| 01-Network slicing commands | 131.53 KB |
display network-slice bandwidth usage statistics
display network-slice binding-list
display network-slice instance
display network-slice nsi-mapping slice-id
display network-slice statistics
reset network-slice statistics
NOTE: Network slicing is available only on the S5130S-HI-G or S5130S-EI-G-V2 series switches. |
description
Use description to configure a description for a network slice instance (NSI).
No description is configured for an NSI.
NSI view
text: Specifies the description for the NSI, a case-sensitive string of 1 to 80 characters.
# Specify the description as specific-instance for NSI 1.
[Sysname] network-slice
[Sysname-network-slice] instance 1
[Sysname-network-slice-instance-1] description specific-instance
Use display network-slice bandwidth usage statistics to display the bandwidth usage of network slices on interfaces.
display network-slice bandwidth usage statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays bandwidth usage of network slices on all interfaces.
# Display the bandwidth usage of network slices on all interfaces.
<Sysname> display network-slice bandwidth usage statistics
Network slice bandwidth usage of interface
GigabitEthernet1/0/1
Total bandwidth : 1000 Mbps
Network slice bandwidth : 850 Mbps
Channelization bandwidth : 100 Mbps
Remaining bandwidth : 50 Mbps
Network slice bandwidth usage of interface |
Bandwidth usage information for network slices on a base interface. |
Total Bandwidth |
Total bandwidth of the interface. |
Network slice bandwidth |
Bandwidth used by network slices on the current interface. |
Channelization bandwidth |
Bandwidth used by slicing interfaces on the base interface. |
Remaining bandwidth |
Remaining bandwidth of the current interface. |
slice-id flex-channel
Use display network-slice binding-list to display the associations between NSIs and interfaces.
display network-slice binding-list [ slice-id slice-instance-id ] [ interface interface-type interface-number ]
slice-id slice-instance-id: Specifies an NSI by its ID. The value range for the slice-instance-id argument is 0 to 6. If you configure the value as 0, the configuration does not take effect. If you do not specify an NSI, this command displays associated interfaces for all NSIs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays NSI information for all interfaces.
# Display interfaces associated with NSI 1.
<Sysname> display network-slice binding-list slice-id 1
Slice ID Interface State
1 GigabitEthernet1/0/1 Active
GigabitEthernet1/0/1.1 Active
Slice ID |
ID of the NSI. |
Interface associated with the NSI. |
State |
Active state: · Active—The network slice channel is issued to the driver successfully. · Inactive—Failed to issue the network slice channel to the driver. |
Use display network-slice instance to display network slice configuration information.
display network-slice instance [ slice-id slice-id ]
slice-id slice-id: Specifies an NSI by its ID. The value range for the slice-id argument is 0 to 6. If you configure the value as 0, the configuration does not take effect. If you do not specify an NSI, this command displays configuration information for all network slices.
# Display configuration information for all network slices.
<Sysname> display network-slice instance
Total number: 2
Statistics : Enabled
Statistics interval(s) : 100
Slice ID Priority Queue buffer class
1 0 4
2 0 3
Total number |
Total number of network slices. |
Statistics |
Enabling status for network slice packet statistics: · Enabled. · Disabled. |
Statistics interval |
Interval for network slice packet statistics, in seconds. |
Slice ID |
ID of the NSI. |
Priority |
This field is not supported in the current software version. Scheduling priority for the network slice channel. |
Queue buffer class |
Class of the queue buffer. |
queue-buffer-class
Use display network-slice nsi-mapping slice-id to display binding information for a specific NSI.
display network-slice nsi-mapping slice-id slice-id
# Display bind information for NSI 1.
<Sysname> display network-slice nsi-mapping slice-id 1
index : 3
type : dscp
value : 1 3 4 to 8 10 11 to 30
replace dscp : 10
index |
Bound attribute index. |
type |
Attribute type bound to the NSI. Options include: · dscp · vlan · interface |
value |
Attribute value bound to the NSI. |
replace dscp |
DSCP value to be replaced. If the DSCP value is not replaced, a hyphen (-) is displayed. |
index binding-type
Use display network-slice statistics to display network slice packet statistics.
display network-slice statistics [ slice-id slice-instance-id ] [ interface interface-type interface-number ] [ verbose ]
slice-id slice-instance-id: Specifies an NSI by its ID. The value range for the slice-instance-id argument is 0 to 6. If you configure the value as 0, the configuration does not take effect. If you do not specify an NSI, this command displays network slice packet statistics for all NSIs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this displays network slice packet statistics for all interfaces.
verbose: Displays detailed network slice packet statistics. If you do not specify this keyword, this command displays brief network slice packet statistics.
# Display brief network slice packet statistics for NSI 1.
<Sysname> display network-slice statistics slice-id 1 interface gigabitethernet 1/0/1
Network slice statistics
Interface : GigabitEthernet1/0/1
Slice ID : 1
[total]
Pass: 42,430,945 packets, 7,298,122,540 bytes
Discard: 2,368,695,114 packets, 407,415,559,608 bytes
Last 50 seconds pass rate:
72,498 pps, 99,757,056 bps
Last 50 seconds discard rate:
4,048,135 pps, 5,570,233,752 bps
Last 5 seconds pass rate:
7298 pps, 99,757,056 bps
Last 5 seconds discard rate:
4148,135 pps, 5,570,233,752 bps
Table 5 Command output
Network slice statistics |
Network slice packet statistics. |
Interface with network slicing enabled. |
SliceID |
ID of the NSI. |
total |
Total packet statistics for all service classes. |
Pass |
Number of packets and bytes that have passed through. |
Discard |
Number of packets and bytes discarded. |
Last m seconds pass rate |
Number of packets and bits that have passed through per second during the last m seconds. Value m equals 10 times the collection interval. You can use the statistics interval command to set the collection interval. |
Last m seconds discard rate |
Number of packets and bits discarded per second during the last m seconds. Value m equals 10 times the collection interval. You can use the statistics interval command to set the collection interval. |
Last n seconds pass rate |
Number of packets and bits that have passed through per second during the last n seconds. Value n equals the collection interval. You can use the statistics interval command to set the collection interval. |
Last n seconds discard rate |
Number of packets and bits discarded per second during the last n seconds. Value n equals the collection interval. You can use the statistics interval command to set the collection interval. |
statistics interval
index binding-type
Use index binding-type to bind packets to NSI IDs.
Use undo index binding-type to delete the bindings between packets and NSI IDs.
index index-value binding-type { dscp { dscp-startvalue [ to dscp-endvalue ] } &<1-32> | interface interface-type interface-number | vlan { vlan-startvalue [ to vlan-endvalue ] } &<1-32> } slice slice-id [ replace dscp dscp-value ]
undo index index-value binding-type
The bindings between packets and NSI IDs are not configured. That is, no packets are scheduled or forwarded through the network slice channels identified by NSI IDs on an interface.
NSI-to-packet mapping view
index-value: Specifies an index for the binding between packets and NSI ID. The value range for this argument is 1 to 65535.
dscp { dscp-startvalue [ to dscp-endvalue ] } &<1-32>: Specifies DSCP values or value ranges. Packets carrying the specified DSCP values will be scheduled and forwarded in the network slice channel identified by the specified NSI ID. The dscp-startvalue argument specifies the start DSCP value in the range of 0 to 63. The dscp-endvalue argument specifies the end DSCP value in the range of 0 to 63. The end DSCP value cannot be smaller than the start DSCP value. To specify a single DSCP value, do not specify the to dscp-endvalue option. & <1-32> indicates that you can specify up to 32 DSCP values or value ranges.
interface interface-type interface-number: Specifies an interface by its type and number. Packets received on this interface will be scheduled and forwarded in the network slice channel identified by the specified NSI ID.
vlan { vlan-startvalue [ to vlan-endvalue ] } &<1-32>: Specifies VLAN IDs or VLAN ID ranges. Packets carrying the specified VLAN IDs will be scheduled and forwarded in the network slice channel identified by the specified NSI ID. The vlan-startvalue argument specifies the start VLAN ID in the range of 1 to 4094. The vlan-endvalue argument specifies the end VLAN ID in the range of 1 to 4094. The end VLAN ID cannot be smaller than the start VLAN ID. To specify a single VLAN ID, do not specify the to vlan-endvalue option. & <1-32> indicates that you can specify up to 32 VLAN IDs or VLAN ID ranges.
slice slice-id: Specifies an NSI by its ID in the range of 0 to 6. If you configure the value as 0, the configuration does not take effect.
replace dscp dscp-value: Replaces the DSCP value in matching packets with the specified value.
Operating mechanism
With this feature configured, the device binds the specified packets to NSI IDs. When forwarding the packets through an output interface, the device searches for the network slice channel configured on the output interface. The device then schedules and forwards the packets through the network slice channel identified by the bound NSI ID. If no network slice channel identified by the bound NSI ID exists on the output interface, the device forwards the packets according to routing table lookup.
You can repeatedly execute the index binding-type command to configure multiple bindings between packets and NSI IDs identified by different index-value values. Upon receiving a packet, the system compares it with packet match criteria in ascending order of index values specified with the index binding-type command. If a match is found, the system does not continue to compare the packet with other bindings.
If you repeatedly execute the index binding-type command and specify the same index value, the most recent configuration takes effect.
If you bind a DSCP/VLAN value or interface to an NSI ID, you cannot bind the DSCP/VLAN value or interface to any other NSI IDs.
In the current software version, only Layer 2 Ethernet interfaces, Layer 2 aggregate interfaces, and Layer 3 Ethernet interfaces support scheduling and forwarding the packets through the network slice channel identified by the bound NSI ID.
# Configure two bindings between packets and NSI IDs:
· Binding 1: Binds packets carrying DSCP values 10 through 20 to NSI ID 1. The device schedules and forwards matching packets through the network slice channel identified by NSI ID 1.
· Binding 2: Binds packets carrying VLANs 10 through 20 to NSI ID 2. The device schedules and forwards matching packets through the network slice channel identified by NSI ID 2, and replaces the DSCP values in the packets with 63.
[Sysname-network-slice] nsi-mapping
[Sysname-network-slice-nsi-mapping] index 1 binding-type dscp 10 to 20 slice 1
[Sysname-network-slice-nsi-mapping] index 2 binding-type vlan 10 to 20 slice 2 replace dscp 63
instance (network slice view)
Use instance to create an NSI and enter its view or enter the view of an existing NSI.
Use undo instance to delete the specified NSI.
instance slice-instance-id
undo instance slice-instance-id
No NSIs exist.
Network slice view
slice-instance-id: Specifies an NSI ID. The value range for the slice-instance-id argument is 0 to 6. If you configure the value as 0, the configuration does not take effect.
If an NSI is associated with an interface through the slice-id flex-channel command, use the undo slice-id flex-channel command to cancel the association before you delete the NSI.
# Create NSI 1 and enter its view.
network-slice (system view)
Use network-slice to enable network slicing and enter network slice view.
Use undo network-slice to disable network slicing.
network-slice
undo network-slice
Network slicing is disabled.
You can configure network slicing settings in network slice view.
# Enable network slicing and enter network slice view.
network-slice enable
Use network-slice enable to enable network slicing for an interface and enter network slice view of the interface.
Use undo network-slice enable to disable network slicing for an interface.
Network slicing is disabled for an interface.
Interface view
An interface with network slicing enabled forwards packets carrying an NSI ID through a network slice channel (matching the NSI ID) on the interface.
If you configure the network-slice enable command to enable network slicing for the interface, you cannot add the interface to a link aggregate group.
In the current software version, this command is not supported by Layer 3 aggregate interfaces and their member ports (including the associated Layer 3 aggregate subinterfaces).
# Enable network slicing for GigabitEthernet1/0/1 and enter network slice view of the interface.
[Sysname-GigabitEthernet1/0/1] network-slice enable
[Sysname-GigabitEthernet1/0/1-network-slice]
nsi-mapping
Use nsi-mapping to create and enter NSI-to-packet mapping view.
Use undo nsi-mapping to delete the NSI-to-packet mapping view and all settings in NSI-to-packet mapping view.
nsi-mapping
undo nsi-mapping
No NSI-to-packet mapping view exists.
Network slice view
You can configure bindings between packets and NSI IDs only in NSI-to-packet mapping view created with this command.
# Create and enter NSI-to-packet mapping view.
queue-buffer-class
Use queue-buffer-class to configure queue buffer class for a network slice channel.
Use undo queue-buffer class to restore the default.
queue-buffer-class number
undo queue-buffer-class
The queue buffer class for a network slice channel is 7.
NSI view
number: Specifies a queue buffer class by its number for a network slice channel. The value range for this argument is 0 to 10. The greater the number, the larger the available buffer space.
Operating mechanism
The queue buffer size on the output interface is fixed. The higher the queue buffer class, the larger the buffer space available for packets in the network slice channel. If network congestion occurs on the output interface, packets are less likely to be discarded when a larger buffer space is available.
For applications that are sensitive to packet loss, you can set a larger queue buffer class to reduce the packet loss probability.
As a best practice, do not manually adjust this parameter setting.
# Configure the queue buffer class as 3 for a network slice channel.
[Sysname-network-slice-instance-1] queue-buffer-class 3
Use reset network-slice statistics to clear network slice packet statistics.
reset network-slice statistics [ slice-id slice-instance-id ] [ interface interface-type interface-number ]
slice-id slice-instance-id: Specifies an NSI by its ID. The value range for the slice-instance-id argument is 0 to 6. If you configure the value as 0, the configuration does not take effect. If you do not specify an NSI, this command clears network slice packet statistics for all NSIs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears network slice packet statistics for all interfaces.
# Clear network slice packet statistics for NSI 2.
<Sysname> reset network-slice statistics slice-id 2
Use slice-id flex-channel to create a network slice channel for an interface, and specify the bandwidth for the network slice channel.
Use undo slice-id flex-channel to remove a network slice channel from an interface.
slice-id slice-instance-id flex-channel flex-channel-value
undo slice-id slice-instance-id flex-channel
No network slice channels are configured on an interface.
Network slice view of the interface
slice-instance-id: Specifies an NSI by its ID associated with the network slice channel. The value range for the slice-instance-id argument is 0 to 6. If you configure the value as 0, the configuration does not take effect.
flex-channel bandwidth-value: Specifies the bandwidth for the network slice channel, in the range of 1 to 4294967295, in Mbps.
Operating mechanism
The device allocates independent scheduling queue resources for network slice channels on the interface. Packets matching an NSI ID are forwarded through the associated network slice channel. The bandwidth specified for the network slice channel created on the interface serves as both the guaranteed bandwidth and the upper limit for the channel. Traffic exceeding this bandwidth is processed by traffic shaping for buffering.
The NSI ID specified in this command must already be created with the instance command.
You can configure multiple network slice channels for an interface.
# Binding interface GigabitEthernet1/0/1 to NSI ID 1, create a network slice channel, and set the bandwidth to 50 Mbps for the network slice channel.
[Sysname-GigabitEthernet1/0/1-network-slice] slice-id 1 flex-channel 50
statistics enable
Use statistics enable to enable network slice packet statistics.
Use undo statistics enable to disable network slice packet statistics.
statistics enable
Network slice packet statistics is disabled.
Network slice view
With network slice packet statistics enabled, you can use the display network-slice statistics command to display statistics of packets forwarded through the specified network slice.
After you create a mapping rule by executing the index binding-type command in NSI-to-packet mapping view, packets can be assigned to the configured slice. At this point, you must execute the slice-id flex-channel command for the interface to configure the network slice channel for the interface, so that packets can be counted for the corresponding network slice channel. Without the configuration, no slice channel is configured, and the network slice traffic data cannot be collected.
# Enable network slice packet statistics.
[Sysname-network-slice] statistics enable
statistics interval
Use statistics interval to set the interval for collecting network slice packet statistics.
Use undo statistics interval command to restore the default.
statistics interval time
The device collects network slice packet statistics at 30-second intervals.
Network slice view
time: Specifies an interval in the range of 5 to 65535 seconds.
# Set the interval to 100 seconds for collecting network slice packet statistics.
[Sysname-network-slice] statistics interval 100
statistics enable
