05-Layer 3—IP Routing Configuration Guide
HomeSupportSwitchesS5130S-EI-G SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S5130S-HI-G & S5130S-EI-G Switch Series Configuration Guides-R8307Pxx-6W10005-Layer 3—IP Routing Configuration Guide
13-DCN configuration
13-DCN configuration 124.47 KB
Configuring DCN
About DCN
Data communication network (DCN) is built for the network management system (NMS) to implement operation, administration, and maintenance (OAM) on the network elements (NEs).
On large-scaled networks with DCN configured, the NMS remotely manages and controls all NEs through the gateway network element (GNE), which reduces operation and maintenance costs.
On the DCN network, all NEs must operate in Area 0 of OSPF process 65535.
Basic concepts
NE
A network device managed by the NMS on the DCN network.
GNE
The NE that is directly connected to the NMS. The NSM communicates with the GNE at the network layer or application layer and manages the NEs through the GNE.
NE table
Stores the NE ID-to-NE IP mappings for each NE in the DCN domain. After DCN is enabled, an NE encapsulates its NE ID and NE IP in a Type-10 Opaque LSA. It floods the LSA to synchronize the mappings with other NEs in the DCN domain.
The NE IP in the Type-10 Opaque LSA might be inconsistent with the NE's router ID when DCN is enabled on an OSPF network. Devices from other vendors will fail to identify the NE. To avoid this problem, change the router ID by modifying the NE IP and do not change the default IP address of the DCN's loopback interface.
GNE
The GNE allows the NMS to access NEs on the DCN network. The GNE provides the NE ID-to-NE IP mappings of all NEs for the Telnet users to access the target NE remotely.
NE search
The NE search feature allows the NMS to search for all NEs that are connected to the GNE. With this feature, the GNE can report information about all NEs in its NE table and the GNE itself to the NMS.
Automatic report
The automatic report feature enables the GNE to automatically report online or offline events of NEs to the NMS.
DCN tasks at a glance
To configure DCN, perform the following tasks:
1.     Enabling DCN
2.     (Optional.) Configuring the NE ID and NE IP
3.     (Optional.) Enabling the automatic report feature
4.     Configuring the LLDP features
a.     Advertising the LLDP management address
b.     Enabling the device to generate ARP entries for received management address LLDP TLVs
Enabling DCN
After DCN is enabled, the device assigns an NE IP to the loopback interface with the largest interface number and uses the interface for communication. The NE IP is specified as the management address and advertised in an LLDP frame. For more information about LLDP, see LLDP configuration in Layer 2—LAN Switching Configuration Guide.
2.     Enable DCN and enter DCN view.
dcn
By default, DCN is disabled.
Typically an NE automatically generates an NE IP according to its NE ID. The automatically generated NE IP changes when the NE ID changes. When you replan your network or an NE ID conflict occurs, you can manually configure the NE ID and NE IP. The manually configured NE IP does not change when the NE ID changes.
2.     Enter DCN view.
dcn
3.     Configure the NE ID.
ne-id id-number
By default, the NE ID is automatically generated by using the 24 low-order bits of the bridge MAC address.
4.     Configure the NE IP.
ne-ip ip-address { mask-length | mask }
By default, the NE IP is automatically generated by using 129 as the eight high-order bits and the NE ID as the rest 16 bits. The mask length is 32.
Perform this task only on GNE to enable it to automatically report online or offline events of NEs to the NMS.
2.     Enter DCN view.
dcn
3.     Enable the automatic report feature.
auto-report
By default, the automatic report feature is disabled.
An NE on the DCN network learns the MAC address of its neighbor through LLDP. Perform this task to enable an NE to advertise the IP address of the specified loopback interface (management address) for ARP entry learning. For more information about LLDP, see LLDP configuration in Layer 2—LAN Switching Configuration Guide.
This feature is supported only on Layer 3 physical interfaces.
2.     Enter interface view.
3.     Advertise the LLDP management address.
lldp tlv-enable basic-tlv management-address-tlv [ ip-address | interface loopback interface-number ]
By default, the LLDP management address is not advertised.
For more information about this command, see LLDP commands in Layer 2—LAN Switching Command Reference.
This feature enables the device to generate an ARP entry for a received LLDP frame that meets the following requirements:
·     The LLDP frame carries a management address TLV.
·     The management address TLV contains an IPv4 address.
The generated ARP entry contains the management address and the source MAC address of the frame. For more information about LLDP, see LLDP configuration in Layer 2—LAN Switching Configuration Guide.
3.     Enable the device to generate an ARP entry when receiving a management address LLDP TLV.
lldp management-address arp-learning [ vlan vlan-id ]
By default, the device does not generate an ARP entry when receiving a management address LLDP TLV.
The device uses the current Layer 3 Ethernet subinterface as the output interface for generated ARP entries.
For more information about this command, see LLDP commands in Layer 2—LAN Switching Configuration Guide.
Display and maintenance commands for DCN
Execute the display commands in any view.
Display the brief DCN information.
display dcn
Display information about all online NEs on the DCN network.
display dcn ne-info
DCN configuration examples
Example: Configuring DCN
As shown in Figure 1, the GNE, Device A, and Device B run DCN. The NMS uses SNMP to manage the GNE, and the GNE automatically sends notifications to the NMS to report online or offline events of NEs.
Figure 1 Network diagram
1.     Configure the GNE:
# Enable SNMP on the GNE. (Details not shown. For more information, see Network Management and Monitoring Configuration Guide.)
# Enable DCN, configure the NE ID as 100001 and NE IP as 11.1.1.1/32, and enable the automatic report feature.
<GNE> system-view
[GNE] dcn
[GNE-dcn] ne-id 100001
[GNE-dcn] ne-ip 11.1.1.1 32
[GNE-dcn] auto-report
[GNE-dcn] quit
[GNE-LoopBack1023] quit
# Enable LLDP globally.
[GNE] lldp global enable
# Enable the nearest bridge agents on GigabitEthernet 1/0/1 to advertise basic LLDP TLVs and management address TLVs. The IP address of interface Loopback 1023 is specified as the management address.
[GNE] interface gigabitethernet 1/0/1
[GNE-GigabitEthernet1/0/1] port link-mode route
[GNE-GigabitEthernet1/0/1] lldp tlv-enable basic-tlv management-address-tlv interface loopback 1023
# Configure the system to issue the generated ARP entry to the Layer 3 Ethernet subinterface associated with VLAN 4094 in Dot1q termination after GigabitEthernet 1/0/1 receives an LLDP frame.
[GNE-GigabitEthernet1/0/1] lldp management-address arp-learning vlan 4094
[GNE-GigabitEthernet1/0/1] quit
# Enable the nearest bridge agents on GigabitEthernet 1/0/2 to advertise basic LLDP TLVs and management address TLVs. The IP address of interface Loopback 1023 is specified as the management address.
[GNE] interface gigabitethernet 1/0/2
[GNE-GigabitEthernet1/0/2] port link-mode route
[GNE-GigabitEthernet1/0/2] lldp tlv-enable basic-tlv management-address-tlv interface loopback 1023
# Configure the system to issue the generated ARP entry to the Layer 3 Ethernet subinterface associated with VLAN 4094 in Dot1q termination after GigabitEthernet 1/0/2 receives an LLDP frame.
[GNE-GigabitEthernet1/0/2] lldp management-address arp-learning vlan 4094
[GNE-GigabitEthernet1/0/2] quit
# Create Ethernet subinterface GigabitEthernet 1/0/1.4094 and Ethernet subinterface GigabitEthernet 1/0/2.4094 that borrow the IP address of Loopback 1023.
[GNE] interface gigabitethernet 1/0/1.4094
[GNE-GigabitEthernet1/0/1.4094] ip address unnumbered interface loopback 1023
[GNE-GigabitEthernet1/0/1.4094] quit
[GNE] interface gigabitethernet 1/0/2.4094
[GNE-GigabitEthernet1/0/2.4094] ip address unnumbered interface loopback 1023
[GNE-GigabitEthernet1/0/2.4094] quit
# Enable OSPF process 65535 and create area 0.
[GNE] ospf 65535
[GNE-ospf-65535] area 0
[GNE-ospf-65535-area-0.0.0.0] network 0.0.0.0 255.255.255.255
[GNE-ospf-65535-area-0.0.0.0] quit
[GNE-ospf-65535] quit
# Set the OSPF network type for GigabitEthernet 1/0/1.4094 to P2P.
[GNE-GigabitEthernet1/0/1.4094] ospf network-type p2p
# Set the OSPF network type for GigabitEthernet 1/0/2.4094 to P2P.
[GNE-GigabitEthernet1/0/2.4094] ospf network-type p2p
2.     Configure Device A:
# Enable DCN, configure the NE ID as 200002 and NE IP as 22.2.2.2/32.
[DeviceA] dcn
[DeviceA-dcn] ne-id 200002
[DeviceA-dcn] ne-ip 22.2.2.2 32
[DeviceA-dcn] quit
[DeviceA] lldp global enable
[DeviceA-GigabitEthernet1/0/1] port link-mode route
[DeviceA-GigabitEthernet1/0/1] lldp tlv-enable basic-tlv management-address-tlv interface loopback 1023
[DeviceA-GigabitEthernet1/0/1] lldp management-address arp-learning vlan 4094
[DeviceA-GigabitEthernet1/0/2] port link-mode route
[DeviceA-GigabitEthernet1/0/2] lldp tlv-enable basic-tlv management-address-tlv interface loopback 1023
[DeviceA-GigabitEthernet1/0/2] lldp management-address arp-learning vlan 4094
[DeviceA] interface gigabitethernet 1/0/1.4094
[DeviceA-GigabitEthernet1/0/1.4094] ip address unnumbered interface loopback 1023
[DeviceA-GigabitEthernet1/0/1.4094] quit
[DeviceA] interface gigabitethernet 1/0/2.4094
[DeviceA-GigabitEthernet1/0/2.4094] ip address unnumbered interface loopback 1023
[DeviceA-GigabitEthernet1/0/2.4094] quit
[DeviceA] ospf 65535
[DeviceA-ospf-65535] area 0
[DeviceA-ospf-65535-area-0.0.0.0] network 0.0.0.0 255.255.255.255
[DeviceA-ospf-65535-area-0.0.0.0] quit
[DeviceA-ospf-65535] quit
[DeviceA-GigabitEthernet1/0/1.4094] ospf network-type p2p
[DeviceA-GigabitEthernet1/0/2.4094] ospf network-type p2p
3.     Configure Device B:
# Enable DCN, configure the NE ID as 300003 and NE IP as 33.3.3.3/32.
[DeviceB] dcn
[DeviceB-dcn] ne-id 300003
[DeviceB-dcn] ne-ip 33.3.3.3 32
[DeviceB-dcn] quit
[DeviceB] lldp global enable
# Enable the nearest bridge agents on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to advertise basic LLDP TLVs and management address TLVs. The IP address of interface Loopback 1023 is specified as the management address. Configure the system to issue the generated ARP entry after GigabitEthernet 1/0/1 or GigabitEthernet 1/0/2 receives an LLDP frame.
[DeviceB-GigabitEthernet1/0/1] port link-mode route
[DeviceB-GigabitEthernet1/0/1] lldp tlv-enable basic-tlv management-address-tlv interface loopback 1023
[DeviceB-GigabitEthernet1/0/1] lldp management-address arp-learning vlan 4094
[DeviceB-GigabitEthernet1/0/2] port link-mode route
[DeviceB-GigabitEthernet1/0/2] lldp tlv-enable basic-tlv management-address-tlv interface loopback 1023
[DeviceB-GigabitEthernet1/0/2] lldp management-address arp-learning vlan 4094
[DeviceB] interface gigabitethernet 1/0/1.4094
[DeviceB-GigabitEthernet1/0/1.4094] ip address unnumbered interface loopback 1023
[DeviceB-GigabitEthernet1/0/1.4094] quit
[DeviceB] interface gigabitethernet 1/0/2.4094
[DeviceB-GigabitEthernet1/0/2.4094] ip address unnumbered interface loopback 1023
[DeviceB-GigabitEthernet1/0/2.4094] quit
[DeviceB] ospf 65535
[DeviceB-ospf-65535] area 0
[DeviceB-ospf-65535-area-0.0.0.0] network 0.0.0.0 255.255.255.255
[DeviceB-ospf-65535-area-0.0.0.0] quit
[DeviceB-ospf-65535] quit
[DeviceB-GigabitEthernet1/0/1.4094] ospf network-type p2p
[DeviceB-GigabitEthernet1/0/2.4094] ospf network-type p2p
# Display brief DCN information on the GNE.
[GNE] display dcn
              DCN Brief Information
 NE ID        : 0x100001
 NE IP        : 11.1.1.1
 Mask         : 255.255.255.255
 DCN interface: LoopBack1023
 Auto report  : Enabled
# Display all DCN NE information on the GNE.
[GNE] display dcn ne-info
              DCN Network Elements Information
 NE ID          NE IP            Metric   Device Type
 0x100001       11.1.1.1         0        H3C S5130S-36S-PWR-HI-G
 0x200002       22.2.2.2         1        H3C S5130S-36S-PWR-HI-G
 0x300003       33.3.3.3         1        H3C S5130S-36S-PWR-HI-G
 Total number: 3
The output shows that GNE, Device A, and Device B are online. The GNE notifies the NMS of the online event. You can successfully ping the NE IP addresses of Device A and Device B from the GNE.
# Remove Device B from the DCN network and display all DCN NE information for the GNE.
 Total number: 2
The output shows that GNE and Device A are online. The GNE notifies the NMS of the offline event of Device B. You can still successfully ping the NE IP address of Device A from the GNE.
