04-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5100[S5500]-D-G&S5130S-G[-V2] Configuration Guides-R8336Pxx-6W10004-Layer 3—IP Services Configuration Guide
05-mDNS gateway configuration
05-mDNS gateway configuration 215.57 KB
Configuring mDNS gateway
About mDNS gateway
A Multicast Domain Name System (mDNS) gateway can be deployed in a large-scale network to enable inter-VLAN mDNS service discovery.  It records a list of available services in the network, responds to service queries from mDNS clients, and performs active mDNS service discovery as well as access control.
mDNS network model
As shown in Figure 1, an mDNS network contains mDNS endpoint devices, mDNS service providers, the mDNS gateway, and mDNS relays.
Figure 1 mDNS networking model
An mDNS endpoint device obtains services from mDNS service providers. Examples are iPhones and iPads.
An mDNS service provider provides services for mDNS endpoint devices. Examples are mDNS-capable printers and Apple TVs.
mDNS gateway
The mDNS gateway records available services advertised by mDNS service providers and responds to queries from mDNS endpoint devices. With mDNS gateway enabled, Device B in Figure 1 can act as the mDNS gateway to help mDNS endpoint devices discover mDNS service providers in a different VLAN from the endpoint devices.
mDNS relay
An mDNS relay ensures successful mDNS communication when mDNS endpoint devices and mDNS service providers are in different subnets.
mDNS gateway functionalities
The mDNS gateway provides the following functionalities based on mDNS policies:
·     Reply mDNS queries.
·     Discover mDNS services.
An mDNS gateway policy defines user VLAN and service VLAN mappings to ensure that endpoint devices in specific VLANs can access only service providers in specific service VLANs.
Replying mDNS queries
Upon receiving mDNS queries from mDNS endpoint devices, the gateway checks its service list and sends responses that carry service information to the endpoint devices if matches are found.
Figure 2 Replying mDNS queries
As shown in Figure 2, the mDNS gateway replies mDNS queries in a VLAN-separated network as follows:
1.     mDNS service providers broadcast mDNS service responses to notify services.
2.     Upon receiving the responses, the mDNS gateway creates an mDNS service entry that records information such as service instance name and service type.
3.     The mDNS endpoint device sends an mDNS query to the mDNS gateway.
4.     The mDNS gateway searches its service list for the requested service.
¡     If a match is found, the mDNS gateway sends a response to the endpoint device directly.
¡     If no match is found, the mDNS gateway starts service discovery in the corresponding service VLANs of the user VLAN in which the endpoint device resides.
5.     The mDNS endpoint device obtains information about the service provider from the response.
Discovering mDNS services
The mDNS gateway discovers mDNS services by listening to mDNS service responses sent by mDNS service providers and then records information about the services as entries. Service providers can broadcast service responses actively or reply service responses upon requests.
After receiving a query to a service that is not in the service list, the mDNS gateway forwards the query in the corresponding service VLANs of the user VLAN. Upon receiving the query, service providers that provide the service will send responses.
Figure 3 Discovering mDNS services
As shown in Figure 3, the mDNS gateway discovers services as follows:
1.     The mDNS gateway receives a query for the printing service from the mDNS endpoint device (iPad).
2.     The mDNS gateway searches its service list for the printing service and no match is found.
3.     The mDNS gateway forwards the mDNS query to the corresponding service VLANs.
4.     Upon receiving the query, the printer sends an mDNS response.
5.     Upon receiving the response, the mDNS gateway records information about the service and sends a response to the mDNS endpoint device.
Protocols and standards
RFC 6762, Multicast DNS
mDNS gateway tasks at a glance
To configure the mDNS gateway, perform the following tasks:
1.     Enabling mDNS gateway
2.     (Optional.) Configuring an mDNS gateway policy
3.     (Optional.) Specifying the permitted service types for entry learning
4.     (Optional.) Specifying trusted mDNS devices
5.     (Optional.) Specifying the source address for mDNS packets
6.     (Optional.) Enabling mDNS gateway periodic probing
7.     (Optional.) Enabling mDNS gateway proxy forwarding
8.     (Optional.) Enabling the mDNS gateway to forward mDNS queries on the receiving port in a VLAN
9.     (Optional.) Configuring the mDNS gateway to support QinQ
2.     Enable mDNS gateway.
mdns gateway enable
By default, mDNS gateway is disabled.
With mDNS gateway policies configured, the mDNS gateway processes only the queries of mDNS endpoint devices in user VLANs configured in the policies.
2.     Create an mDNS gateway policy and enter its view.
mdns gateway policy policy-name
3.     Specify service VLANs.
service vlan vlan-id-list
By default, no service VLAN is specified.
4.     Specify user VLANs.
user vlan vlan-id-list
By default, no user VLAN is specified.
By default, the mDNS gateway can learn all mDNS services of a predefined type, which can be memory-consuming if a large number of service providers exist. You can perform this task to specify the permitted service types that can be learned by the mDNS gateway for the gateway to learn only required services.
2.     Specify a permitted service type for entry learning.
mdns gateway permit service-type { predefined-service-type | user-defined user-defined-service-type } [ max-entry-count count ]
By default, the mDNS gateway can learn all mDNS services of a pre-defined type.
To prevent security issues and resource waste caused by attacks performed by rogue mDNS devices, you can specify trustworthy mDNS relays as trusted mDNS devices. With trusted devices specified, the mDNS gateway processes only unicast queries from the trusted mDNS devices.
2.     Specify a trusted mDNS device.
mdns gateway trust device-ip ip-address [ vpn-instance vpn-instance-name ]
By default, no trusted device is specified.
About specifying the source address for mDNS packets
For responses destined for endpoint devices and mDNS queries and probe queries sent within a VLAN, the default source IP address is the primary IP address of the VLAN interface. If no IP address is configured for the VLAN interface, the mDNS gateway cannot send out the queries.
If the mDNS gateway is connected to a large number of VLANs, configuring an IP address to each VLAN interface wastes IP address resources. You can use this command to specify a specific IP address for the mDNS gateway to use.
When you configure the same source address for mDNS packets configured in different views, the configuration in the following views is in descending order of priority: VLAN view > system view.
Specifying the source address for mDNS packets in a VLAN
mdns gateway enable
3.     Enter VLAN view.
vlan vlan-id
4.     Specify the source address for mDNS packets.
mdns gateway source ip { interface interface-type interface-number | ip-address }
By default, the source IP address is the primary IP address of the VLAN interface.
You can specify only one source address for a VLAN. If you execute this command multiple times, the most recent configuration takes effect.
Specifying the source address for mDNS packets in system view
mdns gateway enable
3.     Specify the source address for mDNS packets.
By default, the mDNS gateway uses the primary IP address of the VLAN interface for packet output as the source IP address of mDNS packets.
In QinQ scenarios, as a best practice to simplify configuration and prevent the mDNS gateway from sending multiple mDNS probe queries, configure this command in system view.
About mDNS gateway periodic probing
mDNS service providers broadcast their services at network association. For the mDNS gateway to discover services offered by service providers that accessed the network earlier than the gateway, enable mDNS gateway periodic probing.
This feature enables the mDNS gateway to send mDNS probe queries at intervals. Each mDNS service provider sends a response to the gateway after receiving the query. The mDNS gateway can learn the latest service information of all mDNS service providers in the network in a timely manner.
For an mDNS device, you can enable periodic probing on its directly connected mDNS gateway or mDNS relay.
If you execute the mdns gateway probe interval command in both mDNS gateway policy view and VLAN view, the mDNS gateway will send two probe queries. As a best practice, execute the command in either of the views.
As a best practice to control periodic probing in different VLANs, configure multiple mDNS gateway policies and execute the mdns gateway probe interval command in the view of each mDNS gateway policy.
In a QinQ scenario, to avoid any impact on the device service networking capabilities due to too many mDNS multicast packets sent within a short period, configure the inner VLANs as accurately as possible.
Enabling mDNS gateway periodic probing in a VLAN
mdns gateway enable
3.     Enter VLAN view.
vlan vlan-id
4.     Enable mDNS gateway periodic probing.
mdns gateway probe interval interval
By default, mDNS gateway periodic probing is disabled.
Enabling mDNS gateway periodic probing in a mDNS gateway policy
mdns gateway enable
3.     Enter mDNS gateway policy view.
By default, mDNS gateway proxy forwarding is enabled. The mDNS gateway can send probe queries to discover mDNS service providers on the network. If you enable both mDNS gateway proxy forwarding and periodic probing, the mDNS gateway will send two probe queries. In this case, disable mDNS gateway proxy forwarding.
As a best practice to control proxy forwarding in different VLANs, configure multiple mDNS gateway policies and execute the mdns gateway probe interval command in the view of each mDNS gateway policy.
In QinQ scenarios or scenarios with a lot of services VLANs, enable periodic probing on the mDNS gateway and disable mDNS gateway proxy forwarding.
2.     Enable mDNS gateway policy view.
3.     Enable mDNS gateway proxy forwarding.
mdns gateway proxy-forward enable
Use this feature in scenarios where the mDNS gateway must receive and forward mDNS queries on the same port.
2.     Enable the mDNS gateway to forward mDNS queries on the receiving port in a VLAN.
mdns gateway permit source-port-forward enable
By default, the mDNS gateway does not forward mDNS queries on the receiving port in a VLAN.
On a QinQ network, packets sent from both the client and server to the mDNS gateway carry two layers of VLAN tags. The inner VLAN tag (also called CVLAN tag) identifies the VLAN to which the frame belongs when it is transmitted in the customer network. The outer VLAN tag (also called SVLAN tag) identifies the VLAN to which the QinQ frame belongs when it is transmitted in the service provider network. The mDNS gateway identifies the two layers of VLAN tags and implements service discovery as follows:
1.     You specify service VLANs and users VLANs for an mDNS gateway policy and specify inner VLANs and outer VLANs.
2.     Upon receiving an mDNS query, the mDNS gateway identifies whether the outer and inner VLAN tags of the packet matches the mDNS gateway policy.
¡     If a match is found, the mDNS gateway forwards the query to the corresponding service VLANs in the mDNS gateway policy.
¡     If no match is found, the mDNS gateway drops the query.
mdns gateway enable
3.     (Optional.) Specify the source address for mDNS packets.
4.     Enter mDNS gateway policy view.
5.     Specify service VLANs for the mDNS gateway policy.
service vlan vlan-id-list second-vlan vlan-id-list
By default, no service VLAN is specified for an mDNS gateway policy.
6.     Specify user VLANs for the mDNS gateway policy.
user vlan vlan-id-list second-vlan vlan-id-list
By default, no user VLAN is specified for an mDNS gateway policy.
Display and maintenance commands for mDNS relay
Display mDNS gateway configuration.
display mdns gateway
Display mDNS gateway policy information.
display mdns gateway policy [ policy-name ]
Display information about services learned by the mDNS gateway.
display mdns gateway service { all | predefined-service-type | user-defined user-defined-service-type | vlan vlan-id }
Display mDNS gateway packet statistics.
display mdns gateway statistics
Clear information about services learned by the mDNS gateway.
reset mdns gateway service { all | predefined-service-type | user-defined user-defined-service-type | vlan vlan-id }
Clear mDNS gateway packet statistics.
reset mdns gateway statistics
mDNS gateway configuration examples
Example: Configuring mDNS gateway
As shown in Figure 4, a campus network uses mDNS to provide services to both teachers and students. Configure mDNS gateway to allow students to access only the printer and allow teachers to access both the Apple TV and the printer.
Enable mDNS gateway periodic probing for the gateway to update mDNS services in time.
Figure 4 Network diagram
1.     Enable mDNS gateway.
[Device] mdns gateway enable
2.     Create an mDNS gateway policy named student.
[Device] mdns gateway policy student
3.     Specify VLAN 10 as a user VLAN and VLAN 30 as a service VLAN.
[Device-mdns-gateway-policy-student] user vlan 10
[Device-mdns-gateway-policy-student] service vlan 30
[Device-mdns-gateway-policy-student] quit
4.     Create an mDNS gateway policy named teacher.
[Device] mdns gateway policy teacher
5.     Specify VLAN 20 as a user VLAN and VLANs 30 and 40 as service VLANs.
[Device-mdns-gateway-policy-teacher] user vlan 20
[Device-mdns-gateway-policy-teacher] service vlan 30 40
[Device-mdns-gateway-policy-teacher] quit
6.     Permit service types airplay, raop, and printer in entry learning.
[Device] mdns gateway permit service-type airplay
[Device] mdns gateway permit service-type raop
[Device] mdns gateway permit service-type printer
7.     Specify the source address for mDNS packets in VLAN 10.
[Device] vlan 10
[Device-vlan10] mdns gateway source ip 192.168.1.1
[Device-vlan10] quit
8.     Specify the source address for mDNS packets in VLAN 20.
[Device] vlan 20
[Device-vlan20] mdns gateway source ip 192.168.2.1
[Device-vlan20] quit
9.     Enable mDNS gateway periodic probing in VLAN 30 and set the probing interval to 600 seconds.
[Device] vlan 30
[Device-vlan30] mdns gateway probe interval 600
[Device-vlan30] quit
10.     Enable mDNS gateway periodic probing in VLAN 40 and set the probing interval to 600 seconds.
[Device] vlan 40
[Device-vlan40] mdns gateway probe interval 600
[Device-vlan40] quit
# Display mDNS gateway configuration.
[Device] display mdns gateway
mDNS gateway status: Enabled
mDNS gateway source IP:
  VLAN 10: 192.168.1.1
  VLAN 20: 192.168.2.1
mDNS gateway probe is enabled in the following VLANs: 30, 40
mDNS gateway probe is enabled in the following VSIs:
mDNS gateway probe is enabled in the following Policys:
# Display information about services learned by the mDNS gateway.
[Device] display mdns gateway service all
Instance name          Service type VLAN/VSI name TTL        Pro IP
Apple TV               airplay      40            120        TCP 192.168.2.100
Apple TV               raop         40            120        TCP 192.168.2.100
Printer                printer      30            120        TCP 192.168.1.100
Total mDNS gateway services: 3
# Verify that students can access only the printer and teachers can access both the Apple TV and the printer.
Troubleshooting mDNS gateway
Failure to receive packets from an mDNS relay
Symptom
The mDNS gateway cannot receive mDNS packets from an mDNS relay.
Analysis
Possible reasons are:
·     The mDNS gateway feature is not enabled.
·     Trusted mDNS devices are configured, but the mDNS relay is not a trusted device.
Solution
To resolve this issue:
1.     Execute the display mdns gateway command to view current configuration. If mDNS gateway is not enabled, execute the mdns gateway enable command to enable this feature.
2.     Execute the display current-configuration command to view trusted mDNS devices. If the mDNS relay is not in the list, execute the mdns gateway trust device-ip command to specify the mDNS relay as a trusted device.
