardware
Yes
MSR830-4LM-WiNet
No
Yes
Yes
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3620-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2600-15-X1-XS
Yes
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
No
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
Yes
You can configure the error packet alarm parameters in system view and interface view.
·     The configuration in system view takes effect on all interfaces. The configuration in interface view takes effect only on the current interface. (Devices that do not support the slot keyword.)
·     The configuration in system view takes effect on all interfaces of the specified slot. The configuration in interface view takes effect only on the current interface. (Devices that support the slot keyword.)
·     For an interface, the configuration in interface view takes priority, and the configuration in system view is used only when no configuration is made in interface view.
An interface that is shut down because of error packet alarms cannot automatically recover. To bring up the interface, execute the undo shutdown command on the interface.
Enabling interface alarm functions
2.     Enable alarm functions for the interface monitoring module.
snmp-agent trap enable ifmonitor [ input-usage | output-usage ] *
By default, all alarm functions are enabled for interfaces.
Configuring input bandwidth usage alarm parameters
2.     Configure global input bandwidth usage alarm parameters.
In standalone mode:
ifmonitor input-usage high-threshold high-value low-threshold low-value
In IRF mode:
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
By default, the upper threshold is 90 and the lower threshold is 80 for input bandwidth usage alarms.
4.     Configure input bandwidth usage alarm parameters.
By default, an interface uses the global input bandwidth usage alarm parameters. Support for this feature varies by device model. For more information, see Interface Command Reference.
Configuring output bandwidth usage alarm parameters
2.     Configure global output bandwidth usage alarm parameters.
In standalone mode:
ifmonitor output-usage high-threshold high-value low-threshold low-value
In IRF mode:
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
By default, the upper threshold is 90 and the lower threshold is 80 for output bandwidth usage alarms.
4.     Configure output bandwidth usage alarm parameters.
By default, an interface uses the global output bandwidth usage alarm parameters. Support for this feature varies by device model. For more information, see Interface Command Reference.
This feature allows you to shut down all physical interfaces except the management Ethernet interfaces and IRF physical interfaces on a device. Physical interfaces shut down by using this command are in ADM state.
To shut down all physical interfaces or the specified interface, execute the shutdown all-physical-interfaces command in system view or execute the shutdown command in interface view.
To bring up a shutdown interface, execute the undo shutdown all-physical-interfaces command in system view and execute the undo shutdown command in interface view.
If you execute this command with the include irf-physical-interface keyword multiple times, this command shuts down all physical interfaces except the management Ethernet interfaces on the device.
2.     Shut down all physical interfaces.
shutdown all-physical-interfaces [ include irf-physical-interface ]
By default, physical interfaces are up.
CAUTION
CAUTION:
This feature might interrupt ongoing network services. Make sure you are fully aware of the impacts of this feature when you use it in a live network.
This feature might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
2.     Enter Ethernet interface view or Ethernet subinterface view.
3.     Restore the default settings for the interface.
default
By default, speed autonegotiation enables an Ethernet interface to negotiate with its peer for the highest speed that both ends support. You can narrow down the speed option list for negotiation.
Figure 2 Speed autonegotiation application scenario
As shown in Figure 2:
·     All interfaces on the device are operating in speed autonegotiation mode, with the highest speed of 1000 Mbps.
·     Port D provides access to the Internet for the servers.
If the transmission rate of each server in the server cluster is 1000 Mbps, their total transmission rate exceeds the capability of Port D.
To avoid congestion on Port D, configure 100 Mbps as the only option available for speed negotiation on interfaces Port A, Port B, and Port C. As a result, the transmission rate on each interface connected to a server is limited to 100 Mbps.
Models
MSR610
No
No
No
No
No
No
No
No
MSR2600-10-X1
No
MSR2630-G-X1
Yes
MSR 2630
No
No
No
No
Yes
Yes
No
MSR-iMC
No
No
No
No
MSR3640-G
No
MSR3640-X1-HI
Yes
Models
No
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
MSR3620-X1-WiNet
No
No
Models
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2600-15-X1-XS
No
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
No
MSR3640-XS
No
MSR3660-XS
Yes
Models
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
The speed and speed auto commands supersede each other, and whichever is configured last takes effect.
3.     Set speed options for autonegotiation.
speed auto { 10 | 100 | 1000 } *
By default, no speed options are set for autonegotiation.
IMPORTANT
IMPORTANT:
Fiber ports do not support the MDIX mode setting.
A physical Ethernet interface has eight pins, each of which plays a dedicated role. For example, pins 1 and 2 transmit signals, and pins 3 and 6 receive signals. You can use both crossover and straight-through Ethernet cables to connect copper Ethernet interfaces. To accommodate these types of cables, a copper Ethernet interface can operate in one of the following Medium Dependent Interface-Crossover (MDIX) modes:
·     MDIX mode—Pins 1 and 2 are receive pins and pins 3 and 6 are transmit pins.
·     MDI mode—Pins 1 and 2 are transmit pins and pins 3 and 6 are receive pins.
·     AutoMDIX mode—The interface negotiates pin roles with its peer.
This feature does not take effect on pins 4, 5, 7, and 8 of physical Ethernet interfaces.
·     Pins 4, 5, 7, and 8 of interfaces operating at 10 Mbps or 100 Mbps do not receive or transmit signals.
·     Pins 4, 5, 7, and 8 of interfaces operating at 1000 Mbps or higher rates receive and transmit signals.
To enable a copper Ethernet interface to communicate with its peer, set the MDIX mode of the interface by following these guidelines:
·     Typically, set the MDIX mode of the interface to AutoMDIX. Set the MDIX mode of the interface to MDI or MDIX only when the device cannot determine the cable type.
·     When a straight-through cable is used, configure the interface to operate in an MDIX mode different than its peer.
·     When a crossover cable is used, perform one of the following tasks:
¡     Configure the interface to operate in the same MDIX mode as its peer.
¡     Configure either end to operate in AutoMDIX mode.
3.     Set the MDIX mode of the Ethernet interface.
mdix-mode { automdix | mdi | mdix }
By default, a copper Ethernet interface operates in auto mode to negotiate pin roles with its peer.
IMPORTANT
IMPORTANT:
If the link of an Ethernet interface is up, testing its cable connection will cause the link to go down and then come up.
Fiber ports do not support this feature.
The virtual cable test (VCT) technology uses time domain reflectometry (TDR) to detect the cable status. When pulse signals are transmitted in a cable, some energy of the signals is reflected at the end or a failure point on the cable. This phenomenon is called TDR. The VCT algorithm measures the time spent in transmitting pulse signals over a cable, reaching the failure point, and returning the pulse signals. The measured time is converted into the distance.
As shown in Figure 3, GE 1/0/1 on Device A is connected to GE 1/0/1 on Device B through a cable. A failure point exists on the cable. After VCT is configured on GE 1/0/1 on Device A, the system will generate pulse signals. Some energy of the signals is reflected at the failure point on the cable. Suppose the distance from Device A to the failure point is L, the interval between sending signals and receiving reflected signals is T, and the signal transmission speed on the cable is V. Then, the distance between GE 1/0/1 on Device A and the failure point can be calculated as follows: L=(V×T)/2.
Figure 3 Schematic diagram for VCT
VCT detects the network cable failure type and identifies the failure point, facilitating failure location on network cables.
Models
MSR610
No
No
No
No
No
No
No
No
MSR2600-10-X1
No
MSR2630-G-X1
No
MSR 2630
No
No
No
No
No
No
No
MSR-iMC
No
No
No
No
MSR3640-G
No
MSR3640-X1-HI
Yes
Models
No
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
MSR3620-X1-WiNet
No
No
Models
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2600-15-X1-XS
No
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
No
MSR3640-XS
No
MSR3660-XS
Yes
Models
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
3.     Perform a test for the cable connected to the Ethernet interface.
virtual-cable-test
By default, a Layer 3 Ethernet interface does not operate in promiscuous mode. In this case, the interface accepts and processes only packets destined to the MAC address of the interface, and drops packets destined to any other MAC address.
For an interface to snoop all packets received, use this command to configure the interface to operate in promiscuous mode. In this mode, a Layer 3 Ethernet interface does not perform MAC address filtering, and accepts and processes all packets regardless whether they are destined to the MAC address of the interface.
2.     Enter Layer 3 Ethernet interface view.
3.     Configure the interface to operate in promiscuous mode.
port promiscuous-mode
By default, an interface does not operate in promiscuous mode.
The maximum transmission unit (MTU) determines the maximum number of bytes in a single IP packet that can be sent. The length of an IP packet refers to the number of bytes starting from the IP header to the payload.
When the IP layer receives an IP data packet to be sent, the IP layer determines the local destination interface of the packet and obtains the MTU of the interface. The IP layer compares the MTU with the length of the data packet to be sent. If the length is greater than the MTU, the IP layer fragments the packet. The length of a fragment can be smaller than or equal to the MTU to ensure that big packets are not lost on the network.
As a best practice, use the default MTU. When the packet length or the packet receiver changes, you can adjust the MTU as needed. When configuring the MTU, follow these restrictions and guidelines:
·     If the configured MTU is small but the packet length is large, the following events might occur:
¡     Packets will be dropped when they are forwarded by hardware.
¡     Packets will be fragmented into too many fragments when packets are forwarded through the CPUs, which affects normal data transmission.
·     If the configured MTU is too large, the MTU will exceed the receiving capabilities of the receiver or a device along the transmission path. As a result, packets will be fragmented or even dropped, which increases the network transmission load and affects data transmission.
The MTU of an Ethernet interface affects the fragmentation and reassembly of IP packets on the interface. Typically, you do not need to modify the MTU of an interface.
2.     Enter interface view.
3.     Set the interface MTU.
mtu size
The default setting is 1500 bytes.
In a network, when the Layer 3 Ethernet interfaces of different devices have the same MAC address, the devices might fail to communicate correctly. To eliminate the MAC address conflicts, use the mac-address command to modify the MAC addresses of Layer 3 Ethernet interfaces.
3.     Set the interface MAC address.
mac-address mac-address
By default, no MAC address is set for a Layer 3 Ethernet interface.
2.     Enter Layer 3 Ethernet subinterface view.
3.     Enable statistics collection on the Layer 3 Ethernet subinterface.
traffic-statistic enable
By default, statistics collection is disabled on a Layer 3 Ethernet subinterface.
4.     (Optional.) Display the subinterface traffic statistics.
display counters
Display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
Display traffic rate statistics of interfaces in up state over the last statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
Display the Ethernet module statistics.
In standalone mode:
display ethernet statistics
In IRF mode:
display ethernet statistics slot slot-number
Display the operational and status information of the specified interfaces.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
Display the status and packet statistics of interfaces.
display interface link-info [ main ]
Display operating status and information of all interfaces except subinterfaces.
display interface [ interface-type ] [ brief [ description | down ] ] main
Display information about link flapping protection on interfaces.
display link-flap protection [ interface interface-type [ interface-number ] ]
Display the link state change statistics of interfaces.
display link-state-change statistics interface [ interface-type [ interface-number ] ]
Clear interface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
Clear the Ethernet module statistics.
In standalone mode:
reset ethernet statistics
In IRF mode:
reset ethernet statistics [ slot slot-number ]
Clear the link state change statistics of interfaces.
reset link-state-change statistics interface [ interface-type [ interface-number ] ]
On the device, some Ethernet interfaces can operate only as Layer 2 Ethernet interfaces (in bridge mode). Some can operate only as Layer 3 Ethernet interfaces (in route mode). Some can operate either as Layer 2 or Layer 3 Ethernet interfaces. You can set the link mode to bridge or route for these Ethernet interfaces by using the port link-mode command.
·     Layer 2 Ethernet interfaces support Layer 2 features such as MAC address table, port isolation, VLAN, and spanning tree.
·     Layer 3 Ethernet interfaces support Layer 3 features such as static routing, OSPF, IS-IS, and BGP.
·     If an interface supports link mode switch, you can successfully issue the port link-mode command. If an interface does not support link mode switch, the system displays a message when you execute the port link-mode command.
The following compatibility matrixes show the support of link mode switchover for fixed interfaces on the device panel:
Table 1 Hardware compatibility with Layer 2 and Layer 3 interfaces
Hardware
Compatibility
MSR610
The following interfaces support link mode switchover: GE0 through GE4, SFP5.
·     The following interfaces on the MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, and MSR810-LM-EI support link mode switchover: GE0 through GE4, SFP5.
·     The following interfaces on the MSR810-10-PoE support link mode switchover: GE2 through GE9.
·     The following interfaces on the MSR810-10-PoE can operate only in Layer 3 mode: GE0, Combo 1 (GE1, SFP1).
The following interfaces support link mode switchover: FE0 through FE3.
·     The following interfaces support link mode switchover: GE1 through GE4.
·     The following interfaces can operate only in Layer 3 mode: GE0, SFP5, SFP6.
·     The following interfaces support link mode switchover: GE2 through GE5.
·     The following interfaces can operate only in Layer 3 mode: GE0 and GE1.
·     The following interfaces on the MSR2600-6-X1 support link mode switchover: GE1 through GE4.
·     The following interfaces on the MSR2600-15-X1 and MSR2600-15-X1-T support link mode switchover: GE5 through GE12.
·     The following interfaces on the MSR2600-6-X1 can operate only in Layer 3 mode: GE0 and SFP5.
·     The following interfaces on the MSR2600-15-X1 and 2600-15-X1-T support link mode switchover: GE0 through GE4, SFP13, SFP14.
MSR2600-10-X1
·     The following interfaces support link mode switchover: GE2 through GE9.
MSR2630-G-X1
·     The following interfaces support link mode switchover: GE5 through GE20, SFP+21, SFP+22.
·     The following interfaces can operate only in Layer 3 mode: GE0 through GE4.
MSR 2630
·     The following interfaces on the MSR3600-28 support link mode switchover: 1000M Ethernet copper ports GE3 through GE26, 1000M Ethernet fiber port SFP27.
·     The following interfaces on the MSR3600-51 support link mode switchover: 1000M Ethernet copper ports GE3 through GE50.
·     The following interfaces on the MSR3600-28 and MSR3600-51 can operate only in Layer 3 mode: GE0 through GE2.
·     The following interfaces on the MSR3600-28-SI support link mode switchover: 100M Ethernet copper ports FE3 through FE26.
·     The following interfaces on the MSR3600-51-SI support link mode switchover: 100M Ethernet copper ports FE3 through FE50.
·     The following interfaces on the MSR3600-28-SI can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE2, 1000M Ethernet fiber port SFP27.
·     The following interfaces on the MSR3600-51-SI can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE2, 1000M Ethernet fiber port SFP51.
·     The following interfaces on the MSR3600-28-X1 and MSR3600-28-X1-DP support link mode switchover: 1000M Ethernet copper ports GE3 through GE26.
·     The following interfaces on the MSR3600-51-X1 and MSR3600-51-X1-DP support link mode switchover: 1000M Ethernet copper ports GE3 through GE50.
·     The following interfaces on the MSR3600-28-X1 and MSR3600-28-X1-DP can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE2, 1000M Ethernet fiber ports SFP27 and SFP28.
·     The following interfaces on the MSR3600-51-X1 and MSR3600-51-X1-DP can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE2, 1000M Ethernet fiber ports SFP51 and SFP52.
·     The following interfaces on the MSR3600-28-G-DP support link mode switchover: 1000M Ethernet copper ports GE5 through GE28, 10G Ethernet fiber ports SFP+29 through SFP+36.
·     The following interfaces on the MSR3600-51-G-DP support link mode switchover: 1000M Ethernet copper ports GE5 through GE52, 10G Ethernet fiber ports SFP+53 and SFP+54.
·     The following interfaces on the MSR3600-28-G-DP and MSR3600-51-G-DP can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE4.
·     The following interfaces on the MSR3600-28-G-X1-DP support link mode switchover: 1000M Ethernet copper ports GE5 through GE36, 10G Ethernet fiber ports SFP+37 and SFP+38.
·     The following interfaces on the MSR3600-51-G-X1-DP support link mode switchover: 1000M Ethernet copper ports GE5 through GE52, 10G Ethernet fiber ports SFP+53 and SFP+54.
·     The following interfaces on the MSR3600-28-G-X1-DP and MSR3600-51-G-X1-DP can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE4.
·     The following interfaces support link mode switchover: GE2 through GE7.
·     The following interfaces can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1).
MSR-iMC
·     The following interfaces on the MSR3620-X1 support link mode switchover: 1000M Ethernet copper ports GE8 through GE15, 10G Ethernet fiber ports SFP+20 and SFP+21.
·     The following interfaces on the MSR3640-X1 support link mode switchover: 1000M Ethernet copper ports GE1 through GE8, 10G Ethernet fiber ports SFP+12 and SFP+13.
·     The following interfaces on the MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, and MSR3610-X1-DP-DC can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0, GE1, Combo 2 (GE2, SFP2), 1000M Ethernet fiber ports SFP4 and SFP5.
·     The following interfaces on the MSR3620-X1 can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE7, 10G Ethernet fiber ports SFP+16 through SFP+19.
·     The following interfaces on the MSR3640-X1 can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), 10G Ethernet fiber ports SFP+9 through SFP+11.
·     The following interfaces on the MSR 3610 and MSR 3620 can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), 1000M Ethernet copper ports GE1 and GE2.
·     The following interfaces on the MSR 3620-DP can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE3 (combo),1000M Ethernet fiber ports SFP0 through SFP3 (combo), 1000M Ethernet fiber ports SFP4 and SFP5.
·     The following interfaces on the MSR 3640 and MSR 3660 can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), 1000M Ethernet copper port GE2.
The following interfaces can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE7 (combo), 1000M Ethernet fiber ports SFP0 through SFP7 (combo).
MSR3640-G
·     MSR3640-G (0235A4G9): The following interfaces can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), GE Ethernet copper ports GE2 through GE9, 10G Ethernet fiber ports SFP+10 through SFP +15.
·     MSR3640-G (0235A4W8): The following interfaces support link mode switchover: Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), GE Ethernet copper ports GE2 through GE9, 10G Ethernet fiber ports SFP+10 through SFP +15.
MSR3640-X1-HI
·     The following interfaces support link mode switchover: 1000M Ethernet copper ports GE1 through GE9, 10G Ethernet fiber ports SFP+10 through SFP+25, SFP28 fiber ports 26 through 29.
·     The following interfaces can operate only in Layer 3 mode: 1000M Ethernet fiber port GE0.
Hardware
Compatibility
MSR830-4LM-WiNet
·     The following interfaces on the MSR830-5BEI-WiNet support link mode switchover: GE2 through GE4.
·     The following interfaces on the MSR830-6EI-WiNet support link mode switchover: GE2 through GE5.
·     The following interfaces on the MSR830-10BEI-WiNet support link mode switchover: GE2 through GE9.
·     The following interfaces on the MSR830-5BEI-WiNet, MSR830-6EI-WiNet, and MSR830-10BEI-WiNet support link mode switchover: GE0 and GE1.
·     The following interfaces on the MSR830-6BHI-WiNet support link mode switchover: GE2 through GE5.
·     The following interfaces on the MSR830-10BHI-WiNet support link mode switchover: GE1, GE2, Combo 3 (GE3, SFP3), GE4 through GE9.
·     The following interfaces on the MSR830-6BHI-WiNet support link mode switchover: Combo 0 (GE0, SFP0), GE1.
·     The following interfaces on the MSR830-10BHI-WiNet can operate only in Layer 3 mode: GE0.
MSR2600-6-WiNet
·     The following interfaces can operate only in Layer 3 mode: GE0 and SFP5.
MSR2600-10-X1-WiNet
MSR2630-WiNet
MSR3600-28-WiNet
·     The following interfaces support link mode switchover: 1000M Ethernet copper ports GE3 through GE26, 1000M Ethernet fiber port SFP27.
·     The following interfaces can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE2.
MSR3610-X1-WiNet
The following interfaces can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 and GE1, Combo 2 (GE2, SFP2), Combo 3 (GE3, SFP3), 1000M Ethernet fiber ports SFP4 and SFP5.
MSR3620-X1-WiNet
·     The following interfaces support link mode switchover: 1000M Ethernet copper ports GE8 through GE15, 10G Ethernet fiber ports SFP+20 and SFP+21.
·     The following interfaces can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE7, 10G Ethernet fiber ports SFP+16 through SFP+19.
·     The following interfaces on the MSR3610-WiNet, MSR3620-10-WiNet, and MSR3620-WiNet can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), 1000M Ethernet copper ports GE1 and GE2.
·     The following interfaces on the MSR3620-DP-WiNet can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE3 (combo),1000M Ethernet fiber ports SFP0 through SFP3 (combo), 1000M Ethernet fiber ports SFP4 and SFP5.
·     The following interfaces on the MSR3660-WiNet can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), 1000M Ethernet copper port GE2.
Hardware
Compatibility
MSR860-6EI-XS
MSR860-6HI-XS
·     The following interfaces can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), GE1.
MSR2600-15-X1-XS
·     The following interfaces support link mode switchover: GE5 through GE12.
·     The following interfaces can operate only in Layer 3 mode: GE0 through GE4, SFP13, SFP14.
MSR2630-XS
MSR3600-28-XS
·     The following interfaces support link mode switchover: 1000M Ethernet copper ports GE3 through GE26.
·     The following interfaces can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE2, 1000M Ethernet fiber ports SFP27 and SFP28.
MSR3610-XS
MSR3620-XS
The following interfaces can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE3 (combo),1000M Ethernet fiber ports SFP0 through SFP3 (combo), 1000M Ethernet fiber ports SFP4 and SFP5.
MSR3610-I-XS
MSR3610-IE-XS
MSR3620-X1-XS
MSR3640-XS
·     The following interfaces support link mode switchover: 1000M Ethernet copper ports GE1 through GE8.
·     The following interface can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), 1000M Ethernet fiber ports SFP9 and SFP10, 10G Ethernet fiber ports SFP+11 through SFP +13.
MSR3660-XS
·     The following interfaces support link mode switchover: 1000M Ethernet copper ports 1 through 9, 10G Ethernet fiber ports SFP+10 through SFP+29.
Hardware
Compatibility
MSR810-LM-GL
MSR810-W-LM-GL
MSR830-6EI-GL
MSR830-10EI-GL
MSR830-6HI-GL
MSR830-10HI-GL
·     The following interfaces support link mode switchover: GE1, GE2, Combo 3 (GE3, SFP3), GE4 through GE9.
·     The following interfaces can operate only in Layer 3 mode: GE0.
MSR1004S-5G-GL
MSR2600-6-X1-GL
MSR3600-28-SI-GL
·     The following interfaces support link mode switchover: 100M Ethernet copper ports FE3 through FE26.
·     The following interfaces can operate only in Layer 3 mode: 1000M Ethernet copper ports GE0 through GE2, 1000M Ethernet fiber port SFP27.
