- 12-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-NTP commands
- 05-PTP commands
- 06-SNMP commands
- 07-RMON commands
- 08-EPA commands
- 09-CWMP commands
- 10-EAA commands
- 11-Process monitoring and maintenance commands
- 12-Sampler commands
- 13-Mirroring commands
- 14-NetAnalysis commands
- 15-sFlow commands
- 16-Information center commands
- 17-Packet capture commands
- 18-VCF fabric commands
- 19-NetStream commands
- 20-IPv6 NetStream commands
- 21-eMDI commands
- 22-Performance management commands
- 23-SQA commands
- 24-TCP connection trace commands
- 25-SmartMC commands
- 26-NETCONF commands
- 27-ISDF commands
- 28-Quicknet commands
| 27-ISDF commands | 46.08 KB |
ISDF commands
bind unified-flow-instance
Use bind unified-flow-instance to bind a UFA instance to ISDF and enter UFA instance view. or enter the view of a bound UFA instance.
Use undo bind unified-flow-instance to unbind between a UFA instance from ISDF.
bind unified-flow-instance instance-id
undo bind unified-flow-instance instance-id
No UFA instance is bound to ISDF.
ISDF view
instance-id: Specifies a UFA instance by its ID in the range of 1 to 2048.
After you create a UFA instance and enable the ISDF packet loss detection feature, you must execute this command to bind ISDF to the UFA instance for ISDF to take effect.
# Bind UFA instance 1 to ISDF and enter UFA instance view.
[Sysname] isdf enable
[Sysname-isdf] bind unified-flow-instance 1
[Sysname-isdf-instance-1]
isdf enable
Use isdf enable to enable ISDF and enter ISDF view, or enter ISDF view.
Use undo isdf enable to disable ISDF.
enable
undo isdf enable
ISDF is disabled.
When a network link fails, traditional routing convergence technologies based on the control plane dynamic routing protocols (for example, BGP and OSPF) can achieve convergence times in the hundreds of milliseconds. This cannot meet the stringent network performance requirements of services such as online transactions and autonomous driving. The ISDF technology can solve this problem.
Instant Silent-Fault Detection and Failover (ISDF) is a fully data plane-based fault detection and recovery technology. It represents a technological evolution from reliance on CP protocol interaction for convergence to real-time fault detection and rapid path switchover-based convergence in the DP. By using DP fault detection, remote fault advertisement, and fast-path switchover mechanisms, ISDF achieves millisecond-level network convergence, significantly improving network reliability and data transmission efficiency.
# Enable ISDF and enter ISDF view.
[Sysname-isdf]
reroute enable
Use reroute enable to enable ISDF reroute.
Use undo reroute enable to disable ISDF reroute.
reroute enable
undo reroute enable
ISDF reroute is disabled.
ISDF view
With this feature enabled, the device will adjust the traffic forwarding path in real time based on the received remote fault advertisement message, automatically mitigate faulty links, and ensure service recovery within milliseconds.
# Enable ISDF reroute.
[Sysname-isdf] reroute enable
reroute-advertise enable
Use reroute-advertise enable to enable fault advertising for ISDF reroute.
Use undo reroute-advertise enable to disable fault advertising for ISDF reroute.
Fault advertising for ISDF reroute is disabled.
Bound UFA instance view
With this feature enabled, the device will send a fault advertisement to the upstream device when it detects a fault. Upon receiving the fault advertisement, the upstream device will perform a traffic forwarding path switchover, enabling rapid fault detection and recovery.
# Enable fault advertising for ISDF reroute.
[Sysname-isdf-instance-1] reroute-advertise enable
