HomeSupportConfigure & DeployConfiguration GuidesH3C S5100[S5500]-D-G&S5130S-G[-V2] Configuration Guides-R8336Pxx-6W10001-Fundamentals Configuration Guide
03-Login management configuration
03-Login management configuration 485.08 KB
Login overview·· 1
Using the console port for the first device access· 2
Configuring CLI login· 3
About CLI login· 3
User lines· 3
Login authentication modes· 3
User roles· 4
FIPS compliance· 4
Restrictions and guidelines: CLI login configuration· 4
Configuring console login· 5
About console, AUX, and USB login· 5
Restrictions and guidelines· 5
Console login configuration tasks at a glance· 5
Configuring console login authentication· 5
Configuring common console login settings· 7
Configuring Telnet login· 9
About Telnet login· 9
Restrictions and guidelines· 9
Configuring the device as a Telnet server 9
Using the device to log in to a Telnet server 14
Configuring SSH login· 14
About SSH login· 14
Configuring the device as an SSH server 15
Using the device to log in to an SSH server 16
Display and maintenance commands for CLI login· 17
Configuring Web login· 18
About Web login· 18
FIPS compliance· 18
Restrictions and guidelines: Web login configuration· 18
Web login configuration tasks at a glance· 18
Prerequisites for Web login· 18
Configuring HTTP login· 18
Configuring HTTPS login· 19
Configuring a Web login local user 21
Managing Web connections· 21
Enabling Web operation logging· 22
Display and maintenance commands for Web login· 22
Web login configuration examples· 22
Example: Configuring HTTP login· 22
Example: Configuring HTTPS login with a Windows Server 2003 CA server 23
Example: Configuring HTTPS login with CA certificate and local certificate obtained· 25
Accessing the device through SNMP·· 28
Configuring RESTful access· 29
About RESTful access· 29
FIPS compliance· 29
Configuring RESTful access over HTTP· 29
Configuring RESTful access over HTTPS· 30
Controlling user access to the device· 31
About login user access control 31
FIPS compliance· 31
Controlling Telnet and SSH logins· 31
Controlling Telnet logins· 31
Controlling SSH logins· 32
Example: Controlling Telnet login· 32
Controlling Web logins· 33
Configuring source IP-based Web login control 33
Example: Controlling Web login· 33
Controlling SNMP access· 34
About SNMP access control 34
Example: Controlling SNMP access· 34
Configuring command authorization· 35
About command authorization· 35
Restrictions and guidelines· 35
Procedure· 35
Example: Configuring command authorization· 36
Configuring command accounting· 38
About command accounting· 38
Restrictions and guidelines· 38
Procedure· 38
Example: Configuring command accounting· 39
Login overview
The device supports the following types of login methods:
·     CLI login—At the CLI, you can enter text commands to configure and manage the device.
To log in to the CLI, you can use one of the following methods:
¡     Connect to the console port.
¡     Use Telnet.
¡     Use SSH.
·     Web login—Through the Web interface, you can configure and manage the device visually.
·     SNMP access—You can run SNMP on an NMS to access the device MIB, and perform Get and Set operations to configure and manage the device.
·     RESTful access—You can use RESTful API operations to configure and manage the device.
The first time you access the device, you can only log in to the CLI through the console port  unless the device is automatically configured at startup. After login, you can change console login parameters or configure other access methods.
Telnet, HTTP-based Web login, and HTTP-based RESTful access are not supported in FIPS mode.
In login management related descriptions, it is assumed that the device does not enter the automatic configuration process at startup.
Console login is the fundamental login method.
To log in through the console port, prepare a terminal, for example, a PC. Make sure the terminal has a terminal emulation program, such as HyperTerminal or PuTTY. For information about how to use terminal emulation programs, see the programs' user guides.
1.     Connect the DB-9 female connector of the console cable shipped with the device to the serial port of the PC.
2.     Identify the console port of the device carefully and connect the RJ-45 connector of the console cable to the console port.
IMPORTANT
IMPORTANT:
·     If the serial port on the PC does not support hot swapping, power off the PC before you connect the console cable to or disconnect the cable from the serial port.
·     When you connect a PC to an operating device, first connect the PC end. To disconnect a PC from an operating device, first disconnect the device end.
Figure 1 Connecting a terminal to the console port
3.     On the PC, launch the terminal emulation program, and create a connection that uses the serial port connected to the device. Set the port properties so the port properties match the following console port default settings:
¡     Bits per second—9600 bps.
¡     Flow control—None.
¡     Parity—None.
¡     Stop bits—1.
¡     Data bits—8.
4.     Power on the device and press Enter as prompted.
The user view prompt appears. You can enter commands to configure or manage the device. To get help, enter a question mark (?).
About CLI login
The device uses user lines (also called user interfaces) to manage CLI sessions and monitor user behavior. For a user line, you can configure access control settings, including the login authentication method and user roles.
User lines
User line types
The device supports the following types of user lines, and different user lines require different login methods:
·     Console line—Login through the console port.
·     Virtual type terminal (VTY) line—Telnet or SSH login.
User line numbering
A user line has an absolute number and a relative number.
An absolute number uniquely identifies a user line among all user lines. The user lines are numbered starting from 0 and incrementing by 1, in the sequence of console and VTY lines. You can use the display line command without any parameters to view supported user lines and their absolute numbers.
A relative number uniquely identifies a user line among all user lines of the same type. The number format is user line type + number. All types of user lines are numbered starting from 0 and incrementing by 1. For example, the first VTY line is VTY 0.
User line assignment
The device assigns user lines to CLI login users depending on their login methods, as described in "User lines." When a user logs in, the device checks the idle user lines for the login method, and assigns the lowest numbered user line to the user. For example, if VTY 0 and VTY 3 are idle when a user Telnets to the device, the device assigns VTY 0 to the user.
Each user line can be assigned only to one user at a time. If no user line is available, a CLI login attempt will be rejected.
You can configure login authentication to prevent illegal access to the device CLI.
In non-FIPS mode, the device supports the following login authentication modes:
·     None—Disables authentication. This mode allows access without authentication and is insecure.
·     Password—Requires password authentication. A user must provide the correct password at login.
·     Scheme—Uses the AAA module to provide local or remote login authentication. A user must provide the correct username and password at login.
In FIPS mode, the device supports only the scheme authentication mode.
Different login authentication modes require different user line configurations, as shown in Table 1.
Table 1 Configuration required for different login authentication modes
Authentication mode
Configuration tasks
None
Set the authentication mode to none.
Password
1.     Set the authentication mode to password.
2.     Set a password.
Scheme
3.     Set the authentication mode to scheme.
4.     Configure login authentication methods in ISP domain view. For more information, see Security Configuration Guide.
User roles
A user is assigned user roles at login. The user roles control the commands available for the user. For more information about user roles, see "Configuring RBAC."
The device assigns user roles based on the login authentication mode and user type.
·     In none or password authentication mode, the device assigns the user roles specified for the user line.
·     In scheme authentication mode, the device uses the following rules to assign user roles:
¡     For an SSH login user who uses publickey or password-publickey authentication, the device assigns the user roles specified for the local device management user with the same name.
¡     For other users, the device assigns user roles according to the user role configuration of the AAA module. If the AAA server does not assign any user roles and the default user role feature is disabled, a remote AAA authentication user cannot log in.
FIPS compliance
Telnet login is not supported in FIPS mode.
For commands that are available in both user line view and user line class view, the following rules apply:
·     A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class.
·     A non-default setting in either view takes precedence over the default setting in the other view. A non-default setting in user line view takes precedence over the non-default setting in user line class view.
·     A setting in user line class view takes effect only on users who log in after the setting is made. It does not affect users who are already online when the setting is made.
You can connect a terminal to the console port of the device to log in and manage the device, as shown in Figure 2. For information about the login procedure, see "Using the console port for the first device access."
Figure 2 Logging in through the console port
By default, console login is enabled and does not require authentication. The default user role is network-admin for a console user. To improve device security, configure password or scheme authentication for console login immediately after you log in to the device for the first time.
A console login configuration change takes effect only on users who log in after the change is made. It does not affect users who are already online when the change is made.
In FIPS mode, the device supports only scheme authentication. You cannot disable authentication or configure password authentication.
The device displays the current memory usage when you log in to the device through the console port if the following conditions exist:
·     The memory-threshold command has been used to set free-memory thresholds.
·     The amount of free memory space has decreased to or below the minor, severe, or critical alarm threshold or the early-warning threshold.
To configure console login, perform the following tasks:
1.     Configuring console login authentication
¡     Disabling authentication for console login
¡     Configuring password authentication for console login
¡     Configuring scheme authentication for console login
2.     (Optional.) Configuring common console login settings
Table 2 Enter system view.
1.     Enter console line view or class view.
¡     Enter console  line view.
line console first-number [ last-number ]
¡     Enter console  line class view.
line class console
2.     Disable authentication.
authentication-mode none
By default, authentication is disabled for console login.
CAUTION
CAUTION:
When authentication is disabled, users can log in to the device through the line or line class without authentication. For security purpose, disable authentication with caution.
3.     Assign a user role.
user-role role-name
By default, a console user is assigned the network-admin user role.
2.     Enter console line view or class view.
¡     Enter console  class view.
line class console
3.     Enable password authentication.
authentication-mode password
4.     Set a password.
set authentication password { hash | simple } password
By default, no password is set.
5.     Assign a user role.
user-role role-name
Table 3 Enter system view.
line class console
2.     Enable scheme authentication.
In non-FIPS mode:
authentication-mode scheme
In FIPS mode:
By default, scheme authentication is enabled.
CAUTION
CAUTION:
When you enable scheme authentication, make sure an authentication user account is available. If no authentication user account is available, you cannot log in to the device through the line or line class at the next time.
3.     Configure user authentication parameters in ISP domain view.
To use local authentication, configure a local user and set the relevant attributes. To use remote authentication, configure a RADIUS, LDAP, or HWTACACS scheme. For more information, see AAA in Security Configuration Guide.
Some common console login settings take effect immediately and can interrupt the current session. Use a login method different from console login to log in to the device before you change console login settings.
After you change console login settings, adjust the settings on the configuration terminal accordingly for a successful login.
Table 4 Enter system view.
line class console
2.     Configure transmission parameters.
¡     Set the transmission rate.
speed speed-value
By default, the transmission rate is 9600 bps.
This command is not available in user line class view.
¡     Specify the parity mode.
By default, a user line does not use parity.
¡     Configure flow control.
By default, the device does not perform flow control.
¡     Specify the number of data bits for a character.
databits { 5 | 6 | 7 | 8 }
The default is 8.
Parameter
7
Uses standard ASCII characters.
8
Uses extended ASCII characters.
¡     Specify the number of stop bits for a character.
stopbits { 1 | 1.5 | 2 }
The default is 1.
Stop bits indicate the end of a character. The more the stop bits, the slower the transmission.
3.     Configure terminal attributes.
¡     Enable the terminal service.
shell
Be default, the terminal service is enabled on all user lines.
The undo shell command is not available in console line view.
¡     Specify the terminal display type.
By default, the terminal display type is ANSI.
The device supports ANSI and VT100 terminal display types. As a best practice, specify VT100 type on both the device and the configuration terminal. You can also specify the ANSI type for both sides, but a display problem might occur if a command line has more than 80 characters.
¡     Set the maximum number of lines of command output to send to the terminal at a time.
screen-length screen-length
By default, the device sends a maximum of 24 lines to the terminal at a time.
To disable pausing between screens of output, set the value to 0.
¡     Set the size for the command history buffer.
history-command max-size value
By default, the buffer size is 10. The buffer for a user line can save a maximum of 10 history commands.
¡     Set the CLI connection idle-timeout timer.
By default, the CLI connection idle-timeout timer is 10 minutes.
If no interaction occurs between the device and the user within the idle-timeout interval, the system automatically terminates the user connection on the user line.
If you set the timeout timer to 0, the connection will not be aged out.
4.     Specify the command to be automatically executed for login users on the lines.
auto-execute command command
By default, no command is specified for auto execution.
CAUTION
CAUTION:
Use this command with caution. If this command is used on a user line, users that log in to the device through this user line might fail to configure the system.
The device will automatically execute the specified command when a user logs in through the user line, and close the user connection after the command is executed.
This command is not available in console line view or console line class view.
5.     Configure shortcut keys.
¡     Specify the terminal session activation key.
activation-key character
By default, pressing Enter starts the terminal session.
¡     Specify the escape key.
escape-key { character | default }
By default, pressing Ctrl+C terminates a command.
¡     Set the user line locking key.
lock-key key-string
By default, no user line locking key is set.
About Telnet login
The device can act as a Telnet server to allow Telnet login, or as a Telnet client to Telnet to other devices.
Telnet login is not supported in FIPS mode. For more information about FIPS mode, see Security Configuration Guide.
A Telnet login configuration change takes effect only on users who log in after the change is made. It does not affect users who are already online when the change is made.
Telnet might be insecure because it transmits all data in plaintext form.
The device displays the current memory usage when you Telnet to the device if the following conditions exist:
Telnet server configuration tasks at a glance
To configure the device as a Telnet server, perform the following tasks:
1.     Enabling the Telnet server
2.     Configuring Telnet login authentication
¡     Disabling authentication for Telnet login
¡     Configuring password authentication for Telnet login
¡     Configuring scheme authentication for Telnet login
3.     (Optional.) Configuring common Telnet server settings
4.     (Optional.) Configuring the alarm threshold and alarm clearance threshold for Telnet login failures
5.     (Optional.) Configuring common VTY line settings
2.     Enable the Telnet server.
telnet server enable
By default, the Telnet server is disabled.
2.     Enter VTY line view or class view.
¡     Enter VTY line view.
line vty first-number [ last-number ]
¡     Enter VTY line class view.
line class vty
3.     Disable authentication.
By default, password authentication is enabled for Telnet login.
CAUTION
CAUTION:
In VTY line view, this command is associated with the protocol inbound command. If one command has a non-default setting in VTY line view, the other command uses its setting in VTY line view, regardless of its setting in VTY line class view.
4.     (Optional.) Assign a user role.
user-role role-name
By default, a VTY line user is assigned the network-operator user role.
line class vty
CAUTION
CAUTION:
When you enable password authentication, you must also configure an authentication password for the line or line class. If no authentication password is configured, you cannot log in to the device through the line or line class at the next time.
4.     Set a password.
5.     (Optional.) Assign a user role.
user-role role-name
line class vty
3.     Enable scheme authentication.
CAUTION
CAUTION:
4.     Configure user authentication parameters in ISP domain view.
2.     Set the DSCP value for outgoing Telnet packets.
IPv4:
telnet server dscp dscp-value
IPv6:
By default, the DSCP value is 48.
The DSCP value is carried in the ToS field of an IPv4 packet and in the Traffic class field of an IPv6 packet to indicate the packet transmission priority.
3.     Specify the Telnet service port number.
IPv4:
IPv6:
By default, the Telnet service port number is 23.
4.     Set the maximum number of concurrent Telnet users.
aaa session-limit telnet max-sessions
By default, the maximum number of concurrent Telnet users is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online Telnet users, no additional users can Telnet in until the number drops below the new limit.
For more information about this command, see Security Command Reference.
2.     Set the alarm threshold and alarm clearance threshold for Telnet login failures in a statistics period.
telnet server login-failed threshold-alarm upper-limit report-times lower-limit resume-times period period-time
By default, the statistics period is five minutes and the alarm threshold and alarm clearance threshold for Telnet login failures in the statistics period is 30 and 20, respectively.
After you execute this command, if the number of Telnet login failures reaches the alarm threshold in a statistics period, an alarm message is generated. If the number of Telnet login failures drops below the alarm clearance threshold in a statistics period, an alarm clearance message is generated. This helps you obtain real-time information about Telnet logins.
line class vty
3.     Configure VTY terminal attributes.
shell
By default, the terminal service is enabled on all user lines.
4.     Specify the supported protocols.
By default, Telnet and SSH are supported.
A protocol change takes effect only on users who log in after the setting is made. It does not affect users who are already online when the setting is made.
In VTY line view, this command is associated with the authentication-mode command. If one command has a non-default setting in VTY line view, the other command uses its setting in VTY line view, regardless of its setting in VTY line class view.
5.     Specify the command to be automatically executed for login users on the user lines.
IMPORTANT
IMPORTANT:
Before you execute this command and save the configuration, make sure you can access the CLI to modify the configuration through other VTY lines or console lines.
For a VTY line, you can specify a command that is to be automatically executed when a user logs in. After executing the specified command, the system automatically disconnects the Telnet session.
6.     Configure shortcut keys.
¡     Specify the shortcut key for terminating a task.
The default setting is Ctrl+C.
lock-key key-string
You can use the device as a Telnet client to log in to a Telnet server.
Figure 3 Telnetting from the device to a Telnet server
Assign an IP address to the device and obtain the IP address of the Telnet server. If the device resides on a different subnet than the Telnet server, make sure the device and the Telnet server can reach each other.
2.     (Optional.) Specify the source IPv4 address or source interface for outgoing Telnet packets.
By default, no source IPv4 address or source interface is specified. The device uses the primary IPv4 address of the output interface as the source address for outgoing Telnet packets.
3.     Return to user view.
4.     Use the device to log in to a Telnet server.
IPv4:
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip ip-address } | dscp dscp-value ] *
IPv6:
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ipv6 ipv6-address } | dscp dscp-value ] *
About SSH login
SSH offers a secure remote login method. By providing encryption and strong authentication, it protects devices against attacks such as IP spoofing and plaintext password interception. For more information, see Security Configuration Guide.
The device can act as an SSH server to allow Telnet login, or as an SSH client to log in to an SSH server.
This section provides the SSH server configuration procedure used when the SSH client authentication method is password. For more information about SSH and publickey authentication configuration, see Security Configuration Guide.
2.     Create local key pairs.
In non-FIPS mode:
public-key local create { dsa | ecdsa [ secp192r1 | secp256r1 | secp384r1 | secp521r1 ] | rsa } [ name key-name ]
In FIPS mode:
public-key local create { dsa | ecdsa [ secp256r1 | secp384r1 | secp521r1 ] | rsa } [ name key-name ]
3.     Enable the SSH server.
ssh server enable
By default, the SSH server is disabled.
4.     (Optional.) Create an SSH user and specify the authentication mode.
ssh user username service-type stelnet authentication-type password
5.     Enter VTY line view or class view.
line class vty
6.     Enable scheme authentication.
In non-FIPS mode:
By default, password authentication is enabled for VTY lines.
In FIPS mode:
By default, scheme authentication is enabled for VTY lines.
CAUTION
CAUTION:
7.     (Optional.) Specify the protocols for the user lines to support.
In non-FIPS mode:
In FIPS mode:
protocol inbound ssh
By default, SSH is supported.
8.     (Optional.) Set the maximum number of concurrent SSH users.
By default, the maximum number of concurrent SSH users is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online SSH users, no additional SSH users can log in until the number drops below the new limit.
9.     (Optional.) Configure common settings for VTY lines:
a.     Return to system view.
b.     Configure common settings for VTY lines.
See "Configuring common VTY line settings."
You can use the device as an SSH client to log in to an SSH server.
Figure 4 Logging in to an SSH server from the device
Assign an IP address to the device and obtain the IP address of the SSH server. If the device resides on a different subnet than the SSH server, make sure the device and the SSH server can reach each other.
To use the device to log in to an SSH server, execute one of the following commands in user view:
IPv4:
ssh2 server
IPv6:
ssh2 ipv6 server
To work with the SSH server, you might need to specify a set of parameters. For more information, see Security Configuration Guide.
Remarks
Display user line information.
display line [ num1 | { console | vty } num2 ] [ summary ]
N/A
Display the packet source setting for the Telnet client.
display telnet client
N/A
Display online CLI users.
display users [ all ]
N/A
Release a user line.
free line { num1 | { console | vty } num2 }
Multiple users can log in to the device to simultaneously configure the device. When necessary, you can execute this command to release some connections.
You cannot use this command to release the connection you are using.
This command is available in user view.
Lock the current user line and set the password for unlocking the line.
lock
By default, the system does not lock any user lines.
This command is not supported in FIPS mode.
Lock the current user line and enable unlocking authentication.
lock reauthentication
By default, the system does not lock any user lines or initiate reauthentication.
To unlock the locked user line, you must press Enter and provide the login password to pass reauthentication.
This command is available in any view.
Send messages to user lines.
send { all | num1 | { console | vty } num2 }
About Web login
The device provides a built-in Web server that supports HTTP 1.0, HTTP 1.1, and HTTPS. You can use a Web browser to log in to and configure the device.
HTTPS uses SSL to ensure the integrity and security of data exchanged between the client and the server, and is more secure than HTTP. You can define a certificate-based access control policy to allow only legal clients to access the Web interface.
FIPS compliance
HTTP is not supported in FIPS mode.
To improve device security, the system automatically enables the HTTPS service when you enable the HTTP service. When the HTTP service is enabled, you cannot disable the HTTPS service.
To configure Web login, perform the following tasks:
1.     Configuring Web login
¡     Configuring HTTP login
¡     Configuring HTTPS login
2.     Configuring a Web login local user
3.     Managing Web connections
4.     Enabling Web operation logging
Before logging in to the Web interface of the device, log in to the device by using any other method and assign an IP address to the device. Make sure the configuration terminal and the device can communicate over the IP network.
1.     (Optional.) Specify a fixed verification code for Web login.
web captcha verification-code
By default, no fixed verification code is specified. A Web user must enter the verification code displayed on the login page at login.
Execute this command in user view.
2.     Enter system view.
3.     Enable the HTTP service.
ip http enable
By default, the HTTP service is disabled.
4.     (Optional.) Specify the HTTP service port number.
ip http port port-number
The default HTTP service port number is 80.
5.     (Optional.) Specify the HTTP methods to be added to the reply to an OPTIONS request.
By default, no HTTP methods are specified.
The device supports the following HTTPS login modes:
·     Simplified mode—Using this mode is easy in configuration but has low security. The device uses a self-signed certificate (a certificate that is generated and signed by the device itself) and the default SSL settings. The device operates in simplified mode after you enable HTTPS service on the device. You do not need to configure an SSL server policy with the HTTPS service. However, a self-signed certificate is not signed by a CA, so it is not trusted by a browser. The browser will prompt a security risk message when you access the device through HTTPS. If you do not have high security requirements and can accept the security risk with a self-signed certificate, you can choose to ignore this message and continue browsing the webpage.
·     Secure mode—Using this mode is complicated in configuration but has high security. The device uses a certificate signed by a CA and a set of user-defined security protection settings to ensure security. For the device to operate in secure mode, you must perform the following tasks:
¡     Obtain a CA certificate and apply a local certificate from the CA.
¡     Enable HTTPS service on the device.
¡     Specify an SSL server policy for the service.
¡     Configure PKI domain-related parameters.
IMPORTANT
IMPORTANT:
To use secure mode for HTTPS login, first purchase a local certificate for SSL from an official third-party CA organization. H3C does not provide the device with a CA certificate issued by an authoritative organization.
For more information about SSL, self-signed certificates, CA-signed certificates, and PKI, see Security Configuration Guide.
·     If the HTTPS service and the SSL VPN service use the same port number, they must use the same SSL server policy. If they use different SSL server policies, only one of them can be enabled.
To modify the SSL server policy used by both the HTTPS service and the SSL VPN service, you must perform the following tasks:
a.     Disable the two services before you modify the SSL server policy.
b.     Enable the two services again after the modification.
If you fail to complete the required tasks, the new settings do not take effect.
·     To associate a different SSL server policy with the HTTPS service, you must perform the following tasks:
c.     Disable the HTTP service and HTTPS service before you associate the new SSL server policy.
d.     Enable the HTTP service and HTTPS service again after the association.
If you fail to complete the required tasks, the new SSL server policy does not take effect.
·     For the HTTP service to use its self-signed certificate after you associate an SSL server policy with the HTTPS service, you must follow these steps:
e.     Disable the HTTP service and HTTPS service.
f.     Execute the undo ip https ssl-server-policy command to remove the existing SSL server policy association.
g.     Enable the HTTP service and HTTPS service again.
·     Enabling the HTTPS service triggers the SSL handshake negotiation process.
¡     If the device has a local certificate, the SSL handshake negotiation succeeds and the HTTPS service starts up.
¡     If the device does not have a local certificate, the certificate application process starts. Because the certificate application process takes a long time, the SSL handshake negotiation might fail and the HTTPS service might not be started. To solve the problem, execute the ip https enable command again until the HTTPS service is enabled.
·     To use a certificate-based access control policy to control HTTPS access, you must perform the following tasks:
¡     Execute the client-verify enable command in the SSL server policy that is associated with the HTTPS service.
¡     Configure a minimum of one permit rule in the certificate-based access control policy.
If you fail to complete the required tasks, HTTPS clients cannot log in.
By default, no fixed verification code is configured. A Web user must enter the verification code displayed on the login page at login.
3.     (Optional.) Apply policies to the HTTPS service.
¡     Apply an SSL server policy.
By default, no SSL server policy is associated. The HTTP service uses a self-signed certificate.
¡     Apply a certificate-based access control policy to control HTTPS access.
By default, no certificate-based access control policy is applied.
For more information about certificate-based access control policies, see PKI in Security Configuration Guide.
4.     Enable the HTTPS service.
ip https enable
By default, HTTPS is disabled.
5.      (Optional.) Specify the HTTPS service port number.
ip https port port-number
The default HTTPS service port number is 443.
6.     (Optional.) Set the HTTPS login authentication mode.
By default, manual authentication mode is used for HTTPS login.
2.     Create a local user and enter local user view.
3.     (Optional.) Configure a password for the local user.
In non-FIPS mode:
By default, no password is configured for a local user. The local user can pass authentication after entering the correct username and passing attribute checks.
In FIPS mode:
password
By default, no password is configured for a local user. The local user cannot pass authentication.
4.     Configure user attributes.
¡     Assign a user role to the local user.
The default user role is network-operator for a Web user.
¡     Specify the service type for the local user.
service-type { http | https }
By default, no service type is specified for a local user.
Setting the Web connection idle-timeout timer
2.     Set the Web connection idle-timeout timer.
web idle-timeout minutes
By default, the Web connection idle-timeout timer is 10 minutes.
Specifying the maximum number of online HTTP or HTTPS users
2.     Specify the maximum number of online HTTP or HTTPS users.
aaa session-limit { http | https } max-sessions
By default, the device supports a maximum number of 32 online HTTP users and 32 online HTTPS users.
Changing this setting does not affect users who are currently online. If the new setting is less than the number of online HTTP or HTTPS users, no additional HTTP or HTTPS users can log in until the number drops below the new limit. For more information about this command, see Security Command Reference.
Logging off Web users
To log off Web users, execute the following command in user view:
2.     Enable Web operation logging.
webui log enable
By default, Web operation logging is disabled.
Display HTTP service configuration and status information.
display ip http
Display HTTPS service configuration and status information.
display ip https
Display Web interface navigation tree information.
display web menu [ chinese ]
Display online Web users.
display web users
As shown in Figure 5, the PC and the device can communicate over the IP network.
Configure the device to allow the PC to log in by using HTTP.
Figure 5 Network diagram
# Create a local user named admin. Set the password to hello12345, the service type to HTTP, and the user role to network-admin.
[Sysname] local-user admin
[Sysname-luser-manage-admin] service-type http
[Sysname-luser-manage-admin] authorization-attribute user-role network-admin
[Sysname-luser-manage-admin] password simple hello12345
[Sysname-luser-manage-admin] quit
# Enable HTTP.
[Sysname] ip http enable
1.     On the PC, run a Web browser and enter the IP address of the device in the address bar.
2.     On the login page, enter the username, password, and verification code. Select English and click Login.
After you pass authentication, the homepage appears and you can configure the device.
As shown in Figure 6, the host, device, and CA can communicate over the IP network.
Perform the following tasks to allow only authorized users to access the device's Web interface:
·     Configure the device as the HTTPS server and request a certificate for the device.
·     Configure the host as the HTTPS client and request a certificate for the host.
Figure 6 Network diagram
If the Windows Server 2003 CA server is used to issue certificates for the device and the host, a security risk prompt will pop up when a user accesses the device over HTTPS. If the user can accept the risk brought by this type of authentication, choose to ignore the prompt and continue to browse the webpage.
Assign IP addresses to relevant interfaces. Make sure the host, device, and CA can communicate over the IP network. (Details not shown.)
This example uses a Windows Server 2003 CA server. Configure the Windows Server 2003 CA server as required. For more information, see PKI configuration in Security Configuration Guide.
1.     Configure the device (HTTPS server):
# Create PKI entity en and set entity parameters.
[Device] pki entity en
[Device-pki-entity-en] common-name http-server1
[Device-pki-entity-en] fqdn ssl.example.com
[Device-pki-entity-en] quit
# Create PKI domain 1 and set domain parameters.
[Device] pki domain 1
[Device-pki-domain-1] ca identifier new-ca
[Device-pki-domain-1] certificate request url https://10.1.2.2/certsrv/mscep/mscep.dll
[Device-pki-domain-1] certificate request from ra
[Device-pki-domain-1] certificate request entity en
# Configure the PKI domain to use the 1024-bit long RSA key pair hostkey for both signing and encryption.
[Device-pki-domain-1] public-key rsa general name hostkey length 1024
[Device-pki-domain-1] quit
# Create RSA local key pairs.
[Device] public-key local create rsa
# Retrieve the CA certificate.
[Device] pki retrieve-certificate domain 1 ca
# Configure the device to request a local certificate through SCEP.
[Device] pki request-certificate domain 1
# Create SSL server policy myssl. Specify PKI domain 1 for the SSL server policy, and enable certificate-based SSL client authentication.
[Device] ssl server-policy myssl
[Device-ssl-server-policy-myssl] pki-domain 1
[Device-ssl-server-policy-myssl] client-verify enable
[Device-ssl-server-policy-myssl] quit
# Create certificate attribute group mygroup1. Configure a certificate attribute rule that matches statements with the new-ca string in the distinguished name of the subject name.
[Device] pki certificate attribute-group mygroup1
[Device-pki-cert-attribute-group-mygroup1] attribute 1 issuer-name dn ctn new-ca
[Device-pki-cert-attribute-group-mygroup1] quit
# Create certificate-based access control policy myacp. Configure a certificate access control rule that uses the matching criteria in certificate attribute group mygroup1.
[Device] pki certificate access-control-policy myacp
[Device-pki-cert-acp-myacp] rule 1 permit mygroup1
[Device-pki-cert-acp-myacp] quit
# Associate SSL server policy myssl with the HTTPS service.
[Device] ip https ssl-server-policy myssl
# Use certificate-based access control policy myacp to control HTTPS access.
[Device] ip https certificate access-control-policy myacp
# Enable the HTTPS service.
[Device] ip https enable
# Create local user usera. Set the password to hello12345, the service type to HTTPS, and the user role to network-admin.
[Device] local-user usera
[Device-luser-usera] password simple hello12345
[Device-luser-usera] service-type https
[Device-luser-usera] authorization-attribute user-role network-admin
2.     Configure the host (HTTPS client):
# On the host, run a Web browser and enter https://10.1.2.2/certsrv in the address bar.
# Request a certificate for the host as prompted.
1.     On the host, enter https://10.1.1.1 in the Web browser's address bar, and select the certificate issued by new-ca.
2.     When the Web login page appears, enter username usera and password hello12345 to log in to the Web interface.
For more information about PKI and SSL configuration commands and the public-key local create rsa command, see Security Command Reference.
As shown in Figure 7, users can access and manage the device via the Web interface of the device. To avoid illegal user access, users must log in to the Web interface of the device through HTTPS.
Figure 7 Network diagram
When the host browser authenticates a local certificate provided by the HTTPS website, it identifies whether the alternative subject name in the certificate matches the domain name of the current access website. Therefore, you must configure the alternative subject name as the domain name of the HTTPS website as prompted by the CA when applying for a local certificate. This ensures that when you use the domain name to access the HTTPS website, the local certificate of the device Web interface can be successfully verified by the browser.
To manage multiple devices at the same time, you can apply for a wildcard certificate when applying for a local certificate from the CA. For example, you can configure the alternative subject name as *.example.com, and map IP addresses for Web login to different domain names such as device1.example.com and device2.example.com. When you log in to any device through HTTPS, the local certificate of the Web interface can be successfully verified by the browser.
·     Make sure the following requirements are met:
¡     The host has obtained and installed a CA certificate that can verify the validity of the local certificate on the device.
¡     When the host accesses the device through the domain name in the alternative subject name field of the local certificate, the domain name can be resolved to an IP address that can log in to the device Web interface.
·     A CA certificate and a local certificate file (with a key pair) have been uploaded to the file system of the device over FTP or TFTP. For more information about FTP and TFTP, see "Configuring FTP" and "Configuring TFTP."
·     To import a local certificate containing an encrypted key pair, you must provide the challenge password. Make sure you have obtained the password from the CA administrator.
1.     Configure a PKI domain:
# Create PKI domain aaa and enter its view.
[Device] pki domain aaa
# Disable CRL checking. (You can configure CRL checking as required. This example assumes CRL checking is not required.)
[Device-pki-domain-aaa] undo crl check enable
# Configure a general-purpose RSA key pair named abc for certificate request in the view of
PKI domain aaa.
[Device-pki-domain-aaa] public-key rsa general name abc
[Device-pki-domain-aaa] quit
2.     Import the certificate files:
# Import a CA certificate in PEM format to PKI domain aaa. This example imports a CA certificate named ca.pem.
[Device] pki import domain aaa pem ca filename ca.pem
# Import local certificate file xyz.example.com.cert.pem in PEM format to the PKI domain and enter the password obtained from the CA administrator. The certificate file contains a key pair.
[Device] pki import domain aaa pem local filename xyz.example.com.cert.pem
Please input the password:******
3.     Configure an SSL server policy and HTTPS service:
# Create SSL server policy myssl and specify PKI domain aaa for the SSL server policy.
[Device-ssl-server-policy-myssl] pki-domain aaa
For more information about PKI and SSL configuration commands, see Security Command Reference.
1.     On the host, enter the domain name of the device Web interface in the Web browser's address bar.
You can run SNMP on an NMS to access the device MIB and perform Get and Set operations to configure and manage the device.
Figure 8 SNMP access diagram
For more information about SNMP, see Network Management and Monitoring Configuration Guide.
The device provides the Representational State Transfer application programming interface (RESTful API). Based on this API, you can use programming languages such as Python, Ruby, or Java to write programs to perform the following tasks:
·     Send RESTful requests to the device to pass authentication.
·     Use RESTful API operations to configure and manage the device. RESTful API operations include Get, Put, Post, and Delete.
The device supports using HTTP or HTTPS to transfer RESTful packets.
FIPS compliance
RESTful access over HTTP is not supported in FIPS mode.
2.     (Optional.) Specify the service port number for RESTful access over HTTP.
restful http port port-number
By default, the service port number for RESTful access over HTTP is 80.
3.     Enable RESTful access over HTTP.
restful http enable
By default, RESTful access over HTTP is disabled.
4.     Create a local user and enter local user view.
5.     Configure a password for the local user.
6.     (Optional.) Assign a user role to the local user.
The default user role is network-operator for a RESTful access user.
7.     Specify the HTTP service for the local user.
service-type http
8.     (Optional.) Use an ACL to control TCP connections from RESTful clients.
IPv4:
IPv6:
By default, all RESTful clients can establish TCP connections to the device.
2.     (Optional.) Apply an SSL server policy to the RESTful access over HTTPS service.
restful https ssl-server-policy policy-name
By default, no SSL server policy is applied to the RESTful access over HTTPS service.
The RESTful access over HTTPS service will use the SSL server policy to enhance service security. For more information about SSL server policies, see SSL configuration in Security Configuration Guide.
3.     (Optional.) Specify the service port number for RESTful access over HTTPS.
restful https port port-number
By default, the service port number for RESTful access over HTTPS is 443.
4.     Enable RESTful access over HTTPS.
restful https enable
By default, RESTful access over HTTPS is disabled.
5.     Create a local user and enter local user view.
6.     Configure a password for the local user.
In non-FIPS mode:
In FIPS mode:
password
7.     (Optional.) Assign a user role to the local user.
8.     Specify the HTTPS service for the local user.
service-type https
9.     (Optional.) Use an ACL to control TCP connections from RESTful clients.
IPv4:
IPv6:
https ipv6 acl { advanced-acl-number | basic-acl-number }
Use ACLs to prevent unauthorized access, and configure command authorization and accounting to monitor and control user behavior.
To control user access, specify an ACL that has rules so only users permitted by the ACL can access the device.
·     If no ACL is applied, all users can access the device.
·     If the ACL for Web user access control does not exist or does not have rules, all Web users can access the device.
·     If the ACL for Telnet, SSH, or SNMP access control does not exist or does not have rules, no Telnet, SSH, or SNMP users can access the device.
·     If a VPN instance is specified in an ACL rule, the rule applies only to the packets of the VPN instance. If no VPN instance is specified in an ACL rule, the rule applies only to the packets on the public network.
For more information about ACLs, see ACL and QoS Configuration Guide.
FIPS compliance
Telnet and HTTP are not supported in FIPS mode.
2.     Apply an ACL to control Telnet logins.
IPv4:
telnet server acl { advanced-acl-number | basic-acl-number | mac mac-acl-number }
IPv6:
telnet server ipv6 acl { ipv6 { advanced-acl-number | basic-acl-number } | mac mac-acl-number }
By default, no ACL is used to control Telnet logins.
3.     (Optional.) Enable logging for Telnet login attempts that are denied by the Telnet login control ACL.
telnet server acl-deny-log enable
By default, logging is disabled for Telnet login attempts that are denied by the Telnet login control ACL.
2.     Apply an ACL to control SSH logins.
IPv4:
IPv6:
By default, no ACL is used to control SSH logins.
3.     (Optional.) Enable logging for SSH login attempts that are denied by the SSH login control ACL.
By default, logging is disabled for SSH login attempts that are denied by the SSH login control ACL.
For more information about ssh commands, see Security Command Reference.
As shown in Figure 9, the device is a Telnet server.
Configure the device to permit only Telnet packets sourced from Host A and Host B.
Figure 9 Network diagram
# Configure an ACL to permit packets sourced from Host A and Host B.
[Sysname] acl basic 2000 match-order config
[Sysname-acl-ipv4-basic-2000] rule 1 permit source 10.110.100.52 0
[Sysname-acl-ipv4-basic-2000] rule 2 permit source 10.110.100.46 0
# Apply the ACL to filter Telnet logins.
[Sysname] telnet server acl 2000
2.     Apply a basic ACL to control Web logins.
¡     Control HTTP logins.
ip http acl { acl-number | name acl-name }
¡     Control HTTPS logins.
ip https acl { acl-number | name acl-name }
By default, no ACL is applied to control Web logins.
3.     (Optional.) Apply an ACL to control TCP connections.
¡     Control TCP connections from HTTP clients.
IPv4:
IPv6:
¡     Control TCP connections from HTTPS clients.
IPv4:
IPv6:
By default, all HTTP clients and HTTPS clients can establish TCP connections to the device.
As shown in Figure 10, the device is an HTTP server.
Configure the device to provide HTTP service only to Host B.
Figure 10 Network diagram
# Create an ACL and configure rule 1 to permit packets sourced from Host B.
[Sysname] acl basic 2030 match-order config
[Sysname-acl-ipv4-basic-2030] rule 1 permit source 10.110.100.52 0
# Apply the ACL to the HTTP service so only a Web user on Host B can access the device.
[Sysname] ip http acl 2030
For information about SNMP access control, see SNMP in Network Management and Monitoring Configuration Guide.
As shown in Figure 11, the device is running SNMP.
Configure the device to allow Host A and Host B to access the device through SNMP.
Figure 11 Network diagram
Network diagram
# Create an ACL to permit packets sourced from Host A and Host B.
# Associate the ACL with the SNMP community and the SNMP group.
[Sysname] snmp-agent community read aaa acl 2000
[Sysname] snmp-agent group v2c groupa acl 2000
[Sysname] snmp-agent usm-user v2c usera groupa acl 2000
By default, commands available for a user depend only on the user's user roles. When the authentication mode is scheme, you can configure the command authorization feature to further control access to commands.
After you enable command authorization, a user can use only commands that are permitted by both the AAA scheme and user roles.
When command authorization is enabled, commands available for a user vary by the user's login authentication mode.
·     If authentication is disabled or password authentication is enabled, command authorization does not take effect, and the user cannot use any commands.
·     If scheme authentication is enabled, commands available for a user vary by the user's access authentication method.
¡     If local authentication is used, the device uses the user roles assigned to the user to perform command authorization.
¡     If remote authentication is used, the remote authorization server performs command authorization to determine whether a command entered by a login user is permitted. If remote authorization fails, the device uses the user roles of a local user with the same name as the login user to determine whether the command can be used. If the authorization also fails, the login user cannot use the command.
Command authorization configuration changes in user line class view do not take effect on the current session. The changes take effect only on subsequent login sessions. Command authorization configuration changes in user line view take effect immediately on all users that access the user line.
If the remote server performs command authorization, you must configure a command authorization method in ISP domain view. For more information, see AAA configuration in Security Configuration Guide.
1.     ‍Enter system view.
2.     Enter user line view or user line class view.
¡     Enter user line view.
line { first-number1 [ last-number1 ] | { console | vty } first-number2 [ last-number2 ] }
¡     Enter user line class view.
line class { console | vty }
A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class. A non-default setting in either view takes precedence over the default setting in the other view. A non-default setting in user line view takes precedence over the non-default setting in user line class view.
In non-FIPS mode:
By default:
¡     Authentication is disabled for console login.
¡     Password authentication is enabled for VTY login.
In FIPS mode:
CAUTION
CAUTION:
4.     Enable command authorization.
By default, command authorization is disabled, and the commands available for a user depend only on the user role.
If the command authorization command is executed in user line class view, command authorization is enabled on all user lines in the class. You cannot execute the undo command authorization command in the view of a user line in the class.
As shown in Figure 12, Host A needs to log in to the device to manage the device.
Configure the device to perform the following operations:
·     Allow Host A to Telnet in after authentication.
·     Use the HWTACACS server to control the commands that the user can execute.
·     If the HWTACACS server is not available, use local authorization.
Network diagram
Figure 12 Network diagram
# Assign IP addresses to relevant interfaces. Make sure the device and the HWTACACS server can reach each other. Make sure the device and Host A can reach each other. (Details not shown.)
# Enable the Telnet server.
[Device] telnet server enable
# Enable scheme authentication for user lines VTY 0 through VTY 63.
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
# Enable command authorization for the user lines.
[Device-line-vty0-63] command authorization
[Device-line-vty0-63] quit
# Create HWTACACS scheme tac.
[Device] hwtacacs scheme tac
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for authentication and authorization.
[Device-hwtacacs-tac] primary authentication 192.168.2.20 49
[Device-hwtacacs-tac] primary authorization 192.168.2.20 49
# Set the shared keys to expert.
[Device-hwtacacs-tac] key authentication simple expert
[Device-hwtacacs-tac] key authorization simple expert
# Remove domain names from usernames sent to the HWTACACS server.
[Device-hwtacacs-tac] user-name-format without-domain
[Device-hwtacacs-tac] quit
# Configure the system-defined domain (system).
[Device] domain system
# Use HWTACACS scheme tac for login user authentication and command authorization. Use local authentication and local authorization as the backup method.
[Device-isp-system] authentication login hwtacacs-scheme tac local
[Device-isp-system] authorization command hwtacacs-scheme tac local
[Device-isp-system] quit
# Create local user monitor. Set the simple password to hello12345, the service type to Telnet, and the default user role to level-1.
[Device] local-user monitor
[Device-luser-manage-monitor] password simple hello12345
[Device-luser-manage-monitor] service-type telnet
[Device-luser-manage-monitor] authorization-attribute user-role level-1
Command accounting uses the HWTACACS server to record all executed commands to monitor user behavior on the device.
If command accounting is enabled but command authorization is not, every executed command is recorded. If both command accounting and command authorization are enabled, only authorized commands that are executed are recorded.
The command accounting method can be the same as or different from the command authorization method and user login authorization method.
For the command accounting feature to take effect, you must configure a command accounting method in ISP domain view. For more information, see Security Configuration Guide.
Table 5 Enter system view.
1.     Enter user line view or user line class view.
In non-FIPS mode:
By default:
In FIPS mode:
CAUTION
CAUTION:
3.     Enable command accounting.
command accounting
By default, command accounting is disabled. The accounting server does not record the commands executed by users.
If the command accounting command is executed in user line class view, command accounting is enabled on all user lines in the class. You cannot execute the undo command accounting command in the view of a user line in the class.
As shown in Figure 13, users need to log in to the device to manage the device.
Configure the device to send commands executed by users to the HWTACACS server to monitor and control user operations on the device.
Figure 13 Network diagram
# Enable command accounting for user line console 0.
[Device] line console 0
[Device-line-console0] command accounting
[Device-line-console0] quit
# Enable command accounting for user lines VTY 0 through VTY 63.
[Device-line-vty0-63] command accounting
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for accounting.
[Device-hwtacacs-tac] primary accounting 192.168.2.20 49
# Set the shared key to expert.
[Device-hwtacacs-tac] key accounting simple expert
# Configure the system-defined domain (system) to use the HWTACACS scheme for command accounting.
[Device-isp-system] accounting command hwtacacs-scheme tac
